Connection issue regarding certificate
  • Baroona
    • Apr 2019
    • 27
    Hi guys/girls, my connection seems to have trouble with certificate. I am unable to access any website for unknown reasons. I have attached picture to further elaborate my issues.
    https://scontent.fsyd4-1.fna.fbcdn.n...f6&oe=5D781C70
    I have tried different browser from my default ( currently chrome ) it works just fine before, however after doing stuff here and there ( such as ignoring error on chrome ) now my chrome can browse however it is not secure while all other browser not working now. This picture below shows my current chrome situation.
    https://scontent.fsyd4-1.fna.fbcdn.n...c1&oe=5D409DEC
    I hope it is not too confusing and thanks in advance for the helps.
    Regards,
    Baroona
    @Malnutrition jmarket
    • jmarket
      PCHF Owner
      • 7695
      • CachyOS
      • Intel Arc A770 (16 GB)
      Hi @Baroona and welcome to PCHF
      Once downloaded right click the FRST desktop icon and select “Run as administrator” from the menu.
      Frst will open with two dialogue boxes, accept the disclaimer.
      Accept the default whitelist options,
      If the additions.txt options box is not checked please select it.
      Then select “Scan”
      Please Copy and Paste the contents of these logs in your next post for review by our Security Team
      • Baroona
        • Apr 2019
        • 27
        jmarket i somehow fix it by downloading adlock, do you think it will impact negatively instead of doing your suggested way?
        Thanks in advance
        • Baroona
          • Apr 2019
          • 27
          one thing to note though, as far as i remember, the https should be green colour isnt it? mine is just gray
          [ATTACH type=“full” alt=“4610”]4610[/ATTACH]
          this gray colour is only on chrome however, opera comes out green just fine. is there any logic behind it maybe?
          • jmarket
            PCHF Owner
            • 7695
            • CachyOS
            Yes. You may have malware on the machine, which could be causing it.
            • Baroona
              • Apr 2019
              • 27
              well i decided to do your advises,
              content on addition
              [HEADING=1]Additional scan result of Farbar Recovery Scan Tool (x64) Version: 17.04.2019
              Ran by Lenovo (19-04-2019 02:14:38)
              Running from C:\Users\Lenovo\Downloads
              Windows 10 Pro Version 1803 17134.706 (X64) (2018-05-26 07:41:06)
              Boot Mode: Normal[/HEADING]
              Administrator (S-1-5-21-1925601759-1010797402-2804155008-500 - Administrator - Disabled)
              DefaultAccount (S-1-5-21-1925601759-1010797402-2804155008-503 - Limited - Disabled)
              Guest (S-1-5-21-1925601759-1010797402-2804155008-501 - Limited - Disabled)
              HomeGroupUser$ (S-1-5-21-1925601759-1010797402-2804155008-1002 - Limited - Enabled)
              Lenovo (S-1-5-21-1925601759-1010797402-2804155008-1000 - Administrator - Enabled) => C:\Users\Lenovo
              WDAGUtilityAccount (S-1-5-21-1925601759-1010797402-2804155008-504 - Limited - Disabled)
              AV: Malwarebytes (Disabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
              AV: 360 Total Security (Enabled - Up to date) {0371CA44-3F80-A1D3-BECE-910620B58D50}
              AS: Malwarebytes (Disabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
              AS: 360 Total Security (Enabled - Up to date) {B8102BA0-19BA-AE5D-847E-AA745B32C7ED}
              . . (HKLM...{3D383E25-72E7-4F09-AA1C-9ADE6A2EF42F}) (Version: 7.1 - Intel) Hidden
              . . . (HKLM-x32...{0C9A6167-6560-4085-9C35-EDB1AE105328}) (Version: 3.2.0.9 - Intel) Hidden
              360 Total Security (HKLM-x32...\360TotalSecurity) (Version: 10.2.0.1180 - 360 Security Center)
              3DP Chip Lite v17.11.1 (HKLM-x32...\3DP Chip Lite) (Version: v17.11.1 - 3DP)
              ACDSee Pro 3 (HKLM-x32...{1B280FAF-AE10-4E31-A41A-DB3917D651DC}) (Version: 3.0.355 - ACD Systems International Inc.)
              Active Directory Authentication Library for SQL Server (HKLM...{32C0D7B2-1046-43AC-98AD-B748E1910916}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
              Active Directory Authentication Library for SQL Server (x86) (HKLM-x32...{F40FA676-46B1-4609-85EF-D2F1F79E0C0E}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
              AdLock (HKLM...{26D2159D-4BE2-43A4-9E68-F0594DF0295C}) (Version: 1.0.2.2 - Hankuper) Hidden
              Adobe Flash Player 29 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 29.0.0.113 - Adobe Systems Incorporated)
              Adobe Flash Player 29 PPAPI (HKLM-x32...\Adobe Flash Player PPAPI) (Version: 29.0.0.113 - Adobe Systems Incorporated)
              AMD Settings (HKLM...\WUCCCApp) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.)
              AMD Software (HKLM...\AMD Catalyst Install Manager) (Version: 18.2.1 - Advanced Micro Devices, Inc.)
              Anathena (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\242cfcc8731b6ee3) (Version: 3.3.8.0 - Anathena)
              Any Video Converter 6.2.5 (HKLM-x32...\Any Video Converter) (Version: 6.2.5 - Anvsoft)
              Apple Application Support (32-bit) (HKLM-x32...{D4C80B0C-CF67-43A7-90C3-466853543B54}) (Version: 6.3 - Apple Inc.)
              Apple Application Support (64-bit) (HKLM...{B2A2E8AF-BC48-4191-B2C4-3846A19835CA}) (Version: 6.3 - Apple Inc.)
              Apple Application Support (HKLM-x32...{46F044A5-CE8B-4196-984E-5BD6525E361D}) (Version: 2.3.6 - Apple Inc.)
              Apple Mobile Device Support (HKLM...{AA7D90D2-2387-4FA5-A3AF-96811BE49BFD}) (Version: 11.0.5.14 - Apple Inc.)
              Apple Software Update (HKLM-x32...{19589375-5C58-4AFA-842F-8B34744CCEAD}) (Version: 2.5.0.1 - Apple Inc.)
              Apple Software Update (HKLM-x32...{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}) (Version: 2.1.3.127 - Apple Inc.)
              ArcSoft WebCam Companion 3 (HKLM-x32...{34985F59-8F6F-46F4-9AD5-53E2714294D2}) (Version: 3.0.189 - ArcSoft)
              AVG 2015 (HKLM...{6E4BAAF0-7F23-41E5-B16B-4727B6FC0C6F}) (Version: 15.0.6081 - AVG Technologies) Hidden
              AVG Web TuneUp (HKLM-x32...\AVG Web TuneUp) (Version: 4.3.6.255 - AVG Technologies)
              Battle.net (HKLM-x32...\Battle.net) (Version: - Blizzard Entertainment)
              BattlePing (HKLM-x32...{DB480AC3-1578-B8DC-3F8F-786A2A4E3BC7}) (Version: 1.3.7.1 - BattlePing)
              Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
              Catalyst Control Center Next Localization BR (HKLM...{15EEB07A-3FB9-FA4C-8EFF-697728CB1E5C}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization CHS (HKLM...{A63E3031-0522-18C6-F18F-7EE80973315F}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization CHT (HKLM...{A2966D0F-43BB-116D-C9C7-49612FBFD0AE}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization CS (HKLM...{4C608ED2-535B-2119-3661-9E6F7DDB600F}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization DA (HKLM...{9005C809-497A-FD45-CB96-76A3338E35B9}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization DE (HKLM...{D84300A6-72F1-5771-B3B1-8FC71184AB38}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization EL (HKLM...{56D13277-FA9F-2842-682D-DD7298973585}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization ES (HKLM...{8D0C7788-D519-7B65-36F6-D0D21296F173}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization FI (HKLM...{930FD2C7-D026-197D-94E4-CB5917CE7420}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization FR (HKLM...{086D11E3-9CA4-DBEF-2B48-5A2EFFD53145}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization HU (HKLM...{D0C1EAB6-92F1-EE91-04C2-5947EE150593}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization IT (HKLM...{57EAA61A-CD02-DF34-0839-2549F57A334C}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization JA (HKLM...{AA477FD2-347B-1732-5D8C-AF35AF1B9703}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization KO (HKLM...{BBFC5953-2CB9-5932-1D47-52E4AA99737B}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization NL (HKLM...{01E7D692-D785-743F-5A55-F00162D26A1C}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization NO (HKLM...{5D8BA452-1264-7D13-E4EC-8236EC5B83FE}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization PL (HKLM...{F49BA906-83DA-3F5A-5B24-03C8DE2A3936}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization RU (HKLM...{5A466CAA-F071-D9EF-A799-EF63552DBE70}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization SV (HKLM...{D7DC4DDB-3E0D-6F79-4258-4A461654B689}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization TH (HKLM...{ACDFF800-6015-BEEC-8A27-7B1A80915273}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              Catalyst Control Center Next Localization TR (HKLM...{A28B1FC5-3947-9D39-7FE5-A3CB18E16358}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
              CCleaner (HKLM...\CCleaner) (Version: 5.41 - Piriform)
              Cheat Engine 6.6 (HKLM-x32...\Cheat Engine 6.6_is1) (Version: - Cheat Engine)
              Cisco EAP-FAST Module (HKLM-x32...{64BF0187-F3D2-498B-99EA-163AF9AE6EC9}) (Version: 2.2.14 - Cisco Systems, Inc.)
              Cisco LEAP Module (HKLM-x32...{AF312B06-5C5C-468E-89B3-BE6DE2645722}) (Version: 1.0.19 - Cisco Systems, Inc.)
              Cisco PEAP Module (HKLM-x32...{0A4EF0E6-A912-4CDE-A7F3-6E56E7C13A2F}) (Version: 1.1.6 - Cisco Systems, Inc.)
              Conexant HD Audio (HKLM...\CNXT_AUDIO_HDA) (Version: 8.66.16.50 - Conexant)
              CyberLink PowerDVD 11 (HKLM-x32...\InstallShield_{F232C87C-6E92-4775-8210-DFE90B7777D9}) (Version: 11.0.1620.51 - CyberLink Corp.)
              D3DX10 (HKLM-x32...{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
              DivX H.264 decoder 8.2.0.26 (HKLM-x32...\divxh264_is1) (Version: 8.2.0.26 - )
              DivX Setup (HKLM-x32...\DivX Setup) (Version: 2.7.0.93 - DivX, LLC)
              Dolby Digital Plus Advanced Audio (HKLM...{B0BFC63F-EA07-419E-960B-3FB2ED5DD0B2}) (Version: 7.6.5.1 - Dolby Laboratories Inc)
              Dolby Digital Plus Home Theater (HKLM...{7E3D8FA1-6092-469A-955B-68FC4A2C67CA}) (Version: 7.6.5.1 - Dolby Laboratories Inc)
              Driver Easy 5.6.1 (HKLM...\DriverEasy_is1) (Version: 5.6.1 - Easeware)
              Dropbox (HKLM-x32...\Dropbox) (Version: 45.4.92 - Dropbox, Inc.)
              Dropbox Update Helper (HKLM-x32...{099218A5-A723-43DC-8DB5-6173656A1E94}) (Version: 1.3.59.1 - Dropbox, Inc.) Hidden
              Energy Management (HKLM-x32...{D0956C11-0F60-43FE-99AD-524E833471BB}) (Version: 7.0.3.9 - Lenovo) Hidden
              Energy Management (HKLM-x32...\InstallShield_{D0956C11-0F60-43FE-99AD-524E833471BB}) (Version: 7.0.3.9 - Lenovo)
              eNexia version 749.0 (HKLM-x32...{8C3EC8A8-70A1-4298-BD7D-3CD7DAE20D64}_is1) (Version: 749.0 - eNexiaTK)
              Free Download Manager (HKLM...{43781dff-e0df-49ce-a6d2-47da96a485e7}}is1) (Version: - FreeDownloadManager.ORG)
              Google Chrome (HKLM-x32...\Google Chrome) (Version: 73.0.3683.103 - Google Inc.)
              Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.34.7 - Google LLC) Hidden
              GRF Editor version 1.7.9 (HKLM-x32...\GRF Editor_is1) (Version: 1.7.9 - )
              Hearthstone (HKLM-x32...\Hearthstone) (Version: - Blizzard Entertainment)
              Hearthstone Deck Tracker (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\HearthstoneDeckTracker) (Version: 1.7.6 - HearthSim)
              Hotspot Shield 7.6.4 (HKLM-x32...{AF599C42-A2E5-4251-B7EE-4925C187EDD1}) (Version: 7.6.4.10926 - AnchorFree Inc.) Hidden
              Hotspot Shield 7.6.4 (HKLM-x32...{f0473374-de13-4075-b4ef-5847e91e1d6a}) (Version: 7.6.4.10926 - AnchorFree Inc.)
              Hotspot Shield 7.6.4 (HKLM-x32...\HotspotShield) (Version: 7.6.4 - AnchorFree Inc.) Hidden
              HxD Hex Editor version 1.7.7.0 (HKLM-x32...\HxD Hex Editor_is1) (Version: 1.7.7.0 - Maël Hörz)
              IIS 10.0 Express (HKLM...{13FD7E30-D2F1-498D-ABC2-A4242DB6610E}) (Version: 10.0.1736 - Microsoft Corporation)
              Intel(R) Chipset Device Software (HKLM-x32...{17408817-d415-4768-a160-ae6d46d6bdb0}) (Version: 10.1.1.44 - Intel(R) Corporation) Hidden
              Intel(R) Computing Improvement Program (HKLM...{699E6891-25C3-443A-9B8E-80C74F0172C8}) (Version: 2.1.03413 - Intel Corporation)
              Intel(R) Management Engine Components (HKLM-x32...{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.15.1730 - Intel Corporation)
              Intel(R) Processor Graphics (HKLM-x32...{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4531 - Intel Corporation)
              Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 12.9.0.1001 - Intel Corporation)
              Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32...{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 2.5.3.34 - Intel Corporation)
              Intel® Driver & Support Assistant (HKLM-x32...{4d839fe1-a8d3-4edc-b0ca-844394309856}) (Version: 3.2.0.9 - Intel)
              IObit Uninstaller 8 (HKLM-x32...\IObitUninstall) (Version: 8.4.0.8 - IObit)
              iTunes (HKLM...{1D7D1271-5258-4F5A-B8C1-7176BF398782}) (Version: 12.7.3.46 - Apple Inc.)
              Java 8 Update 161 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F32180161F0}) (Version: 8.0.1610.12 - Oracle Corporation)
              K-Lite Mega Codec Pack 14.0.5 (HKLM-x32...\KLiteCodecPack_is1) (Version: 14.0.5 - KLCP)
              Lenovo EasyCamera (HKLM-x32...{E399A5B3-ED53-4DEA-AF04-8011E1EB1EAC}) (Version: 6.3.9600.11105 - Realtek Semiconductor Corp.)
              Logitech Gaming Software 8.57 (HKLM...\Logitech Gaming Software) (Version: 8.57.145 - Logitech Inc.)
              Magic Bullet Suite 64-bit (HKLM...{93488C33-D8D6-472A-83BB-F71603355CF0}) (Version: 11.1.0 - Red Giant Software) Hidden
              Magic Bullet Suite 64-bit (HKLM-x32...\InstallShield
              Malwarebytes version 3.4.4.2398 (HKLM...{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}is1) (Version: 3.4.4.2398 - Malwarebytes)
              McAfee True Key (HKLM...\TrueKey) (Version: 5.2.167.1 - McAfee, LLC)
              mHotspot version 7.8.8.0 (HKLM-x32...{beeb7906-9268-4520-8850-8d8af9b1c7c8}is1) (Version: 7.8.8.0 - 1BN Software & IT Solutions Pvt. Ltd.)
              Microsoft .NET Framework 4 Multi-Targeting Pack (HKLM-x32...{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}) (Version: 4.0.30319 - Microsoft Corporation)
              Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (ENU) (HKLM-x32...{D3517C62-68A5-37CF-92F7-93C029A89681}) (Version: 4.5.50932 - Microsoft Corporation)
              Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (HKLM-x32...{6A0C6700-EA93-372C-8871-DCCF13D160A4}) (Version: 4.5.50932 - Microsoft Corporation)
              Microsoft .NET Framework 4.6.1 SDK (HKLM-x32...{2F0ECC80-B9E4-4485-8083-CD32F22ABD92}) (Version: 4.6.01055 - Microsoft Corporation)
              Microsoft .NET Framework 4.6.1 SDK (日本語) (HKLM-x32...{9A330858-0CD6-4FB3-8C57-0F1BB58012B0}) (Version: 4.6.01055 - Microsoft Corporation)
              Microsoft .NET Framework 4.6.1 Targeting Pack (ENU) (HKLM-x32...{8EEB28EE-5141-411C-9CF0-9952264FE4AF}) (Version: 4.6.01055 - Microsoft Corporation)
              Microsoft .NET Framework 4.6.1 Targeting Pack (HKLM-x32...{8BC3EEC9-090F-4C53-A8DA-1BEC913040F9}) (Version: 4.6.01055 - Microsoft Corporation)
              Microsoft .NET Framework 4.6.1 Targeting Pack (日本語) (HKLM-x32...{903C5477-BA28-4CFC-8BE4-62E3C328D4DD}) (Version: 4.6.01055 - Microsoft Corporation)
              Microsoft Chart Controls for Microsoft .NET Framework 3.5 (HKLM-x32...{41785C66-90F2-40CE-8CB5-1C94BFC97280}) (Version: 3.5.0.0 - Microsoft Corporation)
              Microsoft Help Viewer 1.1 (HKLM...\Microsoft Help Viewer 1.1) (Version: 1.1.40219 - Microsoft Corporation)
              Microsoft Help Viewer 2.2 (HKLM-x32...\Microsoft Help Viewer 2.2) (Version: 2.2.25420 - Microsoft Corporation)
              Microsoft Office 2007 Service Pack 3 (SP3) (HKLM-x32...{90120000-0030-0000-0000-0000000FF1CE}ENTERPRISE{6E107EB7-8B55-48BF-ACCB-199F86A2CD93}) (Version: - Microsoft)
              Microsoft Office Enterprise 2007 (HKLM-x32...\ENTERPRISE) (Version: 12.0.6612.1000 - Microsoft Corporation)
              Microsoft Office File Validation Add-In (HKLM-x32...{90140000-2005-0000-0000-0000000FF1CE}) (Version: 14.0.5130.5003 - Microsoft Corporation)
              Microsoft OneDrive (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\OneDriveSetup.exe) (Version: 18.025.0204.0009 - Microsoft Corporation)
              Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50918.0 - Microsoft Corporation)
              Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32...{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
              Microsoft SQL Server 2008 (64-bit) (HKLM...\Microsoft SQL Server 10 Release) (Version: - Microsoft Corporation)
              Microsoft SQL Server 2008 Browser (HKLM-x32...{C688457E-03FD-4941-923B-A27F4D42A7DD}) (Version: 10.1.2531.0 - Microsoft Corporation)
              Microsoft SQL Server 2008 Native Client (HKLM...{BBDE8A3D-64A2-43A6-95F3-C27B87DF7AC1}) (Version: 10.1.2531.0 - Microsoft Corporation)
              Microsoft SQL Server 2008 Setup Support Files (HKLM...{B40EE88B-400A-4266-A17B-E3DE64E94431}) (Version: 10.1.2731.0 - Microsoft Corporation)
              Microsoft SQL Server 2012 Command Line Utilities (HKLM...{9D573E71-1077-4C7E-B4DB-4E22A5D2B48B}) (Version: 11.0.2100.60 - Microsoft Corporation)
              Microsoft SQL Server 2012 Native Client (HKLM...{49D665A2-4C2A-476E-9AB8-FCC425F526FC}) (Version: 11.0.2100.60 - Microsoft Corporation)
              Microsoft SQL Server 2014 Management Objects (HKLM-x32...{2774595F-BC2A-4B12-A25B-0C37A37049B0}) (Version: 12.0.2000.8 - Microsoft Corporation)
              Microsoft SQL Server 2014 Management Objects (x64) (HKLM...{1F9EB3B6-AED7-4AA7-B8F1-8E314B74B2A5}) (Version: 12.0.2000.8 - Microsoft Corporation)
              Microsoft SQL Server 2014 Transact-SQL ScriptDom (HKLM...{020CDFE0-C127-4047-B571-37C82396B662}) (Version: 12.0.2000.8 - Microsoft Corporation)
              Microsoft SQL Server 2014 T-SQL Language Service (HKLM-x32...{47D08E7A-92A1-489B-B0BF-415516497BCE}) (Version: 12.0.2000.8 - Microsoft Corporation)
              Microsoft SQL Server 2016 LocalDB (HKLM...{E359515A-92E6-4FA3-A2C9-E1BA02D8DE6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
              Microsoft SQL Server 2016 Management Objects (HKLM-x32...{0F1C8E2F-199A-4946-B3BF-0906DACFD032}) (Version: 13.0.1601.5 - Microsoft Corporation)
              Microsoft SQL Server 2016 Management Objects (x64) (HKLM...{20EA85AA-2A1D-4F11-B09F-4BA2BF3C8989}) (Version: 13.0.1601.5 - Microsoft Corporation)
              Microsoft SQL Server 2016 T-SQL Language Service (HKLM-x32...{8BFDE775-C5B8-46DB-84EF-43FFC8A2E8AD}) (Version: 13.0.14500.10 - Microsoft Corporation)
              Microsoft SQL Server 2016 T-SQL ScriptDom (HKLM...{D091DE8C-EA0F-49AF-8DE3-BD6C79737C6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
              Microsoft SQL Server Compact 3.5 SP2 ENU (HKLM-x32...{3A9FC03D-C685-4831-94CF-4EDFD3749497}) (Version: 3.5.8080.0 - Microsoft Corporation)
              Microsoft SQL Server Compact 3.5 SP2 x64 ENU (HKLM...{D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}) (Version: 3.5.8080.0 - Microsoft Corporation)
              Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM...{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
              Microsoft SQL Server Data Tools - enu (14.0.60519.0) (HKLM-x32...{4E27B0EF-7BAB-432A-AF3D-3FC8F3F7353F}) (Version: 14.0.60519.0 - Microsoft Corporation)
              Microsoft SQL Server VSS Writer (HKLM...{0826F9E4-787E-481D-83E0-BC6A57B056D5}) (Version: 10.1.2531.0 - Microsoft Corporation)
              Microsoft Sync Framework 2.1 Core Components (x86) ENU (HKLM-x32...{7AC8EF88-D996-4D47-B40C-4DD93E307481}) (Version: 2.1.1648.0 - Microsoft Corporation)
              Microsoft Sync Framework 2.1 Database Providers (x86) ENU (HKLM-x32...{296E293F-C481-4DDE-9ED2-3F79FCF38731}) (Version: 3.1.1648.0 - Microsoft Corporation)
              Microsoft System CLR Types for SQL Server 2014 (HKLM...{FC3BB979-AA54-4B60-BBA3-2C4DA6E08D80}) (Version: 12.0.2402.29 - Microsoft Corporation)
              Microsoft System CLR Types for SQL Server 2014 (HKLM-x32...{091CE6AA-2753-4F6E-AD1C-0E875744EB54}) (Version: 12.0.2402.29 - Microsoft Corporation)
              Microsoft System CLR Types for SQL Server 2016 (HKLM...{96EB5054-C775-4BEF-B7B9-AA96A295EDCD}) (Version: 13.0.1601.5 - Microsoft Corporation)
              Microsoft System CLR Types for SQL Server 2016 (HKLM-x32...{84C23ECA-FE4D-494F-9247-3EBAD57E7F0C}) (Version: 13.0.1601.5 - Microsoft Corporation)
              Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 (HKLM-x32...{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}) (Version: 9.0.21022 - Microsoft Corporation)
              Microsoft Visual C++ 2010 x64 Runtime - 10.0.40219 (HKLM...{1C7C8AAF-A16D-32E8-89E5-F6D165DE0BCE}) (Version: 10.0.40219 - Microsoft Corporation)
              Microsoft Visual C++ 2010 x86 Runtime - 10.0.40219 (HKLM-x32...{5D9ED403-94DE-3BA0-B1D6-71F4BDA412E6}) (Version: 10.0.40219 - Microsoft Corporation)
              Microsoft Visual C++ 2017 Redistributable (x64) - 14.10.25008 (HKLM-x32...{f1e7e313-06df-4c56-96a9-99fdfd149c51}) (Version: 14.10.25008.0 - Microsoft Corporation)
              Microsoft Visual C++ 2017 Redistributable (x86) - 14.10.25008 (HKLM-x32...{c239cea1-d49e-4e16-8e87-8c055765f7ec}) (Version: 14.10.25008.0 - Microsoft Corporation)
              Microsoft Visual Studio 2010 Express Prerequisites x64 - ENU (HKLM...{BCA26999-EC22-3007-BB79-638913079C9A}) (Version: 10.0.40219 - Microsoft Corporation)
              Microsoft Visual Studio 2010 Service Pack 1 (HKLM-x32...\Microsoft Visual Studio 2010 Service Pack 1) (Version: 10.0.40219 - Microsoft Corporation)
              Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
              Microsoft Web Deploy 3.6 (HKLM...{94E1227C-08A9-4962-B388-1F05D89AEA75}) (Version: 3.1238.1962 - Microsoft Corporation)
              Modem AC2726 UI (HKLM...\ZTEWireless-101_is1) (Version: - )
              MornaTK Installer (HKLM-x32...{BCD1C4AD-EB1A-40DF-A838-2AF8C45B5942}) (Version: 1.0 - MornaTales)
              Movavi Video Converter 18 Premium (HKLM-x32...\Movavi Video Converter 18 Premium) (Version: 18.3.0 - Movavi)
              Movie Maker (HKLM-x32...{38F03569-A636-4CF3-BDDE-032C8C251304}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
              Movie Maker (HKLM-x32...{DD67BE4B-7E62-4215-AFA3-F123A800A389}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
              Mozilla Firefox 63.0.3 (x64 en-US) (HKLM...\Mozilla Firefox 63.0.3 (x64 en-US)) (Version: 63.0.3 - Mozilla)
              Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 59.0.1 - Mozilla)
              Mumble 1.2.19 (HKLM-x32...{F62A874F-2354-49B1-87BE-CAAD7C8FA084}) (Version: 1.2.19 - Thorvald Natvig)
              MYOB AccountRight Plus v19.12.0 ED (HKLM-x32...{27D4F4A7-5A34-4657-9E78-D6B1E87C8A90}) (Version: 19.12.0 - MYOB Technology Pty Ltd) Hidden
              MYOB AccountRight Plus v19.12.0 ED (HKLM-x32...\InstallShield
              MYOB ODBC Direct v10 AUS (HKLM-x32...{55D5A77E-FAAA-4358-B3E5-6565E024F78B}) (Version: 10.1.0 - MYOB Technology Pty Ltd) Hidden
              MYOB ODBC Direct v10 AUS (HKLM-x32...\InstallShield
              MySQL Installer - Community (HKLM-x32...{4553E209-560C-451E-9DE9-E6B812D32B8C}) (Version: 1.4.8.0 - Oracle Corporation)
              MySQL Server 5.0 (HKLM-x32...{2FEB25F8-C3CB-49A2-AE79-DE17FFAFB5D9}) (Version: 5.0.45 - MySQL AB)
              MySQL Tools for 5.0 (HKLM-x32...{EC561602-C0B9-4FAA-A175-1B3273639AC3}) (Version: 5.0.12 - MySQL AB)
              Notepad++ (32-bit x86) (HKLM-x32...\Notepad++) (Version: 7.5.6 - Notepad++ Team)
              NovaRO (HKLM-x32...\NovaRO_is1) (Version: 6.0.0 - NovaRO)
              Nox APP Player (HKLM-x32...\Nox) (Version: 6.0.1.1 - Duodian Technology Co. Ltd.)
              OBS Studio (HKLM-x32...\OBS Studio) (Version: 21.1.2 - OBS Project)
              OEM Application Profile (HKLM-x32...{70D5F822-F4C4-33D9-7EEC-2A4AF4EA7BDC}) (Version: 1.00.0000 - Advanced Micro Devices, Inc.) Hidden
              Opera Stable 58.0.3135.127 (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Opera 58.0.3135.127) (Version: 58.0.3135.127 - Opera Software)
              Pingzapper version 2.1.2 (HKLM-x32...{7FD61982-5436-439B-B5D0-36F0536FF8BF}_is1) (Version: 2.1.2 - Pingzapper)
              PlayNexia II (HKLM-x32...\PlayNexia II) (Version: - )
              PlaysTV (HKLM-x32...\PlaysTV) (Version: 1.13.1-r115223-release - Plays.tv, LLC)
              Pokémon World Online Uninstaller (HKLM-x32...{6B67E1A1-1D62-4BDC-8C60-07FDF25CA975}_is1) (Version: 1.97 - PWO Team)
              Prerequisites for SSDT (HKLM-x32...{21373064-AD95-48DB-A32E-0D9E08EF7355}) (Version: 12.0.2000.8 - Microsoft Corporation)
              Prerequisites for SSDT (HKLM-x32...{B7E94916-7AE6-4F7F-A377-7A410A42BA19}) (Version: 13.0.1601.5 - Microsoft Corporation)
              PX Profile Update (HKLM-x32...{230C6C56-D930-2D7A-CF62-9BE26FAEE260}) (Version: 1.00.1. - AMD) Hidden
              QuickTime 7 (HKLM-x32...{80CEEB1E-0A6C-45B9-A312-37A1D25FDEBC}) (Version: 7.78.80.95 - Apple Inc.)
              Ragnarok Online (HKLM-x32...{181579B5-0028-4E01-AC27-97ED80352279}) (Version: 14.2.5 - Gravity Interactive, Inc.)
              Raptr (HKLM-x32...\Raptr) (Version: 5.1.1-r111306-release - Raptr, Inc)
              Razer Game Booster (HKLM-x32...\Razer Game Booster_is1) (Version: 4.1.59.0 - Razer Inc.)
              Realtek Card Reader (HKLM-x32...{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.2.9200.39052 - Realtek Semiconductor Corp.)
              Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.75.827.2013 - Realtek)
              Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8186 - Realtek Semiconductor Corp.)
              REALTEK Wireless LAN Driver (HKLM-x32...{9DAABC60-A5EF-41FF-B2B9-17329590CD5}) (Version: 1.30.0239 - REALTEK Semiconductor Corp.)
              Roslyn Language Services - x86 (HKLM-x32...{6970C7E1-F99D-388D-8903-DF8FCE677FED}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
              Safari (HKLM-x32...{A08BAD08-9AA3-410F-98F3-C92C8EE37218}) (Version: 5.34.54.16 - Apple Inc.)
              Service Pack 1 for SQL Server 2008 (KB968369) (64-bit) (HKLM...\KB968369) (Version: 10.1.2531.0 - Microsoft Corporation)
              Skype™ 7.26 (HKLM-x32...{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.26.101 - Skype Technologies S.A.)
              Speccy (HKLM...\Speccy) (Version: 1.31 - Piriform)
              Spotify (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Spotify) (Version: 1.0.70.388.g8e1ed5af - Spotify AB)
              Sql Server Customer Experience Improvement Program (HKLM...{2F14965D-567B-4E59-ADEB-0A2CC1E3ADDF}) (Version: 10.1.2531.0 - Microsoft Corporation) Hidden
              Team Explorer for Microsoft Visual Studio 2015 Update 3.1 (HKLM-x32...{7A95671A-759E-3B83-B763-4289D1D24D73}) (Version: 14.102.25619 - Microsoft) Hidden
              TeamSpeak 3 Client (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\TeamSpeak 3 Client) (Version: 3.0.16 - TeamSpeak Systems GmbH)
              TeamViewer 14 (HKLM-x32...\TeamViewer) (Version: 14.2.8352 - TeamViewer)
              TypeScript Tools for Microsoft Visual Studio 2015 (HKLM-x32...{BA5762C7-D35F-4725-A4BD-525854127018}) (Version: 1.8.36.0 - Microsoft Corporation) Hidden
              Update for 2007 Microsoft Office System (KB967642) (HKLM-x32...{90120000-0030-0000-0000-0000000FF1CE}ENTERPRISE{C444285D-5E4F-48A4-91DD-47AAAA68E92D}) (Version: - Microsoft)
              Update for Windows 10 for x64-based Systems (KB4023057) (HKLM...{B2E25355-C24E-4E7D-8AD3-455D59810838}) (Version: 2.57.0.0 - Microsoft Corporation)
              VC80CRTRedist - 8.0.50727.6195 (HKLM-x32...{933B4015-4618-4716-A828-5289FC03165F}) (Version: 1.2.0 - DivX, Inc) Hidden
              Vegas Pro 12.0 (64-bit) (HKLM...{BD422D00-5232-11E3-A6F3-F04DA23A5C58}) (Version: 12.0.770 - Sony)
              Vegas Pro 13.0 (64-bit) (HKLM-x32...\Vegas Pro 13.0 (64-bit)) (Version: 13.0 (64-bit) - Exµs ™)
              Visual Studio 2012 x64 Redistributables (HKLM...{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
              Visual Studio 2012 x86 Redistributables (HKLM-x32...{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
              VLC media player (HKLM-x32...\VLC media player) (Version: 3.0.1 - VideoLAN)
              Vulkan Run Time Libraries 1.0.26.0 (HKLM...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
              Vulkan Run Time Libraries 1.0.65.0 (HKLM...\VulkanRT1.0.65.0) (Version: 1.0.65.0 - LunarG, Inc.) Hidden
              Winamp (HKLM-x32...\Winamp) (Version: 5.666 - Nullsoft, Inc)
              Windows Driver Package - Lenovo (ACPIVPC) System (12/15/2011 7.1.0.1) (HKLM...\99841829BE839365AA67B2AD0E50D371F59F8A1E) (Version: 12/15/2011 7.1.0.1 - Lenovo)
              Windows Live Essentials (HKLM-x32...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
              WinPcap 4.1.3 (HKLM-x32...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
              WinRAR 5.70 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.70.0 - win.rar GmbH)
              Wondershare Filmora(Build 8.7.0) (HKLM...\Wondershare Filmora_is1) (Version: - Wondershare Software)
              Wondershare Helper Compact 2.6.0 (HKLM-x32...{5363CE84-5F09-48A1-8B6C-6BB590FFEDF2}_is1) (Version: 2.6.0 - Wondershare)
              Wondershare PDFelement 6 Pro(Build 6.8.6) (HKLM-x32...{B026557A-EF19-4812-8A79-B30F94AA0A78}_is1) (Version: 6.8.6.4121 - Wondershare Software Co.,Ltd.)
              Wondershare Video Converter Ultimate(Build 10.3.0.178) (HKLM-x32...\Video Converter Ultimate_is1) (Version: 10.3.0.178 - Wondershare Software)
              World of Warcraft (HKLM-x32...\World of Warcraft) (Version: - Blizzard Entertainment)
              XAMPP (HKLM-x32...\xampp) (Version: 7.1.1-0 - Bitnami)
              Zoom (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\ZoomUMX) (Version: 4.1 - Zoom Video Communications, Inc.)
              CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{00020420-0000-0000-C000-000000000046}\InprocServer32 → C:\WINDOWS\system32\oleaut32.dll (Microsoft Windows → Microsoft Corporation)
              CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{00020424-0000-0000-C000-000000000046}\InprocServer32 → C:\WINDOWS\system32\oleaut32.dll (Microsoft Windows → Microsoft Corporation)
              CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{018D5C66-4533-4307-9B53-224DE2ED1FE6} → [OneDrive] => {a52bba46-e9e1-435f-b3d9-28daa648c0f6} [0000-00-00 00:00]
              CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{E31EA727-12ED-4702-820C-4B6445F28E1A} → [Dropbox] => C:\Users\Lenovo\Dropbox [2015-07-07 16:17]
              CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{f1d8036a-7f48-43e4-8045-dbcb4e742507}\InprocServer32 → C:\WINDOWS\system32\dfshim.dll (Microsoft Windows → Microsoft Corporation)
              ShellExecuteHooks-x32: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll [2217832 2009-02-26] (Microsoft Corporation → Microsoft Corporation)
              ShellIconOverlayIdentifiers: [ DropboxExt01] → {FB314ED9-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt02] → {FB314EDF-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt03] → {FB314EE1-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt04] → {FB314EDB-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt05] → {FB314EDA-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt06] → {FB314EDC-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt07] → {FB314EDD-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt08] → {FB314EE0-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt09] → {FB314EE2-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ DropboxExt10] → {FB314EDE-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
              ShellIconOverlayIdentifiers: [00asw] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
              ShellIconOverlayIdentifiers: [00avg] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
              ShellIconOverlayIdentifiers-x32: [ DropboxExt01] → {FB314ED9-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt02] → {FB314EDF-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt03] → {FB314EE1-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt04] → {FB314EDB-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt05] → {FB314EDA-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt06] → {FB314EDC-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt07] → {FB314EDD-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt08] → {FB314EE0-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt09] → {FB314EE2-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ DropboxExt10] → {FB314EDE-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ShellIconOverlayIdentifiers-x32: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
              ContextMenuHandlers1: [ANotepad++64] → {B298D29A-A6ED-11DE-BA8C-A68E55D89593} => C:\Program Files (x86)\Notepad++\NppShell_06.dll [2018-03-19] (Notepad++ → )
              ContextMenuHandlers1: [DropboxExt] → {ECD97DE5-3C8F-4ACB-AEEE-CCAB78F7711C} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ContextMenuHandlers1: [IObitUnstaler] → {836AB26C-2DE4-41D3-AC24-4C6C2699B960} => C:\Program Files (x86)\IObit\IObit Uninstaller\IUMenuRight.dll [2018-07-21] (IObit Information Technology → IObit)
              ContextMenuHandlers1: [SD360] → {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → )
              ContextMenuHandlers1: [WinRAR] → {B41DB860-64E4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
              ContextMenuHandlers1-x32: [WinRAR32] → {B41DB860-8EE4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext32.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
              ContextMenuHandlers3: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2018-03-03] (Malwarebytes Corporation → Malwarebytes)
              ContextMenuHandlers4: [DropboxExt] → {ECD97DE5-3C8F-4ACB-AEEE-CCAB78F7711C} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ContextMenuHandlers4: [IObitUnstaler] → {836AB26C-2DE4-41D3-AC24-4C6C2699B960} => C:\Program Files (x86)\IObit\IObit Uninstaller\IUMenuRight.dll [2018-07-21] (IObit Information Technology → IObit)
              ContextMenuHandlers4: [SD360] → {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → )
              ContextMenuHandlers5: [ACE] → {5E2121EE-0300-11D4-8D3B-444553540000} => C:\Program Files\AMD\CNext\CNext\atiacm64.dll [2016-06-28] (Advanced Micro Devices, Inc. → Advanced Micro Devices, Inc.)
              ContextMenuHandlers5: [DropboxExt] → {ECD97DE5-3C8F-4ACB-AEEE-CCAB78F7711C} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              ContextMenuHandlers5: [Gadgets] → {6B9228DA-9C15-419e-856C-19E768A13BDC} => → No File
              ContextMenuHandlers5: [igfxcui] → {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => → No File
              ContextMenuHandlers5: [igfxDTCM] → {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\system32\igfxDTCM.dll [2017-06-12] (Microsoft Windows Hardware Compatibility Publisher → Intel Corporation)
              ContextMenuHandlers6: [IObitUnstaler] → {836AB26C-2DE4-41D3-AC24-4C6C2699B960} => C:\Program Files (x86)\IObit\IObit Uninstaller\IUMenuRight.dll [2018-07-21] (IObit Information Technology → IObit)
              ContextMenuHandlers6: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2018-03-03] (Malwarebytes Corporation → Malwarebytes)
              ContextMenuHandlers6: [SD360] → {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → )
              ContextMenuHandlers6: [WinRAR] → {B41DB860-64E4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
              ContextMenuHandlers6-x32: [WinRAR32] → {B41DB860-8EE4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext32.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
              Task: {012A6F59-87D6-44E0-A91E-4191C44105EE} - System32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
              Task: {02E9EE88-8B2A-45A8-B237-293AF930C0D8} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe (Piriform Ltd → Piriform Ltd)
              Task: {06B7B6A5-89CC-4D81-B982-3F531F29F6A9} - System32\Tasks\Avast Emergency Update => C:\Program Files\AVAST Software\Avast\AvEmUpdate.exe (AVAST Software s.r.o. → AVAST Software)
              Task: {07375CF8-C1FF-492B-8278-0396D0245D6F} - System32\Tasks\DropboxUpdateTaskMachineCore1d1719f 65cee02e => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe (Dropbox, Inc → Dropbox, Inc.)
