Sound cutting out on Toshiba Laptop
  • Juan
    • Apr 2017
    • 31
    Hello,
    I have a Toshiba Qosmio x500 04n laptop. Here are the specifications:
    Toshiba – Payday Deals
    So the problem with sound cutting out completely only occurs when I try to use my “Behringer Guitar/USB Interface” with a DAW program I installed called “Pro Tools First”. What happens is that I activate the interface to be able to record my guitar in the ‘Setup’ drop-down menu, and then there’s no sound from the program, or my computer in general. When I close Pro Tools, I can listen to music, or anything that involves sound.
    I checked in the Device Manager for any new drivers for my sound card and everything is updated, at least according to Windows. I’ve contacted Avid, who manufacture this audio recording software and I’ve had no response.
    I found this link and tried all the solutions provided with no success.
    Things To Check If There Is No Sound In Pro Tools | Pro Tools - The leading website for Pro Tools users
    If I forgot to mention anything, or screenshots are required, or if I’m posting in the wrong forum let me know!
    Thanks!
  • jmarket
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hi Juan and welcome to PCHF
    Flush DNS
    Report IE Proxy Settings
    Reset IE Proxy Settings
    Report FF Proxy Settings
    Reset FF Proxy Settings
    List content of Hosts
    List IP Configuration
    List Winsock Entries
    List Installed Programs
    List Devices (Only Problems)
    Please post the log in your next reply
    • Juan
      • Apr 2017
      • 31
      Here you go. Thanks for replying by the way.
      Ran by Juancho (administrator) on 30-04-2017 at 17:51:24
      Running from “C:\Users\Juancho\Desktop”
      Microsoft Windows 7 Home Premium Service Pack 1 (X64)
      Model: Qosmio X500 Manufacturer: TOSHIBA
      Boot Mode: Normal
      Windows IP Configuration
      Proxy is not enabled.
      No Proxy Server is set.
      “Reset IE Proxy Settings”: IE Proxy Settings were reset.
      “Reset FF Proxy Settings”: Firefox Proxy settings were reset.
      Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC = Wireless Network Connection (Connected)
      Atheros AR8131 PCI-E Gigabit Ethernet Controller = Local Area Connection (Media disconnected)
      [HEADING=1]----------------------------------[/HEADING]
      [HEADING=1]IPv4 Configuration[/HEADING]
      pushd interface ipv4
      reset
      set global icmpredirects=enabled taskoffload=disabled
      add route prefix=169.254.0.0/16 interface=“iftype0_0” nexthop=192.168.0.106 metric=1 publish=Yes
      popd
      [HEADING=1]End of IPv4 configuration[/HEADING]
      Host Name . . . . . . . . . . . . : Juancho-PC
      DNS Suffix Search List. . . . . . : Home
      Wireless LAN adapter Wireless Network Connection:
      Connection-specific DNS Suffix . : Home
      Description . . . . . . . . . . . : Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC
      Physical Address. . . . . . . . . : 1C-65-9D-0D-57-11
      Link-local IPv6 Address . . . . . : fe80::bd61:982f:f949:df36%11(Preferred)
      IPv4 Address. . . . . . . . . . . : 192.168.1.105(Preferred)
      Lease Obtained. . . . . . . . . . : Sunday, 30 April 2017 2:51:09 PM
      Lease Expires . . . . . . . . . . : Monday, 1 May 2017 5:25:33 PM
      DHCPv6 IAID . . . . . . . . . . . : 320628125
      DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-37-88-E5-60-EB-69-05-72-AD
      Connection-specific DNS Suffix . : home
      Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Controller
      Physical Address. . . . . . . . . : 60-EB-69-05-72-AD
      DNS request timed out.
      timeout was 2 seconds.
      Server: UnKnown
      Address: 192.168.1.1
      Addresses: 2404:6800:4006:806::200e
      172.217.25.46
      Pinging google.com [172.217.25.46] with 32 bytes of data:
      Reply from 172.217.25.46: bytes=32 time=47ms TTL=50
      Reply from 172.217.25.46: bytes=32 time=201ms TTL=50
      Ping statistics for 172.217.25.46:
      Minimum = 47ms, Maximum = 201ms, Average = 124ms
      Server: TP-LINK.Home
      Addresses: 2001:4998:44:204::a7
      2001:4998:c:a06::2:4008
      2001:4998:58:c02::a9
      98.138.253.109
      98.139.183.24
      206.190.36.45
      Pinging yahoo.com [98.138.253.109] with 32 bytes of data:
      Reply from 98.138.253.109: bytes=32 time=263ms TTL=47
      Reply from 98.138.253.109: bytes=32 time=310ms TTL=47
      Ping statistics for 98.138.253.109:
      Minimum = 263ms, Maximum = 310ms, Average = 286ms
      [HEADING=1]Ping statistics for 127.0.0.1:
      Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
      [HEADING=1]Interface List
      11…1c 65 9d 0d 57 11 …Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC
      10…60 eb 69 05 72 ad …Atheros AR8131 PCI-E Gigabit Ethernet Controller
      1…Software Loopback Interface 1[/HEADING]
      [HEADING=1]IPv4 Route Table[/HEADING]
      [HEADING=1]Active Routes:
      0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.105 25
      169.254.0.0 255.255.0.0 On-link 192.168.1.105 301
      169.254.255.255 255.255.255.255 On-link 192.168.1.105 281
      192.168.1.0 255.255.255.0 On-link 192.168.1.105 281
      192.168.1.105 255.255.255.255 On-link 192.168.1.105 281
      192.168.1.255 255.255.255.255 On-link 192.168.1.105 281
      224.0.0.0 240.0.0.0 On-link 192.168.1.105 281
      255.255.255.255 255.255.255.255 On-link 192.168.1.105 281[/HEADING]
      [HEADING=1]Persistent Routes:
      Network Address Netmask Gateway Address Metric
      169.254.0.0 255.255.0.0 192.168.0.106 1[/HEADING]
      [HEADING=1]IPv6 Route Table[/HEADING]
      1 306 ::1/128 On-link
      11 281 fe80::/64 On-link
      11 281 fe80::bd61:982f:f949:df36/128
      On-link
      1 306 ff00::/8 On-link
      11 281 ff00::/8 On-link[/HEADING]
      Persistent Routes:
      None
      Catalog5 01 C:\windows\SysWOW64\NLAapi.dll [52224] (Microsoft Corporation)
      Catalog5 02 C:\windows\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
      Catalog5 03 C:\windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
      Catalog5 04 C:\windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
      Catalog5 05 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog5 06 C:\windows\SysWOW64\winrnr.dll [20992] (Microsoft Corporation)
      Catalog5 07 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [145280] (Microsoft Corp.)
