Malware help
  • slonslon7
    • Mar 2017
    • 14
    Malware help
    Hello.
    I’ve been having some malware issues. Have scanned with a host of AM and AV, removed some items but some issues persist:
    -Some kind of DNS hijacker (RogueKiller finds DHCPnameserver) but it keeps coming back. In chrome before visiting any site it says “waiting for ***.freddysrentals.xxx” before eventually taking me to the right site. Some older pages are now not loading at all.
    -Computer CPU was spiking at 100% even when idle. Nothing too out of the ordinary in the processes, but seems like scvhost.exe was taking up the most and was possible root kit. Might have removed this today with MBAR.
    Attaching a bunch of reports here. Really appreciate any assistance you can provide. Thanks so much!
    Master Boot Record:
    aswMBR version 1.0.1.2290 Copyright(c) 2014 AVAST Software
    Run date: 2017-03-01 17:45:04
    17:45:04.371 OS Version: Windows x64 6.2.9200
    17:45:04.372 Number of processors: 8 586 0x3A09
    17:45:04.387 ComputerName: JIRICOMPUTER UserName: SamSwanson
    17:45:05.575 Initialize success
    17:45:06.451 VM: initialized successfully
    17:45:06.453 VM: Intel CPU BiosDisabled
    17:45:38.078 Disk 0 \Device\Harddisk0\DR0 → \Device\0000003e
    17:45:38.081 Disk 0 Vendor: TOSHIBA_DT01ACA300 MX6OABB0 Size: 2861588MB BusType: 11
    17:45:38.098 Disk 1 (boot) \Device\Harddisk1\DR1 → \Device\0000003f
    17:45:38.099 Disk 1 Vendor: OCZ-AGILITY4 1.5.2 Size: 244198MB BusType: 11
    17:45:38.117 Disk 2 \Device\Harddisk2\DR2 → \Device\00000041
    17:45:38.119 Disk 2 Vendor: WDC_WD30EZRZ-00Z5HB0 80.00A80 Size: 2861588MB BusType: 11
    17:45:38.144 Disk 1 MBR read successfully
    17:45:38.147 Disk 1 MBR scan
    17:45:38.149 Disk 1 Windows 7 default MBR code
    17:45:38.151 Disk 1 Partition 1 80 (A) 07 HPFS/NTFS NTFS 350 MB offset 2048
    17:45:38.154 Disk 1 Partition 2 00 07 HPFS/NTFS NTFS 243846 MB offset 718848
    17:45:38.166 Disk 1 scanning C:\WINDOWS\system32\drivers
    17:45:40.101 Service scanning
    17:45:44.621 Service WRkrn C:\WINDOWS\System32\drivers\WRkrn.sys LOCKED 32
    17:45:45.350 Modules scanning
    17:45:45.356 Disk 1 trace - called modules:
    17:45:45.361 ntoskrnl.exe CLASSPNP.SYS disk.sys ACPI.sys storport.sys hal.dll iaStorA.sys
    17:45:45.366 1 nt!IofCallDriver → \Device\Harddisk1\DR1[0xffffb406311e7060]
    17:45:45.369 3 CLASSPNP.SYS[fffff803881a5efb] → nt!IofCallDriver → [0xffffb40630240e40]
    17:45:45.374 5 ACPI.sys[fffff80386d54571] → nt!IofCallDriver → \Device\0000003f[0xffffb406301fa060]
    17:45:45.377 Disk 1 statistics 159841/0/0 @ 65.09 MB/s
    17:45:45.385 Scan finished successfully
    17:46:35.298 Disk 1 MBR has been saved successfully to “C:\Users\SamSwanson\Desktop\Computer fix\MBR.dat”
    17:46:35.310 The log file has been saved successfully to “C:\Users\SamSwanson\Desktop\Computer fix\aswMBR.txt”
    Computer Specs:
    OS Version: Microsoft Windows 10 Pro, 64 bit
    Processor: Intel(R) Core™ i7-3770K CPU @ 3.50GHz, Intel64 Family 6 Model 58 Stepping 9
    Processor Count: 8
    RAM: 32716 Mb
    Graphics Card: NVIDIA GeForce GTX 660 Ti, -2048 Mb
    Hard Drives: C: 238 GB (113 GB Free); R: 2794 GB (1153 GB Free); S: 2794 GB (1561 GB Free);
    Motherboard: ASUSTeK COMPUTER INC., P8Z77-V LX
    Antivirus: Webroot SecureAnywhere, Enabled and Updated
    FRST
    Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 01-03-2017
    Ran by SamSwanson (administrator) on JIRICOMPUTER (01-03-2017 17:43:28)
    Running from C:\Users\SamSwanson\Desktop\Computer fix
    Loaded Profiles: SamSwanson (Available Profiles: SamSwanson)
    Platform: Windows 10 Pro Version 1607 (X64) Language: English (United States)
    Internet Explorer Version 11 (Default browser: Edge)
    Boot Mode: Normal
    Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic...ery-scan-tool/
    (Webroot) C:\Program Files\Webroot\WRSA.exe
    (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe
    (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe
    (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
    (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cavwp.exe
    (Creative Technology Ltd) C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe
    (Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
    (ArcSoft, Inc.) C:\Program Files (x86)\Common Files\ArcSoft\esinter\Bin\eservutil.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.13\AsSysCtrlServi ce.exe
    () C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe
    (Binary Fortress Software) C:\Program Files (x86)\DisplayFusion\DisplayFusionService.exe
    (Arainia Solutions) C:\Program Files (x86)\Gizmo\gservice.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AAHM\1.00.20\aaHMSvc.exe
    () C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe
    () C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AsusFanControlService\1.02.05\AsusFanCo ntrolService.exe
    (Intel(R) Corporation) C:\Program Files\Intel\iCLS Client\HeciServer.exe
    (Intel Corporation) C:\Windows\System32\IPROSetMonitor.exe
    (Intel(R) Corporation) C:\Program Files\Intel Corporation\Intel(R) Technology Access\LegacyCsLoaderService.exe
    (Carbonite, Inc. (www.carbonite.com)) C:\Program Files\Carbonite\Carbonite Backup\CarboniteService.exe
    (Intel(R) Corporation) C:\Program Files\Intel Corporation\Intel(R) Technology Access\IntelTechnologyAccessService.exe
    (Nalpeiron Ltd.) C:\Windows\SysWOW64\nlssrv32.exe
    (M-Audio) C:\Program Files (x86)\M-Audio\Oxygen\AudioDevMon.exe
    (PACE Anti-Piracy, Inc.) C:\Program Files (x86)\Common Files\PACE\Services\LicenseServices\LDSvc.exe
    (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
    (SoftEther VPN Project at University of Tsukuba, Japan.) C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe
    (Nitro PDF Software) C:\Program Files\Common Files\Nitro\Pro\8.0\NitroPDFDriverService8x64.exe
    (Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
    () C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe
    (Avid) C:\Program Files (x86)\Avid\Mbox\AudioDevMon.exe
    (Acronis) C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe
    (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
    (TeamViewer GmbH) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
    (Copyright 2017.) C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
    (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe
    (Bitsum LLC) C:\Program Files\Process Lasso\ProcessGovernor.exe
    (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cistray.exe
    () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzUpdt.exe
    (Microsoft Corporation) C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\RemindersServer.exe
    (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\USB 3.0 Boost\U3BoostSvr64.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\TurboV EVO\TurboVHelp.exe
    (Microsoft Corporation) C:\Windows\System32\SettingSyncHost.exe
    (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\EPU\EPUHelp.exe
    (Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
    (Microsoft Corporation) C:\Windows\System32\rundll32.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe
    (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cis.exe
    (Logitech Inc.) C:\Program Files\Logitech Gaming Software\LCore.exe
    (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\Sensor\AlertHelper\AlertHelper.exe
    (Logitech, Inc.) C:\Program Files\Logitech\SetPointP\SetPoint.exe
    (Logitech, Inc.) C:\Program Files\Common Files\logishrd\KHAL3\KHALMNPR.exe
    (Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
    (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\ShadowPlay\nvspcaps64.exe
    (Dashlane, Inc.) C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe
    () C:\Program Files (x86)\Ditto\Ditto.exe
    (Flux Software LLC) C:\Users\SamSwanson\AppData\Local\FluxSoftware\Flu x\flux.exe
    (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
    (Google Inc.) C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\GoogleCrashHandler.exe
    (Google Inc.) C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\GoogleCrashHandler64.exe
    (Node.js) C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
    () C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl anePlugin.exe
    (SoftEther VPN Project at University of Tsukuba, Japan.) C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe
    (Logitech Inc.) C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe
    () C:\Program Files (x86)\Logitech\LWS\Webcam Software\CameraHelperShell.exe
    (Acronis International GmbH) C:\Program Files (x86)\Common Files\Acronis\TibMounter\TibMounterMonitor.exe
    () C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
    () C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe
    (Avid) C:\Program Files (x86)\Avid\Mbox\DriverInterface.exe
    (Universal Audio, Inc.) C:\Program Files (x86)\Universal Audio\Powered Plugins\UATrayIcon.exe
    (Universal Audio, Inc.) C:\Program Files (x86)\Universal Audio\Powered Plugins\UADPerfMon.exe
    (Carbonite, Inc.) C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteUI.exe
    (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\Jhi_service.exe
    (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
    (Nero AG) C:\Program Files (x86)\Nero\Update\NASvc.exe
    () C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
    (Intel(R) Corporation) C:\Program Files (x86)\Intel\Extreme Tuning Utility\XtuService.exe
    (Google Inc.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe
    (Microsoft Corporation) C:\Windows\System32\prevhost.exe
    ==================== Registry (Whitelisted) ====================
    HKLM...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [8903176 2016-12-03] (Realtek Semiconductor)
    HKLM...\Run: [Logitech Download Assistant] => C:\Windows\system32\rundll32.exe C:\Windows\System32\LogiLDA.dll,LogiFetch
    HKLM...\Run: [THXCfg64] => C:\Windows\system32\RunDLL32.exe C:\Windows\system32\THXCfg64.dll,RunDLLEntry THXCfg64
    HKLM...\Run: [RunDLLEntry] => C:\Windows\system32\RunDLL32.exe C:\Windows\system32\AmbRunE.dll,RunDLLEntry
    HKLM...\Run: [Launch LCore] => C:\Program Files\Logitech Gaming Software\LCore.exe [7406392 2012-11-29] (Logitech Inc.)
    HKLM...\Run: [EvtMgr6] => C:\Program Files\Logitech\SetPointP\SetPoint.exe [3091224 2013-07-31] (Logitech, Inc.)
    HKLM...\Run: [ShadowPlay] => “C:\WINDOWS\system32\rundll32.exe” C:\WINDOWS\system32\nvspcap64.dll,ShadowPlayOnSyst emStart
    HKLM...\Run: [ZAM] => C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [14416624 2017-02-11] (Copyright 2017.)
    HKLM...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [176440 2017-02-11] (Apple Inc.)
    HKLM...\Run: [Malwarebytes TrayApp] => C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\mbamtray.exe [2780112 2017-02-11] (Malwarebytes)
    HKLM...\Run: [SoftEther VPN Client UI Helper] => C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe [5248456 2017-02-25] (SoftEther VPN Project at University of Tsukuba, Japan.)
    HKLM-x32...\Run: [UpdReg] => C:\Windows\UpdReg.EXE [90112 2000-05-11] (Creative Technology Ltd.)
    HKLM-x32...\Run: [QuickTime Task] => C:\Program Files (x86)\QuickTime\QTTask.exe [421888 2012-10-25] (Apple Inc.)
    HKLM-x32...\Run: [SwitchBoard] => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated)
    HKLM-x32...\Run: [LWS] => C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe [204136 2012-09-13] (Logitech Inc.)
    HKLM-x32...\Run: [SunJavaUpdateSched (1)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
    HKLM-x32...\Run: [SunJavaUpdateSched (2)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
    HKLM-x32...\Run: [SunJavaUpdateSched (3)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
    HKLM-x32...\Run: [DivXMediaServer] => C:\Program Files (x86)\DivX\DivX Media Server\DivXMediaServer.exe [448856 2014-12-28] (DivX, LLC)
    HKLM-x32...\Run: [DivXUpdate] => C:\Program Files (x86)\DivX\DivX Update\DivXUpdate.exe [1861968 2014-12-28] ()
    HKLM-x32...\Run: [CheckNDISPortf0ac3e] => C:\Program Files (x86)\Hostless Modem\Mobile Hotspot Admin\CheckNDISPort_df.exe [465664 2014-03-26] ()
    HKLM-x32...\Run: [CancelAutoPlay_df] => C:\Program Files (x86)\Hostless Modem\Mobile Hotspot Admin\CancelAutoPlay_df.exe [446720 2014-03-26] ()
    HKLM-x32...\Run: [AcronisTibMounterMonitor] => C:\Program Files (x86)\Common Files\Acronis\TibMounter\TibMounterMonitor.exe [421768 2016-06-29] (Acronis International GmbH)
    HKLM-x32...\Run: [TrueImageMonitor.exe] => C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe [7382232 2016-10-31] ()
    HKLM-x32...\Run: [WRSVC] => C:\Program Files\Webroot\WRSA.exe [992056 2017-01-18] (Webroot)
    HKLM-x32...\Run: [UATrayIcon] => C:\Program Files (x86)\Universal Audio\Powered Plugins\UATrayIcon.exe [3804160 2016-10-25] (Universal Audio, Inc.)
    HKLM-x32...\Run: [UAPerfMon] => C:\Program Files (x86)\Universal Audio\Powered Plugins\UADPerfMon.exe [5964288 2016-10-25] (Universal Audio, Inc.)
    HKLM-x32...\Run: [SunJavaUpdateSched] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
    HKLM-x32...\Run: [Carbonite Backup] => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteUI.exe [1265256 2017-01-25] (Carbonite, Inc.)
    HKLM...\Policies\Explorer: [NoViewOnDrive] 0
    HKLM...\Policies\Explorer: [DisableLocalMachineRun] 0
    HKLM...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
    HKLM...\Policies\Explorer: [DisableCurrentUserRun] 0
    HKLM...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
    HKLM...\Policies\Explorer: [NoViewContextMenu] 0
    HKLM...\Policies\Explorer: [NoShellSearchButton] 0
    HKLM...\Policies\Explorer: [NoFind] 0
    HKLM...\Policies\Explorer: [NoFile] 0
    HKLM...\Policies\Explorer: [HideClock] 0
    HKLM...\Policies\Explorer: [NoTrayContextMenu] 0
    HKLM...\Policies\Explorer: [NoTrayItemsDisplay] 0
    HKLM...\Policies\Explorer: [NoSetFolders] 0
    HKLM...\Policies\Explorer: [NoDevMgrUpdate] 0
    HKLM...\Policies\Explorer: [NoSetTaskbar] 0
    HKLM...\Policies\Explorer: [NoDeletePrinter] 0
    HKLM...\Policies\Explorer: [NoDFSTab] 0
    HKLM...\Policies\Explorer: [NoChangeStartMenu] 0
    HKLM...\Policies\Explorer: [NoLogoff] 0
    HKLM...\Policies\Explorer: [NoWindowsUpdate] 0
    HKLM...\Policies\Explorer: [NoEncryptOnMove] 0
    HKLM...\Policies\Explorer: [NoRunasInstallPrompt] 0
    HKLM...\Policies\Explorer: [NoResolveSearch] 0
    HKLM...\Policies\Explorer: [NoSaveSettings] 0
    HKLM...\Policies\Explorer: [NoHardwareTab] 0
    HKLM...\Policies\Explorer: [NoStartMenuSubFolders] 0
    HKU\S-1-5-19...\Policies\system: [DisableCMD] 0
    HKU\S-1-5-19...\Policies\system: [NoDispAppearancePage] 0
    HKU\S-1-5-19...\Policies\system: [NoDispBackgroundPage] 0
    HKU\S-1-5-19...\Policies\system: [NoDispSettingsPage] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoViewOnDrive] 0
    HKU\S-1-5-19...\Policies\Explorer: [DisableLocalMachineRun] 0
    HKU\S-1-5-19...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
    HKU\S-1-5-19...\Policies\Explorer: [DisableCurrentUserRun] 0
    HKU\S-1-5-19...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoViewContextMenu] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoShellSearchButton] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoFind] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoFile] 0
    HKU\S-1-5-19...\Policies\Explorer: [HideClock] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoTrayContextMenu] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoTrayItemsDisplay] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoSetFolders] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoDevMgrUpdate] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoSetTaskbar] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoDeletePrinter] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoDFSTab] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoChangeStartMenu] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoLogoff] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoWindowsUpdate] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoEncryptOnMove] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoRunasInstallPrompt] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoResolveSearch] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoSaveSettings] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoHardwareTab] 0
    HKU\S-1-5-19...\Policies\Explorer: [NoStartMenuSubFolders] 0
    HKU\S-1-5-20...\Policies\system: [DisableCMD] 0
    HKU\S-1-5-20...\Policies\system: [NoDispAppearancePage] 0
    HKU\S-1-5-20...\Policies\system: [NoDispBackgroundPage] 0
    HKU\S-1-5-20...\Policies\system: [NoDispSettingsPage] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoViewOnDrive] 0
    HKU\S-1-5-20...\Policies\Explorer: [DisableLocalMachineRun] 0
    HKU\S-1-5-20...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
    HKU\S-1-5-20...\Policies\Explorer: [DisableCurrentUserRun] 0
    HKU\S-1-5-20...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoViewContextMenu] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoShellSearchButton] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoFind] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoFile] 0
    HKU\S-1-5-20...\Policies\Explorer: [HideClock] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoTrayContextMenu] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoTrayItemsDisplay] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoSetFolders] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoDevMgrUpdate] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoSetTaskbar] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoDeletePrinter] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoDFSTab] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoChangeStartMenu] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoLogoff] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoWindowsUpdate] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoEncryptOnMove] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoRunasInstallPrompt] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoResolveSearch] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoSaveSettings] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoHardwareTab] 0
    HKU\S-1-5-20...\Policies\Explorer: [NoStartMenuSubFolders] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Dashlane] => C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe [486352 2017-02-22] (Dashlane, Inc.)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Ditto] => C:\Program Files (x86)\Ditto\Ditto.exe [1433200 2012-11-09] ()
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [F.lux] => C:\Users\SamSwanson\AppData\Local\FluxSoftware\Flu x\flux.exe [1016712 2013-10-16] (Flux Software LLC)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (1)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (2)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (3)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (4)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [DashlanePlugin] => C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl anePlugin.exe [544208 2017-02-20] ()
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Spotify Web Helper] => C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif yWebHelper.exe [1446000 2017-02-17] (Spotify Ltd)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Spotify] => C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe [7067760 2017-02-17] (Spotify Ltd)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update] => C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\GoogleUpdateCore.exe [601752 2016-12-17] (Google Inc.)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [DAEMON Tools Lite Automount] => C:\Program Files (x86)\DAEMON Tools Lite\DTAgent.exe [4468056 2016-08-15] (Disc Soft Ltd)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [GizmoDriveDelegate] => C:\Program Files (x86)\Gizmo\gizmo.exe [223640 2012-12-25] (Arainia Solutions)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [9363672 2017-02-20] (Piriform Ltd)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F 8703B] => C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe [1144152 2017-02-28] (Google Inc.)
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64] => C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q “C:\Users\SamSwanson\AppData\Local\Microsoft\OneDr ive\17.3.6381.0405\amd64”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64] => C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q “C:\Users\SamSwanson\AppData\Local\Microsoft\OneDr ive\17.3.6390.0509\amd64”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\system: [NoDispAppearancePage] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\system: [NoDispSettingsPage] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoCDBurning] 1
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoViewOnDrive] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [DisableLocalMachineRun] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [DisableCurrentUserRun] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoViewContextMenu] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoShellSearchButton] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoFind] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoFile] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [HideClock] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoTrayContextMenu] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoTrayItemsDisplay] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoSetFolders] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoDevMgrUpdate] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoSetTaskbar] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoDeletePrinter] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoDFSTab] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoChangeStartMenu] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoLogoff] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoWindowsUpdate] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoEncryptOnMove] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoRunasInstallPrompt] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoResolveSearch] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoSaveSettings] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoHardwareTab] 0
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Policies\Explorer: [NoStartMenuSubFolders] 0
    HKU\S-1-5-18...\Policies\system: [NoDispAppearancePage] 0
    HKU\S-1-5-18...\Policies\system: [NoDispSettingsPage] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoViewOnDrive] 0
    HKU\S-1-5-18...\Policies\Explorer: [DisableLocalMachineRun] 0
    HKU\S-1-5-18...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
    HKU\S-1-5-18...\Policies\Explorer: [DisableCurrentUserRun] 0
    HKU\S-1-5-18...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoViewContextMenu] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoShellSearchButton] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoFind] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoFile] 0
    HKU\S-1-5-18...\Policies\Explorer: [HideClock] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoTrayContextMenu] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoTrayItemsDisplay] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoSetFolders] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoDevMgrUpdate] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoSetTaskbar] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoDeletePrinter] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoDFSTab] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoChangeStartMenu] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoLogoff] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoWindowsUpdate] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoEncryptOnMove] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoRunasInstallPrompt] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoResolveSearch] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoSaveSettings] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoHardwareTab] 0
    HKU\S-1-5-18...\Policies\Explorer: [NoStartMenuSubFolders] 0
    ShellIconOverlayIdentifiers: [ Carbonite.Green] → {95A27763-F62A-4114-9072-E81D87DE3B68} => C:\Program Files\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
    ShellIconOverlayIdentifiers: [ Carbonite.Partial] → {E300CD91-100F-4E67-9AF3-1384A6124015} => C:\Program Files\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
    ShellIconOverlayIdentifiers: [ Carbonite.Yellow] → {5E529433-B50E-4bef-A63B-16A6B71B071A} => C:\Program Files\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
    ShellIconOverlayIdentifiers: [00avast] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
    ShellIconOverlayIdentifiers: [AcronisSyncError] → {934BC6C0-FEC2-4df5-A100-961DE2C8A0ED} => C:\Program Files (x86)\Acronis\TrueImageHome\tishell64.dll [2016-03-18] (Acronis)
    ShellIconOverlayIdentifiers: [AcronisSyncInProgress] → {00F848DC-B1D4-4892-9C25-CAADC86A215D} => C:\Program Files (x86)\Acronis\TrueImageHome\tishell64.dll [2016-03-18] (Acronis)
    ShellIconOverlayIdentifiers: [AcronisSyncOk] → {71573297-552E-46fc-BE3D-3DFAF88D47B7} => C:\Program Files (x86)\Acronis\TrueImageHome\tishell64.dll [2016-03-18] (Acronis)
    ShellIconOverlayIdentifiers: [MacDriveVolumeIcon] → {6B21AF46-EE37-40D0-A707-C06C17D06CE9} => C:\Program Files\Mediafour\MacDrive 9\MDVolumeIcons.dll [2012-05-21] (Mediafour Corporation)
    ShellIconOverlayIdentifiers: [MacDriveVolumeIconReadOnly] → {E9BC4DCA-0A4E-4C65-9D40-621C9D0CDC5F} => C:\Program Files\Mediafour\MacDrive 9\MDVolumeIcons.dll [2012-05-21] (Mediafour Corporation)
    ShellIconOverlayIdentifiers-x32: [ Carbonite.Green] → {95A27763-F62A-4114-9072-E81D87DE3B68} => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
    ShellIconOverlayIdentifiers-x32: [ Carbonite.Partial] → {E300CD91-100F-4E67-9AF3-1384A6124015} => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
    ShellIconOverlayIdentifiers-x32: [ Carbonite.Yellow] → {5E529433-B50E-4bef-A63B-16A6B71B071A} => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
    Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Snagit 11.lnk [2016-08-23]
    ShortcutTarget: Snagit 11.lnk → C:\Program Files (x86)\TechSmith\Snagit 11\Snagit32.exe (TechSmith Corporation)
    Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\SoftEther VPN Client Manager Startup.lnk [2017-02-25]
    ShortcutTarget: SoftEther VPN Client Manager Startup.lnk → C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe (SoftEther VPN Project at University of Tsukuba, Japan.)
    Startup: C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Startup\EffectRack.lnk [2016-08-11]
    ShortcutTarget: EffectRack.lnk → C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe ()
    Startup: C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Startup\SpeedFan.lnk [2016-08-16]
    ShortcutTarget: SpeedFan.lnk → C:\Program Files (x86)\SpeedFan\speedfan.exe ()
    BootExecute: autocheck autochk * sdnclean64.exePartizan
    GroupPolicy: Restriction <======= ATTENTION
    GroupPolicyScripts: Restriction <======= ATTENTION
    Tcpip\Parameters: [DhcpNameServer] 213.46.172.36 213.46.172.37
    Tcpip..\Interfaces{2173f261-2e23-4f0a-940a-2a88ca2b214b}: [NameServer] 74.82.42.42,192.168.0.1
    Tcpip..\Interfaces{2173f261-2e23-4f0a-940a-2a88ca2b214b}: [DhcpNameServer] 213.46.172.36 213.46.172.37
    Tcpip..\Interfaces{7faf953a-453a-4de6-a3bc-2ce40997f6cc}: [NameServer] 8.8.8.8,8.8.4.4
    Tcpip..\Interfaces{7faf953a-453a-4de6-a3bc-2ce40997f6cc}: [DhcpNameServer] 213.46.172.36 213.46.172.37
    Tcpip..\Interfaces{a56f0fe6-a65d-419a-9a9d-a9f8c86c22bd}: [DhcpNameServer] 192.168.0.1 192.168.0.1
    Tcpip..\Interfaces{c09f412c-6a39-48fa-9e06-9f815d6e9d25}: [NameServer] 8.8.8.8,8.8.4.4
    [HEADING=1]Internet Explorer:[/HEADING]
    HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
    HKU.DEFAULT\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
    HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
    HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
    HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=msnhome
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
    BHO: Skype for Business Browser Helper → {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} → C:\Program Files\Microsoft Office\Office15\OCHelper.dll [2016-05-27] (Microsoft Corporation)
    BHO: Java™ Plug-In SSV Helper → {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} → C:\Program Files\Java\jre1.8.0_121\bin\ssv.dll [2017-02-20] (Oracle Corporation)
    BHO: Webroot Filtering Extension → {C9C42510-9B41-42c1-9DCD-7282A2D07C61} → C:\Program Files\Common Files\Webroot\WebFiltering\wrflt.dll [2017-01-27] (Webroot)
    BHO: Microsoft SkyDrive Pro Browser Helper → {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} → C:\Program Files\Microsoft Office\Office15\GROOVEEX.DLL [2016-05-17] (Microsoft Corporation)
    BHO: Java™ Plug-In 2 SSV Helper → {DBC80044-A445-435b-BC74-9C25C1C588A9} → C:\Program Files\Java\jre1.8.0_121\bin\jp2ssv.dll [2017-02-20] (Oracle Corporation)
    BHO-x32: Skype for Business Browser Helper → {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} → C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll [2016-05-27] (Microsoft Corporation)
    BHO-x32: Webroot Filtering Extension → {C9C42510-9B41-42c1-9DCD-7282A2D07C61} → C:\Program Files (x86)\Common Files\Webroot\WebFiltering\wrflt.dll [2017-01-27] (Webroot)
    BHO-x32: Microsoft SkyDrive Pro Browser Helper → {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} → C:\Program Files (x86)\Microsoft Office\Office15\GROOVEEX.DLL [2016-05-17] (Microsoft Corporation)
    Handler: osf - {D924BDC6-C83A-4BD5-90D0-095128A113D1} - C:\Program Files\Microsoft Office\Office15\MSOSB.DLL [2016-05-17] (Microsoft Corporation)
    Handler-x32: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files (x86)\Common Files\Skype\Skype4COM.dll [2017-01-01] (Skype Technologies)
    [HEADING=1]FireFox:[/HEADING]
    FF DefaultProfile: scoho7@gmail.com
    FF ProfilePath: C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefo x\Profiles\lncyg2i6.default [2017-03-01]
    FF NewTab: Mozilla\Firefox\Profiles\lncyg2i6.default → about:newtab
    FF DefaultSearchUrl: Mozilla\Firefox\Profiles\lncyg2i6.default →
    FF SearchEngineOrder.1: Mozilla\Firefox\Profiles\lncyg2i6.default → Google
    FF Homepage: Mozilla\Firefox\Profiles\lncyg2i6.default → about:blank
    FF Keyword.URL: Mozilla\Firefox\Profiles\lncyg2i6.default →
    FF Extension: (Dashlane) - C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefo x\Profiles\lncyg2i6.default\Extensions\jetpack-extension@dashlane.com.xpi [2017-01-05]
    FF Extension: (Webroot Filtering Extension) - C:\ProgramData\WRData\PKG\FIREFOX\WebrootSecure_So cketServer [2017-01-27]
    FF SearchPlugin: C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefo x\Profiles\lncyg2i6.default\searchplugins\google-avast.xml [2015-01-06]
    FF HKLM...\Firefox\Extensions: [webrootsecure@webroot.com] - C:\ProgramData\WRData\PKG\FIREFOX\WebrootSecure_So cketServer
    FF HKLM-x32...\Firefox\Extensions: [ffpwdman@bitdefender.com] - C:\Program Files\Bitdefender\Bitdefender\Antispam32\ffpwdman => not found
    FF HKLM-x32...\Firefox\Extensions: [{F003DA68-8256-4b37-A6C4-350FA04494DF}] - C:\Program Files\Logitech\SetPointP\LogiSmoothFirefoxExt
    FF Extension: (Logitech SetPoint) - C:\Program Files\Logitech\SetPointP\LogiSmoothFirefoxExt [2014-01-06] [not signed]
    FF HKLM-x32...\Firefox\Extensions: [webrootsecure@webroot.com] - C:\ProgramData\WRData\PKG\FIREFOX\WebrootSecure_So cketServer
    FF SearchPlugin: C:\Program Files (x86)\mozilla firefox\searchplugins\answers.xml [2010-12-03]
    FF SearchPlugin: C:\Program Files (x86)\mozilla firefox\searchplugins\creativecommons.xml [2010-12-03]
    FF Plugin: @adobe.com/FlashPlayer → C:\WINDOWS\system32\Macromed\Flash\NPSWF64_24_0_0_ 221.dll [2017-02-16] ()
    FF Plugin: @divx.com/DivX VOD Helper,version=1.0.0 → C:\Program Files\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC.)
    FF Plugin: @java.com/DTPlugin,version=11.121.2 → C:\Program Files\Java\jre1.8.0_121\bin\dtplugin\npDeployJava1 .dll [2017-02-20] (Oracle Corporation)
    FF Plugin: @java.com/JavaPlugin,version=11.121.2 → C:\Program Files\Java\jre1.8.0_121\bin\plugin2\npjp2.dll [2017-02-20] (Oracle Corporation)
    FF Plugin: @microsoft.com/SharePoint,version=14.0 → C:\PROGRA~1\MICROS~2\Office15\NPSPWRAP.DLL [2014-01-23] (Microsoft Corporation)
    FF Plugin-x32: @adobe.com/FlashPlayer → C:\WINDOWS\SysWoW64\Macromed\Flash\NPSWF32_24_0_0_ 221.dll [2017-02-16] ()
    FF Plugin-x32: @adobe.com/ShockwavePlayer → C:\WINDOWS\SysWOW64\Adobe\Director\np32dsw.dll [2016-09-20] (Adobe Systems, Inc.)
    FF Plugin-x32: @divx.com/DivX VOD Helper,version=1.0.0 → C:\Program Files (x86)\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC.)
    FF Plugin-x32: @divx.com/DivX Web Player Plug-In,version=1.0.0 → C:\Program Files (x86)\DivX\DivX Web Player\npdivx32.dll [2014-11-21] (DivX, LLC)
    FF Plugin-x32: @ilok.com/iLokHelper,version=3.1.0.7 → C:\Program Files (x86)\PACE Anti-Piracy\iLok\NPPaceILok.dll [2012-11-17] ( PACE Anti-Piracy, Inc)
    FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.5 → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2000-01-01] (Intel Corporation)
    FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater → C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2000-01-01] (Intel Corporation)
    FF Plugin-x32: @microsoft.com/Lync,version=15.0 → C:\Program Files (x86)\Mozilla Firefox\plugins\npmeetingjoinpluginoc.dll [2015-11-18] (Microsoft Corporation)
    FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 → C:\PROGRA~2\MICROS~2\Office15\NPSPWRAP.DLL [2014-01-22] (Microsoft Corporation)
    FF Plugin-x32: @Nero.com/KM → C:\PROGRA~2\COMMON~1\Nero\BROWSE~1\NPBROW~1.DLL [2012-08-10] (Nero AG)
    FF Plugin-x32: @nitropdf.com/NitroPDF → C:\Program Files (x86)\Nitro\Pro 8\npnitromozilla.dll [2013-03-25] (Nitro PDF)
    FF Plugin-x32: @nvidia.com/3DVision → C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dv.dll [2017-02-10] (NVIDIA Corporation)
    FF Plugin-x32: @nvidia.com/3DVisionStreaming → C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dvstreaming.dll [2017-02-10] (NVIDIA Corporation)
    FF Plugin-x32: @tools.google.com/Google Update;version=3 → C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
    FF Plugin-x32: @tools.google.com/Google Update;version=9 → C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
    FF Plugin-x32: @videolan.org/vlc,version=2.1.3 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
    FF Plugin-x32: @videolan.org/vlc,version=2.1.5 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
    FF Plugin-x32: @videolan.org/vlc,version=2.2.1 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
    FF Plugin-x32: @videolan.org/vlc,version=2.2.4 → C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
    FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @citrixonline.com/appdetectorplugin → C:\Users\SamSwanson\AppData\Local\Citrix\Plugins\1 04\npappdetector.dll [2013-09-12] (Citrix Online)
    FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @talk.google.com/GoogleTalkPlugin → C:\Users\SamSwanson\AppData\Roaming\Mozilla\plugin s\npgoogletalk.dll [2014-05-15] (Google)
    FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @talk.google.com/O1DPlugin → C:\Users\SamSwanson\AppData\Roaming\Mozilla\plugin s\npo1d.dll [2014-05-15] (Google)
    FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @tools.google.com/Google Update;version=3 → C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
    FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @tools.google.com/Google Update;version=9 → C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
    FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: Ubisoft | Welcome to the official Ubisoft website → C:\Program Files (x86)\Ubisoft\Ubisoft Game Launcher\npuplaypc.dll [2013-06-20] ()
    FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\npMeetingJoinPluginOC.dll [2015-11-18] (Microsoft Corporation)
    FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\npnul32.dll [2010-12-03] (mozilla.org)
    FF Plugin ProgramFiles/Appdata: C:\Users\SamSwanson\AppData\Roaming\mozilla\plugin s\npgoogletalk.dll [2014-05-15] (Google)
    FF Plugin ProgramFiles/Appdata: C:\Users\SamSwanson\AppData\Roaming\mozilla\plugin s\npo1d.dll [2014-05-15] (Google)
    FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\firefox-branding.js [2010-12-03]
    FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\firefox-l10n.js [2010-12-03]
    FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\firefox.js [2010-12-03]
    FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\reporter.js [2010-12-03]
    [HEADING=1]Chrome:[/HEADING]
    CHR DefaultProfile: Default
    CHR HomePage: Default → hxxp://www.search.ask.com/?gct=hp
    CHR DefaultSearchURL: Default → hxxp://www.search.ask.com/web?q={searchTerms}
    CHR DefaultSearchKeyword: Default → search.ask.com
    CHR DefaultSuggestURL: Default → hxxp://ssmsp.ask.com/query?sstype=prefix&li=ff&q={searchTerms}
    CHR Profile: C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default [2017-02-21]
    CHR Extension: (mention) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\agdbnpodkgflemjpckmcdgabbm efpfnb [2014-06-12]
    CHR Extension: (Send using Gmail™ (no button)) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ahldefgplekckalfcolhhnljbb gaiboc [2014-06-12]
    CHR Extension: (Angry Birds) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\aknpkdffaafgjchaibgeefbgmg eghloj [2014-12-13]
    CHR Extension: (Google Docs) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\aohghmighlieiainnegkcijnfi lokake [2016-06-13]
    CHR Extension: (Sortd Smart Skin for Gmail) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\aohlfneeliakfcefeffppfplag bccbni [2016-05-07]
    CHR Extension: (Google Drive) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\apdfllckaahabafndbhieahigk jlhalf [2016-06-13]
    CHR Extension: (Audiense) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\bagknoiagpifjfbempgignagke jmkljm [2016-03-11]
    CHR Extension: (Session Manager) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\bbcnbpafconjjigibnhbfmmgdb bkcjfi [2014-04-11]
    CHR Extension: (Sexy Undo Close Tab) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\bcennaiejdjpomgmmohhpgnjlm pcjmbg [2016-08-06]
    CHR Extension: (Turn Off the Lights) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\bfbmjmiodbnnpllbbbfblcplfj jepjdn [2016-06-24]
    CHR Extension: (ColorZilla) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\bhlhnicpbhignbdhedgjhgdocn mhomnp [2016-04-01]
    CHR Extension: (My Shortcuts) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\bjcpobipejlbogodeiendpdgcd ambjgo [2013-06-05]
    CHR Extension: (YouTube) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldk acnbeo [2016-06-13]
    CHR Extension: (Minimalist for Everything) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\bmihblnpomgpjkfddepdpdafhh epdbek [2017-02-24]
    CHR Extension: (X-notifier (for Gmail™,Hotmail,Yahoo,AOL…)) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\cdfjbkbddpfnoplfhceolpopfo epleco [2016-07-26]
    CHR Extension: (Adblock Plus) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\cfhdojbkjhnklbpkdaibdccddi lifddb [2016-06-29]
    CHR Extension: (TaskMilk) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\chieodlkhimccchlojdmiondhi ggkhmf [2013-06-05]
    CHR Extension: (uBlock Origin) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\cjpalhdlnbpafiamejdnhcphjb keiagm [2016-08-07]
    CHR Extension: (FullContact for Gmail™) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\cnaibnehbbinoohhjafknihmlo pdhhip [2016-05-23]
    CHR Extension: (Speechify) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\dalapoeljdklkcfjkecafidnoj kfpohn [2013-06-05]
    CHR Extension: (MozBar) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\eakacpaijcpapndcfffdgphdic cmpknp [2016-08-10]
    CHR Extension: (NYTimes) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ecmphppfkcfflgglcokcbdkofp fegoel [2013-06-05]
    CHR Extension: (Session Buddy) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\edacconmaakjimmfgnblocblbc dcpbko [2016-04-27]
    CHR Extension: (Photo Zoom for Facebook) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\elioihkkcdgakfbahdoddophfn gopipi [2014-08-06]
    CHR Extension: (Silver Bird) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\encaiiljifbdbjlphpgpiimide gddhic [2017-02-24]
    CHR Extension: (Symtica) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\fafldeedegmfkdkolgpcopgfcd idgbjk [2013-06-05]
    CHR Extension: (After the Deadline) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\fcdjadjbdihbaodagojiomdljh jhjfho [2014-08-22]
    CHR Extension: (ZenMate VPN - Best Cyber Security & Unblock) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\fdcgdnkidjaadafnichfpabhfo mcebme [2016-07-29]
    CHR Extension: (Dashlane) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\fdjamakpfbbddfjaooikfcpapj ohcfmg [2016-08-11]
    CHR Extension: (Google Sheets) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\felcaaldnbdncclmgdcncolpeb giejap [2016-06-13]
    CHR Extension: (Stylish) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\fjnbnpbmkenffdnngjfgmeleoe gfcffe [2016-04-05]
    CHR Extension: (HTTPS Everywhere) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\gcbommkclmclpchllfjekcdonp mejbdp [2016-07-21]
    CHR Extension: (Cestujlevne.com notifikátor) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\genojieiefkacjcapigbigafhe bnmdfp [2016-05-27]
    CHR Extension: (Facebook™ Chat Privacy) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\gfpgaanechfneiboempkfjghni nbibjn [2016-07-19]
    CHR Extension: (Google Docs Offline) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdl olhkhi [2016-06-13]
    CHR Extension: (AdBlock) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\gighmmpiobklfepjocnamgkkbi glidom [2016-07-29]
    CHR Extension: (Pinterest Save Button) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\gpdjojdkbbmdfjfahjcgigfpmk opogic [2016-07-20]
    CHR Extension: (Reader Plus) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\hhcknjkmaaeinhdjgimjnophgp bdgfmg [2013-06-05]
    CHR Extension: (Rapportive) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\hihakjfhbmlmjdnnhegiciffjp lmdhin [2014-12-13]
    CHR Extension: (Select To Get Maps) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\hinehgnhgiohbfpbpgkjnelkcg dkcgha [2013-06-05]
    CHR Extension: (feedly) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\hipbfijinpcgfogaopmgehiega cbhmob [2014-08-31]
    CHR Extension: (Remember The Milk for Gmail) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\hphjpfmagbhbdfhdndglcccmhd jhjjce [2014-12-17]
    CHR Extension: (goo.gl URL Shortener) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\iblijlcdoidgdpfknkckljiocd bnlagk [2015-05-14]
    CHR Extension: (ModHeader) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\idgpnmonknjnojddfkpgkljpfn nfcklj [2016-05-23]
    CHR Extension: (Proxmate) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ifalmiidchkjjmkkbkoaibpmoe ichmki [2016-04-27]
    CHR Extension: (Social Fixer for Facebook) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ifmhoabcaeehkljcfclfiieohk ohdgbb [2014-12-13]
    CHR Extension: (Forecastfox) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ihffmkcfkejomlfnilnmkokcpg clhfeg [2013-06-05]
    CHR Extension: (Power Twitter for Google Chrome™) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\iieehhjfejnoljbnnhfnhibcjh mifffo [2013-06-05]
    CHR Extension: (Mail2Cloud for Chrome
    Revolutionizing Email) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ijhapcklhkanndjbdnhichfmol hiaekg [2016-05-23]
    CHR Extension: (Imagus) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\immpkjjlgappgfkkfieppnmlha kdmaab [2016-05-27]
    CHR Extension: (Spreed - speed read the web) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ipikiaejjblmdopojhpejjmbed hlibno [2016-03-27]
    CHR Extension: (IDM Integration Module) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jeaohhlajejodfjadcponpnjgk iikocn [2014-04-11]
    CHR Extension: (WhoWorks.At) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jeldhknnfopoiloahhpmbblbhe mankjj [2013-06-20]
    CHR Extension: (Disconnect) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jeoacafpbcihiomhlakheieifh pjdfeo [2016-01-22]
    CHR Extension: (Google +1 Button) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jgoepmocgafhnchmokaimcmloj pnlkhp [2014-04-11]
    CHR Extension: (Attachments.me) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jhphhbgmckofodhphhiflhkhib dilddi [2013-06-05]
    CHR Extension: (Image Search by Cooliris) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jllgofbnhaihnfbokejhcndhoo gagdmk [2013-06-05]
    CHR Extension: (Bananatag Email Tracking) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jpbnpbfpgjkblmejlgkfkekaja jhjcid [2016-01-06]
    CHR Extension: (Speed Dial 2) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\jpfpebmajhhopeonhlcgidhclc ccjcik [2016-05-30]
    CHR Extension: (Reddit Enhancement Suite) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\kbmfpngjjgdllneeigpgjifpgo cmfgmb [2016-03-17]
    CHR Extension: (StumbleUpon) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\kcahibnffhnnjcedflmchmoknd kjnhpg [2014-04-11]
    CHR Extension: (Google Voice (by Google)) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\kcnhkahnjcbndmmehfkdnkjoma anaooo [2014-04-11]
    CHR Extension: (Super Full Feeds for Google Reader™) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\khbjahpecnkenngkidhioicnfp akihgo [2013-06-05]
    CHR Extension: (Webroot Filtering Extension) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\kjeghcllfecehndceplomkocgf bklffd [2016-08-04]
    CHR Extension: (StayFocusd) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\laankejkbhbdhmipfmgcngdela hlfoji [2014-11-05]
    CHR Extension: (UglyEmail) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ldgiafaliifpknmgofiifianln bgflgj [2016-06-18]
    CHR Extension: (Stop Autoplay for YouTube.) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\lgdfnbpkmkkdhgidgcpdkgpdlf jcgnnh [2013-06-05]
    CHR Extension: (InvisibleHand) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\lghjfnfolmcikomdjmoiemllfn lmmoko [2016-07-13]
    CHR Extension: (AwardWallet) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\lppkddfmnlpjbojooindbmcokc hjgbib [2016-05-12]
    CHR Extension: (Yahoo! Axis) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\mbilcmekbcocfaiofmdokibplm ongfil [2013-06-05]
    CHR Extension: (TV Countdown) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\meiipljgihfjofljlgkjiellhj djchhi [2014-09-11]
    CHR Extension: (Chrome Downloads) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\mhaaapflafeapcmgbphlmealld komfbe [2013-06-05]
    CHR Extension: (Search Box) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\mknehpjhljpfaghmicofickbkd agooni [2013-06-05]
    CHR Extension: (Ghostery) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\mlomiejdfkolichcflejclcbmp eaniij [2016-02-21]
    CHR Extension: (Incredible StartPage - Productive Start Page) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ncdfeghkpohnalmpblddmnppfo oljekh [2014-10-20]
    CHR Extension: (MailTrack for Gmail) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ndnaehgpjlnokgebbaldlmgkap kpjkkb [2016-08-11]
    CHR Extension: (Save to Pocket) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\niloccemoadcdkdjlinkgdfeke ahmflj [2016-07-20]
    CHR Extension: (YSlow) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ninejjcohidippngpapiilnmkg llmakh [2013-06-05]
    CHR Extension: (RSS Subscription Extension (by Google)) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\nlbjncdgjeocebhnmkbbbdekmm mcbfjd [2014-08-26]
    CHR Extension: (Chrome Web Store Payments) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\nmmhkkegccagdldgiimedpiccm gmieda [2016-04-02]
    CHR Extension: (Better Pop Up Blocker) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\nmpeeekfhbmikbdhlpjbfmnpgc beggic [2013-06-05]
    CHR Extension: (Buffer) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\noojglkidnpfjbincgijbaiedl djfbhh [2016-07-29]
    CHR Extension: (Original Minimalist Email) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\npppajnlimcafecjepdjcijnoa mopngp [2013-06-05]
    CHR Extension: (Google Reader Snow Leopard) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\obhahfkkedakkpdfmjeakfgino bldlai [2013-06-05]
    CHR Extension: (Readlang Web Reader) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\odpdkefpnfejbfnmdilmfhephf ffmfoh [2016-06-28]
    CHR Extension: (Facebook Styler) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\oibchndgminbbeopaejobnnajf jgkcnk [2013-06-05]
    CHR Extension: (SEO Global For Google Search™) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ojgmigafbpedhdilmemphfklkb ghlphi [2013-06-05]
    CHR Extension: (Google Calendar Checker (by Google)) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\ookhcbgokankfmjafalglpofmo lfopek [2015-02-01]
    CHR Extension: (vidIQ Vision for YouTube) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\pachckjkecffpdphbpmfolblod fkgbhl [2016-08-11]
    CHR Extension: (WiseStamp - Email Signatures for Gmail) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\pbcgnkmbeodkmiijjfnliicelk jfcldg [2016-06-22]
    CHR Extension: (Header Hacker) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\phnffahgegfkcobeaapbenpmdn kifigc [2013-06-05]
    CHR Extension: (Evernote Web Clipper) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\pioclpoplcdbaefihamjohnefb ikjilc [2016-06-28]
    CHR Extension: (Gmail) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoe jaedia [2016-06-13]
    CHR Extension: (Chrome Media Router) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcj beemfm [2016-08-04]
    CHR Extension: (Streak CRM for Gmail) - C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\pnnfemgpilpdaojpnkjdgfgbnn jojfik [2016-06-22]
    CHR Extension: (Media Hint) - C:\Users\SamSwanson\mediahint [2017-02-20] [UpdateUrl: hxxps://127.0.0.1] <==== ATTENTION
    CHR HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Google\Chrome\Extensions...\Chrome\E xtension: [iahagolkpaghhinaljhjihagjgomdokb] - C:\Users\SamSwanson\AppData\Local\Alexa\atbpg-HyChcu-1.3.crx [2014-04-29]
    CHR HKLM-x32...\Chrome\Extension: [kjeghcllfecehndceplomkocgfbklffd] - hxxps://clients2.google.com/service/update2/crx
    R2 AcrSch2Svc; C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe [1244408 2016-10-31] ()
    R2 ADExchange; C:\Program Files (x86)\Common Files\ArcSoft\esinter\Bin\eservutil.exe [44736 2013-10-24] (ArcSoft, Inc.)
    R2 afcdpsrv; C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe [4463592 2016-10-31] ()
    R2 AnonVPN VPN; C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe [127336 2016-05-24] ()
    R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2016-10-31] (Apple Inc.)
    R2 asComSvc; C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe [920736 2014-01-07] ()
    R2 asHmComSvc; C:\Program Files (x86)\ASUS\AAHM\1.00.20\aaHMSvc.exe [951936 2014-01-07] (ASUSTeK Computer Inc.)
    R2 AsSysCtrlService; C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.13\AsSysCtrlServi ce.exe [149120 2014-01-07] (ASUSTeK Computer Inc.)
    R2 AsusFanControlService; C:\Program Files (x86)\ASUS\AsusFanControlService\1.02.05\AsusFanCo ntrolService.exe [2005504 2014-01-07] (ASUSTeK Computer Inc.) [File not signed]
    R2 cmdAgent; C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe [5817256 2016-10-13] (COMODO)
    S3 cmdvirth; C:\Program Files\COMODO\COMODO Internet Security\cmdvirth.exe [2271928 2016-10-13] (COMODO)
    S3 Creative ALchemy AL6 Licensing Service; C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\AL6Licensing.exe [79360 2012-12-23] (Creative Labs) [File not signed]
    S3 Creative Audio Engine Licensing Service; C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\CTAELicensing.exe [79360 2012-12-23] (Creative Labs) [File not signed]
    R2 CTAudSvcService; C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe [294912 2010-12-28] (Creative Technology Ltd) [File not signed]
    S3 Disc Soft Lite Bus Service; C:\Program Files (x86)\DAEMON Tools Lite\DiscSoftBusService.exe [1268568 2016-08-15] (Disc Soft Ltd)
    R2 DisplayFusionService; C:\Program Files (x86)\DisplayFusion\DisplayFusionService.exe [1243024 2013-02-11] (Binary Fortress Software)
    R2 Gizmo Central; C:\Program Files (x86)\Gizmo\gservice.exe [34728 2012-12-25] (Arainia Solutions)
    R3 ICCS; C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe [160768 2011-05-27] (Intel Corporation) [File not signed]
    S3 IDriverT; C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [69632 2005-04-04] (Macrovision Corporation) [File not signed]
    R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520 2013-08-27] (Intel(R) Corporation) [File not signed]
    S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [828376 2013-08-27] (Intel(R) Corporation)
    S3 Intel(R) TA SAM; C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [18152 2016-10-11] (Intel Corporation)
    R2 Intel(R) TechnologyAccessLegacyCSLoader; C:\Program Files\Intel Corporation\Intel(R) Technology Access\LegacyCsLoaderService.exe [153296 2016-06-10] (Intel(R) Corporation)
    R2 Intel(R) TechnologyAccessService; C:\Program Files\Intel Corporation\Intel(R) Technology Access\IntelTechnologyAccessService.exe [478416 2016-06-10] (Intel(R) Corporation)
    S2 ISCTAgent; c:\Program Files\Intel\Intel(R) Smart Connect Technology Agent\iSCTAgent.exe [149032 2012-08-16] ()
    S3 iumsvc; C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [177376 2016-10-11] (Intel Corporation)
    R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [169432 2000-01-01] (Intel Corporation)
    R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [4355024 2017-02-11] (Malwarebytes)
    R2 mmsminisrv; C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe [4884064 2016-06-29] (Acronis)
    R2 NitroDriverReadSpool8; C:\Program Files\Common Files\Nitro\Pro\8.0\NitroPDFDriverService8x64.exe [230408 2013-03-25] (Nitro PDF Software)
    R2 NvContainerLocalSystem; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [462784 2017-01-26] (NVIDIA Corporation)
    S3 NvContainerNetworkService; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [462784 2017-01-26] (NVIDIA Corporation)
    R2 NVDisplay.ContainerLocalSystem; C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe [464440 2017-02-10] (NVIDIA Corporation)
    R2 NvTelemetryContainer; C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe [425408 2017-01-26] (NVIDIA Corporation)
    R2 OxygenAudioDevMon; C:\Program Files (x86)\M-Audio\Oxygen\AudioDevMon.exe [1632776 2010-03-04] (M-Audio)
    S3 Sense; C:\Program Files\Windows Defender Advanced Threat Protection\MsSense.exe [2889896 2016-10-13] (Microsoft Corporation)
    R2 SEVPNCLIENT; C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe [5248456 2017-02-25] (SoftEther VPN Project at University of Tsukuba, Japan.)
    S3 SwitchBoard; C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated) [File not signed]
    R2 syncagentsrv; C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe [9698296 2016-06-29] ()
    R2 TeamViewer; C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe [10351856 2017-02-11] (TeamViewer GmbH)
    S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [347328 2016-07-16] (Microsoft Corporation)
    S2 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [103720 2016-07-16] (Microsoft Corporation)
    R2 WRSVC; C:\Program Files\Webroot\WRSA.exe [992056 2017-01-18] (Webroot)
    R2 XTU3SERVICE; C:\Program Files (x86)\Intel\Extreme Tuning Utility\XtuService.exe [14936 2012-08-17] (Intel(R) Corporation)
    R2 ZAMSvc; C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [14416624 2017-02-11] (Copyright 2017.)
    R1 AsIO; C:\Windows\SysWow64\drivers\AsIO.sys [15232 2012-08-22] ()
    R1 AsUpIO; C:\Windows\SysWow64\drivers\AsUpIO.sys [14464 2013-01-15] ()
    R3 ASUSFILTER; C:\Windows\SysWow64\drivers\ASUSFILTER.sys [46152 2011-09-20] (MCCI Corporation)
    S3 AU8168; C:\WINDOWS\system32\DRIVERS\au630x64.sys [792648 2013-09-23] (Realtek )
    R1 CBDisk; C:\Windows\system32\drivers\CBDisk.sys [70344 2011-05-06] (EldoS Corporation)
    R1 cmderd; C:\WINDOWS\System32\DRIVERS\cmderd.sys [40960 2016-09-08] (COMODO)
    R1 cmdGuard; C:\WINDOWS\System32\DRIVERS\cmdguard.sys [862648 2016-09-08] (COMODO)
    R1 cmdhlp; C:\WINDOWS\system32\DRIVERS\cmdhlp.sys [54336 2016-09-08] (COMODO)
    R3 DDMF_Audio; C:\WINDOWS\system32\drivers\DDMFaudio.sys [28456 2015-07-15] (DDMF)
    R3 dtlitescsibus; C:\WINDOWS\System32\drivers\dtlitescsibus.sys [30264 2016-08-15] (Disc Soft Ltd)
    R1 ESProtectionDriver; C:\WINDOWS\system32\drivers\mbae64.sys [77416 2017-02-11] ()
    R0 FancyRd; C:\WINDOWS\System32\drivers\fancyrd.sys [188352 2012-06-24] (Romex Software)
    R0 file_tracker; C:\WINDOWS\System32\DRIVERS\file_tracker.sys [366432 2016-10-31] (Acronis International GmbH)
    R1 GizmoDrv; C:\Windows\System32\Drivers\GizmoDrv.sys [34704 2012-12-25] (Arainia Solutions LLC)
    S3 GVTDrv64; C:\Windows\GVTDrv64.sys [30528 2012-12-24] ()
    R1 HWiNFO32; C:\WINDOWS\SysWoW64\drivers\HWiNFO64A.SYS [27552 2016-11-22] (REALiX™)
    R3 ikbevent; C:\WINDOWS\system32\DRIVERS\ikbevent.sys [20968 2012-08-16] ()
    R3 iLokDrvr; C:\WINDOWS\System32\drivers\iLokDrvr.sys [25808 2013-10-27] ()
    R3 imsevent; C:\WINDOWS\system32\DRIVERS\imsevent.sys [19944 2012-08-16] ()
    R1 inspect; C:\WINDOWS\system32\DRIVERS\inspect.sys [147304 2016-09-08] (COMODO)
    R2 iocbios2; C:\Program Files (x86)\Intel\Extreme Tuning Utility\Drivers\IocDriver\64bit\iocbios2.sys [23832 2012-08-13] (Intel Corporation)
    R3 LGSHidFilt; C:\WINDOWS\system32\DRIVERS\LGSHidFilt.Sys [66360 2012-10-02] (Logitech Inc.)
    S3 LoopBe30; C:\WINDOWS\system32\drivers\loopbe30.sys [16896 2011-02-26] (nerds.de)
    R2 MBAMChameleon; C:\WINDOWS\system32\drivers\MBAMChameleon.sys [176584 2017-03-01] (Malwarebytes)
    R3 MBAMFarflt; C:\WINDOWS\system32\drivers\farflt.sys [110536 2017-03-01] (Malwarebytes)
    R3 MBAMProtection; C:\WINDOWS\system32\drivers\mbam.sys [43968 2017-03-01] (Malwarebytes)
    R3 MBAMSwissArmy; C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys [251848 2017-03-01] (Malwarebytes)
    R3 MBAMWebProtection; C:\WINDOWS\system32\drivers\mwac.sys [91584 2017-03-01] (Malwarebytes)
    R3 MBOX; C:\WINDOWS\system32\DRIVERS\AvidMbox.sys [464616 2016-08-15] (Avid)
    R3 MBOXDFU; C:\WINDOWS\System32\drivers\AvidMbox_DFU.sys [31464 2016-08-15] (Avid)
    R0 MDFSYSNT; C:\Windows\System32\Drivers\MDFSYSNT.sys [322768 2012-11-15] (Mediafour Corporation)
    R0 MDPMGRNT; C:\WINDOWS\System32\DRIVERS\MDPMGRNT.SYS [32464 2012-06-05] (Mediafour Corporation)
    R1 ndisrd; C:\WINDOWS\system32\DRIVERS\ndisrfl.sys [41688 2016-06-10] (Intel Corporation)
    R3 Neo_VPN; C:\WINDOWS\System32\drivers\Neo6_x64_VPN.sys [38216 2017-02-25] (SoftEther Corporation)
    S3 NetAdapterCx; C:\WINDOWS\System32\drivers\NetAdapterCx.sys [90624 2016-07-16] ()
    R3 NetTap630; C:\WINDOWS\system32\DRIVERS\nettap630.sys [67800 2016-06-10] (Intel Corporation)
    R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nv_ dispi.inf_amd64_02838dee03d82b94\nvlddmkm.sys [14427064 2017-02-10] (NVIDIA Corporation)
    S3 NvStreamKms; C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamKms.sys [27584 2017-01-20] (NVIDIA Corporation)
    R3 nvvad_WaveExtensible; C:\WINDOWS\system32\drivers\nvvad64v.sys [46016 2017-02-10] (NVIDIA Corporation)
    R3 nvvhci; C:\WINDOWS\System32\drivers\nvvhci.sys [57792 2017-02-10] (NVIDIA Corporation)
    R3 OXYGEN; C:\WINDOWS\system32\DRIVERS\MAudioOxygen.sys [134664 2010-03-04] (M-Audio)
    U0 Partizan; C:\Windows\SysWOW64\drivers\Partizan.sys [40304 2017-02-24] (Greatis Software)
    R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [943112 2016-11-22] (Realtek )
    R1 SeLow; C:\WINDOWS\system32\DRIVERS\SeLow_x64.sys [51024 2017-02-25] (SoftEther Corporation)
    S3 SmbDrvI; C:\WINDOWS\system32\DRIVERS\Smb_driver_Intel.sys [43832 2012-08-24] (Synaptics Incorporated)
    S3 teVirtualMIDI64; C:\WINDOWS\system32\DRIVERS\teVirtualMIDI64.sys [30208 2012-08-16] (Tobias Erichsen)
    R0 tib; C:\WINDOWS\System32\DRIVERS\tib.sys [1267552 2016-10-31] (Acronis International GmbH)
    R2 tib_mounter; C:\WINDOWS\system32\DRIVERS\tib_mounter.sys [193376 2016-10-31] (Acronis International GmbH)
    S3 tnd; C:\WINDOWS\system32\DRIVERS\tnd.sys [601432 2016-10-31] (Acronis International GmbH)
    R3 UAD2Pcie; C:\WINDOWS\System32\drivers\UAD2Pcie.sys [82752 2016-11-03] (Universal Audio, Inc.)
    R3 UAD2System; C:\WINDOWS\System32\drivers\UAD2System.sys [134464 2016-11-03] (Universal Audio, Inc.)
    R3 UAD2WdmAudio; C:\WINDOWS\system32\DRIVERS\UAD2WdmAudio.sys [27968 2016-11-03] ()
    R3 VBAudioHFVAIOMME; C:\WINDOWS\system32\DRIVERS\vbaudio_hfvaio64_win7. sys [33512 2014-03-07] (Windows (R) Win 7 DDK provider)
    R2 virtual_file; C:\WINDOWS\System32\DRIVERS\virtual_file.sys [279392 2016-06-29] (Acronis International GmbH)
    U5 vwifimp; C:\Windows\System32\Drivers\vwifimp.sys [39936 2016-07-16] (Microsoft Corporation)
    S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44056 2016-07-16] (Microsoft Corporation)
    S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [290144 2016-07-16] (Microsoft Corporation)
    S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [123232 2016-07-16] (Microsoft Corporation)
    S3 WPRO_41_2001; C:\WINDOWS\System32\drivers\WPRO_41_2001.sys [34752 2014-01-03] ()
    R0 WRkrn; C:\WINDOWS\System32\drivers\WRkrn.sys [143248 2017-02-27] (Webroot)
    R3 wrUrlFlt; C:\Windows\system32\DRIVERS\wrUrlFlt.sys [66328 2016-10-11] (Webroot)
    R1 ZAM; C:\WINDOWS\System32\drivers\zam64.sys [203680 2017-02-11] (Zemana Ltd.)
    R1 ZAM_Guard; C:\WINDOWS\System32\drivers\zamguard64.sys [203680 2017-02-11] (Zemana Ltd.)
    S3 FreshIO; ??\C:\Program Files (x86)\FreshDevices\FreshDiagnose\FreshIO.sys
    S3 ManyCam; \SystemRoot\system32\DRIVERS\mcvidrv.sys
    S3 mcaudrv_simple; \SystemRoot\system32\drivers\mcaudrv_x64.sys
    U0 SR; no ImagePath
    U2 srservice; no ImagePath
    2017-03-01 14:33 - 2017-03-01 14:33 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Overloud
    2017-03-01 14:33 - 2017-03-01 14:33 - 00000000 ____D C:\ProgramData\Overloud
    2017-03-01 13:43 - 2017-03-01 13:43 - 00154624 _____ C:\Users\SamSwanson\Desktop\SigLotSizeCalV1.2.xls
    2017-03-01 12:43 - 2017-03-01 12:43 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\ESET
    2017-02-28 22:48 - 2017-03-01 13:45 - 00000000 ____D C:\ProgramData\Malwarebytes’ Anti-Malware (portable)
    2017-02-28 14:25 - 2017-02-28 14:25 - 00000000 ____D C:\ProgramData\MetaQuotes
    2017-02-28 14:24 - 2017-02-28 14:24 - 00002075 _____ C:\Users\Public\Desktop\Tradeo - MetaTrader 4.lnk
    2017-02-28 14:24 - 2017-02-28 14:24 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tradeo - MetaTrader 4
    2017-02-28 14:24 - 2017-02-28 14:24 - 00000000 ____D C:\Program Files (x86)\Tradeo - MetaTrader 4
    2017-02-27 23:05 - 2017-02-27 23:05 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Carbonite
    2017-02-25 14:26 - 2017-02-25 14:26 - 00038216 _____ (SoftEther Corporation) C:\WINDOWS\system32\Drivers\Neo6_x64_VPN.sys
    2017-02-25 14:23 - 2017-03-01 13:45 - 00000000 ____D C:\Program Files\SoftEther VPN Client
    2017-02-25 14:23 - 2017-02-25 14:23 - 00143816 _____ (SoftEther VPN Project at University of Tsukuba, Japan.) C:\WINDOWS\system32\vpncmd.exe
    2017-02-25 14:23 - 2017-02-25 14:23 - 00051024 _____ (SoftEther Corporation) C:\WINDOWS\system32\Drivers\SeLow_x64.sys
    2017-02-25 14:23 - 2017-02-25 14:23 - 00001980 _____ C:\ProgramData\Microsoft\Windows\Start Menu\SoftEther VPN Client Manager.lnk
    2017-02-25 14:23 - 2017-02-25 14:23 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client
    2017-02-24 18:44 - 2017-03-01 13:45 - 00000984 _____ C:\WINDOWS\SysWOW64\PARTIZAN.TXT
    2017-02-24 18:41 - 2017-02-24 18:41 - 00000000 ____D C:@RestoreQuarantine
    2017-02-24 18:28 - 2017-02-24 23:58 - 00000000 ____D C:\ProgramData\RegRun
    2017-02-24 18:27 - 2017-03-01 12:43 - 00000000 ____D C:\Users\SamSwanson\Documents\RegRun2
    2017-02-24 18:27 - 2017-02-24 18:27 - 00040304 _____ (Greatis Software) C:\WINDOWS\SysWOW64\Drivers\Partizan.sys
    2017-02-24 18:27 - 2017-02-24 18:27 - 00003424 _____ C:\WINDOWS\System32\Tasks\UnHackMe Task Scheduler
    2017-02-24 18:27 - 2017-02-24 18:27 - 00000002 RSHOT C:\WINDOWS\winstart.bat
    2017-02-24 18:27 - 2017-02-24 18:27 - 00000002 RSHOT C:\WINDOWS\SysWOW64\CONFIG.NT
    2017-02-24 18:27 - 2017-02-24 18:27 - 00000002 RSHOT C:\WINDOWS\SysWOW64\AUTOEXEC.NT
    2017-02-24 18:26 - 2017-03-01 10:10 - 00000000 ____D C:\Users\Public\Documents\regruninfo
    2017-02-24 18:26 - 2017-02-24 18:30 - 00000000 ____D C:\Program Files (x86)\UnHackMe
    2017-02-24 18:26 - 2017-02-24 18:26 - 00049968 _____ (Greatis Software) C:\WINDOWS\system32\partizan.exe
    2017-02-24 18:26 - 2017-02-24 18:26 - 00014984 _____ (Greatis Software, LLC.) C:\WINDOWS\SysWOW64\Drivers\UnHackMeDrv.sys
    2017-02-24 18:26 - 2017-02-24 18:26 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe
    2017-02-24 16:57 - 2017-02-24 16:57 - 06971584 _____ (Tim Kosse) C:\Users\SamSwanson\Downloads\FileZilla_3.24.1_win 64-setup.exe
    2017-02-23 01:05 - 2017-02-23 01:05 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MetaTrader 5
    2017-02-23 01:05 - 2017-02-23 01:05 - 00000000 ____D C:\Program Files\MetaTrader 5
    2017-02-23 01:04 - 2017-02-23 01:05 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\MetaQuotes
    2017-02-21 16:25 - 2017-02-21 16:26 - 00000000 ____D C:\ProgramData\SupremoRemoteDesktop
    2017-02-21 15:52 - 2017-02-21 16:01 - 00000000 ____D C:\ProgramData\Emsisoft
    2017-02-21 15:25 - 2017-02-21 15:25 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Revo Uninstaller
    2017-02-21 15:24 - 2017-02-21 15:24 - 00000000 ____D C:\Program Files\VS Revo Group
    2017-02-21 14:47 - 2017-02-21 14:47 - 00000120 ___RH C:\Users\SamSwanson\Desktop\Stinger.opt
    2017-02-21 14:39 - 2017-02-21 14:47 - 00000000 ____D C:\Program Files\stinger
    2017-02-21 14:39 - 2017-02-21 14:39 - 00000000 ____D C:\Program Files\McAfee
    2017-02-20 21:33 - 2017-02-20 21:33 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\PackageStaging
    2017-02-20 21:31 - 2017-02-20 21:31 - 00000000 ____D C:\WINDOWS\Panther
    2017-02-20 21:05 - 2017-02-20 21:05 - 00000000 ____D C:\WINDOWS\pss
    2017-02-20 21:01 - 2017-02-20 21:01 - 00003786 _____ C:\WINDOWS\System32\Tasks\Tweaking.com - Windows Repair Tray Icon
    2017-02-20 21:01 - 2017-02-20 21:01 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tweaking.com
    2017-02-20 21:01 - 2017-02-20 21:01 - 00000000 ____D C:\Program Files (x86)\Tweaking.com
    2017-02-20 20:33 - 2017-02-20 20:24 - 00110144 _____ (Oracle Corporation) C:\WINDOWS\SysWOW64\WindowsAccessBridge-64.dll
    2017-02-20 20:24 - 2017-02-20 20:24 - 00110144 _____ (Oracle Corporation) C:\WINDOWS\system32\WindowsAccessBridge-64.dll
    2017-02-19 17:20 - 2017-02-19 17:20 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RogueKiller
    2017-02-19 16:28 - 2017-03-01 17:43 - 00000000 ____D C:\FRST
    2017-02-16 11:45 - 2017-02-24 17:06 - 00000869 _____ C:\Users\Public\Desktop\REAPER (x64).lnk
    2017-02-16 00:59 - 2017-02-16 00:59 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\AnonVPN
    2017-02-15 21:57 - 2017-02-15 21:57 - 00002874 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
    2017-02-15 21:52 - 2017-03-01 17:44 - 00000000 ____D C:\Users\SamSwanson\Desktop\Computer fix
    2017-02-15 17:34 - 2017-02-15 17:34 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\HomeDev
    2017-02-15 17:34 - 2017-02-15 17:34 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HomeDev
    2017-02-15 17:34 - 2017-02-15 17:34 - 00000000 ____D C:\Program Files (x86)\HomeDev
    2017-02-15 17:26 - 2017-02-15 17:26 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\WinDirStat
    2017-02-15 17:26 - 2017-02-15 17:26 - 00000000 ____D C:\Program Files (x86)\WinDirStat
    2017-02-15 17:05 - 2017-02-15 17:05 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Toshiba Corporation
    2017-02-15 17:05 - 2017-02-15 17:05 - 00000000 ____D C:\ProgramData\Toshiba Corporation
    2017-02-15 17:04 - 2017-02-15 17:04 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Toshiba Corporation
    2017-02-15 17:04 - 2017-02-15 17:04 - 00000000 ____D C:\Program Files (x86)\Toshiba Corporation
    2017-02-15 17:03 - 2017-02-15 17:04 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\FreshDiagnose
    2017-02-15 16:57 - 2017-02-15 16:57 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\JxBrowser
    2017-02-13 16:16 - 2017-02-13 16:16 - 00000000 ____D C:\WINDOWS\System32\Tasks\Safer-Networking
    2017-02-13 14:56 - 2017-02-13 16:16 - 00000000 ____D C:\ProgramData\Spybot - Search & Destroy
    2017-02-13 14:26 - 2017-02-13 14:26 - 00100984 _____ C:\Users\SamSwanson\Documents\VME Accounts Gnucash.gnucash.20170213142617.gnucash
    2017-02-13 14:24 - 2017-02-13 14:24 - 00100834 _____ C:\Users\SamSwanson\Documents\VME Accounts Gnucash.gnucash.20170213142442.gnucash
    2017-02-13 00:03 - 2017-02-13 00:03 - 00000000 ____D C:\ProgramData\Sophos
    2017-02-13 00:00 - 2017-02-13 00:00 - 04656523 _____ C:\Users\SamSwanson\Downloads\tdsskiller.zip
    2017-02-13 00:00 - 2017-02-13 00:00 - 00208216 _____ (Kaspersky Lab, GERT) C:\WINDOWS\system32\Drivers\55447846.sys
    2017-02-12 18:19 - 2017-02-12 18:19 - 00014856 ____N C:\bootsqm.dat
    2017-02-11 16:08 - 2017-03-01 13:46 - 00091584 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mwac.sys
    2017-02-11 16:08 - 2017-03-01 13:45 - 00176584 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMChameleon.sys
    2017-02-11 16:08 - 2017-03-01 13:45 - 00110536 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\farflt.sys
    2017-02-11 16:07 - 2017-02-11 16:07 - 00077416 _____ C:\WINDOWS\system32\Drivers\mbae64.sys
    2017-02-11 16:07 - 2017-02-11 16:07 - 00001116 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamViewer 12.lnk
    2017-02-11 16:07 - 2017-02-11 16:07 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
    2017-02-11 16:07 - 2017-02-11 16:07 - 00000000 ____D C:\Program Files\Malwarebytes
    2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Process Lasso
    2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
    2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\Program Files\iTunes
    2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\Program Files\iPod
    2017-02-11 15:29 - 2017-03-01 17:44 - 00134454 _____ C:\WINDOWS\ZAM.krnl.trace
    2017-02-11 15:29 - 2017-03-01 17:44 - 00093083 _____ C:\WINDOWS\ZAM_Guard.krnl.trace
    2017-02-11 15:29 - 2017-02-11 15:29 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zamguard64.sys
    2017-02-11 15:29 - 2017-02-11 15:29 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zam64.sys
    2017-02-11 15:29 - 2017-02-11 15:29 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware
    2017-02-11 15:29 - 2017-02-11 15:29 - 00000000 ____D C:\Program Files (x86)\Zemana AntiMalware
    2017-02-10 22:40 - 2017-02-10 22:40 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Zemana
    2017-02-10 22:39 - 2017-02-10 22:39 - 00012872 _____ (SurfRight B.V.) C:\WINDOWS\system32\bootdelete.exe
    2017-02-10 22:39 - 2017-02-10 22:39 - 00002398 _____ C:\WINDOWS\system32.crusader
    2017-02-10 22:27 - 2017-02-10 22:27 - 00000000 ____D C:\Program Files\HitmanPro
    2017-02-10 22:26 - 2017-02-10 22:39 - 00000000 ____D C:\ProgramData\HitmanPro
    2017-02-10 20:18 - 2017-02-10 20:18 - 00134080 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvStreaming.exe
    2017-02-10 20:17 - 2017-02-10 20:17 - 00125728 _____ C:\WINDOWS\system32\vulkaninfo.exe
    2017-02-10 20:17 - 2017-02-10 20:17 - 00111392 _____ C:\WINDOWS\SysWOW64\vulkaninfo.exe
    2017-02-10 20:17 - 2017-02-10 20:17 - 00000000 ____D C:\Program Files (x86)\VulkanRT
    2017-02-10 20:17 - 2016-12-16 01:33 - 00273696 _____ C:\WINDOWS\SysWOW64\vulkan-1.dll
    2017-02-10 20:17 - 2016-12-16 01:33 - 00266528 _____ C:\WINDOWS\system32\vulkan-1.dll
    2017-02-10 20:12 - 2017-02-10 20:17 - 00000000 __D C:\WINDOWS\LastGood
    2017-02-10 20:09 - 2017-02-10 20:17 - 00047664 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvhdap64.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 40192056 _____ C:\WINDOWS\system32\nvcompiler.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 35272760 _____ C:\WINDOWS\SysWOW64\nvcompiler.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 28239928 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvoglv32.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 19008576 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvopencl.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 14677272 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvopencl.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 11123936 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuda.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 11019192 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvptxJitCompiler.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 09308896 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuda.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 08990584 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvptxJitCompiler.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 03167288 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuvid.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 02715072 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuvid.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 01985080 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispco6437849.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 01591352 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispgenco6437849.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 01051584 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvFBC64.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00988608 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvFBC.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00960568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFR64.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00946456 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncMFTH264.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00909760 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFR.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00721952 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncMFTH264.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00687224 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvfatbinaryLoader.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00609216 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFROpenGL.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00606776 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvDecMFTMjpeg.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00576192 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvfatbinaryLoader.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00573120 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncodeAPI64.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00499136 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFROpenGL.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00483384 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvDecMFTMjpeg.dll
    2017-02-10 20:09 - 2017-02-10 20:11 - 00447800 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncodeAPI.dll
    2017-02-10 20:09 - 2017-01-20 17:38 - 00000669 _____ C:\WINDOWS\SysWOW64\nv-vk32.json
    2017-02-10 20:09 - 2017-01-20 17:38 - 00000669 _____ C:\WINDOWS\system32\nv-vk64.json
    2017-02-10 20:02 - 2017-02-10 20:02 - 00000000 D C:\Users\SamSwanson\AppData\Local\Chromium
    2017-02-10 20:02 - 2017-01-20 19:41 - 01872320 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspcap64.dll
    2017-02-10 20:02 - 2017-01-20 19:41 - 01755072 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspbridge64.dll
    2017-02-10 20:02 - 2017-01-20 19:41 - 01464768 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspcap.dll
    2017-02-10 20:02 - 2017-01-20 19:41 - 01317312 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspbridge.dll
    2017-02-10 20:02 - 2017-01-20 19:41 - 00120256 _____ C:\WINDOWS\system32\NvRtmpStreamer64.dll
    2017-02-10 20:01 - 2017-02-10 20:01 - 00003884 _____ C:\WINDOWS\System32\Tasks\NvNodeLauncher
    {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
    2017-02-10 19:59 - 2017-02-10 19:59 - 00003894 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterDaily
    2017-02-10 19:59 - 2017-02-10 19:59 - 00003866 _____ C:\WINDOWS\System32\Tasks\NvTmRep
    2017-02-10 19:59 - 2017-02-10 19:59 - 00003858 _____ C:\WINDOWS\System32\Tasks\NvTmMon
    2017-02-10 19:59 - 2017-02-10 19:59 - 00003696 _____ C:\WINDOWS\System32\Tasks\NvTmRepOnLogon
    2017-02-10 19:59 - 2017-02-10 19:59 - 00003654 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterOnLogon
    2017-02-10 19:59 - 2017-01-26 09:15 - 00001951 _____ C:\WINDOWS\NvTelemetryContainerRecovery.bat
    2017-02-10 19:58 - 2017-02-10 20:01 - 00057792 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvhci.sys
    2017-02-10 19:58 - 2017-02-10 19:59 - 00156608 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvaudcap64v.dll
    2017-02-10 19:58 - 2017-02-10 19:59 - 00124352 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvaudcap32v.dll
    2017-02-10 19:58 - 2017-02-10 19:59 - 00046016 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvad64v.sys
    2017-02-10 13:29 - 2017-02-20 20:33 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java
    2017-02-08 10:43 - 2017-02-10 20:15 - 00001951 _____ C:\WINDOWS\NvContainerRecovery.bat
    2017-02-08 10:42 - 2017-02-08 10:44 - 00000000 ____D C:\WINDOWS\LastGood.Tmp
    2017-02-08 10:08 - 2017-02-28 15:41 - 00002590 _____ C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Google Chrome Canary.lnk
    2017-02-08 10:08 - 2017-02-28 15:41 - 00002582 _____ C:\Users\SamSwanson\Desktop\Google Chrome Canary.lnk
    2017-01-31 00:10 - 2017-02-16 13:28 - 00000000 ____D C:\Users\SamSwanson\AppData\LocalLow\Mozilla
    2017-03-01 17:37 - 2016-08-11 19:35 - 00000000 ____D C:\WINDOWS\system32\SleepStudy
    2017-03-01 15:42 - 2016-06-13 10:39 - 00000096 _____ C:\Users\SamSwanson\AppData\Roaming\msregsvv.dll
    2017-03-01 15:42 - 2014-01-22 13:15 - 00000128 _____ C:\ProgramData\autobk.inc
    2017-03-01 15:42 - 2012-12-27 05:17 - 00000000 ____D C:\ProgramData\ValhallaRoom
    2017-03-01 13:58 - 2013-05-04 00:13 - 00000000 ___HD C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA
    2017-03-01 13:58 - 2012-10-14 18:47 - 00000000 ___HD C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX
    2017-03-01 13:56 - 2012-12-24 01:13 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\vlc
    2017-03-01 13:53 - 2016-11-23 15:33 - 00000000 ____D C:\ProgramData\boost_interprocess
    2017-03-01 13:49 - 2016-08-11 19:48 - 00829958 _____ C:\WINDOWS\system32\PerfStringBackup.INI
    2017-03-01 13:47 - 2015-07-24 10:55 - 00000000 ____D C:\ProgramData\WRData
    2017-03-01 13:46 - 2012-12-23 13:44 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Ditto
    2017-03-01 13:45 - 2016-08-11 19:50 - 00000006 ____H C:\WINDOWS\Tasks\SA.DAT
    2017-03-01 13:45 - 2014-06-15 15:30 - 00251848 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
    2017-03-01 13:45 - 2012-12-26 18:57 - 00043968 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbam.sys
    2017-03-01 13:45 - 2012-12-23 12:43 - 00000000 ____D C:\ProgramData\NVIDIA
    2017-03-01 13:44 - 2016-07-16 07:04 - 01835008 _____ C:\WINDOWS\system32\config\BBI
    2017-03-01 13:43 - 2012-12-23 10:57 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Packages
    2017-03-01 13:11 - 2013-02-28 11:48 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\CrashDumps
    2017-03-01 11:24 - 2012-12-24 01:02 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Spotify
    2017-03-01 10:32 - 2016-02-15 14:22 - 00028272 _____ C:\WINDOWS\system32\Drivers\TrueSight.sys
    2017-03-01 10:18 - 2012-12-23 12:27 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Spotify
    2017-03-01 10:07 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\tracing
    2017-03-01 00:07 - 2016-01-11 10:36 - 00000000 ____D C:\Users\Public\Documents\ExponentialAudioLogs
    2017-02-27 18:03 - 2016-06-29 15:03 - 00143248 _____ (Webroot) C:\WINDOWS\system32\Drivers\WRkrn.sys
    2017-02-26 20:27 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\AppReadiness
    2017-02-25 14:58 - 2012-12-23 13:18 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\REAPER
    2017-02-25 14:26 - 2016-07-16 12:45 - 00000000 ____D C:\WINDOWS\INF
    2017-02-25 14:03 - 2016-08-12 14:55 - 00000051 _____ C:\Users\SamSwanson\deletedRoute.txt
    2017-02-25 14:03 - 2016-08-12 14:54 - 00009424 _____ C:\Users\SamSwanson\AnonVPN.ovpn
    2017-02-25 10:26 - 2016-07-16 12:47 - 00000000 ___HD C:\Program Files\WindowsApps
    2017-02-24 19:51 - 2015-02-14 01:28 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Mp3tag
    2017-02-24 18:40 - 2016-08-31 16:31 - 00000000 ____D C:\Program Files\Handbrake
    2017-02-24 18:40 - 2014-08-03 21:04 - 00000000 ____D C:\Program Files (x86)\KDNicheFinder
    2017-02-24 17:06 - 2012-12-23 13:18 - 00000000 ____D C:\Program Files\REAPER (x64)
    2017-02-24 16:58 - 2013-02-17 13:21 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\FileZilla
    2017-02-24 11:36 - 2012-12-24 02:10 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\iZotope
    2017-02-23 00:26 - 2016-12-14 23:19 - 00000000 ____D C:\Users\SamSwanson\Desktop\Travel Plans
    2017-02-22 17:26 - 2012-12-23 12:51 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Dashlane
    2017-02-22 17:25 - 2014-03-07 00:23 - 00002013 _____ C:\Users\SamSwanson\Desktop\Dashlane.lnk
    2017-02-22 17:25 - 2012-12-23 12:51 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Dashlane
    2017-02-22 14:40 - 2016-06-05 17:05 - 00000000 ____D C:\Program Files (x86)\TeamViewer
    2017-02-22 09:57 - 2017-01-12 17:52 - 00000830 _____ C:\WINDOWS\Tasks\Adobe Flash Player Updater.job
    2017-02-22 09:57 - 2016-12-03 22:13 - 00000892 _____ C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job
    2017-02-22 01:23 - 2016-12-03 22:13 - 00003986 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player PPAPI Notifier
    2017-02-22 01:23 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\SysWOW64\Macromed
    2017-02-22 01:23 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\Macromed
    2017-02-22 00:10 - 2013-01-09 06:42 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Nitro PDF
    2017-02-21 20:08 - 2016-02-27 01:27 - 00000000 ____D C:\AdwCleaner
    2017-02-21 17:37 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\NDF
    2017-02-21 16:44 - 2016-12-03 21:06 - 00000000 ____D C:\Program Files\CCleaner
    2017-02-21 16:09 - 2016-12-18 13:41 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Electrum
    2017-02-21 16:09 - 2015-12-02 13:37 - 03123997 _____ C:\Users\SamSwanson\Desktop\Money 4 Music.epub
    2017-02-21 15:32 - 2014-09-16 18:19 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Joey Sturgis Tones
    2017-02-21 15:32 - 2014-09-16 18:19 - 00000000 ____D C:\Program Files\Joey Sturgis Tones
    2017-02-21 15:32 - 2012-12-24 06:19 - 00000000 ____D C:\Program Files\Common Files\VST3
    2017-02-21 14:39 - 2016-06-13 17:53 - 00000000 ____D C:\QUARANTINE
    2017-02-20 21:36 - 2016-08-11 19:38 - 00000000 ____D C:\Users\SamSwanson
    2017-02-20 21:31 - 2012-12-23 10:57 - 00000000 ____D C:\WINDOWS\CSC
    2017-02-20 21:29 - 2016-12-05 18:56 - 00000214 _____ C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask .job
    2017-02-20 21:28 - 2016-08-11 19:35 - 04961528 _____ C:\WINDOWS\system32\FNTCACHE.DAT
    2017-02-20 21:26 - 2016-07-16 12:36 - 00000000 ____D C:\WINDOWS\CbsTemp
    2017-02-20 21:19 - 2016-03-30 16:21 - 00000000 ____D C:\Users\SamSwanson\Desktop\Social Media Course
    2017-02-20 21:19 - 2014-06-07 09:57 - 00000000 ____D C:\Users\SamSwanson\mediahint
    2017-02-20 21:19 - 2014-04-04 13:18 - 00000000 ____D C:\Users\SamSwanson\Desktop\Drumatom
    2017-02-20 21:19 - 2013-08-05 18:07 - 00000000 ____D C:\Users\SamSwanson\Desktop\StudioPhotoShoot
    2017-02-20 21:19 - 2013-02-21 13:15 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\DisplayFusion
    2017-02-20 21:19 - 2013-01-03 18:33 - 00000000 ____D C:\Users\SamSwanson\Documents\TAX
    2017-02-20 21:17 - 2012-12-23 11:50 - 06096688 _____ C:\WINDOWS\SysWOW64\PerfStringBackup.INI
    2017-02-20 20:33 - 2012-12-23 12:25 - 00000000 ____D C:\Program Files (x86)\Java
    2017-02-20 20:25 - 2016-08-15 15:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management
    2017-02-20 20:25 - 2016-08-15 15:04 - 00000000 ____D C:\Program Files\Calibre2
    2017-02-20 20:24 - 2012-12-23 12:25 - 00000000 ____D C:\Program Files\Java
    2017-02-20 20:21 - 2016-08-15 14:52 - 00605984 _____ (www.patchmypc.net) C:\Users\SamSwanson\Desktop\PatchMyPC.exe
    2017-02-20 17:51 - 2016-02-15 14:24 - 00007602 _____ C:\Users\SamSwanson\AppData\Local\Resmon.ResmonCfg
    2017-02-19 17:20 - 2016-04-21 13:59 - 00000000 ____D C:\Program Files\RogueKiller
    2017-02-19 14:24 - 2015-07-15 20:46 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\DDMF Effect Rack
    2017-02-19 11:52 - 2014-08-24 11:43 - 00000000 ____D C:\Program Files (x86)\Media Gobbler, Inc
    2017-02-19 11:52 - 2013-06-05 10:24 - 00000000 ____D C:\ProgramData\Package Cache
    2017-02-19 11:52 - 2012-12-23 13:38 - 00000000 ____D C:\ProgramData\Gobbler
    2017-02-18 21:47 - 2013-02-17 14:33 - 00000000 ____D C:\ProgramData\ValhallaUberMod
    2017-02-16 17:07 - 2014-02-10 03:09 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Spectrasonics
    2017-02-16 11:45 - 2016-11-23 09:34 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)
    2017-02-16 00:59 - 2016-08-12 14:54 - 00001150 _____ C:\Users\SamSwanson\Desktop\AnonVPN.lnk
    2017-02-16 00:59 - 2016-08-12 14:54 - 00000000 ____D C:\Program Files (x86)\AnonVPN
    2017-02-15 22:06 - 2015-01-11 23:36 - 00007710 _____ C:\WINDOWS\system32--traceoff
    2017-02-15 22:04 - 2012-12-27 22:58 - 00000000 ____D C:\Program Files (x86)\PdaNet for Android
    2017-02-15 22:03 - 2014-09-13 15:35 - 00000000 ____D C:\Program Files\iZotope
    2017-02-15 22:03 - 2012-12-25 00:35 - 00000000 ____D C:\Users\SamSwanson\Documents\iZotope
    2017-02-15 22:03 - 2012-12-25 00:32 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope
    2017-02-15 22:03 - 2012-12-25 00:29 - 00000000 ____D C:\Program Files (x86)\iZotope
    2017-02-15 22:03 - 2012-12-24 06:19 - 00000000 ____D C:\Program Files\VSTPlugIns
    2017-02-15 22:02 - 2012-12-23 13:11 - 00000000 ____D C:\Program Files (x86)\Growl for Windows
    2017-02-15 22:01 - 2014-02-12 13:01 - 00000000 ____D C:\Program Files (x86)\NeoSmart Technologies
    2017-02-15 22:01 - 2012-12-24 01:07 - 00000000 __RHD C:\Users\Public\AccountPictures
    2017-02-15 22:00 - 2013-09-12 14:56 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Citrix
    2017-02-15 22:00 - 2013-05-24 22:11 - 00000000 __SHD C:\WINDOWS\SysWOW64\AI_RecycleBin
    2017-02-15 22:00 - 2013-05-24 22:11 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Copy
    2017-02-15 21:59 - 2013-05-26 16:02 - 00000000 ____D C:\Program Files (x86)\Audacity
    2017-02-15 18:43 - 2013-06-20 07:57 - 01418640 _____ C:\WINDOWS\system32\Drivers\fvstore.dat
    2017-02-15 16:50 - 2013-07-14 23:12 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CrystalDiskInfo
    2017-02-15 16:50 - 2013-07-14 23:12 - 00000000 ____D C:\Program Files (x86)\CrystalDiskInfo
    2017-02-13 15:55 - 2013-01-20 16:48 - 00000000 ____D C:\Users\SamSwanson.gconfd
    2017-02-13 15:41 - 2013-01-20 16:48 - 00000000 ____D C:\Users\SamSwanson.gconf
    2017-02-13 15:14 - 2015-06-13 09:16 - 00000000 ____D C:\Program Files\Common Files\AV
    2017-02-13 14:26 - 2016-06-13 13:37 - 00100965 _____ C:\Users\SamSwanson\Documents\VME Accounts Gnucash.gnucash
    2017-02-12 00:07 - 2013-03-09 22:52 - 00000132 _____ C:\Users\SamSwanson\AppData\Roaming\Adobe PNG Format CS5 Prefs
    2017-02-11 16:12 - 2012-12-23 13:01 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Skype
    2017-02-11 16:07 - 2016-06-05 17:05 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\TeamViewer
    2017-02-11 16:07 - 2014-06-15 15:30 - 00000000 ____D C:\Program Files (x86)\Malwarebytes Anti-Malware
    2017-02-11 16:07 - 2012-12-26 18:57 - 00000000 ____D C:\ProgramData\Malwarebytes
    2017-02-11 16:06 - 2016-08-15 15:07 - 00000000 ___RD C:\Program Files (x86)\Skype
    2017-02-11 16:06 - 2012-12-23 12:27 - 00000000 ____D C:\ProgramData\Skype
    2017-02-11 16:04 - 2016-08-11 19:50 - 00003096 _____ C:\WINDOWS\System32\Tasks\Process Lasso Core Engine Only
    2017-02-11 16:04 - 2013-07-10 17:57 - 00000000 ____D C:\Program Files\Process Lasso
    2017-02-11 16:04 - 2012-12-23 12:30 - 00000000 ____D C:\Program Files\Common Files\Apple
    2017-02-11 16:00 - 2016-08-15 14:58 - 00001232 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox.lnk
    2017-02-11 16:00 - 2016-08-15 14:58 - 00000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
    2017-02-11 16:00 - 2013-02-21 13:32 - 00000000 ____D C:\Program Files (x86)\Mozilla Firefox
    2017-02-11 12:25 - 2014-01-12 15:06 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\NVIDIA Corporation
    2017-02-10 22:43 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\InputMethod
    2017-02-10 22:39 - 2015-06-24 20:14 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\mgyun
    2017-02-10 20:20 - 2013-03-14 16:55 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
    2017-02-10 20:20 - 2012-12-23 12:43 - 00000000 ____D C:\ProgramData\NVIDIA Corporation
    2017-02-10 20:17 - 2016-12-16 01:33 - 00111392 _____ C:\WINDOWS\SysWOW64\vulkaninfo-1-1-0-37-0.exe
    2017-02-10 20:17 - 2016-12-16 01:32 - 00125728 _____ C:\WINDOWS\system32\vulkaninfo-1-1-0-37-0.exe
    2017-02-10 20:17 - 2015-12-01 17:32 - 01600056 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvhdagenco6420103.dll
    2017-02-10 20:17 - 2015-12-01 17:32 - 00217528 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvhda64v.sys
    2017-02-10 20:12 - 2012-12-23 12:43 - 00000000 ____D C:\Program Files\NVIDIA Corporation
    2017-02-10 20:11 - 2016-08-11 20:08 - 34974656 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvoglv64.dll
    2017-02-10 20:11 - 2016-08-11 20:08 - 04079032 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvapi64.dll
    2017-02-10 20:11 - 2016-08-11 20:08 - 03597640 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvapi.dll
    2017-02-10 20:11 - 2016-07-16 15:29 - 00420408 _____ (Khronos Group) C:\WINDOWS\SysWOW64\opencl.dll
    2017-02-10 20:11 - 2012-12-23 12:43 - 00514616 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.dll
    2017-02-10 20:01 - 2013-07-05 05:36 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\NVIDIA
    2017-02-10 20:01 - 2012-12-23 12:43 - 00000000 ____D C:\Program Files (x86)\NVIDIA Corporation
    2017-02-10 18:50 - 2013-09-17 09:45 - 00000000 ____D C:\ProgramData\Ashampoo
    2017-02-10 18:50 - 2013-02-23 16:34 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Smart PC Solutions
    2017-02-10 18:50 - 2013-02-23 16:34 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Smart PC Solutions
    2017-02-10 13:34 - 2016-11-22 08:52 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Booster 4
    2017-02-09 15:39 - 2015-12-20 01:44 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\boost_interproce ss
    2017-02-09 15:39 - 2012-12-24 02:10 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Celemony Software GmbH
    2017-02-08 23:41 - 2012-12-24 06:23 - 00000000 ____D C:\ProgramData\Slate Digital
    2017-02-08 19:27 - 2016-03-02 16:15 - 00001919 _____ C:\Users\Public\Documents\Lurssen TimeLimitReadExpiration.txt
    2017-02-08 19:27 - 2016-03-02 16:15 - 00000292 _____ C:\Users\Public\Documents\Lurssen TimeLimitGenerateLockNames Log.txt
    2017-02-08 19:27 - 2016-03-02 16:15 - 00000095 _____ C:\Users\Public\Documents\Lorssen Log.txt
    2017-02-08 19:27 - 2016-03-02 16:15 - 00000069 _____ C:\Users\Public\Documents\Lurssen CopyProt Log.txt
    2017-02-08 19:27 - 2016-03-02 16:15 - 00000008 _____ C:\Users\Public\Documents\Lurssen TimeLimitWriteOneProductSettings.txt
    2017-02-08 10:42 - 2017-01-04 15:19 - 01964600 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispco6437653.dll
    2017-02-08 10:42 - 2017-01-04 15:19 - 01600056 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispgenco6437653.dll
    2017-02-07 17:49 - 2013-06-27 14:37 - 00005632 _____ C:\Users\SamSwanson\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    2017-02-06 20:48 - 2014-08-27 13:28 - 00002272 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
    2017-02-03 20:31 - 2013-05-26 16:03 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Audacity
    2017-02-03 11:38 - 2015-06-30 19:18 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\ssd_sampler
    2017-02-02 16:48 - 2012-12-22 22:13 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVS4YOU
    2017-02-02 16:48 - 2012-12-22 22:13 - 00000000 ____D C:\Program Files (x86)\AVS4YOU
    2017-02-02 16:47 - 2012-12-22 22:14 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\AVS4YOU
    2017-02-02 16:46 - 2012-12-22 22:13 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\AVS4YOU
    2013-01-09 05:51 - 2012-10-02 21:03 - 2712200 _____ (Sysinternals - www.sysinternals.com) C:\Program Files\procexp.exe
    2016-10-29 19:23 - 2016-10-29 19:23 - 2722286 _____ () C:\Program Files (x86)\Auto-Tune 8 Manual.pdf
    2016-10-29 19:23 - 2016-10-29 19:23 - 0056051 _____ () C:\Program Files (x86)\VST PC Read Me.pdf
    2013-07-29 18:50 - 2013-07-29 18:50 - 0000132 _____ () C:\Users\SamSwanson\AppData\Roaming\Adobe BMP Format CS5 Prefs
    2013-06-11 13:27 - 2015-08-13 11:46 - 0000132 _____ () C:\Users\SamSwanson\AppData\Roaming\Adobe GIF Format CS5 Prefs
    2013-03-09 22:52 - 2017-02-12 00:07 - 0000132 _____ () C:\Users\SamSwanson\AppData\Roaming\Adobe PNG Format CS5 Prefs
    2014-02-12 22:10 - 2014-02-12 22:10 - 0000005 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_496F4C99-60AD-5b9e-AC1B-FA060E643C04.dll
    2014-02-12 22:10 - 2014-02-12 22:10 - 0000013 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_72024697-2626-4a12-8347-7CAC1834AC3B.dll
    2014-02-12 22:10 - 2014-02-12 22:10 - 0000013 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_D9C6A609-15A1-4768-8E98-6FA00C2547CC.dll
    2014-02-12 22:10 - 2014-02-12 22:10 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_F4F01109-C336-401f-BDE4-7C1926744104.dll
    2014-02-12 22:10 - 2014-02-12 22:10 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_FAB01109-C336-401f-BDE4-AB1926744111.dll
    2014-01-26 19:56 - 2014-01-26 19:56 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_FB9AECF7-F56E-7B2E-A862-9892AA545103.dll
    2016-06-13 10:39 - 2017-03-01 15:42 - 0000096 _____ () C:\Users\SamSwanson\AppData\Roaming\msregsvv.dll
    2016-04-24 21:15 - 2016-06-09 10:20 - 0033783 _____ () C:\Users\SamSwanson\AppData\Roaming\net.telestream .wirecast.xml
    2013-06-27 14:37 - 2017-02-07 17:49 - 0005632 _____ () C:\Users\SamSwanson\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    2015-03-17 14:25 - 2015-03-17 14:25 - 0000600 _____ () C:\Users\SamSwanson\AppData\Local\PUTTY.RND
    2016-06-15 14:58 - 2016-06-15 14:58 - 0000218 _____ () C:\Users\SamSwanson\AppData\Local\recently-used.xbel
    2016-02-15 14:24 - 2017-02-20 17:51 - 0007602 _____ () C:\Users\SamSwanson\AppData\Local\Resmon.ResmonCfg
    2014-01-22 13:15 - 2017-03-01 15:42 - 0000128 _____ () C:\ProgramData\autobk.inc
    2016-08-11 19:35 - 2016-08-11 19:35 - 0000000 ____H () C:\ProgramData\DP45977C.lfl
    2014-01-22 11:21 - 2014-01-22 11:21 - 0000123 _____ () C:\ProgramData\Microsoft.SqlServer.Compact.351.32. bc
    2014-01-22 02:03 - 2014-01-22 02:04 - 0000454 _____ () C:\ProgramData\Microsoft.SqlServer.Compact.400.32. bc
    2016-03-03 11:42 - 2017-01-03 10:19 - 0000253 _____ () C:\ProgramData\SoundToys_Problem_Log.txt
    [HEADING=1]Some files in TEMP:[/HEADING]
    2017-03-01 10:32 - 2016-12-09 12:17 - 1886344 _____ (Microsoft Corporation) C:\Users\SamSwanson\AppData\Local\Temp\dllnt_dump. dll
    LastRegBack: 2017-02-21 11:10
    Addition:
    Additional scan result of Farbar Recovery Scan Tool (x64) Version: 01-03-2017
    Ran by SamSwanson (01-03-2017 17:44:34)
    Running from C:\Users\SamSwanson\Desktop\Computer fix
    Windows 10 Pro Version 1607 (X64) (2016-08-11 18:53:40)
    Boot Mode: Normal
    Administrator (S-1-5-21-3236326594-2611474830-2656184370-500 - Administrator - Disabled)
    DefaultAccount (S-1-5-21-3236326594-2611474830-2656184370-503 - Limited - Disabled)
    Guest (S-1-5-21-3236326594-2611474830-2656184370-501 - Limited - Disabled)
    SamSwanson (S-1-5-21-3236326594-2611474830-2656184370-1001 - Administrator - Enabled) => C:\Users\SamSwanson
    AV: Webroot SecureAnywhere (Enabled - Up to date) {4646A877-74EB-CD3B-8FDB-210DB94FA61A}
    AV: Malwarebytes (Enabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
    AS: Webroot SecureAnywhere (Enabled - Up to date) {FD274993-52D1-C2B5-B56B-1A7FC2C8ECA7}
    AS: Malwarebytes (Enabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
    FW: COMODO Firewall (Enabled) {E8F7F446-E1BD-DFE6-38D1-54E0ADE01D89}
    +10db version 1.0.4 (HKLM...+10db_is1) (Version: 1.0.4 - Boz Digital Labs)
    112dB Big Blue Compressor 1.0.3-r3719 (HKLM...\112dB Big Blue Compressor 1.0.3-r3719) (Version: 1.0.3-r3719 - 112dB)
    112dB Big Blue Limiter 1.1.3-r3719 (HKLM...\112dB Big Blue Limiter 1.1.3-r3719) (Version: 1.1.3-r3719 - 112dB)
    112dB Redline Equalizer 1.0.5-r3719 (HKLM...\112dB Redline Equalizer 1.0.5-r3719) (Version: 1.0.5-r3719 - 112dB)
    112dB Redline Reverb 1.0.10-r3810 (HKLM...\112dB Redline Reverb 1.0.10-r3810) (Version: 1.0.10-r3810 - 112dB)
    2C-Audio Aether (HKLM-x32...\Aether) (Version: - )
    2C-Audio Breeze (HKLM-x32...\Breeze) (Version: - 2C-Audio)
    6030 Ultimate Comp Native (HKLM-x32...{96B75FC3-D48A-4F8B-8BC7-5C2728797E4E}) (Version: 6.0.9 - McDSP)
    7-Zip 16.04 (x64 edition) (HKLM...{23170F69-40C1-2702-1604-000001000000}) (Version: 16.04.00.0 - Igor Pavlov)
    AATranslator (HKLM-x32...{7400C259-1F2E-4FF2-9037-860BF239F39D}) (Version: 4.0.0.2 - Suite Spot Studios)
    Abbeyroadplugins EMI Brilliance Pack VST RTAS v1.0.6 (HKLM-x32...\Abbeyroadplugins EMI Brilliance Pack VST RTAS_is1) (Version: - )
    Abbeyroadplugins EMI RS 124 Compressor VST RTAS v1.0.1 (HKLM-x32...\Abbeyroadplugins EMI RS 124 Compressor_is1) (Version: - )
    Abbeyroadplugins EMI TG 12413 Limiter VST RTAS v2.0.1 (HKLM-x32...\Abbeyroadplugins EMI TG 12413 Limiter VST RTAS_is1) (Version: - )
    Abbeyroadplugins EMI TG Mastering Pack VST RTAS v1.0.2 (HKLM-x32...\Abbeyroadplugins EMI TG Mastering Pack VST RTAS_is1) (Version: - )
    Ableton Live 9 Suite (HKLM...{48EC4E57-1D04-4831-90A7-151DA2269495}) (Version: 9.0.0.0 - Ableton)
    Acronis True Image (HKLM-x32...{E5F28743-0DB5-42C1-8B70-5986D88C0BE0}Visible) (Version: 19.0.6581 - Acronis)
    Acronis True Image (x32 Version: 19.0.6581 - Acronis) Hidden
    acustica AcquaVox (HKLM-x32...\AcquaVox) (Version: - )
    Acustica Audio D361A (HKLM-x32...\D361A Win x64) (Version: 1.3.609.0 - Acustica Audio)
    Acustica Audio EQP1 (HKLM-x32...\EQP1 Win x64) (Version: 1.3.606.0 - Acustica Audio)
    Acustica Audio NEO (HKLM-x32...\NEO Win x64) (Version: 1.3.606.0 - Acustica Audio)
    Acustica Audio REDEQ (HKLM-x32...\REDEQ Win x64) (Version: 1.3.760.0 - Acustica Audio)
    Acustica Audio TAN (HKLM-x32...\TAN Win x64) (Version: 1.4.072.0 - Acustica Audio)
    Acustica Audio TITANIUM3B (HKLM-x32...\TITANIUM3B Win x64) (Version: 1.3.827.0 - Acustica Audio)
    Acustica Audio TRINITYEQ (HKLM-x32...\TRINITYEQ Win x64) (Version: 1.3.687.0 - Acustica Audio)
    AcusticaAudio Nebula3 (HKLM-x32...\Nebula3) (Version: - )
    Adobe After Effects CS4 (HKLM-x32...\Adobe_3dcb365ab9e01871fb8c6f27b0ea079) (Version: 9 - Adobe Systems Incorporated)
    Adobe AIR (HKLM-x32...\Adobe AIR) (Version: 24.0.0.180 - Adobe Systems Incorporated)
    Adobe Flash Player 24 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 24.0.0.221 - Adobe Systems Incorporated)
    Adobe Flash Player 24 PPAPI (HKLM-x32...\Adobe Flash Player PPAPI) (Version: 24.0.0.221 - Adobe Systems Incorporated)
    Adobe Photoshop Lightroom 5 64-bit (HKLM...{6C1A010F-9108-4162-A26F-9FEC4AC0F0F0}) (Version: 5.0.1 - Adobe)
    Adobe Shockwave Player 12.2 (HKLM-x32...{A2116AF9-FA9D-41EA-9874-1E40B227D4DE}) (Version: 12.2.5.195 - Adobe Systems, Inc)
    AI Suite II (HKLM-x32...{34D3688E-A737-44C5-9E2A-FF73618728E1}) (Version: 2.01.02 - ASUSTeK Computer Inc.)
    Altiverb 7 Uninstaller (HKLM...{367662CA-394A-4095-9549-973FC3807B9B}_is1) (Version: 7.2 - Audio Ease BV)
    Amazon Kindle (HKLM-x32...\Amazon Kindle) (Version: - Amazon)
    Amazon Kindle (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Amazon Kindle) (Version: - Amazon)
    AmpegSVX (HKLM-x32...{CF1D7323-8A0A-49C7-83B0-088DB90721E2}) (Version: 1.1.3 - IK Multimedia)
    AmpliTube 3 version 3.11.0 (HKLM...{DA5202AC-12BF-4330-B8EA-BC77F991FA1C}_is1) (Version: 3.11.0 - IK Multimedia)
    AmpliTube 4 version 4.0.1 (HKLM...{21B0C8E0-7EB7-4832-B764-20A7DAE86E02}_is1) (Version: 4.0.1 - IK Multimedia)
    AnonVPN 1.0.5.5 (HKLM-x32...\AnonVPN) (Version: 1.0.5.5 - AnonVPN.io)
    Ansel (Version: 378.49 - NVIDIA Corporation) Hidden
    Antares Autotune Evo VST RTAS v6.0.9 (HKLM-x32...\Antares Autotune Evo VST RTAS_is1) (Version: - )
    Antares AVOX Evo VST RTAS v3.0.2 (HKLM-x32...\Antares AVOX Evo VST RTAS_is1) (Version: - )
    Apple Application Support (32-bit) (HKLM-x32...{9BA1A894-B42F-4805-BC8C-349C905A3930}) (Version: 5.3.1 - Apple Inc.)
    Apple Application Support (64-bit) (HKLM...{7EAC8A42-9FAC-4F6B-AABF-C08C9F2E0F13}) (Version: 5.3.1 - Apple Inc.)
    Apple Mobile Device Support (HKLM...{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
    Apple Software Update (HKLM-x32...{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
    ARC System 2 version 2.1.0 (HKLM...{4952A610-D484-4F6A-B1B4-33797CFDB821}_is1) (Version: 2.1.0 - IK Multimedia)
    ArcSoft Portrait+ 3 (HKLM-x32...{40BB5B1A-6008-4348-8C24-116B654C7ECD}) (Version: 3.0.0.401 - ArcSoft)
    ARIA Engine v1.8.4.8 (HKLM...\ARIA Engine_is1) (Version: v1.8.4.8 - Plogue Art et Technologie, Inc)
    Articulate Storyline (x32 Version: 1.02.02 - Articulate) Hidden
    ASIO Bridge and Hi-Fi Cable (HKLM-x32...\VB:ASIOBridge {17359A74-1236-5467}) (Version: - VB-Audio Software)
    ASIO4ALL (HKLM-x32...\ASIO4ALL) (Version: 2.11 Beta2 - Michael Tippach)
    Assassin’s Creed(R) III v1.03 (HKLM-x32...{9D15E813-0C26-41E7-ABC5-3EB06FF1B3CF}) (Version: 1.03 - Ubisoft)
    Atheros Driver Installation Program (HKLM-x32...{C3A32068-8AB1-4327-BB16-BED9C6219DC7}) (Version: 10.0 - Atheros)
    atomiccleaner3 version 1.3.4.1 (HKLM-x32...{0D6AB211-A181-4F42-AEB4-127C40BF67EF}_is1) (Version: 1.3.4.1 - atomicware)
    AudioEase Altiverb VST RTAS v6.12 (HKLM-x32...\AudioEase Altiverb VST RTAS_is1) (Version: - )
    AudioEase Speakersphone VST RTAS v1.03 (HKLM-x32...\AudioEase Speakersphone VST RTAS_is1) (Version: - Audio Ease)
    Avid Effects (HKLM-x32...{A86F1158-A7F7-4E8C-98E3-88F4996E85EB}) (Version: 10.3.10 - Avid Technology, Inc.)
    Avid HD Driver (x64) (HKLM...{01C898E1-38A7-49B1-9398-49E40636E2C5}) (Version: 9.0 - Avid Technology, Inc.)
    Avid HD Driver (x64) (HKLM...{658E112A-8776-4430-A275-D9248732DFB9}) (Version: 10.3.10 - Avid Technology, Inc.)
    Avid Mbox Driver 1.1.10 (x64) (HKLM...{35BAD2B7-E2EF-4A06-80A2-C6C2F23B8F3E}) (Version: 1.1.10 - Avid)
    Avid Pro Tools (HKLM-x32...{8E60BB71-7EF3-42ED-9F10-AA041F25841A}) (Version: 10.3.10 - Avid Technology, Inc.)
    AVOX Evo VST (HKLM-x32...{65AA5B18-A330-4F35-BCDF-EA85EC888906}) (Version: 3.0.0 - Antares Audio Technologies)
    AVS Audio Converter 7 (HKLM-x32...\AVS Audio Converter_is1) (Version: 7.0.5.510 - Online Media Technologies Ltd.)
    Black Rooster Audio Plugin Pack (HKLM...\Black Rooster Audio Plugin Pack_is1) (Version: - Black Rooster Audio)
    BWF MetaEdit 1.3.0 (HKLM...\BWF MetaEdit) (Version: 1.3.0 - FADGI)
    calibre 64bit (HKLM...{82EA8033-0AE6-4C1A-91B6-D24BED49AB73}) (Version: 2.79.1 - Kovid Goyal)
    Call of Duty 4: Modern Warfare (HKLM-x32...\Steam App 7940) (Version: - Infinity Ward)
    Call of Duty: Modern Warfare 3 (HKLM-x32...\Steam App 42680) (Version: - Infinity Ward - Sledgehammer Games)
    CameraHelperMsi (x32 Version: 13.51.815.0 - Logitech) Hidden
    Camtasia Studio 8 (HKLM-x32...{2B1F8DD0-873D-4AC3-8400-766F255FE263}) (Version: 8.1.0.1281 - TechSmith Corporation)
    Carbonite (HKLM-x32...{C7D98EFB-A351-4098-B474-1A5B362DB648}) (Version: 6.2.2 build 6819 (Jan-25-2017) - Carbonite)
    CCleaner (HKLM...\CCleaner) (Version: 5.27 - Piriform)
    CDSoundMaster NICE-EQ-VST-TUBE-FREE (HKLM-x32...\NICE-EQ-VST-TUBE-FREE) (Version: - )
    CDSoundMaster N-TEN-AT4-Bell-Free-64 (HKLM-x32...\N-TEN-AT4-Bell-Free-64) (Version: - )
    CDS-VTC-FREE-PC-VST-64-BIT THE-VINTAGE-TUBE-COLLECTION-FREE-PC-VST-64-BIT (HKLM-x32...\THE-VINTAGE-TUBE-COLLECTION-FREE-PC-VST-64-BIT) (Version: - )
    Celemony Melodyne Studio 4 (HKLM-x32...\Celemony Melodyne Studio 4) (Version: 4.0.4.004 - Celemony)
    COMODO Internet Security (HKLM...{0E9AFD45-C3BA-41D1-B54B-495A22CB3409}) (Version: 6.0.64131.2674 - COMODO Security Solutions Inc.)
    CP Control (HKLM-x32...\CP Control) (Version: - )
    CrystalDiskInfo 7.0.5 Shizuku Edition (HKLM-x32...\CrystalDiskInfo_is1) (Version: 7.0.5 - Crystal Dew World)
    Custom Shop version 1.7.0 (HKLM-x32...{21BAD046-50EC-49E2-BE7B-F9729704F2C3}_is1) (Version: 1.7.0 - IK Multimedia)
    D16 Group Repeater (HKLM...\Repeater_is1) (Version: 1.0.0 - D16 Group)
    DAEMON Tools Lite (HKLM...\DAEMON Tools Lite) (Version: 10.1.0.0074 - Disc Soft Ltd)
    Dashlane (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Dashlane) (Version: 4.6.7.25343 - Dashlane SAS)
    Day of Defeat: Source (HKLM-x32...\Steam App 300) (Version: - Valve)
    Diamond Cut Forensics8 (HKLM-x32...{38C8BBB6-716E-4486-A386-C8D3242959C5}) (Version: 8.10 - Diamond Cut Productions)
    DisplayFusion 5.0 (HKLM-x32...\B076073A-5527-4f4f-B46B-B10692277DA2_is1) (Version: 5.0.0.0 - Binary Fortress Software)
    Ditto (HKLM-x32...\Ditto_is1) (Version: - Scott Brogden)
    DivX Setup (HKLM-x32...\DivX Setup) (Version: 2.7.0.31 - DivX, LLC)
    DMG Audio Track Range (HKLM...\Track Range_is1) (Version: 1.0.0 - DMG Audio)
    DMGAudio EQuilibrium 1.04 (HKLM-x32...\DMGAudio EQuilibrium_is1) (Version: - DMGAudio)
    DMGAudio Essence 1.00 (HKLM-x32...\DMGAudio Essence_is1) (Version: - DMGAudio)
    DMGAudio Limitless 1.00 (HKLM-x32...\DMGAudio Limitless_is1) (Version: - DMGAudio)
    DragonDisk 1.05 (HKLM-x32...{7914B94-1234-44D2-0864-0348EBF012AC}_is1) (Version: - Almageste)
    Dropbox (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Dropbox) (Version: 2.10.46 - Dropbox, Inc.)
    Drum Leveler version 1.0.0 (HKLM...{94B8FDA3-877B-4EB8-A3E9-5D476329F15D}is1) (Version: 1.0.0 - Sound Radix)
    East West Stormdrum Intakt (HKLM-x32...\East West Stormdrum Intakt) (Version: - )
    Easy Tune 6 B12.0912.1 (HKLM-x32...\InstallShield
    {457D7505-D665-4F95-91C3-ECB8C56E9ACA}) (Version: 1.00.0000 - GIGABYTE)
    Easy Tune 6 B12.0912.1 (x32 Version: 1.00.0000 - GIGABYTE) Hidden
    ElastikVst (HKLM-x32...{92F027CB-BDF9-4047-A654-13A050908158}) (Version: 1.00.0000 - ueberschall sample service GmbH)
    ElastikVst (x32 Version: 1.00.0000 - ueberschall sample service GmbH) Hidden
    Electrum (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Electrum) (Version: 2.7.12 - Electrum Technologies GmbH)
    EmpressPlugins.Tremolo.VST.v1.0 (HKLM-x32...\EmpressPlugins Tremolo_is1) (Version: - )
    eReg (x32 Version: 1.20.138.34 - Logitech, Inc.) Hidden
    f.lux (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Flux) (Version: - )
    FabFilter Pro-C 2.00 (64-bit) (HKLM-x32...\FabFilter Pro-C 2.00 (64-bit)) (Version: - )
    FG-X (HKLM...\Slate Digital FG-X_is1) (Version: - Slate Digital)
    FG-X Virtual Mastering Console (HKLM...\FG-X Virtual Mastering Console_is1) (Version: - Slate Digital)
    Fidelify (HKLM-x32...\Fidelify) (Version: - )
    FileMenu Tools (HKLM...\FileMenu Tools_is1) (Version: - LopeSoft - Rubén López Hernández)
    FileZilla Client 3.24.0 (HKLM-x32...\FileZilla Client) (Version: 3.24.0 - Tim Kosse)
    Finale NotePad 2012 (HKLM-x32...\Finale NotePad 2012) (Version: 2012..r1.5 - MakeMusic)
    FlowStone FL 3.0 (HKLM-x32...\FlowStone) (Version: - )
    Flux Full Pack 2.2 (HKLM...\Full Pack 2.2_is1) (Version: 3.5.25.44238 - Flux)
    Flux Junger Audio Level Magic 5.1 (HKLM-x32...\Flux Junger Audio Level Magic 5.1) (Version: 3.4.6 - Flux)
    Folder Marker Free (HKLM...\Folder Marker Free_is1) (Version: 3.2 - ArcticLine Software)
    Genwaveaudio Genwave EQ VST v1.0 (HKLM-x32...\Genwaveaudio Genwave EQ VST_is1) (Version: - )
    GIZMO (HKLM-x32...{D0529F5A-C45C-40C0-8457-6A5AF24ABC6E}) (Version: 3.21.4000 - ants Inc.)
    Gizmo Central (HKLM-x32...\Gizmo Central) (Version: v2.7.9 - Arainia Solutions, LLC)
    GnuCash 2.4.11 (HKLM-x32...\GnuCash_is1) (Version: - GnuCash Development Team)
    Gobbler (HKLM-x32...{C7CE54DC-7AD2-48A8-BB2E-F7C6A8E40BB5}) (Version: 0.21.75.0 - Media Gobbler, Inc.)
    Google Chrome (HKLM-x32...\Google Chrome) (Version: 56.0.2924.87 - Google Inc.)
    Google Chrome Canary (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Google Chrome SxS) (Version: 58.0.3026.0 - Google Inc.)
    Google Talk (remove only) (HKLM-x32...{226b64e8-dc75-4eea-a6c8-abcb496320f2}-Google Talk) (Version: - )
    Google Talk Plugin (HKLM-x32...{8E29C1CE-346A-3F59-AE22-8C5B7F230498}) (Version: 5.3.1.18536 - Google)
    Google Update Helper (x32 Version: 1.3.25.11 - Google Inc.) Hidden
    Google Update Helper (x32 Version: 1.3.32.7 - Google Inc.) Hidden
    GoToMeeting 7.31.0.6291 (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\GoToMeeting) (Version: 7.31.0.6291 - CitrixOnline)
    HandBrake 0.10.5 (HKLM-x32...\HandBrake) (Version: 0.10.5 - )
    Head Crusher version 1.6 (HKLM...\Head Crusher_is1) (Version: 1.6 - )
    Helium Audio Converter (build 461) (HKLM-x32...{8CF3206B-6330-42D6-B35E-CA7098337CB8}_is1) (Version: 2.0.0.461 - Imploded Software)
    HFSExplorer 0.21 (HKLM-x32...\HFSExplorer) (Version: 0.21 - Catacombae Software)
    HoRNet AutoGain Pro MK2 (HKLM...\AutoGain Pro MK2_is1) (Version: 2.0.1 - HoRNet)
    IK Multimedia Authorization Manager version 1.0.15 (HKLM...{85BC0DCB-69E5-4279-AA25-F108EF896588}is1) (Version: 1.0.15 - IK Multimedia)
    iLok Client Helper (HKLM-x32...\InstallShield
    {DEA491FB-48BC-4B6B-8902-FCD4BAB069BE}) (Version: 5.9.7 - PACE Anti-Piracy, Inc.)
    iLok Client Helper (x32 Version: 5.9.7 - PACE Anti-Piracy, Inc.) Hidden
    Imperial Delay version 1.5.8 (HKLM...\Imperial Delay_is1) (Version: 1.5.8 - )
    Intel Extreme Tuning Utility (HKLM-x32...{7360EE49-7004-4626-A85A-CC48C2D63700}) (Version: 3.2.0.24 - Intel Corporation)
    Intel(R) C++ Redistributables on IA-32 (HKLM-x32...{7858618B-FA45-4797-988D-4E8B793C3B88}) (Version: 17.0.109 - Intel Corporation)
    Intel(R) C++ Redistributables on Intel(R) 64 (HKLM-x32...{A7D3C4B3-2CA8-46F3-9C34-63205AC018FF}) (Version: 17.0.109 - Intel Corporation)
    Intel(R) Chipset Device Software (x32 Version: 10.0.27 - Intel(R) Corporation) Hidden
    Intel(R) Management Engine Components (HKLM-x32...{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.23.1766 - Intel Corporation)
    Intel(R) Network Connections 18.6.110.0 (HKLM...\PROSetDX) (Version: 18.6.110.0 - Intel)
    Intel(R) Processor Graphics (HKLM-x32...{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 9.17.10.2932 - Intel Corporation)
    Intel(R) Smart Connect Technology 3.0 x64 (HKLM...{DE788AD4-F7CE-4995-ADF8-56174A7B613C}) (Version: 3.0.41.1571 - Intel)
    Intel(R) Technology Access (HKLM-x32...{810dff4d-564d-47da-b8bc-a3729815aab7}) (Version: 1.9.1.1008 - Intel Corporation)
    Intel(R) Technology Access Software Asset Manager (x32 Version: 3.4.1942 - Intel Corporation) Hidden
    Intel(R) Update Manager (HKLM-x32...{7224B7CE-196C-4E2A-A1AE-1D7BF259FD36}) (Version: 3.4.1942 - Intel Corporation)
    Intel® Watchdog Timer Driver (Intel® WDT) (HKLM-x32...{3FD0C489-0F02-481a-A3E1-9754CD396761}) (Version: - Intel Corporation)
    ISL (HKLM...\ISL_is1) (Version: - NUGEN Audio)
    iTunes (HKLM...{9D0D2A8B-7E7B-4D88-8D50-24286ED6A5EB}) (Version: 12.5.5.5 - Apple Inc.)
    IVGI version 1.0.0 (HKLM...\IVGI_is1) (Version: 1.0.0 - )
    Ivideon Server (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Ivideon Server) (Version: 3.5.6.1213 - Ivideon)
    iZotope BreakTweaker (HKLM-x32...\iZotope BreakTweaker_is1) (Version: 1.00 - iZotope, Inc.)
    iZotope BreakTweaker Factory Content (HKLM-x32...\iZotope BreakTweaker Factory Content_is1) (Version: 1.00 - iZotope, Inc.)
    iZotope Insight (HKLM-x32...\iZotope Insight_is1) (Version: 1.00 - iZotope, Inc.)
    iZotope Nectar 2 Production Suite (HKLM-x32...\iZotope Nectar 2 Production Suite_is1) (Version: 2.00 - iZotope, Inc.)
    iZotope Ozone 6 Advanced (HKLM-x32...\iZotope Ozone 6 Advanced_is1) (Version: 6.00 - iZotope, Inc.)
    iZotope Ozone 7 Advanced (HKLM-x32...\iZotope Ozone 7 Advanced 7.00) (Version: 7.00 - iZotope, Inc.)
    iZotope RX 5 (HKLM-x32...\iZotope RX 5_is1) (Version: 5.01 - iZotope, Inc.)
    iZotope Trash 2 (HKLM-x32...\iZotope Trash 2_is1) (Version: 2.00 - iZotope, Inc.)
    iZotope Vinyl (HKLM-x32...\iZotope Vinyl_is1) (Version: 1.61 - iZotope, Inc.)
    iZotope VocalSynth (HKLM-x32...\VocalSynth 1.0) (Version: 1.0 - iZotope, Inc.)
    Jack (HKLM-x32...\Jack) (Version: - )
    Java 8 Update 121 (64-bit) (HKLM...{26A24AE4-039D-4CA4-87B4-2F64180121F0}) (Version: 8.0.1210.13 - Oracle Corporation)
    Kazrog LLC Recabinet 3 VST RTAS v3.1.0 (HKLM...\Kazrog LLC Recabinet 3_is1) (Version: - )
    KD Niche Finder (HKLM-x32...\KD Niche Finder1.0.0.2) (Version: 1.0.0.2 - AppBreed Software of InnAnTech Industries Inc.)
    KDPublishingPro (HKLM-x32...{067A07C1-7A31-4881-B53D-DF4CBB865112}) (Version: 1.4.12 - KDPublishingPro.com)
    KDPublishingPro (HKLM-x32...{215E8D21-F375-4D03-A31F-79CBE44FFB4A}) (Version: 1.2.8 - KDPublishingPro.com)
    KDSubmitterPro (HKLM-x32...{E1817648-6DF6-400F-BD1B-B5D9E9BD745D}) (Version: 1.0.0 - KDSubmitterPro.com)
    Kindle DRM Removal (HKLM-x32...\KindleDRMRemoval) (Version: 1.4.1 - eBook Converter)
    Kits Configuration Installer (x32 Version: 8.59.25584 - Microsoft) Hidden
    K-Lite Codec Pack 9.6.0 (64-bit) (HKLM...\KLiteCodecPack64_is1) (Version: 9.6.0 - )
    K-Lite Codec Pack 9.6.0 (Full) (HKLM-x32...\KLiteCodecPack_is1) (Version: 9.6.0 - )
    Kush Audio Clariphonic v1.0 (HKLM...\Clariphonic_is1) (Version: - Kush Audio)
    Lexicon PSP 42 64bit (HKLM...\Lexicon PSP 42 64bit) (Version: 1.6.2 64bit - PSPaudioware.com)
    Liquid Notes version 1.5.2.1 (HKLM...{5AC1D63D-6772-417E-B7B8-1E5F686D9703}_is1) (Version: 1.5.2.1 - Re-Compose)
    Litecoin (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Litecoin) (Version: 0.8.5.1 - Litecoin project)
    Litecoin Core (64-bit) (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Litecoin Core (64-bit)) (Version: 0.10.4.0 - Litecoin Core project)
    Logitech Gaming Software 8.40 (HKLM...\Logitech Gaming Software) (Version: 8.40.83 - Logitech Inc.)
    Logitech SetPoint 6.61 (HKLM...\sp6) (Version: 6.61.15 - Logitech)
    Logitech Webcam Software (HKLM-x32...{D40EB009-0499-459c-A8AF-C9C110766215}) (Version: 2.80 - Logitech Inc.)
    LoopBe30 - Internal MIDI Ports (HKLM-x32...\LoopBe30) (Version: - )
    Lurssen Mastering Console version 1.0.0 (HKLM...{9F525466-89DA-4B7B-BD8C-BBFDC4432DFB}_is1) (Version: 1.0.0 - IK Multimedia)
    M30 Reverb (HKLM-x32...\M30 Reverb) (Version: 1.0.0.1 - TC Electronic)
    MacDrive 9 Pro (HKLM...{C1521748-8700-4CA0-92F1-46CE26DEDC7D}) (Version: 9.0.4.21 - Mediafour Corporation)
    Magic AB VST-x64 1.2.2 (HKLM...{6893EEE5-B48F-47a9-81DC-CD54E7767B35}) (Version: 1.2.2 - Sample Magic)
    Malwarebytes version 3.0.6.1469 (HKLM...{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.0.6.1469 - Malwarebytes)
    Manic Compressor version 1.0.3 (HKLM...\Manic Compressor_is1) (Version: 1.0.3 - )
    Market Samurai (HKLM-x32...\MarketSamurai.6E37012E1CBD7F47B14488FCC7159 44F3EBDCEDC.1) (Version: 0.92.51 - Alliance Software Pty Ltd)
    Market Samurai (x32 Version: 0.92.51 - Alliance Software Pty Ltd) Hidden
    marvell 91xx driver (HKLM-x32...\MagniDriver) (Version: 1.2.0.1027 - Marvell)
    Massey VST Demos (Remove only) (HKLM-x32...\Massey VST Demos) (Version: - )
    MathewLane DrMS Spatial Processor VST RTAS v3.2 (HKLM-x32...\MathewLane DrMS Spatial Processor_is1) (Version: - )
    M-Audio Oxygen Driver 1.2.1 (x64) (HKLM...{6F0B8408-835B-4A55-A429-EB899AD68467}) (Version: 1.2.1 - M-Audio)
    Maxthon Cloud Browser (HKLM-x32...\Maxthon3) (Version: 4.0.3.1000 - Maxthon International Limited)
    McGill English Dictionary of Rhyme & Verse Perfect 2.0 (HKLM-x32...\McGill English Dictionary of Rhyme with VersePer~286A7AE6_is1) (Version: - Bryant McGill / McGill International)
    MeldaProduction Audio Plugins 10 (HKLM-x32...\MeldaProduction Audio Plugins 10) (Version: - MeldaProduction)
    MeldaProduction MTotalBundle64 8 (HKLM-x32...\MeldaProduction MTotalBundle64 8) (Version: - MeldaProduction)
    Melodyne 3.2 (HKLM-x32...{A1F143D1-1F0D-44FB-A44B-71D4367D16DE}) (Version: 3.2.0202 - Celemony Software GmbH)
    Melodyne 3.2 (x32 Version: 3.2.0202 - Celemony Software GmbH) Hidden
    MetaTrader 5 (HKLM...\MetaTrader 5) (Version: 5.00 - MetaQuotes Software Corp.)
    Mic Mod EFX VST (HKLM-x32...{A77728D4-DF6E-42A9-926C-5164BBF1EA72}) (Version: 1.0.4 - Antares Audio Technologies)
    Microsoft ASP.NET MVC 4 Runtime (HKLM-x32...{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
    Microsoft Office Professional Plus 2013 (HKLM...\Office15.PROPLUS) (Version: 15.0.4569.1506 - Microsoft Corporation)
    Microsoft OneDrive (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\OneDriveSetup.exe) (Version: 17.3.6743.1212 - Microsoft Corporation)
    Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM...{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
    Microsoft Visual C++ 2005 Redistributable (HKLM-x32...{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
    Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
    Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}) (Version: 8.0.61000 - Microsoft Corporation)
    Microsoft Visual C++ 2008 Redistributable - x64 9.0.21022 (HKLM...{350AA351-21FA-3270-8B7A-835434E766AD}) (Version: 9.0.21022 - Microsoft Corporation)
    Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022 (HKLM-x32...{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}) (Version: 9.0.21022 - Microsoft Corporation)
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022.218 (HKLM-x32...{E503B4BF-F7BB-3D5F-8BC8-F694B1CFF942}) (Version: 9.0.21022.218 - Microsoft Corporation)
    Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729 (HKLM-x32...{820B6609-4C97-3A2B-B644-573B06A0F0CC}) (Version: 9.0.30729 - Microsoft Corporation)
    Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32...{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
    Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32...{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
    Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24212 (HKLM-x32...{323dad84-0974-4d90-a1c1-e006c7fdbb7d}) (Version: 14.0.24212.0 - Microsoft Corporation)
    Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24212 (HKLM-x32...{462f63a8-6347-4894-a1b3-dbfe3a4c981d}) (Version: 14.0.24212.0 - Microsoft Corporation)
    Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
    Microsoft Web Platform Installer 4.6 (HKLM...{16C7D2AD-20CA-491E-80BC-8607A9AACED9}) (Version: 4.0.40719.0 - Microsoft Corporation)
    MJUC version 1.0.1 (HKLM...\MJUC_is1) (Version: 1.0.1 - )
    MJUCjr version 1.0.0 (HKLM...\MJUCjr_is1) (Version: 1.0.0 - )
    Mobile Hotspot Admin (HKLM-x32...{AEFF9E60-3E93-41EE-9895-311F7D1C5FFD}) (Version: 1.0.0.2 - ZTE Corporation)
    Monofilter v4.0 (HKLM...\Monofilter4_is1) (Version: - NUGEN Audio)
    Mozilla Firefox 51.0.1 (x86 en-US) (HKLM-x32...\Mozilla Firefox 51.0.1 (x86 en-US)) (Version: 51.0.1 - Mozilla)
    Mozilla Maintenance Service (HKLM-x32...\MozillaMaintenanceService) (Version: 51.0.1 - Mozilla)
    Mp3tag v2.73 (HKLM-x32...\Mp3tag) (Version: v2.73 - Florian Heidenreich)
    MusicBrainz Picard (HKLM-x32...\MusicBrainz Picard) (Version: 1.3.2 - MusicBrainz)
    Nalpeiron Service Update to 6.3.9.2 (x32 Version: 7.3.1 - Nalpeiron) Hidden
    Native Instruments Abbey Road 50s Drummer (HKLM-x32...\Native Instruments Abbey Road 50s Drummer) (Version: 1.2.0.10 - Native Instruments)
    Native Instruments Abbey Road 60s Drums (HKLM-x32...\Native Instruments Abbey Road 60s Drums) (Version: - Native Instruments)
    Native Instruments Alicias Keys 1.2 (HKLM-x32...\Native Instruments Alicias Keys 1.2) (Version: - Native Instruments)
    Native Instruments Battery 4 (HKLM-x32...\Native Instruments Battery 4) (Version: 4.1.5.254 - Native Instruments)
    Native Instruments Damage (HKLM-x32...\Native Instruments Damage) (Version: - Native Instruments)
    Native Instruments Elektrik Piano 1.5 (HKLM-x32...\Native Instruments Elektrik Piano 1.5) (Version: - )
    Native Instruments India (HKLM-x32...\Native Instruments India) (Version: 1.0.0.31 - Native Instruments)
    Native Instruments Kontakt 5 (HKLM-x32...\Native Instruments Kontakt 5) (Version: 5.6.5.13 - Native Instruments)
    Native Instruments Session Horns Pro (HKLM-x32...\Native Instruments Session Horns Pro) (Version: 1.3.0.2 - Native Instruments)
    Native Instruments Symphony Series Brass Solo (HKLM-x32...\Native Instruments Symphony Series Brass Solo) (Version: 1.1.0.19 - Native Instruments)
    Native Instruments Symphony Series String Ensemble (HKLM-x32...\Native Instruments Symphony Series String Ensemble) (Version: 1.1.0.7 - Native Instruments)
    Native Instruments Symphony Series Woodwind Solo (HKLM-x32...\Native Instruments Symphony Series Woodwind Solo) (Version: 1.0.0.11 - Native Instruments)
    Native Instruments The Giant (HKLM-x32...\Native Instruments The Giant) (Version: 1.2.0.7 - Native Instruments)
    Native Instruments The Grandeur (HKLM-x32...\Native Instruments The Grandeur) (Version: 1.2.0.2 - Native Instruments)
    Native Instruments Upright Piano (HKLM-x32...\Native Instruments Upright Piano) (Version: - Native Instruments)
    Native Instruments Vintage Organs (HKLM-x32...\Native Instruments Vintage Organs) (Version: - Native Instruments)
    nebula3 CM (HKLM-x32...{5354D5F2-342D-43DD-A361-B65BF7AABE1D}) (Version: 1.2.837 - Acusticaaudio)
    Nero 12 (HKLM-x32...{560FC78C-A4B2-461D-9B47-820C1EEF87B8}) (Version: 12.0.02000 - Nero AG)
    Netflix in Windows Media Center (HKLM-x32...{0CA72D12-F6C6-4D43-A2A0-41F5AA17E2B6}) (Version: 3.3.101.0 - Microsoft Corporation)
    Neutron Advanced (HKLM-x32...\Neutron Advanced 1.0) (Version: 1.0 - iZotope, Inc.)
    NF VST 64-bit Installer (HKLM-x32...\NF VST 64-bit Installer1.0.3) (Version: 1.0.3 - Nomad Factory)
    Nitro Pro 8 (HKLM...{47B42E7A-57E9-407B-8DBB-017B86D7B13F}) (Version: 8.5.2.10 - Nitro)
    NVIDIA 3D Vision Controller Driver 369.04 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
    NVIDIA 3D Vision Driver 378.49 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 378.49 - NVIDIA Corporation)
    NVIDIA GeForce Experience 3.3.0.95 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.3.0.95 - NVIDIA Corporation)
    NVIDIA Graphics Driver 378.49 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 378.49 - NVIDIA Corporation)
    NVIDIA HD Audio Driver 1.3.34.21 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.21 - NVIDIA Corporation)
    NVIDIA PhysX System Software 9.16.0318 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
    NvNodejs (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
    NvTelemetry (Version: 2.3.5.0 - NVIDIA Corporation) Hidden
    NvvHci (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
    Outils de vérification linguistique 2013 de Microsoft Office - Français (Version: 15.0.4569.1506 - Microsoft Corporation) Hidden
    Output Movement (HKLM-x32...\Output Movement) (Version: 1.0.3 - Output)
    PACE License Support Win64 (HKLM-x32...\InstallShield
    {72ad9d51-0903-4fe7-af5d-33b3185fa6e9}) (Version: 2.2.1.0324 - PACE Anti-Piracy, Inc.)
    PACE License Support Win64 (Version: 2.2.1.0324 - PACE Anti-Piracy, Inc.) Hidden
    PatchCleaner (HKLM-x32...{727DA176-50BB-452C-8DB5-96EE0A573ED4}) (Version: 1.4.20 - HomeDev)
    PCM Native Reverb Bundle (HKLM-x32...\PCM Native Reverb Bundle) (Version: - Lexicon)
    PCM Native Reverb Bundle (x32 Version: 1.1.3 - Lexicon) Hidden
    PDF Settings CS5 (x32 Version: 10.0 - Adobe Systems Incorporated) Hidden
    Photoshop Camera Raw (x32 Version: 5.0 - Adobe Systems Incorporated) Hidden
    Pi version 1.0.11 (HKLM...{CFA5721A-9AA1-4D77-BBC2-78E40216FDAB}_is1) (Version: 1.0.11 - Sound Radix)
    PITCHMAP VST-x64 1.6.1 (HKLM...{F9754DD6-985B-4e93-A96B-837EE5415F61}) (Version: 1.6.1 - Zynaptiq)
    Pixel Bender Toolkit (x32 Version: 1.0 - Adobe Systems Incorporated) Hidden
    Plogue chipsounds v1.848 (HKLM...__ARIA_1009___is1) (Version: v1.848 - Plogue)
    Plogue chipspeech v1.016 (HKLM...__ARIA_1017___is1) (Version: v1.016 - Plogue)
    Prerequisite installer (x32 Version: 12.0.0002 - Nero AG) Hidden
    Primo Ramdisk Server Edition 5.6.0 (HKLM...{94B97E1E-9B67-4012-A126-6319E211A298}_is1) (Version: 5.6.0 - Romex Software)
    Process Lasso (HKLM-x32...\ProcessLasso) (Version: 8.9.8.94 - Bitsum)
    PSP 2Meters 64bit (HKLM-x32...\PSP 2Meters 64bit) (Version: 2.0.0 64bit - PSPaudioware.com)
    PSP 608 MultiDelay 64bit (HKLM...\PSP 608 MultiDelay 64bit) (Version: 1.6.1 64bit - PSPaudioware.com)
    PSP 85 64bit (HKLM-x32...\PSP 85 64bit) (Version: 1.1.0 64bit - PSPaudioware.com)
    PSP BussPressor 64bit (HKLM...\PSP BussPressor 64bit) (Version: 1.0.3 64bit - PSPaudioware.com)
    PSP Echo 64bit (HKLM...\PSP Echo 64bit) (Version: 1.0.1 64bit - PSPaudioware.com)
    PSP MasterComp 1.7.1 64bit (HKLM-x32...\PSP MasterComp 1.7.1 64bit) (Version: 1.7.1 64bit - PSPaudioware.com)
    PSP McQ 64bit (HKLM-x32...\PSP McQ 64bit) (Version: 1.8.0 64bit - PSPaudioware.com)
    PSP Neon 64bit (HKLM...\PSP Neon 64bit) (Version: 2.0.3 64bit - PSPaudioware.com)
    PSP NobleQ 64bit (HKLM...\PSP NobleQ 64bit) (Version: 1.7.0 64bit - PSPaudioware.com)
    PSP oldTimer 64bit (HKLM...\PSP oldTimer 64bit) (Version: 2.0.0 64bit - PSPaudioware.com)
    PSP PianoVerb2 64bit (HKLM-x32...\PSP PianoVerb2 64bit) (Version: 2.0.0 64bit - PSPaudioware.com)
    PSP SpringBox 64bit (HKLM-x32...\PSP SpringBox 64bit) (Version: 1.0.0 64bit - PSPaudioware.com)
    PSP Xenon 1.3.0 64bit (HKLM-x32...\PSP Xenon 1.3.0 64bit) (Version: 1.3.0 64bit - PSPaudioware.com)
    PunkBuster Services (HKLM-x32...\PunkBusterSvc) (Version: 0.991 - Even Balance, Inc.)