              Task: {08DE182E-4B30-4A1E-B2FD-C6EB7895D4FF} - System32\Tasks\0915tbUpdateInfo => C:\ProgramData\Avg_Update_0915tb\0915tb_{25635FAF-00C4-4CFA-B296-FCEF7A02AE64}.exe
              Task: {0F9B47A5-A3A5-4CC4-9CF4-6FCF47A1FB9F} - System32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {115F90B7-1231-4FF1-AB5B-92FEF3694B20} - System32\Tasks\Driver Easy Scheduled Scan => C:\Program Files\Easeware\DriverEasy\DriverEasy.exe (Easeware Technology Limited → Easeware)
              Task: {159448A5-F558-4572-8A16-6E303989186A} - System32\Tasks\Microsoft\Windows\Media Center\OCURActivate => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {19946D02-33AE-4E60-81DF-5092DEB8F277} - System32\Tasks\Microsoft\VisualStudio\VSIX Auto Update 14 => D:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\VSIXAutoUpdate.exe
              Task: {1AE784A5-A8C1-469D-ACDC-69A2BD7FEE8A} - System32\Tasks\DropboxUpdateTaskMachineUA1d1719f66 008e5b => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe (Dropbox, Inc → Dropbox, Inc.)
              Task: {1C48C1BE-378A-4BD4-9CBC-1EE169FA27A9} - System32\Tasks\FreeDownloadManagerNetworkMonitor => D:\Program Files\FreeDownloadManager.ORG\Free Download Manager\winwfpmonitor.exe (Softdeluxe Ltd. → FreeDownloadManager.org)
              Task: {1DA9B645-13DA-4059-A3CB-D56C3971092C} - System32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
              Task: {21BE9597-704B-4669-B98E-367AC00D234B} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {24672617-0A93-4BB5-8559-4012CEDFDF08} - System32\Tasks{61E32EBD-8E77-4D1B-9D4E-DFB440A9AB05} => C:\Windows\system32\pcalua.exe -a “D:\game\Gravity\openkore\Ragnarok Online\Setup.exe” -d “D:\game\Gravity\openkore\Ragnarok Online”
              Task: {25C72C5E-A5A2-4F4B-BD37-3E4477093B5A} - System32\Tasks\Microsoft\Windows\Media Center\SqlLiteRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
              Task: {297450E0-6ABB-427D-BB1C-BB2872268E11} - System32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
              Task: {31709D69-4FCE-4D4D-821C-94E1E6D6B831} - System32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {36512371-A906-4CBA-8D6E-CCCA8F25E12E} - System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132-Logon => C:\Program Files\Intel\SUR\QUEENCREEK\Updater\bin\IntelSoftwa reAssetManagerService.exe (Intel(R) Software Asset Manager → Intel Corporation)
              Task: {3BB917BA-28B7-4433-B3E7-7EFBADC9BF05} - System32\Tasks\Avast Software\Overseer => C:\Program Files\Common Files\AVAST Software\Overseer\overseer.exe (AVAST Software s.r.o. → AVAST Software)
              Task: {3BB99F43-80C7-4010-9269-058CFC43E873} - System32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {3C199C18-45CD-429D-B193-E25CBD0D0253} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate_scheduled => C:\WINDOWS\ehome\mcupdate.exe
              Task: {4B4D8E7B-0A5F-40FC-BBCD-29A82DE55E1E} - System32\Tasks\AVG-SSU_0117avz_DELETE => C:\ProgramData\Avg_Update_0117avz\AVG-Secure-Search-Update_0117avz.exe
              Task: {4D4F0449-FE30-4BDD-871D-BC436EDB0421} - System32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {508A340E-5F91-492E-ABB0-B98532F80480} - System32\Tasks\USER_ESRV_SVC_QUEENCREEK => “C:\WINDOWS\System32\Wscript.exe” //B //NoLogo “C:\Program Files\Intel\SUR\QUEENCREEK\task.vbs”
              Task: {522525D9-3E35-4CED-9B07-86DCF48846B4} - System32\Tasks\S-1-5-21-1925601759-1010797402-2804155008-1000\DataSenseLiveTileTask => C:\WINDOWS\System32\DataUsageLiveTileTask.exe (Microsoft Windows → Microsoft Corporation)
              Task: {547C6C01-5708-4D14-AA13-ACA0C447A4A6} - System32\Tasks\StartCN => C:\Program Files\AMD\CNext\CNext\cncmd.exe (Advanced Micro Devices, Inc. → Advanced Micro Devices, Inc.)
              Task: {57DFC5D9-A460-4BFF-B8E3-7B32AFB8CF85} - System32\Tasks\CommView for WiFi Update => C:\Program Files (x86)\CommViewWiFi\Updater.exe
              Task: {5A1FB4EE-EE0E-4270-9E75-684F0AF09C07} - System32\Tasks\Microsoft\Windows\Media Center\ehDRMInit => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {621144B0-DE22-4BA5-8091-E7C4827BEF4F} - System32\Tasks\Microsoft\Windows\Media Center\RecordingRestart => C:\WINDOWS\ehome\ehrec.exe
              Task: {67DA1BE8-90A4-4CF2-A274-8747F431E302} - System32\Tasks\Microsoft\Windows\Media Center\RegisterSearch => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {728F5E94-6E39-4D9D-BDDF-15FE8F3796DB} - \cFos\Registration Tasks\Open Browser → No File <==== ATTENTION
              Task: {754E8E88-D223-42F3-9481-B9A6C2933CF3} - \Microsoft\Windows\UNP\RunCampaignManager → No File <==== ATTENTION
              Task: {789B54F6-B496-4419-97FF-B9199F07696D} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe (Apple Inc. → Apple Inc.)
              Task: {807DE444-D371-423B-899D-8236EA7A416B} - System32\Tasks\Uninstaller_SkipUac_Lenovo => C:\Program Files (x86)\IObit\IObit Uninstaller\IObitUninstaler.exe (IObit Information Technology → IObit)
              Task: {875ACF9F-41FC-404C-9502-1B189212FDFC} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (Google Inc → Google LLC)
              Task: {909165E7-58B7-40A8-BAD4-06369AE44715} - System32\Tasks\Microsoft\Windows\Flighting\Feature Config\ReconcileFeatures
              Task: {9C7FF83C-4028-4C31-9DA7-4814BF4DD82A} - System32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {9EA7EA19-87D5-4A05-90A2-77FAC5CAFED8} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe (Piriform Ltd → Piriform Ltd)
              Task: {A1E768A1-C621-44E3-9D8D-0B31A7AA6480} - System32\Tasks\Intel\Intel Telemetry 2 => C:\Program Files\Intel\Telemetry 2.0\lrio.exe (Intel(R) Software → Intel Corporation)
              Task: {A2BC51F7-A5A5-4583-BCFC-07D102EFC8B5} - System32\Tasks\McAfee Remediation (Prepare) => C:\Program Files\Common Files\AV\McAfee VirusScan\upgrade.exe (McAfee, Inc. → McAfee, Inc.)
              Task: {A3F7EA55-63E8-472B-BD18-E4C82C33D682} - System32\Tasks\Adobe Flash Player Updater => C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpda teService.exe (Adobe Systems Incorporated → Adobe Systems Incorporated)
              Task: {A61D04AD-6E7A-4DD5-B7E7-A8E75622266A} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (Google Inc → Google LLC)
              Task: {A65C2727-BF46-4882-A619-716BB2E10EE3} - System32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry => C:\WINDOWS\ehome\MCUpdate.exe
              Task: {A9744BF1-B3BE-485E-8CED-C8A112DB42C9} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {B170E593-7A4A-42ED-8E5E-FE91C524223A} - System32\Tasks\Adobe Flash Player PPAPI Notifier => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_29_ 0_0_113_pepper.exe (Adobe Systems Incorporated → Adobe Systems Incorporated)
              Task: {B79C1E15-BBAE-4901-8144-CA6499E7F7BD} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {BAB0F865-1900-4889-B5E2-E00F083B9AC6} - System32\Tasks\Opera scheduled assistant Autoupdate 1550324909 => C:\Users\Lenovo\AppData\Local\Programs\Opera\launc her.exe (Opera Software AS → Opera Software)
              Task: {C14A101B-90DF-4EA6-814A-49BE72CAD1BA} - System32\Tasks\AVG-SSU_0117avz => C:\ProgramData\Avg_Update_0117avz\AVG-Secure-Search-Update_0117avz.exe
              Task: {C35EAC49-C654-4AD2-A8E0-13BB4B538500} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate => C:\WINDOWS\ehome\mcupdate.exe
              Task: {CB120083-D139-490E-ABC1-9711116BDE86} - System32\Tasks\Adobe Flash Player NPAPI Notifier => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_29_ 0_0_113_Plugin.exe (Adobe Systems Incorporated → Adobe Systems Incorporated)
              Task: {D841F08B-9CC5-4DE4-8780-B48A4D247CC3} - System32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: {DA3CD105-1C40-4F31-B596-534277F311B7} - System32\Tasks\Microsoft\Windows\Media Center\StartRecording => C:\WINDOWS\ehome\ehrec.exe
              Task: {DEBAD4D3-2F39-4C63-9561-762021145015} - System32\Tasks\MySQL\Installer\ManifestUpdate => C:\Program Files (x86)\MySQL\MySQL Installer for Windows\MySQLInstallerConsole.exe
              Task: {ECF63DBD-0D24-4258-861D-7F5BDFA4C73D} - System32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask => C:\WINDOWS\ehome\mcupdate.exe
              Task: {F73979B7-3B5E-4FBF-AF56-473DC86B90CE} - System32\Tasks\Opera scheduled Autoupdate 1521719234 => C:\Users\Lenovo\AppData\Local\Programs\Opera\launc her.exe (Opera Software AS → Opera Software)
              Task: {F8A429FB-D075-49EE-91B6-D247866AD4A6} - System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132 => C:\Program Files\Intel\SUR\QUEENCREEK\Updater\bin\IntelSoftwa reAssetManagerService.exe (Intel(R) Software Asset Manager → Intel Corporation)
              Task: {FEB657CD-087C-4664-B5E8-D03BBC23E1CF} - System32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath => C:\WINDOWS\ehome\ehPrivJob.exe
              Task: C:\WINDOWS\Tasks\0915tbUpdateInfo.job => C:\ProgramData\Avg_Update_0915tb\0915tb_{25635FAF-00C4-4CFA-B296-FCEF7A02AE64}.exe
              Task: C:\WINDOWS\Tasks\Driver Easy Scheduled Scan.job => C:\Program Files\Easeware\DriverEasy\DriverEasy.exe
              Task: C:\WINDOWS\Tasks\DropboxUpdateTaskMachineCore1d171 9f65cee02e.job => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
              Task: C:\WINDOWS\Tasks\DropboxUpdateTaskMachineUA1d1719f 66008e5b.job => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
              Task: C:\WINDOWS\Tasks\Synaptics TouchPad Enhancements.job => C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
              ShortcutWithArgument: C:\Users\Lenovo\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\ImplicitAppShortcuts\69639df789022856\Googl e Chrome.lnk → C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) → --profile-directory=“Profile 1”
              2018-12-18 14:31 - 2017-10-19 09:17 - 000271360 _____ (Wondershare Software) [File not signed] C:\WINDOWS\System32\WSPDFelementMonitor.dll
              2007-07-06 12:14 - 2007-07-06 12:14 - 005730304 _____ () [File not signed] C:\Program Files (x86)\MySQL\MySQL Server 5.0\bin\mysqld-nt.exe
              2013-08-27 17:32 - 2013-08-27 17:32 - 000747520 _____ (Intel(R) Corporation) [File not signed] C:\Program Files\Intel\iCLS Client\HeciServer.exe
              2016-06-28 21:38 - 2016-06-28 21:38 - 000138752 _____ () [File not signed] C:\Program Files\ATI Technologies\ATI.ACE\A4\AdaptiveSleepService.exe
              2018-01-31 17:49 - 2018-01-31 17:49 - 000009216 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPLauncher.exe
              2018-01-31 17:49 - 2018-01-31 17:49 - 000077312 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPMaster.exe
              2018-01-31 17:49 - 2018-01-31 17:49 - 000060928 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPDU.exe
              2018-01-31 17:49 - 2018-01-31 17:49 - 000011264 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPUF.exe
              2016-06-28 21:36 - 2016-06-28 21:36 - 000004608 _____ (Advanced Micro Devices, Inc.) [File not signed] C:\Program Files\AMD\CNext\CNext\atiamenu.dll
              2015-11-25 06:49 - 2015-11-25 06:49 - 002257408 _____ (ActiveState Software Inc) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\python26.dll
              2015-11-25 06:48 - 2015-11-25 06:48 - 000028160 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\servicemanager.pyd
              2015-11-25 06:46 - 2015-11-25 06:46 - 000110592 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\pywintypes26.dll
              2015-11-25 06:48 - 2015-11-25 06:48 - 000041472 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32service.pyd
              2015-11-25 06:48 - 2015-11-25 06:48 - 000096256 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32api.pyd
              2015-11-25 06:43 - 2015-11-25 06:43 - 000356864 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_hashlib.pyd
              2015-11-25 06:48 - 2015-11-25 06:48 - 000017920 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32event.pyd
              2015-11-25 06:48 - 2015-11-25 06:48 - 000019968 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32evtlog.pyd
              2015-11-25 06:48 - 2015-11-25 06:48 - 000036352 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32process.pyd
              2015-11-25 06:43 - 2015-11-25 06:43 - 000043008 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_socket.pyd
              2015-11-25 06:43 - 2015-11-25 06:43 - 000805376 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_ssl.pyd
              2015-11-25 06:43 - 2015-11-25 06:43 - 000087040 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_ctypes.pyd
              2015-11-25 06:46 - 2015-11-25 06:46 - 000354304 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\pythoncom26.dll
              2015-11-25 06:48 - 2015-11-25 06:48 - 000167936 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32gui.pyd
              2015-11-25 06:47 - 2015-11-25 06:47 - 001980928 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtGui.pyd
              2015-11-25 07:02 - 2015-11-25 07:02 - 004604416 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Gui.dll
              2015-11-25 07:01 - 2015-11-25 07:01 - 004088320 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Core.dll
              2015-11-25 07:02 - 2015-11-25 07:02 - 001316352 _____ (The ICU Project) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\icuuc53.dll
              2015-11-25 07:01 - 2015-11-25 07:01 - 001961472 _____ (The ICU Project) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\icuin53.dll
              2015-11-25 07:01 - 2015-11-25 07:01 - 021529088 _____ (The ICU Project) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\icudt53.dll
              2015-12-08 06:57 - 2015-12-08 06:57 - 000077824 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\sip.pyd
              2015-11-25 06:47 - 2015-11-25 06:47 - 001862144 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtCore.pyd
              2015-11-25 06:47 - 2015-11-25 06:47 - 000516608 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtNetwork.pyd
              2015-11-25 07:02 - 2015-11-25 07:02 - 000839680 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Network.dll
              2015-11-25 06:47 - 2015-11-25 06:47 - 004060160 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtWidgets.pyd
              2015-11-25 07:01 - 2015-11-25 07:01 - 004468736 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Widgets.dll
              2015-11-25 06:43 - 2015-11-25 06:43 - 000010240 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\select.pyd
              2013-11-21 11:31 - 2013-11-21 11:31 - 000286720 _____ (Intel Corporation) [File not signed] C:\Program Files\Intel\Intel(R) Rapid Storage Technology\PsiData.dll
              2013-11-21 11:31 - 2013-11-21 11:31 - 000499200 _____ (Intel Corporation) [File not signed] C:\Program Files\Intel\Intel(R) Rapid Storage Technology\ISDI2.dll
              AlternateDataStreams: C:\ProgramData\Temp:56E2E879 [135]
              ==================== Hosts content: ==========================
              2016-11-15 03:41 - 2018-03-22 23:07 - 000001595 _____ C:\WINDOWS\system32\drivers\etc\hosts
              127.0.0.1 bandicam.com
              127.0.0.1 ssl.bandisoft.com
              127.0.0.1 localhost
              127.0.0.1 tonec.com
              127.0.0.1 www.tonec.com
              127.0.0.1 registeridm.com
              127.0.0.1 www.registeridm.com
              127.0.0.1 secure.registeridm.com
              127.0.0.1 internetdownloadmanager.com
              127.0.0.1 www.internetdownloadmanager.com
              127.0.0.1 secure.internetdownloadmanager.com
              127.0.0.1 www.secure.internetdownloadmanager.com
              127.0.0.1 mirror.internetdownloadmanager.com
              127.0.0.1 www.mirror.internetdownloadmanager.com
              127.0.0.1 mirror2.internetdownloadmanager.com
              127.0.0.1 www.mirror2.internetdownloadmanager.com
              127.0.0.1 mirror3.internetdownloadmanager.com
              127.0.0.1 www.mirror3.internetdownloadmanager.com
              127.0.0.1 174.133.70.98
              2016-11-07 03:29 - 2016-11-07 03:29 - 000000499 _____ C:\WINDOWS\system32\drivers\etc\hosts.ics
              192.168.137.70 iPhone.mshome.net # 2016 11 0 13 17 29 46 813
              192.168.137.1 Lenovo-PC.mshome.net # 2021 11 5 5 17 29 46 813
              HKLM\System\CurrentControlSet\Control\Session Manager\Environment\Path: C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;%SystemRoot%\system32;%SystemRoot%;%SystemR oot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPo werShell\v1.0;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Windows Live\Shared;D:\Program Files (x86)\QuickTime\QTSystem;C:\Program Files (x86)\Skype\Phone;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn;C:\Program Files\Microsoft SQL Server\100\Tools\Binn;C:\Program Files\Microsoft SQL Server\100\DTS\Binn;%SYSTEMROOT%\System32\OpenSSH
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000\Control Panel\Desktop\Wallpaper → C:\Windows\Web\Wallpaper\Windows\img0.jpg
              DNS Servers: 192.168.0.1
              HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
              HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer => (SmartScreenEnabled: Off)
              HKLM\software\microsoft\Windows\CurrentVersion\Tel ephony\Providers => ProviderFileName2 → ndptsp.tsp (No File)
              Windows Firewall is enabled.
              MSCONFIG\Services: ACDaemon => 3
              MSCONFIG\Services: CLHNServiceForPowerDVD => 2
              MSCONFIG\Services: CxAudMsg => 2
              MSCONFIG\Services: CyberLink PowerDVD 11.0 Monitor Service => 2
              MSCONFIG\Services: CyberLink PowerDVD 11.0 Service => 2
              MSCONFIG\Services: dbupdate => 2
              MSCONFIG\Services: dbupdatem => 3
              MSCONFIG\Services: ETDService => 2
              MSCONFIG\Services: gusvc => 3
              MSCONFIG\Services: hmevpnsvc => 2
              MSCONFIG\Services: iPod Service => 3
              MSCONFIG\Services: MozillaMaintenance => 3
              MSCONFIG\Services: OverwolfUpdater => 3
              MSCONFIG\Services: PingzapperSvc => 2
              MSCONFIG\Services: Razer Game Scanner Service => 2
              MSCONFIG\Services: SkypeUpdate => 2
              MSCONFIG\Services: TeamViewer => 2
              MSCONFIG\Services: UDisk Monitor => 2
              MSCONFIG\Services: WtuSystemSupport => 2
              MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^McAfee Security Scan Plus.lnk => C:\Windows\pss\McAfee Security Scan Plus.lnk.CommonStartup
              MSCONFIG\startupfolder: C:^Users^Lenovo^AppData^Roaming^Microsoft^Windows^ Start Menu^Programs^Startup^MYOB Add-On Connector.lnk => C:\Windows\pss\MYOB Add-On Connector.lnk.Startup
              MSCONFIG\startupreg: Adobe ARM => “C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe”
              MSCONFIG\startupreg: AdobeAAMUpdater-1.0 => “C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe”
              MSCONFIG\startupreg: APSDaemon => “C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe”
              MSCONFIG\startupreg: AVG-Secure-Search-Update_0715tb => “C:\ProgramData\Avg_Update_0715tb\AVG-Secure-Search-Update_0715tb.exe” /PROMPT /CMPID=0715tb
              MSCONFIG\startupreg: BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA} => “C:\Program Files (x86)\Common Files\Ahead\Lib\NMBgMonitor.exe”
              MSCONFIG\startupreg: cAudioFilterAgent => C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent 64.exe
              MSCONFIG\startupreg: cFosSpeed => C:\Program Files\cFosSpeed\cFosSpeed.exe
              MSCONFIG\startupreg: Dropbox => “C:\Program Files (x86)\Dropbox\Client\Dropbox.exe” /systemstartup
              MSCONFIG\startupreg: Energy Management => C:\Program Files (x86)\Lenovo\Energy Management\Energy Management.exe
              MSCONFIG\startupreg: EnergyUtility => C:\Program Files (x86)\Lenovo\Energy Management\Utility.exe
              MSCONFIG\startupreg: ForteConfig => C:\Program Files\Conexant\ForteConfig\fmapp.exe
              MSCONFIG\startupreg: Google Update => “C:\Users\Lenovo\AppData\Local\Google\Update\Googl eUpdate.exe” /c
              MSCONFIG\startupreg: GrooveMonitor => “C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe”
              MSCONFIG\startupreg: HotKeysCmds => “C:\Windows\system32\hkcmd.exe”
              MSCONFIG\startupreg: IAStorIcon => “C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIconLaunch.exe” “C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe” 60
              MSCONFIG\startupreg: IgfxTray => “C:\Windows\system32\igfxtray.exe”
              MSCONFIG\startupreg: Launch LCore => C:\Program Files\Logitech Gaming Software\LCore.exe /minimized
              MSCONFIG\startupreg: Overwolf => C:\Program Files (x86)\Overwolf\Overwolf.exe -silent
              MSCONFIG\startupreg: Persistence => “C:\Windows\system32\igfxpers.exe”
              MSCONFIG\startupreg: QuickTime Task => “C:\Program Files (x86)\QuickTime\QTTask.exe” -atboottime
              MSCONFIG\startupreg: Raptr => C:\Program Files (x86)\Raptr\RAPTRS~1.EXE --startup
              MSCONFIG\startupreg: Razer Synapse => “C:\Program Files (x86)\Razer\Synapse\RzSynapse.exe”
              MSCONFIG\startupreg: RemoteControl11 => “C:\Program Files (x86)\CyberLink\PowerDVD11\PDVD11Serv.exe”
              MSCONFIG\startupreg: Sidebar => C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
              MSCONFIG\startupreg: SmartAudio => C:\Program Files\CONEXANT\SAII\SACpl.exe /t
              MSCONFIG\startupreg: Spotify => “C:\Users\Lenovo\AppData\Roaming\Spotify\Spotify.e xe” -autostart -minimized
              MSCONFIG\startupreg: Spotify Web Helper => “C:\Users\Lenovo\AppData\Roaming\Spotify\SpotifyWe bHelper.exe”
              MSCONFIG\startupreg: StartCCC => “C:\Program Files (x86)\AMD\ATI.ACE\Core-Static\amd64\CLIStart.exe” MSRun
              MSCONFIG\startupreg: Steam => “C:\Program Files (x86)\Steam\steam.exe” -silent
              MSCONFIG\startupreg: SynLenovoGestureMgr => %ProgramFiles%\Synaptics\SynTP\SynLenovoGestureMgr .exe
              MSCONFIG\startupreg: SynTPEnh => %ProgramFiles%\Synaptics\SynTP\SynTPEnh.exe
              MSCONFIG\startupreg: USB3MON => “C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe”
              MSCONFIG\startupreg: vProt => “C:\Program Files (x86)\AVG Web TuneUp\vprot.exe”
              MSCONFIG\startupreg: WTFast Tray => “D:\Program Files (x86)\WTFast\WTFast.exe” trayonly
              HKLM...\StartupApproved\Run: => “cAudioFilterAgent”
              HKLM...\StartupApproved\Run: => “ForteConfig”
              HKLM...\StartupApproved\Run: => “iTunesHelper”
              HKLM...\StartupApproved\Run: => “StartCN”
              HKLM...\StartupApproved\Run32: => “DivXUpdate”
              HKLM...\StartupApproved\Run32: => “DivXMediaServer”
              HKLM...\StartupApproved\Run32: => “Dropbox”
              HKLM...\StartupApproved\Run32: => “AVG_UI”
              HKLM...\StartupApproved\Run32: => “QuickTime Task”
              HKLM...\StartupApproved\Run32: => “Raptr”
              HKLM...\StartupApproved\Run32: => “vProt”
              HKLM...\StartupApproved\Run32: => “PlaysTV”
              HKLM...\StartupApproved\Run32: => “Wondershare Helper Compact.exe”
              HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched”
              HKLM...\StartupApproved\Run32: => “SecurityHealth”
              HKLM...\StartupApproved\Run32: => “SmartAudio”
              HKLM...\StartupApproved\Run32: => “ETDCtrl”
              HKLM...\StartupApproved\Run32: => “DSATray”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\StartupFolder: => “hide.me VPN.lnk”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\StartupFolder: => “Bitcoin.lnk”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Discord”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “OneDrive”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Spotify Web Helper”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “WTFast Tray”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “CCleaner Monitoring”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Free Download Manager”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Adguard”
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “DownloadAccelerator”
              FirewallRules: [{7CA842ED-FDC9-4D33-B694-62CC7F8B7B47}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google LLC → Google Inc.)
              FirewallRules: [{4EE071C0-A61C-4D56-B8AC-530BE82152B7}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
              FirewallRules: [{16DC2830-7CDC-4D9A-AF4A-3D0EF4F2249D}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
              FirewallRules: [{C85BB459-5825-465E-9C64-4F6D04295ECA}] => (Allow) D:\Steam\Steam.exe (Valve → Valve Corporation)
              FirewallRules: [{56B248C4-51C0-4881-A3DF-FFE49495D7A2}] => (Allow) D:\Steam\Steam.exe (Valve → Valve Corporation)
              FirewallRules: [{384A9A9E-27F1-4EEA-8FB8-BE8AA17306FB}] => (Allow) D:\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve → Valve Corporation)
              FirewallRules: [{8F158D42-D729-46B6-B6CB-533F4AC05185}] => (Allow) D:\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve → Valve Corporation)
              FirewallRules: [{435422B9-07FA-46DF-A741-237F7C2210F3}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
              FirewallRules: [{22F62F48-C02A-4790-A6F5-8B890C3CCB15}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
              FirewallRules: [{B4DEDF6A-1421-40E0-8BAF-84376A31421B}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2cfg.exe (Valve → )
              FirewallRules: [{08045740-3153-41A2-9A22-8AAD96F532E8}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2cfg.exe (Valve → )
              FirewallRules: [{2C9C57C3-E3E0-4550-87ED-D230BE7E01BA}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
              FirewallRules: [{2F0F5E82-9854-4FF2-8036-7472B1B31AFD}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
              Error: (04/19/2019 12:18:09 AM) (Source: Application Error) (EventID: 1000) (User: )
              Description: Faulting application name: AvLaunch.exe, version: 19.3.4241.0, time stamp: 0x5c82677e
              Faulting module name: ucrtbase.dll, version: 10.0.17134.677, time stamp: 0x9f346d3f
              Exception code: 0xc0000409
              Fault offset: 0x000000000006e14e
              Faulting process id: 0x34a4
              Faulting application start time: 0x01d4f5f17b91dedb
              Faulting application path: C:\Program Files\AVAST Software\Avast\AvLaunch.exe
              Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
              Report Id: 5e740d30-457e-4478-918d-4c2fc62c2872
              Faulting package full name:
              Error: (04/18/2019 03:53:49 PM) (Source: Application Error) (EventID: 1000) (User: )
              Faulting process id: 0x7c8
              Faulting application start time: 0x01d4f5aafef2d94d
              Report Id: 7f26122a-19e9-4d19-ab28-3751a9678530
              Error: (04/18/2019 11:18:25 AM) (Source: Application Error) (EventID: 1000) (User: )
              Faulting process id: 0x2e88
              Faulting application start time: 0x01d4f5847f2e9a20
              Report Id: 88217f84-4c3b-4f25-ab64-88d999f6e834
              Error: (04/18/2019 10:57:21 AM) (Source: Bonjour Service) (EventID: 100) (User: )
              Description: Task Scheduling Error: m->NextScheduledSPRetry 62438
              Description: Task Scheduling Error: m->NextScheduledEvent 62438
              Description: Task Scheduling Error: Continuously busy for more than a second
              Error: (04/18/2019 10:57:05 AM) (Source: Bonjour Service) (EventID: 100) (User: )
              Description: Task Scheduling Error: m->NextScheduledSPRetry 46813
              Description: Task Scheduling Error: m->NextScheduledEvent 46813
              Error: (04/19/2019 02:08:23 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
              and APPID
              to the user Lenovo-PC\Lenovo SID (S-1-5-21-1925601759-1010797402-2804155008-1000) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
              Error: (04/19/2019 01:55:45 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
              and APPID
              Error: (04/19/2019 01:42:15 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
              and APPID
              Error: (04/19/2019 01:40:52 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
              and APPID
              Error: (04/19/2019 01:40:26 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
              and APPID
              Error: (04/19/2019 12:27:14 AM) (Source: Service Control Manager) (EventID: 7000) (User: )
              Description: The Steam Client Service service failed to start due to the following error:
              The service did not respond to the start or control request in a timely fashion.
              Error: (04/19/2019 12:27:14 AM) (Source: Service Control Manager) (EventID: 7009) (User: )
              Description: A timeout was reached (120000 milliseconds) while waiting for the Steam Client Service service to connect.
              Error: (04/19/2019 12:27:13 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
              and APPID
              Date: 2019-04-19 01:13:02.168
              Description:
              Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume2\Program Files (x86)\360\Total Security\I18N64.dll that did not meet the Store signing level requirements.
              Date: 2019-04-19 01:13:02.159
              Description:
              Date: 2019-04-18 16:19:07.501
              Description:
              Date: 2019-04-18 16:19:07.324
              Description:
              Date: 2019-04-18 15:23:03.317
              Description:
              Date: 2019-04-18 15:23:03.050
              Description:
              Date: 2019-04-18 15:22:56.436
              Description:
              Date: 2019-04-18 15:22:55.885
              Description:
              Processor: Intel(R) Core™ i7-4510U CPU @ 2.00GHz
              Percentage of memory in use: 47%
              Total physical RAM: 8088.36 MB
              Available physical RAM: 4219.35 MB
              Total Virtual: 20220.36 MB
              Available Virtual: 16059.62 MB
              Drive c: (OS) (Fixed) (Total:151.27 GB) (Free:17.17 GB) NTFS
              Drive d: (Data) (Fixed) (Total:584.83 GB) (Free:275.71 GB) NTFS
              Drive f: (Bandicam) (Fixed) (Total:195.31 GB) (Free:179.55 GB) NTFS
              \?\Volume{c05dd144-747f-11e4-9d1a-806e6f6e6963}\ (System Reserved) (Fixed) (Total:0.1 GB) (Free:0.05 GB) NTFS
              Disk: 0 (MBR Code: Windows 7/8/10) (Size: 931.5 GB) (Disk ID: D9FA2484)
              Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
              Partition 2: (Not Active) - (Size=151.3 GB) - (Type=07 NTFS)
              Partition 3: (Not Active) - (Size=584.8 GB) - (Type=07 NTFS)
              Partition 4: (Not Active) - (Size=195.3 GB) - (Type=0F Extended)
              content of FRST:
              Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 17.04.2019
              Ran by Lenovo (administrator) on LENOVO-PC (19-04-2019 02:10:45)
              Running from C:\Users\Lenovo\Downloads
              Loaded Profiles: Lenovo (Available Profiles: Lenovo & DefaultAppPool)
              Platform: Windows 10 Pro Version 1803 17134.706 (X64) Language: English (United States)
              Default browser: Chrome
              Boot Mode: Normal
              Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic...ery-scan-tool/
              (AVG Technologies CZ, s.r.o. → ) C:\Program Files (x86)\AVG Web TuneUp\WtuSystemSupport.exe
              (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.) C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe
              (Apple Inc. → Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
              (AnchorFree Inc → AnchorFree Inc.) C:\Program Files (x86)\Hotspot Shield\bin\cmw_srv.exe
              (Conexant Systems, Inc. → Conexant Systems Inc.) C:\Windows\System32\CxAudMsg64.exe
              (Intel(R) Driver & Support Assistant → Intel) C:\Program Files (x86)\Intel Driver and Support Assistant\DSAService.exe
              (Plays.tv, LLC → Plays.tv, LLC) C:\Program Files (x86)\Raptr Inc\PlaysTV\plays_service.exe
              (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDService.exe
              (McAfee, Inc. → McAfee, LLC.) C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.Service.exe
              (McAfee, Inc. → McAfee, LLC.) C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.ServiceHelper. exe
              (McAfee, Inc. → McAfee, LLC.) C:\Program Files\McAfee\TrueKey\McTkSchedulerService.exe
              (Microsoft Corporation → Microsoft Corporation) C:\Program Files\Microsoft SQL Server\90\Shared\sqlwriter.exe
              (Microsoft Corporation → Microsoft Corporation) C:\Program Files\Microsoft SQL Server\MSSQL10.SQLEXPRESS\MSSQL\Binn\sqlservr.exe
              (Apple Inc. → Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
              (Razer Inc. → Razer Inc.) D:\Program Files (x86)\Razer\Razer Game Booster\RzKLService.exe
              (QIHU 360 SOFTWARE CO. LIMITED → QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHWatchdog.exe
              (Intel Corporation - Intel® Management Engine Firmware → Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
              () [File not signed] C:\Program Files\ATI Technologies\ATI.ACE\a4\AdaptiveSleepService.exe
              (Intel Corporation - Intel® Rapid Storage Technology → Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
              (Microsoft Windows → Microsoft Corporation) C:\Program Files\rempl\sedsvc.exe
              (Microsoft Windows → Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
              (TeamViewer GmbH → TeamViewer GmbH) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
              (Google Inc → Google LLC) C:\Program Files (x86)\Google\Update\1.3.34.7\GoogleCrashHandler.ex e
              (Google Inc → Google LLC) C:\Program Files (x86)\Google\Update\1.3.34.7\GoogleCrashHandler64. exe
              (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrl.exe
              (McAfee, Inc. → McAfee, LLC.) C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.SmartMonitor.e xe
              (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrlHelper.exe
              (Microsoft Corporation) [File not signed] C:\Program Files\WindowsApps\Microsoft.SkypeApp_14.42.60.0_x6 4__kzf8qxf38zg5c\SkypeApp.exe
              () [File not signed] C:\Program Files\WindowsApps\Microsoft.SkypeApp_14.42.60.0_x6 4__kzf8qxf38zg5c\SkypeBackgroundHost.exe
              (Microsoft Windows → Microsoft Corporation) C:\Program Files\Windows Defender\MSASCuiL.exe
              (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
              (Microsoft Windows → Microsoft Corporation) C:\Windows\System32\dllhost.exe
              () [File not signed] C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2019.19 021.18010.0_x64__8wekyb3d8bbwe\Microsoft.Photos.ex e
              (Microsoft Windows → Microsoft Corporation) C:\Windows\ImmersiveControlPanel\SystemSettings.ex e
              (Microsoft Corporation → Microsoft Corporation) C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wek yb3d8bbwe\MicrosoftEdge.exe
              (Microsoft Windows → Microsoft Corporation) C:\Windows\System32\browser_broker.exe
              (Microsoft Corporation → Microsoft Corporation) C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wek yb3d8bbwe\MicrosoftEdgeCP.exe
              (Google LLC → Google Inc.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
              (Opera Software AS → Opera Software) C:\Users\Lenovo\AppData\Local\Programs\Opera\58.0. 3135.127\opera.exe
              (Opera Software AS → Opera Software) C:\Users\Lenovo\AppData\Local\Programs\Opera\58.0. 3135.127\opera_crashreporter.exe
              ==================== Registry (Whitelisted) ===========================
              HKLM...\Run: [SecurityHealth] => C:\Program Files\Windows Defender\MSASCuiL.exe [638872 2018-04-12] (Microsoft Windows → Microsoft Corporation)
              HKLM...\Run: [ETDCtrl] => C:\Program Files\Elantech\ETDCtrl.exe [3242696 2015-10-07] (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.)
              HKLM...\Run: [ForteConfig] => C:\Program Files\Conexant\ForteConfig\fmapp.exe [49056 2010-10-26] (Fortemedia Inc → )
              HKLM...\Run: [cAudioFilterAgent] => C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent 64.exe [935104 2014-11-25] (Conexant Systems, Inc. → Conexant Systems, Inc.)
              HKLM...\Run: [iTunesHelper] => D:\Program Files\iTunes\iTunesHelper.exe [298296 2018-01-22] (Apple Inc. → Apple Inc.)
