PC slower than it should be
  • atay
    • Feb 2017
    • 35
    #16
    RogueKiller V12.9.8.0 (x64) [Feb 21 2017] (Free) von Adlice Software
    Betriebssystem : Windows 7 (6.1.7601 Service Pack 1) 64 bits version
    Gestartet in : Normalmodus
    User : Arda [Administrator]
    Gestartet von : C:\Program Files\RogueKiller\RogueKiller64.exe
    Modus : Löschen – Datum : 02/25/2017 20:55:00 (Dauer : 00:13:49)
    ¤¤¤ Prozesse : 0 ¤¤¤
    ¤¤¤ Registry : 2 ¤¤¤
    [PUM.SearchPage] (X64) HKEY_USERS\S-1-5-21-289047654-888293549-2986845424-1000\Software\Microsoft\Internet Explorer\Main | Search Bar : Preserve → Ersetzt ( Internet Explorer 6 Search Companion is no longer supported. )
    [PUM.SearchPage] (X86) HKEY_USERS\S-1-5-21-289047654-888293549-2986845424-1000\Software\Microsoft\Internet Explorer\Main | Search Bar : Preserve → Ersetzt ( Internet Explorer 6 Search Companion is no longer supported. )
    ¤¤¤ Tasks : 0 ¤¤¤
    ¤¤¤ Dateien : 0 ¤¤¤
    ¤¤¤ WMI : 0 ¤¤¤
    ¤¤¤ Hosts-Datei : 0 ¤¤¤
    ¤¤¤ Anti-Rootkit : 0 (Driver: Geladen) ¤¤¤
    ¤¤¤ Webbrowser : 1 ¤¤¤
    [PUM.SearchPage][Chrome:Config] Default [SecurePrefs] : default_search_provider_data.template_url_data.key word [ http://www.google.com/ ] → Gelöscht
    ¤¤¤ MBR-Übeprüfung : ¤¤¤
    +++++ PhysicalDrive0: WDC WD1002FAEX-00Z3A0 ATA Device +++++
    — User —
    [MBR] f04c963f1b12ef03e43aa8b39a98cb8f
    [BSP] c79d948596de15f294523c618448265a : Empty|VT.Unknown MBR Code
    Partition table:
    0 - [MAN-MOUNT] EFI system partition | Offset (sectors): 2048 | Size: 100 MB
    1 - [MAN-MOUNT] Microsoft reserved partition | Offset (sectors): 206848 | Size: 128 MB
    2 - Basic data partition | Offset (sectors): 468992 | Size: 953640 MB
    User = LL1 … OK
    User = LL2 … OK
    • Malnutrition
      PCHF Moderator
      • 7041
      #17
      Step 1: ClearLNK
      Download ClearLNK save it to your desktop.
      Drag the file Check_Browsers_LNK from your Collection log made earlier.
      As per picture.
      A report on the work as a file ClearLNK- .log
      Will be produced, post that log.
      https://pchelpforum.net/proxy.php?image=https%3A%2F%2Fup2sha.re%2Fuploads% 2F2015%2F3%2FBPD7B3BAgEQl.gif&hash=f65630ba2178027 f4643224f28999e44
      Step 2: AVZ Fix
      Disable your antivirus prior to this fix.
      Copy the content of the code box below.
      [ICODE] begin DeleteFile('C:\Windows\system32\diagtrack.dll'); DeleteFile('C:\Windows\system32\tasks\Microsoft\Wi ndows\Application Experience'); DeleteFile('C:\Windows\system32\tasks\Microsoft\Wi ndows\Customer Experience Improvement Program'); DeleteFile('C:\Windows\system32\diagtrack.dll','32 '); RegKeyParamDel('HKEY_LOCAL_MACHINE','SYSTEM\Curren tControlSet\Services\DiagTrack\Parameters','Servic eDll'); DeleteFile('C:\Windows\system32\Tasks\Microsoft\Wi ndows\Media Center\RecordingRestart','64'); DeleteFile('C:\Windows\system32\Tasks\Microsoft\Wi ndows\Media Center\mcupdate','64'); RebootWindows(true); end.[/ICODE]
      Open the folder you unzipped Autologger in. Double click the AVZ4 folder Right click AVZ run as admin. (Xp users Double Click)
      Go to file – Custom Scripts.
      Paste the content of your clipboard into the Custom Script Area.
      Click the Run Button. https://pchelpforum.net/attachments/...7-23-png.1484/
      The program will reboot your machine.
      Step 3: Hijack This Fix.
      Locate the HijackThis file within the Autologger folder, Right Click Run as Admin.
      Click System Scan Only.
      O4 - HKCU..\Run: [Skype] “C:\Program Files (x86)\Skype\Phone\Skype.exe” /minimized /regrun
      O4 - HKCU..\Run: [Spotify Web Helper] “C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebH elper.exe”
      O4 - HKCU..\Run: [Spotify] “C:\Users\Arda\AppData\Roaming\Spotify\Spotify.exe ” -autostart -minimized
      O4 - HKCU..\Run: [Steam] “C:\Program Files (x86)\Steam\steam.exe” -silent
      O4 - HKLM..\Run: [NvBackend] “C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe”
      O4 - HKLM..\Run: [iTunesHelper] “C:\Program Files\iTunes\iTunesHelper.exe”
      O4 - HKU\S-1-5-19..\Run: [Sidebar] C:\Program Files\Windows Sidebar\Sidebar.exe /autoRun
      O4 - HKU\S-1-5-20..\Run: [Sidebar] C:\Program Files\Windows Sidebar\Sidebar.exe /autoRun
      O4-32 - HKLM..\Run: [P17RunE] RunDll32 P17RunE.dll,RunDLLEntry
      O22 - ScheduledTask: (Queued) Adobe Acrobat Update Task - {root} - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe
      O22 - ScheduledTask: (Queued) ProgramDataUpdater - \Microsoft\Windows\Application Experience - C:\Windows\system32\compattelrunner.exe -maintenance
      O22 - ScheduledTask: (Ready) AppleSoftwareUpdate - \Apple - C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe -task
      O22 - ScheduledTask: (Ready) GoogleUpdateTaskMachineCore - {root} - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe /c
      O22 - ScheduledTask: (Ready) GoogleUpdateTaskMachineUA - {root} - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe /ua /installsource scheduler
      O22 - ScheduledTask: (Ready) Microsoft Compatibility Appraiser - \Microsoft\Windows\Application Experience - C:\Windows\system32\CompatTelRunner.exe
      O22 - ScheduledTask: (Ready) SqmUpload_S-1-5-21-289047654-888293549-2986845424-1000 - \WPD - C:\Windows\system32\rundll32.exe portabledeviceapi.dll,#1
      O22 - ScheduledTask: (Ready) ValidationTask - \Microsoft\Windows\Windows Activation Technologies - C:\Windows\system32\Wat\WatAdminSvc.exe /run
      O22 - ScheduledTask: (Ready) ValidationTaskDeadline - \Microsoft\Windows\Windows Activation Technologies - C:\Windows\system32\schtasks.exe /run /I /TN “\Microsoft\Windows\Windows Activation Technologies\ValidationTask”
      Now click on fix checked.
      • atay
        • Feb 2017
        • 35
        #18
        ClearLNK by Alex Dragokas ver. 2.9.0.11
        OS: x64 Windows 7 Home Premium, 6.1.7601, Service Pack: 1
        Time: 27.02.2017 - 00:47
        Language: OS: de-DE (0x407). Display: de-DE (0x407). Non-Unicode: de-DE (0x407)
        Elevated: Yes
        User: Arda (group: Administrator)
        _____________________________ Logbeginn ______________________________
        [DEL ] 1 “C:\Users\Arda\Desktop\just ****\Unknown Device Identifier.lnk” (Ziel ist nicht wiederhergestellt)
        [DEL ] 2 “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EA\BioWare\Star Wars - The Old Republic\View License.lnk” (Ziel ist nicht wiederhergestellt)
        _____________________________ Statistik ______________________________
        Die Heilung wird ausgeführt: 1 mal pro Tag.
        Insgesamt verarbeitet: 2
        Gelöscht: 2
        ____________________________ Berichtsende ____________________________CRC32: E8BB8B85
        • Malnutrition
          PCHF Moderator
          • 7041
          #19
          Alright, how is your computer running now?
          • atay
            • Feb 2017
            • 35
            #20
            Seems the same. Currently running the Hijack fix, ill check tomorrow if it runs better with the fix. Also, I couldn’t find all files you listed, 5 were not in the list.
            • Malnutrition
              PCHF Moderator
              • 7041
              #21
              It happens.
              After the fix run a check disk on the machine from elevated command prompt.
              Run chkdsk /f /r from elevated command prompt.
              [MEDIA=youtube]4feZG3LebOg[/MEDIA]
              After the checkdisk…
              https://sites.google.com/site/canned...kdskResult.png Scan with ListChkDskResult
              Please download ListChkDskResult by SleepyDude and save it to your desktop.
              [li]Right-click on https://sites.google.com/site/canned...kdskResult.png icon and select https://sites.google.com/site/canned...RunAsAdmin.jpg Run as Administrator to start the tool.[/li][li]A message about checking Windows Event Log will pop-up. Click OK.[/li][li]Wait patiently until a notepad window will open. This won’t take long.[/li][li]The displayed logfile will be also saved to your desktop as ListChkDskResult.txt.[/li][/ul]
              Please include the content of this file in your next reply.
              • Malnutrition
                PCHF Moderator
                • 7041
                #22
                @atay How about an update for us? Have you run the checkdisk as of yet?
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  #23
                  Once you have run the check disk…
                  PC Hunter Scan!
                  Download PCHunter
                  Disable your antivirus prior to this scan!!
                  Unzip the program to your desktop.
                  You will need to run the version that is compatible with your windows.
                  Right click either the 64 or 32 bit version and Run as Administrator.
                  After the program starts, go to the Examination Tab.
                  Click it once – Look at the bottom and check mark Hide Safe Items.
                  Then click Generate Examination Report.
                  Allow 5 to 10 minutes for the program to generate the report.
                  Once complete you will be able to click the Export Examination Report button.
                  Save it where you like and name it what you like.
                  Then copy the entire report, and paste it here in your next reply.
                  __________________________________________________ ___________________________________________
                  • atay
                    • Feb 2017
                    • 35
                    #24
                    Sorry, I have been busy the last few days.
                    ListChkdskResult by SleepyDude v0.1.7 Beta | 21-09-2013
                    ------< Log generate on 01.03.2017 05:05:48 >------
                    Category: 0
                    Computer Name: Arda-PC
                    Event Code: 1001
                    Record Number: 16701
                    Source Name: Microsoft-Windows-Wininit
                    Time Written: 02-28-2017 @ 22:37:29
                    Event Type: Informationen
                    User:
                    Message:
                    File system on C: is checked.
                    The type of the file system is NTFS.
                    A disk check is planned.
                    The disk check is now running.
                    CHKDSK checks files (phase 1 of 5) …
                    336128 records processed.
                    File verification finished.
                    535 large records processed.
                    0 invalid records processed.
                    0 I / O records.
                    70 processing records processed.
                    CHKDSK Checks Indices (Phase 2 of 5) …
                    451854 Processing of index entries.
                    Index check finished.
                    0 non-indexed files.
                    0 non-indexed files restored.
                    CHKDSK Verifies Safety Descriptions (Phase 3 of 5) …
                    336128 SDs / SIDs are processed.
                    1162 unused index entries from index $ SII of file 0x9 are cleared.
                    1162 unused index entries from index $ SDH of file 0x9 are cleaned up.
                    1162 unused security descriptions are cleaned up.
                    Verification of the safety descriptions ended.
                    57864 Data files processed.
                    CHKDSK reviews USN journal …
                    34855088 USN bytes processed.
                    The review of the USN Journal has been completed.
                    CHKDSK verifies data files (phase 4 of 5) …
                    336112 Files were processed.
                    Date data check finished.
                    CHKDSK checks free space (phase 5 of 5) …
                    201562729 free cluster processing.
                    Verification of free space is finished.
                    CHKDSK has found free memory, which is stored in the MFT bitmap (master
                    FileTable) is marked as assigned.
                    CHKDSK has found free memory, which in the volume bitmap as
                    Assigned.
                    Windows has fixed problems in the file system.
                    976527359 KB Disk space on the disk total
                    169686724 KB in 200994 files
                    121852 KB in 57865 indexes
                    0 KB in bad sectors
                    467863 KB used by the system
                    65536 KB from the log file
                    806250920 KB available on the disk
                    4096 bytes in each allocation unit
                    244131839 Allocation units on the data carrier total
                    201562730 Allocating units available on the data carrier
                    Internal information:
                    00 21 05 00 37 f3 03 00 e5 06 07 00 00 00 00 00 .. 7 …
                    77 02 00 00 46 00 00 00 00 00 00 00 00 00 00 00 w … F …
                    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
                    The data carrier check has been completed.
                    Please wait until the computer has restarted.
                    • atay
                      • Feb 2017
                      • 35
                      #25
                      PC Hunter Standard — Computer Examination Report
                      Examination Date: 2017-03-01 05:08
                      OS Information: Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
                      Internet Explorer: 9.11.9600.18537
                      Examination Items:
                      Process
                      Process Modules
                      Process Threads
                      Kernel Module
                      Notify Routine
                      Filter
                      DPC Timer
                      Worker Thread
                      HalDispatchTable
                      HalPrivateDispatchTable
                      HalAcpiDispatchTable
                      Wdf01000 Dispatch Fun
                      WdfFunction
                      MiniFilter
                      File System
                      Sfilter FileSystem Filter Callback
                      ClassInitData Callback
                      Npfs Dispatch Fun
                      Msfs Dispatch Fun
                      Usbport Dispatch Fun
                      System Debug
                      Object Hijack
                      Direct IO
                      GDT
                      SSDT
                      Shadow SSDT
                      FSD
                      Keyboard
                      I8042prt
                      Mouclass
                      Partmgr
                      Classpnp
                      Atapi
                      Acpi
                      Scsi
                      Kernel Hook
                      PTE HOOK
                      Kernel Hook
                      IDT
                      Message Hook
                      Process Hook
                      KernelCallbackTable
                      Port
                      Tcpip
                      Nsiproxy
                      Tdx
                      Ndis Handler
                      IE Plugin
                      IE Shell
                      Spi
                      Hosts File
                      Startup
                      Service
                      Schedule Task
                      File Association
                      IFEO
                      IME/CTF
                      Firewall Rule
                      System User Name
                      Scan MBR Rootkit
                      Process
                      Code:
                         NvStreamNetworkService.exe - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe - NVIDIA Corporation
                         nvtray.exe - C:\Program Files\NVIDIA Corporation\Display\nvtray.exe - NVIDIA Corporation
                         QHSafeTray.exe *32 - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                         SkypeBrowserHost.exe *32 - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe - Skype Technologies
                         Skype.exe *32 - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                         NvBackend.exe *32 - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                         pabeSvc64.exe - C:\Program Files\Intel\BCA\pabeSvc64.exe - Intel(R) Corporation
                         NvStreamUserAgent.exe - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe - NVIDIA Corporation
                         Steam.exe *32 - C:\Program Files (x86)\Steam\Steam.exe - Valve Corporation
                         audiodg.exe - C:\Windows\System32\audiodg.exe - Microsoft Corporation
                         steamwebhelper.exe *32 - C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - Valve Corporation
                         chrome.exe *32 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                         QHActiveDefense.exe *32 - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                         iTunes.exe - C:\Program Files\iTunes\iTunes.exe - Apple Inc.
                         nvvsvc.exe - C:\Windows\System32\nvvsvc.exe - NVIDIA Corporation
                         iTunesHelper.exe - C:\Program Files\iTunes\iTunesHelper.exe - Apple Inc.
                         iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                         CTAudSvc.exe *32 - C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe - Creative Technology Ltd
                         NvNetworkService.exe *32 - C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe - NVIDIA Corporation
                         nvxdsync.exe - C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe - NVIDIA Corporation
                         NvStreamService.exe - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe - NVIDIA Corporation
                         PCHunter64.exe - C:\Users\Arda\Desktop\PCHunter_free\PCHunter64.exe - ????(??)????????
                         GoogleUpdate.exe *32 - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe - Google Inc.
                         armsvc.exe *32 - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe - Adobe Systems Incorporated
                         mDNSResponder.exe - C:\Program Files\Bonjour\mDNSResponder.exe - Apple Inc.
                         GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                         QHWatchdog.exe *32 - C:\Program Files (x86)\360\Total Security\safemon\QHWatchdog.exe - QIHU 360 SOFTWARE CO. LIMITED
                         APSDaemon.exe *32 - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe - Apple Inc.
                         McAfee.TrueKey.Service.exe - C:\Program Files\TrueKey\McAfee.TrueKey.Service.exe - McAfee, Inc.
                         AppleMobileDeviceService.exe - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe - Apple Inc.
                         McTkSchedulerService.exe - C:\Program Files\TrueKey\McTkSchedulerService.exe - McAfee, Inc.
                         ViakaraokeSrv.exe - C:\Windows\System32\ViakaraokeSrv.exe - VIA Technologies, Inc.
                         SteamService.exe *32 - C:\Program Files (x86)\Common Files\Steam\SteamService.exe - Valve Corporation
                         SpotifyWebHelper.exe *32 - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe - Spotify Ltd
                         AppleMobileDeviceHelper.exe *32 - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceHelper.exe - Apple Inc.
                         distnoted.exe *32 - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\distnoted.exe - Apple Inc.
                      Process Modules
                      Code:
                        Image File Name[System]Modules
                      Code:
                        Image File Name[NvStreamNetworkService.exe]Modules
                               SSLEAY32.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\SSLEAY32.dll - The OpenSSL Project,  http://www.openssl.org/
                               LIBEAY32.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\LIBEAY32.dll - The OpenSSL Project,  http://www.openssl.org/
                               MessageBus.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\MessageBus.dll -
                               libprotobuf.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\libprotobuf.dll -
                               Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               nvapi64.dll - C:\Windows\system32\nvapi64.dll - NVIDIA Corporation
                               NvMdnsPlugin.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Plugins\NSS\NvMdnsPlugin.dll -
                               NvPortForwardPlugin.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Plugins\NSS\NvPortForwardPlugin.dll -
                               RtspPlugin.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Plugins\NSS\RtspPlugin.dll -
                               RtspServer.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\RtspServer.dll -
                      Code:
                        Image File Name[nvtray.exe]Modules
                               NvUI.dll - C:\Program Files\NVIDIA Corporation\Display\NvUI.dll - NVIDIA Corporation
                               NvBackendAPI64.DLL - C:\Program Files\NVIDIA Corporation\Update Core\NvBackendAPI64.DLL - NVIDIA Corporation
                               NvGFTrayPlugin.dll - C:\Program Files\NVIDIA Corporation\Update Core\NvGFTrayPlugin.dll - NVIDIA Corporation
                               NvGFTrayPluginR.DLL - C:\Program Files\NVIDIA Corporation\Update Core\NvGFTrayPluginR.DLL - NVIDIA Corporation
                      Code:
                        Image File Name[QHSafeTray.exe]Modules
                               QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               360base.dll - C:\Program Files (x86)\360\Total Security\360base.dll - 360.cn
                               i18n.dll - C:\Program Files (x86)\360\Total Security\i18n.dll - Qihu 360 Software Co., Ltd.
                               BAPI.dll - C:\Program Files (x86)\360\Total Security\deepscan\BAPI.dll - 360.cn
                               CrashReport.dll - C:\Program Files (x86)\360\Total Security\CrashReport.dll - 360.cn
                               somkernl.dll - C:\Program Files (x86)\360\Total Security\softmgr\somkernl.dll - 360.cn
                               360netbase.dll - C:\Program Files (x86)\360\Total Security\360netbase.dll - 360.cn
                               360TSCommon.dll - C:\Program Files (x86)\360\Total Security\360TSCommon.dll - QIHU 360 SOFTWARE CO. LIMITED
                               sites.dll - C:\Program Files (x86)\360\Total Security\sites.dll - 360.cn
                               qutmload.dll - C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll -
                               mdnsNSP.dll - C:\Program Files (x86)\Bonjour\mdnsNSP.dll - Apple Inc.
                               i18ngi.dll - C:\Program Files (x86)\360\Total Security\i18ngi.dll - 360.cn
                               cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               360conf.dll - C:\Program Files (x86)\360\Total Security\360conf.dll - Qihu 360 Software Co., Ltd.
                               heavygate.dll - C:\Program Files (x86)\360\Total Security\deepscan\heavygate.dll - Qihu 360 Software Co., Ltd.
                               ipcservice.dll - C:\Program Files (x86)\360\Total Security\ipc\ipcservice.dll - Qihu 360 Software Co., Ltd.
                               x64for32lib.dll - C:\Program Files (x86)\360\Total Security\ipc\x64for32lib.dll - 360.cn
                               CleanPlusCache.tpi - C:\Program Files (x86)\360\Total Security\safemon\CleanPlusCache.tpi - QIHU 360 SOFTWARE CO. LIMITED
                               360bsmon.tpi - C:\Program Files (x86)\360\Total Security\safemon\360bsmon.tpi - Qihu 360 Software Co., Ltd.
                               360connect.tpi - C:\Program Files (x86)\360\Total Security\safemon\360connect.tpi - QIHU 360 SOFTWARE CO. LIMITED
                               360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               360Common.dll - C:\Program Files (x86)\360\Total Security\360Common.dll - 360.cn
                               SomProxy.dll - C:\Program Files (x86)\360\Total Security\safemon\SomProxy.dll - Qihu 360 Software Co., Ltd.
                               360GuardBase.dll - C:\Program Files (x86)\360\Total Security\safemon\360GuardBase.dll - 360.cn
                               urlproc.dll - C:\Program Files (x86)\360\Total Security\safemon\urlproc.dll - Qihu 360 Software Co., Ltd.
                               safemonhlp.dll - C:\Program Files (x86)\360\Total Security\safemon\safemonhlp.dll - Qihu 360 Software Co., Ltd.
                               safemon.dll - C:\Program Files (x86)\360\Total Security\safemon\safemon.dll - Qihu 360 Software Co., Ltd.
                               spsafe.dll - C:\Program Files (x86)\360\Total Security\safemon\spsafe.dll - Qihu 360 Software Co., Ltd.
                               PDown.dll - C:\Program Files (x86)\360\Total Security\PDown.dll - Qihu 360 Software Co., Ltd.
                               360util.dll - C:\Program Files (x86)\360\Total Security\360util.dll - 360.cn
                               wdui2.dll - C:\Program Files (x86)\360\Total Security\safemon\wdui2.dll -
                               360hipsPopWnd.dll - C:\Program Files (x86)\360\Total Security\safemon\360hipsPopWnd.dll - Qihu 360 Software Co., Ltd.
                               AntiAdwa.dll - C:\Program Files (x86)\360\Total Security\AntiAdwa.dll - QIHU360 SOFTWARE CO. LIMITED
                               dynlenv.dll - C:\Program Files (x86)\360\Total Security\dynlenv.dll - 360.cn
                               360Udisk.tpi - C:\Program Files (x86)\360\Total Security\safemon\360Udisk.tpi - Qihu 360
                      Code:
                        Image File Name[winlogon.exe]Modules
                      Code:
                        Image File Name[lsm.exe]Modules
                      Code:
                        Image File Name[SkypeBrowserHost.exe]Modules
                               SkypeBrowserHost.exe - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe - Skype Technologies
                      Code:
                        Image File Name[Skype.exe]Modules
                               Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               nvd3dum.dll - C:\Windows\syswow64\nvd3dum.dll - NVIDIA Corporation
                               iNetSafe.dll - C:\Program Files (x86)\360\Total Security\safemon\iNetSafe.dll - Qihu 360 Software Co., Ltd.
                               I18N.dll - C:\Program Files (x86)\360\Total Security\I18N.dll - Qihu 360 Software Co., Ltd.
                               Updater.dll - C:\Program Files (x86)\Skype\Updater\Updater.dll - Skype Technologies
                      Code:
                        Image File Name[NvBackend.exe]Modules
                               NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               detoured.dll - C:\Program Files (x86)\NVIDIA Corporation\Update Core\detoured.dll -
                               Ontology.dll - C:\Users\Arda\AppData\Local\NVIDIA\NvBackend\ApplicationOntology\Ontology.dll - NVIDIA Corporation
                      Code:
                        Image File Name[pabeSvc64.exe]Modules
                               redwood64.dll - C:\Program Files\Intel\BCA\redwood64.dll - Intel(R) Corporation
                               BluetoothLEProvider64.dll - C:\Program Files\Intel\BCA\Providers\BluetoothLEProvider64.dll - Intel(R) Corporation
                               BluetoothProvider64.dll - C:\Program Files\Intel\BCA\Providers\BluetoothProvider64.dll - Intel(R) Corporation
                               DataVaultProvider64.dll - C:\Program Files\Intel\BCA\Providers\DataVaultProvider64.dll - Intel(R) Corporation
                               deviceIDProvider64.dll - C:\Program Files\Intel\BCA\Providers\deviceIDProvider64.dll - Intel(R) Corporation
                               faceProvider64.dll - C:\Program Files\Intel\BCA\Providers\faceProvider64.dll - Intel(R) Corporation
                               LocationProvider64.dll - C:\Program Files\Intel\BCA\Providers\LocationProvider64.dll - Intel(R) Corporation
                               SgxProvider64.dll - C:\Program Files\Intel\BCA\Providers\SgxProvider64.dll - Intel(R) Corporation
                               WifiInfoProvider64.dll - C:\Program Files\Intel\BCA\Providers\WifiInfoProvider64.dll - Intel(R) Corporation
                      Code:
                        Image File Name[NvStreamUserAgent.exe]Modules
                               boost_system-vc120-mt-1_58.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\boost_system-vc120-mt-1_58.dll -
                               boost_regex-vc120-mt-1_58.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\boost_regex-vc120-mt-1_58.dll -
                               mdnsNSP.dll - C:\Program Files\Bonjour\mdnsNSP.dll - Apple Inc.