    Python 3.3.0 (64-bit) (HKLM...{290329c4-a276-3aec-b633-9f5a39d8dd96}) (Version: 3.3.150 - Python Software Foundation)
    QuickTime (HKLM-x32...{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A}) (Version: 7.73.80.64 - Apple Inc.)
    Rank Tracker (HKLM-x32...\seopowersuite) (Version: - )
    Rapid SEO Tool 1.3 (HKLM-x32...\Rapid SEO Tool_is1) (Version: 1.3 - Karlis Blumentals)
    Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.36.826.2014 - Realtek)
    Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7945 - Realtek Semiconductor Corp.)
    REAPER (x64) (HKLM...\REAPER) (Version: - )
    Reference 3 VST plugin (32-bit) 3 (HKLM-x32...{7627424F-7CB0-471B-AB55-A39F6995C4F0}) (Version: 3.2.11 - Sonarworks)
    Reference 3 VST plugin (64-bit) 3 (HKLM...{510D6D02-214D-4264-A4FD-96DBD82ACFED}) (Version: 3.2.11 - Sonarworks)
    reFX Nexus VSTi RTAS v2.2.0 (HKLM-x32...\reFX Nexus_is1) (Version: - )
    Relab LX480 Lite VST v1.0 (HKLM-x32...\Relab LX480 Lite_is1) (Version: - )
    Resource Hacker Version 3.6.0 (HKLM-x32...\ResourceHacker_is1) (Version: - )
    Revo Uninstaller 2.0.2 (HKLM...{A28DBDA2-3CC7-4ADC-8BFE-66D7743C6C97}_is1) (Version: 2.0.2 - VS Revo Group, Ltd.)
    Rhyme Genie (HKLM-x32...{E48A1AFC-5649-4CC2-B8E1-BD92022C4CC4}) (Version: 6.0 - Idolumic)
    RogueKiller version 12.9.7.0 (HKLM...\8B3D7924-ED89-486B-8322-E8594065D5CB_is1) (Version: 12.9.7.0 - Adlice Software)
    Room EQ Wizard V5 (HKLM-x32...\RoomEQWizardV5) (Version: - John Mulcahy)
    Sasquatch version 1.2.0 (HKLM...\Sasquatch_is1) (Version: 1.2.0 - )
    SEQ1 Master (HKLM-x32...\SEQ1 Master_is1) (Version: - NuGen Audio)
    SEQ2 Master (HKLM-x32...\SEQ2 Master_is1) (Version: - NuGen Audio)
    SEQ-S (HKLM...\SEQ-S_is1) (Version: - NUGEN Audio)
    Service Pack 1 for Microsoft Office 2013 (KB2850036) 64-Bit Edition (Version: - Microsoft) Hidden
    S-GEAR 2 (HKLM...\S-GEAR 2 CE_is1) (Version: 2.5.7 - Scuffham Amps)
    SHIELD Streaming (Version: 7.1.0351 - NVIDIA Corporation) Hidden
    SHIELD Wireless Controller Driver (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
    Sid Meier’s Civilization V (HKLM-x32...\Steam App 8930) (Version: - 2K Games, Inc.)
    SideWidener version 1.0.2 (HKLM...\SideWidener_is1) (Version: 1.0.2 - )
    Skype™ 7.32 (HKLM-x32...{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.32.104 - Skype Technologies S.A.)
    Slack (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\slack) (Version: 2.1.0 - Slack Technologies)
    Slate Digital TRIGGER (HKLM-x32...\SlateDigitalTrigger) (Version: 1.65 - Slate Digital)
    Snagit 11 (HKLM-x32...{A56C6348-59D0-433B-A48A-75914858664E}) (Version: 11.2.1 - TechSmith Corporation)
    Sniper Elite (HKLM-x32...\Steam App 3700) (Version: - Rebellion Developments)
    Sniper Elite V2 (HKLM-x32...\Steam App 63380) (Version: - )
    SoftEther VPN Client (HKLM...\softether_sevpnclient) (Version: 4.22.9634 - SoftEther VPN Project)
    Softube Acoustic Feedback VST RTAS v1.0.7 (HKLM-x32...\Softube Acoustic Feedback VST RTAS_is1) (Version: - )
    Softube Bass Amp Room VST RTAS v1.0.2 (HKLM-x32...\Softube Bass Amp Room VST RTAS_is1) (Version: - )
    Softube FET Compressor VST RTAS v1.0.3 (HKLM-x32...\Softube FET Compressor VST RTAS_is1) (Version: - )
    Softube Metal Amp Room VST RTAS v1.1.5 (HKLM-x32...\Softube Metal Amp Room VST RTAS_is1) (Version: - )
    Softube Passive-Active Pack VST RTAS v1.0.2 (HKLM-x32...\Softube Passive-Active Pack VST RTAS_is1) (Version: - )
    Softube Spring Reverb VST RTAS v1.0.4 (HKLM-x32...\Softube Spring Reverb VST RTAS_is1) (Version: - )
    Softube Trident A-Range VST RTAS v1.0.2 (HKLM-x32...\Softube Trident A-Range VST RTAS_is1) (Version: - )
    Softube Tube Delay VST RTAS v1.0.5 (HKLM-x32...\Softube Tube Delay VST RTAS_is1) (Version: - )
    Softube Tube-Tech CL 1B VST RTAS v1.0.3 (HKLM-x32...\Softube Tube-Tech CL 1B VST RTAS_is1) (Version: - )
    Softube Vintage Amp Room VST RTAS v1.0.8 (HKLM-x32...\Softube Vintage Amp Room VST RTAS_is1) (Version: - )
    Sonalksis Plug-in Manager 3.00 (HKLM-x32...{7A600039-FED6-4C81-AA6E-F151F7FA7EE7}_is1) (Version: - Sonalksis Ltd)
    Sonarworks HD reference 2.2 (HKLM-x32...{F76463A9-42A2-47D5-B7D4-8838523E64E4}) (Version: 2.2.12.30 - Sonarworks)
    Sonarworks HD Reference VST plugin (64-bit) 2.2 (HKLM...{3F08FE5F-23E4-423B-A929-8247E4D5193A}) (Version: 2.2.12.30 - Sonarworks)
    Sonarworks Reference 3 (HKLM-x32...{E8A1DAEE-C491-4833-8D3B-AA8F3E0098AE}) (Version: 3.2.11 - Sonarworks)
    SONiVOX Harmonica (HKLM-x32...\SONiVOX Harmonica) (Version: 1.0 - SONiVOX)
    SONiVOX VocalizerPro (HKLM-x32...\SONiVOX VocalizerPro_is1) (Version: - )
    Sonoris Mastering Compressor (HKLM-x32...\Sonoris Mastering Compressor) (Version: - Sonoris Audio Engineering)
    Sound Blaster X-Fi MB 2 (HKLM-x32...{44DA67A9-C906-4316-94CB-61B036BBDCE5}) (Version: 1.04.02 - Creative Technology Limited)
    SoundToys Native Effects VST RTAS v3.1.2 (HKLM-x32...\SoundToys Native Effects VST RTAS_is1) (Version: - )
    SpeedFan (remove only) (HKLM-x32...\SpeedFan) (Version: - )
    Spotify (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Spotify) (Version: 1.0.49.125.g72ee7853 - Spotify AB)
    SSD Sampler (HKLM-x32...\SSD4) (Version: 1.1 - Yellow Matter Entertainment)
    SSD Utility (HKLM-x32...{3449D0CA-9D99-472B-B36C-A32A58AF18F5}) (Version: 2.2.2645 - Toshiba Corporation)
    SSDlife Pro (HKLM-x32...{3D843494-7DC4-47C9-9E95-3543F0A4E7BC}) (Version: 2.3.56 - BinarySense Inc.)
    Steam (HKLM-x32...{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
    Stereoizer3 v3.1 (HKLM...\Stereoizer3_is1) (Version: - NUGEN Audio)
    Stereoplacer v3 (HKLM...\Stereoplacer3_is1) (Version: - NUGEN Audio)
    Sugar Bytes Looperator 1.0 (HKLM...\Looperator_is1) (Version: 1.0 - Sugar Bytes)
    Suite Shared Configuration CS4 (x32 Version: 1.0 - Adobe Systems Incorporated) Hidden
    Surfer EQ version 1.2.2 (HKLM...{B8D2A156-B2DE-47BD-9789-F1A850F060C1}_is1) (Version: 1.2.2 - Sound Radix)
    swMSM (x32 Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
    System Requirements Lab for Intel (HKLM-x32...{C7CA731B-BF9A-46D9-92CF-8A8737AE9240}) (Version: 4.5.13.0 - Husdawg, LLC)
    Tag&Rename 3.7 (HKLM-x32...\Tag&Rename_is1) (Version: 3.7 - Softpointer Inc)
    TeamViewer 12 (HKLM-x32...\TeamViewer) (Version: 12.0.72365 - TeamViewer)
    TeraCopy 2.3 (HKLM...\TeraCopy_is1) (Version: - Code Sector)
    The Glue (HKLM...\The Glue_is1) (Version: 1.2.8 - )
    The KMPlayer (remove only) (HKLM-x32...\The KMPlayer) (Version: 3.7.0.109 - KMP Media co., Ltd)
    ToneBoosters Morphit (HKLM...\Morphit_is1) (Version: 1.1.4 - ToneBoosters)
    Tracker (HKLM-x32...\com.elance.tracker) (Version: 2.3.3 - Elance Inc)
    Tracker (x32 Version: 2.3.3 - Elance Inc) Hidden
    T-RackS 3 Black 76 version 3.5 (HKLM...{7F0FEB55-6D4A-4892-8A04-3E1EC9001F49}is1) (Version: 3.5 - IK Multimedia)
    T-RackS 3 White 2A version 3.5 (HKLM...{4EE378E8-5B8C-4A56-837F-04986F44F14F}is1) (Version: 3.5 - IK Multimedia)
    T-RackS CS version 4.5.0 (HKLM...{E931EBCC-55F9-4D67-BA0E-D57C4A893A44}is1) (Version: 4.5.0 - IK Multimedia)
    Trackspacer (HKLM...\Trackspacer_is1) (Version: 2.0.4 - Wavesfactory)
    Tradeo - MetaTrader 4 (HKLM-x32...\Tradeo - MetaTrader 4) (Version: 4.00 - MetaQuotes Software Corp.)
    Transify version 1.3 (HKLM...\Transify_is1) (Version: 1.3 - )
    TuneSmith (HKLM-x32...{9061CD4C-6D8A-465B-A2DF-530DF94BCE4D}) (Version: 3.0 - Idolumic)
    Tweaking.com - Windows Repair (HKLM-x32...\Tweaking.com - Windows Repair) (Version: 3.9.25 - Tweaking.com)
    UAD drivers. This may take a while… (x32 Version: 9.0.0.58759 - Universal Audio, Inc.) Hidden
    UAD Powered Plug-Ins (HKLM-x32...{9b9c7089-62a6-4bba-887c-4b94398cc561}) (Version: 9.0.0.58759 - Universal Audio, Inc.)
    UAD Powered Plug-Ins (Version: 9.0.0.58759 - Universal Audio, Inc.) Hidden
    UAD Powered Plug-Ins (x32 Version: 9.0.0.58759 - Universal Audio, Inc.) Hidden
    ubCore64 5.63 (HKLM-x32...\InstallShield
    {F65FE148-FCF5-42F7-8803-FA0B7DA8B8A4}) (Version: - )
    ubCore64 5.63 (Version: 5.63 - Unibrain) Hidden
    UNCHIRP VST-x64 1.0.0 (HKLM...{FE7EB46F-1099-46e2-9165-D10058814B7D}) (Version: 1.0.0 - Zynaptiq)
    UNFILTER VST-x64 1.2.1 (HKLM...{F74A8B13-C915-4CE2-ACE0-CC6845C9D89D}) (Version: 1.2.1 - Zynaptiq)
    UnHackMe 8.60 (HKLM-x32...\UnHackMe_is1) (Version: - Greatis Software, LLC.)
    Universal Extractor 1.6.1 (HKLM-x32...\Universal Extractor_is1) (Version: 1.6.1 - Jared Breland)
    Update for Skype for Business 2015 (KB3039776) 64-Bit Edition (HKLM...{90150000-012B-0409-1000-0000000FF1CE}Office15.PROPLUS{0FA8AE0C-69AE-4F60-A1AB-F79C6BA5A999}) (Version: - Microsoft)
    Update for Skype for Business 2015 (KB3115033) 64-Bit Edition (HKLM...{90150000-00C1-0000-1000-0000000FF1CE}Office15.PROPLUS{F258B6E3-BF41-4FEE-BE45-D7518C3B7FC1}) (Version: - Microsoft)
    Update for Skype for Business 2015 (KB3115033) 64-Bit Edition (HKLM...{90150000-012B-0409-1000-0000000FF1CE}Office15.PROPLUS{F258B6E3-BF41-4FEE-BE45-D7518C3B7FC1}) (Version: - Microsoft)
    Uplay (HKLM-x32...\Uplay) (Version: 2.0 - Ubisoft)
    URS Classic Console Strip Pro VST RTAS v1.0 (HKLM-x32...\URS Classic Console Strip Pro VST RTAS_is1) (Version: - )
    VC80CRTRedist - 8.0.50727.6195 (x32 Version: 1.2.0 - DivX, Inc) Hidden
    VerbSuite Classics - Fusion-IR Bricasti M7 (Part 1) 1.1 (HKLM...\VerbSuite Classics - Fusion-IR Bricasti M7 (Part 1)) (Version: 1.1 - LiquidSonics)
    VerbSuite Classics - Fusion-IR Bricasti M7 (Part 2) 1.1 (HKLM...\VerbSuite Classics - Fusion-IR Bricasti M7 (Part 2)) (Version: 1.1 - LiquidSonics)
    VerbSuite Classics (HKLM...\Slate Digital VerbSuite Classics_is1) (Version: 1.0.3.2 - Slate Digital)
    Virtual Audio Cable 4.13 (HKLM...\Virtual Audio Cable 4.13) (Version: - )
    Virtual Buss Compressors (HKLM...\Slate Digital Virtual Buss Compressors_is1) (Version: 1.2.7.7 - Slate Digital)
    Virtual Tape Machines (HKLM...\Slate Digital Virtual Tape Machines_is1) (Version: - Slate Digital)
    VisLM v1.5.1 (HKLM...\VisLM_is1) (Version: - NUGEN Audio)
    Visual C++ 64-bit Redistributables (HKLM-x32...\InstallShield
    {FB03650C-B373-4B20-ACA5-B7BA1A8EEE33}) (Version: 1.3.0.8766 - PACE Anti-Piracy, Inc.)
    Visual C++ Redistributables (HKLM-x32...\InstallShield
    {F03117FA-9270-46B0-9666-0B4BC2CDEBF5}) (Version: 1.3.0.8766 - PACE Anti-Piracy, Inc.)
    Visual Studio 2012 x64 Redistributables (HKLM...{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
    Visual Studio 2012 x86 Redistributables (HKLM-x32...{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
    Visualizer v1.9.2 (HKLM-x32...\Visualizer1_9_is1) (Version: - NuGen Audio)
    VLC media player (HKLM-x32...\VLC media player) (Version: 2.2.4 - VideoLAN)
    VocALign Pro 4 VST (HKLM-x32...{EB77C666-B349-4046-8BD3-E4941119E1EF}) (Version: 4.00.0000 - Synchro Arts Ltd)
    Voxengo Boogex (HKLM...\Voxengo Boogex_is1) (Version: 2.1 - Voxengo)
    Vulkan Run Time Libraries 1.0.37.0 (HKLM...\VulkanRT1.0.37.0) (Version: 1.0.37.0 - LunarG, Inc.)
    Waves Complete (HKLM...\Complete_is1) (Version: 2016.11.22 - Waves)
    Webroot SecureAnywhere (HKLM-x32...\WRUNINST) (Version: 9.0.15.40 - Webroot)
    Welcome App (Start-up experience) (x32 Version: 12.0.14000 - Nero AG) Hidden
    WinDirStat 1.1.2 (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\WinDirStat) (Version: - )
    Windows 10 Upgrade Assistant (HKLM-x32...{D5C69738-B486-402E-85AC-2456D98A64E4}) (Version: 1.4.9200.17332 - Microsoft Corporation)
    Windows Driver Package - Silicon Laboratories (silabenm) Ports (12/10/2012 6.6.1.0) (HKLM...\D680DEE0F68D64EC53D0C5769879D15D387054CC) (Version: 12/10/2012 6.6.1.0 - Silicon Laboratories)
    Windows Installer Clean Up (HKLM-x32...{121634B0-2F4B-11D3-ADA3-00C04F52DD52}) (Version: 3.00.00.0000 - Microsoft Corporation)
    Windows Software Development Kit (HKLM-x32...{363a2c1e-637f-45ce-933b-5a5463efd945}) (Version: 8.59.29750 - Microsoft Corporation)
    WinRAR 5.40 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
    WinZip 18.0 (HKLM...{CD95F661-A5C4-44F5-A6AA-ECDD91C240DF}) (Version: 18.0.10661 - WinZip Computing, S.L. )
    WPT Redistributables (x32 Version: 8.59.29750 - Microsoft) Hidden
    WPTx64 (x32 Version: 8.59.29722 - Microsoft) Hidden
    Zemana AntiMalware (HKLM-x32...{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.72.101 - Zemana Ltd.)
    Zynaptiq ADAPTIVERB (HKLM...\ADAPTIVERB_is1) (Version: 1.1.0 - Zynaptiq)
    Zynaptiq ADAPTIVERB (HKLM-x32...\Zynaptiq ADAPTIVERB) (Version: 1.0.1 - Zynaptiq)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{005A3A96-BAC4-4B0A-94EA-C0CE100EA736}\localserver32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opbox.exe (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA}\InprocServer32 → C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\psuser_64.dll (Google Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{E8CF3E55-F919-49D9-ABC0-948E6CB34B9F}\InprocServer32 → C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\psuser_64.dll (Google Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314ED9-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314EDA-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314EDB-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314EDC-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314EDD-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314EDE-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314EDF-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID{FB314EE0-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 → C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt64.24.dll (Dropbox, Inc.)
    Task: {04EFF940-BF67-4191-9209-1125A09409A3} - System32\Tasks\Microsoft\Office\Office 15 Subscription Heartbeat => C:\Program Files\Common Files\Microsoft Shared\Office15\OLicenseHeartbeat.exe [2014-01-23] (Microsoft Corporation)
    Task: {05848826-F541-4A0C-B9F2-1611BC2C39B2} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085 => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [2015-08-31] (Google Inc.)
    Task: {063A0BFF-9FB6-4A57-A0FE-92E13D9CF789} - \Auslogics\BoostSpeed\Start BoostSpeed оn SamSwanson logon → No File <==== ATTENTION
    Task: {08ABE768-2FEF-4170-8066-25BB5001F947} - System32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {09888CEB-9E1F-4B6B-BF4A-DB2571F3F71B} - System32\Tasks\ASUS\ASUS AI Suite II Execute => C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe [2016-08-15] (ASUSTeK Computer Inc.)
    Task: {0F509641-76C6-4FAB-BEF3-CB600B547AC5} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {1471D492-58EE-4C44-BE77-AF989C926662} - System32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {1A41D700-2897-4BAA-A036-58E78AA05409} - System32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {1F8E022B-DD5B-4C81-B850-C98F8B88CD15} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2017-02-20] (Piriform Ltd)
    Task: {21C96E5B-F2CD-4BC9-8E73-CA85AC55B19E} - System32\Tasks{EB5A17F7-59B1-4914-80F9-8981CBF7FF0B} => C:\Program Files (x86)\Gizmo\gizmo.exe [2012-12-25] (Arainia Solutions)
    Task: {23972D0B-9EA4-444E-94E3-FEF38A46F53D} - System32\Tasks\Microsoft\Windows\Media Center\ehDRMInit => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {25A3DFC4-D040-485E-B0C3-426340897B2A} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-10-11] (Intel Corporation)
    Task: {26678860-B1BB-4488-B82C-9D65CF436774} - System32\Tasks\NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-26] (NVIDIA Corporation)
    Task: {28DC6CF1-3441-4644-839D-CA8C38FCF81F} - System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmMon.exe [2017-01-26] (NVIDIA Corporation)
    Task: {2A5F42E1-3D73-43DE-AD75-7C45767E1073} - System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-26] (NVIDIA Corporation)
    Task: {31B61FA2-6781-4DDF-A0E6-B5E23DA9740B} - System32\Tasks\Microsoft\Windows\Media Center\RegisterSearch => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {34709417-D411-4C04-AC19-79E7834F99FF} - System32\Tasks\20160618_170750_Restore 12 0 => C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\NBCore.exe [2012-08-13] (Nero AG)
    Task: {355B0E4F-F22C-472D-80DF-8E171D2F3733} - System32\Tasks\Maxthon Update => C:\Program Files (x86)\Maxthon\Bin\mxup.exe [2015-01-05] (Maxthon International ltd.)
    Task: {36AD6884-E5D4-488D-95F6-FE8F55B41FAC} - System32\Tasks\Tweaking.com - Windows Repair Tray Icon => C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\WR_Tray_Icon.exe [2017-02-20] (Tweaking.com)
    Task: {39DBE3EA-4037-4B26-AD52-FC269D6B2855} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2016-02-23] (Apple Inc.)
    Task: {3BC80582-EF19-47C4-B5B2-6C63A4573C8E} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate_scheduled => %SystemRoot%\ehome\mcupdate.exe
    Task: {40305E3B-34DB-4DB3-B2A3-B9F92E3C5D26} - System32\Tasks\Microsoft\Office\OfficeTelemetryAge ntFallBack => C:\Program Files\Microsoft Office\Office15\msoia.exe [2014-01-23] (Microsoft Corporation)
    Task: {460D91C7-7A6C-4120-BDF1-351A93CF1157} - System32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry => %windir%\ehome\MCUpdate.exe
    Task: {4A2A02C8-A390-4ABD-A482-7FE54A9654CB} - System32\Tasks\open effects => C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe [2015-07-15] ()
    Task: {4E2CFB07-EBB0-4549-8B69-C13637DFE808} - System32\Tasks\Patch My PC => C:\Users\SamSwanson\Desktop\PatchMyPC.exe [2017-02-20] (www.patchmypc.net)
    Task: {52F29D63-FCB4-4A1A-BF18-02E57B5BE9A1} - System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d => C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [2016-10-11] (Intel Corporation)
    Task: {5B36754A-B7BE-41F5-BE37-F12045B1C69B} - System32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {5D25CD93-550A-42DF-8295-8A2C8AB3DF1E} - \avastBCLRestartS-1-5-21-3236326594-2611474830-2656184370-1001 → No File <==== ATTENTION
    Task: {5D6CA38A-4C4C-4E18-8C5D-5E2224AEC118} - System32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {63D37EC5-5EDB-47FF-9FD1-1EBEC107D223} - System32\Tasks\Microsoft\Office\OfficeTelemetryAge ntLogOn => C:\Program Files\Microsoft Office\Office15\msoia.exe [2014-01-23] (Microsoft Corporation)
    Task: {66365F28-CE4B-45AD-A996-337675E8A58E} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [2015-08-31] (Google Inc.)
    Task: {668D7E1E-ED4D-47C9-90C6-0775FE94025F} - System32\Tasks\Intel\Intel Telemetry 2 => C:\Program Files\Intel\Telemetry 2.0\lrio.exe [2016-01-10] (Intel Corporation)
    Task: {697EFF5B-44E8-4A03-844A-5C3AD38E4FEA} - System32\Tasks\Microsoft\Windows\Media Center\SqlLiteRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
    Task: {6C09C286-EFF3-4AD4-8FB6-8392EB892C5F} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [2015-08-31] (Google Inc.)
    Task: {6C51BCE8-98E4-49AD-970F-82BA1B4FC324} - System32\Tasks\20160623_163758_Restore 12 0 => C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\NBCore.exe [2012-08-13] (Nero AG)
    Task: {6E398F56-89B4-4FC1-8AEA-E632E89C8918} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
    Task: {6F7DD068-47F7-4EE2-B113-F6BC5435281D} - \Microsoft\Windows\Setup\EOSNotify → No File <==== ATTENTION
    Task: {7388C649-BD6B-458E-BB7D-615016D011FC} - System32\Tasks\COMODO\COMODO Update {A6D52E4F-569B-4756-B3D8-DF217313DA85} => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [2016-10-13] (COMODO)
    Task: {7C23857E-26FD-48C7-AADC-94F9F547CB5F} - System32\Tasks\Process Lasso Core Engine Only => C:\Program Files\Process Lasso\processgovernor.exe [2017-02-11] (Bitsum LLC)
    Task: {7D6CD2E9-7D16-4990-876E-A1DDD1C333DC} - System32\Tasks\Microsoft\Windows\Media Center\RecordingRestart => %SystemRoot%\ehome\ehrec.exe
    Task: {8C2DAB06-A415-4E79-9FD2-92C60BC7FA67} - System32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
    Task: {8D7DD635-2A2D-4000-8D1F-4C6B77F8D80E} - System32\Tasks\Microsoft\Windows\PLA\System{2BCE58 99-48A6-4AB8-B3D9-62E4245605D0}System Diagnostics => Rundll32.exe C:\WINDOWS\system32\pla.dll,PlaHost “system\System Diagnostics” “$(Arg0)”
    Task: {95C752B4-7B0C-48D9-AE1C-3942F5D3BB76} - System32\Tasks\COMODO\COMODO Autostart {D5EFF3B3-E126-4AF6-BCE9-852A72129E10} => C:\Program Files\COMODO\COMODO Internet Security\cistray.exe [2016-09-27] (COMODO)
    Task: {96FDF968-3B9A-47A0-8729-22C64981D02C} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate => %SystemRoot%\ehome\mcupdate.exe
    Task: {9929E7D3-69C5-48B3-BD78-4DA035C80291} - System32\Tasks{BBCD0C7D-45F8-4AA4-A784-5E4F16371482} => pcalua.exe -a E:\ashampoo_firewall_free_1.20_sm.exe -d E:
    Task: {9AC9EE1F-3C7D-4D11-A723-C108476BA2FD} - System32\Tasks\Adobe Flash Player PPAPI Notifier => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_ 0_0_221_pepper.exe [2017-02-22] (Adobe Systems Incorporated)
    Task: {9F6C043A-F8EF-4589-9123-0EF833FBDDE8} - System32\Tasks\NvNodeLauncher
    {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe [2017-01-26] (NVIDIA Corporation)
    Task: {A75CC2EA-C50E-4D36-AEA1-91212A6641DB} - System32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {AD0C68FF-F1EF-4C1E-A767-DBD5729882A2} - System32\Tasks\UnHackMe Task Scheduler => C:\Program Files (x86)\UnHackMe\hackmon.exe [2017-02-24] (Greatis Software)
    Task: {AD2F8636-6963-4AAD-A26F-1D01E01200F0} - System32\Tasks\ASUS\Easy Update => C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzUpdt.exe [2013-01-14] ()
    Task: {AD93EA85-7159-4B00-A2A8-DC9C6441F3A7} - System32\Tasks\Microsoft\Windows\Media Center\StartRecording => %SystemRoot%\ehome\ehrec.exe
    Task: {BD2046AE-D49F-4ADD-BCDE-8005342B87D5} - System32\Tasks{31DDBD37-5DB7-4030-8064-10B0CAA806C3} => C:\Program Files\COMODO\COMODO Internet Security\cistray.exe [2016-09-27] (COMODO)
    Task: {BDE36E30-62CC-4A29-816E-3A295DC2890B} - System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-26] (NVIDIA Corporation)
    Task: {C1590D8D-F402-4E93-8D27-AFD81BC6A5C3} - System32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
    Task: {C374DDAD-C0E9-49BF-A6B0-9ED56EB2165C} - System32\Tasks\ASUS\USB 3.0 Boost Service => C:\Program Files (x86)\ASUS\AI Suite II\USB 3.0 Boost\U3BoostSvr.exe [2016-08-15] ()
    Task: {C488B36A-662D-4D82-8D4E-7ACDD04C6206} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-10-11] (Intel Corporation)
    Task: {CA31EB53-D7B0-4140-9BF1-68356F601421} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpda teService.exe [2017-02-22] (Adobe Systems Incorporated)
    Task: {D583F66C-8EAB-4249-8FEB-75F592B49722} - System32\Tasks\ASUS\ASUS Network iControl Help Execute => C:\Program Files (x86)\ASUS\AI Suite II\Network iControl\NetSvcHelp\NetSvcHelpEntry.exe [2012-05-02] (ASUSTeK Computer Inc.)
    Task: {D6716D1C-E449-4AF6-8063-D330FAEA820B} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [2015-08-31] (Google Inc.)
    Task: {D8D805E5-AFF8-477C-B46C-3A79C13D64E8} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {DAE7EBFF-9B4D-438B-A0E1-76A7FE896D57} - System32\Tasks\Microsoft\Windows\Media Center\OCURActivate => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {E3CC8218-7A1E-4B80-B0E8-C9C2FA606B1B} - System32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
    Task: {E4290C7D-DF68-49AF-B8D3-ECF30CFCE984} - System32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask => %SystemRoot%\ehome\mcupdate.exe
    Task: {E8E81B66-3E1E-448E-9EDA-61D64DB64920} - System32\Tasks{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} => C:\ProgramData\Carbonite\Carbonite Backup\CarboniteUpgrade.exe
    Task: {E8F94C64-88AA-4D59-AE81-D4BF8E78B677} - System32\Tasks\COMODO\COMODO Signature Update {B9D5C6F9-17D2-4917-8BD0-614BAA1C6A59} => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [2016-10-13] (COMODO)
    Task: {ED0C1F69-C3A2-41EA-B8C3-3F0D83A1F6C0} - \Microsoft\Windows\Customer Experience Improvement Program\BthSQM → No File <==== ATTENTION
    Task: {F19205EB-384D-455D-99E3-6BC1A4840E68} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
    Task: {F1C40402-4D4E-40EC-9F8D-55452716F7E0} - System32\Tasks{EE492B24-CD47-404D-95D3-605112E375FA} => pcalua.exe -a “S:\More VSTI\Orchestral.Tools.Metropolis.Ark.2.Orchestra.O f.The.Deep.KONTAKT-P2P\METROPOLIS Ark 2 Win Installer.exe” -d “S:\More VSTI\Orchestral.Tools.Metropolis.Ark.2.Orchestra.O f.The.Deep.KONTAKT-P2P”
    Task: {F6E4AD78-6FF4-4B5F-A68C-36575464E8A3} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {F8D01798-23CD-4BD7-A4B2-3C85ED5B55C9} - System32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService => %SystemRoot%\ehome\ehPrivJob.exe
    Task: {F95AB783-6CE0-421A-B5CE-89C59CE572F7} - System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-26] (NVIDIA Corporation)
    Task: {FAD23CE4-F70B-4FE3-B9F6-F8719DFDC955} - System32\Tasks\Microsoft\Windows\PLA\System{EC8853 F4-75E4-4154-B078-27C2E7531492}_System Diagnostics => Rundll32.exe C:\WINDOWS\system32\pla.dll,PlaHost “system\System Diagnostics” “$(Arg0)”
    Task: {FF6E9CA0-FA25-46F9-970E-F95E6DF9AFA3} - System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d-Logon => C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [2016-10-11] (Intel Corporation)
    Task: C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_ 0_0_221_pepper.exe
    Task: C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpda teService.exe
    Task: C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask .job => C:\WINDOWS\explorer.exe
    Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core.job => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe
    Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA.job => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe
    ==================== Shortcuts =============================
    2016-07-16 12:42 - 2016-07-16 12:42 - 00231424 _____ () C:\WINDOWS\SYSTEM32\ism32k.dll
    2016-12-13 23:35 - 2016-12-13 23:35 - 02681200 _____ () C:\WINDOWS\system32\CoreUIComponents.dll
    2012-12-23 12:43 - 2017-01-20 16:13 - 00134712 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
    2016-10-05 18:17 - 2016-10-05 18:17 - 00092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
    2017-01-13 13:56 - 2017-01-13 13:56 - 01353528 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
    2014-01-07 16:14 - 2014-01-07 16:14 - 00920736 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe
    2016-10-14 14:31 - 2016-10-31 09:17 - 01244408 _____ () C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe
    2016-10-31 09:17 - 2016-10-31 09:17 - 04463592 _____ () C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe
    2015-07-07 10:44 - 2015-07-07 10:44 - 00088064 _____ () C:\Program Files\Intel Corporation\Intel(R) Technology Access\libglog.dll
    2016-04-26 13:30 - 2016-04-26 13:30 - 00367824 _____ () C:\Program Files\Intel Corporation\Intel(R) Technology Access\JsonCpp.dll
    2017-02-10 20:00 - 2017-01-20 19:40 - 04489152 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\Poco.dll
    2017-02-10 20:00 - 2017-01-20 19:40 - 01147328 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\libprotobuf.dll
    2017-02-11 16:07 - 2017-02-11 16:07 - 02264352 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\PoliciesControllerImpl.dll
    2017-02-11 16:07 - 2017-02-11 16:07 - 02829776 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\arwlib.dll
    2017-02-11 16:07 - 2017-02-11 16:07 - 02254800 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\MwacLib.dll
    2016-05-24 01:09 - 2016-05-24 01:09 - 00127336 _____ () C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe
    2016-12-13 23:35 - 2016-12-13 23:35 - 02681200 _____ () C:\WINDOWS\SYSTEM32\CoreUIComponents.dll
    2015-09-15 13:58 - 2015-09-15 13:58 - 08901184 _____ () C:\Program Files\Microsoft Office\Office15\1033\GrooveIntlResource.dll
    2012-12-23 12:26 - 2016-08-15 15:04 - 00657920 _____ () C:\Program Files\TeraCopy\TeraCopy64.dll
    2014-01-07 16:16 - 2013-01-14 16:37 - 01406776 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzUpdt.exe
    2016-09-14 10:10 - 2016-09-14 10:10 - 00134656 _____ () C:\Windows\ShellExperiences\Windows.UI.Shell.Share dUtilities.dll
    2017-01-11 10:41 - 2017-01-11 10:41 - 00474112 _____ () C:\Windows\ShellExperiences\QuickActions.dll
    2017-01-11 10:41 - 2017-01-11 10:41 - 09760768 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\CortanaApi.dll
    2017-01-11 10:41 - 2017-01-11 10:41 - 01401856 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.Core.dll
    2017-01-11 10:41 - 2017-01-11 10:41 - 00757248 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\CSGSuggestLib.dll
    2017-01-11 10:41 - 2017-01-11 10:41 - 01033216 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.Actions.dll
    2017-01-11 10:41 - 2017-01-11 10:41 - 02424320 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.BackgroundTask.dll
    2017-01-11 10:41 - 2017-01-11 10:41 - 04853760 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\RemindersUI.dll
    2012-12-23 11:43 - 2011-12-17 00:18 - 00325120 _____ () C:\Windows\SYSTEM32\APOMgr64.DLL
    2012-12-23 13:44 - 2012-11-09 03:17 - 01433200 _____ () C:\Program Files (x86)\Ditto\Ditto.exe
    2014-02-18 21:52 - 2017-02-20 17:22 - 00544208 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl anePlugin.exe
    2012-09-13 00:38 - 2012-09-13 00:38 - 00264040 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\CameraHelperShell.exe
    2012-01-20 11:27 - 2015-07-15 21:28 - 03042304 _____ () C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
    2016-10-14 14:48 - 2016-10-31 09:17 - 07382232 _____ () C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe
    2016-04-16 11:56 - 2016-06-29 11:01 - 09698296 _____ () C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
    2017-02-28 15:41 - 2017-02-28 11:31 - 03759448 _____ () C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\58.0.3026.0\libglesv2.dll
    2017-02-28 15:41 - 2017-02-28 11:31 - 00100696 _____ () C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\58.0.3026.0\libegl.dll
    2014-01-07 16:14 - 2017-03-01 13:45 - 00026112 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.19\PEbiosinterface32.dll
    2014-01-07 16:14 - 2010-06-29 10:58 - 00104448 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.19\ATKEX.dll
    2014-12-21 17:07 - 2014-12-21 17:07 - 00119822 _____ () C:\Program Files (x86)\AnonVPN\bin\libgcc_s_dw2-1.dll
    2014-12-21 17:07 - 2014-12-21 17:07 - 01026062 _____ () C:\Program Files (x86)\AnonVPN\bin\libstdc+±6.dll
    2015-08-11 14:36 - 2015-08-11 14:36 - 00024896 _____ () C:\Program Files (x86)\Common Files\Acronis\Infrastructure\core_workers_shared_c ontext.dll
    2016-10-14 14:25 - 2016-10-14 14:25 - 00037808 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\thread_pool.dll
    2016-10-14 14:48 - 2016-10-14 14:48 - 04355264 _____ () C:\Program Files (x86)\Common Files\Acronis\Infrastructure\atih_mms_addon.dll
    2015-08-23 14:59 - 2015-08-23 14:59 - 00606672 _____ () C:\Program Files (x86)\Common Files\Acronis\Infrastructure\sqlite3.dll
    2016-10-14 14:47 - 2016-10-14 14:47 - 20605872 _____ () C:\Program Files (x86)\Acronis\TrueImageHome\ti_managers.dll
    2015-11-16 17:05 - 2015-11-16 17:05 - 00126928 _____ () C:\Program Files (x86)\Acronis\TrueImageHome\afcdpapi.dll
    2016-04-16 11:45 - 2016-04-16 11:45 - 00248240 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\sync_agent_api.dll
    2017-02-10 20:01 - 2017-01-20 19:40 - 00018880 _____ () C:\Program Files (x86)\NVIDIA Corporation\Update Core\detoured.dll
    2017-02-10 20:00 - 2017-01-20 19:40 - 03774400 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\Poco.dll
    2017-02-10 20:00 - 2017-01-20 19:40 - 00900032 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\libprotobuf.dll
    2014-01-07 16:16 - 2013-01-14 17:16 - 05771136 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzULIB.dll
    2014-01-07 16:16 - 2010-06-21 15:21 - 00208896 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\ImageHelper.dll
    2014-01-07 16:17 - 2012-08-03 16:41 - 00043520 _____ () C:\Program Files (x86)\ASUS\AI Suite II\TurboV EVO\HookKey32.dll
    2014-01-07 16:17 - 2012-08-03 16:40 - 00253952 _____ () C:\Program Files (x86)\ASUS\AI Suite II\TurboV EVO\pngio.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00147456 _____ () C:\Program Files (x86)\ASUS\AI Suite II\AssistFunc.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00253952 _____ () C:\Program Files (x86)\ASUS\AI Suite II\pngio.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00972288 _____ () C:\Program Files (x86)\ASUS\AI Suite II\BarGadget\BarGadget.dll
    2014-01-07 16:16 - 2013-01-15 15:30 - 01040896 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EasyUpdt.dll
    2014-01-07 16:17 - 2012-07-25 09:56 - 01124864 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Network iControl\Network iControl.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00883712 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Sensor\Sensor.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 01622528 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Sensor Graph\SensorGraph.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 01243136 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Settings\Settings.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00846848 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Splitter\Splitter.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00875520 _____ () C:\Program Files (x86)\ASUS\AI Suite II\TabGadget\TabGadget.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00208896 _____ () C:\Program Files (x86)\ASUS\AI Suite II\ImageHelper.dll
    2014-01-07 16:16 - 2016-08-15 14:56 - 00253952 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Sensor\AlertHelper\pngio.dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 00350160 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWDebugDll_win32.4.6.7.25 343.dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 00441808 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWDebug.4.6.7.25343.dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 00465872 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWUtils.4.6.7.25343.dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 62691792 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWExternLib.4.6.7.25343.d ll
    2017-02-22 17:23 - 2017-02-20 17:21 - 00285648 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWMainLib_win.4.6.7.25343 .dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 06186448 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWData.4.6.7.25343.dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 07395280 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWApplication.4.6.7.25343 .dll
    2017-02-10 20:01 - 2017-01-20 19:39 - 64245184 _____ () C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\libcef.dll
    2017-02-10 20:01 - 2017-01-20 14:36 - 00338488 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVAccountAPINode.node
    2017-02-10 20:01 - 2017-01-20 14:36 - 00254008 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\DriverInstall.node
    2017-02-10 20:01 - 2017-01-20 14:36 - 02808888 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\Downloader.node
    2017-02-10 20:01 - 2017-01-20 14:36 - 00384568 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvGameShareAPINode.node
    2017-02-10 20:01 - 2017-01-20 14:36 - 00537656 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvSpCapsAPINode.node
    2017-02-10 20:01 - 2017-01-20 14:36 - 00468024 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvGalleryAPINode.node
    2017-02-10 20:01 - 2017-01-20 14:36 - 01066552 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvCameraAPINode.node
    2017-02-10 20:01 - 2017-01-20 14:36 - 01014840 _____ () \?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvSDKAPINode.node
    2017-02-22 17:23 - 2017-02-20 17:21 - 13674960 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWMainLib.4.6.7.25343.dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 02215376 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWMainLibData.4.6.7.25343 .dll
    2017-02-22 17:23 - 2017-02-20 17:21 - 00334288 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7 .25343\bin\Firefox_Extension{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\Kwift_DP.4.6.7.25343.dll
    2012-09-13 00:38 - 2012-09-13 00:38 - 02144104 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\QtCore4.dll
    2012-09-13 00:38 - 2012-09-13 00:38 - 07955304 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\QtGui4.dll
    2012-09-13 00:38 - 2012-09-13 00:38 - 00341352 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\QtXml4.dll
    2012-09-13 00:38 - 2012-09-13 00:38 - 00028008 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\imageformats\QGif4.dll
    2012-09-13 00:38 - 2012-09-13 00:38 - 00127336 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\imageformats\QJpeg4.dll
    2012-09-13 00:39 - 2012-09-13 00:39 - 00336232 _____ () C:\Program Files (x86)\Common Files\logishrd\LWSPlugins\LWS\Applets\CameraHelper \DevManagerCore.dll
    2015-11-10 18:38 - 2015-11-10 18:38 - 08337408 _____ () C:\Users\SamSwanson\Downloads\SonarworksforDDMF\Re ference3.dll
    2016-10-14 14:27 - 2016-10-14 14:27 - 00333744 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\resource.dll
    2016-10-14 14:25 - 2016-10-14 14:25 - 00050096 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\rpc_client.dll
    2016-10-14 14:25 - 2016-10-14 14:25 - 00445872 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\ulxmlrpcpp.dll
    2016-10-14 14:23 - 2016-10-14 14:23 - 00115632 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\EXPAT.dll
    2016-10-25 02:29 - 2016-10-25 02:29 - 00224768 _____ () C:\WINDOWS\SYSTEM32\UAD2DriverClient.dll
    2016-10-25 02:29 - 2016-10-25 02:29 - 02058752 _____ () C:\WINDOWS\SYSTEM32\UAD2SDK.dll
    2014-04-27 13:17 - 2000-01-01 01:00 - 01242584 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
    AlternateDataStreams: C:\WINDOWS\explorer.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\grep.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\MBR.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\NIRCMD.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\NvContainerRecovery.bat:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\NvTelemetryContainerRecovery.bat:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\PEV.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\sed.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\splwow64.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SWREG.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SWSC.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SWXCACLS.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\unins002.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\unins005.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\unins006.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\unins007.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\zip.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\aadcloudap.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\aadtb.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AboveLockAppHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AccountsRt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\aclui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\acmigration.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ACPBackgroundManagerPolicy.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AcpiServiceVnA64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ActionCenter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ActionCenterCPL.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ActivationManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\actxprxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AddressParser.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\adsmsext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\aeinv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\aepic.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AERTAC64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AERTAR64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\aitstatic.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-core-xstate-l2-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-conio-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-convert-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-environment-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-filesystem-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-heap-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-locale-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-math-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-multibyte-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-private-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-process-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-runtime-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-stdio-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-string-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-time-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-utility-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppCapture.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppContracts.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\appinfo.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppointmentActivation.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppointmentApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\appraiser.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppReadiness.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\apprepapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\apprepsync.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVCatalog.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVClient.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVDllSurrogate.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVEntStreamingManager.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVEntSubsystemController.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVEntSubsystems64.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVEntVirtualization.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVIntegration.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVManifest.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVOrchestration.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVPolicy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVPublishing.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVReporting.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVScripting.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppVShNotify.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\appwiz.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppXApplicabilityBlob.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentClient.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentExtensions.deskt op.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentExtensions.oneco re.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentServer.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AppxPackaging.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\asycfilt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\atmfd.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\atmlib.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AudioEndpointBuilder.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AudioEng.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AUDIOKSE.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\audioLibVc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AudioSes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\audiosrv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AudioSrvPolicyManager.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AuthBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\authui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\autoplay.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\AzureSettingSyncProvider.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\baaupdate.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BackgroundMediaPolicy.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BarcodeProvisioningPlugin.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bcastdvr.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BcastDVRHelper.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bcdedit.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bcrypt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bdechangepin.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bdesvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bdeui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bdeunlock.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BingMaps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BingOnlineServices.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\bisrv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BitLockerDeviceEncryption.exe: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\biwinrt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BluetoothApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BootMenuUX.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\bootux.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\browserbroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\BthRadioMedia.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CastLaunch.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\CbtBackgroundManagerPolicy.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cdd.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cdp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cdpsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cdpusersvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CertEnroll.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\certprop.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Chakra.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Chakradiag.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Chakrathunk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\chartv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ChatApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ci.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ClipboardServer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ClipUp.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cloudAP.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CloudBackupSettings.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHost.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHostBroker.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHostCommon.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHostUser.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CloudStorageWizard.exe:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\clusapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cmifw.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cmintegrator.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\combase.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\comdlg32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CompatTelRunner.exe:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\comsvcs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CONEQMSAPOGUILibrary.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ConsoleLogon.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ContactActivation.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\ContactApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\container.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ContentDeliveryManager.Utiliti es.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CoreMessaging.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\CoreUIComponents.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CPFilters.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CredProvDataModel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\credprovhost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\credprovs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\credprovslegacy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\crypt32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cryptngc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CryptoWinRT.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cryptui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\cscui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\csrsrv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CX64APO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\CX64Proxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\C_G18030.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\c_GSM7.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\C_IS2022.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\d2d1.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\d3d10warp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\d3d11.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\D3D12.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\d3d9.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\D3DCompiler_47.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dab.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dafBth.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dafpos.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\das.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dasHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DataExchange.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DataSenseHandlers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\daxexec.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dbgeng.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DbgModel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPA64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPA64F3.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPD64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPD64AF3.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPO64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPO64AF3.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPP64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DDPP64AF3.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ddraw.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\delegatorprovider.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DeveloperOptionsSettingsHandle rs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\devenum.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\deviceaccess.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\deviceassociation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DeviceCensus.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DeviceCenter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DeviceEnroller.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DeviceFlows.DataModel.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DevicePairing.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DevicePairingFolder.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DeviceReactivation.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\devinv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dhcpcore6.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\diagtrack.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dialclient.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dialserver.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\discan.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Display.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DisplayManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dlnashext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dmcertinst.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dmenrollengine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DMRServer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dnsapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DolbyDAX2APOProp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DolbyDAX2APOv201.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DolbyDAX2APOv211.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DolbyDecMFT.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\domgmt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dosvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dpapisrv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\drvstore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DscCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DscCoreConfProv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dsreg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dsregcmd.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSBassEnhancementDLL64.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSBoostDLL64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSGainCompensatorDLL64.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSGFXAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSGFXAPONS64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSLFXAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSLimiterDLL64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSNeoPCDLL64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSS2HeadphoneDLL64.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSS2SpeakerDLL64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSSymmetryDLL64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSU2PGFX64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSU2PLFX64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSU2PREC64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DTSVoiceClarityDLL64.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dwmapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dwmcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\DWrite.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dxgi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dxmasf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\dxtrans.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EAMProgressHandler.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\eapp3hst.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\eappcfg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\eappgnui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\eapphost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\eappprxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\easwrt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\edgehtml.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EditBufferTestHook.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\EditionUpgradeHelper.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EditionUpgradeManagerObj.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EDPCleanup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\efsext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\efswrt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EmailApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\encapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EncDec.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\energy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EnterpriseAppMgmtSvc.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\enterprisecsps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\EnterpriseModernAppMgmtCSP.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ErrorDetails.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ErrorDetailsUpdate.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\esent.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\esentutl.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\evr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ExplorerFrame.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ExSMime.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ExtrasXmlParser.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\facecredentialprovider.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Family.Authentication.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Family.Client.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Family.SyncEngine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ffbroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fhcfg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fhcpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fhsettingsprovider.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\FlightSettings.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\FMAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\FntCache.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fontdrvhost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fontext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\FontProvider.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\FrameServer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\FSClient.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fveapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fveapibase.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fvecpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fvenotify.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fveprompt.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fveui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\fvewiz.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\GamePanel.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\gameux.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\gdi32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\gdi32full.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\GdiPlus.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\generaltel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\GenValObj.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Geolocation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\GlobCollationHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\gpsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\hal.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HarmanAudioInterface.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\hevcdecoder.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\hgcpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HiFiDAX2API.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HMAPO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HMClariFi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HMEQ.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\HMEQ_Voice.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HMHVS.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HMLimiter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HMUI.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\HttpsDataSource.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\hvax64.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\hvix64.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\hvloader.efi:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\hvloader.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ICEsoundAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\icsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\icsvcext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\IdCtrls.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ie4uinit.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ieapfltr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\iedkcs32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ieframe.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\iepeers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ieproxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\iernonce.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\iertutil.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\iesetup.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\imapi2.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ImplatSetup.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\indexeddbserver.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\inetcomm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\inetcpl.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\input.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\InputLocaleManager.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\InputService.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\InstallAgent.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\InstallAgentUserBroker.exe:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\IntelSSTAPO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\IntelSstCApoPropPage.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\invagent.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\iphlpsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ipnathlp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\iscsiwmi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\JpMapControl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\jscript9.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\jscript9diag.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\jsproxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\KAAPORT64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\kdhvcom.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\kerberos.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\KernelBase.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\KnobsCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\KnobsCsp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LaunchWinApp.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\libpng15.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LicenseManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LicenseManagerSvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ListSvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\localspl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LocationFramework.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LockAppBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LockAppHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LogonController.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\lpremove.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\LsaIso.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\lsasrv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\lsass.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\lsm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\manage-bde.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapConfiguration.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapControlCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapControlStringsRes.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapGeocoder.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapRouter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapsBtSvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapsBtSvcProxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapsCSP.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MapsStore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mapstoasttask.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mapsupdatetask.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO20.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO30.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO4064.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO5064.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO6064.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO7064.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPOShell64.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioEQ64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioRealtek64.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxSpeechAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxVoiceAPO2064.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxVoiceAPO3064.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxVoiceAPO4064.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MaxxVolumeSDAPO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MbaeApiPublic.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mbsmsapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MCRecvSrc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MDEServer.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MDMAppInstaller.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mdmregistration.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MediaFoundation.DefaultPercept ionProvider.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfasfsrcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfaudiocnv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MFCaptureEngine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfksproxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MFMediaEngine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfmkvsrcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfmp4srcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfmpeg2srcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfnetcore.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\mfnetsrc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfplat.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MFPlay.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfpmp.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfreadwrite.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfsensorgroup.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfsrcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mfsvr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Microsoft-Windows-MapControls.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Microsoft-Windows-MosHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Microsoft-Windows-MosTrace.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\microsoft-windows-system-events.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\migisol.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MiracastReceiver.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mispace.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MISS_APO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\modernexecserver.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mos.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\moshost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MosHostClient.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\moshostcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MosResource.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MosStorage.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mprapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mprddm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mprdim.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MrmCoreR.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MRT.exe:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\MSAC3ENC.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MSAJApi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MSAudDecMFT.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\msctf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msdtcprx.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msdtctm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msdtcuiu.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msdxm.ocx:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msfeeds.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msftedit.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mshtml.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mshtmled.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msinfo32.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msmpeg2vdec.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mspaint.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mssprxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mssrch.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mstsc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\mstscax.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msv1_0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MSVidCtl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MSVideoDSP.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MSVP9DEC.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msvproc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MSVPXENC.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msxml6.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\msxml6r.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MusNotification.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\MusUpdateHandlers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NAHIMICAPOlfx.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NahimicAPONSControl.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NAHIMICV2apo.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NAHIMICV3apo.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nativemap.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NaturalLanguage6.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ncsi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetCfgNotifyObjectHost.exe:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\netiougc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\netplwiz.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetSetupApi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetSetupEngine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetSetupShim.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetSetupSvc.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\netshell.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nettrace.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetworkBindingEngineMigPlugin. dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetworkCollectionAgent.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetworkDesktopSettings.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetworkMobileSettings.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NetworkUXBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NFCProvisioningPlugin.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NfcRadioMedia.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ngccredprov.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NgcCtnr.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\NgcCtnrGidsHandler.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\ngcsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nlasvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nltest.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NMAA.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NmaDirect.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NotificationController.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NPSM.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nshwfp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ntdll.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ntoskrnl.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ntshrui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvapi64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvaudcap64v.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvcompiler.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvcuda.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvcuvid.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvDecMFTMjpeg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434709.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434725.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434752.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434788.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6435354.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6435887.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6435906.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6436909.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6437254.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6437653.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispco6437849.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434709.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434725.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434752.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434788.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6435354.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6435887.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6435906.dll:$CmdTcI D [130]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6436909.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6437254.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6437653.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6437849.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvEncMFTH264.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvEncodeAPI64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvfatbinaryLoader.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NvFBC64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvhdagenco64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvhdagenco6420103.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvhdap64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NvIFR64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\NvIFROpenGL.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvoglv64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvopencl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\nvptxJitCompiler.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\odbcconf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\offlinelsa.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\offlinesam.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\offreg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ole32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\oleaut32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\OnDemandConnRouteHelper.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\OneBackupHandler.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\OneDriveSettingSyncProvider.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\OpenCL.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\partizan.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\pcasvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\pdh.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PhoneProviders.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PhoneService.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PhoneServiceRes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Phoneutil.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PhoneutilRes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\pidgenx.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PimIndexMaintenance.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PlayToDevice.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PlayToManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PlayToReceiver.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\pnidui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\policymanager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\poqexec.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\POSyncServices.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\powercfg.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PrintWSDAHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\prm0005.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\profsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\provdatastore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\provengine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\provhandlers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\provisioningcsp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\provops.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ProvPluginEng.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ProvSysprep.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\provtool.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\PsmServiceExtHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\puiobj.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\pwcreator.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\pwrshplugin.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\qedit.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\qmgr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\R4EEA64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\R4EED64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\R4EEG64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\R4EEL64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\R4EEP64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rasapi32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rascustom.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rasmans.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RCoInstII64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rdpcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rdpcorets.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rdpencom.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rdpinit.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rdpshell.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rdpudd.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RDXService.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RDXTaskFactory.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ReAgent.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ReAgentc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RelPost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\remoteaudioendpoint.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RemoteNaturalLanguage.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RemovableMediaProvisioningPlug in.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ReportingCSP.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\reseteng.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ResetEngine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ResetEngine.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\resutils.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ReWire.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RjvMDMConfig.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RltkAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RMapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RP3DAA64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RP3DHT64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rpcrt4.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\rshx32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTCOM64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RtDataProc64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTEED64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTEEG64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTEEL64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTEEP64A.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RtkApi64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RtkCfg64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RtkCoLDR64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RtlCPAPI64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTMediaFrame.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RtNicProp64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RtPgEx64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTSnMg64.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\RTWorkQ.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\samlib.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\samsrv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sbe.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ScDeviceEnum.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\schannel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SEAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.d ll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\SearchFilterHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SearchFolder.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SearchIndexer.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SearchProtocolHost.exe:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\SecConfig.efi:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SECOMN64.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\securekernel.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SEHDHF64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SEHDRA64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sendmail.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Sens.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SensorDataService.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SensorsApi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SensorService.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\services.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SessEnv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SET8ED1.tmp:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SET8FC2.tmp:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SETA251.tmp:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SETA93F.tmp:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_Bluetooth.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_Flights.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_nt.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_StorageSense. dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_WorkAccess.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingSync.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingSyncCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingSyncHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SettingSyncPolicy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\setupugc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SFAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SFCOM64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SFNHK64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SFSS_APO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SharedStartModel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ShareHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\shdocvw.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\shell32.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\shutdownux.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\skci.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sl3apo64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\slc.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\slcext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\slcnt64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\slprp64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sltech64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\smartscreen.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\smphost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SndVolSSO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SpaceAgent.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SpaceControl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\spaceman.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SpeechPal.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\spoolsv.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sppc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sppcext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sppnp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sppobjs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sppsvc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sppwinob.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\spwmp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRAPO64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRCOM.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRCOM64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRH.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRHInproc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRRPTR64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRSHP64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRSTSH64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRSTSX64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SRSWOW64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sspicli.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\stobject.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\StorageUsage.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\storagewmi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\storagewmi_passthru.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\StoreAgent.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\StorSvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\StructuredQuery.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\sud.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SyncCenter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SyncSettings.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SysResetErr.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\systemreset.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SystemSettings.DeviceEncryptio nHandlers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SystemSettings.UserAccountsHan dlers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SystemSettingsAdminFlows.exe:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\SystemSettingsThresholdAdminFl owUI.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tadefxapo.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tadefxapo264.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\taskbarcpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tcpipcfg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tdh.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tepeqapo64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\TextInputFramework.dll:$CmdTcI D [130]
    AlternateDataStreams: C:\WINDOWS\system32\themecpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\timedate.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\TokenBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tosade.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tosasfapo64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\toseaeapo64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tossaeapo64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tossaemaxapo64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\TpmCoreProvisioning.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\TpmTasks.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\tquery.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\TransportDSA.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tsmf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\TSpkg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tspubwmi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\TSWorkspace.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\twinapi.appcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\twinapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\twinui.appcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\twinui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\twinui.pcshell.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tzautoupdate.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\tzres.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ubpm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UIAnimation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UIAutomationCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UIRibbonRes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\umpoext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\unimdm.tsp:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\updatehandlers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\updatepolicy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\uReFS.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\urlmon.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\usbmon.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\user32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\usercpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserDataAccessRes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserDataLanguageUtil.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserDataPlatformHelperUtil.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserDataTimeUtil.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserDataTypeHelperUtil.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserDeviceRegistration.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserDeviceRegistration.Ngc.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\usermgr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\UserMgrProxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\usocore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\vbscript.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\VCardParser.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\VEStoreEventHandlers.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\vmrdvcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\vpncmd.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\vpnike.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\VPNv2CSP.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\vulkaninfo-1-1-0-37-0.exe:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\vulkaninfo.exe:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\w32time.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WavesGUILib64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wbiosrvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wc_storage.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WebcamUi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\webio.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\weretw.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wevtapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wevtsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wfdprov.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WiFiConfigSP.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wificonnapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wifinetworkmanager.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\wifiprofilessettinghandler.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wifitask.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\win32k.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\win32kbase.sys:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\win32kfull.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\win32spl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\win32u.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WinBioDataModel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WinBioDataModelOOBE.exe:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wincorlib.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.AccountsControl.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Backg round.SystemEventsBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.LockS creen.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Store .dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Store .TestingFramework.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Walle t.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Cortana.Desktop.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Data.Pdf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.AllJoyn.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Bluetooth.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.HumanInterface Device.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.LowLevel.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Midi.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Perception.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Picker.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.PointOfService .dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Printers.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Radios.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Scanners.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Sensors.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.SerialCommunic ation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.SmartCards.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.SmartCards.Pho ne.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Usb.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.WiFi.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.WiFiDirect.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Energy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Gaming.Input.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Gaming.XboxLive.Storag e.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Globalization.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Graphics.Printing.3D.d ll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Graphics.Printing.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Internal.Bluetooth.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Internal.Management.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Internal.UI.Logon.Prox yStub.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Management.Provisionin g.ProxyStub.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Audio.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.BackgroundMediaP layback.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Devices.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Editing.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.FaceAnalysis.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Import.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.MediaControl.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Ocr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Playback.Backgro undMediaPlayer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Playback.MediaPl ayer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Protection.PlayR eady.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Speech.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Speech.UXRes.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Streaming.dll:$C mdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.BackgroundT ransfer.BackgroundManagerPolicy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.BackgroundT ransfer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.Connectivit y.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.HostName.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.ServiceDisc overy.Dnssd.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.Vpn.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Perception.Stub.dll:$C mdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Security.Authenticatio n.Identity.Provider.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Security.Authenticatio n.OnlineId.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Security.Authenticatio n.Web.Core.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Shell.Search.UriHandle r.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.StateRepository.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.StateRepositoryBroker. dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.StateRepositoryClient. dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Storage.ApplicationDat a.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\windows.storage.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.System.UserDeviceAssoc iation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.BioFeedback.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.BlockedShutdown.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Core.TextInput.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Cred.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.CredDialogControlle r.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Immersive.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Input.Inking.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Logon.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Search.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Shell.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.InkControls.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.Maps.dll:$CmdT cID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.Phone.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Web.Diagnostics.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Web.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Windows.Web.Http.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WindowsCodecs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winhttp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wininet.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wininetlui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winload.efi:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winload.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winlogon.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winmde.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winresume.efi:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winresume.exe:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\WinSCard.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\winsrv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wintrust.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WinTypes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wkssvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlanapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlancfg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlanhlp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WlanMediaManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlanmsm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlansec.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlansvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlansvcpal.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wlidsvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wmp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WMPDMC.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wmpdxm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wmpeffects.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\wmploc.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wmpmde.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wmpps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wmpshell.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WordBreakers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wow64.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WpAXHolder.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WpcRefreshTask.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WpcTok.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WpcWebFilter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wpnapps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wpncore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wpninprc.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\wpnprv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wpx.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\ws2_32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wscapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wscinterop.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wscsvc.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\wscui.cpl:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\wsecedit.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WSManHTTPConfig.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WsmSvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wsp_fs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wsp_health.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\wsp_sr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wuapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wuauclt.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wuaueng.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wups.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wups2.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wuuhext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WWAHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\WWanAPI.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wwanconn.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wwanmm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wwanprotdim.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\wwansvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\XamlTileRender.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\XblAuthManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\xpsrchvw.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\YamahaAE.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\YamahaAE2.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\zipfldr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\zlib1.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\aadtb.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AboveLockAppHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\aclui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ActionCenterCPL.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ActivationManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\actxprxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AddressParser.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\adsmsext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-core-xstate-l2-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-conio-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-convert-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-environment-l1-1-0.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-filesystem-l1-1-0.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-heap-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-locale-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-math-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-multibyte-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-private-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-process-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-runtime-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-stdio-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-string-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-time-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-utility-l1-1-0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AppCapture.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AppContracts.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AppointmentActivation.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AppointmentApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\apprepapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\apprepsync.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AppVEntSubsystems32.dll:$CmdTc ID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\appwiz.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AppxPackaging.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\asycfilt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\atmfd.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\atmlib.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AUDIOKSE.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AudioSes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AuthBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AuthExt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\authui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\autoplay.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\BackgroundMediaPolicy.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\bcastdvr.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\BcastDVRHelper.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\bcrypt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\BingMaps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\BingOnlineServices.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\biwinrt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\BluetoothApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\cdp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CertEnroll.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Chakra.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Chakradiag.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Chakrathunk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\chartv.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ChatApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ClipboardServer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudBackupSettings.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudExperienceHostCommon.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudExperienceHostUser.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudStorageWizard.exe:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\clusapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\cmifw.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\combase.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\comctl32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\comdlg32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\comsvcs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ConfigureExpandedStorage.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ContactActivation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ContactApis.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\container.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CoreMessaging.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CoreUIComponents.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CPFilters.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CredProvDataModel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\credprovhost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\credprovs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\credprovslegacy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\crypt32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\cryptngc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\CryptoWinRT.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\cryptui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\C_G18030.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\c_GSM7.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\C_IS2022.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\d2d1.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d10warp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d11.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\D3D12.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d8.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d9.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\D3DCompiler_47.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DataExchange.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\daxexec.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dbgeng.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DbgModel.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ddraw.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\delegatorprovider.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\devenum.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\deviceassociation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DeviceFlows.DataModel.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DevicePairing.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dhcpcore6.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dialclient.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DisplayManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dlnashext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dmenrollengine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dnsapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DolbyDecMFT.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\drvstore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DscCoreConfProv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dsreg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dtdump.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dwmapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dwmcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\DWrite.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dxgi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dxmasf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\dxtrans.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\eapp3hst.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\eappcfg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\eappgnui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\eapphost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\eappprxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\edgehtml.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\EditBufferTestHook.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\efsext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\efswrt.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\EmailApis.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\encapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ErrorDetails.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ErrorDetailsUpdate.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\esent.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\esentutl.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\evr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\explorer.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ExplorerFrame.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ExSMime.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ExtrasXmlParser.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\findnetprinters.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\FlashPlayerApp.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\fontdrvhost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\fontext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\FSClient.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\GamePanel.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\gameux.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\gdi32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\gdi32full.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\GdiPlus.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Geolocation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\GlobCollationHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\hevcdecoder.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\hgcpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ieapfltr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\iedkcs32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ieframe.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\iepeers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ieproxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\iernonce.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\iertutil.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\iesetup.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\imapi2.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\indexeddbserver.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\inetcomm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\inetcpl.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\input.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\InputLocaleManager.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\InputService.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\InstallAgent.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\InstallAgentUserBroker.exe:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\iscsiwmi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\JpMapControl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\jscript9.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\jscript9diag.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\jsproxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\kerberos.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\KernelBase.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\LaunchWinApp.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\LicenseManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\LicenseManagerApi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\LockAppBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\LockAppHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\LogonController.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MapConfiguration.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MapControlCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MapControlStringsRes.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MapGeocoder.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MapRouter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MapsBtSvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MbaeApiPublic.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mbsmsapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MCRecvSrc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mdmregistration.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfasfsrcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfaudiocnv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfksproxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MFMediaEngine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfmkvsrcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfmp4srcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfmpeg2srcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfnetcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfnetsrc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfplat.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MFPlay.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfpmp.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfreadwrite.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfsensorgroup.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfsrcsnk.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mfsvr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Microsoft-Windows-MapControls.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Microsoft-Windows-MosHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Microsoft-Windows-MosTrace.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\migisol.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MiracastReceiver.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mispace.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mos.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MosHostClient.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MosResource.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MosStorage.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mprapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mprddm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mprdim.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MrmCoreR.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MSAC3ENC.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MSAJApi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msctf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msdtcprx.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msdtcuiu.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msdxm.ocx:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msfeeds.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msftedit.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mshtml.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mshtmled.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msinfo32.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msmpeg2vdec.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mspaint.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mssrch.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mstsc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mstscax.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msv1_0.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MSVidCtl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MSVP9DEC.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msvproc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\MSVPXENC.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msxml6.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\msxml6r.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\mtxclu.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NaturalLanguage6.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NetCfgNotifyObjectHost.exe:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\netiougc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NetSetupApi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NetSetupEngine.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NetSetupShim.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\netshell.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NetworkCollectionAgent.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ngccredprov.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NMAA.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NmaDirect.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NPSM.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nshwfp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ntdll.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ntshrui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvaudcap32v.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvcompiler.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvcuda.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvcuvid.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvDecMFTMjpeg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvEncMFTH264.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvEncodeAPI.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvfatbinaryLoader.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NvFBC.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NvIFR.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\NvIFROpenGL.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvoglv32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvopencl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvptxJitCompiler.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\nvStreaming.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\odbcconf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\offlinelsa.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\offlinesam.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\offreg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ole32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\oleacc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\oleaut32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\olepro32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\OneDriveSettingSyncProvider.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\opencl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\pdh.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Phoneutil.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\PhoneutilRes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\pidgenx.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\PlayToDevice.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\PlayToManager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\PlayToReceiver.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\policymanager.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\poqexec.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\POSyncServices.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\powercfg.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\PrintDialogs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\pwrshplugin.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\qdvd.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\rasapi32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\rdpcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\rdpencom.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ReAgent.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ReAgentc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\remoteaudioendpoint.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\RemoteNaturalLanguage.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\resutils.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ReWire.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\RltkAPO.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\rpcrt4.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\RTMediaFrame.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\RTWorkQ.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\samlib.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\schannel.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.d ll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SearchFolder.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SearchIndexer.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SearchProtocolHost.exe:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SECOMN32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SEHDHF32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\sendmail.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SessEnv.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSync.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSyncCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSyncHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSyncPolicy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\setupugc.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SFCOM.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ShareHost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\shell32.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\slc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\slcext.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\smphost.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SndVolSSO.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\sppc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\sppcext.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\spwmp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SRCOM.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\sspicli.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\stobject.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\storagewmi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\storagewmi_passthru.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\StoreAgent.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\sud.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SyncSettings.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\SYNSOEMU.DLL:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\systemcpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\tcpipcfg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\tdh.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\TempSignedLicenseExchangeTask. dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\TextInputFramework.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\themecpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\TimeEditkb.ocx:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\TokenBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\TpmCoreProvisioning.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\tquery.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\tsmf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\TSpkg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\twinapi.appcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\twinapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\twinui.appcore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\twinui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\tzres.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UIAnimation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UIAutomationCore.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UIRibbonRes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\unimdm.tsp:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\updatepolicy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\uReFS.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\urlmon.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\user32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\usercpl.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataAccessRes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataAccountApis.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataLanguageUtil.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataPlatformHelperUtil.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataTimeUtil.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataTypeHelperUtil.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDeviceRegistration.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDeviceRegistration.Ngc.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\UserMgrProxy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\vbscript.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\VCardParser.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\vulkaninfo-1-1-0-37-0.exe:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\vulkaninfo.exe:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WebcamUi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\webio.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\weretw.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wevtapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wfdprov.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\win32k.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\win32kfull.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\win32u.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wincorlib.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.AccountsControl.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Backg round.SystemEventsBroker.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Core. dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.LockS creen.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store .dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store .TestingFramework.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Walle t.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.AllJoyn.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Bluetooth.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.HumanInterface Device.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.LowLevel.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Midi.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Perception.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Picker.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.PointOfService .dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Radios.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Scanners.dll:$ CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Sensors.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.SerialCommunic ation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.SmartCards.dll :$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Usb.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.WiFi.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.WiFiDirect.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Energy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Gaming.Input.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Gaming.XboxLive.Storag e.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Globalization.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Graphics.Printing.3D.d ll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Graphics.Printing.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Internal.Bluetooth.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Internal.Management.dl l:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Internal.UI.Logon.Prox yStub.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Audio.dll:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.BackgroundMediaP layback.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Editing.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.FaceAnalysis.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Import.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Ocr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Playback.Backgro undMediaPlayer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Playback.MediaPl ayer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayR eady.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Speech.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Speech.UXRes.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Streaming.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.BackgroundT ransfer.BackgroundManagerPolicy.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.BackgroundT ransfer.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.Connectivit y.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.dll:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.HostName.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.ServiceDisc overy.Dnssd.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Perception.Stub.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Security.Authenticatio n.Identity.Provider.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Security.Authenticatio n.OnlineId.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Shell.Search.UriHandle r.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.StateRepository.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.StateRepositoryClient. dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Storage.ApplicationDat a.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\windows.storage.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.System.UserDeviceAssoc iation.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.BioFeedback.dll:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.BlockedShutdown.dll :$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Core.TextInput.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Cred.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.CredDialogControlle r.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Input.Inking.dll:$C mdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Logon.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Search.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.InkControls.dl l:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Maps.dll:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Phone.dll:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Resources.dll: $CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Web.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Web.Http.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WindowsCodecs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\winhttp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wininet.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wininetlui.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\winmde.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WinRtTracing.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WinSCard.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wintrust.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WinTypes.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wlanapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wlancfg.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wlanhlp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wmp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WMPDMC.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpdxm.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpeffects.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wmploc.DLL:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpmde.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpshell.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WordBreakers.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WpcWebFilter.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wpnapps.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\ws2_32.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wscapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wscinterop.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wscui.cpl:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wsecedit.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WSManHTTPConfig.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WsmSvc.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wsp_fs.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wsp_health.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wsp_sr.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\wuapi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WwaApi.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WWAHost.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\WWanAPI.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\xolehlp.dll:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\xpsrchvw.exe:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\zipfldr.dll:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\afd.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\ahcache.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\AppVStrm.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\AvidMbox.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\AvidMbox_DFU.sys:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\bowser.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\capimg.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\Classpnp.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\clfs.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\ClipSp.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\cmimcext.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\cng.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\crashdmp.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\dam.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\DDMFaudio.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\dfsc.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\dtlitescsibus.sys:$Cmd TcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\dumpsd.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\dxgkrnl.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\dxgmms1.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\dxgmms2.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\EhStorTcgDrv.sys:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\fastfat.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\file_tracker.sys:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\fvevol.sys:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\FWPKCLNT.SYS:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\hidclass.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\hidparse.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\hidusb.sys:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\http.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\hvservice.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\iaStorA.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\iorate.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\kbdhid.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\ksecdd.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\ksecpkg.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\LGVirHid.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\mbae64.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\MegaSas2i.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\modem.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxdav.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxsmb.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxsmb10.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxsmb20.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\ndis.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\ndisrfl.sys:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\Neo6_x64_VPN.sys:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\nettap630.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\ntfs.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\nvhda64v.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\nvvad64v.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\nvvhci.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\partmgr.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\pci.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\pdc.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\rdbss.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\rt640x64.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\RTKVHD64.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\sdbus.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\SET8839.tmp:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\spaceport.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\srv.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\srv2.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\srvnet.sys:$CmdTcID [130]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\storahci.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\stornvme.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\storport.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tap0901.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tcpip.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\TeeDriverW8x64.sys:$Cm dTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tib.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tib_mounter.sys:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tm.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tnd.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tpm.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\tsvadpcm.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\UAD2Pcie.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\UAD2System.sys:$CmdTcI D [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\UAD2WdmAudio.sys:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\vhdmp.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\virtual_file.sys:$CmdT cID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\vpci.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\wcifs.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\WdiWiFi.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\winhvr.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\wof.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\xboxgip.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\xinputhid.sys:$CmdTcID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Drivers\UnHackMeDrv.sys:$CmdTc ID [64]
    AlternateDataStreams: C:\WINDOWS\SysWOW64\Drivers\UpdateHelper.dll:$CmdT cID [64]
    AlternateDataStreams: C:\ProgramData\Microsoft:Gb9iHSAhBg9BV12C3k73XBgHL Qz [2384]
    AlternateDataStreams: C:\ProgramData\Microsoft:gVCZtV597Pk0byqtUxyu9ZFc [2548]
    AlternateDataStreams: C:\ProgramData\Microsoft:HkCk6pH2rgF930hJgx9 [2112]
    AlternateDataStreams: C:\ProgramData\MicrosoftyzvIDdUHQPoJqcsmkYzVeN [2130]
    AlternateDataStreams: C:\ProgramData\Microsoft:w3lVKHfpoNp0LGn1SO56 [2532]
    AlternateDataStreams: C:\ProgramData\Microsoft:ZUQvhkhISSBkTH7rGp [2562]
    AlternateDataStreams: C:\ProgramData\TEMP:07BF512B [152]
    AlternateDataStreams: C:\ProgramData\TEMP:4FC01C57 [136]
    AlternateDataStreams: C:\Users\SamSwanson\Cookies:3rwwZhw2tLiAmOSNHAwYUq SaJU [1858]
    AlternateDataStreams: C:\Users\SamSwanson\Cookies:IZqLckuoBEmSeyWZ9jWWGP oF9 [2068]
    AlternateDataStreams: C:\Users\SamSwanson\CookiesZUQi9r51MMNkceOnZGIDucq [2336]
    AlternateDataStreams: C:\Users\SamSwanson\Cookies:suYxzGFC9bvFaXMRmXkqqt [1952]
    AlternateDataStreams: C:\Users\SamSwanson\Cookies:w6io6svORgLdd8KCHJbkN7 1r [2442]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\Czech taxes for dummies 2015.pdf:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\dokument.pdf:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\Formulář_žádosti__pro_ cizince,_neobčany_EU_a_jejich_rodinné_příslušníky-rev.pdf:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\how to licesne musick.pdf:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\Money 4 Music.epub:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\PatchMyPC.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\Potvrzení_o_zajištění_ ubytování_FO.DOC:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\RevoicePro.exe:$CmdTcI D [64]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\Rights-Owner-Repertoire.xlsx:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\SigLotSizeCalV1.2.xls: $CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\SM-Offshore-Banking-Report.pdf:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\SongMarket.epub:$CmdZn ID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\uTorrent.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Desktop\uTorrent.exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\3AC2.tmp:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (1).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (1).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (10).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (10).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (2).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (2).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (3).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (3).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (4).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (4).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (5).exe:$CmdTcID [130]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (5).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (6).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (6).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (7).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (7).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (8).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (8).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (9).exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (9).exe:$CmdZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup.exe:$Cmd TcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup.exe:$Cmd ZnID [26]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.15.0.2_w in64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.16.0_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.16.1_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.18.0_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.19.0_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.20.0_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.21.0_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.22.1_win 64-setup.exe:$CmdTcID [130]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.22.2.2_w in64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.23.0.2_w in64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.24.0_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.24.1_win 64-setup.exe:$CmdTcID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\tdsskiller.zip:$CmdT cID [64]
    AlternateDataStreams: C:\Users\SamSwanson\Downloads\tdsskiller.zip:$CmdZ nID [26]
    AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\bvSO2cjMUSN:nKkd VTct7EMl42YHS3SZExMJ [2388]
    AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX6d4DS5PFDAk03KTXvn2F2mu [2712]
    AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA:03H rcMG15SDYyUw1Sza8AWAbY [2338]
    AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\Temporary Internet Files:xwH7V3jDNbvYm9CzQAMppM [2254]
    AlternateDataStreams: C:\Users\SamSwanson\Documents\2015 tax return Horton.pdf:$CmdZnID [26]
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\AppXSvc => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\BFE => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\BITS => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\ClipSvc => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\MBAMService => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\MpsSvc => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\msiserver => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\SharedAccess => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\TweakingRemoveSafeBoot => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\vss => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Min imal\WSService => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\AppXSvc => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\BITS => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\ClipSvc => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\MBAMService => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\msiserver => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\SamSs => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\srv => “”=“Driver”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\srv2 => “”=“Driver”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\srvnet => “”=“Driver”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\TweakingRemoveSafeBoot => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\vss => “”=“Service”
    HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Net work\WSService => “”=“Service”
    2012-07-26 06:26 - 2017-02-20 21:19 - 00000855 ____A C:\WINDOWS\system32\Drivers\etc\hosts
    127.0.0.1 localhost
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Control Panel\Desktop\Wallpaper → C:\Users\SamSwanson\AppData\Local\Microsoft\Window s\Themes\RoamedThemeFiles\DesktopBackground\wallpa per_2.jpg
    DNS Servers: 8.8.8.8 - 8.8.4.4
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
    Windows Firewall is enabled.
    MSCONFIG\Services: WSearch => 2
    HKLM...\StartupApproved\StartupFolder: => “Snagit 11.lnk”
    HKLM...\StartupApproved\StartupFolder: => “LoopBe30 Monitor.lnk”
    HKLM...\StartupApproved\Run: => “Acronis Scheduler2 Service”
    HKLM...\StartupApproved\Run: => “AdobeAAMUpdater-1.0”
    HKLM...\StartupApproved\Run: => “Logitech Download Assistant”
    HKLM...\StartupApproved\Run: => “iTunesHelper”
    HKLM...\StartupApproved\Run: => “ZAM”
    HKLM...\StartupApproved\Run32: => “AdobeCS5ServiceManager”
    HKLM...\StartupApproved\Run32: => “APSDaemon”
    HKLM...\StartupApproved\Run32: => “UpdReg”
    HKLM...\StartupApproved\Run32: => “DivXMediaServer”
    HKLM...\StartupApproved\Run32: => “DivXUpdate”
    HKLM...\StartupApproved\Run32: => “googletalk”
    HKLM...\StartupApproved\Run32: => “iTunesHelper”
    HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched”
    HKLM...\StartupApproved\Run32: => “QuickTime Task”
    HKLM...\StartupApproved\Run32: => “SwitchBoard”
    HKLM...\StartupApproved\Run32: => “Acronis Scheduler2 Service”
    HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched (2)”
    HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched (1)”
    HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched (3)”
    HKLM...\StartupApproved\Run32: => “CancelAutoPlay_df”
    HKLM...\StartupApproved\Run32: => “CheckNDISPortf0ac3e”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\StartupFolder: => “RBTray.exe”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\StartupFolder: => “SpeedFan.lnk”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Gobbler”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “GoogleChromeAutoLaunch_6884A160BCC04722E6F4385CB6 FFBBDA”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Google Update”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Skype”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Spotify”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Spotify Web Helper”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “DAEMON Tools Lite”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “GizmoDriveDelegate”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Copy”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “DriverMax”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “GoogleChromeAutoLaunch_20359AAFD869880A09A939B153 F8703B”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “OneDrive”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “DAEMON Tools Lite Automount”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “CCleaner Monitoring”
    HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “SpybotPostWindows10UpgradeReInstall”
    FirewallRules: [vm-monitoring-nb-session] => (Allow) LPort=139
    FirewallRules: [{D8811F55-5587-4E2E-9803-5F89E86BE479}] => (Allow) C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
    FirewallRules: [{E4BE2C83-8EFB-40F4-AA36-DF1B6E02FC63}] => (Allow) C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
    FirewallRules: [{7E50ECC5-ADEE-41F4-B456-DD8184B7B9D7}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
    FirewallRules: [{06E10D22-128D-4D9C-81AE-CFCC8F5C0D78}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
    FirewallRules: [{800BE274-31F7-4485-93FA-49D22449C363}] => (Allow) S:\SteamGameLibrary\SteamApps\common\Day of Defeat Source\hl2.exe
    FirewallRules: [{B6A68273-9DDE-4550-BF33-23B26844ED8A}] => (Allow) S:\SteamGameLibrary\SteamApps\common\Day of Defeat Source\hl2.exe
    FirewallRules: [{E5A8B4EF-E0C3-46C4-8655-F4667B7C0FC3}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe
    FirewallRules: [{AF19923E-DFBF-44CE-8E35-C061282BF825}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
    FirewallRules: [UDP Query User{F5776BFC-9EE0-43A2-B705-766521F94B2D}C:\program files\litecoin\litecoin-qt.exe] => (Allow) C:\program files\litecoin\litecoin-qt.exe
    FirewallRules: [TCP Query User{A17EFB4D-9DC9-470C-8B1B-BC335E7CA9B8}C:\program files\litecoin\litecoin-qt.exe] => (Allow) C:\program files\litecoin\litecoin-qt.exe
    FirewallRules: [UDP Query User{FEB8E9ED-9B27-4C04-AE59-C6FB21E4CFEE}C:\program files\reaper (x64)\reaper.exe] => (Allow) C:\program files\reaper (x64)\reaper.exe
    FirewallRules: [TCP Query User{4FC0708F-E22A-46A0-B3A1-8BAF833E3603}C:\program files\reaper (x64)\reaper.exe] => (Allow) C:\program files\reaper (x64)\reaper.exe
    FirewallRules: [UDP Query User{82951DBB-1382-405F-B496-B2CB552D2CC9}C:\users\samswanson\appdata\roaming\s potify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotif y.exe
    FirewallRules: [TCP Query User{F2B9FCED-0F9D-49E0-9B96-B20FC514B119}C:\users\samswanson\appdata\roaming\s potify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotif y.exe
    FirewallRules: [UDP Query User{32E5E5FF-AE09-40CA-9019-D3486EEBABF5}C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe] => (Block) C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe
    FirewallRules: [TCP Query User{43AFE483-1F63-4C55-8462-69C60BC018BA}C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe] => (Block) C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe
    FirewallRules: [{EB46C128-ED00-4C3F-8F84-47470F58C813}] => (Block) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_ x64.exe
    FirewallRules: [{69B1232F-5701-454C-ADFE-08E54D6B0920}] => (Block) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_ x64.exe
    FirewallRules: [UDP Query User{1AB4FC87-2B0D-472E-A3E6-61C2B6C070FA}C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_ x64.exe] => (Allow) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_ x64.exe
    FirewallRules: [TCP Query User{EB0FECB5-C9BD-488B-99F8-68E3EE0359D9}C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_ x64.exe] => (Allow) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_ x64.exe
    FirewallRules: [UDP Query User{2AFF58C6-0DEA-4814-BFFB-9396E88BD493}C:\program files\reaper (x64)\plugins\reaper_host64.exe] => (Block) C:\program files\reaper (x64)\plugins\reaper_host64.exe
    FirewallRules: [TCP Query User{78335E54-289F-41C9-A7FB-1EEC0AC1D749}C:\program files\reaper (x64)\plugins\reaper_host64.exe] => (Block) C:\program files\reaper (x64)\plugins\reaper_host64.exe
    FirewallRules: [{7AF1A041-07C9-4959-8274-77EE03809209}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opbox.exe
    FirewallRules: [{6986C6E8-5AE1-4AF7-9F1B-8E4880BEF5F9}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opbox.exe
    FirewallRules: [{9A87E20F-0224-40A4-A0A6-CF2D427F4D20}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opbox.exe
    FirewallRules: [{BA177546-4044-4C07-AFE8-69887582567D}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opbox.exe
    FirewallRules: [UDP Query User{0BFC59AF-9A77-433F-9D79-6A42BC3B990E}C:\program files (x86)\idolumic\tunesmith\tunesmith.exe] => (Block) C:\program files (x86)\idolumic\tunesmith\tunesmith.exe
    FirewallRules: [TCP Query User{A3ECAB14-43DA-4877-B411-E11F65833A70}C:\program files (x86)\idolumic\tunesmith\tunesmith.exe] => (Block) C:\program files (x86)\idolumic\tunesmith\tunesmith.exe
    FirewallRules: [{9F08C694-EC8D-4028-B569-CC536012E7BB}] => (Allow) C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe
    FirewallRules: [{B184610F-D175-44C7-B31A-4C9CF612667C}] => (Allow) C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe
    FirewallRules: [{85F3ACDA-06E5-4E75-BBB3-E4993FCACAEA}] => (Allow) LPort=1688
    FirewallRules: [{FE438153-8F8D-492D-A2FB-B9DC4D356A58}] => (Allow) LPort=1688
    FirewallRules: [{4810449D-6142-46CE-90E8-E59770BFC440}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
    FirewallRules: [{CA27EC5C-5D60-4DE9-A224-7B39FC82845B}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
    FirewallRules: [{50841857-DD2A-46AC-8627-9A7BE07699D7}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
    FirewallRules: [{4EF546A8-7388-4B39-8C68-16D263B1252B}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
    FirewallRules: [{901F754B-7F53-41C0-A07B-A4D8D0DFE036}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
    FirewallRules: [{FF7228E9-9CA7-41CD-A723-2F149E256AC0}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
    FirewallRules: [{6FA2A9E8-A72E-42CF-A794-B18CC107DEA1}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
    FirewallRules: [{F71782BC-163B-4084-BA5E-9BE299F8C6C3}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
    FirewallRules: [{159A065B-2BA1-4A71-8EE1-BAAEA61F9001}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
    FirewallRules: [{FE35395F-4673-4FC1-85FB-576D178B0B1D}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
    FirewallRules: [UDP Query User{1579E7CF-1850-48C3-886A-632A8EC41CB6}C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe
    FirewallRules: [TCP Query User{7DCC07A6-5616-48B2-AC59-2C37A069E637}C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe
    FirewallRules: [UDP Query User{AB2EA62A-A8E9-4766-83D1-08DEFBBBBB76}C:\users\samswanson\appdata\roaming\s potify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotif y.exe
    FirewallRules: [TCP Query User{4E60A726-4483-4E32-9B1C-85B9E69C232F}C:\users\samswanson\appdata\roaming\s potify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotif y.exe
    FirewallRules: [{5EE2E0AD-9DAB-4F6D-8D38-0A41D29BF39E}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
    FirewallRules: [{AE76EA5F-CF6E-4FDC-BF69-7187C5A8CD22}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
    FirewallRules: [{D524EB94-7130-4A51-9936-58807A7CCC32}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
    FirewallRules: [{DC004AA2-EAB9-45C4-8636-FBF333884C16}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
    FirewallRules: [{264C0F87-944D-4B28-B875-008CE407DCEC}] => (Allow) C:\Program Files (x86)\gnucash\bin\gconfd-2.exe
    FirewallRules: [{BEEFD323-7E07-406B-B349-2515E304A47A}] => (Allow) C:\Program Files (x86)\gnucash\bin\gconfd-2.exe
    FirewallRules: [{4C7D8CF3-F3E2-46AD-8B64-D3064C44978B}] => (Allow) C:\Program Files (x86)\gnucash\bin\gnucash.exe
    FirewallRules: [{B73A089E-647C-40E4-BC4B-061EE4354A35}] => (Allow) C:\Program Files (x86)\gnucash\bin\gnucash.exe
    FirewallRules: [{159B9D62-A976-4BF7-8EBB-1E2082C0DA3B}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\MxUp.exe
    FirewallRules: [{394FFBE6-FF1C-4139-B2B4-B00E21956F4E}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe
    FirewallRules: [{57DFEDDE-D220-4A8D-85E3-2EDBBBE665B2}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\MxUp.exe
    FirewallRules: [{09BB3EE1-42E8-4B70-B9FB-ECEE43D6E6E7}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe
    FirewallRules: [UDP Query User{8B077964-B2EF-4647-B909-569A0E35D127}C:\program files (x86)\utorrent\utorrent.exe] => (Block) C:\program files (x86)\utorrent\utorrent.exe
    FirewallRules: [TCP Query User{BA5E5EF7-5ADA-4398-A746-A25FDEA7334A}C:\program files (x86)\utorrent\utorrent.exe] => (Block) C:\program files (x86)\utorrent\utorrent.exe
    FirewallRules: [{39D9F0E3-EEF9-4650-94DB-AD618B47C70A}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\call of duty modern warfare 3\iw5mp.exe
    FirewallRules: [{D3A12194-DFB4-41DE-BAFE-163B728B7C2E}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\call of duty modern warfare 3\iw5mp.exe
    FirewallRules: [UDP Query User{C489928B-BCB6-4CAD-B115-8637D6D5F1E2}C:\program files\reaper (x64)\reaper.exe] => (Block) C:\program files\reaper (x64)\reaper.exe
    FirewallRules: [TCP Query User{873D8F9D-EA4F-4D25-9643-79E633CB1825}C:\program files\reaper (x64)\reaper.exe] => (Block) C:\program files\reaper (x64)\reaper.exe
    FirewallRules: [{3AE70BBF-4187-408E-8552-8C40592320B4}] => (Allow) C:\Program Files (x86)\Nero\KM\KwikMedia.exe
    FirewallRules: [{23AC632F-EAB7-4D82-91A0-AF1745451F95}] => (Allow) C:\Program Files (x86)\Nero\KM\KwikMedia.exe
    FirewallRules: [UDP Query User{34448265-8649-4C33-AC9D-CE6B4BDE66C0}C:\program files (x86)\ditto\ditto.exe] => (Allow) C:\program files (x86)\ditto\ditto.exe
    FirewallRules: [TCP Query User{CC138988-1294-4E93-B9F7-B5EEEAF4385B}C:\program files (x86)\ditto\ditto.exe] => (Allow) C:\program files (x86)\ditto\ditto.exe
    FirewallRules: [{347A2896-44B0-4781-8639-F8E6DADBAF9B}] => (Block) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
    FirewallRules: [{043836B9-CABB-4DE7-BB6F-4C6561C5B4AF}] => (Block) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
    FirewallRules: [UDP Query User{A7D9C2DC-CB32-4544-A540-3CE567BB1891}C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe] => (Allow) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
    FirewallRules: [TCP Query User{C17FD2D4-D884-4DF0-BFC2-BA96D1E34ACC}C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe] => (Allow) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
    FirewallRules: [{FC9A52D6-E8D3-43D5-9EE5-A4CC0A72E7E1}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
    FirewallRules: [{5D44DDEE-E403-49B8-971A-46814BF7814C}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
    FirewallRules: [{65942B4D-AAD7-4320-BDFC-7B54A64A2DF8}] => (Allow) C:\Program Files (x86)\Intel\Extreme Tuning Utility\Client\PerfTune.exe
    FirewallRules: [{10EA7950-8535-46F1-BD21-00FA3E46A57C}] => (Allow) C:\Program Files (x86)\Skype\Phone\Skype.exe
    FirewallRules: [{2A95E67F-00BA-4C7F-982F-21737687F7C2}] => (Allow) C:\Program Files (x86)\Google\Google Talk\googletalk.exe
    FirewallRules: [{D349A76B-9E0E-4A55-BD62-98E51D8FC3FF}] => (Allow) C:\Program Files (x86)\Google\Google Talk\googletalk.exe
    FirewallRules: [TCP Query User{0F05B259-9FEA-40DD-A9E3-70A1E7D792A8}C:\program files (x86)\avid\pro tools\protools.exe] => (Allow) C:\program files (x86)\avid\pro tools\protools.exe
    FirewallRules: [UDP Query User{63BE29B2-A2E7-4578-97CC-D0DCBF7639AE}C:\program files (x86)\avid\pro tools\protools.exe] => (Allow) C:\program files (x86)\avid\pro tools\protools.exe
    FirewallRules: [TCP Query User{FD47186C-FB63-42B6-8252-1BA2D3D031C6}C:\users\samswanson\appdata\local\ivi deon\ivideonserver\ivideonserver.exe] => (Allow) C:\users\samswanson\appdata\local\ivideon\ivideons erver\ivideonserver.exe
    FirewallRules: [UDP Query User{B6461154-8899-4C23-922A-8B13A7389751}C:\users\samswanson\appdata\local\ivi deon\ivideonserver\ivideonserver.exe] => (Allow) C:\users\samswanson\appdata\local\ivideon\ivideons erver\ivideonserver.exe
    FirewallRules: [{33659DC1-1F98-439A-AEC3-57776D741690}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
    FirewallRules: [{4DCCEBA1-C481-409A-B6A3-9978F0C403D4}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
    FirewallRules: [{FE6ED81B-B560-40F0-8975-770BE8C4B4C5}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
    FirewallRules: [{DE906F04-5348-4E10-8278-2FA61E95B0B3}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe
    FirewallRules: [TCP Query User{C20C177B-0E29-469B-A6DA-2CF7B87D207D}C:\program files\webroot\wrsa.exe] => (Allow) C:\program files\webroot\wrsa.exe
    FirewallRules: [UDP Query User{A3922E75-DF5F-4382-9192-D3989C5686AE}C:\program files\webroot\wrsa.exe] => (Allow) C:\program files\webroot\wrsa.exe
    FirewallRules: [TCP Query User{E2572DE2-18A4-4838-BF78-D416F7A58F87}C:\users\samswanson\appdata\local\goo gle\chrome sxs\application\chrome.exe] => (Allow) C:\users\samswanson\appdata\local\google\chrome sxs\application\chrome.exe
    FirewallRules: [UDP Query User{4C7F8891-A519-4288-A555-D6B644C983F9}C:\users\samswanson\appdata\local\goo gle\chrome sxs\application\chrome.exe] => (Allow) C:\users\samswanson\appdata\local\google\chrome sxs\application\chrome.exe
    FirewallRules: [{8164E955-4659-4A72-8510-667E48F5CBCF}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
    FirewallRules: [{193307C5-27EA-4047-8D49-62699F1ABCA8}] => (Allow) C:\Program Files\NVIDIA Corporation\NvContainer\NvContainer.exe
    FirewallRules: [{23D75EBE-3F14-4B79-8CAD-EB12D7FA7A23}] => (Allow) C:\Program Files\NVIDIA Corporation\NvContainer\NvContainer.exe
    FirewallRules: [{F9C2D2D0-2A16-4751-8866-990FE9C3C851}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
    FirewallRules: [{16F6121E-B315-462F-9B0C-4753ECD149D7}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
    FirewallRules: [{C5E08516-C1BC-4B12-BB6E-45A9CE248B88}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
    FirewallRules: [{DE03B6B4-FD06-45C6-991C-EB99785E619A}] => (Allow) C:\Program Files\iTunes\iTunes.exe
    FirewallRules: [{2D32070B-BE19-469C-9749-20AF2E943B77}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer.exe
    FirewallRules: [{B2868D72-9C1F-442F-829F-7E3CC250B9D1}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer.exe
    FirewallRules: [{8E7B85F4-59CC-4743-ABDC-113EF0515C1A}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
    FirewallRules: [{80A0797C-B514-4C9D-9AD0-4030E922803D}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
    FirewallRules: [{151CDCEB-5350-4E0B-B3DF-5D1AFD444318}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
    FirewallRules: [{2FC9AC5D-2002-4226-851A-C906786981FE}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
    FirewallRules: [{CBF94C9D-E30C-4E5E-90C8-84E3E08CAE9B}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
    FirewallRules: [{447E0C97-2CD8-4303-8588-9CEE3774093C}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
    FirewallRules: [{E8226ED0-F618-4BFF-9414-9DE5D234B0E5}] => (Allow) C:\Program Files\MetaTrader 5\metatester64.exe
    FirewallRules: [{4FC8502B-C59D-4A3E-835A-1D56C834280C}] => (Allow) C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe
    FirewallRules: [{266AE150-5BAC-41F2-B9C7-3AEFEF2BD695}] => (Allow) C:\Program Files\SoftEther VPN Client\vpnclient.exe
    FirewallRules: [{A83100B2-AC65-4E83-BCA3-B70ACBD1F190}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmgr.exe
    FirewallRules: [{A6644206-9A35-4A7E-A8AF-0759C35D655D}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe
    FirewallRules: [{97AC4EC6-F9A0-4962-A2AB-EDA3242B18EE}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmd.exe
    FirewallRules: [{6AECC060-1F3B-47E6-8945-52A9F9577BC3}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmd_x64.exe
    FirewallRules: [{5726AA47-031F-426F-B0F5-64624B7C1215}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe
    StandardProfile\AuthorizedApplications: [C:\Program Files (x86)\FlashGet Network\FlashGet 3\FlashGet3.exe] => Enabled:Flashget3
    28-02-2017 11:49:12 UnHackMe Malware Removal
    01-03-2017 11:44:51 JRT Pre-Junkware Removal
    Name:
    Description:
    Class Guid:
    Manufacturer:
    Service:
    Problem: : The drivers for this device are not installed. (Code 28)
    Resolution: To install the drivers for this device, click “Update Driver”, which starts the Hardware Update wizard.
    Name: Primo Ramdisk Controller
    Description: Primo Ramdisk Controller
    Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
    Manufacturer: ROMEX SOFTWARE
    Service: FancyRd
    Problem: : This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
    Resolution: Update the driver
    Error: (03/01/2017 01:45:23 PM) (Source: ISCTAgent) (EventID: 1000) (User: )
    Description: CISCTPnpDriverApi::CreateInstance *****Unable to open the ISCT device driver
    Error: (03/01/2017 01:45:21 PM) (Source: Windows Search Service) (EventID: 10021) (User: )
    Description: Could not get performance counter registry info for WSearchIdxPi for instance due to the following error: The operation completed successfully. 0x0.
    Error: (03/01/2017 01:45:21 PM) (Source: Windows Search Service) (EventID: 3007) (User: )
    Description: Performance monitoring cannot be initialized for the gatherer object, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
    Context: Application, SystemIndex Catalog
    Error: (03/01/2017 01:45:21 PM) (Source: Windows Search Service) (EventID: 3006) (User: )
    Description: Performance monitoring cannot be initialized for the gatherer service, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
    Error: (03/01/2017 01:11:03 PM) (Source: Application Error) (EventID: 1000) (User: )
    Description: Faulting application name: microsoftedgecp.exe, version: 11.0.14393.82, time stamp: 0x57a55786
    Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
    Exception code: 0xc0000604
    Fault offset: 0x0000000000000000
    Faulting process id: 0x3928
    Faulting application start time: 0x01d29284dff4341e
    Faulting application path: C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wek yb3d8bbwe\microsoftedgecp.exe
    Faulting module path: unknown
    Report Id: 48e6d0c5-d8e4-4360-bb8d-3d6bb71a9fc6
    Faulting package full name: Microsoft.MicrosoftEdge_38.14393.0.0_neutral__8wek yb3d8bbwe
    Faulting package-relative application ID: MicrosoftEdge
    Error: (03/01/2017 01:11:01 PM) (Source: Application Error) (EventID: 1000) (User: )
    Report Id: 48790a9b-3153-47b4-a6e5-f22baa3906b6
    Error: (03/01/2017 01:11:00 PM) (Source: Application Error) (EventID: 1000) (User: )
    Report Id: 98b6a535-974c-449e-982a-a246c737bd67
    Error: (03/01/2017 01:10:59 PM) (Source: Application Error) (EventID: 1000) (User: )
    Report Id: a9a55e69-c8eb-463d-aaed-78bcb9e053a9
    Error: (03/01/2017 01:10:58 PM) (Source: Application Error) (EventID: 1000) (User: )
    Report Id: bd5faf09-c96e-41ac-8ba9-644fb2285df0
    Error: (03/01/2017 01:10:57 PM) (Source: Application Error) (EventID: 1000) (User: )
    Report Id: 6cc81cc9-2e64-4a70-a2c2-02284f9bf320
    Error: (03/01/2017 01:47:39 PM) (Source: DCOM) (EventID: 10010) (User: JIRICOMPUTER)
    Description: The server {21F282D1-A881-49E1-9A3A-26E44E39B86C} did not register with DCOM within the required timeout.
    Error: (03/01/2017 01:45:20 PM) (Source: Service Control Manager) (EventID: 7023) (User: )
    Description: The HvHost service terminated with the following error:
    A device attached to the system is not functioning.
    Error: (03/01/2017 01:45:20 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
    Description: The WinDefend service failed to start due to the following error:
    Windows cannot verify the digital signature for this file. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
    Error: (03/01/2017 01:45:20 PM) (Source: Service Control Manager) (EventID: 7024) (User: )
    Description: The HomeGroupListener service terminated with the following service-specific error:
    %%2147944153 = There are no more endpoints available from the endpoint mapper.
    Error: (03/01/2017 01:45:20 PM) (Source: NETLOGON) (EventID: 3095) (User: )
    Description: This computer is configured as a member of a workgroup, not as
    a member of a domain. The Netlogon service does not need to run in this
    configuration.
    Error: (03/01/2017 01:45:08 PM) (Source: volmgr) (EventID: 46) (User: )
    Description: Crash dump initialization failed!
    Error: (03/01/2017 01:45:07 PM) (Source: FancyRd) (EventID: 2) (User: )
    Description: The evaluation period for this installation of Primo Ramdisk has expired.
    Error: (03/01/2017 01:44:29 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
    and APPID
    to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
    Error: (03/01/2017 12:44:27 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
    Description: The eapihdrv service failed to start due to the following error:
    This driver has been blocked from loading
    Error: (03/01/2017 12:44:27 PM) (Source: Application Popup) (EventID: 1060) (User: )
    Description: ??\C:\Users\SAMSWA~1\AppData\Local\Temp\ehdrv.sys
    Date: 2017-03-01 13:45:20.462
    Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume4\Program Files\Windows Defender\MsMpEng.exe because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
    Date: 2017-03-01 13:10:23.122
    Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume4\Windows\System32\nvspcap64 .dll that did not meet the Store signing level requirements.
    Date: 2017-03-01 10:08:14.214
    Date: 2017-02-28 20:24:01.160
    Date: 2017-02-28 14:34:03.436
    Date: 2017-02-28 14:24:45.395
    Date: 2017-02-28 10:27:02.809
    Date: 2017-02-27 23:33:07.375
    Date: 2017-02-27 10:13:30.628
    Date: 2017-02-26 10:20:40.553
    Processor: Intel(R) Core™ i7-3770K CPU @ 3.50GHz
    Percentage of memory in use: 20%
    Total physical RAM: 32716.45 MB
    Available physical RAM: 26103.2 MB
    Total Virtual: 32716.45 MB
    Available Virtual: 25484.44 MB
    Drive c: () (Fixed) (Total:238.13 GB) (Free:113.97 GB) NTFS
    Drive r: (Redundant) (Fixed) (Total:2794.39 GB) (Free:1153.93 GB) NTFS
    Drive s: (Major Scott) (Fixed) (Total:2794.39 GB) (Free:1561.8 GB) NTFS
    Disk: 0 (MBR Code: Windows 7 or 8) (Size: 2794.5 GB) (Disk ID: 3DE8DBCF)
    Partition: GPT.
    Disk: 1 (MBR Code: Windows 7 or 8) (Size: 238.5 GB) (Disk ID: BCDE926D)
    Partition 1: (Active) - (Size=350 MB) - (Type=07 NTFS)
    Partition 2: (Not Active) - (Size=238.1 GB) - (Type=07 NTFS)
    Disk: 2 (MBR Code: Windows 7 or 8) (Size: 2794.5 GB) (Disk ID: 1CD3CAE0)
    Partition: GPT.
    Rkill Report:
    Rkill 2.8.4 by Lawrence Abrams (Grinler)
    Copyright 2008-2017 BleepingComputer.com
    More Information about Rkill can be found at this link:
    Program started at: 03/01/2017 05:57:09 PM in x64 mode.
    Windows Version: Windows 10 Pro
    Checking for Windows services to stop:
    • No malware services found to stop.
    Checking for processes to terminate:
    • No malware processes found to kill.
    Checking Registry for malware related settings:
    • No issues found in the Registry.
    Resetting .EXE, .COM, & .BAT associations in the Windows Registry.
    Performing miscellaneous checks:
    • Windows Defender Disabled
      [HKLM\SOFTWARE\Microsoft\Windows Defender]
      “DisableAntiSpyware” = dword:00000001
    • Reparse Point/Junctions Found (Most likely legitimate)!
      • C:\WINDOWS\ServiceProfiles\NetworkService\AppData\ Local\Microsoft\Windows\INetCache\Content.IE5 => C:\WINDOWS\ServiceProfiles\NetworkService\AppData\ Local\Microsoft\Windows\INetCache\IE [Dir]
    Checking Windows Service Integrity:
    • agp440 [Missing Service]
    • gagp30kx [Missing Service]
    • IEEtwCollectorService [Missing Service]
    • IoQos [Missing Service]
    • nv_agp [Missing Service]
    • TimeBroker [Missing Service]
    • uagp35 [Missing Service]
    • uliagpkx [Missing Service]
    • WcsPlugInService [Missing Service]
    • wpcfltr [Missing Service]
    • WSService [Missing Service]
    • AJRouter => %SystemRoot%\system32\svchost.exe -k LocalServiceNetworkRestricted [Incorrect ImagePath]
    • WpnService => %systemroot%\system32\svchost.exe -k netsvcs [Incorrect ImagePath]
    • vmicrdv => %SystemRoot%\System32\icsvcext.dll [Incorrect ServiceDLL]
    • vmicvss => %SystemRoot%\System32\icsvcext.dll [Incorrect ServiceDLL]
    Searching for Missing Digital Signatures:
    • No issues found.
    Checking HOSTS File:
    • HOSTS file entries found:
    127.0.0.1 localhost
    Program finished at: 03/01/2017 05:58:06 PM
    Execution time: 0 hours(s), 0 minute(s), and 57 seconds(s)
    AdwCleaner Report
    [HEADING=1]AdwCleaner v6.044 - Logfile created 01/03/2017 at 18:04:20[/HEADING]
    [HEADING=1]Updated on 28/02/2017 by Malwarebytes[/HEADING]
    [HEADING=1]Database : 2017-02-28.2 [Server][/HEADING]
    [HEADING=1]Operating System : Windows 10 Pro (X64)[/HEADING]
    [HEADING=1]Username : SamSwanson - JIRICOMPUTER[/HEADING]
    [HEADING=1]Running from : C:\Users\SamSwanson\Desktop\Computer fix\adwcleaner_6.044.exe[/HEADING]
    [HEADING=1]Mode: Scan[/HEADING]
    [HEADING=1]Support : Malwarebytes Help Center[/HEADING]
    ***** [ Services ] *****
    No malicious services found.
    ***** [ Folders ] *****
    No malicious folders found.
    ***** [ Files ] *****
    No malicious files found.
    ***** [ DLL ] *****
    No malicious DLLs found.
    ***** [ WMI ] *****
    No malicious keys found.
    ***** [ Shortcuts ] *****
    No infected shortcut found.
    ***** [ Scheduled Tasks ] *****
    No malicious task found.
    ***** [ Registry ] *****
    No malicious registry entries found.
    ***** [ Web browsers ] *****
    No malicious Firefox based browser items found.
    Chrome pref Found: [C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Secure Preferences ] - iabeihobmhlgpkcgjiloemdbofjbdcic
    Chrome pref Found: [C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Secure Preferences ] - aaaaaiabcopkplhgaedhbloeejhhankf
    Chrome pref Found: [C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Secure Preferences ] - mamnihopcnbfnbfnnneplcohmnkkpipb
    Chrome pref Found: [C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Secure Preferences ] - dgpdioedihjhncjafcpgbbjdpbbkikmi
    Chrome pref Found: [C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Secure Preferences ] - nedjejdfkkjgebciefdfofjhmeogiaga
    Chrome pref Found: [C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\User Data\Default\Secure Preferences ] - dgpdioedihjhncjafcpgbbjdpbbkikmi
    C:\AdwCleaner\AdwCleaner[C1].txt - [14067 Bytes] - [12/08/2016 15:02:17]
    C:\AdwCleaner\AdwCleaner[C2].txt - [5079 Bytes] - [05/12/2016 19:17:10]
    C:\AdwCleaner\AdwCleaner[C3].txt - [3399 Bytes] - [12/02/2017 23:44:50]
    C:\AdwCleaner\AdwCleaner[C4].txt - [2653 Bytes] - [13/02/2017 18:05:07]
    C:\AdwCleaner\AdwCleaner[C5].txt - [2811 Bytes] - [19/02/2017 18:07:14]
    C:\AdwCleaner\AdwCleaner[C6].txt - [2565 Bytes] - [21/02/2017 20:08:34]
    C:\AdwCleaner\AdwCleaner[S1].txt - [14440 Bytes] - [27/02/2016 01:27:24]
    C:\AdwCleaner\AdwCleaner[S2].txt - [356 Bytes] - [27/02/2016 11:35:21]
    C:\AdwCleaner\AdwCleaner[S3].txt - [5075 Bytes] - [05/12/2016 19:10:36]
    C:\AdwCleaner\AdwCleaner[S4].txt - [3532 Bytes] - [12/02/2017 23:37:34]
    C:\AdwCleaner\AdwCleaner[S5].txt - [2923 Bytes] - [13/02/2017 17:58:12]
    C:\AdwCleaner\AdwCleaner[S6].txt - [3081 Bytes] - [19/02/2017 18:01:33]
    C:\AdwCleaner\AdwCleaner[S7].txt - [2784 Bytes] - [21/02/2017 19:50:35]
    C:\AdwCleaner\AdwCleaner[S8].txt - [2784 Bytes] - [01/03/2017 18:04:20]
    ########## EOF - C:\AdwCleaner\AdwCleaner[S8].txt - [2857 Bytes] ##########
  • Malnutrition
    PCHF Moderator
    • 7041
    Let’s clean some trash from the machine before a FRST fix…
    Note: This tool will clean your browsing history as well.
    [li]Download CCleaner from here.[/li][li]After install Click Options.[/li][li]Go to monitoring.[/li][li]Uncheck All Monitoring items.[/li][li]Go to advanced – Click close program after cleaning.[/li][li]Go to settings – click run ccleaner when the computer starts.[/li][li]Now that you have ccleaner installed and set-up:[/li][li]Open the program.[/li][li]Go to Tools[/li][li]Go to Startup[/li][li]Now double click each item. To Disable.[/li][li]Leave only your antivirus enabled.[/li][li]Then disable All items in your scheduled task as well.[/li][li]Unless they are related to windows defender.Or your antivirus.[/li][li]Reboot the machine.[/li][/ul]
    JRT Scan.
    [li]Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.[/li][li]Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.[/li][li]The tool will open and start scanning your system.[/li][li]Please be patient as this can take a while to complete depending on your system’s specifications.[/li][li]On completion, a log is saved to your desktop and will automatically open.[/li][li]Please post the JRT log.[/li][/ul]
    Adware Removal Tool Scan.
    [MEDIA=imgur]LOr0Gd7[/MEDIA]
    Hit Ok.
    [MEDIA=imgur]sYFsqHx[/MEDIA]
    [MEDIA=imgur]8NcZjGc[/MEDIA]
    The Program will close all open programs to complete the removal, so save any work and hit OK. Then hit OK after the removal process is complete, thenOK again to finish up. Post log generated by tool.
    ZHP Scan.
    1. Once you have started the program, you will need to click the scanner button.
    [IMG alt="EgsT69u" width="602px" height="129px"]https://windowsinstructed.com/wp-content/uploads/2015/06/EgsT69u.png[/IMG]
    3. Once the scan is completed, the you will want to click the Repair button.
    [URL unfurl="true"]http://windowsinstructed.com/wp-content/uploads/2015/06/6QJjV50.png[/URL]
    At the end of the process you may be asked to reboot your machine. After you reboot a report will open on your desktop.
    Copy and paste the report here in your next reply.
    Let’s have a fresh look at your system after the above scans please.
    Please run Farbar Recovery Scan Tool to give me a fresh look at your system.
    [li]Right-click on FRST icon and select Run as Administrator to start the tool.[/li](XP users click run after receipt of Windows Security Warning - Open File).
    [li]Make sure that Addition option is checked, as well as Shortcut.txt[/li][li]Press Scan button and wait.[/li][li]The tool will produce three logfiles on your desktop: FRST.txt, and Addition.txt – & Shortcut.txt[/li][/ul]
    Please Copy & Paste them into your next reply. But attach Shortcut.txt
    • slonslon7
      • Mar 2017
      • 14
      Great! Thank you, seems like the tools found some stuff.
      Here are the reports:
      JRT:
      Version: 8.1.1 (02.11.2017)
      Operating System: Windows 10 Pro x64
      Ran by SamSwanson (Administrator) on 03/01/2017 at 19:58:49.14
      Code:
      File System: 1
      Successfully deleted: C:\Users\SamSwanson\AppData\Local\Google\Chrome\User Data\Default\Extensions\bmnlcjabgnpnenekpadlanbbkooimhnj (Folder)
      Registry: 2
      Successfully deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Run\\GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F8703B (Registry Value)
      Successfully deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Run\\GoogleChromeAutoLaunch_6884A160BCC04722E6F4385CB6FFBBDA (Registry Value)
      Scan was completed on 03/01/2017 at 20:10:14.85
      End of JRT log
      Code:
      [B]Adware Removal Tool:[/B]
      Adware Removal Tool 5.1
      Time: 2017_03_01_19_39_52
      OS: Windows 10 Pro - x64 Bit
      Account Name: SamSwanson
      Adware Definition: 03012017
      Elapsed time: 16:26
      Repair Status:- Automatic Done
      \\\\\\\\\\\\\\\\\\\\\\\ Repair Logs \\\\\\\\\\\\\\\\\\\\\\
      [-] Deleted ->> Registry Value Data ->> HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{4eb3fc20-7158-4dd5-a08e-707541e9341c}\ <RegValue:> AppPath <RegData:> C:\Users\SamSwanson\AppData\Local\Pokki\Download Helper : C:\Users\SamSwanson\AppData\Local\Pokki\Download Helper
      [-] Deleted ->> Registry Value Data ->> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{2EECD738-5844-4A99-B4B6-146BF802613B}\ <RegValue:> DllName <RegData:> BabylonToolbar.dll : BabylonToolbar.dll
      [-] Deleted ->> Registry Value Data ->> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E}\ <RegValue:> DllName <RegData:> BabylonToolbar.dll : BabylonToolbar.dll
      [-] Deleted ->> Registry Value Data ->> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{98889811-442D-49DD-99D7-DC866BE87DBC}\ <RegValue:> DllName <RegData:> BabylonToolbarTlbr.dll : BabylonToolbarTlbr.dll
      [-] Deleted ->> Registry Value Data ->> HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Extension Compatibility\{2EECD738-5844-4A99-B4B6-146BF802613B}\ <RegValue:> DllName <RegData:> BabylonToolbar.dll : BabylonToolbar.dll
      [-] Deleted ->> Registry Value Data ->> HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Extension Compatibility\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E}\ <RegValue:> DllName <RegData:> BabylonToolbar.dll : BabylonToolbar.dll
      [-] Deleted ->> Registry Value Data ->> HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Extension Compatibility\{98889811-442D-49DD-99D7-DC866BE87DBC}\ <RegValue:> DllName <RegData:> BabylonToolbarTlbr.dll : BabylonToolbarTlbr.dll
      [-] Repaired ->> File ->> C:\Users\SamSwanson\AppData\Local\Google\Chrome\User Data\Default\Preferences
      [-] Repaired ->> File ->> C:\Users\SamSwanson\AppData\Local\Google\Chrome\User Data\Default\Secure Preferences
      [-] Deleted ->> Registry Key ->> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{2EECD738-5844-4A99-B4B6-146BF802613B}
      [-] Deleted ->> Registry Key ->> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E}
      [-] Deleted ->> Registry Key ->> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{98889811-442D-49DD-99D7-DC866BE87DBC}
      [-] Deleted ->> Registry Key ->> HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Extension Compatibility\{2EECD738-5844-4A99-B4B6-146BF802613B}
      [-] Deleted ->> Registry Key ->> HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Extension Compatibility\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E}
      [-] Deleted ->> Registry Key ->> HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Extension Compatibility\{98889811-442D-49DD-99D7-DC866BE87DBC}
      [B]ZHPCleaner:[/B]
      > ~ ZHPCleaner v2017.2.27.37 by Nicolas Coolman (2017/02/27)
      ~ Run by SamSwanson (Administrator)  (01/03/2017 20:23:38)
      ~ Web:  https://www.nicolascoolman.com
      ~ Blog:  https://nicolascoolman.eu/
      ~ Facebook :  https://www.facebook.com/nicolascoolman1
      ~ State version : Version OK
      ~ Type : Repair
      ~ Report : C:\Users\SamSwanson\Desktop\ZHPCleaner.txt
      ~ Quarantine : C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPCleaner_Quarantine.txt
      ~ UAC : Activate
      ~ Boot Mode : Normal (Normal boot)
      Windows 10 Pro, 64-bit  (Build 14393)
      ---\\  Services (0)
      ~ No malicious or unnecessary items found.
      ---\\  Browser internet (0)
      ---\\  Hosts file (1)
      ~ The hosts file is legitimate (23)
      ---\\  Scheduled automatic tasks. (0)
      ---\\  Explorer ( File, Folder) (50)
      MOVED file: C:\Windows\Installer\wix{273E4CB3-22E9-42B8-9F9E-700A07158113}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{2E4AF2A6-50EA-4260-9BA4-5E582D11879A}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{3490D0B6-BB44-417E-8B82-F30C7B48E3F5}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{38EDF46C-6D02-41E7-B76F-C1330603B63B}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{44B72151-611E-429D-9765-9BA093D7E48A}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{49C3123D-9497-434D-A988-A9B389B1E189}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{583882E7-EA75-4BF0-94FA-7DD5A3731C76}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{6B23CC2A-3660-4430-920B-E3C706A252E4}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{7CC317AF-84DC-4C6B-9894-453545969892}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{919CE8F2-C283-4FBE-B29F-3BEA088C37EA}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{B5E06417-A4AC-4225-B36E-7E34C91616E7}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{D70884EA-E2CE-4539-91DB-4766CC1E5F5F}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{F4404AFD-2EF3-40C1-8C09-29E5F3B6972B}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Windows\Installer\wix{FE4EC25E-CCE4-477C-80B4-C6B351EE1BC6}.SchedServiceConfig.rmi    =>.Superfluous.Empty
      MOVED file: C:\Users\SamSwanson\Downloads\PokkiInstaller.exe [Pokki - Pokki Installer]  =>.Superfluous.SweetLabs
      MOVED file: C:\Windows\Installer\{4F524A2D-5350-4500-76A7-A758B70C1C01}\ToolbarIcon.exe    =>PUP.Optional.BrowserTabSearch
      MOVED folder: C:\Program Files (x86)\QuickTime  =>Riskware.QuickTime
      MOVED folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime  =>Riskware.QuickTime
      MOVED folder: C:\WINDOWS\Installer\MSI1AFE.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI1CFE.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI1F61.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI228D.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI2463.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI26F5.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI463A.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI4633.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI48AC.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI5A4F.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI6D7A.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI7725.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI79D6.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI87D.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI8DE2.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI8FC8.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI9326.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSI99B6.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIA42C.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIA63.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIABAF.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIBA6A.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIC33E.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIC335.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIC90B.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSICFA6.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIDE00.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIE2A.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIECF5.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIF9E5.tmp-  =>.Superfluous.Empty
      MOVED folder: C:\WINDOWS\Installer\MSIFE2C.tmp-  =>.Superfluous.Empty
      ---\\  Registry ( Key, Value, Data) (19)
      DELETED key*: [X64] HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{11111111-1111-1111-1111-110211671166} []  =>PUP.Optional.CrossRider
      DELETED key*: [X64] HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{31111111-1111-1111-1111-110211671166} []  =>PUP.Optional.CrossRider
      DELETED key*: [X64] HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110211671166} []  =>PUP.Optional.CrossRider
      DELETED key*: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\soundcloud.com []  =>PUP.Optional.SoundCloud
      DELETED key*: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\microsoft.microsoftedge_8wekyb3d8bbwe\Children\001\Internet Explorer\DOMStorage\soundcloud.com []  =>PUP.Optional.SoundCloud
      DELETED key*: [X64] HKLM\Software\Classes\Installer\Products\D2A425F405350054677A7A857BC0C110 [Search App by Ask]  =>PUP.Optional.BrowserTabSearch
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\00085D4C91CA53E438FC1F2F2C6B46DA [C:\ProgramData\Ableton\Live 9 Suite\Resources\Extensions\WebConnector\third_party\site-packages\decorator-3.3.2-py2.5.egg\EGG-INFO\PKG-INFO]  =>Adware.Sambreel
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\001286686E58BD54AB9C406325E69AD4 [C:\ProgramData\Ableton\Live 9 Suite\Resources\Extensions\WebConnector\third_party\lib\distutils\debug.pyc]  =>Adware.Sambreel
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0091CD89BDA3D68469CE2EB4994992D1 [C:\Program Files (x86)\Common Files\Native Instruments\Shared Content\Sounds\Reaktor 5\Blue Matrix\Elektro Popper HS.ksd]  =>PUP.Optional.Vonteera
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\010E70FAA1A2E204A99D9E21B7B03C79 [C:\ProgramData\Ableton\Live 9 Suite\Resources\Extensions\WebConnector\third_party\lib\encodings\euc_jis_2004.pyc]  =>Adware.Sambreel
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0125DAD2495BB2242AD12C79F6A2FD8A [S:\More VSTI\Abbey Road 50s Drummer Library\MIDI Files\07 Indie\13 Mid Groover 111BPM\05 8th Toms.mid]  =>PUP.Optional.Shopper
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\014E404DAF14D4F4098B05A6757EDAA6 [C:\ProgramData\Ableton\Live 9 Suite\Resources\Extensions\WebConnector\third_party\lib\encodings\latin_1.pyc]  =>Adware.Sambreel
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\017835FBFF3272B4DBF51AEBE7A2F09D [C:\ProgramData\Ableton\Live 9 Suite\Resources\Extensions\WebConnector\third_party\lib\encodings\__init__.pyc]  =>Adware.Sambreel
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\02458FFBE73543A4A9D78516C3AF4AF0 [C:\ProgramData\Ableton\Live 9 Suite\Resources\Extensions\WebConnector\third_party\lib\distutils\dir_util.pyc]  =>Adware.Sambreel
      DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\028BBEF6A9C7E514DBD346613B4DC0C8 [C:\Program Files (x86)\AskPartnerNetwork\Toolbar\ (Not File)]  =>PUP.Optional.APNToolBar
      DELETED key*: [X64] HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2} [Google Inc.]  =>Heuristic.Suspect
      DELETED key*: [X64] HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{D4F102C5-EEA1-CAE1-8E67-1A7FCE27F673} [Microsoft Corporations]  =>Heuristic.Suspect
      DELETED key*: [X64] HKLM\Software\Classes\Installer\Features\D2A425F405350054677A7A857BC0C110 []  =>PUP.Optional.BrowserTabSearch
      DELETED value: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\\QuickTime Task ["C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime]  =>Riskware.QuickTime
      ---\\  Summary of the elements found (11)
       https://nicolascoolman.eu/2017/01/20/logiciels-superflus/   =>.Superfluous.Empty
       https://nicolascoolman.eu/2017/01/20/logiciels-superflus/   =>.Superfluous.SweetLabs
       https://www.nicolascoolman.com/fr/pup-browsertabsearch/   =>PUP.Optional.BrowserTabSearch
       https://nicolascoolman.eu/2017/01/15/riskware-quicktime/   =>Riskware.QuickTime
       https://www.anti-malware.top/2016/04/30/pup-optional-crossrider/   =>PUP.Optional.CrossRider
       https://nicolascoolman.eu/2017/01/27/repaquetage-et-infection/   =>PUP.Optional.SoundCloud
       https://www.nicolascoolman.com/fr/pup-optional-sambreel/   =>Adware.Sambreel
       https://www.nicolascoolman.com/fr/trojan-vonteera/   =>PUP.Optional.Vonteera
       https://www.anti-malware.top/2016/05/02/pup-optional-shopper/   =>PUP.Optional.Shopper
       https://nicolascoolman.eu/2017/01/27/repaquetage-et-infection/   =>PUP.Optional.APNToolBar
       https://nicolascoolman.eu/2017/01/28/heuristic-suspect/   =>Heuristic.Suspect
      ---\\  Other deletions. (22)
      ~ Registry Keys Tracing deleted (22)
      ~ Remove the old reports ZHPCleaner. (0)
      ---\\ Result of repair
      ~ Repair carried out successfully
      ~ Browser not found (Google Chrome)
      ~ Browser not found (Opera Software)
      ---\\ Statistics
      ~ Items scanned : 901
      ~ Items found : 0
      ~ Items cancelled : 0
      ~ Items repaired : 69
      [B]FRST:
      [/B]
      > Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 01-03-2017
      Ran by SamSwanson (administrator) on JIRICOMPUTER (01-03-2017 20:29:24)
      Running from C:\Users\SamSwanson\Desktop\Computer fix
      Loaded Profiles: SamSwanson (Available Profiles: SamSwanson)
      Platform: Windows 10 Pro Version 1607 (X64) Language: English (United States)
      Internet Explorer Version 11 (Default browser: Edge)
      Boot Mode: Normal
      Tutorial for Farbar Recovery Scan Tool:  http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
      (Webroot) C:\Program Files\Webroot\WRSA.exe
      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
      (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe
      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
      (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cavwp.exe
      (Creative Technology Ltd) C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe
      (ArcSoft, Inc.) C:\Program Files (x86)\Common Files\ArcSoft\esinter\Bin\eservutil.exe
      () C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe
      (Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
      () C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AAHM\1.00.20\aaHMSvc.exe
      (Arainia Solutions) C:\Program Files (x86)\Gizmo\gservice.exe
      (Carbonite, Inc. ([www.carbonite.com]('http://www.carbonite.com'))) C:\Program Files\Carbonite\Carbonite Backup\CarboniteService.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.13\AsSysCtrlService.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AsusFanControlService\1.02.05\AsusFanControlService.exe
      (Nalpeiron Ltd.) C:\Windows\SysWOW64\nlssrv32.exe
      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
      (Acronis) C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe
      (TeamViewer GmbH) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
      (PACE Anti-Piracy, Inc.) C:\Program Files (x86)\Common Files\PACE\Services\LicenseServices\LDSvc.exe
      (Intel(R) Corporation) C:\Program Files\Intel Corporation\Intel(R) Technology Access\IntelTechnologyAccessService.exe
      (Intel(R) Corporation) C:\Program Files\Intel Corporation\Intel(R) Technology Access\LegacyCsLoaderService.exe
      (Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
      (Nitro PDF Software) C:\Program Files\Common Files\Nitro\Pro\8.0\NitroPDFDriverService8x64.exe
      (Copyright 2017.) C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
      (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
      (M-Audio) C:\Program Files (x86)\M-Audio\Oxygen\AudioDevMon.exe
      (Avid) C:\Program Files (x86)\Avid\Mbox\AudioDevMon.exe
      (Intel(R) Corporation) C:\Program Files\Intel\iCLS Client\HeciServer.exe
      (Intel Corporation) C:\Windows\System32\IPROSetMonitor.exe
      () C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe
      () C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe
      (SoftEther VPN Project at University of Tsukuba, Japan.) C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe
      (Binary Fortress Software) C:\Program Files (x86)\DisplayFusion\DisplayFusionService.exe
      (NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
      (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cistray.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe
      () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzUpdt.exe
      (Microsoft Corporation) C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\RemindersServer.exe
      (NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
      (Microsoft Corporation) C:\Windows\System32\SettingSyncHost.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\USB 3.0 Boost\U3BoostSvr64.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\TurboV EVO\TurboVHelp.exe
      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe
      (Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\EPU\EPUHelp.exe
      (Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
      (Microsoft Corporation) C:\Program Files\Windows Defender\MSASCuiL.exe
      (Dashlane, Inc.) C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashlane.exe
      () C:\Program Files (x86)\Ditto\Ditto.exe
      (Flux Software LLC) C:\Users\SamSwanson\AppData\Local\FluxSoftware\Flux\flux.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe
      () C:\Users\SamSwanson\AppData\Roaming\Dashlane\DashlanePlugin.exe
      (COMODO) C:\Program Files\COMODO\COMODO Internet Security\cis.exe
      () C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
      (Logitech Inc.) C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe
      () C:\Program Files (x86)\Logitech\LWS\Webcam Software\CameraHelperShell.exe
      () C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe
      (ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AI Suite II\Sensor\AlertHelper\AlertHelper.exe
      (Avid) C:\Program Files (x86)\Avid\Mbox\DriverInterface.exe
      (Universal Audio, Inc.) C:\Program Files (x86)\Universal Audio\Powered Plugins\UATrayIcon.exe
      (Universal Audio, Inc.) C:\Program Files (x86)\Universal Audio\Powered Plugins\UADPerfMon.exe
      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\Jhi_service.exe
      (Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
      (Nero AG) C:\Program Files (x86)\Nero\Update\NASvc.exe
      () C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
      (Intel(R) Corporation) C:\Program Files (x86)\Intel\Extreme Tuning Utility\XtuService.exe
      ==================== Registry (Whitelisted) ====================
      HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [8903176 2016-12-03] (Realtek Semiconductor)
      HKLM\...\Run: [Logitech Download Assistant] => C:\Windows\system32\rundll32.exe C:\Windows\System32\LogiLDA.dll,LogiFetch
      HKLM\...\Run: [THXCfg64] => C:\Windows\system32\RunDLL32.exe C:\Windows\system32\THXCfg64.dll,RunDLLEntry THXCfg64
      HKLM\...\Run: [RunDLLEntry] => C:\Windows\system32\RunDLL32.exe C:\Windows\system32\AmbRunE.dll,RunDLLEntry
      HKLM\...\Run: [Launch LCore] => C:\Program Files\Logitech Gaming Software\LCore.exe [7406392 2012-11-29] (Logitech Inc.)
      HKLM\...\Run: [EvtMgr6] => C:\Program Files\Logitech\SetPointP\SetPoint.exe [3091224 2013-07-31] (Logitech, Inc.)
      HKLM\...\Run: [ShadowPlay] => "C:\WINDOWS\system32\rundll32.exe" C:\WINDOWS\system32\nvspcap64.dll,ShadowPlayOnSystemStart
      HKLM\...\Run: [ZAM] => C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [14416624 2017-02-11] (Copyright 2017.)
      HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [176440 2017-02-11] (Apple Inc.)
      HKLM\...\Run: [Malwarebytes TrayApp] => C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\mbamtray.exe [2780112 2017-02-11] (Malwarebytes)
      HKLM\...\Run: [SoftEther VPN Client UI Helper] => C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe [5248456 2017-02-25] (SoftEther VPN Project at University of Tsukuba, Japan.)
      HKLM-x32\...\Run: [UpdReg] => C:\Windows\UpdReg.EXE [90112 2000-05-11] (Creative Technology Ltd.)
      HKLM-x32\...\Run: [SwitchBoard] => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated)
      HKLM-x32\...\Run: [LWS] => C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe [204136 2012-09-13] (Logitech Inc.)
      HKLM-x32\...\Run: [SunJavaUpdateSched (1)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
      HKLM-x32\...\Run: [SunJavaUpdateSched (2)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
      HKLM-x32\...\Run: [SunJavaUpdateSched (3)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
      HKLM-x32\...\Run: [DivXMediaServer] => C:\Program Files (x86)\DivX\DivX Media Server\DivXMediaServer.exe [448856 2014-12-28] (DivX, LLC)
      HKLM-x32\...\Run: [DivXUpdate] => C:\Program Files (x86)\DivX\DivX Update\DivXUpdate.exe [1861968 2014-12-28] ()
      HKLM-x32\...\Run: [CheckNDISPortf0ac3e] => C:\Program Files (x86)\Hostless Modem\Mobile Hotspot Admin\CheckNDISPort_df.exe [465664 2014-03-26] ()
      HKLM-x32\...\Run: [CancelAutoPlay_df] => C:\Program Files (x86)\Hostless Modem\Mobile Hotspot Admin\CancelAutoPlay_df.exe [446720 2014-03-26] ()
      HKLM-x32\...\Run: [AcronisTibMounterMonitor] => C:\Program Files (x86)\Common Files\Acronis\TibMounter\TibMounterMonitor.exe [421768 2016-06-29] (Acronis International GmbH)
      HKLM-x32\...\Run: [TrueImageMonitor.exe] => C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe [7382232 2016-10-31] ()
      HKLM-x32\...\Run: [WRSVC] => C:\Program Files\Webroot\WRSA.exe [992056 2017-01-18] (Webroot)
      HKLM-x32\...\Run: [UATrayIcon] => C:\Program Files (x86)\Universal Audio\Powered Plugins\UATrayIcon.exe [3804160 2016-10-25] (Universal Audio, Inc.)
      HKLM-x32\...\Run: [UAPerfMon] => C:\Program Files (x86)\Universal Audio\Powered Plugins\UADPerfMon.exe [5964288 2016-10-25] (Universal Audio, Inc.)
      HKLM-x32\...\Run: [SunJavaUpdateSched] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
      HKLM-x32\...\Run: [Carbonite Backup] => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteUI.exe [1265256 2017-01-25] (Carbonite, Inc.)