              HKLM-x32...\Run: [vProt] => C:\Program Files (x86)\AVG Web TuneUp\vprot.exe [2180680 2016-10-02] (AVG Technologies CZ, s.r.o. → )
              HKLM-x32...\Run: [Dropbox] => C:\Program Files (x86)\Dropbox\Client\Dropbox.exe [3567936 2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              HKLM-x32...\Run: [PlaysTV] => C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv_launcher.exe [71440 2016-08-10] (Plays.tv, LLC → Plays.tv, LLC)
              HKLM-x32...\Run: [Raptr] => C:\Program Files (x86)\Raptr Inc\Raptr\raptrstub.exe [58640 2016-04-01] (Raptr, Inc → Raptr, Inc)
              HKLM-x32...\Run: [QHSafeTray] => C:\Program Files (x86)\360\Total Security\safemon\360Tray.exe [669248 2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
              HKLM-x32...\Run: [DSATray] => C:\Program Files (x86)\Intel Driver and Support Assistant\DsaTray.exe [135968 2018-03-15] (Intel(R) Driver & Support Assistant → Intel)
              HKLM-x32...\Run: [AvastUI.exe] => C:\Program Files\AVAST Software\Avast\AvLaunch.exe [260488 2019-03-18] (AVAST Software s.r.o. → AVAST Software)
              HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Restriction <==== ATTENTION
              HKU\S-1-5-19...\RunOnce: [WAB Migrate] => C:\Program Files\Windows Mail\wab.exe [518144 2018-04-12] (Microsoft Windows → Microsoft Corporation)
              HKU\S-1-5-20...\RunOnce: [WAB Migrate] => C:\Program Files\Windows Mail\wab.exe [518144 2018-04-12] (Microsoft Windows → Microsoft Corporation)
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [17074688 2018-03-07] (Piriform Ltd → Piriform Ltd)
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Run: [Opera Browser Assistant] => C:\Users\Lenovo\AppData\Local\Programs\Opera\assis tant\browser_assistant.exe [2480216 2019-02-12] (Opera Software AS → Opera Software)
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Policies\Explorer: [NoLowDiskSpaceChecks] 1
              HKLM...\Drivers32: [VIDC.FPS1] => C:\WINDOWS\system32\frapsv64.dll [105984 2015-09-05] (Beepa P/L) [File not signed]
              HKLM...\Drivers32: [VIDC.HFYU] => C:\WINDOWS\system32\huffyuv.dll [55296 2005-01-22] () [File not signed]
              HKLM...\Drivers32: [VIDC.LAGS] => C:\WINDOWS\system32\lagarith.dll [148992 2011-12-08] ( ) [File not signed]
              HKLM...\Drivers32: [VIDC.X264] => C:\WINDOWS\system32\x264vfw64.dll [3799552 2017-07-30] (x264vfw project) [File not signed]
              HKLM...\Drivers32: [VIDC.XVID] => C:\WINDOWS\system32\xvidvfw.dll [311296 2018-01-28] () [File not signed]
              HKLM...\Drivers32: [VIDC.FFDS] => C:\WINDOWS\system32\ff_vfw.dll [126976 2015-08-25] () [File not signed]
              HKLM...\Drivers32: [msacm.ac3acm] => C:\WINDOWS\system32\ac3acm.acm [180736 2012-07-21] (fccHandler) [File not signed]
              HKLM...\Drivers32: [VIDC.FPS1] => C:\Windows\SysWOW64\frapsvid.dll [94208 2015-09-05] (Beepa P/L) [File not signed]
              HKLM...\Drivers32: [VIDC.HFYU] => C:\WINDOWS\SysWOW64\huffyuv.dll [39936 2004-05-19] (Disappearing Inc.) [File not signed]
              HKLM...\Drivers32: [VIDC.LAGS] => C:\WINDOWS\SysWOW64\lagarith.dll [216064 2011-12-08] ( ) [File not signed]
              HKLM...\Drivers32: [VIDC.X264] => C:\Windows\SysWOW64\x264vfw.dll [3850240 2017-07-30] (x264vfw project) [File not signed]
              HKLM...\Drivers32: [VIDC.XVID] => C:\WINDOWS\SysWOW64\xvidvfw.dll [284672 2018-01-28] () [File not signed]
              HKLM...\Drivers32: [msacm.ac3acm] => C:\WINDOWS\SysWOW64\ac3acm.acm [122880 2012-07-21] (fccHandler) [File not signed]
              HKLM...\Drivers32: [msacm.lameacm] => C:\Windows\SysWOW64\lameACM.acm [473088 2015-02-26] (hxxp://www.mp3dev.org/) [File not signed]
              HKLM...\Drivers32: [VIDC.FFDS] => C:\WINDOWS\SysWOW64\ff_vfw.dll [112128 2015-08-25] () [File not signed]
              HKLM\Software\Microsoft\Active Setup\Installed Components: [{8A69D345-D564-463c-AFF1-A69D9E530F96}] → C:\Program Files (x86)\Google\Chrome\Application\73.0.3683.103\Inst aller\chrmstp.exe [2019-04-18] (Google LLC → Google Inc.)
              HKLM\Software...\Authentication\Credential Providers: [{503739d0-4c5e-4cfd-b3ba-d881334f0df2}] →
              HKLM\Software...\Authentication\Credential Providers: [{B7724AE5-1135-4889-8A5F-CA98BE6CA1ED}] → C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.CredentialProv ider.dll [2018-11-27] (McAfee, Inc. → McAfee, LLC.)
              Lsa: [Notification Packages] scecli C:\Program Files\TrueKey\McAfeeTrueKeyPasswordFilter “C:\Program Files\TrueKey\McAfeeTrueKeyPasswordFilter” “C:\Program Files\McAfee\TrueKey\McAfeeTrueKeyPasswordFilter”
              GroupPolicy: Restriction ? <==== ATTENTION
              Hosts: There are more than one entry in Hosts. See Hosts section of Addition.txt
              Tcpip\Parameters: [DhcpNameServer] 192.168.0.1
              Tcpip..\Interfaces{2e5093be-ec30-45b1-a0b7-0a9388c176f1}: [DhcpNameServer] 172.20.10.1
              Tcpip..\Interfaces{8d45d7f2-23ec-402e-ba7c-d7e2681ab43c}: [DhcpNameServer] 192.168.0.1
              [HEADING=1]Internet Explorer:[/HEADING]
              HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <==== ATTENTION
              HKLM\Software\Microsoft\Internet Explorer\Main,Search Page =
              HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page =
              HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
              HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL =
              HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
              HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL =
              HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
              HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Local Page =
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000\Software\Microsoft\Internet Explorer\Main,Start Page = hxxps://mysearch.avg.com/?cid=%7BE644F638-8B1F-47E6-B698-D3DB372E9EFA%7D&mid=f4d66996aa8347cda0658ddae406f9 fb-55d4ec08cd7e853dfbd9c9b5e6cb009adb67b172&lang=en&d s=AVG&coid=avgtbavg&cmpid=1214tb&pr=fr&d=2014-11-26%2017:29:01&v=4.1.6.294&pid=wtu&sg=&sap=hp
              HKU\S-1-5-21-1925601759-1010797402-2804155008-1000\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = hxxp://www.google.com/ie
              SearchScopes: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000 → {6A1806CD-94D4-4689-BA73-E35EA1EA9990} URL = hxxp://www.google.com/search?q={sear
              BHO: True Key Helper → {0F4B8786-5502-4803-8EBC-F652A1153BB6} → C:\Program Files\McAfee\TrueKey\MSIE\truekey_ie64.dll [2018-04-23] (McAfee, Inc. → Intel Security)
              BHO: ExplorerWnd Helper → {10921475-03CE-4E04-90CE-E2E7EF20C814} → C:\Program Files (x86)\IObit\IObit Uninstaller\UninstallExplorer.dll [2018-07-19] (IObit Information Technology → IObit)
              BHO: No Name → {13D67BB7-DB5F-48AA-884D-7A5D94168509} → No File
              BHO-x32: True Key Helper → {0F4B8786-5502-4803-8EBC-F652A1153BB6} → C:\Program Files\McAfee\TrueKey\MSIE\truekey_ie.dll [2018-04-23] (McAfee, Inc. → Intel Security)
              BHO-x32: Groove GFS Browser Helper → {72853161-30C5-4D22-B7F9-0BBC1D38A37E} → C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll [2009-02-26] (Microsoft Corporation → Microsoft Corporation)
              BHO-x32: Java™ Plug-In 2 SSV Helper → {DBC80044-A445-435b-BC74-9C25C1C588A9} → C:\Program Files (x86)\Java\jre1.8.0_161\bin\jp2ssv.dll [2018-03-22] (Oracle America, Inc. → Oracle Corporation)
              Toolbar: HKLM - True Key - {4BAAC1B8-0800-42C9-8FA6-08B211F356B8} - C:\Program Files\McAfee\TrueKey\MSIE\truekey_ie64.dll [2018-04-23] (McAfee, Inc. → Intel Security)
              Toolbar: HKLM-x32 - True Key - {4BAAC1B8-0800-42C9-8FA6-08B211F356B8} - C:\Program Files\McAfee\TrueKey\MSIE\truekey_ie.dll [2018-04-23] (McAfee, Inc. → Intel Security)
              Handler-x32: viprotocol - {B658800C-F66E-4EF3-AB85-6C0C227862A9} - C:\Program Files (x86)\Common Files\AVG Secure Search\ViProtocolInstaller\18.2.0\ViProtocol.dll [2014-12-10] (AVG Technologies → AVG Secure Search)
              [HEADING=1]FireFox:[/HEADING]
              FF ProfilePath: C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default [2019-04-18]
              FF Homepage: Mozilla\Firefox\Profiles\yyjwfhm6.default → hxxps://mysearch.avg.com/?cid={E644F638-8B1F-47E6-B698-D3DB372E9EFA}&mid=f4d66996aa8347cda0658ddae406f9fb-55d4ec08cd7e853dfbd9c9b5e6cb009adb67b172&lang=en&d s=AVG&coid=avgtbavg&cmpid=1215tb&pr=fr&d=2014-11-26 17:29:01&v=4.2.1.951&pid=wtu&sg=&sap=hp
              FF Extension: (AVG Web TuneUp) - C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\Extensionsavg@toolbar.xpi [2018-03-31] [UpdateUrl:hxxps://firefoxext.avcdn.net/firefoxext/avg/wtu/update.json]
              FF Extension: (360 Internet Protection) - C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\ExtensionsInternetProtection@360safe.com.xpi [2018-12-06]
              FF Extension: (Avast SafePrice | Comparison, deals, coupons) - C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\Extensionssp@avast.com.xpi [2019-03-18]
              FF Extension: (Avast Online Security) - C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\Extensionswrc@avast.com.xpi [2019-03-18]
              FF Extension: (Video DownloadHelper) - C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\Extensions{b9db16a4-6edc-47ec-a1f4-b86292ed211d}.xpi [2018-08-13]
              FF Extension: (Adblock Plus) - C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\Extensions{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}.xpi [2018-12-06]
              FF Extension: (Telemetry coverage) - C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\features{540a6ceb-17d1-4e61-b926-2fb91d73dcb2}telemetry-coverage-bug1487578@mozilla.org.xpi [2018-12-06] [Legacy]
              FF SearchPlugin: C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\searchplugins\avg-secure-search.xml [2016-10-02]
              FF HKLM-x32...\Firefox\Extensions: [daplinkchecker@speedbit.com] - D:\Program Files (x86)\DAP\daplinkchecker
              FF Extension: (DAP Link Checker) - D:\Program Files (x86)\DAP\daplinkchecker [2017-11-12] [Legacy] [not signed]
              FF HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Firefox\Extensions: [{F17C1572-C9EC-4e5c-A542-D05CBB5C5A08}] - D:\Program Files (x86)\DAP\DAPFireFox
              FF Extension: (Download Accelerator Plus (DAP) extension) - D:\Program Files (x86)\DAP\DAPFireFox [2017-11-12] [Legacy] [not signed]
              FF HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\SeaMonkey\Extensions: [mozilla_cc2@internetdownloadmanager.com] - C:\Program Files (x86)\Internet Download Manager\idmmzcc2.xpi => not found
              FF Plugin: @adobe.com/FlashPlayer → C:\WINDOWS\system32\Macromed\Flash\NPSWF64_29_0_0_ 113.dll [2018-03-22] (Adobe Systems Incorporated → )
              FF Plugin: @divx.com/DivX VOD Helper,version=1.0.0 → C:\Program Files\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC → DivX, LLC.)
              FF Plugin: @java.com/DTPlugin,version=10.40.2 → C:\WINDOWS\system32\npDeployJava1.dll [2014-11-25] (Oracle America, Inc. → Oracle Corporation)
              FF Plugin: @Microsoft.com/NpCtrl,version=1.0 → C:\Program Files\Microsoft Silverlight\5.1.50918.0\npctrl.dll [2018-10-23] (Microsoft Corporation → Microsoft Corporation)
              FF Plugin: adobe.com/AdobeAAMDetect → C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities\npAdobeAAMDet ect64.dll [2014-04-28] (Adobe Systems Incorporated → Adobe Systems)
              FF Plugin-x32: @adobe.com/FlashPlayer → C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_29_0_0_ 113.dll [2018-03-22] (Adobe Systems Incorporated → )
              FF Plugin-x32: @avg.com/AVG SiteSafety plugin,version=11.0.0.1,application/x-avg-sitesafety-plugin → C:\Program Files (x86)\Common Files\AVG Secure Search\SiteSafetyInstaller\40.3.6\npsitesafety.dll [No File]
              FF Plugin-x32: @divx.com/DivX VOD Helper,version=1.0.0 → C:\Program Files (x86)\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC → DivX, LLC.)
              FF Plugin-x32: @divx.com/DivX Web Player Plug-In,version=1.0.0 → C:\Program Files (x86)\DivX\DivX Web Player\npdivx32.dll [2015-09-02] (DivX, LLC → DivX, LLC)
              FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.5 → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2013-09-16] (Intel® Identity Protection Technology Software → Intel Corporation)
              FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2013-09-16] (Intel® Identity Protection Technology Software → Intel Corporation)
              FF Plugin-x32: @java.com/DTPlugin,version=11.161.2 → C:\Program Files (x86)\Java\jre1.8.0_161\bin\dtplugin\npDeployJava1 .dll [2018-03-22] (Oracle America, Inc. → Oracle Corporation)
              FF Plugin-x32: @java.com/JavaPlugin,version=11.161.2 → C:\Program Files (x86)\Java\jre1.8.0_161\bin\plugin2\npjp2.dll [2018-03-22] (Oracle America, Inc. → Oracle Corporation)
              FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 → C:\Program Files (x86)\Microsoft Silverlight\5.1.50918.0\npctrl.dll [2018-10-23] (Microsoft Corporation → Microsoft Corporation)
              FF Plugin-x32: @microsoft.com/WLPG,version=16.4.3528.0331 → C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll [2014-04-01] (Microsoft Corporation → Microsoft Corporation)
              FF Plugin-x32: @raidcall.en/RCplugin → C:\Users\Lenovo\AppData\Roaming\raidcall\plugins\n prcplugin.dll [2014-05-27] (Raidcall) [File not signed]
              FF Plugin-x32: @softnyxNpruntime → D:\Game\SoftnyxGame\NyxLauncherIS\npSoftnyx.dll [No File]
              FF Plugin-x32: @tools.google.com/Google Update;version=3 → C:\Program Files (x86)\Google\Update\1.3.34.7\npGoogleUpdate3.dll [2019-04-18] (Google Inc → Google LLC)
              FF Plugin-x32: @tools.google.com/Google Update;version=9 → C:\Program Files (x86)\Google\Update\1.3.34.7\npGoogleUpdate3.dll [2019-04-18] (Google Inc → Google LLC)
              FF Plugin-x32: @videolan.org/vlc,version=2.2.4 → D:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2018-02-27] (VideoLAN → VideoLAN)
              FF Plugin-x32: @videolan.org/vlc,version=3.0.1 → D:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2018-02-27] (VideoLAN → VideoLAN)
              FF Plugin HKU\S-1-5-21-1925601759-1010797402-2804155008-1000: @zoom.us/ZoomVideoPlugin → C:\Users\Lenovo\AppData\Roaming\Zoom\bin\npzoomplu gin.dll [2017-11-14] (Zoom Video Communications, Inc. → Zoom Video Communications, Inc.)
              [HEADING=1]Chrome:[/HEADING]
              CHR DefaultProfile: Profile 1
              CHR DefaultSearchURL: Profile 1 → hxxps://boq.carolgames.com/assets/img/en_ns/new_favicon.ico
              CHR Profile: C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Profile 1 [2019-04-19]
              CHR Extension: (AdLock ad blocker) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\aemffjkmgcepimloclpkecifcnipnodh [2019-04-19]
              CHR Extension: (S70 Star Porch_Queen of Blade - Carol…) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\aibmialmanhplgcccnndpkophfoaaafj [2017-05-26]
              CHR Extension: (Google Docs Offline) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2018-08-21]
              CHR Extension: (AdBlock) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\gighmmpiobklfepjocnamgkkbiglidom [2019-04-19]
              CHR Extension: (Chrome Media Router) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Profile 1\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2019-04-08]
              CHR HKLM...\Chrome\Extension: [ngpampappnmepgilojfohadhhmbhlaek] - C:\Program Files (x86)\Internet Download Manager\IDMGCExt.crx
              [HEADING=1]Opera:[/HEADING]
              OPR Extension: (Adblock Plus - free ad blocker) - C:\Users\Lenovo\AppData\Roaming\Opera Software\Opera Stable\Extensions\oidhhegpmlfpoeialbgcdocjalghfpkp [2019-04-18]
              HKLM\SYSTEM\CurrentControlSet\Services\aswSP <==== ATTENTION (Rootkit!)
              HKLM\SYSTEM\CurrentControlSet\Services\aswMonFlt <==== ATTENTION (Rootkit!)
              S4 ACDaemon; C:\Program Files (x86)\Common Files\ArcSoft\Connection Service\Bin\ACService.exe [109056 2009-02-06] (ArcSoft, Inc. → ArcSoft Inc.)
              R2 AdaptiveSleepService; C:\Program Files\ATI Technologies\ATI.ACE\A4\AdaptiveSleepService.exe [138752 2016-06-28] () [File not signed]
              S3 AMD External Events Utility; C:\WINDOWS\system32\atiesrxx.exe [287264 2016-08-04] (Microsoft Windows Hardware Compatibility Publisher → AMD)
              R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2018-01-05] (Apple Inc. → Apple Inc.)
              R2 AUEPLauncher; C:\Program Files (x86)\AMD\Performance Profile Client\AUEPLauncher.exe [9216 2018-01-31] () [File not signed]
              S4 CLHNServiceForPowerDVD; C:\Program Files (x86)\CyberLink\PowerDVD11\Kernel\DMP\CLHNServiceF orPowerDVD.exe [83240 2011-04-20] (CyberLink → )
              S4 CyberLink PowerDVD 11.0 Monitor Service; C:\Program Files (x86)\CyberLink\PowerDVD11\Common\MediaServer\CLMS MonitorService.exe [70952 2011-03-31] (CyberLink → CyberLink)
              S4 CyberLink PowerDVD 11.0 Service; C:\Program Files (x86)\CyberLink\PowerDVD11\Common\MediaServer\CLMS Server.exe [312616 2011-03-31] (CyberLink → CyberLink)
              S3 dbupdate; C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [143144 2016-02-28] (Dropbox, Inc → Dropbox, Inc.)
              S3 dbupdatem; C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [143144 2016-02-28] (Dropbox, Inc → Dropbox, Inc.)
              S3 DbxSvc; C:\WINDOWS\system32\DbxSvc.exe [51024 2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
              R2 DSAService; C:\Program Files (x86)\Intel Driver and Support Assistant\DSAService.exe [22816 2018-03-15] (Intel(R) Driver & Support Assistant → Intel)
              S3 ESRV_SVC_QUEENCREEK; C:\Program Files\Intel\SUR\QUEENCREEK\esrv_svc.exe [805632 2016-11-17] (Intel(R) Software Development Products → )
              R2 ETDService; C:\Program Files\Elantech\ETDService.exe [144072 2015-10-07] (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.)
              R2 hshld; C:\Program Files (x86)\Hotspot Shield\bin\cmw_srv.exe [53120 2018-04-10] (AnchorFree Inc → AnchorFree Inc.)
              R2 IAStorDataMgrSvc; C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [15720 2013-11-21] (Intel Corporation - Intel® Rapid Storage Technology → Intel Corporation)
              S3 igfxCUIService2.0.0.0; C:\WINDOWS\system32\igfxCUIService.exe [373688 2017-06-12] (Intel(R) pGFX → Intel Corporation)
              R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520 2013-08-27] (Intel(R) Corporation) [File not signed]
              S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [828376 2013-08-27] (Intel® Trusted Connect Service → Intel(R) Corporation)
              S3 Intel(R) SUR QC SAM; C:\Program Files\Intel\SUR\QUEENCREEK\Updater\bin\IntelSoftwa reAssetManagerService.exe [18168 2017-07-13] (Intel(R) Software Asset Manager → Intel Corporation)
              S2 IObitUnSvr; C:\Program Files (x86)\IObit\IObit Uninstaller\IUService.exe [153360 2018-09-25] (IObit Information Technology → IObit)
              R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [169432 2013-09-16] (Intel Corporation - Intel® Management Engine Firmware → Intel Corporation)
              S3 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [6440736 2018-03-03] (Malwarebytes Corporation → Malwarebytes)
              R2 MSSQL$SQLEXPRESS; C:\Program Files\Microsoft SQL Server\MSSQL10.SQLEXPRESS\MSSQL\Binn\sqlservr.exe [57617752 2009-03-30] (Microsoft Corporation → Microsoft Corporation)
              R2 MySQL; C:\Program Files (x86)\MySQL\MySQL Server 5.0\my.ini [9263 2017-02-03] () [File not signed]
              S3 npggsvc; C:\WINDOWS\SysWOW64\GameMon.des [7780848 2017-11-29] (INCA Internet Co.,Ltd. → INCA Internet Co., Ltd.)
              R2 PlaysService; C:\Program Files (x86)\Raptr Inc\PlaysTV\plays_service.exe [32528 2016-08-10] (Plays.tv, LLC → Plays.tv, LLC)
              R2 QHActiveDefense; C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe [965184 2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
              S3 rpcapd; C:\Program Files (x86)\WinPcap\rpcapd.exe [118520 2013-03-01] (Riverbed Technology, Inc. → Riverbed Technology, Inc.)
              R2 RzKLService; D:\Program Files (x86)\Razer\Razer Game Booster\RzKLService.exe [105448 2013-11-22] (Razer Inc. → Razer Inc.)
              S3 Sense; C:\Program Files\Windows Defender Advanced Threat Protection\MsSense.exe [5074120 2019-03-15] (Microsoft Windows Publisher → Microsoft Corporation)
              S4 SQLAgent$SQLEXPRESS; C:\Program Files\Microsoft SQL Server\MSSQL10.SQLEXPRESS\MSSQL\Binn\SQLAGENT.EXE [427880 2009-03-30] (Microsoft Corporation → Microsoft Corporation)
              R2 TeamViewer; C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe [11795800 2019-04-15] (TeamViewer GmbH → TeamViewer GmbH)
              R2 TrueKey; C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.Service.exe [352688 2018-11-27] (McAfee, Inc. → McAfee, LLC.)
              R2 TrueKeyScheduler; C:\Program Files\McAfee\TrueKey\McTkSchedulerService.exe [352688 2018-11-27] (McAfee, Inc. → McAfee, LLC.)
              R2 TrueKeyServiceHelper; C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.ServiceHelper. exe [194168 2018-11-27] (McAfee, Inc. → McAfee, LLC.)
              S4 UDisk Monitor; D:\Program Files\Modem AC2726 UI\bin\MonServiceUDisk64.exe [407040 2009-09-23] () [File not signed]
              S3 USER_ESRV_SVC_QUEENCREEK; C:\Program Files\Intel\SUR\QUEENCREEK\esrv_svc.exe [805632 2016-11-17] (Intel(R) Software Development Products → )
              S3 VSStandardCollectorService140; D:\Program Files (x86)\Microsoft Visual Studio 14.0\Team Tools\DiagnosticsHub\Collector\StandardCollector.S ervice.exe [108776 2016-09-06] (Microsoft Corporation → Microsoft Corporation)
              S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [4413440 2019-03-14] (Microsoft Corporation → Microsoft Corporation)
              S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [107160 2019-02-16] (Microsoft Corporation → Microsoft Corporation)
              S3 WsDrvInst; C:\Program Files (x86)\Wondershare\Wondershare Video Converter Ultimate\Transfer\DriverInstall.exe [105064 2018-07-25] (Wondershare Technology Co.,Ltd → Wondershare)
              R2 WtuSystemSupport; C:\Program Files (x86)\AVG Web TuneUp\WtuSystemSupport.exe [980552 2016-10-02] (AVG Technologies CZ, s.r.o. → )
              R1 360AntiHacker; C:\WINDOWS\System32\Drivers\360AntiHacker64.sys [192600 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
              R3 360AvFlt; C:\WINDOWS\System32\DRIVERS\360AvFlt.sys [95232 2018-03-13] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
              R3 360AvFlt; C:\Windows\SysWOW64\DRIVERS\360AvFlt.sys [95232 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
              R1 360Box64; C:\WINDOWS\System32\DRIVERS\360Box64.sys [340568 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
              R1 360Camera; C:\WINDOWS\System32\Drivers\360Camera64.sys [57848 2018-03-13] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
              R1 360FsFlt; C:\WINDOWS\System32\DRIVERS\360FsFlt.sys [443992 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
              R1 360netmon; C:\WINDOWS\System32\DRIVERS\360netmon.sys [96424 2018-03-13] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
              R3 AFTrafMgr1.4; C:\Program Files (x86)\Hotspot Shield\bin\TrafMgr_1_4_64.sys [56840 2018-04-04] (AnchorFree Inc → AnchorFree Inc.)
              R3 amdkmdag; C:\WINDOWS\system32\DRIVERS\atikmdag.sys [26706464 2016-08-04] (Microsoft Windows Hardware Compatibility Publisher → Advanced Micro Devices, Inc.)
              R3 amdkmdap; C:\WINDOWS\system32\DRIVERS\atikmpag.sys [518176 2016-08-04] (Microsoft Windows Hardware Compatibility Publisher → Advanced Micro Devices, Inc.)
              R0 amdkmpfd; C:\WINDOWS\System32\drivers\amdkmpfd.sys [73976 2015-06-04] (Advanced Micro Devices, Inc. → Advanced Micro Devices, Inc.)
              R3 athr; C:\WINDOWS\System32\drivers\athw8x.sys [4233728 2018-04-12] (Microsoft Windows → Qualcomm Atheros Communications, Inc.)
              R1 BAPIDRV; C:\WINDOWS\System32\DRIVERS\BAPIDRV64.sys [211160 2018-12-21] (Beijing Qihu Technology Co., Ltd. → 360.cn)
              R3 BtFilter; C:\WINDOWS\system32\DRIVERS\btfilter.sys [610336 2016-07-13] (Microsoft Windows Hardware Compatibility Publisher → Qualcomm Atheros)
              S3 CYUSB3; C:\WINDOWS\System32\Drivers\CYUSB3.sys [90536 2018-08-12] (Cypress Semiconductor Corporation → Cypress Semiconductor)
              S3 GunBod; C:\WINDOWS\system32\gunbod64.sys [84384 2017-02-09] (Beijing Apex Weifeng Technology Co.,Ltd. → )
              R3 IUProcessFilter; C:\Program Files (x86)\IObit\IObit Uninstaller\drivers\win10_amd64\IUProcessFilter.sy s [37184 2018-10-16] (IObit Information Technology → IObit)
              R3 IURegistryFilter; C:\Program Files (x86)\IObit\IObit Uninstaller\drivers\win10_amd64\IURegistryFilter.s ys [43392 2018-10-16] (IObit Information Technology → IObit)
              S3 LGSHidFilt; C:\WINDOWS\system32\DRIVERS\LGSHidFilt.Sys [64280 2013-05-31] (Logitech → Logitech Inc.)
              R3 MEIx64; C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys [99288 2013-09-16] (Intel Corporation - Intel® Management Engine Firmware → Intel Corporation)
              S3 Netaapl; C:\WINDOWS\System32\drivers\netaapl64.sys [23040 2014-08-15] (Microsoft Windows Hardware Compatibility Publisher → Apple Inc.)
              R2 NPF; C:\WINDOWS\System32\drivers\npf.sys [36600 2013-03-01] (Riverbed Technology, Inc. → Riverbed Technology, Inc.)
              R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [886528 2015-07-22] (Realtek Semiconductor Corp → Realtek )
              R3 RTSUER; C:\WINDOWS\system32\Drivers\RtsUer.sys [410880 2015-07-03] (Realtek Semiconductor Corp → Realsil Semiconductor Corporation)
              R3 rtsuvc; C:\WINDOWS\system32\DRIVERS\rtsuvc.sys [3068160 2015-06-16] (Realtek Semiconductor Corp → Realtek Semiconductor Corp.)
              S3 rzendpt; C:\WINDOWS\System32\drivers\rzendpt.sys [50392 2015-08-14] (Razer Inc. → Razer Inc)
              S3 semav6msr64; C:\WINDOWS\system32\drivers\semav6msr64.sys [21984 2016-10-18] (Intel(R) Code Signing External → )
              R3 taphss6; C:\WINDOWS\System32\drivers\taphss6.sys [42064 2016-08-23] (AnchorFree Inc → Anchorfree Inc.)
              S3 USBAAPL64; C:\WINDOWS\System32\Drivers\usbaapl64.sys [54784 2015-06-17] (Microsoft Windows Hardware Compatibility Publisher → Apple, Inc.)
              S3 VBAudioVMVAIOMME; C:\WINDOWS\system32\DRIVERS\vbaudio_vmvaio64_win7. sys [41192 2015-11-07] (Vincent Burel → Windows (R) Win 7 DDK provider)
              S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44616 2018-04-12] (Microsoft Windows Early Launch Anti-malware Publisher → Microsoft Corporation)
              S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [331680 2018-04-12] (Microsoft Windows → Microsoft Corporation)
              S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [44032 2018-04-12] (Microsoft Windows → Microsoft Corporation)
              R2 WtfEngineDrv; C:\WINDOWS\system32\DRIVERS\WtfEngineDrv.sys [37872 2016-05-20] (Initex, OOO → AAA Internet Publishing, Inc.)
              R1 YSDrv; C:\Program Files (x86)\Bignox\BigNoxVM\RT\YSDrv.sys [270608 2017-12-21] (Beijing Duodian Online Science and Technology Co.,Ltd → BigNox Corporation)
              R2 {329F96B6-DF1E-4328-BFDA-39EA953C1312}; C:\Program Files (x86)\CyberLink\PowerDVD11\Common\NavFilter\000.fc l [148976 2011-04-12] (CyberLink → CyberLink Corp.)
