Okay, will do that after I make supper. And checked and it’s still stuck on that line after an hour and ten minutes.
Possible malaware issue (maybe Trojon?)
No problem, just reboot your machine and then continue on. I will leave a new set of instructions as well, you can go through them and then we will remove anything else manually with a script written for use with the FRST tool.
Adware Cleaner Scan.
[li]Close all open programs and internet browsers.[/li][li]Double click on adwcleaner.exe to run the tool.[/li][li]Click on Scan button.[/li][li]When the scan has finished click on Clean button.[/li][li]Your computer will be rebooted automatically. A text file will open after the restart.[/li][li]Please post the contents of that logfile with your next reply.[/li][li]You can find the logfile at C:\AdwCleaner[S1].txt as well.[/li][/ul]
JRT Scan.
[li]Shut down your anti-virus, anti-spyware, and firewall software now to avoid potential conflicts.[/li][li]Run the tool by double-clicking it. If you are using Windows Vista or Windows 7, right-click it and select Run as administrator.[/li][li]The tool will open and start scanning your system.[/li][li]Please be patient as this can take a while to complete depending on your system’s specifications.[/li][li]On completion, a log is saved to your desktop and will automatically open.[/li][li]Please post the JRT log.[/li][/ul]
Adware Removal Tool Scan.
[MEDIA=imgur]LOr0Gd7[/MEDIA]
Hit Ok.
[MEDIA=imgur]sYFsqHx[/MEDIA]
[MEDIA=imgur]8NcZjGc[/MEDIA]
The Program will close all open programs to complete the removal, so save any work and hit OK. Then hit OK after the removal process is complete, thenOK again to finish up. Post log generated by tool.
ZHP Scan.
Please download Zhp Cleaner to your desktop. Right Click the icon and select run as administrator.- Once you have started the program, you will need to click the scanner button.
[IMG alt="EgsT69u" width="602px" height="129px"]https://windowsinstructed.com/wp-content/uploads/2015/06/EgsT69u.png[/IMG]
3. Once the scan is completed, the you will want to click the Repair button.
[URL unfurl="true"]http://windowsinstructed.com/wp-content/uploads/2015/06/6QJjV50.png[/URL]
At the end of the process you may be asked to reboot your machine. After you reboot a report will open on your desktop.
Copy and paste the report here in your next reply.Comment
okay, did the Zemana thing first before I saw the above post. So here’s the log for that one. I will then go and do what is listed above. And post that in my next reply after this one. Zemana report:
Zemana AntiMalware 2.50.2.72 (Installed)
Scan Result : Completed
Scan Date : 2016-9-26
Operating System : Windows 10 64-bit
Processor : 8X Intel(R) Core™ i7-2600K CPU @ 3.40GHz
BIOS Mode : Legacy
CUID : 14B3A37BC959FC09D280D1
Scan Type : Deep Scan
Duration : 2m 34s
Scanned Objects : 247405
Detected Objects : 17
Excluded Objects : 0
Read Level : Normal
Auto Upload : Enabled
Detect All Extensions : Disabled
Scan Documents : Disabled
Domain Info : WORKGROUP,0,2
[HEADING=1]Detected Objects[/HEADING]
Proxy Server (User)
Status : Scanned
Object : HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings\ProxyServer
MD5 : -
Publisher : -
Version : -
Detection : Suspicious Setting
Cleaning Action : Delete
Related Objects :
Registry Entry - HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings\ProxyServer = 127.0.0.1:18159
Fake Internet Explorer Shortcut
Status : Scanned
Object : %appdata%\microsoft\windows\start menu\programs\accessories\intеrnеt ехplоrеr.lnk
MD5 : C90E9A4390E8F760A5F389B4EDA093D0
Publisher : -
Version : -
Detection : Suspicious Browser Setting
Cleaning Action : Repair
Related Objects :
Browser Setting - Fake Internet Explorer Shortcut
File - %appdata%\microsoft\windows\start menu\programs\accessories\intеrnеt ехplоrеr.lnk
Fake Firefox Shortcut
Status : Scanned
Object : %appdata%\microsoft\internet explorer\quick launch\user pinned\taskbar\моzillа firеfох.lnk
MD5 : B8D62D5537607AC5AFDC36D8A7342ED2
Publisher : -
Version : -
Related Objects :
Browser Setting - Fake Firefox Shortcut
File - %appdata%\microsoft\internet explorer\quick launch\user pinned\taskbar\моzillа firеfох.lnk
Status : Scanned
Object : %programdata%\microsoft\windows\start menu\programs\моzillа firеfох.lnk
MD5 : 4D64660B73964EE46D36B1856E65A352
Publisher : -
Version : -
Related Objects :
File - %programdata%\microsoft\windows\start menu\programs\моzillа firеfох.lnk
Firefox Search
Status : Scanned
Object : MPC Safe Search - http://search.mpc.am
MD5 : -
Publisher : -
Version : -
Related Objects :
Browser Setting - Firefox Search
Firefox Homepage
Status : Scanned
Object : %programfiles%\mozilla firefox\browser\features\googletestnt@mozillaonline.com
MD5 : -
Publisher : -
Version : -
Detection : PUA.FirefoxExt!Gr
Related Objects :
Browser Extension - Firefox Homepage
firefox.bat
Status : Scanned
Object : %programfiles%\mozilla firefox\firefox.bat
MD5 : 3DDC4925E869BB4EF925A668347A54BB
Publisher : -
Version : -
Detection : Adware:Win32/BrowserHijack.Gen
Cleaning Action : Quarantine
Related Objects :
File - %programfiles%\mozilla firefox\firefox.bat
Reference - C:\Users\garar\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Моzillа Firеfох.lnk
iexplore.bat
Status : Scanned
Object : %programfiles%\internet explorer\iexplore.bat
MD5 : 92D592EB1ECE6F66F146410A6C646331
Publisher : -
Version : -
Related Objects :
File - %programfiles%\internet explorer\iexplore.bat
Reference - C:\Users\garar\AppData\Roaming\Microsoft\Windows\S tart Menu\Programs\Accessories\Intеrnеt Ехplоrеr.lnk
Utility.dll
Status : Scanned
Object : %temp%\mpconline\utility.dll
MD5 : FAE5878FA528D5B88A39064E0DB58566
Publisher : DotCash Limited
Version : 4.3.13297.812
Detection : Adware:Win32/MPC Cleaner-DJ!Ep
Related Objects :
File - %temp%\mpconline\utility.dll
Support.dll
Status : Scanned
Object : %temp%\mpconline\support.dll
MD5 : 69C1AF45DCF2784C279DC8AB4C1917EE
Related Objects :
File - %temp%\mpconline\support.dll
Report.dll
Status : Scanned
Object : %temp%\mpconline\report.dll
MD5 : FC1A5B9B1290CE85EAEBFFBDF35856A0
Related Objects :
File - %temp%\mpconline\report.dll
MPCDownload.exe
Status : Scanned
Object : %temp%\mpconline\mpcdownload.exe
MD5 : CEBB1F7E5451DBF28AF33D73412294EC
Version : 1.0.0.1
Related Objects :
File - %temp%\mpconline\mpcdownload.exe
msvcm90.dll
Status : Scanned
Object : %temp%\mpconline\microsoft.vc90.crt\msvcm90.dll
MD5 : 581D6771D9CC7ED57F55A59CB0359F5C
Version : 9.0.21022.8
Related Objects :
File - %temp%\mpconline\microsoft.vc90.crt\msvcm90.dll
MPCOnline_393_1.exe
Status : Scanned
Object : %temp%\811e0191-eac3-47b2-ada0-8648c4fd01ed\mpconline_393_1.exe
MD5 : BC959F6725F82943B6CDEAE9AE432378
Version : 3.4.13416.830
Related Objects :
File - %temp%\811e0191-eac3-47b2-ada0-8648c4fd01ed\mpconline_393_1.exe
readme.html
Status : Scanned
Object : NE->c:\program files\bitdefender\bitdefender 2016_enhtml\readme.html
MD5 : -
Publisher : -
Version : -
Detection : Virus:Test/Eicar!Neng
Related Objects :
(null) - (null)
ff-overlay.xul
Status : Scanned
Object : NE->c:\program files (x86)\mozilla firefox\browser\features\googletestnt@mozillaonline.com\chrome\content\ff-overlay.xul
MD5 : -
Publisher : -
Version : -
Detection : Adware:Win32/StartGo123.A!Neng
Related Objects :
(null) - (null)
mpc desktop.lnk
Status : Scanned
Object : NE->c:\users\garar\appdata\roaming\microsoft\windows\ sendto\mpc desktop.lnk
MD5 : -
Publisher : -
Version : -
Detection : Adware:Win32/MPC Cleaner.C!Neng
Related Objects :
(null) - (null)
[HEADING=1]Cleaning Result[/HEADING]
Cleaned : 17
Reported as safe : 0
Failed : 0Comment
[HEADING=1]AdwCleaner v6.020 - Logfile created 26/09/2016 at 22:41:24[/HEADING]
[HEADING=1]Updated on 14/09/2016 by ToolsLib[/HEADING]
[HEADING=1]Database : 2016-09-27.1 [Server][/HEADING]
[HEADING=1]Operating System : Windows 10 Home (X64)[/HEADING]
[HEADING=1]Username : garar - DESKTOP-C5IISBO[/HEADING]
[HEADING=1]Running from : C:\Users\garar\Desktop\adwcleaner_6.020.exe[/HEADING]
[HEADING=1]Mode: Clean[/HEADING]
[HEADING=1]Support : Forum: Ask for help or share your experience. - ToolsLib[/HEADING]
***** [ Services ] *****
[-] Service deleted: MPCKpt
***** [ Folders ] *****
[-] Folder deleted: C:\Users\garar\AppData\Roaming\MCorp
[-] Folder deleted: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MPC AdCleaner
[-] Folder deleted: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MPC Desktop
[-] Folder deleted: C:\Users\garar\AppData\Local\Temp\MPC
[#] Folder deleted on reboot: C:\Users\garar\AppData\Roaming\MCorp
***** [ Files ] *****
[-] File deleted: C:\Users\garar\AppData\Local\Temp\Utils.dll
***** [ DLL ] *****
***** [ WMI ] *****
***** [ Shortcuts ] *****
***** [ Scheduled Tasks ] *****
***** [ Registry ] *****
[-] Key deleted: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uni nstall{BF0467E3-8C6F-40F1-B0B5-A75DE23C824C}_is1
[-] Key deleted: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\mpc.am
[-] Key deleted: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\piroga.space
[-] Key deleted: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\search.mpc.am
[-] Key deleted: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\DOMStorage\mpc.am
[-] Key deleted: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\DOMStorage\piroga.space
[-] Key deleted: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\DOMStorage\search.mpc.am
[#] Key deleted on reboot: [x64] HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\mpc.am
[#] Key deleted on reboot: [x64] HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\piroga.space
[#] Key deleted on reboot: [x64] HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\EdpDomStorage\search.mpc.am
[#] Key deleted on reboot: [x64] HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\DOMStorage\mpc.am
[#] Key deleted on reboot: [x64] HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\DOMStorage\piroga.space
[#] Key deleted on reboot: [x64] HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \AppContainer\Storage\microsoft.microsoftedge_8wek yb3d8bbwe\Children\001\Internet Explorer\DOMStorage\search.mpc.am
[-] Value deleted: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext [MPCInstalled]
***** [ Web browsers ] *****
:: “Tracing” keys deleted
:: Winsock settings cleared
C:\AdwCleaner\AdwCleaner[C0].txt - [4000 Bytes] - [26/09/2016 22:41:24]
C:\AdwCleaner\AdwCleaner[S0].txt - [4117 Bytes] - [26/09/2016 22:40:40]
########## EOF - C:\AdwCleaner\AdwCleaner[C0].txt - [4146 Bytes] ##########Comment
File System: 1Code:Junkware Removal Tool (JRT) by Malwarebytes Version: 8.0.8 (09.20.2016) Operating System: Windows 10 Home x64 Ran by garar (Administrator) on 2016-09-26 at 22:47:16.75
Successfully deleted: C:\ProgramData\1472864521.bdinstall.bin (File)
Registry: 0
Code:Scan was completed on 2016-09-26 at 22:48:10.68 End of JRT log
ZHP Scan
Did not reboot after repair, clicked on the repair button to view what I believe is the report. Posting report then manually rebooting PC and going to re-enable BitDefender after reboot.
~ ZHPCleaner v2016.9.26.147 by Nicolas Coolman (2016/09/26)
~ Run by garar (Administrator) (26/09/2016 23:05:03)
~ Blog: https://www.anti-malware.top
~ Facebook : ZHP
~ State version : Version OK
~ Type : Repair
~ Report : C:\Users\garar\Desktop\ZHPCleaner.txt
~ Quarantine : C:\Users\garar\AppData\Roaming\ZHP\ZHPCleaner_Quar antine.txt
~ UAC : Activate
~ Boot Mode : Normal (Normal boot)
Windows 10 Home, 64-bit (Build 10586)
—\ Services (1)
CLOSED : NetworkStat =>.Superfluous.Privoxy
—\ Browser internet (0)
~ No malicious or unnecessary items found.
—\ Hosts file (2)
REPLACED:
Number of found redirections 1/20
—\ Scheduled automatic tasks. (0)
—\ Explorer ( File, Folder) (1)
MOVED file: C:\Windows\desktop-c5iisbo_310816\oxy.exe [The Privoxy team - www.privoxy.org - Privoxy] =>.Superfluous.Privoxy
—\ Registry ( Key, Value, Data) (5)
DELETED data: HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Param eters\Interfaces{8f0b84d4-3949-4ec3-a249-d64e72d570de}\DhcpNameServer [Bad : 216.104.96.22 216.104.98.222] =>Hijacker.Browser
DELETED data: HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Param eters\DhcpNameServer [Bad : 216.104.96.22 216.104.98.222] =>Hijacker.Browser
DELETED key*: HKLM\SYSTEM\CurrentControlSet\Services\NetworkStat [C:\Windows\desktop-c5iisbo_310816\oxy.exe (Not File)] =>.Superfluous.Privoxy
DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ins taller\UserData\S-1-5-18\Components\0552123F660D94C4AA68BBC7E2FD2BFF [D:\ProgramData\Profantasy\CC3Plus\Symbols\Dungeons \Mike Schley\Wall Features\Sconce Torch lit_VL.PNG] =>.Superfluous.Torch
DELETED key*: [X64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ins taller\UserData\S-1-5-18\Components\0897E6C7B20317F4D8C7E9050306ADAC [D:\ProgramData\Profantasy\CC3Plus\Symbols\Dungeons \Mike Schley\Wall Features\Sconce Torch unlit vari_01_VH.PNG] =>.Superfluous.Torch
—\ Summary of the elements found (3)
Redirecting... =>.Superfluous.Privoxy
https://www.nicolascoolman.com/fr/hijacker-browser/ =>Hijacker.Browser
Blog - Nicolas Coolman =>.Superfluous.Torch
—\ Other deletions. (9)
~ Registry Keys Tracing deleted (9)
~ Remove the old reports ZHPCleaner. (0)
—\ Result of repair
~ Repair carried out successfully
~ Browser not found (Google Chrome)
~ Browser not found (Opera Software)
—\ Statistics
~ Items scanned : 569
~ Items found : 1
~ Items cancelled : 0
~ Items repaired : 7
~ End of clean in 00h00mn19s
ZHPCleaner-[R]-26092016-23_05_22.txt
ZHPCleaner--26092016-23_03_22.txtComment
While we’re waiting for Mal to wake up , let’s go ahead and run Malwarebytes to ensure that whatever Bitdefender missed is caught and treated.
Please download the free version of Malwarebytes HERE
Save the file to somewhere you can easily find it. Double click the saved file to start the install, accept any security warnings that may appear and after the install click the new desktop icon https://www.pchelpforum.net/attachments/mwb-jpg.481/ to start the program. We need to modify a couple of things with MalwareBytes before we use it so please follow the steps below.
