Connection not private - ongoing
  • maramessi
    • Jan 2023
    • 110
    #16
    Na its still the same. Some sites are fine, infact most probably are but the ones I use - twitch/sofscore/youtube/google account info - all these are problems plus I’ve seen it on many other random pages I’ve visited.
    The game is also not loading via the web like it always has done.
    Or when I do somehow manage to get on a site, it never loads properly. For example if load up sofascore it will just tell me that no fixtures are being played on this day - and there tons being played. Twitch at the moment is just a white screen.
    Have you seen anything on the scans?
    This has just came up when I was on my desktop about to open STEAM
    [ATTACH type=“full”]11331[/ATTACH]
    • Malnutrition
      PCHF Moderator
      • 7045
      #17
      Ok. Remove the following programs.
      You can reinstall later this is just a test.
      AVG AntiTrack (HKLM-x32...\AVGAntiTrack) (Version: 3.3.654.558 - AVG)
      AVG Internet Security (HKLM...\AVG Antivirus) (Version: 22.12.3264 - AVG Technologies)
      AVG Secure VPN (HKLM...\AVG Secure VPN) (Version: 5.22.7134.5502 - AVG)
      NordUpdater (HKLM...{6E35DB82-3D19-4DD6-B8CB-F082815FDE18}_is1) (Version: 1.3.0.73 - Nord Security)
      NordVPN (HKLM...{19465C24-3D5D-4327-B99F-3CC0A1D38151}_is1) (Version: 7.1.1.0 - Nord Security)
      NordVPN network TAP (HKLM-x32...{97DEC5D6-2BE9-45BB-BFC5-274B851B486B}) (Version: 1.0.1 - NordVPN)
      uTorrent Web (HKU\S-1-5-21-3473206753-2221114680-3962231543-1001...\utweb) (Version: 1.2.8 - Rainberry, Inc.)
      Reboot the computer, then run the AVG removal tool.
      Reboot again and test. AVG is known for causing connection issues, so just removing it and testing for a minute would be the next logical step. Like I say you can reinstall it as this is just a diagnostic approach.
      • maramessi
        • Jan 2023
        • 110
        #18
        Okay well … that worked, everything seems to be fine now.
        Definitely going to be the AVG causing it and not Nord (not used in a long time) or Torrent (also not used it in a long long time) ?
        • Malnutrition
          PCHF Moderator
          • 7045
          #19
          AVG does cause issues, a whole lot of them. Up to you to reinstall it.
          I suggest the following to increase privacy and security on the machine.
          Ublock Origin
          O&O Shutup Ten
          O&O App Buster
          Update your older programs with Patch My PC home Edition.
          We will clean all the tools we used…
          Download KpRM
          Save to Desktop
          Check Delete Tools’
          Check Delete Restore points.
          Create Restore point.
          Click delete quarantines.
          Then click run.
