Once you have completed the above, then right click FRST run as admin.
Type Panda into the search field.
Then Click on Search Registry.
[ATTACH]1809[/ATTACH]
An output file will appear on your desktop.
Copy and paste that into your next reply.
File Search With Everything Search Engine.
Download and install the Everything Search Engine
Right Click Run As Admin. Type or Copy Paste Panda into search window.
Then Click Edit. >>>Select all.
Right Click highlighted items>>>>>>>> Copy full name to clipboard.
Paste content of clipboard, here in your next reply.
Below are the FRST & Everything Search logs …
FRST - Search Panda result
Farbar Recovery Scan Tool (x86) Version: 08-03-2017
Ran by psimoes (09-03-2017 23:43:05)
Running from C:\Users\psimoes\Desktop
Boot Mode: Normal
Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
Go ahead and run the last FRST fix then the repair. This log takes Days to go over… I will look at it a while tonight then a while tomorrow. Too much information to go over in one sitting…
Apps definitely open much quicker. Panda AV is finally gone.
FRST Fix log ..
Fix result of Farbar Recovery Scan Tool (x86) Version: 08-03-2017
Ran by psimoes (10-03-2017 00:27:43) Run:3
Loaded Profiles: psimoes (Available Profiles: psimoes & Guest)
Boot Mode: Normal
BITS transfer queue => 12582912 B
DOMStoree, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 7290831 B
Java, Flash, Steam htmlcache => 0 B
Windows/system/drivers => 1855199 B
Edge => 0 B
Chrome => 0 B
Firefox => 0 B
Opera => 11132716 B
Users => 0 B
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 66228 B
LocalService => 0 B
NetworkService => 0 B
psimoes => 3279414 B
Guest => 0 B
RecycleBin => 4475973 B
EmptyTemp: => 38.8 MB temporary data Removed.
HD icon still flickers constantly and cannot install some applications due to "Variable must be of type “Object” or “Variable used without being declared” error
Open Elevated Command Prompt.
Copy and paste reg query “HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment” /s > “%userprofile%\Desktop\Export.txt”
Hit enter.
A notepad named export.txt will appear, copy and paste that in your next reply.
Hit enter.
Hi M, I appreciate your continued help on this.
I’m going to review my first thread back in Nov 2016 which reported similar issues with executables not working and find out what the fix was.
As mentioned, PC applications & boot times are much quicker.
The remaining issues are constant HD activity, System Restore & some .exe files won’t run.
[ATTACH]1835[/ATTACH]