      HKLM\...\Policies\Explorer: [NoViewOnDrive] 0
      HKLM\...\Policies\Explorer: [DisableLocalMachineRun] 0
      HKLM\...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
      HKLM\...\Policies\Explorer: [DisableCurrentUserRun] 0
      HKLM\...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
      HKLM\...\Policies\Explorer: [NoViewContextMenu] 0
      HKLM\...\Policies\Explorer: [NoShellSearchButton] 0
      HKLM\...\Policies\Explorer: [NoFind] 0
      HKLM\...\Policies\Explorer: [NoFile] 0
      HKLM\...\Policies\Explorer: [HideClock] 0
      HKLM\...\Policies\Explorer: [NoTrayContextMenu] 0
      HKLM\...\Policies\Explorer: [NoTrayItemsDisplay] 0
      HKLM\...\Policies\Explorer: [NoSetFolders] 0
      HKLM\...\Policies\Explorer: [NoDevMgrUpdate] 0
      HKLM\...\Policies\Explorer: [NoSetTaskbar] 0
      HKLM\...\Policies\Explorer: [NoDeletePrinter] 0
      HKLM\...\Policies\Explorer: [NoDFSTab] 0
      HKLM\...\Policies\Explorer: [NoChangeStartMenu] 0
      HKLM\...\Policies\Explorer: [NoLogoff] 0
      HKLM\...\Policies\Explorer: [NoWindowsUpdate] 0
      HKLM\...\Policies\Explorer: [NoEncryptOnMove] 0
      HKLM\...\Policies\Explorer: [NoRunasInstallPrompt] 0
      HKLM\...\Policies\Explorer: [NoResolveSearch] 0
      HKLM\...\Policies\Explorer: [NoSaveSettings] 0
      HKLM\...\Policies\Explorer: [NoHardwareTab] 0
      HKLM\...\Policies\Explorer: [NoStartMenuSubFolders] 0
      HKLM\...\Policies\Explorer: [NoDesktop] 0
      HKU\S-1-5-19\...\Policies\system: [DisableCMD] 0
      HKU\S-1-5-19\...\Policies\system: [NoDispAppearancePage] 0
      HKU\S-1-5-19\...\Policies\system: [NoDispBackgroundPage] 0
      HKU\S-1-5-19\...\Policies\system: [NoDispSettingsPage] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoViewOnDrive] 0
      HKU\S-1-5-19\...\Policies\Explorer: [DisableLocalMachineRun] 0
      HKU\S-1-5-19\...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
      HKU\S-1-5-19\...\Policies\Explorer: [DisableCurrentUserRun] 0
      HKU\S-1-5-19\...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoViewContextMenu] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoShellSearchButton] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoFind] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoFile] 0
      HKU\S-1-5-19\...\Policies\Explorer: [HideClock] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoTrayContextMenu] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoTrayItemsDisplay] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoSetFolders] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoDevMgrUpdate] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoSetTaskbar] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoDeletePrinter] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoDFSTab] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoChangeStartMenu] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoLogoff] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoWindowsUpdate] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoEncryptOnMove] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoRunasInstallPrompt] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoResolveSearch] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoSaveSettings] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoHardwareTab] 0
      HKU\S-1-5-19\...\Policies\Explorer: [NoStartMenuSubFolders] 0
      HKU\S-1-5-20\...\Policies\system: [DisableCMD] 0
      HKU\S-1-5-20\...\Policies\system: [NoDispAppearancePage] 0
      HKU\S-1-5-20\...\Policies\system: [NoDispBackgroundPage] 0
      HKU\S-1-5-20\...\Policies\system: [NoDispSettingsPage] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoViewOnDrive] 0
      HKU\S-1-5-20\...\Policies\Explorer: [DisableLocalMachineRun] 0
      HKU\S-1-5-20\...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
      HKU\S-1-5-20\...\Policies\Explorer: [DisableCurrentUserRun] 0
      HKU\S-1-5-20\...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoViewContextMenu] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoShellSearchButton] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoFind] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoFile] 0
      HKU\S-1-5-20\...\Policies\Explorer: [HideClock] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoTrayContextMenu] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoTrayItemsDisplay] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoSetFolders] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoDevMgrUpdate] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoSetTaskbar] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoDeletePrinter] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoDFSTab] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoChangeStartMenu] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoLogoff] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoWindowsUpdate] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoEncryptOnMove] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoRunasInstallPrompt] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoResolveSearch] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoSaveSettings] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoHardwareTab] 0
      HKU\S-1-5-20\...\Policies\Explorer: [NoStartMenuSubFolders] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Dashlane] => C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashlane.exe [486352 2017-02-22] (Dashlane, Inc.)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Ditto] => C:\Program Files (x86)\Ditto\Ditto.exe [1433200 2012-11-09] ()
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [F.lux] => C:\Users\SamSwanson\AppData\Local\FluxSoftware\Flux\flux.exe [1016712 2013-10-16] (Flux Software LLC)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Google Update (1)] => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [144200 2015-08-31] (Google Inc.)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Google Update (2)] => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [144200 2015-08-31] (Google Inc.)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Google Update (3)] => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [144200 2015-08-31] (Google Inc.)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Google Update (4)] => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [144200 2015-08-31] (Google Inc.)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [DashlanePlugin] => C:\Users\SamSwanson\AppData\Roaming\Dashlane\DashlanePlugin.exe [544208 2017-02-20] ()
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Spotify Web Helper] => C:\Users\SamSwanson\AppData\Roaming\Spotify\SpotifyWebHelper.exe [1446000 2017-02-17] (Spotify Ltd)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Spotify] => C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotify.exe [7067760 2017-02-17] (Spotify Ltd)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [Google Update] => C:\Users\SamSwanson\AppData\Local\Google\Update\1.3.32.7\GoogleUpdateCore.exe [601752 2016-12-17] (Google Inc.)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [DAEMON Tools Lite Automount] => C:\Program Files (x86)\DAEMON Tools Lite\DTAgent.exe [4468056 2016-08-15] (Disc Soft Ltd)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Run: [GizmoDriveDelegate] => C:\Program Files (x86)\Gizmo\gizmo.exe [223640 2012-12-25] (Arainia Solutions)
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6381.0405\amd64] => C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6381.0405\amd64"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64] => C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\system: [DisableCMD] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\system: [NoDispAppearancePage] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\system: [NoDispBackgroundPage] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\system: [NoDispSettingsPage] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoCDBurning] 1
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoViewOnDrive] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [DisableLocalMachineRun] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [DisableCurrentUserRun] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoViewContextMenu] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoShellSearchButton] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoFind] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoFile] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [HideClock] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoTrayContextMenu] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoTrayItemsDisplay] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoSetFolders] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoDevMgrUpdate] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoSetTaskbar] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoDeletePrinter] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoDFSTab] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoChangeStartMenu] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoLogoff] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoWindowsUpdate] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoEncryptOnMove] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoRunasInstallPrompt] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoResolveSearch] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoSaveSettings] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoHardwareTab] 0
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Policies\Explorer: [NoStartMenuSubFolders] 0
      HKU\S-1-5-18\...\Policies\system: [DisableCMD] 0
      HKU\S-1-5-18\...\Policies\system: [NoDispAppearancePage] 0
      HKU\S-1-5-18\...\Policies\system: [NoDispBackgroundPage] 0
      HKU\S-1-5-18\...\Policies\system: [NoDispSettingsPage] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoViewOnDrive] 0
      HKU\S-1-5-18\...\Policies\Explorer: [DisableLocalMachineRun] 0
      HKU\S-1-5-18\...\Policies\Explorer: [DisableLocalMachineRunOnce] 0
      HKU\S-1-5-18\...\Policies\Explorer: [DisableCurrentUserRun] 0
      HKU\S-1-5-18\...\Policies\Explorer: [DisableCurrentUserRunOnce] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoViewContextMenu] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoShellSearchButton] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoFind] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoFile] 0
      HKU\S-1-5-18\...\Policies\Explorer: [HideClock] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoTrayContextMenu] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoTrayItemsDisplay] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoSetFolders] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoDevMgrUpdate] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoSetTaskbar] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoDeletePrinter] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoDFSTab] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoChangeStartMenu] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoLogoff] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoWindowsUpdate] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoEncryptOnMove] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoRunasInstallPrompt] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoResolveSearch] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoSaveSettings] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoHardwareTab] 0
      HKU\S-1-5-18\...\Policies\Explorer: [NoStartMenuSubFolders] 0
      ShellIconOverlayIdentifiers: [    Carbonite.Green] -> {95A27763-F62A-4114-9072-E81D87DE3B68} => C:\Program Files\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
      ShellIconOverlayIdentifiers: [    Carbonite.Partial] -> {E300CD91-100F-4E67-9AF3-1384A6124015} => C:\Program Files\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
      ShellIconOverlayIdentifiers: [    Carbonite.Yellow] -> {5E529433-B50E-4bef-A63B-16A6B71B071A} => C:\Program Files\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
      ShellIconOverlayIdentifiers: [00avast] -> {472083B0-C522-11CF-8763-00608CC02F24} =>  -> No File
      ShellIconOverlayIdentifiers: [AcronisSyncError] -> {934BC6C0-FEC2-4df5-A100-961DE2C8A0ED} => C:\Program Files (x86)\Acronis\TrueImageHome\tishell64.dll [2016-03-18] (Acronis)
      ShellIconOverlayIdentifiers: [AcronisSyncInProgress] -> {00F848DC-B1D4-4892-9C25-CAADC86A215D} => C:\Program Files (x86)\Acronis\TrueImageHome\tishell64.dll [2016-03-18] (Acronis)
      ShellIconOverlayIdentifiers: [AcronisSyncOk] -> {71573297-552E-46fc-BE3D-3DFAF88D47B7} => C:\Program Files (x86)\Acronis\TrueImageHome\tishell64.dll [2016-03-18] (Acronis)
      ShellIconOverlayIdentifiers: [MacDriveVolumeIcon] -> {6B21AF46-EE37-40D0-A707-C06C17D06CE9} => C:\Program Files\Mediafour\MacDrive 9\MDVolumeIcons.dll [2012-05-21] (Mediafour Corporation)
      ShellIconOverlayIdentifiers: [MacDriveVolumeIconReadOnly] -> {E9BC4DCA-0A4E-4C65-9D40-621C9D0CDC5F} => C:\Program Files\Mediafour\MacDrive 9\MDVolumeIcons.dll [2012-05-21] (Mediafour Corporation)
      ShellIconOverlayIdentifiers-x32: [    Carbonite.Green] -> {95A27763-F62A-4114-9072-E81D87DE3B68} => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
      ShellIconOverlayIdentifiers-x32: [    Carbonite.Partial] -> {E300CD91-100F-4E67-9AF3-1384A6124015} => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
      ShellIconOverlayIdentifiers-x32: [    Carbonite.Yellow] -> {5E529433-B50E-4bef-A63B-16A6B71B071A} => C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll [2017-01-25] (Carbonite, Inc.)
      Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Snagit 11.lnk [2016-08-23]
      ShortcutTarget: Snagit 11.lnk -> C:\Program Files (x86)\TechSmith\Snagit 11\Snagit32.exe (TechSmith Corporation)
      Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\SoftEther VPN Client Manager Startup.lnk [2017-02-25]
      ShortcutTarget: SoftEther VPN Client Manager Startup.lnk -> C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe (SoftEther VPN Project at University of Tsukuba, Japan.)
      Startup: C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\EffectRack.lnk [2016-08-11]
      ShortcutTarget: EffectRack.lnk -> C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe ()
      Startup: C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\SpeedFan.lnk [2016-08-16]
      ShortcutTarget: SpeedFan.lnk -> C:\Program Files (x86)\SpeedFan\speedfan.exe ()
      GroupPolicy: Restriction <======= ATTENTION
      GroupPolicyScripts: Restriction <======= ATTENTION
      Tcpip\Parameters: [DhcpNameServer] 213.46.172.36 213.46.172.37
      Tcpip\..\Interfaces\{2173f261-2e23-4f0a-940a-2a88ca2b214b}: [NameServer] 74.82.42.42,192.168.0.1
      Tcpip\..\Interfaces\{2173f261-2e23-4f0a-940a-2a88ca2b214b}: [DhcpNameServer] 213.46.172.36 213.46.172.37
      Tcpip\..\Interfaces\{7faf953a-453a-4de6-a3bc-2ce40997f6cc}: [NameServer] 8.8.8.8,8.8.4.4
      Tcpip\..\Interfaces\{7faf953a-453a-4de6-a3bc-2ce40997f6cc}: [DhcpNameServer] 213.46.172.36 213.46.172.37
      Tcpip\..\Interfaces\{a56f0fe6-a65d-419a-9a9d-a9f8c86c22bd}: [DhcpNameServer] 192.168.0.1 192.168.0.1
      Tcpip\..\Interfaces\{c09f412c-6a39-48fa-9e06-9f815d6e9d25}: [NameServer] 8.8.8.8,8.8.4.4
      Internet Explorer:
      HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
      HKU\.DEFAULT\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
      HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
      HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://[www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch]('http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch')
      HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://[www.microsoft.com/isapi/redir.dll?prd=ie&ar=msnhome]('http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=msnhome')
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://[www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch]('http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch')
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
      BHO: Skype for Business Browser Helper -> {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} -> C:\Program Files\Microsoft Office\Office15\OCHelper.dll [2016-05-27] (Microsoft Corporation)
      BHO: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files\Java\jre1.8.0_121\bin\ssv.dll [2017-02-20] (Oracle Corporation)
      BHO: Webroot Filtering Extension -> {C9C42510-9B41-42c1-9DCD-7282A2D07C61} -> C:\Program Files\Common Files\Webroot\WebFiltering\wrflt.dll [2017-01-27] (Webroot)
      BHO: Microsoft SkyDrive Pro Browser Helper -> {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} -> C:\Program Files\Microsoft Office\Office15\GROOVEEX.DLL [2016-05-17] (Microsoft Corporation)
      BHO: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files\Java\jre1.8.0_121\bin\jp2ssv.dll [2017-02-20] (Oracle Corporation)
      BHO-x32: Skype for Business Browser Helper -> {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} -> C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll [2016-05-27] (Microsoft Corporation)
      BHO-x32: Webroot Filtering Extension -> {C9C42510-9B41-42c1-9DCD-7282A2D07C61} -> C:\Program Files (x86)\Common Files\Webroot\WebFiltering\wrflt.dll [2017-01-27] (Webroot)
      BHO-x32: Microsoft SkyDrive Pro Browser Helper -> {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} -> C:\Program Files (x86)\Microsoft Office\Office15\GROOVEEX.DLL [2016-05-17] (Microsoft Corporation)
      Handler: osf - {D924BDC6-C83A-4BD5-90D0-095128A113D1} - C:\Program Files\Microsoft Office\Office15\MSOSB.DLL [2016-05-17] (Microsoft Corporation)
      Handler-x32: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files (x86)\Common Files\Skype\Skype4COM.dll [2017-01-01] (Skype Technologies)
      FireFox:
      FF DefaultProfile: [EMAIL]scoho7@gmail.com[/EMAIL]
      FF ProfilePath: C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefox\Profiles\lncyg2i6.default [2017-03-01]
      FF NewTab: Mozilla\Firefox\Profiles\lncyg2i6.default -> about:newtab
      FF DefaultSearchUrl: Mozilla\Firefox\Profiles\lncyg2i6.default ->
      FF SearchEngineOrder.1: Mozilla\Firefox\Profiles\lncyg2i6.default -> Google
      FF Homepage: Mozilla\Firefox\Profiles\lncyg2i6.default -> about:blank
      FF Keyword.URL: Mozilla\Firefox\Profiles\lncyg2i6.default ->
      FF Extension: (Dashlane) - C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefox\Profiles\lncyg2i6.default\Extensions\jetpack-extension@dashlane.com.xpi [2017-01-05]
      FF Extension: (Webroot Filtering Extension) - C:\ProgramData\WRData\PKG\FIREFOX\WebrootSecure_SocketServer [2017-01-27]
      FF SearchPlugin: C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefox\Profiles\lncyg2i6.default\searchplugins\google-avast.xml [2015-01-06]
      FF HKLM\...\Firefox\Extensions: [webrootsecure@webroot.com] - C:\ProgramData\WRData\PKG\FIREFOX\WebrootSecure_SocketServer
      FF HKLM-x32\...\Firefox\Extensions: [ffpwdman@bitdefender.com] - C:\Program Files\Bitdefender\Bitdefender\Antispam32\ffpwdman => not found
      FF HKLM-x32\...\Firefox\Extensions: [{F003DA68-8256-4b37-A6C4-350FA04494DF}] - C:\Program Files\Logitech\SetPointP\LogiSmoothFirefoxExt
      FF Extension: (Logitech SetPoint) - C:\Program Files\Logitech\SetPointP\LogiSmoothFirefoxExt [2014-01-06] [not signed]
      FF HKLM-x32\...\Firefox\Extensions: [webrootsecure@webroot.com] - C:\ProgramData\WRData\PKG\FIREFOX\WebrootSecure_SocketServer
      FF SearchPlugin: C:\Program Files (x86)\mozilla firefox\searchplugins\answers.xml [2010-12-03]
      FF SearchPlugin: C:\Program Files (x86)\mozilla firefox\searchplugins\creativecommons.xml [2010-12-03]
      FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_24_0_0_221.dll [2017-02-16] ()
      FF Plugin: @divx.com/DivX VOD Helper,version=1.0.0 -> C:\Program Files\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC.)
      FF Plugin: @java.com/DTPlugin,version=11.121.2 -> C:\Program Files\Java\jre1.8.0_121\bin\dtplugin\npDeployJava1.dll [2017-02-20] (Oracle Corporation)
      FF Plugin: @java.com/JavaPlugin,version=11.121.2 -> C:\Program Files\Java\jre1.8.0_121\bin\plugin2\npjp2.dll [2017-02-20] (Oracle Corporation)
      FF Plugin: @microsoft.com/SharePoint,version=14.0 -> C:\PROGRA~1\MICROS~2\Office15\NPSPWRAP.DLL [2014-01-23] (Microsoft Corporation)
      FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWoW64\Macromed\Flash\NPSWF32_24_0_0_221.dll [2017-02-16] ()
      FF Plugin-x32: @adobe.com/ShockwavePlayer -> C:\WINDOWS\SysWOW64\Adobe\Director\np32dsw.dll [2016-09-20] (Adobe Systems, Inc.)
      FF Plugin-x32: @divx.com/DivX VOD Helper,version=1.0.0 -> C:\Program Files (x86)\DivX\DivX OVS Helper\npovshelper.dll [2014-05-22] (DivX, LLC.)
      FF Plugin-x32: @divx.com/DivX Web Player Plug-In,version=1.0.0 -> C:\Program Files (x86)\DivX\DivX Web Player\npdivx32.dll [2014-11-21] (DivX, LLC)
      FF Plugin-x32: @ilok.com/iLokHelper,version=3.1.0.7 -> C:\Program Files (x86)\PACE Anti-Piracy\iLok\NPPaceILok.dll [2012-11-17] ( PACE Anti-Piracy, Inc)
      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=4.0.5 -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2000-01-01] (Intel Corporation)
      FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2000-01-01] (Intel Corporation)
      FF Plugin-x32: @microsoft.com/Lync,version=15.0 -> C:\Program Files (x86)\Mozilla Firefox\plugins\npmeetingjoinpluginoc.dll [2015-11-18] (Microsoft Corporation)
      FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 -> C:\PROGRA~2\MICROS~2\Office15\NPSPWRAP.DLL [2014-01-22] (Microsoft Corporation)
      FF Plugin-x32: @Nero.com/KM -> C:\PROGRA~2\COMMON~1\Nero\BROWSE~1\NPBROW~1.DLL [2012-08-10] (Nero AG)
      FF Plugin-x32: @nitropdf.com/NitroPDF -> C:\Program Files (x86)\Nitro\Pro 8\npnitromozilla.dll [2013-03-25] (Nitro PDF)
      FF Plugin-x32: @nvidia.com/3DVision -> C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dv.dll [2017-02-10] (NVIDIA Corporation)
      FF Plugin-x32: @nvidia.com/3DVisionStreaming -> C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dvstreaming.dll [2017-02-10] (NVIDIA Corporation)
      FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
      FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
      FF Plugin-x32: @videolan.org/vlc,version=2.1.3 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
      FF Plugin-x32: @videolan.org/vlc,version=2.1.5 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
      FF Plugin-x32: @videolan.org/vlc,version=2.2.1 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
      FF Plugin-x32: @videolan.org/vlc,version=2.2.4 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
      FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @citrixonline.com/appdetectorplugin -> C:\Users\SamSwanson\AppData\Local\Citrix\Plugins\104\npappdetector.dll [2013-09-12] (Citrix Online)
      FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @talk.google.com/GoogleTalkPlugin -> C:\Users\SamSwanson\AppData\Roaming\Mozilla\plugins\npgoogletalk.dll [2014-05-15] (Google)
      FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @talk.google.com/O1DPlugin -> C:\Users\SamSwanson\AppData\Roaming\Mozilla\plugins\npo1d.dll [2014-05-15] (Google)
      FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @tools.google.com/Google Update;version=3 -> C:\Users\SamSwanson\AppData\Local\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
      FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @tools.google.com/Google Update;version=9 -> C:\Users\SamSwanson\AppData\Local\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
      FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: ubisoft.com/uplaypc -> C:\Program Files (x86)\Ubisoft\Ubisoft Game Launcher\npuplaypc.dll [2013-06-20] ()
      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\npMeetingJoinPluginOC.dll [2015-11-18] (Microsoft Corporation)
      FF Plugin ProgramFiles/Appdata: C:\Program Files (x86)\mozilla firefox\plugins\npnul32.dll [2010-12-03] (mozilla.org)
      FF Plugin ProgramFiles/Appdata: C:\Users\SamSwanson\AppData\Roaming\mozilla\plugins\npgoogletalk.dll [2014-05-15] (Google)
      FF Plugin ProgramFiles/Appdata: C:\Users\SamSwanson\AppData\Roaming\mozilla\plugins\npo1d.dll [2014-05-15] (Google)
      FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\firefox-branding.js [2010-12-03]
      FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\firefox-l10n.js [2010-12-03]
      FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\firefox.js [2010-12-03]
      FF ExtraCheck: C:\Program Files (x86)\mozilla firefox\defaults\pref\reporter.js [2010-12-03]
      Chrome:
      CHR DefaultProfile: Default
      CHR HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [iahagolkpaghhinaljhjihagjgomdokb] - C:\Users\SamSwanson\AppData\Local\Alexa\atbpg-HyChcu-1.3.crx [2014-04-29]
      CHR HKLM-x32\...\Chrome\Extension: [kjeghcllfecehndceplomkocgfbklffd] - hxxps://clients2.google.com/service/update2/crx
      R2 AcrSch2Svc; C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe [1244408 2016-10-31] ()
      R2 ADExchange; C:\Program Files (x86)\Common Files\ArcSoft\esinter\Bin\eservutil.exe [44736 2013-10-24] (ArcSoft, Inc.)
      R2 afcdpsrv; C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe [4463592 2016-10-31] ()
      R2 AnonVPN VPN; C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe [127336 2016-05-24] ()
      R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2016-10-31] (Apple Inc.)
      R2 asComSvc; C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe [920736 2014-01-07] ()
      R2 asHmComSvc; C:\Program Files (x86)\ASUS\AAHM\1.00.20\aaHMSvc.exe [951936 2014-01-07] (ASUSTeK Computer Inc.)
      R2 AsSysCtrlService; C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.13\AsSysCtrlService.exe [149120 2014-01-07] (ASUSTeK Computer Inc.)
      R2 AsusFanControlService; C:\Program Files (x86)\ASUS\AsusFanControlService\1.02.05\AsusFanControlService.exe [2005504 2014-01-07] (ASUSTeK Computer Inc.) [File not signed]
      R2 cmdAgent; C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe [5817256 2016-10-13] (COMODO)
      S3 cmdvirth; C:\Program Files\COMODO\COMODO Internet Security\cmdvirth.exe [2271928 2016-10-13] (COMODO)
      S3 Creative ALchemy AL6 Licensing Service; C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\AL6Licensing.exe [79360 2012-12-23] (Creative Labs) [File not signed]
      S3 Creative Audio Engine Licensing Service; C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\CTAELicensing.exe [79360 2012-12-23] (Creative Labs) [File not signed]
      R2 CTAudSvcService; C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe [294912 2010-12-28] (Creative Technology Ltd) [File not signed]
      S3 Disc Soft Lite Bus Service; C:\Program Files (x86)\DAEMON Tools Lite\DiscSoftBusService.exe [1268568 2016-08-15] (Disc Soft Ltd)
      R2 DisplayFusionService; C:\Program Files (x86)\DisplayFusion\DisplayFusionService.exe [1243024 2013-02-11] (Binary Fortress Software)
      R2 Gizmo Central; C:\Program Files (x86)\Gizmo\gservice.exe [34728 2012-12-25] (Arainia Solutions)
      R3 ICCS; C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe [160768 2011-05-27] (Intel Corporation) [File not signed]
      S3 IDriverT; C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [69632 2005-04-04] (Macrovision Corporation) [File not signed]
      R2 Intel(R) Capability Licensing Service Interface; C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520 2013-08-27] (Intel(R) Corporation) [File not signed]
      S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [828376 2013-08-27] (Intel(R) Corporation)
      S3 Intel(R) TA SAM; C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [18152 2016-10-11] (Intel Corporation)
      R2 Intel(R) TechnologyAccessLegacyCSLoader; C:\Program Files\Intel Corporation\Intel(R) Technology Access\LegacyCsLoaderService.exe [153296 2016-06-10] (Intel(R) Corporation)
      R2 Intel(R) TechnologyAccessService; C:\Program Files\Intel Corporation\Intel(R) Technology Access\IntelTechnologyAccessService.exe [478416 2016-06-10] (Intel(R) Corporation)
      S2 ISCTAgent; c:\Program Files\Intel\Intel(R) Smart Connect Technology Agent\iSCTAgent.exe [149032 2012-08-16] ()
      S3 iumsvc; C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [177376 2016-10-11] (Intel Corporation)
      R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [169432 2000-01-01] (Intel Corporation)
      R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [4355024 2017-02-11] (Malwarebytes)
      R2 mmsminisrv; C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe [4884064 2016-06-29] (Acronis)
      R2 NitroDriverReadSpool8; C:\Program Files\Common Files\Nitro\Pro\8.0\NitroPDFDriverService8x64.exe [230408 2013-03-25] (Nitro PDF Software)
      R2 NvContainerLocalSystem; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [462784 2017-01-26] (NVIDIA Corporation)
      S3 NvContainerNetworkService; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [462784 2017-01-26] (NVIDIA Corporation)
      R2 NVDisplay.ContainerLocalSystem; C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe [464440 2017-02-10] (NVIDIA Corporation)
      R2 NvTelemetryContainer; C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe [425408 2017-01-26] (NVIDIA Corporation)
      R2 OxygenAudioDevMon; C:\Program Files (x86)\M-Audio\Oxygen\AudioDevMon.exe [1632776 2010-03-04] (M-Audio)
      S3 Sense; C:\Program Files\Windows Defender Advanced Threat Protection\MsSense.exe [2889896 2016-10-13] (Microsoft Corporation)
      R2 SEVPNCLIENT; C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe [5248456 2017-02-25] (SoftEther VPN Project at University of Tsukuba, Japan.)
      S3 SwitchBoard; C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated) [File not signed]
      R2 syncagentsrv; C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe [9698296 2016-06-29] ()
      R2 TeamViewer; C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe [10351856 2017-02-11] (TeamViewer GmbH)
      S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [347328 2016-07-16] (Microsoft Corporation)
      S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [103720 2016-07-16] (Microsoft Corporation)
      R2 WRSVC; C:\Program Files\Webroot\WRSA.exe [992056 2017-01-18] (Webroot)
      R2 XTU3SERVICE; C:\Program Files (x86)\Intel\Extreme Tuning Utility\XtuService.exe [14936 2012-08-17] (Intel(R) Corporation)
      R2 ZAMSvc; C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [14416624 2017-02-11] (Copyright 2017.)
      R1 AsIO; C:\Windows\SysWow64\drivers\AsIO.sys [15232 2012-08-22] ()
      R1 AsUpIO; C:\Windows\SysWow64\drivers\AsUpIO.sys [14464 2013-01-15] ()
      R3 ASUSFILTER; C:\Windows\SysWow64\drivers\ASUSFILTER.sys [46152 2011-09-20] (MCCI Corporation)
      S3 AU8168; C:\WINDOWS\system32\DRIVERS\au630x64.sys [792648 2013-09-23] (Realtek                                            )
      R1 CBDisk; C:\Windows\system32\drivers\CBDisk.sys [70344 2011-05-06] (EldoS Corporation)
      R1 cmderd; C:\WINDOWS\System32\DRIVERS\cmderd.sys [40960 2016-09-08] (COMODO)
      R1 cmdGuard; C:\WINDOWS\System32\DRIVERS\cmdguard.sys [862648 2016-09-08] (COMODO)
      R1 cmdhlp; C:\WINDOWS\system32\DRIVERS\cmdhlp.sys [54336 2016-09-08] (COMODO)
      R3 DDMF_Audio; C:\WINDOWS\system32\drivers\DDMFaudio.sys [28456 2015-07-15] (DDMF)
      R3 dtlitescsibus; C:\WINDOWS\System32\drivers\dtlitescsibus.sys [30264 2016-08-15] (Disc Soft Ltd)
      R1 ESProtectionDriver; C:\WINDOWS\system32\drivers\mbae64.sys [77416 2017-02-11] ()
      R0 FancyRd; C:\WINDOWS\System32\drivers\fancyrd.sys [188352 2012-06-24] (Romex Software)
      R0 file_tracker; C:\WINDOWS\System32\DRIVERS\file_tracker.sys [366432 2016-10-31] (Acronis International GmbH)
      R1 GizmoDrv; C:\Windows\System32\Drivers\GizmoDrv.sys [34704 2012-12-25] (Arainia Solutions LLC)
      S3 GVTDrv64; C:\Windows\GVTDrv64.sys [30528 2012-12-24] ()
      R1 HWiNFO32; C:\WINDOWS\SysWoW64\drivers\HWiNFO64A.SYS [27552 2016-11-22] (REALiX(tm))
      R3 ikbevent; C:\WINDOWS\system32\DRIVERS\ikbevent.sys [20968 2012-08-16] ()
      R3 iLokDrvr; C:\WINDOWS\System32\drivers\iLokDrvr.sys [25808 2013-10-27] ()
      R3 imsevent; C:\WINDOWS\system32\DRIVERS\imsevent.sys [19944 2012-08-16] ()
      R1 inspect; C:\WINDOWS\system32\DRIVERS\inspect.sys [147304 2016-09-08] (COMODO)
      R2 iocbios2; C:\Program Files (x86)\Intel\Extreme Tuning Utility\Drivers\IocDriver\64bit\iocbios2.sys [23832 2012-08-13] (Intel Corporation)
      R3 LGSHidFilt; C:\WINDOWS\system32\DRIVERS\LGSHidFilt.Sys [66360 2012-10-02] (Logitech Inc.)
      S3 LoopBe30; C:\WINDOWS\system32\drivers\loopbe30.sys [16896 2011-02-26] (nerds.de)
      R2 MBAMChameleon; C:\WINDOWS\system32\drivers\MBAMChameleon.sys [176584 2017-03-01] (Malwarebytes)
      R3 MBAMFarflt; C:\WINDOWS\system32\drivers\farflt.sys [110536 2017-03-01] (Malwarebytes)
      R3 MBAMProtection; C:\WINDOWS\system32\drivers\mbam.sys [43968 2017-03-01] (Malwarebytes)
      R3 MBAMSwissArmy; C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys [251848 2017-03-01] (Malwarebytes)
      R3 MBAMWebProtection; C:\WINDOWS\system32\drivers\mwac.sys [91584 2017-03-01] (Malwarebytes)
      R3 MBOX; C:\WINDOWS\system32\DRIVERS\AvidMbox.sys [464616 2016-08-15] (Avid)
      R3 MBOXDFU; C:\WINDOWS\System32\drivers\AvidMbox_DFU.sys [31464 2016-08-15] (Avid)
      R0 MDFSYSNT; C:\Windows\System32\Drivers\MDFSYSNT.sys [322768 2012-11-15] (Mediafour Corporation)
      R0 MDPMGRNT; C:\WINDOWS\System32\DRIVERS\MDPMGRNT.SYS [32464 2012-06-05] (Mediafour Corporation)
      R1 ndisrd; C:\WINDOWS\system32\DRIVERS\ndisrfl.sys [41688 2016-06-10] (Intel Corporation)
      R3 Neo_VPN; C:\WINDOWS\System32\drivers\Neo6_x64_VPN.sys [38216 2017-02-25] (SoftEther Corporation)
      S3 NetAdapterCx; C:\WINDOWS\System32\drivers\NetAdapterCx.sys [90624 2016-07-16] ()
      R3 NetTap630; C:\WINDOWS\system32\DRIVERS\nettap630.sys [67800 2016-06-10] (Intel Corporation)
      R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_02838dee03d82b94\nvlddmkm.sys [14427064 2017-02-10] (NVIDIA Corporation)
      S3 NvStreamKms; C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamKms.sys [27584 2017-01-20] (NVIDIA Corporation)
      R3 nvvad_WaveExtensible; C:\WINDOWS\system32\drivers\nvvad64v.sys [46016 2017-02-10] (NVIDIA Corporation)
      R3 nvvhci; C:\WINDOWS\System32\drivers\nvvhci.sys [57792 2017-02-10] (NVIDIA Corporation)
      R3 OXYGEN; C:\WINDOWS\system32\DRIVERS\MAudioOxygen.sys [134664 2010-03-04] (M-Audio)
      U0 Partizan; C:\Windows\SysWOW64\drivers\Partizan.sys [40304 2017-02-24] (Greatis Software)
      R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [943112 2016-11-22] (Realtek                                            )
      R1 SeLow; C:\WINDOWS\system32\DRIVERS\SeLow_x64.sys [51024 2017-02-25] (SoftEther Corporation)
      S3 SmbDrvI; C:\WINDOWS\system32\DRIVERS\Smb_driver_Intel.sys [43832 2012-08-24] (Synaptics Incorporated)
      S3 teVirtualMIDI64; C:\WINDOWS\system32\DRIVERS\teVirtualMIDI64.sys [30208 2012-08-16] (Tobias Erichsen)
      R0 tib; C:\WINDOWS\System32\DRIVERS\tib.sys [1267552 2016-10-31] (Acronis International GmbH)
      R2 tib_mounter; C:\WINDOWS\system32\DRIVERS\tib_mounter.sys [193376 2016-10-31] (Acronis International GmbH)
      S3 tnd; C:\WINDOWS\system32\DRIVERS\tnd.sys [601432 2016-10-31] (Acronis International GmbH)
      R3 UAD2Pcie; C:\WINDOWS\System32\drivers\UAD2Pcie.sys [82752 2016-11-03] (Universal Audio, Inc.)
      R3 UAD2System; C:\WINDOWS\System32\drivers\UAD2System.sys [134464 2016-11-03] (Universal Audio, Inc.)
      R3 UAD2WdmAudio; C:\WINDOWS\system32\DRIVERS\UAD2WdmAudio.sys [27968 2016-11-03] ()
      R3 VBAudioHFVAIOMME; C:\WINDOWS\system32\DRIVERS\vbaudio_hfvaio64_win7.sys [33512 2014-03-07] (Windows (R) Win 7 DDK provider)
      R2 virtual_file; C:\WINDOWS\System32\DRIVERS\virtual_file.sys [279392 2016-06-29] (Acronis International GmbH)
      U5 vwifimp; C:\Windows\System32\Drivers\vwifimp.sys [39936 2016-07-16] (Microsoft Corporation)
      S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44056 2016-07-16] (Microsoft Corporation)
      S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [290144 2016-07-16] (Microsoft Corporation)
      S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [123232 2016-07-16] (Microsoft Corporation)
      S3 WPRO_41_2001; C:\WINDOWS\System32\drivers\WPRO_41_2001.sys [34752 2014-01-03] ()
      R0 WRkrn; C:\WINDOWS\System32\drivers\WRkrn.sys [143248 2017-02-27] (Webroot)
      R3 wrUrlFlt; C:\Windows\system32\DRIVERS\wrUrlFlt.sys [66328 2016-10-11] (Webroot)
      R1 ZAM; C:\WINDOWS\System32\drivers\zam64.sys [203680 2017-02-11] (Zemana Ltd.)
      R1 ZAM_Guard; C:\WINDOWS\System32\drivers\zamguard64.sys [203680 2017-02-11] (Zemana Ltd.)
      S3 FreshIO; \??\C:\Program Files (x86)\FreshDevices\FreshDiagnose\FreshIO.sys [X]
      S3 ManyCam; \SystemRoot\system32\DRIVERS\mcvidrv.sys [X]
      S3 mcaudrv_simple; \SystemRoot\system32\drivers\mcaudrv_x64.sys [X]
      U0 SR; no ImagePath
      U2 srservice; no ImagePath
      2017-03-01 20:11 - 2017-03-01 20:24 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\ZHP
      2017-03-01 19:30 - 2017-03-01 19:30 - 02746880 _____ C:\Users\SamSwanson\Downloads\ec19.tmp
      2017-03-01 19:25 - 2017-03-01 19:40 - 00290304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\subinacl.exe
      2017-03-01 19:25 - 2017-03-01 19:25 - 00000000 ____D C:\Program Files (x86)\Adware Removal Tool by TSA
      2017-03-01 14:33 - 2017-03-01 14:33 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Overloud
      2017-03-01 14:33 - 2017-03-01 14:33 - 00000000 ____D C:\ProgramData\Overloud
      2017-03-01 13:43 - 2017-03-01 13:43 - 00154624 _____ C:\Users\SamSwanson\Desktop\SigLotSizeCalV1.2.xls
      2017-03-01 12:43 - 2017-03-01 12:43 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\ESET
      2017-02-28 22:48 - 2017-03-01 13:45 - 00000000 ____D C:\ProgramData\Malwarebytes' Anti-Malware (portable)
      2017-02-28 14:25 - 2017-02-28 14:25 - 00000000 ____D C:\ProgramData\MetaQuotes
      2017-02-28 14:24 - 2017-02-28 14:24 - 00002075 _____ C:\Users\Public\Desktop\Tradeo - MetaTrader 4.lnk
      2017-02-28 14:24 - 2017-02-28 14:24 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tradeo - MetaTrader 4
      2017-02-28 14:24 - 2017-02-28 14:24 - 00000000 ____D C:\Program Files (x86)\Tradeo - MetaTrader 4
      2017-02-27 23:05 - 2017-02-27 23:05 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Carbonite
      2017-02-25 14:26 - 2017-02-25 14:26 - 00038216 _____ (SoftEther Corporation) C:\WINDOWS\system32\Drivers\Neo6_x64_VPN.sys
      2017-02-25 14:23 - 2017-03-01 20:27 - 00000000 ____D C:\Program Files\SoftEther VPN Client
      2017-02-25 14:23 - 2017-02-25 14:23 - 00143816 _____ (SoftEther VPN Project at University of Tsukuba, Japan.) C:\WINDOWS\system32\vpncmd.exe
      2017-02-25 14:23 - 2017-02-25 14:23 - 00051024 _____ (SoftEther Corporation) C:\WINDOWS\system32\Drivers\SeLow_x64.sys
      2017-02-25 14:23 - 2017-02-25 14:23 - 00001980 _____ C:\ProgramData\Microsoft\Windows\Start Menu\SoftEther VPN Client Manager.lnk
      2017-02-25 14:23 - 2017-02-25 14:23 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client
      2017-02-24 18:44 - 2017-03-01 13:45 - 00000984 _____ C:\WINDOWS\SysWOW64\PARTIZAN.TXT
      2017-02-24 18:41 - 2017-02-24 18:41 - 00000000 ____D C:\@RestoreQuarantine
      2017-02-24 18:28 - 2017-02-24 23:58 - 00000000 ____D C:\ProgramData\RegRun
      2017-02-24 18:27 - 2017-03-01 19:33 - 00002668 _____ C:\WINDOWS\System32\Tasks\UnHackMe Task Scheduler
      2017-02-24 18:27 - 2017-03-01 12:43 - 00000000 ____D C:\Users\SamSwanson\Documents\RegRun2
      2017-02-24 18:27 - 2017-02-24 18:27 - 00040304 _____ (Greatis Software) C:\WINDOWS\SysWOW64\Drivers\Partizan.sys
      2017-02-24 18:27 - 2017-02-24 18:27 - 00000002 RSHOT C:\WINDOWS\winstart.bat
      2017-02-24 18:27 - 2017-02-24 18:27 - 00000002 RSHOT C:\WINDOWS\SysWOW64\CONFIG.NT
      2017-02-24 18:27 - 2017-02-24 18:27 - 00000002 RSHOT C:\WINDOWS\SysWOW64\AUTOEXEC.NT
      2017-02-24 18:26 - 2017-03-01 10:10 - 00000000 ____D C:\Users\Public\Documents\regruninfo
      2017-02-24 18:26 - 2017-02-24 18:30 - 00000000 ____D C:\Program Files (x86)\UnHackMe
      2017-02-24 18:26 - 2017-02-24 18:26 - 00049968 _____ (Greatis Software) C:\WINDOWS\system32\partizan.exe
      2017-02-24 18:26 - 2017-02-24 18:26 - 00014984 _____ (Greatis Software, LLC.) C:\WINDOWS\SysWOW64\Drivers\UnHackMeDrv.sys
      2017-02-24 18:26 - 2017-02-24 18:26 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe
      2017-02-24 16:57 - 2017-02-24 16:57 - 06971584 _____ (Tim Kosse) C:\Users\SamSwanson\Downloads\FileZilla_3.24.1_win64-setup.exe
      2017-02-23 01:05 - 2017-02-23 01:05 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MetaTrader 5
      2017-02-23 01:05 - 2017-02-23 01:05 - 00000000 ____D C:\Program Files\MetaTrader 5
      2017-02-23 01:04 - 2017-02-23 01:05 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\MetaQuotes
      2017-02-21 16:25 - 2017-02-21 16:26 - 00000000 ____D C:\ProgramData\SupremoRemoteDesktop
      2017-02-21 15:52 - 2017-02-21 16:01 - 00000000 ____D C:\ProgramData\Emsisoft
      2017-02-21 15:25 - 2017-02-21 15:25 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Revo Uninstaller
      2017-02-21 15:24 - 2017-02-21 15:24 - 00000000 ____D C:\Program Files\VS Revo Group
      2017-02-21 14:47 - 2017-02-21 14:47 - 00000120 ___RH C:\Users\SamSwanson\Desktop\Stinger.opt
      2017-02-21 14:39 - 2017-02-21 14:47 - 00000000 ____D C:\Program Files\stinger
      2017-02-21 14:39 - 2017-02-21 14:39 - 00000000 ____D C:\Program Files\McAfee
      2017-02-20 21:33 - 2017-02-20 21:33 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\PackageStaging
      2017-02-20 21:31 - 2017-02-20 21:31 - 00000000 ____D C:\WINDOWS\Panther
      2017-02-20 21:05 - 2017-02-20 21:05 - 00000000 ____D C:\WINDOWS\pss
      2017-02-20 21:01 - 2017-03-01 19:33 - 00003068 _____ C:\WINDOWS\System32\Tasks\Tweaking.com - Windows Repair Tray Icon
      2017-02-20 21:01 - 2017-02-20 21:01 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tweaking.com
      2017-02-20 21:01 - 2017-02-20 21:01 - 00000000 ____D C:\Program Files (x86)\Tweaking.com
      2017-02-20 20:33 - 2017-02-20 20:24 - 00110144 _____ (Oracle Corporation) C:\WINDOWS\SysWOW64\WindowsAccessBridge-64.dll
      2017-02-20 20:24 - 2017-02-20 20:24 - 00110144 _____ (Oracle Corporation) C:\WINDOWS\system32\WindowsAccessBridge-64.dll
      2017-02-19 17:20 - 2017-02-19 17:20 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RogueKiller
      2017-02-19 16:28 - 2017-03-01 20:29 - 00000000 ____D C:\FRST
      2017-02-16 11:45 - 2017-02-24 17:06 - 00000869 _____ C:\Users\Public\Desktop\REAPER (x64).lnk
      2017-02-16 00:59 - 2017-02-16 00:59 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\AnonVPN
      2017-02-15 21:57 - 2017-03-01 19:33 - 00002280 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
      2017-02-15 21:52 - 2017-03-01 20:29 - 00000000 ____D C:\Users\SamSwanson\Desktop\Computer fix
      2017-02-15 17:34 - 2017-02-15 17:34 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\HomeDev
      2017-02-15 17:34 - 2017-02-15 17:34 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HomeDev
      2017-02-15 17:34 - 2017-02-15 17:34 - 00000000 ____D C:\Program Files (x86)\HomeDev
      2017-02-15 17:26 - 2017-02-15 17:26 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinDirStat
      2017-02-15 17:26 - 2017-02-15 17:26 - 00000000 ____D C:\Program Files (x86)\WinDirStat
      2017-02-15 17:05 - 2017-02-15 17:05 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Toshiba Corporation
      2017-02-15 17:05 - 2017-02-15 17:05 - 00000000 ____D C:\ProgramData\Toshiba Corporation
      2017-02-15 17:04 - 2017-02-15 17:04 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Toshiba Corporation
      2017-02-15 17:04 - 2017-02-15 17:04 - 00000000 ____D C:\Program Files (x86)\Toshiba Corporation
      2017-02-15 17:03 - 2017-02-15 17:04 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\FreshDiagnose
      2017-02-15 16:57 - 2017-02-15 16:57 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\JxBrowser
      2017-02-13 16:16 - 2017-02-13 16:16 - 00000000 ____D C:\WINDOWS\System32\Tasks\Safer-Networking
      2017-02-13 14:56 - 2017-02-13 16:16 - 00000000 ____D C:\ProgramData\Spybot - Search & Destroy
      2017-02-13 14:26 - 2017-02-13 14:26 - 00100984 _____ C:\Users\SamSwanson\Documents\VME Accounts Gnucash.gnucash.20170213142617.gnucash
      2017-02-13 14:24 - 2017-02-13 14:24 - 00100834 _____ C:\Users\SamSwanson\Documents\VME Accounts Gnucash.gnucash.20170213142442.gnucash
      2017-02-13 00:03 - 2017-02-13 00:03 - 00000000 ____D C:\ProgramData\Sophos
      2017-02-13 00:00 - 2017-02-13 00:00 - 04656523 _____ C:\Users\SamSwanson\Downloads\tdsskiller.zip
      2017-02-13 00:00 - 2017-02-13 00:00 - 00208216 _____ (Kaspersky Lab, GERT) C:\WINDOWS\system32\Drivers\55447846.sys
      2017-02-12 18:19 - 2017-02-12 18:19 - 00014856 ____N C:\bootsqm.dat
      2017-02-11 16:08 - 2017-03-01 20:26 - 00176584 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMChameleon.sys
      2017-02-11 16:08 - 2017-03-01 20:26 - 00110536 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\farflt.sys
      2017-02-11 16:08 - 2017-03-01 20:26 - 00091584 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mwac.sys
      2017-02-11 16:07 - 2017-02-11 16:07 - 00077416 _____ C:\WINDOWS\system32\Drivers\mbae64.sys
      2017-02-11 16:07 - 2017-02-11 16:07 - 00001116 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamViewer 12.lnk
      2017-02-11 16:07 - 2017-02-11 16:07 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
      2017-02-11 16:07 - 2017-02-11 16:07 - 00000000 ____D C:\Program Files\Malwarebytes
      2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Process Lasso
      2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
      2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\Program Files\iTunes
      2017-02-11 16:04 - 2017-02-11 16:04 - 00000000 ____D C:\Program Files\iPod
      2017-02-11 15:29 - 2017-03-01 20:29 - 00078596 _____ C:\WINDOWS\ZAM.krnl.trace
      2017-02-11 15:29 - 2017-03-01 20:29 - 00034981 _____ C:\WINDOWS\ZAM_Guard.krnl.trace
      2017-02-11 15:29 - 2017-02-11 15:29 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zamguard64.sys
      2017-02-11 15:29 - 2017-02-11 15:29 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zam64.sys
      2017-02-11 15:29 - 2017-02-11 15:29 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware
      2017-02-11 15:29 - 2017-02-11 15:29 - 00000000 ____D C:\Program Files (x86)\Zemana AntiMalware
      2017-02-10 22:40 - 2017-02-10 22:40 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Zemana
      2017-02-10 22:39 - 2017-02-10 22:39 - 00012872 _____ (SurfRight B.V.) C:\WINDOWS\system32\bootdelete.exe
      2017-02-10 22:39 - 2017-02-10 22:39 - 00002398 _____ C:\WINDOWS\system32\.crusader
      2017-02-10 22:27 - 2017-02-10 22:27 - 00000000 ____D C:\Program Files\HitmanPro
      2017-02-10 22:26 - 2017-02-10 22:39 - 00000000 ____D C:\ProgramData\HitmanPro
      2017-02-10 20:18 - 2017-02-10 20:18 - 00134080 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvStreaming.exe
      2017-02-10 20:17 - 2017-02-10 20:17 - 00125728 _____ C:\WINDOWS\system32\vulkaninfo.exe
      2017-02-10 20:17 - 2017-02-10 20:17 - 00111392 _____ C:\WINDOWS\SysWOW64\vulkaninfo.exe
      2017-02-10 20:17 - 2017-02-10 20:17 - 00000000 ____D C:\Program Files (x86)\VulkanRT
      2017-02-10 20:17 - 2016-12-16 01:33 - 00273696 _____ C:\WINDOWS\SysWOW64\vulkan-1.dll
      2017-02-10 20:17 - 2016-12-16 01:33 - 00266528 _____ C:\WINDOWS\system32\vulkan-1.dll
      2017-02-10 20:09 - 2017-02-10 20:17 - 00047664 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvhdap64.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 40192056 _____ C:\WINDOWS\system32\nvcompiler.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 35272760 _____ C:\WINDOWS\SysWOW64\nvcompiler.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 28239928 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvoglv32.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 19008576 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvopencl.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 14677272 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvopencl.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 11123936 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuda.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 11019192 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvptxJitCompiler.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 09308896 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuda.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 08990584 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvptxJitCompiler.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 03167288 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuvid.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 02715072 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuvid.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 01985080 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispco6437849.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 01591352 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispgenco6437849.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 01051584 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvFBC64.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00988608 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvFBC.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00960568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFR64.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00946456 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncMFTH264.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00909760 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFR.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00721952 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncMFTH264.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00687224 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvfatbinaryLoader.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00609216 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFROpenGL.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00606776 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvDecMFTMjpeg.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00576192 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvfatbinaryLoader.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00573120 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncodeAPI64.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00499136 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFROpenGL.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00483384 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvDecMFTMjpeg.dll
      2017-02-10 20:09 - 2017-02-10 20:11 - 00447800 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncodeAPI.dll
      2017-02-10 20:09 - 2017-01-20 17:38 - 00000669 _____ C:\WINDOWS\SysWOW64\nv-vk32.json
      2017-02-10 20:09 - 2017-01-20 17:38 - 00000669 _____ C:\WINDOWS\system32\nv-vk64.json
      2017-02-10 20:02 - 2017-02-10 20:02 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Chromium
      2017-02-10 20:02 - 2017-01-20 19:41 - 01872320 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspcap64.dll
      2017-02-10 20:02 - 2017-01-20 19:41 - 01755072 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspbridge64.dll
      2017-02-10 20:02 - 2017-01-20 19:41 - 01464768 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspcap.dll
      2017-02-10 20:02 - 2017-01-20 19:41 - 01317312 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspbridge.dll
      2017-02-10 20:02 - 2017-01-20 19:41 - 00120256 _____ C:\WINDOWS\system32\NvRtmpStreamer64.dll
      2017-02-10 20:01 - 2017-03-01 19:33 - 00002918 _____ C:\WINDOWS\System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
      2017-02-10 19:59 - 2017-03-01 19:33 - 00003044 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
      2017-02-10 19:59 - 2017-03-01 19:33 - 00003016 _____ C:\WINDOWS\System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
      2017-02-10 19:59 - 2017-03-01 19:33 - 00002898 _____ C:\WINDOWS\System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
      2017-02-10 19:59 - 2017-03-01 19:33 - 00002846 _____ C:\WINDOWS\System32\Tasks\NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
      2017-02-10 19:59 - 2017-03-01 19:33 - 00002804 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
      2017-02-10 19:59 - 2017-01-26 09:15 - 00001951 _____ C:\WINDOWS\NvTelemetryContainerRecovery.bat
      2017-02-10 19:58 - 2017-02-10 20:01 - 00057792 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvhci.sys
      2017-02-10 19:58 - 2017-02-10 19:59 - 00156608 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvaudcap64v.dll
      2017-02-10 19:58 - 2017-02-10 19:59 - 00124352 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvaudcap32v.dll
      2017-02-10 19:58 - 2017-02-10 19:59 - 00046016 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvad64v.sys
      2017-02-10 13:29 - 2017-02-20 20:33 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java
      2017-02-08 10:43 - 2017-02-10 20:15 - 00001951 _____ C:\WINDOWS\NvContainerRecovery.bat
      2017-02-08 10:08 - 2017-02-28 15:41 - 00002590 _____ C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Google Chrome Canary.lnk
      2017-02-08 10:08 - 2017-02-28 15:41 - 00002582 _____ C:\Users\SamSwanson\Desktop\Google Chrome Canary.lnk
      2017-01-31 00:10 - 2017-02-16 13:28 - 00000000 ____D C:\Users\SamSwanson\AppData\LocalLow\Mozilla
      2017-03-01 20:27 - 2012-12-23 13:44 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Ditto
      2017-03-01 20:26 - 2016-08-11 19:50 - 00000006 ____H C:\WINDOWS\Tasks\SA.DAT
      2017-03-01 20:26 - 2016-07-16 07:04 - 01835008 _____ C:\WINDOWS\system32\config\BBI
      2017-03-01 20:26 - 2014-06-15 15:30 - 00251848 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
      2017-03-01 20:26 - 2012-12-26 18:57 - 00043968 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbam.sys
      2017-03-01 20:02 - 2013-07-28 08:17 - 00000000 ____D C:\WINDOWS\system32\MRT
      2017-03-01 19:59 - 2016-07-16 12:36 - 00000000 ____D C:\WINDOWS\CbsTemp
      2017-03-01 19:59 - 2012-12-23 13:51 - 138020592 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
      2017-03-01 19:45 - 2016-08-11 19:50 - 00003468 _____ C:\WINDOWS\System32\Tasks\{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4}
      2017-03-01 19:45 - 2016-08-11 19:50 - 00002352 _____ C:\WINDOWS\System32\Tasks\{31DDBD37-5DB7-4030-8064-10B0CAA806C3}
      2017-03-01 19:44 - 2016-08-11 19:50 - 00002144 _____ C:\WINDOWS\System32\Tasks\open effects
      2017-03-01 19:41 - 2016-08-11 19:48 - 00832116 _____ C:\WINDOWS\system32\PerfStringBackup.INI
      2017-03-01 19:41 - 2014-11-06 20:01 - 00485032 ____N (Microsoft Corporation) C:\WINDOWS\system32\MpSigStub.exe
      2017-03-01 19:38 - 2016-07-16 12:45 - 00000000 ____D C:\WINDOWS\INF
      2017-03-01 19:38 - 2016-06-05 17:05 - 00000000 ____D C:\Program Files (x86)\TeamViewer
      2017-03-01 19:38 - 2013-02-28 11:48 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\CrashDumps
      2017-03-01 19:37 - 2017-01-12 17:52 - 00000830 _____ C:\WINDOWS\Tasks\Adobe Flash Player Updater.job
      2017-03-01 19:37 - 2016-12-03 22:13 - 00000892 _____ C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job
      2017-03-01 19:37 - 2012-12-23 12:43 - 00000000 ____D C:\ProgramData\NVIDIA
      2017-03-01 19:37 - 2012-12-23 12:23 - 00000954 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA.job
      2017-03-01 19:37 - 2012-12-23 12:23 - 00000902 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core.job
      2017-03-01 19:36 - 2012-12-24 01:02 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Spotify
      2017-03-01 19:33 - 2017-01-27 09:59 - 00002832 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task v2
      2017-03-01 19:33 - 2017-01-12 17:52 - 00003104 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
      2017-03-01 19:33 - 2016-12-26 18:15 - 00002610 _____ C:\WINDOWS\System32\Tasks\{EE492B24-CD47-404D-95D3-605112E375FA}
      2017-03-01 19:33 - 2016-12-03 22:13 - 00003410 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player PPAPI Notifier
      2017-03-01 19:33 - 2016-08-15 15:00 - 00002894 _____ C:\WINDOWS\System32\Tasks\Patch My PC
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003622 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003552 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003404 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineUA
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003354 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003280 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003180 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineCore
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003154 _____ C:\WINDOWS\System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d
      2017-03-01 19:33 - 2016-08-11 19:50 - 00003102 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473
      2017-03-01 19:33 - 2016-08-11 19:50 - 00002920 _____ C:\WINDOWS\System32\Tasks\20160623_163758_Restore 12 0
      2017-03-01 19:33 - 2016-08-11 19:50 - 00002920 _____ C:\WINDOWS\System32\Tasks\20160618_170750_Restore 12 0
      2017-03-01 19:33 - 2016-08-11 19:50 - 00002812 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-3236326594-2611474830-2656184370-1001
      2017-03-01 19:33 - 2016-08-11 19:50 - 00002788 _____ C:\WINDOWS\System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d-Logon
      2017-03-01 19:33 - 2016-08-11 19:50 - 00002740 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon
      2017-03-01 19:33 - 2016-08-11 19:50 - 00002398 _____ C:\WINDOWS\System32\Tasks\Process Lasso Core Engine Only
      2017-03-01 19:33 - 2015-07-24 10:55 - 00000000 ____D C:\ProgramData\WRData
      2017-03-01 19:20 - 2016-08-11 19:35 - 00000000 ____D C:\WINDOWS\system32\SleepStudy
      2017-03-01 18:23 - 2012-12-23 12:27 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Spotify
      2017-03-01 18:04 - 2016-02-27 01:27 - 00000000 ____D C:\AdwCleaner
      2017-03-01 15:42 - 2016-06-13 10:39 - 00000096 _____ C:\Users\SamSwanson\AppData\Roaming\msregsvv.dll
      2017-03-01 15:42 - 2014-01-22 13:15 - 00000128 _____ C:\ProgramData\autobk.inc
      2017-03-01 15:42 - 2012-12-27 05:17 - 00000000 ____D C:\ProgramData\ValhallaRoom
      2017-03-01 13:58 - 2013-05-04 00:13 - 00000000 ___HD C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA
      2017-03-01 13:58 - 2012-10-14 18:47 - 00000000 ___HD C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX
      2017-03-01 13:56 - 2012-12-24 01:13 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\vlc
      2017-03-01 13:53 - 2016-11-23 15:33 - 00000000 ____D C:\ProgramData\boost_interprocess
      2017-03-01 13:43 - 2012-12-23 10:57 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Packages
      2017-03-01 10:32 - 2016-02-15 14:22 - 00028272 _____ C:\WINDOWS\system32\Drivers\TrueSight.sys
      2017-03-01 10:07 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\tracing
      2017-03-01 00:07 - 2016-01-11 10:36 - 00000000 ____D C:\Users\Public\Documents\ExponentialAudioLogs
      2017-02-27 18:03 - 2016-06-29 15:03 - 00143248 _____ (Webroot) C:\WINDOWS\system32\Drivers\WRkrn.sys
      2017-02-26 20:27 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\AppReadiness
      2017-02-25 14:58 - 2012-12-23 13:18 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\REAPER
      2017-02-25 14:03 - 2016-08-12 14:55 - 00000051 _____ C:\Users\SamSwanson\deletedRoute.txt
      2017-02-25 14:03 - 2016-08-12 14:54 - 00009424 _____ C:\Users\SamSwanson\AnonVPN.ovpn
      2017-02-25 10:26 - 2016-07-16 12:47 - 00000000 ___HD C:\Program Files\WindowsApps
      2017-02-24 19:51 - 2015-02-14 01:28 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Mp3tag
      2017-02-24 18:40 - 2016-08-31 16:31 - 00000000 ____D C:\Program Files\Handbrake
      2017-02-24 18:40 - 2014-08-03 21:04 - 00000000 ____D C:\Program Files (x86)\KDNicheFinder
      2017-02-24 17:06 - 2012-12-23 13:18 - 00000000 ____D C:\Program Files\REAPER (x64)
      2017-02-24 16:58 - 2013-02-17 13:21 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\FileZilla
      2017-02-24 11:36 - 2012-12-24 02:10 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\iZotope
      2017-02-23 00:26 - 2016-12-14 23:19 - 00000000 ____D C:\Users\SamSwanson\Desktop\Travel Plans
      2017-02-22 17:26 - 2012-12-23 12:51 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Dashlane
      2017-02-22 17:25 - 2014-03-07 00:23 - 00002013 _____ C:\Users\SamSwanson\Desktop\Dashlane.lnk
      2017-02-22 17:25 - 2012-12-23 12:51 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Dashlane
      2017-02-22 01:23 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\SysWOW64\Macromed
      2017-02-22 01:23 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\Macromed
      2017-02-22 00:10 - 2013-01-09 06:42 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Nitro PDF
      2017-02-21 17:37 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\system32\NDF
      2017-02-21 16:44 - 2016-12-03 21:06 - 00000000 ____D C:\Program Files\CCleaner
      2017-02-21 16:09 - 2016-12-18 13:41 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Electrum
      2017-02-21 16:09 - 2015-12-02 13:37 - 03123997 _____ C:\Users\SamSwanson\Desktop\Money 4 Music.epub
      2017-02-21 15:32 - 2014-09-16 18:19 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Joey Sturgis Tones
      2017-02-21 15:32 - 2014-09-16 18:19 - 00000000 ____D C:\Program Files\Joey Sturgis Tones
      2017-02-21 15:32 - 2012-12-24 06:19 - 00000000 ____D C:\Program Files\Common Files\VST3
      2017-02-21 14:39 - 2016-06-13 17:53 - 00000000 ____D C:\QUARANTINE
      2017-02-20 21:36 - 2016-08-11 19:38 - 00000000 ____D C:\Users\SamSwanson
      2017-02-20 21:31 - 2012-12-23 10:57 - 00000000 ____D C:\WINDOWS\CSC
      2017-02-20 21:29 - 2016-12-05 18:56 - 00000214 _____ C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask.job
      2017-02-20 21:28 - 2016-08-11 19:35 - 04961528 _____ C:\WINDOWS\system32\FNTCACHE.DAT
      2017-02-20 21:19 - 2016-03-30 16:21 - 00000000 ____D C:\Users\SamSwanson\Desktop\Social Media Course
      2017-02-20 21:19 - 2014-06-07 09:57 - 00000000 ____D C:\Users\SamSwanson\mediahint
      2017-02-20 21:19 - 2014-04-04 13:18 - 00000000 ____D C:\Users\SamSwanson\Desktop\Drumatom
      2017-02-20 21:19 - 2013-08-05 18:07 - 00000000 ____D C:\Users\SamSwanson\Desktop\StudioPhotoShoot
      2017-02-20 21:19 - 2013-02-21 13:15 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\DisplayFusion
      2017-02-20 21:19 - 2013-01-03 18:33 - 00000000 ____D C:\Users\SamSwanson\Documents\TAX
      2017-02-20 21:17 - 2012-12-23 11:50 - 06096688 _____ C:\WINDOWS\SysWOW64\PerfStringBackup.INI
      2017-02-20 20:33 - 2012-12-23 12:25 - 00000000 ____D C:\Program Files (x86)\Java
      2017-02-20 20:25 - 2016-08-15 15:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management
      2017-02-20 20:25 - 2016-08-15 15:04 - 00000000 ____D C:\Program Files\Calibre2
      2017-02-20 20:24 - 2012-12-23 12:25 - 00000000 ____D C:\Program Files\Java
      2017-02-20 20:21 - 2016-08-15 14:52 - 00605984 _____ ([www.patchmypc.net]('http://www.patchmypc.net')) C:\Users\SamSwanson\Desktop\PatchMyPC.exe
      2017-02-20 17:51 - 2016-02-15 14:24 - 00007602 _____ C:\Users\SamSwanson\AppData\Local\Resmon.ResmonCfg
      2017-02-19 17:20 - 2016-04-21 13:59 - 00000000 ____D C:\Program Files\RogueKiller
      2017-02-19 14:24 - 2015-07-15 20:46 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\DDMF Effect Rack
      2017-02-19 11:52 - 2014-08-24 11:43 - 00000000 ____D C:\Program Files (x86)\Media Gobbler, Inc
      2017-02-19 11:52 - 2013-06-05 10:24 - 00000000 ____D C:\ProgramData\Package Cache
      2017-02-19 11:52 - 2012-12-23 13:38 - 00000000 ____D C:\ProgramData\Gobbler
      2017-02-18 21:47 - 2013-02-17 14:33 - 00000000 ____D C:\ProgramData\ValhallaUberMod
      2017-02-16 17:07 - 2014-02-10 03:09 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Spectrasonics
      2017-02-16 11:45 - 2016-11-23 09:34 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)
      2017-02-16 00:59 - 2016-08-12 14:54 - 00001150 _____ C:\Users\SamSwanson\Desktop\AnonVPN.lnk
      2017-02-16 00:59 - 2016-08-12 14:54 - 00000000 ____D C:\Program Files (x86)\AnonVPN
      2017-02-15 22:06 - 2015-01-11 23:36 - 00007710 _____ C:\WINDOWS\system32\--traceoff
      2017-02-15 22:04 - 2012-12-27 22:58 - 00000000 ____D C:\Program Files (x86)\PdaNet for Android
      2017-02-15 22:03 - 2014-09-13 15:35 - 00000000 ____D C:\Program Files\iZotope
      2017-02-15 22:03 - 2012-12-25 00:35 - 00000000 ____D C:\Users\SamSwanson\Documents\iZotope
      2017-02-15 22:03 - 2012-12-25 00:32 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope
      2017-02-15 22:03 - 2012-12-25 00:29 - 00000000 ____D C:\Program Files (x86)\iZotope
      2017-02-15 22:03 - 2012-12-24 06:19 - 00000000 ____D C:\Program Files\VSTPlugIns
      2017-02-15 22:02 - 2012-12-23 13:11 - 00000000 ____D C:\Program Files (x86)\Growl for Windows
      2017-02-15 22:01 - 2014-02-12 13:01 - 00000000 ____D C:\Program Files (x86)\NeoSmart Technologies
      2017-02-15 22:01 - 2012-12-24 01:07 - 00000000 __RHD C:\Users\Public\AccountPictures
      2017-02-15 22:00 - 2013-09-12 14:56 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Citrix
      2017-02-15 22:00 - 2013-05-24 22:11 - 00000000 __SHD C:\WINDOWS\SysWOW64\AI_RecycleBin
      2017-02-15 22:00 - 2013-05-24 22:11 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Copy
      2017-02-15 21:59 - 2013-05-26 16:02 - 00000000 ____D C:\Program Files (x86)\Audacity
      2017-02-15 18:43 - 2013-06-20 07:57 - 01418640 _____ C:\WINDOWS\system32\Drivers\fvstore.dat
      2017-02-15 16:50 - 2013-07-14 23:12 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CrystalDiskInfo
      2017-02-15 16:50 - 2013-07-14 23:12 - 00000000 ____D C:\Program Files (x86)\CrystalDiskInfo
      2017-02-13 15:55 - 2013-01-20 16:48 - 00000000 ____D C:\Users\SamSwanson\.gconfd
      2017-02-13 15:41 - 2013-01-20 16:48 - 00000000 ____D C:\Users\SamSwanson\.gconf
      2017-02-13 15:14 - 2015-06-13 09:16 - 00000000 ____D C:\Program Files\Common Files\AV
      2017-02-13 14:26 - 2016-06-13 13:37 - 00100965 _____ C:\Users\SamSwanson\Documents\VME Accounts Gnucash.gnucash
      2017-02-12 00:07 - 2013-03-09 22:52 - 00000132 _____ C:\Users\SamSwanson\AppData\Roaming\Adobe PNG Format CS5 Prefs
      2017-02-11 16:12 - 2012-12-23 13:01 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Skype
      2017-02-11 16:07 - 2016-06-05 17:05 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\TeamViewer
      2017-02-11 16:07 - 2014-06-15 15:30 - 00000000 ____D C:\Program Files (x86)\Malwarebytes Anti-Malware
      2017-02-11 16:07 - 2012-12-26 18:57 - 00000000 ____D C:\ProgramData\Malwarebytes
      2017-02-11 16:06 - 2016-08-15 15:07 - 00000000 ___RD C:\Program Files (x86)\Skype
      2017-02-11 16:06 - 2012-12-23 12:27 - 00000000 ____D C:\ProgramData\Skype
      2017-02-11 16:04 - 2013-07-10 17:57 - 00000000 ____D C:\Program Files\Process Lasso
      2017-02-11 16:04 - 2012-12-23 12:30 - 00000000 ____D C:\Program Files\Common Files\Apple
      2017-02-11 16:00 - 2016-08-15 14:58 - 00001232 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox.lnk
      2017-02-11 16:00 - 2016-08-15 14:58 - 00000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
      2017-02-11 16:00 - 2013-02-21 13:32 - 00000000 ____D C:\Program Files (x86)\Mozilla Firefox
      2017-02-11 12:25 - 2014-01-12 15:06 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\NVIDIA Corporation
      2017-02-10 22:43 - 2016-07-16 12:47 - 00000000 ____D C:\WINDOWS\InputMethod
      2017-02-10 22:39 - 2015-06-24 20:14 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\mgyun
      2017-02-10 20:20 - 2013-03-14 16:55 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
      2017-02-10 20:20 - 2012-12-23 12:43 - 00000000 ____D C:\ProgramData\NVIDIA Corporation
      2017-02-10 20:17 - 2016-12-16 01:33 - 00111392 _____ C:\WINDOWS\SysWOW64\vulkaninfo-1-1-0-37-0.exe
      2017-02-10 20:17 - 2016-12-16 01:32 - 00125728 _____ C:\WINDOWS\system32\vulkaninfo-1-1-0-37-0.exe
      2017-02-10 20:17 - 2015-12-01 17:32 - 01600056 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvhdagenco6420103.dll
      2017-02-10 20:17 - 2015-12-01 17:32 - 00217528 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvhda64v.sys
      2017-02-10 20:12 - 2012-12-23 12:43 - 00000000 ____D C:\Program Files\NVIDIA Corporation
      2017-02-10 20:11 - 2016-08-11 20:08 - 34974656 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvoglv64.dll
      2017-02-10 20:11 - 2016-08-11 20:08 - 04079032 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvapi64.dll
      2017-02-10 20:11 - 2016-08-11 20:08 - 03597640 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvapi.dll
      2017-02-10 20:11 - 2016-07-16 15:29 - 00420408 _____ (Khronos Group) C:\WINDOWS\SysWOW64\opencl.dll
      2017-02-10 20:11 - 2012-12-23 12:43 - 00514616 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.dll
      2017-02-10 20:01 - 2013-07-05 05:36 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\NVIDIA
      2017-02-10 20:01 - 2012-12-23 12:43 - 00000000 ____D C:\Program Files (x86)\NVIDIA Corporation
      2017-02-10 18:50 - 2013-09-17 09:45 - 00000000 ____D C:\ProgramData\Ashampoo
      2017-02-10 18:50 - 2013-02-23 16:34 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Smart PC Solutions
      2017-02-10 18:50 - 2013-02-23 16:34 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Smart PC Solutions
      2017-02-10 13:34 - 2016-11-22 08:52 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Booster 4
      2017-02-09 15:39 - 2015-12-20 01:44 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\boost_interprocess
      2017-02-09 15:39 - 2012-12-24 02:10 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Celemony Software GmbH
      2017-02-08 23:41 - 2012-12-24 06:23 - 00000000 ____D C:\ProgramData\Slate Digital
      2017-02-08 19:27 - 2016-03-02 16:15 - 00001919 _____ C:\Users\Public\Documents\Lurssen TimeLimitReadExpiration.txt
      2017-02-08 19:27 - 2016-03-02 16:15 - 00000292 _____ C:\Users\Public\Documents\Lurssen TimeLimitGenerateLockNames Log.txt
      2017-02-08 19:27 - 2016-03-02 16:15 - 00000095 _____ C:\Users\Public\Documents\Lorssen Log.txt
      2017-02-08 19:27 - 2016-03-02 16:15 - 00000069 _____ C:\Users\Public\Documents\Lurssen CopyProt Log.txt
      2017-02-08 19:27 - 2016-03-02 16:15 - 00000008 _____ C:\Users\Public\Documents\Lurssen TimeLimitWriteOneProductSettings.txt
      2017-02-08 10:42 - 2017-01-04 15:19 - 01964600 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispco6437653.dll
      2017-02-08 10:42 - 2017-01-04 15:19 - 01600056 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispgenco6437653.dll
      2017-02-07 17:49 - 2013-06-27 14:37 - 00005632 _____ C:\Users\SamSwanson\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
      2017-02-06 20:48 - 2016-07-16 12:49 - 00835576 _____ C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
      2017-02-06 20:48 - 2016-07-16 12:49 - 00177656 _____ C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
      2017-02-06 20:48 - 2014-08-27 13:28 - 00002272 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
      2017-02-03 20:31 - 2013-05-26 16:03 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Audacity
      2017-02-03 11:38 - 2015-06-30 19:18 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\ssd_sampler
      2017-02-02 16:48 - 2012-12-22 22:13 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVS4YOU
      2017-02-02 16:48 - 2012-12-22 22:13 - 00000000 ____D C:\Program Files (x86)\AVS4YOU
      2017-02-02 16:47 - 2012-12-22 22:14 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\AVS4YOU
      2017-02-02 16:46 - 2012-12-22 22:13 - 00000000 ____D C:\Users\SamSwanson\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\AVS4YOU
      2013-01-09 05:51 - 2012-10-02 21:03 - 2712200 _____ (Sysinternals - [www.sysinternals.com]('http://www.sysinternals.com')) C:\Program Files\procexp.exe
      2016-10-29 19:23 - 2016-10-29 19:23 - 2722286 _____ () C:\Program Files (x86)\Auto-Tune 8 Manual.pdf
      2016-10-29 19:23 - 2016-10-29 19:23 - 0056051 _____ () C:\Program Files (x86)\VST PC Read Me.pdf
      2013-07-29 18:50 - 2013-07-29 18:50 - 0000132 _____ () C:\Users\SamSwanson\AppData\Roaming\Adobe BMP Format CS5 Prefs
      2013-06-11 13:27 - 2015-08-13 11:46 - 0000132 _____ () C:\Users\SamSwanson\AppData\Roaming\Adobe GIF Format CS5 Prefs
      2013-03-09 22:52 - 2017-02-12 00:07 - 0000132 _____ () C:\Users\SamSwanson\AppData\Roaming\Adobe PNG Format CS5 Prefs
      2014-02-12 22:10 - 2014-02-12 22:10 - 0000005 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_496F4C99-60AD-5b9e-AC1B-FA060E643C04.dll
      2014-02-12 22:10 - 2014-02-12 22:10 - 0000013 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_72024697-2626-4a12-8347-7CAC1834AC3B.dll
      2014-02-12 22:10 - 2014-02-12 22:10 - 0000013 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_D9C6A609-15A1-4768-8E98-6FA00C2547CC.dll
      2014-02-12 22:10 - 2014-02-12 22:10 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_F4F01109-C336-401f-BDE4-7C1926744104.dll
      2014-02-12 22:10 - 2014-02-12 22:10 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_FAB01109-C336-401f-BDE4-AB1926744111.dll
      2014-01-26 19:56 - 2014-01-26 19:56 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_FB9AECF7-F56E-7B2E-A862-9892AA545103.dll
      2016-06-13 10:39 - 2017-03-01 15:42 - 0000096 _____ () C:\Users\SamSwanson\AppData\Roaming\msregsvv.dll
      2016-04-24 21:15 - 2016-06-09 10:20 - 0033783 _____ () C:\Users\SamSwanson\AppData\Roaming\net.telestream.wirecast.xml
      2013-06-27 14:37 - 2017-02-07 17:49 - 0005632 _____ () C:\Users\SamSwanson\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
      2015-03-17 14:25 - 2015-03-17 14:25 - 0000600 _____ () C:\Users\SamSwanson\AppData\Local\PUTTY.RND
      2016-06-15 14:58 - 2016-06-15 14:58 - 0000218 _____ () C:\Users\SamSwanson\AppData\Local\recently-used.xbel
      2016-02-15 14:24 - 2017-02-20 17:51 - 0007602 _____ () C:\Users\SamSwanson\AppData\Local\Resmon.ResmonCfg
      2014-01-22 13:15 - 2017-03-01 15:42 - 0000128 _____ () C:\ProgramData\autobk.inc
      2016-08-11 19:35 - 2016-08-11 19:35 - 0000000 ____H () C:\ProgramData\DP45977C.lfl
      2014-01-22 11:21 - 2014-01-22 11:21 - 0000123 _____ () C:\ProgramData\Microsoft.SqlServer.Compact.351.32.bc
      2014-01-22 02:03 - 2014-01-22 02:04 - 0000454 _____ () C:\ProgramData\Microsoft.SqlServer.Compact.400.32.bc
      2016-03-03 11:42 - 2017-01-03 10:19 - 0000253 _____ () C:\ProgramData\SoundToys_Problem_Log.txt
      Some files in TEMP:
      2017-03-01 10:32 - 2016-12-09 12:17 - 1886344 _____ (Microsoft Corporation) C:\Users\SamSwanson\AppData\Local\Temp\dllnt_dump.dll
      LastRegBack: 2017-02-21 11:10
      Addition:
      > Additional scan result of Farbar Recovery Scan Tool (x64) Version: 01-03-2017
      Ran by SamSwanson (01-03-2017 20:30:13)
      Running from C:\Users\SamSwanson\Desktop\Computer fix
      Windows 10 Pro Version 1607 (X64) (2016-08-11 18:53:40)
      Boot Mode: Normal
      Administrator (S-1-5-21-3236326594-2611474830-2656184370-500 - Administrator - Disabled)
      DefaultAccount (S-1-5-21-3236326594-2611474830-2656184370-503 - Limited - Disabled)
      Guest (S-1-5-21-3236326594-2611474830-2656184370-501 - Limited - Disabled)
      SamSwanson (S-1-5-21-3236326594-2611474830-2656184370-1001 - Administrator - Enabled) => C:\Users\SamSwanson
      AV: Webroot SecureAnywhere (Enabled - Up to date) {4646A877-74EB-CD3B-8FDB-210DB94FA61A}
      AV: Malwarebytes (Enabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
      AS: Webroot SecureAnywhere (Enabled - Up to date) {FD274993-52D1-C2B5-B56B-1A7FC2C8ECA7}
      AS: Malwarebytes (Enabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
      FW: COMODO Firewall (Enabled) {E8F7F446-E1BD-DFE6-38D1-54E0ADE01D89}
      +10db version 1.0.4 (HKLM\...\+10db_is1) (Version: 1.0.4 - Boz Digital Labs)
      112dB Big Blue Compressor 1.0.3-r3719 (HKLM\...\112dB Big Blue Compressor 1.0.3-r3719) (Version: 1.0.3-r3719 - 112dB)
      112dB Big Blue Limiter 1.1.3-r3719 (HKLM\...\112dB Big Blue Limiter 1.1.3-r3719) (Version: 1.1.3-r3719 - 112dB)
      112dB Redline Equalizer 1.0.5-r3719 (HKLM\...\112dB Redline Equalizer 1.0.5-r3719) (Version: 1.0.5-r3719 - 112dB)
      112dB Redline Reverb 1.0.10-r3810 (HKLM\...\112dB Redline Reverb 1.0.10-r3810) (Version: 1.0.10-r3810 - 112dB)
      2C-Audio Aether (HKLM-x32\...\Aether) (Version:  - )
      2C-Audio Breeze (HKLM-x32\...\Breeze) (Version:  - 2C-Audio)
      6030 Ultimate Comp Native (HKLM-x32\...\{96B75FC3-D48A-4F8B-8BC7-5C2728797E4E}) (Version: 6.0.9 - McDSP)
      7-Zip 16.04 (x64 edition) (HKLM\...\{23170F69-40C1-2702-1604-000001000000}) (Version: 16.04.00.0 - Igor Pavlov)
      AATranslator (HKLM-x32\...\{7400C259-1F2E-4FF2-9037-860BF239F39D}) (Version: 4.0.0.2 - Suite Spot Studios)
      Abbeyroadplugins EMI Brilliance Pack VST RTAS v1.0.6 (HKLM-x32\...\Abbeyroadplugins EMI Brilliance Pack VST RTAS_is1) (Version:  - )
      Abbeyroadplugins EMI RS 124 Compressor VST RTAS v1.0.1 (HKLM-x32\...\Abbeyroadplugins EMI RS 124 Compressor_is1) (Version:  - )
      Abbeyroadplugins EMI TG 12413 Limiter VST RTAS v2.0.1 (HKLM-x32\...\Abbeyroadplugins EMI TG 12413 Limiter VST RTAS_is1) (Version:  - )
      Abbeyroadplugins EMI TG Mastering Pack VST RTAS v1.0.2 (HKLM-x32\...\Abbeyroadplugins EMI TG Mastering Pack VST RTAS_is1) (Version:  - )
      Ableton Live 9 Suite (HKLM\...\{48EC4E57-1D04-4831-90A7-151DA2269495}) (Version: 9.0.0.0 - Ableton)
      Acronis True Image (HKLM-x32\...\{E5F28743-0DB5-42C1-8B70-5986D88C0BE0}Visible) (Version: 19.0.6581 - Acronis)
      Acronis True Image (x32 Version: 19.0.6581 - Acronis) Hidden
      acustica AcquaVox (HKLM-x32\...\AcquaVox) (Version:  - )
      Acustica Audio D361A (HKLM-x32\...\D361A Win x64) (Version: 1.3.609.0 - Acustica Audio)
      Acustica Audio EQP1 (HKLM-x32\...\EQP1 Win x64) (Version: 1.3.606.0 - Acustica Audio)
      Acustica Audio NEO (HKLM-x32\...\NEO Win x64) (Version: 1.3.606.0 - Acustica Audio)
      Acustica Audio REDEQ (HKLM-x32\...\REDEQ Win x64) (Version: 1.3.760.0 - Acustica Audio)
      Acustica Audio TAN (HKLM-x32\...\TAN Win x64) (Version: 1.4.072.0 - Acustica Audio)
      Acustica Audio TITANIUM3B (HKLM-x32\...\TITANIUM3B Win x64) (Version: 1.3.827.0 - Acustica Audio)
      Acustica Audio TRINITYEQ (HKLM-x32\...\TRINITYEQ Win x64) (Version: 1.3.687.0 - Acustica Audio)
      AcusticaAudio Nebula3 (HKLM-x32\...\Nebula3) (Version:  - )
      Adobe After Effects CS4 (HKLM-x32\...\Adobe_3dcb365ab9e01871fb8c6f27b0ea079) (Version: 9 - Adobe Systems Incorporated)
      Adobe AIR (HKLM-x32\...\Adobe AIR) (Version: 24.0.0.180 - Adobe Systems Incorporated)
      Adobe Flash Player 24 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 24.0.0.221 - Adobe Systems Incorporated)
      Adobe Flash Player 24 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 24.0.0.221 - Adobe Systems Incorporated)
      Adobe Photoshop Lightroom 5 64-bit (HKLM\...\{6C1A010F-9108-4162-A26F-9FEC4AC0F0F0}) (Version: 5.0.1 - Adobe)
      Adobe Shockwave Player 12.2 (HKLM-x32\...\{A2116AF9-FA9D-41EA-9874-1E40B227D4DE}) (Version: 12.2.5.195 - Adobe Systems, Inc)
      AI Suite II (HKLM-x32\...\{34D3688E-A737-44C5-9E2A-FF73618728E1}) (Version: 2.01.02 - ASUSTeK Computer Inc.)
      Altiverb 7 Uninstaller (HKLM\...\{367662CA-394A-4095-9549-973FC3807B9B}_is1) (Version: 7.2 - Audio Ease BV)
      Amazon Kindle (HKLM-x32\...\Amazon Kindle) (Version:  - Amazon)
      Amazon Kindle (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Amazon Kindle) (Version:  - Amazon)
      AmpegSVX (HKLM-x32\...\{CF1D7323-8A0A-49C7-83B0-088DB90721E2}) (Version: 1.1.3 - IK Multimedia)
      AmpliTube 3 version 3.11.0 (HKLM\...\{DA5202AC-12BF-4330-B8EA-BC77F991FA1C}_is1) (Version: 3.11.0 - IK Multimedia)
      AmpliTube 4 version 4.0.1 (HKLM\...\{21B0C8E0-7EB7-4832-B764-20A7DAE86E02}_is1) (Version: 4.0.1 - IK Multimedia)
      AnonVPN 1.0.5.5 (HKLM-x32\...\AnonVPN) (Version: 1.0.5.5 - AnonVPN.io)
      Ansel (Version: 378.49 - NVIDIA Corporation) Hidden
      Antares Autotune Evo VST RTAS v6.0.9 (HKLM-x32\...\Antares Autotune Evo VST RTAS_is1) (Version:  - )
      Antares AVOX Evo VST RTAS v3.0.2 (HKLM-x32\...\Antares AVOX Evo VST RTAS_is1) (Version:  - )
      Apple Application Support (32-bit) (HKLM-x32\...\{9BA1A894-B42F-4805-BC8C-349C905A3930}) (Version: 5.3.1 - Apple Inc.)
      Apple Application Support (64-bit) (HKLM\...\{7EAC8A42-9FAC-4F6B-AABF-C08C9F2E0F13}) (Version: 5.3.1 - Apple Inc.)
      Apple Mobile Device Support (HKLM\...\{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
      Apple Software Update (HKLM-x32\...\{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
      ARC System 2 version 2.1.0 (HKLM\...\{4952A610-D484-4F6A-B1B4-33797CFDB821}_is1) (Version: 2.1.0 - IK Multimedia)
      ArcSoft Portrait+ 3 (HKLM-x32\...\{40BB5B1A-6008-4348-8C24-116B654C7ECD}) (Version: 3.0.0.401 - ArcSoft)
      ARIA Engine v1.8.4.8 (HKLM\...\ARIA Engine_is1) (Version: v1.8.4.8 - Plogue Art et Technologie, Inc)
      Articulate Storyline (x32 Version: 1.02.02 - Articulate) Hidden
      ASIO Bridge and Hi-Fi Cable (HKLM-x32\...\VB:ASIOBridge {17359A74-1236-5467}) (Version:  - VB-Audio Software)
      ASIO4ALL (HKLM-x32\...\ASIO4ALL) (Version: 2.11 Beta2 - Michael Tippach)
      Assassin's Creed(R) III v1.03 (HKLM-x32\...\{9D15E813-0C26-41E7-ABC5-3EB06FF1B3CF}) (Version: 1.03 - Ubisoft)
      Atheros Driver Installation Program (HKLM-x32\...\{C3A32068-8AB1-4327-BB16-BED9C6219DC7}) (Version: 10.0 - Atheros)
      atomiccleaner3 version 1.3.4.1 (HKLM-x32\...\{0D6AB211-A181-4F42-AEB4-127C40BF67EF}_is1) (Version: 1.3.4.1 - atomicware)
      AudioEase Altiverb VST RTAS v6.12 (HKLM-x32\...\AudioEase Altiverb VST RTAS_is1) (Version:  - )
      AudioEase Speakersphone VST RTAS v1.03 (HKLM-x32\...\AudioEase Speakersphone VST RTAS_is1) (Version:  - Audio Ease)
      Avid Effects (HKLM-x32\...\{A86F1158-A7F7-4E8C-98E3-88F4996E85EB}) (Version: 10.3.10 - Avid Technology, Inc.)
      Avid HD Driver (x64) (HKLM\...\{01C898E1-38A7-49B1-9398-49E40636E2C5}) (Version: 9.0 - Avid Technology, Inc.)
      Avid HD Driver (x64) (HKLM\...\{658E112A-8776-4430-A275-D9248732DFB9}) (Version: 10.3.10 - Avid Technology, Inc.)
      Avid Mbox Driver 1.1.10 (x64) (HKLM\...\{35BAD2B7-E2EF-4A06-80A2-C6C2F23B8F3E}) (Version: 1.1.10 - Avid)
      Avid Pro Tools (HKLM-x32\...\{8E60BB71-7EF3-42ED-9F10-AA041F25841A}) (Version: 10.3.10 - Avid Technology, Inc.)
      AVOX Evo VST (HKLM-x32\...\{65AA5B18-A330-4F35-BCDF-EA85EC888906}) (Version: 3.0.0 - Antares Audio Technologies)
      AVS Audio Converter 7 (HKLM-x32\...\AVS Audio Converter_is1) (Version: 7.0.5.510 - Online Media Technologies Ltd.)
      Black Rooster Audio Plugin Pack (HKLM\...\Black Rooster Audio Plugin Pack_is1) (Version:  - Black Rooster Audio)
      BWF MetaEdit 1.3.0 (HKLM\...\BWF MetaEdit) (Version: 1.3.0 - FADGI)
      calibre 64bit (HKLM\...\{82EA8033-0AE6-4C1A-91B6-D24BED49AB73}) (Version: 2.79.1 - Kovid Goyal)
      Call of Duty 4: Modern Warfare (HKLM-x32\...\Steam App 7940) (Version:  - Infinity Ward)
      Call of Duty: Modern Warfare 3 (HKLM-x32\...\Steam App 42680) (Version:  - Infinity Ward - Sledgehammer Games)
      CameraHelperMsi (x32 Version: 13.51.815.0 - Logitech) Hidden
      Camtasia Studio 8 (HKLM-x32\...\{2B1F8DD0-873D-4AC3-8400-766F255FE263}) (Version: 8.1.0.1281 - TechSmith Corporation)
      Carbonite (HKLM-x32\...\{C7D98EFB-A351-4098-B474-1A5B362DB648}) (Version: 6.2.2 build 6819 (Jan-25-2017) - Carbonite)
      CCleaner (HKLM\...\CCleaner) (Version: 5.27 - Piriform)
      CDSoundMaster NICE-EQ-VST-TUBE-FREE (HKLM-x32\...\NICE-EQ-VST-TUBE-FREE) (Version:  - )
      CDSoundMaster N-TEN-AT4-Bell-Free-64 (HKLM-x32\...\N-TEN-AT4-Bell-Free-64) (Version:  - )
      CDS-VTC-FREE-PC-VST-64-BIT THE-VINTAGE-TUBE-COLLECTION-FREE-PC-VST-64-BIT (HKLM-x32\...\THE-VINTAGE-TUBE-COLLECTION-FREE-PC-VST-64-BIT) (Version:  - )
      Celemony Melodyne Studio 4 (HKLM-x32\...\Celemony Melodyne Studio 4) (Version: 4.0.4.004 - Celemony)
      COMODO Internet Security (HKLM\...\{0E9AFD45-C3BA-41D1-B54B-495A22CB3409}) (Version: 6.0.64131.2674 - COMODO Security Solutions Inc.)
      CP Control (HKLM-x32\...\CP Control) (Version:  - )
      CrystalDiskInfo 7.0.5 Shizuku Edition (HKLM-x32\...\CrystalDiskInfo_is1) (Version: 7.0.5 - Crystal Dew World)
      Custom Shop version 1.7.0 (HKLM-x32\...\{21BAD046-50EC-49E2-BE7B-F9729704F2C3}_is1) (Version: 1.7.0 - IK Multimedia)
      D16 Group Repeater (HKLM\...\Repeater_is1) (Version: 1.0.0 - D16 Group)
      DAEMON Tools Lite (HKLM\...\DAEMON Tools Lite) (Version: 10.1.0.0074 - Disc Soft Ltd)
      Dashlane (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Dashlane) (Version: 4.6.7.25343 - Dashlane SAS)
      Day of Defeat: Source (HKLM-x32\...\Steam App 300) (Version:  - Valve)
      Diamond Cut Forensics8 (HKLM-x32\...\{38C8BBB6-716E-4486-A386-C8D3242959C5}) (Version: 8.10 - Diamond Cut Productions)
      DisplayFusion 5.0 (HKLM-x32\...\B076073A-5527-4f4f-B46B-B10692277DA2_is1) (Version: 5.0.0.0 - Binary Fortress Software)
      Ditto (HKLM-x32\...\Ditto_is1) (Version:  - Scott Brogden)
      DivX Setup (HKLM-x32\...\DivX Setup) (Version: 2.7.0.31 - DivX, LLC)
      DMG Audio Track Range (HKLM\...\Track Range_is1) (Version: 1.0.0 - DMG Audio)
      DMGAudio EQuilibrium 1.04 (HKLM-x32\...\DMGAudio EQuilibrium_is1) (Version:  - DMGAudio)
      DMGAudio Essence 1.00 (HKLM-x32\...\DMGAudio Essence_is1) (Version:  - DMGAudio)
      DMGAudio Limitless 1.00 (HKLM-x32\...\DMGAudio Limitless_is1) (Version:  - DMGAudio)
      DragonDisk 1.05 (HKLM-x32\...\{7914B94-1234-44D2-0864-0348EBF012AC}_is1) (Version:  - Almageste)
      Dropbox (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Dropbox) (Version: 2.10.46 - Dropbox, Inc.)
      Drum Leveler version 1.0.0 (HKLM\...\{94B8FDA3-877B-4EB8-A3E9-5D476329F15D}_is1) (Version: 1.0.0 - Sound Radix)
      East West Stormdrum Intakt (HKLM-x32\...\East West Stormdrum Intakt) (Version:  - )
      Easy Tune 6 B12.0912.1 (HKLM-x32\...\InstallShield_{457D7505-D665-4F95-91C3-ECB8C56E9ACA}) (Version: 1.00.0000 - GIGABYTE)
      Easy Tune 6 B12.0912.1 (x32 Version: 1.00.0000 - GIGABYTE) Hidden
      ElastikVst (HKLM-x32\...\{92F027CB-BDF9-4047-A654-13A050908158}) (Version: 1.00.0000 - ueberschall sample service GmbH)
      ElastikVst (x32 Version: 1.00.0000 - ueberschall sample service GmbH) Hidden
      Electrum (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Electrum) (Version: 2.7.12 - Electrum Technologies GmbH)
      EmpressPlugins.Tremolo.VST.v1.0 (HKLM-x32\...\EmpressPlugins Tremolo_is1) (Version:  - )
      eReg (x32 Version: 1.20.138.34 - Logitech, Inc.) Hidden
      f.lux (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Flux) (Version:  - )
      FabFilter Pro-C 2.00 (64-bit) (HKLM-x32\...\FabFilter Pro-C 2.00 (64-bit)) (Version:  - )
      FG-X (HKLM\...\Slate Digital FG-X_is1) (Version:  - Slate Digital)
      FG-X Virtual Mastering Console (HKLM\...\FG-X Virtual Mastering Console_is1) (Version:  - Slate Digital)
      Fidelify (HKLM-x32\...\Fidelify) (Version:  - )
      FileMenu Tools (HKLM\...\FileMenu Tools_is1) (Version:  - LopeSoft - Rubén López Hernández)
      FileZilla Client 3.24.0 (HKLM-x32\...\FileZilla Client) (Version: 3.24.0 - Tim Kosse)
      Finale NotePad 2012 (HKLM-x32\...\Finale NotePad 2012) (Version: 2012..r1.5 - MakeMusic)
      FlowStone FL 3.0 (HKLM-x32\...\FlowStone) (Version:  - )
      Flux Full Pack 2.2 (HKLM\...\Full Pack 2.2_is1) (Version: 3.5.25.44238 - Flux)
      Flux Junger Audio Level Magic 5.1 (HKLM-x32\...\Flux Junger Audio Level Magic 5.1) (Version: 3.4.6 - Flux)
      Folder Marker Free (HKLM\...\Folder Marker Free_is1) (Version: 3.2 - ArcticLine Software)
      Genwaveaudio Genwave EQ VST v1.0 (HKLM-x32\...\Genwaveaudio Genwave EQ VST_is1) (Version:  - )
      GIZMO (HKLM-x32\...\{D0529F5A-C45C-40C0-8457-6A5AF24ABC6E}) (Version: 3.21.4000 - ants Inc.)
      Gizmo Central (HKLM-x32\...\Gizmo Central) (Version: v2.7.9 - Arainia Solutions, LLC)
      GnuCash 2.4.11 (HKLM-x32\...\GnuCash_is1) (Version:  - GnuCash Development Team)
      Gobbler (HKLM-x32\...\{C7CE54DC-7AD2-48A8-BB2E-F7C6A8E40BB5}) (Version: 0.21.75.0 - Media Gobbler, Inc.)
      Google Chrome (HKLM-x32\...\Google Chrome) (Version: 56.0.2924.87 - Google Inc.)
      Google Chrome Canary (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Google Chrome SxS) (Version: 58.0.3026.0 - Google Inc.)
      Google Talk (remove only) (HKLM-x32\...\{226b64e8-dc75-4eea-a6c8-abcb496320f2}-Google Talk) (Version:  - )
      Google Talk Plugin (HKLM-x32\...\{8E29C1CE-346A-3F59-AE22-8C5B7F230498}) (Version: 5.3.1.18536 - Google)
      Google Update Helper (x32 Version: 1.3.32.7 - Google Inc.) Hidden
      GoToMeeting 7.31.0.6291 (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\GoToMeeting) (Version: 7.31.0.6291 - CitrixOnline)
      HandBrake 0.10.5 (HKLM-x32\...\HandBrake) (Version: 0.10.5 - )
      Head Crusher version 1.6 (HKLM\...\Head Crusher_is1) (Version: 1.6 - )
      Helium Audio Converter (build 461) (HKLM-x32\...\{8CF3206B-6330-42D6-B35E-CA7098337CB8}_is1) (Version: 2.0.0.461 - Imploded Software)
      HFSExplorer 0.21 (HKLM-x32\...\HFSExplorer) (Version: 0.21 - Catacombae Software)
      HoRNet AutoGain Pro MK2 (HKLM\...\AutoGain Pro MK2_is1) (Version: 2.0.1 - HoRNet)
      IK Multimedia Authorization Manager version 1.0.15 (HKLM\...\{85BC0DCB-69E5-4279-AA25-F108EF896588}_is1) (Version: 1.0.15 - IK Multimedia)
      iLok Client Helper (HKLM-x32\...\InstallShield_{DEA491FB-48BC-4B6B-8902-FCD4BAB069BE}) (Version: 5.9.7 - PACE Anti-Piracy, Inc.)
      iLok Client Helper (x32 Version: 5.9.7 - PACE Anti-Piracy, Inc.) Hidden
      Imperial Delay version 1.5.8 (HKLM\...\Imperial Delay_is1) (Version: 1.5.8 - )
      Intel Extreme Tuning Utility (HKLM-x32\...\{7360EE49-7004-4626-A85A-CC48C2D63700}) (Version: 3.2.0.24 - Intel Corporation)
      Intel(R) C++ Redistributables on IA-32 (HKLM-x32\...\{7858618B-FA45-4797-988D-4E8B793C3B88}) (Version: 17.0.109 - Intel Corporation)
      Intel(R) C++ Redistributables on Intel(R) 64 (HKLM-x32\...\{A7D3C4B3-2CA8-46F3-9C34-63205AC018FF}) (Version: 17.0.109 - Intel Corporation)
      Intel(R) Chipset Device Software (x32 Version: 10.0.27 - Intel(R) Corporation) Hidden
      Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.23.1766 - Intel Corporation)
      Intel(R) Network Connections 18.6.110.0 (HKLM\...\PROSetDX) (Version: 18.6.110.0 - Intel)
      Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 9.17.10.2932 - Intel Corporation)
      Intel(R) Smart Connect Technology 3.0 x64 (HKLM\...\{DE788AD4-F7CE-4995-ADF8-56174A7B613C}) (Version: 3.0.41.1571 - Intel)
      Intel(R) Technology Access (HKLM-x32\...\{810dff4d-564d-47da-b8bc-a3729815aab7}) (Version: 1.9.1.1008 - Intel Corporation)
      Intel(R) Technology Access Software Asset Manager (x32 Version: 3.4.1942 - Intel Corporation) Hidden
      Intel(R) Update Manager (HKLM-x32\...\{7224B7CE-196C-4E2A-A1AE-1D7BF259FD36}) (Version: 3.4.1942 - Intel Corporation)
      Intel® Watchdog Timer Driver (Intel® WDT) (HKLM-x32\...\{3FD0C489-0F02-481a-A3E1-9754CD396761}) (Version:  - Intel Corporation)
      ISL (HKLM\...\ISL_is1) (Version:  - NUGEN Audio)
      iTunes (HKLM\...\{9D0D2A8B-7E7B-4D88-8D50-24286ED6A5EB}) (Version: 12.5.5.5 - Apple Inc.)
      IVGI version 1.0.0 (HKLM\...\IVGI_is1) (Version: 1.0.0 - )
      Ivideon Server (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Ivideon Server) (Version: 3.5.6.1213 - Ivideon)
      iZotope BreakTweaker (HKLM-x32\...\iZotope BreakTweaker_is1) (Version: 1.00 - iZotope, Inc.)
      iZotope BreakTweaker Factory Content (HKLM-x32\...\iZotope BreakTweaker Factory Content_is1) (Version: 1.00 - iZotope, Inc.)
      iZotope Insight (HKLM-x32\...\iZotope Insight_is1) (Version: 1.00 - iZotope, Inc.)
      iZotope Nectar 2 Production Suite (HKLM-x32\...\iZotope Nectar 2 Production Suite_is1) (Version: 2.00 - iZotope, Inc.)
      iZotope Ozone 6 Advanced (HKLM-x32\...\iZotope Ozone 6 Advanced_is1) (Version: 6.00 - iZotope, Inc.)
      iZotope Ozone 7 Advanced (HKLM-x32\...\iZotope Ozone 7 Advanced 7.00) (Version: 7.00 - iZotope, Inc.)
      iZotope RX 5 (HKLM-x32\...\iZotope RX 5_is1) (Version: 5.01 - iZotope, Inc.)
      iZotope Trash 2 (HKLM-x32\...\iZotope Trash 2_is1) (Version: 2.00 - iZotope, Inc.)
      iZotope Vinyl (HKLM-x32\...\iZotope Vinyl_is1) (Version: 1.61 - iZotope, Inc.)
      iZotope VocalSynth (HKLM-x32\...\VocalSynth 1.0) (Version: 1.0 - iZotope, Inc.)
      Jack (HKLM-x32\...\Jack) (Version:  - )
      Java 8 Update 121 (64-bit) (HKLM\...\{26A24AE4-039D-4CA4-87B4-2F64180121F0}) (Version: 8.0.1210.13 - Oracle Corporation)
      Kazrog LLC Recabinet 3 VST RTAS v3.1.0 (HKLM\...\Kazrog LLC Recabinet 3_is1) (Version:  - )
      KD Niche Finder (HKLM-x32\...\KD Niche Finder1.0.0.2) (Version: 1.0.0.2 - AppBreed Software of InnAnTech Industries Inc.)
      KDPublishingPro (HKLM-x32\...\{067A07C1-7A31-4881-B53D-DF4CBB865112}) (Version: 1.4.12 - KDPublishingPro.com)
      KDPublishingPro (HKLM-x32\...\{215E8D21-F375-4D03-A31F-79CBE44FFB4A}) (Version: 1.2.8 - KDPublishingPro.com)
      KDSubmitterPro (HKLM-x32\...\{E1817648-6DF6-400F-BD1B-B5D9E9BD745D}) (Version: 1.0.0 - KDSubmitterPro.com)
      Kindle DRM Removal (HKLM-x32\...\KindleDRMRemoval) (Version: 1.4.1 - eBook Converter)
      Kits Configuration Installer (x32 Version: 8.59.25584 - Microsoft) Hidden
      K-Lite Codec Pack 9.6.0 (64-bit) (HKLM\...\KLiteCodecPack64_is1) (Version: 9.6.0 - )
      K-Lite Codec Pack 9.6.0 (Full) (HKLM-x32\...\KLiteCodecPack_is1) (Version: 9.6.0 - )
      Kush Audio Clariphonic v1.0 (HKLM\...\Clariphonic_is1) (Version:  - Kush Audio)
      Lexicon PSP 42 64bit (HKLM\...\Lexicon PSP 42 64bit) (Version: 1.6.2 64bit - PSPaudioware.com)
      Liquid Notes version 1.5.2.1 (HKLM\...\{5AC1D63D-6772-417E-B7B8-1E5F686D9703}_is1) (Version: 1.5.2.1 - Re-Compose)
      Litecoin (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Litecoin) (Version: 0.8.5.1 - Litecoin project)
      Litecoin Core (64-bit) (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Litecoin Core (64-bit)) (Version: 0.10.4.0 - Litecoin Core project)
      Logitech Gaming Software 8.40 (HKLM\...\Logitech Gaming Software) (Version: 8.40.83 - Logitech Inc.)
      Logitech SetPoint 6.61 (HKLM\...\sp6) (Version: 6.61.15 - Logitech)
      Logitech Webcam Software (HKLM-x32\...\{D40EB009-0499-459c-A8AF-C9C110766215}) (Version: 2.80 - Logitech Inc.)
      LoopBe30 - Internal MIDI Ports (HKLM-x32\...\LoopBe30) (Version:  - )
      Lurssen Mastering Console version 1.0.0 (HKLM\...\{9F525466-89DA-4B7B-BD8C-BBFDC4432DFB}_is1) (Version: 1.0.0 - IK Multimedia)
      M30 Reverb (HKLM-x32\...\M30 Reverb) (Version: 1.0.0.1 - TC Electronic)
      MacDrive 9 Pro (HKLM\...\{C1521748-8700-4CA0-92F1-46CE26DEDC7D}) (Version: 9.0.4.21 - Mediafour Corporation)
      Magic AB VST-x64 1.2.2 (HKLM\...\{6893EEE5-B48F-47a9-81DC-CD54E7767B35}) (Version: 1.2.2 - Sample Magic)
      Malwarebytes version 3.0.6.1469 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.0.6.1469 - Malwarebytes)
      Manic Compressor version 1.0.3 (HKLM\...\Manic Compressor_is1) (Version: 1.0.3 - )
      Market Samurai (HKLM-x32\...\MarketSamurai.6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1) (Version: 0.92.51 - Alliance Software Pty Ltd)
      Market Samurai (x32 Version: 0.92.51 - Alliance Software Pty Ltd) Hidden
      marvell 91xx driver (HKLM-x32\...\MagniDriver) (Version: 1.2.0.1027 - Marvell)
      Massey VST Demos (Remove only) (HKLM-x32\...\Massey VST Demos) (Version:  - )
      MathewLane DrMS Spatial Processor VST RTAS v3.2 (HKLM-x32\...\MathewLane DrMS Spatial Processor_is1) (Version:  - )
      M-Audio Oxygen Driver 1.2.1 (x64) (HKLM\...\{6F0B8408-835B-4A55-A429-EB899AD68467}) (Version: 1.2.1 - M-Audio)
      Maxthon Cloud Browser (HKLM-x32\...\Maxthon3) (Version: 4.0.3.1000 - Maxthon International Limited)
      McGill English Dictionary of Rhyme & Verse Perfect 2.0 (HKLM-x32\...\McGill English Dictionary of Rhyme with VersePer~286A7AE6_is1) (Version:  - Bryant McGill / McGill International)
      MeldaProduction Audio Plugins 10 (HKLM-x32\...\MeldaProduction Audio Plugins 10) (Version:  - MeldaProduction)
      MeldaProduction MTotalBundle64 8 (HKLM-x32\...\MeldaProduction MTotalBundle64 8) (Version:  - MeldaProduction)
      Melodyne 3.2 (HKLM-x32\...\{A1F143D1-1F0D-44FB-A44B-71D4367D16DE}) (Version: 3.2.0202 - Celemony Software GmbH)
      Melodyne 3.2 (x32 Version: 3.2.0202 - Celemony Software GmbH) Hidden
      MetaTrader 5 (HKLM\...\MetaTrader 5) (Version: 5.00 - MetaQuotes Software Corp.)
      Mic Mod EFX VST (HKLM-x32\...\{A77728D4-DF6E-42A9-926C-5164BBF1EA72}) (Version: 1.0.4 - Antares Audio Technologies)
      Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
      Microsoft Office Professional Plus 2013 (HKLM\...\Office15.PROPLUS) (Version: 15.0.4569.1506 - Microsoft Corporation)
      Microsoft OneDrive (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\OneDriveSetup.exe) (Version: 17.3.6743.1212 - Microsoft Corporation)
      Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM\...\{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.21022 (HKLM\...\{350AA351-21FA-3270-8B7A-835434E766AD}) (Version: 9.0.21022 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.21022.218 (HKLM-x32\...\{E503B4BF-F7BB-3D5F-8BC8-F694B1CFF942}) (Version: 9.0.21022.218 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729 (HKLM-x32\...\{820B6609-4C97-3A2B-B644-573B06A0F0CC}) (Version: 9.0.30729 - Microsoft Corporation)
      Microsoft Visual C++ 2010  x64 Redistributable - 10.0.40219 (HKLM\...\{1D8E6291-B0D5-35EC-8441-6616F567A0F7}) (Version: 10.0.40219 - Microsoft Corporation)
      Microsoft Visual C++ 2010  x86 Redistributable - 10.0.40219 (HKLM-x32\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
      Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32\...\{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
      Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32\...\{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24212 (HKLM-x32\...\{323dad84-0974-4d90-a1c1-e006c7fdbb7d}) (Version: 14.0.24212.0 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24212 (HKLM-x32\...\{462f63a8-6347-4894-a1b3-dbfe3a4c981d}) (Version: 14.0.24212.0 - Microsoft Corporation)
      Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
      Microsoft Web Platform Installer 4.6 (HKLM\...\{16C7D2AD-20CA-491E-80BC-8607A9AACED9}) (Version: 4.0.40719.0 - Microsoft Corporation)
      MJUC version 1.0.1 (HKLM\...\MJUC_is1) (Version: 1.0.1 - )
      MJUCjr version 1.0.0 (HKLM\...\MJUCjr_is1) (Version: 1.0.0 - )
      Mobile Hotspot Admin (HKLM-x32\...\{AEFF9E60-3E93-41EE-9895-311F7D1C5FFD}) (Version: 1.0.0.2 - ZTE Corporation)
      Monofilter v4.0 (HKLM\...\Monofilter4_is1) (Version:  - NUGEN Audio)
      Mozilla Firefox 51.0.1 (x86 en-US) (HKLM-x32\...\Mozilla Firefox 51.0.1 (x86 en-US)) (Version: 51.0.1 - Mozilla)
      Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 51.0.1 - Mozilla)
      Mp3tag v2.73 (HKLM-x32\...\Mp3tag) (Version: v2.73 - Florian Heidenreich)
      MusicBrainz Picard (HKLM-x32\...\MusicBrainz Picard) (Version: 1.3.2 - MusicBrainz)
      Nalpeiron Service Update to 6.3.9.2 (x32 Version: 7.3.1 - Nalpeiron) Hidden
      Native Instruments Abbey Road 50s Drummer (HKLM-x32\...\Native Instruments Abbey Road 50s Drummer) (Version: 1.2.0.10 - Native Instruments)
      Native Instruments Abbey Road 60s Drums (HKLM-x32\...\Native Instruments Abbey Road 60s Drums) (Version:  - Native Instruments)
      Native Instruments Alicias Keys 1.2 (HKLM-x32\...\Native Instruments Alicias Keys 1.2) (Version:  - Native Instruments)
      Native Instruments Battery 4 (HKLM-x32\...\Native Instruments Battery 4) (Version: 4.1.5.254 - Native Instruments)
      Native Instruments Damage (HKLM-x32\...\Native Instruments Damage) (Version:  - Native Instruments)
      Native Instruments Elektrik Piano 1.5 (HKLM-x32\...\Native Instruments Elektrik Piano 1.5) (Version:  - )
      Native Instruments India (HKLM-x32\...\Native Instruments India) (Version: 1.0.0.31 - Native Instruments)
      Native Instruments Kontakt 5 (HKLM-x32\...\Native Instruments Kontakt 5) (Version: 5.6.5.13 - Native Instruments)
      Native Instruments Session Horns Pro (HKLM-x32\...\Native Instruments Session Horns Pro) (Version: 1.3.0.2 - Native Instruments)
      Native Instruments Symphony Series Brass Solo (HKLM-x32\...\Native Instruments Symphony Series Brass Solo) (Version: 1.1.0.19 - Native Instruments)
      Native Instruments Symphony Series String Ensemble (HKLM-x32\...\Native Instruments Symphony Series String Ensemble) (Version: 1.1.0.7 - Native Instruments)
      Native Instruments Symphony Series Woodwind Solo (HKLM-x32\...\Native Instruments Symphony Series Woodwind Solo) (Version: 1.0.0.11 - Native Instruments)
      Native Instruments The Giant (HKLM-x32\...\Native Instruments The Giant) (Version: 1.2.0.7 - Native Instruments)
      Native Instruments The Grandeur (HKLM-x32\...\Native Instruments The Grandeur) (Version: 1.2.0.2 - Native Instruments)
      Native Instruments Upright Piano (HKLM-x32\...\Native Instruments Upright Piano) (Version:  - Native Instruments)
      Native Instruments Vintage Organs (HKLM-x32\...\Native Instruments Vintage Organs) (Version:  - Native Instruments)
      nebula3 CM (HKLM-x32\...\{5354D5F2-342D-43DD-A361-B65BF7AABE1D}) (Version: 1.2.837 - Acusticaaudio)
      Nero 12 (HKLM-x32\...\{560FC78C-A4B2-461D-9B47-820C1EEF87B8}) (Version: 12.0.02000 - Nero AG)
      Netflix in Windows Media Center (HKLM-x32\...\{0CA72D12-F6C6-4D43-A2A0-41F5AA17E2B6}) (Version: 3.3.101.0 - Microsoft Corporation)
      Neutron Advanced (HKLM-x32\...\Neutron Advanced 1.0) (Version: 1.0 - iZotope, Inc.)
      NF VST 64-bit Installer (HKLM-x32\...\NF VST 64-bit Installer1.0.3) (Version: 1.0.3 - Nomad Factory)
      Nitro Pro 8 (HKLM\...\{47B42E7A-57E9-407B-8DBB-017B86D7B13F}) (Version: 8.5.2.10 - Nitro)
      NVIDIA 3D Vision Controller Driver 369.04 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
      NVIDIA 3D Vision Driver 378.49 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 378.49 - NVIDIA Corporation)
      NVIDIA GeForce Experience 3.3.0.95 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.3.0.95 - NVIDIA Corporation)
      NVIDIA Graphics Driver 378.49 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 378.49 - NVIDIA Corporation)
      NVIDIA HD Audio Driver 1.3.34.21 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.21 - NVIDIA Corporation)
      NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
      NvNodejs (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
      NvTelemetry (Version: 2.3.5.0 - NVIDIA Corporation) Hidden
      NvvHci (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
      Outils de vérification linguistique 2013 de Microsoft Office - Français (Version: 15.0.4569.1506 - Microsoft Corporation) Hidden
      Output Movement (HKLM-x32\...\Output Movement) (Version: 1.0.3 - Output)
      PACE License Support Win64 (HKLM-x32\...\InstallShield_{72ad9d51-0903-4fe7-af5d-33b3185fa6e9}) (Version: 2.2.1.0324 - PACE Anti-Piracy, Inc.)
      PACE License Support Win64 (Version: 2.2.1.0324 - PACE Anti-Piracy, Inc.) Hidden
      PatchCleaner (HKLM-x32\...\{727DA176-50BB-452C-8DB5-96EE0A573ED4}) (Version: 1.4.20 - HomeDev)
      PCM Native Reverb Bundle (HKLM-x32\...\PCM Native Reverb Bundle) (Version:  - Lexicon)
      PCM Native Reverb Bundle (x32 Version: 1.1.3 - Lexicon) Hidden
      PDF Settings CS5 (x32 Version: 10.0 - Adobe Systems Incorporated) Hidden
      Photoshop Camera Raw (x32 Version: 5.0 - Adobe Systems Incorporated) Hidden
      Pi version 1.0.11 (HKLM\...\{CFA5721A-9AA1-4D77-BBC2-78E40216FDAB}_is1) (Version: 1.0.11 - Sound Radix)
      PITCHMAP VST-x64 1.6.1 (HKLM\...\{F9754DD6-985B-4e93-A96B-837EE5415F61}) (Version: 1.6.1 - Zynaptiq)
      Pixel Bender Toolkit (x32 Version: 1.0 - Adobe Systems Incorporated) Hidden
      Plogue chipsounds v1.848 (HKLM\...\__ARIA_1009___is1) (Version: v1.848 - Plogue)
      Plogue chipspeech v1.016 (HKLM\...\__ARIA_1017___is1) (Version: v1.016 - Plogue)
      Prerequisite installer (x32 Version: 12.0.0002 - Nero AG) Hidden
      Primo Ramdisk Server Edition 5.6.0 (HKLM\...\{94B97E1E-9B67-4012-A126-6319E211A298}_is1) (Version: 5.6.0 - Romex Software)
      Process Lasso (HKLM-x32\...\ProcessLasso) (Version: 8.9.8.94 - Bitsum)
      PSP 2Meters 64bit (HKLM-x32\...\PSP 2Meters 64bit) (Version: 2.0.0 64bit - PSPaudioware.com)
      PSP 608 MultiDelay 64bit (HKLM\...\PSP 608 MultiDelay 64bit) (Version: 1.6.1 64bit - PSPaudioware.com)
      PSP 85 64bit (HKLM-x32\...\PSP 85 64bit) (Version: 1.1.0 64bit - PSPaudioware.com)
      PSP BussPressor 64bit (HKLM\...\PSP BussPressor 64bit) (Version: 1.0.3 64bit - PSPaudioware.com)
      PSP Echo 64bit (HKLM\...\PSP Echo 64bit) (Version: 1.0.1 64bit - PSPaudioware.com)
      PSP MasterComp 1.7.1 64bit (HKLM-x32\...\PSP MasterComp 1.7.1 64bit) (Version: 1.7.1 64bit - PSPaudioware.com)
      PSP McQ 64bit (HKLM-x32\...\PSP McQ 64bit) (Version: 1.8.0 64bit - PSPaudioware.com)
      PSP Neon 64bit (HKLM\...\PSP Neon 64bit) (Version: 2.0.3 64bit - PSPaudioware.com)
      PSP NobleQ 64bit (HKLM\...\PSP NobleQ 64bit) (Version: 1.7.0 64bit - PSPaudioware.com)
      PSP oldTimer 64bit (HKLM\...\PSP oldTimer 64bit) (Version: 2.0.0 64bit - PSPaudioware.com)
      PSP PianoVerb2 64bit (HKLM-x32\...\PSP PianoVerb2 64bit) (Version: 2.0.0 64bit - PSPaudioware.com)
      PSP SpringBox 64bit (HKLM-x32\...\PSP SpringBox 64bit) (Version: 1.0.0 64bit - PSPaudioware.com)
      PSP Xenon 1.3.0 64bit (HKLM-x32\...\PSP Xenon 1.3.0 64bit) (Version: 1.3.0 64bit - PSPaudioware.com)
      PunkBuster Services (HKLM-x32\...\PunkBusterSvc) (Version: 0.991 - Even Balance, Inc.)
      Python 3.3.0 (64-bit) (HKLM\...\{290329c4-a276-3aec-b633-9f5a39d8dd96}) (Version: 3.3.150 - Python Software Foundation)
      QuickTime (HKLM-x32\...\{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A}) (Version: 7.73.80.64 - Apple Inc.)
      Rank Tracker (HKLM-x32\...\seopowersuite) (Version:  - )
      Rapid SEO Tool 1.3 (HKLM-x32\...\Rapid SEO Tool_is1) (Version: 1.3 - Karlis Blumentals)
      Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.36.826.2014 - Realtek)
      Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7945 - Realtek Semiconductor Corp.)
      REAPER (x64) (HKLM\...\REAPER) (Version:  - )
      Reference 3 VST plugin (32-bit) 3 (HKLM-x32\...\{7627424F-7CB0-471B-AB55-A39F6995C4F0}) (Version: 3.2.11 - Sonarworks)
      Reference 3 VST plugin (64-bit) 3 (HKLM\...\{510D6D02-214D-4264-A4FD-96DBD82ACFED}) (Version: 3.2.11 - Sonarworks)
      reFX Nexus VSTi RTAS v2.2.0 (HKLM-x32\...\reFX Nexus_is1) (Version:  - )
      Relab LX480 Lite VST v1.0 (HKLM-x32\...\Relab LX480 Lite_is1) (Version:  - )
      Resource Hacker Version 3.6.0 (HKLM-x32\...\ResourceHacker_is1) (Version:  - )
      Revo Uninstaller 2.0.2 (HKLM\...\{A28DBDA2-3CC7-4ADC-8BFE-66D7743C6C97}_is1) (Version: 2.0.2 - VS Revo Group, Ltd.)
      Rhyme Genie (HKLM-x32\...\{E48A1AFC-5649-4CC2-B8E1-BD92022C4CC4}) (Version: 6.0 - Idolumic)
      RogueKiller version 12.9.7.0 (HKLM\...\8B3D7924-ED89-486B-8322-E8594065D5CB_is1) (Version: 12.9.7.0 - Adlice Software)
      Room EQ Wizard V5 (HKLM-x32\...\RoomEQWizardV5) (Version:  - John Mulcahy)
      Sasquatch version 1.2.0 (HKLM\...\Sasquatch_is1) (Version: 1.2.0 - )
      SEQ1 Master (HKLM-x32\...\SEQ1 Master_is1) (Version:  - NuGen Audio)
      SEQ2 Master (HKLM-x32\...\SEQ2 Master_is1) (Version:  - NuGen Audio)
      SEQ-S (HKLM\...\SEQ-S_is1) (Version:  - NUGEN Audio)
      Service Pack 1 for Microsoft Office 2013 (KB2850036) 64-Bit Edition (Version:  - Microsoft) Hidden
      S-GEAR 2 (HKLM\...\S-GEAR 2 CE_is1) (Version: 2.5.7 - Scuffham Amps)
      SHIELD Streaming (Version: 7.1.0351 - NVIDIA Corporation) Hidden
      SHIELD Wireless Controller Driver (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
      Sid Meier's Civilization V (HKLM-x32\...\Steam App 8930) (Version:  - 2K Games, Inc.)
      SideWidener version 1.0.2 (HKLM\...\SideWidener_is1) (Version: 1.0.2 - )
      Skype™ 7.32 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.32.104 - Skype Technologies S.A.)
      Slack (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\slack) (Version: 2.1.0 - Slack Technologies)
      Slate Digital TRIGGER (HKLM-x32\...\SlateDigitalTrigger) (Version: 1.65 - Slate Digital)
      Snagit 11 (HKLM-x32\...\{A56C6348-59D0-433B-A48A-75914858664E}) (Version: 11.2.1 - TechSmith Corporation)
      Sniper Elite (HKLM-x32\...\Steam App 3700) (Version:  - Rebellion Developments)
      Sniper Elite V2 (HKLM-x32\...\Steam App 63380) (Version:  - )
      SoftEther VPN Client (HKLM\...\softether_sevpnclient) (Version: 4.22.9634 - SoftEther VPN Project)
      Softube Acoustic Feedback VST RTAS v1.0.7 (HKLM-x32\...\Softube Acoustic Feedback VST RTAS_is1) (Version:  - )
      Softube Bass Amp Room VST RTAS v1.0.2 (HKLM-x32\...\Softube Bass Amp Room VST RTAS_is1) (Version:  - )
      Softube FET Compressor VST RTAS v1.0.3 (HKLM-x32\...\Softube FET Compressor VST RTAS_is1) (Version:  - )
      Softube Metal Amp Room VST RTAS v1.1.5 (HKLM-x32\...\Softube Metal Amp Room VST RTAS_is1) (Version:  - )
      Softube Passive-Active Pack VST RTAS v1.0.2 (HKLM-x32\...\Softube Passive-Active Pack VST RTAS_is1) (Version:  - )
      Softube Spring Reverb VST RTAS v1.0.4 (HKLM-x32\...\Softube Spring Reverb VST RTAS_is1) (Version:  - )
      Softube Trident A-Range VST RTAS v1.0.2 (HKLM-x32\...\Softube Trident A-Range VST RTAS_is1) (Version:  - )
      Softube Tube Delay VST RTAS v1.0.5 (HKLM-x32\...\Softube Tube Delay VST RTAS_is1) (Version:  - )
      Softube Tube-Tech CL 1B VST RTAS v1.0.3 (HKLM-x32\...\Softube Tube-Tech CL 1B VST RTAS_is1) (Version:  - )
      Softube Vintage Amp Room VST RTAS v1.0.8 (HKLM-x32\...\Softube Vintage Amp Room VST RTAS_is1) (Version:  - )
      Sonalksis Plug-in Manager 3.00 (HKLM-x32\...\{7A600039-FED6-4C81-AA6E-F151F7FA7EE7}_is1) (Version:  - Sonalksis Ltd)
      Sonarworks HD reference 2.2 (HKLM-x32\...\{F76463A9-42A2-47D5-B7D4-8838523E64E4}) (Version: 2.2.12.30 - Sonarworks)
      Sonarworks HD Reference VST plugin (64-bit) 2.2 (HKLM\...\{3F08FE5F-23E4-423B-A929-8247E4D5193A}) (Version: 2.2.12.30 - Sonarworks)
      Sonarworks Reference 3 (HKLM-x32\...\{E8A1DAEE-C491-4833-8D3B-AA8F3E0098AE}) (Version: 3.2.11 - Sonarworks)
      SONiVOX Harmonica (HKLM-x32\...\SONiVOX Harmonica) (Version: 1.0 - SONiVOX)
      SONiVOX VocalizerPro (HKLM-x32\...\SONiVOX VocalizerPro_is1) (Version:  - )
      Sonnox Fraunhofer Codec Toolbox v1.0.0 (HKLM\...\Sonnox Fraunhofer Codec Toolbox v1.0.0_is1) (Version: 1.0.0 - Sonnox Ltd, Oxford, UK)
      Sonoris Mastering Compressor (HKLM-x32\...\Sonoris Mastering Compressor) (Version:  - Sonoris Audio Engineering)
      Sound Blaster X-Fi MB 2 (HKLM-x32\...\{44DA67A9-C906-4316-94CB-61B036BBDCE5}) (Version: 1.04.02 - Creative Technology Limited)
      SoundToys Native Effects VST RTAS v3.1.2 (HKLM-x32\...\SoundToys Native Effects VST RTAS_is1) (Version:  - )
      SpeedFan (remove only) (HKLM-x32\...\SpeedFan) (Version:  - )
      Spotify (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\Spotify) (Version: 1.0.49.125.g72ee7853 - Spotify AB)
      SSD Sampler (HKLM-x32\...\SSD4) (Version: 1.1 - Yellow Matter Entertainment)
      SSD Utility (HKLM-x32\...\{3449D0CA-9D99-472B-B36C-A32A58AF18F5}) (Version: 2.2.2645 - Toshiba Corporation)
      SSDlife Pro (HKLM-x32\...\{3D843494-7DC4-47C9-9E95-3543F0A4E7BC}) (Version: 2.3.56 - BinarySense Inc.)
      Steam (HKLM-x32\...\{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
      Stereoizer3 v3.1 (HKLM\...\Stereoizer3_is1) (Version:  - NUGEN Audio)
      Stereoplacer v3 (HKLM\...\Stereoplacer3_is1) (Version:  - NUGEN Audio)
      Sugar Bytes Looperator 1.0 (HKLM\...\Looperator_is1) (Version: 1.0 - Sugar Bytes)
      Suite Shared Configuration CS4 (x32 Version: 1.0 - Adobe Systems Incorporated) Hidden
      Surfer EQ version 1.2.2 (HKLM\...\{B8D2A156-B2DE-47BD-9789-F1A850F060C1}_is1) (Version: 1.2.2 - Sound Radix)
      swMSM (x32 Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
      System Requirements Lab for Intel (HKLM-x32\...\{C7CA731B-BF9A-46D9-92CF-8A8737AE9240}) (Version: 4.5.13.0 - Husdawg, LLC)
      Tag&Rename 3.7 (HKLM-x32\...\Tag&Rename_is1) (Version: 3.7 - Softpointer Inc)
      TeamViewer 12 (HKLM-x32\...\TeamViewer) (Version: 12.0.72365 - TeamViewer)
      TeraCopy 2.3 (HKLM\...\TeraCopy_is1) (Version:  - Code Sector)
      The Glue (HKLM\...\The Glue_is1) (Version: 1.2.8 - )
      The KMPlayer (remove only) (HKLM-x32\...\The KMPlayer) (Version: 3.7.0.109 - KMP Media co., Ltd)
      ToneBoosters Morphit (HKLM\...\Morphit_is1) (Version: 1.1.4 - ToneBoosters)
      Tracker (HKLM-x32\...\com.elance.tracker) (Version: 2.3.3 - Elance Inc)
      Tracker (x32 Version: 2.3.3 - Elance Inc) Hidden
      T-RackS 3 Black 76 version 3.5 (HKLM\...\{7F0FEB55-6D4A-4892-8A04-3E1EC9001F49}_is1) (Version: 3.5 - IK Multimedia)
      T-RackS 3 White 2A version 3.5 (HKLM\...\{4EE378E8-5B8C-4A56-837F-04986F44F14F}_is1) (Version: 3.5 - IK Multimedia)
      T-RackS CS version 4.5.0 (HKLM\...\{E931EBCC-55F9-4D67-BA0E-D57C4A893A44}_is1) (Version: 4.5.0 - IK Multimedia)
      Trackspacer (HKLM\...\Trackspacer_is1) (Version: 2.0.4 - Wavesfactory)
      Tradeo - MetaTrader 4 (HKLM-x32\...\Tradeo - MetaTrader 4) (Version: 4.00 - MetaQuotes Software Corp.)
      Transify version 1.3 (HKLM\...\Transify_is1) (Version: 1.3 - )
      TuneSmith (HKLM-x32\...\{9061CD4C-6D8A-465B-A2DF-530DF94BCE4D}) (Version: 3.0 - Idolumic)
      Tweaking.com - Windows Repair (HKLM-x32\...\Tweaking.com - Windows Repair) (Version: 3.9.25 - Tweaking.com)
      UAD drivers. This may take a while... (x32 Version: 9.0.0.58759 - Universal Audio, Inc.) Hidden
      UAD Powered Plug-Ins (HKLM-x32\...\{9b9c7089-62a6-4bba-887c-4b94398cc561}) (Version: 9.0.0.58759 - Universal Audio, Inc.)
      UAD Powered Plug-Ins (Version: 9.0.0.58759 - Universal Audio, Inc.) Hidden
      UAD Powered Plug-Ins (x32 Version: 9.0.0.58759 - Universal Audio, Inc.) Hidden
      ubCore64 5.63 (HKLM-x32\...\InstallShield_{F65FE148-FCF5-42F7-8803-FA0B7DA8B8A4}) (Version:  - )
      ubCore64 5.63 (Version: 5.63 - Unibrain) Hidden
      UNCHIRP VST-x64 1.0.0 (HKLM\...\{FE7EB46F-1099-46e2-9165-D10058814B7D}) (Version: 1.0.0 - Zynaptiq)
      UNFILTER VST-x64 1.2.1 (HKLM\...\{F74A8B13-C915-4CE2-ACE0-CC6845C9D89D}) (Version: 1.2.1 - Zynaptiq)
      UnHackMe 8.60 (HKLM-x32\...\UnHackMe_is1) (Version:  - Greatis Software, LLC.)
      Universal Extractor 1.6.1 (HKLM-x32\...\Universal Extractor_is1) (Version: 1.6.1 - Jared Breland)
      Update for Skype for Business 2015 (KB3039776) 64-Bit Edition (HKLM\...\{90150000-012B-0409-1000-0000000FF1CE}_Office15.PROPLUS_{0FA8AE0C-69AE-4F60-A1AB-F79C6BA5A999}) (Version:  - Microsoft)
      Update for Skype for Business 2015 (KB3115033) 64-Bit Edition (HKLM\...\{90150000-00C1-0000-1000-0000000FF1CE}_Office15.PROPLUS_{F258B6E3-BF41-4FEE-BE45-D7518C3B7FC1}) (Version:  - Microsoft)
      Update for Skype for Business 2015 (KB3115033) 64-Bit Edition (HKLM\...\{90150000-012B-0409-1000-0000000FF1CE}_Office15.PROPLUS_{F258B6E3-BF41-4FEE-BE45-D7518C3B7FC1}) (Version:  - Microsoft)
      Uplay (HKLM-x32\...\Uplay) (Version: 2.0 - Ubisoft)
      URS Classic Console Strip Pro VST RTAS v1.0 (HKLM-x32\...\URS Classic Console Strip Pro VST RTAS_is1) (Version:  - )
      VC80CRTRedist - 8.0.50727.6195 (x32 Version: 1.2.0 - DivX, Inc) Hidden
      VerbSuite Classics - Fusion-IR Bricasti M7 (Part 1) 1.1 (HKLM\...\VerbSuite Classics - Fusion-IR Bricasti M7 (Part 1)) (Version: 1.1 - LiquidSonics)
      VerbSuite Classics - Fusion-IR Bricasti M7 (Part 2) 1.1 (HKLM\...\VerbSuite Classics - Fusion-IR Bricasti M7 (Part 2)) (Version: 1.1 - LiquidSonics)
      VerbSuite Classics (HKLM\...\Slate Digital VerbSuite Classics_is1) (Version: 1.0.3.2 - Slate Digital)
      Virtual Audio Cable 4.13 (HKLM\...\Virtual Audio Cable 4.13) (Version:  - )
      Virtual Buss Compressors (HKLM\...\Slate Digital Virtual Buss Compressors_is1) (Version: 1.2.7.7 - Slate Digital)
      Virtual Tape Machines (HKLM\...\Slate Digital Virtual Tape Machines_is1) (Version:  - Slate Digital)
      VisLM v1.5.1 (HKLM\...\VisLM_is1) (Version:  - NUGEN Audio)
      Visual C++ 64-bit Redistributables (HKLM-x32\...\InstallShield_{FB03650C-B373-4B20-ACA5-B7BA1A8EEE33}) (Version: 1.3.0.8766 - PACE Anti-Piracy, Inc.)
      Visual C++ Redistributables (HKLM-x32\...\InstallShield_{F03117FA-9270-46B0-9666-0B4BC2CDEBF5}) (Version: 1.3.0.8766 - PACE Anti-Piracy, Inc.)
      Visual Studio 2012 x64 Redistributables (HKLM\...\{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
      Visual Studio 2012 x86 Redistributables (HKLM-x32\...\{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
      Visualizer v1.9.2 (HKLM-x32\...\Visualizer1_9_is1) (Version:  - NuGen Audio)
      VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
      VocALign Pro 4 VST (HKLM-x32\...\{EB77C666-B349-4046-8BD3-E4941119E1EF}) (Version: 4.00.0000 - Synchro Arts Ltd)
      Voxengo Boogex (HKLM\...\Voxengo Boogex_is1) (Version: 2.1 - Voxengo)
      Vulkan Run Time Libraries 1.0.37.0 (HKLM\...\VulkanRT1.0.37.0) (Version: 1.0.37.0 - LunarG, Inc.)
      Waves Complete (HKLM\...\Complete_is1) (Version: 2016.11.22 - Waves)
      Webroot SecureAnywhere (HKLM-x32\...\WRUNINST) (Version: 9.0.15.40 - Webroot)
      Welcome App (Start-up experience) (x32 Version: 12.0.14000 - Nero AG) Hidden
      WinDirStat 1.1.2 (HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\WinDirStat) (Version:  - )
      Windows 10 Upgrade Assistant (HKLM-x32\...\{D5C69738-B486-402E-85AC-2456D98A64E4}) (Version: 1.4.9200.17332 - Microsoft Corporation)
      Windows Driver Package - Silicon Laboratories (silabenm) Ports  (12/10/2012 6.6.1.0) (HKLM\...\D680DEE0F68D64EC53D0C5769879D15D387054CC) (Version: 12/10/2012 6.6.1.0 - Silicon Laboratories)
      Windows Installer Clean Up (HKLM-x32\...\{121634B0-2F4B-11D3-ADA3-00C04F52DD52}) (Version: 3.00.00.0000 - Microsoft Corporation)
      Windows Software Development Kit (HKLM-x32\...\{363a2c1e-637f-45ce-933b-5a5463efd945}) (Version: 8.59.29750 - Microsoft Corporation)
      WinRAR 5.40 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
      WinZip 18.0 (HKLM\...\{CD95F661-A5C4-44F5-A6AA-ECDD91C240DF}) (Version: 18.0.10661 - WinZip Computing, S.L. )
      WPT Redistributables (x32 Version: 8.59.29750 - Microsoft) Hidden
      WPTx64 (x32 Version: 8.59.29722 - Microsoft) Hidden
      Zemana AntiMalware (HKLM-x32\...\{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.72.101 - Zemana Ltd.)
      Zynaptiq ADAPTIVERB (HKLM\...\ADAPTIVERB_is1) (Version: 1.1.0 - Zynaptiq)
      Zynaptiq ADAPTIVERB (HKLM-x32\...\Zynaptiq ADAPTIVERB) (Version: 1.0.1 - Zynaptiq)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{005A3A96-BAC4-4B0A-94EA-C0CE100EA736}\localserver32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dropbox.exe (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA}\InprocServer32 -> C:\Users\SamSwanson\AppData\Local\Google\Update\1.3.32.7\psuser_64.dll (Google Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{E8CF3E55-F919-49D9-ABC0-948E6CB34B9F}\InprocServer32 -> C:\Users\SamSwanson\AppData\Local\Google\Update\1.3.32.7\psuser_64.dll (Google Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314ED9-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314EDA-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314EDB-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314EDC-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314EDD-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314EDE-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314EDF-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      CustomCLSID: HKU\S-1-5-21-3236326594-2611474830-2656184370-1001_Classes\CLSID\{FB314EE0-A251-47B7-93E1-CDD82E34AF8B}\InprocServer32 -> C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\DropboxExt64.24.dll (Dropbox, Inc.)
      Task: {04EFF940-BF67-4191-9209-1125A09409A3} - System32\Tasks\Microsoft\Office\Office 15 Subscription Heartbeat => C:\Program Files\Common Files\Microsoft Shared\Office15\OLicenseHeartbeat.exe [2014-01-23] (Microsoft Corporation)
      Task: {05848826-F541-4A0C-B9F2-1611BC2C39B2} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085 => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-31] (Google Inc.)
      Task: {063A0BFF-9FB6-4A57-A0FE-92E13D9CF789} - \Auslogics\BoostSpeed\Start BoostSpeed оn SamSwanson logon -> No File <==== ATTENTION
      Task: {08ABE768-2FEF-4170-8066-25BB5001F947} - System32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {09888CEB-9E1F-4B6B-BF4A-DB2571F3F71B} - System32\Tasks\ASUS\ASUS AI Suite II Execute => C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe [2016-08-15] (ASUSTeK Computer Inc.)
      Task: {0F509641-76C6-4FAB-BEF3-CB600B547AC5} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {1471D492-58EE-4C44-BE77-AF989C926662} - System32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {1A41D700-2897-4BAA-A036-58E78AA05409} - System32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {1F8E022B-DD5B-4C81-B850-C98F8B88CD15} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2017-02-20] (Piriform Ltd)
      Task: {21C96E5B-F2CD-4BC9-8E73-CA85AC55B19E} - System32\Tasks\{EB5A17F7-59B1-4914-80F9-8981CBF7FF0B} => C:\Program Files (x86)\Gizmo\gizmo.exe [2012-12-25] (Arainia Solutions)
      Task: {23972D0B-9EA4-444E-94E3-FEF38A46F53D} - System32\Tasks\Microsoft\Windows\Media Center\ehDRMInit => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {25A3DFC4-D040-485E-B0C3-426340897B2A} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-10-11] (Intel Corporation)
      Task: {26678860-B1BB-4488-B82C-9D65CF436774} - System32\Tasks\NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-26] (NVIDIA Corporation)
      Task: {28DC6CF1-3441-4644-839D-CA8C38FCF81F} - System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmMon.exe [2017-01-26] (NVIDIA Corporation)
      Task: {2A5F42E1-3D73-43DE-AD75-7C45767E1073} - System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-26] (NVIDIA Corporation)
      Task: {31B61FA2-6781-4DDF-A0E6-B5E23DA9740B} - System32\Tasks\Microsoft\Windows\Media Center\RegisterSearch => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {34709417-D411-4C04-AC19-79E7834F99FF} - System32\Tasks\20160618_170750_Restore 12 0 => C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\NBCore.exe [2012-08-13] (Nero AG)
      Task: {355B0E4F-F22C-472D-80DF-8E171D2F3733} - System32\Tasks\Maxthon Update => C:\Program Files (x86)\Maxthon\Bin\mxup.exe [2015-01-05] (Maxthon International ltd.)
      Task: {36AD6884-E5D4-488D-95F6-FE8F55B41FAC} - System32\Tasks\Tweaking.com - Windows Repair Tray Icon => C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\WR_Tray_Icon.exe [2017-02-20] (Tweaking.com)
      Task: {39DBE3EA-4037-4B26-AD52-FC269D6B2855} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2016-02-23] (Apple Inc.)
      Task: {3BC80582-EF19-47C4-B5B2-6C63A4573C8E} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate_scheduled => %SystemRoot%\ehome\mcupdate.exe
      Task: {40305E3B-34DB-4DB3-B2A3-B9F92E3C5D26} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentFallBack => C:\Program Files\Microsoft Office\Office15\msoia.exe [2014-01-23] (Microsoft Corporation)
      Task: {460D91C7-7A6C-4120-BDF1-351A93CF1157} - System32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry => %windir%\ehome\MCUpdate.exe
      Task: {4A2A02C8-A390-4ABD-A482-7FE54A9654CB} - System32\Tasks\open effects => C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe [2015-07-15] ()
      Task: {4E2CFB07-EBB0-4549-8B69-C13637DFE808} - System32\Tasks\Patch My PC => C:\Users\SamSwanson\Desktop\PatchMyPC.exe [2017-02-20] ([www.patchmypc.net]('http://www.patchmypc.net'))
      Task: {52F29D63-FCB4-4A1A-BF18-02E57B5BE9A1} - System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d => C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [2016-10-11] (Intel Corporation)
      Task: {5B36754A-B7BE-41F5-BE37-F12045B1C69B} - System32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {5D25CD93-550A-42DF-8295-8A2C8AB3DF1E} - \avastBCLRestartS-1-5-21-3236326594-2611474830-2656184370-1001 -> No File <==== ATTENTION
      Task: {5D6CA38A-4C4C-4E18-8C5D-5E2224AEC118} - System32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {63D37EC5-5EDB-47FF-9FD1-1EBEC107D223} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentLogOn => C:\Program Files\Microsoft Office\Office15\msoia.exe [2014-01-23] (Microsoft Corporation)
      Task: {66365F28-CE4B-45AD-A996-337675E8A58E} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-31] (Google Inc.)
      Task: {668D7E1E-ED4D-47C9-90C6-0775FE94025F} - System32\Tasks\Intel\Intel Telemetry 2 => C:\Program Files\Intel\Telemetry 2.0\lrio.exe [2016-01-10] (Intel Corporation)
      Task: {697EFF5B-44E8-4A03-844A-5C3AD38E4FEA} - System32\Tasks\Microsoft\Windows\Media Center\SqlLiteRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
      Task: {6C09C286-EFF3-4AD4-8FB6-8392EB892C5F} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-31] (Google Inc.)