[ol]
[li]If the dashboard is not already displayed select it.[/li][li]Then select “Update” to get the latest definition database.[/li][/ol]
https://www.pchelpforum.net/attachments/mwb1-jpg.482/
[ol]
[li]Next we need to change a scanning option, select “Settings” on the main menu[/li][li]Then “Detection and Protection” on the left.[/li][li]Then select “Scan for rootkits” in the detection options, as well as the other two options already checked.[/li][/ol]
https://www.pchelpforum.net/attachments/mwb2-jpg.483/
Now return to Dashboard on the main menu and select “Scan Now” at the bottom of the screen.
https://www.pchelpforum.net/attachments/mwb3-jpg.484/
Allow MalwareBytes to scan your system, it may take some time depending on how much data loaded onto your hard drive. When the scan is finished any threats will be listed for action. Ensure all threats are selected, and click “Remove Selected”
https://www.pchelpforum.net/attachments/mwb5-jpg.489/
A dialogue box may open and ask to restart the computer, if so select yes.
https://www.pchelpforum.net/attachments/mwb7cc-jpg.486/
Once the computer restarts open Malwarebytes again and select History on the menu bar, Application logs, then click the scan just completed, then click Export, choose text file. Name the text file and select a location, preferably the desktop and close Malwarebytes.
https://www.pchelpforum.net/attachments/mwb8aa-jpg.492/
Please copy and PASTE the contents of the text file in your next post
Please re-run Farbar Recovery Scan Tool to give me a fresh look at your system.
[li]Right-click on FRST icon and select Run as Administrator to start the tool.[/li](XP users click run after receipt of Windows Security Warning - Open File).
[li]Make sure that Addition option is checked.[/li][li]Press Scan button and wait.[/li][li]The tool will produce two logfiles on your desktop: FRST.txt, and Addition.txt.[/li][/ul]
Please Copy & Paste them into your next replyComment
Sorry for delay, pulled a couple double shifts.
Malwarebytes Anti-Malware
www.malwarebytes.org
Scan Date: 2016-09-28
Scan Time: 9:43 PM
Logfile: malwarebyteslog1.txt
Administrator: Yes
Version: 2.2.1.1043
Malware Database: v2016.09.28.12
Rootkit Database: v2016.09.26.02
License: Trial
Malware Protection: Enabled
Malicious Website Protection: Enabled
Self-protection: Disabled
OS: Windows 10
CPU: x64
File System: NTFS
User: garar
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 330356
Time Elapsed: 6 min, 26 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Enabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
(No malicious items detected)
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 3
PUP.Optional.MorePowerfulCleaner, C:\Users\garar\AppData\Local\Temp\MPCOnline, Quarantined, [47456a0d3e5cc37325c23692d32f5ea2],
PUP.Optional.MorePowerfulCleaner, C:\Users\garar\AppData\Local\Temp\MPCOnline\Micros oft.VC90.CRT, Quarantined, [47456a0d3e5cc37325c23692d32f5ea2],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
Files: 11
PUP.Optional.MorePowerfulCleaner, C:\Users\garar\AppData\Local\Temp\MPCOnline\Micros oft.VC90.CRT\Microsoft.VC90.CRT.manifest, Quarantined, [47456a0d3e5cc37325c23692d32f5ea2],
PUP.Optional.MorePowerfulCleaner, C:\Users\garar\AppData\Local\Temp\MPCOnline\Micros oft.VC90.CRT\msvcp90.dll, Quarantined, [47456a0d3e5cc37325c23692d32f5ea2],
PUP.Optional.MorePowerfulCleaner, C:\Users\garar\AppData\Local\Temp\MPCOnline\Micros oft.VC90.CRT\msvcr90.dll, Quarantined, [47456a0d3e5cc37325c23692d32f5ea2],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\config.txt, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\default.action, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\default.filter, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\mgwz.dll, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\oxy.log, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\unins000.dat, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\unins000.exe, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
PUP.Optional.Privoxy, C:\Windows\desktop-c5iisbo_310816\uninstall.bat, Quarantined, [e4a86314fb9fd85e8206b7f1a75d2cd4],
Physical Sectors: 0
(end)Comment
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 28-09-2016
Ran by garar (administrator) on DESKTOP-C5IISBO (28-09-2016 21:57:45)
Running from C:\Users\garar\Desktop
Loaded Profiles: garar (Available Profiles: garar)
Platform: Windows 10 Home Version 1511 (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser: FF)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic...ery-scan-tool/
(Bitdefender) C:\Program Files\Bitdefender\Bitdefender 2016\vsserv.exe
(NVIDIA Corporation) C:\Windows\System32\nvvsvc.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvscpapisvr.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
(Adobe Systems, Incorporated) C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe
() C:\Program Files (x86)\ASUS\AXSP\1.00.18\atkexComSvc.exe
(Micro-Star Int’l Co., Ltd.) C:\Program Files (x86)\MSI\Gaming APP\GamingApp_Service.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe
(Micro-Star INT’L CO., LTD.) C:\Program Files (x86)\MSI\Gaming APP\GamingHotkey_Service.exe
(ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\AAHM\1.00.16\aaHMSvc.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.ex e
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
(Micro-Star INT’L CO., LTD.) C:\Program Files (x86)\MSI\MSI OC Kit\ActiveX_Service\MSI_ActiveX_Service.exe
() C:\Program Files (x86)\Razer\Razer Services\GSS\GameScannerService.exe
(Bitdefender) C:\Program Files\Bitdefender Agent\ProductAgentService.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe
(TorrentsTime) C:\Program Files (x86)\TorrentsTime Media Player\bin\TTService.exe
(Malwarebytes) D:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe
(Malwarebytes) D:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe
(Bitdefender) C:\Program Files\Bitdefender\Bitdefender 2016\updatesrv.exe
(Zemana Ltd.) C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe
(Microsoft Corporation) C:\Windows\syswow64\wbem\WmiPrvSE.exe
(Malwarebytes) D:\Program Files (x86)\Malwarebytes Anti-Malware\mbam.exe
(Micro-Star INT’L CO., LTD.) C:\Program Files (x86)\MSI\Gaming APP\OSD\x64\MsiGamingOSD_x64.exe
(Micro-Star INT’L CO., LTD.) C:\Program Files (x86)\MSI\Gaming APP\OSD\x86\MsiGamingOSD_x86.exe
(MSI) C:\Windows\syswow64\muachost.exe
() C:\Program Files\WindowsApps\Microsoft.Messaging_2.15.20002.0 _x86__8wekyb3d8bbwe\SkypeHost.exe
(Microsoft Corporation) C:\Windows\System32\runonce.exe
(Microsoft Corporation) C:\Windows\syswow64\runonce.exe
(Malwarebytes) C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\mbamdor.exe
(Microsoft Corporation) C:\Windows\System32\cmd.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
(Microsoft Corporation) C:\Windows\System32\SettingSyncHost.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\LCore.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\Applets\LCDMedia.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\Applets\LCDCountdown.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\Applets\LCDClock.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\Applets\LCDPOP3.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\Applets\LCDRSS.exe
(Adobe Systems, Incorporated) C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AdobeGCClient.exe
(Valve Corporation) D:\Program Files (x86)\Steam\Steam.exe
(Overwolf LTD) C:\Program Files (x86)\Overwolf\Overwolf.exe
(Hammer & Chisel, Inc.) C:\Users\garar\AppData\Local\Discord\app-0.0.296\Discord.exe
(Razer Inc.) C:\Program Files (x86)\Razer\Synapse\RzSynapse.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\AdobeIPCBroker.exe
(Valve Corporation) D:\Program Files (x86)\Steam\bin\steamwebhelper.exe
(Valve Corporation) C:\Program Files (x86)\Common Files\Steam\SteamService.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\HEX\Adobe CEF Helper.exe
() C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\CoreSync.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\CCXProcess.exe
(Node.js) C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\libs\node.exe
(Overwolf LTD) C:\Program Files (x86)\Overwolf\0.98.16.0\OverwolfBrowser.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\CCLibrary.exe
(Node.js) C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\node.exe
(Mozilla Corporation) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
(Adobe Systems, Inc.) C:\Windows\syswow64\Macromed\Flash\FlashPlayerPlug in_23_0_0_162.exe
(Bitdefender) C:\Program Files\Bitdefender\Bitdefender 2016\bdagent.exe
(Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ink\InputPersonalization.exe
(Microsoft Corporation) C:\Windows\System32\wbem\WMIADAP.exe
==================== Registry (Whitelisted) ====================
HKLM...\Run: [RtHDVCpl] => C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe [11545192 2010-11-02] (Realtek Semiconductor)
HKLM...\Run: [NvBackend] => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe [2397120 2016-06-14] (NVIDIA Corporation)
HKLM...\Run: [ShadowPlay] => C:\WINDOWS\system32\nvspcap64.dll [1767944 2016-06-14] (NVIDIA Corporation)
HKLM...\Run: [Launch LCore] => C:\Program Files\Logitech Gaming Software\LCore.exe [16286840 2016-08-29] (Logitech Inc.)
HKLM...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [508128 2016-07-01] (Adobe Systems Incorporated)
HKLM...\Run: [ZAM] => C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [13732592 2016-09-26] (Zemana Ltd.)
HKLM-x32...\Run: =>
HKLM-x32...\Run: [Razer Synapse] => C:\Program Files (x86)\Razer\Synapse\RzSynapse.exe [596640 2016-08-10] (Razer Inc.)
HKLM-x32...\Run: [Adobe Creative Cloud] => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe [2383040 2016-08-24] (Adobe Systems Incorporated)
HKLM-x32...\Run: [Discord] => C:\ProgramData\SquirrelMachineInstalls\Discord.exe [50343608 2016-09-06] (Hammer & Chisel, Inc.)
HKU\S-1-5-21-1963327732-3332141323-2774556287-1001...\Run: [Steam] => D:\Program Files (x86)\Steam\steam.exe [2858272 2016-09-20] (Valve Corporation)
HKU\S-1-5-21-1963327732-3332141323-2774556287-1001...\Run: [Overwolf] => C:\Program Files (x86)\Overwolf\OverwolfLauncher.exe [247344 2016-09-15] ()
HKU\S-1-5-21-1963327732-3332141323-2774556287-1001...\Run: [Discord] => C:\Users\garar\AppData\Local\Discord\app-0.0.296\Discord.exe [62471352 2016-08-24] (Hammer & Chisel, Inc.)
ShellIconOverlayIdentifiers: [ AccExtIco1] → {AB9CF9F8-8A96-4F9D-BF21-CE85714C3A47} => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSyncExtension\CoreSync_x64.dll [2016-05-22] ()
ShellIconOverlayIdentifiers: [ AccExtIco2] → {853B7E05-C47D-4985-909A-D0DC5C6D7303} => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSyncExtension\CoreSync_x64.dll [2016-05-22] ()
ShellIconOverlayIdentifiers: [ AccExtIco3] → {42D38F2E-98E9-4382-B546-E24E4D6D04BB} => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSyncExtension\CoreSync_x64.dll [2016-05-22] ()
Tcpip\Parameters: [DhcpNameServer] 216.104.96.22 216.104.98.222
Tcpip..\Interfaces{8f0b84d4-3949-4ec3-a249-d64e72d570de}: [DhcpNameServer] 216.104.96.22 216.104.98.222
ManualProxies:
[HEADING=1]Internet Explorer:[/HEADING]
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL =
HKU\S-1-5-21-1963327732-3332141323-2774556287-1001\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
SearchScopes: HKU\S-1-5-21-1963327732-3332141323-2774556287-1001 → {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
[HEADING=1]FireFox:[/HEADING]
FF ProfilePath: C:\Users\garar\AppData\Roaming\Mozilla\Firefox\Pro files\xgk0okdu.default
FF Homepage: about:newtab
FF Plugin: @adobe.com/FlashPlayer → C:\WINDOWS\system32\Macromed\Flash\NPSWF64_23_0_0_ 162.dll [2016-09-13] ()
FF Plugin: adobe.com/AdobeAAMDetect → C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\npAdobeAAMDetect64.dll [2016-08-24] (Adobe Systems)
FF Plugin-x32: @adobe.com/FlashPlayer → C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_23_0_0_ 162.dll [2016-09-13] ()
FF Plugin-x32: @nvidia.com/3DVision → C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dv.dll [2016-07-10] (NVIDIA Corporation)
FF Plugin-x32: @nvidia.com/3DVisionStreaming → C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dvstreaming.dll [2016-07-10] (NVIDIA Corporation)
FF Plugin-x32: Adobe Reader → C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2016-06-30] (Adobe Systems Inc.)
FF Plugin-x32: adobe.com/AdobeAAMDetect → C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\npAdobeAAMDetect32.dll [2016-08-24] (Adobe Systems)
FF Plugin HKU\S-1-5-21-1963327732-3332141323-2774556287-1001: torrents-time.com/TTPlugin → C:\Program Files (x86)\TorrentsTime Media Player\bin\npTTPlugin.dll [2016-02-25] (Torrents Time)
FF Extension: (Firefox Hotfix) - C:\Users\garar\AppData\Roaming\Mozilla\Firefox\Pro files\xgk0okdu.default\Extensions\firefox-hotfix@mozilla.org.xpi [2016-09-08]
FF Extension: (Adblock Plus) - C:\Users\garar\AppData\Roaming\Mozilla\Firefox\Pro files\xgk0okdu.default\Extensions{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}.xpi [2016-09-02]
FF HKLM...\Thunderbird\Extensions: [bdThunderbird@bitdefender.com] - C:\Program Files\Bitdefender\Bitdefender 2016\bdtbext
FF Extension: (Bitdefender Antispam Toolbar) - C:\Program Files\Bitdefender\Bitdefender 2016\bdtbext [2016-06-27] [not signed]
FF HKLM-x32...\Thunderbird\Extensions: [bdThunderbird@bitdefender.com] - C:\Program Files\Bitdefender\Bitdefender 2016\bdtbext
R2 AdobeUpdateService; C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe [744640 2016-08-24] (Adobe Systems Incorporated)
R2 AGSService; C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe [2159320 2016-08-22] (Adobe Systems, Incorporated)
R2 asComSvc; C:\Program Files (x86)\ASUS\AXSP\1.00.18\atkexComSvc.exe [918448 2011-10-29] () [File not signed]
R2 asHmComSvc; C:\Program Files (x86)\ASUS\AAHM\1.00.16\aaHMSvc.exe [947328 2011-08-09] (ASUSTeK Computer Inc.)
R2 GamingApp_Service; C:\Program Files (x86)\MSI\Gaming APP\GamingApp_Service.exe [45008 2016-08-25] (Micro-Star Int’l Co., Ltd.)
R2 GamingHotkey_Service; C:\Program Files (x86)\MSI\Gaming APP\GamingHotkey_Service.exe [2019792 2016-05-16] (Micro-Star INT’L CO., LTD.)
R2 GfExperienceService; C:\Program Files\NVIDIA Corporation\GeForce Experience Service\GfExperienceService.exe [1163712 2016-06-14] (NVIDIA Corporation)
R2 LogiRegistryService; C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.ex e [193656 2016-08-29] (Logitech Inc.)
R2 MBAMScheduler; D:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe [1514464 2016-03-10] (Malwarebytes)
R2 MBAMService; D:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe [1136608 2016-03-10] (Malwarebytes)
R2 MSI_ActiveX_Service; C:\Program Files (x86)\MSI\MSI OC Kit\ActiveX_Service\MSI_ActiveX_Service.exe [58296 2016-08-12] (Micro-Star INT’L CO., LTD.)
R2 NvNetworkService; C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe [1879488 2016-06-14] (NVIDIA Corporation)
S3 NvStreamNetworkSvc; C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe [3632576 2016-06-14] (NVIDIA Corporation)
S2 NvStreamSvc; C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamService.exe [2521024 2016-06-14] (NVIDIA Corporation)
S3 OverwolfUpdater; C:\Program Files (x86)\Overwolf\OverwolfUpdater.exe [1310448 2016-09-15] (Overwolf LTD)
R2 ProductAgentService; C:\Program Files\Bitdefender Agent\ProductAgentService.exe [1088944 2016-09-13] (Bitdefender)
R2 Razer Game Scanner Service; C:\Program Files (x86)\Razer\Razer Services\GSS\GameScannerService.exe [188072 2015-11-04] ()
R2 TTService; C:\Program Files (x86)\TorrentsTime Media Player\bin\TTService.exe [3312152 2016-03-02] (TorrentsTime)
R2 UPDATESRV; C:\Program Files\Bitdefender\Bitdefender 2016\updatesrv.exe [156016 2016-06-16] (Bitdefender)
S3 vmicvss; C:\Windows\System32\ICSvc.dll [511488 2016-09-07] (Microsoft Corporation)
R2 VSSERV; C:\Program Files\Bitdefender\Bitdefender 2016\vsserv.exe [1693104 2016-06-24] (Bitdefender)
S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [364456 2016-09-07] (Microsoft Corporation)
S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [24864 2016-09-07] (Microsoft Corporation)
R2 ZAMSvc; C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [13732592 2016-09-26] (Zemana Ltd.)