                               NvBackendAPI64.dll - C:\Program Files\NVIDIA Corporation\Update Core\NvBackendAPI64.dll - NVIDIA Corporation
                      Code:
                        Image File Name[smss.exe]Modules
                      Code:
                        Image File Name[svchost.exe]Modules
                               Updater.exe - C:\Program Files (x86)\Skype\Updater\Updater.exe - Skype Technologies
                               UI0Detect.exe - C:\Windows\System32\UI0Detect.exe - Microsoft Corporation
                               wer.dll - C:\Windows\System32\wer.dll - Microsoft Corporation
                               sppsvc.exe - C:\Windows\System32\sppsvc.exe - Microsoft Corporation
                               WatUX.exe - C:\Windows\System32\Wat\WatUX.exe - Microsoft Corporation
                               wininit.exe - C:\Windows\System32\wininit.exe - Microsoft Corporation
                               VSSVC.exe - C:\Windows\System32\VSSVC.exe - Microsoft Corporation
                               dwm.exe - C:\Windows\System32\dwm.exe - Microsoft Corporation
                               loadperf.dll - C:\Windows\System32\loadperf.dll - Microsoft Corporation
                               srcore.dll - C:\Windows\System32\srcore.dll - Microsoft Corporation
                               esent.dll - C:\Windows\System32\esent.dll - Microsoft Corporation
                               mscoree.dll - C:\Windows\System32\mscoree.dll - Microsoft Corporation
                               wersvc.dll - C:\Windows\System32\wersvc.dll - Microsoft Corporation
                               defragsvc.dll - C:\Windows\System32\defragsvc.dll - Microsoft Corporation
                               RstrtMgr.dll - C:\Windows\System32\RstrtMgr.dll - Microsoft Corporation
                               sxs.dll - C:\Windows\System32\sxs.dll - Microsoft Corporation
                               winsrv.dll - C:\Windows\System32\winsrv.dll - Microsoft Corporation
                      Code:
                        Image File Name[Steam.exe]Modules
                               Steam.exe - C:\Program Files (x86)\Steam\Steam.exe - Valve Corporation
                               crashhandler.dll - C:\Program Files (x86)\Steam\crashhandler.dll - Valve Corporation
                               steamui.dll - C:\Program Files (x86)\Steam\steamui.dll - Valve Corporation
                               SDL2.dll - C:\Program Files (x86)\Steam\SDL2.dll -
                               tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               v8.dll - C:\Program Files (x86)\Steam\v8.dll -
                               icui18n.dll - C:\Program Files (x86)\Steam\icui18n.dll -
                               icuuc.dll - C:\Program Files (x86)\Steam\icuuc.dll -
                               video.dll - C:\Program Files (x86)\Steam\video.dll -
                               libavcodec-56.dll - C:\Program Files (x86)\Steam\libavcodec-56.dll -
                               libavutil-54.dll - C:\Program Files (x86)\Steam\libavutil-54.dll -
                               libavformat-56.dll - C:\Program Files (x86)\Steam\libavformat-56.dll -
                               libavresample-2.dll - C:\Program Files (x86)\Steam\libavresample-2.dll -
                               libswscale-3.dll - C:\Program Files (x86)\Steam\libswscale-3.dll -
                               vstdlib_s.dll - C:\Program Files (x86)\Steam\vstdlib_s.dll - Valve Corporation
                               filesystem_stdio.DLL - C:\Program Files (x86)\Steam\bin\filesystem_stdio.DLL - Valve Corporation
                               vgui2_s.DLL - C:\Program Files (x86)\Steam\bin\vgui2_s.DLL - Valve Corporation
                               chromehtml.DLL - C:\Program Files (x86)\Steam\bin\chromehtml.DLL -
                               steamclient.dll - C:\Program Files (x86)\Steam\steamclient.dll - Valve Corporation
                               friendsui.DLL - c:\program files (x86)\steam\bin\friendsui.DLL - Valve Corporation
                               serverbrowser.DLL - c:\program files (x86)\steam\bin\serverbrowser.DLL - Valve Corporation
                               openvr_api.dll - C:\Program Files (x86)\Steam\openvr_api.dll -
                      Code:
                        Image File Name[audiodg.exe]Modules
                      Code:
                        Image File Name[steamwebhelper.exe]Modules
                               steamwebhelper.exe - C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - Valve Corporation
                               libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               chrome_elf.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\chrome_elf.dll - The Chromium Authors
                               winh264.dll - C:\Program Files (x86)\Steam\winh264.dll -
                      Code:
                        Image File Name[WmiPrvSE.exe]Modules
                      Code:
                      Code:
                        Image File Name[chrome.exe]Modules
                               chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               chrome_elf.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_elf.dll - Google Inc.
                               chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                      Code:
                        Image File Name[csrss.exe]Modules
                      Code:
                      Code:
                        Image File Name[QHActiveDefense.exe]Modules
                               QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               360NetBase.dll - C:\Program Files (x86)\360\Total Security\360NetBase.dll - 360.cn
                               360SoftMgrS.dll - C:\Program Files (x86)\360\Total Security\SoftMgr\360SoftMgrS.dll - 360.cn
                               fileMgr.dll - C:\Program Files (x86)\360\Total Security\ipc\fileMgr.dll - Qihu 360 Software Co., Ltd.
                               yhregd.dll - C:\Program Files (x86)\360\Total Security\ipc\yhregd.dll - Qihu 360 Software Co., Ltd.
                               appd.dll - C:\Program Files (x86)\360\Total Security\ipc\appd.dll - Qihu 360 Software Co., Ltd.
                               netdefender.dll - C:\Program Files (x86)\360\Total Security\ipc\netdefender.dll - Qihu 360 Software Co., Ltd.
                               360procmon.dll - C:\Program Files (x86)\360\Total Security\safemon\360procmon.dll - Qihu 360 Software Co., Ltd.
                               SelfProtectAPI2.dll - C:\Program Files (x86)\360\Total Security\safemon\SelfProtectAPI2.dll - Qihu 360 Software Co., Ltd.
                               gamemode.tpi - C:\Program Files (x86)\360\Total Security\safemon\gamemode.tpi - QIHU 360 SOFTWARE CO. LIMITED
                               qex.dll - C:\Program Files (x86)\360\Total Security\deepscan\qex\qex.dll - Qihu 360 Software Co., Ltd.
                               safehmpg.dll - C:\Program Files (x86)\360\Total Security\safemon\safehmpg.dll - Qihu 360 Software Co., Ltd.
                               qutmipc.dll - C:\Program Files (x86)\360\Total Security\ipc\qutmipc.dll - 360.cn
                               SomAdvUtils.dll - C:\Program Files (x86)\360\Total Security\SoftMgr\SomAdvUtils.dll - Qihu 360 Software Co., Ltd.
                               somkernl.dll - C:\Program Files (x86)\360\Total Security\SoftMgr\somkernl.dll - 360.cn
                               sbmon.dll - C:\Program Files (x86)\360\Total Security\ipc\sbmon.dll - Qihu 360 Software Co., Ltd.
                               360box.dll - C:\Program Files (x86)\360\Total Security\ipc\360box.dll - 360.cn
                               appdext.dll - C:\Program Files (x86)\360\Total Security\ipc\appdext.dll - 360.cn
                               Netgm.dll - C:\Program Files (x86)\360\Total Security\netmon\Netgm.dll - 360.cn
                               WDRecord.dll - C:\Program Files (x86)\360\Total Security\safemon\WDRecord.dll - Qihu 360 Software Co., Ltd.
                               jcloudscan.dll - C:\Program Files (x86)\360\Total Security\deepscan\jcloudscan.dll - 360.cn
                               360AntiHacker.dll - C:\Program Files (x86)\360\Total Security\ipc\360AntiHacker.dll - 360.cn
                               DrvUtility.dll - C:\Program Files (x86)\360\Total Security\ipc\DrvUtility.dll - Qihu 360 Software Co., Ltd.
                               360gameidentify.dll - C:\Program Files (x86)\360\Total Security\netmon\360gameidentify.dll - 360.cn
                               ScanStub.dll - C:\Program Files (x86)\360\Total Security\ScanStub.dll - QIHU 360 SOFTWARE CO. LIMITED
                               SafeScan.dll - C:\Program Files (x86)\360\Total Security\SafeScan.dll - QIHU 360 SOFTWARE CO. LIMITED
                               360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               WhiteCache.dll - C:\Program Files (x86)\360\Total Security\filemon\WhiteCache.dll - 360.cn
                               360AvFlt.dll - C:\Program Files (x86)\360\Total Security\filemon\360AvFlt.dll - 360.cn
                               FsrMgr.dll - C:\Program Files (x86)\360\Total Security\filemon\FsrMgr.dll - Qihu 360
                               360SafeCamera.tpi - C:\Program Files (x86)\360\Total Security\safemon\360SafeCamera.tpi - QIHU 360 SOFTWARE CO. LIMITED
                               AVEI.dll - C:\Program Files (x86)\360\Total Security\deepscan\AVE\AVEI.dll - Qihu 360 Software Co., Ltd.
                               AVEngine.dll - C:\Program Files (x86)\360\Total Security\deepscan\AVE\AVEngine.dll - Qihu 360 Software Co., Ltd.
                               scan.dll - C:\PROGRA~3\360Safe\bd\scan.dll - S.C. BitDefender S.R.L
                               bdcore.dll - C:\PROGRA~3\360Safe\bd\bdcore.dll - Bitdefender
                               360HipsPopWnd.dll - C:\Program Files (x86)\360\Total Security\safemon\360HipsPopWnd.dll - Qihu 360 Software Co., Ltd.
                               360QVM.dll - C:\Program Files (x86)\360\Total Security\deepscan\QVM\360QVM.dll - Qihu 360 Software Co., Ltd.
                               deepscan.dll - C:\Program Files (x86)\360\Total Security\deepscan\deepscan.dll - Qihu 360 Software Co., Ltd.
                               DsRes.dll - C:\Program Files (x86)\360\Total Security\i18n\de\deepscan\DsRes.dll - Qihu 360 Software Co., Ltd.
                               7z.dll - C:\Program Files (x86)\360\Total Security\safemon\7z.dll - Igor Pavlov
                      Code:
                      Code:
                        Image File Name[wininit.exe]Modules
                      Code:
                      Code:
                        Image File Name[services.exe]Modules
                      Code:
                        Image File Name[iTunes.exe]Modules
                               iTunesCore.dll - C:\Program Files\iTunes\iTunesCore.dll - Apple Inc.
                               gwrks64.dll - C:\Program Files\iTunes\gwrks64.dll - GEAR-Software
                               ApplePushService.dll - C:\Program Files\Common Files\Apple\Apple Application Support\ApplePushService.dll - Apple Inc.
                               CoreFoundation.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CoreFoundation.dll - Apple Inc.
                               objc.dll - C:\Program Files\Common Files\Apple\Apple Application Support\objc.dll - Apple Inc.
                               ASL.dll - C:\Program Files\Common Files\Apple\Apple Application Support\ASL.dll - Apple Inc.
                               libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               libicuin.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libicuin.dll - The ICU Project
                               libicuuc.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libicuuc.dll - The ICU Project
                               icudt55.dll - C:\Program Files\Common Files\Apple\Apple Application Support\icudt55.dll - The ICU Project
                               GNSDK_DSP.DLL - C:\Program Files\iTunes\GNSDK_DSP.DLL - Gracenote, Inc.
                               GNSDK_MANAGER.DLL - C:\Program Files\iTunes\GNSDK_MANAGER.DLL - Gracenote, Inc.
                               GNSDK_MUSICID.DLL - C:\Program Files\iTunes\GNSDK_MUSICID.DLL - Gracenote, Inc.
                               GNSDK_SUBMIT.DLL - C:\Program Files\iTunes\GNSDK_SUBMIT.DLL - Gracenote, Inc.
                               AVFoundationCF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\AVFoundationCF.dll - Apple Inc.
                               CoreMedia.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CoreMedia.dll - Apple Inc.
                               Foundation.dll - C:\Program Files\Common Files\Apple\Apple Application Support\Foundation.dll - Apple Inc.
                               QuartzCore.dll - C:\Program Files\Common Files\Apple\Apple Application Support\QuartzCore.dll - Apple Inc.
                               CoreGraphics.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CoreGraphics.dll - Apple Inc.
                               CoreVideo.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CoreVideo.dll - Apple Inc.
                               pthreadVC2.dll - C:\Program Files\Common Files\Apple\Apple Application Support\pthreadVC2.dll - Open Source Software community LGPL
                               libxml2.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll -
                               CoreText.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CoreText.dll - Apple Inc.
                               MediaAccessibility.dll - C:\Program Files\Common Files\Apple\Apple Application Support\MediaAccessibility.dll - Apple Inc.
                               CFNetwork.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CFNetwork.dll - Apple Inc.
                               SQLite3.dll - C:\Program Files\Common Files\Apple\Apple Application Support\SQLite3.dll - Apple Inc.
                               zlib1.dll - C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll -
                               CoreAudioToolbox.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CoreAudioToolbox.dll - Apple Inc.
                               JavaScriptCore.dll - C:\Program Files\Common Files\Apple\Apple Application Support\JavaScriptCore.dll - Apple Inc.
                               WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                               libcache.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libcache.dll - Apple Inc.
                               WebKit.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WebKit.dll - Apple Inc.
                               libxslt.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libxslt.dll -
                               dnssd.dll - C:\Windows\system32\dnssd.dll - Apple Inc.
                               CoreFP.dll - C:\Program Files\Common Files\Apple\CoreFP\CoreFP.dll - Apple Inc.
                               iTunesRegistry.DLL - C:\Program Files\iTunes\iTunes.Resources\iTunesRegistry.DLL - Apple Inc.
                               iTunesLocalized.DLL - C:\Program Files\iTunes\iTunes.Resources\de.lproj\iTunesLocalized.DLL - Apple Inc.
                               iTunesResources.DLL - C:\Program Files\iTunes\iTunes.Resources\iTunesResources.DLL - Apple Inc.
                               CoreADI.dll - C:\Program Files\Common Files\Apple\Apple Application Support\CoreADI.dll - Apple Inc.
                               iTunesMobileDevice.dll - C:\Program Files\Common Files\Apple\Mobile Device Support\iTunesMobileDevice.dll - Apple Inc.
                               nvd3dumx.dll - C:\Windows\system32\nvd3dumx.dll - NVIDIA Corporation
                      Code:
                        Image File Name[lsass.exe]Modules
                               McAfeeTrueKeyPasswordFilter.DLL - C:\Program Files\TrueKey\McAfeeTrueKeyPasswordFilter.DLL - McAfee, Inc.
                      Code:
                      Code:
                      Code:
                      Code:
                               chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                      Code:
                        Image File Name[explorer.exe]Modules
                               SafeWrapper.dll - C:\??\C:\Program Files (x86)\360\Total Security\safemon\SafeWrapper.dll - File not found
                               safemon64.dll - C:\Program Files (x86)\360\Total Security\safemon\safemon64.dll - Qihu 360 Software Co., Ltd.
                               Safehmpg64.dll - C:\Program Files (x86)\360\Total Security\safemon\Safehmpg64.dll - Qihu 360 Software Co., Ltd.
                               mbamext.dll - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll - Malwarebytes
                               rarext.dll - C:\Program Files\WinRAR\rarext.dll - Alexander Roshal
                               MenuEx64.dll - C:\Program Files (x86)\360\Total Security\MenuEx64.dll -
                               nv3dappshext.dll - C:\Windows\system32\nv3dappshext.dll - NVIDIA Corporation
                      Code:
                      Code:
                        Image File Name[nvvsvc.exe]Modules
                               nvvsvc.exe - C:\Windows\system32\nvvsvc.exe - NVIDIA Corporation
                               nvxdbat.dll - C:\Program Files\NVIDIA Corporation\Display\nvxdbat.dll - NVIDIA Corporation
                      Code:
                      Code:
                      Code:
                        Image File Name[iTunesHelper.exe]Modules
                               iTunesHelper.dll - C:\Program Files\iTunes\iTunesHelper.dll - Apple Inc.
                               iTunesHelperLocalized.DLL - C:\Program Files\iTunes\iTunesHelper.Resources\de.lproj\iTunesHelperLocalized.DLL - Apple Inc.
                               iTunesHelper.DLL - C:\Program Files\iTunes\iTunesHelper.Resources\iTunesHelper.DLL - Apple Inc.
                      Code:
                        Image File Name[iPodService.exe]Modules
                               iPodServiceLocalized.DLL - C:\Program Files\iPod\bin\iPodService.Resources\de.lproj\iPodServiceLocalized.DLL - Apple Inc.
                               iPodService.DLL - C:\Program Files\iPod\bin\iPodService.Resources\iPodService.DLL - Apple Inc.
                      Code:
                      Code:
                        Image File Name[CTAudSvc.exe]Modules
                               CTAudSvc.exe - C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe - Creative Technology Ltd
                      Code:
                        Image File Name[wuauclt.exe]Modules
                      Code:
                               steam.dll - C:\Program Files (x86)\Steam\steam.dll -
                               Steam2.dll - C:\Program Files (x86)\Steam\Steam2.dll - Valve Corporation
                               CSERHelper.dll - C:\Program Files (x86)\Steam\CSERHelper.dll - Valve
                      Code:
                        Image File Name[spoolsv.exe]Modules
                      Code:
                        Image File Name[dwm.exe]Modules
                               nvwgf2umx.dll - C:\Windows\system32\nvwgf2umx.dll - NVIDIA Corporation
                      Code:
                        Image File Name[taskhost.exe]Modules
                      Code:
                        Image File Name[NvNetworkService.exe]Modules
                               NvNetworkService.exe - C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe - NVIDIA Corporation
                      Code:
                        Image File Name[nvxdsync.exe]Modules
                               NVSVC64.DLL - C:\Windows\system32\NVSVC64.DLL - NVIDIA Corporation
                               NVSVCR.DLL - C:\Windows\system32\NVSVCR.DLL - NVIDIA Corporation
                               nvxdapix.dll - C:\Program Files\NVIDIA Corporation\Display\nvxdapix.dll - NVIDIA Corporation
                               nvumdshimx.dll - C:\Windows\system32\nvumdshimx.dll - NVIDIA Corporation
                               nvxdplcy.dll - C:\Program Files\NVIDIA Corporation\Display\nvxdplcy.dll - NVIDIA Corporation
                               NvSmartMax64.dll - C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll -
                      Code:
                        Image File Name[wmpnetwk.exe]Modules
                      Code:
                        Image File Name[NvStreamService.exe]Modules
                      Code:
                        Image File Name[PCHunter64.exe]Modules
                      Code:
                        Image File Name[dllhost.exe]Modules
                      Code:
                        Image File Name[GoogleUpdate.exe]Modules
                               GoogleUpdate.exe - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe - Google Inc.
                               goopdate.dll - C:\Program Files (x86)\Google\Update\1.3.32.7\goopdate.dll - Google Inc.
                      Code:
                      Code:
                        Image File Name[SearchProtocolHost.exe]Modules
                      Code:
                      Code:
                      Code:
                        Image File Name[armsvc.exe]Modules
                               armsvc.exe - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe - Adobe Systems Incorporated
                      Code:
                        Image File Name[SearchIndexer.exe]Modules
                      Code:
                        Image File Name[mDNSResponder.exe]Modules
                      Code:
                      Code:
                        Image File Name[GfExperienceService.exe]Modules
                               ShieldWirelessController.dll - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\ShieldWirelessController.dll - NVIDIA Corporation
                               GFExperienceUpdate.dll - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GFExperienceUpdate.dll - NVIDIA Corporation
                               ShadowPlayController.dll - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\ShadowPlayController.dll - NVIDIA Corporation
                               rxinput.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\rxinput.dll - NVIDIA Corporation
                      Code:
                      Code:
                        Image File Name[QHWatchdog.exe]Modules
                               QHWatchdog.exe - C:\Program Files (x86)\360\Total Security\safemon\QHWatchdog.exe - QIHU 360 SOFTWARE CO. LIMITED
                      Code:
                      Code:
                      Code:
                      Code:
                        Image File Name[APSDaemon.exe]Modules
                               APSDaemon.exe - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe - Apple Inc.
                               AppleVersions.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\AppleVersions.dll - Apple Inc.
                               YSCrashDump.DLL - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\YSCrashDump.DLL - Apple Inc.
                               CoreFoundation.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\CoreFoundation.dll - Apple Inc.
                               objc.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\objc.dll - Apple Inc.
                               ASL.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\ASL.dll - Apple Inc.
                               libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               libicuin.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libicuin.dll - The ICU Project
                               libicuuc.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libicuuc.dll - The ICU Project
                               icudt55.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\icudt55.dll - The ICU Project
                               APSDaemon_main.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon_main.dll - Apple Inc.
                               CFNetwork.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\CFNetwork.dll - Apple Inc.
                               libxml2.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libxml2.dll -
                               SQLite3.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\SQLite3.dll - Apple Inc.
                               zlib1.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\zlib1.dll -
                               pthreadVC2.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\pthreadVC2.dll - Open Source Software community LGPL
                      Code:
                        Image File Name[McAfee.TrueKey.Service.exe]Modules
                               Mcafee.TrueKey.BCAAdapter.dll - C:\Program Files\TrueKey\Mcafee.TrueKey.BCAAdapter.dll - McAfee, Inc.
                               TrueKeyVault.dll - C:\Program Files\TrueKey\TrueKeyVault.dll - McAfee, Inc.
                               SQLite.Interop.dll - C:\Program Files\TrueKey\SQLite.Interop.dll - Robert Simpson, et al.
                               System.EnterpriseServices.Wrapper.dll - C:\Windows\Microsoft.NET\assembly\GAC_64\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll - Microsoft Corporation
                               system.data.sqlite.dll - C:\Program Files\TrueKey\system.data.sqlite.dll -  http://system.data.sqlite.org/
                               nlog.dll - C:\Program Files\TrueKey\nlog.dll - NLog
                               Newtonsoft.Json.Dll - C:\Program Files\TrueKey\Newtonsoft.Json.Dll - Newtonsoft
                               McAfee.TrueKey.BCAAdapter.dll - C:\Program Files\TrueKey\McAfee.TrueKey.BCAAdapter.dll - McAfee, Inc.
                      Code:
                        Image File Name[AppleMobileDeviceService.exe]Modules
                               AppleVersions.dll - C:\Program Files\Common Files\Apple\Apple Application Support\AppleVersions.dll - Apple Inc.
                               YSCrashDump.DLL - C:\Program Files\Common Files\Apple\Apple Application Support\YSCrashDump.DLL - Apple Inc.
                               AppleMobileDeviceService_main.dll - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService_main.dll - Apple Inc.
                               MobileDevice.dll - C:\Program Files\Common Files\Apple\Mobile Device Support\MobileDevice.dll - Apple Inc.
                      Code:
                        Image File Name[McTkSchedulerService.exe]Modules
                      Code:
                        Image File Name[ViakaraokeSrv.exe]Modules
                               viakaraokesrv.exe - C:\Windows\system32\viakaraokesrv.exe - VIA Technologies, Inc.
                      Code:
                      Code:
                      Code:
                      Code:
                        Image File Name[SteamService.exe]Modules
                               SteamService.exe - C:\Program Files (x86)\Common Files\Steam\SteamService.exe - Valve Corporation
                               SteamService.dll - C:\Program Files (x86)\Common Files\Steam\SteamService.dll - Valve Corporation
                      Code:
                        Image File Name[conhost.exe]Modules
                      Code:
                      Code:
                        Image File Name[SpotifyWebHelper.exe]Modules
                               SpotifyWebHelper.exe - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe - Spotify Ltd
                      Code:
                      Code:
                      Code:
                      Code:
                               chrome_watcher.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_watcher.dll - Google Inc.
                      Code:
                        Image File Name[AppleMobileDeviceHelper.exe]Modules
                               AppleMobileDeviceHelper.exe - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceHelper.exe - Apple Inc.
                               AppleMobileDeviceHelper_main.dll - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceHelper_main.dll - Apple Inc.
                               Foundation.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\Foundation.dll - Apple Inc.
                               libtidy.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libtidy.dll - Apple Inc.
                               DeviceLink.dll - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\DeviceLink.dll - Apple Inc.
                               MobileDevice.dll - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\MobileDevice.dll - Apple Inc.
                               SyncServices.dll - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\SyncServices.dll - Apple Inc.
                               dnssd.dll - C:\Windows\syswow64\dnssd.dll - Apple Inc.
                      Code:
                               libglesv2.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\libglesv2.dll -
                               libegl.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\libegl.dll -
                               nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                      Code:
                        Image File Name[distnoted.exe]Modules
                               distnoted.exe - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\distnoted.exe - Apple Inc.