      Task: {6C51BCE8-98E4-49AD-970F-82BA1B4FC324} - System32\Tasks\20160623_163758_Restore 12 0 => C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\NBCore.exe [2012-08-13] (Nero AG)
      Task: {6E398F56-89B4-4FC1-8AEA-E632E89C8918} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
      Task: {6F7DD068-47F7-4EE2-B113-F6BC5435281D} - \Microsoft\Windows\Setup\EOSNotify -> No File <==== ATTENTION
      Task: {7388C649-BD6B-458E-BB7D-615016D011FC} - System32\Tasks\COMODO\COMODO Update {A6D52E4F-569B-4756-B3D8-DF217313DA85} => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [2016-10-13] (COMODO)
      Task: {7C23857E-26FD-48C7-AADC-94F9F547CB5F} - System32\Tasks\Process Lasso Core Engine Only => C:\Program Files\Process Lasso\processgovernor.exe [2017-02-11] (Bitsum LLC)
      Task: {7D6CD2E9-7D16-4990-876E-A1DDD1C333DC} - System32\Tasks\Microsoft\Windows\Media Center\RecordingRestart => %SystemRoot%\ehome\ehrec.exe
      Task: {8C2DAB06-A415-4E79-9FD2-92C60BC7FA67} - System32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
      Task: {8D7DD635-2A2D-4000-8D1F-4C6B77F8D80E} - System32\Tasks\Microsoft\Windows\PLA\System\{2BCE5899-48A6-4AB8-B3D9-62E4245605D0}_System Diagnostics => Rundll32.exe C:\WINDOWS\system32\pla.dll,PlaHost "system\System Diagnostics" "$(Arg0)"
      Task: {95C752B4-7B0C-48D9-AE1C-3942F5D3BB76} - System32\Tasks\COMODO\COMODO Autostart {D5EFF3B3-E126-4AF6-BCE9-852A72129E10} => C:\Program Files\COMODO\COMODO Internet Security\cistray.exe [2016-09-27] (COMODO)
      Task: {96FDF968-3B9A-47A0-8729-22C64981D02C} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate => %SystemRoot%\ehome\mcupdate.exe
      Task: {9929E7D3-69C5-48B3-BD78-4DA035C80291} - System32\Tasks\{BBCD0C7D-45F8-4AA4-A784-5E4F16371482} => pcalua.exe -a E:\ashampoo_firewall_free_1.20_sm.exe -d E:\
      Task: {9AC9EE1F-3C7D-4D11-A723-C108476BA2FD} - System32\Tasks\Adobe Flash Player PPAPI Notifier => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_0_0_221_pepper.exe [2017-02-22] (Adobe Systems Incorporated)
      Task: {9F6C043A-F8EF-4589-9123-0EF833FBDDE8} - System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe [2017-01-26] (NVIDIA Corporation)
      Task: {A75CC2EA-C50E-4D36-AEA1-91212A6641DB} - System32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {AD0C68FF-F1EF-4C1E-A767-DBD5729882A2} - System32\Tasks\UnHackMe Task Scheduler => C:\Program Files (x86)\UnHackMe\hackmon.exe [2017-02-24] (Greatis Software)
      Task: {AD2F8636-6963-4AAD-A26F-1D01E01200F0} - System32\Tasks\ASUS\Easy Update => C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzUpdt.exe [2013-01-14] ()
      Task: {AD93EA85-7159-4B00-A2A8-DC9C6441F3A7} - System32\Tasks\Microsoft\Windows\Media Center\StartRecording => %SystemRoot%\ehome\ehrec.exe
      Task: {BD2046AE-D49F-4ADD-BCDE-8005342B87D5} - System32\Tasks\{31DDBD37-5DB7-4030-8064-10B0CAA806C3} => C:\Program Files\COMODO\COMODO Internet Security\cistray.exe [2016-09-27] (COMODO)
      Task: {BDE36E30-62CC-4A29-816E-3A295DC2890B} - System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-26] (NVIDIA Corporation)
      Task: {C1590D8D-F402-4E93-8D27-AFD81BC6A5C3} - System32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
      Task: {C374DDAD-C0E9-49BF-A6B0-9ED56EB2165C} - System32\Tasks\ASUS\USB 3.0 Boost Service => C:\Program Files (x86)\ASUS\AI Suite II\USB 3.0 Boost\U3BoostSvr.exe [2016-08-15] ()
      Task: {C488B36A-662D-4D82-8D4E-7ACDD04C6206} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-10-11] (Intel Corporation)
      Task: {CA31EB53-D7B0-4140-9BF1-68356F601421} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpdateService.exe [2017-02-22] (Adobe Systems Incorporated)
      Task: {D583F66C-8EAB-4249-8FEB-75F592B49722} - System32\Tasks\ASUS\ASUS Network iControl Help Execute => C:\Program Files (x86)\ASUS\AI Suite II\Network iControl\NetSvcHelp\NetSvcHelpEntry.exe [2012-05-02] (ASUSTeK Computer Inc.)
      Task: {D6716D1C-E449-4AF6-8063-D330FAEA820B} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [2015-08-31] (Google Inc.)
      Task: {D8D805E5-AFF8-477C-B46C-3A79C13D64E8} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {DAE7EBFF-9B4D-438B-A0E1-76A7FE896D57} - System32\Tasks\Microsoft\Windows\Media Center\OCURActivate => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {E3CC8218-7A1E-4B80-B0E8-C9C2FA606B1B} - System32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
      Task: {E4290C7D-DF68-49AF-B8D3-ECF30CFCE984} - System32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask => %SystemRoot%\ehome\mcupdate.exe
      Task: {E8E81B66-3E1E-448E-9EDA-61D64DB64920} - System32\Tasks\{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} => C:\ProgramData\Carbonite\Carbonite Backup\CarboniteUpgrade.exe
      Task: {E8F94C64-88AA-4D59-AE81-D4BF8E78B677} - System32\Tasks\COMODO\COMODO Signature Update {B9D5C6F9-17D2-4917-8BD0-614BAA1C6A59} => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [2016-10-13] (COMODO)
      Task: {ED0C1F69-C3A2-41EA-B8C3-3F0D83A1F6C0} - \Microsoft\Windows\Customer Experience Improvement Program\BthSQM -> No File <==== ATTENTION
      Task: {F19205EB-384D-455D-99E3-6BC1A4840E68} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
      Task: {F1C40402-4D4E-40EC-9F8D-55452716F7E0} - System32\Tasks\{EE492B24-CD47-404D-95D3-605112E375FA} => pcalua.exe -a "S:\More VSTI\Orchestral.Tools.Metropolis.Ark.2.Orchestra.Of.The.Deep.KONTAKT-P2P\METROPOLIS Ark 2 Win Installer.exe" -d "S:\More VSTI\Orchestral.Tools.Metropolis.Ark.2.Orchestra.Of.The.Deep.KONTAKT-P2P"
      Task: {F6E4AD78-6FF4-4B5F-A68C-36575464E8A3} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {F8D01798-23CD-4BD7-A4B2-3C85ED5B55C9} - System32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService => %SystemRoot%\ehome\ehPrivJob.exe
      Task: {F95AB783-6CE0-421A-B5CE-89C59CE572F7} - System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-26] (NVIDIA Corporation)
      Task: {FAD23CE4-F70B-4FE3-B9F6-F8719DFDC955} - System32\Tasks\Microsoft\Windows\PLA\System\{EC8853F4-75E4-4154-B078-27C2E7531492}_System Diagnostics => Rundll32.exe C:\WINDOWS\system32\pla.dll,PlaHost "system\System Diagnostics" "$(Arg0)"
      Task: {FF6E9CA0-FA25-46F9-970E-F95E6DF9AFA3} - System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d-Logon => C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [2016-10-11] (Intel Corporation)
      Task: C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_0_0_221_pepper.exe
      Task: C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpdateService.exe
      Task: C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask.job => C:\WINDOWS\explorer.exe
      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core.job => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe
      Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA.job => C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe
      ==================== Shortcuts =============================
      2016-07-16 12:42 - 2016-07-16 12:42 - 00231424 _____ () C:\WINDOWS\SYSTEM32\ism32k.dll
      2016-12-13 23:35 - 2016-12-13 23:35 - 02681200 _____ () C:\WINDOWS\system32\CoreUIComponents.dll
      2012-12-23 12:43 - 2017-01-20 16:13 - 00134712 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
      2016-05-24 01:09 - 2016-05-24 01:09 - 00127336 _____ () C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe
      2016-10-05 18:17 - 2016-10-05 18:17 - 00092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
      2017-01-13 13:56 - 2017-01-13 13:56 - 01353528 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
      2014-01-07 16:14 - 2014-01-07 16:14 - 00920736 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe
      2017-02-10 20:00 - 2017-01-20 19:40 - 04489152 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\Poco.dll
      2017-02-10 20:00 - 2017-01-20 19:40 - 01147328 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\libprotobuf.dll
      2015-07-07 10:44 - 2015-07-07 10:44 - 00088064 _____ () C:\Program Files\Intel Corporation\Intel(R) Technology Access\libglog.dll
      2016-04-26 13:30 - 2016-04-26 13:30 - 00367824 _____ () C:\Program Files\Intel Corporation\Intel(R) Technology Access\JsonCpp.dll
      2017-02-11 16:07 - 2017-02-11 16:07 - 02264352 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\PoliciesControllerImpl.dll
      2017-02-11 16:07 - 2017-02-11 16:07 - 02254800 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\MwacLib.dll
      2017-02-11 16:07 - 2017-02-11 16:07 - 02829776 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\arwlib.dll
      2016-10-14 14:31 - 2016-10-31 09:17 - 01244408 _____ () C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe
      2016-10-31 09:17 - 2016-10-31 09:17 - 04463592 _____ () C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe
      2016-12-13 23:35 - 2016-12-13 23:35 - 02681200 _____ () C:\WINDOWS\SYSTEM32\CoreUIComponents.dll
      2015-09-15 13:58 - 2015-09-15 13:58 - 08901184 _____ () C:\Program Files\Microsoft Office\Office15\1033\GrooveIntlResource.dll
      2014-01-07 16:16 - 2013-01-14 16:37 - 01406776 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzUpdt.exe
      2016-10-13 08:57 - 2016-10-13 08:57 - 03388256 _____ () C:\Windows\SystemApps\Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy\ContentDeliveryManager.Background.dll
      2016-09-14 10:10 - 2016-09-14 10:10 - 00134656 _____ () C:\Windows\ShellExperiences\Windows.UI.Shell.SharedUtilities.dll
      2017-01-11 10:41 - 2017-01-11 10:41 - 00474112 _____ () C:\Windows\ShellExperiences\QuickActions.dll
      2017-01-11 10:41 - 2017-01-11 10:41 - 09760768 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CortanaApi.dll
      2017-01-11 10:41 - 2017-01-11 10:41 - 01401856 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Core.dll
      2017-01-11 10:41 - 2017-01-11 10:41 - 00757248 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CSGSuggestLib.dll
      2017-01-11 10:41 - 2017-01-11 10:41 - 01033216 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Actions.dll
      2017-01-11 10:41 - 2017-01-11 10:41 - 02424320 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.BackgroundTask.dll
      2017-01-11 10:41 - 2017-01-11 10:41 - 04853760 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\RemindersUI.dll
      2012-12-23 13:44 - 2012-11-09 03:17 - 01433200 _____ () C:\Program Files (x86)\Ditto\Ditto.exe
      2014-02-18 21:52 - 2017-02-20 17:22 - 00544208 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\DashlanePlugin.exe
      2012-01-20 11:27 - 2015-07-15 21:28 - 03042304 _____ () C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
      2012-09-13 00:38 - 2012-09-13 00:38 - 00264040 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\CameraHelperShell.exe
      2016-10-14 14:48 - 2016-10-31 09:17 - 07382232 _____ () C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe
      2016-04-16 11:56 - 2016-06-29 11:01 - 09698296 _____ () C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
      2014-12-21 17:07 - 2014-12-21 17:07 - 00119822 _____ () C:\Program Files (x86)\AnonVPN\bin\libgcc_s_dw2-1.dll
      2014-12-21 17:07 - 2014-12-21 17:07 - 01026062 _____ () C:\Program Files (x86)\AnonVPN\bin\libstdc++-6.dll
      2014-01-07 16:14 - 2017-03-01 20:26 - 00026112 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.19\PEbiosinterface32.dll
      2014-01-07 16:14 - 2010-06-29 10:58 - 00104448 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.19\ATKEX.dll
      2015-08-11 14:36 - 2015-08-11 14:36 - 00024896 _____ () C:\Program Files (x86)\Common Files\Acronis\Infrastructure\core_workers_shared_context.dll
      2016-10-14 14:25 - 2016-10-14 14:25 - 00037808 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\thread_pool.dll
      2016-10-14 14:48 - 2016-10-14 14:48 - 04355264 _____ () C:\Program Files (x86)\Common Files\Acronis\Infrastructure\atih_mms_addon.dll
      2015-08-23 14:59 - 2015-08-23 14:59 - 00606672 _____ () C:\Program Files (x86)\Common Files\Acronis\Infrastructure\sqlite3.dll
      2016-10-14 14:47 - 2016-10-14 14:47 - 20605872 _____ () C:\Program Files (x86)\Acronis\TrueImageHome\ti_managers.dll
      2015-11-16 17:05 - 2015-11-16 17:05 - 00126928 _____ () C:\Program Files (x86)\Acronis\TrueImageHome\afcdpapi.dll
      2016-04-16 11:45 - 2016-04-16 11:45 - 00248240 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\sync_agent_api.dll
      2017-02-10 20:01 - 2017-01-20 19:40 - 00018880 _____ () C:\Program Files (x86)\NVIDIA Corporation\Update Core\detoured.dll
      2017-02-10 20:00 - 2017-01-20 19:40 - 03774400 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\Poco.dll
      2017-02-10 20:00 - 2017-01-20 19:40 - 00900032 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\libprotobuf.dll
      2014-01-07 16:16 - 2013-01-14 17:16 - 05771136 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzULIB.dll
      2014-01-07 16:16 - 2010-06-21 15:21 - 00208896 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\ImageHelper.dll
      2014-01-07 16:17 - 2012-08-03 16:41 - 00043520 _____ () C:\Program Files (x86)\ASUS\AI Suite II\TurboV EVO\HookKey32.dll
      2014-01-07 16:17 - 2012-08-03 16:40 - 00253952 _____ () C:\Program Files (x86)\ASUS\AI Suite II\TurboV EVO\pngio.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 00350160 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWDebugDll_win32.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 00441808 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWDebug.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 00465872 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWUtils.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 62691792 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWExternLib.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 00285648 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWMainLib_win.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 06186448 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWData.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 07395280 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWApplication.4.6.7.25343.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00147456 _____ () C:\Program Files (x86)\ASUS\AI Suite II\AssistFunc.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00253952 _____ () C:\Program Files (x86)\ASUS\AI Suite II\pngio.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00972288 _____ () C:\Program Files (x86)\ASUS\AI Suite II\BarGadget\BarGadget.dll
      2014-01-07 16:16 - 2013-01-15 15:30 - 01040896 _____ () C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EasyUpdt.dll
      2014-01-07 16:17 - 2012-07-25 09:56 - 01124864 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Network iControl\Network iControl.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00883712 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Sensor\Sensor.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 01622528 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Sensor Graph\SensorGraph.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 01243136 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Settings\Settings.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00846848 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Splitter\Splitter.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00875520 _____ () C:\Program Files (x86)\ASUS\AI Suite II\TabGadget\TabGadget.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00208896 _____ () C:\Program Files (x86)\ASUS\AI Suite II\ImageHelper.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 13674960 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWMainLib.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 02215376 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\KWMainLibData.4.6.7.25343.dll
      2017-02-22 17:23 - 2017-02-20 17:21 - 00334288 _____ () C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6.7.25343\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components\Kwift_DP.4.6.7.25343.dll
      2015-11-10 18:38 - 2015-11-10 18:38 - 08337408 _____ () C:\Users\SamSwanson\Downloads\SonarworksforDDMF\Reference3.dll
      2012-09-13 00:38 - 2012-09-13 00:38 - 02144104 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\QtCore4.dll
      2012-09-13 00:38 - 2012-09-13 00:38 - 07955304 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\QtGui4.dll
      2012-09-13 00:38 - 2012-09-13 00:38 - 00341352 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\QtXml4.dll
      2012-09-13 00:38 - 2012-09-13 00:38 - 00028008 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\imageformats\QGif4.dll
      2012-09-13 00:38 - 2012-09-13 00:38 - 00127336 _____ () C:\Program Files (x86)\Logitech\LWS\Webcam Software\imageformats\QJpeg4.dll
      2012-09-13 00:39 - 2012-09-13 00:39 - 00336232 _____ () C:\Program Files (x86)\Common Files\logishrd\LWSPlugins\LWS\Applets\CameraHelper\DevManagerCore.dll
      2016-10-14 14:27 - 2016-10-14 14:27 - 00333744 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\resource.dll
      2016-10-14 14:25 - 2016-10-14 14:25 - 00050096 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\rpc_client.dll
      2016-10-14 14:25 - 2016-10-14 14:25 - 00445872 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\ulxmlrpcpp.dll
      2016-10-14 14:23 - 2016-10-14 14:23 - 00115632 _____ () C:\Program Files (x86)\Common Files\Acronis\Home\EXPAT.dll
      2014-01-07 16:16 - 2016-08-15 14:56 - 00253952 _____ () C:\Program Files (x86)\ASUS\AI Suite II\Sensor\AlertHelper\pngio.dll
      2016-10-25 02:29 - 2016-10-25 02:29 - 00224768 _____ () C:\WINDOWS\SYSTEM32\UAD2DriverClient.dll
      2016-10-25 02:29 - 2016-10-25 02:29 - 02058752 _____ () C:\WINDOWS\SYSTEM32\UAD2SDK.dll
      2014-04-27 13:17 - 2000-01-01 01:00 - 01242584 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
      AlternateDataStreams: C:\WINDOWS\explorer.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\grep.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\MBR.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\NIRCMD.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\NvContainerRecovery.bat:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\NvTelemetryContainerRecovery.bat:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\PEV.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\sed.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\splwow64.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SWREG.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SWSC.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SWXCACLS.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\unins002.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\unins005.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\unins006.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\unins007.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\zip.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\aadcloudap.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\aadtb.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AboveLockAppHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AccountsRt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\aclui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\acmigration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ACPBackgroundManagerPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AcpiServiceVnA64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ActionCenter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ActionCenterCPL.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ActivationManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\actxprxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AddressParser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\adsmsext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\aeinv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\aepic.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AERTAC64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AERTAR64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\aitstatic.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-core-xstate-l2-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-conio-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-convert-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-environment-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-filesystem-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-heap-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-locale-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-math-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-multibyte-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-private-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-process-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-runtime-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-stdio-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-string-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-time-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\api-ms-win-crt-utility-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppCapture.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppContracts.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\appinfo.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppointmentActivation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppointmentApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\appraiser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppReadiness.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\apprepapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\apprepsync.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVCatalog.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVClient.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVDllSurrogate.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVEntStreamingManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVEntSubsystemController.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVEntSubsystems64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVEntVirtualization.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVIntegration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVManifest.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVOrchestration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVPublishing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVReporting.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVScripting.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppVShNotify.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\appwiz.cpl:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppXApplicabilityBlob.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentExtensions.desktop.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentExtensions.onecore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppXDeploymentServer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AppxPackaging.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\asycfilt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\atmfd.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\atmlib.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AudioEndpointBuilder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AudioEng.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AUDIOKSE.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\audioLibVc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AudioSes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\audiosrv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AudioSrvPolicyManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AuthBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\authui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\autoplay.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\AzureSettingSyncProvider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\baaupdate.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BackgroundMediaPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BarcodeProvisioningPlugin.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bcastdvr.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BcastDVRHelper.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bcdedit.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bcrypt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bdechangepin.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bdesvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bdeui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bdeunlock.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BingMaps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BingOnlineServices.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bisrv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BitLockerDeviceEncryption.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\biwinrt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BluetoothApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BootMenuUX.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\bootux.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\browserbroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\BthRadioMedia.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CastLaunch.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\CbtBackgroundManagerPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cdd.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cdp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cdpsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cdpusersvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CertEnroll.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\certprop.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Chakra.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Chakradiag.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Chakrathunk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\chartv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ChatApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ci.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ClipboardServer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ClipUp.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cloudAP.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CloudBackupSettings.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHostBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHostCommon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CloudExperienceHostUser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CloudStorageWizard.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\clusapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cmifw.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cmintegrator.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\combase.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\comdlg32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CompatTelRunner.exe:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\comsvcs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CONEQMSAPOGUILibrary.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ConsoleLogon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ContactActivation.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\ContactApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\container.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ContentDeliveryManager.Utilities.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CoreMessaging.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\CoreUIComponents.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CPFilters.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CredProvDataModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\credprovhost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\credprovs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\credprovslegacy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\crypt32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cryptngc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CryptoWinRT.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cryptui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\cscui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\csrsrv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CX64APO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\CX64Proxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\C_G18030.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\c_GSM7.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\C_IS2022.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\d2d1.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\d3d10warp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\d3d11.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\D3D12.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\d3d9.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\D3DCompiler_47.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dab.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dafBth.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dafpos.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\das.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dasHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DataExchange.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DataSenseHandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\daxexec.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dbgeng.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DbgModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPA64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPA64F3.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPD64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPD64AF3.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPO64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPO64AF3.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPP64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DDPP64AF3.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ddraw.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\delegatorprovider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DeveloperOptionsSettingsHandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\devenum.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\deviceaccess.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\deviceassociation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DeviceCensus.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DeviceCenter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DeviceEnroller.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DeviceFlows.DataModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DevicePairing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DevicePairingFolder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DeviceReactivation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\devinv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dhcpcore6.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\diagtrack.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dialclient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dialserver.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\discan.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Display.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DisplayManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dlnashext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dmcertinst.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dmenrollengine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DMRServer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dnsapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DolbyDAX2APOProp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DolbyDAX2APOv201.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DolbyDAX2APOv211.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DolbyDecMFT.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\domgmt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dosvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dpapisrv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\drvstore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DscCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DscCoreConfProv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dsreg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dsregcmd.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSBassEnhancementDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSBoostDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSGainCompensatorDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSGFXAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSGFXAPONS64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSLFXAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSLimiterDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSNeoPCDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSS2HeadphoneDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSS2SpeakerDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSSymmetryDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSU2PGFX64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSU2PLFX64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSU2PREC64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DTSVoiceClarityDLL64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dwmapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dwmcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\DWrite.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dxgi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dxmasf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\dxtrans.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EAMProgressHandler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\eapp3hst.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\eappcfg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\eappgnui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\eapphost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\eappprxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\easwrt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\edgehtml.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EditBufferTestHook.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EditionUpgradeHelper.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EditionUpgradeManagerObj.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EDPCleanup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\efsext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\efswrt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EmailApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\encapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EncDec.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\energy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EnterpriseAppMgmtSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\enterprisecsps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\EnterpriseModernAppMgmtCSP.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ErrorDetails.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ErrorDetailsUpdate.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\esent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\esentutl.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\evr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ExplorerFrame.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ExSMime.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ExtrasXmlParser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\facecredentialprovider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Family.Authentication.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Family.Client.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Family.SyncEngine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ffbroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fhcfg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fhcpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fhsettingsprovider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\FlightSettings.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\FMAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\FntCache.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fontdrvhost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fontext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\FontProvider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\FrameServer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\FSClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fveapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fveapibase.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fvecpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fvenotify.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fveprompt.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fveui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\fvewiz.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\GamePanel.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\gameux.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\gdi32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\gdi32full.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\GdiPlus.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\generaltel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\GenValObj.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Geolocation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\GlobCollationHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\gpsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\hal.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HarmanAudioInterface.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\hevcdecoder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\hgcpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HiFiDAX2API.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HMAPO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HMClariFi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HMEQ.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\HMEQ_Voice.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HMHVS.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HMLimiter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HMUI.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\HttpsDataSource.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\hvax64.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\hvix64.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\hvloader.efi:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\hvloader.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ICEsoundAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\icsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\icsvcext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\IdCtrls.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ie4uinit.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ieapfltr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\iedkcs32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ieframe.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\iepeers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ieproxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\iernonce.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\iertutil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\iesetup.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\imapi2.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ImplatSetup.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\indexeddbserver.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\inetcomm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\inetcpl.cpl:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\input.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\InputLocaleManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\InputService.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\InstallAgent.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\InstallAgentUserBroker.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\IntelSSTAPO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\IntelSstCApoPropPage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\invagent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\iphlpsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ipnathlp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\iscsiwmi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\JpMapControl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\jscript9.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\jscript9diag.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\jsproxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\KAAPORT64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\kdhvcom.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\kerberos.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\KernelBase.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\KnobsCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\KnobsCsp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LaunchWinApp.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\libpng15.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LicenseManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LicenseManagerSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ListSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\localspl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LocationFramework.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LockAppBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LockAppHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LogonController.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\lpremove.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\LsaIso.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\lsasrv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\lsass.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\lsm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\manage-bde.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapConfiguration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapControlCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapControlStringsRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapGeocoder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapRouter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapsBtSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapsBtSvcProxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapsCSP.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MapsStore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mapstoasttask.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mapsupdatetask.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO20.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO30.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO4064.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO5064.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO6064.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPO7064.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioAPOShell64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioEQ64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxAudioRealtek64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxSpeechAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxVoiceAPO2064.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxVoiceAPO3064.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxVoiceAPO4064.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MaxxVolumeSDAPO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MbaeApiPublic.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mbsmsapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MCRecvSrc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MDEServer.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MDMAppInstaller.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mdmregistration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MediaFoundation.DefaultPerceptionProvider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfasfsrcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfaudiocnv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MFCaptureEngine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfksproxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MFMediaEngine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfmkvsrcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfmp4srcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfmpeg2srcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfnetcore.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\mfnetsrc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfplat.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MFPlay.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfpmp.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfreadwrite.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfsensorgroup.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfsrcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mfsvr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Microsoft-Windows-MapControls.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Microsoft-Windows-MosHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Microsoft-Windows-MosTrace.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\microsoft-windows-system-events.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\migisol.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MiracastReceiver.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mispace.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MISS_APO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\modernexecserver.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mos.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\moshost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MosHostClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\moshostcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MosResource.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MosStorage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mprapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mprddm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mprdim.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MpSigStub.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MrmCoreR.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MSAC3ENC.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MSAJApi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MSAudDecMFT.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\msctf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msdtcprx.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msdtctm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msdtcuiu.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msdxm.ocx:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msfeeds.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msftedit.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mshtml.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mshtmled.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msinfo32.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msmpeg2vdec.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mspaint.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mssprxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mssrch.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mstsc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\mstscax.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msv1_0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MSVidCtl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MSVideoDSP.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MSVP9DEC.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msvproc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MSVPXENC.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msxml6.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\msxml6r.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MusNotification.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\MusUpdateHandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NAHIMICAPOlfx.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NahimicAPONSControl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NAHIMICV2apo.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NAHIMICV3apo.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nativemap.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NaturalLanguage6.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ncsi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetCfgNotifyObjectHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\netiougc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\netplwiz.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetSetupApi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetSetupEngine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetSetupShim.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetSetupSvc.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\netshell.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nettrace.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetworkBindingEngineMigPlugin.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetworkCollectionAgent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetworkDesktopSettings.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetworkMobileSettings.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NetworkUXBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NFCProvisioningPlugin.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NfcRadioMedia.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ngccredprov.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NgcCtnr.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\NgcCtnrGidsHandler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ngcsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nlasvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nltest.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NMAA.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NmaDirect.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NotificationController.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NPSM.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nshwfp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ntdll.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ntoskrnl.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ntshrui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvapi64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvaudcap64v.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvcompiler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvcuda.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvcuvid.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvDecMFTMjpeg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434709.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434725.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434752.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6434788.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6435354.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6435887.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6435906.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6436909.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6437254.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6437653.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispco6437849.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434709.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434725.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434752.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6434788.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6435354.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6435887.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6435906.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6436909.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6437254.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6437653.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvdispgenco6437849.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvEncMFTH264.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvEncodeAPI64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvfatbinaryLoader.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NvFBC64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvhdagenco64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvhdagenco6420103.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvhdap64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NvIFR64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\NvIFROpenGL.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvoglv64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvopencl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\nvptxJitCompiler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\odbcconf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\offlinelsa.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\offlinesam.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\offreg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ole32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\oleaut32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\OnDemandConnRouteHelper.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\OneBackupHandler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\OneDriveSettingSyncProvider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\OpenCL.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\partizan.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\pcasvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\pdh.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PhoneProviders.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PhoneService.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PhoneServiceRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Phoneutil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PhoneutilRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\pidgenx.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PimIndexMaintenance.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PlayToDevice.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PlayToManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PlayToReceiver.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\pnidui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\policymanager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\poqexec.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\POSyncServices.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\powercfg.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PrintWSDAHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\prm0005.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\profsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\provdatastore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\provengine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\provhandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\provisioningcsp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\provops.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ProvPluginEng.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ProvSysprep.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\provtool.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\PsmServiceExtHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\puiobj.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\pwcreator.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\pwrshplugin.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\qedit.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\qmgr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\R4EEA64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\R4EED64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\R4EEG64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\R4EEL64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\R4EEP64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rasapi32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rascustom.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rasmans.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RCoInstII64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rdpcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rdpcorets.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rdpencom.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rdpinit.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rdpshell.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rdpudd.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RDXService.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RDXTaskFactory.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ReAgent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ReAgentc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RelPost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\remoteaudioendpoint.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RemoteNaturalLanguage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RemovableMediaProvisioningPlugin.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ReportingCSP.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\reseteng.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ResetEngine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ResetEngine.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\resutils.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ReWire.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RjvMDMConfig.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RltkAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RMapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RP3DAA64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RP3DHT64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rpcrt4.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\rshx32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTCOM64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RtDataProc64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTEED64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTEEG64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTEEL64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTEEP64A.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RtkApi64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RtkCfg64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RtkCoLDR64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RtlCPAPI64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTMediaFrame.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RtNicProp64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RtPgEx64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTSnMg64.cpl:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\RTWorkQ.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\samlib.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\samsrv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sbe.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ScDeviceEnum.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\schannel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SEAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\SearchFilterHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SearchFolder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SearchIndexer.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SearchProtocolHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SecConfig.efi:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SECOMN64.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\securekernel.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SEHDHF64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SEHDRA64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sendmail.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Sens.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SensorDataService.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SensorsApi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SensorService.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\services.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SessEnv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SET8ED1.tmp:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SET8FC2.tmp:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SETA251.tmp:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SETA93F.tmp:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_Bluetooth.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_Flights.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_nt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_StorageSense.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingsHandlers_WorkAccess.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingSync.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingSyncCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingSyncHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SettingSyncPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\setupugc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SFAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SFCOM64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SFNHK64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SFSS_APO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SharedStartModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ShareHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\shdocvw.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\shell32.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\shutdownux.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\skci.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sl3apo64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\slc.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\slcext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\slcnt64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\slprp64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sltech64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\smartscreen.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\smphost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SndVolSSO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SpaceAgent.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SpaceControl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\spaceman.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SpeechPal.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\spoolsv.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sppc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sppcext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sppnp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sppobjs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sppsvc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sppwinob.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\spwmp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRAPO64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRCOM.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRCOM64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRH.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRHInproc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRRPTR64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRSHP64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRSTSH64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRSTSX64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SRSWOW64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sspicli.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\stobject.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\StorageUsage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\storagewmi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\storagewmi_passthru.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\StoreAgent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\StorSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\StructuredQuery.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\sud.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SyncCenter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SyncSettings.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SysResetErr.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\systemreset.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SystemSettings.DeviceEncryptionHandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SystemSettings.UserAccountsHandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SystemSettingsAdminFlows.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\SystemSettingsThresholdAdminFlowUI.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tadefxapo.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tadefxapo264.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\taskbarcpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tcpipcfg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tdh.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tepeqapo64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\TextInputFramework.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\themecpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\timedate.cpl:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\TokenBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tosade.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tosasfapo64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\toseaeapo64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tossaeapo64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tossaemaxapo64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\TpmCoreProvisioning.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\TpmTasks.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\tquery.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\TransportDSA.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tsmf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\TSpkg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tspubwmi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\TSWorkspace.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\twinapi.appcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\twinapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\twinui.appcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\twinui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\twinui.pcshell.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tzautoupdate.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\tzres.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ubpm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UIAnimation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UIAutomationCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UIRibbonRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\umpoext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\unimdm.tsp:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\updatehandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\updatepolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\uReFS.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\urlmon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\usbmon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\user32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\usercpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserDataAccessRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserDataLanguageUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserDataPlatformHelperUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserDataTimeUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserDataTypeHelperUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserDeviceRegistration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserDeviceRegistration.Ngc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\usermgr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\UserMgrProxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\usocore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\vbscript.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\VCardParser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\VEStoreEventHandlers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\vmrdvcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\vpncmd.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\vpnike.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\VPNv2CSP.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\vulkaninfo-1-1-0-37-0.exe:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\vulkaninfo.exe:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\w32time.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WavesGUILib64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wbiosrvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wc_storage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WebcamUi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\webio.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\weretw.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wevtapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wevtsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wfdprov.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WiFiConfigSP.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wificonnapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wifinetworkmanager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wifiprofilessettinghandler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wifitask.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\win32k.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\win32kbase.sys:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\win32kfull.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\win32spl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\win32u.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WinBioDataModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WinBioDataModelOOBE.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wincorlib.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.AccountsControl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Background.SystemEventsBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.LockScreen.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Store.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Store.TestingFramework.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.ApplicationModel.Wallet.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Cortana.Desktop.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Data.Pdf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.AllJoyn.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Bluetooth.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.HumanInterfaceDevice.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.LowLevel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Midi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Perception.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Picker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.PointOfService.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Printers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Radios.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Scanners.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Sensors.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.SerialCommunication.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.SmartCards.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.SmartCards.Phone.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.Usb.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.WiFi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Devices.WiFiDirect.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Energy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Gaming.Input.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Gaming.XboxLive.Storage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Globalization.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Graphics.Printing.3D.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Graphics.Printing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Internal.Bluetooth.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Internal.Management.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Internal.UI.Logon.ProxyStub.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Management.Provisioning.ProxyStub.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Audio.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.BackgroundMediaPlayback.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Devices.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Editing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.FaceAnalysis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Import.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.MediaControl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Ocr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Playback.BackgroundMediaPlayer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Playback.MediaPlayer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Protection.PlayReady.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Speech.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Speech.UXRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Media.Streaming.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.BackgroundTransfer.BackgroundManagerPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.BackgroundTransfer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.Connectivity.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.HostName.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.ServiceDiscovery.Dnssd.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Networking.Vpn.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Perception.Stub.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Security.Authentication.Identity.Provider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Security.Authentication.OnlineId.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Security.Authentication.Web.Core.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Shell.Search.UriHandler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.StateRepository.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.StateRepositoryBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.StateRepositoryClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Storage.ApplicationData.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\windows.storage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.System.UserDeviceAssociation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.BioFeedback.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.BlockedShutdown.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Core.TextInput.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Cred.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.CredDialogController.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Immersive.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Input.Inking.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Logon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Search.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Shell.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.InkControls.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.Maps.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.Phone.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Web.Diagnostics.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Web.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Windows.Web.Http.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WindowsCodecs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winhttp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wininet.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wininetlui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winload.efi:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winload.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winlogon.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winmde.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winresume.efi:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winresume.exe:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\WinSCard.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\winsrv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wintrust.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WinTypes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wkssvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlanapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlancfg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlanhlp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WlanMediaManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlanmsm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlansec.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlansvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlansvcpal.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wlidsvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wmp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WMPDMC.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wmpdxm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wmpeffects.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\wmploc.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wmpmde.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wmpps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wmpshell.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WordBreakers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wow64.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WpAXHolder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WpcRefreshTask.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WpcTok.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WpcWebFilter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wpnapps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wpncore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wpninprc.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\wpnprv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wpx.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\ws2_32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wscapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wscinterop.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wscsvc.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\wscui.cpl:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\wsecedit.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WSManHTTPConfig.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WsmSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wsp_fs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wsp_health.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\wsp_sr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wuapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wuauclt.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wuaueng.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wups.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wups2.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wuuhext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WWAHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\WWanAPI.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wwanconn.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wwanmm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wwanprotdim.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\wwansvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\XamlTileRender.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\XblAuthManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\xpsrchvw.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\YamahaAE.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\YamahaAE2.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\zipfldr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\zlib1.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\aadtb.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AboveLockAppHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\aclui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ActionCenterCPL.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ActivationManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\actxprxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AddressParser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\adsmsext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-core-xstate-l2-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-conio-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-convert-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-environment-l1-1-0.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-filesystem-l1-1-0.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-heap-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-locale-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-math-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-multibyte-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-private-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-process-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-runtime-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-stdio-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-string-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-time-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\api-ms-win-crt-utility-l1-1-0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AppCapture.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AppContracts.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AppointmentActivation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AppointmentApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\apprepapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\apprepsync.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AppVEntSubsystems32.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\appwiz.cpl:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AppxPackaging.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\asycfilt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\atmfd.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\atmlib.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AUDIOKSE.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AudioSes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AuthBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AuthExt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\authui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\autoplay.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\BackgroundMediaPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\bcastdvr.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\BcastDVRHelper.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\bcrypt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\BingMaps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\BingOnlineServices.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\biwinrt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\BluetoothApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\cdp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CertEnroll.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Chakra.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Chakradiag.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Chakrathunk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\chartv.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ChatApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ClipboardServer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudBackupSettings.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudExperienceHostCommon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudExperienceHostUser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CloudStorageWizard.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\clusapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\cmifw.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\combase.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\comctl32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\comdlg32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\comsvcs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ConfigureExpandedStorage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ContactActivation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ContactApis.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\container.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CoreMessaging.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CoreUIComponents.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CPFilters.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CredProvDataModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\credprovhost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\credprovs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\credprovslegacy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\crypt32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\cryptngc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\CryptoWinRT.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\cryptui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\C_G18030.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\c_GSM7.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\C_IS2022.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\d2d1.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d10warp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d11.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\D3D12.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d8.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\d3d9.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\D3DCompiler_47.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DataExchange.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\daxexec.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dbgeng.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DbgModel.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ddraw.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\delegatorprovider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\devenum.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\deviceassociation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DeviceFlows.DataModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DevicePairing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dhcpcore6.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dialclient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DisplayManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dlnashext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dmenrollengine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dnsapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DolbyDecMFT.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\drvstore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DscCoreConfProv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dsreg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dtdump.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dwmapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dwmcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\DWrite.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dxgi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dxmasf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\dxtrans.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\eapp3hst.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\eappcfg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\eappgnui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\eapphost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\eappprxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\edgehtml.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\EditBufferTestHook.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\efsext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\efswrt.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\EmailApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\encapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ErrorDetails.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ErrorDetailsUpdate.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\esent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\esentutl.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\evr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\explorer.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ExplorerFrame.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ExSMime.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ExtrasXmlParser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\findnetprinters.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\fontdrvhost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\fontext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\FSClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\GamePanel.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\gameux.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\gdi32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\gdi32full.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\GdiPlus.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Geolocation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\GlobCollationHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\hevcdecoder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\hgcpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ieapfltr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\iedkcs32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ieframe.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\iepeers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ieproxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\iernonce.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\iertutil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\iesetup.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\imapi2.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\indexeddbserver.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\inetcomm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\inetcpl.cpl:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\input.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\InputLocaleManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\InputService.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\InstallAgent.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\InstallAgentUserBroker.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\iscsiwmi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\JpMapControl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\jscript9.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\jscript9diag.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\jsproxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\kerberos.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\KernelBase.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\LaunchWinApp.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\LicenseManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\LicenseManagerApi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\LockAppBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\LockAppHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\LogonController.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MapConfiguration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MapControlCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MapControlStringsRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MapGeocoder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MapRouter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MapsBtSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MbaeApiPublic.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mbsmsapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MCRecvSrc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mdmregistration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfasfsrcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfaudiocnv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfksproxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MFMediaEngine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfmkvsrcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfmp4srcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfmpeg2srcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfnetcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfnetsrc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfplat.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MFPlay.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfpmp.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfreadwrite.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfsensorgroup.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfsrcsnk.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mfsvr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Microsoft-Windows-MapControls.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Microsoft-Windows-MosHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Microsoft-Windows-MosTrace.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\migisol.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MiracastReceiver.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mispace.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mos.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MosHostClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MosResource.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MosStorage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mprapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mprddm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mprdim.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MrmCoreR.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MSAC3ENC.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MSAJApi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msctf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msdtcprx.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msdtcuiu.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msdxm.ocx:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msfeeds.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msftedit.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mshtml.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mshtmled.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msinfo32.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msmpeg2vdec.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mspaint.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mssrch.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mstsc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mstscax.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msv1_0.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MSVidCtl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MSVP9DEC.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msvproc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\MSVPXENC.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msxml6.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\msxml6r.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\mtxclu.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NaturalLanguage6.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NetCfgNotifyObjectHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\netiougc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NetSetupApi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NetSetupEngine.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NetSetupShim.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\netshell.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NetworkCollectionAgent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ngccredprov.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NMAA.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NmaDirect.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NPSM.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nshwfp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ntdll.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ntshrui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvaudcap32v.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvcompiler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvcuda.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvcuvid.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvDecMFTMjpeg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvEncMFTH264.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvEncodeAPI.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvfatbinaryLoader.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NvFBC.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NvIFR.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\NvIFROpenGL.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvoglv32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvopencl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvptxJitCompiler.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\nvStreaming.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\odbcconf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\offlinelsa.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\offlinesam.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\offreg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ole32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\oleacc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\oleaut32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\olepro32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\OneDriveSettingSyncProvider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\opencl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\pdh.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Phoneutil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\PhoneutilRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\pidgenx.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\PlayToDevice.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\PlayToManager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\PlayToReceiver.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\policymanager.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\poqexec.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\POSyncServices.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\powercfg.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\PrintDialogs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\pwrshplugin.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\qdvd.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\rasapi32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\rdpcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\rdpencom.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ReAgent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ReAgentc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\remoteaudioendpoint.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\RemoteNaturalLanguage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\resutils.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ReWire.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\RltkAPO.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\rpcrt4.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\RTMediaFrame.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\RTWorkQ.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\samlib.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\schannel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SearchFolder.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SearchIndexer.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SearchProtocolHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SECOMN32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SEHDHF32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\sendmail.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SessEnv.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSync.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSyncCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSyncHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SettingSyncPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\setupugc.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SFCOM.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ShareHost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\shell32.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\slc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\slcext.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\smphost.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SndVolSSO.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\sppc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\sppcext.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\spwmp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SRCOM.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\sspicli.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\stobject.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\storagewmi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\storagewmi_passthru.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\StoreAgent.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\subinacl.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\sud.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SyncSettings.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\SYNSOEMU.DLL:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\systemcpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\tcpipcfg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\tdh.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\TempSignedLicenseExchangeTask.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\TextInputFramework.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\themecpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\TimeEditkb.ocx:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\TokenBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\TpmCoreProvisioning.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\tquery.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\tsmf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\TSpkg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\twinapi.appcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\twinapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\twinui.appcore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\twinui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\tzres.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UIAnimation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UIAutomationCore.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UIRibbonRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\unimdm.tsp:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\updatepolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\uReFS.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\urlmon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\user32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\usercpl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataAccessRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataAccountApis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataLanguageUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataPlatformHelperUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataTimeUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDataTypeHelperUtil.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDeviceRegistration.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserDeviceRegistration.Ngc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\UserMgrProxy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\vbscript.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\VCardParser.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\vulkaninfo-1-1-0-37-0.exe:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\vulkaninfo.exe:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WebcamUi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\webio.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\weretw.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wevtapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wfdprov.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\win32k.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\win32kfull.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\win32u.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wincorlib.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.AccountsControl.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Background.SystemEventsBroker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Core.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.LockScreen.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.TestingFramework.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Wallet.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.AllJoyn.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Bluetooth.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.HumanInterfaceDevice.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.LowLevel.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Midi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Perception.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Picker.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.PointOfService.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Radios.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Scanners.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Sensors.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.SerialCommunication.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.SmartCards.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.Usb.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.WiFi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Devices.WiFiDirect.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Energy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Gaming.Input.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Gaming.XboxLive.Storage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Globalization.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Graphics.Printing.3D.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Graphics.Printing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Internal.Bluetooth.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Internal.Management.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Internal.UI.Logon.ProxyStub.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Audio.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.BackgroundMediaPlayback.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Editing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.FaceAnalysis.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Import.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Ocr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Playback.BackgroundMediaPlayer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Playback.MediaPlayer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayReady.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Speech.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Speech.UXRes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Media.Streaming.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.BackgroundTransfer.BackgroundManagerPolicy.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.BackgroundTransfer.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.Connectivity.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.HostName.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Networking.ServiceDiscovery.Dnssd.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Perception.Stub.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Security.Authentication.Identity.Provider.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Security.Authentication.OnlineId.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Shell.Search.UriHandler.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.StateRepository.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.StateRepositoryClient.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Storage.ApplicationData.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\windows.storage.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.System.UserDeviceAssociation.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.BioFeedback.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.BlockedShutdown.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Core.TextInput.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Cred.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.CredDialogController.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Input.Inking.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Logon.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Search.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.InkControls.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Maps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Phone.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Resources.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Web.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Windows.Web.Http.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WindowsCodecs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\winhttp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wininet.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wininetlui.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\winmde.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WinRtTracing.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WinSCard.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wintrust.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WinTypes.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wlanapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wlancfg.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wlanhlp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wmp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WMPDMC.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpdxm.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpeffects.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wmploc.DLL:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpmde.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wmpshell.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WordBreakers.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WpcWebFilter.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wpnapps.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\ws2_32.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wscapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wscinterop.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wscui.cpl:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wsecedit.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WSManHTTPConfig.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WsmSvc.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wsp_fs.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wsp_health.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wsp_sr.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\wuapi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WwaApi.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WWAHost.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\WWanAPI.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\xolehlp.dll:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\xpsrchvw.exe:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\zipfldr.dll:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\afd.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\ahcache.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\AppVStrm.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\AvidMbox.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\AvidMbox_DFU.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\bowser.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\capimg.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\Classpnp.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\clfs.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\ClipSp.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\cmimcext.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\cng.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\crashdmp.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\dam.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\DDMFaudio.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\dfsc.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\dtlitescsibus.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\dumpsd.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\dxgkrnl.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\dxgmms1.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\dxgmms2.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\EhStorTcgDrv.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\fastfat.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\file_tracker.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\fvevol.sys:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\FWPKCLNT.SYS:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\hidclass.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\hidparse.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\hidusb.sys:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\http.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\hvservice.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\iaStorA.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\iorate.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\kbdhid.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\ksecdd.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\ksecpkg.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\LGVirHid.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\mbae64.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\MegaSas2i.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\modem.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxdav.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxsmb.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxsmb10.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\mrxsmb20.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\ndis.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\ndisrfl.sys:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\Neo6_x64_VPN.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\nettap630.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\ntfs.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\nvhda64v.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\nvvad64v.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\nvvhci.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\partmgr.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\pci.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\pdc.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\rdbss.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\rt640x64.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\RTKVHD64.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\sdbus.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\SET8839.tmp:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\spaceport.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\srv.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\srv2.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\srvnet.sys:$CmdTcID [130]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\storahci.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\stornvme.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\storport.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tap0901.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tcpip.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\TeeDriverW8x64.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tib.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tib_mounter.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tm.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tnd.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tpm.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\tsvadpcm.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\UAD2Pcie.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\UAD2System.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\UAD2WdmAudio.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\vhdmp.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\virtual_file.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\vpci.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\wcifs.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\WdiWiFi.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\winhvr.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\wof.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\xboxgip.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\system32\Drivers\xinputhid.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Drivers\UnHackMeDrv.sys:$CmdTcID [64]
      AlternateDataStreams: C:\WINDOWS\SysWOW64\Drivers\UpdateHelper.dll:$CmdTcID [64]
      AlternateDataStreams: C:\ProgramData\Microsoft:Gb9iHSAhBg9BV12C3k73XBgHLQz [2384]
      AlternateDataStreams: C:\ProgramData\Microsoft:gVCZtV597Pk0byqtUxyu9ZFc [2548]
      AlternateDataStreams: C:\ProgramData\Microsoft:HkCk6pH2rgF930hJgx9 [2112]
      AlternateDataStreams: C:\ProgramData\Microsoft:pyzvIDdUHQPoJqcsmkYzVeN [2130]
      AlternateDataStreams: C:\ProgramData\Microsoft:w3lVKHfpoNp0LGn1SO56 [2532]
      AlternateDataStreams: C:\ProgramData\Microsoft:ZUQvhkhISSBkTH7rGp [2562]
      AlternateDataStreams: C:\ProgramData\TEMP:07BF512B [152]
      AlternateDataStreams: C:\ProgramData\TEMP:4FC01C57 [136]
      AlternateDataStreams: C:\Users\SamSwanson\Cookies:3rwwZhw2tLiAmOSNHAwYUqSaJU [1858]
      AlternateDataStreams: C:\Users\SamSwanson\Cookies:IZqLckuoBEmSeyWZ9jWWGPoF9 [2068]
      AlternateDataStreams: C:\Users\SamSwanson\Cookies:pZUQi9r51MMNkceOnZGIDucq [2336]
      AlternateDataStreams: C:\Users\SamSwanson\Cookies:suYxzGFC9bvFaXMRmXkqqt [1952]
      AlternateDataStreams: C:\Users\SamSwanson\Cookies:w6io6svORgLdd8KCHJbkN71r [2442]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\Czech taxes for dummies 2015.pdf:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\dokument.pdf:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\Formulář_žádosti__pro_cizince,_neobčany_EU_a_jejich_rodinné_příslušníky-rev.pdf:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\how to licesne musick.pdf:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\Money 4 Music.epub:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\PatchMyPC.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\Potvrzení_o_zajištění_ubytování_FO.DOC:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\RevoicePro.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\Rights-Owner-Repertoire.xlsx:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\SigLotSizeCalV1.2.xls:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\SM-Offshore-Banking-Report.pdf:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\SongMarket.epub:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\uTorrent.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Desktop\uTorrent.exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\3AC2.tmp:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (1).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (1).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (10).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (10).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (2).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (2).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (3).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (3).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (4).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (4).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (5).exe:$CmdTcID [130]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (5).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (6).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (6).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (7).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (7).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (8).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (8).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (9).exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup (9).exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ChromeSetup.exe:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\ec19.tmp:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.15.0.2_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.16.0_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.16.1_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.18.0_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.19.0_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.20.0_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.21.0_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.22.1_win64-setup.exe:$CmdTcID [130]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.22.2.2_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.23.0.2_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.24.0_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\FileZilla_3.24.1_win64-setup.exe:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\tdsskiller.zip:$CmdTcID [64]
      AlternateDataStreams: C:\Users\SamSwanson\Downloads\tdsskiller.zip:$CmdZnID [26]
      AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\bvSO2cjMUSN:nKkdVTct7EMl42YHS3SZExMJ [2388]
      AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX:eek:6d4DS5PFDAk03KTXvn2F2mu [2712]
      AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA:03HrcMG15SDYyUw1Sza8AWAbY [2338]
      AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\Temporary Internet Files:xwH7V3jDNbvYm9CzQAMppM [2254]
      AlternateDataStreams: C:\Users\SamSwanson\Documents\2015 tax return Horton.pdf:$CmdZnID [26]
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\AppXSvc => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\BFE => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\BITS => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ClipSvc => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MpsSvc => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\msiserver => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SharedAccess => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\TweakingRemoveSafeBoot => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vss => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WSService => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AppXSvc => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\BITS => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ClipSvc => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\msiserver => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SamSs => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\srv => ""="Driver"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\srv2 => ""="Driver"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\srvnet => ""="Driver"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\TweakingRemoveSafeBoot => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vss => ""="Service"
      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\WSService => ""="Service"
      HKU\.DEFAULT\Software\Classes\exefile: "%1" %* <===== ATTENTION
      HKU\.DEFAULT\Software\Classes\.exe: exefile => "%1" %* <===== ATTENTION
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Classes\exefile: "%1" %* <===== ATTENTION
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Classes\.exe: exefile => "%1" %* <===== ATTENTION
      2012-07-26 06:26 - 2017-02-20 21:19 - 00000855 ____A C:\WINDOWS\system32\Drivers\etc\hosts
      127.0.0.1       localhost
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Control Panel\Desktop\\Wallpaper -> C:\Users\SamSwanson\AppData\Local\Microsoft\Windows\Themes\RoamedThemeFiles\DesktopBackground\wallpaper_2.jpg
      DNS Servers: 8.8.8.8 - 8.8.4.4
      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System => (ConsentPromptBehaviorAdmin: ) (ConsentPromptBehaviorUser: ) (EnableLUA: 1)
      Windows Firewall is enabled.
      MSCONFIG\Services: WSearch => 2
      HKLM\...\StartupApproved\StartupFolder: => "Snagit 11.lnk"
      HKLM\...\StartupApproved\StartupFolder: => "LoopBe30 Monitor.lnk"
      HKLM\...\StartupApproved\StartupFolder: => "SoftEther VPN Client Manager Startup.lnk"
      HKLM\...\StartupApproved\Run: => "Acronis Scheduler2 Service"
      HKLM\...\StartupApproved\Run: => "AdobeAAMUpdater-1.0"
      HKLM\...\StartupApproved\Run: => "RTHDVCPL"
      HKLM\...\StartupApproved\Run: => "RunDLLEntry"
      HKLM\...\StartupApproved\Run: => "THXCfg64"
      HKLM\...\StartupApproved\Run: => "EvtMgr6"
      HKLM\...\StartupApproved\Run: => "Launch LCore"
      HKLM\...\StartupApproved\Run: => "ShadowPlay"
      HKLM\...\StartupApproved\Run: => "iTunesHelper"
      HKLM\...\StartupApproved\Run: => "ZAM"
      HKLM\...\StartupApproved\Run: => "SoftEther VPN Client UI Helper"
      HKLM\...\StartupApproved\Run32: => "AcronisTibMounterMonitor"
      HKLM\...\StartupApproved\Run32: => "AdobeCS5ServiceManager"
      HKLM\...\StartupApproved\Run32: => "APSDaemon"
      HKLM\...\StartupApproved\Run32: => "UpdReg"
      HKLM\...\StartupApproved\Run32: => "DivXMediaServer"
      HKLM\...\StartupApproved\Run32: => "DivXUpdate"
      HKLM\...\StartupApproved\Run32: => "googletalk"
      HKLM\...\StartupApproved\Run32: => "iTunesHelper"
      HKLM\...\StartupApproved\Run32: => "SunJavaUpdateSched"
      HKLM\...\StartupApproved\Run32: => "QuickTime Task"
      HKLM\...\StartupApproved\Run32: => "SwitchBoard"
      HKLM\...\StartupApproved\Run32: => "Acronis Scheduler2 Service"
      HKLM\...\StartupApproved\Run32: => "SunJavaUpdateSched (2)"
      HKLM\...\StartupApproved\Run32: => "SunJavaUpdateSched (1)"
      HKLM\...\StartupApproved\Run32: => "SunJavaUpdateSched (3)"
      HKLM\...\StartupApproved\Run32: => "Carbonite Backup"
      HKLM\...\StartupApproved\Run32: => "CancelAutoPlay_df"
      HKLM\...\StartupApproved\Run32: => "CheckNDISPortf0ac3e"
      HKLM\...\StartupApproved\Run32: => "ZAM"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\StartupFolder: => "RBTray.exe"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\StartupFolder: => "SpeedFan.lnk"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Gobbler"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "GoogleChromeAutoLaunch_6884A160BCC04722E6F4385CB6FFBBDA"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Google Update"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Skype"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Spotify"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Spotify Web Helper"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "DAEMON Tools Lite"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "GizmoDriveDelegate"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Copy"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Google Update (2)"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Google Update (3)"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Google Update (1)"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Google Update (4)"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "DriverMax"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F8703B"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "OneDrive"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "DAEMON Tools Lite Automount"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "CCleaner Monitoring"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "SpybotPostWindows10UpgradeReInstall"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6381.0405\amd64"
      HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\...\StartupApproved\Run: => "Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64"
      FirewallRules: [vm-monitoring-nb-session] => (Allow) LPort=139
      FirewallRules: [{D8811F55-5587-4E2E-9803-5F89E86BE479}] => (Allow) C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
      FirewallRules: [{E4BE2C83-8EFB-40F4-AA36-DF1B6E02FC63}] => (Allow) C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
      FirewallRules: [{7E50ECC5-ADEE-41F4-B456-DD8184B7B9D7}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
      FirewallRules: [{06E10D22-128D-4D9C-81AE-CFCC8F5C0D78}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
      FirewallRules: [{800BE274-31F7-4485-93FA-49D22449C363}] => (Allow) S:\SteamGameLibrary\SteamApps\common\Day of Defeat Source\hl2.exe
      FirewallRules: [{B6A68273-9DDE-4550-BF33-23B26844ED8A}] => (Allow) S:\SteamGameLibrary\SteamApps\common\Day of Defeat Source\hl2.exe
      FirewallRules: [{E5A8B4EF-E0C3-46C4-8655-F4667B7C0FC3}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe
      FirewallRules: [{AF19923E-DFBF-44CE-8E35-C061282BF825}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
      FirewallRules: [UDP Query User{F5776BFC-9EE0-43A2-B705-766521F94B2D}C:\program files\litecoin\litecoin-qt.exe] => (Allow) C:\program files\litecoin\litecoin-qt.exe
      FirewallRules: [TCP Query User{A17EFB4D-9DC9-470C-8B1B-BC335E7CA9B8}C:\program files\litecoin\litecoin-qt.exe] => (Allow) C:\program files\litecoin\litecoin-qt.exe
      FirewallRules: [UDP Query User{FEB8E9ED-9B27-4C04-AE59-C6FB21E4CFEE}C:\program files\reaper (x64)\reaper.exe] => (Allow) C:\program files\reaper (x64)\reaper.exe
      FirewallRules: [TCP Query User{4FC0708F-E22A-46A0-B3A1-8BAF833E3603}C:\program files\reaper (x64)\reaper.exe] => (Allow) C:\program files\reaper (x64)\reaper.exe
      FirewallRules: [UDP Query User{82951DBB-1382-405F-B496-B2CB552D2CC9}C:\users\samswanson\appdata\roaming\spotify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotify.exe
      FirewallRules: [TCP Query User{F2B9FCED-0F9D-49E0-9B96-B20FC514B119}C:\users\samswanson\appdata\roaming\spotify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotify.exe
      FirewallRules: [UDP Query User{32E5E5FF-AE09-40CA-9019-D3486EEBABF5}C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe] => (Block) C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe
      FirewallRules: [TCP Query User{43AFE483-1F63-4C55-8462-69C60BC018BA}C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe] => (Block) C:\program files (x86)\nero\nero 12\nero backitup\backitup.exe
      FirewallRules: [{EB46C128-ED00-4C3F-8F84-47470F58C813}] => (Block) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_x64.exe
      FirewallRules: [{69B1232F-5701-454C-ADFE-08E54D6B0920}] => (Block) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_x64.exe
      FirewallRules: [UDP Query User{1AB4FC87-2B0D-472E-A3E6-61C2B6C070FA}C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_x64.exe] => (Allow) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_x64.exe
      FirewallRules: [TCP Query User{EB0FECB5-C9BD-488B-99F8-68E3EE0359D9}C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_x64.exe] => (Allow) C:\program files\nyrvsystems\pluginscanner\nyrvpluginscanner_x64.exe
      FirewallRules: [UDP Query User{2AFF58C6-0DEA-4814-BFFB-9396E88BD493}C:\program files\reaper (x64)\plugins\reaper_host64.exe] => (Block) C:\program files\reaper (x64)\plugins\reaper_host64.exe
      FirewallRules: [TCP Query User{78335E54-289F-41C9-A7FB-1EEC0AC1D749}C:\program files\reaper (x64)\plugins\reaper_host64.exe] => (Block) C:\program files\reaper (x64)\plugins\reaper_host64.exe
      FirewallRules: [{7AF1A041-07C9-4959-8274-77EE03809209}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dropbox.exe
      FirewallRules: [{6986C6E8-5AE1-4AF7-9F1B-8E4880BEF5F9}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dropbox.exe
      FirewallRules: [{9A87E20F-0224-40A4-A0A6-CF2D427F4D20}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dropbox.exe
      FirewallRules: [{BA177546-4044-4C07-AFE8-69887582567D}] => (Allow) C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dropbox.exe
      FirewallRules: [UDP Query User{0BFC59AF-9A77-433F-9D79-6A42BC3B990E}C:\program files (x86)\idolumic\tunesmith\tunesmith.exe] => (Block) C:\program files (x86)\idolumic\tunesmith\tunesmith.exe
      FirewallRules: [TCP Query User{A3ECAB14-43DA-4877-B411-E11F65833A70}C:\program files (x86)\idolumic\tunesmith\tunesmith.exe] => (Block) C:\program files (x86)\idolumic\tunesmith\tunesmith.exe
      FirewallRules: [{9F08C694-EC8D-4028-B569-CC536012E7BB}] => (Allow) C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe
      FirewallRules: [{B184610F-D175-44C7-B31A-4C9CF612667C}] => (Allow) C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe
      FirewallRules: [{85F3ACDA-06E5-4E75-BBB3-E4993FCACAEA}] => (Allow) LPort=1688
      FirewallRules: [{FE438153-8F8D-492D-A2FB-B9DC4D356A58}] => (Allow) LPort=1688
      FirewallRules: [{4810449D-6142-46CE-90E8-E59770BFC440}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
      FirewallRules: [{CA27EC5C-5D60-4DE9-A224-7B39FC82845B}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
      FirewallRules: [{50841857-DD2A-46AC-8627-9A7BE07699D7}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
      FirewallRules: [{4EF546A8-7388-4B39-8C68-16D263B1252B}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
      FirewallRules: [{901F754B-7F53-41C0-A07B-A4D8D0DFE036}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
      FirewallRules: [{FF7228E9-9CA7-41CD-A723-2F149E256AC0}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
      FirewallRules: [{6FA2A9E8-A72E-42CF-A794-B18CC107DEA1}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
      FirewallRules: [{F71782BC-163B-4084-BA5E-9BE299F8C6C3}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
      FirewallRules: [{159A065B-2BA1-4A71-8EE1-BAAEA61F9001}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
      FirewallRules: [{FE35395F-4673-4FC1-85FB-576D178B0B1D}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Google Talk Plugin\googletalkplugin.exe
      FirewallRules: [UDP Query User{1579E7CF-1850-48C3-886A-632A8EC41CB6}C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe
      FirewallRules: [TCP Query User{7DCC07A6-5616-48B2-AC59-2C37A069E637}C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\call of duty modern warfare 3\iw5mp.exe
      FirewallRules: [UDP Query User{AB2EA62A-A8E9-4766-83D1-08DEFBBBBB76}C:\users\samswanson\appdata\roaming\spotify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotify.exe
      FirewallRules: [TCP Query User{4E60A726-4483-4E32-9B1C-85B9E69C232F}C:\users\samswanson\appdata\roaming\spotify\spotify.exe] => (Allow) C:\users\samswanson\appdata\roaming\spotify\spotify.exe
      FirewallRules: [{5EE2E0AD-9DAB-4F6D-8D38-0A41D29BF39E}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
      FirewallRules: [{AE76EA5F-CF6E-4FDC-BF69-7187C5A8CD22}] => (Allow) C:\Program Files\Microsoft Office\Office15\UcMapi.exe
      FirewallRules: [{D524EB94-7130-4A51-9936-58807A7CCC32}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
      FirewallRules: [{DC004AA2-EAB9-45C4-8636-FBF333884C16}] => (Allow) C:\Program Files\Microsoft Office\Office15\lync.exe
      FirewallRules: [{264C0F87-944D-4B28-B875-008CE407DCEC}] => (Allow) C:\Program Files (x86)\gnucash\bin\gconfd-2.exe
      FirewallRules: [{BEEFD323-7E07-406B-B349-2515E304A47A}] => (Allow) C:\Program Files (x86)\gnucash\bin\gconfd-2.exe
      FirewallRules: [{4C7D8CF3-F3E2-46AD-8B64-D3064C44978B}] => (Allow) C:\Program Files (x86)\gnucash\bin\gnucash.exe
      FirewallRules: [{B73A089E-647C-40E4-BC4B-061EE4354A35}] => (Allow) C:\Program Files (x86)\gnucash\bin\gnucash.exe
      FirewallRules: [{159B9D62-A976-4BF7-8EBB-1E2082C0DA3B}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\MxUp.exe
      FirewallRules: [{394FFBE6-FF1C-4139-B2B4-B00E21956F4E}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe
      FirewallRules: [{57DFEDDE-D220-4A8D-85E3-2EDBBBE665B2}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\MxUp.exe
      FirewallRules: [{09BB3EE1-42E8-4B70-B9FB-ECEE43D6E6E7}] => (Allow) C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe
      FirewallRules: [UDP Query User{8B077964-B2EF-4647-B909-569A0E35D127}C:\program files (x86)\utorrent\utorrent.exe] => (Block) C:\program files (x86)\utorrent\utorrent.exe
      FirewallRules: [TCP Query User{BA5E5EF7-5ADA-4398-A746-A25FDEA7334A}C:\program files (x86)\utorrent\utorrent.exe] => (Block) C:\program files (x86)\utorrent\utorrent.exe
      FirewallRules: [{39D9F0E3-EEF9-4650-94DB-AD618B47C70A}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\call of duty modern warfare 3\iw5mp.exe
      FirewallRules: [{D3A12194-DFB4-41DE-BAFE-163B728B7C2E}] => (Allow) C:\Program Files (x86)\Steam\SteamApps\common\call of duty modern warfare 3\iw5mp.exe
      FirewallRules: [UDP Query User{C489928B-BCB6-4CAD-B115-8637D6D5F1E2}C:\program files\reaper (x64)\reaper.exe] => (Block) C:\program files\reaper (x64)\reaper.exe
      FirewallRules: [TCP Query User{873D8F9D-EA4F-4D25-9643-79E633CB1825}C:\program files\reaper (x64)\reaper.exe] => (Block) C:\program files\reaper (x64)\reaper.exe
      FirewallRules: [{3AE70BBF-4187-408E-8552-8C40592320B4}] => (Allow) C:\Program Files (x86)\Nero\KM\KwikMedia.exe
      FirewallRules: [{23AC632F-EAB7-4D82-91A0-AF1745451F95}] => (Allow) C:\Program Files (x86)\Nero\KM\KwikMedia.exe
      FirewallRules: [UDP Query User{34448265-8649-4C33-AC9D-CE6B4BDE66C0}C:\program files (x86)\ditto\ditto.exe] => (Allow) C:\program files (x86)\ditto\ditto.exe
      FirewallRules: [TCP Query User{CC138988-1294-4E93-B9F7-B5EEEAF4385B}C:\program files (x86)\ditto\ditto.exe] => (Allow) C:\program files (x86)\ditto\ditto.exe
      FirewallRules: [{347A2896-44B0-4781-8639-F8E6DADBAF9B}] => (Block) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
      FirewallRules: [{043836B9-CABB-4DE7-BB6F-4C6561C5B4AF}] => (Block) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
      FirewallRules: [UDP Query User{A7D9C2DC-CB32-4544-A540-3CE567BB1891}C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe] => (Allow) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
      FirewallRules: [TCP Query User{C17FD2D4-D884-4DF0-BFC2-BA96D1E34ACC}C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe] => (Allow) C:\program files (x86)\media gobbler, inc\gobbler\gobbler.exe
      FirewallRules: [{FC9A52D6-E8D3-43D5-9EE5-A4CC0A72E7E1}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
      FirewallRules: [{5D44DDEE-E403-49B8-971A-46814BF7814C}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
      FirewallRules: [{65942B4D-AAD7-4320-BDFC-7B54A64A2DF8}] => (Allow) C:\Program Files (x86)\Intel\Extreme Tuning Utility\Client\PerfTune.exe
      FirewallRules: [{10EA7950-8535-46F1-BD21-00FA3E46A57C}] => (Allow) C:\Program Files (x86)\Skype\Phone\Skype.exe
      FirewallRules: [{2A95E67F-00BA-4C7F-982F-21737687F7C2}] => (Allow) C:\Program Files (x86)\Google\Google Talk\googletalk.exe
      FirewallRules: [{D349A76B-9E0E-4A55-BD62-98E51D8FC3FF}] => (Allow) C:\Program Files (x86)\Google\Google Talk\googletalk.exe
      FirewallRules: [TCP Query User{0F05B259-9FEA-40DD-A9E3-70A1E7D792A8}C:\program files (x86)\avid\pro tools\protools.exe] => (Allow) C:\program files (x86)\avid\pro tools\protools.exe
      FirewallRules: [UDP Query User{63BE29B2-A2E7-4578-97CC-D0DCBF7639AE}C:\program files (x86)\avid\pro tools\protools.exe] => (Allow) C:\program files (x86)\avid\pro tools\protools.exe
      FirewallRules: [TCP Query User{FD47186C-FB63-42B6-8252-1BA2D3D031C6}C:\users\samswanson\appdata\local\ivideon\ivideonserver\ivideonserver.exe] => (Allow) C:\users\samswanson\appdata\local\ivideon\ivideonserver\ivideonserver.exe
      FirewallRules: [UDP Query User{B6461154-8899-4C23-922A-8B13A7389751}C:\users\samswanson\appdata\local\ivideon\ivideonserver\ivideonserver.exe] => (Allow) C:\users\samswanson\appdata\local\ivideon\ivideonserver\ivideonserver.exe
      FirewallRules: [{33659DC1-1F98-439A-AEC3-57776D741690}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
      FirewallRules: [{4DCCEBA1-C481-409A-B6A3-9978F0C403D4}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
      FirewallRules: [{FE6ED81B-B560-40F0-8975-770BE8C4B4C5}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe
      FirewallRules: [{DE906F04-5348-4E10-8278-2FA61E95B0B3}] => (Allow) C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe
      FirewallRules: [TCP Query User{C20C177B-0E29-469B-A6DA-2CF7B87D207D}C:\program files\webroot\wrsa.exe] => (Allow) C:\program files\webroot\wrsa.exe
      FirewallRules: [UDP Query User{A3922E75-DF5F-4382-9192-D3989C5686AE}C:\program files\webroot\wrsa.exe] => (Allow) C:\program files\webroot\wrsa.exe
      FirewallRules: [TCP Query User{E2572DE2-18A4-4838-BF78-D416F7A58F87}C:\users\samswanson\appdata\local\google\chrome sxs\application\chrome.exe] => (Allow) C:\users\samswanson\appdata\local\google\chrome sxs\application\chrome.exe
      FirewallRules: [UDP Query User{4C7F8891-A519-4288-A555-D6B644C983F9}C:\users\samswanson\appdata\local\google\chrome sxs\application\chrome.exe] => (Allow) C:\users\samswanson\appdata\local\google\chrome sxs\application\chrome.exe
      FirewallRules: [{8164E955-4659-4A72-8510-667E48F5CBCF}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
      FirewallRules: [{193307C5-27EA-4047-8D49-62699F1ABCA8}] => (Allow) C:\Program Files\NVIDIA Corporation\NvContainer\NvContainer.exe
      FirewallRules: [{23D75EBE-3F14-4B79-8CAD-EB12D7FA7A23}] => (Allow) C:\Program Files\NVIDIA Corporation\NvContainer\NvContainer.exe
      FirewallRules: [{F9C2D2D0-2A16-4751-8866-990FE9C3C851}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
      FirewallRules: [{16F6121E-B315-462F-9B0C-4753ECD149D7}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
      FirewallRules: [{C5E08516-C1BC-4B12-BB6E-45A9CE248B88}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
      FirewallRules: [{DE03B6B4-FD06-45C6-991C-EB99785E619A}] => (Allow) C:\Program Files\iTunes\iTunes.exe
      FirewallRules: [{2D32070B-BE19-469C-9749-20AF2E943B77}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer.exe
      FirewallRules: [{B2868D72-9C1F-442F-829F-7E3CC250B9D1}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer.exe
      FirewallRules: [{8E7B85F4-59CC-4743-ABDC-113EF0515C1A}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
      FirewallRules: [{80A0797C-B514-4C9D-9AD0-4030E922803D}] => (Allow) C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
      FirewallRules: [{151CDCEB-5350-4E0B-B3DF-5D1AFD444318}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
      FirewallRules: [{2FC9AC5D-2002-4226-851A-C906786981FE}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
      FirewallRules: [{CBF94C9D-E30C-4E5E-90C8-84E3E08CAE9B}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
      FirewallRules: [{447E0C97-2CD8-4303-8588-9CEE3774093C}] => (Allow) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe
      FirewallRules: [{E8226ED0-F618-4BFF-9414-9DE5D234B0E5}] => (Allow) C:\Program Files\MetaTrader 5\metatester64.exe
      FirewallRules: [{4FC8502B-C59D-4A3E-835A-1D56C834280C}] => (Allow) C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe
      FirewallRules: [{266AE150-5BAC-41F2-B9C7-3AEFEF2BD695}] => (Allow) C:\Program Files\SoftEther VPN Client\vpnclient.exe
      FirewallRules: [{A83100B2-AC65-4E83-BCA3-B70ACBD1F190}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmgr.exe
      FirewallRules: [{A6644206-9A35-4A7E-A8AF-0759C35D655D}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe
      FirewallRules: [{97AC4EC6-F9A0-4962-A2AB-EDA3242B18EE}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmd.exe
      FirewallRules: [{6AECC060-1F3B-47E6-8945-52A9F9577BC3}] => (Allow) C:\Program Files\SoftEther VPN Client\vpncmd_x64.exe
      FirewallRules: [{5726AA47-031F-426F-B0F5-64624B7C1215}] => (Allow) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe
      StandardProfile\AuthorizedApplications: [C:\Program Files (x86)\FlashGet Network\FlashGet 3\FlashGet3.exe] => Enabled:Flashget3
      28-02-2017 11:49:12 UnHackMe Malware Removal
      01-03-2017 11:44:51 JRT Pre-Junkware Removal
      01-03-2017 19:58:49 JRT Pre-Junkware Removal
      Name:
      Description:
      Class Guid:
      Manufacturer:
      Service:
      Problem: : The drivers for this device are not installed. (Code 28)
      Resolution: To install the drivers for this device, click "Update Driver", which starts the Hardware Update wizard.
      Name: Primo Ramdisk Controller
      Description: Primo Ramdisk Controller
      Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
      Manufacturer: ROMEX SOFTWARE
      Service: FancyRd
      Problem: : This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
      Resolution: Update the driver
      Application errors:
      Error: (03/01/2017 08:26:52 PM) (Source: ISCTAgent) (EventID: 1000) (User: )
      Description: CISCTPnpDriverApi::CreateInstance   *****Unable to open the ISCT device driver
      Error: (03/01/2017 08:26:51 PM) (Source: Windows Search Service) (EventID: 10021) (User: )
      Description: Could not get performance counter registry info for WSearchIdxPi for instance   due to the following error: The operation completed successfully.   0x0.
      Error: (03/01/2017 08:26:50 PM) (Source: Windows Search Service) (EventID: 3007) (User: )
      Description: Performance monitoring cannot be initialized for the gatherer object, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
      Context:  Application, SystemIndex Catalog
      Error: (03/01/2017 08:26:50 PM) (Source: Windows Search Service) (EventID: 3006) (User: )
      Description: Performance monitoring cannot be initialized for the gatherer service, because the counters are not loaded or the shared memory object cannot be opened. This only affects availability of the perfmon counters. Restart the computer.
      Error: (03/01/2017 08:02:05 PM) (Source: Perflib) (EventID: 1008) (User: )
      Description: The Open Procedure for service "rdyboost" in DLL "C:\WINDOWS\system32\sysmain.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
      Error: (03/01/2017 08:02:04 PM) (Source: Perflib) (EventID: 1008) (User: )
      Description: The Open Procedure for service ".NETFramework" in DLL "C:\WINDOWS\system32\mscoree.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
      Error: (03/01/2017 07:58:50 PM) (Source: Microsoft-Windows-CAPI2) (EventID: 513) (User: )
      Description: Cryptographic Services failed while processing the OnIdentity() call in the System Writer Object.
      Details:
      AddLegacyDriverFiles: Unable to back up image of binary Microsoft Link-Layer Discovery Protocol.
      System Error:
      Access is denied.
      Error: (03/01/2017 07:41:02 PM) (Source: SecurityCenter) (EventID: 16) (User: )
      Description: Error while updating Windows Defender status to SECURITY_PRODUCT_STATE_ON (error %3).
      Error: (03/01/2017 07:37:57 PM) (Source: ISCTAgent) (EventID: 1000) (User: )
      System errors:
      Error: (03/01/2017 08:28:54 PM) (Source: DCOM) (EventID: 10010) (User: JIRICOMPUTER)
      Description: The server {21F282D1-A881-49E1-9A3A-26E44E39B86C} did not register with DCOM within the required timeout.
      Error: (03/01/2017 08:26:49 PM) (Source: Service Control Manager) (EventID: 7023) (User: )
      Description: The HvHost service terminated with the following error:
      A device attached to the system is not functioning.
      Error: (03/01/2017 08:26:49 PM) (Source: Service Control Manager) (EventID: 7024) (User: )
      Description: The HomeGroupListener service terminated with the following service-specific error:
      %%2147944153 = There are no more endpoints available from the endpoint mapper.
      Error: (03/01/2017 08:26:49 PM) (Source: NETLOGON) (EventID: 3095) (User: )
      Description: This computer is configured as a member of a workgroup, not as
      a member of a domain. The Netlogon service does not need to run in this
      configuration.
      Error: (03/01/2017 08:26:38 PM) (Source: volmgr) (EventID: 46) (User: )
      Description: Crash dump initialization failed!
      Error: (03/01/2017 08:26:37 PM) (Source: FancyRd) (EventID: 2) (User: )
      Description: The evaluation period for this installation of Primo Ramdisk has expired.
      Error: (03/01/2017 08:26:01 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
       and APPID
       to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
      Error: (03/01/2017 07:58:59 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
      Description: The NVIDIA LocalSystem Container service terminated unexpectedly.  It has done this 1 time(s).  The following corrective action will be taken in 1000 milliseconds: Restart the service.
      Error: (03/01/2017 07:40:27 PM) (Source: DCOM) (EventID: 10010) (User: JIRICOMPUTER)
      Error: (03/01/2017 07:37:54 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
      Description: The WinDefend service failed to start due to the following error:
      Windows cannot verify the digital signature for this file. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
      CodeIntegrity:
        Date: 2017-03-01 20:29:01.068
        Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume4\Windows\System32\guard64.dll because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
        Date: 2017-03-01 20:26:52.505
        Date: 2017-03-01 20:26:49.625
        Date: 2017-03-01 19:58:31.418
        Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume4\Windows\System32\nvspcap64.dll that did not meet the Store signing level requirements.
        Date: 2017-03-01 19:42:17.609
        Date: 2017-03-01 19:42:04.491
        Date: 2017-03-01 19:40:59.064
        Date: 2017-03-01 19:40:58.942
        Date: 2017-03-01 19:37:54.540
        Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume4\Program Files\Windows Defender\MsMpEng.exe because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
        Date: 2017-03-01 17:57:44.390
      Processor: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
      Percentage of memory in use: 13%
      Total physical RAM: 32716.45 MB
      Available physical RAM: 28442.09 MB
      Total Virtual: 32716.45 MB
      Available Virtual: 28142.92 MB
      Drive c: () (Fixed) (Total:238.13 GB) (Free:115.12 GB) NTFS
      Drive r: (Redundant) (Fixed) (Total:2794.39 GB) (Free:1153.93 GB) NTFS
      Drive s: (Major Scott) (Fixed) (Total:2794.39 GB) (Free:1562.58 GB) NTFS
      Disk: 0 (MBR Code: Windows 7 or 8) (Size: 2794.5 GB) (Disk ID: 3DE8DBCF)
      Partition: GPT.
      Disk: 1 (MBR Code: Windows 7 or 8) (Size: 238.5 GB) (Disk ID: BCDE926D)
      Partition 1: (Active) - (Size=350 MB) - (Type=07 NTFS)
      Partition 2: (Not Active) - (Size=238.1 GB) - (Type=07 NTFS)
      Disk: 2 (MBR Code: Windows 7 or 8) (Size: 2794.5 GB) (Disk ID: 1CD3CAE0)
      Partition: GPT.
      • Malnutrition
        PCHF Moderator
        • 7041
        FRST Fix.
        Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
        ClearLNK
        Download ClearLNK save it to your desktop.
        Drag the file Shortcut.txt made with FRST earlier.
        As per picture.
        A report on the work as a file ClearLNK- .log
        Will be produced, post that log.
        https://pchelpforum.net/proxy.php?image=https%3A%2F%2Fup2sha.re%2Fuploads% 2F2015%2F3%2FBPD7B3BAgEQl.gif&hash=f65630ba2178027 f4643224f28999e44
        Rogue Killer Scan.
        Download RogueKiller – (Portable) – from one of the following links and save it to your Desktop:
        Link 1
        Link 2
        [li]Close all other the running programs[/li][li]Disable ALL Antivirus – Antimalware – Applications.[/li][li]Right Click Rogue Killer and Run as Administrator.[/li][li]Click the Start Scan button.[/li][li]Allow the scan to run – it can take ten minutes or more.[/li][li]Once the scan is complete check All items for removal.[/li][li]https://pchelpforum.net/attachments/...5-54-png.1658/ [/li]
        [li]After All items are checked then press Remove Selected.[/li]
        [li]Wait until the Status box shows Deleting Finished.[/li][li]Click on open report – then open txt[/li]
        [li]Copy the content of the report and paste it here in your next reply.[/li][/ul]
        • slonslon7
          • Mar 2017
          • 14
          FRST fix:
          Fix result of Farbar Recovery Scan Tool (x64) Version: 01-03-2017
          Ran by SamSwanson (01-03-2017 21:41:38) Run:1
          Running from C:\Users\SamSwanson\Desktop\Computer fix
          Loaded Profiles: SamSwanson (Available Profiles: SamSwanson)
          Boot Mode: Normal
          fixlist content:
          Start
          CreateRestorePoint:
          Closeprocesses:
          Emptytemp:
          HKLM-x32...\Run: [SunJavaUpdateSched (1)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
          HKLM-x32...\Run: [SunJavaUpdateSched (2)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
          HKLM-x32...\Run: [SunJavaUpdateSched (3)] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
          HKLM-x32...\Run: [DivXMediaServer] => C:\Program Files (x86)\DivX\DivX Media Server\DivXMediaServer.exe [448856 2014-12-28] (DivX, LLC)
          HKLM-x32...\Run: [DivXUpdate] => C:\Program Files (x86)\DivX\DivX Update\DivXUpdate.exe [1861968 2014-12-28] ()
          HKLM-x32...\Run: [SunJavaUpdateSched] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2017-02-10] (Oracle Corporation)
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (1)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (2)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (3)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update (4)] => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [144200 2015-08-31] (Google Inc.)
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\Run: [Google Update] => C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\GoogleUpdateCore.exe [601752 2016-12-17] (Google Inc.)
          ShellIconOverlayIdentifiers: [00avast] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
          GroupPolicy: Restriction <======= ATTENTION
          GroupPolicyScripts: Restriction <======= ATTENTION
          Tcpip\Parameters: [DhcpNameServer] 213.46.172.36 213.46.172.37
          Tcpip..\Interfaces{2173f261-2e23-4f0a-940a-2a88ca2b214b}: [NameServer] 74.82.42.42,192.168.0.1
          Tcpip..\Interfaces{2173f261-2e23-4f0a-940a-2a88ca2b214b}: [DhcpNameServer] 213.46.172.36 213.46.172.37
          Tcpip..\Interfaces{7faf953a-453a-4de6-a3bc-2ce40997f6cc}: [NameServer] 8.8.8.8,8.8.4.4
          Tcpip..\Interfaces{7faf953a-453a-4de6-a3bc-2ce40997f6cc}: [DhcpNameServer] 213.46.172.36 213.46.172.37
          Tcpip..\Interfaces{a56f0fe6-a65d-419a-9a9d-a9f8c86c22bd}: [DhcpNameServer] 192.168.0.1 192.168.0.1
          Tcpip..\Interfaces{c09f412c-6a39-48fa-9e06-9f815d6e9d25}: [NameServer] 8.8.8.8,8.8.4.4
          HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
          HKU.DEFAULT\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Policies\Microsoft\Internet Explorer: Restriction <======= ATTENTION
          HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
          HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
          HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=msnhome
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
          BHO: Skype for Business Browser Helper → {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} → C:\Program Files\Microsoft Office\Office15\OCHelper.dll [2016-05-27] (Microsoft Corporation)
          BHO: Java™ Plug-In SSV Helper → {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} → C:\Program Files\Java\jre1.8.0_121\bin\ssv.dll [2017-02-20] (Oracle Corporation)
          BHO: Webroot Filtering Extension → {C9C42510-9B41-42c1-9DCD-7282A2D07C61} → C:\Program Files\Common Files\Webroot\WebFiltering\wrflt.dll [2017-01-27] (Webroot)
          BHO: Microsoft SkyDrive Pro Browser Helper → {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} → C:\Program Files\Microsoft Office\Office15\GROOVEEX.DLL [2016-05-17] (Microsoft Corporation)
          BHO: Java™ Plug-In 2 SSV Helper → {DBC80044-A445-435b-BC74-9C25C1C588A9} → C:\Program Files\Java\jre1.8.0_121\bin\jp2ssv.dll [2017-02-20] (Oracle Corporation)
          BHO-x32: Skype for Business Browser Helper → {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} → C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll [2016-05-27] (Microsoft Corporation)
          BHO-x32: Webroot Filtering Extension → {C9C42510-9B41-42c1-9DCD-7282A2D07C61} → C:\Program Files (x86)\Common Files\Webroot\WebFiltering\wrflt.dll [2017-01-27] (Webroot)
          BHO-x32: Microsoft SkyDrive Pro Browser Helper → {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} → C:\Program Files (x86)\Microsoft Office\Office15\GROOVEEX.DLL [2016-05-17] (Microsoft Corporation)
          Handler: osf - {D924BDC6-C83A-4BD5-90D0-095128A113D1} - C:\Program Files\Microsoft Office\Office15\MSOSB.DLL [2016-05-17] (Microsoft Corporation)
          Handler-x32: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files (x86)\Common Files\Skype\Skype4COM.dll [2017-01-01] (Skype Technologies)
          FF NewTab: Mozilla\Firefox\Profiles\lncyg2i6.default → about:newtab
          FF Homepage: Mozilla\Firefox\Profiles\lncyg2i6.default → about:blank
          FF SearchPlugin: C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefo x\Profiles\lncyg2i6.default\searchplugins\google-avast.xml [2015-01-06]
          FF HKLM-x32...\Firefox\Extensions: [ffpwdman@bitdefender.com] - C:\Program Files\Bitdefender\Bitdefender\Antispam32\ffpwdman => not found
          FF Plugin-x32: @tools.google.com/Google Update;version=3 → C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
          FF Plugin-x32: @tools.google.com/Google Update;version=9 → C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
          FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @tools.google.com/Google Update;version=3 → C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
          FF Plugin HKU\S-1-5-21-3236326594-2611474830-2656184370-1001: @tools.google.com/Google Update;version=9 → C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\npGoogleUpdate3.dll [2016-12-17] (Google Inc.)
          CHR HKLM-x32...\Chrome\Extension: [kjeghcllfecehndceplomkocgfbklffd] - hxxps://clients2.google.com/service/update2/crx
          S3 FreshIO; ??\C:\Program Files (x86)\FreshDevices\FreshDiagnose\FreshIO.sys
          S3 ManyCam; \SystemRoot\system32\DRIVERS\mcvidrv.sys
          S3 mcaudrv_simple; \SystemRoot\system32\drivers\mcaudrv_x64.sys
          U0 SR; no ImagePath
          U2 srservice; no ImagePath
          2017-02-24 18:27 - 2017-03-01 19:33 - 00002668 _____ C:\WINDOWS\System32\Tasks\UnHackMe Task Scheduler
          2017-02-21 15:52 - 2017-02-21 16:01 - 00000000 ____D C:\ProgramData\Emsisoft
          2017-02-21 14:39 - 2017-02-21 14:47 - 00000000 ____D C:\Program Files\stinger
          2017-02-21 14:39 - 2017-02-21 14:39 - 00000000 ____D C:\Program Files\McAfee
          2017-02-13 16:16 - 2017-02-13 16:16 - 00000000 ____D C:\WINDOWS\System32\Tasks\Safer-Networking
          2017-02-13 14:56 - 2017-02-13 16:16 - 00000000 ____D C:\ProgramData\Spybot - Search & Destroy
          2017-02-13 00:03 - 2017-02-13 00:03 - 00000000 ____D C:\ProgramData\Sophos
          2017-02-13 00:00 - 2017-02-13 00:00 - 04656523 _____ C:\Users\SamSwanson\Downloads\tdsskiller.zip
          2017-02-13 00:00 - 2017-02-13 00:00 - 00208216 _____ (Kaspersky Lab, GERT) C:\WINDOWS\system32\Drivers\55447846.sys
          2017-02-10 20:02 - 2017-02-10 20:02 - 00000000 ____D C:\Users\SamSwanson\AppData\Local\Chromium
          2017-03-01 20:02 - 2013-07-28 08:17 - 00000000 ____D C:\WINDOWS\system32\MRT
          2017-03-01 19:37 - 2017-01-12 17:52 - 00000830 _____ C:\WINDOWS\Tasks\Adobe Flash Player Updater.job
          2017-03-01 19:37 - 2016-12-03 22:13 - 00000892 _____ C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job
          2017-03-01 19:37 - 2012-12-23 12:23 - 00000954 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA.job
          2017-03-01 19:37 - 2012-12-23 12:23 - 00000902 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core.job
          2017-03-01 19:33 - 2017-01-12 17:52 - 00003104 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
          2017-03-01 19:33 - 2016-12-26 18:15 - 00002610 _____ C:\WINDOWS\System32\Tasks{EE492B24-CD47-404D-95D3-605112E375FA}
          2017-03-01 19:33 - 2016-12-03 22:13 - 00003410 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player PPAPI Notifier
          2017-03-01 19:33 - 2016-08-15 15:00 - 00002894 _____ C:\WINDOWS\System32\Tasks\Patch My PC
          2017-03-01 19:33 - 2016-08-11 19:50 - 00003622 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a
          2017-03-01 19:33 - 2016-08-11 19:50 - 00003552 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA
          2017-03-01 19:33 - 2016-08-11 19:50 - 00003404 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A
          2017-03-01 19:33 - 2016-08-11 19:50 - 00003354 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085
          2017-03-01 19:33 - 2016-08-11 19:50 - 00003280 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core
          2017-03-01 19:33 - 2016-08-11 19:50 - 00003180 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore
          2017-03-01 19:33 - 2016-08-11 19:50 - 00002920 _____ C:\WINDOWS\System32\Tasks\20160623_163758_Restore 12 0
          2017-03-01 19:33 - 2016-08-11 19:50 - 00002920 _____ C:\WINDOWS\System32\Tasks\20160618_170750_Restore 12 0
          2017-03-01 19:33 - 2016-08-11 19:50 - 00002812 _____ C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-3236326594-2611474830-2656184370-1001
          2017-03-01 13:58 - 2013-05-04 00:13 - 00000000 ___HD C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA
          2017-03-01 13:58 - 2012-10-14 18:47 - 00000000 ___HD C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX
          2017-02-10 18:50 - 2013-09-17 09:45 - 00000000 ____D C:\ProgramData\Ashampoo
          2014-02-12 22:10 - 2014-02-12 22:10 - 0000005 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_496F4C99-60AD-5b9e-AC1B-FA060E643C04.dll
          2014-02-12 22:10 - 2014-02-12 22:10 - 0000013 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_72024697-2626-4a12-8347-7CAC1834AC3B.dll
          2014-02-12 22:10 - 2014-02-12 22:10 - 0000013 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_D9C6A609-15A1-4768-8E98-6FA00C2547CC.dll
          2014-02-12 22:10 - 2014-02-12 22:10 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_F4F01109-C336-401f-BDE4-7C1926744104.dll
          2014-02-12 22:10 - 2014-02-12 22:10 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_FAB01109-C336-401f-BDE4-AB1926744111.dll
          2014-01-26 19:56 - 2014-01-26 19:56 - 0000004 _____ () C:\Users\SamSwanson\AppData\Roaming\iasna_FB9AECF7-F56E-7B2E-A862-9892AA545103.dll
          2016-08-11 19:35 - 2016-08-11 19:35 - 0000000 ____H () C:\ProgramData\DP45977C.lfl
          Task: {05848826-F541-4A0C-B9F2-1611BC2C39B2} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085 => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [2015-08-31] (Google Inc.)
          Task: {063A0BFF-9FB6-4A57-A0FE-92E13D9CF789} - \Auslogics\BoostSpeed\Start BoostSpeed оn SamSwanson logon → No File <==== ATTENTION
          Task: {08ABE768-2FEF-4170-8066-25BB5001F947} - System32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {0F509641-76C6-4FAB-BEF3-CB600B547AC5} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {1471D492-58EE-4C44-BE77-AF989C926662} - System32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {1A41D700-2897-4BAA-A036-58E78AA05409} - System32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {21C96E5B-F2CD-4BC9-8E73-CA85AC55B19E} - System32\Tasks{EB5A17F7-59B1-4914-80F9-8981CBF7FF0B} => C:\Program Files (x86)\Gizmo\gizmo.exe [2012-12-25] (Arainia Solutions)
          Task: {23972D0B-9EA4-444E-94E3-FEF38A46F53D} - System32\Tasks\Microsoft\Windows\Media Center\ehDRMInit => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {25A3DFC4-D040-485E-B0C3-426340897B2A} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [2016-10-11] (Intel Corporation)
          Task: {31B61FA2-6781-4DDF-A0E6-B5E23DA9740B} - System32\Tasks\Microsoft\Windows\Media Center\RegisterSearch => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {36AD6884-E5D4-488D-95F6-FE8F55B41FAC} - System32\Tasks\Tweaking.com - Windows Repair Tray Icon => C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\WR_Tray_Icon.exe [2017-02-20] (Tweaking.com)
          Task: {39DBE3EA-4037-4B26-AD52-FC269D6B2855} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2016-02-23] (Apple Inc.)
          Task: {3BC80582-EF19-47C4-B5B2-6C63A4573C8E} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate_scheduled => %SystemRoot%\ehome\mcupdate.exe
          Task: {460D91C7-7A6C-4120-BDF1-351A93CF1157} - System32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry => %windir%\ehome\MCUpdate.exe
          Task: {5B36754A-B7BE-41F5-BE37-F12045B1C69B} - System32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {5D25CD93-550A-42DF-8295-8A2C8AB3DF1E} - \avastBCLRestartS-1-5-21-3236326594-2611474830-2656184370-1001 → No File <==== ATTENTION
          Task: {5D6CA38A-4C4C-4E18-8C5D-5E2224AEC118} - System32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {66365F28-CE4B-45AD-A996-337675E8A58E} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [2015-08-31] (Google Inc.)
          Task: {6E398F56-89B4-4FC1-8AEA-E632E89C8918} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
          Task: {6F7DD068-47F7-4EE2-B113-F6BC5435281D} - \Microsoft\Windows\Setup\EOSNotify → No File <==== ATTENTION
          Task: {7D6CD2E9-7D16-4990-876E-A1DDD1C333DC} - System32\Tasks\Microsoft\Windows\Media Center\RecordingRestart => %SystemRoot%\ehome\ehrec.exe
          Task: {8C2DAB06-A415-4E79-9FD2-92C60BC7FA67} - System32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
          Task: {96FDF968-3B9A-47A0-8729-22C64981D02C} - System32\Tasks\Microsoft\Windows\Media Center\mcupdate => %SystemRoot%\ehome\mcupdate.exe
          Task: {9929E7D3-69C5-48B3-BD78-4DA035C80291} - System32\Tasks{BBCD0C7D-45F8-4AA4-A784-5E4F16371482} => pcalua.exe -a E:\ashampoo_firewall_free_1.20_sm.exe -d E:
          Task: {9AC9EE1F-3C7D-4D11-A723-C108476BA2FD} - System32\Tasks\Adobe Flash Player PPAPI Notifier => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_ 0_0_221_pepper.exe [2017-02-22] (Adobe Systems Incorporated)
          Task: {A75CC2EA-C50E-4D36-AEA1-91212A6641DB} - System32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {AD0C68FF-F1EF-4C1E-A767-DBD5729882A2} - System32\Tasks\UnHackMe Task Scheduler => C:\Program Files (x86)\UnHackMe\hackmon.exe [2017-02-24] (Greatis Software)
          Task: {AD2F8636-6963-4AAD-A26F-1D01E01200F0} - System32\Tasks\ASUS\Easy Update => C:\Program Files (x86)\ASUS\AI Suite II\EasyUpdate\EzUpdt.exe [2013-01-14] ()
          Task: {AD93EA85-7159-4B00-A2A8-DC9C6441F3A7} - System32\Tasks\Microsoft\Windows\Media Center\StartRecording => %SystemRoot%\ehome\ehrec.exe
          Task: {C1590D8D-F402-4E93-8D27-AFD81BC6A5C3} - System32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
          Task: {CA31EB53-D7B0-4140-9BF1-68356F601421} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpda teService.exe [2017-02-22] (Adobe Systems Incorporated)
          Task: {D6716D1C-E449-4AF6-8063-D330FAEA820B} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [2015-08-31] (Google Inc.)
          Task: {D8D805E5-AFF8-477C-B46C-3A79C13D64E8} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {DAE7EBFF-9B4D-438B-A0E1-76A7FE896D57} - System32\Tasks\Microsoft\Windows\Media Center\OCURActivate => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {E3CC8218-7A1E-4B80-B0E8-C9C2FA606B1B} - System32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask => %SystemRoot%\ehome\mcupdate.exe
          Task: {E4290C7D-DF68-49AF-B8D3-ECF30CFCE984} - System32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask => %SystemRoot%\ehome\mcupdate.exe
          Task: {ED0C1F69-C3A2-41EA-B8C3-3F0D83A1F6C0} - \Microsoft\Windows\Customer Experience Improvement Program\BthSQM → No File <==== ATTENTION
          Task: {F19205EB-384D-455D-99E3-6BC1A4840E68} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-27] (Google Inc.)
          Task: {F6E4AD78-6FF4-4B5F-A68C-36575464E8A3} - System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 => %SystemRoot%\ehome\ehPrivJob.exe
          Task: {F8D01798-23CD-4BD7-A4B2-3C85ED5B55C9} - System32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService => %SystemRoot%\ehome\ehPrivJob.exe
          Task: C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_ 0_0_221_pepper.exe
          Task: C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpda teService.exe
          Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core.job => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe
          Task: C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA.job => C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe
          AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\bvSO2cjMUSN:nKkd VTct7EMl42YHS3SZExMJ [2388]
          AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX6d4DS5PFDAk03KTXvn2F2mu [2712]
          AlternateDataStreams: C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA:03H rcMG15SDYyUw1Sza8AWAbY [2338]
          HKU.DEFAULT\Software\Classes\exefile: “%1” %* <===== ATTENTION
          HKU.DEFAULT\Software\Classes.exe: exefile => “%1” %* <===== ATTENTION
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Classes\exefile: “%1” %* <===== ATTENTION
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Classes.exe: exefile => “%1” %* <===== ATTENTION
          HKLM...\StartupApproved\StartupFolder: => “Snagit 11.lnk”
          HKLM...\StartupApproved\StartupFolder: => “LoopBe30 Monitor.lnk”
          HKLM...\StartupApproved\StartupFolder: => “SoftEther VPN Client Manager Startup.lnk”
          HKLM...\StartupApproved\Run: => “Acronis Scheduler2 Service”
          HKLM...\StartupApproved\Run: => “AdobeAAMUpdater-1.0”
          HKLM...\StartupApproved\Run: => “RTHDVCPL”
          HKLM...\StartupApproved\Run: => “RunDLLEntry”
          HKLM...\StartupApproved\Run: => “THXCfg64”
          HKLM...\StartupApproved\Run: => “EvtMgr6”
          HKLM...\StartupApproved\Run: => “Launch LCore”
          HKLM...\StartupApproved\Run: => “ShadowPlay”
          HKLM...\StartupApproved\Run: => “iTunesHelper”
          HKLM...\StartupApproved\Run: => “ZAM”
          HKLM...\StartupApproved\Run: => “SoftEther VPN Client UI Helper”
          HKLM...\StartupApproved\Run32: => “AcronisTibMounterMonitor”
          HKLM...\StartupApproved\Run32: => “AdobeCS5ServiceManager”
          HKLM...\StartupApproved\Run32: => “APSDaemon”
          HKLM...\StartupApproved\Run32: => “UpdReg”
          HKLM...\StartupApproved\Run32: => “DivXMediaServer”
          HKLM...\StartupApproved\Run32: => “DivXUpdate”
          HKLM...\StartupApproved\Run32: => “googletalk”
          HKLM...\StartupApproved\Run32: => “iTunesHelper”
          HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched”
          HKLM...\StartupApproved\Run32: => “QuickTime Task”
          HKLM...\StartupApproved\Run32: => “SwitchBoard”
          HKLM...\StartupApproved\Run32: => “Acronis Scheduler2 Service”
          HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched (2)”
          HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched (1)”
          HKLM...\StartupApproved\Run32: => “SunJavaUpdateSched (3)”
          HKLM...\StartupApproved\Run32: => “Carbonite Backup”
          HKLM...\StartupApproved\Run32: => “CancelAutoPlay_df”
          HKLM...\StartupApproved\Run32: => “CheckNDISPortf0ac3e”
          HKLM...\StartupApproved\Run32: => “ZAM”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\StartupFolder: => “RBTray.exe”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\StartupFolder: => “SpeedFan.lnk”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Gobbler”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “GoogleChromeAutoLaunch_6884A160BCC04722E6F4385CB6 FFBBDA”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Google Update”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Skype”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Spotify”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Spotify Web Helper”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “DAEMON Tools Lite”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “GizmoDriveDelegate”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Copy”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Google Update (2)”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Google Update (3)”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Google Update (1)”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Google Update (4)”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “DriverMax”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “GoogleChromeAutoLaunch_20359AAFD869880A09A939B153 F8703B”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “OneDrive”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “DAEMON Tools Lite Automount”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “CCleaner Monitoring”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “SpybotPostWindows10UpgradeReInstall”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64”
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001...\StartupApproved\Run: => “Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64”
          RemoveProxy:
          CMD: netsh advfirewall reset
          CMD: netsh advfirewall set allprofiles state Off
          CMD: ipconfig /flushdns
          C:\Windows\system32\Drivers\etc\hosts
          Hosts:
          reboot:
          end
          HKLM\Software\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched (1) => value removed successfully
          HKLM\Software\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched (2) => value removed successfully
          HKLM\Software\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched (3) => value removed successfully
          HKLM\Software\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\DivXMediaServer => value removed successfully
          HKLM\Software\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\DivXUpdate => value removed successfully
          HKLM\Software\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Windows\CurrentVersion\Run \Google Update (1) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Windows\CurrentVersion\Run \Google Update (2) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Windows\CurrentVersion\Run \Google Update (3) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Windows\CurrentVersion\Run \Google Update (4) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Windows\CurrentVersion\Run \Google Update => value removed successfully
          HKLM\Software\Microsoft\Windows\CurrentVersion\Exp lorer\ShellIconOverlayIdentifiers\00avast => key removed successfully
          HKCR\CLSID{472083B0-C522-11CF-8763-00608CC02F24} => key not found.
          C:\WINDOWS\system32\GroupPolicy\Machine => moved successfully
          C:\WINDOWS\system32\GroupPolicy\GPT.ini => moved successfully
          C:\WINDOWS\SysWOW64\GroupPolicy\GPT.ini => moved successfully
          “C:\WINDOWS\system32\GroupPolicy\Machine” => not found.
          HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\DhcpNameServer => value removed successfully
          HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{2173f261-2e23-4f0a-940a-2a88ca2b214b}\NameServer => value removed successfully
          HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{2173f261-2e23-4f0a-940a-2a88ca2b214b}\DhcpNameServer => value removed successfully
          HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{7faf953a-453a-4de6-a3bc-2ce40997f6cc}\NameServer => value removed successfully
          HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{7faf953a-453a-4de6-a3bc-2ce40997f6cc}\DhcpNameServer => value removed successfully
          HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{a56f0fe6-a65d-419a-9a9d-a9f8c86c22bd}\DhcpNameServer => value removed successfully
          HKLM\System\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{c09f412c-6a39-48fa-9e06-9f815d6e9d25}\NameServer => value removed successfully
          HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer => key removed successfully
          HKU.DEFAULT\SOFTWARE\Policies\Microsoft\Internet Explorer => key removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Policies\Microsoft\Internet Explorer => key removed successfully
          HKLM\Software\Microsoft\Internet Explorer\Main\Start Page => value restored successfully
          HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main\Search Page => value removed successfully
          HKU.DEFAULT\Software\Microsoft\Internet Explorer\Main\Start Page => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main\Search Page => value restored successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Microsoft\Internet Explorer\Main\Start Page => value restored successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Browser Helper Objects{31D09BA0-12F5-4CCE-BE8A-2923E76605DA} => key removed successfully
          HKCR\CLSID{31D09BA0-12F5-4CCE-BE8A-2923E76605DA} => key not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Browser Helper Objects{761497BB-D6F0-462C-B6EB-D4DAF1D92D43} => key removed successfully
          HKCR\CLSID{761497BB-D6F0-462C-B6EB-D4DAF1D92D43} => key not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Browser Helper Objects{C9C42510-9B41-42c1-9DCD-7282A2D07C61} => key removed successfully
          HKCR\CLSID{C9C42510-9B41-42c1-9DCD-7282A2D07C61} => key not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Browser Helper Objects{D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} => key removed successfully
          HKCR\CLSID{D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} => key not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Browser Helper Objects{DBC80044-A445-435b-BC74-9C25C1C588A9} => key removed successfully
          HKCR\CLSID{DBC80044-A445-435b-BC74-9C25C1C588A9} => key not found.
          HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\Curren tVersion\Explorer\Browser Helper Objects{31D09BA0-12F5-4CCE-BE8A-2923E76605DA} => key removed successfully
          HKCR\Wow6432Node\CLSID{31D09BA0-12F5-4CCE-BE8A-2923E76605DA} => key not found.
          HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\Curren tVersion\Explorer\Browser Helper Objects{C9C42510-9B41-42c1-9DCD-7282A2D07C61} => key removed successfully
          HKCR\Wow6432Node\CLSID{C9C42510-9B41-42c1-9DCD-7282A2D07C61} => key not found.
          HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\Curren tVersion\Explorer\Browser Helper Objects{D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} => key removed successfully
          HKCR\Wow6432Node\CLSID{D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} => key not found.
          HKCR\PROTOCOLS\Handler\osf => key not found.
          HKCR\CLSID{D924BDC6-C83A-4BD5-90D0-095128A113D1} => key not found.
          HKCR\Wow6432Node\PROTOCOLS\Handler\skype4com => key not found.
          HKCR\Wow6432Node\CLSID{FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} => key not found.
          Firefox “newtab” removed successfully
          Firefox “homepage” removed successfully
          C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefo x\Profiles\lncyg2i6.default\searchplugins\google-avast.xml => moved successfully
          HKLM\Software\Wow6432Node\Mozilla\Firefox\Extensio ns\ffpwdman@bitdefender.com => value removed successfully
          HKLM\Software\Wow6432Node\MozillaPlugins@tools.google.com/Google Update;version=3 => key removed successfully
          C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll => moved successfully
          HKLM\Software\Wow6432Node\MozillaPlugins@tools.google.com/Google Update;version=9 => key removed successfully
          C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll => not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\MozillaPlugins@tools.google.com/Google Update;version=3 => key removed successfully
          C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\npGoogleUpdate3.dll => moved successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\MozillaPlugins@tools.google.com/Google Update;version=9 => key removed successfully
          C:\Users\SamSwanson\AppData\Local\Google\Update\1. 3.32.7\npGoogleUpdate3.dll => not found.
          HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions \kjeghcllfecehndceplomkocgfbklffd => key removed successfully
          HKLM\System\CurrentControlSet\Services\FreshIO => key removed successfully
          FreshIO => service removed successfully
          HKLM\System\CurrentControlSet\Services\ManyCam => key removed successfully
          ManyCam => service removed successfully
          HKLM\System\CurrentControlSet\Services\mcaudrv_sim ple => key removed successfully
          mcaudrv_simple => service removed successfully
          HKLM\System\CurrentControlSet\Services\SR => key removed successfully
          SR => service removed successfully
          HKLM\System\CurrentControlSet\Services\srservice => key removed successfully
          srservice => service removed successfully
          C:\WINDOWS\System32\Tasks\UnHackMe Task Scheduler => moved successfully
          C:\ProgramData\Emsisoft => moved successfully
          C:\Program Files\stinger => moved successfully
          C:\Program Files\McAfee => moved successfully
          C:\WINDOWS\System32\Tasks\Safer-Networking => moved successfully
          C:\ProgramData\Spybot - Search & Destroy => moved successfully
          C:\ProgramData\Sophos => moved successfully
          C:\Users\SamSwanson\Downloads\tdsskiller.zip => moved successfully
          C:\WINDOWS\system32\Drivers\55447846.sys => moved successfully
          C:\Users\SamSwanson\AppData\Local\Chromium => moved successfully
          C:\WINDOWS\system32\MRT => moved successfully
          C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => moved successfully
          C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job => moved successfully
          C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA.job => moved successfully
          C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core.job => moved successfully
          C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater => moved successfully
          C:\WINDOWS\System32\Tasks{EE492B24-CD47-404D-95D3-605112E375FA} => moved successfully
          C:\WINDOWS\System32\Tasks\Adobe Flash Player PPAPI Notifier => moved successfully
          C:\WINDOWS\System32\Tasks\Patch My PC => moved successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a => moved successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA => moved successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A => moved successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085 => moved successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core => moved successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore => moved successfully
          C:\WINDOWS\System32\Tasks\20160623_163758_Restore 12 0 => moved successfully
          C:\WINDOWS\System32\Tasks\20160618_170750_Restore 12 0 => moved successfully
          C:\WINDOWS\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-3236326594-2611474830-2656184370-1001 => moved successfully
          C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA => moved successfully
          C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX => moved successfully
          C:\ProgramData\Ashampoo => moved successfully
          C:\Users\SamSwanson\AppData\Roaming\iasna_496F4C99-60AD-5b9e-AC1B-FA060E643C04.dll => moved successfully
          C:\Users\SamSwanson\AppData\Roaming\iasna_72024697-2626-4a12-8347-7CAC1834AC3B.dll => moved successfully
          C:\Users\SamSwanson\AppData\Roaming\iasna_D9C6A609-15A1-4768-8E98-6FA00C2547CC.dll => moved successfully
          C:\Users\SamSwanson\AppData\Roaming\iasna_F4F01109-C336-401f-BDE4-7C1926744104.dll => moved successfully
          C:\Users\SamSwanson\AppData\Roaming\iasna_FAB01109-C336-401f-BDE4-AB1926744111.dll => moved successfully
          C:\Users\SamSwanson\AppData\Roaming\iasna_FB9AECF7-F56E-7B2E-A862-9892AA545103.dll => moved successfully
          C:\ProgramData\DP45977C.lfl => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{0584882 6-F541-4A0C-B9F2-1611BC2C39B2} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{0584882 6-F541-4A0C-B9F2-1611BC2C39B2} => key removed successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085 => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\GoogleUp dateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core1cf27e25d7e5085 => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{063A0BF F-9FB6-4A57-A0FE-92E13D9CF789} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{063A0BF F-9FB6-4A57-A0FE-92E13D9CF789} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Auslogic s\BoostSpeed\Start BoostSpeed оn SamSwanson logon => key not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{08ABE76 8-2FEF-4170-8066-25BB5001F947} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{08ABE76 8-2FEF-4170-8066-25BB5001F947} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\DispatchRecoveryTasks => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{0F50964 1-76C6-4FAB-BEF3-CB600B547AC5} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{0F50964 1-76C6-4FAB-BEF3-CB600B547AC5} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\PBDADiscovery => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{1471D49 2-58EE-4C44-BE77-AF989C926662} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{1471D49 2-58EE-4C44-BE77-AF989C926662} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\ReindexSearchRoot => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{1A41D70 0-2897-4BAA-A036-58E78AA05409} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{1A41D70 0-2897-4BAA-A036-58E78AA05409} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\ActivateWindowsSearch => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{21C96E5 B-F2CD-4BC9-8E73-CA85AC55B19E} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{21C96E5 B-F2CD-4BC9-8E73-CA85AC55B19E} => key removed successfully
          C:\WINDOWS\System32\Tasks{EB5A17F7-59B1-4914-80F9-8981CBF7FF0B} => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree{EB5A17F7-59B1-4914-80F9-8981CBF7FF0B} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{23972D0 B-9EA4-444E-94E3-FEF38A46F53D} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{23972D0 B-9EA4-444E-94E3-FEF38A46F53D} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\ehDRMInit => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\ehDRMInit => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{25A3DFC 4-D040-485E-B0C3-426340897B2A} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{25A3DFC 4-D040-485E-B0C3-426340897B2A} => key removed successfully
          C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{31B61FA 2-6781-4DDF-A0E6-B5E23DA9740B} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{31B61FA 2-6781-4DDF-A0E6-B5E23DA9740B} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\RegisterSearch => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\RegisterSearch => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{36AD688 4-E5D4-488D-95F6-FE8F55B41FAC} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{36AD688 4-E5D4-488D-95F6-FE8F55B41FAC} => key removed successfully
          C:\WINDOWS\System32\Tasks\Tweaking.com - Windows Repair Tray Icon => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Tweaking .com - Windows Repair Tray Icon => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{39DBE3E A-4037-4B26-AD52-FC269D6B2855} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{39DBE3E A-4037-4B26-AD52-FC269D6B2855} => key removed successfully
          C:\WINDOWS\System32\Tasks\Apple\AppleSoftwareUpdat e => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Apple\Ap pleSoftwareUpdate => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{3BC8058 2-EF19-47C4-B5B2-6C63A4573C8E} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{3BC8058 2-EF19-47C4-B5B2-6C63A4573C8E} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\mcupdate_scheduled => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\mcupdate_scheduled => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{460D91C 7-7A6C-4120-BDF1-351A93CF1157} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{460D91C 7-7A6C-4120-BDF1-351A93CF1157} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\PeriodicScanRetry => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{5B36754 A-B7BE-41F5-BE37-F12045B1C69B} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{5B36754 A-B7BE-41F5-BE37-F12045B1C69B} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\OCURDiscovery => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{5D25CD9 3-550A-42DF-8295-8A2C8AB3DF1E} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{5D25CD9 3-550A-42DF-8295-8A2C8AB3DF1E} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\avastBCL RestartS-1-5-21-3236326594-2611474830-2656184370-1001 => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{5D6CA38 A-4C4C-4E18-8C5D-5E2224AEC118} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{5D6CA38 A-4C4C-4E18-8C5D-5E2224AEC118} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\UpdateRecordPath => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{66365F2 8-CE4B-45AD-A996-337675E8A58E} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{66365F2 8-CE4B-45AD-A996-337675E8A58E} => key removed successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\GoogleUp dateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{6E398F5 6-89B4-4FC1-8AEA-E632E89C8918} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{6E398F5 6-89B4-4FC1-8AEA-E632E89C8918} => key removed successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\GoogleUp dateTaskMachineCore => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{6F7DD06 8-47F7-4EE2-B113-F6BC5435281D} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{6F7DD06 8-47F7-4EE2-B113-F6BC5435281D} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Setup\EOSNotify => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Boot{7D6CD2E9-7D16-4990-876E-A1DDD1C333DC} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{7D6CD2E 9-7D16-4990-876E-A1DDD1C333DC} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\RecordingRestart => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\RecordingRestart => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{8C2DAB0 6-A415-4E79-9FD2-92C60BC7FA67} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{8C2DAB0 6-A415-4E79-9FD2-92C60BC7FA67} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\PvrRecoveryTask => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{96FDF96 8-3B9A-47A0-8729-22C64981D02C} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{96FDF96 8-3B9A-47A0-8729-22C64981D02C} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\mcupdate => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\mcupdate => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{9929E7D 3-69C5-48B3-BD78-4DA035C80291} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{9929E7D 3-69C5-48B3-BD78-4DA035C80291} => key removed successfully
          C:\WINDOWS\System32\Tasks{BBCD0C7D-45F8-4AA4-A784-5E4F16371482} => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree{BBCD0C7D-45F8-4AA4-A784-5E4F16371482} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{9AC9EE1 F-3C7D-4D11-A723-C108476BA2FD} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{9AC9EE1 F-3C7D-4D11-A723-C108476BA2FD} => key removed successfully
          C:\WINDOWS\System32\Tasks\Adobe Flash Player PPAPI Notifier => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Adobe Flash Player PPAPI Notifier => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{A75CC2E A-C50E-4D36-AEA1-91212A6641DB} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{A75CC2E A-C50E-4D36-AEA1-91212A6641DB} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\InstallPlayReady => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{AD0C68F F-F1EF-4C1E-A767-DBD5729882A2} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{AD0C68F F-F1EF-4C1E-A767-DBD5729882A2} => key removed successfully
          C:\WINDOWS\System32\Tasks\UnHackMe Task Scheduler => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\UnHackMe Task Scheduler => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon{AD2F863 6-6963-4AAD-A26F-1D01E01200F0} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{AD2F863 6-6963-4AAD-A26F-1D01E01200F0} => key removed successfully
          C:\WINDOWS\System32\Tasks\ASUS\Easy Update => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\ASUS\Eas y Update => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{AD93EA8 5-7159-4B00-A2A8-DC9C6441F3A7} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{AD93EA8 5-7159-4B00-A2A8-DC9C6441F3A7} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\StartRecording => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\StartRecording => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{C1590D8 D-F402-4E93-8D27-AFD81BC6A5C3} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{C1590D8 D-F402-4E93-8D27-AFD81BC6A5C3} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\MediaCenterRecoveryTask => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{CA31EB5 3-D7B0-4140-9BF1-68356F601421} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{CA31EB5 3-D7B0-4140-9BF1-68356F601421} => key removed successfully
          C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Adobe Flash Player Updater => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{D6716D1 C-E449-4AF6-8063-D330FAEA820B} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{D6716D1 C-E449-4AF6-8063-D330FAEA820B} => key removed successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\GoogleUp dateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{D8D805E 5-AFF8-477C-B46C-3A79C13D64E8} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{D8D805E 5-AFF8-477C-B46C-3A79C13D64E8} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\PBDADiscoveryW1 => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{DAE7EBF F-9B4D-438B-A0E1-76A7FE896D57} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{DAE7EBF F-9B4D-438B-A0E1-76A7FE896D57} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\OCURActivate => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\OCURActivate => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{E3CC821 8-7A1E-4B80-B0E8-C9C2FA606B1B} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{E3CC821 8-7A1E-4B80-B0E8-C9C2FA606B1B} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\ObjectStoreRecoveryTask => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{E4290C7 D-DF68-49AF-B8D3-ECF30CFCE984} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{E4290C7 D-DF68-49AF-B8D3-ECF30CFCE984} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\PvrScheduleTask => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{ED0C1F6 9-C3A2-41EA-B8C3-3F0D83A1F6C0} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{ED0C1F6 9-C3A2-41EA-B8C3-3F0D83A1F6C0} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Customer Experience Improvement Program\BthSQM => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{F19205E B-384D-455D-99E3-6BC1A4840E68} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{F19205E B-384D-455D-99E3-6BC1A4840E68} => key removed successfully
          C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A => not found.
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\GoogleUp dateTaskMachineUA => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{F6E4AD7 8-6FF4-4B5F-A68C-36575464E8A3} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{F6E4AD7 8-6FF4-4B5F-A68C-36575464E8A3} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\PBDADiscoveryW2 => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain{F8D0179 8-23CD-4BD7-A4B2-3C85ED5B55C9} => key removed successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks{F8D0179 8-23CD-4BD7-A4B2-3C85ED5B55C9} => key removed successfully
          C:\WINDOWS\System32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Microsof t\Windows\Media Center\ConfigureInternetTimeService => key removed successfully
          C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job => not found.
          C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => not found.
          C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001Core.job => not found.
          C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA.job => not found.
          C:\Users\SamSwanson\AppData\Local\bvSO2cjMUSN => “:nKkdVTct7EMl42YHS3SZExMJ” ADS removed successfully.
          “C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX” => “6d4DS5PFDAk03KTXvn2F2mu” ADS not found.
          “C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA” => “:03HrcMG15SDYyUw1Sza8AWAbY” ADS not found.
          C:\Users\SamSwanson\AppData\Local\Temporary Internet Files => “:xwH7V3jDNbvYm9CzQAMppM” ADS removed successfully.
          C:\Users\SamSwanson\AppData\Local\bvSO2cjMUSN => moved successfully
          “C:\Users\SamSwanson\AppData\Local\fkMCIEeuWIX” => not found.
          “C:\Users\SamSwanson\AppData\Local\pX1tyrSoUVeA” => not found.
          HKU.DEFAULT\Software\Classes\exefile => key removed successfully
          HKU.DEFAULT\Software\Classes.exe => key removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Classes\exefile => key removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\Classes.exe => key removed successfully
          HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\Services\WSearch => key removed successfully
          HKLM\System\CurrentControlSet\Services\WSearch => key removed successfully
          C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Snagit 11.lnk => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\StartupFolder\Snagit 11.lnk => value removed successfully
          C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\LoopBe30 Monitor.lnk => not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\StartupFolder\LoopBe30 Monitor.lnk => value removed successfully
          C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\SoftEther VPN Client Manager Startup.lnk => moved successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\StartupFolder\SoftEther VPN Client Manager Startup.lnk => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Acronis Scheduler2 Service => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Acronis Scheduler2 Service => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\AdobeAAMUpdater-1.0 => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \AdobeAAMUpdater-1.0 => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\RTHDVCPL => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \RTHDVCPL => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\RunDLLEntry => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \RunDLLEntry => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\THXCfg64 => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \THXCfg64 => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\EvtMgr6 => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \EvtMgr6 => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Launch LCore => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Launch LCore => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\ShadowPlay => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \ShadowPlay => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\iTunesHelper => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \iTunesHelper => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\ZAM => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \ZAM => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\SoftEther VPN Client UI Helper => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \SoftEther VPN Client UI Helper => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\AcronisTibMounterMonit or => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\AcronisTibMounterMonitor => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\AdobeCS5ServiceManager => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\AdobeCS5ServiceManager => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\APSDaemon => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\APSDaemon => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\UpdReg => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\UpdReg => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\DivXMediaServer => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\DivXMediaServer => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\DivXUpdate => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\DivXUpdate => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\googletalk => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\googletalk => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\iTunesHelper => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\iTunesHelper => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\SunJavaUpdateSched => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\QuickTime Task => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\QuickTime Task => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\SwitchBoard => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SwitchBoard => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\Acronis Scheduler2 Service => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\Acronis Scheduler2 Service => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\SunJavaUpdateSched (2) => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched (2) => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\SunJavaUpdateSched (1) => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched (1) => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\SunJavaUpdateSched (3) => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\SunJavaUpdateSched (3) => value not found.
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\Carbonite Backup => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\Carbonite Backup => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\CancelAutoPlay_df => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\CancelAutoPlay_df => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\CheckNDISPortf0ac3e => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\CheckNDISPortf0ac3e => value removed successfully
          HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run32\ZAM => value removed successfully
          HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\Curren tVersion\Run\ZAM => value not found.
          C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Startup\RBTray.exe => not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\StartupFolder\RBTray.exe => value removed successfully
          C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Startup\SpeedFan.lnk => moved successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\StartupFolder\SpeedFan.lnk => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Gobbler => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Gobbler => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\GoogleChromeAutoLaunch_6 884A160BCC04722E6F4385CB6FFBBDA => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \GoogleChromeAutoLaunch_6884A160BCC04722E6F4385CB6 FFBBDA => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Google Update => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Google Update => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Skype => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Skype => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Spotify => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Spotify => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Spotify Web Helper => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Spotify Web Helper => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\DAEMON Tools Lite => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \DAEMON Tools Lite => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\GizmoDriveDelegate => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \GizmoDriveDelegate => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Copy => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Copy => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Google Update (2) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Google Update (2) => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Google Update (3) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Google Update (3) => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Google Update (1) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Google Update (1) => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Google Update (4) => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Google Update (4) => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\DriverMax => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \DriverMax => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\GoogleChromeAutoLaunch_2 0359AAFD869880A09A939B153F8703B => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \GoogleChromeAutoLaunch_20359AAFD869880A09A939B153 F8703B => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\OneDrive => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \OneDrive => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\DAEMON Tools Lite Automount => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \DAEMON Tools Lite Automount => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\CCleaner Monitoring => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \CCleaner Monitoring => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\SpybotPostWindows10Upgra deReInstall => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \SpybotPostWindows10UpgradeReInstall => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64 => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64 => value not found.
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\StartupApproved\Run\Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64 => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64 => value not found.
          HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVers ion\Internet Settings\Connections\DefaultConnectionSettings => value removed successfully
          HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVers ion\Internet Settings\Connections\SavedLegacySettings => value removed successfully
          HKU\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Inter net Settings\Connections\DefaultConnectionSettings => value removed successfully
          HKU\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Inter net Settings\Connections\SavedLegacySettings => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\DefaultConnectionSettings => value removed successfully
          HKU\S-1-5-21-3236326594-2611474830-2656184370-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings\Connections\SavedLegacySettings => value removed successfully
          ========= netsh advfirewall reset =========
          Ok.
          ========= netsh advfirewall set allprofiles state Off =========
          Ok.
          Windows IP Configuration
          Could not move “C:\Windows\system32\Drivers\etc\hosts” => Scheduled to move on reboot.
          Could not move “C:\Windows\System32\Drivers\etc\hosts” => Scheduled to move on reboot.
          BITS transfer queue => 32768 B
          DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 49886422 B
          Java, Flash, Steam htmlcache => 11304565 B
          Windows/system/drivers => 7492450 B
          Edge => 506 B
          Chrome => 29575083 B
          Firefox => 17447753 B
          Opera => 0 B
          Default => 0 B
          Users => 0 B
          ProgramData => 0 B
          Public => 0 B
          systemprofile => 0 B
          systemprofile32 => 560 B
          LocalService => 2520 B
          NetworkService => 51380352 B
          SamSwanson => 41025858 B
          RecycleBin => 0 B
          EmptyTemp: => 198.5 MB temporary data Removed.
          Result of scheduled files to move (Boot Mode: Normal) (Date&Time: 01-03-2017 21:43:26)
          C:\Windows\system32\Drivers\etc\hosts => Is moved successfully
          Hosts restored successfully.