              U3 aswbdisk; no ImagePath
              U3 idsvc; no ImagePath
              ==================== One month (created) ========
              2019-04-19 02:10 - 2019-04-19 02:13 - 000035979 _____ C:\Users\Lenovo\Downloads\FRST.txt
              2019-04-19 02:10 - 2019-04-19 02:10 - 002434048 _____ (Farbar) C:\Users\Lenovo\Downloads\FRST64.exe
              2019-04-19 02:10 - 2019-04-19 02:10 - 000000000 ____D C:\FRST
              2019-04-19 01:58 - 2019-04-19 01:58 - 037133296 _____ (Hankuper s.r.o.) C:\Users\Lenovo\Downloads\Adlock_Installer (2).exe
              2019-04-19 01:24 - 2019-04-19 01:24 - 037133296 _____ (Hankuper s.r.o.) C:\Users\Lenovo\Downloads\Adlock_Installer (1).exe
              2019-04-18 13:16 - 2019-04-19 01:40 - 000002338 _____ C:\Users\Public\Desktop\Google Chrome.lnk
              2019-04-18 13:16 - 2019-04-18 13:16 - 000002379 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
              2019-04-18 13:15 - 2019-04-18 13:16 - 000000000 ____D C:\Users\Lenovo\AppData\Local\Google clean
              2019-04-18 13:15 - 2019-04-18 13:15 - 000003416 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A
              2019-04-18 13:15 - 2019-04-18 13:15 - 000003292 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore
              2019-04-18 13:15 - 2019-04-18 13:15 - 000000000 ____D C:\Program Files (x86)\Google
              2019-04-18 12:52 - 2019-04-18 12:52 - 000030494 _____ C:\Users\Lenovo\Desktop\bookmarks_4_18_19.html
              2019-04-18 12:52 - 2019-04-18 12:52 - 000000000 ____D C:\WINDOWS\Tasks\ImCleanDisabled
              2019-04-18 12:50 - 2019-04-18 12:55 - 000000000 ____D C:\ProgramData\ProductData
              2019-04-18 12:50 - 2019-04-18 12:51 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\IObit
              2019-04-18 12:50 - 2019-04-18 12:50 - 000002950 _____ C:\WINDOWS\System32\Tasks\Uninstaller_SkipUac_Leno vo
              2019-04-18 12:49 - 2019-04-18 12:55 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\IObit
              2019-04-18 12:49 - 2019-04-18 12:54 - 000000000 ____D C:\ProgramData\IObit
              2019-04-18 12:49 - 2019-04-18 12:49 - 000001430 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IObit Uninstaller.lnk
              2019-04-18 12:49 - 2019-04-18 12:49 - 000001418 _____ C:\Users\Public\Desktop\IObit Uninstaller.lnk
              2019-04-18 12:49 - 2019-04-18 12:49 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IObit Uninstaller
              2019-04-18 12:49 - 2019-04-18 12:49 - 000000000 ____D C:\Program Files (x86)\IObit
              2019-04-18 12:48 - 2019-04-18 12:48 - 019349752 _____ (IObit ) C:\Users\Lenovo\Desktop\iobituninstaller.exe
              2019-04-18 12:30 - 2019-04-18 13:38 - 000000000 ____D C:\Program Files (x86)\TeamViewer
              2019-04-18 12:30 - 2019-04-18 12:30 - 000001118 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamViewer 14.lnk
              2019-04-18 12:30 - 2019-04-18 12:30 - 000001106 _____ C:\Users\Public\Desktop\TeamViewer 14.lnk
              2019-04-18 12:20 - 2019-04-18 12:20 - 022796808 _____ (TeamViewer GmbH) C:\Users\Lenovo\Desktop\TeamViewer_Setup.exe
              2019-04-18 12:13 - 2019-04-18 12:13 - 001214008 _____ (Google LLC) C:\Users\Lenovo\Desktop\ChromeSetup.exe
              2019-04-13 05:25 - 2019-04-13 05:25 - 000000077 _____ C:\WINDOWS\system32\Drivers\aswSP.sys.sum
              2019-04-10 09:53 - 2019-04-02 14:40 - 000534016 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vbscript.dll
              2019-04-10 09:53 - 2019-03-15 00:34 - 000127488 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxSysprep.dll
              2019-04-10 09:53 - 2019-03-14 18:17 - 002258944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssrch.dll
              2019-04-10 09:53 - 2019-03-14 18:17 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.d ll
              2019-04-10 09:53 - 2019-03-14 18:14 - 000345088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchProtocolHost.exe
              2019-04-10 09:53 - 2019-03-14 18:14 - 000138240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\smartscreenps.dll
              2019-04-10 09:53 - 2019-03-14 18:13 - 000145408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssph.dll
              2019-04-10 09:53 - 2019-03-14 17:58 - 000150016 _____ (Microsoft Corporation) C:\WINDOWS\system32\fcon.dll
              2019-04-10 09:53 - 2019-03-14 17:56 - 000055296 _____ (Microsoft Corporation) C:\WINDOWS\system32\msscntrs.dll
              2019-04-10 09:53 - 2019-03-14 17:54 - 000227328 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchFilterHost.exe
              2019-04-10 09:52 - 2019-04-02 22:38 - 000094008 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
              2019-04-10 09:52 - 2019-04-02 22:33 - 001634912 _____ (Microsoft Corporation) C:\WINDOWS\system32\gdi32full.dll
              2019-04-10 09:52 - 2019-04-02 22:33 - 000719984 _____ (Microsoft Corporation) C:\WINDOWS\system32\kernel32.dll
              2019-04-10 09:52 - 2019-04-02 22:19 - 012730880 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
              2019-04-10 09:52 - 2019-04-02 22:19 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\iemigplugin.dll
              2019-04-10 09:52 - 2019-04-02 22:18 - 000059904 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf3216.dll
              2019-04-10 09:52 - 2019-04-02 22:16 - 001030144 _____ (Microsoft Corporation) C:\WINDOWS\system32\termsrv.dll
              2019-04-10 09:52 - 2019-04-02 22:15 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\oleprn.dll
              2019-04-10 09:52 - 2019-04-02 22:13 - 001605632 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcorets.dll
              2019-04-10 09:52 - 2019-04-02 22:12 - 003643904 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
              2019-04-10 09:52 - 2019-04-02 22:12 - 001364992 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvruserservice.dll
              2019-04-10 09:52 - 2019-04-02 22:11 - 004053504 _____ (Microsoft Corporation) C:\WINDOWS\system32\msi.dll
              2019-04-10 09:52 - 2019-04-02 22:11 - 001857536 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml3.dll
              2019-04-10 09:52 - 2019-04-02 22:11 - 001662976 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
              2019-04-10 09:52 - 2019-04-02 22:10 - 000130048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\luafv.sys
              2019-04-10 09:52 - 2019-04-02 22:10 - 000033280 _____ (Microsoft Corporation) C:\WINDOWS\system32\sxssrv.dll
              2019-04-10 09:52 - 2019-04-02 19:25 - 001454648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gdi32full.dll
              2019-04-10 09:52 - 2019-04-02 19:25 - 000607960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kernel32.dll
              2019-04-10 09:52 - 2019-04-02 19:11 - 011919360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
              2019-04-10 09:52 - 2019-04-02 19:11 - 000046080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf3216.dll
              2019-04-10 09:52 - 2019-04-02 19:10 - 000117760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\oleprn.dll
              2019-04-10 09:52 - 2019-04-02 19:08 - 002889216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
              2019-04-10 09:52 - 2019-04-02 19:07 - 004054528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msi.dll
              2019-04-10 09:52 - 2019-04-02 19:07 - 001586688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml3.dll
              2019-04-10 09:52 - 2019-04-02 19:06 - 001470976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
              2019-04-10 09:52 - 2019-04-02 18:36 - 001035256 _____ (Microsoft Corporation) C:\WINDOWS\system32\ApplyTrustOffline.exe
              2019-04-10 09:52 - 2019-04-02 18:24 - 000135184 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.dll
              2019-04-10 09:52 - 2019-04-02 18:23 - 001023800 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
              2019-04-10 09:52 - 2019-04-02 18:22 - 001219896 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
              2019-04-10 09:52 - 2019-04-02 18:22 - 000567592 _____ (Microsoft Corporation) C:\WINDOWS\system32\tcblaunch.exe
              2019-04-10 09:52 - 2019-04-02 18:22 - 000076088 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hvservice.sys
              2019-04-10 09:52 - 2019-04-02 18:21 - 007520136 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayR eady.dll
              2019-04-10 09:52 - 2019-04-02 18:21 - 002822160 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
              2019-04-10 09:52 - 2019-04-02 18:21 - 002467536 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml6.dll
              2019-04-10 09:52 - 2019-04-02 18:21 - 000735680 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
              2019-04-10 09:52 - 2019-04-02 18:20 - 002719032 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
              2019-04-10 09:52 - 2019-04-02 18:20 - 000412984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
              2019-04-10 09:52 - 2019-04-02 18:19 - 009083704 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
              2019-04-10 09:52 - 2019-04-02 18:19 - 000793400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
              2019-04-10 09:52 - 2019-04-02 18:19 - 000786080 _____ (Microsoft Corporation) C:\WINDOWS\system32\oleaut32.dll
              2019-04-10 09:52 - 2019-04-02 18:19 - 000713272 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVideoDSP.dll
              2019-04-10 09:52 - 2019-04-02 18:01 - 025857536 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
              2019-04-10 09:52 - 2019-04-02 17:53 - 022717440 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
              2019-04-10 09:52 - 2019-04-02 17:53 - 004384256 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeContent.dll
              2019-04-10 09:52 - 2019-04-02 17:51 - 003399680 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
              2019-04-10 09:52 - 2019-04-02 17:50 - 007591936 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
              2019-04-10 09:52 - 2019-04-02 17:50 - 000808448 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeManager.dll
              2019-04-10 09:52 - 2019-04-02 17:49 - 001307648 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVPXENC.dll
              2019-04-10 09:52 - 2019-04-02 17:49 - 000209408 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXApplicabilityBlob.dll
              2019-04-10 09:52 - 2019-04-02 17:48 - 001559552 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.deskt op.dll
              2019-04-10 09:52 - 2019-04-02 17:48 - 000310272 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbt.sys
              2019-04-10 09:52 - 2019-04-02 17:48 - 000154112 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
              2019-04-10 09:52 - 2019-04-02 17:47 - 001214464 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcore.dll
              2019-04-10 09:52 - 2019-04-02 17:47 - 000894464 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
              2019-04-10 09:52 - 2019-04-02 17:46 - 002174976 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.oneco re.dll
              2019-04-10 09:52 - 2019-04-02 17:45 - 000323584 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxAllUserStore.dll
              2019-04-10 09:52 - 2019-04-02 17:44 - 002208768 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
              2019-04-10 09:52 - 2019-04-02 17:44 - 001724416 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpserverbase.dll
              2019-04-10 09:52 - 2019-04-02 17:44 - 001421312 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpbase.dll
              2019-04-10 09:52 - 2019-04-02 17:43 - 000542720 _____ (Microsoft Corporation) C:\WINDOWS\system32\vbscript.dll
              2019-04-10 09:52 - 2019-04-02 16:22 - 000001312 _____ C:\WINDOWS\system32\tcbres.wim
              2019-04-10 09:52 - 2019-04-02 15:05 - 001989544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml6.dll
              2019-04-10 09:52 - 2019-04-02 15:04 - 006572120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayR eady.dll
              2019-04-10 09:52 - 2019-04-02 15:04 - 000604008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\oleaut32.dll
              2019-04-10 09:52 - 2019-04-02 15:04 - 000581832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVideoDSP.dll
              2019-04-10 09:52 - 2019-04-02 15:04 - 000560600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
              2019-04-10 09:52 - 2019-04-02 14:56 - 022018048 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
              2019-04-10 09:52 - 2019-04-02 14:50 - 019404800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
              2019-04-10 09:52 - 2019-04-02 14:43 - 005788160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
              2019-04-10 09:52 - 2019-04-02 14:43 - 000608768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EdgeManager.dll
              2019-04-10 09:52 - 2019-04-02 14:43 - 000578560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webplatstorageserver.dll
              2019-04-10 09:52 - 2019-04-02 14:42 - 001295360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVPXENC.dll
              2019-04-10 09:52 - 2019-04-02 14:41 - 001540096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpserverbase.dll
              2019-04-10 09:52 - 2019-04-02 14:41 - 001235968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpbase.dll
              2019-04-10 09:52 - 2019-04-02 14:41 - 000230912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxAllUserStore.dll
              2019-04-10 09:52 - 2019-04-02 14:40 - 001073664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpcore.dll
              2019-04-10 09:52 - 2019-03-16 22:54 - 001008640 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.MixedRealityCapt ure.dll
              2019-04-10 09:52 - 2019-03-16 19:03 - 000868864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.MixedRealityCapt ure.dll
              2019-04-10 09:52 - 2019-03-15 00:55 - 001786680 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntVirtualization.dll
              2019-04-10 09:52 - 2019-03-15 00:53 - 001626928 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVIntegration.dll
              2019-04-10 09:52 - 2019-03-15 00:53 - 001038136 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVPolicy.dll
              2019-04-10 09:52 - 2019-03-15 00:53 - 000652088 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVPublishing.dll
              2019-04-10 09:52 - 2019-03-15 00:53 - 000400696 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVScripting.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 003933296 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
              2019-04-10 09:52 - 2019-03-15 00:52 - 001424696 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntSubsystemController.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 000954160 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVManifest.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 000830264 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVOrchestration.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 000827704 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVClient.exe
              2019-04-10 09:52 - 2019-03-15 00:52 - 000825144 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntStreamingManager.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 000749880 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVReporting.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 000670008 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVCatalog.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 000495416 _____ (Microsoft Corporation) C:\WINDOWS\system32\TransportDSA.dll
              2019-04-10 09:52 - 2019-03-15 00:52 - 000164664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\AppvVemgr.sys
              2019-04-10 09:52 - 2019-03-15 00:51 - 000157192 _____ (Microsoft Corporation) C:\WINDOWS\system32\consent.exe
              2019-04-10 09:52 - 2019-03-15 00:35 - 000011776 _____ (Microsoft Corporation) C:\WINDOWS\system32\appinfoext.dll
              2019-04-10 09:52 - 2019-03-15 00:33 - 000182784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rdpdr.sys
              2019-04-10 09:52 - 2019-03-15 00:33 - 000082432 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storqosflt.sys
              2019-04-10 09:52 - 2019-03-15 00:33 - 000030208 _____ (Microsoft Corporation) C:\WINDOWS\system32\RpcPing.exe
              2019-04-10 09:52 - 2019-03-15 00:31 - 000198656 _____ (Microsoft Corporation) C:\WINDOWS\system32\wincredui.dll
              2019-04-10 09:52 - 2019-03-15 00:30 - 000675328 _____ (Microsoft Corporation) C:\WINDOWS\system32\objsel.dll
              2019-04-10 09:52 - 2019-03-15 00:30 - 000440832 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppBroker.dll
              2019-04-10 09:52 - 2019-03-15 00:29 - 000882688 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmartcardCredentialProvider.dl l
              2019-04-10 09:52 - 2019-03-15 00:29 - 000727040 _____ (Microsoft Corporation) C:\WINDOWS\system32\cscsvc.dll
              2019-04-10 09:52 - 2019-03-15 00:28 - 000560640 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsound.dll
              2019-04-10 09:52 - 2019-03-15 00:08 - 003611264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
              2019-04-10 09:52 - 2019-03-14 23:56 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wincredui.dll
              2019-04-10 09:52 - 2019-03-14 23:55 - 000026624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RpcPing.exe
              2019-04-10 09:52 - 2019-03-14 23:53 - 000625664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SmartcardCredentialProvider.dl l
              2019-04-10 09:52 - 2019-03-14 23:53 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\objsel.dll
              2019-04-10 09:52 - 2019-03-14 23:53 - 000375808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppBroker.dll
              2019-04-10 09:52 - 2019-03-14 23:52 - 000502784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dsound.dll
              2019-04-10 09:52 - 2019-03-14 18:57 - 000611640 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\spaceport.sys
              2019-04-10 09:52 - 2019-03-14 18:56 - 000375096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pci.sys
              2019-04-10 09:52 - 2019-03-14 18:38 - 000380728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msv1_0.dll
              2019-04-10 09:52 - 2019-03-14 18:38 - 000090360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mpr.dll
              2019-04-10 09:52 - 2019-03-14 18:37 - 006043496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
              2019-04-10 09:52 - 2019-03-14 18:37 - 002256248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
              2019-04-10 09:52 - 2019-03-14 18:37 - 001171568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ucrtbase.dll
              2019-04-10 09:52 - 2019-03-14 18:28 - 000152072 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wcifs.sys
              2019-04-10 09:52 - 2019-03-14 18:27 - 000436024 _____ (Microsoft Corporation) C:\WINDOWS\system32\msv1_0.dll
              2019-04-10 09:52 - 2019-03-14 18:27 - 000097600 _____ (Microsoft Corporation) C:\WINDOWS\system32\mpr.dll
              2019-04-10 09:52 - 2019-03-14 18:26 - 007436016 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
              2019-04-10 09:52 - 2019-03-14 18:26 - 002768448 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
              2019-04-10 09:52 - 2019-03-14 18:26 - 002421048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
              2019-04-10 09:52 - 2019-03-14 18:26 - 001457576 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
              2019-04-10 09:52 - 2019-03-14 18:26 - 001258688 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
              2019-04-10 09:52 - 2019-03-14 18:26 - 001140984 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
              2019-04-10 09:52 - 2019-03-14 18:26 - 001014344 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase.dll
              2019-04-10 09:52 - 2019-03-14 18:26 - 000983424 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
              2019-04-10 09:52 - 2019-03-14 18:26 - 000481048 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase_enclave.dll
              2019-04-10 09:52 - 2019-03-14 18:26 - 000175416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\spacedump.sys
              2019-04-10 09:52 - 2019-03-14 18:22 - 002700288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
              2019-04-10 09:52 - 2019-03-14 18:20 - 006661632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
              2019-04-10 09:52 - 2019-03-14 18:19 - 003711488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
              2019-04-10 09:52 - 2019-03-14 18:19 - 002969600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cdp.dll
              2019-04-10 09:52 - 2019-03-14 18:18 - 005307392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
              2019-04-10 09:52 - 2019-03-14 18:18 - 000095744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserDataTimeUtil.dll
              2019-04-10 09:52 - 2019-03-14 18:18 - 000035840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\credui.dll
              2019-04-10 09:52 - 2019-03-14 18:18 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tzres.dll
              2019-04-10 09:52 - 2019-03-14 18:17 - 000561152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9diag.dll
              2019-04-10 09:52 - 2019-03-14 18:17 - 000261632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dhcpcore6.dll
              2019-04-10 09:52 - 2019-03-14 18:17 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wcmapi.dll
              2019-04-10 09:52 - 2019-03-14 18:17 - 000057344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntlanman.dll
              2019-04-10 09:52 - 2019-03-14 18:16 - 000392192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\daxexec.dll
              2019-04-10 09:52 - 2019-03-14 18:16 - 000333824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgeIso.dll
              2019-04-10 09:52 - 2019-03-14 18:15 - 000415744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\schannel.dll
              2019-04-10 09:52 - 2019-03-14 18:15 - 000318464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dhcpcore.dll
              2019-04-10 09:52 - 2019-03-14 18:15 - 000195072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ShellCommonCommonProxyStub.dll
              2019-04-10 09:52 - 2019-03-14 18:15 - 000102400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\negoexts.dll
              2019-04-10 09:52 - 2019-03-14 18:14 - 001070080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aadtb.dll
              2019-04-10 09:52 - 2019-03-14 18:14 - 000856576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchIndexer.exe
              2019-04-10 09:52 - 2019-03-14 18:14 - 000735744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssvp.dll
              2019-04-10 09:52 - 2019-03-14 18:14 - 000330752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Graphics.Printing.Work flow.dll
              2019-04-10 09:52 - 2019-03-14 18:14 - 000251904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
              2019-04-10 09:52 - 2019-03-14 18:13 - 001468416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
              2019-04-10 09:52 - 2019-03-14 18:13 - 000669696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript.dll
              2019-04-10 09:52 - 2019-03-14 18:01 - 008188928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
              2019-04-10 09:52 - 2019-03-14 17:58 - 004708864 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdp.dll
              2019-04-10 09:52 - 2019-03-14 17:58 - 002509824 _____ (Microsoft Corporation) C:\WINDOWS\system32\smartscreen.exe
              2019-04-10 09:52 - 2019-03-14 17:57 - 004866560 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
              2019-04-10 09:52 - 2019-03-14 17:57 - 000106496 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationControllerPS.dll
              2019-04-10 09:52 - 2019-03-14 17:56 - 003392000 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
              2019-04-10 09:52 - 2019-03-14 17:56 - 000144384 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
              2019-04-10 09:52 - 2019-03-14 17:56 - 000120320 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataTimeUtil.dll
              2019-04-10 09:52 - 2019-03-14 17:56 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\system32\tzres.dll
              2019-04-10 09:52 - 2019-03-14 17:55 - 003601920 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Service.dl l
              2019-04-10 09:52 - 2019-03-14 17:55 - 002739200 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssrch.dll
              2019-04-10 09:52 - 2019-03-14 17:55 - 000528896 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\nwifi.sys
              2019-04-10 09:52 - 2019-03-14 17:55 - 000458752 _____ (Microsoft Corporation) C:\WINDOWS\system32\cloudAP.dll
              2019-04-10 09:52 - 2019-03-14 17:55 - 000414720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cldflt.sys
              2019-04-10 09:52 - 2019-03-14 17:55 - 000141312 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppointmentActivation.dll
              2019-04-10 09:52 - 2019-03-14 17:55 - 000134656 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmapi.dll
              2019-04-10 09:52 - 2019-03-14 17:55 - 000099328 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActiveSyncCsp.dll
              2019-04-10 09:52 - 2019-03-14 17:55 - 000069120 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntlanman.dll
              2019-04-10 09:52 - 2019-03-14 17:55 - 000062976 _____ (Microsoft Corporation) C:\WINDOWS\system32\EASPolicyManagerBrokerHost.exe
              2019-04-10 09:52 - 2019-03-14 17:55 - 000048640 _____ (Microsoft Corporation) C:\WINDOWS\system32\credui.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 002368000 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebRuntimeManager.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000566784 _____ (Microsoft Corporation) C:\WINDOWS\system32\daxexec.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000395776 _____ (Microsoft Corporation) C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.d ll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000354304 _____ (Microsoft Corporation) C:\WINDOWS\system32\dhcpcore.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000279552 _____ (Microsoft Corporation) C:\WINDOWS\system32\dhcpcore6.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000273408 _____ (Microsoft Corporation) C:\WINDOWS\system32\ubpm.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000231936 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmcsp.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000118784 _____ (Microsoft Corporation) C:\WINDOWS\system32\negoexts.dll
              2019-04-10 09:52 - 2019-03-14 17:54 - 000110592 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcpopkeysrv.dll
              2019-04-10 09:52 - 2019-03-14 17:53 - 000787968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\WdiWiFi.sys
              2019-04-10 09:52 - 2019-03-14 17:53 - 000726528 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
              2019-04-10 09:52 - 2019-03-14 17:53 - 000473600 _____ (Microsoft Corporation) C:\WINDOWS\system32\schannel.dll
              2019-04-10 09:52 - 2019-03-14 17:53 - 000456192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Graphics.Printing.Work flow.dll
              2019-04-10 09:52 - 2019-03-14 17:52 - 002909696 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
              2019-04-10 09:52 - 2019-03-14 17:52 - 000532992 _____ (Microsoft Corporation) C:\WINDOWS\system32\QuietHours.dll
              2019-04-10 09:52 - 2019-03-14 17:52 - 000404480 _____ (Microsoft Corporation) C:\WINDOWS\system32\ShellCommonCommonProxyStub.dll
              2019-04-10 09:52 - 2019-03-14 17:52 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\smartscreenps.dll
              2019-04-10 09:52 - 2019-03-14 17:51 - 001216000 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationController.dll
              2019-04-10 09:52 - 2019-03-14 17:51 - 001058304 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchIndexer.exe
              2019-04-10 09:52 - 2019-03-14 17:51 - 000226304 _____ (Microsoft Corporation) C:\WINDOWS\system32\TetheringMgr.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 001587712 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 001410560 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadtb.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 000947200 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmsvc.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 000847360 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 000796672 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssvp.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 000776192 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 000507392 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgeIso.dll
              2019-04-10 09:52 - 2019-03-14 17:50 - 000406528 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchProtocolHost.exe
              2019-04-10 09:52 - 2019-03-14 17:50 - 000176640 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssph.dll
              2019-04-10 09:52 - 2019-03-14 11:57 - 001311744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjet40.dll
              2019-04-10 09:52 - 2019-03-14 11:57 - 000475648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxbde40.dll
              2019-04-10 09:52 - 2019-03-14 11:57 - 000375808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspbde40.dll
              2019-04-10 09:52 - 2019-03-14 11:57 - 000352768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd3x40.dll
              2019-04-10 09:52 - 2019-03-14 11:57 - 000340992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msexcl40.dll
              2019-04-09 03:02 - 2019-04-09 03:02 - 000000000 ____D C:\ProgramData\Hankuper
              2019-04-09 03:02 - 2019-04-09 03:02 - 000000000 ____D C:\Program Files\AdLock
              2019-04-09 02:58 - 2019-04-09 02:58 - 036153840 _____ (Hankuper s.r.o.) C:\Users\Lenovo\Downloads\Adlock_Installer.exe
              2019-04-09 00:08 - 2019-04-09 00:08 - 003976665 _____ C:\Users\Lenovo\Downloads\Mega Man Battle Network 2 (USA).zip
              2019-04-09 00:06 - 2019-04-09 00:06 - 000001600 _____ C:\Users\Lenovo\Desktop\Continue Megaman Battle Network Installation.lnk
              2019-04-09 00:05 - 2019-04-09 00:06 - 002134624 _____ ( ) C:\Users\Lenovo\Downloads\Megaman Battle Network_0322712152.exe
              2019-04-06 18:30 - 2019-04-06 18:30 - 000364952 _____ C:\Users\Lenovo\Downloads\download.pdf
              2019-04-05 11:04 - 2019-04-05 11:04 - 000192384 _____ C:\Users\Lenovo\Downloads\9299 (1) (1).pdf
              2019-04-05 11:02 - 2019-04-05 11:02 - 000182444 _____ C:\Users\Lenovo\Downloads\9299 (1).pdf
              2019-04-05 11:00 - 2019-04-05 11:00 - 000182444 _____ C:\Users\Lenovo\Downloads\929 (1).pdf
              2019-04-05 10:00 - 2019-04-05 10:00 - 000338279 _____ C:\Users\Lenovo\Downloads\form 80 2015-2019(1) (1)[1145].pdf
              2019-04-01 15:19 - 2019-04-01 15:19 - 000182444 _____ C:\Users\Lenovo\Downloads\929.pdf
              2019-04-01 15:01 - 2019-04-01 15:01 - 000233489 _____ C:\Users\Lenovo\Downloads\form 80 2015-2019(1) (1).pdf
              2019-03-31 01:33 - 2019-03-31 01:33 - 000000000 ____D C:\Users\Lenovo\Downloads\New folder
              2019-03-27 12:24 - 2019-03-27 12:24 - 000233489 _____ C:\Users\Lenovo\Downloads\form 80 2015-2019(1).pdf
              2019-03-25 13:27 - 2019-03-25 13:27 - 000063894 _____ C:\Users\Lenovo\Downloads\Albert - Akta lahir.pdf
              2019-03-25 13:02 - 2019-03-25 13:02 - 001771175 _____ C:\Users\Lenovo\Downloads\Statement20181231.pdf
              2019-03-25 13:01 - 2019-03-25 13:01 - 000116172 _____ C:\Users\Lenovo\Downloads\scoreReport (2).pdf
              2019-03-21 23:11 - 2019-03-23 15:36 - 000000000 ____D C:\ProgramData\Stardock
              2019-03-21 23:11 - 2019-03-21 23:11 - 000000000 ____D C:\Users\Lenovo\AppData\Local\Stardock
              2019-03-21 23:10 - 2019-03-21 23:10 - 000000000 ____D C:\Users\Lenovo\Documents\My Games
              2019-03-21 23:10 - 2019-03-21 23:10 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\MohawkGames
              2019-03-21 15:57 - 2019-03-21 15:57 - 000000202 _____ C:\Users\Lenovo\Desktop\Offworld Trading Company.url
              2019-03-20 14:46 - 2019-03-20 14:46 - 000085072 _____ C:\Users\Lenovo\Downloads\Unconfirmed 583584.crdownload
              ==================== One month (modified) ========
              2019-04-19 02:08 - 2018-04-12 09:38 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
              2019-04-19 01:45 - 2018-03-22 23:45 - 000000410 __RSH C:\ProgramData\ntuser.pol
              2019-04-19 00:28 - 2018-03-22 21:37 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\360WD
              2019-04-19 00:20 - 2014-12-30 12:34 - 000000000 ____D C:\Users\Lenovo\AppData\Local\CrashDumps
              2019-04-18 18:51 - 2018-05-26 17:01 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
              2019-04-18 15:45 - 2017-12-30 07:35 - 000000000 ____D C:\Users\Lenovo\AppData\Local\Packages
              2019-04-18 15:40 - 2016-12-21 04:23 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\Mozilla
              2019-04-18 13:26 - 2017-10-16 00:08 - 000000000 ____D C:\ProgramData\Package Cache
              2019-04-18 13:26 - 2017-05-27 00:44 - 000000000 ____D C:\ProgramData\Adguard
              2019-04-18 13:26 - 2017-05-27 00:43 - 000000000 ____D C:\Program Files (x86)\Adguard
              2019-04-18 12:32 - 2015-09-12 20:58 - 000000000 ____D C:\Users\Lenovo\AppData\Local\TeamViewer
              2019-04-18 12:30 - 2018-05-26 17:10 - 000000000 ____D C:\Users\DefaultAppPool
              2019-04-18 12:30 - 2015-09-12 20:45 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\TeamViewer
              2019-04-18 10:55 - 2018-03-22 21:37 - 000000000 ____D C:\ProgramData\360safe
              2019-04-18 10:36 - 2018-12-14 16:35 - 000001082 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ragnarok M -MuMu App Player.lnk
              2019-04-18 10:36 - 2018-03-22 22:05 - 000000000 ____D C:\ProgramData\360Quarant
              2019-04-18 10:28 - 2018-03-22 21:37 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\360safe
              2019-04-18 10:22 - 2018-05-26 17:40 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
              2019-04-18 10:21 - 2018-04-12 07:04 - 000524288 _____ C:\WINDOWS\system32\config\BBI
              2019-04-18 10:21 - 2018-03-22 21:37 - 000000000 _RSHD C:\360SANDBOX
              2019-04-18 10:20 - 2018-05-26 17:10 - 000000000 ____D C:\Users\Lenovo
              2019-04-18 10:14 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\system32\NDF
              2019-04-18 03:58 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\AppReadiness
              2019-04-18 03:57 - 2018-03-24 19:05 - 000000428 _____ C:\WINDOWS\Tasks\Driver Easy Scheduled Scan.job
              2019-04-18 03:50 - 2019-02-16 23:48 - 000003752 _____ C:\WINDOWS\System32\Tasks\Opera scheduled assistant Autoupdate 1550324909
              2019-04-18 03:50 - 2018-05-26 17:40 - 000003752 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player NPAPI Notifier
              2019-04-18 03:50 - 2018-05-26 17:40 - 000003556 _____ C:\WINDOWS\System32\Tasks\Driver Easy Scheduled Scan
              2019-04-18 03:50 - 2018-05-26 17:40 - 000002970 _____ C:\WINDOWS\System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132
              2019-04-18 03:50 - 2018-05-26 17:40 - 000002646 _____ C:\WINDOWS\System32\Tasks\McAfee Remediation (Prepare)
              2019-04-18 03:50 - 2018-05-26 17:40 - 000002604 _____ C:\WINDOWS\System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132-Logon
              2019-04-18 03:50 - 2018-05-26 17:40 - 000002220 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
              2019-04-18 03:50 - 2018-05-26 17:40 - 000002202 _____ C:\WINDOWS\System32\Tasks\StartCN
              2019-04-18 03:48 - 2019-03-18 21:26 - 000000000 ____D C:\WINDOWS\System32\Tasks\Avast Software
              2019-04-18 01:12 - 2017-09-28 20:12 - 000061060 _____ C:\Users\Lenovo\Desktop\Share.xlsx
              2019-04-17 19:52 - 2018-04-12 09:38 - 000000000 ___HD C:\Program Files\WindowsApps
              2019-04-16 13:23 - 2018-12-26 22:02 - 000019344 _____ C:\Users\Lenovo\Desktop\Mascot-202-RENT.xlsx
              2019-04-13 19:26 - 2016-09-22 12:11 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\vlc
              2019-04-13 05:25 - 2019-03-18 21:25 - 000476264 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\asw1af7b8ca475981fe.tm p
              2019-04-12 12:56 - 2018-03-25 06:00 - 000000000 ____D C:\Program Files (x86)\Intel Driver and Support Assistant
              2019-04-12 03:45 - 2018-05-27 10:37 - 000503220 _____ C:\WINDOWS\system32\perfh011.dat
              2019-04-12 03:45 - 2018-05-27 10:37 - 000145096 _____ C:\WINDOWS\system32\perfc011.dat
              2019-04-12 03:45 - 2018-05-26 17:09 - 001571872 _____ C:\WINDOWS\system32\PerfStringBackup.INI
              2019-04-12 03:45 - 2018-04-12 09:36 - 000000000 ____D C:\WINDOWS\INF
              2019-04-12 02:47 - 2018-03-22 21:47 - 000001443 _____ C:\Users\Lenovo\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs\Opera Browser.lnk
              2019-04-11 18:06 - 2018-03-22 21:38 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\360TotalSecurity
              2019-04-11 17:51 - 2018-08-15 17:42 - 005199288 _____ C:\WINDOWS\system32\FNTCACHE.DAT
              2019-04-11 17:47 - 2018-04-12 19:20 - 000000000 ____D C:\Program Files\Windows Defender Advanced Threat Protection
              2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ___RD C:\Program Files\Windows Defender
              2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\TextInput
              2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\PolicyDefinitions
              2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\bcastdvr
              2019-04-10 10:03 - 2018-04-12 09:30 - 000000000 ____D C:\WINDOWS\CbsTemp
              2019-04-10 09:51 - 2015-03-13 02:43 - 000000000 ____D C:\WINDOWS\system32\MRT
              2019-04-10 09:44 - 2015-03-13 02:42 - 131129288 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
              2019-04-09 00:05 - 2018-03-22 22:30 - 000000000 __SHD C:$360Section
              2019-04-07 23:23 - 2018-03-22 21:48 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\360DrvMgr
              2019-04-05 21:35 - 2017-09-29 19:45 - 000000000 ____D C:\Program Files\rempl
              2019-04-02 03:51 - 2018-11-18 11:45 - 000835480 _____ (Adobe) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
              2019-04-02 03:51 - 2018-11-18 11:45 - 000179608 _____ (Adobe) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
              2019-03-26 08:20 - 2019-02-19 10:38 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Daum
              2019-03-26 07:28 - 2019-03-18 21:25 - 000004264 _____ C:\WINDOWS\System32\Tasks\Avast Emergency Update
              2019-03-21 15:57 - 2017-08-11 00:34 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs\Steam
              2017-05-27 00:44 - 2018-06-15 09:49 - 000000267 _____ () C:\ProgramData\fontcacheev1.dat
              2018-08-13 21:01 - 2018-06-14 21:01 - 000000032 ____R () C:\ProgramData\hash.dat
              2015-10-04 11:52 - 2015-10-04 11:52 - 000000102 _____ () C:\ProgramData{262E20B8-6E20-4CEF-B1FD-D022AB1085F5}.dat
              2015-10-04 11:58 - 2015-10-04 11:58 - 000000097 _____ () C:\Users\Lenovo\AppData\Roaming\settings.xml
              2015-04-25 14:16 - 2015-04-25 14:16 - 000000054 _____ () C:\Users\Lenovo\AppData\Roaming\updater.cfg
              2015-11-09 13:55 - 2015-11-30 19:16 - 000002856 _____ () C:\Users\Lenovo\AppData\Roaming\VoiceMeeterDefault .xml
              2016-09-23 11:37 - 2017-01-05 11:54 - 000000202 _____ () C:\Users\Lenovo\AppData\Roaming_encryptiondb.grf
              2014-11-26 19:09 - 2014-11-26 19:09 - 000000038 ___SH () C:\Users\Lenovo\AppData\Local\1754111884ee9ab5277c a00.95260103
              2014-12-26 00:02 - 2016-06-26 16:10 - 000007603 _____ () C:\Users\Lenovo\AppData\Local\Resmon.ResmonCfg
              [HEADING=1]Some files in TEMP:[/HEADING]
              2018-12-14 16:18 - 2018-12-14 16:18 - 005148112 _____ () C:\Users\Lenovo\AppData\Local\Temp\aria2c.exe
              2018-08-06 08:50 - 2018-08-06 08:50 - 037432936 _____ (Ellora Assets Corporation ) C:\Users\Lenovo\AppData\Local\Temp\FreemakeVideoCo nverterFull.exe
              2019-04-09 00:06 - 2019-04-09 00:06 - 002134624 _____ ( ) C:\Users\Lenovo\AppData\Local\Temp\Megaman Battle Network_0322712152.exe
              2018-12-14 16:19 - 2018-12-14 16:31 - 475120432 _____ (网易游戏) C:\Users\Lenovo\AppData\Local\Temp\nemu-2.0.23.1-overseas-1029172337.exe
              2018-08-17 00:57 - 2018-08-17 00:57 - 002170368 _____ (Opera Software) C:\Users\Lenovo\AppData\Local\Temp\Opera_installer _18081614571768111980.dll
              2018-11-14 16:47 - 2018-11-14 16:47 - 002766848 _____ (Opera Software) C:\Users\Lenovo\AppData\Local\Temp\Opera_installer _18111406473400016512.dll
              2019-03-18 21:23 - 2019-03-18 21:23 - 002128432 _____ ( ) C:\Users\Lenovo\AppData\Local\Temp\Pokemon- Fire Red Version_2090929492.exe
              C:\WINDOWS\system32\dllhost.exe => File is digitally signed
              C:\WINDOWS\SysWOW64\dllhost.exe => File is digitally signed
              LastRegBack: 2018-05-26 17:01
              • jmarket
                PCHF Owner
                • 7695
                • CachyOS
                • Intel Arc A770 (16 GB)
                We will need a log from AdwCleaner for further information.
                Please go HERE and download AdwCleaner to your Desktop. Once downloaded right click the new icon and select Run as Administrator from the context menu to open the program. It will open at the Dashboard tab and no further changes to the program are necessary at this stage.
                Click the Scan Now button.
                [IMG alt="oklj3amfOpqEpPVXnuqk79lHRApDnhPQVXn6z6Y3NoRuE Owdc4_mOGQu11P43d4Fb8OGSEeDJ_AsebIM9FWRakQeH_rBtmE r8_ua1VJwBd_Ws3-miUSngeShjQ7W5K4p6SytCWs2=w2400" width="627px" height="401px"]https://lh3.googleusercontent.com/oklj3amfOpqEpPVXnuqk79lHRApDnhPQVXn6z6Y3NoRuEOwdc4 _mOGQu11P43d4Fb8OGSEeDJ_AsebIM9FWRakQeH_rBtmEr8_ua 1VJwBd_Ws3-miUSngeShjQ7W5K4p6SytCWs2=w2400[/IMG]
                Allow AdwCleaner to start scanning and depending on the amount of data on your PC it may take some time. At the conclusion of the scan any content considered unnecessary will be displayed in the Scan Results box. Ensure all items are selected for removal and click “Clean & Repair”
                [IMG alt="7pQdUft-ojpPn88OGfzif4Zs2nG7cOkKWXOxq2hnIP5ll37IPbMzLUh9W3 aC0wQonD-NEIwql19Hh7DJiYPOF1HL71bdqy81MiaqpcsP5f0JtykiLSk-l96KByQKj1ou2rexlOpo=w2400" width="627px" height="401px"]https://lh3.googleusercontent.com/7pQdUft-ojpPn88OGfzif4Zs2nG7cOkKWXOxq2hnIP5ll37IPbMzLUh9W3 aC0wQonD-NEIwql19Hh7DJiYPOF1HL71bdqy81MiaqpcsP5f0JtykiLSk-l96KByQKj1ou2rexlOpo=w2400[/IMG]
                After selecting “Clean & Repair” another dialogue box may appear asking to restart now or later. If so choose “Clean & Restart Now”
                Once the PC has restarted if AdwCleaner does not restart then open it again and click “Log Files” tab on the left. All log files will be listed. If you have used the program previously you may have several logs to select from so double click the most recent “Clean” log and it will open a notepad file on your Desktop.
                Please COPY and PASTE the contents of that file in your next post
                Download ResetBrowser to your desktop.
                Now close all open browsers. All browsers MUST be closed during this operation!
                Right click and Run as Administrator
                Click on Reset Chrome– Allow completion.
                Click on Reset Firefox– Allow completion.
                Click on Reset Internet Explorer– Allow completion.
                Now reboot your machine.
                • Baroona
                  • Apr 2019
                  • 27
                  [HEADING=1]-------------------------------[/HEADING]
                  [HEADING=1]Malwarebytes AdwCleaner 7.3.0.0[/HEADING]
                  [HEADING=1]Build: 04-04-2019[/HEADING]
                  [HEADING=1]Database: 2019-04-18.2 (Cloud)[/HEADING]
                  [HEADING=1]Support: https://www.malwarebytes.com/support[/HEADING]
                  [HEADING=1]Mode: Scan[/HEADING]
                  [HEADING=1]Start: 04-19-2019[/HEADING]
                  [HEADING=1]Duration: 00:00:14[/HEADING]
                  [HEADING=1]OS: Windows 10 Pro[/HEADING]
                  [HEADING=1]Scanned: 27356[/HEADING]
                  [HEADING=1]Detected: 88[/HEADING]
                  ***** [ Services ] *****
                  PUP.Optional.Legacy WtuSystemSupport
                  ***** [ Folders ] *****
                  PUP.Adware.Heuristic C:\ProgramData\AVG_UPDATE_0215TB
                  PUP.Adware.Heuristic C:\ProgramData\AVG_UPDATE_0516TB
                  PUP.Adware.Heuristic C:\ProgramData\AVG_UPDATE_0816TB
                  PUP.Adware.Heuristic C:\ProgramData\AVG_UPDATE_1016TB
                  PUP.Adware.Heuristic C:\ProgramData\AVG_UPDATE_1214TB
                  PUP.Optional.AdvancedSystemCare C:\ProgramData\IObit\Advanced SystemCare
                  PUP.Optional.AdvancedSystemCare C:\Users\Lenovo\AppData\Roaming\IObit\Advanced SystemCare
                  PUP.Optional.Legacy C:\Program Files (x86)\Common Files\AVG Secure Search
                  PUP.Optional.Legacy C:\Program Files (x86)\avg web tuneup
                  PUP.Optional.Legacy C:\Program Files\Common Files\AVG Secure Search
                  PUP.Optional.Legacy C:\Program Files\avg web tuneup
                  PUP.Optional.Legacy C:\ProgramData\AVG Secure Search
                  PUP.Optional.Legacy C:\ProgramData\AVG Security Toolbar
                  PUP.Optional.Legacy C:\ProgramData\Speedbit
                  PUP.Optional.Legacy C:\ProgramData\avg web tuneup
                  PUP.Optional.Legacy C:\Users\Lenovo\AppData\LocalLow\Speedbit
                  PUP.Optional.Legacy C:\Users\Lenovo\AppData\LocalLow\avg web tuneup
                  PUP.Optional.Legacy C:\Users\Lenovo\AppData\Local\avg web tuneup
                  PUP.Optional.Legacy C:\Users\Lenovo\AppData\Roaming\Speedbit
                  PUP.Optional.MYPCTuneUp C:\Users\Lenovo\AppData\Local\Packages\windows_ie_ ac_001\AC\AVG Web TuneUp
                  Trojan.Sathurbot.E C:\Users\Lenovo\AppData\Local\Microsoft\Performanc e\Monitor
                  ***** [ Files ] *****
                  PUP.Optional.Legacy C:\ProgramData{262E20B8-6E20-4CEF-B1FD-D022AB1085F5}.dat
                  PUP.Optional.Legacy C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default\searchplugins\avg-secure-search.xml
                  ***** [ DLL ] *****
                  No malicious DLLs found.
                  ***** [ WMI ] *****
                  No malicious WMI found.
                  ***** [ Shortcuts ] *****
                  No malicious shortcuts found.
                  ***** [ Tasks ] *****
                  PUP.Adware.Heuristic C:\Windows\System32\Tasks\0915TBUPDATEINFO
                  PUP.Adware.Heuristic C:\Windows\System32\Tasks\AVG-SSU_0117avz
                  PUP.Adware.Heuristic C:\Windows\System32\Tasks\AVG-SSU_0117avz_DELETE
                  PUP.Adware.Heuristic C:\Windows\System32\Tasks\FreeDownloadManagerNetwo rkMonitor
                  PUP.Adware.Heuristic C:\Windows\Tasks\0915TBUPDATEINFO.JOB
                  ***** [ Registry ] *****
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Boot{1C48C1BE-378A-4BD4-9CBC-1EE169FA27A9}
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{08DE182 E-4B30-4A1E-B2FD-C6EB7895D4FF}
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{08DE182 E-4B30-4A1E-B2FD-C6EB7895D4FF}
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{1C48C1B E-378A-4BD4-9CBC-1EE169FA27A9}
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{4B4D8E7 B-0A5F-40FC-BBCD-29A82DE55E1E}
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{C14A101 B-90DF-4EA6-814A-49BE72CAD1BA}
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\0915TBUP DATEINFO
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\AVG-SSU_0117avz
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\AVG-SSU_0117avz_DELETE
                  PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\FreeDown loadManagerNetworkMonitor
                  PUP.Optional.ByteFence HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULA TION|ByteFence.exe
                  PUP.Optional.DriverAgent HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULA TION|DriverSupport.exe
                  PUP.Optional.DriverAgent HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_GPU_RENDERING |DriverSupport.exe
                  PUP.Optional.DriverPack HKCU\Software\drpsu
                  PUP.Optional.InstallCore HKCU\Software\csastats
                  PUP.Optional.Legacy HKCU\Software\AVG Tuneup
                  PUP.Optional.Legacy HKCU\Software\Microsoft\Internet Explorer\Main|Start Page
                  PUP.Optional.Legacy HKCU\Software\SpeedBit
                  PUP.Optional.Legacy HKLM\SOFTWARE\Classes\AppID\ViProtocol.DLL
                  PUP.Optional.Legacy HKLM\SOFTWARE\Classes\protocols\handler\viprotocol
                  PUP.Optional.Legacy HKLM\Software\Classes\AppID{1FDFF5A2-7BB1-48E1-8081-7236812B12B2}
                  PUP.Optional.Legacy HKLM\Software\Classes\Interface{03E2A1F3-4402-4121-8B35-733216D61217}
                  PUP.Optional.Legacy HKLM\Software\Classes\Interface{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
                  PUP.Optional.Legacy HKLM\Software\Classes\Interface{9E3B11F6-4179-4603-A71B-A55F4BCB0BEC}
                  PUP.Optional.Legacy HKLM\Software\Classes\Interface{C401D2CE-DC27-45C7-BC0C-8E6EA7F085D6}
                  PUP.Optional.Legacy HKLM\Software\Classes\TypeLib{74FB6AFD-DD77-4CEB-83BD-AB2B63E63C93}
                  PUP.Optional.Legacy HKLM\Software\Classes\TypeLib{82351433-9094-11D1-A24B-00A0C932C7DF}
                  PUP.Optional.Legacy HKLM\Software\Classes\TypeLib{9C049BA6-EA47-4AC3-AED6-A66D8DC9E1D8}
                  PUP.Optional.Legacy HKLM\Software\Classes\TypeLib{C2AC8A0E-E48E-484B-A71C-C7A937FAAB94}
                  PUP.Optional.Legacy HKLM\Software\Microsoft\Shared Tools\MSConfig\services\WtuSystemSupport
                  PUP.Optional.Legacy HKLM\Software\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run|WebDiscoverBrowser
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\AVG Tuneup
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\SpeedBit
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\AppID\ViProtocol .DLL
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\AppID{1FDFF5A2-7BB1-48E1-8081-7236812B12B2}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\CLSID{4E92DB5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\CLSID{61AB12E1-A5FF-11D1-B2E9-444553540000}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\CLSID{6DC82D15-92F2-11D1-A255-00A0C932C7DF}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\CLSID{82351441-9094-11D1-A24B-00A0C932C7DF}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\CLSID{933B95E2-E7B7-4AD9-B952-7AC336682AE3}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\CLSID{B658800C-F66E-4EF3-AB85-6C0C227862A9}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\CLSID{CA3A5461-96B5-46DD-9341-5350D3C94615}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\Interface{03E2A1 F3-4402-4121-8B35-733216D61217}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\Interface{4E92DB 5F-AAD9-49D3-8EAB-B40CBE5B1FF7}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\Interface{9E3B11 F6-4179-4603-A71B-A55F4BCB0BEC}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\Interface{C401D2 CE-DC27-45C7-BC0C-8E6EA7F085D6}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\TypeLib{74FB6AFD-DD77-4CEB-83BD-AB2B63E63C93}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\TypeLib{82351433-9094-11D1-A24B-00A0C932C7DF}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\TypeLib{9C049BA6-EA47-4AC3-AED6-A66D8DC9E1D8}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\TypeLib{C2AC8A0E-E48E-484B-A71C-C7A937FAAB94}
                  PUP.Optional.Legacy HKLM\Software\Wow6432Node\Classes\protocols\handle r\viprotocol
                  ***** [ Chromium (and derivatives) ] *****
                  PUP.Optional.Legacy Download Accelerator Plus (DAP)
                  PUP.Optional.VideoAdBlocker.ChrPRST bknbnapaddjdnbilpmlacdkjdkjmbjhd
                  ***** [ Chromium URLs ] *****
                  No malicious Chromium URLs found.
                  ***** [ Firefox (and derivatives) ] *****
                  PUP.Optional.Legacy AVG Web TuneUp
                  ***** [ Firefox URLs ] *****
                  PUP.Optional.Legacy https://mysearch.avg.com/?cid= {E644F638-8B1F-47E6-B698-D3DB372E9EFA}&mid=f4d66996aa8347cda0658ddae406f9fb-55d4ec08cd7e853dfbd9c9b5e6cb009adb67b172&lang=en&d s=AVG&coid=avgtbavg&cmpid=1215tb&pr=fr&d=2014-11-26 17:29:01&v=4.2.1.951&pid=wtu&sg=&sap=hp
                  PUP.Optional.Legacy mysearch.avg.com
                  PUP.Optional.MySearch https://mysearch.avg.com/?cid= {E644F638-8B1F-47E6-B698-D3DB372E9EFA}&mid=f4d66996aa8347cda0658ddae406f9fb-55d4ec08cd7e853dfbd9c9b5e6cb009adb67b172&lang=en&d s=AVG&coid=avgtbavg&cmpid=1215tb&pr=fr&d=2014-11-26 17:29:01&v=4.2.1.951&pid=wtu&sg=&sap=hp
                  PUP.Optional.MySearch mysearch.avg.com
                  ########## EOF - C:\AdwCleaner\Logs\AdwCleaner[S00].txt ##########
                  • jmarket
                    PCHF Owner
                    • 7695
                    • CachyOS
                    #10
                    A lot of bad crap was removed. Go ahead and re-run my FRST instructions and post some fresh logs for me to look at
                    How do the browsers act now?