                      Code:
                        Image File Name[SearchFilterHost.exe]Modules
                      Code:
                      Code:
                        Image File Name[Idle]Modules
                      Process Threads
                      Code:
                        Image File Name[System]Threads
                               332 - Wait - 360FsFlt.sys - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                               336 - Wait - 360FsFlt.sys - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                               340 - Wait - 360FsFlt.sys - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                               352 - Wait - 360AntiHacker64.sys - C:\Windows\System32\Drivers\360AntiHacker64.sys - 360.cn
                               384 - Wait - iusb3xhc.sys - C:\Windows\system32\DRIVERS\iusb3xhc.sys - Intel Corporation
                               388 - Wait - iusb3xhc.sys - C:\Windows\system32\DRIVERS\iusb3xhc.sys - Intel Corporation
                               392 - Wait - iusb3xhc.sys - C:\Windows\system32\DRIVERS\iusb3xhc.sys - Intel Corporation
                               396 - Wait - iusb3xhc.sys - C:\Windows\system32\DRIVERS\iusb3xhc.sys - Intel Corporation
                               400 - Wait - iusb3xhc.sys - C:\Windows\system32\DRIVERS\iusb3xhc.sys - Intel Corporation
                               404 - Wait - iusb3xhc.sys - C:\Windows\system32\DRIVERS\iusb3xhc.sys - Intel Corporation
                               412 - Wait - Smb_driver_Intel.sys - C:\Windows\system32\DRIVERS\Smb_driver_Intel.sys - Synaptics Incorporated
                               420 - Wait - nvvad64v.sys - C:\Windows\system32\drivers\nvvad64v.sys - NVIDIA Corporation
                               424 - Wait - athrx.sys - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                               428 - Wait - athrx.sys - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                               432 - Wait - iusb3hub.sys - C:\Windows\system32\DRIVERS\iusb3hub.sys - Intel Corporation
                               436 - Wait - athrx.sys - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                               440 - Wait - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               444 - Wait - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               448 - Wait - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               452 - Wait - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               456 - Terminate - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               460 - Terminate - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               464 - Terminate - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               468 - Terminate - nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                               556 - Wait - nvlddmkm.sys - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                               560 - Wait - nvlddmkm.sys - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                               920 - Wait - mbam.sys - C:\Windows\system32\drivers\mbam.sys - Malwarebytes
                               1328 - Terminate -  -  -
                               4132 - Wait - 360AvFlt.sys - C:\Windows\system32\DRIVERS\360AvFlt.sys - 360.cn
                      Code:
                        Image File Name[NvStreamNetworkService.exe]Threads
                               1816 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               2040 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3164 - Wait - NvStreamNetworkService.exe - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe - NVIDIA Corporation
                               3252 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3260 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3264 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3268 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3272 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3380 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3384 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3388 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3472 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3476 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3480 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3484 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3488 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3492 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3496 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3500 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3504 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                      Code:
                        Image File Name[nvtray.exe]Threads
                               1244 - Wait - nvtray.exe - C:\Program Files\NVIDIA Corporation\Display\nvtray.exe - NVIDIA Corporation
                               2348 - Wait - NvUI.dll - C:\Program Files\NVIDIA Corporation\Display\NvUI.dll - NVIDIA Corporation
                               7204 - Wait - NvBackendAPI64.DLL - C:\Program Files\NVIDIA Corporation\Update Core\NvBackendAPI64.DLL - NVIDIA Corporation
                               7224 - Wait - NvGFTrayPlugin.dll - C:\Program Files\NVIDIA Corporation\Update Core\NvGFTrayPlugin.dll - NVIDIA Corporation
                               7232 - Wait - NvGFTrayPlugin.dll - C:\Program Files\NVIDIA Corporation\Update Core\NvGFTrayPlugin.dll - NVIDIA Corporation
                      Code:
                        Image File Name[QHSafeTray.exe]Threads
                               184 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               540 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               932 - Wait - cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               1320 - Wait - cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               1636 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1904 - Wait - urlproc.dll - C:\Program Files (x86)\360\Total Security\safemon\urlproc.dll - Qihu 360 Software Co., Ltd.
                               1920 - Wait - 360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               1924 - Wait - 360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               1928 - Wait - 360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               2156 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2192 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2380 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2440 - Wait - urlproc.dll - C:\Program Files (x86)\360\Total Security\safemon\urlproc.dll - Qihu 360 Software Co., Ltd.
                               2452 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2488 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2528 - Wait - 360bsmon.tpi - C:\Program Files (x86)\360\Total Security\safemon\360bsmon.tpi - Qihu 360 Software Co., Ltd.
                               2552 - Wait - 360bsmon.tpi - C:\Program Files (x86)\360\Total Security\safemon\360bsmon.tpi - Qihu 360 Software Co., Ltd.
                               2580 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2752 - Wait - 360bsmon.tpi - C:\Program Files (x86)\360\Total Security\safemon\360bsmon.tpi - Qihu 360 Software Co., Ltd.
                               2756 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2800 - Wait - 360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               3120 - Wait - 360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               3128 - Wait - 360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               3360 - Wait - 360safemonpro.tpi - C:\Program Files (x86)\360\Total Security\safemon\360safemonpro.tpi - Qihu 360 Software Co., Ltd.
                               3868 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               3888 - Wait - 360netbase.dll - C:\Program Files (x86)\360\Total Security\360netbase.dll - 360.cn
                               3892 - Wait - QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED
                               3904 - Wait - PDown.dll - C:\Program Files (x86)\360\Total Security\PDown.dll - Qihu 360 Software Co., Ltd.
                               4080 - Wait - qutmload.dll - C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll -
                               4436 - Wait - PDown.dll - C:\Program Files (x86)\360\Total Security\PDown.dll - Qihu 360 Software Co., Ltd.
                               5584 - Wait - wdui2.dll - C:\Program Files (x86)\360\Total Security\safemon\wdui2.dll -
                      Code:
                        Image File Name[winlogon.exe]Threads
                      Code:
                        Image File Name[lsm.exe]Threads
                      Code:
                        Image File Name[SkypeBrowserHost.exe]Threads
                               5616 - Wait - SkypeBrowserHost.exe - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe - Skype Technologies
                               5768 - Wait - SkypeBrowserHost.exe - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe - Skype Technologies
                      Code:
                        Image File Name[Skype.exe]Threads
                               1088 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               1092 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               1144 - Terminate - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               1288 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               1316 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               1940 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               2004 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               2204 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               2276 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               2812 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               2896 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               3240 - Terminate - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               3612 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               3884 - Terminate - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               4164 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4244 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               4256 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4344 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4348 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4388 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4536 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4548 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               4768 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4824 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4840 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               4876 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               4912 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4964 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               4976 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               5024 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               5072 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               5084 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               5188 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               5684 - Wait - Skype.exe - C:\Program Files (x86)\Skype\Phone\Skype.exe - Skype Technologies S.A.
                               5944 - Terminate - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               6588 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                               6668 - Wait - SkypeSkylib.dll - C:\Program Files (x86)\Skype\Phone\SkypeSkylib.dll - Skype Technologies S.A.
                      Code:
                        Image File Name[NvBackend.exe]Threads
                               2104 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               2352 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               2444 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               2464 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               2980 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               2988 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               2996 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               3000 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               3004 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               3008 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               3052 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               3056 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               3068 - Wait - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                               4488 - Terminate - NvBackend.exe - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe - NVIDIA Corporation
                      Code:
                        Image File Name[pabeSvc64.exe]Threads
                               2000 - Wait - pabeSvc64.exe - C:\Program Files\Intel\BCA\pabeSvc64.exe - Intel(R) Corporation
                      Code:
                        Image File Name[NvStreamUserAgent.exe]Threads
                               328 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               372 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               532 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               548 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               668 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               744 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1108 - Terminate - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1180 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1228 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1388 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1396 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1400 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1404 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               1408 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               1568 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1644 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1728 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1752 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               1900 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3592 - Wait - NvStreamUserAgent.exe - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe - NVIDIA Corporation
                               3716 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3720 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3724 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3728 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3732 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3736 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3740 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3748 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3752 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               3756 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3900 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3964 - Terminate - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               4016 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               4020 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               4032 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               4036 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               4092 - Wait - NvBackendAPI64.dll - C:\Program Files\NVIDIA Corporation\Update Core\NvBackendAPI64.dll - NVIDIA Corporation
                      Code:
                        Image File Name[smss.exe]Threads
                      Code:
                        Image File Name[svchost.exe]Threads
                      Code:
                        Image File Name[Steam.exe]Threads
                               1804 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               2160 - Wait - Steam.exe - C:\Program Files (x86)\Steam\Steam.exe - Valve Corporation
                               2396 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               2808 - Wait - SDL2.dll - C:\Program Files (x86)\Steam\SDL2.dll -
                               3404 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               4048 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               4112 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               4172 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               4276 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               4328 - Wait - steamclient.dll - C:\Program Files (x86)\Steam\steamclient.dll - Valve Corporation
                               4404 - Wait - Steam.exe - C:\Program Files (x86)\Steam\Steam.exe - Valve Corporation
                               4532 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               4908 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               5248 - Wait - steamclient.dll - C:\Program Files (x86)\Steam\steamclient.dll - Valve Corporation
                               5360 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               5524 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               5580 - Wait - steamclient.dll - C:\Program Files (x86)\Steam\steamclient.dll - Valve Corporation
                               5592 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               5680 - Wait - Steam.exe - C:\Program Files (x86)\Steam\Steam.exe - Valve Corporation
                               5716 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               5864 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               5964 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6152 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6160 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6164 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6176 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6216 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6220 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6328 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6332 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6392 - Wait - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6396 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6416 - Wait - Steam.exe - C:\Program Files (x86)\Steam\Steam.exe - Valve Corporation
                               6440 - Wait - steamclient.dll - C:\Program Files (x86)\Steam\steamclient.dll - Valve Corporation
                               6480 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6548 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6928 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               6956 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               7092 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                               7096 - Terminate - tier0_s.dll - C:\Program Files (x86)\Steam\tier0_s.dll - Valve Corporation
                      Code:
                        Image File Name[audiodg.exe]Threads
                      Code:
                        Image File Name[steamwebhelper.exe]Threads
                               4468 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               5124 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6204 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6408 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6460 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6648 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6864 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6888 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6972 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               7048 - Wait - steamwebhelper.exe - C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - Valve Corporation
                      Code:
                        Image File Name[WmiPrvSE.exe]Threads
                      Code:
                      Code:
                        Image File Name[chrome.exe]Threads
                               1260 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               1788 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               2872 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               3248 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4336 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4616 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4892 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5636 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6528 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6872 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                               536 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               1004 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4668 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5312 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5712 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6096 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               6532 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6792 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6804 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6860 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                        Image File Name[csrss.exe]Threads
                      Code:
                      Code:
                        Image File Name[QHActiveDefense.exe]Threads
                               564 - Wait - netdefender.dll - C:\Program Files (x86)\360\Total Security\ipc\netdefender.dll - Qihu 360 Software Co., Ltd.
                               1052 - Wait - appd.dll - C:\Program Files (x86)\360\Total Security\ipc\appd.dll - Qihu 360 Software Co., Ltd.
                               1056 - Wait - Netgm.dll - C:\Program Files (x86)\360\Total Security\netmon\Netgm.dll - 360.cn
                               1104 - Wait - 360box.dll - C:\Program Files (x86)\360\Total Security\ipc\360box.dll - 360.cn
                               1128 - Terminate - appdext.dll - C:\Program Files (x86)\360\Total Security\ipc\appdext.dll - 360.cn
                               1140 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1160 - Wait - cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               1172 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1188 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1196 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1224 - Wait - cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               1416 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1432 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1544 - Wait - 360NetBase.dll - C:\Program Files (x86)\360\Total Security\360NetBase.dll - 360.cn
                               1548 - Wait - cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               1552 - Wait - cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               1656 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1668 - Wait - qutmload.dll - C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll -
                               1672 - Wait - qutmload.dll - C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll -
                               1676 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1692 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1696 - Terminate - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1700 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1704 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1708 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1712 - Wait - qutmload.dll - C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll -
                               1744 - Wait - appd.dll - C:\Program Files (x86)\360\Total Security\ipc\appd.dll - Qihu 360 Software Co., Ltd.
                               1756 - Terminate - 360SoftMgrS.dll - C:\Program Files (x86)\360\Total Security\SoftMgr\360SoftMgrS.dll - 360.cn
                               1808 - Wait - fileMgr.dll - C:\Program Files (x86)\360\Total Security\ipc\fileMgr.dll - Qihu 360 Software Co., Ltd.
                               1812 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1828 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1836 - Wait - qutmipc.dll - C:\Program Files (x86)\360\Total Security\ipc\qutmipc.dll - 360.cn
                               1840 - Wait - yhregd.dll - C:\Program Files (x86)\360\Total Security\ipc\yhregd.dll - Qihu 360 Software Co., Ltd.
                               1860 - Wait - 360procmon.dll - C:\Program Files (x86)\360\Total Security\safemon\360procmon.dll - Qihu 360 Software Co., Ltd.
                               1884 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               1896 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1916 - Wait - SelfProtectAPI2.dll - C:\Program Files (x86)\360\Total Security\safemon\SelfProtectAPI2.dll - Qihu 360 Software Co., Ltd.
                               1932 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               1980 - Wait - 360procmon.dll - C:\Program Files (x86)\360\Total Security\safemon\360procmon.dll - Qihu 360 Software Co., Ltd.
                               2052 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2056 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2060 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2064 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2068 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2072 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2076 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2080 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2084 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               2844 - Terminate - cloudcom2.dll - C:\Program Files (x86)\360\Total Security\deepscan\cloudcom2.dll - Qihu 360 Software Co., Ltd.
                               3152 - Wait - yhregd.dll - C:\Program Files (x86)\360\Total Security\ipc\yhregd.dll - Qihu 360 Software Co., Ltd.
                               3424 - Wait - qutmload.dll - C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll -
                               3428 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               3628 - Wait - QHActiveDefense.exe - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe - QIHU 360 SOFTWARE CO. LIMITED
                               3920 - Wait - 360bsmon.tpi - C:\Program Files (x86)\360\Total Security\safemon\360bsmon.tpi - Qihu 360 Software Co., Ltd.
                               3928 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               3980 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               3984 - Wait - 360AvFlt.dll - C:\Program Files (x86)\360\Total Security\filemon\360AvFlt.dll - 360.cn
                               3988 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               3992 - Wait - 360conf.dll - C:\Program Files (x86)\360\Total Security\360conf.dll - Qihu 360 Software Co., Ltd.
                               3996 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4000 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4056 - Wait - qutmload.dll - C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll -
                               4100 - Wait - 360bsmon.tpi - C:\Program Files (x86)\360\Total Security\safemon\360bsmon.tpi - Qihu 360 Software Co., Ltd.
                               4104 - Wait - 360bsmon.tpi - C:\Program Files (x86)\360\Total Security\safemon\360bsmon.tpi - Qihu 360 Software Co., Ltd.
                               4136 - Wait - 360AvFlt.dll - C:\Program Files (x86)\360\Total Security\filemon\360AvFlt.dll - 360.cn
                               4140 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4144 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4148 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4152 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4156 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4160 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4368 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                               4704 - Wait - 360rp.dll - C:\Program Files (x86)\360\Total Security\filemon\360rp.dll - QIHU 360 SOFTWARE CO. LIMITED
                      Code:
                      Code:
                        Image File Name[wininit.exe]Threads
                      Code:
                      Code:
                        Image File Name[services.exe]Threads
                      Code:
                        Image File Name[iTunes.exe]Threads
                               1072 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               1252 - Wait - iTunesMobileDevice.dll - C:\Program Files\Common Files\Apple\Mobile Device Support\iTunesMobileDevice.dll - Apple Inc.
                               1464 - Wait - ApplePushService.dll - C:\Program Files\Common Files\Apple\Apple Application Support\ApplePushService.dll - Apple Inc.
                               1476 - Wait - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               2604 - Wait - WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                               2828 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               3024 - Wait - WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                               4464 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               4708 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               4784 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               4828 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               5516 - Wait - WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                               5540 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               5736 - Wait - iTunesMobileDevice.dll - C:\Program Files\Common Files\Apple\Mobile Device Support\iTunesMobileDevice.dll - Apple Inc.
                               5776 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6172 - Wait - WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                               6180 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6200 - Wait - WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                               6208 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6340 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6352 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6384 - Wait - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6444 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6464 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6504 - Wait - iTunes.exe - C:\Program Files\iTunes\iTunes.exe - Apple Inc.
                               6596 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6680 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6912 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6948 - Wait - WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                               7080 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               7084 - Terminate - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               7128 - Wait - WTF.dll - C:\Program Files\Common Files\Apple\Apple Application Support\WTF.dll - Apple Inc.
                      Code:
                        Image File Name[lsass.exe]Threads
                      Code:
                      Code:
                               2588 - Wait - SkypeBrowserHost.exe - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe - Skype Technologies
                               2852 - Wait - SkypeBrowserHost.exe - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe - Skype Technologies
                      Code:
                      Code:
                               2408 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5336 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5420 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5440 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5456 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5460 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5464 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5468 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5472 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5476 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5480 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5484 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5488 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5492 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5496 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5500 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5528 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5536 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               5544 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               6116 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               6120 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               6132 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               6484 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               7364 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                               7588 - Wait - chrome.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome.dll - Google Inc.
                      Code:
                        Image File Name[explorer.exe]Threads
                      Code:
                      Code:
                        Image File Name[nvvsvc.exe]Threads
                               928 - Wait - nvvsvc.exe - C:\Windows\system32\nvvsvc.exe - NVIDIA Corporation
                      Code:
                      Code:
                      Code:
                        Image File Name[iTunesHelper.exe]Threads
                               1040 - Wait - iTunesHelper.dll - C:\Program Files\iTunes\iTunesHelper.dll - Apple Inc.
                               3104 - Wait - iTunesHelper.exe - C:\Program Files\iTunes\iTunesHelper.exe - Apple Inc.
                               5856 - Wait - iTunesHelper.dll - C:\Program Files\iTunes\iTunesHelper.dll - Apple Inc.
                               6544 - Wait - iTunesMobileDevice.dll - C:\Program Files\Common Files\Apple\Mobile Device Support\iTunesMobileDevice.dll - Apple Inc.
                               6560 - Wait - iTunesHelper.dll - C:\Program Files\iTunes\iTunesHelper.dll - Apple Inc.
                      Code:
                        Image File Name[iPodService.exe]Threads
                               1068 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               3908 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               4120 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               4952 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               5168 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               5804 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               6192 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               6568 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                               6580 - Wait - iPodService.exe - C:\Program Files\iPod\bin\iPodService.exe - Apple Inc.
                      Code:
                               1084 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               3312 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4300 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4776 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5732 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5984 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5996 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6000 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6004 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6008 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6012 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6016 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6020 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                        Image File Name[CTAudSvc.exe]Threads
                               1100 - Wait - CTAudSvc.exe - C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe - Creative Technology Ltd
                      Code:
                        Image File Name[wuauclt.exe]Threads
                      Code:
                               2508 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               2776 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               2944 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               3960 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               4180 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               4240 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               4268 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               4600 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               5144 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               5204 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               5208 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               5316 - Wait - steamwebhelper.exe - C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - Valve Corporation
                               5720 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               5876 - Wait - steamwebhelper.exe - C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - Valve Corporation
                               5888 - Wait - steamwebhelper.exe - C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - Valve Corporation
                               5900 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                      Code:
                        Image File Name[spoolsv.exe]Threads
                      Code:
                        Image File Name[dwm.exe]Threads
                               2976 - Wait - nvwgf2umx.dll - C:\Windows\system32\nvwgf2umx.dll - NVIDIA Corporation
                      Code:
                        Image File Name[taskhost.exe]Threads
                      Code:
                        Image File Name[NvNetworkService.exe]Threads
                               1324 - Wait - NvNetworkService.exe - C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe - NVIDIA Corporation
                      Code:
                        Image File Name[nvxdsync.exe]Threads
                               1304 - Wait - nvxdsync.exe - C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe - NVIDIA Corporation
                               1312 - Wait - nvxdsync.exe - C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe - NVIDIA Corporation
                               1336 - Wait - nvxdsync.exe - C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe - NVIDIA Corporation
                               1356 - Wait - nvapi64.dll - C:\Windows\system32\nvapi64.dll - NVIDIA Corporation
                               1364 - Wait - nvxdapix.dll - C:\Program Files\NVIDIA Corporation\Display\nvxdapix.dll - NVIDIA Corporation
                               1368 - Wait - nvxdsync.exe - C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe - NVIDIA Corporation
                               2144 - Wait - NVSVC64.DLL - C:\Windows\system32\NVSVC64.DLL - NVIDIA Corporation
                               2516 - Wait - nvxdapix.dll - C:\Program Files\NVIDIA Corporation\Display\nvxdapix.dll - NVIDIA Corporation
                               2956 - Wait - nvxdapix.dll - C:\Program Files\NVIDIA Corporation\Display\nvxdapix.dll - NVIDIA Corporation
                               2964 - Wait - nvxdapix.dll - C:\Program Files\NVIDIA Corporation\Display\nvxdapix.dll - NVIDIA Corporation
                               3192 - Wait - NVSVC64.DLL - C:\Windows\system32\NVSVC64.DLL - NVIDIA Corporation
                      Code:
                        Image File Name[wmpnetwk.exe]Threads
                      Code:
                        Image File Name[NvStreamService.exe]Threads
                               2116 - Wait - NvStreamService.exe - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe - NVIDIA Corporation
                               2304 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               2312 - Wait - Poco.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\Poco.dll -
                               2316 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                               3544 - Wait - NvStreamBase.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamBase.dll -
                      Code:
                        Image File Name[PCHunter64.exe]Threads
                               1800 - Wait - PCHunter64.exe - C:\Users\Arda\Desktop\PCHunter_free\PCHunter64.exe - ????(??)????????
                               3452 - Run - PCHunter64.exe - C:\Users\Arda\Desktop\PCHunter_free\PCHunter64.exe - ????(??)????????
                               7240 - Terminate - PCHunter64.exe - C:\Users\Arda\Desktop\PCHunter_free\PCHunter64.exe - ????(??)????????
                      Code:
                        Image File Name[GoogleUpdate.exe]Threads
                               2096 - Wait - goopdate.dll - C:\Program Files (x86)\Google\Update\1.3.32.7\goopdate.dll - Google Inc.
                               5088 - Wait - goopdate.dll - C:\Program Files (x86)\Google\Update\1.3.32.7\goopdate.dll - Google Inc.
                               5100 - Wait - GoogleUpdate.exe - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe - Google Inc.
                      Code:
                               1604 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               2024 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6228 - Wait - steamwebhelper.exe - C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - Valve Corporation
                               6268 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6280 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6284 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6288 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6292 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6296 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6300 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6304 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6308 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                               6660 - Wait - libcef.dll - C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll -
                      Code:
                        Image File Name[SearchProtocolHost.exe]Threads
                      Code:
                      Code:
                               2984 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               2992 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               3172 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               3976 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4288 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               4304 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5216 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6536 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6620 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6856 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                        Image File Name[armsvc.exe]Threads
                               1784 - Wait - armsvc.exe - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe - Adobe Systems Incorporated
                      Code:
                        Image File Name[SearchIndexer.exe]Threads
                      Code:
                        Image File Name[mDNSResponder.exe]Threads
                               1868 - Wait - mDNSResponder.exe - C:\Program Files\Bonjour\mDNSResponder.exe - Apple Inc.
                      Code:
                               4996 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5200 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5428 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5968 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6104 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6468 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6788 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6820 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6916 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               7100 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               7360 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                        Image File Name[GfExperienceService.exe]Threads
                               1948 - Wait - GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                               1956 - Wait - GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                               1960 - Wait - GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                               1964 - Wait - GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                               1984 - Wait - GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                               1988 - Wait - GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                               1992 - Wait - GfExperienceService.exe - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe - NVIDIA Corporation
                               2012 - Wait - rxinput.dll - C:\Program Files\NVIDIA Corporation\NvStreamSrv\rxinput.dll - NVIDIA Corporation
                               2020 - Terminate - GFExperienceUpdate.dll - C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GFExperienceUpdate.dll - NVIDIA Corporation
                      Code:
                               3444 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               3760 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               3956 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4916 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5060 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5068 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5264 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6148 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6844 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               6944 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                        Image File Name[QHWatchdog.exe]Threads
                               2092 - Wait - QHWatchdog.exe - C:\Program Files (x86)\360\Total Security\safemon\QHWatchdog.exe - QIHU 360 SOFTWARE CO. LIMITED
                      Code:
                      Code:
                               2200 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4352 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4984 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5640 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5660 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6136 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6636 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               6672 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6852 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6924 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                      Code:
                        Image File Name[APSDaemon.exe]Threads
                               2228 - Terminate - libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               2796 - Terminate - libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               3220 - Wait - APSDaemon.exe - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe - Apple Inc.
                               5304 - Wait - APSDaemon_main.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon_main.dll - Apple Inc.
                               5816 - Terminate - libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6360 - Terminate - libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6640 - Terminate - libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6808 - Terminate - libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               6996 - Wait - APSDaemon_main.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon_main.dll - Apple Inc.
                               7076 - Wait - libdispatch.dll - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                      Code:
                        Image File Name[McAfee.TrueKey.Service.exe]Threads
                               2284 - Wait - McAfee.TrueKey.Service.exe - C:\Program Files\TrueKey\McAfee.TrueKey.Service.exe - McAfee, Inc.
                      Code:
                        Image File Name[AppleMobileDeviceService.exe]Threads
                               4696 - Wait - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               5756 - Wait - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               5800 - Wait - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               7032 - Wait - libdispatch.dll - C:\Program Files\Common Files\Apple\Apple Application Support\libdispatch.dll - Apple Inc.
                               7072 - Wait - AppleMobileDeviceService.exe - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe - Apple Inc.
                      Code:
                        Image File Name[McTkSchedulerService.exe]Threads
                               2404 - Wait - McTkSchedulerService.exe - C:\Program Files\TrueKey\McTkSchedulerService.exe - McAfee, Inc.
                      Code:
                        Image File Name[ViakaraokeSrv.exe]Threads
                               2480 - Wait - viakaraokesrv.exe - C:\Windows\system32\viakaraokesrv.exe - VIA Technologies, Inc.
                               2500 - Wait - viakaraokesrv.exe - C:\Windows\system32\viakaraokesrv.exe - VIA Technologies, Inc.