          C:\Windows\System32\Drivers\etc\hosts => moved successfully
          ==== End of Fixlog 21:43:26 ====
          Clearlink:
          ClearLNK by Alex Dragokas ver. 2.9.0.11
          OS: x64 Windows 10 Pro, 10.0.14393, Service Pack: 0
          Time: 01.03.2017 - 21:46
          Language: OS: EN (0x409). Display: EN (0x409). Non-Unicode: EN (0x409)
          Elevated: Yes
          User: SamSwanson (group: Administrator)
          _____________________________ Begin of Log ______________________________
          [ OK ] 2 “C:\ProgramData\Microsoft\Windows\Start Menu Places\01 - File Explorer.lnk” → [ “C:\Windows\explorer.exe” ] (icon has been recovered)
          [ OK ] 11 “C:\ProgramData\Microsoft\Windows\Start Menu\Gobbler.lnk” → [ “C:\Program Files (x86)\Media Gobbler, Inc\Gobbler\Gobbler.exe” ] (icon has been recovered)
          [ OK ] 47 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware\Zemana AntiMalware.lnk” → [ “C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe” ] (icon has been recovered)
          [ OK ] 99 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tradeo - MetaTrader 4\Tradeo - MT4.lnk” → [ “C:\Program Files (x86)\Tradeo - MetaTrader 4\terminal.exe” ] (icon has been recovered)
          [ OK ] 119 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools\Windows Defender.lnk” → [ “C:\Program Files\Windows Defender\MSASCui.exe” ] (icon has been recovered)
          [ OK ] 128 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonarworks\Sonarworks\Sonarworks HD reference.lnk” → [ “C:\Program Files (x86)\Sonarworks\Sonarworks HD reference\sonarworks.exe” ] (icon has been recovered)
          [ OK ] 129 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonarworks\Sonarworks\Sonarworks Reference 3.lnk” → [ “C:\Program Files (x86)\Sonarworks\SonarworksReference\Sonarworks Reference 3.exe” ] (icon has been recovered)
          [ OK ] 357 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MetaTrader 5\MetaTrader 5.lnk” → [ “C:\Program Files\MetaTrader 5\terminal64.exe” ] (icon has been recovered)
          [ OK ] 403 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\Configure Java.lnk” → [ “C:\Program Files\Java\jre1.8.0_121\bin\javacpl.exe” ] (icon has been recovered)
          [ OK ] 444 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Extreme Tuning Utility\Intel(R) Extreme Tuning Utility.lnk” → [ “C:\Program Files (x86)\Intel\Extreme Tuning Utility\Client\PerfTune.exe” ] (icon has been recovered)
          [ OK ] 541 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CrystalDiskInfo\CrystalDiskInfo Shizuku Edition.lnk” → [ “C:\Program Files (x86)\CrystalDiskInfo\DiskInfo32S.exe” ] (icon has been recovered)
          [ OK ] 542 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CrystalDiskInfo\CrystalDiskInfo.lnk” → [ “C:\Program Files (x86)\CrystalDiskInfo\DiskInfo.exe” ] (icon has been recovered)
          [ OK ] 594 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Articulator Setup.pdf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\AVOX Evo VST\Articulator Setup.pdf” ] (icon has been recovered)
          [ OK ] 595 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Authorization Read Me.pdf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\AVOX Evo VST\Authorization Read Me.pdf” ] (icon has been recovered)
          [ OK ] 596 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch AVOX Evo License.rtf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\AVOX Evo VST\AVOX Evo License.rtf” ] (icon has been recovered)
          [ OK ] 597 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch AVOX Evo Manual.pdf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\AVOX Evo VST\AVOX Evo Manual.pdf” ] (icon has been recovered)
          [ OK ] 598 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch AVOX THROAT Presets Read Me.rtf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\AVOX Evo VST\AVOX THROAT Presets Read Me.rtf” ] (icon has been recovered)
          [ OK ] 599 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Harmony Engine Evo Manual.pdf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\AVOX Evo VST\Harmony Engine Evo Manual.pdf” ] (icon has been recovered)
          [ OK ] 600 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Harmony Engine Evo VST PC Read Me.pdf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\AVOX Evo VST\Harmony Engine Evo VST PC Read Me.pdf” ] (icon has been recovered)
          [ OK ] 604 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Component Services.lnk” → [ “C:\Windows\System32\comexp.msc” ] (icon has been recovered)
          [ OK ] 605 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\dfrgui.lnk” → [ “C:\Windows\System32\dfrgui.exe” ] (icon has been recovered)
          [ OK ] 606 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Disk Cleanup.lnk” → [ “C:\Windows\System32\cleanmgr.exe” ] (icon has been recovered)
          [ OK ] 607 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\iSCSI Initiator.lnk” → [ “C:\Windows\System32\iscsicpl.exe” ] (icon has been recovered)
          [ OK ] 608 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Memory Diagnostics Tool.lnk” → [ “C:\WINDOWS\system32\MdSched.exe” ] (icon has been recovered)
          [ OK ] 609 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\ODBC Data Sources (32-bit).lnk” → [ “C:\Windows\SysWOW64\odbcad32.exe” ] (icon has been recovered)
          [ OK ] 610 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\ODBC Data Sources (64-bit).lnk” → [ “C:\Windows\System32\odbcad32.exe” ] (icon has been recovered)
          [ OK ] 611 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Print Management.lnk” → [ “C:\WINDOWS\system32\printmanagement.msc” ] (icon has been recovered)
          [ OK ] 612 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\services.lnk” → [ “C:\Windows\System32\services.msc” ] (icon has been recovered)
          [ OK ] 613 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\System Configuration.lnk” → [ “C:\WINDOWS\system32\msconfig.exe” ] (icon has been recovered)
          [ OK ] 614 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\System Information.lnk” → [ “C:\Windows\System32\msinfo32.exe” ] (icon has been recovered)
          [ OK ] 615 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Windows Firewall with Advanced Security.lnk” → [ “C:\Windows\System32\WF.msc” ] (icon has been recovered)
          [ OK ] 620 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Math Input Panel.lnk” → [ “C:\Program Files\Common Files\microsoft shared\ink\mip.exe” ] (icon has been recovered)
          [ OK ] 621 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Paint.lnk” → [ “C:\Windows\System32\mspaint.exe” ] (icon has been recovered)
          [ OK ] 622 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Quick Assist.lnk” → [ “C:\WINDOWS\system32\quickassist.exe” ] (icon has been recovered)
          [ OK ] 623 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Remote Desktop Connection.lnk” → [ “C:\Windows\System32\mstsc.exe” ] (icon has been recovered)
          [ OK ] 624 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Snipping Tool.lnk” → [ “C:\WINDOWS\system32\SnippingTool.exe” ] (icon has been recovered)
          [ OK ] 625 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Steps Recorder.lnk” → [ “C:\Windows\System32\psr.exe” ] (icon has been recovered)
          [ OK ] 626 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Windows Fax and Scan.lnk” → [ “C:\WINDOWS\system32\WFS.exe” ] (icon has been recovered)
          [ OK ] 627 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Wordpad.lnk” → [ “C:\Program Files (x86)\Windows NT\Accessories\wordpad.exe” ] (icon has been recovered)
          [ OK ] 628 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\XPS Viewer.lnk” → [ “C:\Windows\System32\xpsrchvw.exe” ] (icon has been recovered)
          [ OK ] 629 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\System Tools\Character Map.lnk” → [ “C:\Windows\System32\charmap.exe” ] (icon has been recovered)
          [ OK ] 641 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell (x86).lnk” → [ “C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 642 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE (x86).lnk” → [ “C:\Windows\SysWOW64\WindowsPowerShell\v1.0\PowerS hell_ISE.exe” ] (icon has been recovered)
          [ OK ] 643 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\PowerS hell_ISE.exe” ] (icon has been recovered)
          [ OK ] 644 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 650 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessories\Notepad.lnk” → [ “C:\Windows\System32\notepad.exe” ] (icon has been recovered)
          [ OK ] 651 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessibility\Magnify.lnk” → [ “C:\Windows\System32\Magnify.exe” ] (icon has been recovered)
          [ OK ] 652 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessibility\Narrator.lnk” → [ “C:\WINDOWS\system32\narrator.exe” ] (icon has been recovered)
          [ OK ] 653 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessibility\On-Screen Keyboard.lnk” → [ “C:\Windows\System32\osk.exe” ] (icon has been recovered)
          [ OK ] 657 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\01a - Windows PowerShell.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 659 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\02a - Windows PowerShell.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 676 “C:\Users\Public\Desktop\Sonarworks Reference.lnk” → [ “C:\Program Files (x86)\Sonarworks\SonarworksReference\Sonarworks Reference 3.exe” ] (icon has been recovered)
          [ OK ] 678 “C:\Users\Public\Desktop\Tradeo - MetaTrader 4.lnk” → [ “C:\Program Files (x86)\Tradeo - MetaTrader 4\terminal.exe” ] (icon has been recovered)
          [ OK ] 691 “C:\Users\SamSwanson\Desktop\Dashlane.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dash lane.exe” ] (icon has been recovered)
          [ OK ] 697 “C:\Users\SamSwanson\Desktop\Melodyne Studio 4.lnk” → [ “C:\Program Files\Celemony\Melodyne Studio 4\Melodyne.exe” ] (Method RN-S) (OK)
          [ OK ] 711 “C:\Users\SamSwanson\AppData\Roaming\REAPER\Data\R EAPER (reset configuration to factory defaults).lnk” → [ “C:\Program Files\REAPER\reaper.exe” ] (Method RN-S) (OK)
          [ OK ] 735 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell (x86).lnk” → [ “C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 736 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE (x86).lnk” → [ “C:\Windows\SysWOW64\WindowsPowerShell\v1.0\PowerS hell_ISE.exe” ] (icon has been recovered)
          [ OK ] 737 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\PowerS hell_ISE.exe” ] (icon has been recovered)
          [ OK ] 738 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 800 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Litecoin Core\Uninstall Litecoin Core (64-bit).lnk” → [ “C:\Program Files\Litecoin\uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 808 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Jack\Jack Control.lnk” → [ “C:\Program Files (x86)\Jack\qjackctl.exe” ] (icon has been recovered)
          [ OK ] 894 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessories\Internet Explorer.lnk” → [ “C:\Program Files\Internet Explorer\iexplore.exe” ] (Method RN-S) (OK)
          [ OK ] 895 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessories\Notepad.lnk” → [ “C:\Windows\System32\notepad.exe” ] (icon has been recovered)
          [ OK ] 896 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessibility\Magnify.lnk” → [ “C:\Windows\System32\Magnify.exe” ] (icon has been recovered)
          [ OK ] 897 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessibility\Narrator.lnk” → [ “C:\WINDOWS\system32\narrator.exe” ] (icon has been recovered)
          [ OK ] 898 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessibility\On-Screen Keyboard.lnk” → [ “C:\Windows\System32\osk.exe” ] (icon has been recovered)
          [ OK ] 906 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk” → [ “C:\Program Files\Internet Explorer\iexplore.exe” ] (Method RN-S) (OK)
          [ OK ] 913 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\01a - Windows PowerShell.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 915 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\02a - Windows PowerShell.lnk” → [ “C:\Windows\System32\WindowsPowerShell\v1.0\powers hell.exe” ] (icon has been recovered)
          [ OK ] 944 “C:\ProgramData\Microsoft\Windows\Start Menu\SoundToys\Uninstall SoundToys 5.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 945 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe\Check for UnHackMe updates.lnk” → [ “C:\Program Files (x86)\UnHackMe\GWebUpdate.exe” ] (Method RN-S) (OK)
          [ OK ] 946 “C:\ProgramData\Microsoft\Windows\Start Menu\Lexicon\Uninstall Lexicon PCM Total Bundle.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 947 “C:\ProgramData\Microsoft\Windows\Start Menu\Synchro Arts\Uninstall Synchro Arts - Revoice Pro v3.1.1.3.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 948 “C:\ProgramData\Microsoft\Windows\Start Menu\Softube\Uninstall Softube - Drawmer S73 and Drawmer 1973.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 949 “C:\ProgramData\Microsoft\Windows\Start Menu\Softube\Uninstall Softube - Plug-Ins x64 v2.2.76.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 950 “C:\ProgramData\Microsoft\Windows\Start Menu\Sly-Fi Digital\Uninstall Sly-Fi Digital - Axis EQ 1.0.3.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 951 “C:\ProgramData\Microsoft\Windows\Start Menu\Sly-Fi Digital\Uninstall Sly-Fi Digital - Deflector 1.0.2.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 952 “C:\ProgramData\Microsoft\Windows\Start Menu\Sly-Fi Digital\Uninstall Sly-Fi Digital - Kaya 1.0.4.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 953 “C:\ProgramData\Microsoft\Windows\Start Menu\Slate Digital\Uninstall Slate Digital - Virtual Mix Rack 1.5.0.1.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 954 “C:\ProgramData\Microsoft\Windows\Start Menu\Relab\Uninstall Relab - LX480 Complete.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 955 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MacDrive Pro Quick Start.lnk” → [ “C:\Program Files\Mediafour\MacDrive 9\MDQuickStart.exe” ] (Method RN-S) (OK)
          [ OK ] 956 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Media Player.lnk” → [ “C:\Program Files (x86)\Windows Media Player\wmplayer.exe” ] (Method RN-S) (OK)
          [ OK ] 957 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Webroot SecureAnywhere\Webroot SecureAnywhere.lnk” → [ “C:\Program Files\Webroot\WRSA.exe” ] (Method RN-S) (OK)
          [ OK ] 958 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Webcam\Uninstall.lnk” → [ “C:\Program Files (x86)\InstallShield Installation Information{ED1674F5-5165-49BF-B546-AE5343111540}\setup.exe” ] (Method RN-S) (OK)
          [ OK ] 959 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\Uninstall Virtual Audio Cable.lnk” → [ “C:\Program Files\Virtual Audio Cable\setup64.exe” ] (Method RN-S) (OK)
          [ OK ] 960 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\Reset VLC media player preferences and cache files.lnk” → [ “C:\Program Files (x86)\VideoLAN\VLC\vlc.exe” ] (Method RN-S) (OK)
          [ OK ] 961 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VLC media player - reset preferences and cache files.lnk” → [ “C:\Program Files (x86)\VideoLAN\VLC\vlc.exe” ] (Method RN-S) (OK)
          [ OK ] 962 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VLC media player skinned.lnk” → [ “C:\Program Files (x86)\VideoLAN\VLC\vlc.exe” ] (Method RN-S) (OK)
          [ OK ] 963 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tweaking.com\Windows Repair (All in One)\Uninstall Tweaking.com - Windows Repair.lnk” → [ “C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 964 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools\Task Manager.lnk” → [ “C:\Windows\System32\Taskmgr.exe” ] (Method RN-S) (OK)
          [ OK ] 965 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Suite Spot Studios\AATranslator\Uninstall AATranslator.lnk” → [ “C:\Windows\SysWOW64\msiexec.exe” ] (Method RN-S) (OK)
          [ OK ] 967 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoundRadix\Uninstall SoundRadix - Surfer EQ2 v2.0.1.0.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 968 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Manage Remote Computer’s SoftEther VPN Client.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe” ] (Method RN-S) (OK)
          [ OK ] 969 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Language Settings\Configure Display Language.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpnsetup.exe” ] (Method RN-S) (OK)
          [ OK ] 970 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Configuration Tools\TCP Optimization Utility.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe” ] (Method RN-S) (OK)
          [ OK ] 971 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Administrative Tools\Debugging Information Collecting Tool.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpncmd_x64.exe” ] (Method RN-S) (OK)
          [ OK ] 972 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Administrative Tools\Easy Installer Creator.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpnsetup.exe” ] (Method RN-S) (OK)
          [ OK ] 973 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Administrative Tools\Network Traffic Speed Test Tool.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe” ] (Method RN-S) (OK)
          [ OK ] 974 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Administrative Tools\Web Installer Creator.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpnsetup.exe” ] (Method RN-S) (OK)
          [ OK ] 975 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\REAPER (x64) (create new project).lnk” → [ “C:\Program Files\REAPER (x64)\reaper.exe” ] (Method RN-S) (OK)
          [ OK ] 976 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\REAPER (x64) (reset configuration to factory defaults).lnk” → [ “C:\Program Files\REAPER (x64)\reaper.exe” ] (Method RN-S) (OK)
          [ OK ] 977 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\REAPER (x64) (ReWire slave mode).lnk” → [ “C:\Program Files\REAPER (x64)\reaper.exe” ] (Method RN-S) (OK)
          [ OK ] 978 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\REAPER (x64) (show audio configuration on startup).lnk” → [ “C:\Program Files\REAPER (x64)\reaper.exe” ] (Method RN-S) (OK)
          [ OK ] 979 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Python 3.3\IDLE (Python GUI).lnk” → [ “C:\Python33\pythonw.exe” ] (Method RN-S) (OK)
          [ OK ] 980 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Python 3.3\Module Docs.lnk” → [ “C:\Python33\pythonw.exe” ] (Method RN-S) (OK)
          [ OK ] 981 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Python 3.3\Uninstall Python.lnk” → [ “C:\Windows\System32\msiexec.exe” ] (Method RN-S) (OK)
          [ OK ] 982 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Xenon\Uninstall PSP Xenon.lnk” → [ “C:\Program Files\PSPaudioware\PSP Xenon\uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 983 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP SpringBox 64bit\Uninstall PSP SpringBox 64bit.lnk” → [ “C:\Program Files\VSTPlugIns\PSP SpringBox\PSP SpringBox_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 984 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP PianoVerb2 64bit\Uninstall PSP PianoVerb2 64bit.lnk” → [ “C:\Program Files\VSTPlugIns\PSP PianoVerb2\PSP PianoVerb2_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 985 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP oldTimer 64bit\Uninstall PSP oldTimer 64bit.lnk” → [ “C:\Program Files\PSPaudioware\PSP oldTimer 64bit\uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 986 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP NobleQ 64bit\Uninstall PSP NobleQ 64bit.lnk” → [ “C:\Program Files\PSPaudioware\PSP NobleQ 64bit\PSP NobleQ_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 987 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Neon 64bit\Uninstall PSP Neon 64bit.lnk” → [ “C:\Program Files\PSPaudioware\PSP Neon 64bit\PSP Neon_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 988 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP McQ 64bit\Uninstall PSP McQ 64bit.lnk” → [ “C:\Program Files\VSTPlugIns\PSP McQ\PSP McQ_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 989 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP MasterComp\Uninstall PSP MasterComp.lnk” → [ “C:\Program Files\PSPaudioware\PSP MasterComp\uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 990 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Echo 64bit\Uninstall PSP Echo 64bit.lnk” → [ “C:\Program Files\PSPaudioware\PSP Echo 64bit\PSP Echo_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 991 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP BussPressor 64bit\Uninstall PSP BussPressor 64bit.lnk” → [ “C:\Program Files\PSPaudioware\PSP BussPressor 64bit\PSP BussPressor_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 992 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 85 64bit\Uninstall PSP 85 64bit.lnk” → [ “C:\Program Files\VSTPlugIns\PSP 85\PSP 85_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 993 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 608 MultiDelay 64bit\Uninstall PSP 608 MultiDelay 64bit.lnk” → [ “C:\Program Files\PSPaudioware\PSP 608 MultiDelay 64bit\PSP 608 MultiDelay_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 994 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 2Meters 64bit\Uninstall PSP 2Meters 64bit.lnk” → [ “C:\Program Files\PSPaudioware\PSP 2Meters 64bit\PSP 2Meters_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 995 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\Lexicon PSP 42 64bit\Uninstall Lexicon PSP 42 64bit.lnk” → [ “C:\Program Files\VSTPlugIns\Lexicon PSP 42_64bit_uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 996 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Process Lasso\Process Lasso.lnk” → [ “C:\Program Files\Process Lasso\ProcessLassoLauncher.exe” ] (Method RN-S) (OK)
          [ OK ] 997 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Plogue\chipsounds\Generate logs.lnk” → [ “C:\Program Files\Plogue\Aria\AriaReporter.exe” ] (Method RN-S) (OK)
          [ OK ] 998 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation\3D Vision\3D Vision preview pack 1.lnk” → [ “C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvstlink.exe” ] (Method RN-S) (OK)
          [ OK ] 1000 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mobile Hotspot Admin\Uninstall.lnk” → [ “C:\Windows\SysWOW64\SupportAppPBHostless Modem\Setup.exe” ] (Method RN-S) (OK)
          [ OK ] 1001 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\InfoPath Designer 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\INFOPATH.EXE” ] (Method RN-S) (OK)
          [ OK ] 1002 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MeldaProduction\MTotalBundle64\Unins tall MTotalBundle64.lnk” → [ “C:\Program Files\MeldaProduction\MTotalBundle64 8\setup.exe” ] (Method RN-S) (OK)
          [ OK ] 1003 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MeldaProduction\MeldaProduction Audio Plugins\Uninstall Audio Plugins.lnk” → [ “C:\Program Files\MeldaProduction\Audio Plugins 10\setup.exe” ] (Method RN-S) (OK)
          [ OK ] 1004 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\M-Audio\Oxygen\Uninstall M-Audio Oxygen Driver.lnk” → [ “C:\Windows\System32\msiexec.exe” ] (Method RN-S) (OK)
          [ OK ] 1005 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Logitech\Mouse and Keyboard\Mouse and Keyboard Settings.lnk” → [ “C:\Program Files\Logitech\SetPointP\SetPoint.exe” ] (Method RN-S) (OK)
          [ OK ] 1006 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kush\Uninstall Kush - Hammer DSP v1.0.0.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1007 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KD Niche Finder\Uninstall KD Niche Finder.lnk” → [ “C:\Windows\KD Niche Finder\uninstall.exe” ] (Method RN-S) (OK)
          [ OK ] 1008 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\DirectVobSub (x64).lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1009 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\ffdshow audio decoder (x64).lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1010 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\ffdshow VFW interface (x64).lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1011 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\ffdshow video decoder (x64).lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1012 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\Haali Media Splitter (x64).lnk” → [ “C:\Program Files\K-Lite Codec Pack x64\Tools\dsconfig64.exe” ] (Method RN-S) (OK)
          [ OK ] 1013 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\LAV Audio (x64).lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1014 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\LAV Splitter (x64).lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1015 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\LAV Video (x64).lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1016 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Configuration\Reset to recommended settings.lnk” → [ “C:\Program Files\K-Lite Codec Pack x64\Tools\CodecTweakTool.exe” ] (Method RN-S) (OK)
          [ OK ] 1017 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\DirectVobSub.lnk” → [ “C:\Windows\SysWOW64\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1018 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\ffdshow audio decoder.lnk” → [ “C:\Windows\SysWOW64\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1019 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\ffdshow video decoder.lnk” → [ “C:\Windows\SysWOW64\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1020 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\Haali Media Splitter.lnk” → [ “C:\Windows\SysWOW64\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1021 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\LAV Audio.lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1022 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\LAV Splitter.lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1023 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\LAV Video.lnk” → [ “C:\Windows\System32\rundll32.exe” ] (Method RN-S) (OK)
          [ OK ] 1024 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Configuration\Reset to recommended settings.lnk” → [ “C:\Program Files (x86)\K-Lite Codec Pack\Tools\CodecTweakTool.exe” ] (Method RN-S) (OK)
          [ OK ] 1025 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\About Java.lnk” → [ “C:\Program Files\Java\jre1.8.0_121\bin\javacpl.exe” ] (Method RN-S) (OK)
          [ OK ] 1026 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\Check For Updates.lnk” → [ “C:\Program Files\Java\jre1.8.0_121\bin\javacpl.exe” ] (Method RN-S) (OK)
          [ OK ] 1027 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel\Intel(R) Update Manager\Intel(R) Update Manager.lnk” → [ “C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe” ] (Method RN-S) (OK)
          [ OK ] 1028 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HFSExplorer\Run HFSExplorer in Administrator mode.lnk” → [ “C:\Program Files (x86)\HFSExplorer\hfsexplorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1029 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Talk\Google Talk.lnk” → [ “C:\Program Files (x86)\Google\Google Talk\googletalk.exe” ] (Method RN-S) (OK)
          [ OK ] 1030 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Talk\Support\Google Talk Diagnostic Mode.lnk” → [ “C:\Program Files (x86)\Google\Google Talk\googletalk.exe” ] (Method RN-S) (OK)
          [ OK ] 1031 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GIGABYTE\ET6\UnInstall.lnk” → [ “C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriver.exe” ] (Method RN-S) (OK)
          [ OK ] 1032 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Finale NotePad 2012\User Manual.lnk” → [ “C:\Program Files (x86)\Internet Explorer\iexplore.exe” ] (Method RN-S) (OK)
          [ OK ] 1033 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Exponential Audio\Uninstall Exponential Audio - Nimbus v1.0.0.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1034 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Exponential Audio\Uninstall Exponential Audio - R2 Stereo Reverb v3.0.2.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1035 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Empirical Labs\Uninstall Empirical Labs - Arousor v1.0.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1036 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Eiosis\Uninstall Eiosis - E2Deesser v1.0.3.1.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1037 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DivX\Check for Updates.lnk” → [ “C:\Program Files (x86)\DivX\DivX Control Panel\DivXControlPanelLauncher.exe” ] (Method RN-S) (OK)
          [ OK ] 1038 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DivX\Register.lnk” → [ “C:\Program Files (x86)\DivX\DivX Control Panel\DivXControlPanelLauncher.exe” ] (Method RN-S) (OK)
          [ OK ] 1039 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DisplayFusion\DisplayFusion Desktop Wallpaper.lnk” → [ “C:\Program Files (x86)\DisplayFusion\DisplayFusionCommand.exe” ] (Method RN-S) (OK)
          [ OK ] 1040 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DisplayFusion\DisplayFusion Monitor Configuration.lnk” → [ “C:\Program Files (x86)\DisplayFusion\DisplayFusionCommand.exe” ] (Method RN-S) (OK)
          [ OK ] 1041 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DisplayFusion\DisplayFusion Settings.lnk” → [ “C:\Program Files (x86)\DisplayFusion\DisplayFusionCommand.exe” ] (Method RN-S) (OK)
          [ OK ] 1042 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\BigClickCracked78Demo.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1043 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\Demo1.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1044 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\DSS Demo.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1045 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\Female Child Voice ID Test Sentence High Quality.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1046 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\Female Child Voice ID Test Sentence Low Quality.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1047 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\Female Voice ID Test Sentence - High Quality.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1048 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\Female Voice ID Test Sentence - Low Quality.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1049 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\ForensicsDemo.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1050 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\HissBurstDemo.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1051 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\Male Voice ID Test Sentence - High Quality.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1052 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\Male Voice ID Test Sentence - Low Quality.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1053 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Demo Wave Files\RadioDemo.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (Method RN-S) (OK)
          [ OK ] 1054 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Comodo\COMODO Firewall\Add and Remove components.lnk” → [ “C:\Windows\System32\msiexec.exe” ] (Method RN-S) (OK)
          [ OK ] 1055 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Comodo\COMODO Firewall\COMODO Firewall.lnk” → [ “C:\Program Files\COMODO\COMODO Internet Security\cistray.exe” ] (Method RN-S) (OK)
          [ OK ] 1056 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Carbonite\Carbonite.lnk” → [ “C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteUI.exe” ] (Method RN-S) (OK)
          [ OK ] 1057 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Carbonite\Uninstall Carbonite.lnk” → [ “C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteSetup.exe” ] (Method RN-S) (OK)
          [ OK ] 1058 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid\Pro Tools\Documentation.lnk” → [ “C:\Windows\SysWOW64\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1059 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid\Mbox\Uninstall Avid Mbox Driver.lnk” → [ “C:\Windows\System32\msiexec.exe” ] (Method RN-S) (OK)
          [ OK ] 1060 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Computer Management.lnk” → [ “C:\Windows\System32\compmgmt.msc” ] (Method RN-S) (OK)
          [ OK ] 1061 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Event Viewer.lnk” → [ “C:\Windows\System32\eventvwr.msc” ] (Method RN-S) (OK)
          [ OK ] 1062 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Performance Monitor.lnk” → [ “C:\Windows\System32\perfmon.msc” ] (Method RN-S) (OK)
          [ OK ] 1063 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Resource Monitor.lnk” → [ “C:\Windows\System32\perfmon.exe” ] (Method RN-S) (OK)
          [ OK ] 1064 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Security Configuration Management.lnk” → [ “C:\WINDOWS\system32\secpol.msc” ] (Method RN-S) (OK)
          [ OK ] 1065 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Task Scheduler.lnk” → [ “C:\Windows\System32\taskschd.msc” ] (Method RN-S) (OK)
          [ OK ] 1066 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\Activate Acronis Startup Recovery Manager.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageTools.exe” ] (Method RN-S) (OK)
          [ OK ] 1067 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\Add New Disk.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageTools.exe” ] (Method RN-S) (OK)
          [ OK ] 1068 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\Clone Disk.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageTools.exe” ] (Method RN-S) (OK)
          [ OK ] 1069 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\DriveCleanser.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageTools.exe” ] (Method RN-S) (OK)
          [ OK ] 1070 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\Manage Acronis Secure Zone.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageTools.exe” ] (Method RN-S) (OK)
          [ OK ] 1071 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\System Clean-up.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageTools.exe” ] (Method RN-S) (OK)
          [ OK ] 1072 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\Try&Decide.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageTools.exe” ] (Method RN-S) (OK)
          [ OK ] 1073 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Windows Media Player.lnk” → [ “C:\Program Files (x86)\Windows Media Player\wmplayer.exe” ] (Method RN-S) (OK)
          [ OK ] 1074 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessibility\Speech Recognition.lnk” → [ “C:\Windows\Speech\Common\sapisvr.exe” ] (Method RN-S) (OK)
          [ OK ] 1075 “C:\ProgramData\Microsoft\Windows\Start Menu\McDSP\Uninstall McDSP - 6020 Ultimate EQ v6.1.0.8.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1076 “C:\ProgramData\Microsoft\Windows\Start Menu\McDSP\Uninstall McDSP - 6050 Ultimate Channel Strip v6.2.0.10.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1077 “C:\ProgramData\Microsoft\Windows\Start Menu\McDSP\Uninstall McDSP - FutzBox v6.1.0.8.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1078 “C:\ProgramData\Microsoft\Windows\Start Menu\McDSP\Uninstall McDSP - ML4000 v6.1.0.8.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1079 “C:\ProgramData\Microsoft\Windows\Start Menu\McDSP\Uninstall McDSP - SA-2 Dialog Processor v6.1.0.8.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1080 “C:\ProgramData\Microsoft\Windows\Start Menu\MathewLane\Uninstall Mathew Lane - StereoDelta v1.1.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1081 “C:\ProgramData\Microsoft\Windows\Start Menu\Kush\Uninstall Kush - Electra-DSP v1.0.2.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1082 “C:\ProgramData\Microsoft\Windows\Start Menu\Kush\Uninstall Kush - Pusher v1.0.9.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1083 “C:\ProgramData\Microsoft\Windows\Start Menu\Kush\Uninstall Kush - Transformer Model A and N v1.0.4.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1084 “C:\ProgramData\Microsoft\Windows\Start Menu\Exponential Audio\Uninstall Excalibur v1.0.5.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1085 “C:\ProgramData\Microsoft\Windows\Start Menu\Exponential Audio\Uninstall PhoenixVerb Stereo Reverb v2.1.3.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1086 “C:\ProgramData\Microsoft\Windows\Start Menu\Eventide\Uninstall Eventide - Anthology X v1.0.4.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1087 “C:\ProgramData\Microsoft\Windows\Start Menu\Eventide\Uninstall Eventide - Blackhole v2.0.8.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1088 “C:\ProgramData\Microsoft\Windows\Start Menu\Eiosis\Uninstall Eiosis AirEQ Premium 1.1.1.3.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1089 “C:\ProgramData\Microsoft\Windows\Start Menu\Antares\Uninstall Antares - Auto-Tune v8.1.1.lnk” → [ “C:\ProgramData\AudioUTOPiA\Uninstall64.exe” ] (Method RN-S) (OK)
          [ OK ] 1092 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\SendTo\Fax Recipient.lnk” → [ “C:\WINDOWS\system32\WFS.exe” ] (Method RN-S) (OK)
          [ OK ] 1093 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\SendTo\TeamViewer.lnk” → [ “C:\Program Files (x86)\TeamViewer\TeamViewer.exe” ] (Method RN-S) (OK)
          [ OK ] 1094 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\04-1 - Network Connections.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1095 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\05 - Device Manager.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1096 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\06 - System.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1097 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\08 - Power Options.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1098 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\10 - Programs and Features.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1099 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group2\1 - Run.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1100 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group2\2 - Search.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1101 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group2\3 - Windows Explorer.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1102 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group2\5 - Task Manager.lnk” → [ “C:\Windows\System32\Taskmgr.exe” ] (Method RN-S) (OK)
          [ OK ] 1103 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group1\1 - Desktop.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1104 “C:\Users\SamSwanson\Desktop\Slack.lnk” → [ “C:\Users\SamSwanson\AppData\Local\slack\Update.ex e” ] (Method RN-S) (OK)
          [ OK ] 1105 “C:\Users\SamSwanson\AppData\Roaming\ZHP\Quarantin e\QuickTime\QuickTime\Uninstall QuickTime.lnk” → [ “C:\Windows\SysWOW64\msiexec.exe” ] (Method RN-S) (OK)
          [ OK ] 1108 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Slack Technologies\Slack.lnk” → [ “C:\Users\SamSwanson\AppData\Local\slack\Update.ex e” ] (Method RN-S) (OK)
          [ OK ] 1109 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Nomad Factory\Uninstall NF VST 64-bit Installer.lnk” → [ “C:\Program Files\Nomad Factory\uninstall_vst_64.exe” ] (Method RN-S) (OK)
          [ OK ] 1110 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Jack\Jack NetDriver.lnk” → [ “C:\Program Files (x86)\Jack\jackd.exe” ] (Method RN-S) (OK)
          [ OK ] 1111 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Jack\Jack PortAudio.lnk” → [ “C:\Program Files (x86)\Jack\jackd.exe” ] (Method RN-S) (OK)
          [ OK ] 1113 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Gizmo Central\Gizmo Manager.lnk” → [ “C:\Program Files (x86)\Gizmo\gizmo.exe” ] (Method RN-S) (OK)
          [ OK ] 1114 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Gizmo Central\Uninstall.lnk” → [ “C:\Program Files (x86)\Gizmo\gdirector.exe” ] (Method RN-S) (OK)
          [ OK ] 1116 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\SendTo\Fax Recipient.lnk” → [ “C:\Windows\System32\wfs.exe” ] (Method RN-S) (OK)
          [ OK ] 1117 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\SendTo\Skype.lnk” → [ “C:\Program Files (x86)\Skype\Phone\Skype.exe” ] (Method RN-S) (OK)
          [ OK ] 1118 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\SendTo\TeamViewer.lnk” → [ “C:\Program Files (x86)\TeamViewer\TeamViewer.exe” ] (Method RN-S) (OK)
          [ OK ] 1120 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\04-1 - Network Connections.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1121 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\05 - Device Manager.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1122 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\06 - System.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1123 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\08 - Power Options.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1124 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\10 - Programs and Features.lnk” → [ “C:\Windows\System32\control.exe” ] (Method RN-S) (OK)
          [ OK ] 1125 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group2\1 - Run.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1126 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group2\2 - Search.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1127 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group2\3 - Windows Explorer.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ OK ] 1128 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group2\5 - Task Manager.lnk” → [ “C:\Windows\System32\Taskmgr.exe” ] (Method RN-S) (OK)
          [ OK ] 1129 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group1\1 - Desktop.lnk” → [ “C:\Windows\explorer.exe” ] (Method RN-S) (OK)
          [ATTR] 33 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Immersive Control Panel.lnk” → [ “C:\Windows\System32\control.exe” ] (OK) (attribute system was removed)
          [ATTR] 41 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PrintDialog.lnk” → [ “C:\Windows\PrintDialog\PrintDialog.exe” ] (OK) (attribute system was removed)
          [DEL ] 8 “C:\ProgramData\Microsoft\Windows\Start Menu Places\08 - Homegroup.lnk” (target was not recovered)
          [DEL ] 9 “C:\ProgramData\Microsoft\Windows\Start Menu Places\09 - Network.lnk” (target was not recovered)
          [DEL ] 30 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Debut Video Capture Software.lnk” (target was not recovered)
          [DEL ] 34 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KD Niche Finder.lnk” (target was not recovered)
          [DEL ] 37 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MiracastView.lnk” (target was not recovered)
          [DEL ] 155 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\reFX\Nexus\Uninstall Nexus.lnk” (target was not recovered)
          [DEL ] 225 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Overloud\Mark Studio 2\Manual.lnk” (target was not recovered)
          [DEL ] 226 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Overloud\Mark Studio 2\Uninstall.lnk” (target was not recovered)
          [DEL ] 346 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Send to OneNote 2013.lnk” (target was not recovered)
          [DEL ] 350 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Office 2013 Tools\Office 2013 Language Preferences.lnk” (target was not recovered)
          [DEL ] 351 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Office 2013 Tools\Office 2013 Upload Center.lnk” (target was not recovered)
          [DEL ] 386 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KD Niche Finder\KD Niche Finder.lnk” (target was not recovered)
          [DEL ] 415 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\RX 5 Audio Editor\iZotope RX 5 Help PDF.lnk” (target was not recovered)
          [DEL ] 432 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Insight\Readme.lnk” (target was not recovered)
          [DEL ] 435 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\BreakTweaker Factory Content\Uninstall iZotope BreakTweaker Factory Content.lnk” (target was not recovered)
          [DEL ] 516 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Booster 4\Uninstall Driver Booster 4.lnk” (target was not recovered)
          [DEL ] 537 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\D16 Group\Repeater\Manual.lnk” (target was not recovered)
          [DEL ] 584 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Assault\Head Crusher\Head Crusher - Manual.lnk” (target was not recovered)
          [DEL ] 645 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\Command Prompt.lnk” (target was not recovered)
          [DEL ] 646 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\computer.lnk” (target was not recovered)
          [DEL ] 647 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\Control Panel.lnk” (target was not recovered)
          [DEL ] 648 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\File Explorer.lnk” (target was not recovered)
          [DEL ] 649 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\Run.lnk” (target was not recovered)
          [DEL ] 654 “C:\Users\Default\AppData\Roaming\Microsoft\Intern et Explorer\Quick Launch\Shows Desktop.lnk” (target was not recovered)
          [DEL ] 655 “C:\Users\Default\AppData\Roaming\Microsoft\Intern et Explorer\Quick Launch\Window Switcher.lnk” (target was not recovered)
          [DEL ] 656 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\01 - Command Prompt.lnk” (target was not recovered)
          [DEL ] 658 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\02 - Command Prompt.lnk” (target was not recovered)
          [DEL ] 686 “C:\Users\SamSwanson\Links\RecentPlaces.lnk” (target was not recovered)
          [DEL ] 718 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\SessionFiles.lnk” (target was not recovered)
          [DEL ] 755 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\Command Prompt.lnk” (target was not recovered)
          [DEL ] 756 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\computer.lnk” (target was not recovered)
          [DEL ] 757 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\Control Panel.lnk” (target was not recovered)
          [DEL ] 758 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\File Explorer.lnk” (target was not recovered)
          [DEL ] 759 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\Run.lnk” (target was not recovered)
          [DEL ] 784 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Overloud\REmatrix\REmatrix.lnk” (target was not recovered)
          [DEL ] 827 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Handbrake\Handbrake.lnk” (target was not recovered)
          [DEL ] 908 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Shows Desktop.lnk” (target was not recovered)
          [DEL ] 909 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Window Switcher.lnk” (target was not recovered)
          [DEL ] 911 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\User Pinned\TaskBar\File Explorer.lnk” (target was not recovered)
          [DEL ] 912 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\01 - Command Prompt.lnk” (target was not recovered)
          [DEL ] 914 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\02 - Command Prompt.lnk” (target was not recovered)
          [DEL ] 922 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.ZuneVideo_8wekyb3d8bbwe\Micros oft.ZuneVideo.lnk” (target was not recovered)
          [DEL ] 923 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.ZuneMusic_8wekyb3d8bbwe\Micros oft.ZuneMusic.lnk” (target was not recovered)
          [DEL ] 924 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.XboxLIVEGames_8wekyb3d8bbwe\Mi crosoft.XboxLIVEGames.lnk” (target was not recovered)
          [DEL ] 925 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\microsoft.windowsphotos_8wekyb3d8bbwe\Mi crosoft.WindowsLive.ModernPhotos.lnk” (target was not recovered)
          [DEL ] 926 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\microsoft.windowscommunicationsapps_8wek yb3d8bbwe\Microsoft.WindowsLive.Calendar.lnk” (target was not recovered)
          [DEL ] 927 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\microsoft.windowscommunicationsapps_8wek yb3d8bbwe\Microsoft.WindowsLive.Chat.lnk” (target was not recovered)
          [DEL ] 928 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\microsoft.windowscommunicationsapps_8wek yb3d8bbwe\Microsoft.WindowsLive.Mail.lnk” (target was not recovered)
          [DEL ] 929 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\microsoft.windowscommunicationsapps_8wek yb3d8bbwe\Microsoft.WindowsLive.People.lnk” (target was not recovered)
          [DEL ] 930 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.SkypeApp_kzf8qxf38zg5c\App.lnk ” (target was not recovered)
          [DEL ] 931 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.Reader_8wekyb3d8bbwe\Microsoft .Reader.lnk” (target was not recovered)
          [DEL ] 932 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\microsoft.microsoftskydrive_8wekyb3d8bbw e\Microsoft.MicrosoftSkyDrive.lnk” (target was not recovered)
          [DEL ] 933 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.Camera_8wekyb3d8bbwe\Microsoft .Camera.lnk” (target was not recovered)
          [DEL ] 934 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.Bing_8wekyb3d8bbwe\Microsoft.B ing.lnk” (target was not recovered)
          [DEL ] 935 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.BingWeather_8wekyb3d8bbwe\App. lnk” (target was not recovered)
          [DEL ] 936 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.BingTravel_8wekyb3d8bbwe\Appex Travel.lnk” (target was not recovered)
          [DEL ] 937 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.BingSports_8wekyb3d8bbwe\Appex Sports.lnk” (target was not recovered)
          [DEL ] 938 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.BingNews_8wekyb3d8bbwe\AppexNe ws.lnk” (target was not recovered)
          [DEL ] 939 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.BingMaps_8wekyb3d8bbwe\AppexMa ps.lnk” (target was not recovered)
          [DEL ] 940 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\Microsoft.BingFinance_8wekyb3d8bbwe\Appe xFinance.lnk” (target was not recovered)
          [DEL ] 941 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\KAYAK.com.KAYAKTravel_7wg9ew7ydej3j\App. lnk” (target was not recovered)
          [DEL ] 942 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\E97CB0A1.LogitechCameraController_wd885n sp30hay\LogiDeviceApp.App.lnk” (target was not recovered)
          [DEL ] 943 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\Application Shortcuts\BarnesNoble.Nook_ahnzqzva31enc\App.lnk” (target was not recovered)
          [DEL ] 1090 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\Default Apps.lnk” (target was not recovered)
          [DEL ] 1091 “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\Devices.lnk” (target was not recovered)
          [DEL ] 1106 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\Default Apps.lnk” (target was not recovered)
          [DEL ] 1107 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\Devices.lnk” (target was not recovered)
          [DEL ] 1131 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VersePerfect\Documentation.url”
          [DEL ] 1132 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VersePerfect\Updates.url”
          [DEL ] 1133 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VersePerfect\Links\Bryant McGill.url”
          [DEL ] 1134 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Revo Uninstaller\Revo Uninstaller on the Web.url”
          [DEL ] 1135 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Real Hide IP\Buy Real Hide IP.url”
          [DEL ] 1136 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Real Hide IP\Real Hide IP Site.url”
          [DEL ] 1137 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Rapid SEO Tool\Blumentals Software Web Site.url”
          [DEL ] 1138 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Massive\Native Instruments Homepage.url”
          [DEL ] 1139 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mp3tag\Mp3tag Website.url”
          [DEL ] 1140 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MeldaProduction\MTotalBundle64\MTota lBundle website.url”
          [DEL ] 1141 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MeldaProduction\MeldaProduction Audio Plugins\MeldaProduction website.url”
          [DEL ] 1142 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\Get Help.url”
          [DEL ] 1143 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\Visit Java.com.url”
          [DEL ] 1144 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DisplayFusion\DisplayFusion on the Web.url”
          [DEL ] 1145 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner\CCleaner Homepage.url”
          [DEL ] 1146 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management\Get Involved.url”
          [DEL ] 1147 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management\User Manual.url”
          [DEL ] 1148 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\User’s guide.url”
          [DEL ] 1149 “C:\Users\SamSwanson\Favorites\Bing.url”
          [DEL ] 1150 “C:\Users\SamSwanson\Favorites\The NeoSmart Files.url”
          [DEL ] 1151 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\UNFILTER VST-x64 1.2.1\Web Page.url”
          [DEL ] 1152 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\UNCHIRP VST-x64 1.0.0\UNCHIRP VST Web Page.url”
          [DEL ] 1153 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\PITCHMAP VST-x64 1.6.1\Web Page.url”
          [DEL ] 1154 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\The KMPlayer\KMPlayer Home Page.url”
          [DEL ] 1155 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sugar Bytes\Sugar Bytes Website.url”
          [DEL ] 1156 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sample Magic\Magic AB VST-x64 1.2.2\Web Page.url”
          [DEL ] 1157 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Native Instruments Homepage.url”
          [DEL ] 1158 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Maxthon Cloud Browser\Visit Maxthon Forum.url”
          [DEL ] 1159 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\East West Stormdrum Intakt\Native Instruments Homepage.url”
          [DEL ] 1160 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Dropbox\Dropbox Website.URL”
          [SKIP] 40 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nitro Pro 8.lnk → C:\Windows\Installer{47B42E7A-57E9-407B-8DBB-017B86D7B13F}\Professional.ico” (shortcut was not found)
          [SKIP] 49 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR\Console RAR manual.lnk → C:\Program Files\WinRAR\Rar.txt” (shortcut was not found)
          [SKIP] 50 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR\What is new in the latest version.lnk → C:\Program Files\WinRAR\WhatsNew.txt” (shortcut was not found)
          [SKIP] 72 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\Homepage.lnk → C:\Program Files\Virtual Audio Cable\homepage.url” (shortcut was not found)
          [SKIP] 73 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\License Agreement.lnk → C:\Program Files\Virtual Audio Cable\license.txt” (shortcut was not found)
          [SKIP] 74 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\Readme.lnk → C:\Program Files\Virtual Audio Cable\readme.txt” (shortcut was not found)
          [SKIP] 76 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\Documentation.lnk → C:\Program Files (x86)\VideoLAN\VLC\Documentation.url” (shortcut was not found)
          [SKIP] 77 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\Release Notes.lnk → C:\Program Files (x86)\VideoLAN\VLC\NEWS.txt” (shortcut was not found)
          [SKIP] 78 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VideoLAN Website.lnk → C:\Program Files (x86)\VideoLAN\VLC\VideoLAN Website.url” (shortcut was not found)
          [SKIP] 82 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VB Audio\ASIO Bridge\Readme.LNK → C:\Program Files (x86)\VB\ASIOBridge\readme.txt” (shortcut was not found)
          [SKIP] 84 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Unibrain ubCore\Documentation\ChangeLog.lnk → C:\Program Files\Unibrain\ubCore\Readme.txt” (shortcut was not found)
          [SKIP] 86 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe\How to register.lnk → C:\Program Files (x86)\UnHackMe\order.txt” (shortcut was not found)
          [SKIP] 87 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe\Read me.lnk → C:\Program Files (x86)\UnHackMe\readme.txt” (shortcut was not found)
          [SKIP] 103 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeraCopy\TeraCopy on the Web.lnk → C:\Program Files\TeraCopy\TeraCopy.url” (shortcut was not found)
          [SKIP] 115 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TC Electronic\M30 Reverb\License.lnk → C:\Program Files (x86)\TC Electronic\M30 Reverb\Native\TCE_License.txt” (shortcut was not found)
          [SKIP] 121 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Steam\Steam Support Center.lnk → C:\Windows\Installer{048298C9-A4D3-490B-9FF9-AB023A9238F3}\Icon048298C92.url” (shortcut was not found)
          [SKIP] 123 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp\Snagit 11.lnk” (shortcut was not found)
          [SKIP] 158 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\REAPER License and User Agreement.lnk → C:\Program Files\REAPER (x64)\license.txt” (shortcut was not found)
          [SKIP] 160 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\Whatsnew.txt.lnk → C:\Program Files\REAPER (x64)\whatsnew.txt” (shortcut was not found)
          [SKIP] 163 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Xenon\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP Xenon\EULA.txt” (shortcut was not found)
          [SKIP] 165 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Xenon\PSP Xenon Version History.lnk → C:\Program Files\PSPaudioware\PSP Xenon\PSP Xenon Version History.txt” (shortcut was not found)
          [SKIP] 167 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP SpringBox 64bit\End User License Agreement.lnk → C:\Program Files\VSTPlugIns\PSP SpringBox\EULA.txt” (shortcut was not found)
          [SKIP] 169 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP SpringBox 64bit\PSP SpringBox Version History.lnk → C:\Program Files\VSTPlugIns\PSP SpringBox\PSP SpringBox Version History.txt” (shortcut was not found)
          [SKIP] 171 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP PianoVerb2 64bit\End User License Agreement.lnk → C:\Program Files\VSTPlugIns\PSP PianoVerb2\EULA.txt” (shortcut was not found)
          [SKIP] 173 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP PianoVerb2 64bit\PSP PianoVerb2 Version History.lnk → C:\Program Files\VSTPlugIns\PSP PianoVerb2\PSP PianoVerb2 Version History.txt” (shortcut was not found)
          [SKIP] 175 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP oldTimer 64bit\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP oldTimer 64bit\EULA.txt” (shortcut was not found)
          [SKIP] 177 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP oldTimer 64bit\PSP oldTimer Version History.lnk → C:\Program Files\PSPaudioware\PSP oldTimer 64bit\PSP oldTimer Version History.txt” (shortcut was not found)
          [SKIP] 180 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP NobleQ 64bit\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP NobleQ 64bit\EULA.txt” (shortcut was not found)
          [SKIP] 182 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP NobleQ 64bit\PSP NobleQ Version History.lnk → C:\Program Files\PSPaudioware\PSP NobleQ 64bit\PSP NobleQ Version History.txt” (shortcut was not found)
          [SKIP] 184 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Neon 64bit\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP Neon 64bit\EULA.txt” (shortcut was not found)
          [SKIP] 186 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Neon 64bit\PSP Neon Version History.lnk → C:\Program Files\PSPaudioware\PSP Neon 64bit\PSP Neon Version History.txt” (shortcut was not found)
          [SKIP] 188 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP McQ 64bit\End User License Agreement.lnk → C:\Program Files\VSTPlugIns\PSP McQ\EULA.txt” (shortcut was not found)
          [SKIP] 190 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP McQ 64bit\PSP McQ Version History.lnk → C:\Program Files\VSTPlugIns\PSP McQ\PSP McQ Version History.txt” (shortcut was not found)
          [SKIP] 192 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP MasterComp\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP MasterComp\EULA.txt” (shortcut was not found)
          [SKIP] 194 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP MasterComp\PSP MasterComp Version History.lnk → C:\Program Files\PSPaudioware\PSP MasterComp\PSP MasterComp Version History.txt” (shortcut was not found)
          [SKIP] 196 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Echo 64bit\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP Echo 64bit\EULA.txt” (shortcut was not found)
          [SKIP] 198 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Echo 64bit\PSP Echo Version History.lnk → C:\Program Files\PSPaudioware\PSP Echo 64bit\PSP Echo Version History.txt” (shortcut was not found)
          [SKIP] 200 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP BussPressor 64bit\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP BussPressor 64bit\EULA.txt” (shortcut was not found)
          [SKIP] 202 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP BussPressor 64bit\PSP BussPressor Version History.lnk → C:\Program Files\PSPaudioware\PSP BussPressor 64bit\PSP BussPressor Version History.txt” (shortcut was not found)
          [SKIP] 204 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 85 64bit\End User License Agreement.lnk → C:\Program Files\VSTPlugIns\PSP 85\EULA.txt” (shortcut was not found)
          [SKIP] 206 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 85 64bit\PSP 85 Version History.lnk → C:\Program Files\VSTPlugIns\PSP 85\PSP 85 Version History.txt” (shortcut was not found)
          [SKIP] 208 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 608 MultiDelay 64bit\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP 608 MultiDelay 64bit\EULA.txt” (shortcut was not found)
          [SKIP] 210 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 608 MultiDelay 64bit\PSP 608 MultiDelay Version History.lnk → C:\Program Files\PSPaudioware\PSP 608 MultiDelay 64bit\PSP 608 MultiDelay Version History.txt” (shortcut was not found)
          [SKIP] 212 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 2Meters 64bit\End User License Agreement.lnk → C:\Program Files\PSPaudioware\PSP 2Meters 64bit\EULA.txt” (shortcut was not found)
          [SKIP] 214 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 2Meters 64bit\PSP 2Meters Version History.lnk → C:\Program Files\PSPaudioware\PSP 2Meters 64bit\PSP 2Meters Version History.txt” (shortcut was not found)
          [SKIP] 216 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\Lexicon PSP 42 64bit\End User License Agreement.lnk → C:\Program Files\VSTPlugIns\EULA.txt” (shortcut was not found)
          [SKIP] 218 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\Lexicon PSP 42 64bit\Lexicon PSP42 Version History.lnk → C:\Program Files\VSTPlugIns\Lexicon PSP42 Version History.txt” (shortcut was not found)
          [SKIP] 223 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Plogue\chipsounds\Online Support.lnk → C:\Program Files\Plogue\chipsounds\PlogueOnlineSupport.url” (shortcut was not found)
          [SKIP] 229 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Visualizer1_9\NuGen Audio web-site.lnk → C:\Program Files (x86)\NuGen Audio\Visualizer1_9\Internet shortcut.url” (shortcut was not found)
          [SKIP] 233 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\VisLM\NUGEN Audio web-site.lnk → C:\Program Files\NUGEN Audio\VisLM\Internet shortcut.url” (shortcut was not found)
          [SKIP] 237 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoplacer3\NUGEN Audio web-site.lnk → C:\Program Files\NUGEN Audio\Stereoplacer3\Internet shortcut.url” (shortcut was not found)
          [SKIP] 241 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoizer3\NUGEN Audio web-site.lnk → C:\Program Files\NUGEN Audio\Stereoizer3\Internet shortcut.url” (shortcut was not found)
          [SKIP] 244 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ2 Master\NuGen Audio web-site.lnk → C:\Program Files (x86)\NuGen Audio\SEQ2 Master\Internet shortcut.url” (shortcut was not found)
          [SKIP] 247 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ1 Master\NuGen Audio web-site.lnk → C:\Program Files (x86)\NuGen Audio\SEQ1 Master\Internet shortcut.url” (shortcut was not found)
          [SKIP] 251 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ-S\NUGEN Audio web-site.lnk → C:\Program Files\NUGEN Audio\SEQ-S\Internet shortcut.url” (shortcut was not found)
          [SKIP] 256 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Monofilter4\NUGEN Audio web-site.lnk → C:\Program Files\NUGEN Audio\Monofilter4\Internet shortcut.url” (shortcut was not found)
          [SKIP] 259 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\ISL\NUGEN Audio web-site.lnk → C:\Program Files\NUGEN Audio\ISL\Internet shortcut.url” (shortcut was not found)
          [SKIP] 265 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Massive\Documentation\Readme.txt.lnk → C:\Program Files (x86)\Native Instruments\Massive\Documentation\Readme.txt” (shortcut was not found)
          [SKIP] 267 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Readme.txt.lnk → C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Readme.txt” (shortcut was not found)
          [SKIP] 280 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Documentation\Readme.txt.lnk → C:\Program Files\Native Instruments\Service Center\Documentation\Readme.txt” (shortcut was not found)
          [SKIP] 290 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Guitar Rig 5\Documentation\Readme.txt.lnk → C:\Program Files\Native Instruments\Guitar Rig 5\Documentation\Readme.txt” (shortcut was not found)
          [SKIP] 308 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\Readme.txt.lnk → C:\Program Files\Native Instruments\FM8\Documentation\Readme.txt” (shortcut was not found)
          [SKIP] 316 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Documentation\Readme.txt.lnk → C:\Program Files\Native Instruments\Controller Editor\Documentation\Readme.txt” (shortcut was not found)
          [SKIP] 325 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Documentation\Readme.txt.lnk → C:\Program Files\Native Instruments\Absynth 5\Documentation\Readme.txt” (shortcut was not found)
          [SKIP] 329 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mp3tag\Version history.lnk → C:\Program Files (x86)\Mp3tag\Mp3tagVersion.txt” (shortcut was not found)
          [SKIP] 332 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUCjr\Changelog.lnk → C:\Program Files\Klanghelm\MJUCjr\changelog.txt” (shortcut was not found)
          [SKIP] 335 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUC\Changelog.lnk → C:\Program Files\Klanghelm\MJUC\changelog.txt” (shortcut was not found)
          [SKIP] 368 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\M-Audio\Oxygen\ReadMe.txt.lnk → C:\Program Files\M-Audio\Oxygen\ReadMe.txt” (shortcut was not found)
          [SKIP] 379 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Link-AssistantCom\Links\Link-AssistantCom Home Page.lnk → C:\Program Files (x86)\Link-AssistantCom\SEO PowerSuite.url” (shortcut was not found)
          [SKIP] 380 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Link-AssistantCom\Links\Link-AssistantCom Support.lnk → C:\Program Files (x86)\Link-AssistantCom\SEO PowerSuite Support.url” (shortcut was not found)
          [SKIP] 407 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Vinyl\ Visit iZotope.lnk → C:\Program Files (x86)\VSTPlugIns\Vinyl\izotope.url” (shortcut was not found)
          [SKIP] 412 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Trash 2\Visit iZotope.lnk → C:\Program Files\VSTPlugIns\Trash 2\izotope.url” (shortcut was not found)
          [SKIP] 418 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\RX 5 Audio Editor\Visit iZotope.lnk → C:\Program Files (x86)\iZotope\RX 5 Audio Editor\izotope.url” (shortcut was not found)
          [SKIP] 426 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 6\Visit iZotope.lnk → C:\Program Files (x86)\iZotope\Ozone 6\izotope.url” (shortcut was not found)
          [SKIP] 430 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Nectar 2\Visit iZotope.lnk → C:\Program Files (x86)\iZotope\Nectar 2\izotope.url” (shortcut was not found)
          [SKIP] 434 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Insight\Visit iZotope.lnk → C:\Program Files (x86)\iZotope\Insight\izotope.url” (shortcut was not found)
          [SKIP] 438 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\BreakTweaker\Visit iZotope.lnk → C:\Program Files (x86)\iZotope\BreakTweaker\izotope.url” (shortcut was not found)
          [SKIP] 439 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IVGI\Changelog.lnk → C:\VSTPlugIns\IVGI\changelog.txt” (shortcut was not found)
          [SKIP] 488 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HFSExplorer\Developer Web Site.lnk → C:\Program Files (x86)\HFSExplorer\HFSExplorer.url” (shortcut was not found)
          [SKIP] 507 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Folder Marker\Go To Folder Marker’s Website.lnk → C:\Program Files (x86)\Folder Marker\FolderMarkerWebsite.url” (shortcut was not found)
          [SKIP] 572 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid\Mbox\ReadMe.txt.lnk → C:\Program Files\Avid\Mbox\ReadMe.txt” (shortcut was not found)
          [SKIP] 583 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Troubleshooting\Altiverb 6 LOG.lnk → C:\Users\SamSwanson\AppData\Roaming\Audio Ease\Altiverb 6.log” (shortcut was not found)
          [SKIP] 619 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\Bootable Rescue Media Builder.lnk” (shortcut was not found)
          [SKIP] 708 “C:\Users\SamSwanson\AppData\Roaming\ZHP\Quarantin e\QuickTime\QuickTime\About QuickTime.lnk → C:\Windows\Installer{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A}\RichText.ico” (shortcut was not found)
          [SKIP] 709 “C:\Users\SamSwanson\AppData\Roaming\ZHP\Quarantin e\QuickTime\QuickTime\PictureViewer.lnk → C:\Windows\Installer{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A}\PictureViewer.ico” (shortcut was not found)
          [SKIP] 710 “C:\Users\SamSwanson\AppData\Roaming\ZHP\Quarantin e\QuickTime\QuickTime\QuickTime Player.lnk → C:\Windows\Installer{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A}\QTPlayer.ico” (shortcut was not found)
          [SKIP] 731 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\WinRAR\Console RAR manual.lnk → C:\Program Files\WinRAR\Rar.txt” (shortcut was not found)
          [SKIP] 732 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\WinRAR\What is new in the latest version.lnk → C:\Program Files\WinRAR\WhatsNew.txt” (shortcut was not found)
          [SKIP] 745 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\VB Audio\ASIO Bridge\Readme.LNK → C:\Program Files (x86)\VB\ASIOBridge\readme.txt” (shortcut was not found)
          [SKIP] 766 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Startup\SpeedFan.lnk” (shortcut was not found)
          [SKIP] 806 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Kindle DRM Removal\Readme.lnk → C:\Program Files (x86)\eBookConverter\Kindle DRM Removal\Readme.txt” (shortcut was not found)
          [SKIP] 883 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\BWF MetaEdit\History.lnk → C:\Program Files\BWF MetaEdit\History.txt” (shortcut was not found)
          [SKIP] 885 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\BWF MetaEdit\Website.lnk → C:\Program Files\BWF MetaEdit\BWF MetaEdit.url” (shortcut was not found)
          [SKIP] 888 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\ASIO4ALL v2\ASIO4ALL Web Site.lnk → C:\Program Files (x86)\ASIO4ALL v2\ASIO4ALL Web Site.url” (shortcut was not found)
          [SKIP] 966 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp\SoftEther VPN Client Manager Startup.lnk” (shortcut was not found)
          [WARN] 1 “C:\ProgramData\Spectrasonics\STEAM.lnk” → [ “S:\More VSTI\Spectrasonics.Omnisphere.2.DVDR.D1\STEAM\STEA M” ] (already cured)
          [WARN] 3 “C:\ProgramData\Microsoft\Windows\Start Menu Places\03 - Documents.lnk” → [ “C:\Users\SamSwanson\Documents” ] (already cured)
          [WARN] 4 “C:\ProgramData\Microsoft\Windows\Start Menu Places\04 - Downloads.lnk” → [ “C:\Users\SamSwanson\Downloads” ] (already cured)
          [WARN] 5 “C:\ProgramData\Microsoft\Windows\Start Menu Places\05 - Music.lnk” → [ “C:\Users\SamSwanson\Music” ] (already cured)
          [WARN] 6 “C:\ProgramData\Microsoft\Windows\Start Menu Places\06 - Pictures.lnk” → [ “C:\Users\SamSwanson\Pictures” ] (already cured)
          [WARN] 7 “C:\ProgramData\Microsoft\Windows\Start Menu Places\07 - Videos.lnk” → [ “C:\Users\SamSwanson\Videos” ] (already cured)
          [WARN] 10 “C:\ProgramData\Microsoft\Windows\Start Menu Places\10 - UserProfile.lnk” → [ “C:\Users\SamSwanson” ] (already cured)
          [WARN] 12 “C:\ProgramData\Microsoft\Windows\Start Menu\Rhyme Genie.lnk” → [ “C:\Program Files (x86)\Idolumic\Rhyme Genie\Rhyme Genie.exe” ] (already cured)
          [WARN] 13 “C:\ProgramData\Microsoft\Windows\Start Menu\SoftEther VPN Client Manager.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe” ] (already cured)
          [WARN] 14 “C:\ProgramData\Microsoft\Windows\Start Menu\TuneSmith.lnk” → [ “C:\Program Files (x86)\Idolumic\TuneSmith\TuneSmith.exe” ] (already cured)
          [WARN] 15 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis True Image.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageLauncher.exe” ] (already cured)
          [WARN] 16 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe After Effects CS4.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe After Effects CS4\Support Files\AfterFX.exe” ] (already cured)
          [WARN] 17 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Bridge CS5.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Bridge CS5\Bridge.exe” ] (already cured)
          [WARN] 18 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Device Central CS5.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Device Central CS5\DeviceCentral.exe” ] (already cured)
          [WARN] 19 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe ExtendScript Toolkit CS4.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Utilities\ExtendScript Toolkit CS4\ExtendScript Toolkit.exe” ] (already cured)
          [WARN] 20 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe ExtendScript Toolkit CS5.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Utilities - CS5\ExtendScript Toolkit CS5\ExtendScript Toolkit.exe” ] (already cured)
          [WARN] 21 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Extension Manager CS4.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Extension Manager CS4\Adobe Extension Manager CS4.exe” ] (already cured)
          [WARN] 22 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Extension Manager CS5.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Extension Manager CS5\Adobe Extension Manager CS5.exe” ] (already cured)
          [WARN] 23 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Media Encoder CS4.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Media Encoder CS4\Adobe Media Encoder.exe” ] (already cured)
          [WARN] 24 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Photoshop CS5 (64 Bit).lnk” → [ “C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Photoshop.exe” ] (already cured)
          [WARN] 25 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Photoshop Lightroom 5 64-bit.lnk” → [ “C:\Program Files\Adobe\Adobe Photoshop Lightroom 5\lightroom.exe” ] (already cured)
          [WARN] 26 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Pixel Bender Toolkit.lnk” → [ “C:\Program Files (x86)\Adobe\Adobe Utilities\Pixel Bender Toolkit\pixel_bender_toolkit.exe” ] (already cured)
          [WARN] 27 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AmpegSVX.lnk” → [ “C:\Program Files\VSTPlugIns\AmpegSVX.exe” ] (already cured)
          [WARN] 28 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Apple Software Update.lnk” → [ “C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe” ] (already cured)
          [WARN] 29 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\atomiccleaner3.lnk” → [ “C:\Program Files (x86)\atomicware\atomiccleaner3\atomiccleaner3.exe ” ] (already cured)
          [WARN] 31 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk” → [ “C:\Program Files (x86)\Google\Chrome\Application\chrome.exe” ] (already cured)
          [WARN] 32 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iLok License Manager.lnk” → [ “C:\Program Files (x86)\iLok License Manager\iLok License Manager.exe” ] (already cured)
          [WARN] 35 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Market Samurai.lnk” → [ “C:\Program Files (x86)\Market Samurai\Market Samurai.exe” ] (already cured)
          [WARN] 36 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Web Platform Installer.lnk” → [ “C:\Program Files\Microsoft\Web Platform Installer\WebPlatformInstaller.exe” ] (already cured)
          [WARN] 38 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox.lnk” → [ “C:\Program Files (x86)\Mozilla Firefox\firefox.exe” ] (already cured)
          [WARN] 39 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MusicBrainz Picard.lnk” → [ “C:\Program Files (x86)\MusicBrainz Picard\picard.exe” ] (already cured)
          [WARN] 42 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamViewer 12.lnk” → [ “C:\Program Files (x86)\TeamViewer\TeamViewer.exe” ] (already cured)
          [WARN] 43 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tracker.lnk” → [ “C:\Program Files (x86)\Tracker\Tracker.exe” ] (already cured)
          [WARN] 44 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows 10 Upgrade Assistant.lnk” → [ “C:\Windows10Upgrade\Windows10UpgraderApp.exe” ] (already cured)
          [WARN] 45 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zynaptiq\ADAPTIVERB\Manual.lnk” → [ “C:\Program Files\Zynaptiq\ADAPTIVERB\Zynaptiq ADAPTIVERB Manual.pdf” ] (already cured)
          [WARN] 46 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zynaptiq\ADAPTIVERB\Uninstall.lnk” → [ “C:\Program Files\Zynaptiq\ADAPTIVERB\unins000.exe” ] (already cured)
          [WARN] 48 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinZip\WinZip 18.0.lnk” → [ “C:\Program Files\WinZip\WINZIP64.EXE” ] (already cured)
          [WARN] 51 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR\WinRAR help.lnk” → [ “C:\Program Files\WinRAR\WinRAR.chm” ] (already cured)
          [WARN] 52 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR\WinRAR.lnk” → [ “C:\Program Files\WinRAR\WinRAR.exe” ] (already cured)
          [WARN] 53 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Kits\Windows Performance Toolkit\GPUView Help.lnk” → [ “C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit\gpuview\GPUView.chm” ] (already cured)
          [WARN] 54 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Kits\Windows Performance Toolkit\GPUView.lnk” → [ “C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit\gpuview\GPUView.exe” ] (already cured)
          [WARN] 55 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Kits\Windows Performance Toolkit\Windows Performance Analyzer.lnk” → [ “C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit\wpa.exe” ] (already cured)
          [WARN] 56 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Kits\Windows Performance Toolkit\Windows Performance Recorder.lnk” → [ “C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit\WPRUI.exe” ] (already cured)
          [WARN] 57 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Webcam\Webcam videocap.lnk” → [ “C:\Program Files (x86)\ETRON\Webcam\x86\VideoCap.exe” ] (already cured)
          [WARN] 58 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\CODEX.lnk” → [ “C:\Program Files (x86)\Waves\Applications\CODEX App.exe” ] (already cured)
          [WARN] 59 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\Electric200.lnk” → [ “C:\Program Files (x86)\Waves\Applications\Electric200 App.exe” ] (already cured)
          [WARN] 60 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\Electric88.lnk” → [ “C:\Program Files (x86)\Waves\Applications\Electric88 App.exe” ] (already cured)
          [WARN] 61 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\Element.lnk” → [ “C:\Program Files (x86)\Waves\Applications\Element App.exe” ] (already cured)
          [WARN] 62 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\eMotion LV1.lnk” → [ “C:\Program Files (x86)\Waves\eMotion LV1\eMotion LV1.exe” ] (already cured)
          [WARN] 63 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\GTR 3.5.lnk” → [ “C:\Program Files (x86)\Waves\Applications\GTR 3.5.exe” ] (already cured)
          [WARN] 64 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\GTRSolo 3.5.lnk” → [ “C:\Program Files (x86)\Waves\Applications\GTRSolo 3.5.exe” ] (already cured)
          [WARN] 65 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\MultiRack SoundGrid.lnk” → [ “C:\Program Files (x86)\Waves\MultiRack\MultiRack SoundGrid.exe” ] (already cured)
          [WARN] 66 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\MultiRack.lnk” → [ “C:\Program Files (x86)\Waves\MultiRack\MultiRack.exe” ] (already cured)
          [WARN] 67 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\SoundGrid Studio.lnk” → [ “C:\Program Files (x86)\Waves\SoundGrid Studio\SoundGrid Studio.exe” ] (already cured)
          [WARN] 68 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves\Uninstall.lnk” → [ “C:\Program Files (x86)\Waves\unins000.exe” ] (already cured)
          [WARN] 69 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\Audio Repeater (KS).lnk” → [ “C:\Program Files\Virtual Audio Cable\audiorepeater_ks.exe” ] (already cured)
          [WARN] 70 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\Audio Repeater (MME).lnk” → [ “C:\Program Files\Virtual Audio Cable\audiorepeater.exe” ] (already cured)
          [WARN] 71 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\Control panel.lnk” → [ “C:\Program Files\Virtual Audio Cable\vcctlpan.exe” ] (already cured)
          [WARN] 75 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable\User manual.lnk” → [ “C:\Program Files\Virtual Audio Cable\vac.chm” ] (already cured)
          [WARN] 79 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VLC media player.lnk” → [ “C:\Program Files (x86)\VideoLAN\VLC\vlc.exe” ] (already cured)
          [WARN] 80 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VersePerfect\Verse Perfect.lnk” → [ “C:\Program Files (x86)\VersePerfect\VersePerfect.exe” ] (already cured)
          [WARN] 81 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VB Audio\ASIO Bridge\ASIO Bridge.LNK” → [ “C:\Program Files (x86)\VB\ASIOBridge\VBCABLE_AsioBridge.exe” ] (already cured)
          [WARN] 83 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Unibrain ubCore\ubSwitch.lnk” → [ “C:\Program Files\Unibrain\ubCore\Tools\ubSwitch.exe” ] (already cured)
          [WARN] 85 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Unibrain ubCore\Documentation\ubCore Manual.lnk” → [ “C:\Program Files\Unibrain\ubCore\ubCore5_Manual.pdf” ] (already cured)
          [WARN] 88 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe\Reanimator.lnk” → [ “C:\Program Files (x86)\UnHackMe\reanimator.exe” ] (already cured)
          [WARN] 89 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe\Start UnHackMe.lnk” → [ “C:\Program Files (x86)\UnHackMe\Unhackme.exe” ] (already cured)
          [WARN] 90 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe\UnHackMe Monitor.lnk” → [ “C:\Program Files (x86)\UnHackMe\hackmon.exe” ] (already cured)
          [WARN] 91 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe\Uninstall UnHackMe.lnk” → [ “C:\Program Files (x86)\UnHackMe\unins000.exe” ] (already cured)
          [WARN] 92 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UAD Powered Plug-Ins\Documentation.lnk” → [ “C:\Program Files (x86)\Universal Audio\Powered Plugins\Documentation” ] (already cured)
          [WARN] 93 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UAD Powered Plug-Ins\Readme.lnk” → [ “C:\Program Files (x86)\Universal Audio\Powered Plugins\ReadMe.rtf” ] (already cured)
          [WARN] 94 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UAD Powered Plug-Ins\UAD Meter & Control Panel.lnk” → [ “C:\Program Files (x86)\Universal Audio\Powered Plugins\UADPerfMon.exe” ] (already cured)
          [WARN] 95 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tweaking.com\Windows Repair (All in One)\Open Windows Repair (WR) Tray Icon.lnk” → [ “C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\WR_Tray_Icon.exe” ] (already cured)
          [WARN] 96 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tweaking.com\Windows Repair (All in One)\Tweaking.com - Registry Backup.lnk” → [ “C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\files\registry_backup_tool\TweakingRegistryBa ckup.exe” ] (already cured)
          [WARN] 97 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tweaking.com\Windows Repair (All in One)\Tweaking.com - Windows Repair.lnk” → [ “C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\Repair_Windows.exe” ] (already cured)
          [WARN] 98 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tradeo - MetaTrader 4\MetaEditor.lnk” → [ “C:\Program Files (x86)\Tradeo - MetaTrader 4\metaeditor.exe” ] (already cured)
          [WARN] 100 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tradeo - MetaTrader 4\Uninstall.lnk” → [ “C:\Program Files (x86)\Tradeo - MetaTrader 4\uninstall.exe” ] (already cured)
          [WARN] 101 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ToneBoosters\Morphit\Uninstall.lnk” → [ “C:\Program Files\ToneBoosters\Morphit\unins000.exe” ] (already cured)
          [WARN] 102 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeraCopy\TeraCopy Help.lnk” → [ “C:\Program Files\TeraCopy\TeraCopy Help.chm” ] (already cured)
          [WARN] 104 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeraCopy\TeraCopy.lnk” → [ “C:\Program Files\TeraCopy\TeraCopy.exe” ] (already cured)
          [WARN] 105 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeraCopy\Uninstall TeraCopy.lnk” → [ “C:\Program Files\TeraCopy\unins000.exe” ] (already cured)
          [WARN] 106 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Telestream\Wirecast\Support Assistant.lnk” → [ “C:\Program Files\Telestream\Wirecast\SupportAssistant\Wirecas tSupportAssistant.exe” ] (already cured)
          [WARN] 107 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Telestream\Wirecast\Tutorial.lnk” → [ “C:\Program Files\Telestream\Wirecast\rsrc\tutorial\intro_welc ome.html” ] (already cured)
          [WARN] 108 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Telestream\Wirecast\Wirecast.lnk” → [ “C:\Program Files\Telestream\Wirecast\Wirecast.exe” ] (already cured)
          [WARN] 109 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Telestream\Wirecast\Scripting\Docume ntation.lnk” → [ “C:\Program Files\Telestream\Wirecast\rsrc\scriptdocs\index.ht ml” ] (already cured)
          [WARN] 110 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Telestream\Wirecast\Scripting\Exampl es.lnk” → [ “C:\Program Files\Telestream\Wirecast\rsrc\scriptingexamples” ] (already cured)
          [WARN] 111 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TechSmith\Camtasia Recorder 8.lnk” → [ “C:\Program Files (x86)\TechSmith\Camtasia Studio 8\CamRecorder.exe” ] (already cured)
          [WARN] 112 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TechSmith\Camtasia Studio 8.lnk” → [ “C:\Program Files (x86)\TechSmith\Camtasia Studio 8\CamtasiaStudio.exe” ] (already cured)
          [WARN] 113 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TechSmith\Snagit 11 Editor.lnk” → [ “C:\Program Files (x86)\TechSmith\Snagit 11\SnagitEditor.exe” ] (already cured)
          [WARN] 114 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TechSmith\Snagit 11.lnk” → [ “C:\Program Files (x86)\TechSmith\Snagit 11\Snagit32.exe” ] (already cured)
          [WARN] 116 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TC Electronic\M30 Reverb\Uninstall.lnk” → [ “C:\Program Files (x86)\TC Electronic\M30 Reverb\Native\Uninstall\Uninstall.exe” ] (already cured)
          [WARN] 117 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tag&Rename\Tag&Rename help.lnk” → [ “C:\Program Files (x86)\TagRename\TagRename.chm” ] (already cured)
          [WARN] 118 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tag&Rename\Tag&Rename.lnk” → [ “C:\Program Files (x86)\TagRename\TagRename.exe” ] (already cured)
          [WARN] 120 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Suite Spot Studios\AATranslator\AATranslator.lnk” → [ “C:\Program Files (x86)\Suite Spot Studios\AATranslator\AATranslator.exe” ] (already cured)
          [WARN] 122 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Steam\Steam.lnk” → [ “C:\Program Files (x86)\Steam\Steam.exe” ] (already cured)
          [WARN] 124 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SSDlife\SSDlife Pro.lnk” → [ “C:\Program Files (x86)\BinarySense\SSDlife\ssdlife.exe” ] (already cured)
          [WARN] 125 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SONiVOX\SONiVOX VocalizerPro\Uninstall VocalizerPro.lnk” → [ “C:\ProgramData\SONiVOX\VocalizerPro\unins000.exe” ] (already cured)
          [WARN] 126 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonarworks\Sonarworks\License agreement.lnk” → [ “C:\Program Files (x86)\Sonarworks\Sonarworks HD reference\License_agreement_sonarworks.pdf” ] (already cured)
          [WARN] 127 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonarworks\Sonarworks\Sonarworks HD reference Help.lnk” → [ “C:\Program Files (x86)\Sonarworks\Sonarworks HD reference\sonarworks.chm” ] (already cured)
          [WARN] 130 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonalksis\Sonalksis Plugin Manager.lnk” → [ “C:\Program Files (x86)\Sonalksis\Sonalksis Plugin Manager.exe” ] (already cured)
          [WARN] 131 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\SoftEther VPN Client Manager.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpncmgr_x64.exe” ] (already cured)
          [WARN] 132 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\SoftEther VPN Command Line Utility (vpncmd).lnk” → [ “C:\Program Files\SoftEther VPN Client\vpncmd_x64.exe” ] (already cured)
          [WARN] 133 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Configuration Tools\Services Running on this Computer.lnk” → [ “C:\Windows\System32\services.msc” ] (already cured)
          [WARN] 134 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Configuration Tools\Uninstall SoftEther VPN Client.lnk” → [ “C:\Program Files\SoftEther VPN Client\vpnsetup.exe” ] (already cured)
          [WARN] 135 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\Virtual Tape Machines\Uninstall Virtual Tape Machines.lnk” → [ “C:\Program Files\Slate Digital\Virtual Tape Machines\unins000.exe” ] (already cured)
          [WARN] 136 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\Virtual Tape Machines\Virtual Tape Machines User Guide.lnk” → [ “C:\ProgramData\Slate Digital\Virtual Tape Machines\Slate Digital Virtual Tape Machines - User Guide.pdf” ] (already cured)
          [WARN] 137 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\Virtual Buss Compressors\Uninstall Virtual Buss Compressors.lnk” → [ “C:\Program Files\Slate Digital\Virtual Buss Compressors\unins000.exe” ] (already cured)
          [WARN] 138 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\Virtual Buss Compressors\Virtual Buss Compressors Rack User Guide.lnk” → [ “C:\ProgramData\Slate Digital\Virtual Buss Compressors Rack\Slate Digital Virtual Buss Compressors Rack - User Guide.pdf” ] (already cured)
          [WARN] 139 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\VerbSuite Classics\Uninstall VerbSuite Classics.lnk” → [ “C:\Program Files\Slate Digital\VerbSuite Classics\unins000.exe” ] (already cured)
          [WARN] 140 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\VerbSuite Classics\VerbSuite Classics User Guide.lnk” → [ “C:\ProgramData\Slate Digital\VerbSuite Classics\Slate Digital VerbSuite Classics - User Guide.pdf” ] (already cured)
          [WARN] 141 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\FG-X Virtual Mastering Console\Uninstall FG-X.lnk” → [ “C:\Program Files\Slate Digital\FG-X Virtual Mastering Console\unins000.exe” ] (already cured)
          [WARN] 142 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital\FG-X\Uninstall FG-X.lnk” → [ “C:\Program Files\Slate Digital\FG-X\unins000.exe” ] (already cured)
          [WARN] 143 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Skype\Skype.lnk” → [ “C:\Program Files (x86)\Skype\Phone\Skype.exe” ] (already cured)
          [WARN] 144 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Scuffham Amps S-GEAR\Un-install S-GEAR.lnk” → [ “C:\ProgramData\Scuffham Amps\unins000.exe” ] (already cured)
          [WARN] 145 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Scuffham Amps S-GEAR\User manual.lnk” → [ “C:\ProgramData\Scuffham Amps\S-Gear2\sgear_usermanual.pdf” ] (already cured)
          [WARN] 146 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Room EQ Wizard V5\ReadMe.lnk” → [ “C:\Program Files (x86)\Room EQ Wizard V5\readme.html” ] (already cured)
          [WARN] 147 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Room EQ Wizard V5\Room EQ Wizard V5.lnk” → [ “C:\Program Files (x86)\Room EQ Wizard V5\roomeqwizard.exe” ] (already cured)
          [WARN] 148 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Room EQ Wizard V5\Uninstall.lnk” → [ “C:\Program Files (x86)\Room EQ Wizard V5\Uninstall.exe” ] (already cured)
          [WARN] 149 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RogueKiller\RogueKiller.lnk” → [ “C:\Program Files\RogueKiller\RogueKiller64.exe” ] (already cured)
          [WARN] 150 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Revo Uninstaller\Revo Uninstaller Help.lnk” → [ “C:\Program Files\VS Revo Group\Revo Uninstaller\Revo Uninstaller Help.pdf” ] (already cured)
          [WARN] 151 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Revo Uninstaller\Revo Uninstaller.lnk” → [ “C:\Program Files\VS Revo Group\Revo Uninstaller\RevoUnin.exe” ] (already cured)
          [WARN] 152 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Revo Uninstaller\Uninstall Revo Uninstaller.lnk” → [ “C:\Program Files\VS Revo Group\Revo Uninstaller\unins000.exe” ] (already cured)
          [WARN] 153 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Resource Hacker\Resource Hacker.lnk” → [ “C:\Program Files (x86)\Resource Hacker\ResHacker.exe” ] (already cured)
          [WARN] 154 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\reFX\Nexus\NEXUS Manual English.lnk” → [ “C:\Program Files\VSTPlugIns\Manual\Nexus 2 Manual English.pdf” ] (already cured)
          [WARN] 156 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\ReaMote Slave (x64).lnk” → [ “C:\Program Files\REAPER (x64)\reamote.exe” ] (already cured)
          [WARN] 157 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\REAPER (x64).lnk” → [ “C:\Program Files\REAPER (x64)\reaper.exe” ] (already cured)
          [WARN] 159 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)\Uninstall REAPER (x64).lnk” → [ “C:\Program Files\REAPER (x64)\Uninstall.exe” ] (already cured)
          [WARN] 161 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Python 3.3\Python (command line).lnk” → [ “C:\Python33\python.exe” ] (already cured)
          [WARN] 162 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Python 3.3\Python Manuals.lnk” → [ “C:\Python33\Doc\python330.chm” ] (already cured)
          [WARN] 164 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Xenon\PSP Xenon Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP Xenon\PSP Xenon Operation Manual.pdf” ] (already cured)
          [WARN] 166 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Xenon\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP Xenon\PSPaudioware.com.html” ] (already cured)
          [WARN] 168 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP SpringBox 64bit\PSP SpringBox Operation Manual.lnk” → [ “C:\Program Files\VSTPlugIns\PSP SpringBox\PSP SpringBox Manual.pdf” ] (already cured)
          [WARN] 170 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP SpringBox 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\VSTPlugIns\PSP SpringBox\PSPaudioware.com.html” ] (already cured)
          [WARN] 172 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP PianoVerb2 64bit\PSP PianoVerb2 Operation Manual.lnk” → [ “C:\Program Files\VSTPlugIns\PSP PianoVerb2\PSP PianoVerb2 Manual.pdf” ] (already cured)
          [WARN] 174 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP PianoVerb2 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\VSTPlugIns\PSP PianoVerb2\PSPaudioware.com.html” ] (already cured)
          [WARN] 176 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP oldTimer 64bit\PSP oldTimer Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP oldTimer 64bit\PSP oldTimer Operation Manual.pdf” ] (already cured)
          [WARN] 178 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP oldTimer 64bit\PSP oldTimerME Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP oldTimer 64bit\PSP oldTimerME Operation Manual.pdf” ] (already cured)
          [WARN] 179 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP oldTimer 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP oldTimer 64bit\PSPaudioware.com.html” ] (already cured)
          [WARN] 181 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP NobleQ 64bit\PSP NobleQ Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP NobleQ 64bit\PSP NobleQ Operation Manual.pdf” ] (already cured)
          [WARN] 183 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP NobleQ 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP NobleQ 64bit\PSPaudioware.com.html” ] (already cured)
          [WARN] 185 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Neon 64bit\PSP Neon Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP Neon 64bit\PSP Neon Operation Manual.pdf” ] (already cured)
          [WARN] 187 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Neon 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP Neon 64bit\PSPaudioware.com.html” ] (already cured)
          [WARN] 189 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP McQ 64bit\PSP McQ Operation Manual.lnk” → [ “C:\Program Files\VSTPlugIns\PSP McQ\PSP McQ Manual.pdf” ] (already cured)
          [WARN] 191 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP McQ 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\VSTPlugIns\PSP McQ\PSPaudioware.com.html” ] (already cured)
          [WARN] 193 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP MasterComp\PSP MasterComp Operation Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP MasterComp\PSP MasterComp.pdf” ] (already cured)
          [WARN] 195 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP MasterComp\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP MasterComp\PSPaudioware.com.html” ] (already cured)
          [WARN] 197 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Echo 64bit\PSP Echo Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP Echo 64bit\PSP Echo.pdf” ] (already cured)
          [WARN] 199 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP Echo 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP Echo 64bit\PSPaudioware.com.html” ] (already cured)
          [WARN] 201 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP BussPressor 64bit\PSP BussPressor Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP BussPressor 64bit\PSP BussPressor Operation Manual.pdf” ] (already cured)
          [WARN] 203 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP BussPressor 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP BussPressor 64bit\PSPaudioware.com.html” ] (already cured)
          [WARN] 205 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 85 64bit\PSP 85 Operation Manual.lnk” → [ “C:\Program Files\VSTPlugIns\PSP 85\PSP 85 Operation Manual.pdf” ] (already cured)
          [WARN] 207 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 85 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\VSTPlugIns\PSP 85\PSPaudioware.com.html” ] (already cured)
          [WARN] 209 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 608 MultiDelay 64bit\PSP 608 MultiDelay Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP 608 MultiDelay 64bit\PSP 608 MultiDelay Operation Manual.pdf” ] (already cured)
          [WARN] 211 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 608 MultiDelay 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP 608 MultiDelay 64bit\PSPaudioware.com.html” ] (already cured)
          [WARN] 213 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 2Meters 64bit\PSP 2Meters Operation Manual.lnk” → [ “C:\Program Files\PSPaudioware\PSP 2Meters 64bit\PSP 2Meters Operation Manual.pdf” ] (already cured)
          [WARN] 215 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\PSP 2Meters 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\PSPaudioware\PSP 2Meters 64bit\PSPaudioware.com.html” ] (already cured)
          [WARN] 217 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\Lexicon PSP 42 64bit\Lexicon PSP42 Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Lexicon PSP42 Operation Manual.pdf” ] (already cured)
          [WARN] 219 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware\Lexicon PSP 42 64bit\PSPaudioware Home Site.lnk” → [ “C:\Program Files\VSTPlugIns\PSPaudioware.com.html” ] (already cured)
          [WARN] 220 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Process Lasso\Documentation\Documentation.lnk” → [ “C:\Program Files\Process Lasso\PROCESSLASSO.CHM” ] (already cured)
          [WARN] 221 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Primo Ramdisk Server Edition\Primo Ramdisk Server Edition.lnk” → [ “C:\Program Files\Primo Ramdisk Server Edition\FancyRd.exe” ] (already cured)
          [WARN] 222 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Primo Ramdisk Server Edition\Uninstall Primo Ramdisk Server Edition.lnk” → [ “C:\Program Files\Primo Ramdisk Server Edition\unins000.exe” ] (already cured)
          [WARN] 224 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Plogue\chipsounds\Uninstall.lnk” → [ “C:\Program Files\Plogue\chipsounds\unins000.exe” ] (already cured)
          [WARN] 227 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation\GeForce Experience.lnk” → [ “C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA GeForce Experience.exe” ] (already cured)
          [WARN] 228 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation\3D Vision\3D Vision Photo Viewer.lnk” → [ “C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvstview.exe” ] (already cured)
          [WARN] 230 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Visualizer1_9\Uninstall Visualizer.lnk” → [ “C:\Program Files (x86)\NuGen Audio\Visualizer1_9\unins000.exe” ] (already cured)
          [WARN] 231 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Visualizer1_9\Visualizer1_9 Manual.lnk” → [ “C:\Program Files (x86)\NuGen Audio\Visualizer1_9\Visualizer Manual.pdf” ] (already cured)
          [WARN] 232 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\VisLM\Installation and Licensing Guide.lnk” → [ “C:\Program Files\NUGEN Audio\VisLM\NUGEN Audio installation and licensing guide.pdf” ] (already cured)
          [WARN] 234 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\VisLM\Uninstall VisLM.lnk” → [ “C:\Program Files\NUGEN Audio\VisLM\unins000.exe” ] (already cured)
          [WARN] 235 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\VisLM\VisLM Manual.lnk” → [ “C:\Program Files\NUGEN Audio\VisLM\VisLM manual.pdf” ] (already cured)
          [WARN] 236 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoplacer3\Installation and Licensing Guide.lnk” → [ “C:\Program Files\NUGEN Audio\Stereoplacer3\NUGEN Audio installation and licensing guide.pdf” ] (already cured)
          [WARN] 238 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoplacer3\Stereoplacer3 Manual.lnk” → [ “C:\Program Files\NUGEN Audio\Stereoplacer3\Stereoplacer3 manual.pdf” ] (already cured)
          [WARN] 239 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoplacer3\Uninstall Stereoplacer.lnk” → [ “C:\Program Files\NUGEN Audio\Stereoplacer3\unins000.exe” ] (already cured)
          [WARN] 240 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoizer3\Installation and Licensing Guide.lnk” → [ “C:\Program Files\NUGEN Audio\Stereoizer3\NUGEN Audio installation and licensing guide.pdf” ] (already cured)
          [WARN] 242 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoizer3\Stereoizer3 Manual.lnk” → [ “C:\Program Files\NUGEN Audio\Stereoizer3\Stereoizer3 manual.pdf” ] (already cured)
          [WARN] 243 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Stereoizer3\Uninstall Stereoizer3.lnk” → [ “C:\Program Files\NUGEN Audio\Stereoizer3\unins000.exe” ] (already cured)
          [WARN] 245 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ2 Master\SEQ2 Master Manual.lnk” → [ “C:\Program Files (x86)\NuGen Audio\SEQ2 Master\SEQ2 Manual.pdf” ] (already cured)
          [WARN] 246 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ2 Master\Uninstall SEQ2_Master.lnk” → [ “C:\Program Files (x86)\NuGen Audio\SEQ2 Master\unins000.exe” ] (already cured)
          [WARN] 248 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ1 Master\SEQ1 Master Manual.lnk” → [ “C:\Program Files (x86)\NuGen Audio\SEQ1 Master\SEQ1 Manual.pdf” ] (already cured)
          [WARN] 249 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ1 Master\Uninstall SEQ1_Master.lnk” → [ “C:\Program Files (x86)\NuGen Audio\SEQ1 Master\unins000.exe” ] (already cured)
          [WARN] 250 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ-S\Installation and Licensing Guide.lnk” → [ “C:\Program Files\NUGEN Audio\SEQ-S\NUGEN Audio installation and licensing guide.pdf” ] (already cured)
          [WARN] 252 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ-S\SEQ-S Manual.lnk” → [ “C:\Program Files\NUGEN Audio\SEQ-S\SEQ-S Manual.pdf” ] (already cured)
          [WARN] 253 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\SEQ-S\Uninstall SEQ-S.lnk” → [ “C:\Program Files\NUGEN Audio\SEQ-S\unins000.exe” ] (already cured)
          [WARN] 254 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Monofilter4\Installation and Licensing Guide.lnk” → [ “C:\Program Files\NUGEN Audio\Monofilter4\NUGEN Audio installation and licensing guide.pdf” ] (already cured)
          [WARN] 255 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Monofilter4\Monofilter4 Manual.lnk” → [ “C:\Program Files\NUGEN Audio\Monofilter4\Monofilter4 manual.pdf” ] (already cured)
          [WARN] 257 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\Monofilter4\Uninstall Monofilter4.lnk” → [ “C:\Program Files\NUGEN Audio\Monofilter4\unins000.exe” ] (already cured)
          [WARN] 258 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\ISL\ISL Manual.lnk” → [ “C:\Program Files\NUGEN Audio\ISL\ISL Manual.pdf” ] (already cured)
          [WARN] 260 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio\ISL\Uninstall ISL.lnk” → [ “C:\Program Files\NUGEN Audio\ISL\unins000.exe” ] (already cured)
          [WARN] 261 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero\Nero 12\Nero 12.lnk” → [ “C:\Program Files (x86)\Nero\Nero 12\Nero Launcher\NeroLauncher.exe” ] (already cured)
          [WARN] 262 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Massive\Uninstall.lnk” → [ “C:\Program Files (x86)\Native Instruments\Massive\uninstall.exe” ] (already cured)
          [WARN] 263 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Massive\Documentation\Massive Manual English.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Massive\Documentation\Massive Manual English.pdf” ] (already cured)
          [WARN] 264 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Massive\Documentation\Massive Manual Spanish.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Massive\Documentation\Massive Manual Spanish.pdf” ] (already cured)
          [WARN] 266 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Massive\Documentation\Welcome.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Massive\Documentation\Welcome.pdf” ] (already cured)
          [WARN] 268 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual English.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual English.pdf” ] (already cured)
          [WARN] 269 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual French.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual French.pdf” ] (already cured)
          [WARN] 270 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual German.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual German.pdf” ] (already cured)
          [WARN] 271 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual Spanish.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Manual Spanish.pdf” ] (already cured)
          [WARN] 272 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide English.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide English.pdf” ] (already cured)
          [WARN] 273 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide French.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide French.pdf” ] (already cured)
          [WARN] 274 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide German.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide German.pdf” ] (already cured)
          [WARN] 275 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide Spanish.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Elektrik Piano 1.5 Setup Guide Spanish.pdf” ] (already cured)
          [WARN] 276 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\ElektrikPiano15Serial.html.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\ElektrikPiano15Serial.html” ] (already cured)
          [WARN] 277 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5\Documentation\Welcome.pdf.lnk” → [ “C:\Program Files (x86)\Native Instruments\Elektrik Piano 1.5\Documentation\Welcome.pdf” ] (already cured)
          [WARN] 278 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Service Center.lnk” → [ “C:\Program Files\Native Instruments\Service Center\ServiceCenter.exe” ] (already cured)
          [WARN] 279 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Documentation\More Documentation.lnk” → [ “C:\Program Files\Native Instruments\Service Center\Documentation” ] (already cured)
          [WARN] 281 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Documentation\Service Center Manual English.pdf.lnk” → [ “C:\Program Files\Native Instruments\Service Center\Documentation\Service Center Manual English.pdf” ] (already cured)
          [WARN] 282 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Documentation\Service Center Manual French.pdf.lnk” → [ “C:\Program Files\Native Instruments\Service Center\Documentation\Service Center Manual French.pdf” ] (already cured)
          [WARN] 283 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Documentation\Service Center Manual German.pdf.lnk” → [ “C:\Program Files\Native Instruments\Service Center\Documentation\Service Center Manual German.pdf” ] (already cured)
          [WARN] 284 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Documentation\Service Center Manual Japanese.pdf.lnk” → [ “C:\Program Files\Native Instruments\Service Center\Documentation\Service Center Manual Japanese.pdf” ] (already cured)
          [WARN] 285 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Service Center\Documentation\Service Center Manual Spanish.pdf.lnk” → [ “C:\Program Files\Native Instruments\Service Center\Documentation\Service Center Manual Spanish.pdf” ] (already cured)
          [WARN] 286 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Massive\Massive.lnk” → [ “C:\Program Files\Native Instruments\Massive\Massive.exe” ] (already cured)
          [WARN] 287 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Kontakt 5\Kontakt 5.lnk” → [ “C:\Program Files\Native Instruments\Kontakt 5\Kontakt 5.exe” ] (already cured)
          [WARN] 288 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Guitar Rig 5\Guitar Rig 5.lnk” → [ “C:\Program Files\Native Instruments\Guitar Rig 5\Guitar Rig 5.exe” ] (already cured)
          [WARN] 289 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Guitar Rig 5\Documentation\More Documentation.lnk” → [ “C:\Program Files\Native Instruments\Guitar Rig 5\Documentation” ] (already cured)
          [WARN] 291 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\FM8.lnk” → [ “C:\Program Files\Native Instruments\FM8\FM8.exe” ] (already cured)
          [WARN] 292 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Getting Started English.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Getting Started English.pdf” ] (already cured)
          [WARN] 293 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Getting Started French.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Getting Started French.pdf” ] (already cured)
          [WARN] 294 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Getting Started German.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Getting Started German.pdf” ] (already cured)
          [WARN] 295 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Getting Started Japanese.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Getting Started Japanese.pdf” ] (already cured)
          [WARN] 296 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Getting Started Spanish.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Getting Started Spanish.pdf” ] (already cured)
          [WARN] 297 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual Addendum English.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual Addendum English.pdf” ] (already cured)
          [WARN] 298 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual Addendum French.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual Addendum French.pdf” ] (already cured)
          [WARN] 299 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual Addendum German.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual Addendum German.pdf” ] (already cured)
          [WARN] 300 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual Addendum Japanese.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual Addendum Japanese.pdf” ] (already cured)
          [WARN] 301 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual Addendum Spanish.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual Addendum Spanish.pdf” ] (already cured)
          [WARN] 302 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual English.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual English.pdf” ] (already cured)
          [WARN] 303 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual French.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual French.pdf” ] (already cured)
          [WARN] 304 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual German.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual German.pdf” ] (already cured)
          [WARN] 305 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual Japanese.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual Japanese.pdf” ] (already cured)
          [WARN] 306 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\FM8 Manual Spanish.pdf.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation\FM8 Manual Spanish.pdf” ] (already cured)
          [WARN] 307 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\FM8\Documentation\More Documentation.lnk” → [ “C:\Program Files\Native Instruments\FM8\Documentation” ] (already cured)
          [WARN] 309 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Controller Editor.lnk” → [ “C:\Program Files\Native Instruments\Controller Editor\Controller Editor.exe” ] (already cured)
          [WARN] 310 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Documentation\Controller Editor Manual English.pdf.lnk” → [ “C:\Program Files\Native Instruments\Controller Editor\Documentation\Controller Editor Manual English.pdf” ] (already cured)
          [WARN] 311 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Documentation\Controller Editor Manual French.pdf.lnk” → [ “C:\Program Files\Native Instruments\Controller Editor\Documentation\Controller Editor Manual French.pdf” ] (already cured)
          [WARN] 312 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Documentation\Controller Editor Manual German.pdf.lnk” → [ “C:\Program Files\Native Instruments\Controller Editor\Documentation\Controller Editor Manual German.pdf” ] (already cured)
          [WARN] 313 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Documentation\Controller Editor Manual Japanese.pdf.lnk” → [ “C:\Program Files\Native Instruments\Controller Editor\Documentation\Controller Editor Manual Japanese.pdf” ] (already cured)
          [WARN] 314 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Documentation\Controller Editor Manual Spanish.pdf.lnk” → [ “C:\Program Files\Native Instruments\Controller Editor\Documentation\Controller Editor Manual Spanish.pdf” ] (already cured)
          [WARN] 315 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Controller Editor\Documentation\More Documentation.lnk” → [ “C:\Program Files\Native Instruments\Controller Editor\Documentation” ] (already cured)
          [WARN] 317 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Battery 4\Battery 4.lnk” → [ “C:\Program Files\Native Instruments\Battery 4\Battery 4.exe” ] (already cured)
          [WARN] 318 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Absynth 5.lnk” → [ “C:\Program Files\Native Instruments\Absynth 5\Absynth 5.exe” ] (already cured)
          [WARN] 319 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started English.pdf.lnk” → [ “C:\Program Files\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started English.pdf” ] (already cured)
          [WARN] 320 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started French.pdf.lnk” → [ “C:\Program Files\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started French.pdf” ] (already cured)
          [WARN] 321 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started German.pdf.lnk” → [ “C:\Program Files\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started German.pdf” ] (already cured)
          [WARN] 322 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started Japanese.pdf.lnk” → [ “C:\Program Files\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started Japanese.pdf” ] (already cured)
          [WARN] 323 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started Spanish.pdf.lnk” → [ “C:\Program Files\Native Instruments\Absynth 5\Documentation\Absynth 5 Getting Started Spanish.pdf” ] (already cured)
          [WARN] 324 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments\Absynth 5\Documentation\More Documentation.lnk” → [ “C:\Program Files\Native Instruments\Absynth 5\Documentation” ] (already cured)
          [WARN] 326 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mp3tag\Mp3tag Help.lnk” → [ “C:\Program Files (x86)\Mp3tag\help\index.html” ] (already cured)
          [WARN] 327 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mp3tag\Mp3tag.lnk” → [ “C:\Program Files (x86)\Mp3tag\Mp3tag.exe” ] (already cured)
          [WARN] 328 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mp3tag\Uninstall Mp3tag.lnk” → [ “C:\Program Files (x86)\Mp3tag\Mp3tagUninstall.exe” ] (already cured)
          [WARN] 330 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox\Mozilla Firefox.lnk” → [ “C:\Program Files (x86)\Mozilla Firefox\firefox.exe” ] (already cured)
          [WARN] 331 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mobile Hotspot Admin\Mobile Hotspot Admin.lnk” → [ “C:\Program Files (x86)\Hostless Modem\Mobile Hotspot Admin\LaunchWebUI.exe” ] (already cured)
          [WARN] 333 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUCjr\Uninstall MJUCjr.lnk” → [ “C:\Program Files\Klanghelm\MJUCjr\unins000.exe” ] (already cured)
          [WARN] 334 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUCjr\User guide.lnk” → [ “C:\Program Files\Klanghelm\MJUCjr\MJUCjr-manual.pdf” ] (already cured)
          [WARN] 336 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUC\Uninstall MJUC.lnk” → [ “C:\Program Files\Klanghelm\MJUC\unins000.exe” ] (already cured)
          [WARN] 337 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUC\User guide.lnk” → [ “C:\Program Files\Klanghelm\MJUC\MJUC-manual.pdf” ] (already cured)
          [WARN] 338 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Access 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\MSACCESS.EXE” ] (already cured)
          [WARN] 339 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Excel 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\EXCEL.EXE” ] (already cured)
          [WARN] 340 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\InfoPath Filler 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\INFOPATH.EXE” ] (already cured)
          [WARN] 341 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\OneDrive for Business 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\GROOVE.EXE” ] (already cured)
          [WARN] 342 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\OneNote 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\ONENOTE.EXE” ] (already cured)
          [WARN] 343 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Outlook 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\OUTLOOK.EXE” ] (already cured)
          [WARN] 344 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\PowerPoint 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\POWERPNT.EXE” ] (already cured)
          [WARN] 345 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Publisher 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\MSPUB.EXE” ] (already cured)
          [WARN] 347 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Skype for Business 2015.lnk” → [ “C:\Program Files\Microsoft Office\Office15\lync.exe” ] (already cured)
          [WARN] 348 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Word 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\WINWORD.EXE” ] (already cured)
          [WARN] 349 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Office 2013 Tools\Database Compare 2013.lnk” → [ “C:\Program Files (x86)\Microsoft Office\Office15\DCF\DATABASECOMPARE.EXE” ] (already cured)
          [WARN] 352 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Office 2013 Tools\Skype for Business Recording Manager.lnk” → [ “C:\Program Files\Microsoft Office\Office15\OcPubMgr.exe” ] (already cured)
          [WARN] 353 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Office 2013 Tools\Spreadsheet Compare 2013.lnk” → [ “C:\Program Files (x86)\Microsoft Office\Office15\DCF\SPREADSHEETCOMPARE.EXE” ] (already cured)
          [WARN] 354 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Office 2013 Tools\Telemetry Dashboard for Office 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\msotd.exe” ] (already cured)
          [WARN] 355 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013\Office 2013 Tools\Telemetry Log for Office 2013.lnk” → [ “C:\Program Files\Microsoft Office\Office15\msoev.exe” ] (already cured)
          [WARN] 356 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MetaTrader 5\MetaEditor.lnk” → [ “C:\Program Files\MetaTrader 5\metaeditor64.exe” ] (already cured)
          [WARN] 358 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MetaTrader 5\Uninstall.lnk” → [ “C:\Program Files\MetaTrader 5\uninstall.exe” ] (already cured)
          [WARN] 359 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Melodyne 3.2\Manual.lnk” → [ “C:\Program Files (x86)\Celemony\Melodyne.3.2\Documentation\Manual.M elodyneCre8Studio.3.2.English.pdf” ] (already cured)
          [WARN] 360 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Melodyne 3.2\Melodyne.exe.lnk” → [ “C:\Program Files (x86)\Celemony\Melodyne.3.2\Melodyne.exe” ] (already cured)
          [WARN] 361 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Melodyne 3.2\New in 3.2.2.lnk” → [ “C:\Program Files (x86)\Celemony\Melodyne.3.2\NewIn.3.2.2.pdf” ] (already cured)
          [WARN] 362 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McDSP\6030 Ultimate Comp Native\License_Agreement.lnk” → [ “C:\Program Files (x86)\McDSP\6030 Ultimate Comp Native\License_Agreement.rtf” ] (already cured)
          [WARN] 363 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McDSP\6030 Ultimate Comp Native\Read_Me.lnk” → [ “C:\Program Files (x86)\McDSP\6030 Ultimate Comp Native\Read_Me.rtf” ] (already cured)
          [WARN] 364 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McDSP\6030 Ultimate Comp Native\Release_Notes.lnk” → [ “C:\Program Files (x86)\McDSP\6030 Ultimate Comp Native\Release_Notes.rtf” ] (already cured)
          [WARN] 365 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McDSP\6030 Ultimate Comp Native\User_Manual.lnk” → [ “C:\Program Files (x86)\McDSP\6030 Ultimate Comp Native\User_Manual.pdf” ] (already cured)
          [WARN] 366 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes\Malwarebytes.lnk” → [ “C:\Program Files\Malwarebytes\Anti-Malware\mbam.exe” ] (already cured)
          [WARN] 367 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes\Uninstall Malwarebytes.lnk” → [ “C:\Program Files\Malwarebytes\Anti-Malware\unins000.exe” ] (already cured)
          [WARN] 369 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LoopBe30 - Internal MIDI Ports\LoopBe30 Help.lnk” → [ “C:\Program Files (x86)\nerds.de\LoopBe30\loough.chm” ] (already cured)
          [WARN] 370 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LoopBe30 - Internal MIDI Ports\LoopBe30 Monitor.lnk” → [ “C:\Program Files (x86)\nerds.de\LoopBe30\loough.exe” ] (already cured)
          [WARN] 371 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LoopBe30 - Internal MIDI Ports\Uninstall LoopBe30.lnk” → [ “C:\Program Files (x86)\nerds.de\LoopBe30\Uninstall_LoopBe30.exe” ] (already cured)
          [WARN] 372 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Logitech\Logitech Gaming Software 8.40.lnk” → [ “C:\Program Files\Logitech Gaming Software\LCore.exe” ] (already cured)
          [WARN] 373 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Logitech\Logitech Webcam Software.lnk” → [ “C:\Program Files (x86)\Common Files\logishrd\LWSPlugins\LWS\Applets\HelpMain\lau nchershortcut.exe” ] (already cured)
          [WARN] 374 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Logitech\Unifying\Logitech Unifying Software.lnk” → [ “C:\Program Files\Common Files\logishrd\Unifying\DJCUHost.exe” ] (already cured)
          [WARN] 375 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Link-AssistantCom\LinkAssistant.lnk” → [ “C:\Program Files (x86)\Link-AssistantCom\LinkAssistant\bin\linkassistant.exe” ] (already cured)
          [WARN] 376 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Link-AssistantCom\Rank Tracker.lnk” → [ “C:\Program Files (x86)\Link-AssistantCom\Rank Tracker\bin\ranktracker.exe” ] (already cured)
          [WARN] 377 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Link-AssistantCom\SEO SpyGlass.lnk” → [ “C:\Program Files (x86)\Link-AssistantCom\SEO SpyGlass\bin\seospyglass.exe” ] (already cured)
          [WARN] 378 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Link-AssistantCom\WebSite Auditor.lnk” → [ “C:\Program Files (x86)\Link-AssistantCom\WebSite Auditor\bin\websiteauditor.exe” ] (already cured)
          [WARN] 381 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kong Audio\ChineeErHu\Manual_Chinese.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Kong Audio\ChineeErHu\ChineeErHu\Help\index-ch.htm” ] (already cured)
          [WARN] 382 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kong Audio\ChineeErHu\Manual_English.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Kong Audio\ChineeErHu\ChineeErHu\Help\index-en.htm” ] (already cured)
          [WARN] 383 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kong Audio\ChineeErHu\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Kong Audio\unkaerhu.exe” ] (already cured)
          [WARN] 384 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KDSubmitterPro\KDSubmitterPro.lnk” → [ “C:\Program Files (x86)\KDSubmitterPro.com\KDSubmitterPro\KDSubmitte rPro.exe” ] (already cured)
          [WARN] 385 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KDPublishingPro\KDPublishingPro.lnk” → [ “C:\Program Files (x86)\KDPublishingPro.com\KDPublishingPro\KDPublis hingPro.exe” ] (already cured)
          [WARN] 387 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kazrog LLC\Recabinet 3\Uninstall Recabinet 3 v3.1.lnk” → [ “C:\Program Files\Kazrog LLC\Recabinet 3\uninstall\unins000.exe” ] (already cured)
          [WARN] 388 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Codec Tweak Tool.lnk” → [ “C:\Program Files\K-Lite Codec Pack x64\Tools\CodecTweakTool.exe” ] (already cured)
          [WARN] 389 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Uninstall\Uninstall K-Lite Codec Pack x64.lnk” → [ “C:\Program Files\K-Lite Codec Pack x64\unins000.exe” ] (already cured)
          [WARN] 390 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Tools\GraphStudioNext (x64).lnk” → [ “C:\Program Files\K-Lite Codec Pack x64\Tools\GraphStudioNext64.exe” ] (already cured)
          [WARN] 391 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Tools\Win7DSFilterTweaker.lnk” → [ “C:\Program Files\K-Lite Codec Pack x64\Tools\Win7DSFilterTweaker.exe” ] (already cured)
          [WARN] 392 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64\Help\FAQ.lnk” → [ “C:\Program Files\K-Lite Codec Pack x64\Info\faq.htm” ] (already cured)
          [WARN] 393 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Media Player Classic.lnk” → [ “C:\Program Files (x86)\K-Lite Codec Pack\Media Player Classic\mpc-hc.exe” ] (already cured)
          [WARN] 394 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Uninstall\Uninstall K-Lite Codec Pack.lnk” → [ “C:\Program Files (x86)\K-Lite Codec Pack\unins000.exe” ] (already cured)
          [WARN] 395 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Tools\GraphStudioNext.lnk” → [ “C:\Program Files (x86)\K-Lite Codec Pack\Tools\GraphStudioNext.exe” ] (already cured)
          [WARN] 396 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Tools\MediaInfo.lnk” → [ “C:\Program Files (x86)\K-Lite Codec Pack\Tools\mediainfo.exe” ] (already cured)
          [WARN] 397 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Tools\VobSubStrip.lnk” → [ “C:\Program Files (x86)\K-Lite Codec Pack\Tools\VobSubStrip.exe” ] (already cured)
          [WARN] 398 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack\Help\Frequently Asked Questions.lnk” → [ “C:\Program Files (x86)\K-Lite Codec Pack\Info\faq.htm” ] (already cured)
          [WARN] 399 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Joey Sturgis Tones\Transify\Transify Manual.lnk” → [ “C:\Program Files\Joey Sturgis Tones\Transify\Transify - Manual.pdf” ] (already cured)
          [WARN] 400 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Joey Sturgis Tones\Transify\Uninstall Transify.lnk” → [ “C:\Program Files\Joey Sturgis Tones\Transify\unins000.exe” ] (already cured)
          [WARN] 401 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Joey Sturgis Tones\SideWidener\SideWidener User Manual.lnk” → [ “C:\Program Files\Joey Sturgis Tones\SideWidener\SideWidener_manual.pdf” ] (already cured)
          [WARN] 402 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Joey Sturgis Tones\SideWidener\Uninstall SideWidener.lnk” → [ “C:\Program Files\Joey Sturgis Tones\SideWidener\unins000.exe” ] (already cured)
          [WARN] 404 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\VocalSynth\Uninstall VocalSynth.lnk” → [ “C:\Program Files (x86)\iZotope\VocalSynth\Uninstall VocalSynth.exe” ] (already cured)
          [WARN] 405 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Vinyl\ iZotope Vinyl Help.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Vinyl\iZVinyl_en.chm” ] (already cured)
          [WARN] 406 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Vinyl\ Readme.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Vinyl\Readme_en.rtf” ] (already cured)
          [WARN] 408 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Vinyl\Uninstall iZotope Vinyl.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Vinyl\unins000.exe” ] (already cured)
          [WARN] 409 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Trash 2\iZotope Trash 2 Help PDF.lnk” → [ “C:\Program Files\VSTPlugIns\Trash 2\iZTrash2_en.pdf” ] (already cured)
          [WARN] 410 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Trash 2\Readme.lnk” → [ “C:\Program Files\VSTPlugIns\Trash 2\Readme_en.rtf” ] (already cured)
          [WARN] 411 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Trash 2\Uninstall iZotope Trash 2.lnk” → [ “C:\Program Files\VSTPlugIns\Trash 2\unins000.exe” ] (already cured)
          [WARN] 413 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\RX 5 Audio Editor\iZotope RX 5 Audio Editor (32-bit).lnk” → [ “C:\Program Files (x86)\iZotope\RX 5 Audio Editor\win32\iZotope RX 5.exe” ] (already cured)
          [WARN] 414 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\RX 5 Audio Editor\iZotope RX 5 Audio Editor.lnk” → [ “C:\Program Files (x86)\iZotope\RX 5 Audio Editor\win64\iZotope RX 5.exe” ] (already cured)
          [WARN] 416 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\RX 5 Audio Editor\Readme.lnk” → [ “C:\Program Files (x86)\iZotope\RX 5 Audio Editor\Readme_en.rtf” ] (already cured)
          [WARN] 417 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\RX 5 Audio Editor\Uninstall iZotope RX 5.lnk” → [ “C:\Program Files (x86)\iZotope\RX 5 Audio Editor\unins000.exe” ] (already cured)
          [WARN] 419 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 7\iZotope Ozone 7 (32-bit).lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 7\win32\iZotope Ozone 7.exe” ] (already cured)
          [WARN] 420 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 7\iZotope Ozone 7 (64-bit).lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 7\win64\iZotope Ozone 7.exe” ] (already cured)
          [WARN] 421 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 7\Uninstall iZotope Ozone 7.lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 7\Uninstall iZotope Ozone 7 Advanced.exe” ] (already cured)
          [WARN] 422 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 6\iZotope Ozone 6 (64-bit).lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 6\win64\iZotope Ozone 6.exe” ] (already cured)
          [WARN] 423 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 6\iZotope Ozone 6 Help PDF.lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 6\Ozone 6 Help Documentation.pdf” ] (already cured)
          [WARN] 424 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 6\iZotope Ozone 6.lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 6\win32\iZotope Ozone 6.exe” ] (already cured)
          [WARN] 425 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Ozone 6\Uninstall iZotope Ozone 6.lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 6\unins000.exe” ] (already cured)
          [WARN] 427 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Neutron\Uninstall Neutron Advanced.lnk” → [ “C:\Program Files (x86)\iZotope\Neutron\Uninstall Neutron Advanced.exe” ] (already cured)
          [WARN] 428 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Nectar 2\Readme.lnk” → [ “C:\Program Files (x86)\iZotope\Nectar 2\readme_en.rtf” ] (already cured)
          [WARN] 429 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Nectar 2\Uninstall iZotope Nectar 2.lnk” → [ “C:\Program Files (x86)\iZotope\Nectar 2\unins000.exe” ] (already cured)
          [WARN] 431 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Insight\iZotope Insight Help PDF.lnk” → [ “C:\Program Files (x86)\iZotope\Insight\iZInsight_en.pdf” ] (already cured)
          [WARN] 433 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\Insight\Uninstall iZotope Insight.lnk” → [ “C:\Program Files (x86)\iZotope\Insight\unins000.exe” ] (already cured)
          [WARN] 436 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\BreakTweaker\Readme.lnk” → [ “C:\Program Files (x86)\iZotope\BreakTweaker\Readme_en.rtf” ] (already cured)
          [WARN] 437 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope\BreakTweaker\Uninstall iZotope BreakTweaker.lnk” → [ “C:\Program Files (x86)\iZotope\BreakTweaker\unins000.exe” ] (already cured)
          [WARN] 440 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IVGI\Uninstall IVGI.lnk” → [ “C:\VSTPlugIns\IVGI\unins000.exe” ] (already cured)
          [WARN] 441 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IVGI\User guide.lnk” → [ “C:\VSTPlugIns\IVGI\IVGI-manual.pdf” ] (already cured)
          [WARN] 442 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes\About iTunes.lnk” → [ “C:\Program Files\iTunes\iTunes.Resources\en.lproj\About iTunes.rtf” ] (already cured)
          [WARN] 443 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes\iTunes.lnk” → [ “C:\Program Files\iTunes\iTunes.exe” ] (already cured)
          [WARN] 445 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel\Intel(R) Smart Connect Technology.lnk” → [ “C:\Program Files\Intel\Intel(R) Smart Connect Technology Agent\iSCTControl.exe” ] (already cured)
          [WARN] 446 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\AmpliTube 3.exe” ] (already cured)
          [WARN] 447 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube 4.exe” ] (already cured)
          [WARN] 448 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\ARC System 2 Measurement.lnk” → [ “C:\Program Files (x86)\IK Multimedia\ARC System 2\ARC 2 Measurement.exe” ] (already cured)
          [WARN] 449 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\Authorization Manager.lnk” → [ “C:\Program Files (x86)\IK Multimedia\Authorization Manager\Authorization Manager.exe” ] (already cured)
          [WARN] 450 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\Custom Shop.lnk” → [ “C:\Program Files (x86)\IK Multimedia\Custom Shop\Custom Shop.exe” ] (already cured)
          [WARN] 451 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\T-RackS CS\T-RackS CS User Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\T-Racks CS\T-RackS CS User Manual.pdf” ] (already cured)
          [WARN] 452 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\T-RackS CS\Uninstall T-RackS CS.lnk” → [ “C:\Program Files (x86)\IK Multimedia\T-Racks CS\unins000.exe” ] (already cured)
          [WARN] 453 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\T-RackS 3\T-RackS 3 User Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\T-RackS 3\T-RackS 3 User Manual.pdf” ] (already cured)
          [WARN] 454 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\T-RackS 3\White 2A User Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\T-RackS 3\White 2A User Manual.pdf” ] (already cured)
          [WARN] 455 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\Lurssen Mastering Console\Lurssen Mastering Console User Manual.lnk” → [ “C:\Program Files\IK Multimedia\Lurssen Mastering Console\Lurssen Mastering Console User Manual.pdf” ] (already cured)
          [WARN] 456 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\Lurssen Mastering Console\Uninstall Lurssen Mastering Console.lnk” → [ “C:\Program Files\IK Multimedia\Lurssen Mastering Console\unins000.exe” ] (already cured)
          [WARN] 457 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\Custom Shop\Uninstall Custom Shop.lnk” → [ “C:\Program Files (x86)\IK Multimedia\Custom Shop\unins000.exe” ] (already cured)
          [WARN] 458 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\Authorization Manager\Installation and Authorization Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\Authorization Manager\Installation and Authorization Manual.pdf” ] (already cured)
          [WARN] 459 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\Authorization Manager\Uninstall IK Multimedia Authorization Manager.lnk” → [ “C:\Program Files (x86)\IK Multimedia\Authorization Manager\unins000.exe” ] (already cured)
          [WARN] 460 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\ARC System 2\ARC System 2 User Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\ARC System 2\ARC System 2 User Manual.pdf” ] (already cured)
          [WARN] 461 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\ARC System 2\Uninstall ARC System 2.lnk” → [ “C:\Program Files (x86)\IK Multimedia\ARC System 2\unins000.exe” ] (already cured)
          [WARN] 462 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\Ampeg SVX Gear Models.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\Ampeg SVX Gear Models.pdf” ] (already cured)
          [WARN] 463 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube 3 User Manual.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube 3 User Manual.pdf” ] (already cured)
          [WARN] 464 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube 4 Deluxe Gear Models.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube 4 Deluxe Gear Models.pdf” ] (already cured)
          [WARN] 465 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube Custom Shop New Gear Models.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube Custom Shop New Gear Models.pdf” ] (already cured)
          [WARN] 466 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube Custom Shop User Manual.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube Custom Shop User Manual.pdf” ] (already cured)
          [WARN] 467 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube Fender Gear Models.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube Fender Gear Models.pdf” ] (already cured)
          [WARN] 468 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube Jimi Hendrix Anniversary Collection Gear Models.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube Jimi Hendrix Anniversary Collection Gear Models.pdf” ] (already cured)
          [WARN] 469 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube Metal Gear Models.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube Metal Gear Models.pdf” ] (already cured)
          [WARN] 470 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\AmpliTube Slash Gear Models.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\AmpliTube Slash Gear Models.pdf” ] (already cured)
          [WARN] 471 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\Installation and Authorization manual.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\Installation and Authorization manual.pdf” ] (already cured)
          [WARN] 472 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\Uninstall AmpliTube 4.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\unins000.exe” ] (already cured)
          [WARN] 473 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\What’s New in AmpliTube 3.5.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\What’s New in AmpliTube 3.5.pdf” ] (already cured)
          [WARN] 474 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 4\What’s New in AmpliTube 4.lnk” → [ “C:\Program Files\IK Multimedia\AmpliTube 4\What’s New in AmpliTube 4.pdf” ] (already cured)
          [WARN] 475 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\Ampeg SVX Gear Models.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\Ampeg SVX Gear Models.pdf” ] (already cured)
          [WARN] 476 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\AmpliTube 3 User Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\AmpliTube 3 User Manual.pdf” ] (already cured)
          [WARN] 477 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\AmpliTube Custom Shop New Gear Models.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\AmpliTube Custom Shop New Gear Models.pdf” ] (already cured)
          [WARN] 478 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\AmpliTube Custom Shop User Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\AmpliTube Custom Shop User Manual.pdf” ] (already cured)
          [WARN] 479 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\AmpliTube Fender Gear Models.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\AmpliTube Fender Gear Models.pdf” ] (already cured)
          [WARN] 480 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\AmpliTube Metal Gear Models.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\AmpliTube Metal Gear Models.pdf” ] (already cured)
          [WARN] 481 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\AmpliTube Slash Gear Models.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\AmpliTube Slash Gear Models.pdf” ] (already cured)
          [WARN] 482 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\Uninstall AmpliTube 3.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\unins000.exe” ] (already cured)
          [WARN] 483 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpliTube 3\What Is New in AmpliTube 3.5.lnk” → [ “C:\Program Files (x86)\IK Multimedia\AmpliTube 3\What Is New in AmpliTube 3.5.pdf” ] (already cured)
          [WARN] 484 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia\AmpegSVX\User Manual.lnk” → [ “C:\Program Files\VSTPlugIns\User Manual.pdf” ] (already cured)
          [WARN] 485 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HoRNet\AutoGain Pro MK2\Manual.lnk” → [ “C:\Program Files\HoRNet\AutoGain Pro MK2\user-manual.pdf” ] (already cured)
          [WARN] 486 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HoRNet\AutoGain Pro MK2\Uninstall.lnk” → [ “C:\Program Files\HoRNet\AutoGain Pro MK2\unins000.exe” ] (already cured)
          [WARN] 487 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HomeDev\PatchCleaner.lnk” → [ “C:\Program Files (x86)\HomeDev\PatchCleaner\PatchCleaner.exe” ] (already cured)
          [WARN] 489 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HFSExplorer\HFSExplorer.lnk” → [ “C:\Program Files (x86)\HFSExplorer\hfsexplorer.exe” ] (already cured)
          [WARN] 490 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HFSExplorer\Uninstall.lnk” → [ “C:\Program Files (x86)\HFSExplorer\uninst.exe” ] (already cured)
          [WARN] 491 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Helium Audio Converter\Helium Audio Converter.lnk” → [ “C:\Program Files (x86)\Imploded Software\Helium Audio Converter\HeliumAudioConverter.exe” ] (already cured)
          [WARN] 492 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Talk\Support\Uninstall Google Talk.lnk” → [ “C:\Program Files (x86)\Google\Google Talk\uninstall.exe” ] (already cured)
          [WARN] 493 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GIZMO\GIZMO Settings.lnk” → [ “C:\Windows\SysWOW64\GIZMO.cpl” ] (already cured)
          [WARN] 494 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GIGABYTE\ET6\ET6.lnk” → [ “C:\Program Files (x86)\GIGABYTE\ET6\ET6SC.exe” ] (already cured)
          [WARN] 495 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GIGABYTE\ET6\Help.lnk” → [ “C:\Program Files (x86)\GIGABYTE\ET6\et6help.chm” ] (already cured)
          [WARN] 496 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Genwave EQ\GenwaveEQ_userguide.lnk” → [ “C:\Program Files (x86)\Genwave\GenwaveEQ_userguide.pdf” ] (already cured)
          [WARN] 497 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Genwave EQ\Uninstall Genwave EQ.lnk” → [ “C:\Program Files (x86)\Genwave\Uninstall\unins000.exe” ] (already cured)
          [WARN] 498 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique\XBass 4000\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\ungs4000.exe” ] (already cured)
          [WARN] 499 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique\Twisthead VS-206\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\ungsv206.exe” ] (already cured)
          [WARN] 500 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique\Renegade\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\ungsrngd.exe” ] (already cured)
          [WARN] 501 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique\Pultronic EQ-110P\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\ungsq110.exe” ] (already cured)
          [WARN] 502 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique\FSQ1964\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\ungs1964.exe” ] (already cured)
          [WARN] 503 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique\Dubmaster\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\ungsdbmt.exe” ] (already cured)
          [WARN] 504 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique\Alien303\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\ungsa303.exe” ] (already cured)
          [WARN] 505 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Folder Marker\Folder Marker Help.lnk” → [ “C:\Program Files (x86)\Folder Marker\FOLDERMARKER.chm” ] (already cured)
          [WARN] 506 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Folder Marker\Folder Marker.lnk” → [ “C:\Program Files (x86)\Folder Marker\FolderMarker.exe” ] (already cured)
          [WARN] 508 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Folder Marker\Uninstall Folder Marker.lnk” → [ “C:\Program Files (x86)\Folder Marker\unins000.exe” ] (already cured)
          [WARN] 509 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Flux\Full Pack 2.2\Uninstall.lnk” → [ “C:\Program Files\Flux\Full Pack 2.2\unins000.exe” ] (already cured)
          [WARN] 510 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Finale NotePad 2012\Finale NotePad 2012.lnk” → [ “C:\Program Files (x86)\Finale NotePad 2012\Finale NotePad.exe” ] (already cured)
          [WARN] 511 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Finale NotePad 2012\Uninstall Finale NotePad 2012.lnk” → [ “C:\Program Files (x86)\Finale NotePad 2012\UninstallNotePad.exe” ] (already cured)
          [WARN] 512 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\FileZilla FTP Client\FileZilla.lnk” → [ “C:\Program Files (x86)\FileZilla FTP Client\filezilla.exe” ] (already cured)
          [WARN] 513 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\FileZilla FTP Client\Uninstall.lnk” → [ “C:\Program Files (x86)\FileZilla FTP Client\uninstall.exe” ] (already cured)
          [WARN] 514 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Empty Room Systems\EMpTy 250\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uners250.exe” ] (already cured)
          [WARN] 515 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\East West Stormdrum Intakt\Readme.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Stormdrum Intakt\readme.html” ] (already cured)
          [WARN] 517 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DragonDisk\DragonDisk.lnk” → [ “C:\Program Files (x86)\Almageste\DragonDisk\DragonDisk.exe” ] (already cured)
          [WARN] 518 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DragonDisk\Uninstall DragonDisk.lnk” → [ “C:\Program Files (x86)\Almageste\DragonDisk\unins000.exe” ] (already cured)
          [WARN] 519 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DMG Audio\Track Range\Manual.lnk” → [ “C:\Program Files\DMG Audio\Track Range\DMGAudio_TrackRange_Manual.pdf” ] (already cured)
          [WARN] 520 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DMG Audio\Track Range\Uninstall.lnk” → [ “C:\Program Files\DMG Audio\Track Range\unins000.exe” ] (already cured)
          [WARN] 521 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DivX\DivX Converter.lnk” → [ “C:\Program Files (x86)\DivX\DivX Converter\DivXConverterLauncher.exe” ] (already cured)
          [WARN] 522 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DivX\DivX Player.lnk” → [ “C:\Program Files (x86)\DivX\DivX Player\DivX Player.exe” ] (already cured)
          [WARN] 523 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto\Ditto Help.lnk” → [ “C:\Program Files (x86)\Ditto\Help\DittoGettingStarted.htm” ] (already cured)
          [WARN] 524 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto\Ditto.lnk” → [ “C:\Program Files (x86)\Ditto\Ditto.exe” ] (already cured)
          [WARN] 525 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto\Uninstall.lnk” → [ “C:\Program Files (x86)\Ditto\unins000.exe” ] (already cured)
          [WARN] 526 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DisplayFusion\DisplayFusion Uninstall.lnk” → [ “C:\Program Files (x86)\DisplayFusion\unins000.exe” ] (already cured)
          [WARN] 527 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DisplayFusion\DisplayFusion.lnk” → [ “C:\Program Files (x86)\DisplayFusion\DisplayFusion.exe” ] (already cured)
          [WARN] 528 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DiskInternals\DiskInternals ZIP Repair\DiskInternals ZIP Repair.lnk” → [ “C:\Program Files (x86)\DiskInternals\ZipRepair\ZipRepair.exe” ] (already cured)
          [WARN] 529 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DiskInternals\DiskInternals ZIP Repair\Uninstall.lnk” → [ “C:\Program Files (x86)\DiskInternals\ZipRepair\Uninstall.exe” ] (already cured)
          [WARN] 530 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\DCForensics8 Help.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.chm” ] (already cured)
          [WARN] 531 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\Diamond Cut Forensics8.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DCForensics8.exe” ] (already cured)
          [WARN] 532 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio\PDF of DC8Forensics8 Manual.lnk” → [ “C:\Program Files (x86)\Diamond Cut Productions\DCForensics8\DC8Forensics8Manual.pdf” ] (already cured)
          [WARN] 533 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DDMF\Virtual Audio Stream\AudioRecorder.lnk” → [ “C:\Program Files (x86)\DDMF\Virtual Audio Stream\AudioRecorder.exe” ] (already cured)
          [WARN] 534 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DDMF\Virtual Audio Stream\EffectRack.lnk” → [ “C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe” ] (already cured)
          [WARN] 535 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DDMF\Virtual Audio Stream\Uninstall.lnk” → [ “C:\Program Files (x86)\DDMF\Virtual Audio Stream\uninstall.exe” ] (already cured)
          [WARN] 536 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DAEMON Tools Lite\DAEMON Tools Lite.lnk” → [ “C:\Program Files (x86)\DAEMON Tools Lite\DTLauncher.exe” ] (already cured)
          [WARN] 538 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\D16 Group\Repeater\Uninstall.lnk” → [ “C:\Program Files\D16 Group\Repeater\unins000.exe” ] (already cured)
          [WARN] 539 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\cytomic\The Glue - Installation and Quickstart.lnk” → [ “C:\Program Files (x86)\Cytomic\The Glue\The Glue - Installation and Quickstart.pdf” ] (already cured)
          [WARN] 540 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\cytomic\The Glue - Release Notes.lnk” → [ “C:\Program Files (x86)\Cytomic\The Glue\The Glue - Release Notes.pdf” ] (already cured)
          [WARN] 543 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Creative\Creative Software AutoUpdate.lnk” → [ “C:\Program Files (x86)\Creative\Shared Files\Software Update\AutoUpdate.exe” ] (already cured)
          [WARN] 544 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Creative\Sound Blaster X-Fi MB 2\Creative Music Server.lnk” → [ “C:\Program Files (x86)\Creative\Sound Blaster X-Fi MB 2\Music Server\MusicSvr.exe” ] (already cured)
          [WARN] 545 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Creative\Sound Blaster X-Fi MB 2\Sound Blaster Console.lnk” → [ “C:\Program Files (x86)\Creative\Sound Blaster X-Fi MB 2\Sound Blaster Console\SBCsl.exe” ] (already cured)
          [WARN] 546 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Creative\Sound Blaster X-Fi MB 2\Sound Blaster Panel.lnk” → [ “C:\Program Files (x86)\Creative\Sound Blaster X-Fi MB 2\Sound Blaster Panel\VolPanlu.exe” ] (already cured)
          [WARN] 547 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Creative\Sound Blaster X-Fi MB 2\THX TruStudio Pro Settings.lnk” → [ “C:\Program Files (x86)\Creative\Sound Blaster X-Fi MB 2\THXAudioCP\THXAudio.exe” ] (already cured)
          [WARN] 548 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Creative\ALchemy\Creative ALchemy.lnk” → [ “C:\Program Files (x86)\Creative\ALchemy\ALchemy.exe” ] (already cured)
          [WARN] 549 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CP Control\CP Control.lnk” → [ “C:\Program Files (x86)\CP Control\Application\CP Control.exe” ] (already cured)
          [WARN] 550 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CP Control\Uninstall CP Control.lnk” → [ “C:\Program Files (x86)\CP Control\uninstall.exe” ] (already cured)
          [WARN] 551 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner\CCleaner.lnk” → [ “C:\Program Files\CCleaner\CCleaner64.exe” ] (already cured)
          [WARN] 552 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management\calibre 64bit - E-book management.lnk” → [ “C:\Program Files\Calibre2\calibre.exe” ] (already cured)
          [WARN] 553 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management\E-book viewer 64bit.lnk” → [ “C:\Program Files\Calibre2\ebook-viewer.exe” ] (already cured)
          [WARN] 554 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management\Edit E-book 64bit.lnk” → [ “C:\Program Files\Calibre2\ebook-edit.exe” ] (already cured)
          [WARN] 555 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management\LRF viewer 64bit.lnk” → [ “C:\Program Files\Calibre2\lrfviewer.exe” ] (already cured)
          [WARN] 556 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Boz Digital Labs\Sasquatch\Uninstall Sasquatch.lnk” → [ “C:\Program Files\BozDigitalLabs\Sasquatch\unins000.exe” ] (already cured)
          [WARN] 557 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Boz Digital Labs\Plus 10 db\Uninstall Plus10db.lnk” → [ “C:\Program Files\BozDigitalLabs\Plus 10 db\unins000.exe” ] (already cured)
          [WARN] 558 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Boz Digital Labs\Plus 10 db\User guide.lnk” → [ “C:\Program Files\BozDigitalLabs\Plus 10 db\Plus10db_manual.pdf” ] (already cured)
          [WARN] 559 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Boz Digital Labs\Manic Compressor\Uninstall ManicCompressor.lnk” → [ “C:\Program Files\BozDigitalLabs\Manic Compressor\unins000.exe” ] (already cured)
          [WARN] 560 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Boz Digital Labs\Manic Compressor\User guide.lnk” → [ “C:\Program Files\BozDigitalLabs\Manic Compressor\ManicCompressor_manual.pdf” ] (already cured)
          [WARN] 561 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Boz Digital Labs\Imperial Delay 1_5\Uninstall ImperialDelay_1_5.lnk” → [ “C:\Program Files\BozDigitalLabs\Imperial Delay 1_5\unins000.exe” ] (already cured)
          [WARN] 562 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Black Rooster Audio\Plugin Pack\Canary Manual.lnk” → [ “C:\Program Files\Black Rooster Audio\Manuals\Canary.pdf” ] (already cured)
          [WARN] 563 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Black Rooster Audio\Plugin Pack\Uninstall Plugin Pack.lnk” → [ “C:\Program Files\Black Rooster Audio\Uninstaller\unins000.exe” ] (already cured)
          [WARN] 564 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Black Rooster Audio\Plugin Pack\VLA-2A Manual.lnk” → [ “C:\Program Files\Black Rooster Audio\Manuals\VLA-2A.pdf” ] (already cured)
          [WARN] 565 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVS4YOU\Activation.lnk” → [ “C:\Program Files (x86)\AVS4YOU\Registration.exe” ] (already cured)
          [WARN] 566 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVS4YOU\AVS4YOU Activation.lnk” → [ “C:\Program Files (x86)\AVS4YOU\Registration.exe” ] (already cured)
          [WARN] 567 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVS4YOU\Help.lnk” → [ “C:\Program Files (x86)\AVS4YOU\AVS4YOUHelp.chm” ] (already cured)
          [WARN] 568 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVS4YOU\License Agreement.lnk” → [ “C:\Program Files (x86)\AVS4YOU\License Agreement.rtf” ] (already cured)
          [WARN] 569 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid\Pro Tools\DigiTest.lnk” → [ “C:\Program Files (x86)\Avid\Pro Tools\Pro Tools Utilities\DigiTest\DigiTest.exe” ] (already cured)
          [WARN] 570 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid\Pro Tools\Pro Tools 10.lnk” → [ “C:\Program Files (x86)\Avid\Pro Tools\ProTools.exe” ] (already cured)
          [WARN] 571 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid\Mbox\Mbox Control Panel.lnk” → [ “C:\Program Files (x86)\Avid\Mbox\Panel.exe” ] (already cured)
          [WARN] 573 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Uninstall Altiverb 6\Altiverb 6.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Uninstall\unins000.exe” ] (already cured)
          [WARN] 574 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Altiverb 6 Manual.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Altiverb 6 Manual.pdf” ] (already cured)
          [WARN] 575 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Disable Automatic Update Checks.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Disable Automatic Update Checks.reg” ] (already cured)
          [WARN] 576 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Enable Automatic Update Checks.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Enable Automatic Update Checks.reg” ] (already cured)
          [WARN] 577 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Troubleshooting\Altiverb 6 - Disable Diagnostics.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Disable Diagnostics.reg” ] (already cured)
          [WARN] 578 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Troubleshooting\Altiverb 6 - Disable OpenGL.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Disable OpenGL.reg” ] (already cured)
          [WARN] 579 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Troubleshooting\Altiverb 6 - Disable Quicktime.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Disable Quicktime.reg” ] (already cured)
          [WARN] 580 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Troubleshooting\Altiverb 6 - Enable Diagnostics.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Enable Diagnostics.reg” ] (already cured)
          [WARN] 581 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Troubleshooting\Altiverb 6 - Enable OpenGL.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Enable OpenGL.reg” ] (already cured)
          [WARN] 582 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease\Altiverb 6\Troubleshooting\Altiverb 6 - Enable Quicktime.lnk” → [ “C:\Program Files (x86)\Audio Ease\Altiverb 6\Utilities\Altiverb 6 - Enable Quicktime.reg” ] (already cured)
          [WARN] 585 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Assault\Head Crusher\Uninstall Head Crusher.lnk” → [ “C:\Program Files\Head Crusher\unins000.exe” ] (already cured)
          [WARN] 586 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ASUS\AI Suite II\AI Suite II 2.01.02.lnk” → [ “C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe” ] (already cured)
          [WARN] 587 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcSoft Portrait+ 3\Portrait+ 3(64 bit).lnk” → [ “C:\Program Files (x86)\ArcSoft\Portrait+ 3(64 bit)\PortraitPlus.exe” ] (already cured)
          [WARN] 588 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcSoft Portrait+ 3\Portrait+ 3.lnk” → [ “C:\Program Files (x86)\ArcSoft\Portrait+ 3\PortraitPlus.exe” ] (already cured)
          [WARN] 589 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Applied Acoustics Systems\Chromaphone\Chromaphone (32-bit).lnk” → [ “C:\Program Files (x86)\Applied Acoustics Systems\Chromaphone\bin32\Chromaphone.exe” ] (already cured)
          [WARN] 590 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Applied Acoustics Systems\Chromaphone\Chromaphone (64-bit).lnk” → [ “C:\Program Files (x86)\Applied Acoustics Systems\Chromaphone\bin64\Chromaphone.exe” ] (already cured)
          [WARN] 591 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\Mic Mod EFX VST\Launch Authorization Read Me.pdf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\Mic Mod EFX VST\Authorization Read Me.pdf” ] (already cured)
          [WARN] 592 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\Mic Mod EFX VST\Launch Mic Mod EFX License.rtf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\Mic Mod EFX VST\Mic Mod EFX License.rtf” ] (already cured)
          [WARN] 593 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\Mic Mod EFX VST\Launch Mic_Mod_EFX_manual.pdf.lnk” → [ “C:\Program Files (x86)\Antares Audio Technologies\Mic Mod EFX VST\Mic_Mod_EFX_manual.pdf” ] (already cured)
          [WARN] 601 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Altiverb 7\Altiverb 7 manual.lnk” → [ “C:\Program Files\Audio Ease\Altiverb 7\Altiverb 7 manual.pdf” ] (already cured)
          [WARN] 602 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Altiverb 7\Diagnostics.lnk” → [ “C:\ProgramData\Audio Ease\Altiverb 7\Diagnostics” ] (already cured)
          [WARN] 603 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Altiverb 7\Uninstall Altiverb 7.lnk” → [ “C:\Program Files\Audio Ease\Altiverb 7\Uninstaller\unins000.exe” ] (already cured)
          [WARN] 616 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AcusticaAudio\Uninstall Nebula3.lnk” → [ “C:\nebulatemprepository\uninstall3.exe” ] (already cured)
          [WARN] 617 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Acronis True Image.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageLauncher.exe” ] (already cured)
          [WARN] 618 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis\True Image\Tools and Utilities\Acronis System Report.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\SystemReport.exe” ] (already cured)
          [WARN] 630 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\7-Zip\7-Zip File Manager.lnk” → [ “C:\Program Files\7-Zip\7zFM.exe” ] (already cured)
          [WARN] 631 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\7-Zip\7-Zip Help.lnk” → [ “C:\Program Files\7-Zip\7-zip.chm” ] (already cured)
          [WARN] 632 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Reverb\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Redline Reverb\Redline Reverb Manual.pdf” ] (already cured)
          [WARN] 633 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Reverb\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\un112rrv.exe” ] (already cured)
          [WARN] 634 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Preamp\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Redline Preamp\Redline Preamp Manual.pdf” ] (already cured)
          [WARN] 635 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Preamp\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\un112rap.exe” ] (already cured)
          [WARN] 636 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Monitor\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Redline Monitor\Redline Monitor Manual.pdf” ] (already cured)
          [WARN] 637 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Monitor\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\un112rlm.exe” ] (already cured)
          [WARN] 638 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Equalizer\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Redline Equalizer\Redline Equalizer Manual.pdf” ] (already cured)
          [WARN] 639 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB\Redline Equalizer\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\un112req.exe” ] (already cured)
          [WARN] 640 “C:\Users\Default\Links\Shared Space.lnk” → [ “C:\ProgramData\Shared Space” ] (already cured)
          [WARN] 660 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\03 - Computer Management.lnk” → [ “C:\Windows\System32\compmgmt.msc” ] (already cured)
          [WARN] 661 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\04 - Disk Management.lnk” → [ “C:\Windows\System32\diskmgmt.msc” ] (already cured)
          [WARN] 662 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\07 - Event Viewer.lnk” → [ “C:\Windows\System32\eventvwr.exe” ] (already cured)
          [WARN] 663 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\09 - Mobility Center.lnk” → [ “C:\WINDOWS\system32\mblctr.exe” ] (already cured)
          [WARN] 664 “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group2\4 - Control Panel.lnk” → [ “C:\Windows\System32\control.exe” ] (already cured)
          [WARN] 665 “C:\Users\Public\Desktop\AATranslator.lnk” → [ “C:\Program Files (x86)\Suite Spot Studios\AATranslator\AATranslator.exe” ] (already cured)
          [WARN] 666 “C:\Users\Public\Desktop\Acronis True Image.lnk” → [ “C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageLauncher.exe” ] (already cured)
          [WARN] 667 “C:\Users\Public\Desktop\Camtasia Studio 8.lnk” → [ “C:\Program Files (x86)\TechSmith\Camtasia Studio 8\CamtasiaStudio.exe” ] (already cured)
          [WARN] 668 “C:\Users\Public\Desktop\Finale NotePad 2012.lnk” → [ “C:\Program Files (x86)\Finale NotePad 2012\Finale NotePad.exe” ] (already cured)
          [WARN] 669 “C:\Users\Public\Desktop\GnuCash.lnk” → [ “C:\Program Files (x86)\gnucash\bin\gnucash.exe” ] (already cured)
          [WARN] 670 “C:\Users\Public\Desktop\Helium Audio Converter.lnk” → [ “C:\Program Files (x86)\Imploded Software\Helium Audio Converter\HeliumAudioConverter.exe” ] (already cured)
          [WARN] 671 “C:\Users\Public\Desktop\Mp3tag.lnk” → [ “C:\Program Files (x86)\Mp3tag\Mp3tag.exe” ] (already cured)
          [WARN] 672 “C:\Users\Public\Desktop\Nero 12.lnk” → [ “C:\Program Files (x86)\Nero\Nero 12\Nero Launcher\NeroLauncher.exe” ] (already cured)
          [WARN] 673 “C:\Users\Public\Desktop\Pro Tools 10.lnk” → [ “C:\Program Files (x86)\Avid\Pro Tools\ProTools.exe” ] (already cured)
          [WARN] 674 “C:\Users\Public\Desktop\REAPER (x64).lnk” → [ “C:\Program Files\REAPER (x64)\reaper.exe” ] (already cured)
          [WARN] 675 “C:\Users\Public\Desktop\Rhyme Genie.lnk” → [ “C:\Program Files (x86)\Idolumic\Rhyme Genie\Rhyme Genie.exe” ] (already cured)
          [WARN] 677 “C:\Users\Public\Desktop\Steam.lnk” → [ “C:\Program Files (x86)\Steam\Steam.exe” ] (already cured)
          [WARN] 679 “C:\Users\Public\Desktop\TuneSmith.lnk” → [ “C:\Program Files (x86)\Idolumic\TuneSmith\TuneSmith.exe” ] (already cured)
          [WARN] 680 “C:\Users\Public\Desktop\VLC media player.lnk” → [ “C:\Program Files (x86)\VideoLAN\VLC\vlc.exe” ] (already cured)
          [WARN] 681 “C:\Users\Public\Desktop\Wirecast.lnk” → [ “C:\Program Files\Telestream\Wirecast\Wirecast.exe” ] (already cured)
          [WARN] 682 “C:\Users\SamSwanson\Links\Copy.lnk” → [ “C:\Users\SamSwanson\Copy” ] (already cured)
          [WARN] 683 “C:\Users\SamSwanson\Links\Desktop.lnk” → [ “C:\Users\SamSwanson\Desktop” ] (already cured)
          [WARN] 684 “C:\Users\SamSwanson\Links\Downloads.lnk” → [ “C:\Users\SamSwanson\Downloads” ] (already cured)
          [WARN] 685 “C:\Users\SamSwanson\Links\Libraries.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Libraries” ] (already cured)
          [WARN] 687 “C:\Users\SamSwanson\Documents\Sonnox\Sonnox Codec Toolbox Quick Start Guide.pdf.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Sonnox\Codec Toolbox\Sonnox Codec Toolbox Quick Start Guide.pdf” ] (already cured)
          [WARN] 688 “C:\Users\SamSwanson\Documents\Sonnox\Sonnox Codec Toolbox User Guide.pdf.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Sonnox\Codec Toolbox\Sonnox Codec Toolbox User Guide.pdf” ] (already cured)
          [WARN] 689 “C:\Users\SamSwanson\Documents\Finale Files\Shortcut to Finale NotePad Tutorials\target.lnk” → [ “C:\Program Files (x86)\Finale NotePad 2012\Music Files\Finale Notepad Tutorials” ] (already cured)
          [WARN] 690 “C:\Users\SamSwanson\Desktop\AnonVPN.lnk” → [ “C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe” ] (already cured)
          [WARN] 692 “C:\Users\SamSwanson\Desktop\EffectRack.lnk” → [ “C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe” ] (already cured)
          [WARN] 693 “C:\Users\SamSwanson\Desktop\Electrum.lnk” → [ “C:\Program Files (x86)\Electrum\electrum.exe” ] (already cured)
          [WARN] 694 “C:\Users\SamSwanson\Desktop\Google Chrome Canary.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe” ] (already cured)
          [WARN] 695 “C:\Users\SamSwanson\Desktop\HOFA CD-Burn & DDP.lnk” → [ “C:\Program Files (x86)\HOFA-Plugins\HOFA CD-Burn & DDP\HOFA CD-Burn & DDP.exe” ] (already cured)
          [WARN] 696 “C:\Users\SamSwanson\Desktop\Kindle.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Amazon\Kindle\a pplication\Kindle.exe” ] (already cured)
          [WARN] 698 “C:\Users\SamSwanson\Desktop\Scott - Shortcut.lnk” → [ “S:\SessionFiles\Scott” ] (already cured)
          [WARN] 699 “C:\Users\SamSwanson\Desktop\SessionFiles - Shortcut.lnk” → [ “S:\SessionFiles” ] (already cured)
          [WARN] 700 “C:\Users\SamSwanson\Desktop\Spotify.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Spotify\Spoti fy.exe” ] (already cured)
          [WARN] 701 “C:\Users\SamSwanson\Desktop\Computer fix\atomiccleaner3.lnk” → [ “C:\Program Files (x86)\atomicware\atomiccleaner3\atomiccleaner3.exe ” ] (already cured)
          [WARN] 702 “C:\Users\SamSwanson\Desktop\Computer fix\PatchCleaner.lnk” → [ “C:\Program Files (x86)\HomeDev\PatchCleaner\PatchCleaner.exe” ] (already cured)
          [WARN] 703 “C:\Users\SamSwanson\Desktop\Computer fix\Revo Uninstaller.lnk” → [ “C:\Program Files\VS Revo Group\Revo Uninstaller\RevoUnin.exe” ] (already cured)
          [WARN] 704 “C:\Users\SamSwanson\Desktop\Computer fix\RogueKiller.lnk” → [ “C:\Program Files\RogueKiller\RogueKiller64.exe” ] (already cured)
          [WARN] 705 “C:\Users\SamSwanson\Desktop\Computer fix\Tweaking.com - Windows Repair.lnk” → [ “C:\Program Files (x86)\Tweaking.com\Windows Repair (All in One)\Repair_Windows.exe” ] (already cured)
          [WARN] 706 “C:\Users\SamSwanson\Desktop\Computer fix\UnHackMe.lnk” → [ “C:\Program Files (x86)\UnHackMe\Unhackme.exe” ] (already cured)
          [WARN] 707 “C:\Users\SamSwanson\Desktop\Computer fix\WinDirStat.lnk” → [ “C:\Program Files (x86)\WinDirStat\windirstat.exe” ] (already cured)
          [WARN] 712 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Ableton Live 9 Suite.lnk” → [ “C:\ProgramData\Ableton\Live 9 Suite\Program\Ableton Live 9 Suite.exe” ] (already cured)
          [WARN] 713 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\calibre - E-book management.lnk” → [ “C:\Program Files\Calibre2\calibre.exe” ] (already cured)
          [WARN] 714 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Google Chrome Canary.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe” ] (already cured)
          [WARN] 715 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\OneDrive.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Microsoft\OneDr ive\OneDrive.exe” ] (already cured)
          [WARN] 716 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Optional Features.lnk” → [ “C:\Windows\System32\fodhelper.exe” ] (already cured)
          [WARN] 717 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\rapidseo.lnk” → [ “C:\Program Files (x86)\Rapid SEO Tool\rapidseo.exe” ] (already cured)
          [WARN] 719 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Spotify.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Spotify\Spoti fy.exe” ] (already cured)
          [WARN] 720 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows Install Clean Up.lnk” → [ “C:\Program Files (x86)\Windows Installer Clean Up\msicuu.exe” ] (already cured)
          [WARN] 721 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\UNFILTER VST-x64 1.2.1\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\UNFILTER VST data\manual.pdf” ] (already cured)
          [WARN] 722 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\UNFILTER VST-x64 1.2.1\UnfilterAuthorizer.lnk” → [ “C:\Program Files (x86)\Zynaptiq\UNFILTER\UnfilterAuthorizer.exe” ] (already cured)
          [WARN] 723 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\UNFILTER VST-x64 1.2.1\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\UNFILTER VST data\uninst.exe” ] (already cured)
          [WARN] 724 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\UNCHIRP VST-x64 1.0.0\UNCHIRP VST-x64 Manual.lnk” → [ “C:\Program Files\VSTPlugIns\UNCHIRP VST data\manual.pdf” ] (already cured)
          [WARN] 725 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\UNCHIRP VST-x64 1.0.0\UNCHIRP VST-x64 Uninstall.lnk” → [ “C:\Program Files\VstPlugins\UNCHIRP VST data\uninst.exe” ] (already cured)
          [WARN] 726 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\PITCHMAP VST-x64 1.6.1\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\PITCHMAP VST data\manual.pdf” ] (already cured)
          [WARN] 727 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\PITCHMAP VST-x64 1.6.1\Uninstall.lnk” → [ “C:\Program Files\VstPlugins\PITCHMAP VST data\uninst.exe” ] (already cured)
          [WARN] 728 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\ADAPTIVERB\Manual.lnk” → [ “C:\Program Files (x86)\Zynaptiq\ADAPTIVERB\Zynaptiq ADAPTIVERB Manual.pdf” ] (already cured)
          [WARN] 729 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptiq\ADAPTIVERB\Uninstall.lnk” → [ “C:\Program Files (x86)\Zynaptiq\ADAPTIVERB\uninstall.exe” ] (already cured)
          [WARN] 730 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Zynaptic\UNVEIL\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\Zynaptic\UNVEIL\uninstall.exe” ] (already cured)
          [WARN] 733 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\WinRAR\WinRAR help.lnk” → [ “C:\Program Files\WinRAR\WinRAR.chm” ] (already cured)
          [WARN] 734 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\WinRAR\WinRAR.lnk” → [ “C:\Program Files\WinRAR\WinRAR.exe” ] (already cured)
          [WARN] 739 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\WinDirStat\Help (ENG).lnk” → [ “C:\Program Files (x86)\WinDirStat\windirstat.chm” ] (already cured)
          [WARN] 740 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\WinDirStat\Uninstall WinDirStat.lnk” → [ “C:\Program Files (x86)\WinDirStat\Uninstall.exe” ] (already cured)
          [WARN] 741 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\WinDirStat\WinDirStat.lnk” → [ “C:\Program Files (x86)\WinDirStat\windirstat.exe” ] (already cured)
          [WARN] 742 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Wave Arts\Dialog\Manual.lnk” → [ “C:\Program Files (x86)\Wave Arts\Dialog\Dialog Manual.pdf” ] (already cured)
          [WARN] 743 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Wave Arts\Dialog\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 744 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\VB Audio\ASIO Bridge\ASIO Bridge.LNK” → [ “C:\Program Files (x86)\VB\ASIOBridge\VBCABLE_AsioBridge.exe” ] (already cured)
          [WARN] 746 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Valhalla DSP\ValhallaVintageVerb\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 747 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Ubisoft\Uplay\Uninstall.lnk” → [ “C:\Program Files (x86)\Ubisoft\Ubisoft Game Launcher\Uninstall.exe” ] (already cured)
          [WARN] 748 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Ubisoft\Uplay\Uplay.lnk” → [ “C:\Program Files (x86)\Ubisoft\Ubisoft Game Launcher\Uplay.exe” ] (already cured)
          [WARN] 749 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\u-he\Satin\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 750 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\u-he\Diva\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\u-he\Diva\uninstall.exe” ] (already cured)
          [WARN] 751 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Toshiba Corporation\SSD Utility\SSD Utility.lnk” → [ “C:\Program Files (x86)\Toshiba Corporation\SSD Utility\SSDUtility.exe” ] (already cured)
          [WARN] 752 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\The KMPlayer\KMPlayer Setup Wizard.lnk” → [ “C:\Program Files (x86)\The KMPlayer\KMPSetup.exe” ] (already cured)
          [WARN] 753 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\The KMPlayer\KMPlayer.lnk” → [ “C:\Program Files (x86)\The KMPlayer\KMPlayer.exe” ] (already cured)
          [WARN] 754 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\The KMPlayer\Uninstall KMPlayer.lnk” → [ “C:\Program Files (x86)\The KMPlayer\uninstall.exe” ] (already cured)
          [WARN] 760 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sugar Bytes\Looperator\Looperator.lnk” → [ “C:\Program Files\Sugar Bytes\Looperator\Looperator.exe” ] (already cured)
          [WARN] 761 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sugar Bytes\Looperator\Manual Standalone.lnk” → [ “C:\Program Files\Sugar Bytes\Looperator\Manual\Standalone Manual.pdf” ] (already cured)
          [WARN] 762 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sugar Bytes\Looperator\Manual.lnk” → [ “C:\Program Files\Sugar Bytes\Looperator\Manual\Manual English.pdf” ] (already cured)
          [WARN] 763 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sugar Bytes\Effectrix\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Manual\Manual.htm” ] (already cured)
          [WARN] 764 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sugar Bytes\Effectrix\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 765 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Startup\EffectRack.lnk” → [ “C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe” ] (already cured)
          [WARN] 767 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Spectrasonics\Omnisphere\Uninstall.l nk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 768 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\SoundToys\Radiator\Manual.lnk” → [ “C:\Program Files (x86)\SoundToys\Radiator\Documents” ] (already cured)
          [WARN] 769 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\SoundToys\Radiator\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 770 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\SoundToys\Native Effects\Manual.lnk” → [ “C:\Program Files (x86)\SoundToys\Native Effects\Manuals” ] (already cured)
          [WARN] 771 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\SoundToys\Native Effects\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 772 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sonoris\Mastering_Compressor\License _Agreement.lnk” → [ “C:\Program Files (x86)\Sonoris\Mastering_Compressor\License_Agreeme nt.pdf” ] (already cured)
          [WARN] 773 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sonoris\Mastering_Compressor\Sonoris _Mastering_Compressor.lnk” → [ “C:\Program Files (x86)\Sonoris\Mastering_Compressor\Help\Sonoris_Ma stering_Compressor.pdf” ] (already cured)
          [WARN] 774 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sonoris\Mastering_Compressor\Uninsta ll.lnk” → [ “C:\Program Files (x86)\Sonoris\Mastering_Compressor\Uninstall.exe” ] (already cured)
          [WARN] 775 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\SONiVOX\Harmonica\Uninstall.lnk” → [ “C:\Program Files (x86)\SONiVOX\Harmonica\uninstall.exe” ] (already cured)
          [WARN] 776 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\SKnote\Roundtone\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 777 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Schaack Audio Technologies\Transient Shaper\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Transient Shaper.pdf” ] (already cured)
          [WARN] 778 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Schaack Audio Technologies\Transient Shaper\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 779 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Sample Magic\Magic AB VST-x64 1.2.2\Uninstall.lnk” → [ “C:\Program Files\VstPlugins\Magic AB VST data\uninst.exe” ] (already cured)
          [WARN] 780 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Plugin Alliance\Manual.lnk” → [ “C:\Program Files\Plugin Alliance” ] (already cured)
          [WARN] 781 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Plugin Alliance\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 782 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Overloud\TH2\Uninstall.lnk” → [ “C:\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 783 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Overloud\SpringAge\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 785 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Overloud\REmatrix\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\Overloud\REmatrix\uninstall.exe” ] (already cured)
          [WARN] 786 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Overloud\BREVERB 2\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 787 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Output\Movement\Manual.lnk” → [ “C:\Program Files (x86)\Output\Movement\Movement_User_Guide.pdf” ] (already cured)
          [WARN] 788 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Output\Movement\Uninstall.lnk” → [ “C:\Program Files (x86)\Output\Movement\uninstall.exe” ] (already cured)
          [WARN] 789 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\NYRV Systems\Agent\Uninstall.lnk” → [ “C:\Program Files (x86)\NYRV Systems\Agent\uninstall.exe” ] (already cured)
          [WARN] 790 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Nomad Factory\MAGMA\Manual.lnk” → [ “C:\Program Files\Common Files\Nomad Factory\MAGMA\Documentation\MAGMA User Manual.pdf” ] (already cured)
          [WARN] 791 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Nomad Factory\MAGMA\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 792 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Maxthon Cloud Browser\Maxthon Cloud Browser.lnk” → [ “C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe” ] (already cured)
          [WARN] 793 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Maxthon Cloud Browser\Uninstall.lnk” → [ “C:\Program Files (x86)\Maxthon\Bin\Mx3UnInstall.exe” ] (already cured)
          [WARN] 794 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Marvell\91xx driver\UnInstall.lnk” → [ “C:\Program Files (x86)\Marvell\mv91xx\uninst-91xx.exe” ] (already cured)
          [WARN] 795 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\MAGIX\Vintage Effects Suite\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 796 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\MAGIX\Variverb II\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 797 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\MAGIX\essetntialFX Suite\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 798 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\MAGIX\Analogue Modelling Suite Plus\Uninstall.lnk” → [ “C:\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 799 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Litecoin Core\Litecoin Core (64-bit).lnk” → [ “C:\Program Files\Litecoin\litecoin-qt.exe” ] (already cured)
          [WARN] 801 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Litecoin\Litecoin.lnk” → [ “C:\Program Files (x86)\Litecoin\litecoin-qt.exe” ] (already cured)
          [WARN] 802 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Litecoin\Uninstall Litecoin.lnk” → [ “C:\Program Files (x86)\Litecoin\uninstall.exe” ] (already cured)
          [WARN] 803 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Kuassa\Amplifikation One\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\AmplifikationOne Files\AmplifikationOne Manual.pdf” ] (already cured)
          [WARN] 804 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Kuassa\Amplifikation One\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 805 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Kindle DRM Removal\Kindle DRM Removal.lnk” → [ “C:\Program Files (x86)\eBookConverter\Kindle DRM Removal\KindleDRM.exe” ] (already cured)
          [WARN] 807 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Kindle DRM Removal\Uninstall.lnk” → [ “C:\Program Files (x86)\eBookConverter\Kindle DRM Removal\Uninstall.exe” ] (already cured)
          [WARN] 809 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Jack\Uninstall.lnk” → [ “C:\Program Files (x86)\Jack\uninstall.exe” ] (already cured)
          [WARN] 810 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\iZotope\RX 2 Advanced\Manual.lnk” → [ “C:\Program Files (x86)\iZotope\RX 2 Advanced\Documents” ] (already cured)
          [WARN] 811 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\iZotope\RX 2 Advanced\RX 2 Advanced.lnk” → [ “C:\Program Files (x86)\iZotope\RX 2 Advanced\iZotope RX 2.exe” ] (already cured)
          [WARN] 812 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\iZotope\RX 2 Advanced\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\iZotope\RX 2 Advanced\uninstall.exe” ] (already cured)
          [WARN] 813 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\iZotope\Ozone 5 Advanced\Manual.lnk” → [ “C:\Program Files (x86)\iZotope\Ozone 5 Advanced\iZOzone5_en.pdf” ] (already cured)
          [WARN] 814 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\iZotope\Ozone 5 Advanced\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 815 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\iZotope\Nectar\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\Manuals” ] (already cured)
          [WARN] 816 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\iZotope\Nectar\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 817 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Ivideon\Ivideon Server\Ivideon Server.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Ivideon\Ivideon Server\IvideonServer.exe” ] (already cured)
          [WARN] 818 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Ivideon\Ivideon Server\Uninstall.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Ivideon\Ivideon Server\Uninstall.exe” ] (already cured)
          [WARN] 819 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Image-Line\IL Download Manager.lnk” → [ “C:\Program Files (x86)\Image-Line\Downloader\ILDownloadManager.exe” ] (already cured)
          [WARN] 820 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Image-Line\More…lnk” → [ “C:\Program Files (x86)\Image-Line\Shared\Start” ] (already cured)
          [WARN] 821 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\IK Multimedia\T-Racks CS\Manual.lnk” → [ “C:\Program Files (x86)\IK Multimedia\T-Racks CS\T-RackS CS User Manual.pdf” ] (already cured)
          [WARN] 822 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\HOFA-Plugins\HOFA IQ-Reverb\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\HOFA-Plugins\HOFA IQ-Reverb\uninstall.exe” ] (already cured)
          [WARN] 823 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\HOFA-Plugins\HOFA IQ-Eq\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\HOFA-Plugins\HOFA IQ-Eq\uninstall.exe” ] (already cured)
          [WARN] 824 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\HOFA-Plugins\HOFA IQ-Comp\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\HOFA-Plugins\HOFA IQ-Comp\uninstall.exe” ] (already cured)
          [WARN] 825 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\HOFA-Plugins\HOFA CD-Burn & DDP\HOFA CD-Burn & DDP.lnk” → [ “C:\Program Files (x86)\HOFA-Plugins\HOFA CD-Burn & DDP\HOFA CD-Burn & DDP.exe” ] (already cured)
          [WARN] 826 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\HOFA-Plugins\HOFA CD-Burn & DDP\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\HOFA-Plugins\HOFA CD-Burn & DDP\uninstall.exe” ] (already cured)
          [WARN] 828 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Handbrake\Uninstall.lnk” → [ “C:\Program Files\Handbrake\uninst.exe” ] (already cured)
          [WARN] 829 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Gizmo Central\Gizmo.lnk” → [ “C:\Program Files (x86)\Gizmo\gizmo.exe” ] (already cured)
          [WARN] 830 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\G-Sonique\Ultrabass MX 4-4\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\G-Sonique\Ultrabass MX 4-4\uninstall.exe” ] (already cured)
          [WARN] 831 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Focusrite\Midnight Plug-in Suite\Manual.lnk” → [ “C:\Program Files (x86)\Focusrite\Midnight Plug-in Suite\Documents” ] (already cured)
          [WARN] 832 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Focusrite\Midnight Plug-in Suite\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 833 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Flux\Flux.lnk” → [ “C:\Users\SamSwanson\AppData\Local\FluxSoftware\Fl ux\flux.exe” ] (already cured)
          [WARN] 834 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Flux\Uninstall.lnk” → [ “C:\Users\SamSwanson\AppData\Local\FluxSoftware\Fl ux\uninstall.exe” ] (already cured)
          [WARN] 835 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Flux\Junger Audio Level Magic 5.1\Uninstall.lnk” → [ “C:\Program Files (x86)\Flux\Junger Audio Level Magic 5.1\uninstall.exe” ] (already cured)
          [WARN] 836 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Fidelify\Uninstall.lnk” → [ “C:\Program Files (x86)\Fidelify\uninstall.exe” ] (already cured)
          [WARN] 837 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Volcano 2\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Volcano 2\FabFilter Volcano 2.chm” ] (already cured)
          [WARN] 838 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Volcano 2\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 839 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Timeless 2\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Timeless 2\FabFilter Timeless 2.chm” ] (already cured)
          [WARN] 840 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Timeless 2\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 841 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Saturn\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Saturn\FabFilter Saturn.chm” ] (already cured)
          [WARN] 842 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Saturn\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 843 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-Q 2\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Pro-Q 2\FabFilter Pro-Q 2.chm” ] (already cured)
          [WARN] 844 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-Q 2\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\FabFilter\Pro-Q 2\uninstall.exe” ] (already cured)
          [WARN] 845 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-Q\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Pro-Q\FabFilter Pro-Q.chm” ] (already cured)
          [WARN] 846 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-Q\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 847 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-MB\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Pro-MB\FabFilter Pro-MB.chm” ] (already cured)
          [WARN] 848 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-MB\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\FabFilter\Pro-MB\uninstall.exe” ] (already cured)
          [WARN] 849 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-L\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Pro-L\FabFilter Pro-L.chm” ] (already cured)
          [WARN] 850 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-L\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 851 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-G\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Pro-G\FabFilter Pro-G.chm” ] (already cured)
          [WARN] 852 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-G\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 853 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-DS\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Pro-DS\FabFilter Pro-DS.chm” ] (already cured)
          [WARN] 854 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-DS\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 855 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-C\Manual.lnk” → [ “C:\Program Files (x86)\FabFilter\Pro-C\FabFilter Pro-C.chm” ] (already cured)
          [WARN] 856 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\FabFilter\Pro-C\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 857 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Electrum\Electrum.lnk” → [ “C:\Program Files (x86)\Electrum\electrum.exe” ] (already cured)
          [WARN] 858 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Electrum\Uninstall.lnk” → [ “C:\Program Files (x86)\Electrum\Uninstall.exe” ] (already cured)
          [WARN] 859 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Dropbox\Uninstall Dropbox.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\D ropboxUninstaller.exe” ] (already cured)
          [WARN] 860 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\PitchFunk\Manual.lnk” → [ “C:\Program Files (x86)\DMG Audio\PitchFunk\DMGAudio PitchFunk Manual.pdf” ] (already cured)
          [WARN] 861 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\PitchFunk\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 862 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\EQuilibrium\Manual.lnk” → [ “C:\Program Files (x86)\DMG Audio\EQuilibrium\DMGAudio EQuilibrium Manual.pdf” ] (already cured)
          [WARN] 863 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\EQuilibrium\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 864 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\EQuick\Manual.lnk” → [ “C:\Program Files (x86)\DMG Audio\EQuick\DMGAudio EQuick Manual.pdf” ] (already cured)
          [WARN] 865 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\EQuick\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 866 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\EQuality\Manual.lnk” → [ “C:\Program Files (x86)\DMG Audio\EQuality\DMGAudio EQuality Manual.pdf” ] (already cured)
          [WARN] 867 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\EQuality\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 868 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\Compassion\Manual.lnk” → [ “C:\Program Files (x86)\DMG Audio\Compassion\DMGAudio Compassion Manual.pdf” ] (already cured)
          [WARN] 869 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\DMG Audio\Compassion\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 870 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Dashlane\Dashlane.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dash lane.exe” ] (already cured)
          [WARN] 871 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Dashlane\Uninstaller.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Dashlane\4.6. 7.25343\bin\DashlaneUninstall.exe” ] (already cured)
          [WARN] 872 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Cytomic\The Glue\Manual.lnk” → [ “C:\Program Files\VSTPlugIns\The Glue - Installation and Quickstart.pdf” ] (already cured)
          [WARN] 873 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Cytomic\The Glue\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 874 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Crysonic\ANUNA\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 875 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Celemony\Melodyne Studio 4\Manual.lnk” → [ “C:\Program Files (x86)\Celemony\Melodyne Studio 4\Melodyne 4 Introduction.pdf” ] (already cured)
          [WARN] 876 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Celemony\Melodyne Studio 4\Melodyne Studio 4.lnk” → [ “C:\Program Files\Celemony\Melodyne Studio 4\Melodyne.exe” ] (already cured)
          [WARN] 877 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Celemony\Melodyne Studio 4\Uninstall.lnk” → [ “C:\Program Files (x86)\Celemony\Melodyne Studio 4\uninstall.exe” ] (already cured)
          [WARN] 878 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Celemony\Melodyne Editor\Melodyne Editor.lnk” → [ “C:\Program Files\Celemony\Melodyne editor\Melodyne singletrack.exe” ] (already cured)
          [WARN] 879 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Celemony\Melodyne Editor\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 880 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\CDSoundMaster\VTM-M2\Manual.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\CDSoundMaster\VTM-M2\VTM-M2-Manual.pdf” ] (already cured)
          [WARN] 881 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\CDSoundMaster\VTM-M2\Uninstall.lnk” → [ “C:\Program Files (x86)\VSTPlugIns\CDSoundMaster\VTM-M2\uninstall.exe” ] (already cured)
          [WARN] 882 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\BWF MetaEdit\BWF MetaEdit.lnk” → [ “C:\Program Files\BWF MetaEdit\bwfedit-gui.exe” ] (already cured)
          [WARN] 884 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\BWF MetaEdit\Uninstall.lnk” → [ “C:\Program Files\BWF MetaEdit\uninst.exe” ] (already cured)
          [WARN] 886 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\AVS4YOU\Uninstall.lnk” → [ “C:\Program Files (x86)\AVS4YOU\Uninstall.exe” ] (already cured)
          [WARN] 887 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\ASIO4ALL v2\ASIO4ALL v2 Instruction Manual.lnk” → [ “C:\Program Files (x86)\ASIO4ALL v2\ASIO4ALL v2 Instruction Manual.pdf” ] (already cured)
          [WARN] 889 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\ASIO4ALL v2\Uninstall.lnk” → [ “C:\Program Files (x86)\ASIO4ALL v2\uninstall.exe” ] (already cured)
          [WARN] 890 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\AnonVPN\AnonVPN.lnk” → [ “C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe” ] (already cured)
          [WARN] 891 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\AnonVPN\Uninstall AnonVPN.lnk” → [ “C:\Program Files (x86)\AnonVPN\Uninstall.exe” ] (already cured)
          [WARN] 892 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Amazon\Amazon Kindle\Kindle.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Amazon\Kindle\a pplication\Kindle.exe” ] (already cured)
          [WARN] 893 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Amazon\Amazon Kindle\Uninstall Kindle.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Amazon\Kindle\a pplication\uninstall.exe” ] (already cured)
          [WARN] 899 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\A.O.M. Factory\Stereo Imager D\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 900 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\A.O.M. Factory\A.O.M. Invisible Limiter\Uninstall.lnk” → [ “C:\Program Files\VSTPlugIns\uninstall.exe” ] (already cured)
          [WARN] 901 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\SendTo\AVS Mobile Uploader.lnk” → [ “C:\Program Files (x86)\Common Files\AVSMedia\MobileUploader\AVSMobileUploader.ex e” ] (already cured)
          [WARN] 902 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\SendTo\Bluetooth File Transfer.LNK” → [ “C:\Windows\System32\fsquirt.exe” ] (already cured)
          [WARN] 903 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Finale NotePad 2012.lnk” → [ “C:\Program Files (x86)\Finale NotePad 2012\Finale NotePad.exe” ] (already cured)
          [WARN] 904 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Google Chrome Canary.lnk” → [ “C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe” ] (already cured)
          [WARN] 905 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Google Chrome.lnk” → [ “C:\Program Files (x86)\Google\Chrome\Application\chrome.exe” ] (already cured)
          [WARN] 907 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Pro Tools 10.lnk” → [ “C:\Program Files (x86)\Avid\Pro Tools\ProTools.exe” ] (already cured)
          [WARN] 910 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\User Pinned\TaskBar\EffectRack.lnk” → [ “C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe” ] (already cured)
          [WARN] 916 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\03 - Computer Management.lnk” → [ “C:\Windows\System32\compmgmt.msc” ] (already cured)
          [WARN] 917 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\04 - Disk Management.lnk” → [ “C:\Windows\System32\diskmgmt.msc” ] (already cured)
          [WARN] 918 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\07 - Event Viewer.lnk” → [ “C:\Windows\System32\eventvwr.exe” ] (already cured)
          [WARN] 919 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\09 - Mobility Center.lnk” → [ “C:\WINDOWS\system32\mblctr.exe” ] (already cured)
          [WARN] 920 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group2\4 - Control Panel.lnk” → [ “C:\Windows\System32\control.exe” ] (already cured)
          [WARN] 921 “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\GameExplorer{FB493C78-F984-42E5-93C9-ECB086EAAAAB}\PlayTasks\0\Play.lnk” → [ “S:\SteamGameLibrary\SteamApps\common\Day of Defeat Source\hl2.exe” ] (already cured)
          [WARN] 999 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox\Mozilla Firefox (Safe Mode).lnk” → [ “C:\Program Files (x86)\Mozilla Firefox\firefox.exe” -safe-mode ] (already cured)
          [WARN] 1112 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Google Chrome\Chrome App Launcher.lnk” → [ “C:\Program Files (x86)\Google\Chrome\Application\chrome.exe” --show-app-list ] (already cured)
          [WARN] 1115 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Dropbox\Dropbox.lnk” → [ “C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\D ropbox.exe” /home ] (already cured)
          [WARN] 1119 “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Int ernet Explorer\Quick Launch\Chrome App Launcher.lnk” → [ “C:\Program Files (x86)\Google\Chrome\Application\chrome.exe” --show-app-list ] (already cured)
          [WARN] 1130 “C:\Users\SamSwanson\AppData\Local\Google\Chrome\U ser Data\Chrome App Launcher.lnk” → [ “C:\Program Files (x86)\Google\Chrome\Application\chrome.exe” --show-app-list ] (already cured)
          ____________________________ Icons location _____________________________
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu Places\01 - File Explorer.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Gobbler.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Immersive Control Panel.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PrintDialog.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware\Zemana AntiMalware.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tradeo - MetaTrader 4\Tradeo - MT4.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools\Windows Defender.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonarworks\Sonarworks\Sonarworks HD reference.lnk” → [ “.”, index=1 ] (Method: 4)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonarworks\Sonarworks\Sonarworks Reference 3.lnk” → [ “.”, index=1 ] (Method: 4)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MetaTrader 5\MetaTrader 5.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\Configure Java.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Extreme Tuning Utility\Intel(R) Extreme Tuning Utility.lnk” → [ “.”, index=1 ] (Method: 4)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CrystalDiskInfo\CrystalDiskInfo Shizuku Edition.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CrystalDiskInfo\CrystalDiskInfo.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Articulator Setup.pdf.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Authorization Read Me.pdf.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch AVOX Evo License.rtf.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch AVOX Evo Manual.pdf.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch AVOX THROAT Presets Read Me.rtf.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Harmony Engine Evo Manual.pdf.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies\AVOX Evo VST\Launch Harmony Engine Evo VST PC Read Me.pdf.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Component Services.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\dfrgui.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Disk Cleanup.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\iSCSI Initiator.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Memory Diagnostics Tool.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\ODBC Data Sources (32-bit).lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\ODBC Data Sources (64-bit).lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Print Management.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\services.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\System Configuration.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\System Information.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Windows Firewall with Advanced Security.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Math Input Panel.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Paint.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Quick Assist.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Remote Desktop Connection.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Snipping Tool.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Steps Recorder.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Windows Fax and Scan.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Wordpad.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\XPS Viewer.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\System Tools\Character Map.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell (x86).lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE (x86).lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Windows PowerShell\Windows PowerShell.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessories\Notepad.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessibility\Magnify.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessibility\Narrator.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\Accessibility\On-Screen Keyboard.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\01a - Windows PowerShell.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Local\Microsoft\Windows\ WinX\Group3\02a - Windows PowerShell.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Public\Desktop\Sonarworks Reference.lnk” → [ “.”, index=1 ] (Method: 4)
          [ OK ] “C:\Users\Public\Desktop\Tradeo - MetaTrader 4.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\Users\SamSwanson\Desktop\Dashlane.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell (x86).lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE (x86).lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell ISE.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Windows PowerShell\Windows PowerShell.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Jack\Jack Control.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessories\Notepad.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessibility\Magnify.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessibility\Narrator.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\Accessibility\On-Screen Keyboard.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\01a - Windows PowerShell.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Local\Microsoft\Windo ws\WinX\Group3\02a - Windows PowerShell.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Media Player.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools\Task Manager.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Manage Remote Computer’s SoftEther VPN Client.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Configuration Tools\TCP Optimization Utility.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Administrative Tools\Debugging Information Collecting Tool.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client\Administrative Tools\Network Traffic Speed Test Tool.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\About Java.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java\Check For Updates.lnk” → [ “.”, index=1 ] (Method: 6)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Computer Management.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Event Viewer.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Performance Monitor.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Resource Monitor.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Security Configuration Management.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\Task Scheduler.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Windows Media Player.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessibility\Speech Recognition.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\Default\AppData\Roaming\Microsoft\Window s\SendTo\Fax Recipient.lnk” → [ “.”, index=1 ] (Method: 3)
          [ OK ] “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\SendTo\Fax Recipient.lnk” → [ “.”, index=1 ] (Method: 6)
          ______________________________ Statistics _______________________________
          Cure ran per today: 1 times.
