Slow Laptop after a day of running
  • herrick
    • Mar 2017
    • 55
    #46
    Emsisoft Emergency Kit - Version 2017.2
    Last update: 4/8/2017 6:19:20 AM
    User account: MAMBA\ASUS
    Computer name: MAMBA
    OS version: Windows 10x64
    Scan settings:
    Scan type: Malware Scan
    Objects: Rootkits, Memory, Traces, Files
    Detect PUPs: On
    Scan archives: Off
    ADS Scan: On
    File extension filter: Off
    Direct disk access: Off
    Scan start: 4/8/2017 6:20:14 AM
    Scanned 136507
    Found 0
    Scan end: 4/8/2017 6:25:59 AM
    Scan time: 0:05:45
    I will be busy for the next 2 days, have a flight and stuff. I will be back in 2 days and do the rest.
    Thank you for your time and the help <3
    • herrick
      • Mar 2017
      • 55
      #47
      ok im back, i will try to do the rest
      • herrick
        • Mar 2017
        • 55
        #48
        VirusTotal
        VirusTotal
        VirusTotal
        VirusTotal
        VirusTotal
        VirusTotal
        VirusTotal
        • Malnutrition
          PCHF Moderator
          • 7041
          #49
          Alright, I am short on time for the night, but a couple of those files need to go. I will prepare a fix to remove them tomorrow after I return from work… Can you in the meantime tell me what issues remain?
          • herrick
            • Mar 2017
            • 55
            #50
            sry late reply, for now the laptop looks fine except that when i tried to uninstall hotspot shield i get this error
            and i havnt run suprestric, 360 antivirus detected a trojan. is it safe to run it?
            • Malnutrition
              PCHF Moderator
              • 7041
              #51
              Yes, I would not post unsafe tools here.
              Use Geek Uninstaller with Force mode.
              Before I remove wxstart.exe from your machine, do you use it or have any idea what it is?
              • herrick
                • Mar 2017
                • 55
                #52
                oh wxstart.exe is a program for my game. like a bot for automatic playing. i hope its ok for me to keep it.
                and i will run the suprestic and geek uninstaller tonight. sorry couldnt reply and do thing as fast as i used to. busy in here. and thanks for your time
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  #53
                  Alright, we will leave it some apps are flagged as malware when they are not… I’d like to see the final logs then we will move from there.
                  • herrick
                    • Mar 2017
                    • 55
                    #54
                    suprestric gave me this log
                    Rapport de Contrôle restrictions Pierre13 (CTR version 2.5.0.0 ) du 13\04\2017 à 12:48:21
                    PC de ASUS
                    Microsoft Windows 10 Enterprise (64 bits) [10.0.14393]
                    Réparation erreur 2203 effectuée.
                    Contrôle présence restrictions
                    [BKDR_BLACKEN.A] clé PhishingFilter corrigée.
                    PC vacciné contre sponsor Java.
                    Service Pare feu Windows activé.
                    Paramètres Pare feu Windows rétablis par défaut et activés.
                    240 restrictions contrôlées.
                    2 restriction(s) réparée(s).
                    Re démarrer le PC pour prendre en compte la ou les réparations.
                    Le rapport est sur le bureau (C:\Users\ASUS\Desktop\CTR.txt)
                    its not suppose to be in english?
                    • herrick
                      • Mar 2017
                      • 55
                      #55
                      and i think thats all that i needed to run right?
                      Hotspot shield succesfully uninstalled with geekuninstaller too
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #56
                        Correct, and now that you have Voodoo Shield installed, you should remain malware free so long as you head the warnings of the tool…