                      Code:
                               2572 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4052 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5328 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5596 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5724 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5796 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5884 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5948 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5956 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5972 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6664 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                               2804 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4868 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5140 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6312 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6372 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6632 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6848 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               7036 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               7040 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                      Code:
                               3096 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               3572 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4380 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4516 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4576 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4792 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               4928 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5532 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6424 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6656 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6724 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               7564 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               7568 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               7584 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                        Image File Name[SteamService.exe]Threads
                               5384 - Wait - SteamService.dll - C:\Program Files (x86)\Common Files\Steam\SteamService.dll - Valve Corporation
                               5880 - Wait - SteamService.exe - C:\Program Files (x86)\Common Files\Steam\SteamService.exe - Valve Corporation
                               6212 - Wait - SteamService.dll - C:\Program Files (x86)\Common Files\Steam\SteamService.dll - Valve Corporation
                      Code:
                        Image File Name[conhost.exe]Threads
                      Code:
                      Code:
                        Image File Name[SpotifyWebHelper.exe]Threads
                               3784 - Wait - SpotifyWebHelper.exe - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe - Spotify Ltd
                               3816 - Wait - SpotifyWebHelper.exe - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe - Spotify Ltd
                               3820 - Wait - SpotifyWebHelper.exe - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe - Spotify Ltd
                      Code:
                      Code:
                               5764 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               6024 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6036 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6040 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6044 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6048 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6052 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6056 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               6060 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                               5356 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5392 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5396 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5404 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5408 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                      Code:
                               5416 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5452 - Wait - chrome_watcher.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_watcher.dll - Google Inc.
                      Code:
                        Image File Name[AppleMobileDeviceHelper.exe]Threads
                               6992 - Wait - AppleMobileDeviceHelper.exe - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceHelper.exe - Apple Inc.
                      Code:
                               5512 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5548 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5556 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               5560 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5820 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               5828 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               5836 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               5840 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               5860 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               6072 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               6076 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               6080 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               6084 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                               6088 - Wait - nvwgf2um.dll - C:\Windows\syswow64\nvwgf2um.dll - NVIDIA Corporation
                      Code:
                        Image File Name[distnoted.exe]Threads
                               5648 - Wait - distnoted.exe - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\distnoted.exe - Apple Inc.
                      Code:
                        Image File Name[SearchFilterHost.exe]Threads
                      Code:
                               5792 - Wait - chrome.exe - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - Google Inc.
                               5904 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5916 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5920 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5924 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5928 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5932 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5936 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                               5940 - Wait - chrome_child.dll - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll - Google Inc.
                      Code:
                        Image File Name[Idle]Threads
                      Kernel Module
                      Code:
                         mvs91xx.sys - C:\Windows\system32\DRIVERS\mvs91xx.sys - Marvell Semiconductor, Inc.
                         mvxxmm.sys - C:\Windows\system32\DRIVERS\mvxxmm.sys - Marvell Semiconductor Inc.
                         amdxata.sys - C:\Windows\system32\drivers\amdxata.sys - Advanced Micro Devices
                         360Box64.sys - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         360FsFlt.sys - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         360AntiHacker64.sys - C:\Windows\System32\Drivers\360AntiHacker64.sys - 360.cn
                         BAPIDRV64.sys - C:\Windows\system32\DRIVERS\BAPIDRV64.sys - 360.cn
                         nvlddmkm.sys - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         iusb3xhc.sys - C:\Windows\system32\DRIVERS\iusb3xhc.sys - Intel Corporation
                         TeeDriverx64.sys - C:\Windows\system32\DRIVERS\TeeDriverx64.sys - Intel Corporation
                         athrx.sys - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         xhcdrv.sys - C:\Windows\system32\DRIVERS\xhcdrv.sys - VIA Technologies, Inc.
                         P17.sys - C:\Windows\system32\drivers\P17.sys - Creative Technology Ltd.
                         L1C62x64.sys - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         Smb_driver_Intel.sys - C:\Windows\system32\DRIVERS\Smb_driver_Intel.sys - Synaptics Incorporated
                         tap0901.sys - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         nvvad64v.sys - C:\Windows\system32\drivers\nvvad64v.sys - NVIDIA Corporation
                         iusb3hub.sys - C:\Windows\system32\DRIVERS\iusb3hub.sys - Intel Corporation
                         nvhda64v.sys - C:\Windows\system32\drivers\nvhda64v.sys - NVIDIA Corporation
                         viahduaa.sys - C:\Windows\system32\drivers\viahduaa.sys - VIA Technologies, Inc.
                         dump_dumpata.sys - C:\Windows\System32\Drivers\dump_dumpata.sys - File not found
                         dump_msahci.sys - C:\Windows\System32\Drivers\dump_msahci.sys - File not found
                         dump_dumpfve.sys - C:\Windows\System32\Drivers\dump_dumpfve.sys - File not found
                         mbam.sys - C:\Windows\system32\drivers\mbam.sys - Malwarebytes
                         NvStreamKms.sys - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamKms.sys - NVIDIA Corporation
                         360AvFlt.sys - C:\Windows\system32\DRIVERS\360AvFlt.sys - 360.cn
                         PCHunter64am.sys - C:\Users\Arda\Desktop\PCHunter_free\PCHunter64am.sys - File not found
                         [UnloadDriver] BRDriver64.sys - C:\ProgramData\BitRaider\support\1.3.3\E02B25FC\BRDriver64.sys - BitRaider
                         [UnloadDriver] 360Camera64.sys - C:\Windows\System32\Drivers\360Camera64.sys - 360.cn
                         [UnloadDriver] BrSerWdm.sys - C:\Windows\System32\Drivers\BrSerWdm.sys - Brother Industries Ltd.
                         [UnloadDriver] BrUsbMdm.sys - C:\Windows\System32\Drivers\BrUsbMdm.sys - Brother Industries Ltd.
                         [UnloadDriver] BrUsbSer.sys - C:\Windows\System32\Drivers\BrUsbSer.sys - Brother Industries Ltd.
                         [UnloadDriver] Brserid.sys - C:\Windows\System32\Drivers\Brserid.sys - Brother Industries Ltd.
                         [UnloadDriver] usbaapl64.sys - C:\Windows\System32\Drivers\usbaapl64.sys - Apple, Inc.
                         [UnloadDriver] PGRXHCI.sys - C:\Windows\system32\DRIVERS\PGRXHCI.sys - Point Grey Research
                         [UnloadDriver] b57nd60a.sys - C:\Windows\system32\DRIVERS\b57nd60a.sys - Broadcom Corporation
                         [UnloadDriver] netaapl64.sys - C:\Windows\system32\DRIVERS\netaapl64.sys - Apple Inc.
                         [UnloadDriver] BrFiltLo.sys - C:\Windows\system32\drivers\BrFiltLo.sys - Brother Industries, Ltd.
                         [UnloadDriver] BrFiltUp.sys - C:\Windows\system32\drivers\BrFiltUp.sys - Brother Industries, Ltd.
                         [UnloadDriver] HpSAMD.sys - C:\Windows\system32\drivers\HpSAMD.sys - Hewlett-Packard Company
                         [UnloadDriver] MBAMSwissArmy.sys - C:\Windows\system32\drivers\MBAMSwissArmy.sys - Malwarebytes
                         [UnloadDriver] MegaSR.sys - C:\Windows\system32\drivers\MegaSR.sys - LSI Corporation, Inc.
                         [UnloadDriver] SiSRaid2.sys - C:\Windows\system32\drivers\SiSRaid2.sys - Silicon Integrated Systems Corp.
                         [UnloadDriver] adp94xx.sys - C:\Windows\system32\drivers\adp94xx.sys - Adaptec, Inc.
                         [UnloadDriver] adpahci.sys - C:\Windows\system32\drivers\adpahci.sys - Adaptec, Inc.
                         [UnloadDriver] adpu320.sys - C:\Windows\system32\drivers\adpu320.sys - Adaptec, Inc.
                         [UnloadDriver] aliide.sys - C:\Windows\system32\drivers\aliide.sys - Acer Laboratories Inc.
                         [UnloadDriver] amdsata.sys - C:\Windows\system32\drivers\amdsata.sys - Advanced Micro Devices
                         [UnloadDriver] amdsbs.sys - C:\Windows\system32\drivers\amdsbs.sys - AMD Technologies Inc.
                         [UnloadDriver] arc.sys - C:\Windows\system32\drivers\arc.sys - Adaptec, Inc.
                         [UnloadDriver] arcsas.sys - C:\Windows\system32\drivers\arcsas.sys - Adaptec, Inc.
                         [UnloadDriver] bxvbda.sys - C:\Windows\system32\drivers\bxvbda.sys - Broadcom Corporation
                         [UnloadDriver] cmdide.sys - C:\Windows\system32\drivers\cmdide.sys - CMD Technology, Inc.
                         [UnloadDriver] elxstor.sys - C:\Windows\system32\drivers\elxstor.sys - Emulex
                         [UnloadDriver] evbda.sys - C:\Windows\system32\drivers\evbda.sys - Broadcom Corporation
                         [UnloadDriver] hcw85cir.sys - C:\Windows\system32\drivers\hcw85cir.sys - Hauppauge Computer Works, Inc.
                         [UnloadDriver] iaStorV.sys - C:\Windows\system32\drivers\iaStorV.sys - Intel Corporation
                         [UnloadDriver] iirsp.sys - C:\Windows\system32\drivers\iirsp.sys - Intel Corp./ICP vortex GmbH
                         [UnloadDriver] lsi_fc.sys - C:\Windows\system32\drivers\lsi_fc.sys - LSI Corporation
                         [UnloadDriver] lsi_sas.sys - C:\Windows\system32\drivers\lsi_sas.sys - LSI Corporation
                         [UnloadDriver] lsi_sas2.sys - C:\Windows\system32\drivers\lsi_sas2.sys - LSI Corporation
                         [UnloadDriver] lsi_scsi.sys - C:\Windows\system32\drivers\lsi_scsi.sys - LSI Corporation
                         [UnloadDriver] megasas.sys - C:\Windows\system32\drivers\megasas.sys - LSI Corporation
                         [UnloadDriver] mwac.sys - C:\Windows\system32\drivers\mwac.sys - Malwarebytes Corporation
                         [UnloadDriver] nfrd960.sys - C:\Windows\system32\drivers\nfrd960.sys - IBM Corporation
                         [UnloadDriver] nvraid.sys - C:\Windows\system32\drivers\nvraid.sys - NVIDIA Corporation
                         [UnloadDriver] nvstor.sys - C:\Windows\system32\drivers\nvstor.sys - NVIDIA Corporation
                         [UnloadDriver] ql2300.sys - C:\Windows\system32\drivers\ql2300.sys - QLogic Corporation
                         [UnloadDriver] ql40xx.sys - C:\Windows\system32\drivers\ql40xx.sys - QLogic Corporation
                         [UnloadDriver] sisraid4.sys - C:\Windows\system32\drivers\sisraid4.sys - Silicon Integrated Systems
                         [UnloadDriver] stexstor.sys - C:\Windows\system32\drivers\stexstor.sys - Promise Technology
                         [UnloadDriver] viaide.sys - C:\Windows\system32\drivers\viaide.sys - VIA Technologies, Inc.
                         [UnloadDriver] vsmraid.sys - C:\Windows\system32\drivers\vsmraid.sys - VIA Technologies Inc.,Ltd
                      Notify Routine
                      Code:
                         CreateProcess - 0xFFFFF880042F905C - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         CreateProcess - 0xFFFFF88004216738 - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         CreateProcess - 0xFFFFF8800100666C - C:\Windows\System32\Drivers\360AntiHacker64.sys - 360.cn
                         CreateProcess - 0xFFFFF8800F17EB30 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         CreateProcess - 0xFFFFF880099AC3EC - C:\Windows\system32\DRIVERS\360AvFlt.sys - 360.cn
                         CreateThread - 0xFFFFF88004220038 - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         CreateThread - 0xFFFFF8800F1B2648 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         LoadImage - 0xFFFFF8800423B098 - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         LoadImage - 0xFFFFF8800F8C0DA8 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         CmpCallback - 0xFFFFF880042FA950 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         CmpCallback - 0xFFFFF88004229F6C - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         BugCheckReasonCallback - 0xFFFFF8800F17C3C0 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         Shutdown - 0xFFFFF880042EF248 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         PlugPlay - 0xFFFFF88004C78A60 - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         PlugPlay - 0xFFFFF8800F5F26B4 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         PlugPlay - 0xFFFFF8800F2C9600 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         PowerSettingCallback - 0xFFFFF880048107FC - C:\Windows\system32\DRIVERS\TeeDriverx64.sys - Intel Corporation
                      Filter
                      Code:
                         Nsiproxy - \Driver\360AntiHacker->\Driver\nsiproxy - 0xFFFFFA8009720D10[360NsiFilter] - C:\Windows\System32\Drivers\360AntiHacker64.sys - 360.cn
                         PnpManager - \Driver\nvvad_WaveExtensible->\Driver\PnpManager - 0xFFFFFA80099C0CA0[0000006f] - C:\Windows\system32\drivers\nvvad64v.sys - NVIDIA Corporation
                         PnpManager - \Driver\tap0901->\Driver\PnpManager - 0xFFFFFA8009A0D050[NDMP16] - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         PnpManager - \Driver\ACPI_HAL->\Driver\PnpManager - 0xFFFFFA8006780E10[] -  -
                      DPC Timer
                      Code:
                         0xFFFFFA800A3F92A0 - 0xFFFFF8800F242160 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                         0xFFFFFA800977D010 - 0xFFFFF8800F1806E4 - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                      Worker Thread
                      Code:
                         Nothing
                      HalDispatchTable
                      Code:
                         Nothing
                      HalPrivateDispatchTable
                      Code:
                         Nothing
                      HalAcpiDispatchTable
                      Code:
                         Nothing
                      Wdf01000 Dispatch Fun
                      Code:
                         Nothing
                      WdfFunction
                      Code:
                         Nothing
                      MiniFilter
                      Code:
                         Nothing
                      File System
                      Code:
                         Nothing
                      Sfilter FileSystem Filter Callback
                      Code:
                         Nothing
                      ClassInitData Callback
                      Code:
                         Nothing
                      Npfs Dispatch Fun
                      Code:
                         IRP_MJ_CREATE - npfs hook - 0xFFFFF88004315250 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         IRP_MJ_CREATE_NAMED_PIPE - npfs hook - 0xFFFFF880043155E8 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         IRP_MJ_CLOSE - npfs hook - 0xFFFFF88004315788 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         IRP_MJ_WRITE - npfs hook - 0xFFFFF88004315980 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         IRP_MJ_FILE_SYSTEM_CONTROL - npfs hook - 0xFFFFF88004315858 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                      Msfs Dispatch Fun
                      Code:
                         Nothing
                      Usbport Dispatch Fun
                      Code:
                         Nothing
                      System Debug
                      Code:
                         Nothing
                      Object Hijack
                      Code:
                         Nothing
                      Direct IO
                      Code:
                         Nothing
                      GDT
                      Code:
                         Nothing
                      SSDT
                      Code:
                         Nothing
                      Shadow SSDT
                      Code:
                         NtUserGetKeyState - inline hook - 0xFFFFF96000145E00 - C:\Windows\System32\win32k.sys - Microsoft Corporation
                         NtUserGetAsyncKeyState - inline hook - 0xFFFFF9600013E474 - C:\Windows\System32\win32k.sys - Microsoft Corporation
                         NtUserGetKeyboardState - inline hook - 0xFFFFF96000145C84 - C:\Windows\System32\win32k.sys - Microsoft Corporation
                         NtUserAttachThreadInput - inline hook - 0xFFFFF9600013D3F8 - C:\Windows\System32\win32k.sys - Microsoft Corporation
                         NtUserGetRawInputBuffer - inline hook - 0xFFFFF9600014ADB0 - C:\Windows\System32\win32k.sys - Microsoft Corporation
                         NtUserGetRawInputData - inline hook - 0xFFFFF9600014A520 - C:\Windows\System32\win32k.sys - Microsoft Corporation
                         NtUserRegisterHotKey - inline hook - 0xFFFFF9600013F690 - C:\Windows\System32\win32k.sys - Microsoft Corporation
                      FSD
                      Code:
                         Nothing
                      Keyboard
                      Code:
                         Nothing
                      I8042prt
                      Code:
                         Nothing
                      Mouclass
                      Code:
                         Nothing
                      Partmgr
                      Code:
                         Nothing
                      Classpnp
                      Code:
                         IRP_MJ_WRITE - classpnp hook - 0xFFFFF8800421CC30 - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                      Atapi
                      Code:
                         Nothing
                      Acpi
                      Code:
                         Nothing
                      Scsi
                      Code:
                         Nothing
                      Kernel Hook
                      Code:
                         Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80002E815A2]->[-]
                         Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80002E81686]->[-]
                         Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80002E81842]->[-]
                         Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80002E81928]->[-]
                         Inline - len(8) [ntoskrnl.exe] - [0xFFFFF80002FAF1D0]->[-]
                         Iat - ntoskrnl.exe:KeUserModeCallback[win32k.sys<=>0xFFFFF960003178E0] - [0xFFFFF8000316E48C]->[0xFFFFF8800431401C][C:\Windows\system32\DRIVERS\360Box64.sys]
                         Inline - len(14) [win32k.sys] - [0xFFFFF9600013D3F8]->[-]
                         Inline - len(14) [win32k.sys] - [0xFFFFF9600013E474]->[-]
                         Inline - len(14) [win32k.sys] - [0xFFFFF9600013F690]->[-]
                         Inline - len(14) [win32k.sys] - [0xFFFFF96000145C84]->[-]
                         Inline - len(14) [win32k.sys] - [0xFFFFF96000145E00]->[-]
                         Inline - len(14) [win32k.sys] - [0xFFFFF9600014A520]->[-]
                         Inline - len(14) [win32k.sys] - [0xFFFFF9600014ADB0]->[-]
                      PTE HOOK
                      Code:
                         Nothing
                      Kernel Hook
                      Code:
                         PostOperation - Process - ObjectType_Callback - 0xFFFFF88004216B5C - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         PreOperation - Process - ObjectType_Callback - 0xFFFFF88004216B3C - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         PostOperation - Process - ObjectType_Callback - 0xFFFFF880042F9640 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         PreOperation - Process - ObjectType_Callback - 0xFFFFF880042F9634 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         PostOperation - Thread - ObjectType_Callback - 0xFFFFF88004216B5C - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         PreOperation - Thread - ObjectType_Callback - 0xFFFFF88004216B3C - C:\Windows\system32\DRIVERS\360FsFlt.sys - 360.cn
                         PostOperation - Thread - ObjectType_Callback - 0xFFFFF880042F9640 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         PreOperation - Thread - ObjectType_Callback - 0xFFFFF880042F9634 - C:\Windows\system32\DRIVERS\360Box64.sys - 360.cn
                         - PowerState(0xFFFFFA800674FC40::0xFFFFFA800A9572B0) - Callback_Object - 0xFFFFF8800F1E1C2C - C:\Windows\system32\DRIVERS\nvlddmkm.sys - NVIDIA Corporation
                      IDT
                      Code:
                         KiUnexpectedInterrupt7 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[0] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[0] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[0] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[0] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[0] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[0] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[0] - 0x00 - OK - 0x0000000000000000 - - -
                         KiUnexpectedInterrupt7 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[1] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[1] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[1] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[1] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[1] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[1] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[1] - 0x00 - OK - 0x0000000000000000 - - -
                         KiUnexpectedInterrupt7 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[2] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[2] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[2] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[2] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[2] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[2] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[2] - 0x00 - OK - 0x0000000000000000 - - -
                         KiUnexpectedInterrupt7 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[3] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[3] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[3] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[3] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[3] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[3] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[3] - 0x00 - OK - 0x0000000000000000 - - -
                         KiUnexpectedInterrupt7 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[4] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[4] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[4] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[4] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[4] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[4] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[4] - 0x00 - OK - 0x0000000000000000 - - -
                         KiUnexpectedInterrupt7 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[5] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[5] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[5] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[5] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[5] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[5] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[5] - 0x00 - OK - 0x0000000000000000 - - -
                         KiUnexpectedInterrupt7 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[6] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[6] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[6] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[6] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[6] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[6] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[6] - 0x00 - OK - 0x0000000000000000 - - -
                         KiUnexpectedInterrupt7 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80066E1350 - unknown image -
                         KiUnexpectedInterrupt15 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80066E13F0 - unknown image -
                         KiUnexpectedInterrupt32 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80066E1530 - unknown image -
                         KiUnexpectedInterrupt33 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6090 - unknown image -
                         KiUnexpectedInterrupt49 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6510 - unknown image -
                         KiUnexpectedInterrupt81 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6210 - unknown image -
                         KiUnexpectedInterrupt82 - cpu[7] - 0x02 - idt hook - 0xFFFFFA8009DFEF90 - unknown image -
                         KiUnexpectedInterrupt98 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E62D0 - unknown image -
                         KiUnexpectedInterrupt112 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6B10 - unknown image -
                         KiUnexpectedInterrupt114 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6ED0 - unknown image -
                         KiUnexpectedInterrupt120 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6BD0 - unknown image -
                         KiUnexpectedInterrupt121 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6A50 - unknown image -
                         KiUnexpectedInterrupt122 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6990 - unknown image -
                         KiUnexpectedInterrupt123 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E68D0 - unknown image -
                         KiUnexpectedInterrupt124 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6810 - unknown image -
                         KiUnexpectedInterrupt125 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6750 - unknown image -
                         KiUnexpectedInterrupt126 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6690 - unknown image -
                         KiUnexpectedInterrupt127 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E65D0 - unknown image -
                         KiUnexpectedInterrupt128 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6450 - unknown image -
                         KiUnexpectedInterrupt129 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6F90 - unknown image -
                         KiUnexpectedInterrupt130 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80087E6390 - unknown image -
                         KiUnexpectedInterrupt132 - cpu[7] - 0x02 - idt hook - 0xFFFFFA8009DFEED0 - unknown image -
                         KiUnexpectedInterrupt133 - cpu[7] - 0x02 - idt hook - 0xFFFFFA8009DFEE10 - unknown image -
                         KiUnexpectedInterrupt134 - cpu[7] - 0x02 - idt hook - 0xFFFFFA8009DFED50 - unknown image -
                         KiUnexpectedInterrupt135 - cpu[7] - 0x02 - idt hook - 0xFFFFFA8009DFEC90 - unknown image -
                         KiUnexpectedInterrupt178 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80066E15D0 - unknown image -
                         KiUnexpectedInterrupt179 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80066E1490 - unknown image -
                         KiUnexpectedInterrupt205 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80066E1670 - unknown image -
                         KiUnexpectedInterrupt206 - cpu[7] - 0x02 - idt hook - 0xFFFFFA80066E1710 - unknown image -
                         KiUnexpectedInterrupt207 - cpu[7] - 0x00 - OK - 0x0000000000000000 - - -
                      Message Hook
                      Code:
                         QHSafeTray.exe - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - WH_CBT - safemon.dll
                      Process Hook
                      Code:
                        Image File Name[3160 NvStreamNetworkService.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2340 nvtray.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3864 QHSafeTray.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[888 winlogon.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[708 lsm.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[264 SkypeBrowserHost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5020 Skype.exe]Process Hook
                               Iat - Skype.exe->user32.dll:TrackPopupMenu - 0x0000000075A3DDE0->0x0000000000522C70[C:\Program Files (x86)\Skype\Phone\Skype.exe]
                               Iat - Skype.exe->user32.dll:DispatchMessageW - 0x0000000075A1787B->0x0000000000522B0C[C:\Program Files (x86)\Skype\Phone\Skype.exe]
                               Iat - Skype.exe->ole32.dll:OleUninitialize - 0x000000007529EB81->0x0000000000BCDDB4[C:\Program Files (x86)\Skype\Phone\Skype.exe]
                               inline - len(5) kernel32.dll->MoveFileWithProgressW - 0x00000000750D9ABC->_
                      Code:
                        Image File Name[2788 NvBackend.exe]Process Hook
                               inline - len(5) KERNELBASE.dll->LoadLibraryExW - 0x0000000075E02BDC->_
                      Code:
                        Image File Name[1996 pabeSvc64.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3588 NvStreamUserAgent.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[364 smss.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[516 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2888 Steam.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2540 audiodg.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[492 steamwebhelper.exe]Process Hook
                               Iat - steamwebhelper.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000280010
                               inline - len(7) ntdll.dll->NtCreateFile - 0x00000000775E00C9->_
                               inline - len(7) ntdll.dll->NtCreateKey - 0x00000000775DFB55->_
                               inline - len(7) ntdll.dll->NtMapViewOfSection - 0x00000000775DFC65->_
                               inline - len(7) ntdll.dll->NtOpenFile - 0x00000000775DFD79->_
                               inline - len(7) ntdll.dll->NtOpenKey - 0x00000000775DFA3D->_
                               inline - len(7) ntdll.dll->NtOpenKeyEx - 0x00000000775E102D->_
                               inline - len(7) ntdll.dll->NtOpenProcess - 0x00000000775DFC35->_
                               inline - len(7) ntdll.dll->NtOpenProcessToken - 0x00000000775E10D5->_
                               inline - len(7) ntdll.dll->NtOpenProcessTokenEx - 0x00000000775DFD2D->_
                               inline - len(7) ntdll.dll->NtOpenThread - 0x00000000775E114D->_
                               inline - len(7) ntdll.dll->NtOpenThreadToken - 0x00000000775DFC05->_
                               inline - len(7) ntdll.dll->NtOpenThreadTokenEx - 0x00000000775DFD15->_
                               inline - len(7) ntdll.dll->NtQueryAttributesFile - 0x00000000775DFE71->_
                               inline - len(7) ntdll.dll->NtQueryFullAttributesFile - 0x00000000775E1351->_
                               inline - len(7) ntdll.dll->NtSetInformationFile - 0x00000000775DFC4D->_
                               inline - len(7) ntdll.dll->NtSetInformationThread - 0x00000000775DF9C1->_
                               inline - len(7) ntdll.dll->NtUnmapViewOfSection - 0x00000000775DFC95->_
                               inline - len(7) ntdll.dll->ZwCreateFile - 0x00000000775E00C9->_
                               inline - len(7) ntdll.dll->ZwCreateKey - 0x00000000775DFB55->_
                               inline - len(7) ntdll.dll->ZwMapViewOfSection - 0x00000000775DFC65->_
                               inline - len(7) ntdll.dll->ZwOpenFile - 0x00000000775DFD79->_
                               inline - len(7) ntdll.dll->ZwOpenKey - 0x00000000775DFA3D->_
                               inline - len(7) ntdll.dll->ZwOpenKeyEx - 0x00000000775E102D->_
                               inline - len(7) ntdll.dll->ZwOpenProcess - 0x00000000775DFC35->_
                               inline - len(7) ntdll.dll->ZwOpenProcessToken - 0x00000000775E10D5->_
                               inline - len(7) ntdll.dll->ZwOpenProcessTokenEx - 0x00000000775DFD2D->_
                               inline - len(7) ntdll.dll->ZwOpenThread - 0x00000000775E114D->_
                               inline - len(7) ntdll.dll->ZwOpenThreadToken - 0x00000000775DFC05->_
                               inline - len(7) ntdll.dll->ZwOpenThreadTokenEx - 0x00000000775DFD15->_
                               inline - len(7) ntdll.dll->ZwQueryAttributesFile - 0x00000000775DFE71->_
                               inline - len(7) ntdll.dll->ZwQueryFullAttributesFile - 0x00000000775E1351->_
                               inline - len(7) ntdll.dll->ZwSetInformationFile - 0x00000000775DFC4D->_
                               inline - len(7) ntdll.dll->ZwSetInformationThread - 0x00000000775DF9C1->_
                               inline - len(7) ntdll.dll->ZwUnmapViewOfSection - 0x00000000775DFC95->_
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100280010
                               Iat - libcef.dll->GDI32.dll:GetFontData - 0x0000000075E59D6A->0x0000000053FB95E4[C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll]
                               Iat - libcef.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000280010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000280010
                               Iat - DWrite.dll->ADVAPI32.dll:OpenServiceW - 0x00000000753FC9CC->0x0000000053FBEC7D[C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll]
                               Iat - DWrite.dll->ADVAPI32.dll:CloseServiceHandle - 0x00000000754035E4->0x0000000053FBE7D9[C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll]
                               Iat - DWrite.dll->ADVAPI32.dll:OpenSCManagerW - 0x00000000753FC9E4->0x0000000053FBEC6D[C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll]
                               Iat - DWrite.dll->ADVAPI32.dll:StartServiceW - 0x00000000753F78F4->0x0000000053FBEECA[C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll]
                               Iat - DWrite.dll->ntdll.dll:NtAlpcConnectPort - 0x00000000775E03C8->0x0000000053FBEC65[C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll]
                      Code:
                        Image File Name[504 WmiPrvSE.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[4732 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[756 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[6684 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000010A0010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x00000001010A0010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000010A0010
                               Iat - chrome_child.dll->GDI32.dll:GetFontData - 0x0000000075E59D6A->0x000000005FA46B5D[C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll]
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000010A0010
                               Iat - DWrite.dll->ADVAPI32.dll:OpenServiceW - 0x00000000753FC9CC->0x000000005FA48DC4[C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll]
                               Iat - DWrite.dll->ADVAPI32.dll:CloseServiceHandle - 0x00000000754035E4->0x000000005FA4893F[C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll]
                               Iat - DWrite.dll->ADVAPI32.dll:OpenSCManagerW - 0x00000000753FC9E4->0x000000005FA48DB4[C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll]
                               Iat - DWrite.dll->ADVAPI32.dll:StartServiceW - 0x00000000753F78F4->0x000000005FA48F94[C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll]
                               Iat - DWrite.dll->ntdll.dll:NtAlpcConnectPort - 0x00000000775E03C8->0x000000005ECF1462[C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\chrome_child.dll]
                      Code:
                        Image File Name[1220 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000900010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100900010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000900010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000900010
                      Code:
                        Image File Name[544 csrss.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[620 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1192 QHActiveDefense.exe]Process Hook
                               inline - len(5) cryptnet.dll->CryptGetObjectUrl - 0x000000006E654D4C->_
                      Code:
                        Image File Name[568 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[624 wininit.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[640 csrss.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[676 services.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[7008 iTunes.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[696 lsass.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3028 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5092 SkypeBrowserHost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[812 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5332 chrome.exe]Process Hook
                               inline - len(5) kernel32.dll->CopyFileA - 0x00000000750E58CD->_
                               inline - len(5) kernel32.dll->CopyFileExA - 0x000000007513F261->_
                               inline - len(7) kernel32.dll->CopyFileExW - 0x00000000750E3B7A->_
                               inline - len(5) kernel32.dll->CopyFileW - 0x00000000750E82ED->_
                               inline - len(5) kernel32.dll->MoveFileA - 0x000000007513DF21->_
                               inline - len(5) kernel32.dll->MoveFileW - 0x00000000750D9AE0->_
                               inline - len(5) kernel32.dll->MoveFileWithProgressA - 0x00000000750ECD11->_
                               inline - len(54) chrome_elf.dll - 0x0000000063DAA000->_
                               inline - len(5) SHELL32.dll->SHFileOperationW - 0x0000000076499670->_
                               inline - len(5) ole32.dll->CoCreateInstance - 0x00000000752C9CBB->_
                               inline - len(5) ole32.dll->CoGetClassObject - 0x00000000752B546D->_
                               inline - len(5) urlmon.dll->URLDownloadToCacheFileA - 0x0000000075BFC500->_
                               inline - len(5) urlmon.dll->URLDownloadToCacheFileW - 0x0000000075B59030->_
                               inline - len(5) urlmon.dll->URLDownloadToFileA - 0x0000000075BFC650->_
                               inline - len(5) urlmon.dll->URLDownloadToFileW - 0x0000000075B595D0->_
                      Code:
                        Image File Name[1240 explorer.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1448 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[924 nvvsvc.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[964 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1912 iTunesHelper.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[6612 iPodService.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5728 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000002E0010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x00000001002E0010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000002E0010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000002E0010
                      Code:
                        Image File Name[1096 CTAudSvc.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1480 wuauclt.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5180 steamwebhelper.exe]Process Hook
                      Code:
                        Image File Name[1596 spoolsv.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2132 dwm.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2216 taskhost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1280 NvNetworkService.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1300 nvxdsync.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[4228 wmpnetwk.exe]Process Hook
                               inline - len(11) BlackBox.dll - 0x000007FEE296F5D0->_