          Total processed: 1160
          Cured: 249
          Deleted: 97
          Omitted: 95
          Blocked: 5
          Warnings: 719
          ______________________________ End of Log _______________________________
          ______________________________ Debug Info _______________________________
          • Shortcut is damaged: “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MiracastView.lnk” (2219 bytes)
          • Shortcut is damaged: “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\computer.lnk” (335 bytes)
          • Shortcut is damaged: “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\Control Panel.lnk” (405 bytes)
          • Shortcut is damaged: “C:\Users\Default\AppData\Roaming\Microsoft\Window s\Start Menu\Programs\System Tools\Run.lnk” (409 bytes)
          • Shortcut is damaged: “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\computer.lnk” (335 bytes)
          • Shortcut is damaged: “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\Control Panel.lnk” (405 bytes)
          • Shortcut is damaged: “C:\Users\SamSwanson\AppData\Roaming\Microsoft\Win dows\Start Menu\Programs\System Tools\Run.lnk” (409 bytes)
            03/01/2017 9:46:32 PM - clsMD5_hash.DigestFileToHexStr - #75 Path/File access error. LastDllError = 0. File= C:\Program Files (x86)\Image-Line\Shared\Start
            03/01/2017 9:46:32 PM - clsMD5_hash.DigestFileToHexStr - #52 (You were not connected because a duplicate name exists on the network. If joining a domain, go to System in Control Panel to change the computer name and try again. If joining a workgroup, choose another workgroup name.) Bad file name or number. LastDllError = 317. File= C:\Program Files (x86)\Image-Line\Shared\Start
            ___________________________ End of debugging ____________________________CRC32: 320721D8
          RogueKiller:
          RogueKiller V12.9.9.0 (x64) [Feb 27 2017] (Free) by Adlice Software
          mail : Support Form | Contact • Adlice Software
          Feedback : http://forum.adlice.com
          Website : Free Virus Cleaner | RogueKiller AntiMalware • Adlice Software
          Blog : http://www.adlice.com
          Operating System : Windows 10 (10.0.14393) 64 bits version
          Started in : Normal mode
          User : SamSwanson [Administrator]
          Started from : C:\Users\SamSwanson\Desktop\Computer fix\RogueKillerX64.exe
          Mode : Delete – Date : 03/01/2017 21:49:27 (Duration : 00:31:51)
          ¤¤¤ Processes : 0 ¤¤¤
          ¤¤¤ Registry : 2 ¤¤¤
          [ManyCam] (X64) HKEY_USERS\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\ManyCam → Deleted
          [ManyCam] (X86) HKEY_USERS\S-1-5-21-3236326594-2611474830-2656184370-1001\Software\ManyCam → Deleted
          ¤¤¤ Tasks : 0 ¤¤¤
          ¤¤¤ Files : 1 ¤¤¤
          [Adw.Cloudguard][File] C:\Users\SamSwanson\Documents\Microsoft.Win32.Task Scheduler.dll → Deleted
          ¤¤¤ WMI : 0 ¤¤¤
          ¤¤¤ Hosts File : 0 ¤¤¤
          ¤¤¤ Antirootkit : 0 (Driver: Loaded) ¤¤¤
          ¤¤¤ Web browsers : 1 ¤¤¤
          [PUP.Gen0][Chrome:Addon] Default : Bitly | Unleash the power of the link [iabeihobmhlgpkcgjiloemdbofjbdcic] → ERROR [2]
          ¤¤¤ MBR Check : ¤¤¤
          +++++ PhysicalDrive0: TOSHIBA DT01ACA300 +++++
          — User —
          [MBR] 78fdc8d3b1f26c08622f93a8a7354bbd
          [BSP] 19cabced11aa3dd8276eedf190a206af : Windows Vista/7/8|VT.Unknown MBR Code
          Partition table:
          0 - Microsoft reserved partition | Offset (sectors): 34 | Size: 128 MB
          1 - Basic data partition | Offset (sectors): 264192 | Size: 2861459 MB
          User = LL1 … OK
          User = LL2 … OK
          +++++ PhysicalDrive1: OCZ-AGILITY4 +++++
          — User —
          [MBR] 9898d9d1072fd9941a4986e671466750
          [BSP] 123caec5dc8fa688a9ffe28160afdac2 : Windows Vista/7/8 MBR Code
          Partition table:
          0 - [ACTIVE] NTFS (0x7) [VISIBLE] Offset (sectors): 2048 | Size: 350 MB [Windows Vista/7/8 Bootstrap | Windows Vista/7/8 Bootloader]
          1 - [XXXXXX] NTFS (0x7) [VISIBLE] Offset (sectors): 718848 | Size: 243846 MB [Windows Vista/7/8 Bootstrap | Windows Vista/7/8 Bootloader]
          User = LL1 … OK
          User = LL2 … OK
          +++++ PhysicalDrive2: WDC WD30EZRZ-00Z5HB0 +++++
          — User —
          [MBR] 55263320db473a9323eb006365ab045a
          [BSP] b69224873c9f7dc8db7581f798fe915c : Windows Vista/7/8|VT.Unknown MBR Code
          Partition table:
          User = LL1 … OK
          User = LL2 … OK
          +++++ PhysicalDrive3: Generic Compact Flash USB Device +++++
          Error reading User MBR! ([15] The device is not ready. )
          Error reading LL1 MBR! NOT VALID!
          Error reading LL2 MBR! ([32] The request is not supported. )
          +++++ PhysicalDrive4: Generic SM/xD-Picture USB Device +++++
          +++++ PhysicalDrive5: Generic SDXC/MMC USB Device +++++
          +++++ PhysicalDrive6: Generic MS/MS-Pro/HG USB Device +++++
          +++++ PhysicalDrive7: Generic SD/MMC/MS/MSPRO USB Device +++++
          • Malnutrition
            PCHF Moderator
            • 7041
            Issue solved now?
            • slonslon7
              • Mar 2017
              • 14
              Thank you very much, the computer cpu type issues seem very well solved.
              Just checked in the browser (chrome) and still when entering new websites in the omnibar, in the bottom left corner it will quickly say “waiting for ***.freddysrentals.c0m”
              The weirdest thing because I’ve never heard of the site, but no matter what site I go to it still does this first.
              • Malnutrition
                PCHF Moderator
                • 7041
                Alright, lets check a little deeper…
                First Back up Chrome Settings. The tool does a backup, just to make sure best to back up manually as well.
                How to Backup and Restore Google Chrome's Entire Settings][/URL]
                [li]https://i.imgur.com/vwUeyaZ.png[/li]
                [li]Now close all open browsers. – Disable Antivirus Applications – Third Party Firewall…[/li]
                [li]Download ResetBrowser To your desktop.[/li][li]Right click and run as administrator.[/li][li]Click on Reset Chrome. – Allow completion.[/li][/ul]
                Now lets use a tool that looks bit deeper than FRST. To see if there is malware hiding on your machine…
                ZHP Diag Scan
                Download ZHP Diag to your desktop.
                1. Right Click Run as Admin.
                  2. Click the Scanner button.
                A notepad will open… copy and paste the report in your next reply.
                • slonslon7
                  • Mar 2017
                  • 14
                  So I reset my browser and it seemed to work well.
                  I had actually been using Chrome Canary version as the official Chrome release wasn’t behaving for me. I’ve checked things out in the new Chrome browser and everything seems normal and free of this problem. When I open the Canary version, I still get the issue. Of course, I’ll just avoid using the Canary version now and use the official release.
                  I"ll paste the results from the Diag scan, but please let me know if you think it is worth it to investigate further or it is best to uninstall Canary and be finished. Thank you!
                  ~ ZHPDiag v2017.2.27.37 By Nicolas Coolman (2017/02/27)
                  ~ Run by SamSwanson (Administrator) (2017/03/01 22:56:33)
                  ~ Blog: https://nicolascoolman.eu/
                  ~ Facebook: ZHP
                  ~ State version: Version OK
                  ~ Mode: Scan
                  ~ Report: C:\Users\SamSwanson\Desktop\ZHPDiag.txt
                  ~ Report: C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPDiag.tx t
                  ~ UAC: Activate
                  ~ System startup: Normal (Normal boot)
                  Windows 10 Pro, 64-bit (Build 14393) =>.Microsoft Corporation
                  —\ Internet Browsers (3) - 0s
                  ~ MFIE: Mozilla Firefox 51.0.1 (x86 en-US)
                  ~ OPIE: Looperator_is1 v1.0
                  ~ MSIE: Internet Explorer v11.576.14393.0
                  —\ Windows Product Information (3) - 3s
                  ~ Windows Server License Manager Script : OK
                  ~ Licence Script File Génération : OK
                  Windows Automatic Updates : OK
                  —\ System protection software (1) - 4s
                  Windows Defender (Deactivate)
                  —\ System protection software (Superfluous) (1) - 4s
                  ~ Zemana AntiMalware v2.72.101 (Superfluous)
                  —\ System optimization software (2) - 5s
                  ~ atomiccleaner3 version 1.3.4.1 v1.3.4.1 (Optimize)
                  ~ Tweaking.com - Windows Repair v3.9.25 (Optimize)
                  —\ Surveillance software (1) - 5s
                  ~ Adobe Flash Player 24 PPAPI (Surveillance)
                  —\ Information on the system (6) - 0s
                  ~ Operating System: Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
                  ~ Operating System: 64-bit
                  ~ Boot mode: Normal (Normal boot)
                  Total RAM: 33501.64 MB (90% free) : OK =>.RAM Value
                  System Restore: Activé (Enable)
                  System drive C: has 116 GB (47%) free of 243 GB : OK =>.Disk Space
                  —\ Connection to the system mode (3) - 0s
                  ~ Computer Name: JIRICOMPUTER
                  ~ User Name: SamSwanson
                  ~ Logged in as Administrator
                  —\ Enumeration of the disk units (3) - 0s
                  ~ Drive C: has 116 GB free of 243 GB (System)
                  ~ Drive R: has 1181 GB free of 2861 GB
                  ~ Drive S: has 1600 GB free of 2861 GB
                  —\ State of the Windows Security Center (17) - 0s
                  [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\Explorer] NoActiveDesktopChanges: OK
                  [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\Explorer] NoDesktop: OK
                  [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\Explorer] NoFind: OK
                  [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\Explorer] NoFolderOptions: OK
                  [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\Explorer] NoDesktop: OK
                  [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\Explorer] NoResolveSearch: OK
                  [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\Explorer] NoClose: OK
                  [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System] DisableTaskMgr: OK
                  [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System] DisableRegistryTools: OK
                  [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\pol icies\system] EnableLUA: OK
                  [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Advanced\Folder\Hidden\NOHIDDEN] CheckedValue: Modified
                  [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings] WarnOnHTTPSToHTTPRedirect: OK
                  [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Advanced\Folder\Hidden\SHOWALL] CheckedValue: OK
                  [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Exp lorer\Associations] Application: OK
                  [HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon] Shell: OK
                  [HKCU\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows] Load: OK
                  [HKLM\SYSTEM\CurrentControlSet\Services\COMSysApp] Type: OK
                  —\ Search Generic System Files (24) - 1s
                  [MD5.4E10FB1A015B49AC68F76C1A3F4D9C0F] - 09/12/2016 - (.Microsoft Corporation - Windows Explorer.) – C:\WINDOWS\Explorer.exe [4673304] =>.Microsoft Windows®
                  [MD5.C7645D43451C6D94D87F4D07BDE59C89] - 16/07/2016 - (.Microsoft Corporation - Windows host process (Rundll32).) – C:\WINDOWS\System32\rundll32.exe [69632] =>.Microsoft Corporation
                  [MD5.99A19C9A74E2F9820E501DCE77F84F70] - 16/07/2016 - (.Microsoft Corporation - Windows Start-Up Application.) – C:\WINDOWS\System32\Wininit.exe [304240] =>.Microsoft Windows Publisher®
                  [MD5.E584CDC70F694F9A984A060A8291EB04] - 09/12/2016 - (.Microsoft Corporation - Internet Extensions for Win32.) – C:\WINDOWS\System32\wininet.dll [2669056] =>.Microsoft Corporation
                  [MD5.917F081E2AB667C44F7D96DE1D16DFAE] - 11/01/2017 - (.Microsoft Corporation - Windows Logon Application.) – C:\WINDOWS\System32\Winlogon.exe [673792] =>.Microsoft Corporation
                  [MD5.9600B7F2F89DE60A80D13DE42F672834] - 16/07/2016 - (.Microsoft Corporation - Software Licensing Library.) – C:\WINDOWS\System32\sppcomapi.dll [402432] =>.Microsoft Corporation
                  [MD5.96B8A433F6407DE34850927C96C6CE9B] - 13/10/2016 - (.Microsoft Corporation - DNS Client API DLL.) – C:\WINDOWS\System32\dnsapi.dll [646136] =>.Microsoft Windows®
                  [MD5.227CFE3EDA82029AAC1C088A16297CD7] - 13/10/2016 - (.Microsoft Corporation - DNS Client API DLL.) – C:\WINDOWS\Syswow64\dnsapi.dll [496872] =>.Microsoft Windows®
                  [MD5.323AA1953ED9C01E23F740FA891FE064] - 28/10/2016 - (.Microsoft Corporation - Ancillary Function Driver for WinSock.) – C:\WINDOWS\System32\drivers\AFD.sys [584032] =>.Microsoft Windows®
                  [MD5.A10F989A812B57B9695F6C305907C9C6] - 16/07/2016 - (.Microsoft Corporation - ATAPI IDE Miniport Driver.) – C:\WINDOWS\System32\drivers\atapi.sys [28512] =>.Microsoft Windows®
                  [MD5.F8FB51B9EF6372610E9B31A1D86B62FC] - 16/07/2016 - (.Microsoft Corporation - CD-ROM File System Driver.) – C:\WINDOWS\System32\drivers\Cdfs.sys [92160] =>.Microsoft Corporation
                  [MD5.613D0137C269187FA298A157E3D14A18] - 16/07/2016 - (.Microsoft Corporation - SCSI CD-ROM Driver.) – C:\WINDOWS\System32\drivers\Cdrom.sys [173056] =>.Microsoft Corporation
                  [MD5.0D1D392ED2597F295956D058D33BD7C3] - 13/10/2016 - (.Microsoft Corporation - DFS Namespace Client Driver.) – C:\WINDOWS\System32\drivers\DfsC.sys [144896] =>.Microsoft Corporation
                  [MD5.10E3515FE5DBA6656FA62C29342EC4A1] - 16/07/2016 - (.Microsoft Corporation - High Definition Audio Bus Driver.) – C:\WINDOWS\System32\drivers\HDAudBus.sys [83456] =>.Microsoft Corporation
                  [MD5.B54B30992620C97230013A74461C8517] - 16/07/2016 - (.Microsoft Corporation - i8042 Port Driver.) – C:\WINDOWS\System32\drivers\i8042prt.sys [114176] =>.Microsoft Corporation
                  [MD5.F1DAECC3B3D6399875D4F10529D6A77C] - 16/07/2016 - (.Microsoft Corporation - IP Network Address Translator.) – C:\WINDOWS\System32\drivers\IpNat.sys [212480] =>.Microsoft Corporation
                  [MD5.E671EDAB0726E05ECEF4058B4CD73C4D] - 14/09/2016 - (.Microsoft Corporation - Windows NT SMB Minirdr.) – C:\WINDOWS\System32\drivers\MRxSmb.sys [450392] =>.Microsoft Windows®
                  [MD5.6FEBB0A847FFD5F057B9AC8889F1B9A7] - 16/07/2016 - (.Microsoft Corporation - MBT Transport driver.) – C:\WINDOWS\System32\drivers\netBT.sys [279040] =>.Microsoft Corporation
                  [MD5.DB69C6DA8B3DDFDC547D455CA23A8250] - 09/11/2016 - (.Microsoft Corporation - NT File System Driver.) – C:\WINDOWS\System32\drivers\ntfs.sys [2255712] =>.Microsoft Windows®
                  [MD5.6B81BF7853D161DB8AC62CD8B9C2DE6B] - 16/07/2016 - (.Microsoft Corporation - Parallel Port Driver.) – C:\WINDOWS\System32\drivers\Parport.sys [96768] =>.Microsoft Corporation
                  [MD5.17E565710172ED71B8531D8822E1C5D1] - 16/07/2016 - (.Microsoft Corporation - RAS L2TP mini-port/call-manager driver.) – C:\WINDOWS\System32\drivers\Rasl2tp.sys [104960] =>.Microsoft Corporation
                  [MD5.7135785C21CA79D270D11037C43D3F19] - 16/07/2016 - (.Microsoft Corporation - Microsoft RDP Device redirector.) – C:\WINDOWS\System32\drivers\rdpdr.sys [177152] =>.Microsoft Corporation
                  [MD5.9D2DD64A0B51C56285512DC9454340F6] - 16/07/2016 - (.Microsoft Corporation - TDI Translation Driver.) – C:\WINDOWS\System32\drivers\tdx.sys [118112] =>.Microsoft Windows®
                  [MD5.BF2546583BB75F01DDA60A7921DFB230] - 16/07/2016 - (.Microsoft Corporation - Volume Shadow Copy driver.) – C:\WINDOWS\System32\drivers\volsnap.sys [391520] =>.Microsoft Windows®
                  —\ Non Microsoft non disabled Windows Services (40) - 1s
                  O23 - Service: Acronis Scheduler2 Service (AcrSch2Svc) . (…) - C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe =>.Acronis International GmbH®
                  O23 - Service: ArcSoft Exchange Service (ADExchange) . (.ArcSoft, Inc. - ArcSoft eservutil..) - C:\Program Files (x86)\Common Files\ArcSoft\esinter\Bin\eservutil.exe =>.ArcSoft, Inc.®
                  O23 - Service: (AnonVPN VPN) . (…) - C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe {1121FA93F95E0C2F6A3A3272F08A5C1E0CC4}
                  O23 - Service: Apple Mobile Device Service (Apple Mobile Device Service) . (.Apple Inc. - MobileDeviceService.) - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe =>.Apple Inc.®
                  O23 - Service: ASUS Com Service (asComSvc) . (…) - C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe =>.ASUSTeK Computer Inc.®
                  O23 - Service: ASUS HM Com Service (asHmComSvc) . (.ASUSTeK Computer Inc. - .) - C:\Program Files (x86)\ASUS\AAHM\1.00.20\aaHMSvc.exe =>.ASUSTeK Computer Inc.®
                  O23 - Service: ASUS System Control Service (AsSysCtrlService) . (.ASUSTeK Computer Inc. - AsSysCtr Application.) - C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.13\AsSysCtrlServi ce.exe =>.ASUSTeK Computer Inc.®
                  O23 - Service: AsusFanControlService (AsusFanControlService) . (.ASUSTeK Computer Inc. - ASUS Motherboard Fan Control Service.) - C:\Program Files (x86)\ASUS\AsusFanControlService\1.02.05\AsusFanCo ntrolService.exe =>.ASUSTek Computer Inc.
                  O23 - Service: CarboniteService (CarboniteService) . (.Carbonite, Inc. (www.carbonite.com) - Carbonite Secure Backup Engine.) - C:\Program Files\Carbonite\Carbonite Backup\carboniteservice.exe {18455E6EF6D43CE1BB0C2DAC7DED3004}
                  O23 - Service: COMODO Internet Security Helper Service (cmdAgent) . (.COMODO - COMODO Internet Security.) - C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe =>.Comodo Security Solutions®
                  O23 - Service: Creative Audio Service (CTAudSvcService) . (.Creative Technology Ltd - Creative Audio Service.) - C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe =>.Creative Technology Ltd
                  O23 - Service: DisplayFusionService (DisplayFusionService) . (.Binary Fortress Software - DisplayFusion Service.) - C:\Program Files (x86)\DisplayFusion\DisplayFusionService.exe =>.Binary Fortress Software Ltd.®
                  O23 - Service: Gizmo Central (Gizmo Central) . (.Arainia Solutions - Gizmo Central Service.) - C:\Program Files (x86)\Gizmo\gservice.exe =>.Arainia Solutions, LLC®
                  O23 - Service: Google Update Service (gupdate) (gupdate) . (.Google Inc. - Google Installer.) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe =>.Google Inc®
                  O23 - Service: Intel(R) Capability Licensing Service Interface (Intel(R) Capability Licensing Service Interface) . (.Intel(R) Corporation - Intel(R) Capability Licensing Service Inter.) - C:\Program Files\Intel\iCLS Client\HeciServer.exe =>.Intel(R) Corporation
                  O23 - Service: Intel(R) PROSet Monitoring Service (Intel(R) PROSet Monitoring Service) . (.Intel Corporation - Intel® PROSet Monitoring Service.) - C:\Windows\system32\IProsetMonitor.exe =>.Intel Corporation
                  O23 - Service: Intel(R) Technology Access Legacy CS Loader (Intel(R) TechnologyAccessLegacyCSLoader) . (.Intel(R) Corporation - Intel(R) Technology Access LegacyCsLoaderSe.) - C:\Program Files\Intel Corporation\Intel(R) Technology Access\LegacyCsLoaderService.exe =>.Intel(R) Technology Access®
                  O23 - Service: Intel(R) Technology Access Service (Intel(R) TechnologyAccessService) . (.Intel(R) Corporation - Intel(R) Technology Access - Service.) - C:\Program Files\Intel Corporation\Intel(R) Technology Access\IntelTechnologyAccessService.exe =>.Intel(R) Technology Access®
                  O23 - Service: ISCT Always Updated Agent (ISCTAgent) . (.Copyright (C) 2011-2012 Intel Corporation - ISCT Agent Application.) - c:\Program Files\Intel\Intel(R) Smart Connect Technology Agent\iSCTAgent.exe =>.Intel(R) Smart Connect software®
                  O23 - Service: Intel(R) Dynamic Application Loader Host Interface Service (jhi_service) . (.Intel Corporation - Intel(R) Dynamic Application Loader Host In.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe =>.Intel Corporation - Intel® Management Engine Firmware®
                  O23 - Service: Intel(R) Management and Security Application Local Manageme (LMS) . (.Intel Corporation - Intel(R) Local Management Service.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe =>.Intel Corporation - Software and Firmware Products®
                  O23 - Service: Logitech Gaming Registry Service (LogiRegistryService) . (.Logitech Inc. - Logitech Surround Sound Service.) - C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.ex e =>.Logitech Inc®
                  O23 - Service: Malwarebytes Service (MBAMService) . (.Malwarebytes - Malwarebytes Service.) - C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe =>.Malwarebytes Corporation®
                  O23 - Service: Mbox Audio Device Monitor (MboxAudioDevMon) . (.Avid - Mbox Audio Device Monitor.) - C:\Program Files (x86)\Avid\Mbox\AudioDevMon.exe {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  O23 - Service: Acronis Managed Machine Service Mini (mmsminisrv) . (.Acronis - Managed Machine Service Mini.) - C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe =>.Acronis International GmbH®
                  O23 - Service: Nero Update (NAUpdate) . (.Nero AG - NeroUpdate.) - C:\Program Files (x86)\Nero\Update\NASvc.exe =>.Nero AG®
                  O23 - Service: NitroPDFDriverCreatorReadSpool8 (NitroDriverReadSpool8) . (.Nitro PDF Software - Nitro PDF Spool Service.) - C:\Program Files\Common Files\Nitro\Pro\8.0\NitroPDFDriverService8x64.exe =>.Nitro PDF Software®
                  O23 - Service: Nalpeiron Licensing Service (nlsX86cc) . (.Nalpeiron Ltd. - This service enables products that use the.) - C:\Windows\SysWOW64\nlssrv32.exe =>.Nalpeiron Inc®
                  O23 - Service: NVIDIA LocalSystem Container (NvContainerLocalSystem) . (.NVIDIA Corporation - NVIDIA Container.) - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe =>.NVIDIA Corporation®
                  O23 - Service: NVIDIA Display Container LS (NVDisplay.ContainerLocalSystem) . (.NVIDIA Corporation - NVIDIA Container.) - C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe =>.NVIDIA Corporation®
                  O23 - Service: NVIDIA Telemetry Container (NvTelemetryContainer) . (.NVIDIA Corporation - NVIDIA Container.) - C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe =>.NVIDIA Corporation®
                  O23 - Service: Oxygen Audio Device Monitor (OxygenAudioDevMon) . (.M-Audio - Oxygen Audio Device Monitor.) - C:\Program Files (x86)\M-Audio\Oxygen\AudioDevMon.exe =>.M-Audio®
                  O23 - Service: PACE License Services (PaceLicenseDServices) . (.PACE Anti-Piracy, Inc. - PACE License Service.) - C:\Program Files (x86)\Common Files\PACE\Services\LicenseServices\LDSvc.exe =>.PACE Anti-Piracy, Inc.®
                  O23 - Service: SoftEther VPN Client (SEVPNCLIENT) . (.SoftEther VPN Project at University of Tsukuba, Japan - SoftEther VPN.) - C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe =>.SoftEther K.K.®
                  O23 - Service: Skype Updater (SkypeUpdate) . (.Skype Technologies - Skype Updater Service.) - C:\Program Files (x86)\Skype\Updater\Updater.exe =>.Skype Software Sarl®
                  O23 - Service: Acronis Sync Agent Service (syncagentsrv) . (…) - C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe =>.Acronis International GmbH®
                  O23 - Service: TeamViewer 12 (TeamViewer) . (.TeamViewer GmbH - TeamViewer 12.) - C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe =>.TeamViewer GmbH®
                  O23 - Service: WRSVC (WRSVC) . (.Webroot - Webroot SecureAnywhere.) - C:\Program Files\Webroot\WRSA.exe {6FBB6E1D2367DC6BD38B1C8FA0BF6637} =>.Webroot
                  O23 - Service: Intel(R) Extreme Tuning Utility Service (XTU3SERVICE) . (.Intel(R) Corporation - XtuService.) - C:\Program Files (x86)\Intel\Extreme Tuning Utility\XtuService.exe =>.Intel(R) Software®
                  O23 - Service: ZAM Controller Service (ZAMSvc) . (.Copyright 2017. - ZAM.) - C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe =>.Zemana Ltd.®
                  —\ Services not Microsoft (SR=Run, SS=Stop) (59) - 24s
                  SR - Auto [31/10/2016] [ 1244408] Acronis Scheduler2 Service (AcrSch2Svc) . (…) - C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe =>.Acronis International GmbH®
                  SR - Auto [24/10/2013] [ 44736] ArcSoft Exchange Service (ADExchange) . (.ArcSoft, Inc..) - C:\Program Files (x86)\Common Files\ArcSoft\esinter\Bin\eservutil.exe =>.ArcSoft, Inc.®
                  SS - Demand [22/02/2017] [ 270936] Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) . (.Adobe Systems Incorporated.) - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpda teService.exe =>.Adobe Systems Incorporated®
                  SR - Auto [24/05/2016] [ 127336] (AnonVPN VPN) . (…) - C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe {1121FA93F95E0C2F6A3A3272F08A5C1E0CC4}
                  SR - Auto [31/10/2016] [ 83768] Apple Mobile Device Service (Apple Mobile Device Service) . (.Apple Inc..) - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe =>.Apple Inc.®
                  SR - Auto [07/01/2014] [ 920736] ASUS Com Service (asComSvc) . (…) - C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe =>.ASUSTeK Computer Inc.®
                  SR - Auto [07/01/2014] [ 951936] ASUS HM Com Service (asHmComSvc) . (.ASUSTeK Computer Inc..) - C:\Program Files (x86)\ASUS\AAHM\1.00.20\aaHMSvc.exe =>.ASUSTeK Computer Inc.®
                  SR - Auto [07/01/2014] [ 149120] ASUS System Control Service (AsSysCtrlService) . (.ASUSTeK Computer Inc..) - C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.13\AsSysCtrlServi ce.exe =>.ASUSTeK Computer Inc.®
                  SR - Auto [07/01/2014] [ 2005504] AsusFanControlService (AsusFanControlService) . (.ASUSTeK Computer Inc..) - C:\Program Files (x86)\ASUS\AsusFanControlService\1.02.05\AsusFanCo ntrolService.exe =>.ASUSTek Computer Inc.
                  SR - Auto [25/01/2017] [ 9239144] CarboniteService (CarboniteService) . (.Carbonite, Inc. (www.carbonite.com).) - C:\Program Files\Carbonite\Carbonite Backup\carboniteservice.exe {18455E6EF6D43CE1BB0C2DAC7DED3004}
                  SR - Auto [25/01/2017] [ 9239144] COMODO Internet Security Helper Service (cmdAgent) . (.COMODO.) - C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe =>.Comodo Security Solutions®
                  SS - Demand [25/01/2017] [ 9239144] COMODO Virtual Service Manager (cmdvirth) . (.COMODO.) - C:\Program Files\COMODO\COMODO Internet Security\cmdvirth.exe =>.Comodo Security Solutions®
                  SS - Demand [25/01/2017] [ 9239144] Creative ALchemy AL6 Licensing Service (Creative ALchemy AL6 Licensing Service) . (.Creative Labs.) - C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\AL6Licensing.exe =>.Creative Labs
                  SS - Demand [25/01/2017] [ 9239144] Creative Audio Engine Licensing Service (Creative Audio Engine Licensing Service) . (.Creative Labs.) - C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\CTAELicensing.exe =>.Creative Labs
                  SR - Auto [25/01/2017] [ 9239144] Creative Audio Service (CTAudSvcService) . (.Creative Technology Ltd.) - C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe =>.Creative Technology Ltd
                  SS - Demand [25/01/2017] [ 9239144] Disc Soft Lite Bus Service (Disc Soft Lite Bus Service) . (.Disc Soft Ltd.) - C:\Program Files (x86)\DAEMON Tools Lite\DiscSoftBusService.exe =>.Disc Soft Ltd®
                  SR - Auto [25/01/2017] [ 9239144] DisplayFusionService (DisplayFusionService) . (.Binary Fortress Software.) - C:\Program Files (x86)\DisplayFusion\DisplayFusionService.exe =>.Binary Fortress Software Ltd.®
                  SS - Demand [25/01/2017] [ 9239144] FLEXnet Licensing Service (FLEXnet Licensing Service) . (.Flexera Software LLC.) - C:\Program Files (x86)\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe =>.Flexera Software LLC®
                  SS - Demand [25/01/2017] [ 9239144] FlexNet Licensing Service 64 (FlexNet Licensing Service 64) . (.Flexera Software LLC.) - C:\Program Files\Common Files\Macrovision Shared\FlexNet Publisher\FNPLicensingService64.exe =>.Flexera Software LLC®
                  SR - Auto [25/01/2017] [ 9239144] Gizmo Central (Gizmo Central) . (.Arainia Solutions.) - C:\Program Files (x86)\Gizmo\gservice.exe =>.Arainia Solutions, LLC®
                  SS - Auto [25/01/2017] [ 9239144] Google Update Service (gupdate) (gupdate) . (.Google Inc..) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe =>.Google Inc®
                  SS - Demand [25/01/2017] [ 9239144] Google Update Service (gupdatem) (gupdatem) . (.Google Inc..) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe =>.Google Inc®
                  SR - Demand [25/01/2017] [ 9239144] Intel(R) Integrated Clock Controller Service - Intel(R) ICCS (ICCS) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe =>.Intel Corporation
                  SS - Demand [25/01/2017] [ 9239144] InstallDriver Table Manager (IDriverT) . (.Macrovision Corporation.) - C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe =>.Macrovision Corporation
                  SR - Auto [25/01/2017] [ 9239144] Intel(R) Capability Licensing Service Interface (Intel(R) Capability Licensing Service Interface) . (.Intel(R) Corporation.) - C:\Program Files\Intel\iCLS Client\HeciServer.exe =>.Intel(R) Corporation
                  SS - Demand [25/01/2017] [ 9239144] Intel(R) Capability Licensing Service TCP IP Interface (Intel(R) Capability Licensing Service TCP IP Interface) . (.Intel(R) Corporation.) - C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe =>.Intel® Trusted Connect Service®
                  SR - Auto [25/01/2017] [ 9239144] Intel(R) PROSet Monitoring Service (Intel(R) PROSet Monitoring Service) . (.Intel Corporation.) - C:\Windows\system32\IProsetMonitor.exe =>.Intel Corporation®
                  SS - Demand [25/01/2017] [ 9239144] Intel(R) Technology Access Software Asset Manager (Intel(R) TA SAM) . (.Intel Corporation.) - C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe {56000000B3D2126A53D17267B40000000000B3} =>.Intel Corporation
                  SR - Auto [25/01/2017] [ 9239144] Intel(R) Technology Access Legacy CS Loader (Intel(R) TechnologyAccessLegacyCSLoader) . (.Intel(R) Corporation.) - C:\Program Files\Intel Corporation\Intel(R) Technology Access\LegacyCsLoaderService.exe =>.Intel(R) Technology Access®
                  SR - Auto [25/01/2017] [ 9239144] Intel(R) Technology Access Service (Intel(R) TechnologyAccessService) . (.Intel(R) Corporation.) - C:\Program Files\Intel Corporation\Intel(R) Technology Access\IntelTechnologyAccessService.exe =>.Intel(R) Technology Access®
                  SS - Demand [25/01/2017] [ 9239144] iPod Service (iPod Service) . (.Apple Inc..) - C:\Program Files\iPod\bin\iPodService.exe =>.Apple Inc.®
                  SS - Auto [25/01/2017] [ 9239144] ISCT Always Updated Agent (ISCTAgent) . (.Copyright (C) 2011-2012 Intel Corporation.) - c:\Program Files\Intel\Intel(R) Smart Connect Technology Agent\iSCTAgent.exe =>.Intel(R) Smart Connect software®
                  SS - Demand [25/01/2017] [ 9239144] Intel(R) Update Manager (iumsvc) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe =>.Intel(R) Update Manager®
                  SR - Auto [25/01/2017] [ 9239144] Intel(R) Dynamic Application Loader Host Interface Service (jhi_service) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe =>.Intel Corporation - Intel® Management Engine Firmware®
                  SS - Demand [25/01/2017] [ 9239144] Logitech Bluetooth Service (LBTServ) . (.Logitech, Inc..) - C:\Program Files\Common Files\logishrd\Bluetooth\LBTServ.exe =>.Logitech®
                  SR - Auto [25/01/2017] [ 9239144] Intel(R) Management and Security Application Local Manageme (LMS) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe =>.Intel Corporation - Software and Firmware Products®
                  SR - Auto [25/01/2017] [ 9239144] Logitech Gaming Registry Service (LogiRegistryService) . (.Logitech Inc..) - C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.ex e =>.Logitech Inc®
                  SS - Auto [25/01/2017] [ 9239144] Malwarebytes Service (MBAMService) . (.Malwarebytes.) - C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe =>.Malwarebytes Corporation®
                  SR - Auto [25/01/2017] [ 9239144] Mbox Audio Device Monitor (MboxAudioDevMon) . (.Avid.) - C:\Program Files (x86)\Avid\Mbox\AudioDevMon.exe {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  SR - Auto [25/01/2017] [ 9239144] Acronis Managed Machine Service Mini (mmsminisrv) . (.Acronis.) - C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe =>.Acronis International GmbH®
                  SS - Demand [25/01/2017] [ 9239144] Mozilla Maintenance Service (MozillaMaintenance) . (.Mozilla Foundation.) - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe =>.Mozilla Corporation®
                  SR - Auto [25/01/2017] [ 9239144] Nero Update (NAUpdate) . (.Nero AG.) - C:\Program Files (x86)\Nero\Update\NASvc.exe =>.Nero AG®
                  SR - Auto [25/01/2017] [ 9239144] NitroPDFDriverCreatorReadSpool8 (NitroDriverReadSpool8) . (.Nitro PDF Software.) - C:\Program Files\Common Files\Nitro\Pro\8.0\NitroPDFDriverService8x64.exe =>.Nitro PDF Software®
                  SR - Auto [25/01/2017] [ 9239144] Nalpeiron Licensing Service (nlsX86cc) . (.Nalpeiron Ltd..) - C:\Windows\SysWOW64\nlssrv32.exe =>.Nalpeiron Inc®
                  SR - Auto [25/01/2017] [ 9239144] NVIDIA LocalSystem Container (NvContainerLocalSystem) . (.NVIDIA Corporation.) - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe =>.NVIDIA Corporation®
                  SS - Demand [25/01/2017] [ 9239144] NVIDIA NetworkService Container (NvContainerNetworkService) . (.NVIDIA Corporation.) - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe =>.NVIDIA Corporation®
                  SR - Auto [25/01/2017] [ 9239144] NVIDIA Display Container LS (NVDisplay.ContainerLocalSystem) . (.NVIDIA Corporation.) - C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe =>.NVIDIA Corporation®
                  SR - Auto [25/01/2017] [ 9239144] NVIDIA Telemetry Container (NvTelemetryContainer) . (.NVIDIA Corporation.) - C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe =>.NVIDIA Corporation®
                  SR - Auto [25/01/2017] [ 9239144] Oxygen Audio Device Monitor (OxygenAudioDevMon) . (.M-Audio.) - C:\Program Files (x86)\M-Audio\Oxygen\AudioDevMon.exe =>.M-Audio®
                  SR - Auto [25/01/2017] [ 9239144] PACE License Services (PaceLicenseDServices) . (.PACE Anti-Piracy, Inc..) - C:\Program Files (x86)\Common Files\PACE\Services\LicenseServices\LDSvc.exe =>.PACE Anti-Piracy, Inc.®
                  SR - Auto [25/01/2017] [ 9239144] SoftEther VPN Client (SEVPNCLIENT) . (.SoftEther VPN Project at University of Tsukuba, Japan.) - C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe =>.SoftEther K.K.®
                  SS - Auto [25/01/2017] [ 9239144] Skype Updater (SkypeUpdate) . (.Skype Technologies.) - C:\Program Files (x86)\Skype\Updater\Updater.exe =>.Skype Software Sarl®
                  SS - Demand [25/01/2017] [ 9239144] Steam Client Service (Steam Client Service) . (.Valve Corporation.) - C:\Program Files (x86)\Common Files\Steam\SteamService.exe =>.Valve®
                  SS - Demand [25/01/2017] [ 9239144] Adobe SwitchBoard (SwitchBoard) . (.Adobe Systems Incorporated.) - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe =>.Adobe Systems Incorporated
                  SR - Auto [25/01/2017] [ 9239144] Acronis Sync Agent Service (syncagentsrv) . (…) - C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe =>.Acronis International GmbH®
                  SR - Auto [25/01/2017] [ 9239144] TeamViewer 12 (TeamViewer) . (.TeamViewer GmbH.) - C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe =>.TeamViewer GmbH®
                  SS - Auto [25/01/2017] [ 9239144] WRSVC (WRSVC) . (.Webroot.) - C:\Program Files\Webroot\WRSA.exe {6FBB6E1D2367DC6BD38B1C8FA0BF6637} =>.Webroot
                  SR - Auto [25/01/2017] [ 9239144] Intel(R) Extreme Tuning Utility Service (XTU3SERVICE) . (.Intel(R) Corporation.) - C:\Program Files (x86)\Intel\Extreme Tuning Utility\XtuService.exe =>.Intel(R) Software®
                  SR - Auto [25/01/2017] [ 9239144] ZAM Controller Service (ZAMSvc) . (.Copyright 2017..) - C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe =>.Zemana Ltd.®
                  —\ Task Planned Automatically (50) - 11s
                  [MD5.93E6D367162053ED83589FF176FECF22] [APT] [20160618_170750_Restore 12 0] (.Nero AG.) – C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\NBCore.exe [9239144] (.Activate.) =>.Nero AG®
                  [MD5.93E6D367162053ED83589FF176FECF22] [APT] [20160623_163758_Restore 12 0] (.Nero AG.) – C:\Program Files (x86)\Nero\Nero 12\Nero BackItUp\NBCore.exe [9239144] (.Activate.) =>.Nero AG®
                  [MD5.3B2336A8281ABE998D156B580D6FAC4F] [APT] [CCleanerSkipUAC] (.Piriform Ltd.) – C:\Program Files\CCleaner\CCleaner.exe [9239144] (.Activate.) =>.Piriform Ltd®
                  [MD5.A8FD9222E4D72596BB37DA8BE95C0BA4] [APT] [GoogleUpdateTaskMachineCore] (.Google Inc..) – C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                  [MD5.A8FD9222E4D72596BB37DA8BE95C0BA4] [APT] [GoogleUpdateTaskMachineUA] (.Google Inc..) – C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                  [MD5.DD7423ABBE2913E70D50E9318AD57EE4] [APT] [GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a] (.Google Inc..) – C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                  [MD5.00D44FD91DFA18DD2A3B05AEE676E9DE] [APT] [IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d] (.Intel Corporation.) – C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [9239144] (.Activate.) {56000000B3D2126A53D17267B40000000000B3} =>.Intel Corporation
                  [MD5.00D44FD91DFA18DD2A3B05AEE676E9DE] [APT] [IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d-Logon] (.Intel Corporation.) – C:\Program Files (x86)\Intel Corporation\Intel(R) Technology Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [9239144] (.Activate.) {56000000B3D2126A53D17267B40000000000B3} =>.Intel Corporation
                  [MD5.622BF9C46A47CF17608C501320E8EFBD] [APT] [IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon] (.Intel Corporation.) – C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe [9239144] (.Activate.) =>.Intel(R) Update Manager®
                  [MD5.4E429B3FFB76C3EABC748ED3AFE54CF8] [APT] [Maxthon Update] (.Maxthon International ltd..) – C:\Program Files (x86)\Maxthon\Bin\MxUp.exe [9239144] (.Activate.) =>.Maxthon (Asia) Limited.®
                  [MD5.6733287C1E974086A5161EE2FAC19177] [APT] [NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}] (.NVIDIA Corporation.) – C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe [9239144] (.Activate.) =>.NVIDIA Corporation®
                  [MD5.74A8D1356B55488234036F18CDF1AC91] [APT] [NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}] (.NVIDIA Corporation.) – C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [9239144] (.Activate.) =>.NVIDIA Corporation®
                  [MD5.74A8D1356B55488234036F18CDF1AC91] [APT] [NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}] (.NVIDIA Corporation.) – C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [9239144] (.Activate.) =>.NVIDIA Corporation®
                  [MD5.EF799BD8DB05464D12882E32E9E98198] [APT] [NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}] (.NVIDIA Corporation.) – C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmMon.exe [9239144] (.Activate.) =>.NVIDIA Corporation®
                  [MD5.841984D166E6A3313207A3FE9D077C81] [APT] [NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}] (.NVIDIA Corporation.) – C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [9239144] (.Activate.) =>.NVIDIA Corporation®
                  [MD5.841984D166E6A3313207A3FE9D077C81] [APT] [NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}] (.NVIDIA Corporation.) – C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [9239144] (.Activate.) =>.NVIDIA Corporation®
                  [MD5.DAE9DD73874D082B45D29D65725F71F0] [APT] [open effects] (…) – C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe [9239144] (.Activate.)
                  [MD5.BC0F10A23F249ED126445D8B21C40D73] [APT] [Patch My PC] (.www.patchmypc.net.) – C:\Users\SamSwanson\Desktop\PatchMyPC.exe [9239144] (.Activate.) {5C41B76745317171CE32E40024DF400E} =>.www.patchmypc.net
                  [MD5.C61915B07118DAA09C7B80C029DD89A4] [APT] [Process Lasso Core Engine Only] (.Bitsum LLC.) – C:\Program Files\Process Lasso\processgovernor.exe [9239144] (.Activate.) =>.Bitsum LLC®
                  [MD5.AADD1A163DA2BEFC4C1CE8646A7F79CB] [APT] [{31DDBD37-5DB7-4030-8064-10B0CAA806C3}] (.COMODO.) – C:\Program Files\COMODO\COMODO Internet Security\cistray.exe [9239144] (.Activate.) =>.Comodo Security Solutions®
                  [MD5.00000000000000000000000000000000] [APT] [{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4}] (…) – C:\ProgramData\Carbonite\Carbonite Backup\CarboniteUpgrade.exe (.not file.) [9239144] (.Activate.)
                  [MD5.00000000000000000000000000000000] [APT] [{EE492B24-CD47-404D-95D3-605112E375FA}] (…) – S:\More VSTI\Orchestral.Tools.Metropolis.Ark.2.Orchestra.O f.The.Deep.KONTAKT-P2P\METROPOLIS Ark 2 Win Installer.exe (.not file.) [9239144] (.Activate.) =>PUP.Optional.CrossRider
                  [MD5.8C9231025FAF86B78906B6C847531FFB] [APT] [ASUS\ASUS AI Suite II Execute] (.ASUSTeK Computer Inc..) – C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe [9239144] (.Activate.) =>.ASUSTeK Computer Inc.®
                  [MD5.7AD73B398B58F8271257C77EF5371D46] [APT] [ASUS\ASUS Network iControl Help Execute] (.ASUSTeK Computer Inc..) – C:\Program Files (x86)\ASUS\AI Suite II\Network iControl\NetSvcHelp\NetSvcHelpEntry.exe [9239144] (.Activate.) =>.ASUSTeK Computer Inc.®
                  [MD5.2642FF237C75CC6058D281BDDBB060AC] [APT] [ASUS\USB 3.0 Boost Service] (.Copyright (C) 2011.) – C:\Program Files (x86)\ASUS\AI Suite II\USB 3.0 Boost\U3BoostSvr.exe [9239144] (.Activate.)
                  [MD5.AADD1A163DA2BEFC4C1CE8646A7F79CB] [APT] [COMODO\COMODO Autostart {D5EFF3B3-E126-4AF6-BCE9-852A72129E10}] (.COMODO.) – C:\Program Files\COMODO\COMODO Internet Security\cistray.exe [9239144] (.Activate.) =>.Comodo Security Solutions®
                  [MD5.E77BBF9D31128DDB24D8BE95C775E2E6] [APT] [COMODO\COMODO Signature Update {B9D5C6F9-17D2-4917-8BD0-614BAA1C6A59}] (.COMODO.) – C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [9239144] (.Activate.) =>.Comodo Security Solutions®
                  [MD5.E77BBF9D31128DDB24D8BE95C775E2E6] [APT] [COMODO\COMODO Update {A6D52E4F-569B-4756-B3D8-DF217313DA85}] (.COMODO.) – C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [9239144] (.Activate.) =>.Comodo Security Solutions®
                  [MD5.39DE0EB9D270F62A5A71EA58DB15640B] [APT] [Intel\Intel Telemetry 2] (.Intel Corporation.) – C:\Program Files\Intel\Telemetry 2.0\lrio.exe [9239144] (.Activate.) =>.Intel(R) Software®
                  O39 - APT: Unknown - (.Legitimate.) – C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask .job [9239144]
                  O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) – C:\WINDOWS\Tasks\GoogleUpdateTaskMachineCore.job [9239144] =>.Google Inc®
                  O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) – C:\WINDOWS\Tasks\GoogleUpdateTaskMachineUA.job [9239144] =>.Google Inc®
                  O39 - APT: CCleanerSkipUAC - (.Piriform Ltd.) – C:\WINDOWS\System32\Tasks\CCleanerSkipUAC [9239144] =>.Piriform Ltd®
                  O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) – C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore [9239144] =>.Google Inc®
                  O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) – C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A [9239144] =>.Google Inc®
                  O39 - APT: IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d - (.Intel Corporation.) – C:\WINDOWS\System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d [9239144] {56000000B3D2126A53D17267B40000000000B3} =>.Intel Corporation
                  O39 - APT: IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d-Logon - (.Intel Corporation.) – C:\WINDOWS\System32\Tasks\IntelTA-Upgrade-56460984-97c2-4bc7-a632-d776cf817f5d-Logon [9239144] {56000000B3D2126A53D17267B40000000000B3} =>.Intel Corporation
                  O39 - APT: IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon - (.Intel Corporation.) – C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473-Logon [9239144] =>.Intel(R) Update Manager®
                  O39 - APT: Maxthon Update - (.Maxthon International ltd..) – C:\WINDOWS\System32\Tasks\Maxthon Update [9239144] =>.Maxthon (Asia) Limited.®
                  O39 - APT: NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - (.NVIDIA Corporation.) – C:\WINDOWS\System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} [9239144] =>.NVIDIA Corporation®
                  O39 - APT: NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - (.NVIDIA Corporation.) – C:\WINDOWS\System32\Tasks\NvProfileUpdaterDaily_{B 2FE1952-0186-46C3-BAEC-A80AA35AC5B8} [9239144] =>.NVIDIA Corporation®
                  O39 - APT: NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - (.NVIDIA Corporation.) – C:\WINDOWS\System32\Tasks\NvProfileUpdaterOnLogon_ {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} [9239144] =>.NVIDIA Corporation®
                  O39 - APT: NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - (.NVIDIA Corporation.) – C:\WINDOWS\System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} [9239144] =>.NVIDIA Corporation®
                  O39 - APT: NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - (.NVIDIA Corporation.) – C:\WINDOWS\System32\Tasks\NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} [9239144] =>.NVIDIA Corporation®
                  O39 - APT: NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} - (.NVIDIA Corporation.) – C:\WINDOWS\System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} [9239144] =>.NVIDIA Corporation®
                  O39 - APT: Unknown - (.Microsoft Corporation.) – C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task v2 [9239144] =>.Microsoft Corporation
                  O39 - APT: open effects - (…) – C:\WINDOWS\System32\Tasks\open effects [9239144]
                  O39 - APT: Process Lasso Core Engine Only - (.Bitsum LLC.) – C:\WINDOWS\System32\Tasks\Process Lasso Core Engine Only [9239144] =>.Bitsum LLC®
                  O39 - APT: {31DDBD37-5DB7-4030-8064-10B0CAA806C3} - (.COMODO.) – C:\WINDOWS\System32\Tasks{31DDBD37-5DB7-4030-8064-10B0CAA806C3} [9239144] =>.Comodo Security Solutions®
                  O39 - APT: {5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} - (…) – C:\WINDOWS\System32\Tasks{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} [9239144] (.Orphan.) =>.Superfluous.Orphan
                  —\ Auto loading programs from Registry and folders (24) - 0s
                  O4 - HKLM..\Run: [Logitech Download Assistant] . (.Logitech, Inc. - Logitech Download Assistant.) – C:\Windows\System32\LogiLDA.dll =>.Logitech, Inc.
                  O4 - HKLM..\Run: [Malwarebytes TrayApp] . (.Malwarebytes - Malwarebytes Tray Application.) – C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\mbamtray.exe =>.Malwarebytes Corporation®
                  O4 - HKLM..\Run: [Launch LCore] . (.Logitech Inc. - Logitech Gaming Framework.) – C:\Program Files\Logitech Gaming Software\LCore.exe =>.Logitech Inc®
                  O4 - HKCU..\Run: [Dashlane] . (.Dashlane, Inc. - Dashlane.) – C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe =>.Dashlane®
                  O4 - HKCU..\Run: [Ditto] . (.Copyright (C) 2003 - Ditto.) – C:\Program Files (x86)\Ditto\Ditto.exe
                  O4 - HKCU..\Run: [F.lux] . (.Flux Software LLC - f.lux.) – C:\Users\SamSwanson\AppData\Local\FluxSoftware\Flu x\flux.exe =>.Michael Herf®
                  O4 - HKCU..\Run: [DashlanePlugin] . (…) – C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl anePlugin.exe =>.Dashlane®
                  O4 - HKCU..\Run: [GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F 8703B] . (.Google Inc. - Google Chrome.) – C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - HKCU..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64 (.not file.)
                  O4 - HKCU..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64 (.not file.)
                  O4 - HKLM..\Wow6432Node\Run: [LWS] . (.Logitech Inc. - Logitech Webcam Software.) – C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe =>.Logitech, Inc.®
                  O4 - HKLM..\Wow6432Node\Run: [TrueImageMonitor.exe] . (…) – C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe =>.Acronis International GmbH®
                  O4 - HKLM..\Wow6432Node\Run: [WRSVC] . (.Webroot - Webroot SecureAnywhere.) – C:\Program Files\Webroot\WRSA.exe {6FBB6E1D2367DC6BD38B1C8FA0BF6637} =>.Webroot
                  O4 - HKLM..\Wow6432Node\Run: [UATrayIcon] . (.Universal Audio, Inc. - UAD System Menu.) – C:\Program Files (x86)\Universal Audio\Powered Plugins\UATrayIcon.exe =>.Universal Audio, Inc.
                  O4 - HKLM..\Wow6432Node\Run: [UAPerfMon] . (.Universal Audio, Inc. - UAD Performance Monitor.) – C:\Program Files (x86)\Universal Audio\Powered Plugins\UADPerfMon.exe =>.Universal Audio, Inc.
                  O4 - HKUS\S-1-5-19..\Run: [OneDriveSetup] . (.Microsoft Corporation - Microsoft OneDrive Setup.) – C:\Windows\SysWOW64\OneDriveSetup.exe =>.Microsoft Corporation®
                  O4 - HKUS\S-1-5-20..\Run: [OneDriveSetup] . (.Microsoft Corporation - Microsoft OneDrive Setup.) – C:\Windows\SysWOW64\OneDriveSetup.exe =>.Microsoft Corporation®
                  O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\Run: [Dashlane] . (.Dashlane, Inc. - Dashlane.) – C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe =>.Dashlane®
                  O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\Run: [Ditto] . (.Copyright (C) 2003 - Ditto.) – C:\Program Files (x86)\Ditto\Ditto.exe
                  O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\Run: [F.lux] . (.Flux Software LLC - f.lux.) – C:\Users\SamSwanson\AppData\Local\FluxSoftware\Flu x\flux.exe =>.Michael Herf®
                  O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\Run: [DashlanePlugin] . (…) – C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl anePlugin.exe =>.Dashlane®
                  O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\Run: [GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F 8703B] . (.Google Inc. - Google Chrome.) – C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64 (.not file.)
                  O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64 (.not file.)
                  —\ Process running (63) - 2s
                  [MD5.F2C12A68577CA1A069A394A535A176CC] - (.NVIDIA Corporation - NVIDIA Container.) – C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Containe r.exe [464440] [PID.1980] =>.NVIDIA Corporation®
                  [MD5.C206F35A1D0B32B6A65BE2B5D7049B84] - (.COMODO - COMODO Internet Security.) – C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe [5817256] [PID.1428] =>.Comodo Security Solutions®
                  [MD5.2B874307502F677558178FE5A1EB45C1] - (.NVIDIA Corporation - NVIDIA User Experience Driver Component.) – C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe [1286592] [PID.1644] =>.NVIDIA Corporation®
                  [MD5.84F9993BECF0F36890D7394B852DFC23] - (.COMODO - COMODO Internet Security.) – C:\Program Files\COMODO\COMODO Internet Security\cavwp.exe [523448] [PID.3344] =>.Comodo Security Solutions®
                  [MD5.CC37DE63E5454CB129E833F6F7000FD8] - (.Creative Technology Ltd - Creative Audio Service.) – C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe [294912] [PID.3696] =>.Creative Technology Ltd
                  [MD5.7D811EA7A2AAA49B0446D42CBC1CD338] - (.Apple Inc. - MobileDeviceService.) – C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768] [PID.3356] =>.Apple Inc.®
                  [MD5.2D2DF41D56BE1E51DBCA37B72E19714F] - (…) – C:\Program Files (x86)\Common Files\Acronis\Schedule2\schedul2.exe [1244408] [PID.2832] =>.Acronis International GmbH®
                  [MD5.B8EF8E8BDEF9F56F52C7659A05BFF52E] - (.Carbonite, Inc. (www.carbonite.com) - Carbonite Secure Backup Engine.) – C:\Program Files\Carbonite\Carbonite Backup\carboniteservice.exe [9239144] [PID.3220] {18455E6EF6D43CE1BB0C2DAC7DED3004}
                  [MD5.F6738481FDF022102EAF2F80E63C4595] - (.Binary Fortress Software - DisplayFusion Service.) – C:\Program Files (x86)\DisplayFusion\DisplayFusionService.exe [1243024] [PID.3320] =>.Binary Fortress Software Ltd.®
                  [MD5.C375765A0BC4646BF9097263DBBD6476] - (…) – C:\Program Files (x86)\AnonVPN\bin\AnonVPNService.exe [127336] [PID.3308] {1121FA93F95E0C2F6A3A3272F08A5C1E0CC4}
                  [MD5.EEA4C099FA7DE4FBD54756C33BAF14D5] - (.ArcSoft, Inc. - ArcSoft eservutil..) – C:\Program Files (x86)\Common Files\ArcSoft\esinter\Bin\eservutil.exe [44736] [PID.3408] =>.ArcSoft, Inc.®
                  [MD5.AD8947D621FDCA48F1F39F4624B60AA1] - (.ASUSTeK Computer Inc. - AsSysCtr Application.) – C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.13\AsSysCtrlServi ce.exe [149120] [PID.3428] =>.ASUSTeK Computer Inc.®
                  [MD5.0466B91EE5767A769E9F8EDB8EF94DDB] - (.ASUSTeK Computer Inc. - .) – C:\Program Files (x86)\ASUS\AAHM\1.00.20\aaHMSvc.exe [951936] [PID.3436] =>.ASUSTeK Computer Inc.®
                  [MD5.B1C9B932F5A728800AB9C2C88C92594A] - (.Arainia Solutions - Gizmo Central Service.) – C:\Program Files (x86)\Gizmo\gservice.exe [34728] [PID.3448] =>.Arainia Solutions, LLC®
                  [MD5.8FC1304D14CA88CD5B46567D4842A14E] - (.Intel(R) Corporation - Intel(R) Technology Access LegacyCsLoaderSe.) – C:\Program Files\Intel Corporation\Intel(R) Technology Access\LegacyCsLoaderService.exe [153296] [PID.3456] =>.Intel(R) Technology Access®
                  [MD5.44449A0EB8EBD8DCBC3ED4BB62BA3A5F] - (.TeamViewer GmbH - TeamViewer 12.) – C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe [10351856] [PID.3472] =>.TeamViewer GmbH®
                  [MD5.00000000000000000000000000000000] - (.Intel Corporation - Intel® PROSet Monitoring Service.) – C:\Windows\system32\IProsetMonitor.exe [0] [PID.3488] =>.Intel Corporation
                  [MD5.DCD10994A3545BD66CF83252D3121B6E] - (.NVIDIA Corporation - NVIDIA Container.) – C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [462784] [PID.3500] =>.NVIDIA Corporation®
                  [MD5.E357862CA46F2C3E98E5E8007A317363] - (.M-Audio - Oxygen Audio Device Monitor.) – C:\Program Files (x86)\M-Audio\Oxygen\AudioDevMon.exe [1632776] [PID.3512] =>.M-Audio®
                  [MD5.FD9AAD16400B3FF662BDD8B2A7033B40] - (.Avid - Mbox Audio Device Monitor.) – C:\Program Files (x86)\Avid\Mbox\AudioDevMon.exe [520936] [PID.3524] {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  [MD5.D0B202843B8ADE504EB304DC1E889A3C] - (.ASUSTeK Computer Inc. - ASUS Motherboard Fan Control Service.) – C:\Program Files (x86)\ASUS\AsusFanControlService\1.02.05\AsusFanCo ntrolService.exe [2005504] [PID.3532] =>.ASUSTek Computer Inc.
                  [MD5.3160EA50294C423524EF4E2AAC39A3B0] - (.Intel(R) Corporation - Intel(R) Technology Access - Service.) – C:\Program Files\Intel Corporation\Intel(R) Technology Access\IntelTechnologyAccessService.exe [478416] [PID.3540] =>.Intel(R) Technology Access®
                  [MD5.A875E7BBB33FB96170DAF3DE8922EE82] - (.NVIDIA Corporation - NVIDIA Container.) – C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe [425408] [PID.3548] =>.NVIDIA Corporation®
                  [MD5.0F7EB1FEF3B94B06593CD792530D7A2E] - (.Nitro PDF Software - Nitro PDF Spool Service.) – C:\Program Files\Common Files\Nitro\Pro\8.0\NitroPDFDriverService8x64.exe [230408] [PID.3568] =>.Nitro PDF Software®
                  [MD5.D9652739D1007B9B5CE34CEF38E095C5] - (.Acronis - Managed Machine Service Mini.) – C:\Program Files (x86)\Common Files\Acronis\Infrastructure\mms_mini.exe [4884064] [PID.3588] =>.Acronis International GmbH®
                  [MD5.0F302AD88A2B89C841FB770FF8587FE5] - (.Logitech Inc. - Logitech Surround Sound Service.) – C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.ex e [225400] [PID.3604] =>.Logitech Inc®
                  [MD5.9EF328DCD8311F500CB9ED89C6FE4E54] - (.PACE Anti-Piracy, Inc. - PACE License Service.) – C:\Program Files (x86)\Common Files\PACE\Services\LicenseServices\LDSvc.exe [47305256] [PID.3620] =>.PACE Anti-Piracy, Inc.®
                  [MD5.31E2470E61D5A390405BA41C279D8446] - (…) – C:\Program Files (x86)\ASUS\AXSP\1.00.19\atkexComSvc.exe [920736] [PID.3644] =>.ASUSTeK Computer Inc.®
                  [MD5.91FC7F4BB192639E8893A9733E1F0E82] - (.Nalpeiron Ltd. - This service enables products that use the.) – C:\Windows\SysWOW64\nlssrv32.exe [70768] [PID.2064] =>.Nalpeiron Inc®
                  [MD5.004D1CF0250B5635C572DDEC489E3709] - (.SoftEther VPN Project at University of Tsukuba, Japan - SoftEther VPN.) – C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe [5248456] [PID.3868] =>.SoftEther K.K.®
                  [MD5.D58AFA917D97BFF073E58763B13E4A65] - (…) – C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe [4463592] [PID.4004] =>.Acronis International GmbH®
                  [MD5.DAE6C3099D291EED8922A65C29ABCF52] - (.Intel(R) Corporation - Intel(R) Capability Licensing Service Inter.) – C:\Program Files\Intel\iCLS Client\HeciServer.exe [747520] [PID.4164] =>.Intel(R) Corporation
                  [MD5.C78761C2A5475EA16ADCD438CC17841F] - (.Copyright 2017. - ZAM.) – C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [14416624] [PID.4176] =>.Zemana Ltd.®
                  [MD5.050AC6DA1056F43EB69112F19F9C3A29] - (.NVIDIA Corporation - NVIDIA Container.) – C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe [425408] [PID.5200] =>.NVIDIA Corporation®
                  [MD5.8C9231025FAF86B78906B6C847531FFB] - (.ASUSTeK Computer Inc. - ASUS Routine Controller.) – C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe [2935424] [PID.7068] =>.ASUSTeK Computer Inc.®
                  [MD5.BEEDC296881D39DC2A305E17E2B98133] - (.NVIDIA Corporation - NVIDIA Settings.) – C:\Program Files\NVIDIA Corporation\Display\nvtray.exe [2456632] [PID.2272] =>.NVIDIA Corporation®
                  [MD5.EC1562C59581C35B13DE537E27161A5D] - (.ASUSTeK Computer Inc. - USB 3.0 Boost Service.) – C:\Program Files (x86)\ASUS\AI Suite II\USB 3.0 Boost\U3BoostSvr64.exe [426296] [PID.4336] =>.ASUSTeK Computer Inc.®
                  [MD5.710CB3685FD1F39CCE1BDE033AEE64A4] - (.ASUSTeK Computer Inc. - TurboVHelp.) – C:\Program Files (x86)\ASUS\AI Suite II\TurboV EVO\TurboVHelp.exe [1112064] [PID.3468] =>.ASUSTek Computer Inc.
                  [MD5.90D95B25F8413F937A2E155F196D892C] - (.Intel Corporation - Intel(R) Integrated Clock Controller Servic.) – C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe [160768] [PID.7760] =>.Intel Corporation
                  [MD5.4624731A850366C5E049C93BCB5D41FD] - (.ASUSTeK Computer Inc. - EPUHelp.) – C:\Program Files (x86)\ASUS\AI Suite II\EPU\EPUHelp.exe [1256576] [PID.3352] =>.ASUSTeK Computer Inc.®
                  [MD5.00455A64B9D7B9E73C2E4DDB3C9940F7] - (.Logitech Inc. - Logitech Gaming Framework.) – C:\Program Files\Logitech Gaming Software\LCore.exe [17406072] [PID.8264] =>.Logitech Inc®
                  [MD5.FBA05BD09342A3B55F7C04BB4D050331] - (.Dashlane, Inc. - Dashlane.) – C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe [486352] [PID.7796] =>.Dashlane®
                  [MD5.A7569CDF60DB586EC255EF9FFE311498] - (.Copyright (C) 2003 - Ditto.) – C:\Program Files (x86)\Ditto\Ditto.exe [1433200] [PID.8640]
                  [MD5.DA5FBAA5D62B4FD393947DE5EE8715BE] - (.Flux Software LLC - f.lux.) – C:\Users\SamSwanson\AppData\Local\FluxSoftware\Flu x\flux.exe [1016712] [PID.7828] =>.Michael Herf®
                  [MD5.3F188126510FA73A469F42DE42252937] - (.ASUSTeK Computer Inc. - AI Suite II.) – C:\Program Files (x86)\ASUS\AI Suite II\AI Suite II.exe [1504640] [PID.7260] =>.ASUSTeK Computer Inc.®
                  [MD5.10FE13F1AAC08C92605B5ED7E55968D3] - (…) – C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl anePlugin.exe [544208] [PID.9096] =>.Dashlane®
                  [MD5.1886DA4ADB90A186E52674FC3A8AFE98] - (.ASUSTeK Computer Inc. - AlertHelper.) – C:\Program Files (x86)\ASUS\AI Suite II\Sensor\AlertHelper\AlertHelper.exe [1112704] [PID.9260] =>.ASUSTeK Computer Inc.®
                  [MD5.DAE9DD73874D082B45D29D65725F71F0] - (…) – C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe [3042304] [PID.10232]
                  [MD5.8FFDB89A0FB7C8ABC3A8825E38047341] - (.Logitech Inc. - Logitech Webcam Software.) – C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe [204136] [PID.11040] =>.Logitech, Inc.®
                  [MD5.E4C53CE8409DCFF708C790A0AC76398D] - (…) – C:\Program Files (x86)\Logitech\LWS\Webcam Software\CameraHelperShell.exe [264040] [PID.9572] =>.Logitech, Inc.®
                  [MD5.C00A993D99DCB1649865961EB233BB6F] - (…) – C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageMonitor.exe [7382232] [PID.10784] =>.Acronis International GmbH®
                  [MD5.A50EB4964612CD290065452F9229EDDF] - (.Avid - Mbox Driver Interface.) – C:\Program Files (x86)\Avid\Mbox\DriverInterface.exe [680680] [PID.11364] {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  [MD5.A50EB4964612CD290065452F9229EDDF] - (.Avid - Mbox Driver Interface.) – C:\Program Files (x86)\Avid\Mbox\DriverInterface.exe [680680] [PID.11448] {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  [MD5.61DD4B814C686A84BEE7DD5C17CE1341] - (.Universal Audio, Inc. - UAD System Menu.) – C:\Program Files (x86)\Universal Audio\Powered Plugins\UATrayIcon.exe [3804160] [PID.11468] =>.Universal Audio, Inc.
                  [MD5.A50EB4964612CD290065452F9229EDDF] - (.Avid - Mbox Driver Interface.) – C:\Program Files (x86)\Avid\Mbox\DriverInterface.exe [680680] [PID.11548] {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  [MD5.A50EB4964612CD290065452F9229EDDF] - (.Avid - Mbox Driver Interface.) – C:\Program Files (x86)\Avid\Mbox\DriverInterface.exe [680680] [PID.11820] {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  [MD5.0BE2D435EB59BE55BAC449038F4BACB7] - (.Universal Audio, Inc. - UAD Performance Monitor.) – C:\Program Files (x86)\Universal Audio\Powered Plugins\UADPerfMon.exe [5964288] [PID.12056] =>.Universal Audio, Inc.
                  [MD5.52069AEB42D3D0F97CBCA1085EBF55E6] - (.Intel Corporation - Intel(R) Dynamic Application Loader Host In.) – C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [169432] [PID.8104] =>.Intel Corporation - Intel® Management Engine Firmware®
                  [MD5.E2952760B05A256FB1412D20A41C89C1] - (.Intel Corporation - Intel(R) Local Management Service.) – C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe [390616] [PID.12120] =>.Intel Corporation - Software and Firmware Products®
                  [MD5.E0E4A1F81A7D69C595A8A9DDAD084C19] - (.Nero AG - NeroUpdate.) – C:\Program Files (x86)\Nero\Update\NASvc.exe [769432] [PID.11300] =>.Nero AG®
                  [MD5.C653C8A3D3079A7D03F8DAB6C5FE6DD7] - (…) – C:\Program Files (x86)\Common Files\Acronis\SyncAgent\syncagentsrv.exe [9698296] [PID.6820] =>.Acronis International GmbH®
                  [MD5.1F980CB280DAA8C77DEAAC162471943E] - (.Intel(R) Corporation - XtuService.) – C:\Program Files (x86)\Intel\Extreme Tuning Utility\XtuService.exe [14936] [PID.8084] =>.Intel(R) Software®
                  [MD5.6E2F0DE7B5EBEE2640EB49707A40AD50] - (.Nicolas Coolman - ZHPDiag.) – C:\Users\SamSwanson\Desktop\Computer fix\ZHPDiag3.exe [2705920] [PID.10632] =>.Nicolas Coolman
                  —\ Google Chrome, Start,Search,Extensions (21) - 1s
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://tools.google.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://apis.google.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://fonts.googleapis.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://fonts.gstatic.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://googleads.g.doubleclick.net =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.google-analytics.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.gstatic.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.gstatic.com =>.Google Inc.
                  G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.youtube.com =>.Youtube
                  G2 - GCE: Preference [User Data\Default] [aapocclcgogkmnckokdopfmhonfmgoek] Google Chrome manifest =>.Google Inc. =>.Google Inc.
                  G2 - GCE: Preference [User Data\Default] [aohghmighlieiainnegkcijnfilokake] Docs =>.Legitimate
                  G2 - GCE: Preference [User Data\Default] [apdfllckaahabafndbhieahigkjlhalf] Google Chrome manifest =>.Google Inc.
                  G2 - GCE: Preference [User Data\Default] [blpcfgokakmgnkcojhhkbfbldkacnbeo] Google Chrome manifest =>.Google Inc.
                  G2 - GCE: Preference [User Data\Default] [felcaaldnbdncclmgdcncolpebgiejap] Google Chrome manifest =>.Google Inc. =>.Google Inc.
                  G2 - GCE: Preference [User Data\Default] [ghbmnnjooekpmoecnnnilnnbdlolhkhi] Google Chrome manifest =>.Google Inc. =>.Google Inc.
                  G2 - GCE: Preference [User Data\Default] [iahagolkpaghhinaljhjihagjgomdokb] [ https://s3.amazonaws.com/com.alexa.toolbar/autoupd ] VME =>Hijacker.Browser
                  G2 - GCE: Preference [User Data\Default] [kjeghcllfecehndceplomkocgfbklffd] Webroot Filtering Extension
                  G2 - GCE: Preference [User Data\Default] [nmmhkkegccagdldgiimedpiccmgmieda] Google Chrome manifest =>.Google Inc.
                  G2 - GCE: Preference [User Data\Default] [pjkljhegncpnkpknbcohdijeoejaedia] Google Chrome manifest =>.Google Inc.
                  G2 - GCE: Preference [User Data\Default] [pkedcjkdefgpdelpbcmbmeomcjbeemfm] Chrome Media Router =>.Google Inc.
                  —\ Mozilla Firefox,Plugins,Start,Search,Extensions (8) - 1s
                  M1 - SPR:Search Page Redirection - C:\Program Files (x86)\Mozilla Firefox\extensions{972ce4c6-7e08-4474-a285-3208198ce6fd}
                  P2 - EXT: (.Microsoft Corporation - The plugin allows you to have a better expe.) – C:\Program Files (x86)\Mozilla Firefox\Plugins\npMeetingJoinPluginOC.dll =>.Microsoft Corporation®
                  P2 - EXT: (.mozilla.org - Default Plug-in.) – C:\Program Files (x86)\Mozilla Firefox\Plugins\npnul32.dll =>.Mozilla Corporation®
                  P2 - EXT FILE: (.Dashlane - Password Manager and Secure Digital Wa.) – C:\Users\SamSwanson\AppData\Roaming\Mozilla\Firefo x\Profiles\lncyg2i6.default\extensions\jetpack-extension@dashlane.com.xpi =>.Dashlane
                  P2 - EXT: (…) – C:\Users\SamSwanson\AppData\Roaming\Mozilla\Extens ions{ec8030f7-c20a-464f-9b0e-13a3a9e97384} =>PUP.Optional.Wajam
                  P2 - FPN: [HKCU] [Ubisoft | Welcome to the official Ubisoft website] - (…) – C:\Program Files (x86)\Ubisoft\Ubisoft Game Launcher\npuplaypc.dll
                  P2 - FPN: [HKLM] [@adobe.com/FlashPlayer] - (.Adobe Systems Incorporated.) – C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_24_0_0_ 221.dll =>.Adobe Systems Incorporated
                  P2 - FPN: [HKLM] [@ilok.com/iLokHelper,version=3.1.0.7] - (.PACE Anti-Piracy, Inc.) – C:\Program Files (x86)\PACE Anti-Piracy\iLok\NPPaceILok.dll
                  —\ Internet Explorer Extensions, Start, Search (18) - 0s
                  R0 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
                  R0 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
                  R0 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
                  R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
                  R3 - URLSearchHook: (no name) - {CFBFAE00-17A6-11D0-99CB-00C04FD64497} Orphan =>.Microsoft Internet Explorer
                  R4 - HKLM\SOFTWARE\Microsoft\Internet Explorer\PhishingFilter,EnabledV9 = 0
                  R4 - HKCU\SOFTWARE\Microsoft\Internet Explorer\PhishingFilter,Enabled = 2
                  R4 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\PhishingFilter,EnabledV9 = 0
                  —\ Internet Explorer, Proxy Management (6) - 0s
                  R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyEnable = 0
                  R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,MigrateProxy = 1
                  R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,EnableHttp1_1 = 1
                  R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyHttp1.1 = 1
                  R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,AutoConfigProxy = wininet.dll
                  R5 - HKLM\SYSTEM\CurrentControlSet\services\NlaSvc\Para meters\Internet\ManualProxies
                  —\ Line Analysis, IniFiles, Auto loading programs (3) - 0s
                  F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe (.Microsoft Corporation.) =>.Microsoft Corporation
                  F2 - REG:system.ini: Shell=C:\WINDOWS\explorer.exe (.Microsoft Corporation.) =>.Microsoft Corporation
                  F2 - REG:system.ini: VMApplet=
                  —\ Hosts file redirection (1) - 0s
                  ~ Le fichier hôte est sain (The hosts file is clean) (1)
                  —\ Global shortcuts Startup (167) - 7s
                  O4 - GS\Desktop [Administrator]: AnonVPN.lnk . (…) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe {1121FA93F95E0C2F6A3A3272F08A5C1E0CC4}
                  O4 - GS\Desktop [Administrator]: Dashlane.lnk . (.Dashlane, Inc. - Dashlane.) C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe =>.Dashlane®
                  O4 - GS\Desktop [Administrator]: EffectRack.lnk . (…) C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
                  O4 - GS\Desktop [Administrator]: Electrum.lnk . (…) C:\Program Files (x86)\Electrum\electrum.exe
                  O4 - GS\Desktop [Administrator]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Desktop [Administrator]: HOFA CD-Burn & DDP.lnk . (…) C:\Program Files (x86)\HOFA-Plugins\HOFA CD-Burn & DDP\HOFA CD-Burn & DDP.exe
                  O4 - GS\Desktop [Administrator]: Kindle.lnk . (.Amazon.com - Kindle.) C:\Users\SamSwanson\AppData\Local\Amazon\Kindle\ap plication\Kindle.exe =>.Amazon Services LLC®
                  O4 - GS\Desktop [Administrator]: Melodyne Studio 4.lnk . (.Celemony Software GmbH - Melodyne.) C:\Program Files\Celemony\Melodyne Studio 4\Melodyne.exe =>.Celemony Software GmbH
                  O4 - GS\Desktop [Administrator]: Scott - Shortcut.lnk . (…) S:\SessionFiles\Scott
                  O4 - GS\Desktop [Administrator]: SessionFiles - Shortcut.lnk . (…) S:\SessionFiles
                  O4 - GS\Desktop [Administrator]: Slack.lnk . (…) C:\Users\SamSwanson\AppData\Local\slack\Update.exe =>.Slack Technologies Inc.®
                  O4 - GS\Desktop [Administrator]: Spotify.lnk . (.Spotify Ltd - Spotify.) C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe =>.Spotify AB®
                  O4 - GS\Desktop [Administrator]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPDiag3.e xe =>.Nicolas Coolman
                  O4 - GS\Quicklaunch [Administrator]: Chrome App Launcher.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe --show-app-list =>.Google Inc®
                  O4 - GS\Quicklaunch [Administrator]: Finale NotePad 2012.lnk . (.MakeMusic Inc. - Finale® NotePad for Windows.) C:\Program Files (x86)\Finale NotePad 2012\Finale NotePad.exe =>.MakeMusic Inc.®
                  O4 - GS\Quicklaunch [Administrator]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Quicklaunch [Administrator]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Quicklaunch [Administrator]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
                  O4 - GS\Quicklaunch [Administrator]: Pro Tools 10.lnk . (.Avid Technology, Inc. - Pro Tools Application.) C:\Program Files (x86)\Avid\Pro Tools\ProTools.exe =>.Avid Technology, Inc.
                  O4 - GS\sendTo [Administrator]: AVS Mobile Uploader.lnk . (.Online Media Technologies Ltd. - AVS Mobile Uploader.) C:\Program Files (x86)\Common Files\AVSMedia\MobileUploader\AVSMobileUploader.ex e =>.Online Media Technologies Ltd.®
                  O4 - GS\sendTo [Administrator]: Bluetooth File Transfer.LNK . (.Microsoft Corporation - .) C:\Windows\System32\fsquirt.exe =>.Microsoft Corporation
                  O4 - GS\sendTo [Administrator]: Fax Recipient.lnk . (…) C:\Windows\System32\WFS.exe
                  O4 - GS\sendTo [Administrator]: Skype.lnk . (.Skype Technologies S.A. - Skype.) C:\Program Files (x86)\Skype\Phone\Skype.exe =>.Skype Software Sarl®
                  O4 - GS\sendTo [Administrator]: TeamViewer.lnk . (.TeamViewer GmbH - TeamViewer 12.) C:\Program Files (x86)\TeamViewer\TeamViewer.exe =>.TeamViewer GmbH®
                  O4 - GS\Startup [Administrator]: EffectRack.lnk . (…) C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
                  O4 - GS\Programs [Administrator]: Ableton Live 9 Suite.lnk . (.Ableton - .) C:\ProgramData\Ableton\Live 9 Suite\Program\Ableton Live 9 Suite.exe =>.Ableton
                  O4 - GS\Programs [Administrator]: calibre - E-book management.lnk . (…) C:\Program Files\Calibre2\calibre.exe
                  O4 - GS\Programs [Administrator]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Programs [Administrator]: OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\OneDrive.exe =>.Microsoft Corporation®
                  O4 - GS\Programs [Administrator]: Optional Features.lnk . (.Microsoft Corporation - Features On Demand Helper.) C:\Windows\System32\fodhelper.exe =>.Microsoft Corporation
                  O4 - GS\Programs [Administrator]: rapidseo.lnk . (.Blumentals Software - .) C:\Program Files (x86)\Rapid SEO Tool\rapidseo.exe {11210DFE920F3763B774D7BA7A6B587930C8} =>.Blumentals Software
                  O4 - GS\Programs [Administrator]: Spotify.lnk . (.Spotify Ltd - Spotify.) C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe =>.Spotify AB®
                  O4 - GS\Programs [Administrator]: Windows Install Clean Up.lnk . (…) C:\Users\SamSwanson\AppData\Roaming\Microsoft\Inst aller{121634B0-2F4B-11D3-ADA3-00C04F52DD52}\Icon386ED4E3.exe
                  O4 - GS\Desktop [Guest]: AnonVPN.lnk . (…) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe {1121FA93F95E0C2F6A3A3272F08A5C1E0CC4}
                  O4 - GS\Desktop [Guest]: Dashlane.lnk . (.Dashlane, Inc. - Dashlane.) C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe =>.Dashlane®
                  O4 - GS\Desktop [Guest]: EffectRack.lnk . (…) C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
                  O4 - GS\Desktop [Guest]: Electrum.lnk . (…) C:\Program Files (x86)\Electrum\electrum.exe
                  O4 - GS\Desktop [Guest]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Desktop [Guest]: HOFA CD-Burn & DDP.lnk . (…) C:\Program Files (x86)\HOFA-Plugins\HOFA CD-Burn & DDP\HOFA CD-Burn & DDP.exe
                  O4 - GS\Desktop [Guest]: Kindle.lnk . (.Amazon.com - Kindle.) C:\Users\SamSwanson\AppData\Local\Amazon\Kindle\ap plication\Kindle.exe =>.Amazon Services LLC®
                  O4 - GS\Desktop [Guest]: Melodyne Studio 4.lnk . (.Celemony Software GmbH - Melodyne.) C:\Program Files\Celemony\Melodyne Studio 4\Melodyne.exe =>.Celemony Software GmbH
                  O4 - GS\Desktop [Guest]: Scott - Shortcut.lnk . (…) S:\SessionFiles\Scott
                  O4 - GS\Desktop [Guest]: SessionFiles - Shortcut.lnk . (…) S:\SessionFiles
                  O4 - GS\Desktop [Guest]: Slack.lnk . (…) C:\Users\SamSwanson\AppData\Local\slack\Update.exe =>.Slack Technologies Inc.®
                  O4 - GS\Desktop [Guest]: Spotify.lnk . (.Spotify Ltd - Spotify.) C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe =>.Spotify AB®
                  O4 - GS\Desktop [Guest]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPDiag3.e xe =>.Nicolas Coolman
                  O4 - GS\Quicklaunch [Guest]: Chrome App Launcher.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe --show-app-list =>.Google Inc®
                  O4 - GS\Quicklaunch [Guest]: Finale NotePad 2012.lnk . (.MakeMusic Inc. - Finale® NotePad for Windows.) C:\Program Files (x86)\Finale NotePad 2012\Finale NotePad.exe =>.MakeMusic Inc.®
                  O4 - GS\Quicklaunch [Guest]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Quicklaunch [Guest]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Quicklaunch [Guest]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
                  O4 - GS\Quicklaunch [Guest]: Pro Tools 10.lnk . (.Avid Technology, Inc. - Pro Tools Application.) C:\Program Files (x86)\Avid\Pro Tools\ProTools.exe =>.Avid Technology, Inc.
                  O4 - GS\sendTo [Guest]: AVS Mobile Uploader.lnk . (.Online Media Technologies Ltd. - AVS Mobile Uploader.) C:\Program Files (x86)\Common Files\AVSMedia\MobileUploader\AVSMobileUploader.ex e =>.Online Media Technologies Ltd.®
                  O4 - GS\sendTo [Guest]: Bluetooth File Transfer.LNK . (.Microsoft Corporation - .) C:\Windows\System32\fsquirt.exe =>.Microsoft Corporation
                  O4 - GS\sendTo [Guest]: Fax Recipient.lnk . (…) C:\Windows\System32\WFS.exe
                  O4 - GS\sendTo [Guest]: Skype.lnk . (.Skype Technologies S.A. - Skype.) C:\Program Files (x86)\Skype\Phone\Skype.exe =>.Skype Software Sarl®
                  O4 - GS\sendTo [Guest]: TeamViewer.lnk . (.TeamViewer GmbH - TeamViewer 12.) C:\Program Files (x86)\TeamViewer\TeamViewer.exe =>.TeamViewer GmbH®
                  O4 - GS\Startup [Guest]: EffectRack.lnk . (…) C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
                  O4 - GS\Programs [Guest]: Ableton Live 9 Suite.lnk . (.Ableton - .) C:\ProgramData\Ableton\Live 9 Suite\Program\Ableton Live 9 Suite.exe =>.Ableton
                  O4 - GS\Programs [Guest]: calibre - E-book management.lnk . (…) C:\Program Files\Calibre2\calibre.exe
                  O4 - GS\Programs [Guest]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Programs [Guest]: OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\OneDrive.exe =>.Microsoft Corporation®
                  O4 - GS\Programs [Guest]: Optional Features.lnk . (.Microsoft Corporation - Features On Demand Helper.) C:\Windows\System32\fodhelper.exe =>.Microsoft Corporation
                  O4 - GS\Programs [Guest]: rapidseo.lnk . (.Blumentals Software - .) C:\Program Files (x86)\Rapid SEO Tool\rapidseo.exe {11210DFE920F3763B774D7BA7A6B587930C8} =>.Blumentals Software
                  O4 - GS\Programs [Guest]: Spotify.lnk . (.Spotify Ltd - Spotify.) C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe =>.Spotify AB®
                  O4 - GS\Programs [Guest]: Windows Install Clean Up.lnk . (…) C:\Users\SamSwanson\AppData\Roaming\Microsoft\Inst aller{121634B0-2F4B-11D3-ADA3-00C04F52DD52}\Icon386ED4E3.exe
                  O4 - GS\Desktop [SamSwanson]: AnonVPN.lnk . (…) C:\Program Files (x86)\AnonVPN\bin\AnonVPN.exe {1121FA93F95E0C2F6A3A3272F08A5C1E0CC4}
                  O4 - GS\Desktop [SamSwanson]: Dashlane.lnk . (.Dashlane, Inc. - Dashlane.) C:\Users\SamSwanson\AppData\Roaming\Dashlane\Dashl ane.exe =>.Dashlane®
                  O4 - GS\Desktop [SamSwanson]: EffectRack.lnk . (…) C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
                  O4 - GS\Desktop [SamSwanson]: Electrum.lnk . (…) C:\Program Files (x86)\Electrum\electrum.exe
                  O4 - GS\Desktop [SamSwanson]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Desktop [SamSwanson]: HOFA CD-Burn & DDP.lnk . (…) C:\Program Files (x86)\HOFA-Plugins\HOFA CD-Burn & DDP\HOFA CD-Burn & DDP.exe
                  O4 - GS\Desktop [SamSwanson]: Kindle.lnk . (.Amazon.com - Kindle.) C:\Users\SamSwanson\AppData\Local\Amazon\Kindle\ap plication\Kindle.exe =>.Amazon Services LLC®
                  O4 - GS\Desktop [SamSwanson]: Melodyne Studio 4.lnk . (.Celemony Software GmbH - Melodyne.) C:\Program Files\Celemony\Melodyne Studio 4\Melodyne.exe =>.Celemony Software GmbH
                  O4 - GS\Desktop [SamSwanson]: Scott - Shortcut.lnk . (…) S:\SessionFiles\Scott
                  O4 - GS\Desktop [SamSwanson]: SessionFiles - Shortcut.lnk . (…) S:\SessionFiles
                  O4 - GS\Desktop [SamSwanson]: Slack.lnk . (…) C:\Users\SamSwanson\AppData\Local\slack\Update.exe =>.Slack Technologies Inc.®
                  O4 - GS\Desktop [SamSwanson]: Spotify.lnk . (.Spotify Ltd - Spotify.) C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe =>.Spotify AB®
                  O4 - GS\Desktop [SamSwanson]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPDiag3.e xe =>.Nicolas Coolman
                  O4 - GS\Quicklaunch [SamSwanson]: Chrome App Launcher.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe --show-app-list =>.Google Inc®
                  O4 - GS\Quicklaunch [SamSwanson]: Finale NotePad 2012.lnk . (.MakeMusic Inc. - Finale® NotePad for Windows.) C:\Program Files (x86)\Finale NotePad 2012\Finale NotePad.exe =>.MakeMusic Inc.®
                  O4 - GS\Quicklaunch [SamSwanson]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Quicklaunch [SamSwanson]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Quicklaunch [SamSwanson]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
                  O4 - GS\Quicklaunch [SamSwanson]: Pro Tools 10.lnk . (.Avid Technology, Inc. - Pro Tools Application.) C:\Program Files (x86)\Avid\Pro Tools\ProTools.exe =>.Avid Technology, Inc.
                  O4 - GS\sendTo [SamSwanson]: AVS Mobile Uploader.lnk . (.Online Media Technologies Ltd. - AVS Mobile Uploader.) C:\Program Files (x86)\Common Files\AVSMedia\MobileUploader\AVSMobileUploader.ex e =>.Online Media Technologies Ltd.®
                  O4 - GS\sendTo [SamSwanson]: Bluetooth File Transfer.LNK . (.Microsoft Corporation - .) C:\Windows\System32\fsquirt.exe =>.Microsoft Corporation
                  O4 - GS\sendTo [SamSwanson]: Fax Recipient.lnk . (…) C:\Windows\System32\WFS.exe
                  O4 - GS\sendTo [SamSwanson]: Skype.lnk . (.Skype Technologies S.A. - Skype.) C:\Program Files (x86)\Skype\Phone\Skype.exe =>.Skype Software Sarl®
                  O4 - GS\sendTo [SamSwanson]: TeamViewer.lnk . (.TeamViewer GmbH - TeamViewer 12.) C:\Program Files (x86)\TeamViewer\TeamViewer.exe =>.TeamViewer GmbH®
                  O4 - GS\Startup [SamSwanson]: EffectRack.lnk . (…) C:\Program Files (x86)\DDMF\Virtual Audio Stream\EffectRack.exe
                  O4 - GS\Programs [SamSwanson]: Ableton Live 9 Suite.lnk . (.Ableton - .) C:\ProgramData\Ableton\Live 9 Suite\Program\Ableton Live 9 Suite.exe =>.Ableton
                  O4 - GS\Programs [SamSwanson]: calibre - E-book management.lnk . (…) C:\Program Files\Calibre2\calibre.exe
                  O4 - GS\Programs [SamSwanson]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Programs [SamSwanson]: OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\OneDrive.exe =>.Microsoft Corporation®
                  O4 - GS\Programs [SamSwanson]: Optional Features.lnk . (.Microsoft Corporation - Features On Demand Helper.) C:\Windows\System32\fodhelper.exe =>.Microsoft Corporation
                  O4 - GS\Programs [SamSwanson]: rapidseo.lnk . (.Blumentals Software - .) C:\Program Files (x86)\Rapid SEO Tool\rapidseo.exe {11210DFE920F3763B774D7BA7A6B587930C8} =>.Blumentals Software
                  O4 - GS\Programs [SamSwanson]: Spotify.lnk . (.Spotify Ltd - Spotify.) C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe =>.Spotify AB®
                  O4 - GS\Programs [SamSwanson]: Windows Install Clean Up.lnk . (…) C:\Users\SamSwanson\AppData\Roaming\Microsoft\Inst aller{121634B0-2F4B-11D3-ADA3-00C04F52DD52}\Icon386ED4E3.exe
                  O4 - GS\CommonDesktop [Public]: AATranslator.lnk . (.Acresso Software Inc. - InstallShield.) C:\Windows\Installer{7400C259-1F2E-4FF2-9037-860BF239F39D}\AATranslator.exe1_C28CFF94EA9F4C26BD F90000EC57510F.exe =>.Acresso Software Inc.
                  O4 - GS\CommonDesktop [Public]: Acronis True Image.lnk . (…) C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageLauncher.exe =>.Acronis International GmbH®
                  O4 - GS\CommonDesktop [Public]: Camtasia Studio 8.lnk . (.TechSmith Corporation - Camtasia Studio.) C:\Program Files (x86)\TechSmith\Camtasia Studio 8\CamtasiaStudio.exe =>.TechSmith Corporation®
                  O4 - GS\CommonDesktop [Public]: Finale NotePad 2012.lnk . (.MakeMusic Inc. - Finale® NotePad for Windows.) C:\Program Files (x86)\Finale NotePad 2012\Finale NotePad.exe =>.MakeMusic Inc.®
                  O4 - GS\CommonDesktop [Public]: GnuCash.lnk . (…) C:\Program Files (x86)\gnucash\bin\gnucash.exe
                  O4 - GS\CommonDesktop [Public]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
                  O4 - GS\CommonDesktop [Public]: Helium Audio Converter.lnk . (.Imploded Software - .) C:\Program Files (x86)\Imploded Software\Helium Audio Converter\HeliumAudioConverter.exe {0F3D0100E3FF527E1E94810557B6E783}
                  O4 - GS\CommonDesktop [Public]: Mp3tag.lnk . (.Florian Heidenreich - Mp3tag - the universal Tag editor.) C:\Program Files (x86)\Mp3tag\Mp3tag.exe =>.Florian Heidenreich®
                  O4 - GS\CommonDesktop [Public]: Nero 12.lnk . (.Acresso Software Inc. - InstallShield.) C:\Windows\Installer{0E4630AF-0AB7-440E-A978-1A78FC4F43B9}\NeroLauncher.ex_06255901E67449719980 557FAA5EC1C6.exe =>.Nero AG®
                  O4 - GS\CommonDesktop [Public]: Pro Tools 10.lnk . (.Avid Technology, Inc. - Pro Tools Application.) C:\Program Files (x86)\Avid\Pro Tools\ProTools.exe =>.Avid Technology, Inc.
                  O4 - GS\CommonDesktop [Public]: REAPER (x64).lnk . (.Cockos Incorporated - REAPER.) C:\Program Files\REAPER (x64)\reaper.exe =>.Cockos Incorporated
                  O4 - GS\CommonDesktop [Public]: Rhyme Genie.lnk . (.FileMaker, Inc. - FileMaker Pro Runtime.) C:\Program Files (x86)\Idolumic\Rhyme Genie\Rhyme Genie.exe {00BB32180E894701C6DF225597E3F7A25E} =>.FileMaker, Inc.
                  O4 - GS\CommonDesktop [Public]: Sonarworks Reference.lnk . (.Sonarworks - Sonarworks Reference 3.) C:\Program Files (x86)\Sonarworks\SonarworksReference\Sonarworks Reference 3.exe
                  O4 - GS\CommonDesktop [Public]: Steam.lnk . (.Valve Corporation - Steam Client Bootstrapper.) C:\Program Files (x86)\Steam\Steam.exe =>.Valve®
                  O4 - GS\CommonDesktop [Public]: Tradeo - MetaTrader 4.lnk . (.MetaQuotes Software Corp. - MetaTrader.) C:\Program Files (x86)\Tradeo - MetaTrader 4\terminal.exe {00A74246F26ADF987743017FED54891570} =>.MetaQuotes Software Corp.
                  O4 - GS\CommonDesktop [Public]: TuneSmith.lnk . (.FileMaker, Inc. - FileMaker Pro Runtime.) C:\Program Files (x86)\Idolumic\TuneSmith\TuneSmith.exe {00BB32180E894701C6DF225597E3F7A25E} =>.FileMaker, Inc.
                  O4 - GS\CommonDesktop [Public]: VLC media player.lnk . (.VideoLAN - VLC media player.) C:\Program Files (x86)\VideoLAN\VLC\vlc.exe =>.VideoLAN®
                  O4 - GS\CommonDesktop [Public]: Wirecast.lnk . (.Telestream LLC - Wirecast Application.) C:\Program Files\Telestream\Wirecast\Wirecast.exe {7ACC998C1F033DB5852DA274F21E78E5} =>.Telestream LLC
                  O4 - GS\Programs [Public]: Ableton Live 9 Suite.lnk . (.Ableton - .) C:\ProgramData\Ableton\Live 9 Suite\Program\Ableton Live 9 Suite.exe =>.Ableton
                  O4 - GS\Programs [Public]: calibre - E-book management.lnk . (…) C:\Program Files\Calibre2\calibre.exe
                  O4 - GS\Programs [Public]: Google Chrome Canary.lnk . (.Google Inc. - Google Chrome.) C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                  O4 - GS\Programs [Public]: OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\OneDrive.exe =>.Microsoft Corporation®
                  O4 - GS\Programs [Public]: Optional Features.lnk . (.Microsoft Corporation - Features On Demand Helper.) C:\Windows\System32\fodhelper.exe =>.Microsoft Corporation
                  O4 - GS\Programs [Public]: rapidseo.lnk . (.Blumentals Software - .) C:\Program Files (x86)\Rapid SEO Tool\rapidseo.exe {11210DFE920F3763B774D7BA7A6B587930C8} =>.Blumentals Software
                  O4 - GS\Programs [Public]: Spotify.lnk . (.Spotify Ltd - Spotify.) C:\Users\SamSwanson\AppData\Roaming\Spotify\Spotif y.exe =>.Spotify AB®
                  O4 - GS\Programs [Public]: Windows Install Clean Up.lnk . (…) C:\Users\SamSwanson\AppData\Roaming\Microsoft\Inst aller{121634B0-2F4B-11D3-ADA3-00C04F52DD52}\Icon386ED4E3.exe
                  O4 - GS\Accessories [Public]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
                  O4 - GS\Accessories [Public]: Notepad.lnk . (.Microsoft Corporation - Notepad.) C:\WINDOWS\system32\notepad.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Math Input Panel.lnk . (.Microsoft Corporation - Math Input Panel Accessory.) C:\Program Files\Common Files\microsoft shared\ink\mip.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Paint.lnk . (.Microsoft Corporation - Paint.) C:\WINDOWS\system32\mspaint.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Quick Assist.lnk . (.Microsoft Corporation - Quick Assist.) C:\WINDOWS\system32\quickassist.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Remote Desktop Connection.lnk . (.Microsoft Corporation - Remote Desktop Connection.) C:\WINDOWS\system32\mstsc.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Snipping Tool.lnk . (.Microsoft Corporation - Snipping Tool.) C:\WINDOWS\system32\SnippingTool.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Steps Recorder.lnk . (.Microsoft Corporation - Steps Recorder.) C:\WINDOWS\system32\psr.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Windows Fax and Scan.lnk . (…) C:\WINDOWS\system32\WFS.exe
                  O4 - GS\Accessories [Public]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: Wordpad.lnk . (.Microsoft Corporation - Windows Wordpad Application.) C:\Program Files (x86)\Windows NT\Accessories\wordpad.exe =>.Microsoft Corporation
                  O4 - GS\Accessories [Public]: XPS Viewer.lnk . (.Microsoft Corporation - XPS Viewer.) C:\WINDOWS\system32\xpsrchvw.exe =>.Microsoft Corporation
                  O4 - GS\SystemTools [Public]: Character Map.lnk . (.Microsoft Corporation - Character Map.) C:\WINDOWS\system32\charmap.exe =>.Microsoft Corporation
                  O4 - GS\ProgramsCommon [Public]: Acronis True Image.lnk . (…) C:\Program Files (x86)\Acronis\TrueImageHome\TrueImageLauncher.exe =>.Acronis International GmbH®
                  O4 - GS\ProgramsCommon [Public]: Adobe After Effects CS4.lnk . (.Adobe Systems Incorporated - Adobe After Effects CS4.) C:\Program Files (x86)\Adobe\Adobe After Effects CS4\Support Files\AfterFX.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Bridge CS5.lnk . (.Adobe Systems, Inc. - Adobe Bridge CS5.) C:\Program Files (x86)\Adobe\Adobe Bridge CS5\Bridge.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Device Central CS5.lnk . (.Adobe Systems Inc. - Adobe Device Central CS5.) C:\Program Files (x86)\Adobe\Adobe Device Central CS5\DeviceCentral.exe =>.Adobe Systems Inc.
                  O4 - GS\ProgramsCommon [Public]: Adobe ExtendScript Toolkit CS4.lnk . (.Adobe Systems Incorporated - ExtendScript Toolkit CS4 and Debugger (32 b.) C:\Program Files (x86)\Adobe\Adobe Utilities\ExtendScript Toolkit CS4\ExtendScript Toolkit.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe ExtendScript Toolkit CS5.lnk . (.Adobe Systems Incorporated - ExtendScript Toolkit CS5 and Debugger (32 b.) C:\Program Files (x86)\Adobe\Adobe Utilities - CS5\ExtendScript Toolkit CS5\ExtendScript Toolkit.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Extension Manager CS4.lnk . (.Adobe Systems Incorporated - Adobe Extension Manager CS4.) C:\Program Files (x86)\Adobe\Adobe Extension Manager CS4\Adobe Extension Manager CS4.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Extension Manager CS5.lnk . (.Adobe Systems Incorporated - Adobe Extension Manager CS5.) C:\Program Files (x86)\Adobe\Adobe Extension Manager CS5\Adobe Extension Manager CS5.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Media Encoder CS4.lnk . (.Adobe Systems, Incorporated - .) C:\Program Files (x86)\Adobe\Adobe Media Encoder CS4\Adobe Media Encoder.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Photoshop CS5 (64 Bit).lnk . (.Adobe Systems, Incorporated - Adobe Photoshop CS5.) C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Photoshop.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Photoshop Lightroom 5 64-bit.lnk . (.Adobe Systems - Adobe Photoshop Lightroom 64-bit.) C:\Program Files\Adobe\Adobe Photoshop Lightroom 5\lightroom.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: Adobe Pixel Bender Toolkit.lnk . (…) C:\Program Files (x86)\Adobe\Adobe Utilities\Pixel Bender Toolkit\pixel_bender_toolkit.exe =>.Adobe Systems Incorporated®
                  O4 - GS\ProgramsCommon [Public]: AmpegSVX.lnk . (.IK Multimedia - AmpegSVX.) C:\Program Files\VSTPlugIns\AmpegSVX.exe =>.IK Multimedia
                  O4 - GS\ProgramsCommon [Public]: Apple Software Update.lnk . (…) C:\Windows\Installer{56EC47AA-5813-4FF6-8E75-544026FBEA83}\AppleSoftwareUpdateIco.exe =>.Apple Inc.
                  O4 - GS\ProgramsCommon [Public]: atomiccleaner3.lnk . (.atomicware - atomiccleaner3.) C:\Program Files (x86)\atomicware\atomiccleaner3\atomiccleaner3.exe =>.AtomicWare
                  O4 - GS\ProgramsCommon [Public]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
                  O4 - GS\ProgramsCommon [Public]: iLok License Manager.lnk . (.PACE Anti-Piracy, Inc. - iLok License Manager.) C:\Program Files (x86)\iLok License Manager\iLok License Manager.exe =>.PACE Anti-Piracy, Inc.®
                  O4 - GS\ProgramsCommon [Public]: Immersive Control Panel.lnk . (.Microsoft Corporation - Windows Control Panel.) C:\WINDOWS\System32\Control.exe =>.Microsoft Corporation
                  O4 - GS\ProgramsCommon [Public]: MacDrive Pro Quick Start.lnk . (.Mediafour Corporation - MacDrive Quick Start.) C:\Program Files\Mediafour\MacDrive 9\MDQuickStart.exe =>.Mediafour Corporation
                  O4 - GS\ProgramsCommon [Public]: Market Samurai.lnk . (…) C:\Program Files (x86)\Market Samurai\Market Samurai.exe
                  O4 - GS\ProgramsCommon [Public]: Microsoft Web Platform Installer.lnk . (.Microsoft Corporation - .) C:\Program Files\Microsoft\Web Platform Installer\WebPlatformInstaller.exe =>.Microsoft Corporation®
                  O4 - GS\ProgramsCommon [Public]: Mozilla Firefox.lnk . (.Mozilla Corporation - Firefox.) C:\Program Files (x86)\Mozilla Firefox\firefox.exe =>.Mozilla Corporation®
                  O4 - GS\ProgramsCommon [Public]: MusicBrainz Picard.lnk . (…) C:\Program Files (x86)\MusicBrainz Picard\picard.exe
                  O4 - GS\ProgramsCommon [Public]: Nitro Pro 8.lnk . (…) C:\Windows\Installer{47B42E7A-57E9-407B-8DBB-017B86D7B13F}\Professional.ico
                  O4 - GS\ProgramsCommon [Public]: PrintDialog.lnk . (.Microsoft Corporation - Print Dialog.) C:\WINDOWS\PrintDialog\PrintDialog.exe =>.Microsoft Windows®
                  O4 - GS\ProgramsCommon [Public]: TeamViewer 12.lnk . (.TeamViewer GmbH - TeamViewer 12.) C:\Program Files (x86)\TeamViewer\TeamViewer.exe =>.TeamViewer GmbH®
                  O4 - GS\ProgramsCommon [Public]: Tracker.lnk . (…) C:\Program Files (x86)\Tracker\Tracker.exe {2B7213718E6165}
                  O4 - GS\ProgramsCommon [Public]: Windows 10 Upgrade Assistant.lnk . (.Microsoft Corporation - Windows 10 Upgrade Assistant.) C:\Windows10Upgrade\Windows10UpgraderApp.exe =>.Microsoft Corporation®
                  O4 - GS\ProgramsCommon [Public]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe =>.Microsoft Corporation
                  —\ Lop.com/Domain Hijackers (2) - 0s
                  O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 213.46.172.36 213.46.172.37
                  O17 - HKLM\System\CCS\Services\Tcpip..{7faf953a-453a-4de6-a3bc-2ce40997f6cc}: DhcpNameServer = 213.46.172.36 213.46.172.37
                  —\ Extra protocols (25) - 0s
                  O18 - Handler: about [64Bits] - {3050F406-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) – C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
                  O18 - Handler: cdl [64Bits] - {3dd53d40-7b8b-11D0-b013-00aa0059ce02} . (.Microsoft Corporation - OLE32 Extensions for Win32.) – C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
                  O18 - Handler: dvd [64Bits] - {12D51199-0DB5-46FE-A120-47A3D7D937CC} . (.Microsoft Corporation - ActiveX control for streaming video.) – C:\Windows\SysWOW64\MSVidCtl.dll =>.Microsoft Corporation
                  O18 - Handler: file [64Bits] - {79eac9e7-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) – C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
                  O18 - Handler: ftp [64Bits] - {79eac9e3-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) – C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
                  O18 - Handler: http [64Bits] - {79eac9e2-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) – C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
                  O18 - Handler: https [64Bits] - {79eac9e5-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) – C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
                  O18 - Handler: its [64Bits] - {9D148291-B9C8-11D0-A4CC-0000F80149F6} . (.Microsoft Corporation - Microsoft® InfoTech Storage System Library.) – C:\Windows\SysWOW64\itss.dll =>.Microsoft Corporation
                  O18 - Handler: javascript [64Bits] - {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) – C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
                  O18 - Handler: local [64Bits] - {79eac9e7-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) – C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
                  O18 - Handler: mailto [64Bits] - {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) – C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
                  O18 - Handler: mhtml [64Bits] - {05300401-BCBC-11d0-85E3-00C04FD85AB4} . (.Microsoft Corporation - Microsoft Internet Messaging API Resources.) – C:\Windows\SysWOW64\inetcomm.dll =>.Microsoft Corporation
                  O18 - Handler: mk [64Bits] - {79eac9e6-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) – C:\Windows\SysWOW64\urlmon.dll =>.Microsoft Corporation
                  O18 - Handler: ms-its [64Bits] - {9D148291-B9C8-11D0-A4CC-0000F80149F6} . (.Microsoft Corporation - Microsoft® InfoTech Storage System Library.) – C:\Windows\SysWOW64\itss.dll =>.Microsoft Corporation
                  O18 - Handler: osf [64Bits] - {D924BDC6-C83A-4BD5-90D0-095128A113D1} . (.Microsoft Corporation - Microsoft Office 2013 component.) – C:\Program Files (x86)\Microsoft Office\Office15\MSOSB.DLL =>.Microsoft Corporation®
                  O18 - Handler: res [64Bits] - {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) – C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
                  O18 - Handler: skype4com [64Bits] - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} . (.Skype Technologies - Skype4COM.) – C:\Program Files (x86)\Common Files\Skype\Skype4COM.dll =>.Skype Software Sarl®
                  O18 - Handler: tbauth [64Bits] - {14654CA6-5711-491D-B89A-58E571679951} . (.Microsoft Corporation - TBAuth protocol handler.) – C:\Windows\SysWOW64\tbauth.dll =>.Microsoft Corporation
                  O18 - Handler: tv [64Bits] - {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} . (.Microsoft Corporation - ActiveX control for streaming video.) – C:\Windows\SysWOW64\MSVidCtl.dll =>.Microsoft Corporation
                  O18 - Handler: vbscript [64Bits] - {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) – C:\Windows\SysWOW64\mshtml.dll =>.Microsoft Corporation
                  O18 - Handler: windows.tbauth [64Bits] - {14654CA6-5711-491D-B89A-58E571679951} . (.Microsoft Corporation - TBAuth protocol handler.) – C:\Windows\SysWOW64\tbauth.dll =>.Microsoft Corporation
                  O18 - Filter: application/octet-stream [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) – C:\Windows\SysWOW64\mscoree.dll =>.Microsoft Corporation
                  O18 - Filter: application/x-complus [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) – C:\Windows\SysWOW64\mscoree.dll =>.Microsoft Corporation
                  O18 - Filter: application/x-msdownload [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) – C:\Windows\SysWOW64\mscoree.dll =>.Microsoft Corporation
                  O18 - Filter: text/xml [64Bits] - {807583E5-5146-11D5-A672-00B0D022E945} . (.Microsoft Corporation - Microsoft Office XML MIME Filter.) – C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\MSOXMLMF.DLL =>.Microsoft Corporation®
                  —\ Software installed (548) - 34s
                  O42 - Logiciel: +10db version 1.0.4 - (.Boz Digital Labs.) [HKLM][64Bits] – +10db_is1 {0ADC604849EEBAB4E04433112E3D4A65}
                  O42 - Logiciel: 112dB Big Blue Compressor 1.0.3-r3719 - (.112dB.) [HKLM][64Bits] – 112dB Big Blue Compressor 1.0.3-r3719
                  O42 - Logiciel: 112dB Big Blue Limiter 1.1.3-r3719 - (.112dB.) [HKLM][64Bits] – 112dB Big Blue Limiter 1.1.3-r3719
                  O42 - Logiciel: 112dB Redline Equalizer 1.0.5-r3719 - (.112dB.) [HKLM][64Bits] – 112dB Redline Equalizer 1.0.5-r3719
                  O42 - Logiciel: 112dB Redline Reverb 1.0.10-r3810 - (.112dB.) [HKLM][64Bits] – 112dB Redline Reverb 1.0.10-r3810
                  O42 - Logiciel: 2C-Audio Aether - (..) [HKLM][64Bits] – Aether
                  O42 - Logiciel: 2C-Audio Breeze - (.2C-Audio.) [HKLM][64Bits] – Breeze
                  O42 - Logiciel: 6030 Ultimate Comp Native - (.McDSP.) [HKLM][64Bits] – {96B75FC3-D48A-4F8B-8BC7-5C2728797E4E} {00DC102D00CE0D3CDF37E11A4D1EEBB5F2}
                  O42 - Logiciel: 7-Zip 16.04 (x64 edition) - (.Igor Pavlov.) [HKLM][64Bits] – {23170F69-40C1-2702-1604-000001000000} =>.Igor Pavlov
                  O42 - Logiciel: AATranslator - (.Suite Spot Studios.) [HKLM][64Bits] – {7400C259-1F2E-4FF2-9037-860BF239F39D}
                  O42 - Logiciel: Abbeyroadplugins EMI Brilliance Pack VST RTAS v1.0.6 - (..) [HKLM][64Bits] – Abbeyroadplugins EMI Brilliance Pack VST RTAS_is1
                  O42 - Logiciel: Abbeyroadplugins EMI RS 124 Compressor VST RTAS v1.0.1 - (..) [HKLM][64Bits] – Abbeyroadplugins EMI RS 124 Compressor_is1
                  O42 - Logiciel: Abbeyroadplugins EMI TG 12413 Limiter VST RTAS v2.0.1 - (..) [HKLM][64Bits] – Abbeyroadplugins EMI TG 12413 Limiter VST RTAS_is1
                  O42 - Logiciel: Abbeyroadplugins EMI TG Mastering Pack VST RTAS v1.0.2 - (..) [HKLM][64Bits] – Abbeyroadplugins EMI TG Mastering Pack VST RTAS_is1
                  O42 - Logiciel: Ableton Live 9 Suite - (.Ableton.) [HKLM][64Bits] – {48EC4E57-1D04-4831-90A7-151DA2269495} =>.Ableton
                  O42 - Logiciel: Acronis True Image - (.Acronis.) [HKLM][64Bits] – {E5F28743-0DB5-42C1-8B70-5986D88C0BE0} =>.Acronis
                  O42 - Logiciel: Acronis True Image - (.Acronis.) [HKLM][64Bits] – {E5F28743-0DB5-42C1-8B70-5986D88C0BE0}Visible =>.Acronis International GmbH®
                  O42 - Logiciel: acustica AcquaVox - (..) [HKLM][64Bits] – AcquaVox
                  O42 - Logiciel: Acustica Audio D361A - (.Acustica Audio.) [HKLM][64Bits] – D361A Win x64
                  O42 - Logiciel: Acustica Audio EQP1 - (.Acustica Audio.) [HKLM][64Bits] – EQP1 Win x64
                  O42 - Logiciel: Acustica Audio NEO - (.Acustica Audio.) [HKLM][64Bits] – NEO Win x64
                  O42 - Logiciel: Acustica Audio REDEQ - (.Acustica Audio.) [HKLM][64Bits] – REDEQ Win x64
                  O42 - Logiciel: Acustica Audio TAN - (.Acustica Audio.) [HKLM][64Bits] – TAN Win x64
                  O42 - Logiciel: Acustica Audio TITANIUM3B - (.Acustica Audio.) [HKLM][64Bits] – TITANIUM3B Win x64
                  O42 - Logiciel: Acustica Audio TRINITYEQ - (.Acustica Audio.) [HKLM][64Bits] – TRINITYEQ Win x64
                  O42 - Logiciel: AcusticaAudio Nebula3 - (..) [HKLM][64Bits] – Nebula3
                  O42 - Logiciel: Adobe After Effects CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {45EC816C-0771-4C14-AE6D-72D1B578F4C8} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe After Effects CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – Adobe_3dcb365ab9e01871fb8c6f27b0ea079 =>.Adobe Systems Incorporated®
                  O42 - Logiciel: Adobe After Effects CS4 Presets - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {44E240EC-2224-4078-A88B-2CEE0D3016EF} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe AIR - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {63B5DA5A-477B-438D-A6A0-118787A4C71B} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe AIR - (.Adobe Systems Incorporated.) [HKLM][64Bits] – Adobe AIR =>.Adobe Systems Incorporated®
                  O42 - Logiciel: Adobe Anchor Service CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {1618734A-3957-4ADD-8199-F973763109A8} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe CMaps CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {94D398EB-D2FD-4FD1-B8C4-592635E8A191} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Color Video Profiles AE CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {B15381DD-FF97-4FCD-A881-ED4DB0975500} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Default Language CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {C52E3EC1-048C-45E1-8D53-10B0C6509683} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Dynamiclink Support - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {60DB5894-B5A1-4B62-B0F3-669A22C0EE5D} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe ExtendScript Toolkit CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {F8EF2B3F-C345-4F20-8FE4-791A20333CD5} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Extension Manager CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {054EFA56-2AC1-48F4-A883-0AB89874B972} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Flash Player 24 NPAPI - (.Adobe Systems Incorporated.) [HKLM][64Bits] – Adobe Flash Player NPAPI =>.Adobe Systems Incorporated®
                  O42 - Logiciel: Adobe Flash Player 24 PPAPI - (.Adobe Systems Incorporated.) [HKLM][64Bits] – Adobe Flash Player PPAPI =>.Adobe Systems Incorporated®
                  O42 - Logiciel: Adobe Fonts All - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {FCDD51BB-CAD0-4BB1-B7DF-CE86D1032794} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Media Encoder CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {DEB90B8E-0DCB-48CE-B90E-8842A2BD643E} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Media Encoder CS4 Additional Exporter - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {BE9CEAAA-F069-4331-BF2F-8D350F6504F4} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe MotionPicture Color Files CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {B05DE7B7-0B40-4411-BD4B-222CAE2D8F15} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Output Module - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {BB4E33EC-8181-4685-96F7-8554293DEC6A} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe PDF Library Files CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {F93C84A6-0DC6-42AF-89FA-776F7C377353} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Photoshop Lightroom 5 64-bit - (.Adobe.) [HKLM][64Bits] – {6C1A010F-9108-4162-A26F-9FEC4AC0F0F0} =>.Adobe
                  O42 - Logiciel: Adobe Setup - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {411F3ABA-2AB5-4799-AA19-6ADF0A8F7424} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Shockwave Player 12.2 - (.Adobe Systems, Inc.) [HKLM][64Bits] – {A2116AF9-FA9D-41EA-9874-1E40B227D4DE} =>.Adobe Systems, Inc
                  O42 - Logiciel: Adobe Type Support CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {820D3F45-F6EE-4AAF-81EF-CE21FF21D230} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe Update Manager CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {05308C4E-7285-4066-BAE3-6B50DA6ED755} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Adobe XMP Panels CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {3A4E8896-C2E7-4084-A4A4-B8FD1894E739} =>.Adobe Systems Incorporated
                  O42 - Logiciel: AI Suite II - (.ASUSTeK Computer Inc..) [HKLM][64Bits] – {34D3688E-A737-44C5-9E2A-FF73618728E1} =>.ASUSTeK Computer Inc.®
                  O42 - Logiciel: Altiverb 7 Uninstaller - (.Audio Ease BV.) [HKLM][64Bits] – {367662CA-394A-4095-9549-973FC3807B9B}_is1
                  O42 - Logiciel: Amazon Kindle - (.Amazon.) [HKCU][64Bits] – Amazon Kindle =>.Amazon
                  O42 - Logiciel: Amazon Kindle - (.Amazon.) [HKLM][64Bits] – Amazon Kindle =>.Amazon
                  O42 - Logiciel: AmpegSVX - (.IK Multimedia.) [HKLM][64Bits] – {CF1D7323-8A0A-49C7-83B0-088DB90721E2} =>.Macrovision Corporation®
                  O42 - Logiciel: AmpliTube 3 version 3.11.0 - (.IK Multimedia.) [HKLM][64Bits] – {DA5202AC-12BF-4330-B8EA-BC77F991FA1C}_is1 =>.IK Multimedia
                  O42 - Logiciel: AmpliTube 4 version 4.0.1 - (.IK Multimedia.) [HKLM][64Bits] – {21B0C8E0-7EB7-4832-B764-20A7DAE86E02}_is1 =>.IK Multimedia
                  O42 - Logiciel: AnonVPN 1.0.5.5 - (.AnonVPN.io.) [HKLM][64Bits] – AnonVPN
                  O42 - Logiciel: Ansel - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel =>.NVIDIA Corporation
                  O42 - Logiciel: Antares Autotune Evo VST RTAS v6.0.9 - (..) [HKLM][64Bits] – Antares Autotune Evo VST RTAS_is1
                  O42 - Logiciel: Antares AVOX Evo VST RTAS v3.0.2 - (.Antares.) [HKLM][64Bits] – Antares AVOX Evo VST RTAS_is1
                  O42 - Logiciel: Antares Harmony Engine VST RTAS v1.0 - (.Team AiR 2007.) [HKLM][64Bits] – Antares Harmony Engine VST RTAS_is1 =>.Team AiR 2007
                  O42 - Logiciel: Apple Application Support (32-bit) - (.Apple Inc..) [HKLM][64Bits] – {9BA1A894-B42F-4805-BC8C-349C905A3930} =>.Apple Inc.
