PC Slow with Frequent Not Responding Message
  • werdnarolyat
    • Mar 2018
    • 81
    #16
    Hi gus,
    The above is the only other scan results I could find from today - found it in the C://AdwCleaner folder.
    I mistakenly thought that Malwarebytes was more of an on demand tool rather than constantly running. When I try to load it from the system tray I get an error saying:
    "Malwarebytes is unable to load the Anti-Rootkit DDA Driver.
    This error may be due to rootkit activity. We recommend rebooting so Malwarebytes can attempt to install the driver.
    Do you want to reboot now?"
    I will remove Malwarebytes.
    Is there a more powerful tool than CCleaner for uninstalling programs? I think I must’ve attempted to remove Zonealarm using CCleaner.
    I did not deliberately open ports on in the firewall.
    • system
      PCHF Owner
      • 7695
      • CachyOS
      • Intel Arc A770 (16 GB)
      #17
      Hi, werdnarolyat,
      Tools such as Revo Uninstaller or Geek Uninstaller are arguably the pick of the uninstall tools, mind you no tools will remove everything. Probably jumping a bit ahead here too before I check your logs, but if you have anything Iobit on you machine I would strongly urge you to remove it/them.
      I will be away for Today and whilst I look over your logs properly will you please run RogueKiller.
      Please go here and download RogueKiller, click HERE to download a 32bit version, or HERE for a 64bit one. If you are unsure if your PC is a 32 or 64bit version look HERE.
      [COLOR=rgb(184, 49, 47)]Save the download to your desktop.
      [li][COLOR=rgb(184, 49, 47)]Close all running programs, Including any Antivirus or Security programs. If you are unsure how to do this please ask.[/li][li]Right click the new RogueKiller desktop shortcut, and then click on “Run as Administrator”[/li][li]If you get a dialogue box explaining that there is a new version, go to the website and download it. Click the go to website button at the bottom of the box.[/li][li]Once the application is open, or you have updated it, click on the Scan button located on the top menu bar.[/li][li]The scan may take some time to complete depending on the amount of data on your PC. Allow it to complete.[/li][li]Once the scan is complete check every item for deletion.[/li][li]Then check “Remove Selected” [/li][/ul]
      [MEDIA=imgur]C4i7v64[/MEDIA]
      Again it may take a little time to remove the detections.
      Then click “Open Report” on the bottom left of the main program interface.
      A new dialogue box will open, click “Open TXT”
      [MEDIA=imgur]u32ik5U[/MEDIA]
      [COLOR=rgb(41, 105, 176)]Please Copy and Paste the contents of that text file in your next post.
      If by chance you have closed the TXT file before copying it you can retrieve it by clicking on the History button on the programs main interface.[/COLOR][/COLOR][/COLOR]
      • werdnarolyat
        • Mar 2018
        • 81
        #18
        Thanks gus.
        Should I use Geek Uninstaller after you’ve checked the above logs and I’ve run Rogue Killer?
        • werdnarolyat
          • Mar 2018
          • 81
          #19
          RogueKiller V12.12.10.0 [Mar 26 2018] (Free) by Adlice Software
          mail : Support Form | Contact • Adlice Software
          Feedback : https://forum.adlice.com
          Website : Free Virus Cleaner | RogueKiller AntiMalware • Adlice Software
          Blog : http://www.adlice.com
          Operating System : Windows 7 (6.1.7601 Service Pack 1) 32 bits version
          Started in : Normal mode
          User : David [Administrator]
          Started from : C:\Users\David\Desktop\RogueKiller_portable32.exe
          Mode : Delete – Date : 03/29/2018 09:17:09 (Duration : 01:18:08)
          ¤¤¤ Processes : 0 ¤¤¤
          ¤¤¤ Registry : 2 ¤¤¤
          [Hj.RegVal] HKEY_LOCAL_MACHINE\RK_Software_ON_D_653C\Microsoft \Windows NT\CurrentVersion\Winlogon | Shell : cmd.exe /k start cmd.exe → Replaced (explorer.exe)