      Catalog5 08 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [145280] (Microsoft Corp.)
      Catalog5 09 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [121704] (Apple Inc.)
      Catalog9 01 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 02 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 03 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 04 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 05 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 06 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 07 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 08 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 09 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      Catalog9 10 C:\windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
      x64-Catalog5 01 C:\Windows\System32\NLAapi.dll [70656] (Microsoft Corporation)
      x64-Catalog5 02 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
      x64-Catalog5 04 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
      x64-Catalog5 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog5 06 C:\Windows\System32\winrnr.dll [28672] (Microsoft Corporation)
      x64-Catalog5 07 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [171392] (Microsoft Corp.)
      x64-Catalog5 08 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [171392] (Microsoft Corp.)
      x64-Catalog5 09 C:\Program Files\Bonjour\mdnsNSP.dll [132968] (Apple Inc.)
      x64-Catalog9 01 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 02 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 03 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 04 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 06 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 07 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 08 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 09 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      x64-Catalog9 10 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
      Error: (04/30/2017 04:51:45 PM) (Source: Bonjour Service) (User: )
      Description: Task Scheduling Error: m->NextScheduledSPRetry 9391
      Description: Task Scheduling Error: m->NextScheduledEvent 9391
      Description: Task Scheduling Error: Continuously busy for more than a second
      Error: (04/30/2017 04:51:44 PM) (Source: Bonjour Service) (User: )
      Description: Task Scheduling Error: m->NextScheduledSPRetry 8393
      Description: Task Scheduling Error: m->NextScheduledEvent 8393
      Error: (04/30/2017 04:51:43 PM) (Source: Bonjour Service) (User: )
      Description: Task Scheduling Error: m->NextScheduledSPRetry 7395
      Description: Task Scheduling Error: m->NextScheduledEvent 7395
      Error: (04/30/2017 04:51:42 PM) (Source: Bonjour Service) (User: )
      Description: Task Scheduling Error: m->NextScheduledSPRetry 6396
      Error: (04/30/2017 04:51:46 PM) (Source: Microsoft-Windows-HAL) (User: )
      Description: The platform firmware has corrupted memory across the previous system power transition. Please check for updated firmware for your system.
      Error: (04/30/2017 02:50:58 PM) (Source: EventLog) (User: )
      Description: The previous system shutdown at 2:49:14 PM on ‎30/‎04/‎2017 was unexpected.
      Error: (04/29/2017 04:34:31 PM) (Source: cdrom) (User: )
      Description: The driver detected a controller error on \Device\CdRom0.
      [HEADING=1]Microsoft Office Sessions:[/HEADING]
      Error: (04/30/2017 04:51:45 PM) (Source: Bonjour Service)(User: )
      Error: (04/30/2017 04:51:44 PM) (Source: Bonjour Service)(User: )
      Error: (04/30/2017 04:51:43 PM) (Source: Bonjour Service)(User: )
      Error: (04/30/2017 04:51:42 PM) (Source: Bonjour Service)(User: )
      [HEADING=1]CodeIntegrity Errors:[/HEADING]
      Date: 2015-09-13 21:19:10.993
      Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume2\Program Files\SpaceSoundPro\SpaceSoundPro.dll because the set of per-page image hashes could not be found on the system.
      Date: 2015-09-13 21:18:58.113
      Acrobat.com (HKLM-x32...{287ECFA4-719A-2143-A09B-D6A12DE54E40}) (Version: 1.6.65 - Adobe Systems Incorporated)
      Adobe AIR (HKLM-x32...\Adobe AIR) (Version: 1.5.0.7220 - Adobe Systems Inc.)
      Adobe Flash Player 20 ActiveX (HKLM-x32...\Adobe Flash Player ActiveX) (Version: 20.0.0.270 - Adobe Systems Incorporated)
      Adobe Flash Player 20 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 20.0.0.267 - Adobe Systems Incorporated)
      Adobe Reader 9.5.0 (HKLM-x32...{AC76BA86-7AD7-1033-7B44-A95000000001}) (Version: 9.5.0 - Adobe Systems Incorporated)
      Adobe Shockwave Player 12.2 (HKLM-x32...\Adobe Shockwave Player) (Version: 12.2.4.194 - Adobe Systems, Inc.)
      AIR Xpand!2 (HKLM...{69A89482-FEC4-4E34-97F9-46BB287D0953}) (Version: 12.0.0.615 - AIR Music Technology)
      Apple Application Support (HKLM-x32...{F5266D28-E0B2-4130-BFC5-EE155AD514DC}) (Version: 2.3 - Apple Inc.)
      Apple Mobile Device Support (HKLM...{E5C95CA5-4565-4B9D-97ED-05088D775614}) (Version: 3.3.1.3 - Apple Inc.)
      Apple Software Update (HKLM-x32...{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}) (Version: 2.1.3.127 - Apple Inc.)