R3 Alpham1; C:\Windows\System32\drivers\Alpham164.sys [52992 2007-07-23] (Ideazon Corporation)
R3 Alpham2; C:\Windows\System32\drivers\Alpham264.sys [21760 2007-03-20] (Ideazon Corporation)
R1 AsIO; C:\Windows\SysWow64\drivers\AsIO.sys [13440 2010-08-24] ()
R0 avc3; C:\Windows\System32\DRIVERS\avc3.sys [1603264 2016-09-02] (BitDefender)
R3 avckf; C:\Windows\System32\DRIVERS\avckf.sys [850464 2016-09-02] (BitDefender)
S0 bdelam; C:\Windows\System32\drivers\bdelam.sys [23568 2013-09-08] (Bitdefender)
R1 bdfwfpf; C:\Program Files\Common Files\Bitdefender\Bitdefender Firewall\bdfwfpf.sys [128400 2016-06-24] (BitDefender LLC)
S4 BDVEDISK; C:\Windows\system32\DRIVERS\bdvedisk.sys [87912 2015-12-04] (BitDefender)
R0 gzflt; C:\Windows\System32\DRIVERS\gzflt.sys [182936 2015-12-16] (BitDefender LLC)
R3 I2cHkBurn; C:\Windows\system32\drivers\I2cHkBurn.sys [41760 2015-07-27] (FINTEK Corp.)
S3 IAMTVE; C:\Windows\System32\drivers\IAMTVE.sys [43416 2007-04-11] (Intel Corporation)
R0 ignis; C:\Windows\system32\DRIVERS\ignis.sys [299816 2016-06-16] (Bitdefender)
R2 LGCoreTemp; C:\Program Files\Logitech Gaming Software\Drivers\LgCoreTemp\lgcoretemp.sys [14184 2015-06-21] (Logitech)
R3 LGJoyXlCore; C:\Windows\system32\drivers\LGJoyXlCore.sys [67736 2016-08-29] (Logitech Inc.)
S3 LGSHidFilt; C:\Windows\System32\drivers\LGSHidFilt.Sys [64280 2013-05-30] (Logitech Inc.)
R3 MBAMProtector; C:\WINDOWS\system32\drivers\mbam.sys [27008 2016-03-10] (Malwarebytes)
R3 MBAMSwissArmy; C:\WINDOWS\system32\drivers\MBAMSwissArmy.sys [192216 2016-09-28] (Malwarebytes)
R3 MBAMWebAccessControl; C:\WINDOWS\system32\drivers\mwac.sys [65408 2016-03-10] (Malwarebytes Corporation)
S3 NvStreamKms; C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamKms.sys [26560 2016-06-14] (NVIDIA Corporation)
R3 nvvad_WaveExtensible; C:\Windows\system32\drivers\nvvad64v.sys [56384 2016-04-14] (NVIDIA Corporation)
R3 rt640x64; C:\Windows\System32\drivers\rt640x64.sys [589824 2015-10-30] (Realtek )
R2 rzpmgrk; C:\WINDOWS\system32\drivers\rzpmgrk.sys [37184 2015-09-22] (Razer, Inc.)
R2 rzpnk; C:\WINDOWS\system32\drivers\rzpnk.sys [130880 2015-12-14] (Razer, Inc.)
R0 trufos; C:\Windows\System32\DRIVERS\trufos.sys [520032 2016-03-10] (BitDefender S.R.L.)
R3 UHSfiltv; C:\Windows\system32\drivers\UHSfiltv.sys [32264 2015-07-22] (Creative Technology Ltd.)
S3 WdBoot; C:\Windows\system32\drivers\WdBoot.sys [44568 2015-10-30] (Microsoft Corporation)
S3 WdFilter; C:\Windows\system32\drivers\WdFilter.sys [293216 2015-10-30] (Microsoft Corporation)
S3 WdNisDrv; C:\Windows\System32\Drivers\WdNisDrv.sys [118112 2015-10-30] (Microsoft Corporation)
R1 ZAM; C:\WINDOWS\System32\drivers\zam64.sys [203680 2016-09-26] (Zemana Ltd.)
R1 ZAM_Guard; C:\WINDOWS\System32\drivers\zamguard64.sys [203680 2016-09-26] (Zemana Ltd.)
2016-09-28 21:57 - 2016-09-28 22:00 - 00018441 _____ C:\Users\garar\Desktop\FRST.txt
2016-09-28 21:57 - 2016-09-28 21:57 - 00000000 ____D C:\Users\garar\Desktop\FRST-OlderVersion
2016-09-28 21:55 - 2016-09-28 21:55 - 00002836 _____ C:\Users\garar\Desktop\malwarebyteslog1.txt
2016-09-28 21:52 - 2016-09-28 21:52 - 00000000 ___HD C:\OneDriveTemp
2016-09-28 21:41 - 2016-09-28 21:52 - 00192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
2016-09-28 21:40 - 2016-09-28 21:40 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Malware
2016-09-28 21:40 - 2016-09-28 21:40 - 00000000 ____D C:\ProgramData\Malwarebytes
2016-09-28 21:40 - 2016-03-10 14:09 - 00065408 _____ (Malwarebytes Corporation) C:\WINDOWS\system32\Drivers\mwac.sys
2016-09-28 21:40 - 2016-03-10 14:08 - 00140672 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbamchameleon.sys
2016-09-28 21:40 - 2016-03-10 14:08 - 00027008 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbam.sys
2016-09-28 21:39 - 2016-09-28 21:39 - 22851472 _____ (Malwarebytes ) C:\Users\garar\Downloads\mbam-setup-2.2.1.1043.exe
2016-09-26 23:03 - 2016-09-26 23:05 - 00002824 _____ C:\Users\garar\Desktop\ZHPCleaner.txt
2016-09-26 22:59 - 2016-09-26 23:05 - 00000000 ____D C:\Users\garar\AppData\Roaming\ZHP
2016-09-26 22:59 - 2016-09-26 22:59 - 00000875 _____ C:\Users\garar\Desktop\ZHPCleaner.lnk
2016-09-26 22:58 - 2016-09-26 22:59 - 02416128 _____ C:\Users\garar\Desktop\ZHPCleaner.exe
2016-09-26 22:50 - 2016-09-26 22:50 - 00290304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\subinacl.exe
2016-09-26 22:50 - 2016-09-26 22:50 - 00000000 ____D C:\Program Files (x86)\Adware Removal Tool by TSA
2016-09-26 22:49 - 2016-09-26 22:49 - 00752296 _____ C:\Users\garar\Desktop\Adware Removal Tool by TSA.exe
2016-09-26 22:48 - 2016-09-26 22:48 - 00000618 _____ C:\Users\garar\Desktop\JRT.txt
2016-09-26 22:45 - 2016-09-26 22:46 - 01615456 _____ (Malwarebytes) C:\Users\garar\Desktop\JRT.exe
2016-09-26 22:39 - 2016-09-26 22:41 - 00000000 ____D C:\AdwCleaner
2016-09-26 22:13 - 2016-09-26 22:39 - 03861056 _____ C:\Users\garar\Desktop\adwcleaner_6.020.exe
2016-09-26 21:57 - 2016-09-28 21:58 - 00069529 _____ C:\WINDOWS\ZAM.krnl.trace
2016-09-26 21:57 - 2016-09-28 21:58 - 00034613 _____ C:\WINDOWS\ZAM_Guard.krnl.trace
2016-09-26 21:57 - 2016-09-26 21:57 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zamguard64.sys
2016-09-26 21:57 - 2016-09-26 21:57 - 00203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zam64.sys
2016-09-26 21:57 - 2016-09-26 21:57 - 00001221 _____ C:\Users\Public\Desktop\Zemana AntiMalware.lnk
2016-09-26 21:57 - 2016-09-26 21:57 - 00000000 ____D C:\Users\garar\AppData\Local\Zemana
2016-09-26 21:57 - 2016-09-26 21:57 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware
2016-09-26 21:57 - 2016-09-26 21:57 - 00000000 ____D C:\Program Files (x86)\Zemana AntiMalware
2016-09-26 21:56 - 2016-09-26 21:57 - 05310648 _____ ( ) C:\Users\garar\Downloads\Zemana.AntiMalware.Setup. exe
2016-09-26 20:06 - 2016-09-26 20:06 - 00000000 ____D C:\Users\garar\AppData\Local\ActiveSync
2016-09-26 20:05 - 2016-09-26 20:06 - 00000000 ____D C:\Users\garar\AppData\Roaming\discord
2016-09-26 20:05 - 2016-09-26 20:05 - 00000000 ____D C:\Users\garar\AppData\Local\VirtualStore
2016-09-26 16:40 - 2016-09-26 16:40 - 00000000 ____D C:\zoek
2016-09-26 16:22 - 2016-09-26 16:42 - 00002983 _____ C:\runcheck.txt
2016-09-26 16:22 - 2016-09-26 16:42 - 00000000 ____D C:\zoek_backup
2016-09-26 16:20 - 2016-09-26 16:22 - 01309184 _____ C:\Users\garar\Desktop\zoek.exe
2016-09-25 20:42 - 2016-09-25 20:42 - 00000512 _____ C:\Users\garar\Desktop\MBR.dat
2016-09-25 20:40 - 2016-09-25 20:42 - 00003930 _____ C:\Users\garar\Desktop\aswMBR.txt
2016-09-25 20:39 - 2016-09-25 20:39 - 05200384 _____ (AVAST Software) C:\Users\garar\Downloads\aswmbr.exe
2016-09-25 20:23 - 2016-09-25 20:24 - 00037316 _____ C:\Users\garar\Downloads\Addition.txt
2016-09-25 20:22 - 2016-09-28 21:57 - 00000000 ____D C:\FRST
2016-09-25 20:22 - 2016-09-25 20:24 - 00184457 _____ C:\Users\garar\Downloads\FRST.txt
2016-09-25 20:21 - 2016-09-28 21:57 - 02404352 _____ (Farbar) C:\Users\garar\Desktop\FRST64.exe
2016-09-19 21:36 - 2016-09-19 21:36 - 00026837 _____ C:\ProgramData\agent.1474335373.bdinstall.bin
2016-09-19 18:00 - 2016-09-19 18:00 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsigne2575cf367 850c79
2016-09-19 17:59 - 2016-09-19 17:59 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignb4e41b1902 82c97d
2016-09-19 17:59 - 2016-09-19 17:59 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign758003a20a a1c633
2016-09-19 17:59 - 2016-09-19 17:59 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign491f379cf2 187421
2016-09-19 17:59 - 2016-09-19 17:59 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign2f5562a456 dca9ea
2016-09-19 17:59 - 2016-09-19 17:59 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign0906545ef3 d2ccd4
2016-09-15 22:04 - 2016-09-15 22:04 - 00000000 ____D C:\Users\garar\AppData\Temp
2016-09-15 20:13 - 2016-09-15 20:13 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign828a5b88b8 34b3ed
2016-09-15 20:13 - 2016-09-15 20:13 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign7e0caaa4ff d45751
2016-09-15 19:52 - 2016-09-23 00:07 - 00000000 ____D C:\Users\garar\AppData\Roaming\TS3Client
2016-09-15 19:52 - 2016-09-15 19:52 - 00000871 _____ C:\Users\Public\Desktop\TeamSpeak 3 Client.lnk
2016-09-15 19:52 - 2016-09-15 19:52 - 00000821 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamSpeak 3 Client.lnk
2016-09-15 19:44 - 2016-09-15 19:48 - 32019840 _____ (TeamSpeak Systems GmbH) C:\Users\garar\Downloads\TeamSpeak3-Client-win64-3.0.19.4.exe
2016-09-13 23:45 - 2016-09-13 23:45 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign4161003068 ac4071
2016-09-13 23:45 - 2016-09-13 23:45 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign2fdcefa3f1 52120f
2016-09-13 21:43 - 2016-09-13 21:43 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign89d28bea2e 1b652e
2016-09-13 21:42 - 2016-09-13 21:42 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign8ee6a04b30 5059b6
2016-09-13 21:42 - 2016-09-13 21:42 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign7730159777 d0a10a
2016-09-13 21:42 - 2016-09-13 21:42 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign48e8adcdb1 b5ddf3
2016-09-13 21:42 - 2016-09-13 21:42 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign1ac8100fe2 1f71a4
2016-09-13 21:42 - 2016-09-13 21:42 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign19f79e399d 5f52cb
2016-09-13 18:54 - 2016-09-07 01:39 - 02656952 _____ C:\WINDOWS\system32\CoreUIComponents.dll
2016-09-13 18:54 - 2016-09-07 01:39 - 01098640 _____ (Microsoft Corporation) C:\WINDOWS\system32\MrmCoreR.dll
2016-09-13 18:54 - 2016-09-07 01:26 - 02544256 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2016-09-13 18:54 - 2016-09-07 01:26 - 01299504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfnetsrc.dll
2016-09-13 18:54 - 2016-09-07 01:26 - 01152320 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfasfsrcsnk.dll
2016-09-13 18:54 - 2016-09-07 01:26 - 00588320 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmdrmdev.dll
2016-09-13 18:54 - 2016-09-07 01:25 - 02607336 _____ (Microsoft Corporation) C:\WINDOWS\system32\combase.dll
2016-09-13 18:54 - 2016-09-07 01:23 - 01750440 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcMon.exe
2016-09-13 18:54 - 2016-09-07 01:19 - 00294752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msv1_0.dll
2016-09-13 18:54 - 2016-09-07 00:48 - 22379520 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2016-09-13 18:54 - 2016-09-07 00:43 - 16985600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
2016-09-13 18:54 - 2016-09-07 00:39 - 01567744 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Globalization.dll
2016-09-13 18:54 - 2016-09-07 00:35 - 24611840 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2016-09-13 18:54 - 2016-09-07 00:35 - 00383488 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
2016-09-13 18:54 - 2016-09-07 00:32 - 00581632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\apphelp.dll
2016-09-13 18:54 - 2016-09-07 00:31 - 00794624 _____ (Microsoft Corporation) C:\WINDOWS\system32\winhttp.dll
2016-09-13 18:54 - 2016-09-07 00:31 - 00610304 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmdrmsdk.dll
2016-09-13 18:54 - 2016-09-07 00:31 - 00335872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
2016-09-13 18:54 - 2016-09-07 00:30 - 18676224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2016-09-13 18:54 - 2016-09-07 00:30 - 02127360 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
2016-09-13 18:54 - 2016-09-07 00:30 - 01707520 _____ (Microsoft Corporation) C:\WINDOWS\system32\msdtctm.dll
2016-09-13 18:54 - 2016-09-07 00:30 - 00904704 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcss.dll
2016-09-13 18:54 - 2016-09-07 00:30 - 00784384 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
2016-09-13 18:54 - 2016-09-07 00:30 - 00602624 _____ (Microsoft Corporation) C:\WINDOWS\system32\vbscript.dll
2016-09-13 18:54 - 2016-09-07 00:29 - 19350016 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2016-09-13 18:54 - 2016-09-07 00:28 - 00938496 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchIndexer.exe
2016-09-13 18:54 - 2016-09-07 00:27 - 01743872 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtsvc.dll
2016-09-13 18:54 - 2016-09-07 00:27 - 00963072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsp_health.dll
2016-09-13 18:54 - 2016-09-07 00:27 - 00552960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppointmentApis.dll
2016-09-13 18:54 - 2016-09-07 00:26 - 13392384 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
2016-09-13 18:54 - 2016-09-07 00:26 - 02050048 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
2016-09-13 18:54 - 2016-09-07 00:26 - 01508352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winmsipc.dll
2016-09-13 18:54 - 2016-09-07 00:26 - 00687616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
2016-09-13 18:54 - 2016-09-07 00:25 - 01526272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
2016-09-13 18:54 - 2016-09-07 00:25 - 01166848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Pimstore.dll
2016-09-13 18:54 - 2016-09-07 00:25 - 00769536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ContactApis.dll
2016-09-13 18:54 - 2016-09-07 00:24 - 03428864 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
2016-09-13 18:54 - 2016-09-07 00:23 - 00980480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winipcsecproc.dll
2016-09-13 18:54 - 2016-09-07 00:23 - 00701952 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinapi.dll
2016-09-13 18:54 - 2016-09-07 00:22 - 12134400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
2016-09-13 18:54 - 2016-09-07 00:22 - 02582016 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
2016-09-13 18:54 - 2016-09-07 00:21 - 03046400 _____ (Microsoft Corporation) C:\WINDOWS\system32\xpsservices.dll
2016-09-13 18:54 - 2016-09-07 00:21 - 01797120 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
2016-09-13 18:54 - 2016-09-07 00:20 - 02352128 _____ (Microsoft Corporation) C:\WINDOWS\system32\authui.dll
2016-09-13 18:54 - 2016-09-07 00:19 - 03663360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
2016-09-13 18:54 - 2016-09-07 00:19 - 02102272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xpsservices.dll
2016-09-13 18:54 - 2016-09-07 00:18 - 03577344 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
2016-09-13 18:54 - 2016-09-07 00:18 - 02876928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Wpc.dll
2016-09-13 18:54 - 2016-09-07 00:17 - 02285568 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcWebSync.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 04412928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 03671040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msi.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 02911744 _____ (Microsoft Corporation) C:\WINDOWS\system32\CertEnroll.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 02746368 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 02597888 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssrch.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 02280960 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 02217984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Wpc.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 01676800 _____ (Microsoft Corporation) C:\WINDOWS\system32\XpsPrint.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 01194496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Phone.dll
2016-09-13 18:54 - 2016-09-07 00:16 - 01123328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XpsPrint.dll
2016-09-13 18:54 - 2016-09-07 00:15 - 07831552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2016-09-13 18:54 - 2016-09-07 00:15 - 05659136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2016-09-13 18:54 - 2016-09-07 00:15 - 02604032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CertEnroll.dll
2016-09-13 18:54 - 2016-09-07 00:15 - 02055168 _____ (Microsoft Corporation) C:\WINDOWS\system32\OpcServices.dll
2016-09-13 18:54 - 2016-09-07 00:15 - 00416256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hnetcfg.dll
2016-09-13 18:54 - 2016-09-07 00:14 - 06743040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstscax.dll
2016-09-13 18:54 - 2016-09-07 00:14 - 04895232 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
2016-09-13 18:54 - 2016-09-07 00:14 - 01946112 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmcore.dll
2016-09-13 18:54 - 2016-09-07 00:13 - 04171264 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcorets.dll
2016-09-13 18:54 - 2016-09-07 00:13 - 02874880 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcndmgr.dll
2016-09-13 18:54 - 2016-09-07 00:11 - 03065344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstsc.exe
2016-09-13 18:53 - 2016-09-07 01:39 - 01317640 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2016-09-13 18:53 - 2016-09-07 01:39 - 01142560 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2016-09-13 18:53 - 2016-09-07 01:39 - 01030408 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2016-09-13 18:53 - 2016-09-07 01:39 - 00875480 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2016-09-13 18:53 - 2016-09-07 01:39 - 00845568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MrmCoreR.dll
2016-09-13 18:53 - 2016-09-07 01:39 - 00754664 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
2016-09-13 18:53 - 2016-09-07 01:39 - 00620176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kernel32.dll
2016-09-13 18:53 - 2016-09-07 01:39 - 00277848 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdbus.sys
2016-09-13 18:53 - 2016-09-07 01:39 - 00175120 _____ (Microsoft Corporation) C:\WINDOWS\system32\sspicli.dll
2016-09-13 18:53 - 2016-09-07 01:37 - 00572272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\taskschd.dll
2016-09-13 18:53 - 2016-09-07 01:37 - 00129888 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ksecdd.sys
2016-09-13 18:53 - 2016-09-07 01:36 - 00405856 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\FWPKCLNT.SYS
2016-09-13 18:53 - 2016-09-07 01:34 - 02587696 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml6.dll
2016-09-13 18:53 - 2016-09-07 01:33 - 01297760 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicenseManager.dll
2016-09-13 18:53 - 2016-09-07 01:33 - 00986976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LicenseManager.dll
2016-09-13 18:53 - 2016-09-07 01:33 - 00026408 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuauclt.exe
2016-09-13 18:53 - 2016-09-07 01:27 - 00538632 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWanAPI.dll
2016-09-13 18:53 - 2016-09-07 01:27 - 00413536 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifitask.exe
2016-09-13 18:53 - 2016-09-07 01:26 - 01092464 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfplat.dll
2016-09-13 18:53 - 2016-09-07 01:26 - 00858952 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfnetcore.dll
2016-09-13 18:53 - 2016-09-07 01:26 - 00847648 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsvr.dll