          [PUM.Proxy] HKEY_LOCAL_MACHINE\RK_System_ON_D_0500\ControlSet0 01\Services\NlaSvc\Parameters\Internet\ManualProxi es | (default) : → Deleted
          ¤¤¤ Tasks : 2 ¤¤¤
          [Suspicious.Path] %WINDIR%\Tasks{4DB442F9-C5C4-47D4-CABC-256BB9E033EC}.job – C:\Users\David\AppData\Local{453F7~1\UNINST~1.EXE (/Check) → Deleted
          [Hj.Shortcut] {6DCE0CBF-14D4-4F83-A3A5-6D140E6CC7A3} – “c:\program files\mozilla firefox\firefox.exe” ( http://ui.skype.com/ui/0/5.8.0.158.2...ll?page=tsMain ) → Deleted
          ¤¤¤ Files : 1 ¤¤¤
          [Hj.Shortcut][File] C:\Users\David\AppData\Roaming\QuickScan\Launch QuickScan.lnk [LNK@] C:\PROGRA~1\MOZILL~1\firefox.exe http://quickscan.bitdefender.com/ → Shortcut cleaned
          ¤¤¤ WMI : 0 ¤¤¤
          ¤¤¤ Hosts File : 0 [Too big!] ¤¤¤
          ¤¤¤ Antirootkit : 0 (Driver: Loaded) ¤¤¤
          ¤¤¤ Web browsers : 0 ¤¤¤
          ¤¤¤ MBR Check : ¤¤¤
          +++++ PhysicalDrive0: ST3750630AS ATA Device +++++
          — User —
          [MBR] 3245321b7248dc7923dd47d9a442a0bd
          [BSP] 5ac569e9e71c018ba2b70830b9d7016e : Windows Vista/7/8 MBR Code
          Partition table:
          0 - [XXXXXX] DELL-UTIL (0xde) [VISIBLE] Offset (sectors): 63 | Size: 86 MB
          1 - [XXXXXX] NTFS (0x7) [VISIBLE] Offset (sectors): 178176 | Size: 15360 MB [Windows Vista/7/8 Bootstrap | Windows Vista/7/8 Bootloader]
          2 - [ACTIVE] NTFS (0x7) [VISIBLE] Offset (sectors): 31635456 | Size: 699956 MB [Windows Vista/7/8 Bootstrap | Windows Vista/7/8 Bootloader]
          User = LL1 … OK
          User = LL2 … OK
          +++++ PhysicalDrive1: Seagate FreeAgent USB Device +++++
          — User —
          [MBR] e4d4c344682f37fae9a22fb26ed1af77
          [BSP] a496701c9300c65bf86f597667d86edf : Windows XP|VT.Unknown MBR Code
          Partition table:
          0 - [XXXXXX] NTFS (0x7) [VISIBLE] Offset (sectors): 63 | Size: 953867 MB [Windows XP Bootstrap | Windows XP Bootloader]
          User = LL1 … OK
          Error reading LL2 MBR! ([32] The request is not supported. )
          +++++ PhysicalDrive2: Generic- Compact Flash USB Device +++++
          Error reading User MBR! ([15] The device is not ready. )
          Error reading LL1 MBR! NOT VALID!
          +++++ PhysicalDrive3: Generic- SM/xD-Picture USB Device +++++
          +++++ PhysicalDrive4: Generic- SD/MMC USB Device +++++
          +++++ PhysicalDrive5: Generic- MS/MS-Pro USB Device +++++
          • werdnarolyat
            • Mar 2018
            • 81
            #20
            Hi gus,
            Just to let you know, I tried using Geek Uninstaller but it found no trace of any ZoneAlarm or Iobit products.
            • system
              PCHF Owner
              • 7695
              • CachyOS
              #21
              Hi werdnarolyat, sorry about the delay, back now so will check your logs today. If you have no Iobit apps I will remove the bits from your logs. Let me make a fix for your logs to date and then we will get some fresh logs and we will come back to Zonealarm later.
              • werdnarolyat
                • Mar 2018
                • 81
                #22
                Great, thanks gus.
                There are no Iobit apps intentionally installed just now.
                • system
                  PCHF Owner
                  • 7695
                  • CachyOS
                  #23
                  Hi, can you also uninstall Superantispyware?
                  • system
                    PCHF Owner
                    • 7695
                    • CachyOS
                    #24
                    Hi again,
                    Please left click on the attached Fixlist.txt file at the bottom of this post. On the dialogue box that opens click “Save File” and then “OK”
                    [MEDIA=imgur]vzol8OV[/MEDIA]
                    Select a location then save the file. [COLOR=rgb(184, 49, 47)]IMPORTANT the fixlist.txt file must be in the same location as the FRST program otherwise the fix will not work.