      Atheros Communications Inc.(R) AR81Family Gigabit/Fast Ethernet Driver (HKLM-x32...{3108C217-BE83-42E4-AE9E-A56A2A92E549}) (Version: 1.0.0.17 - Atheros Communications Inc.)
      Audacity 1.2.6 (HKLM-x32...\Audacity_is1) (Version: - )
      Audacity 1.3.13 (Unicode) (HKLM-x32...\Audacity 1.3 Beta (Unicode)is1) (Version: - Audacity Team)
      Avid Application Manager (HKLM-x32...{A59C0B17-6673-46E6-9E00-BB25E755A299}) (Version: 2.4.4.6575 - Avid Technology, Inc.)
      Avid Cloud Client Services (HKLM...{F9A1CAF7-904F-4542-AD7A-9D2D2E3AA80F}) (Version: 2.1.1.11080 - Avid Technology, Inc.)
      Avid Effects (HKLM...{C7DB24AC-3016-45A3-AE71-790F09BFBFC3}) (Version: 12.3.1.705 - Avid Technology, Inc.)
      Avid Pro Tools First (HKLM...{E085DE97-171E-42B0-8BB7-B086A7E35CEB}) (Version: 12.3.1.705 - Avid Technology, Inc.)
      Battlelog Web Plugins (HKLM-x32...\Battlelog Web Plugins) (Version: 2.6.2 - EA Digital Illusions CE AB)
      BattlEye for OA Uninstall (HKLM-x32...\BattlEye for OA) (Version: - )
      BattlEye Uninstall (HKLM-x32...\BattlEye for A2) (Version: - )
      BEHRINGER USB AUDIO DRIVER (HKLM...\USB_AUDIO_DEusb-audio.deBehringer2902) (Version: - )
      BEHRINGER USB AUDIO DRIVER (HKLM-x32...\USB_AUDIO_DEusb-audio.deBehringer2902) (Version: - )
      Bejeweled 2 Deluxe (HKLM-x32...\WT078308) (Version: 2.2.0.82 - WildTangent) Hidden
      BioShock 2 (HKLM-x32...{5454085C-129F-416C-9C0B-8B1000058301}) (Version: 1.0.0005.131 - Take-Two Interactive Software) Hidden
      BioShock 2 (HKLM-x32...{5454085C-840F-4070-8FAA-441000038301}) (Version: 1.0.0003.131 - Take-Two Interactive Software) Hidden
      BitRaider Streaming Client (HKLM-x32...\BitRaider Streaming Client) (Version: 1.3.3.4098 - BitRaider, LLC)
      Bluetooth Stack for Windows by Toshiba (HKLM...{CEBB6BFB-D708-4F99-A633-BC2600E01EF6}) (Version: v7.10.01(T) - TOSHIBA CORPORATION)
      Bonjour (HKLM...{6E3610B2-430D-4EB0-81E3-2B57E8B9DE8D}) (Version: 3.0.0.10 - Apple Inc.)
      BOSS (HKLM-x32...\BOSS) (Version: 2.1.1 - BOSS Development Team)
      Business Contact Manager for Outlook 2007 SP2 (HKLM-x32...{B32C4059-6E7A-41EF-AD20-56DF1872B923}) (Version: 3.0.8619.1 - Microsoft Corporation) Hidden
      Business Contact Manager for Outlook 2007 SP2 (HKLM-x32...\Business Contact Manager) (Version: 3.0.8619.1 - Microsoft Corporation)
      Canon Easy-PhotoPrint EX (HKLM-x32...\Easy-PhotoPrint EX) (Version: - )
      Canon Easy-WebPrint EX (HKLM-x32...\Easy-WebPrint EX) (Version: - )
      Canon IJ Network Tool (HKLM-x32...\Canon_IJ_Network_UTILITY) (Version: - )
      Canon Inkjet Printer/Scanner/Fax Extended Survey Program (HKLM-x32...\CANONIJPLM100) (Version: - )
      Canon MP Navigator EX 4.0 (HKLM-x32...\MP Navigator EX 4.0) (Version: - )
      Canon MP495 series MP Drivers (HKLM...{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}Canon_MP495_series) (Version: - )
      Canon My Printer (HKLM-x32...\CanonMyPrinter) (Version: - )
      Canon Solution Menu EX (HKLM-x32...\CanonSolutionMenuEX) (Version: - )
      Cheat Engine 6.2 (HKLM-x32...\Cheat Engine 6.2_is1) (Version: - Dark Byte)
      Chuzzle Deluxe (HKLM-x32...\WT078316) (Version: 2.2.0.82 - WildTangent) Hidden
      Cities: Skylines (HKLM-x32...\Steam App 255710) (Version: - Colossal Order)
      Conexant HD Audio (HKLM...\CNXT_AUDIO) (Version: 4.126.0.62 - Conexant)
      D3DX10 (HKLM-x32...{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
      Dead Rising 2 (HKLM-x32...{4343080E-448E-4E2C-B27F-B91000028201}) (Version: 1.0.0002.130 - Capcom) Hidden
      Direct DiscRecorder (HKLM-x32...{F2004B8D-7791-4B35-A3FA-D8CA8BB4DD81}) (Version: 1.00.0000 - Corel Corporation) Hidden
      Direct DiscRecorder (HKLM-x32...\InstallShield
      Dolby Control Center (HKLM...{20387B45-18A4-4D48-ABD9-A23D2CBE42B3}) (Version: 2.2.1 - Dolby)
      Download Manager 2.3.10 (HKLM-x32...\Download Manager) (Version: 2.3.10 - IGN Entertainment, Inc.)