                    • Baroona
                      • Apr 2019
                      • 27
                      #11
                      Haha thanks for the step by step guidance, however my chrome still has issues in which the lock is still on gray colour, this issues only happened in chrome which is quite weird.
                      sidenote: my Antivirus detected resetbrowser as trojan and i just ignore the whole thing, is it a normal interaction or no?
                      [HEADING=1]Addition:
                      Additional scan result of Farbar Recovery Scan Tool (x64) Version: 18.04.2019
                      Ran by Lenovo (19-04-2019 12:48:10)
                      Running from C:\Users\Lenovo\Downloads
                      Windows 10 Pro Version 1803 17134.706 (X64) (2018-05-26 07:41:06)
                      Boot Mode: Normal[/HEADING]
                      Administrator (S-1-5-21-1925601759-1010797402-2804155008-500 - Administrator - Disabled)
                      DefaultAccount (S-1-5-21-1925601759-1010797402-2804155008-503 - Limited - Disabled)
                      Guest (S-1-5-21-1925601759-1010797402-2804155008-501 - Limited - Disabled)
                      HomeGroupUser$ (S-1-5-21-1925601759-1010797402-2804155008-1002 - Limited - Enabled)
                      Lenovo (S-1-5-21-1925601759-1010797402-2804155008-1000 - Administrator - Enabled) => C:\Users\Lenovo
                      WDAGUtilityAccount (S-1-5-21-1925601759-1010797402-2804155008-504 - Limited - Disabled)
                      AV: Malwarebytes (Disabled - Out of date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
                      AV: 360 Total Security (Disabled - Up to date) {0371CA44-3F80-A1D3-BECE-910620B58D50}
                      AS: Malwarebytes (Disabled - Out of date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
                      AS: 360 Total Security (Disabled - Up to date) {B8102BA0-19BA-AE5D-847E-AA745B32C7ED}
                      . . (HKLM...{3D383E25-72E7-4F09-AA1C-9ADE6A2EF42F}) (Version: 7.1 - Intel) Hidden
                      . . . (HKLM-x32...{0C9A6167-6560-4085-9C35-EDB1AE105328}) (Version: 3.2.0.9 - Intel) Hidden
                      360 Total Security (HKLM-x32...\360TotalSecurity) (Version: 10.2.0.1180 - 360 Security Center)
                      3DP Chip Lite v17.11.1 (HKLM-x32...\3DP Chip Lite) (Version: v17.11.1 - 3DP)
                      ACDSee Pro 3 (HKLM-x32...{1B280FAF-AE10-4E31-A41A-DB3917D651DC}) (Version: 3.0.355 - ACD Systems International Inc.)
                      Active Directory Authentication Library for SQL Server (HKLM...{32C0D7B2-1046-43AC-98AD-B748E1910916}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
                      Active Directory Authentication Library for SQL Server (x86) (HKLM-x32...{F40FA676-46B1-4609-85EF-D2F1F79E0C0E}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
                      AdLock (HKLM...{26D2159D-4BE2-43A4-9E68-F0594DF0295C}) (Version: 1.0.2.2 - Hankuper) Hidden
                      Adobe Flash Player 29 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 29.0.0.113 - Adobe Systems Incorporated)
                      Adobe Flash Player 29 PPAPI (HKLM-x32...\Adobe Flash Player PPAPI) (Version: 29.0.0.113 - Adobe Systems Incorporated)
                      AMD Settings (HKLM...\WUCCCApp) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.)
                      AMD Software (HKLM...\AMD Catalyst Install Manager) (Version: 18.2.1 - Advanced Micro Devices, Inc.)
                      Anathena (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\242cfcc8731b6ee3) (Version: 3.3.8.0 - Anathena)
                      Any Video Converter 6.2.5 (HKLM-x32...\Any Video Converter) (Version: 6.2.5 - Anvsoft)
                      Apple Application Support (32-bit) (HKLM-x32...{D4C80B0C-CF67-43A7-90C3-466853543B54}) (Version: 6.3 - Apple Inc.)
                      Apple Application Support (64-bit) (HKLM...{B2A2E8AF-BC48-4191-B2C4-3846A19835CA}) (Version: 6.3 - Apple Inc.)
                      Apple Application Support (HKLM-x32...{46F044A5-CE8B-4196-984E-5BD6525E361D}) (Version: 2.3.6 - Apple Inc.)
                      Apple Mobile Device Support (HKLM...{AA7D90D2-2387-4FA5-A3AF-96811BE49BFD}) (Version: 11.0.5.14 - Apple Inc.)
                      Apple Software Update (HKLM-x32...{19589375-5C58-4AFA-842F-8B34744CCEAD}) (Version: 2.5.0.1 - Apple Inc.)
                      Apple Software Update (HKLM-x32...{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}) (Version: 2.1.3.127 - Apple Inc.)
                      ArcSoft WebCam Companion 3 (HKLM-x32...{34985F59-8F6F-46F4-9AD5-53E2714294D2}) (Version: 3.0.189 - ArcSoft)
                      AVG 2015 (HKLM...{6E4BAAF0-7F23-41E5-B16B-4727B6FC0C6F}) (Version: 15.0.6081 - AVG Technologies) Hidden
                      AVG Web TuneUp (HKLM-x32...\AVG Web TuneUp) (Version: 4.3.6.255 - AVG Technologies)
                      Battle.net (HKLM-x32...\Battle.net) (Version: - Blizzard Entertainment)
                      BattlePing (HKLM-x32...{DB480AC3-1578-B8DC-3F8F-786A2A4E3BC7}) (Version: 1.3.7.1 - BattlePing)
                      Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
                      Catalyst Control Center Next Localization BR (HKLM...{15EEB07A-3FB9-FA4C-8EFF-697728CB1E5C}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization CHS (HKLM...{A63E3031-0522-18C6-F18F-7EE80973315F}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization CHT (HKLM...{A2966D0F-43BB-116D-C9C7-49612FBFD0AE}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization CS (HKLM...{4C608ED2-535B-2119-3661-9E6F7DDB600F}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization DA (HKLM...{9005C809-497A-FD45-CB96-76A3338E35B9}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization DE (HKLM...{D84300A6-72F1-5771-B3B1-8FC71184AB38}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization EL (HKLM...{56D13277-FA9F-2842-682D-DD7298973585}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization ES (HKLM...{8D0C7788-D519-7B65-36F6-D0D21296F173}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization FI (HKLM...{930FD2C7-D026-197D-94E4-CB5917CE7420}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization FR (HKLM...{086D11E3-9CA4-DBEF-2B48-5A2EFFD53145}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization HU (HKLM...{D0C1EAB6-92F1-EE91-04C2-5947EE150593}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization IT (HKLM...{57EAA61A-CD02-DF34-0839-2549F57A334C}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization JA (HKLM...{AA477FD2-347B-1732-5D8C-AF35AF1B9703}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization KO (HKLM...{BBFC5953-2CB9-5932-1D47-52E4AA99737B}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization NL (HKLM...{01E7D692-D785-743F-5A55-F00162D26A1C}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization NO (HKLM...{5D8BA452-1264-7D13-E4EC-8236EC5B83FE}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization PL (HKLM...{F49BA906-83DA-3F5A-5B24-03C8DE2A3936}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization RU (HKLM...{5A466CAA-F071-D9EF-A799-EF63552DBE70}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization SV (HKLM...{D7DC4DDB-3E0D-6F79-4258-4A461654B689}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization TH (HKLM...{ACDFF800-6015-BEEC-8A27-7B1A80915273}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      Catalyst Control Center Next Localization TR (HKLM...{A28B1FC5-3947-9D39-7FE5-A3CB18E16358}) (Version: 2016.0628.2138.37120 - Advanced Micro Devices, Inc.) Hidden
                      CCleaner (HKLM...\CCleaner) (Version: 5.41 - Piriform)
                      Cheat Engine 6.6 (HKLM-x32...\Cheat Engine 6.6_is1) (Version: - Cheat Engine)
                      Cisco EAP-FAST Module (HKLM-x32...{64BF0187-F3D2-498B-99EA-163AF9AE6EC9}) (Version: 2.2.14 - Cisco Systems, Inc.)
                      Cisco LEAP Module (HKLM-x32...{AF312B06-5C5C-468E-89B3-BE6DE2645722}) (Version: 1.0.19 - Cisco Systems, Inc.)
                      Cisco PEAP Module (HKLM-x32...{0A4EF0E6-A912-4CDE-A7F3-6E56E7C13A2F}) (Version: 1.1.6 - Cisco Systems, Inc.)
                      Conexant HD Audio (HKLM...\CNXT_AUDIO_HDA) (Version: 8.66.16.50 - Conexant)
                      CyberLink PowerDVD 11 (HKLM-x32...\InstallShield_{F232C87C-6E92-4775-8210-DFE90B7777D9}) (Version: 11.0.1620.51 - CyberLink Corp.)
                      D3DX10 (HKLM-x32...{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
                      DivX H.264 decoder 8.2.0.26 (HKLM-x32...\divxh264_is1) (Version: 8.2.0.26 - )
                      DivX Setup (HKLM-x32...\DivX Setup) (Version: 2.7.0.93 - DivX, LLC)
                      Dolby Digital Plus Advanced Audio (HKLM...{B0BFC63F-EA07-419E-960B-3FB2ED5DD0B2}) (Version: 7.6.5.1 - Dolby Laboratories Inc)
                      Dolby Digital Plus Home Theater (HKLM...{7E3D8FA1-6092-469A-955B-68FC4A2C67CA}) (Version: 7.6.5.1 - Dolby Laboratories Inc)
                      Driver Easy 5.6.1 (HKLM...\DriverEasy_is1) (Version: 5.6.1 - Easeware)
                      Dropbox (HKLM-x32...\Dropbox) (Version: 45.4.92 - Dropbox, Inc.)
                      Dropbox Update Helper (HKLM-x32...{099218A5-A723-43DC-8DB5-6173656A1E94}) (Version: 1.3.59.1 - Dropbox, Inc.) Hidden
                      Energy Management (HKLM-x32...{D0956C11-0F60-43FE-99AD-524E833471BB}) (Version: 7.0.3.9 - Lenovo) Hidden
                      Energy Management (HKLM-x32...\InstallShield_{D0956C11-0F60-43FE-99AD-524E833471BB}) (Version: 7.0.3.9 - Lenovo)
                      eNexia version 749.0 (HKLM-x32...{8C3EC8A8-70A1-4298-BD7D-3CD7DAE20D64}_is1) (Version: 749.0 - eNexiaTK)
                      Free Download Manager (HKLM...{43781dff-e0df-49ce-a6d2-47da96a485e7}}is1) (Version: - FreeDownloadManager.ORG)
                      Google Chrome (HKLM-x32...{8CAF1821-50A9-3971-88C2-371AACE003E1}) (Version: 73.0.3683.103 - Google LLC)
                      Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.34.7 - Google LLC) Hidden
                      GRF Editor version 1.7.9 (HKLM-x32...\GRF Editor_is1) (Version: 1.7.9 - )
                      Hearthstone (HKLM-x32...\Hearthstone) (Version: - Blizzard Entertainment)
                      Hearthstone Deck Tracker (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\HearthstoneDeckTracker) (Version: 1.7.6 - HearthSim)
                      Hotspot Shield 7.6.4 (HKLM-x32...{AF599C42-A2E5-4251-B7EE-4925C187EDD1}) (Version: 7.6.4.10926 - AnchorFree Inc.) Hidden
                      Hotspot Shield 7.6.4 (HKLM-x32...{f0473374-de13-4075-b4ef-5847e91e1d6a}) (Version: 7.6.4.10926 - AnchorFree Inc.)
                      Hotspot Shield 7.6.4 (HKLM-x32...\HotspotShield) (Version: 7.6.4 - AnchorFree Inc.) Hidden
                      HxD Hex Editor version 1.7.7.0 (HKLM-x32...\HxD Hex Editor_is1) (Version: 1.7.7.0 - Maël Hörz)
                      IIS 10.0 Express (HKLM...{13FD7E30-D2F1-498D-ABC2-A4242DB6610E}) (Version: 10.0.1736 - Microsoft Corporation)
                      Intel(R) Chipset Device Software (HKLM-x32...{17408817-d415-4768-a160-ae6d46d6bdb0}) (Version: 10.1.1.44 - Intel(R) Corporation) Hidden
                      Intel(R) Computing Improvement Program (HKLM...{699E6891-25C3-443A-9B8E-80C74F0172C8}) (Version: 2.1.03413 - Intel Corporation)
                      Intel(R) Management Engine Components (HKLM-x32...{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.15.1730 - Intel Corporation)
                      Intel(R) Processor Graphics (HKLM-x32...{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4531 - Intel Corporation)
                      Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 12.9.0.1001 - Intel Corporation)
                      Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32...{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 2.5.3.34 - Intel Corporation)
                      Intel® Driver & Support Assistant (HKLM-x32...{4d839fe1-a8d3-4edc-b0ca-844394309856}) (Version: 3.2.0.9 - Intel)
                      IObit Uninstaller 8 (HKLM-x32...\IObitUninstall) (Version: 8.4.0.8 - IObit)
                      iTunes (HKLM...{1D7D1271-5258-4F5A-B8C1-7176BF398782}) (Version: 12.7.3.46 - Apple Inc.)
                      Java 8 Update 161 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F32180161F0}) (Version: 8.0.1610.12 - Oracle Corporation)
                      K-Lite Mega Codec Pack 14.0.5 (HKLM-x32...\KLiteCodecPack_is1) (Version: 14.0.5 - KLCP)
                      Lenovo EasyCamera (HKLM-x32...{E399A5B3-ED53-4DEA-AF04-8011E1EB1EAC}) (Version: 6.3.9600.11105 - Realtek Semiconductor Corp.)
                      Logitech Gaming Software 8.57 (HKLM...\Logitech Gaming Software) (Version: 8.57.145 - Logitech Inc.)
                      Magic Bullet Suite 64-bit (HKLM...{93488C33-D8D6-472A-83BB-F71603355CF0}) (Version: 11.1.0 - Red Giant Software) Hidden
                      Magic Bullet Suite 64-bit (HKLM-x32...\InstallShield
                      Malwarebytes version 3.4.4.2398 (HKLM...{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}is1) (Version: 3.4.4.2398 - Malwarebytes)
                      McAfee True Key (HKLM...\TrueKey) (Version: 5.2.167.1 - McAfee, LLC)
                      mHotspot version 7.8.8.0 (HKLM-x32...{beeb7906-9268-4520-8850-8d8af9b1c7c8}is1) (Version: 7.8.8.0 - 1BN Software & IT Solutions Pvt. Ltd.)
                      Microsoft .NET Framework 4 Multi-Targeting Pack (HKLM-x32...{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}) (Version: 4.0.30319 - Microsoft Corporation)
                      Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (ENU) (HKLM-x32...{D3517C62-68A5-37CF-92F7-93C029A89681}) (Version: 4.5.50932 - Microsoft Corporation)
                      Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (HKLM-x32...{6A0C6700-EA93-372C-8871-DCCF13D160A4}) (Version: 4.5.50932 - Microsoft Corporation)
                      Microsoft .NET Framework 4.6.1 SDK (HKLM-x32...{2F0ECC80-B9E4-4485-8083-CD32F22ABD92}) (Version: 4.6.01055 - Microsoft Corporation)
                      Microsoft .NET Framework 4.6.1 SDK (日本語) (HKLM-x32...{9A330858-0CD6-4FB3-8C57-0F1BB58012B0}) (Version: 4.6.01055 - Microsoft Corporation)
                      Microsoft .NET Framework 4.6.1 Targeting Pack (ENU) (HKLM-x32...{8EEB28EE-5141-411C-9CF0-9952264FE4AF}) (Version: 4.6.01055 - Microsoft Corporation)
                      Microsoft .NET Framework 4.6.1 Targeting Pack (HKLM-x32...{8BC3EEC9-090F-4C53-A8DA-1BEC913040F9}) (Version: 4.6.01055 - Microsoft Corporation)
                      Microsoft .NET Framework 4.6.1 Targeting Pack (日本語) (HKLM-x32...{903C5477-BA28-4CFC-8BE4-62E3C328D4DD}) (Version: 4.6.01055 - Microsoft Corporation)
                      Microsoft Chart Controls for Microsoft .NET Framework 3.5 (HKLM-x32...{41785C66-90F2-40CE-8CB5-1C94BFC97280}) (Version: 3.5.0.0 - Microsoft Corporation)
                      Microsoft Help Viewer 1.1 (HKLM...\Microsoft Help Viewer 1.1) (Version: 1.1.40219 - Microsoft Corporation)
                      Microsoft Help Viewer 2.2 (HKLM-x32...\Microsoft Help Viewer 2.2) (Version: 2.2.25420 - Microsoft Corporation)
                      Microsoft Office 2007 Service Pack 3 (SP3) (HKLM-x32...{90120000-0030-0000-0000-0000000FF1CE}ENTERPRISE{6E107EB7-8B55-48BF-ACCB-199F86A2CD93}) (Version: - Microsoft)
                      Microsoft Office Enterprise 2007 (HKLM-x32...\ENTERPRISE) (Version: 12.0.6612.1000 - Microsoft Corporation)
                      Microsoft Office File Validation Add-In (HKLM-x32...{90140000-2005-0000-0000-0000000FF1CE}) (Version: 14.0.5130.5003 - Microsoft Corporation)
                      Microsoft OneDrive (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\OneDriveSetup.exe) (Version: 18.025.0204.0009 - Microsoft Corporation)
                      Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50918.0 - Microsoft Corporation)
                      Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32...{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
                      Microsoft SQL Server 2008 (64-bit) (HKLM...\Microsoft SQL Server 10 Release) (Version: - Microsoft Corporation)
                      Microsoft SQL Server 2008 Browser (HKLM-x32...{C688457E-03FD-4941-923B-A27F4D42A7DD}) (Version: 10.1.2531.0 - Microsoft Corporation)
                      Microsoft SQL Server 2008 Native Client (HKLM...{BBDE8A3D-64A2-43A6-95F3-C27B87DF7AC1}) (Version: 10.1.2531.0 - Microsoft Corporation)
                      Microsoft SQL Server 2008 Setup Support Files (HKLM...{B40EE88B-400A-4266-A17B-E3DE64E94431}) (Version: 10.1.2731.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Command Line Utilities (HKLM...{9D573E71-1077-4C7E-B4DB-4E22A5D2B48B}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Native Client (HKLM...{49D665A2-4C2A-476E-9AB8-FCC425F526FC}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Microsoft SQL Server 2014 Management Objects (HKLM-x32...{2774595F-BC2A-4B12-A25B-0C37A37049B0}) (Version: 12.0.2000.8 - Microsoft Corporation)
                      Microsoft SQL Server 2014 Management Objects (x64) (HKLM...{1F9EB3B6-AED7-4AA7-B8F1-8E314B74B2A5}) (Version: 12.0.2000.8 - Microsoft Corporation)
                      Microsoft SQL Server 2014 Transact-SQL ScriptDom (HKLM...{020CDFE0-C127-4047-B571-37C82396B662}) (Version: 12.0.2000.8 - Microsoft Corporation)
                      Microsoft SQL Server 2014 T-SQL Language Service (HKLM-x32...{47D08E7A-92A1-489B-B0BF-415516497BCE}) (Version: 12.0.2000.8 - Microsoft Corporation)
                      Microsoft SQL Server 2016 LocalDB (HKLM...{E359515A-92E6-4FA3-A2C9-E1BA02D8DE6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
                      Microsoft SQL Server 2016 Management Objects (HKLM-x32...{0F1C8E2F-199A-4946-B3BF-0906DACFD032}) (Version: 13.0.1601.5 - Microsoft Corporation)
                      Microsoft SQL Server 2016 Management Objects (x64) (HKLM...{20EA85AA-2A1D-4F11-B09F-4BA2BF3C8989}) (Version: 13.0.1601.5 - Microsoft Corporation)
                      Microsoft SQL Server 2016 T-SQL Language Service (HKLM-x32...{8BFDE775-C5B8-46DB-84EF-43FFC8A2E8AD}) (Version: 13.0.14500.10 - Microsoft Corporation)
                      Microsoft SQL Server 2016 T-SQL ScriptDom (HKLM...{D091DE8C-EA0F-49AF-8DE3-BD6C79737C6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
                      Microsoft SQL Server Compact 3.5 SP2 ENU (HKLM-x32...{3A9FC03D-C685-4831-94CF-4EDFD3749497}) (Version: 3.5.8080.0 - Microsoft Corporation)
                      Microsoft SQL Server Compact 3.5 SP2 x64 ENU (HKLM...{D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}) (Version: 3.5.8080.0 - Microsoft Corporation)
                      Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM...{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
                      Microsoft SQL Server Data Tools - enu (14.0.60519.0) (HKLM-x32...{4E27B0EF-7BAB-432A-AF3D-3FC8F3F7353F}) (Version: 14.0.60519.0 - Microsoft Corporation)
                      Microsoft SQL Server VSS Writer (HKLM...{0826F9E4-787E-481D-83E0-BC6A57B056D5}) (Version: 10.1.2531.0 - Microsoft Corporation)
                      Microsoft Sync Framework 2.1 Core Components (x86) ENU (HKLM-x32...{7AC8EF88-D996-4D47-B40C-4DD93E307481}) (Version: 2.1.1648.0 - Microsoft Corporation)
                      Microsoft Sync Framework 2.1 Database Providers (x86) ENU (HKLM-x32...{296E293F-C481-4DDE-9ED2-3F79FCF38731}) (Version: 3.1.1648.0 - Microsoft Corporation)
                      Microsoft System CLR Types for SQL Server 2014 (HKLM...{FC3BB979-AA54-4B60-BBA3-2C4DA6E08D80}) (Version: 12.0.2402.29 - Microsoft Corporation)
                      Microsoft System CLR Types for SQL Server 2014 (HKLM-x32...{091CE6AA-2753-4F6E-AD1C-0E875744EB54}) (Version: 12.0.2402.29 - Microsoft Corporation)
                      Microsoft System CLR Types for SQL Server 2016 (HKLM...{96EB5054-C775-4BEF-B7B9-AA96A295EDCD}) (Version: 13.0.1601.5 - Microsoft Corporation)
                      Microsoft System CLR Types for SQL Server 2016 (HKLM-x32...{84C23ECA-FE4D-494F-9247-3EBAD57E7F0C}) (Version: 13.0.1601.5 - Microsoft Corporation)
                      Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 (HKLM-x32...{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}) (Version: 9.0.21022 - Microsoft Corporation)
                      Microsoft Visual C++ 2010 x64 Runtime - 10.0.40219 (HKLM...{1C7C8AAF-A16D-32E8-89E5-F6D165DE0BCE}) (Version: 10.0.40219 - Microsoft Corporation)
                      Microsoft Visual C++ 2010 x86 Runtime - 10.0.40219 (HKLM-x32...{5D9ED403-94DE-3BA0-B1D6-71F4BDA412E6}) (Version: 10.0.40219 - Microsoft Corporation)
                      Microsoft Visual C++ 2017 Redistributable (x64) - 14.10.25008 (HKLM-x32...{f1e7e313-06df-4c56-96a9-99fdfd149c51}) (Version: 14.10.25008.0 - Microsoft Corporation)
                      Microsoft Visual C++ 2017 Redistributable (x86) - 14.10.25008 (HKLM-x32...{c239cea1-d49e-4e16-8e87-8c055765f7ec}) (Version: 14.10.25008.0 - Microsoft Corporation)
                      Microsoft Visual Studio 2010 Express Prerequisites x64 - ENU (HKLM...{BCA26999-EC22-3007-BB79-638913079C9A}) (Version: 10.0.40219 - Microsoft Corporation)
                      Microsoft Visual Studio 2010 Service Pack 1 (HKLM-x32...\Microsoft Visual Studio 2010 Service Pack 1) (Version: 10.0.40219 - Microsoft Corporation)
                      Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
                      Microsoft Web Deploy 3.6 (HKLM...{94E1227C-08A9-4962-B388-1F05D89AEA75}) (Version: 3.1238.1962 - Microsoft Corporation)
                      Modem AC2726 UI (HKLM...\ZTEWireless-101_is1) (Version: - )
                      MornaTK Installer (HKLM-x32...{BCD1C4AD-EB1A-40DF-A838-2AF8C45B5942}) (Version: 1.0 - MornaTales)
                      Movavi Video Converter 18 Premium (HKLM-x32...\Movavi Video Converter 18 Premium) (Version: 18.3.0 - Movavi)
                      Movie Maker (HKLM-x32...{38F03569-A636-4CF3-BDDE-032C8C251304}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
                      Movie Maker (HKLM-x32...{DD67BE4B-7E62-4215-AFA3-F123A800A389}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
                      Mozilla Firefox 66.0.3 (x86 en-US) (HKLM-x32...\Mozilla Firefox 66.0.3 (x86 en-US)) (Version: 66.0.3 - Mozilla)
                      Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 66.0.3 - Mozilla)
                      Mumble 1.2.19 (HKLM-x32...{F62A874F-2354-49B1-87BE-CAAD7C8FA084}) (Version: 1.2.19 - Thorvald Natvig)
                      MYOB AccountRight Plus v19.12.0 ED (HKLM-x32...{27D4F4A7-5A34-4657-9E78-D6B1E87C8A90}) (Version: 19.12.0 - MYOB Technology Pty Ltd) Hidden
                      MYOB AccountRight Plus v19.12.0 ED (HKLM-x32...\InstallShield
                      MYOB ODBC Direct v10 AUS (HKLM-x32...{55D5A77E-FAAA-4358-B3E5-6565E024F78B}) (Version: 10.1.0 - MYOB Technology Pty Ltd) Hidden
                      MYOB ODBC Direct v10 AUS (HKLM-x32...\InstallShield
                      MySQL Installer - Community (HKLM-x32...{4553E209-560C-451E-9DE9-E6B812D32B8C}) (Version: 1.4.8.0 - Oracle Corporation)
                      MySQL Server 5.0 (HKLM-x32...{2FEB25F8-C3CB-49A2-AE79-DE17FFAFB5D9}) (Version: 5.0.45 - MySQL AB)
                      MySQL Tools for 5.0 (HKLM-x32...{EC561602-C0B9-4FAA-A175-1B3273639AC3}) (Version: 5.0.12 - MySQL AB)
                      Notepad++ (32-bit x86) (HKLM-x32...\Notepad++) (Version: 7.5.6 - Notepad++ Team)
                      NovaRO (HKLM-x32...\NovaRO_is1) (Version: 6.0.0 - NovaRO)
                      Nox APP Player (HKLM-x32...\Nox) (Version: 6.0.1.1 - Duodian Technology Co. Ltd.)
                      OBS Studio (HKLM-x32...\OBS Studio) (Version: 21.1.2 - OBS Project)
                      OEM Application Profile (HKLM-x32...{70D5F822-F4C4-33D9-7EEC-2A4AF4EA7BDC}) (Version: 1.00.0000 - Advanced Micro Devices, Inc.) Hidden
                      Opera Stable 58.0.3135.127 (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Opera 58.0.3135.127) (Version: 58.0.3135.127 - Opera Software)
                      Pingzapper version 2.1.2 (HKLM-x32...{7FD61982-5436-439B-B5D0-36F0536FF8BF}_is1) (Version: 2.1.2 - Pingzapper)
                      PlayNexia II (HKLM-x32...\PlayNexia II) (Version: - )
                      PlaysTV (HKLM-x32...\PlaysTV) (Version: 1.13.1-r115223-release - Plays.tv, LLC)
                      Pokémon World Online Uninstaller (HKLM-x32...{6B67E1A1-1D62-4BDC-8C60-07FDF25CA975}_is1) (Version: 1.97 - PWO Team)
                      Prerequisites for SSDT (HKLM-x32...{21373064-AD95-48DB-A32E-0D9E08EF7355}) (Version: 12.0.2000.8 - Microsoft Corporation)
                      Prerequisites for SSDT (HKLM-x32...{B7E94916-7AE6-4F7F-A377-7A410A42BA19}) (Version: 13.0.1601.5 - Microsoft Corporation)
                      PX Profile Update (HKLM-x32...{230C6C56-D930-2D7A-CF62-9BE26FAEE260}) (Version: 1.00.1. - AMD) Hidden
                      QuickTime 7 (HKLM-x32...{80CEEB1E-0A6C-45B9-A312-37A1D25FDEBC}) (Version: 7.78.80.95 - Apple Inc.)
                      Ragnarok Online (HKLM-x32...{181579B5-0028-4E01-AC27-97ED80352279}) (Version: 14.2.5 - Gravity Interactive, Inc.)
                      Raptr (HKLM-x32...\Raptr) (Version: 5.1.1-r111306-release - Raptr, Inc)
                      Razer Game Booster (HKLM-x32...\Razer Game Booster_is1) (Version: 4.1.59.0 - Razer Inc.)
                      Realtek Card Reader (HKLM-x32...{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.2.9200.39052 - Realtek Semiconductor Corp.)
                      Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.75.827.2013 - Realtek)
                      Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8186 - Realtek Semiconductor Corp.)
                      REALTEK Wireless LAN Driver (HKLM-x32...{9DAABC60-A5EF-41FF-B2B9-17329590CD5}) (Version: 1.30.0239 - REALTEK Semiconductor Corp.)
                      Roslyn Language Services - x86 (HKLM-x32...{6970C7E1-F99D-388D-8903-DF8FCE677FED}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
                      Safari (HKLM-x32...{A08BAD08-9AA3-410F-98F3-C92C8EE37218}) (Version: 5.34.54.16 - Apple Inc.)
                      Service Pack 1 for SQL Server 2008 (KB968369) (64-bit) (HKLM...\KB968369) (Version: 10.1.2531.0 - Microsoft Corporation)
                      Skype™ 7.26 (HKLM-x32...{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.26.101 - Skype Technologies S.A.)
                      Speccy (HKLM...\Speccy) (Version: 1.31 - Piriform)
                      Spotify (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Spotify) (Version: 1.0.70.388.g8e1ed5af - Spotify AB)
                      Sql Server Customer Experience Improvement Program (HKLM...{2F14965D-567B-4E59-ADEB-0A2CC1E3ADDF}) (Version: 10.1.2531.0 - Microsoft Corporation) Hidden
                      Team Explorer for Microsoft Visual Studio 2015 Update 3.1 (HKLM-x32...{7A95671A-759E-3B83-B763-4289D1D24D73}) (Version: 14.102.25619 - Microsoft) Hidden
                      TeamSpeak 3 Client (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\TeamSpeak 3 Client) (Version: 3.0.16 - TeamSpeak Systems GmbH)
                      TeamViewer 14 (HKLM-x32...\TeamViewer) (Version: 14.2.8352 - TeamViewer)
                      TypeScript Tools for Microsoft Visual Studio 2015 (HKLM-x32...{BA5762C7-D35F-4725-A4BD-525854127018}) (Version: 1.8.36.0 - Microsoft Corporation) Hidden
                      Update for 2007 Microsoft Office System (KB967642) (HKLM-x32...{90120000-0030-0000-0000-0000000FF1CE}ENTERPRISE{C444285D-5E4F-48A4-91DD-47AAAA68E92D}) (Version: - Microsoft)
                      Update for Windows 10 for x64-based Systems (KB4023057) (HKLM...{B2E25355-C24E-4E7D-8AD3-455D59810838}) (Version: 2.57.0.0 - Microsoft Corporation)
                      VC80CRTRedist - 8.0.50727.6195 (HKLM-x32...{933B4015-4618-4716-A828-5289FC03165F}) (Version: 1.2.0 - DivX, Inc) Hidden
                      Vegas Pro 12.0 (64-bit) (HKLM...{BD422D00-5232-11E3-A6F3-F04DA23A5C58}) (Version: 12.0.770 - Sony)
                      Vegas Pro 13.0 (64-bit) (HKLM-x32...\Vegas Pro 13.0 (64-bit)) (Version: 13.0 (64-bit) - Exµs ™)
                      Visual Studio 2012 x64 Redistributables (HKLM...{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
                      Visual Studio 2012 x86 Redistributables (HKLM-x32...{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
                      VLC media player (HKLM-x32...\VLC media player) (Version: 3.0.1 - VideoLAN)
                      Vulkan Run Time Libraries 1.0.26.0 (HKLM...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
                      Vulkan Run Time Libraries 1.0.65.0 (HKLM...\VulkanRT1.0.65.0) (Version: 1.0.65.0 - LunarG, Inc.) Hidden
                      Winamp (HKLM-x32...\Winamp) (Version: 5.666 - Nullsoft, Inc)
                      Windows Driver Package - Lenovo (ACPIVPC) System (12/15/2011 7.1.0.1) (HKLM...\99841829BE839365AA67B2AD0E50D371F59F8A1E) (Version: 12/15/2011 7.1.0.1 - Lenovo)
                      Windows Live Essentials (HKLM-x32...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
                      WinPcap 4.1.3 (HKLM-x32...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
                      WinRAR 5.70 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.70.0 - win.rar GmbH)
                      Wondershare Filmora(Build 8.7.0) (HKLM...\Wondershare Filmora_is1) (Version: - Wondershare Software)
                      Wondershare Helper Compact 2.6.0 (HKLM-x32...{5363CE84-5F09-48A1-8B6C-6BB590FFEDF2}_is1) (Version: 2.6.0 - Wondershare)
                      Wondershare PDFelement 6 Pro(Build 6.8.6) (HKLM-x32...{B026557A-EF19-4812-8A79-B30F94AA0A78}_is1) (Version: 6.8.6.4121 - Wondershare Software Co.,Ltd.)
                      Wondershare Video Converter Ultimate(Build 10.3.0.178) (HKLM-x32...\Video Converter Ultimate_is1) (Version: 10.3.0.178 - Wondershare Software)
                      World of Warcraft (HKLM-x32...\World of Warcraft) (Version: - Blizzard Entertainment)
                      XAMPP (HKLM-x32...\xampp) (Version: 7.1.1-0 - Bitnami)
                      Zoom (HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\ZoomUMX) (Version: 4.1 - Zoom Video Communications, Inc.)
                      CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{00020420-0000-0000-C000-000000000046}\InprocServer32 → C:\WINDOWS\system32\oleaut32.dll (Microsoft Windows → Microsoft Corporation)
                      CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{00020424-0000-0000-C000-000000000046}\InprocServer32 → C:\WINDOWS\system32\oleaut32.dll (Microsoft Windows → Microsoft Corporation)
                      CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{E31EA727-12ED-4702-820C-4B6445F28E1A} → [Dropbox] => C:\Users\Lenovo\Dropbox [2015-07-07 16:17]
                      CustomCLSID: HKU\S-1-5-21-1925601759-1010797402-2804155008-1000_Classes\CLSID{f1d8036a-7f48-43e4-8045-dbcb4e742507}\InprocServer32 → C:\WINDOWS\system32\dfshim.dll (Microsoft Windows → Microsoft Corporation)
                      ShellExecuteHooks-x32: Groove GFS Stub Execution Hook - {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll [2217832 2009-02-26] (Microsoft Corporation → Microsoft Corporation)
                      ShellIconOverlayIdentifiers: [ DropboxExt01] → {FB314ED9-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt02] → {FB314EDF-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt03] → {FB314EE1-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt04] → {FB314EDB-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt05] → {FB314EDA-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt06] → {FB314EDC-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt07] → {FB314EDD-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt08] → {FB314EE0-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt09] → {FB314EE2-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ DropboxExt10] → {FB314EDE-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
                      ShellIconOverlayIdentifiers: [00asw] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
                      ShellIconOverlayIdentifiers: [00avg] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt01] → {FB314ED9-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt02] → {FB314EDF-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt03] → {FB314EE1-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt04] → {FB314EDB-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt05] → {FB314EDA-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt06] → {FB314EDC-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt07] → {FB314EDD-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt08] → {FB314EE0-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt09] → {FB314EE2-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ DropboxExt10] → {FB314EDE-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ShellIconOverlayIdentifiers-x32: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
                      ContextMenuHandlers1: [ANotepad++64] → {B298D29A-A6ED-11DE-BA8C-A68E55D89593} => C:\Program Files (x86)\Notepad++\NppShell_06.dll [2018-03-19] (Notepad++ → )
                      ContextMenuHandlers1: [DropboxExt] → {ECD97DE5-3C8F-4ACB-AEEE-CCAB78F7711C} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ContextMenuHandlers1: [IObitUnstaler] → {836AB26C-2DE4-41D3-AC24-4C6C2699B960} => C:\Program Files (x86)\IObit\IObit Uninstaller\IUMenuRight.dll [2018-07-21] (IObit Information Technology → IObit)
                      ContextMenuHandlers1: [SD360] → {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → )
                      ContextMenuHandlers1: [WinRAR] → {B41DB860-64E4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
                      ContextMenuHandlers1-x32: [WinRAR32] → {B41DB860-8EE4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext32.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
                      ContextMenuHandlers3: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2018-03-03] (Malwarebytes Corporation → Malwarebytes)
                      ContextMenuHandlers4: [DropboxExt] → {ECD97DE5-3C8F-4ACB-AEEE-CCAB78F7711C} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ContextMenuHandlers4: [IObitUnstaler] → {836AB26C-2DE4-41D3-AC24-4C6C2699B960} => C:\Program Files (x86)\IObit\IObit Uninstaller\IUMenuRight.dll [2018-07-21] (IObit Information Technology → IObit)
                      ContextMenuHandlers4: [SD360] → {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → )
                      ContextMenuHandlers5: [ACE] → {5E2121EE-0300-11D4-8D3B-444553540000} => C:\Program Files\AMD\CNext\CNext\atiacm64.dll [2016-06-28] (Advanced Micro Devices, Inc. → Advanced Micro Devices, Inc.)
                      ContextMenuHandlers5: [DropboxExt] → {ECD97DE5-3C8F-4ACB-AEEE-CCAB78F7711C} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.19.0.dll [2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      ContextMenuHandlers5: [Gadgets] → {6B9228DA-9C15-419e-856C-19E768A13BDC} => → No File
                      ContextMenuHandlers5: [igfxcui] → {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => → No File
                      ContextMenuHandlers5: [igfxDTCM] → {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\system32\igfxDTCM.dll [2017-06-12] (Microsoft Windows Hardware Compatibility Publisher → Intel Corporation)
                      ContextMenuHandlers6: [IObitUnstaler] → {836AB26C-2DE4-41D3-AC24-4C6C2699B960} => C:\Program Files (x86)\IObit\IObit Uninstaller\IUMenuRight.dll [2018-07-21] (IObit Information Technology → IObit)
                      ContextMenuHandlers6: [MBAMShlExt] → {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2018-03-03] (Malwarebytes Corporation → Malwarebytes)
                      ContextMenuHandlers6: [SD360] → {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → )
                      ContextMenuHandlers6: [WinRAR] → {B41DB860-64E4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
                      ContextMenuHandlers6-x32: [WinRAR32] → {B41DB860-8EE4-11D2-9906-E49FADC173CA} => D:\Program Files\WinRAR\rarext32.dll [2019-02-25] (win.rar GmbH → Alexander Roshal)
                      Task: {012A6F59-87D6-44E0-A91E-4191C44105EE} - System32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
                      Task: {02E9EE88-8B2A-45A8-B237-293AF930C0D8} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe (Piriform Ltd → Piriform Ltd)
                      Task: {06B7B6A5-89CC-4D81-B982-3F531F29F6A9} - System32\Tasks\Avast Emergency Update => C:\Program Files\AVAST Software\Avast\AvEmUpdate.exe (AVAST Software s.r.o. → AVAST Software)
                      Task: {07375CF8-C1FF-492B-8278-0396D0245D6F} - System32\Tasks\DropboxUpdateTaskMachineCore1d1719f 65cee02e => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe (Dropbox, Inc → Dropbox, Inc.)