2016-09-13 18:53 - 2016-09-07 01:26 - 00785088 _____ (Microsoft Corporation) C:\WINDOWS\system32\evr.dll
2016-09-13 18:53 - 2016-09-07 01:26 - 00586200 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf.dll
2016-09-13 18:53 - 2016-09-07 01:26 - 00245840 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
2016-09-13 18:53 - 2016-09-07 01:26 - 00131424 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ufxsynopsys.sys
2016-09-13 18:53 - 2016-09-07 01:25 - 01447776 _____ (Microsoft Corporation) C:\WINDOWS\system32\webservices.dll
2016-09-13 18:53 - 2016-09-07 01:25 - 01322248 _____ (Microsoft Corporation) C:\WINDOWS\system32\ole32.dll
2016-09-13 18:53 - 2016-09-07 01:25 - 01270064 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinTypes.dll
2016-09-13 18:53 - 2016-09-07 01:24 - 03693064 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
2016-09-13 18:53 - 2016-09-07 01:24 - 01349632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winmde.dll
2016-09-13 18:53 - 2016-09-07 01:24 - 00808288 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWAHost.exe
2016-09-13 18:53 - 2016-09-07 01:24 - 00511312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf.dll
2016-09-13 18:53 - 2016-09-07 01:24 - 00501600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\NetSetupEngine.dll
2016-09-13 18:53 - 2016-09-07 01:24 - 00496360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmdrmdev.dll
2016-09-13 18:53 - 2016-09-07 01:24 - 00355672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netcfgx.dll
2016-09-13 18:53 - 2016-09-07 01:23 - 22561256 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2016-09-13 18:53 - 2016-09-07 01:23 - 06605544 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2016-09-13 18:53 - 2016-09-07 01:23 - 06536248 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppsvc.exe
2016-09-13 18:53 - 2016-09-07 01:23 - 01603224 _____ (Microsoft Corporation) C:\WINDOWS\system32\propsys.dll
2016-09-13 18:53 - 2016-09-07 01:23 - 01040792 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinapi.appcore.dll
2016-09-13 18:53 - 2016-09-07 01:23 - 00725776 _____ (Microsoft Corporation) C:\WINDOWS\system32\SHCore.dll
2016-09-13 18:53 - 2016-09-07 01:22 - 02937384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
2016-09-13 18:53 - 2016-09-07 01:22 - 01128096 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipUp.exe
2016-09-13 18:53 - 2016-09-07 01:22 - 01085728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webservices.dll
2016-09-13 18:53 - 2016-09-07 01:22 - 00604920 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cng.sys
2016-09-13 18:53 - 2016-09-07 01:21 - 00465760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncHost.exe
2016-09-13 18:53 - 2016-09-07 01:20 - 01355336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\propsys.dll
2016-09-13 18:53 - 2016-09-07 01:20 - 00569744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SHCore.dll
2016-09-13 18:53 - 2016-09-07 01:15 - 00911640 _____ (Microsoft Corporation) C:\WINDOWS\system32\dcomp.dll
2016-09-13 18:53 - 2016-09-07 01:13 - 01865584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d9.dll
2016-09-13 18:53 - 2016-09-07 01:12 - 02195632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d10warp.dll
2016-09-13 18:53 - 2016-09-07 01:12 - 01522152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WindowsCodecs.dll
2016-09-13 18:53 - 2016-09-07 01:12 - 01174008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msctf.dll
2016-09-13 18:53 - 2016-09-07 01:11 - 00057912 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsass.exe
2016-09-13 18:53 - 2016-09-07 01:08 - 00116216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sspicli.dll
2016-09-13 18:53 - 2016-09-07 01:07 - 01951848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hevcdecoder.dll
2016-09-13 18:53 - 2016-09-07 00:52 - 01035776 _____ (Microsoft Corporation) C:\WINDOWS\system32\XboxNetApiSvc.dll
2016-09-13 18:53 - 2016-09-07 00:52 - 00084480 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
2016-09-13 18:53 - 2016-09-07 00:49 - 00649216 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcsvc.dll
2016-09-13 18:53 - 2016-09-07 00:48 - 00957952 _____ (Microsoft Corporation) C:\WINDOWS\system32\IKEEXT.DLL
2016-09-13 18:53 - 2016-09-07 00:47 - 00824320 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcWebFilter.dll
2016-09-13 18:53 - 2016-09-07 00:46 - 00123392 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
2016-09-13 18:53 - 2016-09-07 00:46 - 00088576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\olepro32.dll
2016-09-13 18:53 - 2016-09-07 00:45 - 00086528 _____ (Microsoft Corporation) C:\WINDOWS\system32\spcompat.dll
2016-09-13 18:53 - 2016-09-07 00:44 - 00134656 _____ (Microsoft Corporation) C:\WINDOWS\system32\wificonnapi.dll
2016-09-13 18:53 - 2016-09-07 00:44 - 00069120 _____ (Microsoft Corporation) C:\WINDOWS\system32\pngfilt.dll
2016-09-13 18:53 - 2016-09-07 00:43 - 00015872 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\MTConfig.sys
2016-09-13 18:53 - 2016-09-07 00:42 - 00572928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WpcWebFilter.dll
2016-09-13 18:53 - 2016-09-07 00:42 - 00163328 _____ (Microsoft Corporation) C:\WINDOWS\system32\WsmAuto.dll
2016-09-13 18:53 - 2016-09-07 00:42 - 00140288 _____ (Microsoft Corporation) C:\WINDOWS\system32\WcnApi.dll
2016-09-13 18:53 - 2016-09-07 00:42 - 00112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\fdWCN.dll
2016-09-13 18:53 - 2016-09-07 00:42 - 00050176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MosHostClient.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00313856 _____ (Microsoft Corporation) C:\WINDOWS\system32\DictationManager.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00125952 _____ (Microsoft Corporation) C:\WINDOWS\system32\MediaFoundation.DefaultPercept ionProvider.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00124928 _____ (Microsoft Corporation) C:\WINDOWS\system32\shsetup.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00094720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserDataTimeUtil.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00066048 _____ (Microsoft Corporation) C:\WINDOWS\system32\OnDemandConnRouteHelper.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00056832 _____ (Microsoft Corporation) C:\WINDOWS\system32\fwcfg.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00047616 _____ (Microsoft Corporation) C:\WINDOWS\system32\deviceassociation.dll
2016-09-13 18:53 - 2016-09-07 00:41 - 00025600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\odbcconf.dll
2016-09-13 18:53 - 2016-09-07 00:40 - 00471040 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbemcomn.dll
2016-09-13 18:53 - 2016-09-07 00:40 - 00086528 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppCapture.dll
2016-09-13 18:53 - 2016-09-07 00:40 - 00027648 _____ (Microsoft Corporation) C:\WINDOWS\system32\CheckNetIsolation.exe
2016-09-13 18:53 - 2016-09-07 00:39 - 00379392 _____ (Microsoft Corporation) C:\WINDOWS\system32\usocore.dll
2016-09-13 18:53 - 2016-09-07 00:39 - 00096256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\VoipRT.dll
2016-09-13 18:53 - 2016-09-07 00:39 - 00075264 _____ (Microsoft Corporation) C:\WINDOWS\system32\wiarpc.dll
2016-09-13 18:53 - 2016-09-07 00:39 - 00059904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\udhisapi.dll
2016-09-13 18:53 - 2016-09-07 00:39 - 00053760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Cortana.ProxyStub.dll
2016-09-13 18:53 - 2016-09-07 00:38 - 00288768 _____ (Microsoft Corporation) C:\WINDOWS\system32\WsmWmiPl.dll
2016-09-13 18:53 - 2016-09-07 00:38 - 00254464 _____ (Microsoft Corporation) C:\WINDOWS\system32\prnntfy.dll
2016-09-13 18:53 - 2016-09-07 00:38 - 00206848 _____ (Microsoft Corporation) C:\WINDOWS\system32\LegacyNetUXHost.exe
2016-09-13 18:53 - 2016-09-07 00:38 - 00157184 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Geolocation.d ll
2016-09-13 18:53 - 2016-09-07 00:38 - 00059392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MosStorage.dll
2016-09-13 18:53 - 2016-09-07 00:38 - 00038912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsmprovhost.exe
2016-09-13 18:53 - 2016-09-07 00:38 - 00035840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\upnpcont.exe
2016-09-13 18:53 - 2016-09-07 00:37 - 00642048 _____ (Microsoft Corporation) C:\WINDOWS\system32\enterprisecsps.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00617984 _____ (Microsoft Corporation) C:\WINDOWS\system32\StorSvc.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00435712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.AllJoyn.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00404480 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\HdAudio.sys
2016-09-13 18:53 - 2016-09-07 00:37 - 00381952 _____ (Microsoft Corporation) C:\WINDOWS\system32\apprepsync.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00373248 _____ (Microsoft Corporation) C:\WINDOWS\system32\WmpDui.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00274944 _____ (Microsoft Corporation) C:\WINDOWS\system32\DisplayManager.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00145408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WsmAuto.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00100352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WcnApi.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00092160 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtmled.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00087040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapsBtSvc.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00035328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\deviceassociation.dll
2016-09-13 18:53 - 2016-09-07 00:37 - 00026624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WsmAgent.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 06572032 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwanmm.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 01568768 _____ (Microsoft Corporation) C:\WINDOWS\system32\msdt.exe
2016-09-13 18:53 - 2016-09-07 00:36 - 01051136 _____ (Microsoft Corporation) C:\WINDOWS\system32\DiagCpl.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00764928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00489984 _____ (Microsoft Corporation) C:\WINDOWS\system32\authfwcfg.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00457216 _____ (Microsoft Corporation) C:\WINDOWS\system32\azroleui.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00414720 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvr.exe
2016-09-13 18:53 - 2016-09-07 00:36 - 00319488 _____ (Microsoft Corporation) C:\WINDOWS\system32\dot3ui.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00287744 _____ (Microsoft Corporation) C:\WINDOWS\system32\apprepapi.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00200192 _____ (Microsoft Corporation) C:\WINDOWS\system32\WUDFPlatform.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00174592 _____ (Microsoft Corporation) C:\WINDOWS\system32\easwrt.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00102912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shsetup.dll
2016-09-13 18:53 - 2016-09-07 00:36 - 00047104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fwcfg.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00814592 _____ (Microsoft Corporation) C:\WINDOWS\system32\msctfuimanager.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00715264 _____ (Microsoft Corporation) C:\WINDOWS\system32\GamePanel.exe
2016-09-13 18:53 - 2016-09-07 00:35 - 00704000 _____ (Microsoft Corporation) C:\WINDOWS\system32\CellularAPI.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00591872 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmsRouterSvc.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00577536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Walle t.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00522240 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.WiFiDirect.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00458752 _____ (Microsoft Corporation) C:\WINDOWS\system32\PlayToDevice.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00412672 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlanui.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00394240 _____ (Microsoft Corporation) C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.d ll
2016-09-13 18:53 - 2016-09-07 00:35 - 00393216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wbemcomn.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00339968 _____ (Microsoft Corporation) C:\WINDOWS\system32\SensorService.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00256512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\unimdm.tsp
2016-09-13 18:53 - 2016-09-07 00:35 - 00254464 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExecModelClient.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00206848 _____ (Microsoft Corporation) C:\WINDOWS\system32\SharedStartModelShim.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00205312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\oemlicense.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00119296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Streaming.ps.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00115712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcshext.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00070656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppCapture.dll
2016-09-13 18:53 - 2016-09-07 00:35 - 00052736 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vsstrace.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00952320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.PointOfService .dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00727040 _____ (Microsoft Corporation) C:\WINDOWS\system32\nshwfp.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00619520 _____ (Microsoft Corporation) C:\WINDOWS\system32\efswrt.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00510464 _____ (Microsoft Corporation) C:\WINDOWS\system32\WlanMediaManager.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00497664 _____ (Microsoft Corporation) C:\WINDOWS\system32\WalletService.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00387072 _____ (Microsoft Corporation) C:\WINDOWS\system32\qdvd.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00371712 _____ (Microsoft Corporation) C:\WINDOWS\system32\MDEServer.exe
2016-09-13 18:53 - 2016-09-07 00:34 - 00344064 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.Picker.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00305152 _____ (Microsoft Corporation) C:\WINDOWS\system32\edputil.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00300032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcbase.dll
2016-09-13 18:53 - 2016-09-07 00:34 - 00163840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cic.dll
2016-09-13 18:53 - 2016-09-07 00:33 - 00904704 _____ (Microsoft Corporation) C:\WINDOWS\system32\azroles.dll
2016-09-13 18:53 - 2016-09-07 00:33 - 00847360 _____ (Microsoft Corporation) C:\WINDOWS\system32\netlogon.dll
2016-09-13 18:53 - 2016-09-07 00:33 - 00576000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.UX.EapReque stHandler.dll
2016-09-13 18:53 - 2016-09-07 00:33 - 00330240 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store .TestingFramework.dll
2016-09-13 18:53 - 2016-09-07 00:33 - 00316416 _____ (Microsoft Corporation) C:\WINDOWS\system32\sti.dll
2016-09-13 18:53 - 2016-09-07 00:33 - 00290304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WmpDui.dll
2016-09-13 18:53 - 2016-09-07 00:33 - 00238080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WsmWmiPl.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 04213248 _____ (Microsoft Corporation) C:\WINDOWS\system32\WlanMM.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 01294336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcnwiz.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 01048576 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebcamUi.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00947200 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasgcw.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00757248 _____ (Microsoft Corporation) C:\WINDOWS\system32\winipcsecproc_ssp.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00738816 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmartCardSimulator.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00651776 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserLanguagesCpl.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00643584 _____ (Microsoft Corporation) C:\WINDOWS\system32\wiaservc.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00517632 _____ (Microsoft Corporation) C:\WINDOWS\system32\winspool.drv
2016-09-13 18:53 - 2016-09-07 00:32 - 00506880 _____ (Microsoft Corporation) C:\WINDOWS\system32\tileobjserver.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00471040 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcncsvc.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00466944 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwanconn.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00444928 _____ (Microsoft Corporation) C:\WINDOWS\system32\das.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00432640 _____ (Microsoft Corporation) C:\WINDOWS\system32\CredProvDataModel.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00407040 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srv.sys
2016-09-13 18:53 - 2016-09-07 00:32 - 00386048 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Devices.LowLevel.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00356864 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActivationManager.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00339456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\azroleui.dll
2016-09-13 18:53 - 2016-09-07 00:32 - 00334848 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchProtocolHost.exe
