Possible remote control threat
  • Avy
    • Jul 2022
    • 7
    I have been receiving this strange error the past couple of days, that a file: “GL503GE_pre.sign” was unable to be copied. GL503GE is my laptop model, but I am not copying this file, I wasn’t even able to find out any info about it. I don’t know what is causing it, I scanned my PC using MalwareBytes and Windows Defender (full scans for both) but nothing was detected and I have no idea why this happens. I will attach a screenshot of the error. Any help will be greatly appreciated.
    I will tag our expert for help..
    @Malnutrition
    • Malnutrition
      PCHF Moderator
      • 7041
      Once downloaded right click the FRST desktop icon and select “Run as administrator” from the menu"
      [IMG alt=“icon2.jpg”]https://pchelpforum.net/attachments/icon2-jpg.794/
      FRST will open with two dialogue boxes, accept the disclaimer.
      Code:
          [IMG alt="frst disclaimer.jpg"]https://pchelpforum.net/attachments/frst-disclaimer-jpg.795/
      [ol]
      [li]Accept the default whitelist options,[/li][li]If the additions.txt options box is not checked please select it.[/li][li]Then select Scan[/li][/ol]
      [IMG alt=“frst.jpg”]https://pchelpforum.net/attachments/frst-jpg.796/
      Code:
          [IMG alt="2016-08-12_152002.jpg"]https://pchelpforum.net/attachments/2016-08-12_152002-jpg.797/
      Please Attach the contents of these logs in your next post for review by our Security Team[/IMG]
      • Malnutrition
        PCHF Moderator
        • 7041
        Also, download the everything search engine, and type [COLOR=rgb(184, 49, 47)].sign[COLOR=rgb(184, 49, 47)] in the everything search window.
        Then click Edit select all.
        Right click highlighted text.
        Copy full name to clipboard.
        Post those results in your next reply along with the FRST and Addition.txt logs.[/COLOR][/COLOR]
        • Avy
          • Jul 2022
          • 7
          Code:
          [ol]
          Code:
          Hello, thank you for you in-depth reply.
          I have followed your instructions and have attached FRST.txt but I am unable to attach Addition.txt
          Everything search engine results:
          C:\Program Files\WindowsApps\Microsoft.YourPhone_1.22052.136. 0_x64__8wekyb3d8bbwe\YourPhoneServer\Microsoft.Asp NetCore.SignalR.Client.Core.dll
          C:\Program Files\WindowsApps\Microsoft.YourPhone_1.22052.136. 0_x64__8wekyb3d8bbwe\YourPhoneServer\Microsoft.Asp NetCore.SignalR.Client.dll
          C:\Program Files\WindowsApps\Microsoft.YourPhone_1.22052.136. 0_x64__8wekyb3d8bbwe\YourPhoneServer\Microsoft.Asp NetCore.SignalR.Common.dll
          C:\Program Files\WindowsApps\Microsoft.YourPhone_1.22052.136. 0_x64__8wekyb3d8bbwe\YourPhoneServer\Microsoft.Asp NetCore.SignalR.Protocols.Json.dll
          C:\Program Files\WindowsApps\Microsoft.YourPhone_1.22052.136. 0_x64__8wekyb3d8bbwe\YourPhoneServer\Microsoft.Asp NetCore.SignalR.Protocols.MessagePack.dll
          C:\Gradle\docs\dsl\org.gradle.plugins.signing.Sign .html
          C:\Users\night.gradle\wrapper\dists\gradle-5.4.1-all\3221gyojl5jsh0helicew7rwx\gradle-5.4.1\docs\dsl\org.gradle.plugins.signing.Sign.htm l
          C:\Gradle\docs\dsl\org.gradle.plugins.signing.Sign ingExtension.html
          C:\Users\night.gradle\wrapper\dists\gradle-5.4.1-all\3221gyojl5jsh0helicew7rwx\gradle-5.4.1\docs\dsl\org.gradle.plugins.signing.SigningE xtension.html
          C:\Gradle\src\signing\META-INF\gradle-plugins\org.gradle.signing.properties
          C:\Users\night.gradle\wrapper\dists\gradle-5.4.1-all\3221gyojl5jsh0helicew7rwx\gradle-5.4.1\src\signing\META-INF\gradle-plugins\org.gradle.signing.properties
          D:\Steam\steam.signatures
          C:\Windows\System32\Windows.Internal.Signals.dll
          C:\Windows\WinSxS\amd64_microsoft-windows-signalmanager_31bf3856ad364e35_10.0.22000.1_none_3 559580e92087d6d\Windows.Internal.Signals.dll
          Thank you[/IMG][/QUOTE]
          • Avy
            • Jul 2022
            • 7
            Thank you
            I was unable to attach Addition.txt, I will upload it as zip
            • Malnutrition
              PCHF Moderator
              • 7041
              I’ll have a look at these when I get home from work. Expect a reply around 7 pm eastern time.