                      Task: {08DE182E-4B30-4A1E-B2FD-C6EB7895D4FF} - \0915tbUpdateInfo → No File <==== ATTENTION
                      Task: {0F9B47A5-A3A5-4CC4-9CF4-6FCF47A1FB9F} - System32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {115F90B7-1231-4FF1-AB5B-92FEF3694B20} - System32\Tasks\Driver Easy Scheduled Scan => C:\Program Files\Easeware\DriverEasy\DriverEasy.exe (Easeware Technology Limited → Easeware)
                      Task: {159448A5-F558-4572-8A16-6E303989186A} - System32\Tasks\Microsoft\Windows\Media Center\OCURActivate => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {19946D02-33AE-4E60-81DF-5092DEB8F277} - System32\Tasks\Microsoft\VisualStudio\VSIX Auto Update 14 => D:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\VSIXAutoUpdate.exe
                      Task: {1AE784A5-A8C1-469D-ACDC-69A2BD7FEE8A} - System32\Tasks\DropboxUpdateTaskMachineUA1d1719f66 008e5b => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe (Dropbox, Inc → Dropbox, Inc.)
                      Task: {1C48C1BE-378A-4BD4-9CBC-1EE169FA27A9} - \FreeDownloadManagerNetworkMonitor → No File <==== ATTENTION
                      Task: {1DA9B645-13DA-4059-A3CB-D56C3971092C} - System32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
                      Task: {21BE9597-704B-4669-B98E-367AC00D234B} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {24672617-0A93-4BB5-8559-4012CEDFDF08} - System32\Tasks{61E32EBD-8E77-4D1B-9D4E-DFB440A9AB05} => C:\Windows\system32\pcalua.exe -a “D:\game\Gravity\openkore\Ragnarok Online\Setup.exe” -d “D:\game\Gravity\openkore\Ragnarok Online”
                      Task: {25C72C5E-A5A2-4F4B-BD37-3E4477093B5A} - System32\Tasks\Microsoft\Windows\Media Center\SqlLiteRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
                      Task: {297450E0-6ABB-427D-BB1C-BB2872268E11} - System32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask => C:\WINDOWS\ehome\mcupdate.exe
                      Task: {31709D69-4FCE-4D4D-821C-94E1E6D6B831} - System32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {36512371-A906-4CBA-8D6E-CCCA8F25E12E} - System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132-Logon => C:\Program Files\Intel\SUR\QUEENCREEK\Updater\bin\IntelSoftwa reAssetManagerService.exe (Intel(R) Software Asset Manager → Intel Corporation)
                      Task: {3BB917BA-28B7-4433-B3E7-7EFBADC9BF05} - System32\Tasks\Avast Software\Overseer => C:\Program Files\Common Files\AVAST Software\Overseer\overseer.exe (AVAST Software s.r.o. → AVAST Software)
                      Task: {3BB99F43-80C7-4010-9269-058CFC43E873} - System32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {3C199C18-45CD-429D-B193-E25CBD0D0253} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate_scheduled => C:\WINDOWS\ehome\mcupdate.exe
                      Task: {4B4D8E7B-0A5F-40FC-BBCD-29A82DE55E1E} - \AVG-SSU_0117avz_DELETE → No File <==== ATTENTION
                      Task: {4D4F0449-FE30-4BDD-871D-BC436EDB0421} - System32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {508A340E-5F91-492E-ABB0-B98532F80480} - System32\Tasks\USER_ESRV_SVC_QUEENCREEK => “C:\WINDOWS\System32\Wscript.exe” //B //NoLogo “C:\Program Files\Intel\SUR\QUEENCREEK\task.vbs”
                      Task: {522525D9-3E35-4CED-9B07-86DCF48846B4} - System32\Tasks\S-1-5-21-1925601759-1010797402-2804155008-1000\DataSenseLiveTileTask => C:\WINDOWS\System32\DataUsageLiveTileTask.exe (Microsoft Windows → Microsoft Corporation)
                      Task: {547C6C01-5708-4D14-AA13-ACA0C447A4A6} - System32\Tasks\StartCN => C:\Program Files\AMD\CNext\CNext\cncmd.exe (Advanced Micro Devices, Inc. → Advanced Micro Devices, Inc.)
                      Task: {57DFC5D9-A460-4BFF-B8E3-7B32AFB8CF85} - System32\Tasks\CommView for WiFi Update => C:\Program Files (x86)\CommViewWiFi\Updater.exe
                      Task: {5A1FB4EE-EE0E-4270-9E75-684F0AF09C07} - System32\Tasks\Microsoft\Windows\Media Center\ehDRMInit => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {621144B0-DE22-4BA5-8091-E7C4827BEF4F} - System32\Tasks\Microsoft\Windows\Media Center\RecordingRestart => C:\WINDOWS\ehome\ehrec.exe
                      Task: {67DA1BE8-90A4-4CF2-A274-8747F431E302} - System32\Tasks\Microsoft\Windows\Media Center\RegisterSearch => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {728F5E94-6E39-4D9D-BDDF-15FE8F3796DB} - \cFos\Registration Tasks\Open Browser → No File <==== ATTENTION
                      Task: {754E8E88-D223-42F3-9481-B9A6C2933CF3} - \Microsoft\Windows\UNP\RunCampaignManager → No File <==== ATTENTION
                      Task: {789B54F6-B496-4419-97FF-B9199F07696D} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe (Apple Inc. → Apple Inc.)
                      Task: {807DE444-D371-423B-899D-8236EA7A416B} - System32\Tasks\Uninstaller_SkipUac_Lenovo => C:\Program Files (x86)\IObit\IObit Uninstaller\IObitUninstaler.exe (IObit Information Technology → IObit)
                      Task: {909165E7-58B7-40A8-BAD4-06369AE44715} - System32\Tasks\Microsoft\Windows\Flighting\Feature Config\ReconcileFeatures
                      Task: {9C7FF83C-4028-4C31-9DA7-4814BF4DD82A} - System32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {9EA7EA19-87D5-4A05-90A2-77FAC5CAFED8} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe (Piriform Ltd → Piriform Ltd)
                      Task: {A1E768A1-C621-44E3-9D8D-0B31A7AA6480} - System32\Tasks\Intel\Intel Telemetry 2 => C:\Program Files\Intel\Telemetry 2.0\lrio.exe (Intel(R) Software → Intel Corporation)
                      Task: {A2BC51F7-A5A5-4583-BCFC-07D102EFC8B5} - System32\Tasks\McAfee Remediation (Prepare) => C:\Program Files\Common Files\AV\McAfee VirusScan\upgrade.exe (McAfee, Inc. → McAfee, Inc.)
                      Task: {A3F7EA55-63E8-472B-BD18-E4C82C33D682} - System32\Tasks\Adobe Flash Player Updater => C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpda teService.exe (Adobe Systems Incorporated → Adobe Systems Incorporated)
                      Task: {A65C2727-BF46-4882-A619-716BB2E10EE3} - System32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry => C:\WINDOWS\ehome\MCUpdate.exe
                      Task: {A9744BF1-B3BE-485E-8CED-C8A112DB42C9} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {B170E593-7A4A-42ED-8E5E-FE91C524223A} - System32\Tasks\Adobe Flash Player PPAPI Notifier => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_29_ 0_0_113_pepper.exe (Adobe Systems Incorporated → Adobe Systems Incorporated)
                      Task: {B79C1E15-BBAE-4901-8144-CA6499E7F7BD} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {BAB0F865-1900-4889-B5E2-E00F083B9AC6} - System32\Tasks\Opera scheduled assistant Autoupdate 1550324909 => C:\Users\Lenovo\AppData\Local\Programs\Opera\launc her.exe (Opera Software AS → Opera Software)
                      Task: {C14A101B-90DF-4EA6-814A-49BE72CAD1BA} - \AVG-SSU_0117avz → No File <==== ATTENTION
                      Task: {C35EAC49-C654-4AD2-A8E0-13BB4B538500} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate => C:\WINDOWS\ehome\mcupdate.exe
                      Task: {CB120083-D139-490E-ABC1-9711116BDE86} - System32\Tasks\Adobe Flash Player NPAPI Notifier => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_29_ 0_0_113_Plugin.exe (Adobe Systems Incorporated → Adobe Systems Incorporated)
                      Task: {CC790BC5-5E2E-431D-96D7-38992A378467} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (Google Inc → Google Inc.)
                      Task: {D841F08B-9CC5-4DE4-8780-B48A4D247CC3} - System32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: {DA3CD105-1C40-4F31-B596-534277F311B7} - System32\Tasks\Microsoft\Windows\Media Center\StartRecording => C:\WINDOWS\ehome\ehrec.exe
                      Task: {DC97CD24-99CA-4409-AA44-E0B8E9790D31} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (Google Inc → Google Inc.)
                      Task: {DEBAD4D3-2F39-4C63-9561-762021145015} - System32\Tasks\MySQL\Installer\ManifestUpdate => C:\Program Files (x86)\MySQL\MySQL Installer for Windows\MySQLInstallerConsole.exe
                      Task: {ECF63DBD-0D24-4258-861D-7F5BDFA4C73D} - System32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask => C:\WINDOWS\ehome\mcupdate.exe
                      Task: {F73979B7-3B5E-4FBF-AF56-473DC86B90CE} - System32\Tasks\Opera scheduled Autoupdate 1521719234 => C:\Users\Lenovo\AppData\Local\Programs\Opera\launc her.exe (Opera Software AS → Opera Software)
                      Task: {F8A429FB-D075-49EE-91B6-D247866AD4A6} - System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132 => C:\Program Files\Intel\SUR\QUEENCREEK\Updater\bin\IntelSoftwa reAssetManagerService.exe (Intel(R) Software Asset Manager → Intel Corporation)
                      Task: {FEB657CD-087C-4664-B5E8-D03BBC23E1CF} - System32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath => C:\WINDOWS\ehome\ehPrivJob.exe
                      Task: C:\WINDOWS\Tasks\Driver Easy Scheduled Scan.job => C:\Program Files\Easeware\DriverEasy\DriverEasy.exe
                      Task: C:\WINDOWS\Tasks\DropboxUpdateTaskMachineCore1d171 9f65cee02e.job => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
                      Task: C:\WINDOWS\Tasks\DropboxUpdateTaskMachineUA1d1719f 66008e5b.job => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
                      Task: C:\WINDOWS\Tasks\Synaptics TouchPad Enhancements.job => C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
                      ShortcutWithArgument: C:\Users\Lenovo\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\ImplicitAppShortcuts\69639df789022856\Googl e Chrome.lnk → C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) → --profile-directory=“Profile 1”
                      2018-12-18 14:31 - 2017-10-19 09:17 - 000271360 _____ (Wondershare Software) [File not signed] C:\WINDOWS\System32\WSPDFelementMonitor.dll
                      2013-08-27 17:32 - 2013-08-27 17:32 - 000747520 _____ (Intel(R) Corporation) [File not signed] C:\Program Files\Intel\iCLS Client\HeciServer.exe
                      2007-07-06 12:14 - 2007-07-06 12:14 - 005730304 _____ () [File not signed] C:\Program Files (x86)\MySQL\MySQL Server 5.0\bin\mysqld-nt.exe
                      2018-03-22 23:25 - 2018-01-31 13:39 - 001656832 _____ (Igor Pavlov) [File not signed] C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\7z.dll
                      2016-06-28 21:38 - 2016-06-28 21:38 - 000138752 _____ () [File not signed] C:\Program Files\ATI Technologies\ATI.ACE\A4\AdaptiveSleepService.exe
                      2018-01-31 17:49 - 2018-01-31 17:49 - 000009216 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPLauncher.exe
                      2018-01-31 17:49 - 2018-01-31 17:49 - 000077312 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPMaster.exe
                      2018-01-31 17:49 - 2018-01-31 17:49 - 000011264 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPUF.exe
                      2018-01-31 17:49 - 2018-01-31 17:49 - 000060928 _____ () [File not signed] C:\Program Files (x86)\AMD\Performance Profile Client\AUEPDU.exe
                      2015-11-25 06:49 - 2015-11-25 06:49 - 002257408 _____ (ActiveState Software Inc) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\python26.dll
                      2015-11-25 06:48 - 2015-11-25 06:48 - 000028160 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\servicemanager.pyd
                      2015-11-25 06:46 - 2015-11-25 06:46 - 000110592 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\pywintypes26.dll
                      2015-11-25 06:48 - 2015-11-25 06:48 - 000041472 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32service.pyd
                      2015-11-25 06:48 - 2015-11-25 06:48 - 000096256 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32api.pyd
                      2015-11-25 06:43 - 2015-11-25 06:43 - 000356864 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_hashlib.pyd
                      2015-11-25 06:48 - 2015-11-25 06:48 - 000017920 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32event.pyd
                      2015-11-25 06:48 - 2015-11-25 06:48 - 000019968 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32evtlog.pyd
                      2015-11-25 06:48 - 2015-11-25 06:48 - 000036352 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32process.pyd
                      2015-11-25 06:43 - 2015-11-25 06:43 - 000043008 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_socket.pyd
                      2015-11-25 06:43 - 2015-11-25 06:43 - 000805376 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_ssl.pyd
                      2015-11-25 06:43 - 2015-11-25 06:43 - 000087040 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV_ctypes.pyd
                      2015-11-25 06:46 - 2015-11-25 06:46 - 000354304 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\pythoncom26.dll
                      2015-11-25 06:48 - 2015-11-25 06:48 - 000167936 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\win32gui.pyd
                      2015-11-25 06:47 - 2015-11-25 06:47 - 001980928 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtGui.pyd
                      2015-11-25 07:02 - 2015-11-25 07:02 - 004604416 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Gui.dll
                      2015-11-25 07:01 - 2015-11-25 07:01 - 004088320 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Core.dll
                      2015-11-25 07:01 - 2015-11-25 07:01 - 001961472 _____ (The ICU Project) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\icuin53.dll
                      2015-11-25 07:02 - 2015-11-25 07:02 - 001316352 _____ (The ICU Project) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\icuuc53.dll
                      2015-11-25 07:01 - 2015-11-25 07:01 - 021529088 _____ (The ICU Project) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\icudt53.dll
                      2015-12-08 06:57 - 2015-12-08 06:57 - 000077824 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\sip.pyd
                      2015-11-25 06:47 - 2015-11-25 06:47 - 001862144 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtCore.pyd
                      2015-11-25 06:47 - 2015-11-25 06:47 - 000516608 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtNetwork.pyd
                      2015-11-25 07:02 - 2015-11-25 07:02 - 000839680 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Network.dll
                      2015-11-25 06:47 - 2015-11-25 06:47 - 004060160 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\PyQt5.QtWidgets.pyd
                      2015-11-25 07:01 - 2015-11-25 07:01 - 004468736 _____ (Digia Plc and/or its subsidiary(-ies)) [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\Qt5Widgets.dll
                      2015-11-25 06:43 - 2015-11-25 06:43 - 000010240 _____ () [File not signed] C:\Program Files (x86)\Raptr Inc\PlaysTV\select.pyd
                      2018-03-22 23:24 - 2018-01-18 15:20 - 002570752 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5Quick.dll
                      2018-03-22 23:24 - 2018-01-18 15:24 - 000206336 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5WinExtras.dll
                      2018-03-22 23:24 - 2018-01-18 15:14 - 004482048 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5Widgets.dll
                      2018-03-22 23:24 - 2018-01-18 15:12 - 005100032 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5Gui.dll
                      2018-03-22 23:24 - 2018-01-18 15:10 - 002012672 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5Network.dll
                      2018-03-22 23:24 - 2018-02-22 13:58 - 004809728 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5Core.dll
                      2018-03-22 23:24 - 2018-01-18 15:18 - 002522112 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5Qml.dll
                      2018-03-22 23:24 - 2018-01-18 15:15 - 000993792 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\platforms\qwindows.dll
                      2018-03-22 23:24 - 2018-01-18 15:15 - 000024576 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qgif.dll
                      2018-03-22 23:24 - 2018-01-18 15:16 - 000031232 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qicns.dll
                      2018-03-22 23:24 - 2018-01-18 15:15 - 000025088 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qico.dll
                      2018-03-22 23:24 - 2018-01-18 15:15 - 000242688 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qjpeg.dll
                      2018-03-22 23:24 - 2018-01-18 15:16 - 000019968 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qsvg.dll
                      2018-03-22 23:24 - 2018-01-18 15:16 - 000247808 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\Qt5Svg.dll
                      2018-03-22 23:24 - 2018-01-18 15:16 - 000018944 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qtga.dll
                      2018-03-22 23:24 - 2018-01-18 15:16 - 000318976 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qtiff.dll
                      2018-03-22 23:24 - 2018-01-18 15:16 - 000017920 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qwbmp.dll
                      2018-03-22 23:24 - 2018-01-18 15:16 - 000328704 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\imageformats\qwebp.dll
                      2018-03-22 23:24 - 2018-01-18 15:22 - 000013824 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\QtQuick.2\qtquick2plugin.dll
                      2018-03-22 23:24 - 2018-01-18 15:27 - 000698368 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\QtQuick\Controls\qtquickcontrolsplugin.dll
                      2018-03-22 23:24 - 2018-01-18 15:26 - 000069632 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\QtQuick\Layouts\qquicklayoutsplugin.dll
                      2018-03-22 23:24 - 2018-01-18 15:27 - 000173056 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\QtQuick\Dialogs\dialogplugin.dll
                      2018-03-22 23:24 - 2018-01-18 15:22 - 000013312 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\QtQuick\Window.2\windowplugin.dll
                      2018-03-22 23:24 - 2018-01-18 15:22 - 000013312 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\QtQml\Models.2\modelsplugin.dll
                      2018-03-22 23:24 - 2018-01-18 15:27 - 000097280 _____ (The Qt Company Ltd) [File not signed] C:\Program Files\Malwarebytes\Anti-Malware\QtQuick\PrivateWidgets\widgetsplugin.dll
                      2013-11-21 11:31 - 2013-11-21 11:31 - 000286720 _____ (Intel Corporation) [File not signed] C:\Program Files\Intel\Intel(R) Rapid Storage Technology\PsiData.dll
                      2013-11-21 11:31 - 2013-11-21 11:31 - 000499200 _____ (Intel Corporation) [File not signed] C:\Program Files\Intel\Intel(R) Rapid Storage Technology\ISDI2.dll
                      2018-05-26 17:16 - 2018-05-26 17:16 - 000097280 _____ (Microsoft Corporation) [File not signed] C:\WINDOWS\WinSxS\x86_microsoft.vc80.atl_1fc8b3b9a 1e18e3b_8.0.50727.6195_none_d1cb102c435421de\ATL80 .DLL
                      AlternateDataStreams: C:\ProgramData\Temp:56E2E879 [135]
                      ==================== Hosts content: ==========================
                      2016-11-15 03:41 - 2018-03-22 23:07 - 000001595 _____ C:\WINDOWS\system32\drivers\etc\hosts
                      127.0.0.1 bandicam.com
                      127.0.0.1 ssl.bandisoft.com
                      127.0.0.1 localhost
                      127.0.0.1 tonec.com
                      127.0.0.1 www.tonec.com
                      127.0.0.1 registeridm.com
                      127.0.0.1 www.registeridm.com
                      127.0.0.1 secure.registeridm.com
                      127.0.0.1 internetdownloadmanager.com
                      127.0.0.1 www.internetdownloadmanager.com
                      127.0.0.1 secure.internetdownloadmanager.com
                      127.0.0.1 www.secure.internetdownloadmanager.com
                      127.0.0.1 mirror.internetdownloadmanager.com
                      127.0.0.1 www.mirror.internetdownloadmanager.com
                      127.0.0.1 mirror2.internetdownloadmanager.com
                      127.0.0.1 www.mirror2.internetdownloadmanager.com
                      127.0.0.1 mirror3.internetdownloadmanager.com
                      127.0.0.1 www.mirror3.internetdownloadmanager.com
                      127.0.0.1 174.133.70.98
                      2016-11-07 03:29 - 2016-11-07 03:29 - 000000499 _____ C:\WINDOWS\system32\drivers\etc\hosts.ics
                      192.168.137.70 iPhone.mshome.net # 2016 11 0 13 17 29 46 813
                      192.168.137.1 Lenovo-PC.mshome.net # 2021 11 5 5 17 29 46 813
                      HKLM\System\CurrentControlSet\Control\Session Manager\Environment\Path: C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;%SystemRoot%\system32;%SystemRoot%;%SystemR oot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPo werShell\v1.0;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Windows Live\Shared;D:\Program Files (x86)\QuickTime\QTSystem;C:\Program Files (x86)\Skype\Phone;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn;C:\Program Files\Microsoft SQL Server\100\Tools\Binn;C:\Program Files\Microsoft SQL Server\100\DTS\Binn;%SYSTEMROOT%\System32\OpenSSH
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000\Control Panel\Desktop\Wallpaper → C:\Windows\Web\Wallpaper\Windows\img0.jpg
                      DNS Servers: 192.168.0.1
                      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
                      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer => (SmartScreenEnabled: Off)
                      HKLM\software\microsoft\Windows\CurrentVersion\Tel ephony\Providers => ProviderFileName2 → ndptsp.tsp (No File)
                      Windows Firewall is enabled.
                      If an entry is included in the fixlist, it will be removed.
                      MSCONFIG\Services: ACDaemon => 3
                      MSCONFIG\Services: CLHNServiceForPowerDVD => 2
                      MSCONFIG\Services: CxAudMsg => 2
                      MSCONFIG\Services: CyberLink PowerDVD 11.0 Monitor Service => 2
                      MSCONFIG\Services: CyberLink PowerDVD 11.0 Service => 2
                      MSCONFIG\Services: dbupdate => 2
                      MSCONFIG\Services: dbupdatem => 3
                      MSCONFIG\Services: ETDService => 2
                      MSCONFIG\Services: gusvc => 3
                      MSCONFIG\Services: hmevpnsvc => 2
                      MSCONFIG\Services: iPod Service => 3
                      MSCONFIG\Services: MozillaMaintenance => 3
                      MSCONFIG\Services: OverwolfUpdater => 3
                      MSCONFIG\Services: PingzapperSvc => 2
                      MSCONFIG\Services: Razer Game Scanner Service => 2
                      MSCONFIG\Services: SkypeUpdate => 2
                      MSCONFIG\Services: TeamViewer => 2
                      MSCONFIG\Services: UDisk Monitor => 2
                      MSCONFIG\Services: WtuSystemSupport => 2
                      MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^McAfee Security Scan Plus.lnk => C:\Windows\pss\McAfee Security Scan Plus.lnk.CommonStartup
                      MSCONFIG\startupfolder: C:^Users^Lenovo^AppData^Roaming^Microsoft^Windows^ Start Menu^Programs^Startup^MYOB Add-On Connector.lnk => C:\Windows\pss\MYOB Add-On Connector.lnk.Startup
                      MSCONFIG\startupreg: Adobe ARM => “C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe”
                      MSCONFIG\startupreg: AdobeAAMUpdater-1.0 => “C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe”
                      MSCONFIG\startupreg: APSDaemon => “C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe”
                      MSCONFIG\startupreg: AVG-Secure-Search-Update_0715tb => “C:\ProgramData\Avg_Update_0715tb\AVG-Secure-Search-Update_0715tb.exe” /PROMPT /CMPID=0715tb
                      MSCONFIG\startupreg: BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA} => “C:\Program Files (x86)\Common Files\Ahead\Lib\NMBgMonitor.exe”
                      MSCONFIG\startupreg: cAudioFilterAgent => C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent 64.exe
                      MSCONFIG\startupreg: cFosSpeed => C:\Program Files\cFosSpeed\cFosSpeed.exe
                      MSCONFIG\startupreg: Dropbox => “C:\Program Files (x86)\Dropbox\Client\Dropbox.exe” /systemstartup
                      MSCONFIG\startupreg: Energy Management => C:\Program Files (x86)\Lenovo\Energy Management\Energy Management.exe
                      MSCONFIG\startupreg: EnergyUtility => C:\Program Files (x86)\Lenovo\Energy Management\Utility.exe
                      MSCONFIG\startupreg: ForteConfig => C:\Program Files\Conexant\ForteConfig\fmapp.exe
                      MSCONFIG\startupreg: Google Update => “C:\Users\Lenovo\AppData\Local\Google\Update\Googl eUpdate.exe” /c
                      MSCONFIG\startupreg: GrooveMonitor => “C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe”
                      MSCONFIG\startupreg: HotKeysCmds => “C:\Windows\system32\hkcmd.exe”
                      MSCONFIG\startupreg: IAStorIcon => “C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIconLaunch.exe” “C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe” 60
                      MSCONFIG\startupreg: IgfxTray => “C:\Windows\system32\igfxtray.exe”
                      MSCONFIG\startupreg: Launch LCore => C:\Program Files\Logitech Gaming Software\LCore.exe /minimized
                      MSCONFIG\startupreg: Overwolf => C:\Program Files (x86)\Overwolf\Overwolf.exe -silent
                      MSCONFIG\startupreg: Persistence => “C:\Windows\system32\igfxpers.exe”
                      MSCONFIG\startupreg: QuickTime Task => “C:\Program Files (x86)\QuickTime\QTTask.exe” -atboottime
                      MSCONFIG\startupreg: Raptr => C:\Program Files (x86)\Raptr\RAPTRS~1.EXE --startup
                      MSCONFIG\startupreg: Razer Synapse => “C:\Program Files (x86)\Razer\Synapse\RzSynapse.exe”
                      MSCONFIG\startupreg: RemoteControl11 => “C:\Program Files (x86)\CyberLink\PowerDVD11\PDVD11Serv.exe”
                      MSCONFIG\startupreg: Sidebar => C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
                      MSCONFIG\startupreg: SmartAudio => C:\Program Files\CONEXANT\SAII\SACpl.exe /t
                      MSCONFIG\startupreg: Spotify => “C:\Users\Lenovo\AppData\Roaming\Spotify\Spotify.e xe” -autostart -minimized
                      MSCONFIG\startupreg: Spotify Web Helper => “C:\Users\Lenovo\AppData\Roaming\Spotify\SpotifyWe bHelper.exe”
                      MSCONFIG\startupreg: StartCCC => “C:\Program Files (x86)\AMD\ATI.ACE\Core-Static\amd64\CLIStart.exe” MSRun
                      MSCONFIG\startupreg: Steam => “C:\Program Files (x86)\Steam\steam.exe” -silent
                      MSCONFIG\startupreg: SynLenovoGestureMgr => %ProgramFiles%\Synaptics\SynTP\SynLenovoGestureMgr .exe
                      MSCONFIG\startupreg: SynTPEnh => %ProgramFiles%\Synaptics\SynTP\SynTPEnh.exe
                      MSCONFIG\startupreg: USB3MON => “C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe”
                      MSCONFIG\startupreg: vProt => “C:\Program Files (x86)\AVG Web TuneUp\vprot.exe”
                      MSCONFIG\startupreg: WTFast Tray => “D:\Program Files (x86)\WTFast\WTFast.exe” trayonly
                      HKLM...\StartupApproved\Run: => “cAudioFilterAgent”
                      HKLM...\StartupApproved\Run: => “ForteConfig”
                      HKLM...\StartupApproved\Run: => “iTunesHelper”
                      HKLM...\StartupApproved\Run: => “StartCN”
                      HKLM...\StartupApproved\Run32: => “DivXUpdate”
                      HKLM...\StartupApproved\Run32: => “DivXMediaServer”
                      HKLM...\StartupApproved\Run32: => “Dropbox”
                      HKLM...\StartupApproved\Run32: => “AVG_UI”
                      HKLM...\StartupApproved\Run32: => “QuickTime Task”
                      HKLM...\StartupApproved\Run32: => “Raptr”
                      HKLM...\StartupApproved\Run32: => “vProt”
                      HKLM...\StartupApproved\Run32: => “PlaysTV”
                      HKLM...\StartupApproved\Run32: => “Wondershare Helper Compact.exe”
                      HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched”
                      HKLM...\StartupApproved\Run32: => “SecurityHealth”
                      HKLM...\StartupApproved\Run32: => “SmartAudio”
                      HKLM...\StartupApproved\Run32: => “ETDCtrl”
                      HKLM...\StartupApproved\Run32: => “DSATray”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\StartupFolder: => “hide.me VPN.lnk”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\StartupFolder: => “Bitcoin.lnk”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Discord”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “OneDrive”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Spotify Web Helper”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “WTFast Tray”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “CCleaner Monitoring”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Free Download Manager”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “Adguard”
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\StartupApproved\Run: => “DownloadAccelerator”
                      FirewallRules: [{C85BB459-5825-465E-9C64-4F6D04295ECA}] => (Allow) D:\Steam\Steam.exe (Valve → Valve Corporation)
                      FirewallRules: [{56B248C4-51C0-4881-A3DF-FFE49495D7A2}] => (Allow) D:\Steam\Steam.exe (Valve → Valve Corporation)
                      FirewallRules: [{384A9A9E-27F1-4EEA-8FB8-BE8AA17306FB}] => (Allow) D:\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve → Valve Corporation)
                      FirewallRules: [{8F158D42-D729-46B6-B6CB-533F4AC05185}] => (Allow) D:\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve → Valve Corporation)
                      FirewallRules: [{435422B9-07FA-46DF-A741-237F7C2210F3}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
                      FirewallRules: [{22F62F48-C02A-4790-A6F5-8B890C3CCB15}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
                      FirewallRules: [{B4DEDF6A-1421-40E0-8BAF-84376A31421B}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2cfg.exe (Valve → )
                      FirewallRules: [{08045740-3153-41A2-9A22-8AAD96F532E8}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2cfg.exe (Valve → )
                      FirewallRules: [{2C9C57C3-E3E0-4550-87ED-D230BE7E01BA}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
                      FirewallRules: [{2F0F5E82-9854-4FF2-8036-7472B1B31AFD}] => (Allow) D:\Steam\SteamApps\common\dota 2 beta\game\bin\win64\dota2.exe (Valve → )
                      FirewallRules: [{91CF5134-F890-4AD5-9C20-E746603126B1}] => (Allow) C:\Program Files (x86)\360\Total Security\LiveUpdate360.exe (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
                      FirewallRules: [{2900A6FC-2B32-4C08-A628-19A07D548503}] => (Allow) C:\Program Files (x86)\360\Total Security\LiveUpdate360.exe (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
                      FirewallRules: [{C233EE90-5EF6-4A79-B869-7D6D847044E9}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation → Mozilla Corporation)
                      FirewallRules: [{0729A247-3837-46E5-8510-48BDE54ECD0B}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation → Mozilla Corporation)
                      FirewallRules: [{0B7BDA4E-3B54-4A69-86BA-2E08D8A8F8D8}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google LLC → Google Inc.)
                      FirewallRules: [{539A723E-25CF-46FC-88FD-54482A7313F9}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
                      FirewallRules: [{345B4A24-9BEC-4E18-A135-B2BE5B1E76FE}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
                      19-04-2019 04:42:40 Scheduled Checkpoint
                      Error: (04/19/2019 10:14:43 AM) (Source: Application Error) (EventID: 1000) (User: )
                      Description: Faulting application name: AvLaunch.exe, version: 19.3.4241.0, time stamp: 0x5c82677e
                      Faulting module name: ucrtbase.dll, version: 10.0.17134.677, time stamp: 0x9f346d3f
                      Exception code: 0xc0000409
                      Fault offset: 0x000000000006e14e
                      Faulting process id: 0x176c
                      Faulting application start time: 0x01d4f6449fe30c0a
                      Faulting application path: C:\Program Files\AVAST Software\Avast\AvLaunch.exe
                      Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
                      Report Id: 63396444-9bfc-471f-a29d-aab87208a1ba
                      Faulting package full name:
                      Error: (04/19/2019 10:09:58 AM) (Source: MSSQL$SQLEXPRESS) (EventID: 8317) (User: )
                      Description: Cannot query value ‘First Counter’ associated with registry key ‘HKLM\SYSTEM\CurrentControlSet\Services\MSSQL$SQLE XPRESS\Performance’. SQL Server performance counters are disabled.
                      Error: (04/19/2019 10:06:59 AM) (Source: Windows Search Service) (EventID: 1019) (User: )
                      Description: Windows Search Service failed to process the list of included and excluded locations with the error <30, 0x80040d07, “iehistory://{S-1-5-21-1925601759-1010797402-2804155008-1000}/”>.
                      Error: (04/19/2019 10:03:38 AM) (Source: VSS) (EventID: 8193) (User: )
                      Description: Volume Shadow Copy Service error: Unexpected error calling routine QueryFullProcessImageNameW. hr = 0x80070006, The handle is invalid.
                      Operation:
                      Executing Asynchronous Operation
                      Context:
                      Current State: DoSnapshotSet
                      Error: (04/19/2019 09:53:50 AM) (Source: Application Error) (EventID: 1000) (User: )
                      Faulting process id: 0x2340
                      Faulting application start time: 0x01d4f641b75869fb
                      Report Id: 2fb64e77-70ba-4a85-adc7-38962547547f
                      Error: (04/19/2019 09:51:05 AM) (Source: Perflib) (EventID: 1008) (User: )
                      Description: The Open Procedure for service “SQLAgent$SQLEXPRESS” in DLL “perf-SQLAgent$SQLEXPRESS-sqlagtctr10.1.2531.0.dll” failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
                      Error: (04/19/2019 09:51:04 AM) (Source: Perflib) (EventID: 1023) (User: )
                      Description: Windows cannot load the extensible counter DLL rdyboost. The first four bytes (DWORD) of the Data section contains the Windows error code.
                      Error: (04/19/2019 09:50:59 AM) (Source: Perflib) (EventID: 1008) (User: )
                      Description: The Open Procedure for service “MSSQL$SQLEXPRESS” in DLL “perf-MSSQL$SQLEXPRESS-sqlctr10.1.2531.0.dll” failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
                      Error: (04/19/2019 10:49:31 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
                      and APPID
                      to the user Lenovo-PC\Lenovo SID (S-1-5-21-1925601759-1010797402-2804155008-1000) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
                      Error: (04/19/2019 10:16:33 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      Description: The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
                      Windows.SecurityCenter.WscBrokerManager
                      and APPID
                      Unavailable
                      to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
                      Error: (04/19/2019 10:16:32 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      and APPID
                      Unavailable
                      Error: (04/19/2019 10:16:31 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      and APPID
                      Unavailable
                      Error: (04/19/2019 10:16:30 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      and APPID
                      Unavailable
                      Error: (04/19/2019 10:16:29 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      and APPID
                      Unavailable
                      Error: (04/19/2019 10:14:35 AM) (Source: DCOM) (EventID: 10016) (User: Lenovo-PC)
                      and APPID
                      Error: (04/19/2019 10:10:37 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
                      and APPID
                      to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
                      Date: 2019-04-19 10:35:52.456
                      Description:
                      Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume2\Program Files (x86)\360\Total Security\I18N64.dll that did not meet the Store signing level requirements.
                      Date: 2019-04-19 10:35:52.425
                      Description:
                      Date: 2019-04-19 10:35:34.363
                      Description:
                      Date: 2019-04-19 10:35:33.720
                      Description:
                      Date: 2019-04-19 10:35:26.718
                      Description:
                      Description:
                      Date: 2019-04-19 03:22:50.135
                      Description:
                      Date: 2019-04-19 03:22:50.082
                      Description:
                      Processor: Intel(R) Core™ i7-4510U CPU @ 2.00GHz
                      Percentage of memory in use: 47%
                      Total physical RAM: 8088.36 MB
                      Available physical RAM: 4226.23 MB
                      Total Virtual: 20220.36 MB
                      Available Virtual: 15388.08 MB
                      Drive c: (OS) (Fixed) (Total:151.27 GB) (Free:19.03 GB) NTFS
                      Drive d: (Data) (Fixed) (Total:584.83 GB) (Free:275.81 GB) NTFS
                      Drive f: (Bandicam) (Fixed) (Total:195.31 GB) (Free:179.55 GB) NTFS
                      \?\Volume{c05dd144-747f-11e4-9d1a-806e6f6e6963}\ (System Reserved) (Fixed) (Total:0.1 GB) (Free:0.05 GB) NTFS
                      Disk: 0 (MBR Code: Windows 7/8/10) (Size: 931.5 GB) (Disk ID: D9FA2484)
                      Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
                      Partition 2: (Not Active) - (Size=151.3 GB) - (Type=07 NTFS)
                      Partition 3: (Not Active) - (Size=584.8 GB) - (Type=07 NTFS)
                      Partition 4: (Not Active) - (Size=195.3 GB) - (Type=0F Extended)
                      FRST:
                      Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 18.04.2019
                      Ran by Lenovo (administrator) on LENOVO-PC (19-04-2019 12:45:49)
                      Running from C:\Users\Lenovo\Downloads
                      Loaded Profiles: Lenovo (Available Profiles: Lenovo & DefaultAppPool)
                      Platform: Windows 10 Pro Version 1803 17134.706 (X64) Language: English (United States)
                      Default browser: Chrome
                      Boot Mode: Normal
                      Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic...ery-scan-tool/
                      (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.) C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe
                      (Apple Inc. → Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                      (AnchorFree Inc → AnchorFree Inc.) C:\Program Files (x86)\Hotspot Shield\bin\cmw_srv.exe
                      (Conexant Systems, Inc. → Conexant Systems Inc.) C:\Windows\System32\CxAudMsg64.exe
                      (Intel(R) Driver & Support Assistant → Intel) C:\Program Files (x86)\Intel Driver and Support Assistant\DSAService.exe
                      (McAfee, Inc. → McAfee, LLC.) C:\Program Files\McAfee\TrueKey\McTkSchedulerService.exe
                      (Apple Inc. → Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
                      (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDService.exe
                      (Plays.tv, LLC → Plays.tv, LLC) C:\Program Files (x86)\Raptr Inc\PlaysTV\plays_service.exe
                      (McAfee, Inc. → McAfee, LLC.) C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.Service.exe
                      (McAfee, Inc. → McAfee, LLC.) C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.ServiceHelper. exe
                      (Microsoft Corporation → Microsoft Corporation) C:\Program Files\Microsoft SQL Server\90\Shared\sqlwriter.exe
                      (Microsoft Corporation → Microsoft Corporation) C:\Program Files\Microsoft SQL Server\MSSQL10.SQLEXPRESS\MSSQL\Binn\sqlservr.exe
                      (Razer Inc. → Razer Inc.) D:\Program Files (x86)\Razer\Razer Game Booster\RzKLService.exe
                      (Malwarebytes Corporation → Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
                      (TeamViewer GmbH → TeamViewer GmbH) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
                      (QIHU 360 SOFTWARE CO. LIMITED → QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHWatchdog.exe
                      (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrl.exe
                      (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.) C:\Program Files\Elantech\ETDCtrlHelper.exe
                      (TeamViewer GmbH → TeamViewer GmbH) C:\Program Files (x86)\TeamViewer\TeamViewer.exe
                      (Malwarebytes Corporation → Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
                      (IObit Information Technology → IObit) C:\Program Files (x86)\IObit\IObit Uninstaller\UninstallMonitor.exe
                      (TeamViewer GmbH → TeamViewer GmbH) C:\Program Files (x86)\TeamViewer\tv_w32.exe
                      (TeamViewer GmbH → TeamViewer GmbH) C:\Program Files (x86)\TeamViewer\tv_x64.exe
                      (Intel Corporation - Intel® Management Engine Firmware → Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
                      (Microsoft Corporation) [File not signed] C:\Program Files\WindowsApps\Microsoft.SkypeApp_14.42.60.0_x6 4__kzf8qxf38zg5c\SkypeApp.exe
                      () [File not signed] C:\Program Files\WindowsApps\Microsoft.SkypeApp_14.42.60.0_x6 4__kzf8qxf38zg5c\SkypeBackgroundHost.exe
                      (Microsoft Windows → Microsoft Corporation) C:\Program Files\Windows Defender\MSASCuiL.exe
                      (Opera Software AS → Opera Software) C:\Users\Lenovo\AppData\Local\Programs\Opera\assis tant\browser_assistant.exe
                      () [File not signed] C:\Program Files\WindowsApps\Microsoft.ZuneVideo_10.19031.114 11.0_x64__8wekyb3d8bbwe\Video.UI.exe
                      () [File not signed] C:\Program Files\ATI Technologies\ATI.ACE\a4\AdaptiveSleepService.exe
                      (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
                      (Intel Corporation - Intel® Rapid Storage Technology → Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
                      (Microsoft Windows → Microsoft Corporation) C:\Program Files\rempl\sedsvc.exe
                      (Microsoft Windows → Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
                      (Google LLC → Google Inc.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                      (Microsoft Windows → Microsoft Corporation) C:\Windows\System32\OpenWith.exe
                      (Microsoft Windows → Microsoft Corporation) C:\Windows\System32\dllhost.exe
                      () [File not signed] C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2019.19 021.18010.0_x64__8wekyb3d8bbwe\Microsoft.Photos.ex e
                      ==================== Registry (Whitelisted) ===========================
                      HKLM...\Run: [SecurityHealth] => C:\Program Files\Windows Defender\MSASCuiL.exe [638872 2018-04-12] (Microsoft Windows → Microsoft Corporation)
                      HKLM...\Run: [ETDCtrl] => C:\Program Files\Elantech\ETDCtrl.exe [3242696 2015-10-07] (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.)