      DriverToolkit version 8.4.0.0 (HKLM-x32...{D66BF89F-B0A2-48F5-A2E4-242EB645AB76}is1) (Version: 8.4.0.0 - Megaify Software)
      Dual-Core Optimizer (HKLM-x32...{9FD6F1A8-5550-46AF-8509-271DF0E768B5}) (Version: 1.1.4.0169 - AMD)
      DVD MovieFactory for TOSHIBA (HKLM-x32...{50F68032-B5B7-4513-9116-C978DBD8F27A}) (Version: 7.0.0 - Corel Corporation) Hidden
      DVD MovieFactory for TOSHIBA (HKLM-x32...\InstallShield
      EAX4 Unified Redist (HKLM-x32...{89661B04-C646-4412-B6D3-5E19F02F1F37}) (Version: 4.001 - Creative Labs)
      FATE (HKLM-x32...\WT078108) (Version: 2.2.0.82 - WildTangent) Hidden
      GameSpy Comrade (HKLM-x32...{5F4C776F-8CBD-4C4F-892F-B568ABDD70C8}) (Version: 1.5.0.156 - GameSpy)
      Google Chrome (HKCU...\Google Chrome) (Version: 57.0.2987.133 - Google Inc.)
      Google Toolbar for Internet Explorer (HKLM-x32...{18455581-E099-4BA8-BC6B-F34B2F06600C}) (Version: 1.0.0 - Google Inc.) Hidden
      Google Toolbar for Internet Explorer (HKLM-x32...{2318C2B1-4965-11d4-9B18-009027A5CD4F}) (Version: 7.5.8231.2252 - Google Inc.)
      Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
      HDMI Control Manager (HKLM...{63DA1F6A-2E65-4367-99B9-9E39FADEC446}) (Version: 2.0 - TOSHIBA CORPORATION) Hidden
      HDMI Control Manager (HKLM-x32...{63DA1F6A-2E65-4367-99B9-9E39FADEC446}) (Version: 2.0 - TOSHIBA CORPORATION) Hidden
      HDMI Control Manager (HKLM-x32...\InstallShield
      Indiana Jones and the Fate of Atlantis (HKLM-x32...\Steam App 6010) (Version: - LucasArts)
      Intel(R) Control Center (HKLM-x32...{F8A9085D-4C7A-41a9-8A77-C8998A96C421}) (Version: 1.2.1.1007 - Intel Corporation)
      Intel(R) Rapid Storage Technology (HKLM-x32...{3E29EE6C-963A-4aae-86C1-DC237C4A49FC}) (Version: 9.5.6.1001 - Intel Corporation)
      InterVideo WinDVD BD for TOSHIBA (HKLM-x32...{20471B27-D702-4FE8-8DEC-0702CC8C0A85}) (Version: 8.0-B20.185 - InterVideo Inc.) Hidden
      InterVideo WinDVD BD for TOSHIBA (HKLM-x32...\InstallShield_{20471B27-D702-4FE8-8DEC-0702CC8C0A85}) (Version: 8.0-B20.185 - InterVideo Inc.)
      iTunes (HKLM...{77B8B4A5-EE79-4907-A318-2DA86325B8D7}) (Version: 10.1.2.17 - Apple Inc.)
      Java 8 Update 31 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F83218031F0}) (Version: 8.0.310 - Oracle Corporation)
      Junk Mail filter update (HKLM-x32...{1F6AB0E7-8CDD-4B93-8A23-AA9EB2FEFCE4}) (Version: 15.4.3502.0922 - Microsoft Corporation) Hidden
      Kane and Lynch: Dead Men (HKLM-x32...{A66C4716-7E10-4A53-8101-00C3C11D6A9C}) (Version: 1.00.0000 - Eidos)
      Kaspersky PURE 3.0 (HKLM-x32...{D0702EE9-9DE4-419A-9C6C-4730B1C985BA}) (Version: 13.0.2.558 - Kaspersky Lab) Hidden
      Kaspersky PURE 3.0 (HKLM-x32...\InstallWIX_{D0702EE9-9DE4-419A-9C6C-4730B1C985BA}) (Version: 13.0.2.558 - Kaspersky Lab)
      LAV Filters 0.62.0 (HKLM-x32...\lavfilters_is1) (Version: 0.62.0 - Hendrik Leppkes)
      Life Is Strange™ (HKLM-x32...\Steam App 319630) (Version: - DONTNOD Entertainment)
      Magic Match - The Genie’s Journey (HKLM-x32...\WT078338) (Version: 2.2.0.82 - WildTangent) Hidden
      Malwarebytes Anti-Malware version 2.1.8.1057 (HKLM-x32...\Malwarebytes Anti-Malware_is1) (Version: 2.1.8.1057 - Malwarebytes Corporation)
      Mass Effect 2 (HKLM-x32...{75D84EF7-0D8C-4e70-B3FA-7B42A5D4E0EB}) (Version: 1.00 - Electronic Arts, Inc.)