                    [MEDIA=imgur]pjsQ8XB[/MEDIA]
                    To run the fix right click the FRST icon and choose “Run as Administrator” then click on “Fix”
                    [MEDIA=imgur]cp0349X[/MEDIA]
                    Depending on the amount of data to be moved it may take a few minutes to complete, and the computer may reboot. When the fix is complete and/or the computer has rebooted the “Fixlist.txt” file you created will be renamed “Fixlog.txt”
                    [COLOR=rgb(184, 49, 47)]Please COPY and PASTE the contents of this new file in your next post[COLOR=rgb(184, 49, 47)]
                    Now you need to reset your Internet Explorer browser.
                    https://i.imgur.com/vwUeyaZ.png
                    [li]Download ResetBrowser To your desktop.[/li][li]Now [COLOR=rgb(41, 105, 176)]please close all open browsers.[/li][li]Right click and run as administrator.[/li][li]Click on [COLOR=rgb(250, 197, 28)]Reset INTERNET EXPLORER and allow completion.[/li][/ul][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR]
                    • werdnarolyat
                      • Mar 2018
                      • 81
                      #25
                      Fix result of Farbar Recovery Scan Tool (x86) Version: 14.03.2018
                      Ran by David (30-03-2018 20:26:05) Run:1
                      Running from C:\Users\David\Desktop
                      Loaded Profiles: David & UpdatusUser (Available Profiles: David & UpdatusUser)
                      Boot Mode: Normal
                      fixlist content:
                      Start
                      CreateRestorepoint:
                      CloseProcesses:
                      Winsock: Catalog5 07 C:\Program Files\Bonjour\mdnsNSP.dll [122128 2015-08-12] (Apple Inc.)
                      HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = hxxp://uk.msn.com/?rd=1&ucc=GB&dcc=GB&opt=0&ocid=iehp
                      HKU\S-1-5-21-1365679944-132168641-953657067-1000\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = hxxp://g.uk.msn.com/USCON/2
                      SearchScopes: HKLM → DefaultScope {CE278C74-1B0C-4615-96A3-38CC94C07A27} URL =
                      SearchScopes: HKLM → {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
                      SearchScopes: HKU.DEFAULT → DefaultScope {CE278C74-1B0C-4615-96A3-38CC94C07A27} URL =
                      SearchScopes: HKU\S-1-5-21-1365679944-132168641-953657067-1000 → {6A1806CD-94D4-4689-BA73-E35EA1EA9990} URL =
                      SearchScopes: HKU\S-1-5-21-1365679944-132168641-953657067-1000 → {8EEAC88A-079B-4b2c-80C1-7836F79EB40A} URL = hxxp://uk.search.yahoo.com/search?p={searchTerms}&fr=chr-comodo
                      DPF: {56762DEC-6B0D-4AB4-A8AD-989993B5D08B} hxxp://www.eset.eu/buxus/docs/OnlineScanner.cab
                      DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} hxxp://java.sun.com/update/1.7.0/jinstall-1_7_0_51-windows-i586.cab
                      DPF: {CAFEEFAC-0017-0000-0051-ABCDEFFEDCBA} hxxp://java.sun.com/update/1.7.0/jinstall-1_7_0_51-windows-i586.cab
                      DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} hxxp://java.sun.com/update/1.7.0/jinstall-1_7_0_51-windows-i586.cab
                      FF Extension: (No Name) - C:\Program Files\eMusic Download Manager\xulrunner\extensionsdlm_itunes@emusic.com [not found]
                      FF Extension: (No Name) - C:\Program Files\eMusic Download Manager\xulrunner\extensionsdlm_winamp@emusic.com [not found]
                      FF Extension: (No Name) - C:\Program Files\eMusic Download Manager\xulrunner\extensionsdlm_wmp@emusic.com [not found]