                      HKLM...\Run: [ForteConfig] => C:\Program Files\Conexant\ForteConfig\fmapp.exe [49056 2010-10-26] (Fortemedia Inc → )
                      HKLM...\Run: [cAudioFilterAgent] => C:\Program Files\Conexant\cAudioFilterAgent\cAudioFilterAgent 64.exe [935104 2014-11-25] (Conexant Systems, Inc. → Conexant Systems, Inc.)
                      HKLM...\Run: [iTunesHelper] => D:\Program Files\iTunes\iTunesHelper.exe [298296 2018-01-22] (Apple Inc. → Apple Inc.)
                      HKLM-x32...\Run: [vProt] => “C:\Program Files (x86)\AVG Web TuneUp\vprot.exe”
                      HKLM-x32...\Run: [Dropbox] => C:\Program Files (x86)\Dropbox\Client\Dropbox.exe [3567936 2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      HKLM-x32...\Run: [PlaysTV] => C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv_launcher.exe [71440 2016-08-10] (Plays.tv, LLC → Plays.tv, LLC)
                      HKLM-x32...\Run: [Raptr] => C:\Program Files (x86)\Raptr Inc\Raptr\raptrstub.exe [58640 2016-04-01] (Raptr, Inc → Raptr, Inc)
                      HKLM-x32...\Run: [QHSafeTray] => C:\Program Files (x86)\360\Total Security\safemon\360Tray.exe [669248 2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
                      HKLM-x32...\Run: [DSATray] => C:\Program Files (x86)\Intel Driver and Support Assistant\DsaTray.exe [135968 2018-03-15] (Intel(R) Driver & Support Assistant → Intel)
                      HKLM-x32...\Run: [AvastUI.exe] => C:\Program Files\AVAST Software\Avast\AvLaunch.exe [260488 2019-03-18] (AVAST Software s.r.o. → AVAST Software)
                      HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Restriction <==== ATTENTION
                      HKU\S-1-5-19...\RunOnce: [WAB Migrate] => C:\Program Files\Windows Mail\wab.exe [518144 2018-04-12] (Microsoft Windows → Microsoft Corporation)
                      HKU\S-1-5-20...\RunOnce: [WAB Migrate] => C:\Program Files\Windows Mail\wab.exe [518144 2018-04-12] (Microsoft Windows → Microsoft Corporation)
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [17074688 2018-03-07] (Piriform Ltd → Piriform Ltd)
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Run: [Opera Browser Assistant] => C:\Users\Lenovo\AppData\Local\Programs\Opera\assis tant\browser_assistant.exe [2480216 2019-02-12] (Opera Software AS → Opera Software)
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Policies\Explorer: [NoLowDiskSpaceChecks] 1
                      HKLM...\Drivers32: [VIDC.FPS1] => C:\WINDOWS\system32\frapsv64.dll [105984 2015-09-05] (Beepa P/L) [File not signed]
                      HKLM...\Drivers32: [VIDC.HFYU] => C:\WINDOWS\system32\huffyuv.dll [55296 2005-01-22] () [File not signed]
                      HKLM...\Drivers32: [VIDC.LAGS] => C:\WINDOWS\system32\lagarith.dll [148992 2011-12-08] ( ) [File not signed]
                      HKLM...\Drivers32: [VIDC.X264] => C:\WINDOWS\system32\x264vfw64.dll [3799552 2017-07-30] (x264vfw project) [File not signed]
                      HKLM...\Drivers32: [VIDC.XVID] => C:\WINDOWS\system32\xvidvfw.dll [311296 2018-01-28] () [File not signed]
                      HKLM...\Drivers32: [VIDC.FFDS] => C:\WINDOWS\system32\ff_vfw.dll [126976 2015-08-25] () [File not signed]
                      HKLM...\Drivers32: [msacm.ac3acm] => C:\WINDOWS\system32\ac3acm.acm [180736 2012-07-21] (fccHandler) [File not signed]
                      HKLM...\Drivers32: [VIDC.FPS1] => C:\Windows\SysWOW64\frapsvid.dll [94208 2015-09-05] (Beepa P/L) [File not signed]
                      HKLM...\Drivers32: [VIDC.HFYU] => C:\WINDOWS\SysWOW64\huffyuv.dll [39936 2004-05-19] (Disappearing Inc.) [File not signed]
                      HKLM...\Drivers32: [VIDC.LAGS] => C:\WINDOWS\SysWOW64\lagarith.dll [216064 2011-12-08] ( ) [File not signed]
                      HKLM...\Drivers32: [VIDC.X264] => C:\Windows\SysWOW64\x264vfw.dll [3850240 2017-07-30] (x264vfw project) [File not signed]
                      HKLM...\Drivers32: [VIDC.XVID] => C:\WINDOWS\SysWOW64\xvidvfw.dll [284672 2018-01-28] () [File not signed]
                      HKLM...\Drivers32: [msacm.ac3acm] => C:\WINDOWS\SysWOW64\ac3acm.acm [122880 2012-07-21] (fccHandler) [File not signed]
                      HKLM...\Drivers32: [msacm.lameacm] => C:\Windows\SysWOW64\lameACM.acm [473088 2015-02-26] (hxxp://www.mp3dev.org/) [File not signed]
                      HKLM...\Drivers32: [VIDC.FFDS] => C:\WINDOWS\SysWOW64\ff_vfw.dll [112128 2015-08-25] () [File not signed]
                      HKLM\Software\Wow6432Node\Microsoft\Active Setup\Installed Components: [{8A69D345-D564-463c-AFF1-A69D9E530F96}] → C:\Program Files (x86)\Google\Chrome\Application\73.0.3683.103\Inst aller\chrmstp.exe [2019-04-19] (Google LLC → Google Inc.)
                      HKLM\Software...\Authentication\Credential Providers: [{503739d0-4c5e-4cfd-b3ba-d881334f0df2}] →
                      HKLM\Software...\Authentication\Credential Providers: [{B7724AE5-1135-4889-8A5F-CA98BE6CA1ED}] → C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.CredentialProv ider.dll [2018-11-27] (McAfee, Inc. → McAfee, LLC.)
                      Lsa: [Notification Packages] scecli C:\Program Files\TrueKey\McAfeeTrueKeyPasswordFilter “C:\Program Files\TrueKey\McAfeeTrueKeyPasswordFilter” “C:\Program Files\McAfee\TrueKey\McAfeeTrueKeyPasswordFilter”
                      GroupPolicy: Restriction ? <==== ATTENTION
                      Hosts: There are more than one entry in Hosts. See Hosts section of Addition.txt
                      Tcpip\Parameters: [DhcpNameServer] 192.168.0.1
                      Tcpip..\Interfaces{2e5093be-ec30-45b1-a0b7-0a9388c176f1}: [DhcpNameServer] 172.20.10.1
                      Tcpip..\Interfaces{8d45d7f2-23ec-402e-ba7c-d7e2681ab43c}: [DhcpNameServer] 192.168.0.1
                      [HEADING=1]Internet Explorer:[/HEADING]
                      HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <==== ATTENTION
                      HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://www.google.com/
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = hxxp://www.google.com/
                      HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.google.com/?q={searchTerms}
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.google.com/?q={searchTerms}
                      HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://www.google.com/
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://www.google.com/
                      HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = hxxp://www.google.com/
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = hxxp://www.google.com/
                      HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Local Page =
                      HKU\S-1-5-21-1925601759-1010797402-2804155008-1000\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = hxxp://www.google.com/ie
                      BHO: ExplorerWnd Helper → {10921475-03CE-4E04-90CE-E2E7EF20C814} → C:\Program Files (x86)\IObit\IObit Uninstaller\UninstallExplorer.dll [2018-07-19] (IObit Information Technology → IObit)
                      BHO-x32: Groove GFS Browser Helper → {72853161-30C5-4D22-B7F9-0BBC1D38A37E} → C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll [2009-02-26] (Microsoft Corporation → Microsoft Corporation)
                      Toolbar: HKLM - True Key - {4BAAC1B8-0800-42C9-8FA6-08B211F356B8} - C:\Program Files\McAfee\TrueKey\MSIE\truekey_ie64.dll [2018-04-23] (McAfee, Inc. → Intel Security)
                      Toolbar: HKLM-x32 - True Key - {4BAAC1B8-0800-42C9-8FA6-08B211F356B8} - C:\Program Files\McAfee\TrueKey\MSIE\truekey_ie.dll [2018-04-23] (McAfee, Inc. → Intel Security)
                      Handler: viprotocol - {B658800C-F66E-4EF3-AB85-6C0C227862A9} - C:\Program Files (x86)\Common Files\AVG Secure Search\ViProtocolInstaller\18.2.0\ViProtocol.dll No File
                      [HEADING=1]FireFox:[/HEADING]
                      FF ProfilePath: C:\Users\Lenovo\AppData\Roaming\Mozilla\Firefox\Pr ofiles\yyjwfhm6.default [2019-04-19]
                      FF HKLM-x32...\Firefox\Extensions: [daplinkchecker@speedbit.com] - D:\Program Files (x86)\DAP\daplinkchecker
                      FF Extension: (DAP Link Checker) - D:\Program Files (x86)\DAP\daplinkchecker [2017-11-12] [Legacy] [not signed]
                      FF HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\Firefox\Extensions: [{F17C1572-C9EC-4e5c-A542-D05CBB5C5A08}] - D:\Program Files (x86)\DAP\DAPFireFox
                      FF Extension: (Download Accelerator Plus (DAP) extension) - D:\Program Files (x86)\DAP\DAPFireFox [2017-11-12] [Legacy] [not signed]
                      FF HKU\S-1-5-21-1925601759-1010797402-2804155008-1000...\SeaMonkey\Extensions: [mozilla_cc2@internetdownloadmanager.com] - C:\Program Files (x86)\Internet Download Manager\idmmzcc2.xpi => not found
                      FF Plugin: @adobe.com/FlashPlayer → C:\WINDOWS\system32\Macromed\Flash\NPSWF64_29_0_0_ 113.dll [2018-03-22] (Adobe Systems Incorporated → )
                      FF Plugin: @divx.com/DivX VOD Helper,version=1.0.0 → C:\Program Files\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC → DivX, LLC.)
                      FF Plugin: @java.com/DTPlugin,version=10.40.2 → C:\WINDOWS\system32\npDeployJava1.dll [2014-11-25] (Oracle America, Inc. → Oracle Corporation)
                      FF Plugin: @Microsoft.com/NpCtrl,version=1.0 → C:\Program Files\Microsoft Silverlight\5.1.50918.0\npctrl.dll [2018-10-23] (Microsoft Corporation → Microsoft Corporation)
                      FF Plugin: adobe.com/AdobeAAMDetect → C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities\npAdobeAAMDet ect64.dll [2014-04-28] (Adobe Systems Incorporated → Adobe Systems)
                      FF Plugin-x32: @adobe.com/FlashPlayer → C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_29_0_0_ 113.dll [2018-03-22] (Adobe Systems Incorporated → )
                      FF Plugin-x32: @avg.com/AVG SiteSafety plugin,version=11.0.0.1,application/x-avg-sitesafety-plugin → C:\Program Files (x86)\Common Files\AVG Secure Search\SiteSafetyInstaller\40.3.6\npsitesafety.dll [No File]
                      FF Plugin-x32: @divx.com/DivX VOD Helper,version=1.0.0 → C:\Program Files (x86)\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC → DivX, LLC.)
                      FF Plugin-x32: @divx.com/DivX Web Player Plug-In,version=1.0.0 → C:\Program Files (x86)\DivX\DivX Web Player\npdivx32.dll [2015-09-02] (DivX, LLC → DivX, LLC)
                      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.5 → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2013-09-16] (Intel® Identity Protection Technology Software → Intel Corporation)
                      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2013-09-16] (Intel® Identity Protection Technology Software → Intel Corporation)
                      FF Plugin-x32: @java.com/DTPlugin,version=11.161.2 → C:\Program Files (x86)\Java\jre1.8.0_161\bin\dtplugin\npDeployJava1 .dll [2018-03-22] (Oracle America, Inc. → Oracle Corporation)
                      FF Plugin-x32: @java.com/JavaPlugin,version=11.161.2 → C:\Program Files (x86)\Java\jre1.8.0_161\bin\plugin2\npjp2.dll [2018-03-22] (Oracle America, Inc. → Oracle Corporation)
                      FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 → C:\Program Files (x86)\Microsoft Silverlight\5.1.50918.0\npctrl.dll [2018-10-23] (Microsoft Corporation → Microsoft Corporation)
                      FF Plugin-x32: @microsoft.com/WLPG,version=16.4.3528.0331 → C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll [2014-04-01] (Microsoft Corporation → Microsoft Corporation)
                      FF Plugin-x32: @raidcall.en/RCplugin → C:\Users\Lenovo\AppData\Roaming\raidcall\plugins\n prcplugin.dll [2014-05-27] (Raidcall) [File not signed]
                      FF Plugin-x32: @softnyxNpruntime → D:\Game\SoftnyxGame\NyxLauncherIS\npSoftnyx.dll [No File]
                      FF Plugin-x32: @tools.google.com/Google Update;version=3 → C:\Program Files (x86)\Google\Update\1.3.34.7\npGoogleUpdate3.dll [2019-04-19] (Google Inc → Google LLC)
                      FF Plugin-x32: @tools.google.com/Google Update;version=9 → C:\Program Files (x86)\Google\Update\1.3.34.7\npGoogleUpdate3.dll [2019-04-19] (Google Inc → Google LLC)
                      FF Plugin-x32: @videolan.org/vlc,version=2.2.4 → D:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2018-02-27] (VideoLAN → VideoLAN)
                      FF Plugin-x32: @videolan.org/vlc,version=3.0.1 → D:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2018-02-27] (VideoLAN → VideoLAN)
                      FF Plugin HKU\S-1-5-21-1925601759-1010797402-2804155008-1000: @zoom.us/ZoomVideoPlugin → C:\Users\Lenovo\AppData\Roaming\Zoom\bin\npzoomplu gin.dll [2017-11-14] (Zoom Video Communications, Inc. → Zoom Video Communications, Inc.)
                      [HEADING=1]Chrome:[/HEADING]
                      CHR Profile: C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default [2019-04-19]
                      CHR Extension: (Slides) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhon fmgoek [2019-04-19]
                      CHR Extension: (AdLock ad blocker) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\aemffjkmgcepimloclpkecifcn ipnodh [2019-04-19]
                      CHR Extension: (Docs) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfi lokake [2019-04-19]
                      CHR Extension: (Google Drive) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigk jlhalf [2019-04-19]
                      CHR Extension: (YouTube) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldk acnbeo [2019-04-19]
                      CHR Extension: (Sheets) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpeb giejap [2019-04-19]
                      CHR Extension: (Google Docs Offline) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdl olhkhi [2019-04-19]
                      CHR Extension: (AdBlock) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\gighmmpiobklfepjocnamgkkbi glidom [2019-04-19]
                      CHR Extension: (Chrome Web Store Payments) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccm gmieda [2019-04-19]
                      CHR Extension: (Gmail) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoe jaedia [2019-04-19]
                      CHR Extension: (Chrome Media Router) - C:\Users\Lenovo\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm [2019-04-19]
                      CHR HKLM...\Chrome\Extension: [ngpampappnmepgilojfohadhhmbhlaek] - C:\Program Files (x86)\Internet Download Manager\IDMGCExt.crx
                      [HEADING=1]Opera:[/HEADING]
                      OPR Extension: (Adblock Plus - free ad blocker) - C:\Users\Lenovo\AppData\Roaming\Opera Software\Opera Stable\Extensions\oidhhegpmlfpoeialbgcdocjalghfpkp [2019-04-18]
                      S4 ACDaemon; C:\Program Files (x86)\Common Files\ArcSoft\Connection Service\Bin\ACService.exe [109056 2009-02-06] (ArcSoft, Inc. → ArcSoft Inc.)
                      R2 AdaptiveSleepService; C:\Program Files\ATI Technologies\ATI.ACE\A4\AdaptiveSleepService.exe [138752 2016-06-28] () [File not signed]
                      S3 AMD External Events Utility; C:\WINDOWS\system32\atiesrxx.exe [287264 2016-08-04] (Microsoft Windows Hardware Compatibility Publisher → AMD)
                      R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2018-01-05] (Apple Inc. → Apple Inc.)
                      R2 AUEPLauncher; C:\Program Files (x86)\AMD\Performance Profile Client\AUEPLauncher.exe [9216 2018-01-31] () [File not signed]
                      S4 CLHNServiceForPowerDVD; C:\Program Files (x86)\CyberLink\PowerDVD11\Kernel\DMP\CLHNServiceF orPowerDVD.exe [83240 2011-04-20] (CyberLink → )
                      S4 CyberLink PowerDVD 11.0 Monitor Service; C:\Program Files (x86)\CyberLink\PowerDVD11\Common\MediaServer\CLMS MonitorService.exe [70952 2011-03-31] (CyberLink → CyberLink)
                      S4 CyberLink PowerDVD 11.0 Service; C:\Program Files (x86)\CyberLink\PowerDVD11\Common\MediaServer\CLMS Server.exe [312616 2011-03-31] (CyberLink → CyberLink)
                      S3 dbupdate; C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [143144 2016-02-28] (Dropbox, Inc → Dropbox, Inc.)
                      S3 dbupdatem; C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [143144 2016-02-28] (Dropbox, Inc → Dropbox, Inc.)
                      S3 DbxSvc; C:\WINDOWS\system32\DbxSvc.exe [51024 2018-03-15] (Dropbox, Inc → Dropbox, Inc.)
                      R2 DSAService; C:\Program Files (x86)\Intel Driver and Support Assistant\DSAService.exe [22816 2018-03-15] (Intel(R) Driver & Support Assistant → Intel)
                      S3 ESRV_SVC_QUEENCREEK; C:\Program Files\Intel\SUR\QUEENCREEK\esrv_svc.exe [805632 2016-11-17] (Intel(R) Software Development Products → )
                      R2 ETDService; C:\Program Files\Elantech\ETDService.exe [144072 2015-10-07] (ELAN Microelectronics Corporation → ELAN Microelectronics Corp.)
                      R2 hshld; C:\Program Files (x86)\Hotspot Shield\bin\cmw_srv.exe [53120 2018-04-10] (AnchorFree Inc → AnchorFree Inc.)
                      R2 IAStorDataMgrSvc; C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [15720 2013-11-21] (Intel Corporation - Intel® Rapid Storage Technology → Intel Corporation)
                      S3 igfxCUIService2.0.0.0; C:\WINDOWS\system32\igfxCUIService.exe [373688 2017-06-12] (Intel(R) pGFX → Intel Corporation)
                      R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520 2013-08-27] (Intel(R) Corporation) [File not signed]
                      S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [828376 2013-08-27] (Intel® Trusted Connect Service → Intel(R) Corporation)
                      S3 Intel(R) SUR QC SAM; C:\Program Files\Intel\SUR\QUEENCREEK\Updater\bin\IntelSoftwa reAssetManagerService.exe [18168 2017-07-13] (Intel(R) Software Asset Manager → Intel Corporation)
                      S2 IObitUnSvr; C:\Program Files (x86)\IObit\IObit Uninstaller\IUService.exe [153360 2018-09-25] (IObit Information Technology → IObit)
                      R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [169432 2013-09-16] (Intel Corporation - Intel® Management Engine Firmware → Intel Corporation)
                      R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [6440736 2018-03-03] (Malwarebytes Corporation → Malwarebytes)
                      R2 MSSQL$SQLEXPRESS; C:\Program Files\Microsoft SQL Server\MSSQL10.SQLEXPRESS\MSSQL\Binn\sqlservr.exe [57617752 2009-03-30] (Microsoft Corporation → Microsoft Corporation)
                      R2 MySQL; C:\Program Files (x86)\MySQL\MySQL Server 5.0\my.ini [9263 2017-02-03] () [File not signed]
                      S3 npggsvc; C:\WINDOWS\SysWOW64\GameMon.des [7780848 2017-11-29] (INCA Internet Co.,Ltd. → INCA Internet Co., Ltd.)
                      R2 PlaysService; C:\Program Files (x86)\Raptr Inc\PlaysTV\plays_service.exe [32528 2016-08-10] (Plays.tv, LLC → Plays.tv, LLC)
                      R2 QHActiveDefense; C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe [965184 2018-09-28] (QIHU 360 SOFTWARE CO. LIMITED → Qihoo 360 Technology Co. Ltd.)
                      S3 rpcapd; C:\Program Files (x86)\WinPcap\rpcapd.exe [118520 2013-03-01] (Riverbed Technology, Inc. → Riverbed Technology, Inc.)
                      R2 RzKLService; D:\Program Files (x86)\Razer\Razer Game Booster\RzKLService.exe [105448 2013-11-22] (Razer Inc. → Razer Inc.)
                      S3 Sense; C:\Program Files\Windows Defender Advanced Threat Protection\MsSense.exe [5074120 2019-03-15] (Microsoft Windows Publisher → Microsoft Corporation)
                      S4 SQLAgent$SQLEXPRESS; C:\Program Files\Microsoft SQL Server\MSSQL10.SQLEXPRESS\MSSQL\Binn\SQLAGENT.EXE [427880 2009-03-30] (Microsoft Corporation → Microsoft Corporation)
                      R2 TeamViewer; C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe [11795800 2019-04-15] (TeamViewer GmbH → TeamViewer GmbH)
                      R2 TrueKey; C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.Service.exe [352688 2018-11-27] (McAfee, Inc. → McAfee, LLC.)
                      R2 TrueKeyScheduler; C:\Program Files\McAfee\TrueKey\McTkSchedulerService.exe [352688 2018-11-27] (McAfee, Inc. → McAfee, LLC.)
                      R2 TrueKeyServiceHelper; C:\Program Files\McAfee\TrueKey\McAfee.TrueKey.ServiceHelper. exe [194168 2018-11-27] (McAfee, Inc. → McAfee, LLC.)
                      S4 UDisk Monitor; D:\Program Files\Modem AC2726 UI\bin\MonServiceUDisk64.exe [407040 2009-09-23] () [File not signed]
                      S3 USER_ESRV_SVC_QUEENCREEK; C:\Program Files\Intel\SUR\QUEENCREEK\esrv_svc.exe [805632 2016-11-17] (Intel(R) Software Development Products → )
                      S3 VSStandardCollectorService140; D:\Program Files (x86)\Microsoft Visual Studio 14.0\Team Tools\DiagnosticsHub\Collector\StandardCollector.S ervice.exe [108776 2016-09-06] (Microsoft Corporation → Microsoft Corporation)
                      S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [4413440 2019-03-14] (Microsoft Corporation → Microsoft Corporation)
                      S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [107160 2019-02-16] (Microsoft Corporation → Microsoft Corporation)
                      S3 WsDrvInst; C:\Program Files (x86)\Wondershare\Wondershare Video Converter Ultimate\Transfer\DriverInstall.exe [105064 2018-07-25] (Wondershare Technology Co.,Ltd → Wondershare)
                      R1 360AntiHacker; C:\WINDOWS\System32\Drivers\360AntiHacker64.sys [192600 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
                      R3 360AvFlt; C:\WINDOWS\System32\DRIVERS\360AvFlt.sys [95232 2018-03-13] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
                      R3 360AvFlt; C:\Windows\SysWOW64\DRIVERS\360AvFlt.sys [95232 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
                      R1 360Box64; C:\WINDOWS\System32\DRIVERS\360Box64.sys [340568 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
                      R1 360Camera; C:\WINDOWS\System32\Drivers\360Camera64.sys [57848 2018-03-13] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
                      R1 360FsFlt; C:\WINDOWS\System32\DRIVERS\360FsFlt.sys [443992 2018-09-28] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
                      R1 360netmon; C:\WINDOWS\System32\DRIVERS\360netmon.sys [96424 2018-03-13] (Qihoo 360 Software (Beijing) Company Limited → 360.cn)
                      R3 AFTrafMgr1.4; C:\Program Files (x86)\Hotspot Shield\bin\TrafMgr_1_4_64.sys [56840 2018-04-04] (AnchorFree Inc → AnchorFree Inc.)
                      R3 amdkmdag; C:\WINDOWS\system32\DRIVERS\atikmdag.sys [26706464 2016-08-04] (Microsoft Windows Hardware Compatibility Publisher → Advanced Micro Devices, Inc.)
                      R3 amdkmdap; C:\WINDOWS\system32\DRIVERS\atikmpag.sys [518176 2016-08-04] (Microsoft Windows Hardware Compatibility Publisher → Advanced Micro Devices, Inc.)
                      R0 amdkmpfd; C:\WINDOWS\System32\drivers\amdkmpfd.sys [73976 2015-06-04] (Advanced Micro Devices, Inc. → Advanced Micro Devices, Inc.)
                      R3 athr; C:\WINDOWS\System32\drivers\athw8x.sys [4233728 2018-04-12] (Microsoft Windows → Qualcomm Atheros Communications, Inc.)
                      R1 BAPIDRV; C:\WINDOWS\System32\DRIVERS\BAPIDRV64.sys [211160 2018-12-21] (Beijing Qihu Technology Co., Ltd. → 360.cn)
                      R3 BtFilter; C:\WINDOWS\system32\DRIVERS\btfilter.sys [610336 2016-07-13] (Microsoft Windows Hardware Compatibility Publisher → Qualcomm Atheros)
                      S3 CYUSB3; C:\WINDOWS\System32\Drivers\CYUSB3.sys [90536 2018-08-12] (Cypress Semiconductor Corporation → Cypress Semiconductor)
                      S3 GunBod; C:\WINDOWS\system32\gunbod64.sys [84384 2017-02-09] (Beijing Apex Weifeng Technology Co.,Ltd. → )
                      R3 IUProcessFilter; C:\Program Files (x86)\IObit\IObit Uninstaller\drivers\win10_amd64\IUProcessFilter.sy s [37184 2018-10-16] (IObit Information Technology → IObit)
                      R3 IURegistryFilter; C:\Program Files (x86)\IObit\IObit Uninstaller\drivers\win10_amd64\IURegistryFilter.s ys [43392 2018-10-16] (IObit Information Technology → IObit)
                      S3 LGSHidFilt; C:\WINDOWS\system32\DRIVERS\LGSHidFilt.Sys [64280 2013-05-31] (Logitech → Logitech Inc.)
                      R0 MBAMSwissArmy; C:\WINDOWS\System32\Drivers\mbamswissarmy.sys [253664 2019-04-19] (Malwarebytes Corporation → Malwarebytes)
                      R3 MEIx64; C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys [99288 2013-09-16] (Intel Corporation - Intel® Management Engine Firmware → Intel Corporation)
                      S3 Netaapl; C:\WINDOWS\System32\drivers\netaapl64.sys [23040 2014-08-15] (Microsoft Windows Hardware Compatibility Publisher → Apple Inc.)
                      R2 NPF; C:\WINDOWS\System32\drivers\npf.sys [36600 2013-03-01] (Riverbed Technology, Inc. → Riverbed Technology, Inc.)
                      R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [886528 2015-07-22] (Realtek Semiconductor Corp → Realtek )
                      R3 RTSUER; C:\WINDOWS\system32\Drivers\RtsUer.sys [410880 2015-07-03] (Realtek Semiconductor Corp → Realsil Semiconductor Corporation)
                      R3 rtsuvc; C:\WINDOWS\system32\DRIVERS\rtsuvc.sys [3068160 2015-06-16] (Realtek Semiconductor Corp → Realtek Semiconductor Corp.)
                      S3 rzendpt; C:\WINDOWS\System32\drivers\rzendpt.sys [50392 2015-08-14] (Razer Inc. → Razer Inc)
                      S3 semav6msr64; C:\WINDOWS\system32\drivers\semav6msr64.sys [21984 2016-10-18] (Intel(R) Code Signing External → )
                      R3 taphss6; C:\WINDOWS\System32\drivers\taphss6.sys [42064 2016-08-23] (AnchorFree Inc → Anchorfree Inc.)
                      S3 USBAAPL64; C:\WINDOWS\System32\Drivers\usbaapl64.sys [54784 2015-06-17] (Microsoft Windows Hardware Compatibility Publisher → Apple, Inc.)
                      S3 VBAudioVMVAIOMME; C:\WINDOWS\system32\DRIVERS\vbaudio_vmvaio64_win7. sys [41192 2015-11-07] (Vincent Burel → Windows (R) Win 7 DDK provider)
                      S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44616 2018-04-12] (Microsoft Windows Early Launch Anti-malware Publisher → Microsoft Corporation)
                      S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [331680 2018-04-12] (Microsoft Windows → Microsoft Corporation)
                      S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [44032 2018-04-12] (Microsoft Windows → Microsoft Corporation)
                      R2 WtfEngineDrv; C:\WINDOWS\system32\DRIVERS\WtfEngineDrv.sys [37872 2016-05-20] (Initex, OOO → AAA Internet Publishing, Inc.)
                      R1 YSDrv; C:\Program Files (x86)\Bignox\BigNoxVM\RT\YSDrv.sys [270608 2017-12-21] (Beijing Duodian Online Science and Technology Co.,Ltd → BigNox Corporation)
                      R2 {329F96B6-DF1E-4328-BFDA-39EA953C1312}; C:\Program Files (x86)\CyberLink\PowerDVD11\Common\NavFilter\000.fc l [148976 2011-04-12] (CyberLink → CyberLink Corp.)
