A corruption was found in a file system index structure. The file reference number is 0x30000000212ea.
  • Malnutrition
    PCHF Moderator
    • 7041
    #31
    Allow it to complete.
    • Marco_Oliveras
      • Feb 2023
      • 35
      #32
      I did but when it scans it doesn’t show any percentage it just boots up
      • Malnutrition
        PCHF Moderator
        • 7041
        #33
        First, create a restore point. To do this, open an elevated command prompt, copy each line into the code field below, and press Enter.
        [ICODE]wmic /Namespace:\\root\default Path SystemRestore Call Enable "%SystemDrive%" WMIC /Namespace:\\root\default Path SystemRestore Call CreateRestorePoint "pchelpforum", 100, 10[/ICODE]
        [COLOR=rgb(184, 49, 47)]Note. It is very important to run this tool only in safe mode!
        Download Windows all in one recovery tool.
        Install the program.
        Load windows in safe mode.
        Right-click all in one recovery tool and run as administrator.
        Run it with all the default items checked.
        Let it finish, and once it’s done, boot up normally and check for the problem.[/COLOR]
        • Marco_Oliveras
          • Feb 2023
          • 35
          #34
          issue is resolved thank you for your help!
          • Malnutrition
            PCHF Moderator
            • 7041
            #35
            Update your older programs with Patch My PC home Edition.
            We will clean all the tools we used…
            Download KpRM
            Save to Desktop
            Check Delete Tools’
            Check Delete Restore points.
            Create Restore point.
            Click delete quarantines.
            Then click run.
            I suggest:
            Ublock Origin
            O&O Shutup Ten
            O&O App Buster
            • Marco_Oliveras
              • Feb 2023
              • 35
              #36
              Thank you! could I also redownload winrar or should I use to 7zip?
              • Malnutrition
                PCHF Moderator
                • 7041
                #37
                7 Zip works fine, that is up to you.
