Originally posted by Joshua Bobbitt
Need help, laptop cannot connect to certain websites.
From this point yes, but I am able to see what modes you are running in, if there was an issue I would have let you know. -
Pre_Scan may change your WLAN AutoConfig rendering you unable to connect via wireless.
Use easy service optmizer, Right Click on Wlansvc — WLAN AutoConfig, then select start service, the edit service.
Make sure it is automatic across the board, as per the picture.
[MEDIA=imgur]YJjG3hv[/MEDIA]
[li]Or use windows, hit the start button. [/li][li]Type Services, hit enter.[/li][li]Scroll to WLAN AutoConfig[/li][li]Right Click[/li][li]Start the service.[/li][li]Right Click Properties.[/li][li]Change startup type to Automatic.[/li][/ul]
[MEDIA=imgur]Ev0ftZj[/MEDIA]Comment
Reboot and click on the bottom left corner of 9-Lab.Originally posted by Joshua Bobbittdatabase to update for 9labs
Let’s see some fresh FRST logs, we may be on the verge of solving this. I would like to see FRESH FRST logs, after Combofix scan, this tool is more stable and will run without issue.Originally posted by Joshua BobbittWell, I think I’m just going to do a clean install of windows, do you think that would fix it?
Combofix Scan
Download Combofix from HERE, and save it to your desktop.
Note: It is important that it is saved directly to your desktop
IMPORTANT!! - Disable your AntiVirus and AntiSpyware applications.
Right click on ComboFix.exe Run as Administrator & follow the prompts.
[li]If you have trouble, stop and post back. Do not try to repeatedly run comboFix![/li][li]When finished, it will produce a report for you.[/li][/ul]
Note: If after running ComboFix you receive a message stating, “Illegal Operation Attempted on a registry key that has been marked for deletion” rebooting your computer will resolve the problem.Comment
Thread closed; due to lack of response by OP.~ Please send me a private message if you would like this thread re-opened for closure.Comment