      Max Payne 3 (HKLM-x32...{1AA94747-3BF6-4237-9E1A-7B3067738FE1}) (Version: 1.0.0.0 - Rockstar Games)
      Microsoft .NET Framework 1.1 (HKLM-x32...{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}) (Version: 1.1.4322 - Microsoft)
      Microsoft .NET Framework 4.6.1 (HKLM...{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.6.01055 - Microsoft Corporation)
      Microsoft ASP.NET MVC 4 Runtime (HKLM-x32...{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
      Microsoft Games for Windows - LIVE Redistributable (HKLM-x32...{42AA4CA8-DCD8-4308-BCAB-0B6D75856A9D}) (Version: 3.5.95.0 - Microsoft Corporation)
      Microsoft Games for Windows Marketplace (HKLM-x32...{4CB0307C-565E-4441-86BE-0DF2E4FB828C}) (Version: 3.5.50.0 - Microsoft Corporation)
      Microsoft Office Home and Student 2010 (HKLM-x32...\Office14.SingleImage) (Version: 14.0.7015.1000 - Microsoft Corporation)
      Microsoft Office Outlook Connector (HKLM-x32...{95140000-0081-0409-0000-0000000FF1CE}) (Version: 14.0.6123.5001 - Microsoft Corporation)
      Microsoft Silverlight (HKLM...{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50906.0 - Microsoft Corporation)
      Microsoft SQL Server 2005 (HKLM-x32...\Microsoft SQL Server 2005) (Version: - Microsoft Corporation)
      Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32...{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
      Microsoft SQL Server Native Client (HKLM...{9ACF3FDB-C8E6-444C-8C64-13A221F7BFFD}) (Version: 9.00.5000.00 - Microsoft Corporation)
      Microsoft SQL Server Setup Support Files (English) (HKLM-x32...{53F5C3EE-05ED-4830-994B-50B2F0D50FCE}) (Version: 9.00.5000.00 - Microsoft Corporation)
      Microsoft SQL Server VSS Writer (HKLM...{B636C9B9-A3F2-4DCE-ADCC-72E095018385}) (Version: 9.00.5000.00 - Microsoft Corporation)
      Microsoft Visual C++ 2005 ATL Update kb973923 - x64 8.0.50727.4053 (HKLM...{B6E3757B-5E77-3915-866A-CCFC4B8D194C}) (Version: 8.0.50727.4053 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (HKLM-x32...{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (HKLM-x32...{A49F249F-0C91-497F-86DF-B2585E8E76B7}) (Version: 8.0.50727.42 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) - KB2467175 (HKLM...{aac9fcc4-dd9e-4add-901c-b5496a07ab2e}) (Version: 8.0.51011 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}) (Version: 8.0.61000 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - KB2467174 - x64 9.0.30729.5570 (HKLM...{8338783A-0968-3B85-AFC7-BAAE0A63DC50}) (Version: 9.0.30729.5570 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - KB2467174 - x86 9.0.30729.5570 (HKLM-x32...{86CE85E6-DBAC-3FFD-B977-E4B79F83C909}) (Version: 9.0.30729.5570 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.21022 (HKLM...{350AA351-21FA-3270-8B7A-835434E766AD}) (Version: 9.0.21022 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM...{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 (HKLM-x32...{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}) (Version: 9.0.21022 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24123 (HKLM-x32...{2cbcedbb-f38c-48a3-a3e1-6c6fd821a7f4}) (Version: 14.0.24123.0 - Microsoft Corporation)
      Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
      Microsoft WSE 3.0 Runtime (HKLM-x32...{E3E71D07-CD27-46CB-8448-16D4FB29AA13}) (Version: 3.0.5305.0 - Microsoft Corp.)
      Microsoft XNA Framework Redistributable 4.0 (HKLM-x32...{2BFC7AA0-544C-4E3A-8796-67F3BE655BE9}) (Version: 4.0.20823.0 - Microsoft Corporation)
      MixPad Multitrack Recording Software (HKLM-x32...\MixPad) (Version: 4.27 - NCH Software)
      Monopoly (HKLM-x32...\WT078123) (Version: 2.2.0.82 - WildTangent) Hidden
      Mozilla Firefox 43.0.1 (x86 en-GB) (HKLM-x32...\Mozilla Firefox 43.0.1 (x86 en-GB)) (Version: 43.0.1 - Mozilla)
      Mozilla Maintenance Service (HKLM-x32...\MozillaMaintenanceService) (Version: 43.0.1.5828 - Mozilla)
      MS Access 97 SP2 (HKLM-x32...\MS Access 97 SP2) (Version: - )
      MSXML 4.0 SP2 (KB954430) (HKLM-x32...{86493ADD-824D-4B8E-BD72-8C5DCDC52A71}) (Version: 4.20.9870.0 - Microsoft Corporation)
      MSXML 4.0 SP2 (KB973688) (HKLM-x32...{F662A8E6-F4DC-41A2-901E-8C11F044BDEC}) (Version: 4.20.9876.0 - Microsoft Corporation)
      My Game Long Name (HKLM...\UDK-1734a83b-3ca5-4f44-a23f-ab7b53e39c82) (Version: - Epic Games, Inc.)
      My Game Long Name (HKLM...\UDK-c02085fa-7eb8-44b6-a885-985b9cfb9c61) (Version: - Epic Games, Inc.)
      Native Instruments AC Box Combo (HKLM-x32...\Native Instruments AC Box Combo) (Version: - )
      Native Instruments Service Center (HKLM-x32...\Native Instruments Service Center) (Version: - )
      Nexus Mod Manager (HKLM...\6af12c54-643b-4752-87d0-8335503010de_is1) (Version: 0.41.0 - Black Tree Gaming)
      Nokia Connectivity Cable Driver (HKLM...{BC4AE628-81A4-4FC6-863A-7A9BA2E2531F}) (Version: 7.1.32.69 - )
      NVIDIA 3D Vision Controller Driver 340.50 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.NVIRUSB) (Version: 340.50 - NVIDIA Corporation)
      NVIDIA GeForce Experience 2.4.3.22 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.GFExperience) (Version: 2.4.3.22 - NVIDIA Corporation)
      NVIDIA Graphics Driver 341.44 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.Driver) (Version: 341.44 - NVIDIA Corporation)
      NVIDIA HD Audio Driver 1.3.30.1 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}HDAudio.Driver) (Version: 1.3.30.1 - NVIDIA Corporation)
      NVIDIA PhysX (HKLM-x32...{B455E95A-B804-439F-B533-336B1635AE97}) (Version: 9.14.0702 - NVIDIA Corporation)
      O2Micro Flash Memory Card Windows Driver (HKLM...{08D341E2-6FC3-4361-B18A-48E8AC004FEB}) (Version: 2.0.24.D - O2Micro International LTD.) Hidden
      O2Micro Flash Memory Card Windows Driver (HKLM-x32...\InstallShield
      OpenAL (HKLM-x32...\OpenAL) (Version: - )
      Origin (HKLM-x32...\Origin) (Version: 9.3.10.4710 - Electronic Arts, Inc.)