2016-09-13 18:53 - 2016-09-07 00:32 - 00275968 _____ (Microsoft Corporation) C:\WINDOWS\system32\facecredentialprovider.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 01216512 _____ (Microsoft Corporation) C:\WINDOWS\system32\netcenter.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 01094656 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Vpn.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00970752 _____ (Microsoft Corporation) C:\WINDOWS\system32\nettrace.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00941568 _____ (Microsoft Corporation) C:\WINDOWS\system32\MiracastReceiver.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00900608 _____ (Microsoft Corporation) C:\WINDOWS\system32\CPFilters.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00859136 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store .dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00839680 _____ (Microsoft Corporation) C:\WINDOWS\system32\comuid.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00828928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.AccountsControl.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00821760 _____ (Microsoft Corporation) C:\WINDOWS\system32\MrmIndexer.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00753664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msctfuimanager.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00607232 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxApplicabilityEngine.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00578560 _____ (Microsoft Corporation) C:\WINDOWS\system32\mscms.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00541184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GamePanel.exe
2016-09-13 18:53 - 2016-09-07 00:31 - 00538112 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Cortana.Desktop.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00504320 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppReadiness.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00435200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Walle t.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00334336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcastdvr.exe
2016-09-13 18:53 - 2016-09-07 00:31 - 00262144 _____ (Microsoft Corporation) C:\WINDOWS\system32\webcheck.dll
2016-09-13 18:53 - 2016-09-07 00:31 - 00114688 _____ (Microsoft Corporation) C:\WINDOWS\system32\offlinelsa.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 02476032 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSAJApi.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 01575936 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Speech.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 01001472 _____ (Microsoft Corporation) C:\WINDOWS\system32\schedsvc.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00870400 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00817152 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Storage.Search.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00698368 _____ (Microsoft Corporation) C:\WINDOWS\system32\PlayToManager.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00585728 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieui.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00576000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nshwfp.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00471552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\filemgmt.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00436224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mprdim.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00349696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapConfiguration.dll
2016-09-13 18:53 - 2016-09-07 00:30 - 00294912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PhoneOm.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 02624512 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 01902592 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml3.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 01319424 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifinetworkmanager.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 01213440 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00888320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00841728 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32spl.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00669696 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.Sensors.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00553472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cryptui.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00499712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MessagingDataModel2.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00442368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dlnashext.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00286208 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb10.sys
2016-09-13 18:53 - 2016-09-07 00:29 - 00250880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store .TestingFramework.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00242688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sti.dll
2016-09-13 18:53 - 2016-09-07 00:29 - 00199680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SyncSettings.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 01752576 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 01291776 _____ (Microsoft Corporation) C:\WINDOWS\system32\werconcpl.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 01226752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wcnwiz.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00879616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WebcamUi.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00846336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasgcw.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00800768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\JpMapControl.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00780800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tdh.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00755712 _____ (Microsoft Corporation) C:\WINDOWS\system32\spoolsv.exe
2016-09-13 18:53 - 2016-09-07 00:28 - 00674816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MiracastReceiver.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00673280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00654336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winipcsecproc_ssp.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00645120 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpnapps.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00614400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winhttp.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00489984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mbsmsapi.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00400896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winspool.drv
2016-09-13 18:53 - 2016-09-07 00:28 - 00381952 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00337920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Geolocation.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00334848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CredProvDataModel.dll
2016-09-13 18:53 - 2016-09-07 00:28 - 00296448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sysdm.cpl
2016-09-13 18:53 - 2016-09-07 00:28 - 00284160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\eappcfg.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 01872896 _____ (Microsoft Corporation) C:\WINDOWS\system32\workfolderssvc.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 01424384 _____ (Microsoft Corporation) C:\WINDOWS\system32\wdc.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 01139712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vssapi.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 01131520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Audio.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00784896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\NMAA.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00708608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CPFilters.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00549888 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchFolder.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00521728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmdrmsdk.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00502272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mscms.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00458752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wlidprov.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00400896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OneDriveSettingSyncProvider.dl l
2016-09-13 18:53 - 2016-09-07 00:27 - 00329216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\upnphost.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00248320 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\resutils.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00230400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webcheck.dll
2016-09-13 18:53 - 2016-09-07 00:27 - 00100864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offlinelsa.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 01915392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSAJApi.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 01588224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml3.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 01537536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\pla.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 01497088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WMPDMC.exe
2016-09-13 18:53 - 2016-09-07 00:26 - 01063936 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 00854528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Devices.Bluetooth.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 00736768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SmartcardCredentialProvider.dl l
2016-09-13 18:53 - 2016-09-07 00:26 - 00711680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapControlCore.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 00673280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MbaeApiPublic.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 00638464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 00488960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\clusapi.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 00482816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\duser.dll
2016-09-13 18:53 - 2016-09-07 00:26 - 00321024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\syncutil.dll
2016-09-13 18:53 - 2016-09-07 00:25 - 06312448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Search.dll
2016-09-13 18:53 - 2016-09-07 00:25 - 06296064 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mos.dll
2016-09-13 18:53 - 2016-09-07 00:25 - 04404736 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Search.dll
2016-09-13 18:53 - 2016-09-07 00:25 - 01944576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
2016-09-13 18:53 - 2016-09-07 00:25 - 00888832 _____ (Microsoft Corporation) C:\WINDOWS\system32\printfilterpipelinesvc.exe
2016-09-13 18:53 - 2016-09-07 00:25 - 00501760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Devices.Sensors.dll
2016-09-13 18:53 - 2016-09-07 00:24 - 03695104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_47.dll
2016-09-13 18:53 - 2016-09-07 00:24 - 01276928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsp_fs.dll
2016-09-13 18:53 - 2016-09-07 00:24 - 00785920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mprddm.dll
2016-09-13 18:53 - 2016-09-07 00:24 - 00489984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ShareHost.dll
2016-09-13 18:53 - 2016-09-07 00:24 - 00460800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchFolder.dll
2016-09-13 18:53 - 2016-09-07 00:23 - 01562112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmc.exe
2016-09-13 18:53 - 2016-09-07 00:23 - 01309696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wdc.dll
2016-09-13 18:53 - 2016-09-07 00:23 - 00838144 _____ (Microsoft Corporation) C:\WINDOWS\system32\uDWM.dll
2016-09-13 18:53 - 2016-09-07 00:23 - 00787456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Web.dll
2016-09-13 18:53 - 2016-09-07 00:22 - 02106368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\storagewmi.dll
2016-09-13 18:53 - 2016-09-07 00:22 - 01987072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DWrite.dll
2016-09-13 18:53 - 2016-09-07 00:22 - 01297408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SensorDataService.exe
2016-09-13 18:53 - 2016-09-07 00:22 - 00778240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MsSpellCheckingFacility.dll
2016-09-13 18:53 - 2016-09-07 00:21 - 02527232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mispace.dll
2016-09-13 18:53 - 2016-09-07 00:21 - 01410560 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Web.Http.dll
2016-09-13 18:53 - 2016-09-07 00:21 - 01063936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gpedit.dll
2016-09-13 18:53 - 2016-09-07 00:21 - 00639488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
2016-09-13 18:53 - 2016-09-07 00:20 - 00900608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.BackgroundT ransfer.dll
2016-09-13 18:53 - 2016-09-07 00:20 - 00882688 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntshrui.dll
2016-09-13 18:53 - 2016-09-07 00:20 - 00870400 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpncore.dll
2016-09-13 18:53 - 2016-09-07 00:20 - 00417792 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenrollengine.dll
2016-09-13 18:53 - 2016-09-07 00:19 - 05325824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
2016-09-13 18:53 - 2016-09-07 00:19 - 04169728 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbon.dll
2016-09-13 18:53 - 2016-09-07 00:19 - 02295808 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansvc.dll
2016-09-13 18:53 - 2016-09-07 00:19 - 01388544 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
2016-09-13 18:53 - 2016-09-07 00:19 - 01072128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Web.Http.dll
2016-09-13 18:53 - 2016-09-07 00:19 - 00503296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSync.dll
2016-09-13 18:53 - 2016-09-07 00:18 - 07536640 _____ (Microsoft Corporation) C:\WINDOWS\system32\mstscax.dll
2016-09-13 18:53 - 2016-09-07 00:18 - 05205504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BingMaps.dll
2016-09-13 18:53 - 2016-09-07 00:18 - 04826624 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
2016-09-13 18:53 - 2016-09-07 00:18 - 00592384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Web.dll
2016-09-13 18:53 - 2016-09-07 00:18 - 00451072 _____ (Microsoft Corporation) C:\WINDOWS\system32\XpsDocumentTargetPrint.dll
2016-09-13 18:53 - 2016-09-07 00:18 - 00450560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SyncController.dll
2016-09-13 18:53 - 2016-09-07 00:17 - 03459584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbon.dll
2016-09-13 18:53 - 2016-09-07 00:17 - 02679808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netshell.dll
2016-09-13 18:53 - 2016-09-07 00:17 - 02175488 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2016-09-13 18:53 - 2016-09-07 00:17 - 01674240 _____ (Microsoft Corporation) C:\WINDOWS\system32\quartz.dll
2016-09-13 18:53 - 2016-09-07 00:17 - 01526784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Phone.dll
2016-09-13 18:53 - 2016-09-07 00:17 - 01502208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
2016-09-13 18:53 - 2016-09-07 00:16 - 02680320 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msftedit.dll
2016-09-13 18:53 - 2016-09-07 00:16 - 02444288 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.appcore.dll
2016-09-13 18:53 - 2016-09-07 00:16 - 02361856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcndmgr.dll
2016-09-13 18:53 - 2016-09-07 00:16 - 02155008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authui.dll
2016-09-13 18:53 - 2016-09-07 00:16 - 00314880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XpsDocumentTargetPrint.dll
2016-09-13 18:53 - 2016-09-07 00:16 - 00232448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\notepad.exe
2016-09-13 18:53 - 2016-09-07 00:15 - 02067968 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.dll
2016-09-13 18:53 - 2016-09-07 00:15 - 01626112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dwmcore.dll
2016-09-13 18:53 - 2016-09-07 00:15 - 01448960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dui70.dll
2016-09-13 18:53 - 2016-09-07 00:15 - 01249280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usercpl.dll
2016-09-13 18:53 - 2016-09-07 00:15 - 01121792 _____ (Microsoft Corporation) C:\WINDOWS\system32\localspl.dll
2016-09-13 18:53 - 2016-09-07 00:15 - 00835072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Streaming.dll
2016-09-13 18:53 - 2016-09-07 00:15 - 00573440 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserLanguagesCpl.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 03351040 _____ (Microsoft Corporation) C:\WINDOWS\system32\msi.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 03078656 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 02573824 _____ (Microsoft Corporation) C:\WINDOWS\system32\WsmSvc.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 02553856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 02177024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WsmSvc.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 01732096 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 01708032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ActiveSyncProvider.dll
2016-09-13 18:53 - 2016-09-07 00:14 - 01487872 _____ (Microsoft Corporation) C:\WINDOWS\system32\SpeechPal.dll
2016-09-13 18:53 - 2016-09-07 00:12 - 02180096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
2016-09-13 18:53 - 2016-09-07 00:12 - 00754176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncCore.dll
2016-09-13 18:53 - 2016-09-07 00:12 - 00339456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\certcli.dll
2016-09-13 18:53 - 2016-09-07 00:11 - 03294208 _____ (Microsoft Corporation) C:\WINDOWS\system32\mstsc.exe
2016-09-13 18:53 - 2016-09-07 00:11 - 03053568 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcore.dll
2016-09-13 18:53 - 2016-09-07 00:10 - 01035776 _____ (Microsoft Corporation) C:\WINDOWS\system32\TSWorkspace.dll
2016-09-13 18:53 - 2016-09-07 00:10 - 00712704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RemoteNaturalLanguage.dll
2016-09-13 18:53 - 2016-09-07 00:10 - 00341504 _____ (Microsoft Corporation) C:\WINDOWS\system32\RADCUI.dll
2016-09-13 18:53 - 2016-09-07 00:09 - 00824832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\adtschema.dll
2016-09-13 18:53 - 2016-09-07 00:09 - 00218624 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ahcache.sys
2016-09-13 18:53 - 2016-09-04 20:37 - 00445765 _____ C:\WINDOWS\system32\ApnDatabase.xml
2016-09-13 18:52 - 2016-09-07 01:39 - 07468896 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2016-09-13 18:52 - 2016-09-07 01:39 - 04387680 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupapi.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 01997832 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 01862000 _____ C:\WINDOWS\SysWOW64\CoreUIComponents.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 01557768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 01238584 _____ (Microsoft Corporation) C:\WINDOWS\system32\Taskmgr.exe