                               inline - len(59) BlackBox.dll - 0x000007FEE296F5E0->_
                               inline - len(14) BlackBox.dll - 0x000007FEE296F620->_
                               inline - len(43) BlackBox.dll - 0x000007FEE296F638->_
                               inline - len(25) BlackBox.dll - 0x000007FEE296F668->_
                               inline - len(32) BlackBox.dll - 0x000007FEE296F688->_
                               inline - len(51) BlackBox.dll - 0x000007FEE296F6B0->_
                               inline - len(42) BlackBox.dll - 0x000007FEE296F6E8->_
                               inline - len(17) BlackBox.dll - 0x000007FEE296F718->_
                               inline - len(9) BlackBox.dll - 0x000007FEE296F730->_
                               inline - len(18) BlackBox.dll - 0x000007FEE296F740->_
                               inline - len(27) BlackBox.dll - 0x000007FEE296F758->_
                               inline - len(11) BlackBox.dll - 0x000007FEE296F778->_
                               inline - len(18) BlackBox.dll - 0x000007FEE296F788->_
                               inline - len(10) BlackBox.dll - 0x000007FEE296F7A0->_
                               inline - len(35) BlackBox.dll - 0x000007FEE296F7B0->_
                               inline - len(19) BlackBox.dll - 0x000007FEE296F7D8->_
                               inline - len(74) BlackBox.dll - 0x000007FEE296F7F0->_
                               inline - len(11) BlackBox.dll - 0x000007FEE296F840->_
                               inline - len(34) BlackBox.dll - 0x000007FEE296F850->_
                               inline - len(59) BlackBox.dll - 0x000007FEE296F878->_
                               inline - len(66) BlackBox.dll - 0x000007FEE296F8B8->_
                               inline - len(11) BlackBox.dll - 0x000007FEE296F900->_
                               inline - len(10) BlackBox.dll - 0x000007FEE296F910->_
                               inline - len(42) BlackBox.dll - 0x000007FEE296F920->_
                               inline - len(18) BlackBox.dll - 0x000007FEE296FA50->_
                               inline - len(11) BlackBox.dll - 0x000007FEE296FA68->_
                               inline - len(9) BlackBox.dll - 0x000007FEE296FA78->_
                      Code:
                        Image File Name[2112 NvStreamService.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[4496 PCHunter64.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2028 GoogleUpdate.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[6224 steamwebhelper.exe]Process Hook
                               Iat - steamwebhelper.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000004A0010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x00000001004A0010
                               Iat - libcef.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000004A0010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000004A0010
                      Code:
                        Image File Name[4392 SearchProtocolHost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1624 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3276 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000D50010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100D50010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000D50010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000D50010
                      Code:
                        Image File Name[1780 armsvc.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[4008 SearchIndexer.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1864 mDNSResponder.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[1876 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000390010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100390010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000390010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000390010
                      Code:
                        Image File Name[1944 GfExperienceService.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[7112 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000F70010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100F70010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000F70010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000F70010
                      Code:
                        Image File Name[2088 QHWatchdog.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3548 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[6800 chrome.exe]Process Hook
                      Code:
                        Image File Name[2220 svchost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[4764 APSDaemon.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2280 McAfee.TrueKey.Service.exe]Process Hook
                               C:\Program Files\TrueKey\McAfee.TrueKey.Service.exe - Hijack on Module File
                               inline - len(47) clr.dll - 0x000007FEF6301573->_
                               inline - len(10) clr.dll - 0x000007FEF63015E0->_
                               inline - len(10) clr.dll - 0x000007FEF6301600->_
                               inline - len(10) clr.dll - 0x000007FEF6301630->_
                               inline - len(1) clr.dll - 0x000007FEF6304C48->_
                               inline - len(1) clr.dll - 0x000007FEF6304C85->_
                               inline - len(1) clr.dll - 0x000007FEF6304D00->_
                               inline - len(1) clr.dll - 0x000007FEF6304D63->_
                               inline - len(1) clr.dll - 0x000007FEF6304DB8->_
                               inline - len(1) clr.dll - 0x000007FEF6304E02->_
                               inline - len(1) clr.dll - 0x000007FEF6304F8F->_
                               inline - len(1) clr.dll - 0x000007FEF6305091->_
                               inline - len(1) clr.dll - 0x000007FEF6305208->_
                               inline - len(1) clr.dll - 0x000007FEF6305225->_
                               inline - len(1) clr.dll - 0x000007FEF6305245->_
                               inline - len(1) clr.dll - 0x000007FEF63052B0->_
                               inline - len(1) clr.dll - 0x000007FEF63052F0->_
                               inline - len(1) clr.dll - 0x000007FEF6305320->_
                               inline - len(1) clr.dll - 0x000007FEF6305360->_
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:CloseHandle - 0x00000000772E1910->0x0000000000020476
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetCurrentThread - 0x00000000772D33C0->0x0000000000020462
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetLastError - 0x00000000772E1760->0x0000000000020452
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetModuleHandleW - 0x00000000772E20C0->0x0000000000020484
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetCurrentProcess - 0x00000000772D5190->0x0000000000020498
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:LoadLibraryW - 0x00000000772D6420->0x00000000000200C8
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:DisableThreadLibraryCalls - 0x00000000772D5C20->0x00000000000203F6
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetSystemTimeAsFileTime - 0x00000000772D33E0->0x00000000000203DC
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetCurrentThreadId - 0x00000000772D3380->0x00000000000203C6
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetCurrentProcessId - 0x00000000772D4EF0->0x00000000000203B0
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:QueryPerformanceCounter - 0x00000000772D59A0->0x0000000000020396
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:IsProcessorFeaturePresent - 0x000000007730D0D0->0x000000000002037A
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:IsDebuggerPresent - 0x00000000772C7910->0x0000000000020366
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:DecodePointer - 0x0000000077408080->0x0000000000020356
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:EncodePointer - 0x0000000077410A50->0x0000000000020346
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:GetProcAddress - 0x00000000772E2020->0x00000000000200B6
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:FreeLibrary - 0x00000000772D5AC0->0x00000000000200A8
                               Iat - System.EnterpriseServices.Wrapper.dll->KERNEL32.dll:Sleep - 0x00000000772E1520->0x00000000000204AC
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__dllonexit - 0x000007FEF6271F10->0x0000000000020282
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_onexit - 0x000007FEF6271FF0->0x0000000000020290
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_calloc_crt - 0x000007FEF626A8D0->0x0000000000020274
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:memcmp - 0x000007FEF623F120->0x000000000002060A
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_resetstkoflw - 0x000007FEF626B3A0->0x00000000000205FA
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_unlock - 0x000007FEF6225410->0x000000000002026A
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_lock - 0x000007FEF6225220->0x0000000000020262
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__FrameUnwindFilter - 0x000007FEF62623C0->0x000000000002055E
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_cexit - 0x000007FEF6224990->0x0000000000020554
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__CxxUnregisterExceptionObject - 0x000007FEF6262260->0x0000000000020532
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:?_type_info_dtor_internal_method@type_info@@QEAAXXZ - 0x000007FEF6260F20->0x000000000002022C
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:?terminate@@YAXXZ - 0x000007FEF6260A40->0x0000000000020218
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__crtCapturePreviousContext - 0x000007FEF6272240->0x00000000000201FA
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__crtCaptureCurrentContext - 0x000007FEF62721D0->0x00000000000201DC
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__crtTerminateProcess - 0x000007FEF6272E60->0x00000000000201C4
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__crtUnhandledException - 0x000007FEF6272E80->0x00000000000201AA
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__crt_debugger_hook - 0x000007FEF6277BF0->0x0000000000020194
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_initterm_e - 0x000007FEF6224B30->0x0000000000020186
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_initterm - 0x000007FEF6224AD0->0x000000000002017A
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_malloc_crt - 0x000007FEF626A950->0x000000000002016C
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:free - 0x000007FEF626A7D0->0x0000000000020164
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_amsg_exit - 0x000007FEF6224960->0x0000000000020156
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__CppXcptFilter - 0x000007FEF62742D0->0x0000000000020144
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:??3@YAXPEAX@Z - 0x000007FEF626A7C0->0x0000000000020134
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:memcpy - 0x000007FEF623F290->0x0000000000020114
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__CxxFrameHandler3 - 0x000007FEF62630B0->0x00000000000200FE
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__C_specific_handler - 0x000007FEF6273820->0x00000000000200E6
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__clean_type_info_names_internal - 0x000007FEF6263580->0x000000000002029A
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__CxxQueryExceptionSize - 0x000007FEF6262180->0x00000000000204B4
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__CxxExceptionFilter - 0x000007FEF6261F80->0x00000000000204CE
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__CxxRegisterExceptionObject - 0x000007FEF6262190->0x00000000000204E6
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:_CxxThrowException - 0x000007FEF62629B0->0x0000000000020506
                               Iat - System.EnterpriseServices.Wrapper.dll->MSVCR120_CLR0400.dll:__CxxDetectRethrow - 0x000007FEF6261F30->0x000000000002051C
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:StringFromGUID2 - 0x000007FEFDD82DF0->0x0000000000020614
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoGetMarshalSizeMax - 0x000007FEFDD8E6D0->0x00000000000202BE
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoTaskMemAlloc - 0x000007FEFDD886F0->0x00000000000202D4
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoTaskMemFree - 0x000007FEFDD886A0->0x00000000000202E6
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoMarshalInterface - 0x000007FEFDD8E95C->0x00000000000202F6
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoInitializeEx - 0x000007FEFDD822D8->0x00000000000205B6
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoCreateInstanceEx - 0x000007FEFDD6D870->0x00000000000205A0
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoGetStandardMarshal - 0x000007FEFDE8DD50->0x0000000000020588
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoCreateInstance - 0x000007FEFDD86D10->0x0000000000020574
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoUnmarshalInterface - 0x000007FEFDD8E344->0x000000000002030C
                               Iat - System.EnterpriseServices.Wrapper.dll->ole32.dll:CoReleaseMarshalData - 0x000007FEFDD661A0->0x0000000000020324
                               Iat - System.EnterpriseServices.Wrapper.dll->ADVAPI32.dll:LookupAccountSidW - 0x000007FEFF09DAE8->0x0000000000020412
                               Iat - System.EnterpriseServices.Wrapper.dll->ADVAPI32.dll:RegCreateKeyExW - 0x000007FEFF09D600->0x00000000000205D6
                               Iat - System.EnterpriseServices.Wrapper.dll->ADVAPI32.dll:RegSetValueExA - 0x000007FEFF094450->0x00000000000205E8
                               Iat - System.EnterpriseServices.Wrapper.dll->ADVAPI32.dll:RegOpenKeyExW - 0x000007FEFF0A4220->0x0000000000020426
                               Iat - System.EnterpriseServices.Wrapper.dll->ADVAPI32.dll:RegCloseKey - 0x000007FEFF0A4250->0x0000000000020436
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:293] - 0x000007FEFF1C8B00->0x8000000000000125
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:285] - 0x000007FEFF1666B0->0x800000000000011D
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:284] - 0x000007FEFF166350->0x800000000000011C
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:283] - 0x000007FEFF166320->0x800000000000011B
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:294] - 0x000007FEFF1D1240->0x8000000000000126
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:292] - 0x000007FEFF1B19B0->0x8000000000000124
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:291] - 0x000007FEFF1B19C0->0x8000000000000123
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:16] - 0x000007FEFF163EE0->0x8000000000000010
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:6] - 0x000007FEFF161210->0x8000000000000006
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:8] - 0x000007FEFF161240->0x8000000000000008
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:9] - 0x000007FEFF161180->0x8000000000000009
                               Iat - System.EnterpriseServices.Wrapper.dll->OLEAUT32.dll:[Ordinal:286] - 0x000007FEFF166670->0x800000000000011E
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_CountRefs - 0x000007FEFF614240->0x00000000000207AE
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_IsIIDSupported - 0x000007FEFF6141E0->0x000000000002078E
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_Invoke - 0x000007FEFF5C1450->0x0000000000020776
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_Disconnect - 0x000007FEFF5B4E30->0x000000000002075A
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_DebugServerRelease - 0x000007FEFF614200->0x00000000000207F6
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:IUnknown_QueryInterface_Proxy - 0x000007FEFF5C2AC0->0x000000000002081A
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrDllRegisterProxy - 0x000007FEFF61C0C0->0x0000000000020626
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:IUnknown_AddRef_Proxy - 0x000007FEFF5C1640->0x000000000002083A
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:IUnknown_Release_Proxy - 0x000007FEFF5C1430->0x0000000000020852
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_AddRef - 0x000007FEFF59E420->0x0000000000020728
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_DebugServerQueryInterface - 0x000007FEFF614220->0x00000000000207CA
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_QueryInterface - 0x000007FEFF59E400->0x0000000000020708
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrDllUnregisterProxy - 0x000007FEFF61C060->0x000000000002063C
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrCStdStubBuffer_Release - 0x000007FEFF5B4E50->0x0000000000020654
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrDllGetClassObject - 0x000007FEFF5CEB80->0x0000000000020670
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrDllCanUnloadNow - 0x000007FEFF5B0370->0x0000000000020688
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrCStdStubBuffer2_Release - 0x000007FEFF6141C0->0x000000000002069E
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrStubCall2 - 0x000007FEFF5B3B90->0x00000000000206BC
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrOleAllocate - 0x000007FEFF5C1260->0x00000000000206CC
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrOleFree - 0x000007FEFF5C12A0->0x00000000000206DE
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:NdrStubForwardingFunction - 0x000007FEFF614140->0x00000000000206EC
                               Iat - System.EnterpriseServices.Wrapper.dll->RPCRT4.dll:CStdStubBuffer_Connect - 0x000007FEFF614260->0x0000000000020740
                               Iat - System.EnterpriseServices.Wrapper.dll->mscoree.dll:_CorDllMain - 0x000007FEF6D43298->0x0000000000020878
                               C:\Program Files\TrueKey\system.data.sqlite.dll - Hijack on Module File
                               C:\Program Files\TrueKey\nlog.dll - Hijack on Module File
                               C:\Program Files\TrueKey\Newtonsoft.Json.Dll - Hijack on Module File
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:NdrClientCall2 - 0x000007FEFF670DE0->0x000000000027DF0E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:NdrAsyncClientCall - 0x000007FEFF66F0C0->0x000000000027DEF8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcAsyncInitializeHandle - 0x000007FEFF66FED0->0x000000000027DED0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcBindingSetAuthInfoW - 0x000007FEFF5BE8F0->0x000000000027DEB6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcStringFreeW - 0x000007FEFF5C59F0->0x000000000027DEA4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcBindingFree - 0x000007FEFF5D82C0->0x000000000027DE92
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcAsyncCompleteCall - 0x000007FEFF66F890->0x000000000027DE7A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcStringBindingComposeW - 0x000007FEFF5C7000->0x000000000027DE5E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcBindingFromStringBindingW - 0x000007FEFF5C7610->0x000000000027DE3E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->RPCRT4.dll:RpcAsyncCancelCall - 0x000007FEFF64BAE0->0x000000000027DE28
                               Iat - McAfee.TrueKey.BCAAdapter.dll->ADVAPI32.dll:CloseServiceHandle - 0x000007FEFF09A830->0x000000000027F922
                               Iat - McAfee.TrueKey.BCAAdapter.dll->ADVAPI32.dll:OpenSCManagerW - 0x000007FEFF08E500->0x000000000027F910
                               Iat - McAfee.TrueKey.BCAAdapter.dll->ADVAPI32.dll:QueryServiceStatus - 0x000007FEFF095BAC->0x000000000027F982
                               Iat - McAfee.TrueKey.BCAAdapter.dll->ADVAPI32.dll:ControlService - 0x000007FEFF0A4A50->0x000000000027F970
                               Iat - McAfee.TrueKey.BCAAdapter.dll->ADVAPI32.dll:StartServiceW - 0x000007FEFF0891A4->0x000000000027F960
                               Iat - McAfee.TrueKey.BCAAdapter.dll->ADVAPI32.dll:OpenServiceW - 0x000007FEFF08E514->0x000000000027F950
                               Iat - McAfee.TrueKey.BCAAdapter.dll->ADVAPI32.dll:QueryServiceStatusEx - 0x000007FEFF0891B8->0x000000000027F938
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__crtCapturePreviousContext - 0x000007FEFC3EE160->0x000000000027E42E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__crtTerminateProcess - 0x000007FEFC3EE8FC->0x000000000027E416
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__crtUnhandledException - 0x000007FEFC3EE91C->0x000000000027E3FC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__crt_debugger_hook - 0x000007FEFC3F3304->0x000000000027E3E6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__clean_type_info_names_internal - 0x000007FEFC3DF9F8->0x000000000027E3C2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:?_type_info_dtor_internal_method@type_info@@QEAAXXZ - 0x000007FEFC3DD508->0x000000000027E38C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_vsnprintf - 0x000007FEFC3B373C->0x000000000027E37E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_onexit - 0x000007FEFC3EDF18->0x000000000027E374
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__dllonexit - 0x000007FEFC3EDE44->0x000000000027E366
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_calloc_crt - 0x000007FEFC3E6AB4->0x000000000027E358
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_unlock - 0x000007FEFC3A2FB0->0x000000000027E34E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_lock - 0x000007FEFC3A2DC0->0x000000000027E346
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_vsnprintf_s - 0x000007FEFC3B3974->0x000000000027E336
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__C_specific_handler - 0x000007FEFC3EF238->0x000000000027E31E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_initterm_e - 0x000007FEFC3A278C->0x000000000027E310
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_initterm - 0x000007FEFC3A272C->0x000000000027E304
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_malloc_crt - 0x000007FEFC3E6B34->0x000000000027E2F6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_amsg_exit - 0x000007FEFC3A25D4->0x000000000027E2E8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__CppXcptFilter - 0x000007FEFC3EFCBC->0x000000000027E2D6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_vacopy - 0x000007FEFC3F540C->0x000000000027E2BE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:free - 0x000007FEFC3E69BC->0x000000000027E2B6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:swprintf_s - 0x000007FEFC3B20F8->0x000000000027E2A8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__RTDynamicCast - 0x000007FEFC3E00B4->0x000000000027E296
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:sprintf - 0x000007FEFC3B1B0C->0x000000000027E28C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:strchr - 0x000007FEFC3B69CC->0x000000000027E282
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:strtod - 0x000007FEFC3BF6A4->0x000000000027E278
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_errno - 0x000007FEFC3A70F0->0x000000000027E26E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:memcmp - 0x000007FEFC3BC250->0x000000000027E264
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:strtoul - 0x000007FEFC3BF964->0x000000000027E25A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:strtol - 0x000007FEFC3BF934->0x000000000027E250
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_strtoui64 - 0x000007FEFC3BFC64->0x000000000027E242
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_strtoi64 - 0x000007FEFC3BFC08->0x000000000027E236
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:ldiv - 0x000007FEFC3F7070->0x000000000027E22E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:memset - 0x000007FEFC3BC940->0x000000000027E224
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_snprintf - 0x000007FEFC3B13EC->0x000000000027E218
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fprintf - 0x000007FEFC3AEF78->0x000000000027E20E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:memcpy - 0x000007FEFC3BC3C0->0x000000000027E204
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__CxxFrameHandler3 - 0x000007FEFC3DF560->0x000000000027E1EE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_CxxThrowException - 0x000007FEFC3DEEB0->0x000000000027E1D8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:?terminate@@YAXXZ - 0x000007FEFC3DD0E0->0x000000000027E1C4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??_V@YAXPEAX@Z - 0x000007FEFC3E6D48->0x000000000027E1B2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??_U@YAPEAX_K@Z - 0x000007FEFC3E6D40->0x000000000027E1A0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??0exception@std@@QEAA@XZ - 0x000007FEFC3DD2C4->0x000000000027E184
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_time64 - 0x000007FEFC3BB268->0x000000000027E17A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fclose - 0x000007FEFC3AE968->0x000000000027E170
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:strcat_s - 0x000007FEFC3B70CC->0x000000000027E164
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:atol - 0x000007FEFC3A52D8->0x000000000027E15C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:memcpy_s - 0x000007FEFC3B644C->0x000000000027E150
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:strcpy_s - 0x000007FEFC3B7220->0x000000000027E144
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_lock_file - 0x000007FEFC3ADF20->0x000000000027E136
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:setvbuf - 0x000007FEFC3B12D8->0x000000000027E12C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_mkdir - 0x000007FEFC3A7384->0x000000000027E122
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fsetpos - 0x000007FEFC3AF98C->0x000000000027E118
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:remove - 0x000007FEFC3A76C4->0x000000000027E10E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fgetc - 0x000007FEFC3AD020->0x000000000027E106
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fflush - 0x000007FEFC3AEC44->0x000000000027E0FC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:memchr - 0x000007FEFC3B6430->0x000000000027E0F2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_fseeki64 - 0x000007FEFC3AF864->0x000000000027E0E6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fgetpos - 0x000007FEFC3AED70->0x000000000027E0DC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:strtok_s - 0x000007FEFC3B7528->0x000000000027E0D0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:ungetc - 0x000007FEFC3B2EA0->0x000000000027E0C6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_localtime64_s - 0x000007FEFC3BAC94->0x000000000027E0B4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_unlock_file - 0x000007FEFC3ADFBC->0x000000000027E0A4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:isspace - 0x000007FEFC3BDB14->0x000000000027E09A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??0bad_cast@std@@QEAA@AEBV01@@Z - 0x000007FEFC3DD1AC->0x000000000027E078
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??0bad_cast@std@@QEAA@PEBD@Z - 0x000007FEFC3DD1D0->0x000000000027E058
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??1bad_cast@std@@UEAA@XZ - 0x000007FEFC3DD2DC->0x000000000027E03C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:rename - 0x000007FEFC3A73CC->0x000000000027E032
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:abort - 0x000007FEFC3F49FC->0x000000000027E02A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??2@YAPEAX_K@Z - 0x000007FEFC3E6948->0x000000000027E018
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_finite - 0x000007FEFC400218->0x000000000027E00E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fwrite - 0x000007FEFC3B036C->0x000000000027E004
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_ecvt_s - 0x000007FEFC3BE4F8->0x000000000027DFFA
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??3@YAXPEAX@Z - 0x000007FEFC3E69B4->0x000000000027DFEA
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:isprint - 0x000007FEFC3BDA18->0x000000000027DFE0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__iob_func - 0x000007FEFC3ADF18->0x000000000027DFD2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:memmove - 0x000007FEFC3BC3C0->0x000000000027DFC8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??0exception@std@@QEAA@AEBQEBD@Z - 0x000007FEFC3DD24C->0x000000000027DFA4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??1exception@std@@UEAA@XZ - 0x000007FEFC3DD2DC->0x000000000027DF88
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:fputc - 0x000007FEFC3AD5FC->0x000000000027DF80
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__CxxQueryExceptionSize - 0x000007FEFC3DE6BC->0x000000000027F7CC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__CxxExceptionFilter - 0x000007FEFC3DE4C4->0x000000000027F7E6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__CxxRegisterExceptionObject - 0x000007FEFC3DE6C4->0x000000000027F7FE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__CxxDetectRethrow - 0x000007FEFC3DE47C->0x000000000027F81E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__CxxUnregisterExceptionObject - 0x000007FEFC3DE788->0x000000000027F834
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_cexit - 0x000007FEFC3A260C->0x000000000027F856
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:__FrameUnwindFilter - 0x000007FEFC3DE8E0->0x000000000027F860
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:vsprintf_s - 0x000007FEFC3B3BB8->0x000000000027F876
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:??0exception@std@@QEAA@AEBV01@@Z - 0x000007FEFC3DD298->0x000000000027DF5C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:_purecall - 0x000007FEFC3EDD98->0x000000000027DF50
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCR120.dll:?what@exception@std@@UEBAPEBDXZ - 0x000007FEFC3DD428->0x000000000027DF2E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Xtime_get_ticks - 0x000007FEFC4AD748->0x000000000027F884
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Future_error_map@std@@YAPEBDH@Z - 0x000007FEFC4823FC->0x000000000027F59E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_FNan - 0x000007FEFC505120->0x000000000027F596
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_FInf - 0x000007FEFC505110->0x000000000027F58E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Incref@facet@locale@std@@UEAAXXZ - 0x000007FEFC4794B8->0x000000000027F568
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Decref@facet@locale@std@@UEAAPEAV_Facet_base@3@XZ - 0x000007FEFC4794C0->0x000000000027F532
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Addfac@_Locimp@locale@std@@AEAAXPEAVfacet@23@_K@Z - 0x000007FEFC4795F0->0x000000000027F4FC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?in@?$codecvt@_WDH@std@@QEBAHAEAHPEBD1AEAPEBDPEA_W3AEAPEA_W@Z - 0x000007FEFC47976C->0x000000000027F4BC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?out@?$codecvt@_WDH@std@@QEBAHAEAHPEB_W1AEAPEB_WPEAD3AEAPEAD@Z - 0x000007FEFC4797AC->0x000000000027F47A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??0?$codecvt@_WDH@std@@QEAA@_K@Z - 0x000007FEFC4797FC->0x000000000027F456
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Getcat@?$codecvt@_WDH@std@@SA_KPEAPEBVfacet@locale@2@PEBV42@@ - 0x000007FEFC4798C0->0x000000000027F412
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??4?$_Yarn@D@std@@QEAAAEAV01@PEBD@Z - 0x000007FEFC47C230->0x000000000027F3EC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??_7_Facet_base@std@@6B@ - 0x000007FEFC4C5CE8->0x000000000027F3D0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??_7codecvt_base@std@@6B@ - 0x000007FEFC4C5D48->0x000000000027F3B4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??_7?$codecvt@_WDH@std@@6B@ - 0x000007FEFC4C5D80->0x000000000027F396
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??_7facet@locale@std@@6B@ - 0x000007FEFC4C5D08->0x000000000027F37A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Init@locale@std@@CAPEAV_Locimp@12@_N@Z - 0x000007FEFC4AE62C->0x000000000027F34E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_New_Locimp@_Locimp@locale@std@@CAPEAV123@AEBV123@@Z - 0x000007FEFC4AE7D8->0x000000000027F316
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?id@?$codecvt@_WDH@std@@2V0locale@2@A - 0x000007FEFC50DA28->0x000000000027F2EE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_1@placeholders@std@@3V?$_Ph@$00@2@A - 0x000007FEFC5086B3->0x000000000027E44C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_3@placeholders@std@@3V?$_Ph@$02@2@A - 0x000007FEFC5086BD->0x000000000027E474
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_2@placeholders@std@@3V?$_Ph@$01@2@A - 0x000007FEFC5086BA->0x000000000027E49C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Winerror_map@std@@YAPEBDH@Z - 0x000007FEFC4A91F8->0x000000000027E4C4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Syserror_map@std@@YAPEBDH@Z - 0x000007FEFC4A91D0->0x000000000027E4E4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Xbad_alloc@std@@YAXXZ - 0x000007FEFC4808DC->0x000000000027E504
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Xout_of_range@std@@YAXPEBD@Z - 0x000007FEFC4809C0->0x000000000027E51E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Xlength_error@std@@YAXPEBD@Z - 0x000007FEFC480988->0x000000000027E540
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?write@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV12@ - 0x000007FEFC4A827C->0x000000000027E562
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Xbad_function_call@std@@YAXXZ - 0x000007FEFC480920->0x000000000027E5AC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_BADOFF@std@@3_JB - 0x000007FEFC4CC118->0x000000000027E5CE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?cout@std@@3V?$basic_ostream@DU?$char_traits@D@std@@@1@A - 0x000007FEFC508B10->0x000000000027E5E4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?cerr@std@@3V?$basic_ostream@DU?$char_traits@D@std@@@1@A - 0x000007FEFC508790->0x000000000027E620
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??1_Lockit@std@@QEAA@XZ - 0x000007FEFC4AE030->0x000000000027E65C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??0_Lockit@std@@QEAA@H@Z - 0x000007FEFC4ADF94->0x000000000027E676
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?uncaught_exception@std@@YA_NXZ - 0x000007FEFC4AA064->0x000000000027E692
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Getgloballocale@locale@std@@CAPEAV_Locimp@12@XZ - 0x000007FEFC4AE624->0x000000000027E6B4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Fiopen@std@@YAPEAU_iobuf@@PEBDHH@Z - 0x000007FEFC482344->0x000000000027E6E8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?id@?$codecvt@DDH@std@@2V0locale@2@A - 0x000007FEFC508800->0x000000000027E710
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?put@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV12@D@ - 0x000007FEFC4A4DC4->0x000000000027E738
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Getcat@?$codecvt@DDH@std@@SA_KPEAPEBVfacet@locale@2@PEBV42@@Z - 0x000007FEFC48104C->0x000000000027E77C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?sputc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QEAAHD@Z - 0x000007FEFC4A71C8->0x000000000027E7BE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Osfx@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAXXZ - 0x000007FEFC47D35C->0x000000000027E800
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?widen@?$basic_ios@DU?$char_traits@D@std@@@std@@QEBADD@Z - 0x000007FEFC481E0C->0x000000000027E83E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Init@?$basic_streambuf@DU?$char_traits@D@std@@@std@@IEAAXXZ - 0x000007FEFC4979CC->0x000000000027E87A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?getloc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QEBA?AVl - 0x000007FEFC4A3B24->0x000000000027E8BA
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??0?$basic_streambuf@DU?$char_traits@D@std@@@std@@IEAA@XZ - 0x000007FEFC480C78->0x000000000027E906
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?unshift@?$codecvt@DDH@std@@QEBAHAEAHPEAD1AEAPEAD@Z - 0x000007FEFC4797EC->0x000000000027E942
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??0?$basic_iostream@DU?$char_traits@D@std@@@std@@QEAA@PEAV?$bas - 0x000007FEFC48434C->0x000000000027E978
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??0?$basic_ios@DU?$char_traits@D@std@@@std@@IEAA@XZ - 0x000007FEFC480BEC->0x000000000027E9E4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?clear@?$basic_ios@DU?$char_traits@D@std@@@std@@QEAAXH_N@Z - 0x000007FEFC47CAA0->0x000000000027EA1A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Pninc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@IEAAPEAD - 0x000007FEFC4811D0->0x000000000027EA58
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?setg@?$basic_streambuf@DU?$char_traits@D@std@@@std@@IEAAXPEAD0 - 0x000007FEFC481AA0->0x000000000027EA9C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?sputn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QEAA_JPEB - 0x000007FEFC47A524->0x000000000027EAE2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?out@?$codecvt@DDH@std@@QEBAHAEAHPEBD1AEAPEBDPEAD3AEAPEAD@Z - 0x000007FEFC4797AC->0x000000000027EB2A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?in@?$codecvt@DDH@std@@QEBAHAEAHPEBD1AEAPEBDPEAD3AEAPEAD@Z - 0x000007FEFC47976C->0x000000000027EB68
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??1?$basic_iostream@DU?$char_traits@D@std@@@std@@UEAA@XZ - 0x000007FEFC4861D0->0x000000000027EBA6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?tellg@?$basic_istream@DU?$char_traits@D@std@@@std@@QEAA?AV?$fp - 0x000007FEFC4A79B4->0x000000000027EBE2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?seekg@?$basic_istream@DU?$char_traits@D@std@@@std@@QEAAAEAV12@ - 0x000007FEFC4A664C->0x000000000027EC2E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Nan - 0x000007FEFC5050B8->0x000000000027F2E6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?flush@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV12@ - 0x000007FEFC47D0E8->0x000000000027ECC6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??6?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV01@K@Z - 0x000007FEFC48B008->0x000000000027ED0A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??6?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV01@H@Z - 0x000007FEFC48ABDC->0x000000000027ED4C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??6?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV01@P6AA - 0x000007FEFC48DE3C->0x000000000027ED8E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?setstate@?$basic_ios@DU?$char_traits@D@std@@@std@@QEAAXH_N@Z - 0x000007FEFC47C37C->0x000000000027EDE2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??1?$basic_ios@DU?$char_traits@D@std@@@std@@UEAA@XZ - 0x000007FEFC47B964->0x000000000027EE22
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?imbue@?$basic_streambuf@DU?$char_traits@D@std@@@std@@MEAAXAEBV - 0x000007FEFC4718B4->0x000000000027EE58
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?sync@?$basic_streambuf@DU?$char_traits@D@std@@@std@@MEAAHXZ - 0x000007FEFC479D64->0x000000000027EEA6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?setbuf@?$basic_streambuf@DU?$char_traits@D@std@@@std@@MEAAPEAV - 0x000007FEFC4718B0->0x000000000027EEE6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?xsputn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@MEAA_JPE - 0x000007FEFC481F2C->0x000000000027EF34
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?xsgetn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@MEAA_JPE - 0x000007FEFC481E74->0x000000000027EF7C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?uflow@?$basic_streambuf@DU?$char_traits@D@std@@@std@@MEAAHXZ - 0x000007FEFC481D7C->0x000000000027EFC4
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?showmanyc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@MEAA_ - 0x000007FEFC479D64->0x000000000027F004
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Unlock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@UEAAXXZ - 0x000007FEFC4718B4->0x000000000027F04A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Lock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@UEAAXXZ - 0x000007FEFC4718B4->0x000000000027F08C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??1?$basic_streambuf@DU?$char_traits@D@std@@@std@@UEAA@XZ - 0x000007FEFC480DF4->0x000000000027F0CC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?always_noconv@codecvt_base@std@@QEBA_NXZ - 0x000007FEFC47572C->0x000000000027F108
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??Bid@locale@std@@QEAA_KXZ - 0x000007FEFC479468->0x000000000027F134
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Swap_all@_Container_base0@std@@QEAAXAEAU12@@Z - 0x000007FEFC4718B4->0x000000000027F152
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Orphan_all@_Container_base0@std@@QEAAXXZ - 0x000007FEFC4718B4->0x000000000027F184
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Thrd_equal - 0x000007FEFC4ACAF0->0x000000000027F1B2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Throw_Cpp_error@std@@YAXH@Z - 0x000007FEFC4AC758->0x000000000027F1C0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Throw_C_error@std@@YAXH@Z - 0x000007FEFC4AC71C->0x000000000027F1E0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Release@_Pad@std@@QEAAXXZ - 0x000007FEFC4AD1E0->0x000000000027F1FE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?_Launch@_Pad@std@@QEAAXPEAU_Thrd_imp_t@@@Z - 0x000007FEFC4AD178->0x000000000027F21C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??1_Pad@std@@QEAA@XZ - 0x000007FEFC4AD12C->0x000000000027F24A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:??0_Pad@std@@QEAA@XZ - 0x000007FEFC4AD06C->0x000000000027F262
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Thrd_detach - 0x000007FEFC4ACAD4->0x000000000027F27A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Mtx_destroy - 0x000007FEFC4ACE78->0x000000000027F28A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Thrd_join - 0x000007FEFC4ACB18->0x000000000027F29A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Thrd_current - 0x000007FEFC4ACA54->0x000000000027F2A8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Mtx_unlock - 0x000007FEFC4ACF94->0x000000000027F2B8
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Mtx_lock - 0x000007FEFC4ACF10->0x000000000027F2C6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Mtx_init - 0x000007FEFC4ACEB0->0x000000000027F2D2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:_Inf - 0x000007FEFC5050A8->0x000000000027F2DE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->MSVCP120.dll:?seekg@?$basic_istream@DU?$char_traits@D@std@@@std@@QEAAAEAV12@ - 0x000007FEFC4A653C->0x000000000027EC76
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:IsProcessorFeaturePresent - 0x000000007730D0D0->0x000000000027F7A2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:IsDebuggerPresent - 0x00000000772C7910->0x000000000027F78E
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:DisableThreadLibraryCalls - 0x00000000772D5C20->0x000000000027F772
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetCurrentProcessId - 0x00000000772D4EF0->0x000000000027F75C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:QueryPerformanceCounter - 0x00000000772D59A0->0x000000000027F742
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:DecodePointer - 0x0000000077408080->0x000000000027F732
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:EncodePointer - 0x0000000077410A50->0x000000000027F722
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:DeleteTimerQueueTimer - 0x00000000772C86B0->0x000000000027F8C2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:Sleep - 0x00000000772E1520->0x000000000027F71A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetProcessHeap - 0x00000000772E19E0->0x000000000027F708
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:SleepEx - 0x00000000772E1560->0x000000000027F6FE