      PACE License Support Win64 (HKLM...{83E92696-D92D-4c7e-B094-0BE853B191FE}) (Version: 2.5.2.1034 - PACE Anti-Piracy, Inc.) Hidden
      PACE License Support Win64 (HKLM-x32...\InstallShield
      Paranormal (HKLM...\UDK-894f5f43-0329-4bcc-911c-cbd31c758333) (Version: - Epic Games, Inc.)
      Peggle (HKLM-x32...\WT078364) (Version: 2.2.0.82 - WildTangent) Hidden
      PlayReady PC Runtime amd64 (HKLM...{BCA9334F-B6C9-4F65-9A73-AC5A329A4D04}) (Version: 1.3.0 - Microsoft Corporation)
      Polar Bowler (HKLM-x32...\WT078129) (Version: 2.2.0.82 - WildTangent) Hidden
      Polar Golfer (HKLM-x32...\WT078492) (Version: 2.2.0.82 - WildTangent) Hidden
      Portal 2 (HKLM-x32...\Steam App 620) (Version: - Valve)
      PreSonus Studio One 3 x64 (HKLM...\PreSonus Studio One 3) (Version: 3.3.4.41933 - PreSonus Audio Electronics)
      PunkBuster Services (HKLM-x32...\PunkBusterSvc) (Version: 0.993 - Even Balance, Inc.)
      QuickTime (HKLM-x32...{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A}) (Version: 7.73.80.64 - Apple Inc.)
      Raptr (HKLM-x32...\Raptr) (Version: - )
      Rapture3D 2.5.1 Game (HKLM-x32...{D2FCA41E-AC01-4DCD-B3A7-DC9E32363065}}is1) (Version: - Blue Ripple Sound)
      Rayman Origins (HKLM-x32...\Uplay Install 80) (Version: - Ubisoft)
      Realtek WLAN Driver (HKLM-x32...{0FB630AB-7BD8-40AE-B223-60397D57C3C9}) (Version: 2.00.0006 - Realtek)
      Red Faction: Guerrilla (HKLM-x32...{54510837-BD04-4C32-9676-DB1000038201}) (Version: 1.0.0003.130 - THQ) Hidden
      Red Faction: Guerrilla (HKLM-x32...{54510837-BD04-4C32-9676-DB1000038202}) (Version: 1.0.0003.130 - THQ) Hidden
      redist (HKLM-x32...{153C7D89-9CF4-4719-A551-C5BF45236DB5}) (Version: 1.0.0.0 - redist)
      Regi (HKLM...{63B4D80D-7BAC-4D1D-B9B6-27FF54197982}) (Version: 1.00.0000 - InterVideo Inc.) Hidden
      Rockstar Games Social Club (HKLM-x32...\Rockstar Games Social Club) (Version: 1.1.9.5 - Rockstar Games)
      ScummVM 1.6.0 (HKLM-x32...\ScummVM_is1) (Version: - The ScummVM Team)
      Service Pack 2 for Microsoft Office 2010 (KB2687455) 32-Bit Edition (HKLM-x32...{90140000-003D-0000-0000-0000000FF1CE}Office14.SingleImage{DE28B448-32E8-4E8F-84F0-A52B21A49B5B}) (Version: - Microsoft)
      Setup (HKLM-x32...{7ADF667E-E14D-4D2C-827C-B0108F0D93BC}) (Version: - )
      SHIELD Streaming (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}GFExperience.NvStreamSrv) (Version: 4.1.1000 - NVIDIA Corporation) Hidden
      SHIELD Wireless Controller Driver (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}ShieldWirelessController) (Version: 2.4.3.22 - NVIDIA Corporation) Hidden
      Shockwave (HKLM-x32...\Shockwave) (Version: - )
      Skype Click to Call (HKLM-x32...{B6CF2967-C81E-40C0-9815-C05774FEF120}) (Version: 6.12.13601 - Skype Technologies S.A.)
      Skype™ 7.0 (HKLM-x32...{24991BA0-F0EE-44AD-9CC8-5EC50AECF6B7}) (Version: 7.0.102 - Skype Technologies S.A.)
      Spelling Dictionaries Support For Adobe Reader 9 (HKLM-x32...{AC76BA86-7AD7-5464-3428-900000000004}) (Version: 9.0.0 - Adobe Systems Incorporated)
      Stagelight (HKLM...\Stagelight) (Version: 3.0.6.6284 - Open Labs, LLC.)
      Star Wars The Old Republic (HKLM-x32...\swtor_swtor) (Version: 8.0.0.26 - Bioware/EA)
      Star Wars: The Old Republic (HKLM-x32...{3B11D799-48E0-48ED-BFD7-EA655676D8BB}) (Version: 1.00 - Electronic Arts, Inc.)
