FRST Fix.
Click Here To Download Fixlist.
Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
Zemana Deep Scan
[li]
Zemana Deep Scan
[li]
- [/li][li]Right click on Zemana and run as admin.[/li][/ul]
[li]Click the Cog/Sproket Wheel, at the top right of Zemana[/li][/ul]
[li]Select Advanced - I have read the warning and wish to proceed.[/li][/ul]
[li]Place a tick next to Detect Suspicious (Root CA) Certificates.[/li][/ul]
[li]Then click the house icon in Zemana.[/li][/ul]
[li]Then hit your start button at the lower left hand corner of your desktop.[/li][/ul]
[li]Then left click on Computer.[/li][/ul]
[li]Drag Local Disk C: or whichever drive you decide to check first.[/li]
[li]Into the area of Zemana that reads Drag and drop files here to scan them.[/li][/ul]
[li]http://i.imgur.com/bOVO6lY.png[/li][/ul]
[li]Once the scan has completed click graph icon on the top right of the programs User interface.[/li][/ul]
[li]Double click to open the latest log-file.[/li][/ul]
[li]Copy it to your clipboard.[/li][/ul]
[li]Post the log here in your next reply.[/li][/ul]
{F29F85E0-4FF9-1068-AB91-08002B27B3D9},6*{B725F130-47EF-101A-A5F1-02608C9EEBAC},101SPS_ǵZeMJuEg$<ISettingsPageRestor eRestoreC1SPSU(Ly9K-1SPStk\;Co,oud1AAA_SettingsPageRestoreRestore.sett ingcontent-msU1SPS<I]@;l9d.settingcontent-ms-1SPSoOM'rT<1SPSjc(=O]C:\Users\HP-PC\AppData\Local\Packages\windows.immersivecontrol panel_cw5n1h2txyewy\LocalState\Indexed\Settings\en-US\AAA_SettingsPageRestoreRestore.settingcontent-ms9.settingcontent-msy f^aMh 2PJ 0UCEJQ1SPSOh+'5Recovery optionsy1SPSLX㈷ZJ ZDɬ]C:\Users\HP-PC\AppData\Local\Packages\windows.immersivecontrol panel_cw5n1h2txyewy\LocalState\Indexed\Settings\en-US\AAA_SettingsPageRestoreRestore.settingcontent-ms1SPSjc(=O9.settingcontent-ms]C:\Users\HP-PC\AppData\Local\Packages\windows.immersivecontrol panel_cw5n1h2txyewy\LocalState\Indexed\Settings\en-US\AAA_SettingsPageRestoreRestore.settingcontent-msw1SPS0%G[/ICODE] 5Recovery options@X1SPStk;Co,oud1AAA_SettingsPageRestoreRest ore.settingcontent-ms1SPSiI~+.