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:HeapFree - 0x00000000772E1A00->0x000000000027F6F2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:HeapAlloc - 0x000000007742DC60->0x000000000027F6E6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetCurrentThreadId - 0x00000000772D3380->0x000000000027F6D0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:OutputDebugStringA - 0x00000000772C48D0->0x000000000027F6BA
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:DeleteCriticalSection - 0x00000000774039A0->0x000000000027F6A2
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:EnterCriticalSection - 0x000000007742DA50->0x000000000027F68A
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetEnvironmentVariableA - 0x00000000772D5960->0x000000000027F670
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:LeaveCriticalSection - 0x000000007742DA00->0x000000000027F658
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetFileAttributesA - 0x00000000772D0880->0x000000000027F642
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:InitializeCriticalSection - 0x0000000077406540->0x000000000027F626
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetSystemTimeAsFileTime - 0x00000000772D33E0->0x000000000027F60C
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetLastError - 0x00000000772E1760->0x000000000027F5FC
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:MultiByteToWideChar - 0x00000000772D4FF0->0x000000000027F5E6
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:WideCharToMultiByte - 0x00000000772E1F80->0x000000000027F5D0
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:CreateTimerQueueTimer - 0x00000000772C8150->0x000000000027F8AA
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetTickCount64 - 0x00000000772C8AD0->0x000000000027F898
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetSystemTime - 0x00000000772E1ED0->0x000000000027F8DA
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:OutputDebugStringW - 0x00000000772CAC10->0x000000000027F8EA
                               Iat - McAfee.TrueKey.BCAAdapter.dll->KERNEL32.dll:GetTickCount - 0x00000000772E14B0->0x000000000027F900
                               Iat - McAfee.TrueKey.BCAAdapter.dll->mscoree.dll:_CorDllMain - 0x000007FEF6D43298->0x000000000027F998
                      Code:
                        Image File Name[5376 AppleMobileDeviceService.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[2400 McTkSchedulerService.exe]Process Hook
                      Code:
                        Image File Name[2476 ViakaraokeSrv.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5872 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000600010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100600010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000600010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000600010
                      Code:
                        Image File Name[7000 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000370010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100370010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000370010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000370010
                      Code:
                        Image File Name[6752 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000F80010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100F80010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000F80010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000F80010
                      Code:
                        Image File Name[5868 SteamService.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3596 conhost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3772 conhost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[3780 SpotifyWebHelper.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5240 conhost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5352 chrome.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5412 chrome.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5448 AppleMobileDeviceHelper.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5508 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000660010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100660010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000660010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000660010
                      Code:
                        Image File Name[6836 distnoted.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[7848 SearchFilterHost.exe]Process Hook
                               Nothing
                      Code:
                        Image File Name[5760 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000006A0010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x00000001006A0010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000006A0010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x00000000006A0010
                      Code:
                        Image File Name[5788 chrome.exe]Process Hook
                               Iat - chrome.exe->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000410010
                               Eat - kernel32.dll->CreateNamedPipeW - 0x00000000751448CB->0x0000000100410010
                               Iat - chrome_elf.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000410010
                               Iat - chrome_child.dll->KERNEL32.dll:CreateNamedPipeW - 0x00000000751448CB->0x0000000000410010
                      KernelCallbackTable
                      Code:
                        Image File Name[4 System]KernelCallbackTable
                      Code:
                        Image File Name[3160 NvStreamNetworkService.exe]KernelCallbackTable
                      Code:
                        Image File Name[2340 nvtray.exe]KernelCallbackTable
                      Code:
                        Image File Name[3864 QHSafeTray.exe]KernelCallbackTable
                      Code:
                        Image File Name[888 winlogon.exe]KernelCallbackTable
                      Code:
                        Image File Name[708 lsm.exe]KernelCallbackTable
                      Code:
                        Image File Name[264 SkypeBrowserHost.exe]KernelCallbackTable
                      Code:
                        Image File Name[5020 Skype.exe]KernelCallbackTable
                      Code:
                        Image File Name[2788 NvBackend.exe]KernelCallbackTable
                      Code:
                        Image File Name[1996 pabeSvc64.exe]KernelCallbackTable
                      Code:
                        Image File Name[3588 NvStreamUserAgent.exe]KernelCallbackTable
                      Code:
                        Image File Name[364 smss.exe]KernelCallbackTable
                      Code:
                        Image File Name[516 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[2888 Steam.exe]KernelCallbackTable
                      Code:
                        Image File Name[2540 audiodg.exe]KernelCallbackTable
                      Code:
                        Image File Name[492 steamwebhelper.exe]KernelCallbackTable
                      Code:
                        Image File Name[504 WmiPrvSE.exe]KernelCallbackTable
                      Code:
                        Image File Name[756 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[6684 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[1220 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[544 csrss.exe]KernelCallbackTable
                      Code:
                        Image File Name[620 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[1192 QHActiveDefense.exe]KernelCallbackTable
                      Code:
                        Image File Name[568 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[624 wininit.exe]KernelCallbackTable
                      Code:
                        Image File Name[640 csrss.exe]KernelCallbackTable
                      Code:
                        Image File Name[676 services.exe]KernelCallbackTable
                      Code:
                        Image File Name[7008 iTunes.exe]KernelCallbackTable
                      Code:
                        Image File Name[696 lsass.exe]KernelCallbackTable
                      Code:
                        Image File Name[3028 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[5092 SkypeBrowserHost.exe]KernelCallbackTable
                      Code:
                        Image File Name[812 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[1240 explorer.exe]KernelCallbackTable
                      Code:
                        Image File Name[1448 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[924 nvvsvc.exe]KernelCallbackTable
                      Code:
                        Image File Name[964 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[4732 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[5332 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[1912 iTunesHelper.exe]KernelCallbackTable
                      Code:
                        Image File Name[6612 iPodService.exe]KernelCallbackTable
                      Code:
                        Image File Name[5728 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[1096 CTAudSvc.exe]KernelCallbackTable
                      Code:
                        Image File Name[1480 wuauclt.exe]KernelCallbackTable
                      Code:
                        Image File Name[5180 steamwebhelper.exe]KernelCallbackTable
                      Code:
                        Image File Name[1596 spoolsv.exe]KernelCallbackTable
                      Code:
                        Image File Name[2132 dwm.exe]KernelCallbackTable
                      Code:
                        Image File Name[2216 taskhost.exe]KernelCallbackTable
                      Code:
                        Image File Name[1280 NvNetworkService.exe]KernelCallbackTable
                      Code:
                        Image File Name[1300 nvxdsync.exe]KernelCallbackTable
                      Code:
                        Image File Name[2112 NvStreamService.exe]KernelCallbackTable
                      Code:
                        Image File Name[2028 GoogleUpdate.exe]KernelCallbackTable
                      Code:
                        Image File Name[6224 steamwebhelper.exe]KernelCallbackTable
                      Code:
                        Image File Name[1624 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[4228 wmpnetwk.exe]KernelCallbackTable
                      Code:
                        Image File Name[1780 armsvc.exe]KernelCallbackTable
                      Code:
                        Image File Name[4496 PCHunter64.exe]KernelCallbackTable
                      Code:
                        Image File Name[4008 SearchIndexer.exe]KernelCallbackTable
                      Code:
                        Image File Name[1864 mDNSResponder.exe]KernelCallbackTable
                      Code:
                        Image File Name[1876 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[1944 GfExperienceService.exe]KernelCallbackTable
                      Code:
                        Image File Name[3276 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[7112 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[2088 QHWatchdog.exe]KernelCallbackTable
                      Code:
                        Image File Name[3548 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[6800 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[2220 svchost.exe]KernelCallbackTable
                      Code:
                        Image File Name[4764 APSDaemon.exe]KernelCallbackTable
                      Code:
                        Image File Name[2280 McAfee.TrueKey.Service.exe]KernelCallbackTable
                      Code:
                        Image File Name[5376 AppleMobileDeviceService.exe]KernelCallbackTable
                      Code:
                        Image File Name[2400 McTkSchedulerService.exe]KernelCallbackTable
                      Code:
                        Image File Name[2476 ViakaraokeSrv.exe]KernelCallbackTable
                      Code:
                        Image File Name[5872 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[7000 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[6752 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[5868 SteamService.exe]KernelCallbackTable
                      Code:
                        Image File Name[3596 conhost.exe]KernelCallbackTable
                      Code:
                        Image File Name[3772 conhost.exe]KernelCallbackTable
                      Code:
                        Image File Name[3780 SpotifyWebHelper.exe]KernelCallbackTable
                      Code:
                        Image File Name[5240 conhost.exe]KernelCallbackTable
                      Code:
                        Image File Name[5352 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[5412 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[5448 AppleMobileDeviceHelper.exe]KernelCallbackTable
                      Code:
                        Image File Name[5508 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[6836 distnoted.exe]KernelCallbackTable
                      Code:
                        Image File Name[5760 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[5788 chrome.exe]KernelCallbackTable
                      Code:
                        Image File Name[0 Idle]KernelCallbackTable
                         Nothing
                      Port
                      Code:
                         Tcp 0.0.0.0 : 80 - 0.0.0.0 : 0 - LISTENING - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Tcp 0.0.0.0 : 135 - 0.0.0.0 : 0 - LISTENING - 964 - C:\Windows\System32\svchost.exe
                         Tcp 192.168.0.16 : 139 - 0.0.0.0 : 0 - LISTENING - 4 - System
                         Tcp 0.0.0.0 : 443 - 0.0.0.0 : 0 - LISTENING - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Tcp 0.0.0.0 : 554 - 0.0.0.0 : 0 - LISTENING - 4228 - C:\Program Files\Windows Media Player\wmpnetwk.exe
                         Tcp 127.0.0.1 : 4370 - 0.0.0.0 : 0 - LISTENING - 3780 - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe
                         Tcp 127.0.0.1 : 4380 - 0.0.0.0 : 0 - LISTENING - 3780 - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe
                         Tcp 127.0.0.1 : 5354 - 0.0.0.0 : 0 - LISTENING - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Tcp 127.0.0.1 : 5354 - 127.0.0.1 : 49627 - ESTABLISHED - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Tcp 127.0.0.1 : 5354 - 127.0.0.1 : 49628 - ESTABLISHED - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Tcp 127.0.0.1 : 5354 - 127.0.0.1 : 49768 - ESTABLISHED - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Tcp 127.0.0.1 : 5354 - 127.0.0.1 : 49772 - ESTABLISHED - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Tcp 127.0.0.1 : 5354 - 127.0.0.1 : 49773 - ESTABLISHED - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Tcp 127.0.0.1 : 9990 - 0.0.0.0 : 0 - LISTENING - 1280 - C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
                         Tcp 127.0.0.1 : 27015 - 0.0.0.0 : 0 - LISTENING - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Tcp 127.0.0.1 : 27015 - 127.0.0.1 : 49759 - ESTABLISHED - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Tcp 127.0.0.1 : 27015 - 127.0.0.1 : 49762 - ESTABLISHED - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Tcp 127.0.0.1 : 27015 - 127.0.0.1 : 49780 - ESTABLISHED - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Tcp 0.0.0.0 : 27036 - 0.0.0.0 : 0 - LISTENING - 2888 - C:\Program Files (x86)\Steam\Steam.exe
                         Tcp 127.0.0.1 : 30000 - 0.0.0.0 : 0 - LISTENING - 2280 - C:\Program Files\TrueKey\McAfee.TrueKey.Service.exe
                         Tcp 0.0.0.0 : 47984 - 0.0.0.0 : 0 - LISTENING - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Tcp 0.0.0.0 : 47989 - 0.0.0.0 : 0 - LISTENING - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Tcp 0.0.0.0 : 48010 - 0.0.0.0 : 0 - LISTENING - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Tcp 0.0.0.0 : 49152 - 0.0.0.0 : 0 - LISTENING - 624 - C:\Windows\System32\wininit.exe
                         Tcp 0.0.0.0 : 49153 - 0.0.0.0 : 0 - LISTENING - 516 - C:\Windows\System32\svchost.exe
                         Tcp 0.0.0.0 : 49154 - 0.0.0.0 : 0 - LISTENING - 620 - C:\Windows\System32\svchost.exe
                         Tcp 0.0.0.0 : 49159 - 0.0.0.0 : 0 - LISTENING - 696 - C:\Windows\System32\lsass.exe
                         Tcp 0.0.0.0 : 49161 - 0.0.0.0 : 0 - LISTENING - 676 - C:\Windows\System32\services.exe
                         Tcp 127.0.0.1 : 49180 - 127.0.0.1 : 65001 - ESTABLISHED - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Tcp 192.168.0.16 : 49227 - 54.77.146.221 : 80 - ESTABLISHED - 1192 - C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe
                         Tcp 192.168.0.16 : 49245 - 157.55.235.161 : 40007 - ESTABLISHED - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Tcp 192.168.0.16 : 49268 - 104.86.236.53 : 443 - ESTABLISHED - 5092 - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe
                         Tcp 192.168.0.16 : 49269 - 104.86.236.53 : 443 - ESTABLISHED - 5092 - C:\Program Files (x86)\Skype\Browser\SkypeBrowserHost.exe
                         Tcp 192.168.0.16 : 49315 - 64.233.167.188 : 5228 - ESTABLISHED - 5332 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                         Tcp 192.168.0.16 : 49369 - 52.174.25.205 : 443 - ESTABLISHED - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Tcp 127.0.0.1 : 49627 - 127.0.0.1 : 5354 - ESTABLISHED - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Tcp 127.0.0.1 : 49628 - 127.0.0.1 : 5354 - ESTABLISHED - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Tcp 127.0.0.1 : 49759 - 127.0.0.1 : 27015 - ESTABLISHED - 1912 - C:\Program Files\iTunes\iTunesHelper.exe
                         Tcp 127.0.0.1 : 49762 - 127.0.0.1 : 27015 - ESTABLISHED - 7008 - C:\Program Files\iTunes\iTunes.exe
                         Tcp 127.0.0.1 : 49768 - 127.0.0.1 : 5354 - ESTABLISHED - 7008 - C:\Program Files\iTunes\iTunes.exe
                         Tcp 127.0.0.1 : 49772 - 127.0.0.1 : 5354 - ESTABLISHED - 7008 - C:\Program Files\iTunes\iTunes.exe
                         Tcp 127.0.0.1 : 49773 - 127.0.0.1 : 5354 - ESTABLISHED - 7008 - C:\Program Files\iTunes\iTunes.exe
                         Tcp 127.0.0.1 : 49780 - 127.0.0.1 : 27015 - ESTABLISHED - 7008 - C:\Program Files\iTunes\iTunes.exe
                         Tcp 192.168.0.16 : 51185 - 155.133.229.251 : 27017 - ESTABLISHED - 2888 - C:\Program Files (x86)\Steam\Steam.exe
                         Tcp 192.168.0.16 : 51678 - 40.77.226.192 : 443 - ESTABLISHED - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Tcp 192.168.0.16 : 51774 - 151.101.193.140 : 443 - ESTABLISHED - 5332 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                         Tcp 192.168.0.16 : 51792 - 91.190.218.51 : 12350 - ESTABLISHED - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Tcp 192.168.0.16 : 51801 - 17.188.166.110 : 5223 - ESTABLISHED - 4764 - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe
                         Tcp 192.168.0.16 : 51830 - 207.7.88.134 : 443 - CLOSE_WAIT - 5332 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                         Tcp 0.0.0.0 : 60026 - 0.0.0.0 : 0 - LISTENING - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Tcp 127.0.0.1 : 65000 - 0.0.0.0 : 0 - LISTENING - 2112 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe
                         Tcp 127.0.0.1 : 65001 - 0.0.0.0 : 0 - LISTENING - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Tcp 127.0.0.1 : 65001 - 127.0.0.1 : 49180 - ESTABLISHED - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Tcp 0.0.0.0 : 445 - 0.0.0.0 : 0 - LISTENING - 4 - System
                         Tcp 0.0.0.0 : 2869 - 0.0.0.0 : 0 - LISTENING - 4 - System
                         Tcp 0.0.0.0 : 3587 - 0.0.0.0 : 0 - LISTENING - 4732 - C:\Windows\System32\svchost.exe
                         Tcp 0.0.0.0 : 5357 - 0.0.0.0 : 0 - LISTENING - 4 - System
                         Tcp 0.0.0.0 : 10243 - 0.0.0.0 : 0 - LISTENING - 4 - System
                         Udp 192.168.0.16 : 68 - * : * - 516 - C:\Windows\System32\svchost.exe
                         Udp 192.168.0.16 : 137 - * : * - 4 - System
                         Udp 192.168.0.16 : 138 - * : * - 4 - System
                         Udp 0.0.0.0 : 443 - * : * - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Udp 127.0.0.1 : 1900 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 192.168.0.16 : 1900 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 3600 - * : * - 3864 - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
                         Udp 0.0.0.0 : 3702 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 3702 - * : * - 756 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 5004 - * : * - 4228 - C:\Program Files\Windows Media Player\wmpnetwk.exe
                         Udp 0.0.0.0 : 5005 - * : * - 4228 - C:\Program Files\Windows Media Player\wmpnetwk.exe
                         Udp 0.0.0.0 : 5353 - * : * - 5332 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                         Udp 192.168.0.16 : 5353 - * : * - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Udp 192.168.0.16 : 5353 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 0.0.0.0 : 5355 - * : * - 1448 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 27036 - * : * - 2888 - C:\Program Files (x86)\Steam\Steam.exe
                         Udp 127.0.0.1 : 48200 - * : * - 2788 - C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
                         Udp 127.0.0.1 : 48201 - * : * - 2340 - C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
                         Udp 127.0.0.1 : 48202 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 0.0.0.0 : 49154 - * : * - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Udp 127.0.0.1 : 49160 - * : * - 2112 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe
                         Udp 0.0.0.0 : 49570 - * : * - 3864 - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
                         Udp 127.0.0.1 : 50765 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 127.0.0.1 : 50766 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 127.0.0.1 : 50767 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 127.0.0.1 : 50768 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 0.0.0.0 : 51694 - * : * - 5332 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                         Udp 127.0.0.1 : 52132 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 52133 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 52134 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 52135 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 52136 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 52137 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 52138 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 52139 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 53673 - * : * - 4764 - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe
                         Udp 127.0.0.1 : 53674 - * : * - 4764 - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe
                         Udp 0.0.0.0 : 53690 - * : * - 756 - C:\Windows\System32\svchost.exe
                         Udp 127.0.0.1 : 54740 - * : * - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Udp 127.0.0.1 : 57468 - * : * - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Udp 127.0.0.1 : 57469 - * : * - 5376 - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
                         Udp 127.0.0.1 : 58649 - * : * - 1912 - C:\Program Files\iTunes\iTunesHelper.exe
                         Udp 127.0.0.1 : 58650 - * : * - 1912 - C:\Program Files\iTunes\iTunesHelper.exe
                         Udp 192.168.0.16 : 59453 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 127.0.0.1 : 59454 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 60026 - * : * - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Udp 127.0.0.1 : 60446 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 60447 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 0.0.0.0 : 61487 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 0.0.0.0 : 62990 - * : * - 5332 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                         Udp 0.0.0.0 : 63615 - * : * - 2888 - C:\Program Files (x86)\Steam\Steam.exe
                         Udp 127.0.0.1 : 64727 - * : * - 3588 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
                         Udp 127.0.0.1 : 64764 - * : * - 7008 - C:\Program Files\iTunes\iTunes.exe
                         Udp 127.0.0.1 : 64765 - * : * - 7008 - C:\Program Files\iTunes\iTunes.exe
                         Udp 0.0.0.0 : 64834 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 64836 - * : * - 756 - C:\Windows\System32\svchost.exe
                         Udp 127.0.0.1 : 65000 - * : * - 2112 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe
                         Udp 0.0.0.0 : 1900 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 3540 - * : * - 4732 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 5353 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 0.0.0.0 : 5353 - * : * - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Udp 0.0.0.0 : 49155 - * : * - 1864 - C:\Program Files\Bonjour\mDNSResponder.exe
                         Udp 0.0.0.0 : 49848 - * : * - 5020 - C:\Program Files (x86)\Skype\Phone\Skype.exe
                         Udp 0.0.0.0 : 53691 - * : * - 756 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 59451 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 59452 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 61488 - * : * - 3160 - C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
                         Udp 0.0.0.0 : 64835 - * : * - 3548 - C:\Windows\System32\svchost.exe
                         Udp 0.0.0.0 : 64837 - * : * - 756 - C:\Windows\System32\svchost.exe
                      Tcpip
                      Code:
                         Nothing
                      Nsiproxy
                      Code:
                         Nothing
                      Tdx
                      Code:
                         Nothing
                      Ndis Handler
                      Code:
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF88004A80C70 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF88005CCFD98 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF88005CCF97C - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF88004A80C70 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF88005CCF78C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15F010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88005CCFDF4 - StatusHandler - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88005CCFD98 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88005CCF97C - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88004F152D8 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF88005CCF78C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C8D0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88005CCFDF4 - StatusHandler - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88004843440 - WSendHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88004842B50 - WTransferDataHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88005CCFD98 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88005CCF97C - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF88005CCF78C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
                         0xFFFFFA800B15C010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBC41C - StatusHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBB80C - PnPEventHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBB4C4 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBB6F0 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBB63C - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBB774 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBCFC8 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBE000 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B147300 - NdisProtocolBlock - 0xFFFFF88005CBC34C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88005CBC41C - StatusHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88005CBE000 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88005CBCFC8 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88005CE7388 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF88005CBC34C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B304010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88005CBC41C - StatusHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88004A80C70 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88005CBE000 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88005CBCFC8 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88004A80C70 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF88005CBC34C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B1568D0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88005CBC41C - StatusHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88005CBE000 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88005CBCFC8 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88004F152D8 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF88005CBC34C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B156010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88005CBC41C - StatusHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88004843440 - WSendHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88004842B50 - WTransferDataHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88005CBE000 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88005CBCFC8 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF88005CBC34C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndisuio.sys - Microsoft Corporation
                         0xFFFFFA800B14A6C0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF88005849AAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF88005849368 - PnPEventHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF88005848E54 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF88005849B50 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF88005849350 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF880058492F0 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF880058494FC - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF88005849908 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800AFB1530 - NdisProtocolBlock - 0xFFFFF8800584F9D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF88005849AAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF88005849908 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF880058494FC - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF88005CE7388 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF8800584F9D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B306010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF88005849AAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF88004A80C70 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF88005849908 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF880058494FC - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF88004A80C70 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF8800584F9D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B13D8D0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF88005849AAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF88005849908 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF880058494FC - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF88004F152D8 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF8800584F9D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B131010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88005849AAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88004843440 - WSendHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88004842B50 - WTransferDataHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88005849908 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF880058494FC - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF8800584F9D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
                         0xFFFFFA800B130010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F066008 - OpenAdapterCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F066030 - CloseAdapterCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F058B48 - (Wan)SendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F058B48 - (Wan)TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F058BD4 - BindAdapterHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F0592B8 - UnbindAdapterHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F066064 - PnPEventHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F059EBC - UnloadHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F059F0C - CoStatusHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F059FA8 - CoReceivePacketHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9010 - NdisProtocolBlock - 0xFFFFF8800F059824 - CoAfRegisterNotifyHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88004A22954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058B48 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058B54 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85840 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88004A22954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F061008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F061008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F061008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F0585A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D85010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88004A02270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058B48 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058B54 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82840 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88004A02270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F061008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F061008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F061008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F0585A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D82010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88004FDAD0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058B48 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058B54 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7E010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88004FDAD0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F061008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F061008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F061008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F0585A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D840 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88004F7BAF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058B48 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058B54 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1840 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88004F7BAF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F061008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F061008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F061008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F0585A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086E1010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001798EB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001799570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001712F60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88004F715D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88004F65B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058B48 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058B54 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001712F60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88004F715D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001798EB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF88004F65AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800869D010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001798EB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001799570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F058B48 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F058B48 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F059808 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001712F60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F058B48 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F058B48 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88004F715D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88004F65B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F061008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F061008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F061008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F0585A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001712F60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88004F715D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001798EB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF8800F058B48 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF88004F65AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086D9550 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDDAC4 - OpenAdapterCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDE050 - CloseAdapterCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FECF28 - (Wan)SendCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FED778 - (Wan)TransferDataCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDDBA4 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FED468 - (Wan)ReceiveHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FED904 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDE11C - StatusHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDDB98 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FECFF0 - ReceivePacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDD348 - BindAdapterHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDDDE0 - UnbindAdapterHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FDE1E8 - PnPEventHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FF7A0 - NdisProtocolBlock - 0xFFFFF88004FE6550 - UnloadHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FD2820 - OpenAdapterCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FD2F70 - CloseAdapterCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FCFA00 - (Wan)SendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB4620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB0B10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FCF7B0 - (Wan)ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FAB5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB65D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB39D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB00E0 - BindAdapterHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB5BA0 - UnbindAdapterHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB0980 - PnPEventHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB45A0 - UnloadHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FC12C0 - CoSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FB6220 - CoStatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FC0190 - CoReceivePacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F63B0 - NdisProtocolBlock - 0xFFFFF88004FAFD80 - CoAfRegisterNotifyHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF8800179BA60 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88004FCF7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88004FAB5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88004FB0B10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88004FB4620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88004FB65D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88004FB39D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF880098736B4 - WSendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF8800179BA60 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88004FCFA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DF9010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FCF7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FAB5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FB0B10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FB4620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FB65D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FB39D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004A22954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FAE360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88004FCFA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D83840 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FCF7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FAB5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FB0B10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FB4620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FB65D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FB39D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004A02270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FAE360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88004FCFA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D81010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FCF7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FAB5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FB0B10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FB4620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FB65D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FB39D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FDAD0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FAE360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88004FCFA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7D010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001799920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FCF7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FAB5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FB0B10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FB4620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FB65D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FB39D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004F7BAF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FAE360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88004FCFA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CBE840 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001798EB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001799570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FCF7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FAB5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FB0B10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001712F60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FB4620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FB65D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FB39D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004F715D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004F65B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FAF0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FAE360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001799480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001712F60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004F715D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001798EB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004FCFA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88001761170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF88004F65AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF880017A1560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80086DA840 