      Steam (HKLM-x32...{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
      swMSM (HKLM-x32...{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
      Synaptics Pointing Device Driver (HKLM...\SynTPDeinstKey) (Version: 13.2.7.3 - Synaptics Incorporated)
      System Requirements Lab (HKLM-x32...{0A3A9522-EFA2-4C56-9138-101692C2A130}) (Version: 4.4.26.0 - Husdawg, LLC)
      System Requirements Lab (HKLM-x32...\SystemRequirementsLab) (Version: - )
      System Requirements Lab CYRI (HKLM-x32...{1110A014-1471-4B66-BFDC-E8EED120CC59}) (Version: 6.0.20.0 - Husdawg, LLC)
      System Requirements Lab Detection (HKLM-x32...{9099668B-1005-43DD-92FA-D8341E1D7FE2}) (Version: 2.0.0.0 - Husdawg, LLC)
      Tales from the Borderlands (HKLM-x32...\Steam App 330830) (Version: - Telltale Games)
      TOSHIBA Assist (HKLM-x32...{1B87C40B-A60B-4EF3-9A68-706CF4B69978}) (Version: 3.00.10 - TOSHIBA)
      TOSHIBA Bulletin Board (HKLM-x32...\InstallShield
      {F64684A0-754B-4637-B7F9-6E8DAA8CD5CD}) (Version: 1.5.05.64 - TOSHIBA Corporation)
      TOSHIBA ConfigFree (HKLM-x32...{F3529665-D75E-4D6D-98F0-745C78C68E9B}) (Version: 8.0.25 - TOSHIBA Corporation)
      TOSHIBA Disc Creator (HKLM...{5DA0E02F-970B-424B-BF41-513A5018E4C0}) (Version: 2.1.0.2 for x64 - TOSHIBA Corporation)
      TOSHIBA DVD PLAYER (HKLM-x32...{6C5F3BDC-0A1B-4436-A696-5939629D5C31}) (Version: 3.01.1.07-A - TOSHIBA Corporation)
      TOSHIBA eco Utility (HKLM-x32...\InstallShield
      {B3FF1CD9-B2F0-4D71-BB55-5F580401C48E}) (Version: 1.1.12.64 - TOSHIBA Corporation)
      TOSHIBA Extended Tiles for Windows Mobility Center (HKLM-x32...\InstallShield
      {617C36FD-0CBE-4600-84B2-441CEB12FADF}) (Version: - )
      TOSHIBA Face Recognition (HKLM-x32...\InstallShield
      {F67FA545-D8E5-4209-86B1-AEE045D1003F}) (Version: 3.1.3.64 - TOSHIBA Corporation)
      TOSHIBA Hardware Setup (HKLM-x32...\InstallShield
      {C4FFA951-9678-4D51-84B4-AFD15D3C45AD}) (Version: 4.02.01.00 - )
      TOSHIBA HDD Protection (HKLM...{94A90C69-71C1-470A-88F5-AA47ECC96B40}) (Version: 2.2.0.3 - TOSHIBA Corporation)
      TOSHIBA HDD/SSD Alert (HKLM-x32...\InstallShield_{D4322448-B6AF-4316-B859-D8A0E84DCB38}) (Version: 3.1.64.4 - TOSHIBA Corporation)
      TOSHIBA PC Health Monitor (HKLM...{9DECD0F9-D3E8-48B0-A390-1CF09F54E3A4}) (Version: 1.5.1.64 - TOSHIBA Corporation)
      TOSHIBA Recovery Media Creator (HKLM...{B65BBB06-1F8E-48F5-8A54-B024A9E15FDF}) (Version: 2.1.0.4 for x64 - TOSHIBA Corporation)
      TOSHIBA ReelTime (HKLM-x32...\InstallShield_{5BCC94A1-DEF1-4AB4-8046-BC13048E929A}) (Version: 1.5.07.64 - TOSHIBA Corporation)
      TOSHIBA Service Station (HKLM-x32...{AC6569FA-6919-442A-8552-073BE69E247A}) (Version: 2.1.40 - TOSHIBA)
      TOSHIBA Speech System Applications (HKLM-x32...{EE033C1F-443E-41EC-A0E2-559B539A4E4D}) (Version: 1.00.2518 - )
      TOSHIBA Speech System SR Engine(U.S.) Version1.0 (HKLM-x32...{008D69EB-70FF-46AB-9C75-924620DF191A}) (Version: - )
      TOSHIBA Speech System TTS Engine(U.S.) Version1.0 (HKLM-x32...{3FBF6F99-8EC6-41B4-8527-0A32241B5496}) (Version: - )
      TOSHIBA Supervisor Password (HKLM-x32...\InstallShield_{CBD6B23D-41D5-4A46-8019-6208516C9712}) (Version: 4.02.01.00 - )
      TOSHIBA USB Sleep and Charge Utility (HKLM-x32...{E487EE7D-EAAA-4E2A-9116-E3B477D8A74F}) (Version: 1.3.2.0 - TOSHIBA Corporation)
      TOSHIBA Value Added Package (HKLM-x32...\InstallShield_{066CFFF8-12BF-4390-A673-75F95EFF188E}) (Version: 1.2.39.64 - TOSHIBA Corporation)
      TOSHIBA Web Camera Application (HKLM-x32...{5E6F6CF3-BACC-4144-868C-E14622C658F3}) (Version: 1.1.1.10 - TOSHIBA Corporation)
      Ubisoft Game Launcher (HKLM-x32...{888F1505-C2B3-4FDE-835D-36353EBD4754}) (Version: 1.0.0.0 - UBISOFT)
      Uplay (HKLM-x32...\Uplay) (Version: 4.3 - Ubisoft)
      VLC media player 2.0.4 (HKLM-x32...\VLC media player) (Version: 2.0.4 - VideoLAN)
      VRally Multiplayer Championship Edition (HKLM-x32...\VRally Multiplayer Championship Edition) (Version: - )
      WildTangent Games (HKLM-x32...\WildTangent toshiba Master Uninstall) (Version: 1.0.0.80 - WildTangent)
      WildTangent ORB Game Console (HKLM-x32...\TOSHIBA Game Console) (Version: - WildTangent) Hidden
      Windows Live Essentials (HKLM-x32...\WinLiveSuite) (Version: 15.4.3555.0308 - Microsoft Corporation)
      Windows Live Sync (HKLM-x32...{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}) (Version: 14.0.8089.726 - Microsoft Corporation)
      Windows Phone app for desktop (HKLM-x32...{5F71448B-88EB-4357-9A98-8658D4C49C48}) (Version: 1.1.2726.0 - Microsoft Corporation)
      WinRAR 4.10 beta 1 (32-bit) (HKLM-x32...\WinRAR archiver) (Version: 4.10.1 - win.rar GmbH)
      Zuma Deluxe (HKLM-x32...\WT078480) (Version: 2.2.0.82 - WildTangent) Hidden
      Zynewave Podium Free 3.2.1 (x64) (HKLM...{EFA46A5D-4ACD-4665-A074-1B7CF713A9BB}) (Version: 3.2.1 - Zynewave)
      Name: Teredo Tunneling Pseudo-Interface
      Description: Microsoft Teredo Tunneling Adapter
      Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
      Manufacturer: Microsoft
      Service: tunnel
      Device ID: ROOT*TEREDO\0000
      Problem: : This device cannot start. (Code10)
      Resolution: Device failed to start. Click “Update Driver” to update the drivers for this device.