2016-09-13 18:52 - 2016-09-07 01:39 - 00799568 _____ (Microsoft Corporation) C:\WINDOWS\system32\oleaut32.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 00705576 _____ (Microsoft Corporation) C:\WINDOWS\system32\kernel32.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 00601744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\oleaut32.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 00428896 _____ (Microsoft Corporation) C:\WINDOWS\system32\hal.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 00414232 _____ (Microsoft Corporation) C:\WINDOWS\system32\BCP47Langs.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 00337328 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Storage.ApplicationDat a.dll
2016-09-13 18:52 - 2016-09-07 01:39 - 00328520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BCP47Langs.dll
2016-09-13 18:52 - 2016-09-07 01:36 - 00528736 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcasvc.dll
2016-09-13 18:52 - 2016-09-07 01:35 - 01613664 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack.dll
2016-09-13 18:52 - 2016-09-07 01:35 - 00989536 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecConfig.efi
2016-09-13 18:52 - 2016-09-07 01:35 - 00523616 _____ (Microsoft Corporation) C:\WINDOWS\system32\wimserv.exe
2016-09-13 18:52 - 2016-09-07 01:34 - 03449168 _____ (Microsoft Corporation) C:\WINDOWS\system32\WSService.dll
2016-09-13 18:52 - 2016-09-07 01:33 - 02026736 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml6.dll
2016-09-13 18:52 - 2016-09-07 01:26 - 01554152 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpmde.dll
2016-09-13 18:52 - 2016-09-07 01:26 - 01552104 _____ (Microsoft Corporation) C:\WINDOWS\system32\winmde.dll
2016-09-13 18:52 - 2016-09-07 01:26 - 00693592 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetSetupEngine.dll
2016-09-13 18:52 - 2016-09-07 01:26 - 00516544 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
2016-09-13 18:52 - 2016-09-07 01:26 - 00439136 _____ (Microsoft Corporation) C:\WINDOWS\system32\netcfgx.dll
2016-09-13 18:52 - 2016-09-07 01:24 - 02180128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2016-09-13 18:52 - 2016-09-07 01:24 - 01118200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfnetsrc.dll
2016-09-13 18:52 - 2016-09-07 01:24 - 00980352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfasfsrcsnk.dll
2016-09-13 18:52 - 2016-09-07 01:24 - 00925064 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfplat.dll
2016-09-13 18:52 - 2016-09-07 01:24 - 00709176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsvr.dll
2016-09-13 18:52 - 2016-09-07 01:24 - 00652312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\evr.dll
2016-09-13 18:52 - 2016-09-07 01:24 - 00451928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFCaptureEngine.dll
2016-09-13 18:52 - 2016-09-07 01:23 - 04515256 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
2016-09-13 18:52 - 2016-09-07 01:23 - 01540216 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
2016-09-13 18:52 - 2016-09-07 01:23 - 00730344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Shell.Broker. dll
2016-09-13 18:52 - 2016-09-07 01:23 - 00565600 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncHost.exe
2016-09-13 18:52 - 2016-09-07 01:23 - 00374008 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsAdminFlows.exe
2016-09-13 18:52 - 2016-09-07 01:23 - 00303216 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppHost.exe
2016-09-13 18:52 - 2016-09-07 01:22 - 01824264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\combase.dll
2016-09-13 18:52 - 2016-09-07 01:22 - 00957608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ole32.dll
2016-09-13 18:52 - 2016-09-07 01:22 - 00742192 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeManagerObj.dll
2016-09-13 18:52 - 2016-09-07 01:22 - 00703840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWAHost.exe
2016-09-13 18:52 - 2016-09-07 01:22 - 00638816 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ClipSp.sys
2016-09-13 18:52 - 2016-09-07 01:22 - 00625000 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipSVC.dll
2016-09-13 18:52 - 2016-09-07 01:22 - 00359256 _____ (Microsoft Corporation) C:\WINDOWS\system32\msv1_0.dll
2016-09-13 18:52 - 2016-09-07 01:21 - 21123320 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2016-09-13 18:52 - 2016-09-07 01:21 - 05240952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2016-09-13 18:52 - 2016-09-07 01:21 - 04074160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
2016-09-13 18:52 - 2016-09-07 01:20 - 00836752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinapi.appcore.dll
2016-09-13 18:52 - 2016-09-07 01:16 - 02773088 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d11.dll
2016-09-13 18:52 - 2016-09-07 01:16 - 02548936 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d10warp.dll
2016-09-13 18:52 - 2016-09-07 01:16 - 02144512 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d9.dll
2016-09-13 18:52 - 2016-09-07 01:16 - 01988448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2016-09-13 18:52 - 2016-09-07 01:15 - 01776768 _____ (Microsoft Corporation) C:\WINDOWS\system32\WindowsCodecs.dll
2016-09-13 18:52 - 2016-09-07 01:15 - 01415200 _____ (Microsoft Corporation) C:\WINDOWS\system32\msctf.dll
2016-09-13 18:52 - 2016-09-07 01:15 - 00550656 _____ (Microsoft Corporation) C:\WINDOWS\system32\directmanipulation.dll
2016-09-13 18:52 - 2016-09-07 01:14 - 00430944 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb.sys
2016-09-13 18:52 - 2016-09-07 01:14 - 00216416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb20.sys
2016-09-13 18:52 - 2016-09-07 01:13 - 02186856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d11.dll
2016-09-13 18:52 - 2016-09-07 01:12 - 28851224 _____ (Microsoft Corporation) C:\WINDOWS\system32\WindowsCodecsRaw.dll
2016-09-13 18:52 - 2016-09-07 01:12 - 00871776 _____ (Microsoft Corporation) C:\WINDOWS\system32\drvstore.dll
2016-09-13 18:52 - 2016-09-07 01:11 - 02187408 _____ (Microsoft Corporation) C:\WINDOWS\system32\hevcdecoder.dll
2016-09-13 18:52 - 2016-09-07 01:11 - 00503600 _____ (Microsoft Corporation) C:\WINDOWS\system32\DMRServer.dll
2016-09-13 18:52 - 2016-09-07 01:11 - 00388888 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpps.dll
2016-09-13 18:52 - 2016-09-07 01:11 - 00305296 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpeffects.dll
2016-09-13 18:52 - 2016-09-07 01:08 - 28083144 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WindowsCodecsRaw.dll
2016-09-13 18:52 - 2016-09-07 01:07 - 00253080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmpeffects.dll
2016-09-13 18:52 - 2016-09-07 00:53 - 01033216 _____ (Microsoft Corporation) C:\WINDOWS\system32\termsrv.dll
2016-09-13 18:52 - 2016-09-07 00:51 - 00089088 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapsCSP.dll
2016-09-13 18:52 - 2016-09-07 00:47 - 00066560 _____ (Microsoft Corporation) C:\WINDOWS\system32\MosHostClient.dll
2016-09-13 18:52 - 2016-09-07 00:46 - 00119296 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataTimeUtil.dll
2016-09-13 18:52 - 2016-09-07 00:46 - 00068608 _____ (Microsoft Corporation) C:\WINDOWS\system32\fdProxy.dll
2016-09-13 18:52 - 2016-09-07 00:46 - 00061952 _____ (Microsoft Corporation) C:\WINDOWS\system32\vss_ps.dll
2016-09-13 18:52 - 2016-09-07 00:46 - 00031232 _____ (Microsoft Corporation) C:\WINDOWS\system32\odbcconf.dll
2016-09-13 18:52 - 2016-09-07 00:45 - 00037376 _____ (Microsoft Corporation) C:\WINDOWS\system32\cmintegrator.dll
2016-09-13 18:52 - 2016-09-07 00:44 - 00120832 _____ (Microsoft Corporation) C:\WINDOWS\system32\VoipRT.dll
2016-09-13 18:52 - 2016-09-07 00:44 - 00105984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Cortana.ProxyStub.dll
2016-09-13 18:52 - 2016-09-07 00:44 - 00095232 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecureTimeAggregator.dll
2016-09-13 18:52 - 2016-09-07 00:44 - 00068608 _____ (Microsoft Corporation) C:\WINDOWS\system32\udhisapi.dll
2016-09-13 18:52 - 2016-09-07 00:44 - 00028672 _____ (Microsoft Corporation) C:\WINDOWS\system32\mapsupdatetask.dll
2016-09-13 18:52 - 2016-09-07 00:44 - 00014848 _____ (Microsoft Corporation) C:\WINDOWS\system32\IconCodecService.dll
2016-09-13 18:52 - 2016-09-07 00:43 - 00584704 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIRibbonRes.dll
2016-09-13 18:52 - 2016-09-07 00:43 - 00074240 _____ (Microsoft Corporation) C:\WINDOWS\system32\MosStorage.dll
2016-09-13 18:52 - 2016-09-07 00:43 - 00041472 _____ (Microsoft Corporation) C:\WINDOWS\system32\upnpcont.exe
2016-09-13 18:52 - 2016-09-07 00:43 - 00037376 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsmprovhost.exe
2016-09-13 18:52 - 2016-09-07 00:42 - 00219136 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseModernAppMgmtCSP.dll
2016-09-13 18:52 - 2016-09-07 00:42 - 00120320 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapsBtSvc.dll
2016-09-13 18:52 - 2016-09-07 00:42 - 00117760 _____ (Microsoft Corporation) C:\WINDOWS\system32\dafWCN.dll
2016-09-13 18:52 - 2016-09-07 00:42 - 00031744 _____ (Microsoft Corporation) C:\WINDOWS\system32\WsmAgent.dll
2016-09-13 18:52 - 2016-09-07 00:41 - 00309760 _____ (Microsoft Corporation) C:\WINDOWS\system32\wusa.exe
2016-09-13 18:52 - 2016-09-07 00:41 - 00091136 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
2016-09-13 18:52 - 2016-09-07 00:41 - 00072704 _____ (Microsoft Corporation) C:\WINDOWS\system32\moshost.dll
2016-09-13 18:52 - 2016-09-07 00:41 - 00047616 _____ (Microsoft Corporation) C:\WINDOWS\system32\TpmTasks.dll
2016-09-13 18:52 - 2016-09-07 00:40 - 13018624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
2016-09-13 18:52 - 2016-09-07 00:40 - 00297472 _____ (Microsoft Corporation) C:\WINDOWS\system32\unimdm.tsp
2016-09-13 18:52 - 2016-09-07 00:40 - 00245248 _____ (Microsoft Corporation) C:\WINDOWS\system32\MicrosoftAccountExtension.dll
2016-09-13 18:52 - 2016-09-07 00:40 - 00135680 _____ (Microsoft Corporation) C:\WINDOWS\system32\vdsutil.dll
2016-09-13 18:52 - 2016-09-07 00:40 - 00129024 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcshext.dll
2016-09-13 18:52 - 2016-09-07 00:40 - 00070144 _____ (Microsoft Corporation) C:\WINDOWS\system32\vsstrace.dll
2016-09-13 18:52 - 2016-09-07 00:39 - 09324032 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmploc.DLL
2016-09-13 18:52 - 2016-09-07 00:39 - 00356352 _____ (Microsoft Corporation) C:\WINDOWS\system32\mcbuilder.exe
2016-09-13 18:52 - 2016-09-07 00:39 - 00270848 _____ (Microsoft Corporation) C:\WINDOWS\system32\moshostcore.dll
2016-09-13 18:52 - 2016-09-07 00:38 - 00584704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIRibbonRes.dll
2016-09-13 18:52 - 2016-09-07 00:38 - 00335360 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcbase.dll
2016-09-13 18:52 - 2016-09-07 00:38 - 00210432 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmcsp.dll
2016-09-13 18:52 - 2016-09-07 00:38 - 00187392 _____ (Microsoft Corporation) C:\WINDOWS\system32\BootMenuUX.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00846848 _____ (Microsoft Corporation) C:\WINDOWS\system32\ipsecsnp.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00308736 _____ (Microsoft Corporation) C:\WINDOWS\system32\eapphost.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00250880 _____ (Microsoft Corporation) C:\WINDOWS\system32\MicrosoftAccountCloudAP.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00198144 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00126464 _____ (Microsoft Corporation) C:\WINDOWS\system32\dialserver.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00118784 _____ (Microsoft Corporation) C:\WINDOWS\system32\fhsvc.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00099328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\srpapi.dll
2016-09-13 18:52 - 2016-09-07 00:37 - 00095744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fdWCN.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 01582080 _____ (Microsoft Corporation) C:\WINDOWS\system32\aitstatic.exe
2016-09-13 18:52 - 2016-09-07 00:36 - 00752128 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneService.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00600064 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.LowLevel.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00567808 _____ (Microsoft Corporation) C:\WINDOWS\system32\MBMediaManager.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00479744 _____ (Microsoft Corporation) C:\WINDOWS\system32\apphelp.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00467968 _____ (Microsoft Corporation) C:\WINDOWS\system32\swprv.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00394752 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMPhoto.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00332800 _____ (Microsoft Corporation) C:\WINDOWS\system32\eapp3hst.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00317952 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkBindingEngineMigPlugin. dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00314368 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtSvc.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00250880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppLockerCSP.dll
2016-09-13 18:52 - 2016-09-07 00:36 - 00112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\eapsvc.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 09324032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmploc.DLL
2016-09-13 18:52 - 2016-09-07 00:35 - 00945664 _____ (Microsoft Corporation) C:\WINDOWS\system32\autochk.exe
2016-09-13 18:52 - 2016-09-07 00:35 - 00714240 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettings.Handlers.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00685568 _____ (Microsoft Corporation) C:\WINDOWS\system32\scapi.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00460800 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapConfiguration.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00450048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Bluetooth.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00368640 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack_win.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00363008 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneOm.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00342016 _____ (Microsoft Corporation) C:\WINDOWS\system32\APHostService.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00131072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usbceip.dll
2016-09-13 18:52 - 2016-09-07 00:35 - 00024064 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CheckNetIsolation.exe
2016-09-13 18:52 - 2016-09-07 00:34 - 11545088 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00790528 _____ (Microsoft Corporation) C:\WINDOWS\system32\EmailApis.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00667136 _____ (Microsoft Corporation) C:\WINDOWS\system32\vds.exe
2016-09-13 18:52 - 2016-09-07 00:34 - 00630784 _____ (Microsoft Corporation) C:\WINDOWS\system32\MessagingDataModel2.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00572928 _____ (Microsoft Corporation) C:\WINDOWS\system32\filemgmt.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00440320 _____ (Microsoft Corporation) C:\WINDOWS\system32\fhcfg.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00414720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.BioFeedback.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00318464 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Cortana.OneCore.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00304128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Devices.Midi.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00278016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Management.dl l
2016-09-13 18:52 - 2016-09-07 00:34 - 00270336 _____ (Microsoft Corporation) C:\WINDOWS\system32\netplwiz.dll
2016-09-13 18:52 - 2016-09-07 00:34 - 00265728 _____ (Microsoft Corporation) C:\WINDOWS\system32\netman.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 01813504 _____ (Microsoft Corporation) C:\WINDOWS\system32\pnidui.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00948736 _____ (Microsoft Corporation) C:\WINDOWS\system32\XblAuthManager.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00726528 _____ (Microsoft Corporation) C:\WINDOWS\system32\ChatApis.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00606720 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmsvc.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00602112 _____ (Microsoft Corporation) C:\WINDOWS\system32\cryptui.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00504832 _____ (Microsoft Corporation) C:\WINDOWS\system32\dlnashext.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00448000 _____ (Microsoft Corporation) C:\WINDOWS\system32\winipcfile.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00321536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Devices.AllJoyn.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00315392 _____ (Microsoft Corporation) C:\WINDOWS\system32\RDXTaskFactory.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00276480 _____ (Microsoft Corporation) C:\WINDOWS\system32\WindowsCodecsExt.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00200704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DisplayManager.dll
2016-09-13 18:52 - 2016-09-07 00:33 - 00092160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IdCtrls.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00892416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.SmartCards.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00708608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authenticatio n.Web.Core.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00674304 _____ (Microsoft Corporation) C:\WINDOWS\system32\mbsmsapi.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00492544 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettings.UserAccountsHan dlers.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00484352 _____ (Microsoft Corporation) C:\WINDOWS\system32\DataSenseHandlers.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00352768 _____ (Microsoft Corporation) C:\WINDOWS\system32\eappcfg.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00310784 _____ (Microsoft Corporation) C:\WINDOWS\system32\sysdm.cpl
2016-09-13 18:52 - 2016-09-07 00:32 - 00292864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dot3ui.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00283648 _____ (Microsoft Corporation) C:\WINDOWS\system32\PlayToReceiver.dll