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041DDE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041E8AB0 - PnPEventHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041DE6B0 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041E98D0 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041E7350 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041E9850 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041DD010 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041DD3E0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009700CE0 - NdisProtocolBlock - 0xFFFFF880041DEB20 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880041DDE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF88004FABAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880041DD3E0 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880041DD010 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880041DEB20 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D7C010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041DDE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041E8AB0 - PnPEventHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041DE6B0 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041E98D0 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041E7350 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041E9850 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041DD010 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041DD3E0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80097043B0 - NdisProtocolBlock - 0xFFFFF880041DEB20 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880041DDE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF88004FABAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880041DD3E0 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880041DD010 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880041DEB20 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8009D76010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF8800181ADA0 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF88001819C70 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018047F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018DC7F0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF88001804EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF88001854E50 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF88001859BE0 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5CCE0 - NdisProtocolBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88004522210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8006A86010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88004522210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA80069FD680 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88004522210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B42C010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88004522210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A29010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018D7390 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018D7390 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018D7390 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018D7390 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001915410 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88004522210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009A398D0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF8800193F640 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF88001819C70 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018047F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018DC7F0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF88001804EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF88001854E50 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF88001859BE0 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5C850 - NdisProtocolBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF8800193F6C0 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF88001819C70 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018047F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018DC7F0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF88001804EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF88001854E50 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF88001859BE0 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B5B850 - NdisProtocolBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88005CE7388 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B30D010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88004A80C70 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88004A80C70 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B1478D0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88004843440 - WSendHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88004842B50 - WTransferDataHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009DB9010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88004F152D8 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D4E8D0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF8800193F680 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF88001819C70 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018047F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018DC7F0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF88001804EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF88001854E50 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF88001859BE0 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8008B56820 - NdisProtocolBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88005CE7388 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B3038D0 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88001798CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF8800179B630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88004A80C70 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88004A80C70 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA800B123010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88004843440 - WSendHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88004842B50 - WTransferDataHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001798A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009D8D010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001797920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880017980A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880016FBF90 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880017977E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001797710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880017953A0 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001813BC0 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCF70 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCEB0 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCE60 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCE10 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCDC0 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCA40 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DCA90 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001931760 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018DC990 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001794620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001859BE0 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001854E50 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88004F152D8 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF88001798CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018890A0 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880018CD0F0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
                         0xFFFFFA8009CD3010 - NdisOpenBlock - 0xFFFFF880016E3300 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C75C5C - SetOptionsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C84210 - SetFilterModuleOptionsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C75C80 - AttachHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76754 - DetachHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C7638C - RestartHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C761D8 - PauseHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76EE8 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C70838 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76FD4 - CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C70558 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76FC0 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76C60 - OidRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C6DCDC - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C836E8 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76DC0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76DD4 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C709E8 - StatusHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76BBC - DirectOidRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B131D50 - NdisFilterDriverBlock - 0xFFFFF88005C76C08 - DirectOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88001794440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88004175140 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005CE753C - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005CE7388 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C84210 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76EE8 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C70838 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76FD4 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C70558 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76FC0 - Characteristics.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76EE8 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C70838 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76FD4 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C70558 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76FC0 - SavedCharacteristics.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76C60 - OidRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C6DCDC - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C836E8 - CancelRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76DC0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76DD4 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C709E8 - StatusHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF880016FBFD0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76BBC - DirectOidRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2EDC80 - NdisFilterBlock - 0xFFFFF88005C76C08 - DirectOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF880041A05D0 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88004175140 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF880041A07A4 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF880041A0A68 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C84210 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76EE8 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C70838 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76FD4 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C70558 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76FC0 - Characteristics.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76EE8 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C70838 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76FD4 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C70558 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76FC0 - SavedCharacteristics.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76C60 - OidRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C6DCDC - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C836E8 - CancelRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76DC0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76DD4 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C709E8 - StatusHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF880016DF4E0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76BBC - DirectOidRequestHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B1318B0 - NdisFilterBlock - 0xFFFFF88005C76C08 - DirectOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419E1D8 - AttachHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419E620 - DetachHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419E92C - RestartHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419E7F0 - PauseHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF880041A05D0 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF880041A00B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF880041A0A68 - CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF880041A0868 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF880041A07A4 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419EEC0 - OidRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419F5A4 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419F06C - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419FED8 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF880041A0018 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419FDCC - StatusHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419F950 - DirectOidRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419FD28 - DirectOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA80096D40B0 - NdisFilterDriverBlock - 0xFFFFF8800419F9EC - CancelDirectOidRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF88001794440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF88005C70838 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF88005C70558 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF88004A7D880 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF88004A80C70 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A05D0 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A00B0 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A0A68 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A0868 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A07A4 - Characteristics.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A05D0 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A00B0 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A0A68 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A0868 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A07A4 - SavedCharacteristics.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419EEC0 - OidRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419F5A4 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419F06C - CancelRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419FED8 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880041A0018 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419FDCC - StatusHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880016DF4E0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419F950 - DirectOidRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419FD28 - DirectOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800A0A1C80 - NdisFilterBlock - 0xFFFFF8800419F9EC - CancelDirectOidRequestHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF88004179920 - SetOptionsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF88004183610 - SetFilterModuleOptionsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF8800417E880 - AttachHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF8800417E6F0 - DetachHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF8800418A6F0 - RestartHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF8800417C170 - PauseHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009706590 - NdisFilterDriverBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88005C76EE8 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88005C76FC0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88005C76FD4 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004183610 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004175170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004175140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004177A70 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004175170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004175140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004177A70 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF880016FC030 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF880016FBFD0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B23BAF0 - NdisFilterBlock - 0xFFFFF880016FBF90 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88005C76EE8 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88005C76FC0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88005C76FD4 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004183610 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004175170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004175140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004177A70 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004175170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004175140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004177A70 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF880016DF4E0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800A0A0C80 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF880017948F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004183610 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004175170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004175140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004177A70 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004175170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004175140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004177A70 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF880016FC030 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF880016FBFD0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D87C80 - NdisFilterBlock - 0xFFFFF880016FBF90 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF880017948F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004183610 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004175170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004175140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004177A70 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF8800417E270 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004175170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004175140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004177A70 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF8800417E270 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF880016DF4E0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D76C80 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF880017948F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004183610 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004175170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004175140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004177A70 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF8800417E270 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004175170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004175140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004177A70 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF8800417E270 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF880016DF4E0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E0EC80 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF880017948F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004183610 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004175170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004175140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004177A70 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF8800417E270 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004175170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004175140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004177A70 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF8800417E270 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF880016DF4E0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D74380 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88001794440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004F16BB0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004F152D8 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004183610 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004175170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004175140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004177A70 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004175170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004175140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004177A70 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF880041750C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004175010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004188AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004188AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF88004182520 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF880016FC030 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF880016FBFD0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CAE1E0 - NdisFilterBlock - 0xFFFFF880016FBF90 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416CBDC - SetFilterModuleOptionsHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C008 - AttachHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C380 - DetachHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C2DC - RestartHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C284 - PauseHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C5C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C7DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C7F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8008F35D60 - NdisFilterDriverBlock - 0xFFFFF8800416C7C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF88004175170 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF88005C76FC0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF88004177A70 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF8800416CBDC - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF8800416C5C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF8800416C684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF8800416C7DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF8800416C7F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF8800416C7C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF880016FC030 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF880016FBFD0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B2DA610 - NdisFilterBlock - 0xFFFFF880016FBF90 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF88004175170 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF88005C76FC0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF88004177A70 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF8800416CBDC - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF8800416C5C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF8800416C684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF8800416C7DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF8800416C7F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF8800416C7C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF880016E9650 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF880016DF4E0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B132870 - NdisFilterBlock - 0xFFFFF880016FBFA0 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF88004175170 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF880017948F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF88004177A70 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF8800416CBDC - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF8800416C5C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF8800416C684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF8800416C7DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF8800416C7F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF8800416C7C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF880016FC030 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF880016FBFD0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009D8BC80 - NdisFilterBlock - 0xFFFFF880016FBF90 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF88004175170 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF88001794260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF880016DF570 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF88004F16BB0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF88004177A70 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF8800416CBDC - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF8800416C5C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF8800416C684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF8800416C7DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF8800416C7F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF8800416C7C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF880016FC030 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF880016FBFD0 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009CD1C80 - NdisFilterBlock - 0xFFFFF880016FBF90 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DFE6C0 - NdisMiniDriverBlock - 0xFFFFF88009874E1C - HaltHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA8006DFE6C0 - NdisMiniDriverBlock - 0xFFFFF88009874E7C - InitializeHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA8006DFE6C0 - NdisMiniDriverBlock - 0xFFFFF8800987267C - QueryInformationHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA8006DFE6C0 - NdisMiniDriverBlock - 0xFFFFF88009875398 - ReconfigureHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA8006DFE6C0 - NdisMiniDriverBlock - 0xFFFFF880098753A4 - ResetHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA8006DFE6C0 - NdisMiniDriverBlock - 0xFFFFF880098736B4 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA8006DFE6C0 - NdisMiniDriverBlock - 0xFFFFF88009872924 - SetInformationHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CEB488 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE66C8 - HaltHandlerEx - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CEB3AC - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE6828 - PauseHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE68DC - RestartHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE6CC0 - OidRequestHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE722C - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE753C - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE7388 - CancelSendHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE6AE4 - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE697C - ResetHandlerEx - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE6B50 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE6A78 - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B2D0020 - NdisMiniDriverBlock - 0xFFFFF88005CE6F44 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF880048420A0 - UnloadHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF88004842640 - HaltHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF880048420D0 - InitializeHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF88004842B60 - QueryInformationHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF88004842B50 - ResetHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF88004843440 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF88004842EA0 - SetInformationHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0B3E0 - NdisMiniDriverBlock - 0xFFFFF88004842B50 - (Wan)TransferDataHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2D328 - UnloadHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2DBB0 - HaltHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2DF54 - InitializeHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A222D4 - ResetHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2F008 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2F068 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2F0B0 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2F0F8 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A22954 - CoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2F068 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF88004A2F0B0 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A065B0 - NdisMiniDriverBlock - 0xFFFFF880016E0CA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A16400 - UnloadHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A089E0 - HaltHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A1A1B0 - InitializeHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A04BF0 - ResetHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A0FDB0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A163B0 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A16360 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A102D0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A02270 - CoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A163B0 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF88004A16360 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A03760 - NdisMiniDriverBlock - 0xFFFFF880016E0CA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE52B4 - UnloadHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FDA4B4 - HaltHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE5AB4 - InitializeHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FDA604 - ResetHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE7008 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE7150 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE7198 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE71E0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FDAD0C - CoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE7150 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF88004FE7198 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA80099FFAE0 - NdisMiniDriverBlock - 0xFFFFF880016E0CA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FCCB00 - UnloadHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB5DA0 - HaltHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FD2350 - InitializeHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB49A0 - ReconfigureHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB48D0 - ResetHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FAB6F0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FABAD0 - SendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB4850 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB47D0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB4750 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB46D0 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB6670 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FAE760 - CoRequestHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB4850 - MiniportCharacteristics.CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB47D0 - MiniportCharacteristics.CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB4750 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF88004FB46D0 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F8020 - NdisMiniDriverBlock - 0xFFFFF880016E0CA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F98120 - UnloadHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F98010 - HaltHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F96500 - InitializeHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F7E470 - ResetHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F873D0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F92930 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F92930 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F885A0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F7BAF0 - CoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F92930 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF88004F92930 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EA3D0 - NdisMiniDriverBlock - 0xFFFFF880016E0CA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65B7C - CoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65B7C - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65B7C - CoActivateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65B7C - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F71418 - CoSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65AEC - CoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F6631C - CmCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F6659C - CmDeleteVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65D18 - CmOpenAfHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65DA4 - CmCloseAfHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F668A8 - CmRegisterSapHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F66A10 - CmDeregisterSapHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F66E7C - CmMakeCallHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F66DDC - CmCloseCallHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F71650 - CmIncomingCallCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F7183C - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F71A50 - CmDeactivateVcCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F71B38 - CmModifyCallQoSHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F6754C - CmOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F67598 - CmOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F67598 - CmNotifyCloseAfCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F70138 - SetOptionsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F6FC60 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F652D4 - HaltHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F6F328 - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F654DC - PauseHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65550 - RestartHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F715D0 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F715DC - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F715D0 - CancelSendHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F6558C - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F65B70 - ResetHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F70364 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F67598 - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099E7570 - NdisMiniDriverBlock - 0xFFFFF88004F67598 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F1EE84 - AddDeviceHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F1F18C - RemoveDeviceHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F1EF50 - FilterResourceRequirementsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F0F7AC - SetOptionsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F0F57C - InitializeHandlerEx - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F0F478 - HaltHandlerEx - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F0F898 - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F115B4 - PauseHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F122A8 - RestartHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F11524 - OidRequestHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F153DC - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F16BB0 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F152D8 - CancelSendHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F1111C - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F12208 - ResetHandlerEx - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F11624 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F0F81C - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA800976BC70 - NdisMiniDriverBlock - 0xFFFFF88004F11110 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A52BF0 - SetOptionsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A50240 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A53730 - HaltHandlerEx - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A50050 - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A51AD0 - PauseHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A51780 - RestartHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A52740 - OidRequestHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A816B0 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A7D880 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A80C70 - CancelSendHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A52CA0 - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A53050 - ResetHandlerEx - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A53260 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004A534F0 - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA80097865E0 - NdisMiniDriverBlock - 0xFFFFF88004C91640 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004520F84 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004521D80 - HaltHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF880045317DC - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004521ED8 - PauseHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004522000 - RestartHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004521CCC - OidRequestHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004521D54 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004521D44 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004522210 - CancelSendHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF880045257AC - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF88004531944 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF880045220FC - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA800972FC60 - NdisMiniDriverBlock - 0xFFFFF880045217F8 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017186C0 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8006DA91A0 - NdisMiniportBlock - 0xFFFFF880098736B4 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88005CE6A78 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88005CE7388 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88005CE753C - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwifimp.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88004177A70 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88005C70838 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88005C70558 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88005C76FC0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF88004175170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800B27E1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800179A730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800179EC30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017A00D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001794AB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88004842640 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001725F90 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88004177A70 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88004175140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88004175170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A0D1A0 - NdisMiniportBlock - 0xFFFFF88004843440 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\tap0901.sys - The OpenVPN Project
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001773340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800179A730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88004A2F008 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88004A2F008 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A091A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001773340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800179A730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88004A0FDB0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88004A0FDB0 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A041A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001773340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800179A730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88004FE7008 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88004FE7008 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8009A001A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001794AB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800179AB10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800179EC30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017A00D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88004FABAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001794AB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88004FAB6F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88004177A70 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88004175140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800417E270 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF88004175170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FC1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001794AB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800179AB10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800179EC30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017A00D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88004FABAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001794AB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88004FAB6F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88004177A70 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88004175140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800417E270 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF88004175170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099FA1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001794AB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800179AB10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800179EC30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017A00D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88004FABAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001794AB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88004FAB6F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88004177A70 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88004175140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800417E270 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF88004175170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099F41A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001798A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800179A730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88004F873D0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88004F873D0 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF880017948F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099EC1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001794440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88004F67598 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88004F715D0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88004F715DC - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88004F715D0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88004F715DC - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
                         0xFFFFFA80099B91A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88004F0F81C - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88004F152D8 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88004F16BB0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88004177A70 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88004175140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88004F16BB0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\L1C62x64.sys - Qualcomm Atheros Co., Ltd.