              If you can rerun the everything search with this
              *.sign
              • Malnutrition
                PCHF Moderator
                • 7041
                FRST Fix.
                Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  Post new FRST and addition.txt logs and let me know how the machine is performing.
                  • Avy
                    • Jul 2022
                    • 7
                    #10
                    FRST Fix.
                    Hello, thanks for the reply.
                    I have attached fixlog and the new frst and addition flies.
                    In the everything search however, *.sign yielded no results.
                    The PC is performing well. My main concern was the strange error that shows up once a day. I will post it here if it happens again.
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #11
                      Adware Cleaner
                      [li]Download AdwCleaner and save it to your Desktop[/li][li]Right-click on AdwCleaner.exeand select[/li]
                      [IMG alt=“Spcusrh.png”]https://i.imgur.com/Spcusrh.png
                      Run as Administrator
                      [li]Accept the EULA (I accept), then click on Scan Now[/li][li]Let the scan complete[/li][li]Once the scan completes, make sure that every item listed in the different tabs is checked and click on the Clean & Repair button[/li][li]Subsequently you may be asked to Run Basic Repair. This is optional. I would suggest holding off on this for now.[/li][li]Once the cleaning process is complete, AdwCleaner will ask you to restart your computer[/li][li]Close all other open windows and allow it to restart[/li][li]After the restart, Notepad will open with the AdwCleaner cleaning log[/li][li]Please Attach the contents of that log into your next reply to me[/li][/ul]
                      Make sure and disable your antivirus/defender prior to the scan.
                      [li]Download ESET Online Scanner from here and save it to your Desktop.[/li][li]Right click the esetonlinescanner.exe file you downloaded and select Run as administrator.[/li][li]Click Get started.[/li][li]In the Terms of use screen, click Accept if you agree to the Terms of use.[/li][li]Click Get started in the welcome screen.[/li][li]Select your preference for the Customer Experience Improvement Program and the Detection feedback system.Click Continue.[/li][li]Click Computer scan, in the Welcome back screen.[/li][li]Choose Full scan on the next screen.[/li][li]Select Enable ESET to detect and quarantine potentially unwanted applications.Then click Start scan[/li][li]When the scan is finished click Save scan log and save it to your Desktop as ESETScan.txt. Click Continue.[/li][li]ESET Online Scanner will now ask if you wish to turn on the Periodic Scan feature.Click Continue[/li][li]You will now be offered a trial version of ESET Internet Security.Click continue[/li][li]On the next screen, you can leave feedback about the program if you wish.[/li][li]Select Delete application’s data on closing, if you are short of disk space or do not wish to retain the program for future use.[/li][li]If you left feedback, click Submit and continue. If not, Close without feedback.[/li][li]Copy and paste the contents of the ESETScan.txt file in your next reply.[/li][/ul][/IMG]
                      • Avy
                        • Jul 2022
                        • 7
                        #12
                        Adware Cleaner
                        Greetings, I have attached the log files.
                        • Malnutrition
                          PCHF Moderator
                          • 7041
                          #13
                          How is the machine now? Same error occur?
                          • Avy
                            • Jul 2022
                            • 7
                            #14
                            Hello, I will keep a close eye on my PC today. The error used to occur once per day. I will tell you if it does or does not today.
                            Thank you!
                            • Malnutrition
                              PCHF Moderator
                              • 7041
                              #15
                              Alright.
                              Security Check Scan.
                              [li]Download Security Check to your desktop.[/li][li]Right click it run as administrator.[/li][li]When the program completes, the tool will automatically open a log file.[/li][li]Please Copy and paste that log here in your next post[/li][/ul]