                      CHR HKLM...\Chrome\Extension: [flliilndjeohchalpbbcdekjklbdgfkk] - hxxps://clients2.google.com/service/update2/crx
                      CHR HKLM...\Chrome\Extension: [jfmjfhklogoienhpfnppmbcbjfjnkonk] - <no Path/update_url>
                      C:\Windows\Tasks{4DB442F9-C5C4-47D4-CABC-256BB9E033EC}.job
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{04EBE69E-2DED-44F6-9854-9A3988F751ED}\InprocServer32 → C:\Users\David\AppData\Local\Dropbox\Update\1.3.51 .1\psuser.dll => No File
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{0A368B9B-3566-4730-B40E-EAF6858A53AF}\InprocServer32 → C:\Users\David\AppData\Local\Dropbox\Update\1.3.27 .33\psuser.dll => No File
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{144DF3B2-2402-47AE-9583-5A045929A8D4}\InprocServer32 → C:\Users\David\AppData\Local\Google\Update\1.3.33. 5\psuser.dll => No File
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{2027D000-8CEB-4191-9620-15DD2561855F}\InprocServer32 → C:\Users\David\AppData\Local\Dropbox\Update\1.3.57 .1\psuser.dll => No File
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{590C4387-5EBD-4D46-8A84-CD0BA2EF2856}\InprocServer32 → C:\Users\David\AppData\Local\Google\Update\1.3.30. 3\psuser.dll => No File
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{59B55F04-DE14-4BB8-92FF-C4A22EF2E5F4}\InprocServer32 → C:\Users\David\AppData\Local\Google\Update\1.3.31. 5\psuser.dll => No File
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{8C46158B-D978-483C-A312-16EE5013BE04}\InprocServer32 → C:\Users\David\AppData\Local\Google\Update\1.3.33. 3\psuser.dll => No File
                      CustomCLSID: HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA}\InprocServer32 → C:\Users\David\AppData\Local\Google\Update\1.3.32. 7\psuser.dll => No File
                      ContextMenuHandlers1: [IObitUnstaler] → {B19ED566-D419-470b-B111-3C89040BC027} => → No File
                      ContextMenuHandlers1: [LavasoftShellExt] → {DCE027F7-16A4-4BEE-9BE7-74F80EE3738F} => → No File
                      ContextMenuHandlers1: [SmartDefragExtension] → {189F1E63-33A7-404B-B2F6-8C76A452CC54} => → No File
                      ContextMenuHandlers1: [ZLAVShExt] → {D9872D13-7651-4471-9EEE-F0A00218BEBB} => C:\Program Files\CheckPoint\ZoneAlarm\zlavscan.dll → No File
                      ContextMenuHandlers5: [igfxcui] → {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => → No File
                      ContextMenuHandlers6: [ZLAVShExt] → {D9872D13-7651-4471-9EEE-F0A00218BEBB} => C:\Program Files\CheckPoint\ZoneAlarm\zlavscan.dll → No File
                      Task: {07BA4BB6-FE13-4020-985A-780781738826} - \Driver Booster SkipUAC (David) → No File <==== ATTENTION
                      Task: {2BF84EFE-C4BA-4720-BD3C-C9BFBC620937} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2018-03-06] (Piriform Ltd)
                      Task: {57A9D223-4743-42A4-A195-BD5F48C5755B} - System32\Tasks\SmartDefrag => C:\Program Files\IObit\IObit SmartDefrag\IObit SmartDefrag.exe
                      Task: {8401FDD5-BD53-4F87-AA11-45BB97713683} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe [2018-03-06] (Piriform Ltd)
                      Task: {878236F4-BFB9-42A4-8EB7-BA1552F24AF4} - {4DB442F9-C5C4-47D4-CABC-256BB9E033EC} → No File <==== ATTENTION
                      Task: {BB81403D-923E-4F31-B6FA-1F24F0BDD336} - System32\Tasks{DF81553E-9FE4-46F9-A698-E6FEC3497677} => C:\Windows\system32\pcalua.exe -a C:\Users\David\Downloads\Xvid-1.2.2-07062009.exe -d “K:\Photos\Lost season 5”
                      Task: {C2C21F40-674F-47CF-8D11-D24E7D21EBBC} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files\Apple Software Update\SoftwareUpdate.exe [2017-10-12] (Apple Inc.)