                  O42 - Logiciel: Apple Application Support (64-bit) - (.Apple Inc..) [HKLM][64Bits] – {7EAC8A42-9FAC-4F6B-AABF-C08C9F2E0F13} =>.Apple Inc.
                  O42 - Logiciel: Apple Mobile Device Support - (.Apple Inc..) [HKLM][64Bits] – {55BB2110-FB43-49B3-93F4-945A0CFB0A6C} =>.Apple Inc.
                  O42 - Logiciel: Apple Software Update - (.Apple Inc..) [HKLM][64Bits] – {56EC47AA-5813-4FF6-8E75-544026FBEA83} =>.Apple Inc.
                  O42 - Logiciel: ARC System 2 version 2.1.0 - (.IK Multimedia.) [HKLM][64Bits] – {4952A610-D484-4F6A-B1B4-33797CFDB821}_is1 =>.IK Multimedia
                  O42 - Logiciel: ArcSoft Portrait+ 3 - (.ArcSoft.) [HKLM][64Bits] – {40BB5B1A-6008-4348-8C24-116B654C7ECD} =>.ArcSoft
                  O42 - Logiciel: ARIA Engine v1.8.4.8 - (.Plogue Art et Technologie, Inc.) [HKLM][64Bits] – ARIA Engine_is1
                  O42 - Logiciel: Articulate Storyline - (.Articulate.) [HKLM][64Bits] – {451ABD1C-BA0D-4512-BE18-2D9A39F29036} =>.Articulate
                  O42 - Logiciel: ASIO Bridge and Hi-Fi Cable - (.VB-Audio Software.) [HKLM][64Bits] – VB:ASIOBridge {17359A74-1236-5467} =>.Vincent Burel®
                  O42 - Logiciel: ASIO4ALL - (.Michael Tippach.) [HKLM][64Bits] – ASIO4ALL =>.Michael Tippach
                  O42 - Logiciel: Assassin’s Creed(R) III v1.03 - (.Ubisoft.) [HKLM][64Bits] – {9D15E813-0C26-41E7-ABC5-3EB06FF1B3CF} =>.Ubisoft
                  O42 - Logiciel: Atheros Driver Installation Program - (.Atheros.) [HKLM][64Bits] – {C3A32068-8AB1-4327-BB16-BED9C6219DC7} =>.Atheros
                  O42 - Logiciel: atomiccleaner3 version 1.3.4.1 - (.atomicware.) [HKLM][64Bits] – {0D6AB211-A181-4F42-AEB4-127C40BF67EF}_is1 =>.AtomicWare
                  O42 - Logiciel: AudioEase Altiverb VST RTAS v6.12 - (..) [HKLM][64Bits] – AudioEase Altiverb VST RTAS_is1
                  O42 - Logiciel: AudioEase Speakersphone VST RTAS v1.03 - (.Audio Ease.) [HKLM][64Bits] – AudioEase Speakersphone VST RTAS_is1
                  O42 - Logiciel: Avid Effects - (.Avid Technology, Inc..) [HKLM][64Bits] – {A86F1158-A7F7-4E8C-98E3-88F4996E85EB} =>.Avid Technology, Inc.
                  O42 - Logiciel: Avid HD Driver (x64) - (.Avid Technology, Inc..) [HKLM][64Bits] – {01C898E1-38A7-49B1-9398-49E40636E2C5} =>.Avid Technology, Inc.
                  O42 - Logiciel: Avid HD Driver (x64) - (.Avid Technology, Inc..) [HKLM][64Bits] – {658E112A-8776-4430-A275-D9248732DFB9} =>.Avid Technology, Inc.
                  O42 - Logiciel: Avid Mbox Driver 1.1.10 (x64) - (.Avid.) [HKLM][64Bits] – {35BAD2B7-E2EF-4A06-80A2-C6C2F23B8F3E} =>.Avid
                  O42 - Logiciel: Avid Pro Tools - (.Avid Technology, Inc..) [HKLM][64Bits] – {8E60BB71-7EF3-42ED-9F10-AA041F25841A} =>.Avid Technology, Inc.
                  O42 - Logiciel: AVOX Evo VST - (.Antares Audio Technologies.) [HKLM][64Bits] – {65AA5B18-A330-4F35-BCDF-EA85EC888906} =>.Antares Audio Technologies
                  O42 - Logiciel: AVS Audio Converter 7 - (.Online Media Technologies Ltd..) [HKLM][64Bits] – AVS Audio Converter_is1 =>.Online Media Technologies Ltd.
                  O42 - Logiciel: Black Rooster Audio Plugin Pack - (.Black Rooster Audio.) [HKLM][64Bits] – Black Rooster Audio Plugin Pack_is1
                  O42 - Logiciel: BWF MetaEdit 1.3.0 - (.FADGI.) [HKLM][64Bits] – BWF MetaEdit
                  O42 - Logiciel: calibre 64bit - (.Kovid Goyal.) [HKLM][64Bits] – {82EA8033-0AE6-4C1A-91B6-D24BED49AB73} =>.Kovid Goyal
                  O42 - Logiciel: Call of Duty 4: Modern Warfare - (.Infinity Ward.) [HKLM][64Bits] – Steam App 7940 =>.Valve®
                  O42 - Logiciel: Call of Duty: Modern Warfare 3 - (.Infinity Ward - Sledgehammer Games.) [HKLM][64Bits] – Steam App 42680 =>.Valve®
                  O42 - Logiciel: CameraHelperMsi - (.Logitech.) [HKLM][64Bits] – {15634701-BACE-4449-8B25-1567DA8C9FD3} =>.Logitech
                  O42 - Logiciel: Camtasia Studio 8 - (.TechSmith Corporation.) [HKLM][64Bits] – {2B1F8DD0-873D-4AC3-8400-766F255FE263} =>.TechSmith Corporation
                  O42 - Logiciel: Carbonite - (.Carbonite.) [HKLM][64Bits] – {C7D98EFB-A351-4098-B474-1A5B362DB648} {18455E6EF6D43CE1BB0C2DAC7DED3004} =>.Carbonite
                  O42 - Logiciel: CCleaner - (.Piriform.) [HKLM][64Bits] – CCleaner =>.Piriform Ltd®
                  O42 - Logiciel: CDSoundMaster NICE-EQ-VST-TUBE-FREE - (..) [HKLM][64Bits] – NICE-EQ-VST-TUBE-FREE
                  O42 - Logiciel: CDSoundMaster N-TEN-AT4-Bell-Free-64 - (..) [HKLM][64Bits] – N-TEN-AT4-Bell-Free-64
                  O42 - Logiciel: CDS-VTC-FREE-PC-VST-64-BIT THE-VINTAGE-TUBE-COLLECTION-FREE-PC-VST-64-BIT - (..) [HKLM][64Bits] – THE-VINTAGE-TUBE-COLLECTION-FREE-PC-VST-64-BIT
                  O42 - Logiciel: Celemony Melodyne Studio 4 - (.Celemony.) [HKLM][64Bits] – Celemony Melodyne Studio 4 =>.Celemony
                  O42 - Logiciel: COMODO Internet Security - (.COMODO Security Solutions Inc..) [HKLM][64Bits] – {0E9AFD45-C3BA-41D1-B54B-495A22CB3409} =>.COMODO Security Solutions Inc.
                  O42 - Logiciel: CP Control - (..) [HKLM][64Bits] – CP Control
                  O42 - Logiciel: CrystalDiskInfo 7.0.5 Shizuku Edition - (.Crystal Dew World.) [HKLM][64Bits] – CrystalDiskInfo_is1 =>.Crystal Dew World
                  O42 - Logiciel: Custom Shop version 1.7.0 - (.IK Multimedia.) [HKLM][64Bits] – {21BAD046-50EC-49E2-BE7B-F9729704F2C3}_is1 =>.IK Multimedia
                  O42 - Logiciel: D16 Group Repeater - (.D16 Group.) [HKLM][64Bits] – Repeater_is1 =>.D16 Group
                  O42 - Logiciel: DAEMON Tools Lite - (.Disc Soft Ltd.) [HKLM][64Bits] – DAEMON Tools Lite =>.Disc Soft Ltd®
                  O42 - Logiciel: Dashlane - (.Dashlane SAS.) [HKCU][64Bits] – Dashlane =>.Dashlane SAS
                  O42 - Logiciel: Day of Defeat: Source - (.Valve.) [HKLM][64Bits] – Steam App 300 =>.Valve®
                  O42 - Logiciel: Diamond Cut Forensics8 - (.Diamond Cut Productions.) [HKLM][64Bits] – {38C8BBB6-716E-4486-A386-C8D3242959C5}
                  O42 - Logiciel: DisplayFusion 5.0 - (.Binary Fortress Software.) [HKLM][64Bits] – B076073A-5527-4f4f-B46B-B10692277DA2_is1 =>.Binary Fortress Software Ltd.®
                  O42 - Logiciel: Ditto - (.Scott Brogden.) [HKLM][64Bits] – Ditto_is1
                  O42 - Logiciel: DivX Setup - (.DivX, LLC.) [HKLM][64Bits] – DivX Setup =>.DivX, LLC®
                  O42 - Logiciel: DMG Audio Track Range - (.DMG Audio.) [HKLM][64Bits] – Track Range_is1
                  O42 - Logiciel: DMGAudio EQuilibrium 1.04 - (.DMGAudio.) [HKLM][64Bits] – DMGAudio EQuilibrium_is1
                  O42 - Logiciel: DMGAudio Essence 1.00 - (.DMGAudio.) [HKLM][64Bits] – DMGAudio Essence_is1
                  O42 - Logiciel: DMGAudio Limitless 1.00 - (.DMGAudio.) [HKLM][64Bits] – DMGAudio Limitless_is1
                  O42 - Logiciel: DragonDisk 1.05 - (.Almageste.) [HKLM][64Bits] – {7914B94-1234-44D2-0864-0348EBF012AC}_is1
                  O42 - Logiciel: Dropbox - (.Dropbox, Inc..) [HKCU][64Bits] – Dropbox =>.Dropbox, Inc®
                  O42 - Logiciel: Drum Leveler version 1.0.0 - (.Sound Radix.) [HKLM][64Bits] – {94B8FDA3-877B-4EB8-A3E9-5D476329F15D}is1
                  O42 - Logiciel: East West Stormdrum Intakt - (..) [HKLM][64Bits] – East West Stormdrum Intakt
                  O42 - Logiciel: Easy Tune 6 B12.0912.1 - (.GIGABYTE.) [HKLM][64Bits] – {457D7505-D665-4F95-91C3-ECB8C56E9ACA} =>.Gigabyte
                  O42 - Logiciel: Easy Tune 6 B12.0912.1 - (.GIGABYTE.) [HKLM][64Bits] – InstallShield
                  O42 - Logiciel: ElastikVst - (.ueberschall sample service GmbH.) [HKLM][64Bits] – {086EDF55-3DA3-46C9-A6BF-5CE2E4618C32}
                  O42 - Logiciel: ElastikVst - (.ueberschall sample service GmbH.) [HKLM][64Bits] – {92F027CB-BDF9-4047-A654-13A050908158}
                  O42 - Logiciel: Electrum - (.Electrum Technologies GmbH.) [HKCU][64Bits] – Electrum
                  O42 - Logiciel: EmpressPlugins.Tremolo.VST.v1.0 - (..) [HKLM][64Bits] – EmpressPlugins Tremolo_is1
                  O42 - Logiciel: eReg - (.Logitech, Inc..) [HKLM][64Bits] – {3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C} =>.Logitech, Inc.
                  O42 - Logiciel: f.lux - (.Stereopsis.) [HKCU][64Bits] – Flux =>.Stereopsis
                  O42 - Logiciel: FabFilter Pro-C 2.00 (64-bit) - (..) [HKLM][64Bits] – FabFilter Pro-C 2.00 (64-bit)
                  O42 - Logiciel: FG-X - (.Slate Digital.) [HKLM][64Bits] – Slate Digital FG-X_is1 =>.Slate Digital
                  O42 - Logiciel: FG-X Virtual Mastering Console - (.Slate Digital.) [HKLM][64Bits] – FG-X Virtual Mastering Console_is1 =>.Slate Digital
                  O42 - Logiciel: Fidelify - (..) [HKLM][64Bits] – Fidelify
                  O42 - Logiciel: FileMenu Tools - (.LopeSoft - Rubén López Hernández.) [HKLM][64Bits] – FileMenu Tools_is1
                  O42 - Logiciel: FileZilla Client 3.24.0 - (.Tim Kosse.) [HKLM][64Bits] – FileZilla Client =>.Tim Kosse
                  O42 - Logiciel: Finale NotePad 2012 - (.MakeMusic.) [HKLM][64Bits] – Finale NotePad 2012 =>.MakeMusic Inc.®
                  O42 - Logiciel: FlowStone FL 3.0 - (..) [HKLM][64Bits] – FlowStone
                  O42 - Logiciel: Flux Full Pack 2.2 - (.Flux.) [HKLM][64Bits] – Full Pack 2.2_is1
                  O42 - Logiciel: Flux Junger Audio Level Magic 5.1 - (.Flux.) [HKLM][64Bits] – Flux Junger Audio Level Magic 5.1
                  O42 - Logiciel: Folder Marker Free - (.ArcticLine Software.) [HKLM][64Bits] – Folder Marker Free_is1 =>.ArcticLine Software
                  O42 - Logiciel: Genwaveaudio Genwave EQ VST v1.0 - (..) [HKLM][64Bits] – Genwaveaudio Genwave EQ VST_is1
                  O42 - Logiciel: GIZMO - (.ants Inc..) [HKLM][64Bits] – {D0529F5A-C45C-40C0-8457-6A5AF24ABC6E}
                  O42 - Logiciel: Gizmo Central - (.Arainia Solutions, LLC.) [HKLM][64Bits] – Gizmo Central =>.Arainia Solutions, LLC®
                  O42 - Logiciel: GnuCash 2.4.11 - (.GnuCash Development Team.) [HKLM][64Bits] – GnuCash_is1 =>.GnuCash Development Team
                  O42 - Logiciel: Gobbler - (.Media Gobbler, Inc..) [HKLM][64Bits] – {C7CE54DC-7AD2-48A8-BB2E-F7C6A8E40BB5}
                  O42 - Logiciel: Google Chrome - (.Google, Inc..) [HKLM][64Bits] – {742D8ED2-E248-3870-AFA1-F7A1166F217C} =>.Google, Inc.
                  O42 - Logiciel: Google Chrome Canary - (.Google Inc..) [HKCU][64Bits] – Google Chrome SxS =>.Google Inc®
                  O42 - Logiciel: Google Talk (remove only) - (..) [HKLM][64Bits] – {226b64e8-dc75-4eea-a6c8-abcb496320f2}-Google Talk
                  O42 - Logiciel: Google Talk Plugin - (.Google.) [HKLM][64Bits] – {8E29C1CE-346A-3F59-AE22-8C5B7F230498} =>.Google
                  O42 - Logiciel: GoToMeeting 7.31.0.6291 - (.CitrixOnline.) [HKCU][64Bits] – GoToMeeting =>.CitrixOnline
                  O42 - Logiciel: HandBrake 0.10.5 - (.HandBrake Team.) [HKLM][64Bits] – HandBrake =>.HandBrake Team
                  O42 - Logiciel: Head Crusher version 1.6 - (..) [HKLM][64Bits] – Head Crusher_is1
                  O42 - Logiciel: Helium Audio Converter (build 461) - (.Imploded Software.) [HKLM][64Bits] – {8CF3206B-6330-42D6-B35E-CA7098337CB8}_is1
                  O42 - Logiciel: HFSExplorer 0.21 - (.Catacombae Software.) [HKLM][64Bits] – HFSExplorer =>.Catacombae Software
                  O42 - Logiciel: HoRNet AutoGain Pro MK2 - (.HoRNet.) [HKLM][64Bits] – AutoGain Pro MK2_is1
                  O42 - Logiciel: IK Multimedia Authorization Manager version 1.0.15 - (.IK Multimedia.) [HKLM][64Bits] – {85BC0DCB-69E5-4279-AA25-F108EF896588}is1 =>.IK Multimedia
                  O42 - Logiciel: iLok Client Helper - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – {DEA491FB-48BC-4B6B-8902-FCD4BAB069BE} =>.PACE Anti-Piracy, Inc.
                  O42 - Logiciel: iLok Client Helper - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – InstallShield
                  {DEA491FB-48BC-4B6B-8902-FCD4BAB069BE} =>.PACE Anti-Piracy, Inc.®
                  O42 - Logiciel: Imperial Delay version 1.5.8 - (..) [HKLM][64Bits] – Imperial Delay_is1
                  O42 - Logiciel: Intel Extreme Tuning Utility - (.Intel Corporation.) [HKLM][64Bits] – {7360EE49-7004-4626-A85A-CC48C2D63700} =>.Intel Corporation
                  O42 - Logiciel: Intel(R) C++ Redistributables on IA-32 - (.Intel Corporation.) [HKLM][64Bits] – {7858618B-FA45-4797-988D-4E8B793C3B88} =>.Intel Corporation
                  O42 - Logiciel: Intel(R) C++ Redistributables on Intel(R) 64 - (.Intel Corporation.) [HKLM][64Bits] – {A7D3C4B3-2CA8-46F3-9C34-63205AC018FF} =>.Intel Corporation
                  O42 - Logiciel: Intel(R) Chipset Device Software - (.Intel Corporation.) [HKLM][64Bits] – {5CA7FC9B-8508-4494-B365-6FBCBAEB8E89} =>.Intel Corporation
                  O42 - Logiciel: Intel(R) Chipset Device Software - (.Intel(R) Corporation.) [HKLM][64Bits] – {98f335cd-0a32-4b3f-b74c-ef9480e834f0} =>.Intel Corporation - Software and Firmware Products®
                  O42 - Logiciel: Intel(R) Management Engine Components - (.Intel Corporation.) [HKLM][64Bits] – {65153EA5-8B6E-43B6-857B-C6E4FC25798A} =>.Intel Corporation - Software and Firmware Products®
                  O42 - Logiciel: Intel(R) Network Connections 18.6.110.0 - (.Intel.) [HKLM][64Bits] – {DA107BF8-DDA2-4545-AD1F-BE650B2DE8B0} =>.Intel
                  O42 - Logiciel: Intel(R) Network Connections 18.6.110.0 - (.Intel.) [HKLM][64Bits] – PROSetDX =>.Intel
                  O42 - Logiciel: Intel(R) Processor Graphics - (.Intel Corporation.) [HKLM][64Bits] – {F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA} =>.Intel Corporation - pGFX®
                  O42 - Logiciel: Intel(R) Smart Connect Technology 3.0 x64 - (.Intel.) [HKLM][64Bits] – {DE788AD4-F7CE-4995-ADF8-56174A7B613C} =>.Intel
                  O42 - Logiciel: Intel(R) Technology Access - (.Intel Corporation.) [HKLM][64Bits] – {810dff4d-564d-47da-b8bc-a3729815aab7} =>.Intel(R) Technology Access®
                  O42 - Logiciel: Intel(R) Technology Access - (.Intel Corporation.) [HKLM][64Bits] – {919CE8F2-C283-4FBE-B29F-3BEA088C37EA} =>.Intel Corporation
                  O42 - Logiciel: Intel(R) Technology Access Software Asset Manager - (.Intel Corporation.) [HKLM][64Bits] – {C1C74874-4E6F-49B8-BBCD-D43E277D8D28} =>.Intel Corporation
                  O42 - Logiciel: Intel(R) Update Manager - (.Intel Corporation.) [HKLM][64Bits] – {7224B7CE-196C-4E2A-A1AE-1D7BF259FD36} =>.Intel Corporation
                  O42 - Logiciel: Intel® Trusted Connect Service Client - (.Intel Corporation.) [HKLM][64Bits] – {B5E06417-A4AC-4225-B36E-7E34C91616E7} =>.Intel Corporation
                  O42 - Logiciel: Intel® Watchdog Timer Driver (Intel® WDT) - (.Intel Corporation.) [HKLM][64Bits] – {3FD0C489-0F02-481a-A3E1-9754CD396761} =>.Intel Corporation
                  O42 - Logiciel: ISL - (.NUGEN Audio.) [HKLM][64Bits] – ISL_is1 =>.NuGen Audio
                  O42 - Logiciel: iTunes - (.Apple Inc..) [HKLM][64Bits] – {9D0D2A8B-7E7B-4D88-8D50-24286ED6A5EB} =>.Apple Inc.
                  O42 - Logiciel: IVGI version 1.0.0 - (..) [HKLM][64Bits] – IVGI_is1
                  O42 - Logiciel: Ivideon Server - (.Ivideon.) [HKCU][64Bits] – Ivideon Server
                  O42 - Logiciel: iZotope BreakTweaker - (.iZotope, Inc..) [HKLM][64Bits] – iZotope BreakTweaker_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope BreakTweaker Factory Content - (.iZotope, Inc..) [HKLM][64Bits] – iZotope BreakTweaker Factory Content_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope Insight - (.iZotope, Inc..) [HKLM][64Bits] – iZotope Insight_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope Nectar 2 Production Suite - (.iZotope, Inc..) [HKLM][64Bits] – iZotope Nectar 2 Production Suite_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope Ozone 6 Advanced - (.iZotope, Inc..) [HKLM][64Bits] – iZotope Ozone 6 Advanced_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope Ozone 7 Advanced - (.iZotope, Inc..) [HKLM][64Bits] – iZotope Ozone 7 Advanced 7.00 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope RX 5 - (.iZotope, Inc..) [HKLM][64Bits] – iZotope RX 5_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope Trash 2 - (.iZotope, Inc..) [HKLM][64Bits] – iZotope Trash 2_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope Vinyl - (.iZotope, Inc..) [HKLM][64Bits] – iZotope Vinyl_is1 =>.iZotope, Inc.
                  O42 - Logiciel: iZotope VocalSynth - (.iZotope, Inc..) [HKLM][64Bits] – VocalSynth 1.0 =>.iZotope, Inc.
                  O42 - Logiciel: Jack - (..) [HKLM][64Bits] – Jack
                  O42 - Logiciel: Java 8 Update 121 (64-bit) - (.Oracle Corporation.) [HKLM][64Bits] – {26A24AE4-039D-4CA4-87B4-2F64180121F0} =>.Oracle Corporation
                  O42 - Logiciel: Java Auto Updater - (.Oracle Corporation.) [HKLM][64Bits] – {4A03706F-666A-4037-7777-5F2748764D10} =>.Oracle Corporation
                  O42 - Logiciel: Kazrog LLC Recabinet 3 VST RTAS v3.1.0 - (..) [HKLM][64Bits] – Kazrog LLC Recabinet 3_is1
                  O42 - Logiciel: KD Niche Finder - (.AppBreed Software of InnAnTech Industries Inc..) [HKLM][64Bits] – KD Niche Finder1.0.0.2
                  O42 - Logiciel: KDPublishingPro - (.KDPublishingPro.com.) [HKLM][64Bits] – {067A07C1-7A31-4881-B53D-DF4CBB865112}
                  O42 - Logiciel: KDPublishingPro - (.KDPublishingPro.com.) [HKLM][64Bits] – {215E8D21-F375-4D03-A31F-79CBE44FFB4A}
                  O42 - Logiciel: KDSubmitterPro - (.KDSubmitterPro.com.) [HKLM][64Bits] – {E1817648-6DF6-400F-BD1B-B5D9E9BD745D}
                  O42 - Logiciel: Kindle DRM Removal - (.eBook Converter.) [HKLM][64Bits] – KindleDRMRemoval
                  O42 - Logiciel: Kits Configuration Installer - (.Microsoft.) [HKLM][64Bits] – {E14DDED2-919B-FCCB-84AC-5ABB6D182D46} =>.Microsoft
                  O42 - Logiciel: K-Lite Codec Pack 9.6.0 (64-bit) - (.KLite Inc.) [HKLM][64Bits] – KLiteCodecPack64_is1 =>.KLite Inc
                  O42 - Logiciel: K-Lite Codec Pack 9.6.0 (Full) - (.KLite Inc.) [HKLM][64Bits] – KLiteCodecPack_is1 =>.KLite Inc
                  O42 - Logiciel: Kush Audio Clariphonic v1.0 - (.Kush Audio.) [HKLM][64Bits] – Clariphonic_is1
                  O42 - Logiciel: Lexicon PSP 42 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – Lexicon PSP 42 64bit
                  O42 - Logiciel: Liquid Notes version 1.5.2.1 - (.Re-Compose.) [HKLM][64Bits] – {5AC1D63D-6772-417E-B7B8-1E5F686D9703}_is1
                  O42 - Logiciel: Litecoin - (.Litecoin project.) [HKCU][64Bits] – Litecoin
                  O42 - Logiciel: Litecoin Core (64-bit) - (.Litecoin Core project.) [HKCU][64Bits] – Litecoin Core (64-bit)
                  O42 - Logiciel: Logitech Gaming Software - (.Logitech Inc..) [HKLM][64Bits] – {690285C2-2481-44FB-8402-162EA970A6DD} =>.Logitech Inc.
                  O42 - Logiciel: Logitech Gaming Software 8.91 - (.Logitech Inc..) [HKLM][64Bits] – Logitech Gaming Software =>.Logitech Inc®
                  O42 - Logiciel: Logitech SetPoint 6.61 - (.Logitech.) [HKLM][64Bits] – sp6 =>.Logitech®
                  O42 - Logiciel: Logitech Webcam Software - (.Logitech Inc..) [HKLM][64Bits] – {D40EB009-0499-459c-A8AF-C9C110766215} =>.Logitech®
                  O42 - Logiciel: LoopBe30 - Internal MIDI Ports - (..) [HKLM][64Bits] – LoopBe30
                  O42 - Logiciel: Lurssen Mastering Console version 1.0.0 - (.IK Multimedia.) [HKLM][64Bits] – {9F525466-89DA-4B7B-BD8C-BBFDC4432DFB}_is1 =>.IK Multimedia
                  O42 - Logiciel: LWS Facebook - (.Logitech.) [HKLM][64Bits] – {FF167195-9EE4-46C0-8CD7-FBA3457E88AB} =>.Logitech
                  O42 - Logiciel: LWS Gallery - (.Logitech.) [HKLM][64Bits] – {6F76EC3C-34B1-436E-97FB-48C58D7BEDCD} =>.Logitech
                  O42 - Logiciel: LWS Help_main - (.Logitech.) [HKLM][64Bits] – {1651216E-E7AD-4250-92A1-FB8ED61391C9} =>.Logitech
                  O42 - Logiciel: LWS Launcher - (.Logitech.) [HKLM][64Bits] – {83C8FA3C-F4EA-46C4-8392-D3CE353738D6} =>.Logitech
                  O42 - Logiciel: LWS Motion Detection - (.Logitech.) [HKLM][64Bits] – {71E66D3F-A009-44AB-8784-75E2819BA4BA} =>.Logitech
                  O42 - Logiciel: LWS Pictures And Video - (.Logitech.) [HKLM][64Bits] – {08610298-29AE-445B-B37D-EFBE05802967} =>.Logitech
                  O42 - Logiciel: LWS Twitter - (.Logitech.) [HKLM][64Bits] – {174A3B31-4C43-43DD-866F-73C9DB887B48} =>.Logitech
                  O42 - Logiciel: LWS Webcam Software - (.Logitech.) [HKLM][64Bits] – {8937D274-C281-42E4-8CDB-A0B2DF979189} =>.Logitech
                  O42 - Logiciel: LWS WLM Plugin - (.Logitech.) [HKLM][64Bits] – {9DAEA76B-E50F-4272-A595-0124E826553D} =>.Logitech
                  O42 - Logiciel: LWS YouTube Plugin - (.Logitech.) [HKLM][64Bits] – {21DF0294-6B9D-4741-AB6F-B2ABFBD2387E} =>.Logitech
                  O42 - Logiciel: M30 Reverb - (.TC Electronic.) [HKLM][64Bits] – M30 Reverb =>.TC Electronic
                  O42 - Logiciel: MacDrive 9 Pro - (.Mediafour Corporation.) [HKLM][64Bits] – {C1521748-8700-4CA0-92F1-46CE26DEDC7D} =>.Mediafour Corporation
                  O42 - Logiciel: Magic AB VST-x64 1.2.2 - (.Sample Magic.) [HKLM][64Bits] – {6893EEE5-B48F-47a9-81DC-CD54E7767B35}
                  O42 - Logiciel: Malwarebytes version 3.0.6.1469 - (.Malwarebytes.) [HKLM][64Bits] – {35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1 =>.Malwarebytes Corporation®
                  O42 - Logiciel: Manic Compressor version 1.0.3 - (..) [HKLM][64Bits] – Manic Compressor_is1
                  O42 - Logiciel: Market Samurai - (.Alliance Software Pty Ltd.) [HKLM][64Bits] – {C9D3864A-5566-C8E4-7289-381284A3E078} =>.Alliance Software Pty Ltd
                  O42 - Logiciel: Market Samurai - (.Alliance Software Pty Ltd.) [HKLM][64Bits] – MarketSamurai.6E37012E1CBD7F47B14488FCC715944F3EBD CEDC.1 =>.Alliance Software Pty Ltd
                  O42 - Logiciel: marvell 91xx driver - (.Marvell.) [HKLM][64Bits] – MagniDriver =>.Marvell
                  O42 - Logiciel: Massey VST Demos (Remove only) - (..) [HKLM][64Bits] – Massey VST Demos
                  O42 - Logiciel: MathewLane DrMS Spatial Processor VST RTAS v3.2 - (..) [HKLM][64Bits] – MathewLane DrMS Spatial Processor_is1
                  O42 - Logiciel: M-Audio Oxygen Driver 1.2.1 (x64) - (.M-Audio.) [HKLM][64Bits] – {6F0B8408-835B-4A55-A429-EB899AD68467} =>.M-Audio
                  O42 - Logiciel: Maxthon Cloud Browser - (.Maxthon International Limited.) [HKLM][64Bits] – Maxthon3 =>.Maxthon (Asia) Limited.®
                  O42 - Logiciel: McGill English Dictionary of Rhyme & Verse Perfect 2.0 - (.Bryant McGill / McGill International.) [HKLM][64Bits] – McGill English Dictionary of Rhyme with VersePer~286A7AE6_is1
                  O42 - Logiciel: MeldaProduction Audio Plugins 10 - (.MeldaProduction.) [HKLM][64Bits] – MeldaProduction Audio Plugins 10 =>.MeldaProduction
                  O42 - Logiciel: MeldaProduction MTotalBundle64 8 - (.MeldaProduction.) [HKLM][64Bits] – MeldaProduction MTotalBundle64 8 =>.MeldaProduction
                  O42 - Logiciel: Melodyne 3.2 - (.Celemony Software GmbH.) [HKLM][64Bits] – {2E337869-756A-4E46-A936-0E67FE043A5E} =>.Celemony Software GmbH
                  O42 - Logiciel: Melodyne 3.2 - (.Celemony Software GmbH.) [HKLM][64Bits] – {A1F143D1-1F0D-44FB-A44B-71D4367D16DE} =>.Celemony Software GmbH
                  O42 - Logiciel: MetaTrader 5 - (.MetaQuotes Software Corp..) [HKLM][64Bits] – MetaTrader 5 =>.MetaQuotes Software Corp.®
                  O42 - Logiciel: Mic Mod EFX VST - (.Antares Audio Technologies.) [HKLM][64Bits] – {A77728D4-DF6E-42A9-926C-5164BBF1EA72} =>.Antares Audio Technologies
                  O42 - Logiciel: Microsoft Access MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-0015-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Access Setup Metadata MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-0117-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft DCF MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-0090-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Excel MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-0016-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Groove MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-00BA-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft InfoPath MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-0044-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Lync MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-012B-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft OneDrive - (.Microsoft Corporation.) [HKCU][64Bits] – OneDriveSetup.exe =>.Microsoft Corporation®
                  O42 - Logiciel: Microsoft OneNote MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-00A1-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Outlook MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-001A-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft PowerPoint MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-0018-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Publisher MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-0019-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Web Platform Installer 4.6 - (.Microsoft Corporation.) [HKLM][64Bits] – {16C7D2AD-20CA-491E-80BC-8607A9AACED9} =>.Microsoft Corporation
                  O42 - Logiciel: Microsoft Word MUI (English) 2013 - (.Microsoft Corporation.) [HKLM][64Bits] – {90150000-001B-0409-1000-0000000FF1CE} =>.Microsoft Corporation
                  O42 - Logiciel: MJUC version 1.0.1 - (..) [HKLM][64Bits] – MJUC_is1
                  O42 - Logiciel: MJUCjr version 1.0.0 - (..) [HKLM][64Bits] – MJUCjr_is1
                  O42 - Logiciel: Mobile Hotspot Admin - (.ZTE Corporation.) [HKLM][64Bits] – {AEFF9E60-3E93-41EE-9895-311F7D1C5FFD} =>.ZTE CORPORATION®
                  O42 - Logiciel: Monofilter v4.0 - (.NUGEN Audio.) [HKLM][64Bits] – Monofilter4_is1 =>.NuGen Audio
                  O42 - Logiciel: Mozilla Firefox 51.0.1 (x86 en-US) - (.Mozilla.) [HKLM][64Bits] – Mozilla Firefox 51.0.1 (x86 en-US) =>.Mozilla Corporation®
                  O42 - Logiciel: Mozilla Maintenance Service - (.Mozilla.) [HKLM][64Bits] – MozillaMaintenanceService =>.Mozilla
                  O42 - Logiciel: Mp3tag v2.73 - (.Florian Heidenreich.) [HKLM][64Bits] – Mp3tag =>.Florian Heidenreich
                  O42 - Logiciel: MusicBrainz Picard - (.MusicBrainz.) [HKLM][64Bits] – MusicBrainz Picard =>.MusicBrainz
                  O42 - Logiciel: Nalpeiron Service Update to 6.3.9.2 - (.Nalpeiron.) [HKLM][64Bits] – {251D3D16-D48D-40E3-9B35-243274D64B78} =>.Nalpeiron
                  O42 - Logiciel: Native Instruments Abbey Road 50s Drummer - (.Native Instruments.) [HKLM][64Bits] – {cb8b5623-806d-4412-828a-9a47fe4411ae} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Abbey Road 50s Drummer - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Abbey Road 50s Drummer =>.Native Instruments
                  O42 - Logiciel: Native Instruments Abbey Road 60s Drums - (.Native Instruments.) [HKLM][64Bits] – {60BB45B2-E8E4-41C5-B69F-C6DC5D991DF5} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Abbey Road 60s Drums - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Abbey Road 60s Drums =>.Native Instruments
                  O42 - Logiciel: Native Instruments Absynth 5 - (.Native Instruments.) [HKLM][64Bits] – {371B17C3-9624-4583-A497-DF980313D851} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Alicias Keys 1.2 - (.Native Instruments.) [HKLM][64Bits] – {5E9CC0AB-E0E0-4138-A3E4-7ADE83AC5C7F} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Alicias Keys 1.2 - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Alicias Keys 1.2 =>.NATIVE INSTRUMENTS GmbH®
                  O42 - Logiciel: Native Instruments Battery 4 - (.Native Instruments.) [HKLM][64Bits] – {BED5CC32-11B2-4EF7-9C9C-8C0160D0C465} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Battery 4 - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Battery 4 =>.Native Instruments
                  O42 - Logiciel: Native Instruments Berlin Concert Grand - (.Native Instruments.) [HKLM][64Bits] – {36ccb7d4-42c7-473e-b293-72e41a8ec766} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Controller Editor - (.Native Instruments.) [HKLM][64Bits] – {0886900B-B2F3-452C-B580-60F1253F7F80} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Damage - (.Native Instruments.) [HKLM][64Bits] – {83548C26-B785-48DD-BCCF-2673CC0D992D} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Damage - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Damage =>.NATIVE INSTRUMENTS GmbH®
                  O42 - Logiciel: Native Instruments Elektrik Piano 1.5 - (..) [HKLM][64Bits] – Native Instruments Elektrik Piano 1.5
                  O42 - Logiciel: Native Instruments Enhanced EQ - (.Native Instruments.) [HKLM][64Bits] – {FFABEF59-581B-482C-A51D-421D48AA69AE} =>.Native Instruments
                  O42 - Logiciel: Native Instruments FM8 - (.Native Instruments.) [HKLM][64Bits] – {B2552FA6-86E3-410D-84AD-265C2242D410} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Guitar Rig 5 - (.Native Instruments.) [HKLM][64Bits] – {01D57CF6-B5BC-4D03-AFF5-7960CFBD05A9} =>.Native Instruments
                  O42 - Logiciel: Native Instruments India - (.Native Instruments.) [HKLM][64Bits] – {23f245e8-01e7-4a12-9102-c32675486857} =>.Native Instruments
                  O42 - Logiciel: Native Instruments India - (.Native Instruments.) [HKLM][64Bits] – Native Instruments India =>.Native Instruments
                  O42 - Logiciel: Native Instruments Kontakt 5 - (.Native Instruments.) [HKLM][64Bits] – {3cede7e3-b10d-4c72-a6cb-fe5217399507} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Kontakt 5 - (.Native Instruments.) [HKLM][64Bits] – {5552453B-BB76-45E3-973D-F95E458ED780} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Kontakt 5 - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Kontakt 5 =>.Native Instruments
                  O42 - Logiciel: Native Instruments Massive - (.Native Instruments.) [HKLM][64Bits] – {491DF203-7B61-4F0E-BDCB-A1218C4DAFE9} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Passive EQ - (.Native Instruments.) [HKLM][64Bits] – {280867A7-5185-4379-AE9E-5ADAB1211347} =>.Native Instruments
                  O42 - Logiciel: Native Instruments RC 24 - (.Native Instruments.) [HKLM][64Bits] – {03DC1A7A-3F8D-40C1-ADD8-181BBB49F166} =>.Native Instruments
                  O42 - Logiciel: Native Instruments RC 48 - (.Native Instruments.) [HKLM][64Bits] – {16C964BA-7E2D-49EC-96D7-3A1497751660} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Reaktor 5 - (.Native Instruments.) [HKLM][64Bits] – {E9EA5F38-6299-45A1-9D23-F21729A19357} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Retro Machines Mk2 - (.Native Instruments.) [HKLM][64Bits] – {86F4B370-079C-4EF9-B727-452B85CFA415} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Service Center - (.Native Instruments.) [HKLM][64Bits] – {0B8565BA-BAD5-4732-B122-5FD78EFC50A9} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Session Horns Pro - (.Native Instruments.) [HKLM][64Bits] – {0c6c1809-ad23-4103-904a-180217ecccc0} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Session Horns Pro - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Session Horns Pro =>.Native Instruments
                  O42 - Logiciel: Native Instruments Solid Bus Comp FX - (.Native Instruments.) [HKLM][64Bits] – {CF14C576-C523-4754-A46C-F6D16EDE8A0A} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Solid Dynamics FX - (.Native Instruments.) [HKLM][64Bits] – {AF382DDE-EBE2-4AD5-BA1E-4A69450D6C5B} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Symphony Series Brass Solo - (.Native Instruments.) [HKLM][64Bits] – {c9175fb5-5cd6-4126-987d-da7a74017075} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Symphony Series Brass Solo - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Symphony Series Brass Solo =>.Native Instruments
                  O42 - Logiciel: Native Instruments Symphony Series String Ensemble - (.Native Instruments.) [HKLM][64Bits] – {e2efa5ab-8acf-47d8-bab1-7231add7bec8} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Symphony Series String Ensemble - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Symphony Series String Ensemble =>.Native Instruments
                  O42 - Logiciel: Native Instruments Symphony Series Woodwind Solo - (.Native Instruments.) [HKLM][64Bits] – {41fd9a14-8a7a-4ca4-b2a6-b4eaa66cc9eb} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Symphony Series Woodwind Solo - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Symphony Series Woodwind Solo =>.Native Instruments
                  O42 - Logiciel: Native Instruments The Finger R2 - (.Native Instruments.) [HKLM][64Bits] – {5D03CB59-6F91-4097-922C-9DCA057D2A76} =>.Native Instruments
                  O42 - Logiciel: Native Instruments The Giant - (.Native Instruments.) [HKLM][64Bits] – {2bfe5e99-6caa-4c5d-86d0-75d97c14d1dc} =>.Native Instruments
                  O42 - Logiciel: Native Instruments The Giant - (.Native Instruments.) [HKLM][64Bits] – Native Instruments The Giant =>.Native Instruments
                  O42 - Logiciel: Native Instruments The Grandeur - (.Native Instruments.) [HKLM][64Bits] – {b3cc56f9-a86c-44b1-a1de-3a6796844c0f} =>.Native Instruments
                  O42 - Logiciel: Native Instruments The Grandeur - (.Native Instruments.) [HKLM][64Bits] – Native Instruments The Grandeur =>.Native Instruments
                  O42 - Logiciel: Native Instruments The Mouth - (.Native Instruments.) [HKLM][64Bits] – {434CC4CB-0183-4CDE-BE7F-00230BE26494} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Transient Master FX - (.Native Instruments.) [HKLM][64Bits] – {481F95A7-229D-4116-82EB-4760F320907A} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Upright Piano - (.Native Instruments.) [HKLM][64Bits] – {d8650fdb-9422-4a07-9f57-585c06d9d760} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Upright Piano - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Upright Piano =>.NATIVE INSTRUMENTS GmbH®
                  O42 - Logiciel: Native Instruments Vari Comp - (.Native Instruments.) [HKLM][64Bits] – {1CB29E6B-BF4E-4343-A94D-ABCF8B2BC7DF} =>.Native Instruments
                  O42 - Logiciel: Native Instruments VC 160 FX - (.Native Instruments.) [HKLM][64Bits] – {A11C105B-0C54-47CB-A7FE-3B9A2555B826} =>.Native Instruments
                  O42 - Logiciel: Native Instruments VC 2A FX - (.Native Instruments.) [HKLM][64Bits] – {FB1B9DFE-1E22-4CAD-A101-D7DB9C12A7A7} =>.Native Instruments
                  O42 - Logiciel: Native Instruments VC 76 FX - (.Native Instruments.) [HKLM][64Bits] – {C7CD74F5-4A28-40D3-8CE0-28AA0695C641} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Vintage Organs - (.Native Instruments.) [HKLM][64Bits] – {14C1DD2C-D54E-464A-9588-C109E3E39EEF} =>.Native Instruments
                  O42 - Logiciel: Native Instruments Vintage Organs - (.Native Instruments.) [HKLM][64Bits] – Native Instruments Vintage Organs =>.NATIVE INSTRUMENTS GmbH®
                  O42 - Logiciel: nebula3 CM - (.Acusticaaudio.) [HKLM][64Bits] – {5354D5F2-342D-43DD-A361-B65BF7AABE1D}
                  O42 - Logiciel: Nero 12 - (.Nero AG.) [HKLM][64Bits] – {560FC78C-A4B2-461D-9B47-820C1EEF87B8} =>.Nero AG
                  O42 - Logiciel: Nero Audio Pack 1 - (.Nero AG.) [HKLM][64Bits] – {A7A0BF2E-31CC-49E3-9913-52C503EB969D} =>.Nero AG
                  O42 - Logiciel: Nero BackItUp - (.Nero AG.) [HKLM][64Bits] – {0071820F-09B0-4998-8320-F89629DCBC99} =>.Nero AG
                  O42 - Logiciel: Nero BackItUp Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {EF0D1292-8FC1-41BE-9740-DBC134F66415} =>.Nero AG
                  O42 - Logiciel: Nero Blu-ray Player - (.Nero AG.) [HKLM][64Bits] – {A2FE691E-3F8E-4E30-AA7D-FF17AC77EA87} =>.Nero AG
                  O42 - Logiciel: Nero Blu-ray Player Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {5B79E730-D897-4B8F-A1AD-7BB2D1F22B96} =>.Nero AG
                  O42 - Logiciel: Nero Burning ROM - (.Nero AG.) [HKLM][64Bits] – {5963F4B4-D138-47CD-ADEF-470E87E185BD} =>.Nero AG
                  O42 - Logiciel: Nero Burning ROM Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {2890E324-6F3B-4975-8B95-E7D6D80E0226} =>.Nero AG
                  O42 - Logiciel: Nero ControlCenter - (.Nero AG.) [HKLM][64Bits] – {ABC88553-8770-4B97-B43E-5A90647A5B63} =>.Nero AG
                  O42 - Logiciel: Nero ControlCenter Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {C994C746-C6D0-4EBA-B09E-DF7B18381B69} =>.Nero AG
                  O42 - Logiciel: Nero Core Components - (.Nero AG.) [HKLM][64Bits] – {BEBEE34D-84A2-4EDD-8BEA-96CC54371263} =>.Nero AG
                  O42 - Logiciel: Nero Disc Menus Basic - (.Nero AG.) [HKLM][64Bits] – {E17BCB76-9924-4BD5-B6D6-50D3407B4E74} =>.Nero AG
                  O42 - Logiciel: Nero Effects Basic - (.Nero AG.) [HKLM][64Bits] – {29F67D84-3A70-456E-806A-52301B02070B} =>.Nero AG
                  O42 - Logiciel: Nero Express - (.Nero AG.) [HKLM][64Bits] – {848A7C68-0ADC-4193-8A89-2CEA78E56A0C} =>.Nero AG
                  O42 - Logiciel: Nero Express Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {0708FF30-78C0-47B0-81F0-C84604DC769C} =>.Nero AG
                  O42 - Logiciel: Nero Kwik Media - (.Nero AG.) [HKLM][64Bits] – {052A1E34-A54B-458C-A4E3-24C3E054754A} =>.Nero AG
                  O42 - Logiciel: Nero Kwik Media Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {1F16820E-D0E7-4636-939E-45CBFEFB06E1} =>.Nero AG
                  O42 - Logiciel: Nero Kwik Themes Basic - (.Nero AG.) [HKLM][64Bits] – {1B6F5E51-575E-4693-BCA2-7543570D076D} =>.Nero AG
                  O42 - Logiciel: Nero Launcher - (.Nero AG.) [HKLM][64Bits] – {0E4630AF-0AB7-440E-A978-1A78FC4F43B9} =>.Nero AG
                  O42 - Logiciel: Nero PiP Effects Basic - (.Nero AG.) [HKLM][64Bits] – {ACE49D50-19CD-44A6-B192-46F985283B26} =>.Nero AG
                  O42 - Logiciel: Nero Recode - (.Nero AG.) [HKLM][64Bits] – {1943C3BD-4462-4612-92C3-D36DD917C447} =>.Nero AG
                  O42 - Logiciel: Nero Recode Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {86847081-B387-4F49-AED1-C9B0A090D66C} =>.Nero AG
                  O42 - Logiciel: Nero RescueAgent - (.Nero AG.) [HKLM][64Bits] – {B953732D-B623-4E84-B369-CFFF7B1AE06F} =>.Nero AG
                  O42 - Logiciel: Nero RescueAgent Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {0B311221-05A5-4766-8D03-7A6446794156} =>.Nero AG
                  O42 - Logiciel: Nero SharedVideoCodecs - (.Nero AG.) [HKLM][64Bits] – {2432E589-6256-4513-B0BF-EFA8E325D5F0} =>.Nero AG
                  O42 - Logiciel: Nero Update - (.Nero AG.) [HKLM][64Bits] – {65BB0407-4CC8-4DC7-952E-3EEFDF05602A} =>.Nero AG
                  O42 - Logiciel: Nero Video - (.Nero AG.) [HKLM][64Bits] – {83FCCFCD-46E3-43FB-A397-78BFD5A8980A} =>.Nero AG
                  O42 - Logiciel: Nero Video Help (CHM) - (.Nero AG.) [HKLM][64Bits] – {B128179D-A5E1-43AC-9422-12A109ECD2A0} =>.Nero AG
                  O42 - Logiciel: neroxml - (.Nero AG.) [HKLM][64Bits] – {56C049BE-79E9-4502-BEA7-9754A3E60F9B} =>.Nero AG
                  O42 - Logiciel: Netflix in Windows Media Center - (.Microsoft Corporation.) [HKLM][64Bits] – {0CA72D12-F6C6-4D43-A2A0-41F5AA17E2B6} =>.Microsoft Corporation
                  O42 - Logiciel: Neutron Advanced - (.iZotope, Inc..) [HKLM][64Bits] – Neutron Advanced 1.0 =>.iZotope, Inc.
                  O42 - Logiciel: NF VST 64-bit Installer - (.Nomad Factory.) [HKLM][64Bits] – NF VST 64-bit Installer1.0.3 =>.Nomad Factory
                  O42 - Logiciel: Nitro Pro 8 - (.Nitro.) [HKLM][64Bits] – {47B42E7A-57E9-407B-8DBB-017B86D7B13F} =>.Nitro
                  O42 - Logiciel: NVIDIA 3D Vision Controller Driver 369.04 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA 3D Vision Driver 378.49 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Backend - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvBackend =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Container - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Control Panel 378.49 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.ControlPanel =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Display Container - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NVDisplayContainer =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Display Container LS - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NVDisplayContainerLS =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA GeForce Experience 3.3.0.95 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Graphics Driver 378.49 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA HD Audio Driver 1.3.34.21 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Install Application - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_installer =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA LocalSystem Container - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.LocalSystem =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Message Bus for NvContainer - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.MessageBus =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA NetworkService Container - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.NetworkService =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA PhysX System Software 9.16.0318 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Session Container - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.Session =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA ShadowPlay 3.3.0.95 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShadowPlay =>.NVIDIA Corporation
                  O42 - Logiciel: Nvidia Share - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_OSC =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Stereoscopic 3D Driver - (.NVIDIA Corporation.) [HKLM][64Bits] – NVIDIAStereo =>.NVIDIA Corporation®
                  O42 - Logiciel: NVIDIA Telemetry Container - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetryContainer =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Update 23.23.0.0 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Update =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Update Core - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Update.Core =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA User Container - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.User =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Virtual Audio 3.51.2 - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_VirtualAudio.Driver =>.NVIDIA Corporation
                  O42 - Logiciel: NVIDIA Watchdog Plugin for NvContainer - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvPlugin.Watchdog =>.NVIDIA Corporation
                  O42 - Logiciel: NvNodejs - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs =>.NVIDIA Corporation
                  O42 - Logiciel: NvTelemetry - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry =>.NVIDIA Corporation
                  O42 - Logiciel: NvvHci - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}NvvHci =>.NVIDIA Corporation
                  O42 - Logiciel: Output Movement - (.Output.) [HKLM][64Bits] – Output Movement
                  O42 - Logiciel: PACE License Support Win64 - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – {72ad9d51-0903-4fe7-af5d-33b3185fa6e9} =>.PACE Anti-Piracy, Inc.
                  O42 - Logiciel: PACE License Support Win64 - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – InstallShield
                  O42 - Logiciel: PatchCleaner - (.HomeDev.) [HKLM][64Bits] – {727DA176-50BB-452C-8DB5-96EE0A573ED4} =>.HomeDev
                  O42 - Logiciel: PCM Native Reverb Bundle - (.Lexicon.) [HKLM][64Bits] – {294B9A61-B4D6-4EDB-91BF-354619C43FE2} =>.Lexicon
                  O42 - Logiciel: PCM Native Reverb Bundle - (.Lexicon.) [HKLM][64Bits] – PCM Native Reverb Bundle =>.Lexicon
                  O42 - Logiciel: PDF Settings CS5 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {A78FE97A-C0C8-49CE-89D0-EDD524A17392} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Photoshop Camera Raw - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {CC75AB5C-2110-4A7F-AF52-708680D22FE8} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Pi version 1.0.11 - (.Sound Radix.) [HKLM][64Bits] – {CFA5721A-9AA1-4D77-BBC2-78E40216FDAB}_is1
                  O42 - Logiciel: PITCHMAP VST-x64 1.6.1 - (.Zynaptiq.) [HKLM][64Bits] – {F9754DD6-985B-4e93-A96B-837EE5415F61}
                  O42 - Logiciel: Pixel Bender Toolkit - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {43509E18-076E-40FE-AF38-CA5ED400A5A9} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Plogue chipsounds v1.848 - (.Plogue.) [HKLM][64Bits] – __ARIA_1009___is1
                  O42 - Logiciel: Plogue chipspeech v1.016 - (.Plogue.) [HKLM][64Bits] – __ARIA_1017___is1
                  O42 - Logiciel: Prerequisite installer - (.Nero AG.) [HKLM][64Bits] – {3AAB08A3-F129-4BD5-B409-AE674F93759D} =>.Nero AG
                  O42 - Logiciel: Primo Ramdisk Server Edition 5.6.0 - (.Romex Software.) [HKLM][64Bits] – {94B97E1E-9B67-4012-A126-6319E211A298}_is1 =>.Romex Software
                  O42 - Logiciel: Process Lasso - (.Bitsum.) [HKLM][64Bits] – ProcessLasso =>.Bitsum
                  O42 - Logiciel: PSP 2Meters 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP 2Meters 64bit
                  O42 - Logiciel: PSP 608 MultiDelay 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP 608 MultiDelay 64bit
                  O42 - Logiciel: PSP 85 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP 85 64bit
                  O42 - Logiciel: PSP BussPressor 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP BussPressor 64bit
                  O42 - Logiciel: PSP Echo 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP Echo 64bit
                  O42 - Logiciel: PSP MasterComp 1.7.1 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP MasterComp 1.7.1 64bit
                  O42 - Logiciel: PSP McQ 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP McQ 64bit
                  O42 - Logiciel: PSP Neon 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP Neon 64bit
                  O42 - Logiciel: PSP NobleQ 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP NobleQ 64bit
                  O42 - Logiciel: PSP oldTimer 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP oldTimer 64bit
                  O42 - Logiciel: PSP PianoVerb2 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP PianoVerb2 64bit
                  O42 - Logiciel: PSP SpringBox 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP SpringBox 64bit
                  O42 - Logiciel: PSP Xenon 1.3.0 64bit - (.PSPaudioware.com.) [HKLM][64Bits] – PSP Xenon 1.3.0 64bit
                  O42 - Logiciel: PunkBuster Services - (.Even Balance, Inc..) [HKLM][64Bits] – PunkBusterSvc =>.Even Balance, Inc.
                  O42 - Logiciel: Python 3.3.0 (64-bit) - (.Python Software Foundation.) [HKLM][64Bits] – {290329c4-a276-3aec-b633-9f5a39d8dd96} =>.Python Software Foundation
                  O42 - Logiciel: QuickTime - (.Apple Inc..) [HKLM][64Bits] – {AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A} =>Riskware.QuickTime
                  O42 - Logiciel: Rank Tracker - (..) [HKLM][64Bits] – seopowersuite
                  O42 - Logiciel: Rapid SEO Tool 1.3 - (.Karlis Blumentals.) [HKLM][64Bits] – Rapid SEO Tool_is1 =>.Karlis Blumentals
                  O42 - Logiciel: Realtek Ethernet Controller Driver - (.Realtek.) [HKLM][64Bits] – {8833FFB6-5B0C-4764-81AA-06DFEED9A476} =>.Realtek Semiconductor Corp®
                  O42 - Logiciel: Realtek High Definition Audio Driver - (.Realtek Semiconductor Corp..) [HKLM][64Bits] – {F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC} =>.Realtek Semiconductor Corp.®
                  O42 - Logiciel: REAPER (x64) - (.Cockos Incorporated.) [HKLM][64Bits] – REAPER =>.Cockos Incorporated
                  O42 - Logiciel: Reference 3 VST plugin (32-bit) 3 - (.Sonarworks.) [HKLM][64Bits] – {7627424F-7CB0-471B-AB55-A39F6995C4F0}
                  O42 - Logiciel: Reference 3 VST plugin (64-bit) 3 - (.Sonarworks.) [HKLM][64Bits] – {510D6D02-214D-4264-A4FD-96DBD82ACFED}
                  O42 - Logiciel: reFX Nexus VSTi RTAS v2.2.0 - (..) [HKLM][64Bits] – reFX Nexus_is1
                  O42 - Logiciel: Relab LX480 Lite VST v1.0 - (..) [HKLM][64Bits] – Relab LX480 Lite_is1
                  O42 - Logiciel: Resource Hacker Version 3.6.0 - (..) [HKLM][64Bits] – ResourceHacker_is1
                  O42 - Logiciel: Revo Uninstaller 2.0.2 - (.VS Revo Group, Ltd..) [HKLM][64Bits] – {A28DBDA2-3CC7-4ADC-8BFE-66D7743C6C97}_is1 =>.VS Revo Group, Ltd.
                  O42 - Logiciel: Rhyme Genie - (.Idolumic.) [HKLM][64Bits] – {E48A1AFC-5649-4CC2-B8E1-BD92022C4CC4}
                  O42 - Logiciel: RogueKiller version 12.9.7.0 - (.Adlice Software.) [HKLM][64Bits] – 8B3D7924-ED89-486B-8322-E8594065D5CB_is1 =>.Adlice®
                  O42 - Logiciel: Room EQ Wizard V5 - (.John Mulcahy.) [HKLM][64Bits] – RoomEQWizardV5 {60F8408A760A353500199525E243FF27} =>.John Mulcahy
                  O42 - Logiciel: Sasquatch version 1.2.0 - (..) [HKLM][64Bits] – Sasquatch_is1
                  O42 - Logiciel: SEQ1 Master - (.NuGen Audio.) [HKLM][64Bits] – SEQ1 Master_is1 =>.NuGen Audio
                  O42 - Logiciel: SEQ2 Master - (.NuGen Audio.) [HKLM][64Bits] – SEQ2 Master_is1 =>.NuGen Audio
                  O42 - Logiciel: SEQ-S - (.NUGEN Audio.) [HKLM][64Bits] – SEQ-S_is1 =>.NuGen Audio
                  O42 - Logiciel: S-GEAR 2 - (.Scuffham Amps.) [HKLM][64Bits] – S-GEAR 2 CE_is1
                  O42 - Logiciel: SHIELD Streaming - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv =>.NVIDIA Corporation
                  O42 - Logiciel: SHIELD Wireless Controller Driver - (.NVIDIA Corporation.) [HKLM][64Bits] – {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController =>.NVIDIA Corporation
                  O42 - Logiciel: Sid Meier’s Civilization V - (.2K Games, Inc..) [HKLM][64Bits] – Steam App 8930 =>.Valve®
                  O42 - Logiciel: SideWidener version 1.0.2 - (..) [HKLM][64Bits] – SideWidener_is1
                  O42 - Logiciel: Skype™ 7.32 - (.Skype Technologies S.A..) [HKLM][64Bits] – {FC965A47-4839-40CA-B618-18F486F042C6} =>.Skype Technologies S.A.
                  O42 - Logiciel: Slack - (.Slack Technologies.) [HKCU][64Bits] – slack =>.Slack Technologies Inc.®
                  O42 - Logiciel: Slate Digital TRIGGER - (.Slate Digital.) [HKLM][64Bits] – SlateDigitalTrigger =>.Slate Digital
                  O42 - Logiciel: Snagit 11 - (.TechSmith Corporation.) [HKLM][64Bits] – {A56C6348-59D0-433B-A48A-75914858664E} =>.TechSmith Corporation
                  O42 - Logiciel: Sniper Elite - (.Rebellion Developments.) [HKLM][64Bits] – Steam App 3700 =>.Valve®
                  O42 - Logiciel: Sniper Elite V2 - (..) [HKLM][64Bits] – Steam App 63380 =>.Valve®
                  O42 - Logiciel: SoftEther VPN Client - (.SoftEther VPN Project.) [HKLM][64Bits] – softether_sevpnclient =>.SoftEther K.K.®
                  O42 - Logiciel: Softube Acoustic Feedback VST RTAS v1.0.7 - (..) [HKLM][64Bits] – Softube Acoustic Feedback VST RTAS_is1
                  O42 - Logiciel: Softube Bass Amp Room VST RTAS v1.0.2 - (..) [HKLM][64Bits] – Softube Bass Amp Room VST RTAS_is1
                  O42 - Logiciel: Softube FET Compressor VST RTAS v1.0.3 - (..) [HKLM][64Bits] – Softube FET Compressor VST RTAS_is1
                  O42 - Logiciel: Softube Metal Amp Room VST RTAS v1.1.5 - (..) [HKLM][64Bits] – Softube Metal Amp Room VST RTAS_is1
                  O42 - Logiciel: Softube Passive-Active Pack VST RTAS v1.0.2 - (..) [HKLM][64Bits] – Softube Passive-Active Pack VST RTAS_is1
                  O42 - Logiciel: Softube Spring Reverb VST RTAS v1.0.4 - (..) [HKLM][64Bits] – Softube Spring Reverb VST RTAS_is1
                  O42 - Logiciel: Softube Trident A-Range VST RTAS v1.0.2 - (..) [HKLM][64Bits] – Softube Trident A-Range VST RTAS_is1
                  O42 - Logiciel: Softube Tube Delay VST RTAS v1.0.5 - (..) [HKLM][64Bits] – Softube Tube Delay VST RTAS_is1
                  O42 - Logiciel: Softube Tube-Tech CL 1B VST RTAS v1.0.3 - (..) [HKLM][64Bits] – Softube Tube-Tech CL 1B VST RTAS_is1
                  O42 - Logiciel: Softube Vintage Amp Room VST RTAS v1.0.8 - (..) [HKLM][64Bits] – Softube Vintage Amp Room VST RTAS_is1
                  O42 - Logiciel: Sonalksis Plug-in Manager 3.00 - (.Sonalksis Ltd.) [HKLM][64Bits] – {7A600039-FED6-4C81-AA6E-F151F7FA7EE7}_is1
                  O42 - Logiciel: Sonarworks HD reference 2.2 - (.Sonarworks.) [HKLM][64Bits] – {F76463A9-42A2-47D5-B7D4-8838523E64E4}
                  O42 - Logiciel: Sonarworks HD Reference VST plugin (64-bit) 2.2 - (.Sonarworks.) [HKLM][64Bits] – {3F08FE5F-23E4-423B-A929-8247E4D5193A}
                  O42 - Logiciel: Sonarworks Reference 3 - (.Sonarworks.) [HKLM][64Bits] – {E8A1DAEE-C491-4833-8D3B-AA8F3E0098AE}
                  O42 - Logiciel: SONiVOX Harmonica - (.SONiVOX.) [HKLM][64Bits] – SONiVOX Harmonica =>.SONiVOX
                  O42 - Logiciel: SONiVOX VocalizerPro - (..) [HKLM][64Bits] – SONiVOX VocalizerPro_is1
                  O42 - Logiciel: Sonnox Fraunhofer Codec Toolbox v1.0.0 - (.Sonnox Ltd, Oxford, UK.) [HKLM][64Bits] – Sonnox Fraunhofer Codec Toolbox v1.0.0_is1
                  O42 - Logiciel: Sonnox Oxford Inflator Native VST v1.5.1 - (.Team AiR 2007.) [HKLM][64Bits] – Sonnox Oxford Inflator Native VST_is1 =>.Team AiR 2007
                  O42 - Logiciel: Sonnox Oxford Limiter Native VST v1.1.1 - (.Team AiR 2007.) [HKLM][64Bits] – Sonnox Oxford Limiter Native VST_is1 =>.Team AiR 2007
                  O42 - Logiciel: Sonnox Oxford R3 Dynamics Native VST v1.3.1 - (.Team AiR 2007.) [HKLM][64Bits] – Sonnox Oxford R3 Dynamics Native VST_is1 =>.Team AiR 2007
                  O42 - Logiciel: Sonnox Oxford R3 EQ Native VST v1.6.1 - (.Team AiR 2007.) [HKLM][64Bits] – Sonnox Oxford R3 EQ Native VST_is1 =>.Team AiR 2007
                  O42 - Logiciel: Sonnox Oxford Reverb Native VST v1.0 - (.Team AiR 2007.) [HKLM][64Bits] – Sonnox Oxford Reverb Native VST_is1 =>.Team AiR 2007
                  O42 - Logiciel: Sonnox Oxford TransMod Native VST v1.3.1 - (.Team AiR 2007.) [HKLM][64Bits] – Sonnox Oxford TransMod Native VST_is1 =>.Team AiR 2007
                  O42 - Logiciel: Sonoris Mastering Compressor - (.Sonoris Audio Engineering.) [HKLM][64Bits] – Sonoris Mastering Compressor
                  O42 - Logiciel: Sound Blaster X-Fi MB 2 - (.Creative Technology Limited.) [HKLM][64Bits] – {44DA67A9-C906-4316-94CB-61B036BBDCE5} =>.Creative Technology Limited
                  O42 - Logiciel: SoundToys Native Effects VST RTAS v3.1.2 - (..) [HKLM][64Bits] – SoundToys Native Effects VST RTAS_is1
                  O42 - Logiciel: SpeedFan (remove only) - (.Almico Software.) [HKLM][64Bits] – SpeedFan =>.Almico Software
                  O42 - Logiciel: Spotify - (.Spotify AB.) [HKCU][64Bits] – Spotify =>.Spotify AB®
                  O42 - Logiciel: SSD Sampler - (.Yellow Matter Entertainment.) [HKLM][64Bits] – SSD4
                  O42 - Logiciel: SSD Utility - (.Toshiba Corporation.) [HKLM][64Bits] – {3449D0CA-9D99-472B-B36C-A32A58AF18F5} =>.Toshiba Corporation
                  O42 - Logiciel: SSDlife Pro - (.BinarySense Inc..) [HKLM][64Bits] – {3D843494-7DC4-47C9-9E95-3543F0A4E7BC} =>.BinarySense Inc.
                  O42 - Logiciel: SSL Duende Native (32-bit) v3.6.6 - (.Team V.R.) [HKLM][64Bits] – SSL Duende Native_is1 =>.Team V.R
                  O42 - Logiciel: Steam - (.Valve Corporation.) [HKLM][64Bits] – {048298C9-A4D3-490B-9FF9-AB023A9238F3} =>.Valve Corporation
                  O42 - Logiciel: Stereoizer3 v3.1 - (.NUGEN Audio.) [HKLM][64Bits] – Stereoizer3_is1 =>.NuGen Audio
                  O42 - Logiciel: Stereoplacer v3 - (.NUGEN Audio.) [HKLM][64Bits] – Stereoplacer3_is1 =>.NuGen Audio
                  O42 - Logiciel: Sugar Bytes Looperator 1.0 - (.Sugar Bytes.) [HKLM][64Bits] – Looperator_is1 =>.Sugar Bytes
                  O42 - Logiciel: Suite Shared Configuration CS4 - (.Adobe Systems Incorporated.) [HKLM][64Bits] – {842B4B72-9E8F-4962-B3C1-1C422A5C4434} =>.Adobe Systems Incorporated
                  O42 - Logiciel: Surfer EQ version 1.2.2 - (.Sound Radix.) [HKLM][64Bits] – {B8D2A156-B2DE-47BD-9789-F1A850F060C1}_is1
                  O42 - Logiciel: swMSM - (.Adobe Systems, Inc.) [HKLM][64Bits] – {612C34C7-5E90-47D8-9B5C-0F717DD82726} =>.Adobe Systems, Inc
                  O42 - Logiciel: System Requirements Lab for Intel - (.Husdawg, LLC.) [HKLM][64Bits] – {C7CA731B-BF9A-46D9-92CF-8A8737AE9240} =>.Husdawg, LLC
                  O42 - Logiciel: Tag&Rename 3.7 - (.Softpointer Inc.) [HKLM][64Bits] – Tag&Rename_is1 {009B5D9ACC30DA5DC1E782623935B1D9A5} =>.Softpointer Inc
                  O42 - Logiciel: TeamViewer 12 - (.TeamViewer.) [HKLM][64Bits] – TeamViewer =>.TeamViewer GmbH®
                  O42 - Logiciel: TeraCopy 2.3 - (.Code Sector.) [HKLM][64Bits] – TeraCopy_is1 =>.Code Sector®
                  O42 - Logiciel: The Glue - (..) [HKLM][64Bits] – The Glue_is1
                  O42 - Logiciel: The KMPlayer (remove only) - (.KMP Media co., Ltd.) [HKLM][64Bits] – The KMPlayer
                  O42 - Logiciel: ToneBoosters Morphit - (.ToneBoosters.) [HKLM][64Bits] – Morphit_is1
                  O42 - Logiciel: Tracker - (.Elance Inc.) [HKLM][64Bits] – {DDFB9315-8964-B381-2167-0C0FE726CD99}
                  O42 - Logiciel: Tracker - (.Elance Inc.) [HKLM][64Bits] – com.elance.tracker
                  O42 - Logiciel: T-RackS 3 Black 76 version 3.5 - (.IK Multimedia.) [HKLM][64Bits] – {7F0FEB55-6D4A-4892-8A04-3E1EC9001F49}is1 =>.IK Multimedia
                  O42 - Logiciel: T-RackS 3 White 2A version 3.5 - (.IK Multimedia.) [HKLM][64Bits] – {4EE378E8-5B8C-4A56-837F-04986F44F14F}is1 =>.IK Multimedia
                  O42 - Logiciel: T-RackS CS version 4.5.0 - (.IK Multimedia.) [HKLM][64Bits] – {E931EBCC-55F9-4D67-BA0E-D57C4A893A44}is1 =>.IK Multimedia
                  O42 - Logiciel: Trackspacer - (.Wavesfactory.) [HKLM][64Bits] – Trackspacer_is1
                  O42 - Logiciel: Tradeo - MetaTrader 4 - (.MetaQuotes Software Corp..) [HKLM][64Bits] – Tradeo - MetaTrader 4 =>.MetaQuotes Software Corp.®
                  O42 - Logiciel: Transify version 1.3 - (..) [HKLM][64Bits] – Transify_is1
                  O42 - Logiciel: TuneSmith - (.Idolumic.) [HKLM][64Bits] – {9061CD4C-6D8A-465B-A2DF-530DF94BCE4D}
                  O42 - Logiciel: Tweaking.com - Windows Repair - (.Tweaking.com.) [HKLM][64Bits] – Tweaking.com - Windows Repair =>.Tweaking.com
                  O42 - Logiciel: UAD drivers. This may take a while… - (.Universal Audio, Inc..) [HKLM][64Bits] – {5E9376D2-3FD7-4A1B-AE36-9F8A2D32BE43} =>.Universal Audio, Inc.
                  O42 - Logiciel: UAD Powered Plug-Ins - (.Universal Audio, Inc..) [HKLM][64Bits] – {4D60D5BA-97AF-44C5-B345-2A4B06821208} =>.Universal Audio, Inc.
                  O42 - Logiciel: UAD Powered Plug-Ins - (.Universal Audio, Inc..) [HKLM][64Bits] – {682B131A-6BED-431E-89AD-5F2249F2F9D9} =>.Universal Audio, Inc.
                  O42 - Logiciel: UAD Powered Plug-Ins - (.Universal Audio, Inc..) [HKLM][64Bits] – {9b9c7089-62a6-4bba-887c-4b94398cc561} {00BB422EC67CF34C25} =>.Universal Audio, Inc.
                  O42 - Logiciel: UAD Powered Plug-Ins - (.Universal Audio, Inc..) [HKLM][64Bits] – {B69D27E0-8CC0-40B7-9FA1-5D3EE307BE13} =>.Universal Audio, Inc.
                  O42 - Logiciel: UAD Powered Plug-Ins - (.Universal Audio, Inc..) [HKLM][64Bits] – {C88BB7C3-14C2-4D9E-8F13-CA9DFBCB5F37} =>.Universal Audio, Inc.
                  O42 - Logiciel: UAD Powered Plug-Ins - (.Universal Audio, Inc..) [HKLM][64Bits] – {D1041E05-ED4D-42CC-9278-8F81D8C30863} =>.Universal Audio, Inc.
                  O42 - Logiciel: ubCore64 5.63 - (..) [HKLM][64Bits] – InstallShield
                  {F65FE148-FCF5-42F7-8803-FA0B7DA8B8A4}
                  O42 - Logiciel: ubCore64 5.63 - (.Unibrain.) [HKLM][64Bits] – {F65FE148-FCF5-42F7-8803-FA0B7DA8B8A4} =>.Unibrain
                  O42 - Logiciel: UNCHIRP VST-x64 1.0.0 - (.Zynaptiq.) [HKLM][64Bits] – {FE7EB46F-1099-46e2-9165-D10058814B7D}
                  O42 - Logiciel: UNFILTER VST-x64 1.2.1 - (.Zynaptiq.) [HKLM][64Bits] – {F74A8B13-C915-4CE2-ACE0-CC6845C9D89D}
                  O42 - Logiciel: UnHackMe 8.60 - (.Greatis Software, LLC..) [HKLM][64Bits] – UnHackMe_is1 =>.Greatis Software, LLC.
                  O42 - Logiciel: Universal Extractor 1.6.1 - (.Jared Breland.) [HKLM][64Bits] – Universal Extractor_is1 =>.Jared Breland
                  O42 - Logiciel: Update for Skype for Business 2015 (KB3039776) 64-Bit Edition - (.Microsoft.) [HKLM][64Bits] – {90150000-012B-0409-1000-0000000FF1CE}Office15.PROPLUS{0FA8AE0C-69AE-4F60-A1AB-F79C6BA5A999} =>.Microsoft Corporation®
                  O42 - Logiciel: Update for Skype for Business 2015 (KB3115033) 64-Bit Edition - (.Microsoft.) [HKLM][64Bits] – {90150000-00C1-0000-1000-0000000FF1CE}Office15.PROPLUS{F258B6E3-BF41-4FEE-BE45-D7518C3B7FC1} =>.Microsoft Corporation®
                  O42 - Logiciel: Update for Skype for Business 2015 (KB3115033) 64-Bit Edition - (.Microsoft.) [HKLM][64Bits] – {90150000-012B-0409-1000-0000000FF1CE}Office15.PROPLUS{F258B6E3-BF41-4FEE-BE45-D7518C3B7FC1} =>.Microsoft Corporation®
                  O42 - Logiciel: Uplay - (.Ubisoft.) [HKLM][64Bits] – Uplay =>.Ubisoft Entertainment Sweden AB®
                  O42 - Logiciel: URS Classic Console Strip Pro VST RTAS v1.0 - (..) [HKLM][64Bits] – URS Classic Console Strip Pro VST RTAS_is1
                  O42 - Logiciel: VC80CRTRedist - 8.0.50727.6195 - (.DivX, Inc.) [HKLM][64Bits] – {933B4015-4618-4716-A828-5289FC03165F} =>.DivX, Inc
                  O42 - Logiciel: VerbSuite Classics - (.Slate Digital.) [HKLM][64Bits] – Slate Digital VerbSuite Classics_is1 =>.Slate Digital
                  O42 - Logiciel: VerbSuite Classics - Fusion-IR Bricasti M7 (Part 1) 1.1 - (.LiquidSonics.) [HKLM][64Bits] – VerbSuite Classics - Fusion-IR Bricasti M7 (Part 1) =>.LiquidSonics
                  O42 - Logiciel: VerbSuite Classics - Fusion-IR Bricasti M7 (Part 2) 1.1 - (.LiquidSonics.) [HKLM][64Bits] – VerbSuite Classics - Fusion-IR Bricasti M7 (Part 2) =>.LiquidSonics
                  O42 - Logiciel: Virtual Audio Cable 4.13 - (..) [HKLM][64Bits] – Virtual Audio Cable 4.13 =>.Muzychenko Evgenii Viktorovich®
                  O42 - Logiciel: Virtual Buss Compressors - (.Slate Digital.) [HKLM][64Bits] – Slate Digital Virtual Buss Compressors_is1 =>.Slate Digital
                  O42 - Logiciel: Virtual Tape Machines - (.Slate Digital.) [HKLM][64Bits] – Slate Digital Virtual Tape Machines_is1 =>.Slate Digital
                  O42 - Logiciel: VisLM v1.5.1 - (.NUGEN Audio.) [HKLM][64Bits] – VisLM_is1 =>.NuGen Audio
                  O42 - Logiciel: Visual C++ 64-bit Redistributables - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – {FB03650C-B373-4B20-ACA5-B7BA1A8EEE33} =>.PACE Anti-Piracy, Inc.
                  O42 - Logiciel: Visual C++ 64-bit Redistributables - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – InstallShield
                  O42 - Logiciel: Visual C++ Redistributables - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – {F03117FA-9270-46B0-9666-0B4BC2CDEBF5} =>.PACE Anti-Piracy, Inc.
                  O42 - Logiciel: Visual C++ Redistributables - (.PACE Anti-Piracy, Inc..) [HKLM][64Bits] – InstallShield
                  O42 - Logiciel: Visual Studio 2012 x64 Redistributables - (.AVG Technologies.) [HKLM][64Bits] – {8C775E70-A791-4DA8-BCC3-6AB7136F4484} =>.AVG Technologies
                  O42 - Logiciel: Visual Studio 2012 x86 Redistributables - (.AVG Technologies CZ, s.r.o..) [HKLM][64Bits] – {98EFF19A-30AB-4E4B-B943-F06B1C63EBF8} =>.AVG Technologies CZ, s.r.o.
                  O42 - Logiciel: Visualizer v1.9.2 - (.NuGen Audio.) [HKLM][64Bits] – Visualizer1_9_is1 =>.NuGen Audio
                  O42 - Logiciel: VLC media player - (.VideoLAN.) [HKLM][64Bits] – VLC media player =>.VideoLAN
                  O42 - Logiciel: VocALign Pro 4 VST - (.Synchro Arts Ltd.) [HKLM][64Bits] – {EB77C666-B349-4046-8BD3-E4941119E1EF}
                  O42 - Logiciel: Voxengo Boogex - (.Voxengo.) [HKLM][64Bits] – Voxengo Boogex_is1 =>.Voxengo®
                  O42 - Logiciel: Vulkan Run Time Libraries 1.0.37.0 - (.LunarG, Inc..) [HKLM][64Bits] – VulkanRT1.0.37.0 =>.LunarG, Inc.®
                  O42 - Logiciel: Waves Complete - (.Waves.) [HKLM][64Bits] – Complete_is1 =>.Waves
                  O42 - Logiciel: Webroot SecureAnywhere - (.Webroot.) [HKLM][64Bits] – WRUNINST {6FBB6E1D2367DC6BD38B1C8FA0BF6637} =>.Webroot
                  O42 - Logiciel: Welcome App (Start-up experience) - (.Nero AG.) [HKLM][64Bits] – {828175FA-7307-4DBF-95AD-9CEE086B6F45} =>.Nero AG
                  O42 - Logiciel: WinDirStat 1.1.2 - (.Seifert Systems.) [HKCU][64Bits] – WinDirStat =>.Seifert Systems
                  O42 - Logiciel: Windows 10 Upgrade Assistant - (.Microsoft Corporation.) [HKLM][64Bits] – {D5C69738-B486-402E-85AC-2456D98A64E4} =>.Microsoft Corporation®
                  O42 - Logiciel: Windows Driver Package - Silicon Laboratories (silabenm) Ports (12/10/2012 - (.Silicon Laboratories.) [HKLM][64Bits] – D680DEE0F68D64EC53D0C5769879D15D387054CC =>.Silicon Laboratories
                  O42 - Logiciel: Windows Installer Clean Up - (.Microsoft Corporation.) [HKLM][64Bits] – {121634B0-2F4B-11D3-ADA3-00C04F52DD52} =>.Microsoft Corporation
                  O42 - Logiciel: Windows Software Development Kit - (.Microsoft Corporation.) [HKLM][64Bits] – {363a2c1e-637f-45ce-933b-5a5463efd945} =>.Microsoft Corporation®
                  O42 - Logiciel: WinRAR 5.40 (64-bit) - (.win.rar GmbH.) [HKLM][64Bits] – WinRAR archiver =>.win.rar GmbH®
                  O42 - Logiciel: WinZip 18.0 - (.WinZip Computing, S.L..) [HKLM][64Bits] – {CD95F661-A5C4-44F5-A6AA-ECDD91C240DF} =>.WinZip Computing, S.L.
                  O42 - Logiciel: WPT Redistributables - (.Microsoft.) [HKLM][64Bits] – {A5D42D71-4036-5F88-5085-657C9DF9F1DD} =>.Microsoft
                  O42 - Logiciel: WPTx64 - (.Microsoft.) [HKLM][64Bits] – {986EABFC-92F6-CECD-9E5A-B13CAC40BB1D} =>.Microsoft
                  O42 - Logiciel: Zemana AntiMalware - (.Zemana Ltd..) [HKLM][64Bits] – {8F0CD7D1-42F3-4195-95CD-833578D45057}_is1 =>.Zemana Ltd.
                  O42 - Logiciel: Zynaptiq ADAPTIVERB - (.Zynaptiq.) [HKLM][64Bits] – ADAPTIVERB_is1
                  O42 - Logiciel: Zynaptiq ADAPTIVERB - (.Zynaptiq.) [HKLM][64Bits] – Zynaptiq ADAPTIVERB
                  —\ HKCU & HKLM Software Keys (392) - 34s
                  HKLM\SOFTWARE\Wow6432Node\112dB
                  HKLM\SOFTWARE\Wow6432Node\2C-Audio
                  HKLM\SOFTWARE\Wow6432Node\Acronis =>.Acronis
                  HKLM\SOFTWARE\Wow6432Node\Activision =>.Activision
                  HKLM\SOFTWARE\Wow6432Node\Adobe =>.Adobe
                  HKLM\SOFTWARE\Wow6432Node\Adware Removal Tool by TSA =>.TSA Softwares
                  HKLM\SOFTWARE\Wow6432Node\AGEIA Technologies =>.AGEIA Technologies
                  HKLM\SOFTWARE\Wow6432Node\Amazon =>.Amazon
                  HKLM\SOFTWARE\Wow6432Node\AnonVPN
                  HKLM\SOFTWARE\Wow6432Node\Antares Audio Technologies =>.Antares Audio Technologies
                  HKLM\SOFTWARE\Wow6432Node\AppDataLow =>.Microsoft Corporation
                  HKLM\SOFTWARE\Wow6432Node\Apple Computer, Inc. =>.Apple Computer, Inc.
                  HKLM\SOFTWARE\Wow6432Node\Apple Inc. =>.Apple Inc.
                  HKLM\SOFTWARE\Wow6432Node\Applied Acoustics Systems =>.Applied Acoustics Systems
                  HKLM\SOFTWARE\Wow6432Node\Aqbanking
                  HKLM\SOFTWARE\Wow6432Node\Arainia =>.Arainia Solutions, LLC
                  HKLM\SOFTWARE\Wow6432Node\ArcSoft =>.ArcSoft
                  HKLM\SOFTWARE\Wow6432Node\ASIO =>.Steinberg Media Technologies
                  HKLM\SOFTWARE\Wow6432Node\ASIO4ALL =>.Michael Tippach
                  HKLM\SOFTWARE\Wow6432Node\ASProtect =>.ASPack Software
                  HKLM\SOFTWARE\Wow6432Node\ASUS =>.ASUS
                  HKLM\SOFTWARE\Wow6432Node\Atheros =>.Qualcomm Atheros
                  HKLM\SOFTWARE\Wow6432Node\Audio Ease
                  HKLM\SOFTWARE\Wow6432Node\AVID =>.Avid
                  HKLM\SOFTWARE\Wow6432Node\Avid Technology =>.Avid Technology
                  HKLM\SOFTWARE\Wow6432Node\AVS4YOU =>.AVS4YOU
                  HKLM\SOFTWARE\Wow6432Node\Bevee
                  HKLM\SOFTWARE\Wow6432Node\BinarySense =>.BinarySense
                  HKLM\SOFTWARE\Wow6432Node\Bitsum =>.Bitsum
                  HKLM\SOFTWARE\Wow6432Node\Boz Digital Labs
                  HKLM\SOFTWARE\Wow6432Node\Cakewalk Music Software =>.Cakewalk Music Software
                  HKLM\SOFTWARE\Wow6432Node\Caphyon =>.Caphyon
                  HKLM\SOFTWARE\Wow6432Node\Carbonite =>.Carbonite
                  HKLM\SOFTWARE\Wow6432Node\CDDB =>.Cddb Software
                  HKLM\SOFTWARE\Wow6432Node\CDSoundMaster
                  HKLM\SOFTWARE\Wow6432Node\Celemony Software GmbH =>.Celemony Software GmbH
                  HKLM\SOFTWARE\Wow6432Node\Citrix =>.Citrix
                  HKLM\SOFTWARE\Wow6432Node\Codec Tweak Tool =>.KLite Inc
                  HKLM\SOFTWARE\Wow6432Node\Creative Labs =>.Creative Labs
                  HKLM\SOFTWARE\Wow6432Node\Creative Tech =>.Creative Tech
                  HKLM\SOFTWARE\Wow6432Node\Digidesign =>.Avid Audio
                  HKLM\SOFTWARE\Wow6432Node\Dimension
                  HKLM\SOFTWARE\Wow6432Node\Disc Soft =>.Disc Soft
                  HKLM\SOFTWARE\Wow6432Node\DivX =>.DivX Inc.
                  HKLM\SOFTWARE\Wow6432Node\DivXNetworks =>.DivXNetworks
                  HKLM\SOFTWARE\Wow6432Node\DSPRobotics
                  HKLM\SOFTWARE\Wow6432Node\DT Soft =>.DT Soft Ltd
                  HKLM\SOFTWARE\Wow6432Node\Empress
                  HKLM\SOFTWARE\Wow6432Node\eSellerate
                  HKLM\SOFTWARE\Wow6432Node\Eset =>.ESET
                  HKLM\SOFTWARE\Wow6432Node\FabFilter
                  HKLM\SOFTWARE\Wow6432Node\Fidelify
                  HKLM\SOFTWARE\Wow6432Node\FileZilla 3 =>.FileZilla
                  HKLM\SOFTWARE\Wow6432Node\FileZilla Client =>.Tim Kosse
                  HKLM\SOFTWARE\Wow6432Node\FlashGet Network
                  HKLM\SOFTWARE\Wow6432Node\Florian Heidenreich =>.Florian Heidenreich
                  HKLM\SOFTWARE\Wow6432Node\Focusrite =>.Focusrite
                  HKLM\SOFTWARE\Wow6432Node\FreshDevices
                  HKLM\SOFTWARE\Wow6432Node\FXpansion =>.FXpansion
                  HKLM\SOFTWARE\Wow6432Node\Garmin =>.Garmin Ltd
                  HKLM\SOFTWARE\Wow6432Node\GIZMO2
                  HKLM\SOFTWARE\Wow6432Node\GNU =>.GNU
                  HKLM\SOFTWARE\Wow6432Node\GnuCash
                  HKLM\SOFTWARE\Wow6432Node\Google =>.Google
                  HKLM\SOFTWARE\Wow6432Node\Gravity =>.Gravity
                  HKLM\SOFTWARE\Wow6432Node\Greatis =>.Greatis Software
                  HKLM\SOFTWARE\Wow6432Node\Gwenhywfar
                  HKLM\SOFTWARE\Wow6432Node\HaaliMkx =>.Haali Media
                  HKLM\SOFTWARE\Wow6432Node\IK Multimedia =>.IK Multimedia
                  HKLM\SOFTWARE\Wow6432Node\IM Providers =>.IM Providers
                  HKLM\SOFTWARE\Wow6432Node\Image-Line =>.Image-Line
                  HKLM\SOFTWARE\Wow6432Node\Imploded Software
                  HKLM\SOFTWARE\Wow6432Node\InstallShield =>.InstallShield
                  HKLM\SOFTWARE\Wow6432Node\Intel =>.Intel
                  HKLM\SOFTWARE\Wow6432Node\Intuit =>.Intuit
                  HKLM\SOFTWARE\Wow6432Node\IObit =>.IObit
                  HKLM\SOFTWARE\Wow6432Node\Ivideon
                  HKLM\SOFTWARE\Wow6432Node\iZotope, Inc./iZotope Ozone 7 Advanced
                  HKLM\SOFTWARE\Wow6432Node\iZotope, Inc./Neutron Advanced
                  HKLM\SOFTWARE\Wow6432Node\iZotope, Inc./VocalSynth
                  HKLM\SOFTWARE\Wow6432Node\JavaSoft =>.JavaSoft
                  HKLM\SOFTWARE\Wow6432Node\Joey Sturgis Tones
                  HKLM\SOFTWARE\Wow6432Node\JreMetrics =>.JreMetrics
                  HKLM\SOFTWARE\Wow6432Node\Khronos =>.Khronos
                  HKLM\SOFTWARE\Wow6432Node\KLCodecPack =>.KLite Inc
                  HKLM\SOFTWARE\Wow6432Node\KMPlayer =>.KMPlayer
                  HKLM\SOFTWARE\Wow6432Node\Kong Audio
                  HKLM\SOFTWARE\Wow6432Node\LAV =>.LAV Inc
                  HKLM\SOFTWARE\Wow6432Node\Lexicon =>.Lexicon
                  HKLM\SOFTWARE\Wow6432Node\Licenses =>.Microsoft Corporation
                  HKLM\SOFTWARE\Wow6432Node\Link-Assistant.Com =>.Link-Assistant.Com
                  HKLM\SOFTWARE\Wow6432Node\Litecoin
                  HKLM\SOFTWARE\Wow6432Node\logishrd =>.LogiShrd
                  HKLM\SOFTWARE\Wow6432Node\Logitech =>.Logitech
                  HKLM\SOFTWARE\Wow6432Node\Macromedia =>.Macromedia
                  HKLM\SOFTWARE\Wow6432Node\Macrovision =>.Macrovision
                  HKLM\SOFTWARE\Wow6432Node\MakeMusic =>.MakeMusic
                  HKLM\SOFTWARE\Wow6432Node\Malwarebytes Anti-Rootkit =>.Malwarebytes
                  HKLM\SOFTWARE\Wow6432Node\Malwarebytes’ Anti-Malware =>.Malwarebytes’ Anti-Malware
                  HKLM\SOFTWARE\Wow6432Node\Marvell =>.Marvell
                  HKLM\SOFTWARE\Wow6432Node\Massey
                  HKLM\SOFTWARE\Wow6432Node\McDSP
                  HKLM\SOFTWARE\Wow6432Node\MimarSinan =>.Mimar Sinan
                  HKLM\SOFTWARE\Wow6432Node\Mozilla =>.Mozilla
                  HKLM\SOFTWARE\Wow6432Node\mozilla.org =>.mozilla.org
                  HKLM\SOFTWARE\Wow6432Node\MozillaPlugins =>.MozillaPlugins
                  HKLM\SOFTWARE\Wow6432Node\MusicBrainz =>.MusicBrainz
                  HKLM\SOFTWARE\Wow6432Node\Native Instruments =>.Native Instruments
                  HKLM\SOFTWARE\Wow6432Node\NCH Software =>.NCH Software
                  HKLM\SOFTWARE\Wow6432Node\NCH Swift Sound =>.NCH Swift Sound
                  HKLM\SOFTWARE\Wow6432Node\nerds.de =>.nerds.de
                  HKLM\SOFTWARE\Wow6432Node\Nero =>.Ahead Corporation
                  HKLM\SOFTWARE\Wow6432Node\Nevron =>.Nevron
                  HKLM\SOFTWARE\Wow6432Node\Nico Mak Computing =>.Nico Mak Computing
                  HKLM\SOFTWARE\Wow6432Node\Nitro =>.Nitro
                  HKLM\SOFTWARE\Wow6432Node\Nuance =>.Nuance
                  HKLM\SOFTWARE\Wow6432Node\NuGen Audio =>.NuGen Audio
                  HKLM\SOFTWARE\Wow6432Node\NVIDIA Corporation =>.nVidia Corporation
                  HKLM\SOFTWARE\Wow6432Node\ODBC =>.DB Connectivity Solutions
                  HKLM\SOFTWARE\Wow6432Node\OpenAL =>.Open Audio Library
                  HKLM\SOFTWARE\Wow6432Node\PACE Anti-Piracy =>.PACE Anti-Piracy
                  HKLM\SOFTWARE\Wow6432Node\pit
                  HKLM\SOFTWARE\Wow6432Node\PowerPivot =>.PowerPivot
                  HKLM\SOFTWARE\Wow6432Node\ProcessLasso =>.Bitsum Technologies
                  HKLM\SOFTWARE\Wow6432Node\Propellerhead Software =>.Propellerhead Software
                  HKLM\SOFTWARE\Wow6432Node\Qualcomm Atheros =>.Qualcomm Atheros
                  HKLM\SOFTWARE\Wow6432Node\Realtek =>.Realtek Semiconductor Corp.
                  HKLM\SOFTWARE\Wow6432Node\Realtek Semiconductor Corp. =>.Realtek Semiconductor Corp.
                  HKLM\SOFTWARE\Wow6432Node\REAPER =>.Cockos Incorporated
                  HKLM\SOFTWARE\Wow6432Node\Rebellion =>.Rebellion
                  HKLM\SOFTWARE\Wow6432Node\S3R521
                  HKLM\SOFTWARE\Wow6432Node\Safer Networking Limited =>.Safer Networking Limited
                  HKLM\SOFTWARE\Wow6432Node\Sandwich
                  HKLM\SOFTWARE\Wow6432Node\Scuffham Amps
                  HKLM\SOFTWARE\Wow6432Node\Siding
                  HKLM\SOFTWARE\Wow6432Node\Silicon Laboratories, Inc. =>.Silicon Laboratories, Inc.
                  HKLM\SOFTWARE\Wow6432Node\Skype =>.Skype
                  HKLM\SOFTWARE\Wow6432Node\Slate Digital =>.Slate Digital
                  HKLM\SOFTWARE\Wow6432Node\SoftEther Project =>.SoftEther Project
                  HKLM\SOFTWARE\Wow6432Node\SoftVoice =>.SoftVoice
                  HKLM\SOFTWARE\Wow6432Node\Sonarworks
                  HKLM\SOFTWARE\Wow6432Node\SONiVOX =>.SONiVOX
                  HKLM\SOFTWARE\Wow6432Node\Sonoris
                  HKLM\SOFTWARE\Wow6432Node\Sony Creative Software =>.Sony Creative Software
                  HKLM\SOFTWARE\Wow6432Node\Sound Radix
                  HKLM\SOFTWARE\Wow6432Node\SpeedFan =>.Almico Software
                  HKLM\SOFTWARE\Wow6432Node\SRS Labs =>.SRS Labs
                  HKLM\SOFTWARE\Wow6432Node\Steven Slate
                  HKLM\SOFTWARE\Wow6432Node\Steven Slate Drums
                  HKLM\SOFTWARE\Wow6432Node\SuppHelpDir =>.Toshiba Corporation
                  HKLM\SOFTWARE\Wow6432Node\Swearware =>.Swearware
                  HKLM\SOFTWARE\Wow6432Node\Symantec =>.Symantec
                  HKLM\SOFTWARE\Wow6432Node\TC Electronic =>.TC Electronic
                  HKLM\SOFTWARE\Wow6432Node\TC Works
                  HKLM\SOFTWARE\Wow6432Node\TeamViewer =>.TeamViewer
                  HKLM\SOFTWARE\Wow6432Node\TechSmith =>.TechSmith
                  HKLM\SOFTWARE\Wow6432Node\Tobias Erichsen =>.Tobias Erichsen
                  HKLM\SOFTWARE\Wow6432Node\TOSHIBA =>.Toshiba Corporation
                  HKLM\SOFTWARE\Wow6432Node\Ubisoft =>.Ubisoft
                  HKLM\SOFTWARE\Wow6432Node\ueberschall sample service GmbH
                  HKLM\SOFTWARE\Wow6432Node\Unblock-Us
                  HKLM\SOFTWARE\Wow6432Node\Universal Audio =>.RSA Security
                  HKLM\SOFTWARE\Wow6432Node\Valve =>.Valve
                  HKLM\SOFTWARE\Wow6432Node\VideoLAN =>.VideoLAN
                  HKLM\SOFTWARE\Wow6432Node\Volatile =>.Microsoft Corporation
                  HKLM\SOFTWARE\Wow6432Node\VST =>.Virtual Studio Technology
                  HKLM\SOFTWARE\Wow6432Node\Waves =>.Waves
                  HKLM\SOFTWARE\Wow6432Node\webroot =>.Webroot
                  HKLM\SOFTWARE\Wow6432Node\Wise Solutions =>.Wise Solutions
                  HKLM\SOFTWARE\Wow6432Node\WOW6432Node =>.Microsoft Corporation
                  HKLM\SOFTWARE\Wow6432Node\WRData
                  HKLM\SOFTWARE\Wow6432Node\Yahoo =>.Yahoo! Inc.
                  HKLM\SOFTWARE\Wow6432Node\Zynaptiq
                  HKLM\SOFTWARE\Wow6432Node\RegisteredApplications =>.Microsoft Corporation
                  HKCU\SOFTWARE\112dB
                  HKCU\SOFTWARE\7-Zip =>.Igor Pavlov
                  HKCU\SOFTWARE\Ableton =>.Ableton
                  HKCU\SOFTWARE\Acronis =>.Acronis
                  HKCU\SOFTWARE\Acusticaudio
                  HKCU\SOFTWARE\Adobe =>.Adobe
                  HKCU\SOFTWARE\Adobe Lightroom =>.Adobe Inc.
                  HKCU\SOFTWARE\Akeo Consulting =>.Akeo Consulting
                  HKCU\SOFTWARE\Almageste
                  HKCU\SOFTWARE\Amazon =>.Amazon
                  HKCU\SOFTWARE\AnonVPN
                  HKCU\SOFTWARE\AppDataLow =>.Microsoft Corporation
                  HKCU\SOFTWARE\Apple Computer, Inc. =>.Apple Computer, Inc.
                  HKCU\SOFTWARE\Apple Inc. =>.Apple Inc.
                  HKCU\SOFTWARE\Arainia =>.Arainia Solutions, LLC
                  HKCU\SOFTWARE\ArcSoft =>.ArcSoft
                  HKCU\SOFTWARE\ArcticLine =>.ArcticLine
                  HKCU\SOFTWARE\Articulate =>.Articulate
                  HKCU\SOFTWARE\ASIO4ALL v2 by Wuschel =>.Unknow
                  HKCU\SOFTWARE\ASProtect =>.ASPack Software
                  HKCU\SOFTWARE\ASUS =>.ASUS
                  HKCU\SOFTWARE\AtomicWare =>.AtomicWare
                  HKCU\SOFTWARE\Audacity =>.Audacity
                  HKCU\SOFTWARE\Audio Ease
                  HKCU\SOFTWARE\AVAST Software =>.AVAST Software
                  HKCU\SOFTWARE\Avg Secure Update =>.AVG Software
                  HKCU\SOFTWARE\Avid =>.Avid
                  HKCU\SOFTWARE\AVS4YOU =>.AVS4YOU
                  HKCU\SOFTWARE\Binary Fortress Software =>.Binary Fortress Software
                  HKCU\SOFTWARE\BinarySense =>.BinarySense
                  HKCU\SOFTWARE\Bird
                  HKCU\SOFTWARE\Bitsum =>.Bitsum
                  HKCU\SOFTWARE\BugSplat =>.Bugsplat Game
                  HKCU\SOFTWARE\calibre =>.Kovid Goyal
                  HKCU\SOFTWARE\Carbonite =>.Carbonite
                  HKCU\SOFTWARE\CDDB =>.Cddb Software
                  HKCU\SOFTWARE\cdsoundmaster
                  HKCU\SOFTWARE\Chromium =>.Chromium
                  HKCU\SOFTWARE\Citrix =>.Citrix
                  HKCU\SOFTWARE\Code Sector =>.Code Sector
                  HKCU\SOFTWARE\Common =>.Corel Corporation
                  HKCU\SOFTWARE\ComodoGroup =>.ComodoGroup
                  HKCU\SOFTWARE\Convolver =>.Convolver
                  HKCU\SOFTWARE\Creative Tech =>.Creative Tech
                  HKCU\SOFTWARE\Curtains
                  HKCU\SOFTWARE\Dashlane =>.Dashlane
                  HKCU\SOFTWARE\Dashlane_profiles =>.Dashlane, Inc
                  HKCU\SOFTWARE\Diamond Cut Productions
                  HKCU\SOFTWARE\DirectShow =>.Microsoft Corporation
                  HKCU\SOFTWARE\Disc Soft =>.Disc Soft
                  HKCU\SOFTWARE\DiskInternals =>.DiskInternals Research
                  HKCU\SOFTWARE\Ditto
                  HKCU\SOFTWARE\DivX =>.DivX Inc.
                  HKCU\SOFTWARE\DivXNetworks =>.DivXNetworks
                  HKCU\SOFTWARE\DMGAudio
                  HKCU\SOFTWARE\Doblon =>.Doblon
                  HKCU\SOFTWARE\DownloadCenter =>.DownloadCenter
                  HKCU\SOFTWARE\Dropbox =>.Dropbox
                  HKCU\SOFTWARE\drpsu =>.Driver PackSolution
                  HKCU\SOFTWARE\dskMetrics
                  HKCU\SOFTWARE\DT Soft =>.DT Soft Ltd
                  HKCU\SOFTWARE\East West =>.East West
                  HKCU\SOFTWARE\eBookConverter
                  HKCU\SOFTWARE\Electrum =>.Electrum
                  HKCU\SOFTWARE\eSellerate
                  HKCU\SOFTWARE\ESET =>.ESET
                  HKCU\SOFTWARE\FabFilter
                  HKCU\SOFTWARE\Fidelify
                  HKCU\SOFTWARE\FileMaker =>.FileMaker Inc
                  HKCU\SOFTWARE\FileOpen =>.FileOpen Systems Inc.
                  HKCU\SOFTWARE\FlashGet Network
                  HKCU\SOFTWARE\FLEXlm License Manager =>.FlexNet
                  HKCU\SOFTWARE\Flux
                  HKCU\SOFTWARE\Flux:: - IRCAM
                  HKCU\SOFTWARE\Flux:: sound and picture development
                  HKCU\SOFTWARE\FreshDevices
                  HKCU\SOFTWARE\Gabest =>.Gabest
                  HKCU\SOFTWARE\Garmin =>.Garmin Ltd
                  HKCU\SOFTWARE\Gigabyte =>.Gigabyte
                  HKCU\SOFTWARE\GIZMO2
                  HKCU\SOFTWARE\GNU =>.GNU
                  HKCU\SOFTWARE\Gobbler
                  HKCU\SOFTWARE\Google =>.Google
                  HKCU\SOFTWARE\Greatis =>.Greatis Software
                  HKCU\SOFTWARE\Growl
                  HKCU\SOFTWARE\Gui
                  HKCU\SOFTWARE\Haali =>.Haali Media
                  HKCU\SOFTWARE\Icaros =>.Icaros
                  HKCU\SOFTWARE\IK Multimedia =>.IK Multimedia
                  HKCU\SOFTWARE\IM Providers =>.IM Providers
                  HKCU\SOFTWARE\Image-Line =>.Image-Line
                  HKCU\SOFTWARE\Innovative Solutions =>.Innovative Solutions
                  HKCU\SOFTWARE\Intel =>.Intel
                  HKCU\SOFTWARE\Intuit =>.Intuit
                  HKCU\SOFTWARE\Ivideon
                  HKCU\SOFTWARE\iZotope =>.iZotope
                  HKCU\SOFTWARE\JavaSoft =>.JavaSoft
                  HKCU\SOFTWARE\join.me =>.LogMeIn Entreprise
                  HKCU\SOFTWARE\Junger Audio / Flux::
                  HKCU\SOFTWARE\Karlis Blumentals =>.Karlis Blumentals
                  HKCU\SOFTWARE\KMPlayer =>.KMPlayer
                  HKCU\SOFTWARE\LANGAGENT =>.LangAgent
                  HKCU\SOFTWARE\LApplication App
                  HKCU\SOFTWARE\Leadertech =>.Leadertech Systems
                  HKCU\SOFTWARE\Licenses =>.Microsoft Corporation
                  HKCU\SOFTWARE\Litecoin
                  HKCU\SOFTWARE\Litecoin Core (64-bit)
                  HKCU\SOFTWARE\Local AppWizard-Generated Applications =>.ZWCAD
                  HKCU\SOFTWARE\LogiShrd =>.LogiShrd
                  HKCU\SOFTWARE\Logitech =>.Logitech
                  HKCU\SOFTWARE\LopeSoft =>.LopeSoft
                  HKCU\SOFTWARE\M-Audio =>.M-Audio
                  HKCU\SOFTWARE\Macromedia =>.Macromedia
                  HKCU\SOFTWARE\madshi =>.madshi.net
                  HKCU\SOFTWARE\MainConcept =>.MainConcept AG
                  HKCU\SOFTWARE\MakeMusic =>.MakeMusic
                  HKCU\SOFTWARE\Malwarebytes =>.Malwarebytes
                  HKCU\SOFTWARE\Malwarebytes’ Anti-Malware =>.Malwarebytes’ Anti-Malware
                  HKCU\SOFTWARE\Massey
                  HKCU\SOFTWARE\Maxthon3 =>.Maxthon International Ltd
                  HKCU\SOFTWARE\MediaInfo =>.Jérôme Martinez
                  HKCU\SOFTWARE\MetaQuotes Software =>.MetaQuotes Software
                  HKCU\SOFTWARE\Michael Herf =>.Michael Herf
                  HKCU\SOFTWARE\Mouse
                  HKCU\SOFTWARE\Mozilla =>.Mozilla
                  HKCU\SOFTWARE\MozillaPlugins =>.MozillaPlugins
                  HKCU\SOFTWARE\MTK =>.MTK
                  HKCU\SOFTWARE\MusicBrainz =>.MusicBrainz
                  HKCU\SOFTWARE\Native Instruments =>.Native Instruments
                  HKCU\SOFTWARE\NCH Software =>.NCH Software
                  HKCU\SOFTWARE\NCH Swift Sound =>.NCH Swift Sound
                  HKCU\SOFTWARE\nerds.de =>.nerds.de
                  HKCU\SOFTWARE\Nero =>.Ahead Corporation
                  HKCU\SOFTWARE\Netscape =>.Netscape
                  HKCU\SOFTWARE\Nico Mak Computing =>.Nico Mak Computing
                  HKCU\SOFTWARE\Nitro =>.Nitro
                  HKCU\SOFTWARE\Nitro PDF =>.Nitro PDF
                  HKCU\SOFTWARE\NuGen Audio =>.NuGen Audio
                  HKCU\SOFTWARE\NVIDIA Corporation =>.nVidia Corporation
                  HKCU\SOFTWARE\ODBC =>.DB Connectivity Solutions
                  HKCU\SOFTWARE\Overloud =>.Overloud
                  HKCU\SOFTWARE\PACE Anti-Piracy =>.PACE Anti-Piracy
                  HKCU\SOFTWARE\PaceAP
                  HKCU\SOFTWARE\PdaNetAndroid =>.June Fabrics Technology Inc.
                  HKCU\SOFTWARE\PEiD
                  HKCU\SOFTWARE\Photograph
                  HKCU\SOFTWARE\Piriform =>.Piriform
                  HKCU\SOFTWARE\Plogue Art et Technologie, Inc =>.Plogue Art et Technologie, Inc
                  HKCU\SOFTWARE\Plugin Alliance =>.Plugin Alliance
                  HKCU\SOFTWARE\ProcessLasso =>.Bitsum Technologies
                  HKCU\SOFTWARE\PSP-audioware
                  HKCU\SOFTWARE\QtProject =>.QtProject
                  HKCU\SOFTWARE\Realtek =>.Realtek Semiconductor Corp.
                  HKCU\SOFTWARE\reFX =>.reFX Audio Software Inc
                  HKCU\SOFTWARE\RegisteredApplications =>.Microsoft Corporation
                  HKCU\SOFTWARE\rncbc.org
                  HKCU\SOFTWARE\RocketDock =>.Punk Software
                  HKCU\SOFTWARE\Romex Software =>.Romex Software
                  HKCU\SOFTWARE\Safer Networking Limited =>.Safer Networking Limited
                  HKCU\SOFTWARE\Scuffham Amps
                  HKCU\SOFTWARE\Seifert =>.Seifert Systems
                  HKCU\SOFTWARE\SimonTatham =>.Simon Tatham
                  HKCU\SOFTWARE\Skype =>.Skype
                  HKCU\SOFTWARE\SoftEther Project =>.SoftEther Project
                  HKCU\SOFTWARE\Softpointer =>.Softpointer
                  HKCU\SOFTWARE\SoftVoice =>.SoftVoice
                  HKCU\SOFTWARE\Sonarworks
                  HKCU\SOFTWARE\Sonnox Plugins
                  HKCU\SOFTWARE\Sony Creative Software =>.Sony Creative Software
                  HKCU\SOFTWARE\Sony Plugins
                  HKCU\SOFTWARE\Soup
                  HKCU\SOFTWARE\SourceForge =>.SourceForge
                  HKCU\SOFTWARE\SpeedFan =>.Almico Software
                  HKCU\SOFTWARE\Spotify =>.Spotify
                  HKCU\SOFTWARE\Sugar Bytes =>.Sugar Bytes
                  HKCU\SOFTWARE\SyncEngines =>.Microsoft Corporation
                  HKCU\SOFTWARE\Synchro Arts
                  HKCU\SOFTWARE\Sysinternals =>.Sysinternals
                  HKCU\SOFTWARE\System Requirements Lab =>.System Requirements Lab
                  HKCU\SOFTWARE\TAdvCheckList =>.Borland
                  HKCU\SOFTWARE\TC Works
                  HKCU\SOFTWARE\TeamViewer =>.TeamViewer
                  HKCU\SOFTWARE\TechnicaDelArte
                  HKCU\SOFTWARE\TechSmith =>.TechSmith
                  HKCU\SOFTWARE\Telestream =>.Telestream
                  HKCU\SOFTWARE\The Silicon Realms Toolworks =>.The Silicon Realms Toolworks
                  HKCU\SOFTWARE\Tobias Erichsen =>.Tobias Erichsen
                  HKCU\SOFTWARE\Toneboosters
                  HKCU\SOFTWARE\Toshiba Corporation =>.Toshiba Corporation
                  HKCU\SOFTWARE\Trolltech =>.Trolltech
                  HKCU\SOFTWARE\Ubisoft =>.Ubisoft
                  HKCU\SOFTWARE\ueberschall sample service GmbH
                  HKCU\SOFTWARE\UniExtract
                  HKCU\SOFTWARE\Universal Audio =>.RSA Security
                  HKCU\SOFTWARE\Universal Audio, Inc. =>.RSA Security
                  HKCU\SOFTWARE\University of Tsukuba =>.University of Tsukuba
                  HKCU\SOFTWARE\Valve =>.Valve
                  HKCU\SOFTWARE\VB and VBA Program Settings =>.Microsoft Corporation
                  HKCU\SOFTWARE\VideoLAN =>.VideoLAN
                  HKCU\SOFTWARE\VidSoft
                  HKCU\SOFTWARE\vladgsound
                  HKCU\SOFTWARE\VS Revo Group =>.VS Revo Group
                  HKCU\SOFTWARE\Wave Arts
                  HKCU\SOFTWARE\WinRAR =>.WinRAR
                  HKCU\SOFTWARE\WinRAR SFX =>.RarLab
                  HKCU\SOFTWARE\WinZip Computing =>.WinZip Computing
                  HKCU\SOFTWARE\Wow6432Node =>.Microsoft Corporation
                  HKCU\SOFTWARE\WRData
                  HKCU\SOFTWARE\XHEO INC
                  HKCU\SOFTWARE\Zemana =>.Zemana
                  HKCU\SOFTWARE\ZHP =>.Nicolas Coolman
                  HKCU\SOFTWARE\Zynaptiq
                  HKCU\SOFTWARE\AppDataLow\COMODO =>.COMODO
                  HKCU\SOFTWARE\AppDataLow\Software =>.Microsoft Corporation
                  HKCU\SOFTWARE\AppDataLow\Software\Adobe =>.Adobe
                  HKCU\SOFTWARE\AppDataLow\Software\JavaSoft =>.JavaSoft
                  HKCU\SOFTWARE\AppDataLow\Software\Macromedia =>.Macromedia
                  HKCU\SOFTWARE\AppDataLow\Software\webroot =>.Webroot
                  —\ Contents of the Common Files folders (1023) - 28s
                  O43 - CFD: 26/04/2015 - D – C:\Program Files\112dB
                  O43 - CFD: 30/04/2013 - D – C:\Program Files\2C-Audio
                  O43 - CFD: 31/10/2016 - D – C:\Program Files\7-Zip =>.Igor Pavlov
                  O43 - CFD: 13/07/2013 - D – C:\Program Files\Adobe =>.Adobe Systems Incorporated®
                  O43 - CFD: 27/12/2012 - D – C:\Program Files\Aether
                  O43 - CFD: 28/10/2013 - D – C:\Program Files\Antares Audio Technologies =>.Antares Audio Technologies
                  O43 - CFD: 11/02/2014 - D – C:\Program Files\Applied Acoustics Systems =>.Applied Acoustics Systems
                  O43 - CFD: 07/01/2014 - D – C:\Program Files\ASUS =>.MCCI Corporation®
                  O43 - CFD: 16/06/2016 - D – C:\Program Files\Audio Ease
                  O43 - CFD: 06/11/2014 - D – C:\Program Files\AVAST Software =>.AVAST Software
                  O43 - CFD: 15/08/2016 - AD – C:\Program Files\Avid {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  O43 - CFD: 06/11/2014 - [0] D – C:\Program Files\Bitdefender =>.Bitdefender
                  O43 - CFD: 06/01/2017 - RD – C:\Program Files\Black Rooster Audio
                  O43 - CFD: 03/12/2015 - D – C:\Program Files\BozDigitalLabs
                  O43 - CFD: 15/08/2013 - D – C:\Program Files\BWF MetaEdit
                  O43 - CFD: 20/02/2017 - AD – C:\Program Files\Calibre2 =>.Kovid Goyal
                  O43 - CFD: 22/07/2015 - D – C:\Program Files\Carbonite {18455E6EF6D43CE1BB0C2DAC7DED3004} =>.Carbonite
                  O43 - CFD: 21/02/2017 - AD – C:\Program Files\CCleaner =>.Piriform Ltd
                  O43 - CFD: 20/02/2016 - D – C:\Program Files\Celemony =>.Celemony
                  O43 - CFD: 12/08/2016 - D – C:\Program Files\CMAK =>.Microsoft Corporation
                  O43 - CFD: 22/11/2016 - D – C:\Program Files\Common Files =>.Microsoft Corporation
                  O43 - CFD: 23/12/2012 - D – C:\Program Files\COMODO =>.Comodo
                  O43 - CFD: 23/12/2012 - D – C:\Program Files\Creative =>.Creative
                  O43 - CFD: 23/11/2016 - D – C:\Program Files\D16 Group =>.D16 Group
                  O43 - CFD: 10/03/2013 - D – C:\Program Files\DIFX =>.Microsoft Corporation
                  O43 - CFD: 28/12/2014 - D – C:\Program Files\DivX =>.DivX
                  O43 - CFD: 26/12/2016 - D – C:\Program Files\DMG Audio
                  O43 - CFD: 14/09/2015 - D – C:\Program Files\FabFilter
                  O43 - CFD: 22/11/2016 - D – C:\Program Files\Flux =>.Stereopsis
                  O43 - CFD: 23/12/2012 - [0] D – C:\Program Files\GIGABYTE =>.Gigabyte
                  O43 - CFD: 24/02/2017 - D – C:\Program Files\Handbrake =>.Handbrake
                  O43 - CFD: 29/01/2017 - AD – C:\Program Files\Head Crusher
                  O43 - CFD: 10/02/2017 - [0] D – C:\Program Files\HitmanPro =>.EIDOS hitman Game
                  O43 - CFD: 25/12/2016 - D – C:\Program Files\HoRNet
                  O43 - CFD: 02/03/2016 - D – C:\Program Files\IK Multimedia =>.IK Multimedia
                  O43 - CFD: 27/01/2014 - D – C:\Program Files\Image-Line =>.Image-Line
                  O43 - CFD: 05/12/2016 - AD – C:\Program Files\Intel =>.Intel Corporation
                  O43 - CFD: 24/02/2015 - D – C:\Program Files\Intel Corporation =>.Intel Corporation
                  O43 - CFD: 11/01/2017 - D – C:\Program Files\Internet Explorer =>.Microsoft Corporation
                  O43 - CFD: 11/02/2017 - D – C:\Program Files\iPod =>.Apple Inc.®
                  O43 - CFD: 11/02/2017 - AD – C:\Program Files\iTunes =>.Apple Inc.
                  O43 - CFD: 15/02/2017 - D – C:\Program Files\iZotope =>.iZotope Inc
                  O43 - CFD: 20/02/2017 - D – C:\Program Files\Java =>.Oracle
                  O43 - CFD: 21/02/2017 - D – C:\Program Files\Joey Sturgis Tones
                  O43 - CFD: 23/12/2012 - AD – C:\Program Files\K-Lite Codec Pack x64
                  O43 - CFD: 24/12/2012 - D – C:\Program Files\Kazrog LLC
                  O43 - CFD: 03/08/2015 - D – C:\Program Files\Klanghelm
                  O43 - CFD: 20/12/2015 - D – C:\Program Files\Lexicon =>.Lexicon
                  O43 - CFD: 05/03/2014 - AD – C:\Program Files\Liquid Notes
                  O43 - CFD: 07/04/2016 - D – C:\Program Files\Litecoin
                  O43 - CFD: 09/01/2013 - D – C:\Program Files\Logitech =>.Logitech®
                  O43 - CFD: 01/03/2017 - D – C:\Program Files\Logitech Gaming Software =>.Logitech Inc®
                  O43 - CFD: 23/12/2012 - D – C:\Program Files\LopeSoft =>.LopeSoft
                  O43 - CFD: 23/12/2012 - D – C:\Program Files\M-Audio =>.M-Audio®
                  O43 - CFD: 11/02/2017 - D – C:\Program Files\Malwarebytes =>.Malwarebytes
                  O43 - CFD: 23/12/2012 - D – C:\Program Files\Mediafour =>.Mediafour
                  O43 - CFD: 30/08/2016 - D – C:\Program Files\MeldaProduction =>.MeldaProduction
                  O43 - CFD: 23/02/2017 - AD – C:\Program Files\MetaTrader 5 {00A74246F26ADF987743017FED54891570}
                  O43 - CFD: 31/10/2013 - D – C:\Program Files\Microsoft =>.Microsoft Corporation
                  O43 - CFD: 21/01/2013 - D – C:\Program Files\Microsoft Analysis Services =>.Microsoft Corporation
                  O43 - CFD: 21/01/2013 - AD – C:\Program Files\Microsoft Office =>.Microsoft Corporation
                  O43 - CFD: 21/01/2013 - D – C:\Program Files\Microsoft SQL Server =>.Microsoft Corporation
                  O43 - CFD: 17/11/2015 - AD – C:\Program Files\Microsoft SQL Server Compact Edition =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Program Files\Microsoft.NET =>.Microsoft Corporation
                  O43 - CFD: 12/08/2016 - D – C:\Program Files\MSBuild =>.Microsoft Corporation
                  O43 - CFD: 29/06/2016 - D – C:\Program Files\Native Instruments =>.Native Instruments
                  O43 - CFD: 25/12/2012 - AD – C:\Program Files\Nomad Factory =>.Nomad Factory
                  O43 - CFD: 25/06/2014 - D – C:\Program Files\NUGEN Audio =>.NuGen Audio
                  O43 - CFD: 10/02/2017 - D – C:\Program Files\NVIDIA Corporation =>.nVidia Corporation
                  O43 - CFD: 13/09/2015 - D – C:\Program Files\NyrvSystems =>.NYRV Systems
                  O43 - CFD: 13/04/2016 - D – C:\Program Files\Plogue {1121CE3F3440B5E7E5577DDCF47350154F74}
                  O43 - CFD: 17/04/2015 - D – C:\Program Files\Plugin Alliance =>.Plugin Alliance
                  O43 - CFD: 26/01/2013 - AD – C:\Program Files\Primo Ramdisk Server Edition =>.Romex Software
                  O43 - CFD: 11/02/2017 - D – C:\Program Files\Process Lasso =>.Bitsum LLC®
                  O43 - CFD: 26/12/2012 - D – C:\Program Files\ProgramExplorer =>.Microsoft Corporation®
                  O43 - CFD: 27/05/2013 - D – C:\Program Files\PSPaudioware
                  O43 - CFD: 11/08/2016 - D – C:\Program Files\Realtek =>.Realtek
                  O43 - CFD: 24/02/2017 - D – C:\Program Files\REAPER (x64)
                  O43 - CFD: 12/08/2016 - D – C:\Program Files\Reference Assemblies =>.Microsoft Corporation
                  O43 - CFD: 19/02/2017 - AD – C:\Program Files\RogueKiller =>.Adlice
                  O43 - CFD: 03/05/2016 - D – C:\Program Files\Scuffham Amps
                  O43 - CFD: 27/12/2012 - D – C:\Program Files\Shared
                  O43 - CFD: 31/10/2016 - D – C:\Program Files\Slate Digital =>.Slate Digital
                  O43 - CFD: 01/03/2017 - D – C:\Program Files\SoftEther VPN Client =>.SoftEther
                  O43 - CFD: 20/12/2015 - D – C:\Program Files\Softube
                  O43 - CFD: 02/12/2013 - D – C:\Program Files\Sonnox =>.INS Corporation
                  O43 - CFD: 19/12/2014 - D – C:\Program Files\Sound Radix
                  O43 - CFD: 27/05/2013 - D – C:\Program Files\Steinberg =>.Steinberg
                  O43 - CFD: 29/02/2016 - D – C:\Program Files\Sugar Bytes =>.Sugar Bytes
                  O43 - CFD: 11/08/2016 - D – C:\Program Files\Synaptics =>.Synaptics
                  O43 - CFD: 20/12/2015 - D – C:\Program Files\Synchro Arts Ltd
                  O43 - CFD: 24/04/2016 - D – C:\Program Files\Telestream =>.Telestream
                  O43 - CFD: 15/08/2016 - AD – C:\Program Files\TeraCopy =>.Code Sector Inc.
                  O43 - CFD: 29/12/2016 - D – C:\Program Files\ToneBoosters
                  O43 - CFD: 25/05/2013 - D – C:\Program Files\Unibrain =>.Unibrain
                  O43 - CFD: 26/07/2012 - [0] HD – C:\Program Files\Uninstall Information =>.Microsoft Corporation
                  O43 - CFD: 03/11/2016 - D – C:\Program Files\Universal Audio =>.RSA Security
                  O43 - CFD: 07/03/2014 - D – C:\Program Files\VB =>.Vincent Burel®
                  O43 - CFD: 07/03/2014 - D – C:\Program Files\Virtual Audio Cable =>.Muzychenko Evgenii Viktorovich®
                  O43 - CFD: 16/06/2016 - D – C:\Program Files\Voxengo =>.Voxengo®
                  O43 - CFD: 21/02/2017 - D – C:\Program Files\VS Revo Group =>.VS Revo Group
                  O43 - CFD: 15/02/2017 - AD – C:\Program Files\VSTPlugIns =>.VTS
                  O43 - CFD: 12/10/2015 - D – C:\Program Files\VSTPlugIns64
                  O43 - CFD: 29/06/2016 - AD – C:\Program Files\Webroot =>.Webroot
                  O43 - CFD: 14/09/2016 - RD – C:\Program Files\Windows Defender =>.Microsoft Corporation
                  O43 - CFD: 14/10/2016 - D – C:\Program Files\Windows Defender Advanced Threat Protection =>.Microsoft Corporation
                  O43 - CFD: 14/10/2016 - D – C:\Program Files\Windows Mail =>.Microsoft Corporation
                  O43 - CFD: 29/10/2016 - D – C:\Program Files\Windows Media Player =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files\Windows Multimedia Platform =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files\Windows NT =>.Microsoft Corporation
                  O43 - CFD: 14/10/2016 - D – C:\Program Files\Windows Photo Viewer =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files\Windows Portable Devices =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - SHD – C:\Program Files\Windows Sidebar =>.Microsoft Corporation
                  O43 - CFD: 25/02/2017 - HD – C:\Program Files\WindowsApps =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files\WindowsPowerShell =>.Microsoft Corporation
                  O43 - CFD: 31/10/2016 - AD – C:\Program Files\WinRAR =>.win.rar GmbH®
                  O43 - CFD: 26/11/2013 - AD – C:\Program Files\WinZip =>.WinZip Computing®
                  O43 - CFD: 06/12/2013 - D – C:\Program Files\WRData =>.Webroot
                  O43 - CFD: 22/11/2016 - D – C:\Program Files\Zynaptiq
                  O43 - CFD: 23/12/2012 - AD – C:\Program Files (x86)\Acronis =>.Acronis
                  O43 - CFD: 15/08/2016 - D – C:\Program Files (x86)\Adobe =>.Adobe Systems Incorporated®
                  O43 - CFD: 01/03/2017 - D – C:\Program Files (x86)\Adware Removal Tool by TSA =>.TSA Softwares
                  O43 - CFD: 18/12/2014 - D – C:\Program Files (x86)\Almageste
                  O43 - CFD: 02/04/2014 - D – C:\Program Files (x86)\Amazon =>.Amazon
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\AMD =>.AMD
                  O43 - CFD: 16/02/2017 - D – C:\Program Files (x86)\AnonVPN
                  O43 - CFD: 28/10/2013 - AD – C:\Program Files (x86)\Antares Audio Technologies =>.Antares Audio Technologies
                  O43 - CFD: 01/05/2016 - AD – C:\Program Files (x86)\Apple Software Update =>.Apple Inc.
                  O43 - CFD: 11/02/2014 - D – C:\Program Files (x86)\Applied Acoustics Systems =>.Applied Acoustics Systems
                  O43 - CFD: 13/02/2013 - D – C:\Program Files (x86)\Aqualab
                  O43 - CFD: 19/02/2014 - AD – C:\Program Files (x86)\ArcSoft =>.ArcSoft
                  O43 - CFD: 25/10/2016 - D – C:\Program Files (x86)\Arousor
                  O43 - CFD: 29/09/2013 - D – C:\Program Files (x86)\ASIO4ALL v2 =>.Michael Tippach
                  O43 - CFD: 07/01/2014 - D – C:\Program Files (x86)\ASUS =>.ASUSTeK Computer Inc.®
                  O43 - CFD: 26/09/2013 - AD – C:\Program Files (x86)\Atheros =>.Qualcomm Atheros
                  O43 - CFD: 22/11/2016 - D – C:\Program Files (x86)\atomicware =>.AtomicWare
                  O43 - CFD: 15/02/2017 - AD – C:\Program Files (x86)\Audacity =>.Audacity
                  O43 - CFD: 03/09/2013 - D – C:\Program Files (x86)\Audio Ease
                  O43 - CFD: 11/01/2015 - D – C:\Program Files (x86)\AVG =>.AVG Software
                  O43 - CFD: 15/08/2016 - D – C:\Program Files (x86)\Avid =>.Avid
                  O43 - CFD: 02/02/2017 - D – C:\Program Files (x86)\AVS4YOU =>.AVS4YOU
                  O43 - CFD: 11/09/2013 - D – C:\Program Files (x86)\BinarySense {4DF4EDF6C1282C4A94BCC190D56DC407} =>.BinarySense
                  O43 - CFD: 22/07/2015 - D – C:\Program Files (x86)\Carbonite {18455E6EF6D43CE1BB0C2DAC7DED3004} =>.Carbonite
                  O43 - CFD: 20/02/2016 - D – C:\Program Files (x86)\Celemony =>.Celemony
                  O43 - CFD: 12/09/2013 - D – C:\Program Files (x86)\Citrix =>.Citrix
                  O43 - CFD: 12/08/2016 - D – C:\Program Files (x86)\CMAK =>.Microsoft Corporation
                  O43 - CFD: 11/02/2017 - D – C:\Program Files (x86)\Common Files =>.Microsoft Corporation
                  O43 - CFD: 23/12/2012 - [0] D – C:\Program Files (x86)\Comodo =>.Comodo
                  O43 - CFD: 23/02/2013 - D – C:\Program Files (x86)\CP Control
                  O43 - CFD: 25/07/2015 - D – C:\Program Files (x86)\CrashPlan
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Creative =>.Creative
                  O43 - CFD: 15/02/2017 - AD – C:\Program Files (x86)\CrystalDiskInfo =>.Crystal Dew World
                  O43 - CFD: 08/08/2013 - D – C:\Program Files (x86)\Cytomic
                  O43 - CFD: 15/08/2016 - D – C:\Program Files (x86)\DAEMON Tools Lite =>.DAEMON Tools
                  O43 - CFD: 15/07/2015 - D – C:\Program Files (x86)\DDMF
                  O43 - CFD: 19/10/2013 - D – C:\Program Files (x86)\Diamond Cut Productions
                  O43 - CFD: 27/12/2012 - AD – C:\Program Files (x86)\Digidesign =>.Digidesign
                  O43 - CFD: 24/01/2015 - D – C:\Program Files (x86)\DiskInternals =>.DiskInternals Research
                  O43 - CFD: 25/02/2013 - AD – C:\Program Files (x86)\DisplayFusion =>.DisplayFusion
                  O43 - CFD: 23/12/2012 - AD – C:\Program Files (x86)\Ditto
                  O43 - CFD: 28/12/2014 - D – C:\Program Files (x86)\DivX =>.DivX
                  O43 - CFD: 23/03/2013 - D – C:\Program Files (x86)\DMG Audio
                  O43 - CFD: 12/05/2013 - D – C:\Program Files (x86)\DMGAudio
                  O43 - CFD: 27/01/2014 - D – C:\Program Files (x86)\DSPRobotics =>.DSPRobotics
                  O43 - CFD: 02/11/2013 - D – C:\Program Files (x86)\eBookConverter
                  O43 - CFD: 18/12/2016 - D – C:\Program Files (x86)\Electrum =>.Electrum
                  O43 - CFD: 17/02/2013 - AD – C:\Program Files (x86)\EMI
                  O43 - CFD: 17/02/2013 - D – C:\Program Files (x86)\EmpressPlugins
                  O43 - CFD: 30/12/2012 - D – C:\Program Files (x86)\ETRON =>.Etron
                  O43 - CFD: 28/08/2014 - D – C:\Program Files (x86)\FabFilter
                  O43 - CFD: 15/07/2015 - D – C:\Program Files (x86)\Fidelify
                  O43 - CFD: 26/01/2017 - AD – C:\Program Files (x86)\FileZilla FTP Client =>.Tim Kosse
                  O43 - CFD: 11/10/2015 - D – C:\Program Files (x86)\Finale NotePad 2012 =>.MakeMusic Inc.®
                  O43 - CFD: 16/05/2013 - D – C:\Program Files (x86)\FirefoxPortableLegacy36 {00932FC9AF0EFA79D8A3F771681FE20334}
                  O43 - CFD: 02/08/2015 - D – C:\Program Files (x86)\FlashGet Network =>.FlashGet
                  O43 - CFD: 22/11/2016 - D – C:\Program Files (x86)\Flux =>.Stereopsis
                  O43 - CFD: 27/12/2012 - D – C:\Program Files (x86)\Focusrite =>.Focusrite
                  O43 - CFD: 26/01/2013 - AD – C:\Program Files (x86)\Folder Marker =>.ArcticLine Software®
                  O43 - CFD: 30/12/2012 - D – C:\Program Files (x86)\Garmin =>.Garmin Ltd
                  O43 - CFD: 18/06/2013 - AD – C:\Program Files (x86)\Genwave
                  O43 - CFD: 11/08/2016 - D – C:\Program Files (x86)\GIGABYTE =>.Giga-Byte Technology®
                  O43 - CFD: 25/12/2012 - D – C:\Program Files (x86)\Gizmo =>.Gizmo Project
                  O43 - CFD: 23/01/2013 - AD – C:\Program Files (x86)\GIZMO2 {19916829E1150BF7B3AD8FD9347F76BA}
                  O43 - CFD: 20/01/2013 - AD – C:\Program Files (x86)\gnucash
                  O43 - CFD: 01/03/2017 - D – C:\Program Files (x86)\Google =>.Google Inc®
                  O43 - CFD: 15/02/2017 - D – C:\Program Files (x86)\Growl for Windows
                  O43 - CFD: 23/12/2012 - [0] D – C:\Program Files (x86)\GUM7E55.tmp
                  O43 - CFD: 08/01/2013 - D – C:\Program Files (x86)\HFSExplorer
                  O43 - CFD: 30/07/2013 - D – C:\Program Files (x86)\HOFA-Plugins
                  O43 - CFD: 15/02/2017 - D – C:\Program Files (x86)\HomeDev =>.HomeDev
                  O43 - CFD: 26/11/2015 - D – C:\Program Files (x86)\Hostless Modem =>.ZTE CORPORATION®
                  O43 - CFD: 05/02/2014 - D – C:\Program Files (x86)\Idolumic {00BB32180E894701C6DF225597E3F7A25E}
                  O43 - CFD: 11/11/2015 - D – C:\Program Files (x86)\IK Multimedia =>.IK Multimedia
                  O43 - CFD: 12/08/2016 - AD – C:\Program Files (x86)\iLok License Manager =>.PACE Anti-Piracy, Inc.®
                  O43 - CFD: 27/01/2014 - D – C:\Program Files (x86)\Image-Line =>.Image-Line
                  O43 - CFD: 31/03/2015 - D – C:\Program Files (x86)\Imploded Software {0F3D0100E3FF527E1E94810557B6E783}
                  O43 - CFD: 15/08/2016 - HD – C:\Program Files (x86)\InstallShield Installation Information =>.InstallShield Software
                  O43 - CFD: 19/10/2015 - D – C:\Program Files (x86)\Intel =>.Intel Corporation
                  O43 - CFD: 07/09/2015 - D – C:\Program Files (x86)\Intel Corporation =>.Intel Corporation
                  O43 - CFD: 11/01/2017 - D – C:\Program Files (x86)\Internet Explorer =>.Microsoft Corporation
                  O43 - CFD: 05/12/2016 - [0] D – C:\Program Files (x86)\IObit =>.IObit
                  O43 - CFD: 15/02/2017 - D – C:\Program Files (x86)\iZotope =>.iZotope Inc
                  O43 - CFD: 15/07/2015 - D – C:\Program Files (x86)\Jack
                  O43 - CFD: 20/02/2017 - D – C:\Program Files (x86)\Java =>.Oracle
                  O43 - CFD: 23/12/2012 - AD – C:\Program Files (x86)\K-Lite Codec Pack =>.KLite Inc
                  O43 - CFD: 24/02/2017 - AD – C:\Program Files (x86)\KDNicheFinder
                  O43 - CFD: 03/08/2014 - D – C:\Program Files (x86)\KDPublishingPro.com
                  O43 - CFD: 03/08/2014 - D – C:\Program Files (x86)\KDSubmitterPro.com
                  O43 - CFD: 19/05/2013 - D – C:\Program Files (x86)\Kush
                  O43 - CFD: 13/02/2013 - D – C:\Program Files (x86)\Link-AssistantCom
                  O43 - CFD: 30/11/2013 - D – C:\Program Files (x86)\Litecoin
                  O43 - CFD: 02/01/2014 - D – C:\Program Files (x86)\Logitech =>.Logitech, Inc.®
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\M-Audio =>.M-Audio®
                  O43 - CFD: 11/02/2017 - AD – C:\Program Files (x86)\Malwarebytes Anti-Malware =>.Malwarebytes
                  O43 - CFD: 15/06/2014 - [0] D – C:\Program Files (x86)\Malwarebytes’ Anti-Malware =>.Malwarebytes’ Anti-Malware
                  O43 - CFD: 14/04/2013 - AD – C:\Program Files (x86)\Market Samurai
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Marvell =>.Marvell
                  O43 - CFD: 20/05/2015 - D – C:\Program Files (x86)\Massey Plugins
                  O43 - CFD: 17/02/2013 - D – C:\Program Files (x86)\Mathew Lane
                  O43 - CFD: 05/11/2013 - AD – C:\Program Files (x86)\Maxthon =>.Maxthon
                  O43 - CFD: 29/10/2016 - D – C:\Program Files (x86)\McDSP
                  O43 - CFD: 19/02/2017 - D – C:\Program Files (x86)\Media Gobbler, Inc
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Mediafour {6FB31CAF7DD1D018473E68C3DC522A3F} =>.Mediafour
                  O43 - CFD: 21/01/2013 - D – C:\Program Files (x86)\Microsoft Analysis Services =>.Microsoft Corporation
                  O43 - CFD: 19/01/2016 - D – C:\Program Files (x86)\Microsoft ASP.NET =>.Microsoft Corporation
                  O43 - CFD: 21/01/2013 - D – C:\Program Files (x86)\Microsoft Office =>.Microsoft Corporation
                  O43 - CFD: 21/01/2013 - D – C:\Program Files (x86)\Microsoft SQL Server =>.Microsoft Corporation
                  O43 - CFD: 17/11/2015 - D – C:\Program Files (x86)\Microsoft SQL Server Compact Edition =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - AD – C:\Program Files (x86)\Microsoft.NET =>.Microsoft Corporation
                  O43 - CFD: 11/02/2017 - AD – C:\Program Files (x86)\Mozilla Firefox =>.Mozilla
                  O43 - CFD: 11/02/2017 - D – C:\Program Files (x86)\Mozilla Maintenance Service =>.Mozilla
                  O43 - CFD: 21/12/2015 - D – C:\Program Files (x86)\Mp3tag =>.Florian Heidenreich
                  O43 - CFD: 12/08/2016 - D – C:\Program Files (x86)\MSBuild =>.Microsoft Corporation
                  O43 - CFD: 28/10/2013 - D – C:\Program Files (x86)\MSECACHE =>.Microsoft Corporation
                  O43 - CFD: 18/02/2016 - D – C:\Program Files (x86)\MusicBrainz Picard =>.MusicBrainz Team
                  O43 - CFD: 22/08/2014 - D – C:\Program Files (x86)\Native Instruments =>.Native Instruments
                  O43 - CFD: 01/05/2013 - D – C:\Program Files (x86)\Neitsoft, Inc
                  O43 - CFD: 15/02/2017 - [0] D – C:\Program Files (x86)\NeoSmart Technologies =>.NeoSmart Technologies
                  O43 - CFD: 05/03/2014 - D – C:\Program Files (x86)\nerds.de =>.nerds.de
                  O43 - CFD: 23/12/2012 - AD – C:\Program Files (x86)\Nero =>.Ahead Corporation
                  O43 - CFD: 23/07/2013 - D – C:\Program Files (x86)\Nitro =>.Nitro
                  O43 - CFD: 24/01/2013 - D – C:\Program Files (x86)\NuGen Audio =>.NuGen Audio
                  O43 - CFD: 10/02/2017 - D – C:\Program Files (x86)\NVIDIA Corporation =>.nVidia Corporation
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\NVIDIA nTune Performance Application
                  O43 - CFD: 13/09/2015 - D – C:\Program Files (x86)\NYRV Systems =>.NYRV Systems
                  O43 - CFD: 13/09/2015 - D – C:\Program Files (x86)\NyrvSystems =>.NYRV Systems
                  O43 - CFD: 23/09/2016 - D – C:\Program Files (x86)\Output
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\PACE Anti-Piracy =>.PACE Anti-Piracy, Inc.®
                  O43 - CFD: 15/02/2017 - AD – C:\Program Files (x86)\PdaNet for Android =>.June Fabrics Technology Inc.
