Help with Error Message
  • Malnutrition
    PCHF Moderator
    • 7045
    #16
    All right, I have just seen this. I will take a look in the morning, and get a reply ready for you. While you wait, please run this tool.
    Once you have started the program, you will need to click the scanner button.
    Once the scan is completed, the you will want to click the Repair button.
    At the end of the process you may be asked to reboot your machine.
    After you reboot a report will open on your desktop.
    Attach the report here in your next reply.
    • Malnutrition
      PCHF Moderator
      • 7045
      #17
      Disable windows defender.
      FRST Fix.
      Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
      • Malnutrition
        PCHF Moderator
        • 7045
        #18
        @9MikeMike any update?
        • 9MikeMike
          • Aug 2022
          • 12
          #19
          Hey. Sorry about the slowness. Actually just came by to say almost there.
          I had a few things going so had a bunch of tabs open and such. I got all the programs downloaded, ready to
          go. Most likely will do it tomorrow morning and post the reports.
          • 9MikeMike
            • Aug 2022
            • 12
            #20
            Smoke…so much smoke. Firefighters running away
            (ps what I was picturing as I ran the stranger-danger “fix”)
            Anyways, all done except Defender - no exe to run it. The .vbs only opened an updater for Windows.
            ZHP kicked out 2 reports - you ask, you shall receive.
            And the fixlog.txt
            And a big thank you!
            • Malnutrition
              PCHF Moderator
              • 7045
              #21
              No problem, I’ll have a look at these later on. How is the machine running now?
              Lol
              Download Autoruns and Autorunsc Unzip it to your desktop and then right click
              [IMG alt=“Capture.PNG”]https://pchelpforum.net/attachments/capture-png.9995/
              Run as Admin.
              After the scan is finished then click on File----Then click----Save
              The default name will be autoruns.arn make sure to leave it this way.
              Attach the file in your next reply.
              If the file is too large, then use catbox.moe or Ufile.io and send the link in your next reply.[/IMG]
              • 9MikeMike
                • Aug 2022
                • 12
                #22
                Feels like the old girl boots faster.
                A few “admin” niggles here and there - no problem to fix.
                Still clearing some clutter that won’t necessarily show up under scans.
                Adware was asking about a Winsock reset? No idea…
                Defender now off. Panda can get quite unruly - grabbing exe’s and what not. Already doing more than AVG who just pushed pop ups. So far so good.
                As for Autoruns - that link flashes and disappears - Panda again, me thinks haha
                Either way, I found a link, got it, ran it and got the .arn. However, when I open it, it’s blank, ie just the tabs, no info.
                Downloaded Autoruns has a number of .exe’s - autorunsc 64a, 64, plain (just exe) and autoruns 64a, 64, plain. I ran two different ones and both were blank.
                The attach tool also does not “see” the .arn file. “I plead stupid, your honour”.
                • Malnutrition
                  PCHF Moderator
                  • 7045
                  #23
                  Upload the .arn to one of the sites i mentioned, and then send the link. You won’t be able to open the .arn unless you drag and drop it onto autruns.
                  If you can not use catbox or other site to upload the file, the try and zip it prior to uploading.
                  Let me know if you need further instructions
                  • Malnutrition
                    PCHF Moderator
                    • 7045
                    #24
                    WhatSoftware, a daily updated Tech Blog with basic and advanced, unbiased software reviews, computer tips news and more!
                    [ATTACH type=“full” alt=“Capture.PNG”]10532[/ATTACH]
                    Decrap my computer it’s an outdated software, but works fine with windows 7, you might be surprised at what you find with this tool. Do not run in fully auto mode.
                    Not needed.
                    • 9MikeMike
                      • Aug 2022
                      • 12
                      #25
                      Got it.
                      Then I almost forgot about this bad boy. Usually pops up after restart, even after the latest restarts.
                      Then it popped up out of nowhere.
                      The MS Visual C++ is the latest version. I had a problem earlier today where the game would not fire because it was looking for a .dll
                      file, even though the damn file was right there - in both sys32 and syswow64. One internet solution was to update the C++ so I got the latest
                      but it still would not work. And the game was made for W7 this time…
                      Then this guy showed up. So, I’m wondering if this is related to some of the troubles I’ve had. it does not seem to affect anything obvious…
                      • Malnutrition
                        PCHF Moderator
                        • 7045
                        #26
                        I’d suggest that you use Ublock Origin.
                        Download and run Kill em all, this will kill all non essential programs and services. Then run the C++ repair…
                        https://www.microsoft.com/en-us/Down....aspx?id=30135
                        If this does not help with the pop up issue then we will take a different route after you have done everything suggested in this post.
                        Right click autoruns and run as admin, uncheck everything highlighted below, then reboot the computer.
                        [ATTACH type=“full”]10535[/ATTACH]
                        [ATTACH type=“full”]10536[/ATTACH]
                        • 9MikeMike
                          • Aug 2022
                          • 12
                          #27
                          Hey there. Did the above.
                          That pop up did come back after I thought we had killed it. The context was a bit strange though.
                          Since updating Radeon software my xbox controller has been seriously acting up. So I uninstalled
                          it. Yeah, bad idea. PC looked like a minecraft picture because it uninstalled the $$%%% graphics card.
                          So after finally getting it all back I switched as much off in the software as I could. Then when bringing
                          up controller, it crashed the runtime, visual, c++ thingamajig. Also getting a strange little pop that I’ve never seen.
                          “There was a problem sending the command to the program.” (??)
                          Not sure if all this relevant but I thought I’d put it out there.
                          • Malnutrition
                            PCHF Moderator
                            • 7045
                            #28
                            Create a new Admin user and see if the issue persist.
                            How to Create Admin Account in Windows 7 & 10 with Full Privileges, Code Exploit Cyber Security: How to Create Admin Account in Windows 7 & 10 with Full Privileges, Code Exploit Cyber Security
                            • Malnutrition
                              PCHF Moderator
                              • 7045
                              #29
                              @9MikeMike Any update? If not this thread will be locked in 48 hours.