                      U3 aswbdisk; no ImagePath
                      U3 idsvc; no ImagePath
                      ==================== One month (created) ========
                      2019-04-19 12:46 - 2019-04-19 12:46 - 000000000 ____D C:\Users\Lenovo\AppData\Local\Mozilla
                      2019-04-19 12:45 - 2019-04-19 12:45 - 000000000 ____D C:\Users\Lenovo\Downloads\FRST-OlderVersion
                      2019-04-19 10:06 - 2019-04-19 10:19 - 000003530 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A
                      2019-04-19 10:06 - 2019-04-19 10:19 - 000003406 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore
                      2019-04-19 10:06 - 2019-04-19 10:06 - 000002303 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
                      2019-04-19 10:06 - 2019-04-19 10:06 - 000002262 _____ C:\Users\Public\Desktop\Google Chrome.lnk
                      2019-04-19 10:03 - 2019-04-19 10:03 - 000000000 ____D C:\Program Files (x86)\Mozilla Firefox
                      2019-04-19 09:59 - 2019-04-19 09:59 - 001622528 _____ C:\Users\Lenovo\Downloads\resetbrowser.exe
                      2019-04-19 09:47 - 2019-04-19 09:49 - 005208384 _____ C:\WINDOWS\system32\FNTCACHE.DAT
                      2019-04-19 09:42 - 2019-04-19 09:44 - 000000000 ____D C:\AdwCleaner
                      2019-04-19 09:38 - 2019-04-19 09:40 - 007025360 _____ (Malwarebytes) C:\Users\Lenovo\Downloads\adwcleaner_7.3.exe
                      2019-04-19 02:27 - 2019-04-19 02:27 - 000253664 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbamswissarmy.sys
                      2019-04-19 02:14 - 2019-04-19 02:21 - 000079423 _____ C:\Users\Lenovo\Downloads\Addition.txt
                      2019-04-19 02:10 - 2019-04-19 12:47 - 000032944 _____ C:\Users\Lenovo\Downloads\FRST.txt
                      2019-04-19 02:10 - 2019-04-19 12:45 - 002434048 _____ (Farbar) C:\Users\Lenovo\Downloads\FRST64.exe
                      2019-04-19 02:10 - 2019-04-19 12:45 - 000000000 ____D C:\FRST
                      2019-04-19 01:58 - 2019-04-19 01:58 - 037133296 _____ (Hankuper s.r.o.) C:\Users\Lenovo\Downloads\Adlock_Installer (2).exe
                      2019-04-19 01:24 - 2019-04-19 01:24 - 037133296 _____ (Hankuper s.r.o.) C:\Users\Lenovo\Downloads\Adlock_Installer (1).exe
                      2019-04-18 13:15 - 2019-04-19 10:06 - 000000000 ____D C:\Program Files (x86)\Google
                      2019-04-18 13:15 - 2019-04-18 13:16 - 000000000 ____D C:\Users\Lenovo\AppData\Local\Google clean
                      2019-04-18 12:52 - 2019-04-18 12:52 - 000000000 ____D C:\WINDOWS\Tasks\ImCleanDisabled
                      2019-04-18 12:50 - 2019-04-19 09:55 - 000000000 ____D C:\ProgramData\ProductData
                      2019-04-18 12:50 - 2019-04-18 12:51 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\IObit
                      2019-04-18 12:50 - 2019-04-18 12:50 - 000002950 _____ C:\WINDOWS\System32\Tasks\Uninstaller_SkipUac_Leno vo
                      2019-04-18 12:49 - 2019-04-18 12:55 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\IObit
                      2019-04-18 12:49 - 2019-04-18 12:54 - 000000000 ____D C:\ProgramData\IObit
                      2019-04-18 12:49 - 2019-04-18 12:49 - 000001430 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IObit Uninstaller.lnk
                      2019-04-18 12:49 - 2019-04-18 12:49 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IObit Uninstaller
                      2019-04-18 12:49 - 2019-04-18 12:49 - 000000000 ____D C:\Program Files (x86)\IObit
                      2019-04-18 12:30 - 2019-04-19 10:10 - 000000000 ____D C:\Program Files (x86)\TeamViewer
                      2019-04-18 12:30 - 2019-04-18 12:30 - 000001118 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamViewer 14.lnk
                      2019-04-18 12:30 - 2019-04-18 12:30 - 000001106 _____ C:\Users\Public\Desktop\TeamViewer 14.lnk
                      2019-04-13 05:25 - 2019-04-13 05:25 - 000000077 _____ C:\WINDOWS\system32\Drivers\aswSP.sys.sum
                      2019-04-10 09:53 - 2019-04-02 14:40 - 000534016 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vbscript.dll
                      2019-04-10 09:53 - 2019-03-15 00:34 - 000127488 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxSysprep.dll
                      2019-04-10 09:53 - 2019-03-14 18:17 - 002258944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssrch.dll
                      2019-04-10 09:53 - 2019-03-14 18:17 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.d ll
                      2019-04-10 09:53 - 2019-03-14 18:14 - 000345088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchProtocolHost.exe
                      2019-04-10 09:53 - 2019-03-14 18:14 - 000138240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\smartscreenps.dll
                      2019-04-10 09:53 - 2019-03-14 18:13 - 000145408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssph.dll
                      2019-04-10 09:53 - 2019-03-14 17:58 - 000150016 _____ (Microsoft Corporation) C:\WINDOWS\system32\fcon.dll
                      2019-04-10 09:53 - 2019-03-14 17:56 - 000055296 _____ (Microsoft Corporation) C:\WINDOWS\system32\msscntrs.dll
                      2019-04-10 09:53 - 2019-03-14 17:54 - 000227328 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchFilterHost.exe
                      2019-04-10 09:52 - 2019-04-02 22:38 - 000094008 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
                      2019-04-10 09:52 - 2019-04-02 22:33 - 001634912 _____ (Microsoft Corporation) C:\WINDOWS\system32\gdi32full.dll
                      2019-04-10 09:52 - 2019-04-02 22:33 - 000719984 _____ (Microsoft Corporation) C:\WINDOWS\system32\kernel32.dll
                      2019-04-10 09:52 - 2019-04-02 22:19 - 012730880 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
                      2019-04-10 09:52 - 2019-04-02 22:19 - 000064000 _____ (Microsoft Corporation) C:\WINDOWS\system32\iemigplugin.dll
                      2019-04-10 09:52 - 2019-04-02 22:18 - 000059904 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf3216.dll
                      2019-04-10 09:52 - 2019-04-02 22:16 - 001030144 _____ (Microsoft Corporation) C:\WINDOWS\system32\termsrv.dll
                      2019-04-10 09:52 - 2019-04-02 22:15 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\oleprn.dll
                      2019-04-10 09:52 - 2019-04-02 22:13 - 001605632 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcorets.dll
                      2019-04-10 09:52 - 2019-04-02 22:12 - 003643904 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
                      2019-04-10 09:52 - 2019-04-02 22:12 - 001364992 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvruserservice.dll
                      2019-04-10 09:52 - 2019-04-02 22:11 - 004053504 _____ (Microsoft Corporation) C:\WINDOWS\system32\msi.dll
                      2019-04-10 09:52 - 2019-04-02 22:11 - 001857536 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml3.dll
                      2019-04-10 09:52 - 2019-04-02 22:11 - 001662976 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
                      2019-04-10 09:52 - 2019-04-02 22:10 - 000130048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\luafv.sys
                      2019-04-10 09:52 - 2019-04-02 22:10 - 000033280 _____ (Microsoft Corporation) C:\WINDOWS\system32\sxssrv.dll
                      2019-04-10 09:52 - 2019-04-02 19:25 - 001454648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gdi32full.dll
                      2019-04-10 09:52 - 2019-04-02 19:25 - 000607960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kernel32.dll
                      2019-04-10 09:52 - 2019-04-02 19:11 - 011919360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
                      2019-04-10 09:52 - 2019-04-02 19:11 - 000046080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf3216.dll
                      2019-04-10 09:52 - 2019-04-02 19:10 - 000117760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\oleprn.dll
                      2019-04-10 09:52 - 2019-04-02 19:08 - 002889216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
                      2019-04-10 09:52 - 2019-04-02 19:07 - 004054528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msi.dll
                      2019-04-10 09:52 - 2019-04-02 19:07 - 001586688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml3.dll
                      2019-04-10 09:52 - 2019-04-02 19:06 - 001470976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
                      2019-04-10 09:52 - 2019-04-02 18:36 - 001035256 _____ (Microsoft Corporation) C:\WINDOWS\system32\ApplyTrustOffline.exe
                      2019-04-10 09:52 - 2019-04-02 18:24 - 000135184 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.dll
                      2019-04-10 09:52 - 2019-04-02 18:23 - 001023800 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
                      2019-04-10 09:52 - 2019-04-02 18:22 - 001219896 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
                      2019-04-10 09:52 - 2019-04-02 18:22 - 000567592 _____ (Microsoft Corporation) C:\WINDOWS\system32\tcblaunch.exe
                      2019-04-10 09:52 - 2019-04-02 18:22 - 000076088 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hvservice.sys
                      2019-04-10 09:52 - 2019-04-02 18:21 - 007520136 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayR eady.dll
                      2019-04-10 09:52 - 2019-04-02 18:21 - 002822160 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
                      2019-04-10 09:52 - 2019-04-02 18:21 - 002467536 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml6.dll
                      2019-04-10 09:52 - 2019-04-02 18:21 - 000735680 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
                      2019-04-10 09:52 - 2019-04-02 18:20 - 002719032 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
                      2019-04-10 09:52 - 2019-04-02 18:20 - 000412984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
                      2019-04-10 09:52 - 2019-04-02 18:19 - 009083704 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
                      2019-04-10 09:52 - 2019-04-02 18:19 - 000793400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
                      2019-04-10 09:52 - 2019-04-02 18:19 - 000786080 _____ (Microsoft Corporation) C:\WINDOWS\system32\oleaut32.dll
                      2019-04-10 09:52 - 2019-04-02 18:19 - 000713272 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVideoDSP.dll
                      2019-04-10 09:52 - 2019-04-02 18:01 - 025857536 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
                      2019-04-10 09:52 - 2019-04-02 17:53 - 022717440 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
                      2019-04-10 09:52 - 2019-04-02 17:53 - 004384256 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeContent.dll
                      2019-04-10 09:52 - 2019-04-02 17:51 - 003399680 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
                      2019-04-10 09:52 - 2019-04-02 17:50 - 007591936 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
                      2019-04-10 09:52 - 2019-04-02 17:50 - 000808448 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeManager.dll
                      2019-04-10 09:52 - 2019-04-02 17:49 - 001307648 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVPXENC.dll
                      2019-04-10 09:52 - 2019-04-02 17:49 - 000209408 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXApplicabilityBlob.dll
                      2019-04-10 09:52 - 2019-04-02 17:48 - 001559552 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.deskt op.dll
                      2019-04-10 09:52 - 2019-04-02 17:48 - 000310272 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbt.sys
                      2019-04-10 09:52 - 2019-04-02 17:48 - 000154112 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
                      2019-04-10 09:52 - 2019-04-02 17:47 - 001214464 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcore.dll
                      2019-04-10 09:52 - 2019-04-02 17:47 - 000894464 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
                      2019-04-10 09:52 - 2019-04-02 17:46 - 002174976 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.oneco re.dll
                      2019-04-10 09:52 - 2019-04-02 17:45 - 000323584 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxAllUserStore.dll
                      2019-04-10 09:52 - 2019-04-02 17:44 - 002208768 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
                      2019-04-10 09:52 - 2019-04-02 17:44 - 001724416 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpserverbase.dll
                      2019-04-10 09:52 - 2019-04-02 17:44 - 001421312 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpbase.dll
                      2019-04-10 09:52 - 2019-04-02 17:43 - 000542720 _____ (Microsoft Corporation) C:\WINDOWS\system32\vbscript.dll
                      2019-04-10 09:52 - 2019-04-02 16:22 - 000001312 _____ C:\WINDOWS\system32\tcbres.wim
                      2019-04-10 09:52 - 2019-04-02 15:05 - 001989544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml6.dll
                      2019-04-10 09:52 - 2019-04-02 15:04 - 006572120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayR eady.dll
                      2019-04-10 09:52 - 2019-04-02 15:04 - 000604008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\oleaut32.dll
                      2019-04-10 09:52 - 2019-04-02 15:04 - 000581832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVideoDSP.dll
                      2019-04-10 09:52 - 2019-04-02 15:04 - 000560600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
                      2019-04-10 09:52 - 2019-04-02 14:56 - 022018048 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
                      2019-04-10 09:52 - 2019-04-02 14:50 - 019404800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
                      2019-04-10 09:52 - 2019-04-02 14:43 - 005788160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
                      2019-04-10 09:52 - 2019-04-02 14:43 - 000608768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EdgeManager.dll
                      2019-04-10 09:52 - 2019-04-02 14:43 - 000578560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webplatstorageserver.dll
                      2019-04-10 09:52 - 2019-04-02 14:42 - 001295360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVPXENC.dll
                      2019-04-10 09:52 - 2019-04-02 14:41 - 001540096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpserverbase.dll
                      2019-04-10 09:52 - 2019-04-02 14:41 - 001235968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpbase.dll
                      2019-04-10 09:52 - 2019-04-02 14:41 - 000230912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxAllUserStore.dll
                      2019-04-10 09:52 - 2019-04-02 14:40 - 001073664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpcore.dll
                      2019-04-10 09:52 - 2019-03-16 22:54 - 001008640 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.MixedRealityCapt ure.dll
                      2019-04-10 09:52 - 2019-03-16 19:03 - 000868864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.MixedRealityCapt ure.dll
                      2019-04-10 09:52 - 2019-03-15 00:55 - 001786680 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntVirtualization.dll
                      2019-04-10 09:52 - 2019-03-15 00:53 - 001626928 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVIntegration.dll
                      2019-04-10 09:52 - 2019-03-15 00:53 - 001038136 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVPolicy.dll
                      2019-04-10 09:52 - 2019-03-15 00:53 - 000652088 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVPublishing.dll
                      2019-04-10 09:52 - 2019-03-15 00:53 - 000400696 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVScripting.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 003933296 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
                      2019-04-10 09:52 - 2019-03-15 00:52 - 001424696 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntSubsystemController.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000954160 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVManifest.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000830264 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVOrchestration.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000827704 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVClient.exe
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000825144 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntStreamingManager.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000749880 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVReporting.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000670008 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVCatalog.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000495416 _____ (Microsoft Corporation) C:\WINDOWS\system32\TransportDSA.dll
                      2019-04-10 09:52 - 2019-03-15 00:52 - 000164664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\AppvVemgr.sys
                      2019-04-10 09:52 - 2019-03-15 00:51 - 000157192 _____ (Microsoft Corporation) C:\WINDOWS\system32\consent.exe
                      2019-04-10 09:52 - 2019-03-15 00:35 - 000011776 _____ (Microsoft Corporation) C:\WINDOWS\system32\appinfoext.dll
                      2019-04-10 09:52 - 2019-03-15 00:33 - 000182784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rdpdr.sys
                      2019-04-10 09:52 - 2019-03-15 00:33 - 000082432 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storqosflt.sys
                      2019-04-10 09:52 - 2019-03-15 00:33 - 000030208 _____ (Microsoft Corporation) C:\WINDOWS\system32\RpcPing.exe
                      2019-04-10 09:52 - 2019-03-15 00:31 - 000198656 _____ (Microsoft Corporation) C:\WINDOWS\system32\wincredui.dll
                      2019-04-10 09:52 - 2019-03-15 00:30 - 000675328 _____ (Microsoft Corporation) C:\WINDOWS\system32\objsel.dll
                      2019-04-10 09:52 - 2019-03-15 00:30 - 000440832 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppBroker.dll
                      2019-04-10 09:52 - 2019-03-15 00:29 - 000882688 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmartcardCredentialProvider.dl l
                      2019-04-10 09:52 - 2019-03-15 00:29 - 000727040 _____ (Microsoft Corporation) C:\WINDOWS\system32\cscsvc.dll
                      2019-04-10 09:52 - 2019-03-15 00:28 - 000560640 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsound.dll
                      2019-04-10 09:52 - 2019-03-15 00:08 - 003611264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
                      2019-04-10 09:52 - 2019-03-14 23:56 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wincredui.dll
                      2019-04-10 09:52 - 2019-03-14 23:55 - 000026624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RpcPing.exe
                      2019-04-10 09:52 - 2019-03-14 23:53 - 000625664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SmartcardCredentialProvider.dl l
                      2019-04-10 09:52 - 2019-03-14 23:53 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\objsel.dll
                      2019-04-10 09:52 - 2019-03-14 23:53 - 000375808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppBroker.dll
                      2019-04-10 09:52 - 2019-03-14 23:52 - 000502784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dsound.dll
                      2019-04-10 09:52 - 2019-03-14 18:57 - 000611640 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\spaceport.sys
                      2019-04-10 09:52 - 2019-03-14 18:56 - 000375096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pci.sys
                      2019-04-10 09:52 - 2019-03-14 18:38 - 000380728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msv1_0.dll
                      2019-04-10 09:52 - 2019-03-14 18:38 - 000090360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mpr.dll
                      2019-04-10 09:52 - 2019-03-14 18:37 - 006043496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
                      2019-04-10 09:52 - 2019-03-14 18:37 - 002256248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
                      2019-04-10 09:52 - 2019-03-14 18:37 - 001171568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ucrtbase.dll
                      2019-04-10 09:52 - 2019-03-14 18:28 - 000152072 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wcifs.sys
                      2019-04-10 09:52 - 2019-03-14 18:27 - 000436024 _____ (Microsoft Corporation) C:\WINDOWS\system32\msv1_0.dll
                      2019-04-10 09:52 - 2019-03-14 18:27 - 000097600 _____ (Microsoft Corporation) C:\WINDOWS\system32\mpr.dll
                      2019-04-10 09:52 - 2019-03-14 18:26 - 007436016 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
                      2019-04-10 09:52 - 2019-03-14 18:26 - 002768448 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
                      2019-04-10 09:52 - 2019-03-14 18:26 - 002421048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
                      2019-04-10 09:52 - 2019-03-14 18:26 - 001457576 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
                      2019-04-10 09:52 - 2019-03-14 18:26 - 001258688 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
                      2019-04-10 09:52 - 2019-03-14 18:26 - 001140984 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
                      2019-04-10 09:52 - 2019-03-14 18:26 - 001014344 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase.dll
                      2019-04-10 09:52 - 2019-03-14 18:26 - 000983424 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
                      2019-04-10 09:52 - 2019-03-14 18:26 - 000481048 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase_enclave.dll
                      2019-04-10 09:52 - 2019-03-14 18:26 - 000175416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\spacedump.sys
                      2019-04-10 09:52 - 2019-03-14 18:22 - 002700288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
                      2019-04-10 09:52 - 2019-03-14 18:20 - 006661632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
                      2019-04-10 09:52 - 2019-03-14 18:19 - 003711488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
                      2019-04-10 09:52 - 2019-03-14 18:19 - 002969600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cdp.dll
                      2019-04-10 09:52 - 2019-03-14 18:18 - 005307392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
                      2019-04-10 09:52 - 2019-03-14 18:18 - 000095744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserDataTimeUtil.dll
                      2019-04-10 09:52 - 2019-03-14 18:18 - 000035840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\credui.dll
                      2019-04-10 09:52 - 2019-03-14 18:18 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tzres.dll
                      2019-04-10 09:52 - 2019-03-14 18:17 - 000561152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9diag.dll
                      2019-04-10 09:52 - 2019-03-14 18:17 - 000261632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dhcpcore6.dll
                      2019-04-10 09:52 - 2019-03-14 18:17 - 000105472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wcmapi.dll
                      2019-04-10 09:52 - 2019-03-14 18:17 - 000057344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntlanman.dll
                      2019-04-10 09:52 - 2019-03-14 18:16 - 000392192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\daxexec.dll
                      2019-04-10 09:52 - 2019-03-14 18:16 - 000333824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgeIso.dll
                      2019-04-10 09:52 - 2019-03-14 18:15 - 000415744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\schannel.dll
                      2019-04-10 09:52 - 2019-03-14 18:15 - 000318464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dhcpcore.dll
                      2019-04-10 09:52 - 2019-03-14 18:15 - 000195072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ShellCommonCommonProxyStub.dll
                      2019-04-10 09:52 - 2019-03-14 18:15 - 000102400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\negoexts.dll
                      2019-04-10 09:52 - 2019-03-14 18:14 - 001070080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aadtb.dll
                      2019-04-10 09:52 - 2019-03-14 18:14 - 000856576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchIndexer.exe
                      2019-04-10 09:52 - 2019-03-14 18:14 - 000735744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssvp.dll
                      2019-04-10 09:52 - 2019-03-14 18:14 - 000330752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Graphics.Printing.Work flow.dll
                      2019-04-10 09:52 - 2019-03-14 18:14 - 000251904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
                      2019-04-10 09:52 - 2019-03-14 18:13 - 001468416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
                      2019-04-10 09:52 - 2019-03-14 18:13 - 000669696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript.dll
                      2019-04-10 09:52 - 2019-03-14 18:01 - 008188928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
                      2019-04-10 09:52 - 2019-03-14 17:58 - 004708864 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdp.dll
                      2019-04-10 09:52 - 2019-03-14 17:58 - 002509824 _____ (Microsoft Corporation) C:\WINDOWS\system32\smartscreen.exe
                      2019-04-10 09:52 - 2019-03-14 17:57 - 004866560 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
                      2019-04-10 09:52 - 2019-03-14 17:57 - 000106496 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationControllerPS.dll
                      2019-04-10 09:52 - 2019-03-14 17:56 - 003392000 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
                      2019-04-10 09:52 - 2019-03-14 17:56 - 000144384 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
                      2019-04-10 09:52 - 2019-03-14 17:56 - 000120320 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataTimeUtil.dll
                      2019-04-10 09:52 - 2019-03-14 17:56 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\system32\tzres.dll
                      2019-04-10 09:52 - 2019-03-14 17:55 - 003601920 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Service.dl l
                      2019-04-10 09:52 - 2019-03-14 17:55 - 002739200 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssrch.dll
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000528896 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\nwifi.sys
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000458752 _____ (Microsoft Corporation) C:\WINDOWS\system32\cloudAP.dll
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000414720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cldflt.sys
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000141312 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppointmentActivation.dll
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000134656 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmapi.dll
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000099328 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActiveSyncCsp.dll
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000069120 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntlanman.dll
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000062976 _____ (Microsoft Corporation) C:\WINDOWS\system32\EASPolicyManagerBrokerHost.exe
                      2019-04-10 09:52 - 2019-03-14 17:55 - 000048640 _____ (Microsoft Corporation) C:\WINDOWS\system32\credui.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 002368000 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebRuntimeManager.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000566784 _____ (Microsoft Corporation) C:\WINDOWS\system32\daxexec.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000395776 _____ (Microsoft Corporation) C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.d ll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000354304 _____ (Microsoft Corporation) C:\WINDOWS\system32\dhcpcore.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000279552 _____ (Microsoft Corporation) C:\WINDOWS\system32\dhcpcore6.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000273408 _____ (Microsoft Corporation) C:\WINDOWS\system32\ubpm.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000231936 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmcsp.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000118784 _____ (Microsoft Corporation) C:\WINDOWS\system32\negoexts.dll
                      2019-04-10 09:52 - 2019-03-14 17:54 - 000110592 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcpopkeysrv.dll
                      2019-04-10 09:52 - 2019-03-14 17:53 - 000787968 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\WdiWiFi.sys
                      2019-04-10 09:52 - 2019-03-14 17:53 - 000726528 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
                      2019-04-10 09:52 - 2019-03-14 17:53 - 000473600 _____ (Microsoft Corporation) C:\WINDOWS\system32\schannel.dll
                      2019-04-10 09:52 - 2019-03-14 17:53 - 000456192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Graphics.Printing.Work flow.dll
                      2019-04-10 09:52 - 2019-03-14 17:52 - 002909696 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
                      2019-04-10 09:52 - 2019-03-14 17:52 - 000532992 _____ (Microsoft Corporation) C:\WINDOWS\system32\QuietHours.dll
                      2019-04-10 09:52 - 2019-03-14 17:52 - 000404480 _____ (Microsoft Corporation) C:\WINDOWS\system32\ShellCommonCommonProxyStub.dll
                      2019-04-10 09:52 - 2019-03-14 17:52 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\smartscreenps.dll
                      2019-04-10 09:52 - 2019-03-14 17:51 - 001216000 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationController.dll
                      2019-04-10 09:52 - 2019-03-14 17:51 - 001058304 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchIndexer.exe
                      2019-04-10 09:52 - 2019-03-14 17:51 - 000226304 _____ (Microsoft Corporation) C:\WINDOWS\system32\TetheringMgr.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 001587712 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 001410560 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadtb.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 000947200 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmsvc.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 000847360 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 000796672 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssvp.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 000776192 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 000507392 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgeIso.dll
                      2019-04-10 09:52 - 2019-03-14 17:50 - 000406528 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchProtocolHost.exe
                      2019-04-10 09:52 - 2019-03-14 17:50 - 000176640 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssph.dll
                      2019-04-10 09:52 - 2019-03-14 11:57 - 001311744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msjet40.dll
                      2019-04-10 09:52 - 2019-03-14 11:57 - 000475648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxbde40.dll
                      2019-04-10 09:52 - 2019-03-14 11:57 - 000375808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspbde40.dll
                      2019-04-10 09:52 - 2019-03-14 11:57 - 000352768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msrd3x40.dll
                      2019-04-10 09:52 - 2019-03-14 11:57 - 000340992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msexcl40.dll
                      2019-04-09 03:02 - 2019-04-09 03:02 - 000000000 ____D C:\ProgramData\Hankuper
                      2019-04-09 03:02 - 2019-04-09 03:02 - 000000000 ____D C:\Program Files\AdLock
                      2019-04-09 02:58 - 2019-04-09 02:58 - 036153840 _____ (Hankuper s.r.o.) C:\Users\Lenovo\Downloads\Adlock_Installer.exe
                      2019-04-09 00:08 - 2019-04-09 00:08 - 003976665 _____ C:\Users\Lenovo\Downloads\Mega Man Battle Network 2 (USA).zip
                      2019-04-06 18:30 - 2019-04-06 18:30 - 000364952 _____ C:\Users\Lenovo\Downloads\download.pdf
                      2019-04-05 11:04 - 2019-04-05 11:04 - 000192384 _____ C:\Users\Lenovo\Downloads\9299 (1) (1).pdf
                      2019-04-05 11:02 - 2019-04-05 11:02 - 000182444 _____ C:\Users\Lenovo\Downloads\9299 (1).pdf
                      2019-04-05 11:00 - 2019-04-05 11:00 - 000182444 _____ C:\Users\Lenovo\Downloads\929 (1).pdf
                      2019-04-05 10:00 - 2019-04-05 10:00 - 000338279 _____ C:\Users\Lenovo\Downloads\form 80 2015-2019(1) (1)[1145].pdf
                      2019-04-01 15:19 - 2019-04-01 15:19 - 000182444 _____ C:\Users\Lenovo\Downloads\929.pdf
                      2019-04-01 15:01 - 2019-04-01 15:01 - 000233489 _____ C:\Users\Lenovo\Downloads\form 80 2015-2019(1) (1).pdf
                      2019-03-31 01:33 - 2019-03-31 01:33 - 000000000 ____D C:\Users\Lenovo\Downloads\New folder
                      2019-03-27 12:24 - 2019-03-27 12:24 - 000233489 _____ C:\Users\Lenovo\Downloads\form 80 2015-2019(1).pdf
                      2019-03-25 13:27 - 2019-03-25 13:27 - 000063894 _____ C:\Users\Lenovo\Downloads\Albert - Akta lahir.pdf
                      2019-03-25 13:02 - 2019-03-25 13:02 - 001771175 _____ C:\Users\Lenovo\Downloads\Statement20181231.pdf
                      2019-03-25 13:01 - 2019-03-25 13:01 - 000116172 _____ C:\Users\Lenovo\Downloads\scoreReport (2).pdf
                      2019-03-21 23:11 - 2019-03-23 15:36 - 000000000 ____D C:\ProgramData\Stardock
                      2019-03-21 23:11 - 2019-03-21 23:11 - 000000000 ____D C:\Users\Lenovo\AppData\Local\Stardock
                      2019-03-21 23:10 - 2019-03-21 23:10 - 000000000 ____D C:\Users\Lenovo\Documents\My Games
                      2019-03-21 23:10 - 2019-03-21 23:10 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\MohawkGames
                      2019-03-20 14:46 - 2019-03-20 14:46 - 000085072 _____ C:\Users\Lenovo\Downloads\Unconfirmed 583584.crdownload
                      ==================== One month (modified) ========
                      2019-04-19 12:47 - 2018-03-22 21:37 - 000000000 ____D C:\ProgramData\360safe
                      2019-04-19 12:47 - 2016-12-21 04:23 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\Mozilla
                      2019-04-19 12:47 - 2014-11-25 18:39 - 000000000 ____D C:\ProgramData\Mozilla
                      2019-04-19 12:46 - 2018-04-12 09:38 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
                      2019-04-19 12:46 - 2014-11-25 18:39 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\Mozilla
                      2019-04-19 12:21 - 2018-05-26 17:01 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
                      2019-04-19 10:24 - 2018-03-22 21:37 - 000000000 ____D C:\Users\Lenovo\AppData\LocalLow\360WD
                      2019-04-19 10:20 - 2014-12-30 12:34 - 000000000 ____D C:\Users\Lenovo\AppData\Local\CrashDumps
                      2019-04-19 10:09 - 2018-05-26 17:40 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
                      2019-04-19 10:09 - 2014-11-25 18:39 - 000000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
                      2019-04-19 10:08 - 2018-04-12 07:04 - 000524288 _____ C:\WINDOWS\system32\config\BBI
                      2019-04-19 10:08 - 2018-03-22 21:37 - 000000000 _RSHD C:\360SANDBOX
                      2019-04-19 10:04 - 2014-11-25 18:39 - 000001234 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox.lnk
                      2019-04-19 10:01 - 2018-03-22 22:30 - 000000000 __SHD C:$360Section
                      2019-04-19 10:01 - 2018-03-22 22:05 - 000000000 ____D C:\ProgramData\360Quarant
                      2019-04-19 09:47 - 2018-03-25 05:46 - 000000000 ____D C:\Program Files (x86)\Driver Support
                      2019-04-19 04:48 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\AppReadiness
                      2019-04-19 02:36 - 2017-09-30 14:04 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs\Albion Online
                      2019-04-19 02:35 - 2019-02-26 14:27 - 000000000 ____D C:\WINDOWS\Minidump
                      2019-04-19 02:35 - 2018-04-12 09:36 - 000000000 ____D C:\WINDOWS\INF
                      2019-04-19 01:45 - 2018-03-22 23:45 - 000000410 __RSH C:\ProgramData\ntuser.pol
                      2019-04-18 15:45 - 2017-12-30 07:35 - 000000000 ____D C:\Users\Lenovo\AppData\Local\Packages
                      2019-04-18 13:26 - 2017-10-16 00:08 - 000000000 ____D C:\ProgramData\Package Cache
                      2019-04-18 13:26 - 2017-05-27 00:44 - 000000000 ____D C:\ProgramData\Adguard
                      2019-04-18 13:26 - 2017-05-27 00:43 - 000000000 ____D C:\Program Files (x86)\Adguard
                      2019-04-18 12:32 - 2015-09-12 20:58 - 000000000 ____D C:\Users\Lenovo\AppData\Local\TeamViewer
                      2019-04-18 12:30 - 2018-05-26 17:10 - 000000000 ____D C:\Users\DefaultAppPool
                      2019-04-18 12:30 - 2015-09-12 20:45 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\TeamViewer
                      2019-04-18 10:28 - 2018-03-22 21:37 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\360safe
                      2019-04-18 10:20 - 2018-05-26 17:10 - 000000000 ____D C:\Users\Lenovo
                      2019-04-18 10:14 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\system32\NDF
                      2019-04-18 03:57 - 2018-03-24 19:05 - 000000428 _____ C:\WINDOWS\Tasks\Driver Easy Scheduled Scan.job
                      2019-04-18 03:50 - 2019-02-16 23:48 - 000003752 _____ C:\WINDOWS\System32\Tasks\Opera scheduled assistant Autoupdate 1550324909
                      2019-04-18 03:50 - 2018-05-26 17:40 - 000003752 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player NPAPI Notifier
                      2019-04-18 03:50 - 2018-05-26 17:40 - 000003556 _____ C:\WINDOWS\System32\Tasks\Driver Easy Scheduled Scan
                      2019-04-18 03:50 - 2018-05-26 17:40 - 000002970 _____ C:\WINDOWS\System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132
                      2019-04-18 03:50 - 2018-05-26 17:40 - 000002646 _____ C:\WINDOWS\System32\Tasks\McAfee Remediation (Prepare)
                      2019-04-18 03:50 - 2018-05-26 17:40 - 000002604 _____ C:\WINDOWS\System32\Tasks\IntelSURQC-Upgrade-86621605-2a0b-4128-8ffc-15514c247132-Logon
                      2019-04-18 03:50 - 2018-05-26 17:40 - 000002220 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
                      2019-04-18 03:50 - 2018-05-26 17:40 - 000002202 _____ C:\WINDOWS\System32\Tasks\StartCN
                      2019-04-18 03:48 - 2019-03-18 21:26 - 000000000 ____D C:\WINDOWS\System32\Tasks\Avast Software
                      2019-04-18 01:12 - 2017-09-28 20:12 - 000061060 _____ C:\Users\Lenovo\Desktop\Share.xlsx
                      2019-04-17 19:52 - 2018-04-12 09:38 - 000000000 ___HD C:\Program Files\WindowsApps
                      2019-04-16 13:23 - 2018-12-26 22:02 - 000019344 _____ C:\Users\Lenovo\Desktop\Mascot-202-RENT.xlsx
                      2019-04-13 19:26 - 2016-09-22 12:11 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\vlc
                      2019-04-13 05:25 - 2019-03-18 21:25 - 000476264 _____ (AVAST Software) C:\WINDOWS\system32\Drivers\asw1af7b8ca475981fe.tm p
                      2019-04-12 12:56 - 2018-03-25 06:00 - 000000000 ____D C:\Program Files (x86)\Intel Driver and Support Assistant
                      2019-04-12 03:45 - 2018-05-27 10:37 - 000503220 _____ C:\WINDOWS\system32\perfh011.dat
                      2019-04-12 03:45 - 2018-05-27 10:37 - 000145096 _____ C:\WINDOWS\system32\perfc011.dat
                      2019-04-12 03:45 - 2018-05-26 17:09 - 001571872 _____ C:\WINDOWS\system32\PerfStringBackup.INI
                      2019-04-12 02:47 - 2018-03-22 21:47 - 000001443 _____ C:\Users\Lenovo\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs\Opera Browser.lnk
                      2019-04-11 18:06 - 2018-03-22 21:38 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\360TotalSecurity
                      2019-04-11 17:47 - 2018-04-12 19:20 - 000000000 ____D C:\Program Files\Windows Defender Advanced Threat Protection
                      2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ___RD C:\Program Files\Windows Defender
                      2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\TextInput
                      2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\PolicyDefinitions
                      2019-04-11 17:47 - 2018-04-12 09:38 - 000000000 ____D C:\WINDOWS\bcastdvr
                      2019-04-10 10:03 - 2018-04-12 09:30 - 000000000 ____D C:\WINDOWS\CbsTemp
                      2019-04-10 09:51 - 2015-03-13 02:43 - 000000000 ____D C:\WINDOWS\system32\MRT
                      2019-04-10 09:44 - 2015-03-13 02:42 - 131129288 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
                      2019-04-07 23:23 - 2018-03-22 21:48 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\360DrvMgr
                      2019-04-05 21:35 - 2017-09-29 19:45 - 000000000 ____D C:\Program Files\rempl
                      2019-04-02 03:51 - 2018-11-18 11:45 - 000835480 _____ (Adobe) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
                      2019-04-02 03:51 - 2018-11-18 11:45 - 000179608 _____ (Adobe) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
                      2019-03-26 08:20 - 2019-02-19 10:38 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Daum
                      2019-03-26 07:28 - 2019-03-18 21:25 - 000004264 _____ C:\WINDOWS\System32\Tasks\Avast Emergency Update
                      2019-03-21 15:57 - 2017-08-11 00:34 - 000000000 ____D C:\Users\Lenovo\AppData\Roaming\Microsoft\Windows\ Start Menu\Programs\Steam
                      2017-05-27 00:44 - 2018-06-15 09:49 - 000000267 _____ () C:\ProgramData\fontcacheev1.dat
                      2018-08-13 21:01 - 2018-06-14 21:01 - 000000032 ____R () C:\ProgramData\hash.dat
                      2015-10-04 11:58 - 2015-10-04 11:58 - 000000097 _____ () C:\Users\Lenovo\AppData\Roaming\settings.xml
                      2015-04-25 14:16 - 2015-04-25 14:16 - 000000054 _____ () C:\Users\Lenovo\AppData\Roaming\updater.cfg
                      2015-11-09 13:55 - 2015-11-30 19:16 - 000002856 _____ () C:\Users\Lenovo\AppData\Roaming\VoiceMeeterDefault .xml
                      2016-09-23 11:37 - 2017-01-05 11:54 - 000000202 _____ () C:\Users\Lenovo\AppData\Roaming_encryptiondb.grf
                      2014-11-26 19:09 - 2014-11-26 19:09 - 000000038 ___SH () C:\Users\Lenovo\AppData\Local\1754111884ee9ab5277c a00.95260103
                      2014-12-26 00:02 - 2016-06-26 16:10 - 000007603 _____ () C:\Users\Lenovo\AppData\Local\Resmon.ResmonCfg
                      C:\WINDOWS\system32\dllhost.exe => File is digitally signed
                      C:\WINDOWS\SysWOW64\dllhost.exe => File is digitally signed
                      ATTENTION: ==> Could not access BCD.
                      LastRegBack: 2018-05-26 17:01
                      • jmarket
                        PCHF Owner
                        • 7695
                        • CachyOS
                        • Intel Arc A770 (16 GB)
                        #12
                        I assure you ResetBrowser is safe. Please run it and report back.
                        You still have some junk on the machine. I will have to analyze your log file before I have a fix for you.
                        • Baroona
                          • Apr 2019
                          • 27
                          #13
                          Yeah i trust you. I did run it before but im just wondering haha.
                          There is one weird interaction though, i tried to rerun the resetbrowser, however it doesnt automatically install the chrome when i press the reset button. It works with mozila but not chrome. So i have to download manually.
                          • jmarket
                            PCHF Owner
                            • 7695
                            • CachyOS
                            #14
                            Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system. Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
                            • Baroona
                              • Apr 2019
                              • 27
                              #15
                              Big thanks for the helps jmarket, however my chrome is still not fixed.
                              [HEADING=1]fix logs:
                              Fix result of Farbar Recovery Scan Tool (x64) Version: 18.04.2019
                              Ran by Lenovo (20-04-2019 04:13:00) Run:1
                              Running from C:\Users\Lenovo\Downloads\FRST
                              Loaded Profiles: Lenovo (Available Profiles: Lenovo & DefaultAppPool)
                              Boot Mode: Normal[/HEADING]
                              fixlist content:
                              start
                              CreateRestorePoint:
                              CloseProcesses:
                              ShellIconOverlayIdentifiers: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
                              ShellIconOverlayIdentifiers: [00asw] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
                              ShellIconOverlayIdentifiers: [00avg] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
                              ShellIconOverlayIdentifiers-x32: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
                              ContextMenuHandlers5: [Gadgets] → {6B9228DA-9C15-419e-856C-19E768A13BDC} => → No File
                              ContextMenuHandlers5: [igfxcui] → {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => → No File
                              Task: {08DE182E-4B30-4A1E-B2FD-C6EB7895D4FF} - \0915tbUpdateInfo → No File <==== ATTENTION
                              Task: {1C48C1BE-378A-4BD4-9CBC-1EE169FA27A9} - \FreeDownloadManagerNetworkMonitor → No File <==== ATTENTION
                              Task: {4B4D8E7B-0A5F-40FC-BBCD-29A82DE55E1E} - \AVG-SSU_0117avz_DELETE → No File <==== ATTENTION
                              Task: {728F5E94-6E39-4D9D-BDDF-15FE8F3796DB} - \cFos\Registration Tasks\Open Browser → No File <==== ATTENTION
                              Task: {754E8E88-D223-42F3-9481-B9A6C2933CF3} - \Microsoft\Windows\UNP\RunCampaignManager → No File <==== ATTENTION
                              Task: {C14A101B-90DF-4EA6-814A-49BE72CAD1BA} - \AVG-SSU_0117avz → No File <==== ATTENTION
                              AlternateDataStreams: C:\ProgramData\Temp:56E2E879 [135]
                              HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Restriction <==== ATTENTION
                              GroupPolicy: Restriction ? <==== ATTENTION
                              Tcpip..\Interfaces{2e5093be-ec30-45b1-a0b7-0a9388c176f1}: [DhcpNameServer] 172.20.10.1
                              Tcpip..\Interfaces{8d45d7f2-23ec-402e-ba7c-d7e2681ab43c}: [DhcpNameServer] 192.168.0.1
                              HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <==== ATTENTION
                              Hosts:
                              CMD: netsh advfirewall reset
                              CMD: netsh advfirewall set allprofiles state On
                              RemoveProxy:
                              CMD: ipconfig /flushdns
                              CMD: netsh winsock reset catalog
                              CMD: netsh int ip reset c:\resetlog.txt
                              CMD: ipconfig /release
                              CMD: ipconfig /renew
                              CMD: netsh int ipv4 reset
                              CMD: netsh int ipv6 reset
                              EmptyTemp:
                              reboot:
                              end
                              HKLM\Software\Microsoft\Windows\CurrentVersion\Exp lorer\ShellIconOverlayIdentifiers\ OneDrive7 => removed successfully
                              HKLM\Software\Classes\CLSID{C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => not found
                              HKLM\Software\Microsoft\Windows\CurrentVersion\Exp lorer\ShellIconOverlayIdentifiers\00asw => removed successfully
                              HKLM\Software\Classes\CLSID{472083B0-C522-11CF-8763-00608CC02F24} => not found
                              HKLM\Software\Microsoft\Windows\CurrentVersion\Exp lorer\ShellIconOverlayIdentifiers\00avg => removed successfully
                              HKLM\Software\Wow6432Node\Microsoft\Windows\Curren tVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive7 => removed successfully
                              HKLM\Software\Wow6432Node\Classes\CLSID{C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => not found
                              HKLM\Software\Classes\Directory\Background\ShellEx \ContextMenuHandlers\Gadgets => removed successfully
                              HKLM\Software\Classes\CLSID{6B9228DA-9C15-419e-856C-19E768A13BDC} => not found
                              HKLM\Software\Classes\Directory\Background\ShellEx \ContextMenuHandlers\igfxcui => removed successfully
                              HKLM\Software\Classes\CLSID{3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => not found
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{08DE182 E-4B30-4A1E-B2FD-C6EB7895D4FF}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{08DE182 E-4B30-4A1E-B2FD-C6EB7895D4FF}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\0915tbUp dateInfo” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Boot{1C48C1BE-378A-4BD4-9CBC-1EE169FA27A9}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{1C48C1B E-378A-4BD4-9CBC-1EE169FA27A9}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\FreeDown loadManagerNetworkMonitor” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{4B4D8E7 B-0A5F-40FC-BBCD-29A82DE55E1E}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{4B4D8E7 B-0A5F-40FC-BBCD-29A82DE55E1E}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\AVG-SSU_0117avz_DELETE” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{728F5E9 4-6E39-4D9D-BDDF-15FE8F3796DB}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{728F5E9 4-6E39-4D9D-BDDF-15FE8F3796DB}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\cFos\Reg istration Tasks\Open Browser” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{754E8E8 8-D223-42F3-9481-B9A6C2933CF3}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{754E8E8 8-D223-42F3-9481-B9A6C2933CF3}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\UNP\RunCampaignManager” => not found
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{C14A101 B-90DF-4EA6-814A-49BE72CAD1BA}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{C14A101 B-90DF-4EA6-814A-49BE72CAD1BA}” => removed successfully
                              “HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\AVG-SSU_0117avz” => removed successfully
                              C:\ProgramData\Temp => “:56E2E879” ADS removed successfully
                              HKLM\SOFTWARE\Policies\Microsoft\Windows Defender => removed successfully
                              C:\WINDOWS\system32\GroupPolicy\Machine => moved successfully
                              C:\WINDOWS\system32\GroupPolicy\GPT.ini => moved successfully
                              “HKLM\System\CurrentControlSet\Services\Tcpip\Para meters\Interfaces{2e5093be-ec30-45b1-a0b7-0a9388c176f1}\DhcpNameServer” => removed successfully
                              “HKLM\System\CurrentControlSet\Services\Tcpip\Para meters\Interfaces{8d45d7f2-23ec-402e-ba7c-d7e2681ab43c}\DhcpNameServer” => removed successfully
                              HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer => removed successfully
                              C:\Windows\System32\Drivers\etc\hosts => moved successfully
                              Hosts restored successfully.
                              ========= netsh advfirewall reset =========
                              Ok.
                              ========= netsh advfirewall set allprofiles state On =========
                              Ok.
                              “HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVer sion\Internet Settings\Connections\DefaultConnectionSettings” => removed successfully
                              “HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVer sion\Internet Settings\Connections\SavedLegacySettings” => removed successfully
                              “HKU\S-1-5-21-1925601759-1010797402-2804155008-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\DefaultConnectionSettings” => removed successfully
                              “HKU\S-1-5-21-1925601759-1010797402-2804155008-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\SavedLegacySettings” => removed successfully
                              Windows IP Configuration
                              ========= netsh winsock reset catalog =========
                              Sucessfully reset the Winsock Catalog.
                              You must restart the computer in order to complete the reset.
                              ========= netsh int ip reset c:\resetlog.txt =========
                              Resetting Compartment Forwarding, OK!
                              Resetting Compartment, OK!
                              Resetting Control Protocol, OK!
                              Resetting Echo Sequence Request, OK!
                              Resetting Global, OK!
                              Resetting Interface, OK!
                              Resetting Anycast Address, OK!
                              Resetting Multicast Address, OK!
                              Resetting Unicast Address, OK!
                              Resetting Neighbor, OK!
                              Resetting Path, OK!
                              Resetting Potential, OK!
                              Resetting Prefix Policy, OK!
                              Resetting Proxy Neighbor, OK!
                              Resetting Route, OK!
                              Resetting Site Prefix, OK!
                              Resetting Subinterface, OK!
                              Resetting Wakeup Pattern, OK!
                              Resetting Resolve Neighbor, OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , failed.
                              Access is denied.
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Restart the computer to complete this action.
                              ========= ipconfig /release =========
                              No operation can be performed on Ethernet while it has its media disconnected.
                              No operation can be performed on Local Area Connection* 4 while it has its media disconnected.
                              No operation can be performed on Local Area Connection* 5 while it has its media disconnected.
                              Ethernet adapter Ethernet:
                              Wireless LAN adapter Local Area Connection* 4:
                              Wireless LAN adapter Local Area Connection* 5:
                              Wireless LAN adapter Wi-Fi:
                              Link-local IPv6 Address . . . . . : fe80::941a:52d:426a:63f6%15
                              Default Gateway . . . . . . . . . :
                              ========= ipconfig /renew =========
                              No operation can be performed on Local Area Connection while it has its media disconnected.
                              IPv4 Address. . . . . . . . . . . : 192.168.0.2
                              ========= netsh int ipv4 reset =========
                              Resetting Path, OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , failed.
                              Access is denied.
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              ========= netsh int ipv6 reset =========
                              Resetting Path, OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , failed.
                              Access is denied.
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              Resetting , OK!
                              BITS transfer queue => 10510336 B
                              DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 75883627 B
                              Java, Flash, Steam htmlcache => 450836743 B
                              Windows/system/drivers => 8045374 B
                              Edge => 6322 B
                              Chrome => 251903992 B
                              Firefox => 981972574 B
                              Opera => 28188050 B
                              Default => 6656 B
                              Users => 0 B
                              ProgramData => 0 B
                              Public => 0 B
                              systemprofile => 0 B
                              systemprofile32 => 0 B
                              LocalService => 9376 B
                              LocalService => 0 B
                              NetworkService => 6656 B
                              NetworkService => 0 B
                              Lenovo => 95666212 B
                              DefaultAppPool => 6656 B
                              RecycleBin => 0 B
                              EmptyTemp: => 1.8 GB temporary data Removed.
                              The system needed a reboot.
                              ==== End of Fixlog 04:16:06 ====