                  O43 - CFD: 01/03/2013 - D – C:\Program Files (x86)\Qualcomm Atheros =>.Qualcomm Atheros
                  O43 - CFD: 28/02/2013 - AD – C:\Program Files (x86)\Rapid SEO Tool {11210DFE920F3763B774D7BA7A6B587930C8}
                  O43 - CFD: 18/10/2015 - D – C:\Program Files (x86)\Realtek =>.Realtek
                  O43 - CFD: 24/05/2013 - D – C:\Program Files (x86)\REAPER =>.Cockos Incorporated
                  O43 - CFD: 12/08/2016 - D – C:\Program Files (x86)\Reference Assemblies =>.Microsoft Corporation
                  O43 - CFD: 24/02/2013 - D – C:\Program Files (x86)\Relab
                  O43 - CFD: 04/04/2015 - AD – C:\Program Files (x86)\Resource Hacker =>.Angus Johnson
                  O43 - CFD: 06/04/2013 - D – C:\Program Files (x86)\Room EQ Wizard V5
                  O43 - CFD: 23/02/2013 - D – C:\Program Files (x86)\Silabs =>.SiLabs
                  O43 - CFD: 11/02/2017 - RD – C:\Program Files (x86)\Skype =>.Skype
                  O43 - CFD: 24/12/2012 - D – C:\Program Files (x86)\Slate Digital =>.Slate Digital
                  O43 - CFD: 13/02/2016 - [0] D – C:\Program Files (x86)\Smart PC Solutions =>.Smart PC Solutions
                  O43 - CFD: 24/12/2012 - AD – C:\Program Files (x86)\Softube
                  O43 - CFD: 03/07/2013 - D – C:\Program Files (x86)\Solid State Logic =>.Solid State Logic
                  O43 - CFD: 24/12/2012 - AD – C:\Program Files (x86)\Sonalksis =>.Sonalksis
                  O43 - CFD: 12/11/2015 - D – C:\Program Files (x86)\Sonarworks
                  O43 - CFD: 06/11/2016 - D – C:\Program Files (x86)\SONiVOX =>.SONiVOX
                  O43 - CFD: 11/01/2015 - AD – C:\Program Files (x86)\Sonnox =>.INS Corporation
                  O43 - CFD: 06/07/2013 - D – C:\Program Files (x86)\Sonoris
                  O43 - CFD: 29/12/2015 - AD – C:\Program Files (x86)\SoundToys
                  O43 - CFD: 25/02/2014 - D – C:\Program Files (x86)\Spectrasonics =>.Spectrasonics
                  O43 - CFD: 16/08/2016 - D – C:\Program Files (x86)\SpeedFan =>.Almico Software
                  O43 - CFD: 14/08/2016 - AD – C:\Program Files (x86)\Steam =>.Steam Games
                  O43 - CFD: 24/12/2012 - D – C:\Program Files (x86)\Steinberg =>.Steinberg
                  O43 - CFD: 29/09/2013 - D – C:\Program Files (x86)\Suite Spot Studios
                  O43 - CFD: 07/11/2013 - D – C:\Program Files (x86)\Synchro Arts Ltd
                  O43 - CFD: 24/03/2013 - AD – C:\Program Files (x86)\SystemRequirementsLab =>.System Requirements Lab
                  O43 - CFD: 29/09/2013 - AD – C:\Program Files (x86)\TagRename
                  O43 - CFD: 17/02/2013 - D – C:\Program Files (x86)\TC Electronic =>.TC Electronic
                  O43 - CFD: 01/03/2017 - AD – C:\Program Files (x86)\TeamViewer =>.TeamViewer GmbH®
                  O43 - CFD: 27/06/2013 - D – C:\Program Files (x86)\TechSmith =>.TechSmith
                  O43 - CFD: 07/01/2014 - [0] HD – C:\Program Files (x86)\Temp =>.Microsoft Corporation
                  O43 - CFD: 10/10/2013 - AD – C:\Program Files (x86)\The KMPlayer =>.The KMPlayer Team
                  O43 - CFD: 15/02/2017 - D – C:\Program Files (x86)\Toshiba Corporation =>.Toshiba Corporation
                  O43 - CFD: 16/10/2013 - AD – C:\Program Files (x86)\Tracker {2B7213718E6165}
                  O43 - CFD: 28/02/2017 - AD – C:\Program Files (x86)\Tradeo - MetaTrader 4 {00A74246F26ADF987743017FED54891570}
                  O43 - CFD: 03/01/2013 - D – C:\Program Files (x86)\TurboTax
                  O43 - CFD: 20/02/2017 - D – C:\Program Files (x86)\Tweaking.com =>.Tweaking LLC®
                  O43 - CFD: 17/10/2013 - D – C:\Program Files (x86)\u-he
                  O43 - CFD: 06/01/2013 - D – C:\Program Files (x86)\Ubisoft =>.Ubisoft
                  O43 - CFD: 24/02/2017 - AD – C:\Program Files (x86)\UnHackMe =>.Greatis
                  O43 - CFD: 20/02/2017 - [0] HD – C:\Program Files (x86)\Uninstall Information =>.Microsoft Corporation
                  O43 - CFD: 05/06/2013 - D – C:\Program Files (x86)\Universal Audio =>.RSA Security
                  O43 - CFD: 26/02/2013 - AD – C:\Program Files (x86)\Universal Extractor =>.RSA Security
                  O43 - CFD: 17/02/2013 - AD – C:\Program Files (x86)\URS Plugins
                  O43 - CFD: 23/12/2012 - AD – C:\Program Files (x86)\uTorrent =>.BitTorrent Inc®
                  O43 - CFD: 07/03/2014 - D – C:\Program Files (x86)\VB =>.Vincent Burel®
                  O43 - CFD: 05/02/2014 - AD – C:\Program Files (x86)\VersePerfect
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\VideoLAN =>.VideoLan Team
                  O43 - CFD: 06/01/2017 - AD – C:\Program Files (x86)\VSTPlugIns =>.VTS
                  O43 - CFD: 12/10/2015 - D – C:\Program Files (x86)\VSTPlugIns64
                  O43 - CFD: 10/02/2017 - D – C:\Program Files (x86)\VulkanRT =>.LunarG, Inc
                  O43 - CFD: 24/12/2012 - D – C:\Program Files (x86)\Wave Arts
                  O43 - CFD: 23/11/2016 - AD – C:\Program Files (x86)\Waves =>.Waves
                  O43 - CFD: 15/02/2017 - D – C:\Program Files (x86)\WinDirStat =>.Seifert Systems
                  O43 - CFD: 14/09/2016 - D – C:\Program Files (x86)\Windows Defender =>.Microsoft Corporation
                  O43 - CFD: 28/10/2013 - D – C:\Program Files (x86)\Windows Installer Clean Up =>.Microsoft Corporation
                  O43 - CFD: 12/02/2014 - D – C:\Program Files (x86)\Windows Kits =>.Microsoft Corporation
                  O43 - CFD: 14/09/2016 - D – C:\Program Files (x86)\Windows Mail =>.Microsoft Corporation
                  O43 - CFD: 29/10/2016 - D – C:\Program Files (x86)\Windows Media Player =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files (x86)\Windows Multimedia Platform =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files (x86)\Windows NT =>.Microsoft Corporation
                  O43 - CFD: 14/10/2016 - D – C:\Program Files (x86)\Windows Photo Viewer =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files (x86)\Windows Portable Devices =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - SHD – C:\Program Files (x86)\Windows Sidebar =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Program Files (x86)\WindowsPowerShell =>.Microsoft Corporation
                  O43 - CFD: 11/02/2017 - AD – C:\Program Files (x86)\Zemana AntiMalware =>.Zemana
                  O43 - CFD: 25/09/2016 - D – C:\Program Files (x86)\Zynaptiq
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\112dB
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\7-Zip =>.Igor Pavlov
                  O43 - CFD: 01/03/2017 - RD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessibility =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - RD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories =>.Microsoft Corporation
                  O43 - CFD: 31/10/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acronis =>.Acronis
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AcusticaAudio
                  O43 - CFD: 01/03/2017 - RD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools =>.Administrative Tools
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Altiverb 7
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Antares Audio Technologies =>.Antares Audio Technologies
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Applied Acoustics Systems =>.Applied Acoustics Systems
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcSoft Portrait+ 3 =>.ArcSoft
                  O43 - CFD: 15/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ASUS =>.ASUS
                  O43 - CFD: 29/01/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Assault
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Audio Ease
                  O43 - CFD: 15/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avid =>.Avid
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVS4YOU =>.AVS4YOU
                  O43 - CFD: 06/01/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Black Rooster Audio
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Boz Digital Labs
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre 64bit - E-book Management =>.Kovid Goyal
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Carbonite =>.Carbonite
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner =>.Piriform Ltd
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Comodo =>.Comodo
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CP Control
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Creative =>.Creative
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CrystalDiskInfo =>.Crystal Dew World
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\cytomic
                  O43 - CFD: 23/11/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\D16 Group =>.D16 Group
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DAEMON Tools Lite =>.DAEMON Tools
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DDMF
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Diamond Cut Audio
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DiskInternals =>.DiskInternals Research
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DisplayFusion =>.DisplayFusion
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DivX =>.DivX
                  O43 - CFD: 26/12/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DMG Audio
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DragonDisk
                  O43 - CFD: 01/03/2017 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Booster 4 =>.IObit
                  O43 - CFD: 15/02/2016 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DriverMax =>.Innovative Solutions
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\East West Stormdrum Intakt
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Eiosis
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Empirical Labs
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Empty Room Systems
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Exponential Audio
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\FileZilla FTP Client =>.Tim Kosse
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Finale NotePad 2012
                  O43 - CFD: 22/11/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Flux =>.Stereopsis
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Folder Marker
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\G-Sonique =>.Games Software
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Genwave EQ
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GIGABYTE =>.Gigabyte
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GIZMO =>.Gizmo Project
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Talk
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Helium Audio Converter
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HFSExplorer
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HomeDev =>.HomeDev
                  O43 - CFD: 25/12/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HoRNet
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IK Multimedia =>.IK Multimedia
                  O43 - CFD: 01/03/2017 - RD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel =>.Intel Corporation
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Extreme Tuning Utility
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes =>.Apple Inc.
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IVGI
                  O43 - CFD: 15/02/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iZotope =>.iZotope Inc
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java =>.Oracle
                  O43 - CFD: 21/02/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Joey Sturgis Tones
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack =>.KLite Inc
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack x64
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kazrog LLC
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KD Niche Finder
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KDPublishingPro
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\KDSubmitterPro
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kong Audio
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Kush
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Link-AssistantCom
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Logitech =>.Logitech
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LoopBe30 - Internal MIDI Ports
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\M-Audio =>.M-Audio
                  O43 - CFD: 16/07/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Maintenance =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes =>.Malwarebytes
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McDSP
                  O43 - CFD: 30/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MeldaProduction =>.MeldaProduction
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Melodyne 3.2
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MetaTrader 5
                  O43 - CFD: 01/03/2017 - RD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office 2013 =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUC
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MJUCjr
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mobile Hotspot Admin
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox =>.Mozilla
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mp3tag =>.Florian Heidenreich
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments =>.Native Instruments
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Native Instruments Massive
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nero =>.Ahead Corporation
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NuGen Audio =>.NuGen Audio
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation =>.nVidia Corporation
                  O43 - CFD: 27/12/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Overloud =>.Overloud
                  O43 - CFD: 15/02/2016 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PCM Native Reverb Bundle
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Plogue
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Primo Ramdisk Server Edition =>.Romex Software
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Process Lasso
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PSPaudioware
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Python 3.3 =>.Python
                  O43 - CFD: 01/03/2017 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Rapid SEO Tool
                  O43 - CFD: 01/03/2017 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Real Hide IP
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\REAPER (x64)
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\reFX =>.reFX Audio Software Inc
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Resource Hacker =>.Angus Johnson
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Revo Uninstaller =>.VS Revo Group
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RogueKiller =>.Adlice
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Room EQ Wizard V5
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Scuffham Amps S-GEAR
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Skype =>.Skype
                  O43 - CFD: 31/10/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Slate Digital =>.Slate Digital
                  O43 - CFD: 10/02/2017 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Smart PC Solutions =>.Smart PC Solutions
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoftEther VPN Client =>.SoftEther
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonalksis =>.Sonalksis
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sonarworks
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SONiVOX =>.SONiVOX
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SoundRadix
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SSDlife
                  O43 - CFD: 01/03/2017 - RD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Steam =>.Steam Games
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Suite Spot Studios
                  O43 - CFD: 19/04/2014 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Sylenth1
                  O43 - CFD: 01/03/2017 - RD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools =>.Microsoft Corporation
                  O43 - CFD: 26/07/2012 - [0] RHD – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tablet PC =>.Wacom Technology
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tag&Rename =>.Evgeny S. Efimov
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TC Electronic =>.TC Electronic
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TechSmith =>.TechSmith
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Telestream =>.Telestream
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeraCopy =>.Code Sector Inc.
                  O43 - CFD: 29/12/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ToneBoosters
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tradeo - MetaTrader 4
                  O43 - CFD: 20/02/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tweaking.com =>.Tweaking.com
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UAD Powered Plug-Ins
                  O43 - CFD: 10/06/2014 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UltraChannel
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\UnHackMe =>.Greatis
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Unibrain ubCore
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VB Audio
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VersePerfect
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN =>.VideoLan Team
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Virtual Audio Cable
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Waves =>.Waves
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Webcam
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Webroot SecureAnywhere
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Kits =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR =>.WinRAR
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinZip =>.WinZip
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware =>.Zemana
                  O43 - CFD: 22/11/2016 - D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zynaptiq
                  O43 - CFD: 15/08/2016 - D – C:\ProgramData\34BE82C4-E596-4e99-A191-52C6199EBF69 =>.GEAR Software, Inc.
                  O43 - CFD: 28/11/2013 - D – C:\ProgramData\Ableton =>.Ableton
                  O43 - CFD: 31/10/2016 - AD – C:\ProgramData\Acronis =>.Acronis
                  O43 - CFD: 13/07/2013 - D – C:\ProgramData\Adobe =>.Adobe
                  O43 - CFD: 02/01/2013 - AD – C:\ProgramData\Antares Models
                  O43 - CFD: 15/08/2016 - D – C:\ProgramData\Apple =>.Apple Inc.
                  O43 - CFD: 31/10/2016 - D – C:\ProgramData\Apple Computer =>.Apple Inc.
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\ProgramData\Application Data =>.Microsoft Corporation
                  O43 - CFD: 25/06/2013 - D – C:\ProgramData\Application Support
                  O43 - CFD: 19/02/2014 - D – C:\ProgramData\ArcSoft =>.ArcSoft
                  O43 - CFD: 20/12/2015 - D – C:\ProgramData\Arturia =>.Arturia
                  O43 - CFD: 07/01/2014 - D – C:\ProgramData\ASUS =>.ASUS
                  O43 - CFD: 07/01/2014 - D – C:\ProgramData\ASUS OC Profiles
                  O43 - CFD: 16/06/2016 - D – C:\ProgramData\Audio Ease
                  O43 - CFD: 24/12/2016 - D – C:\ProgramData\AudioUTOPiA
                  O43 - CFD: 11/01/2015 - D – C:\ProgramData\AVAST Software =>.AVAST Software
                  O43 - CFD: 24/07/2015 - D – C:\ProgramData\AVG2015 =>.AVG Software
                  O43 - CFD: 15/08/2016 - D – C:\ProgramData\AVID =>.Avid
                  O43 - CFD: 22/12/2012 - D – C:\ProgramData\AVS4YOU =>.AVS4YOU
                  O43 - CFD: 02/01/2014 - D – C:\ProgramData\bdch =>.Softwin
                  O43 - CFD: 02/01/2014 - D – C:\ProgramData\BDLogging =>.Bitdefender
                  O43 - CFD: 25/02/2013 - D – C:\ProgramData\Binary Fortress Software =>.Binary Fortress Software
                  O43 - CFD: 30/12/2012 - D – C:\ProgramData\Binarysense =>.BinarySense
                  O43 - CFD: 06/11/2014 - D – C:\ProgramData\Bitdefender =>.Bitdefender
                  O43 - CFD: 28/02/2013 - D – C:\ProgramData\Blumentals
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\boost_interprocess =>.boost.org
                  O43 - CFD: 22/07/2015 - D – C:\ProgramData\Carbonite =>.Carbonite
                  O43 - CFD: 18/02/2014 - D – C:\ProgramData\CDSoundMaster
                  O43 - CFD: 17/05/2013 - D – C:\ProgramData\Celemony Software GmbH =>.Celemony Software GmbH
                  O43 - CFD: 11/01/2015 - HD – C:\ProgramData\Common Files =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - [0] D – C:\ProgramData\Comms =>.Microsoft Corporation
                  O43 - CFD: 23/12/2012 - D – C:\ProgramData\COMODO =>.Comodo
                  O43 - CFD: 25/07/2015 - D – C:\ProgramData\CrashPlan
                  O43 - CFD: 23/12/2012 - D – C:\ProgramData\Creative =>.Creative
                  O43 - CFD: 23/12/2012 - D – C:\ProgramData\Creative Labs =>.Creative Labs
                  O43 - CFD: 23/11/2016 - D – C:\ProgramData\D16 Group =>.D16 Group
                  O43 - CFD: 28/12/2012 - D – C:\ProgramData\DAEMON Tools Lite =>.DAEMON Tools
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\ProgramData\Desktop =>.Microsoft Corporation
                  O43 - CFD: 27/12/2012 - D – C:\ProgramData\DigiDriver
                  O43 - CFD: 28/12/2014 - D – C:\ProgramData\DivX =>.DivX
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\ProgramData\Documents =>.Microsoft Corporation
                  O43 - CFD: 29/10/2016 - D – C:\ProgramData\Eiosis
                  O43 - CFD: 17/02/2013 - D – C:\ProgramData\Empress Effects Inc
                  O43 - CFD: 31/10/2016 - D – C:\ProgramData\ExponentialAudio
                  O43 - CFD: 22/12/2012 - D – C:\ProgramData\FileOpen =>.FileOpen Systems Inc.
                  O43 - CFD: 23/06/2016 - D – C:\ProgramData\FLEXnet =>.Flexera Software
                  O43 - CFD: 28/03/2016 - D – C:\ProgramData\Flux =>.Stereopsis
                  O43 - CFD: 19/02/2017 - D – C:\ProgramData\Gobbler
                  O43 - CFD: 10/02/2017 - D – C:\ProgramData\HitmanPro =>.EIDOS hitman Game
                  O43 - CFD: 30/07/2013 - D – C:\ProgramData\HOFA
                  O43 - CFD: 08/01/2014 - [0] D – C:\ProgramData\IDM =>.IDM
                  O43 - CFD: 31/03/2015 - D – C:\ProgramData\Imploded Software
                  O43 - CFD: 18/10/2015 - D – C:\ProgramData\Intel =>.Intel Corporation
                  O43 - CFD: 10/01/2016 - D – C:\ProgramData\Intel Telemetry =>.Intel Corporation
                  O43 - CFD: 11/10/2016 - D – C:\ProgramData\Intel(R) Update Manager
                  O43 - CFD: 03/01/2013 - D – C:\ProgramData\Intuit =>.Intuit
                  O43 - CFD: 05/12/2016 - D – C:\ProgramData\IObit =>.IObit
                  O43 - CFD: 29/10/2016 - D – C:\ProgramData\Kush Audio
                  O43 - CFD: 11/09/2013 - D – C:\ProgramData\Licenses =>.Microsoft Corporation
                  O43 - CFD: 06/01/2014 - D – C:\ProgramData\LogiShrd =>.Logitech Inc.
                  O43 - CFD: 06/01/2014 - [0] D – C:\ProgramData\Logitech =>.Logitech
                  O43 - CFD: 07/01/2014 - D – C:\ProgramData\Logs =>.ABBYY Software
                  O43 - CFD: 18/03/2013 - D – C:\ProgramData\MAGIX =>.Magix
                  O43 - CFD: 11/10/2015 - D – C:\ProgramData\MakeMusic =>.MakeMusic
                  O43 - CFD: 11/02/2017 - D – C:\ProgramData\Malwarebytes =>.Malwarebytes
                  O43 - CFD: 01/03/2017 - [0] D – C:\ProgramData\Malwarebytes’ Anti-Malware (portable) =>.Malwarebytes
                  O43 - CFD: 23/12/2012 - AD – C:\ProgramData\Mediafour =>.Mediafour
                  O43 - CFD: 30/08/2016 - D – C:\ProgramData\MeldaProduction =>.MeldaProduction
                  O43 - CFD: 28/02/2017 - D – C:\ProgramData\MetaQuotes
                  O43 - CFD: 24/07/2015 - D – C:\ProgramData\MFAData =>.AVG Software
                  O43 - CFD: 13/02/2017 - ASD – C:\ProgramData\Microsoft =>.Microsoft Corporation
                  O43 - CFD: 15/06/2016 - D – C:\ProgramData\Microsoft Help =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\Microsoft OneDrive =>.Microsoft Corporation
                  O43 - CFD: 28/12/2012 - D – C:\ProgramData\Native Instruments =>.Native Instruments
                  O43 - CFD: 01/05/2013 - D – C:\ProgramData\Neitsoft
                  O43 - CFD: 23/12/2012 - AD – C:\ProgramData\Nero =>.Ahead Corporation
                  O43 - CFD: 22/12/2012 - D – C:\ProgramData\Nitro =>.Nitro
                  O43 - CFD: 10/02/2014 - [0] D – C:\ProgramData\Note
                  O43 - CFD: 01/03/2017 - [0] D – C:\ProgramData\NVIDIA =>.nVidia Corporation
                  O43 - CFD: 10/02/2017 - D – C:\ProgramData\NVIDIA Corporation =>.nVidia Corporation
                  O43 - CFD: 25/01/2016 - D – C:\ProgramData\Oracle =>.Oracle
                  O43 - CFD: 23/09/2016 - D – C:\ProgramData\Output
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Overloud =>.Overloud
                  O43 - CFD: 23/12/2012 - D – C:\ProgramData\PACE
                  O43 - CFD: 14/08/2016 - D – C:\ProgramData\PACE Anti-Piracy =>.PACE Anti-Piracy
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Package Cache =>.Microsoft Corporation
                  O43 - CFD: 17/04/2015 - D – C:\ProgramData\Plugin Alliance =>.Plugin Alliance
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\PRICache =>.Microsoft Corporation
                  O43 - CFD: 10/07/2013 - [0] D – C:\ProgramData\ProcessLasso
                  O43 - CFD: 06/07/2013 - D – C:\ProgramData\Qualcomm Atheros =>.Qualcomm Atheros
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\regid.1986-12.com.adobe =>.Adobe Inc.
                  O43 - CFD: 11/08/2016 - AD – C:\ProgramData\regid.1991-06.com.microsoft =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - AD – C:\ProgramData\regid.1995-08.com.techsmith =>.TechSmith Corporation
                  O43 - CFD: 24/02/2017 - [0] D – C:\ProgramData\RegRun =>.Greatis Software
                  O43 - CFD: 20/12/2015 - D – C:\ProgramData\Relab Development
                  O43 - CFD: 15/02/2016 - D – C:\ProgramData\RogueKiller =>.Adlice
                  O43 - CFD: 23/01/2013 - D – C:\ProgramData\Screentime =>.Screen Time Labs
                  O43 - CFD: 03/05/2016 - D – C:\ProgramData\Scuffham
                  O43 - CFD: 23/06/2016 - D – C:\ProgramData\Scuffham Amps
                  O43 - CFD: 23/12/2012 - SD – C:\ProgramData\Shared Space =>.Comodo
                  O43 - CFD: 11/02/2017 - D – C:\ProgramData\Skype =>.Skype
                  O43 - CFD: 08/02/2017 - D – C:\ProgramData\Slate Digital =>.Slate Digital
                  O43 - CFD: 29/03/2016 - D – C:\ProgramData\Sly-Fi
                  O43 - CFD: 16/07/2016 - [0] D – C:\ProgramData\SoftwareDistribution =>.Microsoft Corporation
                  O43 - CFD: 06/11/2016 - D – C:\ProgramData\SONiVOX =>.SONiVOX
                  O43 - CFD: 19/12/2014 - D – C:\ProgramData\SoundRadix
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\Spectrasonics =>.Spectrasonics
                  O43 - CFD: 24/06/2015 - D – C:\ProgramData\SP_FT_Logs
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\ProgramData\Start Menu =>.Microsoft Corporation
                  O43 - CFD: 30/06/2015 - D – C:\ProgramData\Steven Slate Drums
                  O43 - CFD: 21/02/2017 - D – C:\ProgramData\SupremoRemoteDesktop
                  O43 - CFD: 21/12/2015 - D – C:\ProgramData\SynchroArts
                  O43 - CFD: 27/06/2013 - AD – C:\ProgramData\TechSmith =>.TechSmith
                  O43 - CFD: 24/04/2016 - [0] D – C:\ProgramData\Telestream =>.Telestream
                  O43 - CFD: 07/01/2014 - [0] AD – C:\ProgramData\TEMP =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\ProgramData\Templates =>.Microsoft Corporation
                  O43 - CFD: 24/12/2012 - [0] D – C:\ProgramData\Temporary =>.Unknow
                  O43 - CFD: 15/02/2017 - D – C:\ProgramData\Toshiba Corporation =>.Toshiba Corporation
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\USOPrivate =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\ProgramData\USOShared =>.Microsoft Corporation
                  O43 - CFD: 17/02/2013 - D – C:\ProgramData\Valhalla DSP, LLC
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\ValhallaRoom
                  O43 - CFD: 18/02/2017 - D – C:\ProgramData\ValhallaUberMod
                  O43 - CFD: 09/01/2013 - D – C:\ProgramData\VST3 Presets
                  O43 - CFD: 23/11/2016 - D – C:\ProgramData\Waves Audio =>.Waves Audio Ltd
                  O43 - CFD: 26/11/2013 - D – C:\ProgramData\WinZip =>.WinZip
                  O43 - CFD: 01/03/2017 - D – C:\ProgramData\WRData =>.Webroot
                  O43 - CFD: 14/01/2017 - HDC – C:\ProgramData{0221FDDB-41E3-4971-AC93-5048F8D7CAAC}
                  O43 - CFD: 16/06/2016 - HDC – C:\ProgramData{03B61650-6A02-427E-8669-446D635453DD}
                  O43 - CFD: 16/06/2016 - [0] DC – C:\ProgramData{16F4DC45-A5B6-4C2D-98FE-551183B20EBB}
                  O43 - CFD: 16/06/2016 - HDC – C:\ProgramData{3AB18567-B5B8-472E-AEA5-E670C366B44A}
                  O43 - CFD: 16/06/2016 - HDC – C:\ProgramData{428A1995-5E0B-4921-A401-9CDC3FFF63BD}
                  O43 - CFD: 14/09/2016 - [0] DC – C:\ProgramData{6C0AC9FD-47AA-4173-94B1-36C8B94B75EF}
                  O43 - CFD: 16/06/2016 - HDC – C:\ProgramData{8248E23A-B811-474B-951C-5AD780E7F743}
                  O43 - CFD: 05/07/2016 - HDC – C:\ProgramData{8EBA5D59-992E-4FFF-85F5-7975D7358C55}
                  O43 - CFD: 16/06/2016 - HDC – C:\ProgramData{9A8C93DA-7DC1-47CF-AF41-88DCBF044907}
                  O43 - CFD: 16/06/2016 - HDC – C:\ProgramData{BD76B45E-45BE-4F37-8334-C8F16C9EEE15}
                  O43 - CFD: 14/12/2016 - HDC – C:\ProgramData{C0A56C90-63A5-498A-9F30-3E1C9B7A3718}
                  O43 - CFD: 18/10/2016 - HDC – C:\ProgramData{C1594E76-BF94-41B4-981C-492EEB97B049}
                  O43 - CFD: 16/06/2016 - HDC – C:\ProgramData{CF5889A7-BDDD-4A2B-A7EF-A24FFB4696A0}
                  O43 - CFD: 31/10/2016 - AD – C:\Program Files (x86)\Common Files\Acronis =>.Acronis
                  O43 - CFD: 08/06/2013 - AD – C:\Program Files (x86)\Common Files\Adobe =>.Adobe
                  O43 - CFD: 12/01/2017 - AD – C:\Program Files (x86)\Common Files\Adobe AIR =>.Adobe Inc.
                  O43 - CFD: 15/08/2016 - D – C:\Program Files (x86)\Common Files\Apple =>.Apple Inc.
                  O43 - CFD: 19/02/2014 - D – C:\Program Files (x86)\Common Files\ArcSoft =>.ArcSoft
                  O43 - CFD: 06/02/2013 - D – C:\Program Files (x86)\Common Files\Articulate =>.Articulate
                  O43 - CFD: 24/12/2012 - AD – C:\Program Files (x86)\Common Files\Avid =>.Avid
                  O43 - CFD: 02/02/2017 - D – C:\Program Files (x86)\Common Files\AVSMedia =>.AVSMedia
                  O43 - CFD: 20/02/2016 - D – C:\Program Files (x86)\Common Files\Celemony =>.Celemony
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Common Files\Creative Labs Shared =>.Creative Labs
                  O43 - CFD: 27/12/2012 - D – C:\Program Files (x86)\Common Files\Digidesign =>.Digidesign
                  O43 - CFD: 28/12/2014 - D – C:\Program Files (x86)\Common Files\DivX Shared =>.DivX
                  O43 - CFD: 22/06/2013 - [0] D – C:\Program Files (x86)\Common Files\eSellerate =>.eSellerate
                  O43 - CFD: 23/11/2016 - D – C:\Program Files (x86)\Common Files\Flux =>.Stereopsis
                  O43 - CFD: 07/01/2014 - D – C:\Program Files (x86)\Common Files\InstallShield =>.InstallShield
                  O43 - CFD: 12/05/2015 - D – C:\Program Files (x86)\Common Files\Intel =>.Intel Corporation
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Common Files\Intel Corporation =>.Intel Corporation
                  O43 - CFD: 10/02/2017 - D – C:\Program Files (x86)\Common Files\Java =>.Oracle
                  O43 - CFD: 11/08/2016 - AD – C:\Program Files (x86)\Common Files\logishrd =>.Logitech Inc.
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Common Files\Macrovision Shared =>.Rovi Corporation
                  O43 - CFD: 04/04/2015 - D – C:\Program Files (x86)\Common Files\McDSP
                  O43 - CFD: 23/12/2012 - AD – C:\Program Files (x86)\Common Files\Mediafour =>.Mediafour
                  O43 - CFD: 12/08/2016 - AD – C:\Program Files (x86)\Common Files\Microsoft Shared =>.Microsoft Corporation
                  O43 - CFD: 04/02/2014 - AD – C:\Program Files (x86)\Common Files\Native Instruments =>.Native Instruments
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Common Files\Nero =>.Ahead Corporation
                  O43 - CFD: 23/07/2013 - D – C:\Program Files (x86)\Common Files\Nitro =>.Nitro
                  O43 - CFD: 25/06/2014 - D – C:\Program Files (x86)\Common Files\NUGEN Audio =>.NuGen Audio
                  O43 - CFD: 19/02/2017 - AD – C:\Program Files (x86)\Common Files\PACE
                  O43 - CFD: 24/12/2012 - D – C:\Program Files (x86)\Common Files\PACE Anti-Piracy =>.PACE Anti-Piracy
                  O43 - CFD: 23/12/2012 - D – C:\Program Files (x86)\Common Files\postureAgent =>.Microsoft Corporation
                  O43 - CFD: 08/01/2013 - D – C:\Program Files (x86)\Common Files\Propellerhead Software =>.Propellerhead Software AB
                  O43 - CFD: 16/07/2016 - D – C:\Program Files (x86)\Common Files\Services =>.Microsoft Corporation
                  O43 - CFD: 11/02/2017 - AD – C:\Program Files (x86)\Common Files\Skype =>.Skype
                  O43 - CFD: 02/12/2013 - D – C:\Program Files (x86)\Common Files\Sonnox =>.INS Corporation
                  O43 - CFD: 12/11/2015 - AD – C:\Program Files (x86)\Common Files\Soraco
                  O43 - CFD: 08/01/2013 - D – C:\Program Files (x86)\Common Files\SoundToys
                  O43 - CFD: 01/08/2016 - D – C:\Program Files (x86)\Common Files\Steam =>.Steam Games
                  O43 - CFD: 04/04/2015 - D – C:\Program Files (x86)\Common Files\Steinberg =>.Steinberg
                  O43 - CFD: 15/12/2016 - AD – C:\Program Files (x86)\Common Files\System =>.Microsoft Corporation
                  O43 - CFD: 27/06/2013 - D – C:\Program Files (x86)\Common Files\TechSmith Shared =>.TechSmith
                  O43 - CFD: 17/10/2013 - [0] D – C:\Program Files (x86)\Common Files\Tmp =>.Legitimate
                  O43 - CFD: 28/10/2013 - D – C:\Program Files (x86)\Common Files\VST2
                  O43 - CFD: 23/11/2016 - AD – C:\Program Files (x86)\Common Files\VST3
                  O43 - CFD: 25/03/2016 - D – C:\Program Files (x86)\Common Files\Webroot =>.Webroot
                  O43 - CFD: 23/11/2016 - D – C:\Program Files (x86)\Common Files\WPAPI
                  O43 - CFD: 30/04/2013 - D – C:\Users\SamSwanson\AppData\Roaming\2C-Audio
                  O43 - CFD: 28/11/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Ableton =>.Ableton
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Acronis =>.Acronis
                  O43 - CFD: 13/07/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Adobe =>.Adobe
                  O43 - CFD: 13/09/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Agent
                  O43 - CFD: 29/10/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Antares =>.Antares Audio Technologies
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Apple Computer =>.Apple Inc.
                  O43 - CFD: 25/06/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Application Support
                  O43 - CFD: 11/02/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Applied Acoustics Systems =>.Applied Acoustics Systems
                  O43 - CFD: 19/02/2014 - D – C:\Users\SamSwanson\AppData\Roaming\ArcSoft =>.ArcSoft
                  O43 - CFD: 26/01/2013 - D – C:\Users\SamSwanson\AppData\Roaming\ArcticLine =>.ArcticLine
                  O43 - CFD: 06/02/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Articulate =>.Articulate
                  O43 - CFD: 03/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Audacity =>.Audacity
                  O43 - CFD: 03/09/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Audio Ease
                  O43 - CFD: 16/06/2016 - D – C:\Users\SamSwanson\AppData\Roaming\AudioEase
                  O43 - CFD: 11/01/2015 - D – C:\Users\SamSwanson\AppData\Roaming\AVG2015 =>.AVG Software
                  O43 - CFD: 12/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Avid =>.Avid
                  O43 - CFD: 02/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\AVS4YOU =>.AVS4YOU
                  O43 - CFD: 04/08/2015 - D – C:\Users\SamSwanson\AppData\Roaming\BITS =>.BITS
                  O43 - CFD: 06/01/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Black Rooster Audio
                  O43 - CFD: 24/09/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Blue Cat Audio =>.Blue Cat Audio
                  O43 - CFD: 17/02/2016 - D – C:\Users\SamSwanson\AppData\Roaming\bwfmetaedit
                  O43 - CFD: 27/07/2014 - D – C:\Users\SamSwanson\AppData\Roaming\calibre =>.Kovid Goyal
                  O43 - CFD: 09/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Celemony Software GmbH =>.Celemony Software GmbH
                  O43 - CFD: 17/10/2013 - D – C:\Users\SamSwanson\AppData\Roaming\com.elance.tra cker
                  O43 - CFD: 13/09/2015 - D – C:\Users\SamSwanson\AppData\Roaming\com.NyrvSystem s.NyrvAgent
                  O43 - CFD: 08/05/2015 - D – C:\Users\SamSwanson\AppData\Roaming\com.sonible.fr eiraum
                  O43 - CFD: 21/02/2013 - SHD – C:\Users\SamSwanson\AppData\Roaming\Common =>.Microsoft Corporation
                  O43 - CFD: 13/09/2015 - D – C:\Users\SamSwanson\AppData\Roaming\CommonResource s
                  O43 - CFD: 15/02/2017 - AD – C:\Users\SamSwanson\AppData\Roaming\Copy
                  O43 - CFD: 18/12/2014 - D – C:\Users\SamSwanson\AppData\Roaming\CrashPlan
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Creative =>.Creative
                  O43 - CFD: 02/06/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Cyberduck
                  O43 - CFD: 21/08/2014 - SHD – C:\Users\SamSwanson\AppData\Roaming\Cyberduck Updater AU
                  O43 - CFD: 21/02/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Cytomic
                  O43 - CFD: 23/11/2016 - D – C:\Users\SamSwanson\AppData\Roaming\D16 Group =>.D16 Group
                  O43 - CFD: 14/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\DAEMON Tools Lite =>.DAEMON Tools
                  O43 - CFD: 22/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Dashlane =>.Dashlane
                  O43 - CFD: 19/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\DDMF Effect Rack
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Dexpot
                  O43 - CFD: 04/01/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Dextronet
                  O43 - CFD: 27/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Digidesign =>.Digidesign
                  O43 - CFD: 20/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\DisplayFusion =>.DisplayFusion
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Ditto
                  O43 - CFD: 28/12/2014 - D – C:\Users\SamSwanson\AppData\Roaming\DivX =>.DivX
                  O43 - CFD: 25/08/2015 - [0] D – C:\Users\SamSwanson\AppData\Roaming\DMCache =>.DMCache
                  O43 - CFD: 31/01/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Doblon =>.Doblon
                  O43 - CFD: 23/07/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Downloaded Installations =>.Microsoft Corporation
                  O43 - CFD: 06/11/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Dropbox =>.Dropbox
                  O43 - CFD: 22/04/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Drumatom
                  O43 - CFD: 21/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Electrum =>.Electrum
                  O43 - CFD: 31/10/2016 - D – C:\Users\SamSwanson\AppData\Roaming\ExponentialAud io
                  O43 - CFD: 14/09/2015 - D – C:\Users\SamSwanson\AppData\Roaming\FabFilter
                  O43 - CFD: 15/07/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Fidelify
                  O43 - CFD: 22/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\FileOpen =>.FileOpen Systems Inc.
                  O43 - CFD: 24/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\FileZilla =>.FileZilla
                  O43 - CFD: 02/08/2015 - [0] D – C:\Users\SamSwanson\AppData\Roaming\FlashgetSetup
                  O43 - CFD: 27/01/2014 - D – C:\Users\SamSwanson\AppData\Roaming\FlowStone =>.DSPRobotics
                  O43 - CFD: 22/11/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Flux =>.Stereopsis
                  O43 - CFD: 15/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\FreshDiagnose
                  O43 - CFD: 30/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Garmin =>.Garmin Ltd
                  O43 - CFD: 25/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Gizmo =>.Gizmo Project
                  O43 - CFD: 02/01/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Glitchmachines
                  O43 - CFD: 31/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\HandBrake =>.Handbrake
                  O43 - CFD: 31/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\HandBrake Team =>.HandBrake Team
                  O43 - CFD: 30/07/2013 - D – C:\Users\SamSwanson\AppData\Roaming\HOFA
                  O43 - CFD: 02/03/2016 - D – C:\Users\SamSwanson\AppData\Roaming\IK Multimedia =>.IK Multimedia
                  O43 - CFD: 27/01/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Image-Line =>.Image-Line
                  O43 - CFD: 31/03/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Imploded Software
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\InstallShield =>.InstallShield
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Intel Corporation =>.Intel Corporation
                  O43 - CFD: 03/01/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Intuit =>.Intuit
                  O43 - CFD: 05/12/2016 - D – C:\Users\SamSwanson\AppData\Roaming\IObit =>.IObit
                  O43 - CFD: 24/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\iZotope =>.iZotope Inc
                  O43 - CFD: 31/01/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Karaoke Builder
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Kazrog LLC
                  O43 - CFD: 11/09/2014 - [0] D – C:\Users\SamSwanson\AppData\Roaming\KDPublishingPr o
                  O43 - CFD: 03/08/2014 - D – C:\Users\SamSwanson\AppData\Roaming\KDSubmitterPro
                  O43 - CFD: 25/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Leadertech =>.Leadertech Systems
                  O43 - CFD: 08/01/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Lexicon PCM Native
                  O43 - CFD: 07/05/2015 - D – C:\Users\SamSwanson\AppData\Roaming\liptikl
                  O43 - CFD: 07/04/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Litecoin
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Logishrd =>.Logitech Inc.
                  O43 - CFD: 12/02/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Logitech =>.Logitech
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Macromedia =>.Macromedia
                  O43 - CFD: 11/10/2015 - D – C:\Users\SamSwanson\AppData\Roaming\MakeMusic =>.MakeMusic
                  O43 - CFD: 15/06/2014 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Malwarebytes =>.Malwarebytes
                  O43 - CFD: 05/11/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Maxthon3 =>.Maxthon International Ltd
                  O43 - CFD: 19/09/2012 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Media Center Programs =>.Microsoft Corporation
                  O43 - CFD: 30/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\MeldaProductio n =>.MeldaProduction
                  O43 - CFD: 23/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\MetaQuotes
                  O43 - CFD: 10/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\mgyun =>.mgyun.com
                  O43 - CFD: 11/08/2016 - SD – C:\Users\SamSwanson\AppData\Roaming\Microsoft =>.Microsoft Corporation
                  O43 - CFD: 22/05/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Mozilla =>.Mozilla Corporation
                  O43 - CFD: 24/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Mp3tag =>.Florian Heidenreich
                  O43 - CFD: 11/10/2015 - D – C:\Users\SamSwanson\AppData\Roaming\MuseScore =>.MusE
                  O43 - CFD: 18/02/2016 - D – C:\Users\SamSwanson\AppData\Roaming\MusicBrainz =>.MusicBrainz
                  O43 - CFD: 03/04/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Nero =>.Ahead Corporation
                  O43 - CFD: 22/03/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Nitro =>.Nitro
                  O43 - CFD: 22/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Nitro PDF =>.Nitro PDF
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Nomad Factory =>.Nomad Factory
                  O43 - CFD: 10/04/2016 - D – C:\Users\SamSwanson\AppData\Roaming\NUGEN Audio =>.NuGen Audio
                  O43 - CFD: 11/04/2013 - D – C:\Users\SamSwanson\AppData\Roaming\NVIDIA =>.nVidia Corporation
                  O43 - CFD: 13/09/2015 - D – C:\Users\SamSwanson\AppData\Roaming\NyrvSystems =>.NYRV Systems
                  O43 - CFD: 23/09/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Output
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Overloud =>.Overloud
                  O43 - CFD: 14/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\PACE Anti-Piracy =>.PACE Anti-Piracy
                  O43 - CFD: 01/01/2015 - D – C:\Users\SamSwanson\AppData\Roaming\parallax-audio
                  O43 - CFD: 09/05/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Plogue
                  O43 - CFD: 13/04/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Plogue Art et Technologie, Inc
                  O43 - CFD: 04/04/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Plugin Alliance =>.Plugin Alliance
                  O43 - CFD: 15/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\ProcessLasso
                  O43 - CFD: 12/01/2015 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Publish Providers =>.Unknow
                  O43 - CFD: 02/01/2014 - [0] D – C:\Users\SamSwanson\AppData\Roaming\QuickScan =>.Bitdefender
                  O43 - CFD: 25/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\REAPER =>.Cockos Incorporated
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Recabinet3Pres ets
                  O43 - CFD: 11/02/2014 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Rhyme Genie
                  O43 - CFD: 13/06/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Sample Magic
                  O43 - CFD: 11/10/2015 - D – C:\Users\SamSwanson\AppData\Roaming\ScoreCloud
                  O43 - CFD: 11/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Skype =>.Skype
                  O43 - CFD: 21/07/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Slack =>.Slack Technologies
                  O43 - CFD: 20/12/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Slate Digital =>.Slate Digital
                  O43 - CFD: 10/02/2017 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Smart PC Solutions =>.Smart PC Solutions
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Sonalksis =>.Sonalksis
                  O43 - CFD: 12/11/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Sonarworks
                  O43 - CFD: 02/12/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Sonnox =>.INS Corporation
                  O43 - CFD: 06/07/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Sonoris_Master ing_Compressor
                  O43 - CFD: 11/01/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Sony =>.Sony
                  O43 - CFD: 12/01/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Sony Creative Software Inc =>.Sony Corporation
                  O43 - CFD: 21/07/2014 - D – C:\Users\SamSwanson\AppData\Roaming\Spiritsoft
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\SPL Plug-Ins
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Spotify =>.Spotify
                  O43 - CFD: 03/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\ssd_sampler
                  O43 - CFD: 01/09/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Sun =>.Oracle
                  O43 - CFD: 20/12/2015 - D – C:\Users\SamSwanson\AppData\Roaming\SynchroArts
                  O43 - CFD: 11/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\TeamViewer =>.TeamViewer
                  O43 - CFD: 01/09/2016 - D – C:\Users\SamSwanson\AppData\Roaming\TechSmith =>.TechSmith
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\TeraCopy =>.Code Sector Inc.
                  O43 - CFD: 14/01/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Toneboosters
                  O43 - CFD: 02/07/2013 - D – C:\Users\SamSwanson\AppData\Roaming\tor =>.Tor
                  O43 - CFD: 15/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Toshiba Corporation =>.Toshiba Corporation
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Trigger
                  O43 - CFD: 16/06/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Trigger2
                  O43 - CFD: 12/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Trillium Lane
                  O43 - CFD: 05/02/2014 - [0] D – C:\Users\SamSwanson\AppData\Roaming\TuneSmith
                  O43 - CFD: 11/01/2015 - D – C:\Users\SamSwanson\AppData\Roaming\TuneUp Software =>.TuneUp Software
                  O43 - CFD: 03/11/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Universal Audio =>.RSA Security
                  O43 - CFD: 17/02/2013 - D – C:\Users\SamSwanson\AppData\Roaming\Valhalla DSP, LLC
                  O43 - CFD: 27/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\ValhallaRoom
                  O43 - CFD: 17/02/2013 - D – C:\Users\SamSwanson\AppData\Roaming\ValhallaUberMo d
                  O43 - CFD: 24/04/2016 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Vara Software
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\vlc =>.VideoLan Team
                  O43 - CFD: 16/10/2013 - D – C:\Users\SamSwanson\AppData\Roaming\VoiCode
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Roaming\Voxengo =>.Voxengo
                  O43 - CFD: 13/08/2015 - D – C:\Users\SamSwanson\AppData\Roaming\VST3 Presets
                  O43 - CFD: 11/12/2015 - D – C:\Users\SamSwanson\AppData\Roaming\Waves Audio =>.Waves Audio Ltd
                  O43 - CFD: 06/07/2013 - D – C:\Users\SamSwanson\AppData\Roaming\WinBatch =>.winbatch.com
                  O43 - CFD: 05/12/2013 - D – C:\Users\SamSwanson\AppData\Roaming\WinRAR =>.WinRAR
                  O43 - CFD: 24/04/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Wirecast Play
                  O43 - CFD: 08/03/2013 - D – C:\Users\SamSwanson\AppData\Roaming\WSCC2
                  O43 - CFD: 07/01/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Xfer
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\ZHP =>.Nicolas Coolman
                  O43 - CFD: 22/11/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Zynaptiq
                  O43 - CFD: 10/07/2015 - D – C:\Users\SamSwanson\AppData\Local\112dB
                  O43 - CFD: 23/10/2016 - HD – C:\Users\SamSwanson\AppData\Local\7e6o4rLRYCc7H
                  O43 - CFD: 12/08/2016 - HD – C:\Users\SamSwanson\AppData\Local\7yk7MNqz
                  O43 - CFD: 29/01/2017 - D – C:\Users\SamSwanson\AppData\Local\Adobe =>.Adobe
                  O43 - CFD: 06/12/2016 - D – C:\Users\SamSwanson\AppData\Local\Albion
                  O43 - CFD: 29/04/2014 - D – C:\Users\SamSwanson\AppData\Local\Alexa
                  O43 - CFD: 05/08/2015 - D – C:\Users\SamSwanson\AppData\Local\Amazon =>.Amazon
                  O43 - CFD: 12/08/2016 - D – C:\Users\SamSwanson\AppData\Local\AnonVPN
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Local\Apple =>.Apple Inc.
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Local\Apple Computer =>.Apple Inc.
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\SamSwanson\AppData\Local\Application Data =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Local\Apps =>.Microsoft Corporation
                  O43 - CFD: 19/02/2014 - D – C:\Users\SamSwanson\AppData\Local\ArcSoft =>.ArcSoft
                  O43 - CFD: 06/02/2013 - D – C:\Users\SamSwanson\AppData\Local\Articulate =>.Articulate
                  O43 - CFD: 16/09/2016 - D – C:\Users\SamSwanson\AppData\Local\Audacity =>.Audacity
                  O43 - CFD: 22/05/2015 - D – C:\Users\SamSwanson\AppData\Local\Avg =>.AVG Software
                  O43 - CFD: 11/01/2015 - D – C:\Users\SamSwanson\AppData\Local\Avg2015 =>.AVG Software
                  O43 - CFD: 15/08/2016 - D – C:\Users\SamSwanson\AppData\Local\Avid =>.Avid
                  O43 - CFD: 02/01/2014 - D – C:\Users\SamSwanson\AppData\Local\bdch =>.Softwin
                  O43 - CFD: 28/02/2013 - D – C:\Users\SamSwanson\AppData\Local\Blumentals
                  O43 - CFD: 09/02/2017 - D – C:\Users\SamSwanson\AppData\Local\boost_interproce ss =>.boost.org
                  O43 - CFD: 27/07/2014 - [0] D – C:\Users\SamSwanson\AppData\Local\calibre-cache =>.Kovid Goyal
                  O43 - CFD: 03/08/2015 - D – C:\Users\SamSwanson\AppData\Local\CEF =>.CEF
                  O43 - CFD: 15/02/2017 - D – C:\Users\SamSwanson\AppData\Local\Citrix =>.Citrix
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Local\Comms =>.Microsoft Corporation
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Local\Comodo =>.Comodo
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Local\ConnectedDevices Platform =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Local\CrashDumps =>.Microsoft Corporation
                  O43 - CFD: 17/01/2013 - D – C:\Users\SamSwanson\AppData\Local\DDMSettings
                  O43 - CFD: 13/02/2017 - D – C:\Users\SamSwanson\AppData\Local\Diagnostics =>.Microsoft Corporation
                  O43 - CFD: 18/10/2016 - D – C:\Users\SamSwanson\AppData\Local\Disc_Soft_Ltd =>.Disc Soft Ltd
                  O43 - CFD: 17/11/2015 - D – C:\Users\SamSwanson\AppData\Local\Downloaded Installations =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Local\ESET =>.ESET
                  O43 - CFD: 05/02/2014 - D – C:\Users\SamSwanson\AppData\Local\FileMaker
                  O43 - CFD: 25/12/2016 - D – C:\Users\SamSwanson\AppData\Local\FileZilla =>.FileZilla
                  O43 - CFD: 17/10/2013 - D – C:\Users\SamSwanson\AppData\Local\FluxSoftware =>.Stereopsis
                  O43 - CFD: 23/01/2013 - D – C:\Users\SamSwanson\AppData\Local\GIZMO2
                  O43 - CFD: 02/10/2013 - D – C:\Users\SamSwanson\AppData\Local\Gobbler
                  O43 - CFD: 25/10/2016 - D – C:\Users\SamSwanson\AppData\Local\Google =>.Google
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\SamSwanson\AppData\Local\History =>.Microsoft Corporation
                  O43 - CFD: 15/02/2017 - D – C:\Users\SamSwanson\AppData\Local\HomeDev =>.HomeDev
                  O43 - CFD: 29/11/2013 - D – C:\Users\SamSwanson\AppData\Local\Intel =>.Intel Corporation
                  O43 - CFD: 03/01/2013 - D – C:\Users\SamSwanson\AppData\Local\IsolatedStorage =>.id Software
                  O43 - CFD: 14/08/2016 - D – C:\Users\SamSwanson\AppData\Local\Ivideon
                  O43 - CFD: 22/06/2016 - D – C:\Users\SamSwanson\AppData\Local\join.me =>.LogMeIn Entreprise
                  O43 - CFD: 15/02/2017 - [0] D – C:\Users\SamSwanson\AppData\Local\JxBrowser
                  O43 - CFD: 17/11/2015 - D – C:\Users\SamSwanson\AppData\Local\KBL_Media
                  O43 - CFD: 09/01/2013 - D – C:\Users\SamSwanson\AppData\Local\Logishrd =>.Logitech Inc.
                  O43 - CFD: 09/01/2013 - D – C:\Users\SamSwanson\AppData\Local\Logitech =>.Logitech
                  O43 - CFD: 02/01/2014 - D – C:\Users\SamSwanson\AppData\Local\Logitech® Webcam Software =>.Logitech Inc.
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Local\logs =>.ABBYY Software
                  O43 - CFD: 02/01/2014 - D – C:\Users\SamSwanson\AppData\Local\lptmp1274216945
                  O43 - CFD: 12/12/2013 - D – C:\Users\SamSwanson\AppData\Local\lptmp345652723
                  O43 - CFD: 27/07/2013 - D – C:\Users\SamSwanson\AppData\Local\Macromedia =>.Macromedia
                  O43 - CFD: 06/08/2015 - D – C:\Users\SamSwanson\AppData\Local\Media_Gobbler,_I nc
                  O43 - CFD: 26/12/2016 - D – C:\Users\SamSwanson\AppData\Local\Metropolis Ark 2
                  O43 - CFD: 11/01/2015 - D – C:\Users\SamSwanson\AppData\Local\MFAData =>.AVG Software
                  O43 - CFD: 20/02/2017 - D – C:\Users\SamSwanson\AppData\Local\Microsoft =>.Microsoft Corporation
                  O43 - CFD: 21/01/2013 - [0] D – C:\Users\SamSwanson\AppData\Local\Microsoft Help =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Local\MicrosoftEdge =>.Microsoft Corporation
                  O43 - CFD: 01/03/2013 - D – C:\Users\SamSwanson\AppData\Local\Mozilla =>.Mozilla Corporation
                  O43 - CFD: 11/10/2015 - D – C:\Users\SamSwanson\AppData\Local\MuseScore =>.MusE
                  O43 - CFD: 18/02/2016 - D – C:\Users\SamSwanson\AppData\Local\MusicBrainz =>.MusicBrainz
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Local\My Games =>.My Games
                  O43 - CFD: 31/01/2014 - D – C:\Users\SamSwanson\AppData\Local\Native Instruments =>.Native Instruments
                  O43 - CFD: 12/02/2014 - D – C:\Users\SamSwanson\AppData\Local\NeoSmart_Technol ogies =>.NeoSmart Technologies
                  O43 - CFD: 29/12/2012 - D – C:\Users\SamSwanson\AppData\Local\Nero =>.Ahead Corporation
                  O43 - CFD: 13/05/2013 - D – C:\Users\SamSwanson\AppData\Local\Nero_AG =>.Ahead
                  O43 - CFD: 10/02/2017 - D – C:\Users\SamSwanson\AppData\Local\NVIDIA =>.nVidia Corporation
                  O43 - CFD: 11/02/2017 - D – C:\Users\SamSwanson\AppData\Local\NVIDIA Corporation =>.nVidia Corporation
                  O43 - CFD: 02/12/2013 - D – C:\Users\SamSwanson\AppData\Local\PACE
                  O43 - CFD: 13/09/2015 - D – C:\Users\SamSwanson\AppData\Local\PACE Anti-Piracy =>.PACE Anti-Piracy
                  O43 - CFD: 24/06/2013 - D – C:\Users\SamSwanson\AppData\Local\PaceAP
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Local\Packages =>.Microsoft Corporation
                  O43 - CFD: 20/02/2017 - [0] D – C:\Users\SamSwanson\AppData\Local\PackageStaging =>.Apcera
                  O43 - CFD: 11/08/2016 - [0] D – C:\Users\SamSwanson\AppData\Local\PeerDistRepub =>.Microsoft Corporation
                  O43 - CFD: 23/12/2012 - D – C:\Users\SamSwanson\AppData\Local\Programs =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Local\Publishers =>.Microsoft Corporation
                  O43 - CFD: 07/11/2013 - D – C:\Users\SamSwanson\AppData\Local\PunkBuster =>.PunkBuster Games
                  O43 - CFD: 23/01/2013 - D – C:\Users\SamSwanson\AppData\Local\Screentime =>.Screen Time Labs
                  O43 - CFD: 13/08/2015 - HD – C:\Users\SamSwanson\AppData\Local\Sgisu0yuIs6
                  O43 - CFD: 15/08/2016 - [0] D – C:\Users\SamSwanson\AppData\Local\Skype =>.Skype
                  O43 - CFD: 29/06/2016 - D – C:\Users\SamSwanson\AppData\Local\slack =>.Slack Technologies
                  O43 - CFD: 24/12/2012 - D – C:\Users\SamSwanson\AppData\Local\SniperV2 =>.Games Software
                  O43 - CFD: 11/01/2015 - D – C:\Users\SamSwanson\AppData\Local\Sony =>.Sony
                  O43 - CFD: 16/02/2017 - D – C:\Users\SamSwanson\AppData\Local\Spectrasonics =>.Spectrasonics
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Local\Spotify =>.Spotify
                  O43 - CFD: 12/08/2016 - D – C:\Users\SamSwanson\AppData\Local\SquirrelTemp =>.Squirrels
                  O43 - CFD: 31/07/2016 - D – C:\Users\SamSwanson\AppData\Local\Steam =>.Steam Games
                  O43 - CFD: 05/06/2016 - D – C:\Users\SamSwanson\AppData\Local\TeamViewer =>.TeamViewer
                  O43 - CFD: 27/06/2013 - D – C:\Users\SamSwanson\AppData\Local\TechSmith =>.TechSmith
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Local\Temp =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\SamSwanson\AppData\Local\Temporary Internet Files =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Local\TileDataLayer =>.Microsoft Corporation
                  O43 - CFD: 06/01/2013 - D – C:\Users\SamSwanson\AppData\Local\Ubisoft Game Launcher =>.Ubisoft
                  O43 - CFD: 17/05/2015 - D – C:\Users\SamSwanson\AppData\Local\Universal Audio =>.RSA Security
                  O43 - CFD: 08/08/2015 - D – C:\Users\SamSwanson\AppData\Local\VirtualStore =>.Microsoft Corporation
                  O43 - CFD: 26/12/2012 - D – C:\Users\SamSwanson\AppData\Local\Wave Arts
                  O43 - CFD: 20/01/2013 - D – C:\Users\SamSwanson\AppData\Local\webkit =>.webkit
                  O43 - CFD: 13/08/2015 - HD – C:\Users\SamSwanson\AppData\Local\WfcjZQxwceO5G
                  O43 - CFD: 11/04/2014 - D – C:\Users\SamSwanson\AppData\Local\WinZip =>.WinZip
                  O43 - CFD: 23/10/2016 - HD – C:\Users\SamSwanson\AppData\Local\Zckp5HOHCw
                  O43 - CFD: 10/02/2017 - D – C:\Users\SamSwanson\AppData\Local\Zemana =>.Zemana
                  O43 - CFD: 12/08/2016 - D – C:\Users\SamSwanson\AppData\Local\ZenMate =>.ZenGuard GmbH
                  O43 - CFD: 23/12/2012 - [0] D – C:\Users\SamSwanson\AppData\Local\Programs\Common =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\112dB
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\A.O.M. Factory
                  O43 - CFD: 01/03/2017 - RD – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Accessibility =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - RD – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Accessories =>.Microsoft Corporation
                  O43 - CFD: 29/08/2013 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Acustica Audio
                  O43 - CFD: 21/02/2013 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\AcusticaAudio
                  O43 - CFD: 11/01/2017 - RD – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Administrative Tools =>.Administrative Tools
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Amazon =>.Amazon
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\AnonVPN
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\ASIO4ALL v2 =>.Michael Tippach
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\AVS4YOU =>.AVS4YOU
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\BWF MetaEdit
                  O43 - CFD: 14/02/2016 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\CD - DVD Publishing Service
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\CDSoundMaster
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Celemony =>.Celemony
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Crysonic
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Cytomic
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Dashlane =>.Dashlane
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\DDMF
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\DiskInternals =>.DiskInternals Research
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\DMG Audio
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Dropbox =>.Dropbox
                  O43 - CFD: 01/03/2017 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\East West Stormdrum Intakt
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Electrum =>.Electrum
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Empty Room Systems
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\FabFilter
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Fidelify
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Flux =>.Stereopsis
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Focusrite =>.Focusrite
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\G-Sonique =>.Games Software
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Gizmo Central
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Google Chrome =>.Google Inc.
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Handbrake =>.Handbrake
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\HFSExplorer
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\HOFA-Plugins
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\IK Multimedia =>.IK Multimedia
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Image-Line =>.Image-Line
                  O43 - CFD: 14/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Ivideon
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\iZotope =>.iZotope Inc
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Jack
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Kindle DRM Removal
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Kong Audio
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Kuassa
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Litecoin
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Litecoin Core
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\MAGIX =>.Magix
                  O43 - CFD: 16/07/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Maintenance =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Marvell =>.Marvell
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Maxthon Cloud Browser =>.Maxthon
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Native Instruments Elektrik Piano 1.5
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Nomad Factory =>.Nomad Factory
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\NYRV Systems =>.NYRV Systems
                  O43 - CFD: 23/09/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Output
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Overloud =>.Overloud
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Plugin Alliance =>.Plugin Alliance
                  O43 - CFD: 12/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Sample Magic
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Schaack Audio Technologies
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\SKnote
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Slack Technologies =>.Slack Technologies
                  O43 - CFD: 06/11/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\SONiVOX =>.SONiVOX
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Sonoris
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\SoundToys
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Spectrasonics =>.Spectrasonics
                  O43 - CFD: 01/03/2017 - RD – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Startup =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Sugar Bytes =>.Sugar Bytes
                  O43 - CFD: 01/03/2017 - RD – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\System Tools =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\TC Electronic =>.TC Electronic
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\The KMPlayer =>.The KMPlayer Team
                  O43 - CFD: 15/02/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Toshiba Corporation =>.Toshiba Corporation
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\u-he
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Ubisoft =>.Ubisoft
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Valhalla DSP
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\VB Audio
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Wave Arts
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\WinDirStat =>.Seifert Systems
                  O43 - CFD: 01/03/2017 - RD – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Windows PowerShell =>.Microsoft Corporation
                  O43 - CFD: 01/03/2017 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\WinRAR =>.WinRAR
                  O43 - CFD: 12/08/2016 - [0] D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\ZenGuard GmbH =>.ZenGuard GmbH
                  O43 - CFD: 11/08/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Zynaptic
                  O43 - CFD: 25/09/2016 - D – C:\Users\SamSwanson\AppData\Roaming\Microsoft\Wind ows\Start Menu\Programs\Zynaptiq
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\Default\AppData\Local\Application Data =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\Default\AppData\Local\History =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Users\Default\AppData\Local\Microsoft =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] D – C:\Users\Default\AppData\Local\Microsoft Help =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - [0] D – C:\Users\Default\AppData\Local\Temp =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\Default\AppData\Local\Temporary Internet Files =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\Default User\AppData\Local\Application Data =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\Default User\AppData\Local\History =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - D – C:\Users\Default User\AppData\Local\Microsoft =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] D – C:\Users\Default User\AppData\Local\Microsoft Help =>.Microsoft Corporation
                  O43 - CFD: 16/07/2016 - [0] D – C:\Users\Default User\AppData\Local\Temp =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] SHD – C:\Users\Default User\AppData\Local\Temporary Internet Files =>.Microsoft Corporation
                  O43 - CFD: 15/02/2017 - [0] – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\Application Data =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\ArcSoft =>.ArcSoft
                  O43 - CFD: 13/02/2017 - D – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\CrashDumps =>.Microsoft Corporation
                  O43 - CFD: 15/02/2017 - [0] – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\DevelopmentFiles
                  O43 - CFD: 15/02/2017 - [0] – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\History =>.Microsoft Corporation
                  O43 - CFD: 20/02/2017 - D – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\Microsoft =>.Microsoft Corporation
                  O43 - CFD: 11/08/2016 - [0] – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\PeerDistRepub =>.Microsoft Corporation
                  O43 - CFD: 13/02/2017 - – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\Programs =>.Microsoft Corporation
                  O43 - CFD: 15/02/2017 - [0] – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\Temporary Internet Files =>.Microsoft Corporation
                  O43 - CFD: 11/02/2017 - – C:\WINDOWS\System32\Config\systemprofile\AppData\L ocal\Zemana =>.Zemana
                  O43 - CFD: 11/08/2016 - D – C:\WINDOWS\System32\Config\systemprofile\AppData\R oaming\Apple Computer =>.Apple Inc.
                  O43 - CFD: 15/02/2017 - D – C:\WINDOWS\System32\Config\systemprofile\AppData\R oaming\Microsoft =>.Microsoft Corporation
                  —\ ShellIconOverlayIdentifiers (SIOI) (25) - 2s
                  O106 - SIOI: Icon Overlay(Green) Class [ Carbonite.Green] - {95A27763-F62A-4114-9072-E81D87DE3B68}. (.Carbonite, Inc. - Carbonite Explorer Extensions.) – C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll {18455E6EF6D43CE1BB0C2DAC7DED3004}
                  O106 - SIOI: Icon Overlay(Partial) Class [ Carbonite.Partial] - {E300CD91-100F-4E67-9AF3-1384A6124015}. (.Carbonite, Inc. - Carbonite Explorer Extensions.) – C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll {18455E6EF6D43CE1BB0C2DAC7DED3004}
                  O106 - SIOI: Icon Overlay(Yellow) Class [ Carbonite.Yellow] - {5E529433-B50E-4bef-A63B-16A6B71B071A}. (.Carbonite, Inc. - Carbonite Explorer Extensions.) – C:\Program Files (x86)\Carbonite\Carbonite Backup\CarboniteNSE.dll {18455E6EF6D43CE1BB0C2DAC7DED3004}
                  O106 - SIOI: ErrorOverlayHandler Class [ OneDrive1] - {BBACC218-34EA-4666-9D7A-C78F2274A524}. (.Microsoft Corporation - Microsoft OneDrive Shell Extension.) – C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6743.1212\FileSyncShell.dll =>.Microsoft Corporation®
                  O106 - SIOI: SharedOverlayHandler Class [ OneDrive2] - {5AB7172C-9C11-405C-8DD5-AF20F3606282}. (.Microsoft Corporation - Microsoft OneDrive Shell Extension.) – C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6743.1212\FileSyncShell.dll =>.Microsoft Corporation®
                  O106 - SIOI: SharedSyncingOverlayHandler Class [ OneDrive3] - {A78ED123-AB77-406B-9962-2A5D9D2F7F30}. (.Microsoft Corporation - Microsoft OneDrive Shell Extension.) – C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6743.1212\FileSyncShell.dll =>.Microsoft Corporation®
                  O106 - SIOI: UpToDateOverlayHandler Class [ OneDrive4] - {F241C880-6982-4CE5-8CF7-7085BA96DA5A}. (.Microsoft Corporation - Microsoft OneDrive Shell Extension.) – C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6743.1212\FileSyncShell.dll =>.Microsoft Corporation®
                  O106 - SIOI: SyncingOverlayHandler Class [ OneDrive5] - {A0396A93-DC06-4AEF-BEE9-95FFCCAEF20E}. (.Microsoft Corporation - Microsoft OneDrive Shell Extension.) – C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6743.1212\FileSyncShell.dll =>.Microsoft Corporation®
                  O106 - SIOI: Microsoft SkyDrive Pro Icon Overlay 1 (ErrorConflict) [ SkyDrivePro1 (ErrorConflict)] - {8BA85C75-763B-4103-94EB-9470F12FE0F7}. (.Microsoft Corporation - Microsoft OneDrive for Business Extensions.) – C:\Program Files (x86)\Microsoft Office\Office15\GROOVEEX.DLL =>.Microsoft Corporation®
                  O106 - SIOI: Microsoft SkyDrive Pro Icon Overlay 2 (SyncInProgress) [ SkyDrivePro2 (SyncInProgress)] - {CD55129A-B1A1-438E-A425-CEBC7DC684EE}. (.Microsoft Corporation - Microsoft OneDrive for Business Extensions.) – C:\Program Files (x86)\Microsoft Office\Office15\GROOVEEX.DLL =>.Microsoft Corporation®
                  O106 - SIOI: Microsoft SkyDrive Pro Icon Overlay 3 (InSync) [ SkyDrivePro3 (InSync)] - {E768CD3B-BDDC-436D-9C13-E1B39CA257B1}. (.Microsoft Corporation - Microsoft OneDrive for Business Extensions.) – C:\Program Files (x86)\Microsoft Office\Office15\GROOVEEX.DLL =>.Microsoft Corporation®
                  O106 - SIOI: DropboxExt [“DropboxExt1”] - {FB314ED9-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: DropboxExt [“DropboxExt2”] - {FB314EDA-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: DropboxExt [“DropboxExt3”] - {FB314EDD-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: DropboxExt [“DropboxExt4”] - {FB314EDE-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: DropboxExt [“DropboxExt5”] - {FB314EDB-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: DropboxExt [“DropboxExt6”] - {FB314EDF-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: DropboxExt [“DropboxExt7”] - {FB314EDC-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: DropboxExt [“DropboxExt8”] - {FB314EE0-A251-47B7-93E1-CDD82E34AF8B}. (.Dropbox, Inc. - Dropbox Shell Extension.) – C:\Users\SamSwanson\AppData\Roaming\Dropbox\bin\Dr opboxExt.24.dll =>.Dropbox, Inc®
                  O106 - SIOI: Acronis True Image Shell Sync Error Icon Overlay Extension [AcronisSyncError] - {934BC6C0-FEC2-4df5-A100-961DE2C8A0ED}. (.Acronis - Acronis True Image Shell Extensions.) – C:\Program Files (x86)\Acronis\TrueImageHome\tishell.dll =>.Acronis International GmbH®
                  O106 - SIOI: Acronis True Image Shell Sync In Progress Icon Overlay Extension [AcronisSyncInProgress] - {00F848DC-B1D4-4892-9C25-CAADC86A215D}. (.Acronis - Acronis True Image Shell Extensions.) – C:\Program Files (x86)\Acronis\TrueImageHome\tishell.dll =>.Acronis International GmbH®
                  O106 - SIOI: Acronis True Image Shell Sync Ok Icon Overlay Extension [AcronisSyncOk] - {71573297-552E-46fc-BE3D-3DFAF88D47B7}. (.Acronis - Acronis True Image Shell Extensions.) – C:\Program Files (x86)\Acronis\TrueImageHome\tishell.dll =>.Acronis International GmbH®
                  —\ System Drivers List (127) - 5s
                  O58 - SDL:2016/07/16 12:41:53 A . (.LSI - LSI 3ware SCSI Storport Driver.) – C:\WINDOWS\System32\drivers\3ware.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.PMC-Sierra - PMC-Sierra Storport Driver For SPC8x6G SAS.) – C:\WINDOWS\System32\drivers\adp80xx.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Advanced Micro Devices - AHCI 1.3 Device Driver.) – C:\WINDOWS\System32\drivers\amdsata.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.AMD Technologies Inc. - AMD Technology AHCI Compatible Controller D.) – C:\WINDOWS\System32\drivers\amdsbs.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Advanced Micro Devices - Storage Filter Driver.) – C:\WINDOWS\System32\drivers\amdxata.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.PMC-Sierra, Inc. - Adaptec SAS RAID WS03 Driver.) – C:\WINDOWS\System32\drivers\arcsas.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2013/09/23 14:04:04 A . (.Realtek - Realtek 8101E/8168/8169 NDIS 6.30 64-bit Dr.) – C:\WINDOWS\System32\drivers\au630x64.sys [9239144] =>.Realtek Semiconductor Corp®
                  O58 - SDL:2016/08/15 11:01:36 A . (.Avid - Mbox WDM Audio Streaming Driver.) – C:\WINDOWS\System32\drivers\AvidMbox.sys [9239144] {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  O58 - SDL:2016/08/15 11:01:39 A . (.Avid - Avid WDM DFU Driver.) – C:\WINDOWS\System32\drivers\AvidMbox_DFU.sys [9239144] {32FCE884652634BA17F648BC5BE6F36F} =>.Avid
                  O58 - SDL:2016/07/16 12:41:53 A . (.Windows (R) Win 7 DDK provider - BCM Function 2 Device Driver.) – C:\WINDOWS\System32\drivers\bcmfn.sys [9239144] =>.Windows (R) Win 7 DDK provider
                  O58 - SDL:2016/07/16 12:41:53 A . (.Windows (R) Win 7 DDK provider - BCM Function 2 Device Driver.) – C:\WINDOWS\System32\drivers\bcmfn2.sys [9239144] =>.Windows (R) Win 7 DDK provider
                  O58 - SDL:2016/07/16 12:41:52 A . (.QLogic Corporation - QLogic Gigabit Ethernet VBD.) – C:\WINDOWS\System32\drivers\bxvbda.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2011/05/06 15:19:34 A . (.EldoS Corporation - CallbackDisk Virtual Storage Driver.) – C:\WINDOWS\System32\drivers\CBDisk.sys [9239144] =>.EldoS Corporation®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Chelsio Communications - Chelsio iSCSI Crash Dump Driver.) – C:\WINDOWS\System32\drivers\cht4dx64.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Chelsio Communications - Chelsio iSCSI VMiniport Driver.) – C:\WINDOWS\System32\drivers\cht4sx64.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Chelsio Communications - Virtual Bus Driver for Chelsio ® T4 Chipset.) – C:\WINDOWS\System32\drivers\cht4vx64.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/09/08 17:40:53 A . (.COMODO - COMODO Internet Security Eradication Driver.) – C:\WINDOWS\System32\drivers\cmderd.sys [9239144] =>.Comodo Security Solutions®
                  O58 - SDL:2016/09/08 17:38:19 A . (.COMODO - COMODO Internet Security Sandbox Driver.) – C:\WINDOWS\System32\drivers\cmdguard.sys [9239144] =>.Comodo Security Solutions®
                  O58 - SDL:2016/09/08 17:41:01 A . (.COMODO - COMODO Internet Security Helper Driver.) – C:\WINDOWS\System32\drivers\cmdhlp.sys [9239144] =>.Comodo Security Solutions®
                  O58 - SDL:2015/07/15 21:28:57 A . (.DDMF - DDMF Virtual Audio Device.) – C:\WINDOWS\System32\drivers\DDMFaudio.sys [9239144] {010000000001300C4E5D19}
                  O58 - SDL:2013/08/07 00:34:18 A . (.Avid Technology, Inc. - 64-bit Ethernet Packet Driver.) – C:\WINDOWS\System32\drivers\diginet.sys [9239144] =>.Avid Technology, Inc.®
                  O58 - SDL:2016/08/15 15:05:42 A . (.Disc Soft Ltd - DAEMON Tools Lite Virtual SCSI Bus Driver.) – C:\WINDOWS\System32\drivers\dtlitescsibus.sys [9239144] =>.Disc Soft Ltd®
                  O58 - SDL:2011/07/08 17:36:16 A . (.Etron - Etron Camera Driver.) – C:\WINDOWS\System32\drivers\ETdrv.sys [9239144] =>.Etron
                  O58 - SDL:2016/07/16 12:41:52 A . (.QLogic Corporation - QLogic 10 GigE VBD.) – C:\WINDOWS\System32\drivers\evbda.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2012/06/24 14:39:42 A . (.Romex Software - Primo Ramdisk (Srv) Controller Driver.) – C:\WINDOWS\System32\drivers\fancyrd.sys [9239144] =>.SmartSource Shanghai Electronic Technology Co. Ltd®
                  O58 - SDL:2017/03/01 22:24:19 A . (.Malwarebytes - Malwarebytes Anti-Ransomware Protection.) – C:\WINDOWS\System32\drivers\farflt.sys [9239144] =>.Malwarebytes Corporation®
                  O58 - SDL:2016/10/31 09:17:53 A . (.Acronis International GmbH - File tracker minifilter driver.) – C:\WINDOWS\System32\drivers\file_tracker.sys [9239144] =>.ACRONIS INTERNATIONAL GMBH®
                  O58 - SDL:2016/06/29 11:02:26 A . (.Acronis International GmbH - Acronis Storage Filter Management Driver.) – C:\WINDOWS\System32\drivers\fltsrv.sys [9239144] =>.ACRONIS INTERNATIONAL GMBH®
                  O58 - SDL:2012/08/21 20:01:20 A . (.GEAR Software Inc. - CD DVD Filter.) – C:\WINDOWS\System32\drivers\GEARAspiWDM.sys [9239144] =>.GEAR Software Inc.®
                  O58 - SDL:2012/12/25 00:46:50 A . (.Arainia Solutions LLC - Gizmo Drive, kernel-mode device driver.) – C:\WINDOWS\System32\drivers\gizmodrv.sys [9239144] =>.Arainia Solutions, LLC®
                  O58 - SDL:2013/01/11 19:02:34 A . (.Intel Corporation - Intel(R) Management Engine Interface.) – C:\WINDOWS\System32\drivers\HECIx64.sys [9239144] =>.Intel Corporation - Intel® Management Engine Firmware®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Hewlett-Packard Company - Smart Array SAS/SATA Controller Media Drive.) – C:\WINDOWS\System32\drivers\HpSAMD.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:54 A . (.Intel(R) Corporation - Intel(R) Serial IO GPIO Controller Driver.) – C:\WINDOWS\System32\drivers\iagpio.sys [9239144] =>.Intel(R) Corporation
                  O58 - SDL:2016/07/16 12:41:54 A . (.Intel(R) Corporation - Intel(R) Serial IO I2C Driver.) – C:\WINDOWS\System32\drivers\iai2c.sys [9239144] =>.Intel(R) Corporation
                  O58 - SDL:2016/07/16 12:41:54 A . (.Intel Corporation - Intel(R) Serial IO GPIO Driver v2.) – C:\WINDOWS\System32\drivers\iaLPSS2i_GPIO2.sys [9239144] =>.Intel Corporation
                  O58 - SDL:2016/07/16 12:41:54 A . (.Intel Corporation - Intel(R) Serial IO I2C Driver v2.) – C:\WINDOWS\System32\drivers\iaLPSS2i_I2C.sys [9239144] =>.Intel Corporation - Embedded Subsystems and IP Blocks Group®
                  O58 - SDL:2016/07/16 12:41:52 A . (.Intel Corporation - Intel(R) Serial IO GPIO Controller Driver.) – C:\WINDOWS\System32\drivers\iaLPSSi_GPIO.sys [9239144] =>.Intel Corporation - Client Components Group®
                  O58 - SDL:2016/07/16 12:41:50 A . (.Intel Corporation - Intel(R) Serial IO I2C Controller Driver.) – C:\WINDOWS\System32\drivers\iaLPSSi_I2C.sys [9239144] =>.Intel Corporation
                  O58 - SDL:2013/07/11 15:01:42 A . (.Intel Corporation - NDIS 6.30 Advanced Networking Services..) – C:\WINDOWS\System32\drivers\iANSW60e.sys [9239144] =>.Intel Corporation®
                  O58 - SDL:2016/12/05 11:57:44 A . (.Intel Corporation - Intel Rapid Storage Technology driver - x64.) – C:\WINDOWS\System32\drivers\iaStorA.sys [9239144] =>.Intel Corporation - Intel® Rapid Storage Technology®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Intel Corporation - Intel(R) Rapid Storage Technology driver (i.) – C:\WINDOWS\System32\drivers\iaStorAV.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Intel Corporation - Intel Matrix Storage Manager driver - x64.) – C:\WINDOWS\System32\drivers\iaStorV.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Mellanox - InfiniBand Fabric Bus Driver.) – C:\WINDOWS\System32\drivers\ibbus.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2012/07/17 11:05:14 A . (.Intel Corporation - Intel(R) Watchdog Timer Driver (Intel(R) WD.) – C:\WINDOWS\System32\drivers\ICCWDT.sys [9239144] =>.Intel Corporation®
                  O58 - SDL:2012/08/16 20:31:26 A . (.Authors - Intel Keyboard Class Upper Filter Driver.) – C:\WINDOWS\System32\drivers\ikbevent.sys [9239144] =>.Intel(R) Smart Connect software®
                  O58 - SDL:2013/10/27 17:02:44 A . (.Authors - iLok Kernel Driver File.) – C:\WINDOWS\System32\drivers\iLokDrvr.sys [9239144] =>.PACE Anti-Piracy, Inc.®
                  O58 - SDL:2012/08/16 20:31:28 A . (.Authors - Intel Mouse Class Upper Filter Driver.) – C:\WINDOWS\System32\drivers\imsevent.sys [9239144] =>.Intel(R) Smart Connect software®
                  O58 - SDL:2016/09/08 17:41:03 A . (.COMODO - COMODO Internet Security Firewall Driver.) – C:\WINDOWS\System32\drivers\inspect.sys [9239144] =>.Comodo Security Solutions®
                  O58 - SDL:2013/08/12 11:50:00 A . (.Intel Corporation - Intel(R) Network Adapter Diagnostic Driver.) – C:\WINDOWS\System32\drivers\iqvw64e.sys [9239144] =>.Intel Corporation®
                  O58 - SDL:2013/05/23 07:12:48 A . (.Logitech, Inc. - Logitech Equad USB Driver..) – C:\WINDOWS\System32\drivers\LEqdUsb.sys [9239144] =>.Logitech®
                  O58 - SDL:2017/01/23 23:20:02 A . (.Logitech Inc. - Logitech WingMan Virtual Bus Enumerator Dri.) – C:\WINDOWS\System32\drivers\LGBusEnum.sys [9239144] =>.Logitech Inc®
                  O58 - SDL:2017/01/23 23:20:02 A . (.Logitech Inc. - Logitech Gaming Software Joystick Translati.) – C:\WINDOWS\System32\drivers\LGJoyXlCore.sys [9239144] =>.Logitech Inc®
                  O58 - SDL:2017/01/23 23:20:02 A . (.Logitech Inc. - Logitech Gaming HID Filter Driver..) – C:\WINDOWS\System32\drivers\LGSHidFilt.Sys [9239144] =>.Logitech®
                  O58 - SDL:2017/01/23 23:20:02 A . (.Logitech Inc. - Logitech GamePanel Virtual Hid Device Drive.) – C:\WINDOWS\System32\drivers\LGVirHid.sys [9239144] =>.Logitech Inc®
                  O58 - SDL:2013/05/23 07:12:48 A . (.Logitech, Inc. - Logitech HID Filter Driver..) – C:\WINDOWS\System32\drivers\LHidEqd.sys [9239144] =>.Logitech®
                  O58 - SDL:2013/05/23 07:12:50 A . (.Logitech, Inc. - Logitech HID Filter Driver..) – C:\WINDOWS\System32\drivers\LHidFilt.Sys [9239144] =>.Logitech®
                  O58 - SDL:2013/05/23 07:12:52 A . (.Logitech, Inc. - Logitech Mouse Filter Driver..) – C:\WINDOWS\System32\drivers\LMouFilt.Sys [9239144] =>.Logitech®
                  O58 - SDL:2017/03/01 22:24:17 A . (.Logitech, Inc. - Logitech Non-Plug and Play Driver..) – C:\WINDOWS\System32\drivers\LNonPnP.sys [9239144] =>.Logitech®
                  O58 - SDL:2011/02/26 20:44:48 A . (.nerds.de - nerds.de LoopBe30 Internal MIDI Device.) – C:\WINDOWS\System32\drivers\loopbe30.sys [9239144] =>.nerds.de
                  O58 - SDL:2016/07/16 12:41:53 A . (.LSI Corporation - LSI Fusion-MPT SAS Driver (StorPort).) – C:\WINDOWS\System32\drivers\lsi_sas.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.LSI Corporation - LSI SAS Gen2 Driver (StorPort).) – C:\WINDOWS\System32\drivers\lsi_sas2i.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Avago Technologies - Avago SAS Gen3 Driver (StorPort).) – C:\WINDOWS\System32\drivers\lsi_sas3i.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.LSI Corporation - LSI SSS PCIe/Flash Driver (StorPort).) – C:\WINDOWS\System32\drivers\lsi_sss.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2012/10/26 16:42:22 A . (.Logitech Inc. - Logitech Kernel Audio Improvement Filter Dr.) – C:\WINDOWS\System32\drivers\lvrs64.sys [9239144] =>.Logitech, Inc.®
                  O58 - SDL:2012/10/26 16:42:22 A . (.Logitech Inc. - Logitech USB Video Class Driver.) – C:\WINDOWS\System32\drivers\lvuvc64.sys [9239144] =>.Logitech, Inc.®
                  O58 - SDL:2010/03/04 13:31:30 A . (.M-Audio - Oxygen WDM Audio Streaming Driver.) – C:\WINDOWS\System32\drivers\MAudioOxygen.sys [9239144] =>.M-Audio®
                  O58 - SDL:2017/02/11 16:07:57 A . (.Authors - .) – C:\WINDOWS\System32\drivers\mbae64.sys [9239144] =>.Malwarebytes Corporation®
                  O58 - SDL:2017/03/01 22:24:18 A . (.Malwarebytes - Malwarebytes Real-Time Protection.) – C:\WINDOWS\System32\drivers\mbam.sys [9239144] =>.Malwarebytes Corporation®
                  O58 - SDL:2017/03/01 22:24:19 A . (.Malwarebytes - Malwarebytes Chameleon.) – C:\WINDOWS\System32\drivers\MBAMChameleon.sys [9239144] =>.Malwarebytes Corporation®
                  O58 - SDL:2017/03/01 22:24:18 A . (.Malwarebytes - Malwarebytes SwissArmy.) – C:\WINDOWS\System32\drivers\MBAMSwissArmy.sys [9239144] =>.Malwarebytes Corporation®
                  O58 - SDL:2012/11/15 17:50:18 A . (.Mediafour Corporation - MacDrive file system driver.) – C:\WINDOWS\System32\drivers\MDFSYSNT.SYS [9239144] {6FB31CAF7DD1D018473E68C3DC522A3F} =>.Mediafour Corporation
                  O58 - SDL:2012/06/05 22:27:24 A . (.Mediafour Corporation - MacDrive partition driver.) – C:\WINDOWS\System32\drivers\MDPMGRNT.SYS [9239144] {6FB31CAF7DD1D018473E68C3DC522A3F} =>.Mediafour Corporation
                  O58 - SDL:2016/07/16 12:41:53 A . (.Avago Technologies - MEGASAS RAID Controller Driver for Windows.) – C:\WINDOWS\System32\drivers\megasas.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/10/13 08:57:18 A . (.Avago Technologies - MEGASAS RAID Controller Driver for Windows.) – C:\WINDOWS\System32\drivers\MegaSas2i.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.LSI Corporation, Inc. - LSI MegaRAID Software RAID Driver.) – C:\WINDOWS\System32\drivers\megasr.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Mellanox - MLX4 Bus Driver.) – C:\WINDOWS\System32\drivers\mlx4_bus.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Marvell Semiconductor, Inc. - Marvell Flash Controller Driver.) – C:\WINDOWS\System32\drivers\mvumis.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2017/03/01 22:36:34 A . (.Malwarebytes - Malwarebytes Web Protection.) – C:\WINDOWS\System32\drivers\mwac.sys [9239144] =>.Malwarebytes Corporation®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Mellanox - NetworkDirect Support Filter Driver.) – C:\WINDOWS\System32\drivers\ndfltr.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/06/10 19:12:33 A . (.Intel Corporation - Intel(R) Technology Access Filter Driver.) – C:\WINDOWS\System32\drivers\ndisrfl.sys [9239144] =>.Intel(R) Technology Access®
                  O58 - SDL:2017/02/25 14:26:25 A . (.SoftEther Corporation - SoftEther VPN.) – C:\WINDOWS\System32\drivers\Neo6_x64_VPN.sys [9239144] =>.SoftEther Corporation®
                  O58 - SDL:2016/07/16 12:42:03 A . (.Authors - .) – C:\WINDOWS\System32\drivers\NetAdapterCx.sys [9239144] =>.Microsoft Corporation
                  O58 - SDL:2016/06/10 19:12:33 N . (.Intel Corporation - Intel(R) Technology Access TAP Driver.) – C:\WINDOWS\System32\drivers\nettap630.sys [9239144] =>.Intel(R) Technology Access®
                  O58 - SDL:2017/02/10 20:17:44 A . (.NVIDIA Corporation - NVIDIA HDMI Audio Driver.) – C:\WINDOWS\System32\drivers\nvhda64v.sys [9239144] =>.NVIDIA Corporation®
                  O58 - SDL:2016/07/16 12:41:53 A . (.NVIDIA Corporation - NVIDIA® nForce™ RAID Driver.) – C:\WINDOWS\System32\drivers\nvraid.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.NVIDIA Corporation - NVIDIA® nForce™ Sata Performance Driver.) – C:\WINDOWS\System32\drivers\nvstor.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2017/02/10 19:59:57 A . (.NVIDIA Corporation - NVIDIA Virtual Audio Driver.) – C:\WINDOWS\System32\drivers\nvvad64v.sys [9239144] =>.NVIDIA Corporation®
                  O58 - SDL:2017/02/10 20:01:36 A . (.NVIDIA Corporation - Virtual USB Host Controller driver.) – C:\WINDOWS\System32\drivers\nvvhci.sys [9239144] =>.NVIDIA Corporation®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Avago Technologies - MEGASAS RAID Controller Driver for Windows.) – C:\WINDOWS\System32\drivers\percsas2i.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Avago Technologies - MEGASAS RAID Controller Driver for Windows.) – C:\WINDOWS\System32\drivers\percsas3i.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2011/11/25 08:25:52 A . (.June Fabrics Technology Inc. - PdaNet Broadband Adapter Driver.) – C:\WINDOWS\System32\drivers\pneteth.sys [9239144] =>.June Fabrics Technology Inc.
                  O58 - SDL:2000/01/01 01:00:00 A . (.Realtek - Realtek 8101E/8168/8169 NDIS 6.30 64-bit Dr.) – C:\WINDOWS\System32\drivers\Rt630x64.sys [9239144] =>.Realtek Semiconductor Corp®
                  O58 - SDL:2016/11/22 08:59:29 A . (.Realtek - Realtek 8101E/8168/8169 NDIS 6.40 64-bit Dr.) – C:\WINDOWS\System32\drivers\rt640x64.sys [9239144] =>.Realtek Semiconductor Corp.®
                  O58 - SDL:2016/12/03 21:02:58 A . (.Realtek Semiconductor Corp. - Realtek(r) High Definition Audio Function D.) – C:\WINDOWS\System32\drivers\RTKVHD64.sys [9239144] =>.Realtek Semiconductor Corp.®
                  O58 - SDL:2012/04/18 17:12:12 A . (.Windows (R) Win 7 DDK provider - RXBSKNL Driver.) – C:\WINDOWS\System32\drivers\rxbsknl.sys [9239144] =>.SmartSource Shanghai Electronic Technology Co. Ltd®
                  O58 - SDL:2017/02/25 14:23:22 A . (.SoftEther Corporation - SoftEther VPN.) – C:\WINDOWS\System32\drivers\SeLow_x64.sys [9239144] =>.SoftEther Corporation®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Silicon Integrated Systems Corp. - SiS RAID Stor Miniport Driver.) – C:\WINDOWS\System32\drivers\sisraid2.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Silicon Integrated Systems - SiS AHCI Stor-Miniport Driver.) – C:\WINDOWS\System32\drivers\sisraid4.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2012/08/24 10:38:28 A . (.Synaptics Incorporated - Synaptics SMBus Driver.) – C:\WINDOWS\System32\drivers\Smb_driver_Intel.sys [9239144] =>.Synaptics Incorporated®
                  O58 - SDL:2016/06/29 11:02:41 A . (.Acronis International GmbH - Acronis Snapshot API.) – C:\WINDOWS\System32\drivers\snapman.sys [9239144] =>.ACRONIS INTERNATIONAL GMBH®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Promise Technology, Inc. - Promise SuperTrak EX Series Driver for Wind.) – C:\WINDOWS\System32\drivers\stexstor.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/08/12 14:54:21 A . (.The OpenVPN Project - TAP-Windows Virtual Network Driver (NDIS 6..) – C:\WINDOWS\System32\drivers\tap0901.sys [9239144] =>.The OpenVPN Project
                  O58 - SDL:2016/11/22 08:57:09 A . (.Intel Corporation - Intel(R) Management Engine Interface.) – C:\WINDOWS\System32\drivers\TeeDriverW8x64.sys [9239144] =>.Intel(R) Embedded Subsystems and IP Blocks Group®
                  O58 - SDL:2000/01/01 01:00:00 A . (.Intel Corporation - Intel(R) Management Engine Interface.) – C:\WINDOWS\System32\drivers\TeeDriverx64.sys [9239144] =>.Intel Corporation - Intel® Management Engine Firmware®
                  O58 - SDL:2012/08/16 06:41:38 A . (.Tobias Erichsen - Virtual MIDI Driver (x64).) – C:\WINDOWS\System32\drivers\teVirtualMIDI64.sys [9239144] =>.Tobias Erichsen
                  O58 - SDL:2016/10/31 09:17:25 A . (.Acronis International GmbH - Acronis Backup Archive Explorer.) – C:\WINDOWS\System32\drivers\tib.sys [9239144] =>.ACRONIS INTERNATIONAL GMBH®
                  O58 - SDL:2016/10/31 09:17:25 A . (.Acronis International GmbH - Acronis TIB Mounter Driver.) – C:\WINDOWS\System32\drivers\tib_mounter.sys [9239144] =>.ACRONIS INTERNATIONAL GMBH®
                  O58 - SDL:2016/10/31 09:17:26 A . (.Acronis International GmbH - Acronis Try&Decide Volume Filter Driver.) – C:\WINDOWS\System32\drivers\tnd.sys [9239144] =>.ACRONIS INTERNATIONAL GMBH®
                  O58 - SDL:2013/04/11 13:08:40 A . (.PACE Anti-Piracy, Inc. - 64bit Tpkd Device Driver.) – C:\WINDOWS\System32\drivers\Tpkd.sys [9239144] =>.PACE Anti-Piracy, Inc.®
                  O58 - SDL:2017/03/01 21:49:28 A . (.Authors - .) – C:\WINDOWS\System32\drivers\TrueSight.sys [9239144] =>.Adlice®
                  O58 - SDL:2016/04/24 21:13:33 A . (.Windows (R) Win 7 DDK provider - Telestream Virtual Audio Device.) – C:\WINDOWS\System32\drivers\tsvadpcm.sys [9239144] =>.Telestream Inc.®
                  O58 - SDL:2016/11/03 22:39:29 A . (.Universal Audio, Inc. - UAD-2 PCIe Device Driver.) – C:\WINDOWS\System32\drivers\UAD2Pcie.sys [9239144] {1A6A518872003ECF} =>.Universal Audio, Inc.
                  O58 - SDL:2016/11/03 22:39:30 A . (.Universal Audio, Inc. - UAD-2 System Driver.) – C:\WINDOWS\System32\drivers\UAD2System.sys [9239144] {1A6A518872003ECF} =>.Universal Audio, Inc.
                  O58 - SDL:2016/11/03 22:39:31 A . (.Authors - .) – C:\WINDOWS\System32\drivers\UAD2WdmAudio.sys [9239144] {1A6A518872003ECF}
                  O58 - SDL:2014/03/07 11:28:16 A . (.Windows (R) Win 7 DDK provider - VB Virtual Audio Device.) – C:\WINDOWS\System32\drivers\vbaudio_hfvaio64_win7. sys [9239144] =>.Vincent Burel®
                  O58 - SDL:2016/06/29 11:02:45 A . (.Acronis International GmbH - Acronis Virtual File.) – C:\WINDOWS\System32\drivers\virtual_file.sys [9239144] =>.ACRONIS INTERNATIONAL GMBH®
                  O58 - SDL:2013/07/23 17:17:16 A . (.Eugene V. Muzychenko - Kernel-mode WDM driver.) – C:\WINDOWS\System32\drivers\vrtaucbl.sys [9239144] =>.Muzychenko Evgenii Viktorovich®
                  O58 - SDL:2016/07/16 12:41:53 A . (.VIA Technologies Inc.,Ltd - VIA RAID DRIVER FOR AMD-X86-64.) – C:\WINDOWS\System32\drivers\vsmraid.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.VIA Corporation - VIA StorX RAID Controller Driver.) – C:\WINDOWS\System32\drivers\VSTXRAID.SYS [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Mellanox - Kernel WinMad.) – C:\WINDOWS\System32\drivers\winmad.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2016/07/16 12:41:53 A . (.Mellanox - Kernel WinVerbs.) – C:\WINDOWS\System32\drivers\winverbs.sys [9239144] =>.Microsoft Windows®
                  O58 - SDL:2014/01/03 09:13:44 A . (.Authors - .) – C:\WINDOWS\System32\drivers\WPRO_41_2001.sys [9239144] =>.Intel(R) Smart Connect software®
                  O58 - SDL:2017/02/27 18:03:02 A . (.Webroot - Webroot SecureAnywhere.) – C:\WINDOWS\System32\drivers\WRkrn.sys [9239144] {6FBB6E1D2367DC6BD38B1C8FA0BF6637} =>.Webroot
                  O58 - SDL:2016/10/11 12:13:27 AT . (.Webroot - Url Filter Driver.) – C:\WINDOWS\System32\drivers\wrUrlFlt.sys [9239144] {6FBB6E1D2367DC6BD38B1C8FA0BF6637} =>.Webroot
                  O58 - SDL:2017/02/11 15:29:54 A . (.Zemana Ltd. - ZAM.) – C:\WINDOWS\System32\drivers\zam64.sys [9239144] =>.Zemana Ltd.®
                  O58 - SDL:2017/02/11 15:29:54 A . (.Zemana Ltd. - ZAM.) – C:\WINDOWS\System32\drivers\zamguard64.sys [9239144] =>.Zemana Ltd.®
                  O58 - SDL:2012/11/18 23:57:58 A . (.Qualcomm Atheros Communications, Inc. - Qualcomm Atheros Extensible Wireless LAN de.) – C:\WINDOWS\System32\athw8x.sys [9239144] =>.Qualcomm Atheros Communications, Inc.
                  —\ Last modified or created user files (8) - 9s
                  O61 - LFC: 2017/02/28 11:14:28 A . (..) – C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\58.0.3026.0\natives_blob.bin [258644]
                  O61 - LFC: 2017/02/28 11:14:28 A . (..) – C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\58.0.3026.0\snapshot_blob.bin [1447824]
                  O61 - LFC: 2017/02/28 14:25:15 A . (..) – C:\Users\SamSwanson\AppData\Roaming\MetaQuotes\Ter minal\FB843E06E68644E748DE160AA2162BB8\MQL4\Script s\Examples\DLL\Libraries\DLLSample.dll [105472]
                  O61 - LFC: 2017/03/01 22:30:31 A . (..) – C:\Users\SamSwanson\AppData\Roaming\msregsvv.dll [96]
                  O61 - LFC: 2017/03/01 19:25:10 A . (.Copyright © 2015.) – C:\Users\SamSwanson\Desktop\Computer fix\Adware Removal Tool by TSA.exe [752296] {317DD1C55F51AC2756D9C93C060C6FA5}
                  O61 - LFC: 2017/03/01 21:45:14 A . (.Alex Dragokas.) – C:\Users\SamSwanson\Desktop\Computer fix\clearlnk_2.9.0.11.exe [462976]
                  O61 - LFC: 2017/02/28 22:48:02 A . (..) – C:\Users\SamSwanson\Desktop\Computer fix\mbar\mbar.cmd [1118]
                  O61 - LFC: 2017/02/24 17:27:25 A . (.TechGuy, Inc..) – C:\Users\SamSwanson\Desktop\Computer fix\SysInfo.exe [748192] {00C786324C9D57D27F8C10069AFC5A2B2C}
                  —\ File Associations Shell Spawning (10) - 0s
                  O67 - Shell Spawning: <.bat> [HKLM..\open\Command] (…) – “%1” %*
                  O67 - Shell Spawning: <.cpl> [HKLM..\cplopen\Command] (.Microsoft Corporation - Windows Control Panel.) – C:\Windows\System32\control.exe =>.Microsoft Corporation
                  O67 - Shell Spawning: <.cmd> [HKLM..\open\Command] (…) – “%1” %*
                  O67 - Shell Spawning: <.com> [HKLM..\open\Command] (…) – “%1” %*
                  O67 - Shell Spawning: <.evt> [HKLM..\open\Command] (.Microsoft Corporation - Event Viewer Snapin Launcher.) – C:\Windows\System32\eventvwr.exe =>.Microsoft Corporation
                  O67 - Shell Spawning: <.exe> [HKLM..\open\Command] (…) – “%1” %*
                  O67 - Shell Spawning: <.html> [HKLM..\open\Command] (.Microsoft Corporation - Internet Explorer.) – C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
                  O67 - Shell Spawning: <.js> [HKLM..\open\Command] (.Microsoft Corporation - Microsoft ® Windows Based Script Host.) – C:\Windows\System32\wscript.exe =>.Microsoft Corporation
                  O67 - Shell Spawning: <.reg> [HKLM..\open\Command] (.Microsoft Corporation - Registry Editor.) – C:\Windows\regedit.exe =>.Microsoft Corporation
                  O67 - Shell Spawning: <.scr> [HKLM..\open\Command] (…) – “%1” /S
                  —\ Start Menu Internet (16) - 0s
                  O68 - StartMenuInternet: <FIREFOX.EXE> [HKLM..\Shell\open\Command] (.Mozilla Corporation - Firefox.) – C:\Program Files (x86)\Mozilla Firefox\firefox.exe =>.Mozilla Corporation®
                  O68 - StartMenuInternet: [HKLM..\Shell\open\Command] (.Google Inc. - Google Chrome.) – C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
                  O68 - StartMenuInternet: <IEXPLORE.EXE> [HKLM..\Shell\open\Command] (.Microsoft Corporation - Internet Explorer.) – C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
                  O68 - StartMenuInternet: [HKLM..\Shell\open\Command] (.Maxthon International ltd. - Maxthon Cloud Browser.) – C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe =>.Maxthon (Asia) Limited.®
                  O68 - StartMenuInternet: <FIREFOX.EXE> [HKLM..\InstallInfo\ShowIconsCommand] (.Mozilla Corporation - Firefox Helper.) – C:\Program Files (x86)\Mozilla Firefox\uninstall\helper.exe =>.Mozilla Corporation
                  O68 - StartMenuInternet: [HKLM..\InstallInfo\ShowIconsCommand] (.Google Inc. - Google Chrome.) – C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc.
                  O68 - StartMenuInternet: <IEXPLORE.EXE> [HKLM..\InstallInfo\ShowIconsCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) – C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
                  O68 - StartMenuInternet: [HKLM..\InstallInfo\ShowIconsCommand] (.Maxthon International ltd. - Maxthon Cloud Browser.) – C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe =>.Maxthon International ltd.
                  O68 - StartMenuInternet: <FIREFOX.EXE> [HKLM..\InstallInfo\ReinstallCommand] (.Mozilla Corporation - Firefox Helper.) – C:\Program Files (x86)\Mozilla Firefox\uninstall\helper.exe =>.Mozilla Corporation
                  O68 - StartMenuInternet: [HKLM..\InstallInfo\ReinstallCommand] (.Google Inc. - Google Chrome.) – C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc.
                  O68 - StartMenuInternet: <IEXPLORE.EXE> [HKLM..\InstallInfo\ReinstallCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) – C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
                  O68 - StartMenuInternet: [HKLM..\InstallInfo\ReinstallCommand] (.Maxthon International ltd. - Maxthon Cloud Browser.) – C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe =>.Maxthon International ltd.
                  O68 - StartMenuInternet: <FIREFOX.EXE> [HKLM..\InstallInfo\HideIconsCommand] (.Mozilla Corporation - Firefox Helper.) – C:\Program Files (x86)\Mozilla Firefox\uninstall\helper.exe =>.Mozilla Corporation
                  O68 - StartMenuInternet: [HKLM..\InstallInfo\HideIconsCommand] (.Google Inc. - Google Chrome.) – C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc.
                  O68 - StartMenuInternet: <IEXPLORE.EXE> [HKLM..\InstallInfo\HideIconsCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) – C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
                  O68 - StartMenuInternet: [HKLM..\InstallInfo\HideIconsCommand] (.Maxthon International ltd. - Maxthon Cloud Browser.) – C:\Program Files (x86)\Maxthon\Bin\Maxthon.exe =>.Maxthon International ltd.
                  —\ Search Browser Infection (4) - 2s
                  O69 - SBI: SearchScopes [HKCU] {0633EE93-D776-472f-A0FF-E1416B8B2E3A} [DefaultScope] - (Bing) - http://www.bing.com/ =>.Bing.com
                  O69 - SBI: SearchScopes [HKCU] {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} - (Google) - http://www.google.com/ =>.Google Inc.
                  O69 - SBI: SearchScopes [HKLM] {0633EE93-D776-472f-A0FF-E1416B8B2E3A} [DefaultScope] - (@ieframe.dll,-12512) - http://www.bing.com/ =>.Bing.com
                  O69 - SBI: SearchScopes [HKLM] {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} - (Google) - http://www.google.com/ =>.Google Inc.
                  —\ Search Svchost Services (46) - 1s
                  O83 - Search Svchost Services: CertPropSvc (CertPropSvc) . (.Microsoft Corporation - Microsoft Smartcard Certificate Propagation.) – C:\WINDOWS\System32\certprop.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: SCPolicySvc (SCPolicySvc) . (.Microsoft Corporation - Microsoft Smartcard Certificate Propagation.) – C:\WINDOWS\System32\certprop.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: lanmanserver (lanmanserver) . (.Microsoft Corporation - Server Service DLL.) – C:\WINDOWS\system32\srvsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: gpsvc (gpsvc) . (.Microsoft Corporation - Group Policy Client.) – C:\WINDOWS\System32\gpsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: IKEEXT (IKEEXT) . (.Microsoft Corporation - IKE extension.) – C:\WINDOWS\System32\ikeext.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: iphlpsvc (iphlpsvc) . (.Microsoft Corporation - Service that offers IPv6 connectivity over.) – C:\WINDOWS\System32\iphlpsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: seclogon (seclogon) . (.Microsoft Corporation - Secondary Logon Service DLL.) – C:\WINDOWS\system32\seclogon.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: AppInfo (AppInfo) . (.Microsoft Corporation - Application Information Service.) – C:\WINDOWS\System32\appinfo.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: msiscsi (msiscsi) . (.Microsoft Corporation - iSCSI Discovery service.) – C:\WINDOWS\system32\iscsiexe.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: EapHost (EapHost) . (.Microsoft Corporation - Microsoft EAPHost service.) – C:\WINDOWS\System32\eapsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: schedule (schedule) . (.Microsoft Corporation - Task Scheduler Service.) – C:\WINDOWS\system32\schedsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: winmgmt (winmgmt) . (.Microsoft Corporation - WMI.) – C:\WINDOWS\system32\wbem\WMIsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: browser (browser) . (.Microsoft Corporation - Computer Browser Service DLL.) – C:\WINDOWS\System32\browser.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: SessionEnv (SessionEnv) . (.Microsoft Corporation - Remote Desktop Configuration service.) – C:\Windows\System32\SessEnv.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: wercplsupport (wercplsupport) . (.Microsoft Corporation - Problem Reports and Solutions.) – C:\WINDOWS\System32\wercplsupport.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: shpamsvc (shpamsvc) . (.Microsoft Corporation - SharedPC.AccountManager.) – C:\WINDOWS\system32\Windows.SharedPC.AccountManage r.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: Themes (Themes) . (.Microsoft Corporation - Windows Shell Theme Service Dll.) – C:\WINDOWS\system32\themeservice.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: lfsvc (lfsvc) . (.Microsoft Corporation - Geolocation Service.) – C:\WINDOWS\System32\lfsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: DmEnrollmentSvc (DmEnrollmentSvc) . (.Microsoft Corporation - Windows Managent Service DLL.) – C:\Windows\System32\Windows.Internal.Management.dl l [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: Irmon (Irmon) . (.Microsoft Corporation - Infrared Monitor.) – C:\WINDOWS\System32\irmon.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: Rasauto (Rasauto) . (.Microsoft Corporation - Remote Access AutoDial Manager.) – C:\WINDOWS\System32\rasauto.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: Rasman (Rasman) . (.Microsoft Corporation - Remote Access Connection Manager.) – C:\WINDOWS\System32\rasmans.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: Remoteaccess (Remoteaccess) . (.Microsoft Corporation - Dynamic Interface Manager.) – C:\Windows\System32\mprdim.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: SENS (SENS) . (.Microsoft Corporation - System Event Notification Service (SENS).) – C:\WINDOWS\System32\sens.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: Sharedaccess (Sharedaccess) . (.Microsoft Corporation - Microsoft NAT Helper Components.) – C:\WINDOWS\System32\ipnathlp.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: Tapisrv (Tapisrv) . (.Microsoft Corporation - Microsoft® Windows™ Telephony Server.) – C:\Windows\System32\tapisrv.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: wuauserv (wuauserv) . (.Microsoft Corporation - Windows Update Agent.) – C:\WINDOWS\system32\wuaueng.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: BITS (BITS) . (.Microsoft Corporation - Background Intelligent Transfer Service.) – C:\WINDOWS\System32\qmgr.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: ShellHWDetection (ShellHWDetection) . (.Microsoft Corporation - Windows Shell Services Dll.) – C:\Windows\System32\shsvcs.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: dmwappushservice (dmwappushservice) . (.Microsoft Corporation - dmwappushsvc.) – C:\WINDOWS\system32\dmwappushsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: WpnService (WpnService) . (.Microsoft Corporation - Windows Push Notification System Service.) – C:\WINDOWS\system32\WpnService.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: XboxNetApiSvc (XboxNetApiSvc) . (.Microsoft Corporation - Xbox Live Networking Service.) – C:\WINDOWS\system32\XboxNetApiSvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: DcpSvc (DcpSvc) . (.Microsoft Corporation - dcpsvc Task.) – C:\WINDOWS\system32\dcpsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: RetailDemo (RetailDemo) . (.Microsoft Corporation - RDXService.) – C:\WINDOWS\system32\RDXService.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: BDESVC (BDESVC) . (.Microsoft Corporation - BDE Service.) – C:\WINDOWS\System32\bdesvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: DsmSvc (DsmSvc) . (.Microsoft Corporation - Device Setup Manager.) – C:\WINDOWS\System32\DeviceSetupManager.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: NcaSvc (NcaSvc) . (.Microsoft Corporation - Microsoft Network Connectivity Assistant Se.) – C:\WINDOWS\System32\ncasvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: AppMgmt (AppMgmt) . (.Microsoft Corporation - Software installation Service.) – C:\Windows\System32\appmgmts.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: XblAuthManager (XblAuthManager) . (.Microsoft Corporation - Xbox Live Auth Manager.) – C:\WINDOWS\System32\XblAuthManager.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: UsoSvc (UsoSvc) . (.Microsoft Corporation - Update Session Orchestrator Core.) – C:\WINDOWS\system32\usocore.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: ProfSvc (ProfSvc) . (.Microsoft Corporation - ProfSvc.) – C:\WINDOWS\system32\profsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: UserManager (UserManager) . (.Microsoft Corporation - UserMgr.) – C:\WINDOWS\System32\usermgr.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: XblGameSave (XblGameSave) . (.Microsoft Corporation - Xbox Live Game Save Service.) – C:\WINDOWS\System32\XblGameSave.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: wisvc (wisvc) . (.Microsoft Corporation - Flight Settings.) – C:\WINDOWS\system32\flightsettings.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: wlidsvc (wlidsvc) . (.Microsoft Corporation - Microsoft® Account Service.) – C:\WINDOWS\system32\wlidsvc.dll [9239144] =>.Microsoft Corporation
                  O83 - Search Svchost Services: NetSetupSvc (NetSetupSvc) . (.Microsoft Corporation - Network Setup Service.) – C:\WINDOWS\System32\NetSetupSvc.dll [9239144] =>.Microsoft Corporation
                  —\ Windows Installer Scan (2) - 3s
                  [MD5.] [WIS][2015/04/28 17:46:19] (.APN, LLC - Ask.com ® - Install Builder.) – C:\WINDOWS\Installer\1de3b60.msi [9239144] =>Adware.Bandoo
                  [MD5.] [WIS][2014/02/12 12:57:46] (.Microsoft Corporations - Windows Installer XML - SOC (3.6.2723.0).) – C:\WINDOWS\Installer\5c453f.msi [9239144] =>Heuristic.Suspect
                  —\ Additional Scan (O88) (6) - 0s
                  C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Extensions\iahagolkpaghhinaljhjihagjg omdokb =>Hijacker.Browser
                  C:\Users\SamSwanson\AppData\Roaming\Mozilla\Extens ions{ec8030f7-c20a-464f-9b0e-13a3a9e97384} =>PUP.Optional.Wajam
                  HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uni nstall{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A} =>Riskware.QuickTime
                  HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\Curren tVersion\Uninstall{AF0CE7C0-A3E4-4D73-988B-B29187EC6E9A} =>Riskware.QuickTime
                  C:\WINDOWS\Installer\1de3b60.msi =>Adware.Bandoo
                  C:\WINDOWS\Installer\5c453f.msi =>Heuristic.Suspect
                  —\ Summary of the elements found (6) - 0s
                  Redirecting... =>PUP.Optional.CrossRider
                  Hijacker Browser, un pirate de navigateur internet. - ZAM =>Hijacker.Browser
                  Wajam, Logiciel Potentiellement Indésirable. - ZAM =>PUP.Optional.Wajam
                  https://nicolascoolman.eu/2017/01/15...are-quicktime/ =>Riskware.QuickTime
                  Bandoo, Logiciel publicitaire - ZAM =>Adware.Bandoo
                  Heuristic Suspect, 1 Logiciel Indésirable. - ZAM =>Heuristic.Suspect
                  ~ Unselected Options: O82,
                  ~ End of the scan, 120586 items in 08mn57s (2855)(0)
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #10
                    ZHP Fix [MEDIA=imgur]4bd9Ugb[/MEDIA]
                    [li]Disable your antivirus prior to this fix![/li]
                    [li]Download ZHP-Fix from here.[/li][li]Install it.[/li][li]Click Suivant 5 Times.[/li][li]Then Installer.[/li][li]Then Terminer.[/li][li]Then right clcick the ZHP Fix icon Run as admin.[/li][li]Copy the entire content of the code box below, the next step will grab it from your clipboard.[/li]
                    [li]Then click on import.[/li][li]Then click GO.[/li][li]Allow completion.[/li][li]A log file will appear on your desktop. [/li]
                    [li]Post it here in your next reply.[/li][/ul]
                    Code:
                    Script ZhpFix
                    SysRestore
                    EmptyFlash
                    EmptyTemp
                    FirewallRaz
                    EmptyCLSID
                    [MD5.A8FD9222E4D72596BB37DA8BE95C0BA4] [APT] [GoogleUpdateTaskMachineCore] (.Google Inc..) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                    [MD5.A8FD9222E4D72596BB37DA8BE95C0BA4] [APT] [GoogleUpdateTaskMachineUA] (.Google Inc..) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                    [MD5.DD7423ABBE2913E70D50E9318AD57EE4] [APT] [GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a] (.Google Inc..) -- C:\Users\SamSwanson\AppData\Local\Google\Update\GoogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                    [MD5.4E429B3FFB76C3EABC748ED3AFE54CF8] [APT] [Maxthon Update] (.Maxthon International ltd..) -- C:\Program Files (x86)\Maxthon\Bin\MxUp.exe [9239144] (.Activate.) =>.Maxthon (Asia) Limited.®
                    [MD5.00000000000000000000000000000000] [APT] [{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4}] (...) -- C:\ProgramData\Carbonite\Carbonite Backup\CarboniteUpgrade.exe (.not file.) [9239144] (.Activate.)
                    [MD5.00000000000000000000000000000000] [APT] [{EE492B24-CD47-404D-95D3-605112E375FA}] (...) -- S:\More VSTI\Orchestral.Tools.Metropolis.Ark.2.Orchestra.Of.The.Deep.KONTAKT-P2P\METROPOLIS Ark 2 Win Installer.exe (.not file.) [9239144] (.Activate.) =>PUP.Optional.CrossRider
                    O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) -- C:\WINDOWS\Tasks\GoogleUpdateTaskMachineCore.job [9239144] =>.Google Inc®
                    O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) -- C:\WINDOWS\Tasks\GoogleUpdateTaskMachineUA.job [9239144] =>.Google Inc®
                    O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) -- C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineCore [9239144] =>.Google Inc®
                    O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) -- C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineUA [9239144] =>.Google Inc®
                    O39 - APT: Maxthon Update - (.Maxthon International ltd..) -- C:\WINDOWS\System32\Tasks\Maxthon Update [9239144] =>.Maxthon (Asia) Limited.®
                    O39 - APT: {5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} - (...) -- C:\WINDOWS\System32\Tasks\{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} [9239144] (.Orphan.) =>.Superfluous.Orphan
                    O4 - HKCU\..\Run: [GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F8703B] . (.Google Inc. - Google Chrome.) -- C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                    O4 - HKCU\..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6381.0405\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6381.0405\amd64 (.not file.)
                    O4 - HKCU\..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64 (.not file.)
                    O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001\..\Run: [GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F8703B] . (.Google Inc. - Google Chrome.) -- C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                    O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001\..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6381.0405\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6381.0405\amd64 (.not file.)
                    O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001\..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64 (.not file.)
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://fonts.googleapis.com =>.Google Inc.
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://fonts.gstatic.com =>.Google Inc.
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://googleads.g.doubleclick.net =>.Google Inc.
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.google-analytics.com =>.Google Inc.
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.gstatic.com =>.Google Inc.
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google.com =>.Google Inc.
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.gstatic.com =>.Google Inc.
                    G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.youtube.com =>.Youtube
                    G2 - GCE: Preference [User Data\Default] [iahagolkpaghhinaljhjihagjgomdokb] [s3.amazonaws.com/com.alexa.toolbar/autoupd] VME =>Hijacker.Browser
                    P2 - EXT: (...) -- C:\Users\SamSwanson\AppData\Roaming\Mozilla\Extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384} =>PUP.Optional.Wajam
                    R0 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
                    R0 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
                    R0 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
                    R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
                    R3 - URLSearchHook: (no name) - {CFBFAE00-17A6-11D0-99CB-00C04FD64497} Orphan =>.Microsoft Internet Explorer
                    R4 - HKLM\SOFTWARE\Microsoft\Internet Explorer\PhishingFilter,EnabledV9 = 0
                    R4 - HKCU\SOFTWARE\Microsoft\Internet Explorer\PhishingFilter,Enabled = 2
                    R4 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\PhishingFilter,EnabledV9 = 0
                    R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyEnable = 0
                    R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,MigrateProxy = 1
                    R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,EnableHttp1_1 = 1
                    R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyHttp1.1 = 1
                    R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,AutoConfigProxy = wininet.dll
                    R5 - HKLM\SYSTEM\CurrentControlSet\services\NlaSvc\Parameters\Internet\ManualProxies []
                    HKLM\SOFTWARE\Wow6432Node\Eset =>.ESET
                    HKLM\SOFTWARE\Wow6432Node\IObit =>.IObit
                    HKLM\SOFTWARE\Wow6432Node\Yahoo =>.Yahoo! Inc.
                    HKCU\SOFTWARE\AVAST Software =>.AVAST Software
                    HKCU\SOFTWARE\Avg Secure Update =>.AVG Software
                    HKCU\SOFTWARE\ESET =>.ESET
                    O43 - CFD: 06/11/2014 - [] D -- C:\Program Files\AVAST Software =>.AVAST Software
                    O43 - CFD: 06/11/2014 - [0] D -- C:\Program Files\Bitdefender =>.Bitdefender
                    O43 - CFD: 11/01/2015 - [] D -- C:\Program Files (x86)\AVG =>.AVG Software
                    O43 - CFD: 23/12/2012 - [0] D -- C:\Program Files (x86)\GUM7E55.tmp
                    O43 - CFD: 05/12/2016 - [0] D -- C:\Program Files (x86)\IObit =>.IObit
                    O43 - CFD: 23/12/2012 - [] AD -- C:\Program Files (x86)\uTorrent =>.BitTorrent Inc®
                    O43 - CFD: 01/03/2017 - [0] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Booster 4 =>.IObit
                    O43 - CFD: 15/02/2016 - [0] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DriverMax =>.Innovative Solutions
                    O43 - CFD: 11/01/2015 - [] D -- C:\ProgramData\AVAST Software =>.AVAST Software
                    O43 - CFD: 24/07/2015 - [] D -- C:\ProgramData\AVG2015 =>.AVG Software
                    O43 - CFD: 02/01/2014 - [] D -- C:\ProgramData\BDLogging =>.Bitdefender
                    O43 - CFD: 06/11/2014 - [] D -- C:\ProgramData\Bitdefender =>.Bitdefender
                    O43 - CFD: 05/12/2016 - [] D -- C:\ProgramData\IObit =>.IObit
                    O43 - CFD: 11/01/2015 - [] D -- C:\Users\SamSwanson\AppData\Roaming\AVG2015 =>.AVG Software
                    O43 - CFD: 05/12/2016 - [] D -- C:\Users\SamSwanson\AppData\Roaming\IObit =>.IObit
                    O43 - CFD: 10/02/2017 - [] D -- C:\Users\SamSwanson\AppData\Roaming\mgyun =>.mgyun.com
                    O43 - CFD: 02/01/2014 - [0] D -- C:\Users\SamSwanson\AppData\Roaming\QuickScan =>.Bitdefender
                    O43 - CFD: 11/01/2015 - [] D -- C:\Users\SamSwanson\AppData\Roaming\TuneUp Software =>.TuneUp Software
                    O43 - CFD: 23/10/2016 - [] HD -- C:\Users\SamSwanson\AppData\Local\7e6o4rLRYCc7H
                    O43 - CFD: 12/08/2016 - [] HD -- C:\Users\SamSwanson\AppData\Local\7yk7MNqz
                    C:\Users\SamSwanson\AppData\Local\lptmp345652723
                    C:\Users\SamSwanson\AppData\Local\lptmp1274216945
                    C:\Users\SamSwanson\AppData\Local\Sgisu0yuIs6
                    C:\Users\SamSwanson\AppData\Local\WfcjZQxwceO5G
                    O43 - CFD: 22/05/2015 - [] D -- C:\Users\SamSwanson\AppData\Local\Avg =>.AVG Software
                    O43 - CFD: 11/01/2015 - [] D -- C:\Users\SamSwanson\AppData\Local\Avg2015 =>.AVG Software
                    O43 - CFD: 01/03/2017 - [] D -- C:\Users\SamSwanson\AppData\Local\ESET =>.ESET
                    O43 - CFD: 02/01/2014 - [] D -- C:\Users\SamSwanson\AppData\Local\lptmp1274216945
                    O43 - CFD: 12/12/2013 - [] D -- C:\Users\SamSwanson\AppData\Local\lptmp345652723
                    O43 - CFD: 13/08/2015 - [] HD -- C:\Users\SamSwanson\AppData\Local\Sgisu0yuIs6
                    [MD5.] [WIS][2015/04/28 17:46:19] (.APN, LLC - Ask.com ® - Install Builder.) -- C:\WINDOWS\Installer\1de3b60.msi [9239144] =>Adware.Bandoo
                    C:\Users\SamSwanson\AppData\Local\Google\Chrome\User Data\Default\Extensions\iahagolkpaghhinaljhjihagjgomdokb =>Hijacker.Browser
                    O43 - CFD: 13/08/2015 - [] HD -- C:\Users\SamSwanson\AppData\Local\WfcjZQxwceO5G
                    You need to copy and paste the above fix into the ZHP fix app. Then hit Go..
                    • slonslon7
                      • Mar 2017
                      • 14
                      #11
                      Rapport de ZHPFix 2015.10.19.9 par Nicolas Coolman, Update du 19/10/2015
                      Fichier d’export Registre :
                      Run by SamSwanson at 03/02/2017 12:34:43 AM
                      High Elevated Privileges : OK
                      Windows 8 Business Edition, 64-bit Service Pack 1 (14393)
                      Recycle Bin emptied (03mn AMs)
                      ========== Registry values ==========
                      REMOVES: FirewallRaz (SP) : C:\Program Files (x86)\FlashGet Network\FlashGet 3\FlashGet3.exe
                      ABSENT value Domain Profile: FirewallRaz :
                      REMOVES RunValue: Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64
                      REMOVES RunValue: Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64
                      ========== Elements of the registry data ==========
                      REMOVES: R0 - Main,Start Page = KCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page
                      REMOVES: R0 - Main,Start Page = KLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page
                      REMOVES: R0 - Main,Start Page = KLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page
                      REMOVES: R1 Search Page = Search - Microsoft Bing
                      REMOVES: R1 Search Page = MSN
                      REMOVES: R1 Search Page = about:NoAdd-ons
                      REMOVES: R1 Search Page = about:SecurityRisk
                      ========== Preferences browser ==========
                      NOW Chrome File: C:\Users\SamSwanson\AppData\Local\Google\Chrome\Us er Data\Default\Preferences
                      ABSENT Chrome Site: http://fonts.googleapis.com
                      ABSENT Chrome Site: http://fonts.gstatic.com
                      ABSENT Chrome Site: http://googleads.g.doubleclick.net
                      ABSENT Chrome Site: http://ssl.google-analytics.com
                      ABSENT Chrome Site: http://ssl.gstatic.com
                      ABSENT Chrome Site: http://www.google.com
                      ABSENT Chrome Site: http://www.gstatic.com
                      ABSENT Chrome Site: http://www.youtube.com
                      ========== Folders ==========
                      No folders empty CLSID Local user
                      ========== Files ==========
                      REMOVES Flash Cookies (0) (0 octets)
                      Deletes temporary Windows (0) (0 octets)
                      ========== Scheduled task ==========
                      REMOVES: GoogleUpdateTaskMachineCore
                      REMOVES: GoogleUpdateTaskMachineUA
                      REMOVES: GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a
                      REMOVES: Maxthon Update
                      REMOVES: {5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4}
                      REMOVES: {EE492B24-CD47-404D-95D3-605112E375FA}
                      ========== System restore ==========
                      The system successfully created restore point
                      ========== Summary ==========
                      4 : Registry values
                      7 : Elements of the registry data
                      1 : Folders
                      2 : Files
                      16 : Preferences browser
                      7 : Scheduled task
                      1 : System restore
                      End of clean in 15mn AMs
                      ========== Path to file report ==========
                      C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPFix[R1].txt - 03/02/2017 12:34:47 AM [3312]
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #12
                        I am not sure that you copied the entire fix…
                        Can you re run the ZHP fix this time copy everything below in bold text and re-run for me please.
                        _________________________________ Copy all below this line. __________________________________________________ ______________________________
                        Script ZhpFix
                        SysRestore
                        EmptyFlash
                        EmptyTemp
                        FirewallRaz
                        EmptyCLSID
                        [MD5.A8FD9222E4D72596BB37DA8BE95C0BA4] [APT] [GoogleUpdateTaskMachineCore] (.Google Inc..) – C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                        [MD5.A8FD9222E4D72596BB37DA8BE95C0BA4] [APT] [GoogleUpdateTaskMachineUA] (.Google Inc..) – C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                        [MD5.DD7423ABBE2913E70D50E9318AD57EE4] [APT] [GoogleUpdateTaskUserS-1-5-21-3236326594-2611474830-2656184370-1001UA1cf27e25ff0855a] (.Google Inc..) – C:\Users\SamSwanson\AppData\Local\Google\Update\Go ogleUpdate.exe [9239144] (.Activate.) =>.Google Inc®
                        [MD5.4E429B3FFB76C3EABC748ED3AFE54CF8] [APT] [Maxthon Update] (.Maxthon International ltd..) – C:\Program Files (x86)\Maxthon\Bin\MxUp.exe [9239144] (.Activate.) =>.Maxthon (Asia) Limited.®
                        [MD5.00000000000000000000000000000000] [APT] [{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4}] (…) – C:\ProgramData\Carbonite\Carbonite Backup\CarboniteUpgrade.exe (.not file.) [9239144] (.Activate.)
                        [MD5.00000000000000000000000000000000] [APT] [{EE492B24-CD47-404D-95D3-605112E375FA}] (…) – S:\More VSTI\Orchestral.Tools.Metropolis.Ark.2.Orchestra.O f.The.Deep.KONTAKT-P2P\METROPOLIS Ark 2 Win Installer.exe (.not file.) [9239144] (.Activate.) =>PUP.Optional.CrossRider
                        O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) – C:\WINDOWS\Tasks\GoogleUpdateTaskMachineCore.job [9239144] =>.Google Inc®
                        O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) – C:\WINDOWS\Tasks\GoogleUpdateTaskMachineUA.job [9239144] =>.Google Inc®
                        O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) – C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineC ore [9239144] =>.Google Inc®
                        O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) – C:\WINDOWS\System32\Tasks\GoogleUpdateTaskMachineU A [9239144] =>.Google Inc®
                        O39 - APT: Maxthon Update - (.Maxthon International ltd..) – C:\WINDOWS\System32\Tasks\Maxthon Update [9239144] =>.Maxthon (Asia) Limited.®
                        O39 - APT: {5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} - (…) – C:\WINDOWS\System32\Tasks{5F6010C8-60E5-41f3-BF5B-C3AF5DBE12D4} [9239144] (.Orphan.) =>.Superfluous.Orphan
                        O4 - HKCU..\Run: [GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F 8703B] . (.Google Inc. - Google Chrome.) – C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                        O4 - HKCU..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64 (.not file.)
                        O4 - HKCU..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64 (.not file.)
                        O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\Run: [GoogleChromeAutoLaunch_20359AAFD869880A09A939B153F 8703B] . (.Google Inc. - Google Chrome.) – C:\Users\SamSwanson\AppData\Local\Google\Chrome SxS\Application\chrome.exe =>.Google Inc®
                        O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6381.0405\amd64 (.not file.)
                        O4 - HKUS\S-1-5-21-3236326594-2611474830-2656184370-1001..\RunOnce: [Uninstall C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64] C:\Users\SamSwanson\AppData\Local\Microsoft\OneDri ve\17.3.6390.0509\amd64 (.not file.)
                        G2 - GCE: Preference [User Data\Default] [iahagolkpaghhinaljhjihagjgomdokb] [ https://s3.amazonaws.com/com.alexa.toolbar/autoupd ] VME =>Hijacker.Browser
                        P2 - EXT: (…) – C:\Users\SamSwanson\AppData\Roaming\Mozilla\Extens ions{ec8030f7-c20a-464f-9b0e-13a3a9e97384} =>PUP.Optional.Wajam
                        R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyEnable = 0
                        R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,MigrateProxy = 1
                        R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,EnableHttp1_1 = 1
                        R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyHttp1.1 = 1
                        R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,AutoConfigProxy = wininet.dll
                        R5 - HKLM\SYSTEM\CurrentControlSet\services\NlaSvc\Para meters\Internet\ManualProxies []
                        O43 - CFD: 06/11/2014 - [] D – C:\Program Files\AVAST Software =>.AVAST Software
                        O43 - CFD: 06/11/2014 - [0] D – C:\Program Files\Bitdefender =>.Bitdefender
                        O43 - CFD: 11/01/2015 - [] D – C:\Program Files (x86)\AVG =>.AVG Software
                        O43 - CFD: 23/12/2012 - [0] D – C:\Program Files (x86)\GUM7E55.tmp
                        O43 - CFD: 05/12/2016 - [0] D – C:\Program Files (x86)\IObit =>.IObit
                        O43 - CFD: 23/12/2012 - [] AD – C:\Program Files (x86)\uTorrent =>.BitTorrent Inc®
                        O43 - CFD: 01/03/2017 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Booster 4 =>.IObit
                        O43 - CFD: 15/02/2016 - [0] D – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DriverMax =>.Innovative Solutions
                        O43 - CFD: 11/01/2015 - [] D – C:\ProgramData\AVAST Software =>.AVAST Software
                        O43 - CFD: 24/07/2015 - [] D – C:\ProgramData\AVG2015 =>.AVG Software
                        O43 - CFD: 02/01/2014 - [] D – C:\ProgramData\BDLogging =>.Bitdefender
                        O43 - CFD: 06/11/2014 - [] D – C:\ProgramData\Bitdefender =>.Bitdefender
                        O43 - CFD: 05/12/2016 - [] D – C:\ProgramData\IObit =>.IObit
                        O43 - CFD: 11/01/2015 - [] D – C:\Users\SamSwanson\AppData\Roaming\AVG2015 =>.AVG Software
                        O43 - CFD: 05/12/2016 - [] D – C:\Users\SamSwanson\AppData\Roaming\IObit =>.IObit
                        O43 - CFD: 10/02/2017 - [] D – C:\Users\SamSwanson\AppData\Roaming\mgyun =>.mgyun.com
                        O43 - CFD: 02/01/2014 - [0] D – C:\Users\SamSwanson\AppData\Roaming\QuickScan =>.Bitdefender
                        O43 - CFD: 11/01/2015 - [] D – C:\Users\SamSwanson\AppData\Roaming\TuneUp Software =>.TuneUp Software
                        O43 - CFD: 23/10/2016 - [] HD – C:\Users\SamSwanson\AppData\Local\7e6o4rLRYCc7H
                        O43 - CFD: 12/08/2016 - [] HD – C:\Users\SamSwanson\AppData\Local\7yk7MNqz
                        O43 - CFD: 22/05/2015 - [] D – C:\Users\SamSwanson\AppData\Local\Avg =>.AVG Software
                        O43 - CFD: 11/01/2015 - [] D – C:\Users\SamSwanson\AppData\Local\Avg2015 =>.AVG Software
                        O43 - CFD: 01/03/2017 - [] D – C:\Users\SamSwanson\AppData\Local\ESET =>.ESET
                        O43 - CFD: 02/01/2014 - [] D – C:\Users\SamSwanson\AppData\Local\lptmp1274216945
                        O43 - CFD: 12/12/2013 - [] D – C:\Users\SamSwanson\AppData\Local\lptmp345652723
                        O43 - CFD: 13/08/2015 - [] HD – C:\Users\SamSwanson\AppData\Local\Sgisu0yuIs6
                        O43 - CFD: 13/08/2015 - [] HD – C:\Users\SamSwanson\AppData\Local\WfcjZQxwceO5G
                        • slonslon7
                          • Mar 2017
                          • 14
                          #13
                          Sure, I had thought I copied everything but can certainly run it again.
                          Run by SamSwanson at 03/02/2017 12:52:04 AM
                          Recycle Bin emptied (01mn AMs)
                          ========== Registry keys ==========
                          REMOVES: HKLM\SOFTWARE\Wow6432Node\Eset
                          REMOVES: HKLM\SOFTWARE\Wow6432Node\IObit
                          REMOVES: HKLM\SOFTWARE\Wow6432Node\Yahoo
                          REMOVES: HKCU\SOFTWARE\AVAST Software
                          REMOVES: HKCU\SOFTWARE\Avg Secure Update
                          REMOVES: HKCU\SOFTWARE\ESET
                          REMOVES: SearchScopes :{0633EE93-D776-472f-A0FF-E1416B8B2E3A}
                          ABSENT value Standard Profile: FirewallRaz :
                          REMOVES: URLSearchHook: {CFBFAE00-17A6-11D0-99CB-00C04FD64497}
                          REMOVES: R1 Search Page = http://google.com
                          REMOVES: R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyEnable
                          REMOVES: R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,MigrateProxy
                          REMOVES: R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,EnableHttp1_1
                          REMOVES: R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyHttp1.1
                          REMOVES: R5 AutoConfigProxy = wininet.dll
                          REMOVES: C:\Program Files\AVAST Software
                          REMOVES: C:\Program Files\Bitdefender
                          REMOVES: C:\Program Files (x86)\AVG
                          REMOVES: C:\Program Files (x86)\GUM7E55.tmp
                          REMOVES: C:\Program Files (x86)\IObit
                          REMOVES: C:\Program Files (x86)\uTorrent
                          REMOVES: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Booster 4
                          REMOVES: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DriverMax
                          REMOVES: C:\ProgramData\AVAST Software
                          REMOVES: C:\ProgramData\AVG2015
                          REMOVES: C:\ProgramData\BDLogging
                          REMOVES: C:\ProgramData\Bitdefender
                          REMOVES: C:\ProgramData\IObit
                          REMOVES: C:\Users\SamSwanson\AppData\Roaming\AVG2015
                          REMOVES: C:\Users\SamSwanson\AppData\Roaming\IObit
                          REMOVES: C:\Users\SamSwanson\AppData\Roaming\mgyun
                          REMOVES: C:\Users\SamSwanson\AppData\Roaming\QuickScan
                          REMOVES: C:\Users\SamSwanson\AppData\Roaming\TuneUp Software
                          REMOVES: C:\Users\SamSwanson\AppData\Local\7e6o4rLRYCc7H
                          REMOVES: C:\Users\SamSwanson\AppData\Local\7yk7MNqz
                          REMOVES: c:\users\samswanson\appdata\local\lptmp345652723
                          REMOVES: c:\users\samswanson\appdata\local\lptmp1274216945
                          REMOVES: c:\users\samswanson\appdata\local\sgisu0yuis6
                          REMOVES: c:\users\samswanson\appdata\local\wfcjzqxwceo5g
                          REMOVES: C:\Users\SamSwanson\AppData\Local\Avg
                          REMOVES: C:\Users\SamSwanson\AppData\Local\Avg2015
                          REMOVES: C:\Users\SamSwanson\AppData\Local\ESET
                          REMOVES: c:\users\samswanson\appdata\roaming\mozilla\extens ions{ec8030f7-c20a-464f-9b0e-13a3a9e97384}
                          REMOVES: c:\users\samswanson\appdata\local\google\chrome\us er data\default\preferences
                          REMOVES: C:\WINDOWS\Installer\1de3b60.msi
                          ========== Other ==========
                          NON-TREATY R5 - HKLM\SYSTEM\CurrentControlSet\services\NlaSvc\Para meters\Internet\ManualProxies
                          7 : Registry keys
                          3 : Registry values
                          14 : Elements of the registry data
                          29 : Folders
                          4 : Files
                          1 : System restore
                          1 : Other
                          End of clean in 29mn AMs
                          C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPFix[R1].txt - 03/02/2017 12:34:47 AM [3400]
                          C:\Users\SamSwanson\AppData\Roaming\ZHP\ZHPFix[R2].txt - 03/02/2017 12:52:05 AM [5434]
                          • Malnutrition
                            PCHF Moderator
                            • 7041
                            #14
                            Ok, that looks like everything was removed for sure this time.
                            Anymore issues to speak of, or do you consider this solved?
                            • slonslon7
                              • Mar 2017
                              • 14
                              #15
                              Case closed - all solved from here. Thank you so much for the assistance, it was great!