                      Task: {DEAEF5E5-4577-4785-B02A-19A99003D01F} - {77FD207A-F73E-4650-9133-C6BF9DCB9A1D} → No File <==== ATTENTION
                      Task: {E3B74E19-B294-4BA5-8891-D72218EE4503} - System32\Tasks{C16E4FDC-EC6A-4B6B-9404-EDA79210A247} => C:\Windows\system32\pcalua.exe -a “C:\Program Files\VS Revo Group\Revo Uninstaller\RevoUnin.exe” -d “C:\Program Files\VS Revo Group\Revo Uninstaller”
                      Task: {F31BB7E0-A603-46F9-B04E-10075749C18E} - System32\Tasks{6DCE0CBF-14D4-4F83-A3A5-6D140E6CC7A3} => “c:\program files\mozilla firefox\firefox.exe” hxxp://ui.skype.com/ui/0/5.8.0.158.259/en/abandoninstall?page=tsMain
                      Task: C:\Windows\Tasks\SmartDefrag.job => C:\Program Files\IObit\IObit SmartDefrag\IObit SmartDefrag.exe
                      Task: C:\Windows\Tasks{4DB442F9-C5C4-47D4-CABC-256BB9E033EC}.job => C:\Users\David\AppData\Local{453F7~1\UNINST~1.EXE <==== ATTENTION
                      AlternateDataStreams: C:\Users\David\Downloads\f9824a1717a164c3.mp4:TOC. WMV [130]
                      C:\Program Files\GUT3E11.tmp
                      C:\Users\David\Downloads\4jtq78j5.exe
                      CMD: netsh advfirewall reset
                      CMD: netsh advfirewall set allprofiles state On
                      CMD: ipconfig /flushdns
                      Hosts:
                      Emptytemp:
                      Reboot:
                      end
                      “HKLM\SYSTEM\CurrentControlSet\Services\WinSock2\P arameters\NameSpace_Catalog5\Catalog_Entries\00000 0000007” => removed successfully.
                      “HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main\Start Page Redirect Cache” => removed successfully.
                      HKU\S-1-5-21-1365679944-132168641-953657067-1000\Software\Microsoft\Internet Explorer\Main\Default_Page_URL => value restored successfully
                      HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\DefaultScope => value restored successfully
                      “HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes{0633EE93-D776-472f-A0FF-E1416B8B2E3A}” => removed successfully.
                      HKLM\Software\Classes\CLSID{0633EE93-D776-472f-A0FF-E1416B8B2E3A} => not found
                      “HKU.DEFAULT\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\DefaultScope” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000\SOFTWARE\Microsoft\Internet Explorer\SearchScopes{6A1806CD-94D4-4689-BA73-E35EA1EA9990}” => removed successfully.
                      HKLM\Software\Classes\CLSID{6A1806CD-94D4-4689-BA73-E35EA1EA9990} => not found
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000\SOFTWARE\Microsoft\Internet Explorer\SearchScopes{8EEAC88A-079B-4b2c-80C1-7836F79EB40A}” => removed successfully.
                      HKLM\Software\Classes\CLSID{8EEAC88A-079B-4b2c-80C1-7836F79EB40A} => not found
                      “HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units{56762DEC-6B0D-4AB4-A8AD-989993B5D08B}” => removed successfully.
                      HKLM\Software\Classes\CLSID{56762DEC-6B0D-4AB4-A8AD-989993B5D08B} => not found
                      “HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units{8AD9C840-044E-11D1-B3E9-00805F499D93}” => removed successfully.
                      HKLM\Software\Classes\CLSID{8AD9C840-044E-11D1-B3E9-00805F499D93} => not found
                      “HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units{CAFEEFAC-0017-0000-0051-ABCDEFFEDCBA}” => removed successfully.
                      HKLM\Software\Classes\CLSID{CAFEEFAC-0017-0000-0051-ABCDEFFEDCBA} => not found
                      “HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}” => removed successfully.
                      HKLM\Software\Classes\CLSID{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} => not found
                      C:\Program Files\eMusic Download Manager\xulrunner\extensionsdlm_itunes@emusic.com => path removed successfully.
                      C:\Program Files\eMusic Download Manager\xulrunner\extensionsdlm_winamp@emusic.com => path removed successfully.
                      C:\Program Files\eMusic Download Manager\xulrunner\extensionsdlm_wmp@emusic.com => path removed successfully.
                      “HKLM\SOFTWARE\Google\Chrome\Extensions\flliilndje ohchalpbbcdekjklbdgfkk” => removed successfully.
                      “HKLM\SOFTWARE\Google\Chrome\Extensions\jfmjfhklog oienhpfnppmbcbjfjnkonk” => removed successfully.
