Security Check Scan.
[li]Download Security Check to your desktop.[/li][/ul]
[li]Right click it run as administrator.[/li][/ul]
[li]When the program completes, the tool will automatically open a log file.[/li][/ul]
[li]Please post that log here in your next post.[/li][/ul]
[/ul]
Hijack This Fix.
Start HijackThis , Right Click Run as Admin.
Click System Scan Only.
O4 - HKCU..\Run: [BingSvc] C:\Users\Georgene\AppData\Local\Microsoft\BingSvc\ BingSvc.exe
O4 - HKCU..\Run: [BlueStacks Agent] C:\Program Files (x86)\Bluestacks\HD-Agent.exe
O4 - HKCU..\Run: [Imo Messenger] C:\Users\Georgene\AppData\Roaming\Imo Messenger\ImoDesktopApp.exe -minimized
O4 - HKCU..\Run: [OneDrive] C:\Users\Georgene\AppData\Local\Microsoft\OneDrive \OneDrive.exe /background
O4 - HKCU..\Run: [Skype] C:\Program Files (x86)\Skype\Phone\Skype.exe /minimized /regrun
O4 - HKCU..\Run: [Upwork] C:\Program Files (x86)\Upwork\upwork.exe
O4 - HKLM..\StartupApproved\Run32: [HPMessageService] C:\Program Files (x86)\Hewlett-Packard\HP System Event\HPMSGSVC.exe
O4 - HKLM..\StartupApproved\Run32: [PowerDVD14Agent] C:\Program Files (x86)\CyberLink\PowerDVD14\PowerDVD14Agent.exe
O4 - HKLM..\StartupApproved\Run: [RTHDVCPL] C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe -s
O4 - HKU\S-1-5-19..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup
O4 - HKU\S-1-5-20..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup
O22 - Task (Ready): Adobe Acrobat Update Task - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe
O22 - Task (Ready): DropboxOEM - C:\Program Files (x86)\Dropbox\DropboxOEM\DropboxOEM.exe auto
O22 - Task (Ready): WpsNotifyTask_Administrator - C:\Program Files (x86)\Kingsoft\WPS Office\9.1.0.5113\wtoolex\wpsnotify.exe -from=task
O22 - Task (Ready): WpsUpdateTask_Administrator - C:\Program Files (x86)\Kingsoft\WPS Office\9.1.0.5113\wtoolex\wpsupdate.exe -from=task
O22 - Task (Ready): \Hewlett-Packard\HP Active Health\HP Active Health Scan (HPSA) - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPActiveHealth\ActiveHealth.ex e -task -source HPSA
O22 - Task (Ready): \Hewlett-Packard\HP Support Assistant\HP Active Health Launcher - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPActiveHealth\ActiveHealth.ex e -source HPSA --create-task
O22 - Task (Ready): \Hewlett-Packard\HP Support Assistant\HP Support Assistant Quick Start - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\HPSF.exe /taskrestart
O22 - Task (Ready): \Hewlett-Packard\HP Support Assistant\HP Support Solutions Framework Report - C:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\Modules\HPSFReport.exe /send
O22 - Task (Ready): \Hewlett-Packard\HP Support Assistant\HP Support Solutions Framework Updater - C:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\Modules\HPSSFUpdater.exe /u
O22 - Task (Ready): \Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser - C:\WINDOWS\system32\compattelrunner.exe
O22 - Task (Ready): \Microsoft\Windows\Application Experience\ProgramDataUpdater - C:\WINDOWS\system32\compattelrunner.exe -maintenance
O22 - Task (Running): YCMServiceAgent - C:\Program Files (x86)\CyberLink\YouCam6\YouCamService6.exe
O23 - Service R2: Adobe Acrobat Update Service - (AdobeARMservice) - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service R2: GamesAppIntegrationService - C:\Program Files (x86)\WildTangent Games\App\GamesAppIntegrationService.exe
O23 - Service R2: HP Support Solutions Framework Service - (HPSupportSolutionsFrameworkService) - c:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\HPSupportSolutionsFrameworkService.exe
O23 - Service S3: GamesAppService - C:\Program Files (x86)\WildTangent Games\App\GamesAppService.exe
Now click on fix checked.
After the reboot post a new hijack this log and let me know how things are running now.
[/ul]
Hijack This Fix.
