Here it is
					System (32 bit) or otherwise called winserv.exe is pottentially eating my Laptop
Tried to reboot it twice. Didn’t try restore points (if that is what I was supposed to try?). Ill try it a bit later either way.Originally posted by RordonGamseyDidn’t work sadly
( here’s the fixlogComment
No more issues, all the permissions seem to be in order. There are no overheating issues, no lag, no internet issues, nothing. I think you did it!!!
Man, this took a REALLY long time, and I imagine that it had to take a lot of patience to deal with me and with this whole issue. And I just want to thank you for all your help and all the work you do here. I know you guys don’t get much appreciation around here, but you are saving lives !!!Comment
Solved!!
We will clean all the tools we used…
Download KpRM
Save to Desktop
Check Delete Tools’
Check Delete Restore points.
Create Restore point.
Click delete quarantines.
Then click run.Comment