2016-09-13 18:52 - 2016-09-07 00:32 - 00260096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\apprepsync.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 09920512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 02125312 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_Bluetooth.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 01985024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\certmgr.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 01056256 _____ (Microsoft Corporation) C:\WINDOWS\system32\JpMapControl.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00988160 _____ (Microsoft Corporation) C:\WINDOWS\system32\NMAA.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00984576 _____ (Microsoft Corporation) C:\WINDOWS\system32\tdh.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00970752 _____ (Microsoft Corporation) C:\WINDOWS\system32\kerberos.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00965632 _____ (Microsoft Corporation) C:\WINDOWS\system32\SRH.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00915456 _____ (Microsoft Corporation) C:\WINDOWS\system32\configurationclient.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00852992 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapsStore.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00700416 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppointmentApis.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00588288 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidprov.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00564224 _____ (Microsoft Corporation) C:\WINDOWS\system32\DevicePairing.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00527872 _____ (Microsoft Corporation) C:\WINDOWS\system32\defragsvc.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00519680 _____ (Microsoft Corporation) C:\WINDOWS\system32\WLanConn.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00515072 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneDriveSettingSyncProvider.dl l
2016-09-13 18:52 - 2016-09-07 00:31 - 00511488 _____ (Microsoft Corporation) C:\WINDOWS\system32\icsvc.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00472064 _____ (Microsoft Corporation) C:\WINDOWS\system32\Geolocation.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00452608 _____ (Microsoft Corporation) C:\WINDOWS\system32\upnphost.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00358912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authfwcfg.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00313344 _____ (Microsoft Corporation) C:\WINDOWS\system32\resutils.dll
2016-09-13 18:52 - 2016-09-07 00:31 - 00282624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.d ll
2016-09-13 18:52 - 2016-09-07 00:31 - 00190464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\apprepapi.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 14251520 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmp.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 02012672 _____ (Microsoft Corporation) C:\WINDOWS\system32\winmsipc.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 01558528 _____ (Microsoft Corporation) C:\WINDOWS\system32\vssapi.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 01500160 _____ (Microsoft Corporation) C:\WINDOWS\system32\RecoveryDrive.exe
2016-09-13 18:52 - 2016-09-07 00:30 - 01387520 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2016-09-13 18:52 - 2016-09-07 00:30 - 01318400 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsp_health.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 01144320 _____ (Microsoft Corporation) C:\WINDOWS\system32\qmgr.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 01054208 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00990208 _____ (Microsoft Corporation) C:\WINDOWS\system32\SharedStartModel.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00982016 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxPackaging.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00939520 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapControlCore.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00814080 _____ (Microsoft Corporation) C:\WINDOWS\system32\appwiz.cpl
2016-09-13 18:52 - 2016-09-07 00:30 - 00697344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authenticatio n.OnlineId.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00649216 _____ (Microsoft Corporation) C:\WINDOWS\system32\clusapi.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00599040 _____ (Microsoft Corporation) C:\WINDOWS\system32\duser.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00569856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\qdvd.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00531456 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppcext.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00436736 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
2016-09-13 18:52 - 2016-09-07 00:30 - 00368128 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Graphics.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 07977984 _____ (Microsoft Corporation) C:\WINDOWS\system32\mos.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 01847808 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMPDMC.exe
2016-09-13 18:52 - 2016-09-07 00:29 - 01487360 _____ (Microsoft Corporation) C:\WINDOWS\system32\pla.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 01465344 _____ (Microsoft Corporation) C:\WINDOWS\system32\VSSVC.exe
2016-09-13 18:52 - 2016-09-07 00:29 - 01443328 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagperf.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 01239552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.Bluetooth.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 00896512 _____ (Microsoft Corporation) C:\WINDOWS\system32\MbaeApiPublic.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 00853504 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadtb.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 00785408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\azroles.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 00387584 _____ (Microsoft Corporation) C:\WINDOWS\system32\syncutil.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 00283136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.BioFeedback.dll
2016-09-13 18:52 - 2016-09-07 00:29 - 00268288 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatehandlers.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 04143104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WlanMM.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 02731008 _____ (Microsoft Corporation) C:\WINDOWS\system32\gameux.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 01783808 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsp_fs.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 01717760 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 01671168 _____ (Microsoft Corporation) C:\WINDOWS\system32\FntCache.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 01648640 _____ (Microsoft Corporation) C:\WINDOWS\system32\comsvcs.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 01466368 _____ (Microsoft Corporation) C:\WINDOWS\system32\Pimstore.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 01211904 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Cred.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 00938496 _____ (Microsoft Corporation) C:\WINDOWS\system32\ContactApis.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 00889344 _____ (Microsoft Corporation) C:\WINDOWS\system32\mprddm.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 00638976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MrmIndexer.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 00638976 _____ (Microsoft Corporation) C:\WINDOWS\system32\ShareHost.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 00413696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WLanConn.dll
2016-09-13 18:52 - 2016-09-07 00:28 - 00282624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchProtocolHost.exe
2016-09-13 18:52 - 2016-09-07 00:27 - 04456448 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_47.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 01395712 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIAutomationCore.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 01073152 _____ (Microsoft Corporation) C:\WINDOWS\system32\RDXService.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00961024 _____ (Microsoft Corporation) C:\WINDOWS\system32\WSShared.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00865792 _____ (Microsoft Corporation) C:\WINDOWS\system32\AzureSettingSyncProvider.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00792576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kerberos.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00651776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comuid.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00585216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.AccountsControl.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00555520 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncController.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00517632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PlayToManager.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00502272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DevicePairing.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00477184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieui.dll
2016-09-13 18:52 - 2016-09-07 00:27 - 00372224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppBroker.dll
2016-09-13 18:52 - 2016-09-07 00:26 - 02881536 _____ (Microsoft Corporation) C:\WINDOWS\system32\storagewmi.dll
2016-09-13 18:52 - 2016-09-07 00:26 - 02057216 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidsvc.dll
2016-09-13 18:52 - 2016-09-07 00:26 - 01570816 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbengine.exe
2016-09-13 18:52 - 2016-09-07 00:26 - 01117184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Speech.dll
2016-09-13 18:52 - 2016-09-07 00:26 - 00821760 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
2016-09-13 18:52 - 2016-09-07 00:26 - 00738816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appwiz.cpl
2016-09-13 18:52 - 2016-09-07 00:26 - 00645632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Storage.Search.dll
2016-09-13 18:52 - 2016-09-07 00:26 - 00501760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vbscript.dll
2016-09-13 18:52 - 2016-09-07 00:26 - 00434688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LogonController.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 02578432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gameux.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 02445312 _____ (Microsoft Corporation) C:\WINDOWS\system32\DWrite.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 01965568 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmc.exe
2016-09-13 18:52 - 2016-09-07 00:25 - 01467392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 01328128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comsvcs.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 01105920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Audio.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 01052160 _____ (Microsoft Corporation) C:\WINDOWS\system32\MsSpellCheckingFacility.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 00759808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchIndexer.exe
2016-09-13 18:52 - 2016-09-07 00:25 - 00508416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wpnapps.dll
2016-09-13 18:52 - 2016-09-07 00:25 - 00207872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\licensingdiag.exe
2016-09-13 18:52 - 2016-09-07 00:24 - 07200256 _____ (Microsoft Corporation) C:\WINDOWS\system32\BingMaps.dll
2016-09-13 18:52 - 2016-09-07 00:24 - 03994624 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
2016-09-13 18:52 - 2016-09-07 00:24 - 00805888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WSShared.dll
2016-09-13 18:52 - 2016-09-07 00:24 - 00764928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Cred.dll
2016-09-13 18:52 - 2016-09-07 00:24 - 00667648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll
2016-09-13 18:52 - 2016-09-07 00:23 - 04646912 _____ (Microsoft Corporation) C:\WINDOWS\system32\xpsrchvw.exe
2016-09-13 18:52 - 2016-09-07 00:23 - 01490432 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataService.dll
2016-09-13 18:52 - 2016-09-07 00:23 - 00918016 _____ (Microsoft Corporation) C:\WINDOWS\system32\XpsFilt.dll
2016-09-13 18:52 - 2016-09-07 00:22 - 12585472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmp.dll
2016-09-13 18:52 - 2016-09-07 00:22 - 03093504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mispace.dll
2016-09-13 18:52 - 2016-09-07 00:22 - 00465920 _____ (Microsoft Corporation) C:\WINDOWS\system32\StikyNot.exe
2016-09-13 18:52 - 2016-09-07 00:21 - 00636928 _____ (Microsoft Corporation) C:\WINDOWS\system32\hgcpl.dll
2016-09-13 18:52 - 2016-09-07 00:21 - 00620544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XpsFilt.dll
2016-09-13 18:52 - 2016-09-07 00:21 - 00613376 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSync.dll
2016-09-13 18:52 - 2016-09-07 00:20 - 06976000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
2016-09-13 18:52 - 2016-09-07 00:20 - 03585536 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsThresholdAdminFl owUI.dll
2016-09-13 18:52 - 2016-09-07 00:20 - 02800128 _____ (Microsoft Corporation) C:\WINDOWS\system32\netshell.dll
2016-09-13 18:52 - 2016-09-07 00:20 - 01385472 _____ (Microsoft Corporation) C:\WINDOWS\system32\usercpl.dll
2016-09-13 18:52 - 2016-09-07 00:20 - 00683008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.BackgroundT ransfer.dll
2016-09-13 18:52 - 2016-09-07 00:20 - 00581632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinapi.dll
2016-09-13 18:52 - 2016-09-07 00:20 - 00513024 _____ (Microsoft Corporation) C:\WINDOWS\system32\hnetcfg.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 06471168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspaint.exe
2016-09-13 18:52 - 2016-09-07 00:19 - 04078592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dbgeng.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 03589120 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2016-09-13 18:52 - 2016-09-07 00:19 - 03555840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xpsrchvw.exe
2016-09-13 18:52 - 2016-09-07 00:19 - 02902528 _____ (Microsoft Corporation) C:\WINDOWS\system32\themeui.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 02798080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 02610176 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkMobileSettings.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 01997312 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActiveSyncProvider.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 01213440 _____ (Microsoft Corporation) C:\WINDOWS\system32\sdengin2.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 01141248 _____ (Microsoft Corporation) C:\WINDOWS\system32\winipcsecproc.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 00733184 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
2016-09-13 18:52 - 2016-09-07 00:19 - 00527872 _____ (Microsoft Corporation) C:\WINDOWS\system32\w32time.dll
2016-09-13 18:52 - 2016-09-07 00:18 - 05503488 _____ (Microsoft Corporation) C:\WINDOWS\system32\d2d1.dll
2016-09-13 18:52 - 2016-09-07 00:17 - 05123072 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbgeng.dll
2016-09-13 18:52 - 2016-09-07 00:17 - 02062336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
2016-09-13 18:52 - 2016-09-07 00:16 - 04759040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
2016-09-13 18:52 - 2016-09-07 00:16 - 02635776 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Logon.dll
2016-09-13 18:52 - 2016-09-07 00:16 - 01984000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssrch.dll
2016-09-13 18:52 - 2016-09-07 00:16 - 01582080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
2016-09-13 18:52 - 2016-09-07 00:16 - 00574976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hgcpl.dll
2016-09-13 18:52 - 2016-09-07 00:16 - 00162816 _____ (Microsoft Corporation) C:\WINDOWS\system32\enrollmentapi.dll
2016-09-13 18:52 - 2016-09-07 00:15 - 02772480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
2016-09-13 18:52 - 2016-09-07 00:15 - 01755648 _____ (Microsoft Corporation) C:\WINDOWS\system32\dui70.dll
2016-09-13 18:52 - 2016-09-07 00:15 - 01556992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OpcServices.dll
2016-09-13 18:52 - 2016-09-07 00:15 - 00802816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntshrui.dll
2016-09-13 18:52 - 2016-09-07 00:14 - 03355136 _____ (Microsoft Corporation) C:\WINDOWS\system32\msftedit.dll
2016-09-13 18:52 - 2016-09-07 00:14 - 02519552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themecpl.dll
2016-09-13 18:52 - 2016-09-07 00:14 - 02000896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.appcore.dll
2016-09-13 18:52 - 2016-09-07 00:14 - 01799680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Logon.dll
2016-09-13 18:52 - 2016-09-07 00:14 - 01097216 _____ (Microsoft Corporation) C:\WINDOWS\system32\dosvc.dll
2016-09-13 18:52 - 2016-09-07 00:13 - 01390592 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Shell.dll
2016-09-13 18:52 - 2016-09-07 00:13 - 00984576 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncCore.dll
2016-09-13 18:52 - 2016-09-07 00:13 - 00711680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3D12.dll
2016-09-13 18:52 - 2016-09-07 00:12 - 02632192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpcore.dll
2016-09-13 18:52 - 2016-09-07 00:12 - 01036288 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Streaming.dll
2016-09-13 18:52 - 2016-09-07 00:12 - 00899072 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3D12.dll
2016-09-13 18:52 - 2016-09-07 00:11 - 00958976 _____ (Microsoft Corporation) C:\WINDOWS\system32\RemoteNaturalLanguage.dll
2016-09-13 18:52 - 2016-09-07 00:10 - 01087488 _____ (Microsoft Corporation) C:\WINDOWS\system32\reseteng.dll
2016-09-13 18:52 - 2016-09-07 00:10 - 00770048 _____ (Microsoft Corporation) C:\WINDOWS\system32\certca.dll
2016-09-13 18:52 - 2016-09-07 00:10 - 00627200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\certca.dll
2016-09-13 18:52 - 2016-09-07 00:09 - 00824832 _____ (Microsoft Corporation) C:\WINDOWS\system32\adtschema.dll
2016-09-13 18:52 - 2016-09-07 00:09 - 00063488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msobjs.dll
2016-09-13 18:52 - 2016-09-07 00:09 - 00063488 _____ (Microsoft Corporation) C:\WINDOWS\system32\msobjs.dll
2016-09-13 18:52 - 2016-09-07 00:09 - 00058368 _____ (Microsoft Corporation) C:\WINDOWS\system32\csrsrv.dll
2016-09-13 18:52 - 2016-09-06 23:57 - 00461824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
2016-09-13 18:51 - 2016-09-07 01:23 - 00692136 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppwinob.dll