      On the “General Properties” tab of the device, click “Troubleshoot” to start the troubleshooting wizard.
      Percentage of memory in use: 41%
      Total physical RAM: 8180.48 MB
      Available physical RAM: 4771.44 MB
      Total Virtual: 16359.14 MB
      Available Virtual: 12607.21 MB
      1 Drive c: (S3A8371D005) (Fixed) (Total:453.87 GB) (Free:190.73 GB) NTFS
      3 Drive e: (juan 2nd drive) (Fixed) (Total:465.76 GB) (Free:395.43 GB) NTFS
      User accounts for \JUANCHO-PC
      90C7FCC91F104BC89704 Administrator ASPNET
      Guest Juancho
      **** End of log ****
      • Malnutrition
        PCHF Moderator
        • 7041
        Still having issues?
        • Malnutrition
          PCHF Moderator
          • 7041
          Update your drivers…
          Snappy driver installer.
          • Juan
            • Apr 2017
            • 31
            Hi. Yeah I’m still having the issue I explained previously. I’ll update my drivers and let you know what happens.
            Thanks again.
            • Juan
              • Apr 2017
              • 31
              Hi again.
              So now after updating the drivers using the program you provided, there is sound on my computer when ProTools is open. However there is no sound in ProTools.
              I imagine this isn’t the right forum for ProTools configuration troubleshooting. I’ll have search online for music forums or something.
              Thanks for your help, and for recommending that driver updating software, that’s going to come in handy.
              • Malnutrition
                PCHF Moderator
                • 7041
                OK. I do notice a lot of outdated programs as well as some useless ones. If you want I can help you clean the machine up a bit…
                I start by updating your old programs with Patch My PC.
                I would personally uninstall all the items below with Geek Uninstaller.
                TOSHIBA eco Utility (HKLM-x32...\InstallShield_{B3FF1CD9-B2F0-4D71-BB55-5F580401C48E}) (Version: 1.1.12.64 - TOSHIBA Corporation)
                TOSHIBA Extended Tiles for Windows Mobility Center (HKLM-x32...\InstallShield_{617C36FD-0CBE-4600-84B2-441CEB12FADF}) (Version: - )
                TOSHIBA Face Recognition (HKLM-x32...\InstallShield_{F67FA545-D8E5-4209-86B1-AEE045D1003F}) (Version: 3.1.3.64 - TOSHIBA Corporation)
                TOSHIBA Hardware Setup (HKLM-x32...\InstallShield_{C4FFA951-9678-4D51-84B4-AFD15D3C45AD}) (Version: 4.02.01.00 - )
                Note: This tool will clean your browsing history as well.
                [li]Download CCleaner from here.[/li][li]After install Click Options.[/li][li]Go to monitoring.[/li][li]Uncheck All Monitoring items.[/li][li]Go to advanced – Click close program after cleaning.[/li][li]Go to settings – click run ccleaner when the computer starts.[/li][li]Now that you have ccleaner installed and set-up:[/li][li]Open the program.[/li][li]Go to Tools[/li][li]Go to Startup[/li][li]Now double click each item. To Disable.[/li][li]Leave only your antivirus enabled.[/li][li]Then disable All items in your scheduled task as well.[/li][li]Unless they are related to windows defender.Or your antivirus.[/li][li]Reboot the machine.[/li][/ul]
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  Might try uninstall Pro tools with Geek Uninstaller, then reboot and then enable the Admin account and install it after logging into the admin account and see if that solves the issue.
                  • Juan
                    • Apr 2017
                    • 31
                    #10
                    Thanks for the tips, I’m in the process of doing all that. My computer’s been crashing constantly, it’s getting picked up today to be cleaned. Last time it was cleaned it stopped crashing, we’ll see what happens.
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #11
                      Let me know what happens, I can help clean it up more if needed.
                      • Juan
                        • Apr 2017
                        • 31
                        #12
                        Thanks a bunch. He’s actually physically cleaning it, getting dust and all the crap out of it. I should have it back soon (On Monday when he took it, he said about 2 days), if it’s still crashing and showing all the problems I mentioned I’ll let you know. Either way I’ll post here and keep you informed as to not waste your time or have a thread on this site that isn’t being used. Before he took my laptop I did clean it up in terms of uninstalling those programs like you suggested. That driver and uninstalling software were really useful! Thanks for telling me about them!
                        • Malnutrition
                          PCHF Moderator
                          • 7041
                          #13
                          Ok, any update for us?
                          • Juan
                            • Apr 2017
                            • 31
                            #14
                            Hi, I just got my computer back yesterday. The guy says it isn’t crashing anymore, but to use it and let him know if it starts crashing again. I just tried to use ProTools and now it just doesn’t open. So I’m going to uninstall it now using the Geek Uninstaller program you provided and I’ll let you know how that goes as soon as I’m done. Sorry about the delay in posts and responding, I haven’t been at home that much.
                              #15
                              Thanks for the update.