                      “C:\Windows\Tasks{4DB442F9-C5C4-47D4-CABC-256BB9E033EC}.job” => not found
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{04EBE69E-2DED-44F6-9854-9A3988F751ED}” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{0A368B9B-3566-4730-B40E-EAF6858A53AF}” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{144DF3B2-2402-47AE-9583-5A045929A8D4}” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{2027D000-8CEB-4191-9620-15DD2561855F}” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{590C4387-5EBD-4D46-8A84-CD0BA2EF2856}” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{59B55F04-DE14-4BB8-92FF-C4A22EF2E5F4}” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{8C46158B-D978-483C-A312-16EE5013BE04}” => removed successfully.
                      “HKU\S-1-5-21-1365679944-132168641-953657067-1000_Classes\CLSID{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA}” => removed successfully.
                      “HKLM\Software\Classes*\ShellEx\ContextMenuHandler s\IObitUnstaler” => removed successfully.
                      HKLM\Software\Classes\CLSID{B19ED566-D419-470b-B111-3C89040BC027} => not found
                      “HKLM\Software\Classes*\ShellEx\ContextMenuHandler s\LavasoftShellExt” => removed successfully.
                      HKLM\Software\Classes\CLSID{DCE027F7-16A4-4BEE-9BE7-74F80EE3738F} => not found
                      “HKLM\Software\Classes*\ShellEx\ContextMenuHandler s\SmartDefragExtension” => removed successfully.
                      HKLM\Software\Classes\CLSID{189F1E63-33A7-404B-B2F6-8C76A452CC54} => not found
                      “HKLM\Software\Classes*\ShellEx\ContextMenuHandler s\ZLAVShExt” => removed successfully.
                      “HKLM\Software\Classes\CLSID{D9872D13-7651-4471-9EEE-F0A00218BEBB}” => removed successfully.
                      “HKLM\Software\Classes\Directory\Background\ShellE x\ContextMenuHandlers\igfxcui” => removed successfully.
                      HKLM\Software\Classes\CLSID{3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => not found
                      “HKLM\Software\Classes\Folder\ShellEx\ContextMenuH andlers\ZLAVShExt” => removed successfully.
                      HKLM\Software\Classes\CLSID{D9872D13-7651-4471-9EEE-F0A00218BEBB} => not found
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{07BA4BB 6-FE13-4020-985A-780781738826}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{07BA4BB 6-FE13-4020-985A-780781738826}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Driver Booster SkipUAC (David)” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{2BF84EF E-C4BA-4720-BD3C-C9BFBC620937}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{2BF84EF E-C4BA-4720-BD3C-C9BFBC620937}” => removed successfully.
                      C:\Windows\System32\Tasks\CCleanerSkipUAC => moved successfully
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\CCleaner SkipUAC” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{57A9D22 3-4743-42A4-A195-BD5F48C5755B}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{57A9D22 3-4743-42A4-A195-BD5F48C5755B}” => removed successfully.
                      C:\Windows\System32\Tasks\SmartDefrag => moved successfully
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\SmartDef rag” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Boot{8401FDD5-BD53-4F87-AA11-45BB97713683}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{8401FDD 5-BD53-4F87-AA11-45BB97713683}” => removed successfully.
                      C:\Windows\System32\Tasks\CCleaner Update => moved successfully
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\CCleaner Update” => removed successfully.
                      HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{878236F 4-BFB9-42A4-8EB7-BA1552F24AF4} => could not remove. Access Denied.
                      HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree{4DB442F9-C5C4-47D4-CABC-256BB9E033EC} => could not remove. Access Denied.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{BB81403 D-923E-4F31-B6FA-1F24F0BDD336}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{BB81403 D-923E-4F31-B6FA-1F24F0BDD336}” => removed successfully.
                      C:\Windows\System32\Tasks{DF81553E-9FE4-46F9-A698-E6FEC3497677} => moved successfully
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree{DF81553E-9FE4-46F9-A698-E6FEC3497677}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{C2C21F4 0-674F-47CF-8D11-D24E7D21EBBC}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{C2C21F4 0-674F-47CF-8D11-D24E7D21EBBC}” => removed successfully.
                      C:\Windows\System32\Tasks\Apple\AppleSoftwareUpdat e => moved successfully
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Apple\Ap pleSoftwareUpdate” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{DEAEF5E 5-4577-4785-B02A-19A99003D01F}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{DEAEF5E 5-4577-4785-B02A-19A99003D01F}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree{77FD207A-F73E-4650-9133-C6BF9DCB9A1D}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{E3B74E1 9-B294-4BA5-8891-D72218EE4503}” => removed successfully.