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF88004175170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA80099711A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880016FB550 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880016D7390 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88004A534F0 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88004A80C70 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88004A7D880 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\athrx.sys - Qualcomm Atheros Communications, Inc.
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88004177A70 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880041A00B0 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880041A0868 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\vwififlt.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88005C76FC0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\nwifi.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF88004175170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
                         0xFFFFFA800997B1A0 - NdisMiniportBlock - 0xFFFFF8800179D010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001794440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880045220FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88004522210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88004522210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097391A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001794440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880045220FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88004522210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88004522210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097361A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001794440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880045220FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88004522210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88004522210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA80097331A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001794440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880045220FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88004522210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88004522210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008E021A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800171E2F0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001794FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880017703B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001770C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800179E650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800179F280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800179E570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800179F1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800175FBB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001765BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001799720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880017705C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880017704D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880017983C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800176A8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800176A7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001773340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880016FBF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880017947D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001794440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001765910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880017941B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880017618C0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800171D420 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880045220FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800175D900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001773340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF8800179C0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88004522210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001794260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001794440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88004522210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001794260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF880016DF570 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88004521D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
                         0xFFFFFA8008D681A0 - NdisMiniportBlock - 0xFFFFF88001773340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA80096CB250 - NdisIfProviderBlock - 0xFFFFF880041DD4F0 - QueryObjectHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA80096CB250 - NdisIfProviderBlock - 0xFFFFF880041E9610 - SetObjectHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
                         0xFFFFFA8008AD9340 - NdisIfProviderBlock - 0xFFFFF880016DCD70 - QueryObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008AD9340 - NdisIfProviderBlock - 0xFFFFF88001700D40 - SetObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008ADABB0 - NdisIfProviderBlock - 0xFFFFF880016D9C80 - QueryObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                         0xFFFFFA8008ADABB0 - NdisIfProviderBlock - 0xFFFFF88001700D40 - SetObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
                      IE Plugin
                      Code:
                         ActiveX -  -  -  - {0F4B8786-5502-4803-8EBC-F652A1153BB6}
                         ActiveX -  -  -  - {4BAAC1B8-0800-42C9-8FA6-08B211F356B8}
                         ActiveX -  -  -  - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497}
                         ActiveX - SafeMon Class - C:\Program Files (x86)\360\Total Security\safemon\safemon64.dll - Qihu 360 Software Co., Ltd. - {B69F34DD-F0F9-42DC-9EDD-957187DA688D}
                         ActiveX -  -  -  - {D4B68B83-8710-488B-A692-D74B50BA558E}
                         ActiveX -  -  -  - {E705A591-DA3C-4228-B0D5-A356DBA42FBF}
                         ActiveX -  -  -  - {F6ACF75C-C32C-447B-9BEF-46B766368D29}
                      IE Shell
                      Code:
                         Nothing
                      Spi
                      Code:
                         mdnsNSP - C:\Program Files (x86)\Bonjour\mdnsNSP.dll - Apple Inc.
                         mdnsNSP - C:\Program Files\Bonjour\mdnsNSP.dll - Apple Inc.
                      Hosts File
                      Code:
                         Nothing
                      Startup
                      Code:
                         iTunesHelper - C:\Program Files\iTunes\iTunesHelper.exe - Apple Inc. - [\Registry\Machine\SOFTWARE\Microsoft\Windows\CurrentVersion\Run iTunesHelper]
                         QHSafeTray - C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - QIHU 360 SOFTWARE CO. LIMITED - [\Registry\Machine\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run QHSafeTray]
                         Spotify Web Helper - C:\Users\Arda\AppData\Roaming\Spotify\SpotifyWebHelper.exe - Spotify Ltd - [\REGISTRY\USER\S-1-5-21-289047654-888293549-2986845424-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Spotify Web Helper]
                         DllDirectory32 - C:\Windows\system32\ -  - [\Registry\Machine\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDLLs DllDirectory32]
                         PRIVAM~1.DLL(PrivaZer) - C:\PROGRA~2\PrivaZer\PRIVAM~1.DLL - File not found - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers PrivaZer]
                         MenuEx64.dll(SD360) - C:\Program Files (x86)\360\Total Security\MenuEx64.dll -  - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers SD360]
                         RarExt.dll(WinRAR) - C:\Program Files\WinRAR\RarExt.dll - Alexander Roshal - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers WinRAR]
                         mbamext.dll(MBAMShlExt) - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll - Malwarebytes - [\Registry\Machine\SOFTWARE\Classes\AllFilesystemObjects\shellex\ContextMenuHandlers MBAMShlExt]
                         PRIVAM~1.DLL(PrivaZer) - C:\PROGRA~2\PrivaZer\PRIVAM~1.DLL - File not found - [\Registry\Machine\SOFTWARE\Classes\AllFilesystemObjects\shellex\ContextMenuHandlers PrivaZer]
                         mbamext.dll(MBAMShlExt) - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamext.dll - Malwarebytes - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers MBAMShlExt]
                         PRIVAM~1.DLL(PrivaZer) - C:\PROGRA~2\PrivaZer\PRIVAM~1.DLL - File not found - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers PrivaZer]
                         MenuEx64.dll(SD360) - C:\Program Files (x86)\360\Total Security\MenuEx64.dll -  - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers SD360]
                         RarExt.dll(WinRAR) - C:\Program Files\WinRAR\RarExt.dll - Alexander Roshal - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers WinRAR]
                         Google Chrome({8A69D345-D564-463c-AFF1-A69D9E530F96}) - C:\Program Files (x86)\Google\Chrome\Application\56.0.2924.87\Installer\chrmstp.exe - Google Inc. - [\Registry\Machine\SOFTWARE\Wow6432Node\Microsoft\Active Setup\Installed Components {8A69D345-D564-463c-AFF1-A69D9E530F96}]
                      Service
                      Code:
                         AdobeARMservice - Started - Automatic - "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe" - Adobe Systems Incorporated -  -
                         Apple Mobile Device Service - Started - Automatic - "C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe" - Apple Inc. -  -
                         Bonjour Service - Started - Automatic - "C:\Program Files\Bonjour\mDNSResponder.exe" - Apple Inc. -  -
                         BRSptStub - Stopped - Manual - "C:\ProgramData\BitRaider\BRSptStub.exe" - BitRaider, LLC -  -
                         Creative Audio Engine Licensing Service - Stopped - Manual - "C:\Program Files (x86)\Common Files\Creative Labs Shared\Service\CTAELicensing.exe" - Creative Labs -  -
                         CTAudSvcService - Started - Automatic - C:\Program Files (x86)\Creative\Shared Files\CTAudSvc.exe - Creative Technology Ltd -  -
                         GfExperienceService - Started - Automatic - "C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe" - NVIDIA Corporation -  -
                         gupdate - Stopped - Automatic - "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /svc - Google Inc. -  -
                         gupdatem - Stopped - Manual - "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /medsvc - Google Inc. -  -
                         IEEtwCollectorService - Stopped - Manual - C:\Windows\syswow64\IEEtwCollector.exe /V - File not found -  -
                         IntelBCAsvc - Started - Automatic - "C:\Program Files\Intel\BCA\pabeSvc64.exe" - Intel(R) Corporation -  -
                         MBAMScheduler - Stopped - Disabled - "C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe" - Malwarebytes -  -
                         MBAMService - Stopped - Automatic - "C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe" - Malwarebytes -  -
                         NvNetworkService - Started - Automatic - "C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe" - NVIDIA Corporation -  -
                         NvStreamNetworkSvc - Started - Manual - "C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe" - NVIDIA Corporation -  -
                         NvStreamSvc - Started - Automatic - "C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe" - NVIDIA Corporation -  -
                         nvsvc - Started - Automatic - "C:\Windows\system32\nvvsvc.exe" - NVIDIA Corporation -  -
                         QHActiveDefense - Started - Automatic - "C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe" - QIHU 360 SOFTWARE CO. LIMITED -  -
                         SkypeUpdate - Stopped - Automatic - "C:\Program Files (x86)\Skype\Updater\Updater.exe" - Skype Technologies -  -
                         Steam Client Service - Started - Manual - "C:\Program Files (x86)\Common Files\Steam\SteamService.exe" /RunAsService - Valve Corporation -  -
                         TrueKey - Started - Automatic - "C:\Program Files\TrueKey\McAfee.TrueKey.Service.exe" - McAfee, Inc. -  -
                         TrueKeyScheduler - Started - Automatic - "C:\Program Files\TrueKey\McTkSchedulerService.exe" - McAfee, Inc. -  -
                         TrueKeyServiceHelper - Stopped - Manual - "C:\Program Files\TrueKey\McAfee.TrueKey.ServiceHelper.exe" - McAfee, Inc. -  -
                         VIAKaraokeService - Started - Automatic - C:\Windows\System32\viakaraokesrv.exe - VIA Technologies, Inc. -  -
                         iPod Service - Started - Manual - "C:\Program Files\iPod\bin\iPodService.exe" - Apple Inc. -  -
                      Schedule Task
                      Code:
                         AitAgent - \Microsoft\Windows\Application Experience\AitAgent - aitagent - Sammelt Anwendungstelemetrieinformationen und lädt diese hoch, wenn Sie sich für die Teilnahme am Programm zur Verbesserung der Benutzerfreundlichkeit von Microsoft angemeldet haben. - Enable -
                         GatherNetworkInfo - \Microsoft\Windows\NetTrace\GatherNetworkInfo - C:\Windows\System32\gatherNetworkInfo.vbs - Sammlung für Netzwerkinformationen - Enable -
                      File Association
                      Code:
                         hlpfile - %SystemRoot%\winhlp32.exe %1 - HKEY_CLASSES_ROOT\hlpfile\Shell\Open\Command
                         vbsfile - "%SystemRoot%\System32\WScript.exe" "%1" %* - HKEY_CLASSES_ROOT\vbsfile\Shell\Open\Command
                         jsfile - C:\Windows\System32\WScript.exe "%1" %* - HKEY_CLASSES_ROOT\jsfile\Shell\Open\Command
                      IFEO
                      Code:
                         Nothing
                      IME/CTF
                      Code:
                         Nothing
                      Firewall Rule
                      Code:
                         NetPres-Out-TCP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=6|Profile=Private|Profile=Public|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31765|Desc=@FirewallAPI.dll,-31768|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
                         NetPres-In-TCP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=6|Profile=Private|Profile=Public|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31761|Desc=@FirewallAPI.dll,-31764|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
                         NetPres-WSD-Out-UDP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=17|RPort=3702|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31757|Desc=@FirewallAPI.dll,-31760|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
                         NetPres-WSD-In-UDP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=17|LPort=3702|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31753|Desc=@FirewallAPI.dll,-31756|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
                         NetPres-Out-TCP-NoScope --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=6|Profile=Domain|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31765|Desc=@FirewallAPI.dll,-31768|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
                         NetPres-In-TCP-NoScope --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=6|Profile=Domain|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31761|Desc=@FirewallAPI.dll,-31764|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
                         TCP Query User{48860A50-4C98-4707-8DD9-73D87FDAB149}C:\program files (x86)\skype\phone\skype.exe --> C:\program files (x86)\Skype\Phone\Skype.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\program files (x86)\skype\phone\skype.exe|Name=Skype |Desc=Skype |Defer=User| - Enabled - Skype Technologies S.A.
                         UDP Query User{D800195A-9D95-40E5-96E8-96077CE628B3}C:\program files (x86)\skype\phone\skype.exe --> C:\program files (x86)\Skype\Phone\Skype.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\program files (x86)\skype\phone\skype.exe|Name=Skype |Desc=Skype |Defer=User| - Enabled - Skype Technologies S.A.
                         {F61824D6-CC73-478C-A675-6A26DF8B829F} --> C:\Program Files (x86)\Steam\Steam.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=C:\Program Files (x86)\Steam\Steam.exe|Name=Steam| - Enabled - Valve Corporation
                         {F0CDBBEE-B206-474A-A5E2-492EDE9DD826} --> C:\Program Files (x86)\Steam\Steam.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=C:\Program Files (x86)\Steam\Steam.exe|Name=Steam| - Enabled - Valve Corporation
                         {6B25416F-7CB7-46D1-8823-D084DA623E1D} --> C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - Valve Corporation
                         {506FB900-C20C-4B3B-8BDD-0C2A71CFE998} --> C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - Valve Corporation
                         TCP Query User{551BC06E-A0FF-4B72-9649-79E5005BB4A0}C:\users\arda\appdata\roaming\spotify\spotify.exe --> C:\Users\Arda\AppData\Roaming\Spotify\Spotify.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\users\arda\appdata\roaming\spotify\spotify.exe|Name=Spotify|Desc=Spotify|Defer=User| - Enabled - Spotify Ltd
                         UDP Query User{80629ADA-72ED-4E6F-904F-F58C2B4469F5}C:\users\arda\appdata\roaming\spotify\spotify.exe --> C:\Users\Arda\AppData\Roaming\Spotify\Spotify.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\users\arda\appdata\roaming\spotify\spotify.exe|Name=Spotify|Desc=Spotify|Defer=User| - Enabled - Spotify Ltd
                         TCP Query User{37AA2109-CFB8-4CD9-90B6-1B5AB4CCEE4D}C:\program files (x86)\google\chrome\application\chrome.exe --> C:\program files (x86)\Google\Chrome\application\chrome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\program files (x86)\google\chrome\application\chrome.exe|Name=Google Chrome|Desc=Google Chrome|Defer=User| - Enabled - Google Inc.
                         UDP Query User{541EE1DE-7E00-450D-A1A2-46473031107E}C:\program files (x86)\google\chrome\application\chrome.exe --> C:\program files (x86)\Google\Chrome\application\chrome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\program files (x86)\google\chrome\application\chrome.exe|Name=Google Chrome|Desc=Google Chrome|Defer=User| - Enabled - Google Inc.
                         TCP Query User{FBAE1540-E3D3-43D7-8FBE-98FFA9F61BB7}C:\program files (x86)\steam\steamapps\common\chivalrymedievalwarfare\binaries\win64\cmw.exe --> C:\program files (x86)\Steam\steamapps\common\chivalrymedievalwarfare\Binaries\Win64\CMW.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\program files (x86)\steam\steamapps\common\chivalrymedievalwarfare\binaries\win64\cmw.exe|Name=CMW|Desc=CMW|Defer=User| - Enabled - Epic Games, Inc.
                         UDP Query User{0AF7B65A-57FB-4EFF-B13B-CB265B2AD6E3}C:\program files (x86)\steam\steamapps\common\chivalrymedievalwarfare\binaries\win64\cmw.exe --> C:\program files (x86)\Steam\steamapps\common\chivalrymedievalwarfare\Binaries\Win64\CMW.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\program files (x86)\steam\steamapps\common\chivalrymedievalwarfare\binaries\win64\cmw.exe|Name=CMW|Desc=CMW|Defer=User| - Enabled - Epic Games, Inc.
                         TCP Query User{5683E5BE-72F6-4453-96A2-23390F03132B}C:\program files (x86)\steam\steamapps\common\tabletop simulator\tabletop simulator.exe --> C:\program files (x86)\Steam\steamapps\common\tabletop simulator\tabletop simulator.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\program files (x86)\steam\steamapps\common\tabletop simulator\tabletop simulator.exe|Name=Tabletop Simulator|Desc=Tabletop Simulator|Defer=User| - Enabled -
                         UDP Query User{1BA5BA3E-C710-4E77-9BD8-4F469D077523}C:\program files (x86)\steam\steamapps\common\tabletop simulator\tabletop simulator.exe --> C:\program files (x86)\Steam\steamapps\common\tabletop simulator\tabletop simulator.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\program files (x86)\steam\steamapps\common\tabletop simulator\tabletop simulator.exe|Name=Tabletop Simulator|Desc=Tabletop Simulator|Defer=User| - Enabled -
                         {22DBFEE5-81E2-4884-9D45-F52434989FD6} --> C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe|Name=360 Total Security| - Enabled - QIHU 360 SOFTWARE CO. LIMITED
                         {95352B4E-2221-4796-A380-274AC0E78E1D} --> C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe|Name=360 Total Security| - Enabled - QIHU 360 SOFTWARE CO. LIMITED
                         {8F31944F-161A-4F9A-9FC5-E6488276B68B} --> C:\Program Files\iTunes\iTunes.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|App=C:\Program Files\iTunes\iTunes.exe|Name=iTunes|Edge=TRUE| - Enabled - Apple Inc.
                      System User Name
                      Code:
                         Nothing
                      Scan MBR Rootkit
                      Code:
                         Unknow MBR!
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #26
                        It will take a while to go over the PCHunter log… Check disk has corrected a few errors, how is the machine running now?
                        Also download deluxe task manager from my signature.
                        Unzip it to your desktop.
                        Right click run as admin.
                        Click the down arrow next to the ghost icon.
                        [ATTACH]1715[/ATTACH]
                        Click on take snapshot.
                        Upload the snapshot here in your next reply.
                        • Malnutrition
                          PCHF Moderator
                          • 7041
                          #27
                          Looking over the PCHunter log… I see zero signs of malware.
                          How does your machine perform in Safe Mode — Also, how does it perform under a clean boot?
                          • atay
                            • Feb 2017
                            • 35
                            #28
                            Snapshots
                            • Malnutrition
                              PCHF Moderator
                              • 7041
                              #29
                              Easy Service Optimizer
                              Download easy service optmizer, save it to your desktop and unzip it there. Right click it and run as admin, then select Tweaked at the bottom. Then click on the rocket, this will turn off a lot of useless items.
                              https://i.imgur.com/tnkjYlk.png
                              You will however need to change one setting. Right Click on Wlansvc — WLAN AutoConfig, then select start service, the edit service. Make sure it is automatic across the board, as per the picture.
                              https://i.imgur.com/PO7tPc7.png
                              Process Hacker.
                              [ATTACH]1729[/ATTACH]
                              Also, please Download Process Hacker and screen shot the Svchost.exe that is taking up the memory.
                              Right click on it and select send to Virus Total.
                              Click no when the box pops up that reads view existing report.
                              [URL unfurl="true"]https://forum.windowsinstructed.com/uploads/monthly_2016_03/1.PNG.7c8a5df9057e88b7be81483205af1a09.PNG[/URL]
                              Then Select Reanalyse
                              [URL unfurl="true"]https://forum.windowsinstructed.com/uploads/monthly_2016_03/2.PNG.c0403fc52fe9fc2f6aca24c014486d6b.PNG[/URL]
                              Post the resulting link of the scan back here in your next reply.
                              Step two: Process Hacker.
                              Next on the Svchost.exe that is causing the large CPU usage right click on it and select properties.
                              Then go to the services tab. Screen shot the services appended to it for me, with the Snipping Tool.
                              Example below:
                              [URL unfurl="true"]https://forum.windowsinstructed.com/uploads/monthly_2016_03/3.PNG.6acd33f5258a750407d9e021ff3f844c.PNG[/URL]
                              • Malnutrition
                                PCHF Moderator
                                • 7041
                                #30
                                HijackThis.
                                1- Please click HERE to download HijackThis. – Unzip to your desktop.
                                2- Right click run as admin.
                                5- Copy paste the log here.