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{E3B74E1 9-B294-4BA5-8891-D72218EE4503}” => removed successfully.
                      C:\Windows\System32\Tasks{C16E4FDC-EC6A-4B6B-9404-EDA79210A247} => moved successfully
                      “HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree{C16E4FDC-EC6A-4B6B-9404-EDA79210A247}” => removed successfully.
                      HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{F31BB7E 0-A603-46F9-B04E-10075749C18E} => could not remove. Access Denied.
                      “C:\Windows\System32\Tasks{6DCE0CBF-14D4-4F83-A3A5-6D140E6CC7A3}” => not found
                      HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree{6DCE0CBF-14D4-4F83-A3A5-6D140E6CC7A3} => could not remove. Access Denied.
                      C:\Windows\Tasks\SmartDefrag.job => moved successfully
                      C:\Users\David\Downloads\f9824a1717a164c3.mp4 => “:TOC.WMV” ADS removed successfully.
                      C:\Program Files\GUT3E11.tmp => moved successfully
                      C:\Users\David\Downloads\4jtq78j5.exe => moved successfully
                      ========= netsh advfirewall reset =========
                      Initialization Function InitHelperDll in NSHHTTP.DLL failed to start with error code 11003
                      Ok.
                      ========= netsh advfirewall set allprofiles state On =========
                      Ok.
                      Windows IP Configuration
                      Could not move “C:\Windows\System32\Drivers\etc\hosts” => Scheduled to move on reboot.
                      BITS transfer queue => 8388608 B
                      DOMStoree, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 41976357 B
                      Java, Flash, Steam htmlcache => 506 B
                      Windows/system/drivers => 4009913 B
                      Edge => 0 B
                      Chrome => 791599070 B
                      Firefox => 28578707 B
                      Opera => 0 B
                      Users => 0 B
                      Default => 66228 B
                      Public => 0 B
                      ProgramData => 0 B
                      systemprofile => 31217978 B
                      LocalService => 132244 B
                      NetworkService => 85514 B
                      David => 180130137 B
                      UpdatusUser => 66116 B
                      RecycleBin => 80291510 B
                      EmptyTemp: => 1.1 GB temporary data Removed.
                      Result of scheduled files to move (Boot Mode: Normal) (Date&Time: 30-03-2018 21:09:10)
                      “C:\Windows\System32\Drivers\etc\hosts” => Could not move.
                      Could not restore Hosts.
                      Result of scheduled keys to remove after reboot:
                      ==== End of Fixlog 21:09:10 ====
                      • werdnarolyat
                        • Mar 2018
                        • 81
                        #26
                        Hi gus,
                        I have removed Super Anti-Spyware and reset Internet Explorer as you recommended.
                        • system
                          PCHF Owner
                          • 7695
                          • CachyOS
                          #27
                          Hi wernarolyat,
                          [li]Click here to download RstHosts v2.0[/li][li]Save the file to your desktop.[/li][li]Right Click and Run as Administrator.[/li][li]Click on Restaurer, then click OK at the prompt.[/li][li]This will restore the default host file.[/li][li]Next Click on Creer Un Rapport.[/li][li]This will open a logfile, please post that in your next reply.[/li][/ul]
                          Next up,
                          [li]Please go HERE and download Malwarebytes Anti-Rootkit, save it to your desktop.[/li][li]Right click the new desktop icon and then click “Run as Administrator” from the menu.[/li][li]A dialogue box will ask where to extract the program, again select the desktop. After the files are extracted a new folder will be created on the desktop, called Mbar, and the program will open.[/li][li]To re-open the program once it has been closed, right click the MBAR icon again and let it extract and overwrite the new folder again and the app will open, or open the folder Mbar created originally and right click mbar.exe or mbar.cmd and select “Run as Administrator”[/li][li]Once the program is open at the Introduction page, click Next.[/li][li]On the next screen click the update button on the right, and allow it to update. Once updated click Next.[/li][li]On the next screen click Scan. It will take some time to scan your system.[/li][li]When the scan is finished and if malware has been found, check all items and click cleanup. Should the program request a reboot please do so. (If the scan resulted in no malware found simply exit the app.[/li][li]Once the computer has rebooted open the desktop folder (mbar) and locate the log file with a similar format to that below excepting make sure the date is of your latest scan.[/li][/ul]
                          [MEDIA=imgur]K57Mh25[/MEDIA]
                          [li][COLOR=rgb(184, 49, 47)]Open the notepad file by double clicking it, copy and paste the contents of it in your next post please[COLOR=rgb(184, 49, 47)]:[/li][/ul][/COLOR][/COLOR]
                          • werdnarolyat
                            • Mar 2018
                            • 81
                            #28
                            -|x| RstHosts v2.0 - Rapport créé le 31/03/2018 à 11:44:41
                            -|x| Système d’exploitation : Windows 7 Home Premium Service Pack 1 (32 bits)
                            -|x| Nom d’utilisateur : David - DAVID-PC (Administrateur)
                            -|x|- Informations -|x|-
                            Emplacement : C:\Windows\System32\drivers\etc\hosts
                            Attribut(s) : RASH
                            Propriétaire : Administrators - BUILTIN
                            Taille : 444930 bytes
                            Date de création : 02/11/2006 - 11:23:50
                            Date de modification : 24/10/2012 - 15:18:56
                            Date de dernier accès : 02/11/2006 - 11:23:50
                            -|x|- Contenu du fichier -|x|-
                            [HEADING=1]Copyright (c) 1993-2006 Microsoft Corp.[/HEADING]
                            [HEADING=1]This is a sample HOSTS file used by Microsoft TCP/IP for Windows.[/HEADING]
                            [HEADING=1]This file contains the mappings of IP addresses to host names. Each[/HEADING]
                            [HEADING=1]entry should be kept on an individual line. The IP address should[/HEADING]
                            [HEADING=1]be placed in the first column followed by the corresponding host name.[/HEADING]
                            [HEADING=1]The IP address and the host name should be separated by at least one[/HEADING]
                            [HEADING=1]space.[/HEADING]
                            [HEADING=1]Additionally, comments (such as these) may be inserted on individual[/HEADING]
                            [HEADING=1]lines or following the machine name denoted by a ‘#’ symbol.[/HEADING]
                            [HEADING=1]For example:[/HEADING]
                            [HEADING=1]102.54.94.97 rhino.acme.com # source server[/HEADING]
                            [HEADING=1]38.25.63.10 x.acme.com # x client host[/HEADING]
                            127.0.0.1 localhost
                            ::1 localhost
                            [HEADING=1]Start of entries inserted by Spybot - Search & Destroy[/HEADING]
                            127.0.0.1 www.007guard.com
                            127.0.0.1 007guard.com
                            127.0.0.1 008i.com
                            127.0.0.1 www.008k.com
                            → 15303 ligne(s) supplémentaire(s)
                            -|x|- E.O.F - C:\RstHosts.txt - 1492 bytes -|x|-
                            • werdnarolyat
                              • Mar 2018
                              • 81
                              #29
                              Malwarebytes Anti-Rootkit BETA 1.10.3.1001
                              www.malwarebytes.org
                              Database version:
                              main: v2018.03.31.04
                              rootkit: v2018.03.08.03
                              Windows 7 Service Pack 1 x86 NTFS
                              Internet Explorer 11.0.9600.18860
                              David :: DAVID-PC [administrator]
                              31/03/2018 11:51:29
                              mbar-log-2018-03-31 (11-51-29).txt
                              Scan type: Quick scan
                              Scan options enabled: Anti-Rootkit | Drivers | MBR | Physical Sectors | Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken
                              Scan options disabled:
                              Objects scanned: 215029
                              Time elapsed: 40 minute(s), 40 second(s)
                              Memory Processes Detected: 0
                              (No malicious items detected)
                              Memory Modules Detected: 0
                              Registry Keys Detected: 0
                              Registry Values Detected: 0
                              Registry Data Items Detected: 0
                              Folders Detected: 0
                              Files Detected: 0
                              Physical Sectors Detected: 0
                              (end)
                              • system
                                PCHF Owner
                                • 7695
                                • CachyOS
                                #30
                                Hi werdnarolyat, can you please run another scan with FRST as per instructions in post number 5 and post the logs please. No need to delete the old logs because FRST will overwrite them. Only need FRST and not AdwCleaner.