2016-09-13 18:51 - 2016-09-07 01:22 - 00431296 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcryptprimitives.dll
2016-09-13 18:51 - 2016-09-07 01:19 - 00360480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcryptprimitives.dll
2016-09-13 18:51 - 2016-09-07 00:40 - 00285184 _____ (Microsoft Corporation) C:\WINDOWS\system32\oemlicense.dll
2016-09-13 18:51 - 2016-09-07 00:39 - 00238592 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Streaming.ps.dll
2016-09-13 18:51 - 2016-09-07 00:39 - 00090624 _____ (Microsoft Corporation) C:\WINDOWS\system32\FingerprintEnrollment.dll
2016-09-13 18:51 - 2016-09-07 00:38 - 00413696 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.Midi.dll
2016-09-13 18:51 - 2016-09-07 00:38 - 00203776 _____ (Microsoft Corporation) C:\WINDOWS\system32\cic.dll
2016-09-13 18:51 - 2016-09-07 00:38 - 00110080 _____ (Microsoft Corporation) C:\WINDOWS\system32\IdCtrls.dll
2016-09-13 18:51 - 2016-09-07 00:36 - 00237056 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkDesktopSettings.dll
2016-09-13 18:51 - 2016-09-07 00:36 - 00233984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DictationManager.dll
2016-09-13 18:51 - 2016-09-07 00:35 - 00813056 _____ (Microsoft Corporation) C:\WINDOWS\system32\mqsnap.dll
2016-09-13 18:51 - 2016-09-07 00:35 - 00475648 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.BlockedShutdown.dll
2016-09-13 18:51 - 2016-09-07 00:35 - 00318976 _____ (Microsoft Corporation) C:\WINDOWS\system32\domgmt.dll
2016-09-13 18:51 - 2016-09-07 00:35 - 00258560 _____ (Microsoft Corporation) C:\WINDOWS\system32\credprovs.dll
2016-09-13 18:51 - 2016-09-07 00:35 - 00188416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.PicturePassword.dll
2016-09-13 18:51 - 2016-09-07 00:34 - 00507904 _____ (Microsoft Corporation) C:\WINDOWS\system32\mprdim.dll
2016-09-13 18:51 - 2016-09-07 00:34 - 00492544 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_StorageSense. dll
2016-09-13 18:51 - 2016-09-07 00:34 - 00392192 _____ (Microsoft Corporation) C:\WINDOWS\system32\zipfldr.dll
2016-09-13 18:51 - 2016-09-07 00:34 - 00273408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncSettings.dll
2016-09-13 18:51 - 2016-09-07 00:33 - 00224256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\prnntfy.dll
2016-09-13 18:51 - 2016-09-07 00:32 - 00689664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srv2.sys
2016-09-13 18:51 - 2016-09-07 00:32 - 00556032 _____ (Microsoft Corporation) C:\WINDOWS\system32\PsmServiceExtHost.dll
2016-09-13 18:51 - 2016-09-07 00:31 - 00769536 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppinst.dll
2016-09-13 18:51 - 2016-09-07 00:31 - 00480768 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppBroker.dll
2016-09-13 18:51 - 2016-09-07 00:31 - 00236544 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srvnet.sys
2016-09-13 18:51 - 2016-09-07 00:31 - 00183808 _____ (Microsoft Corporation) C:\WINDOWS\system32\WSSync.dll
2016-09-13 18:51 - 2016-09-07 00:30 - 01500672 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbghelp.dll
2016-09-13 18:51 - 2016-09-07 00:30 - 01159168 _____ (Microsoft Corporation) C:\WINDOWS\system32\ApplicationFrame.dll
2016-09-13 18:51 - 2016-09-07 00:30 - 01037824 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmartcardCredentialProvider.dl l
2016-09-13 18:51 - 2016-09-07 00:30 - 00912384 _____ (Microsoft Corporation) C:\WINDOWS\system32\usermgr.dll
2016-09-13 18:51 - 2016-09-07 00:30 - 00775168 _____ (Microsoft Corporation) C:\WINDOWS\system32\Display.dll
2016-09-13 18:51 - 2016-09-07 00:30 - 00607232 _____ (Microsoft Corporation) C:\WINDOWS\system32\WUDFx.dll
2016-09-13 18:51 - 2016-09-07 00:29 - 00529920 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
2016-09-13 18:51 - 2016-09-07 00:29 - 00238592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WindowsCodecsExt.dll
2016-09-13 18:51 - 2016-09-07 00:29 - 00236032 _____ (Microsoft Corporation) C:\WINDOWS\system32\licensingdiag.exe
2016-09-13 18:51 - 2016-09-07 00:28 - 00243712 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingMonitor.dll
2016-09-13 18:51 - 2016-09-07 00:27 - 03415040 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncCenter.dll
2016-09-13 18:51 - 2016-09-07 00:27 - 00799744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SRH.dll
2016-09-13 18:51 - 2016-09-07 00:27 - 00153088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WSSync.dll
2016-09-13 18:51 - 2016-09-07 00:25 - 01228800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Globalization.dll
2016-09-13 18:51 - 2016-09-07 00:25 - 01139712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIAutomationCore.dll
2016-09-13 18:51 - 2016-09-07 00:25 - 00489984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.dll
2016-09-13 18:51 - 2016-09-07 00:22 - 01113600 _____ (Microsoft Corporation) C:\WINDOWS\system32\gpedit.dll
2016-09-13 18:51 - 2016-09-07 00:20 - 06675968 _____ (Microsoft Corporation) C:\WINDOWS\system32\mspaint.exe
2016-09-13 18:51 - 2016-09-07 00:20 - 00583680 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhotoScreensaver.scr
2016-09-13 18:51 - 2016-09-07 00:19 - 02563584 _____ (Microsoft Corporation) C:\WINDOWS\system32\themecpl.dll
2016-09-13 18:51 - 2016-09-07 00:19 - 00515584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PhotoScreensaver.scr
2016-09-13 18:51 - 2016-09-07 00:19 - 00088064 _____ (Microsoft Corporation) C:\WINDOWS\system32\ImplatSetup.dll
2016-09-13 18:51 - 2016-09-07 00:11 - 00621568 _____ (Microsoft Corporation) C:\WINDOWS\system32\DbgModel.dll
2016-09-13 18:51 - 2016-09-07 00:11 - 00459776 _____ (Microsoft Corporation) C:\WINDOWS\system32\certcli.dll
2016-09-13 18:51 - 2016-09-07 00:10 - 00438784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DbgModel.dll
2016-09-13 18:40 - 2016-09-13 18:40 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignac7a7447e0 072799
2016-09-13 18:40 - 2016-09-13 18:40 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign8dae46f9de ad5d13
2016-09-13 18:40 - 2016-09-13 18:40 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign8bd4dd28ce 8d93f2
2016-09-13 18:40 - 2016-09-13 18:40 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign5b512d25f9 1a3f16
2016-09-13 18:40 - 2016-09-13 18:40 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign4cff1cccd5 6b88e3
2016-09-13 18:40 - 2016-09-13 18:40 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign39b6a2aae3 774712
2016-09-11 23:03 - 2016-09-11 23:03 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign859c52ecad 9a3e45
2016-09-11 22:36 - 2016-09-11 22:36 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsigndd1ccc74a6 8e6b3e
2016-09-11 22:36 - 2016-09-11 22:36 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign814b895583 b16072
2016-09-11 21:48 - 2016-09-11 21:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignf54767d6c6 32bf75
2016-09-11 21:48 - 2016-09-11 21:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc7e108b984 4aec90
2016-09-11 21:48 - 2016-09-11 21:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc0a414f071 833ea1
2016-09-11 21:48 - 2016-09-11 21:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign77a50f516e 995d24
2016-09-11 21:48 - 2016-09-11 21:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign52c32c3158 969642
2016-09-11 21:48 - 2016-09-11 21:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign34897bc6d4 3910cb
2016-09-10 11:15 - 2016-09-10 11:15 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TorrentsTime Media Player
2016-09-10 11:15 - 2016-09-10 11:15 - 00000000 ____D C:\Program Files (x86)\TorrentsTime Media Player
2016-09-08 23:02 - 2016-09-08 23:02 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignf2886709f4 cb0c3c
2016-09-08 23:02 - 2016-09-08 23:02 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignd276861e06 5a71c6
2016-09-08 23:02 - 2016-09-08 23:02 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign7e6bc0d203 611b51
2016-09-08 23:02 - 2016-09-08 23:02 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign35ea1b58ff 410313
2016-09-08 23:02 - 2016-09-08 23:02 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign1780ca78f1 945cfc
2016-09-08 23:02 - 2016-09-08 23:02 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign0380f7e005 7a50e5
2016-09-08 22:54 - 2016-09-08 22:54 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsigne3f1f7c670 161a4a
2016-09-08 22:54 - 2016-09-08 22:54 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsigne1947cf282 63f752
2016-09-08 22:54 - 2016-09-08 22:54 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign3453149ab2 c998dd
2016-09-08 22:50 - 2016-09-08 22:50 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignf6ac6a50ba 439e8c
2016-09-08 22:50 - 2016-09-08 22:50 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc4ee34e789 1f1cc9
2016-09-08 22:50 - 2016-09-08 22:50 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc4458fe945 a03c22
2016-09-08 22:50 - 2016-09-08 22:50 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign9efe8997fd 823d30
2016-09-08 22:50 - 2016-09-08 22:50 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign7cbe4186f8 069071
2016-09-08 22:50 - 2016-09-08 22:50 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign1135ea4cff 0fc7c6
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignca377f48c0 81ae3f
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc9e9d4c8b6 b19eb9
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc4ed5537de 3c207a
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign9f0479b90f a5b7a1
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign5d5fb14c5e f3e9af
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign509c06e4de 89eb99
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign3d7ee335c3 70ea31
2016-09-08 21:34 - 2016-09-08 21:34 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign34c068662f 768513
2016-09-08 21:33 - 2016-09-08 21:33 - 00000385 _____ C:\Users\garar\AppData\Roaminguser_gensett.xml
2016-09-08 14:36 - 2016-09-08 14:36 - 00040448 _____ (activision) C:\WINDOWS\act_win_1339.exe
2016-09-07 22:38 - 2016-09-07 22:38 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign96febe7c9d a1ec2a
2016-09-07 22:37 - 2016-09-07 22:37 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign82f6be7bcf 18a03e
2016-09-07 22:37 - 2016-09-07 22:37 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign38f309810d c8eb69
2016-09-07 21:22 - 2016-09-07 21:22 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignbad14a18ab af6018
2016-09-07 21:10 - 2016-09-07 21:10 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignf38d283361 cbe48f
2016-09-07 21:09 - 2016-09-07 21:09 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc7f13f5fd3 46d1f7
2016-09-07 21:09 - 2016-09-07 21:09 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign1ee89d82de a5b667
2016-09-07 21:08 - 2016-09-07 21:08 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignfa9c2a60a2 f06896
2016-09-07 21:08 - 2016-09-07 21:08 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignd31094be9b ffc0cf
2016-09-07 21:08 - 2016-09-07 21:08 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignc4a5fcc621 de0785
2016-09-07 21:08 - 2016-09-07 21:08 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign1cd841854f 112558
2016-09-07 21:08 - 2016-09-07 21:08 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign157c3d9942 191753
2016-09-07 21:08 - 2016-09-07 21:08 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign14cd1da5ad 0a09de
2016-09-07 20:48 - 2016-09-07 20:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign99878cab21 1dcc9b
2016-09-07 20:48 - 2016-09-07 20:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign95a40fb5c7 41bc38
2016-09-07 20:48 - 2016-09-07 20:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign7e7834b71f 748993
2016-09-07 20:48 - 2016-09-07 20:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign72017d07e1 7706c0
2016-09-07 20:48 - 2016-09-07 20:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign2a90ffca98 298e99
2016-09-07 20:48 - 2016-09-07 20:48 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign0605ecb00c b695a5
2016-09-07 20:18 - 2016-09-07 20:18 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign86711be6be a8f6d6
2016-09-06 20:04 - 2016-09-06 20:04 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignb62f5c40c4 e6d177
2016-09-06 20:04 - 2016-09-06 20:04 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign2879c30d9e af4035
2016-09-06 19:34 - 2016-09-06 19:34 - 00002237 _____ C:\Users\garar\Desktop\Discord.lnk
2016-09-06 19:34 - 2016-09-06 19:34 - 00000000 ____D C:\Users\garar\AppData\Roaming\Microsoft\Windows\S tart Menu\Programs\Hammer & Chisel, Inc
2016-09-06 19:33 - 2016-09-06 19:34 - 00000000 ____D C:\Users\garar\AppData\Local\SquirrelTemp
2016-09-06 19:33 - 2016-09-06 19:34 - 00000000 ____D C:\Users\garar\AppData\Local\Discord
2016-09-06 19:33 - 2016-09-06 19:33 - 00000000 ____D C:\ProgramData\SquirrelMachineInstalls
2016-09-05 22:08 - 2016-09-05 22:08 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign2f42856b4f 6cb846
2016-09-05 22:07 - 2016-09-05 22:07 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign644ba8466a 8d77f7
2016-09-05 22:07 - 2016-09-05 22:07 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign28bf1d258c e254d8
2016-09-05 20:45 - 2016-09-05 20:45 - 00001101 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Photoshop CC 2015.5.lnk
2016-09-05 20:45 - 2016-09-05 20:45 - 00000000 ____D C:\Users\garar\OneDrive\Documents\Adobe
2016-09-05 20:45 - 2016-09-05 20:45 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign449e2a49dc 99f333
2016-09-05 20:45 - 2016-09-05 20:45 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign3bd21d1661 7eba6c
2016-09-05 20:44 - 2016-09-05 20:44 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign29859784c4 d69297
2016-09-05 20:43 - 2016-09-19 17:59 - 00000033 _____ C:\Users\garar\AppData\Roaming\AdobeWLCMCache.dat
2016-09-05 20:43 - 2016-09-05 20:43 - 00003662 _____ C:\WINDOWS\System32\Tasks\AdobeAAMUpdater-1.0-MicrosoftAccount-gararion@gmail.com
2016-09-05 20:43 - 2016-09-05 20:43 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsigneb6385cd98 9b46c5
2016-09-05 20:43 - 2016-09-05 20:43 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignde322f5e97 dc508d
2016-09-05 20:43 - 2016-09-05 20:43 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsignac56367ba6 e4454b
2016-09-05 20:43 - 2016-09-05 20:43 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign7c14b48d67 39fa75
2016-09-05 20:43 - 2016-09-05 20:43 - 00000000 ____D C:\Users\garar\AppData\Local\Tempzxpsign263178747e 9360ca
2016-09-05 20:40 - 2016-09-05 20:43 - 00000000 ____D C:\ProgramData\regid.1986-12.com.adobe
2016-09-05 20:40 - 2016-09-05 20:43 - 00000000 ____D C:\Program Files\Common Files\Adobe
2016-09-05 20:40 - 2016-09-05 20:40 - 00002540 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Illustrator CC 2015.3.lnk
2016-09-05 20:37 - 2016-09-28 21:52 - 00000000 ___RD C:\Users\garar\Creative Cloud Files
2016-09-05 20:37 - 2016-09-28 21:52 - 00000000 ____D C:\ProgramData\boost_interprocess
2016-09-05 20:37 - 2016-09-05 20:45 - 00000000 ____D C:\Program Files\Adobe
2016-09-05 20:35 - 2016-09-05 20:35 - 00001302 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Creative Cloud.lnk
2016-09-05 20:35 - 2016-09-05 20:35 - 00001290 _____ C:\Users\Public\Desktop\Adobe Creative Cloud.lnk
2016-09-05 19:23 - 2016-09-05 19:23 - 00000000 ____D C:\Users\garar\AppData\Roaming\Trimble Connect for SketchUp
2016-09-05 18:05 - 2016-09-05 18:05 - 00000000 ____D C:\Users\garar\AppData\Roaming\SketchUp
2016-09-05 17:55 - 2016-09-05 17:55 - 00001953 ____N C:\Users\Public\Desktop\Style Builder 2016.lnk
2016-09-05 17:55 - 2016-09-05 17:55 - 00001887 ____N C:\Users\Public\Desktop\LayOut 2016.lnk
2016-09-05 17:55 - 2016-09-05 17:55 - 00001808 ____N C:\Users\Public\Desktop\SketchUp 2016.lnk
2016-09-05 17:55 - 2016-09-05 17:55 - 00000000 ____D C:\ProgramData\SketchUp
2016-09-05 17:55 - 2016-09-05 17:55 - 00000000 ____D C:\ProgramData\Reprise
2016-09-05 17:55 - 2016-09-05 17:55 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SketchUp 2016
2016-09-05 12:38 - 2016-09-05 12:38 - 00000000 ____D C:\ProgramData\LogiShrd
2016-09-05 12:26 - 2010-06-02 04:55 - 00527192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_7.dll
2016-09-05 12:26 - 2010-06-02 04:55 - 00518488 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_7.dll
2016-09-05 12:26 - 2010-06-02 04:55 - 00239960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_7.dll
2016-09-05 12:26 - 2010-06-02 04:55 - 00176984 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_7.dll
2016-09-05 12:26 - 2010-06-02 04:55 - 00077656 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_5.dll
2016-09-05 12:26 - 2010-06-02 04:55 - 00074072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_5.dll
2016-09-05 12:26 - 2010-05-26 11:41 - 01907552 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dcsx_43.dll
2016-09-05 12:26 - 2010-05-26 11:41 - 01868128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dcsx_43.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00530776 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_6.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00528216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_6.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00238936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_6.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00176984 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_6.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00078680 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_4.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00074072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_4.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00024920 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_7.dll
2016-09-05 12:26 - 2010-02-04 10:01 - 00022360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_7.dll
2016-09-05 12:26 - 2009-09-04 17:44 - 00517960 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_5.dll
2016-09-05 12:26 - 2009-09-04 17:44 - 00515416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_5.dll
2016-09-05 12:26 - 2009-09-04 17:44 - 00238936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_5.dll
2016-09-05 12:26 - 2009-09-04 17:44 - 00176968 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_5.dll
2016-09-05 12:26 - 2009-09-04 17:44 - 00073544 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_3.dll
2016-09-05 12:26 - 2009-09-04 17:44 - 00069464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_3.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 05554512 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dcsx_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 05501792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dcsx_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 02582888 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 02475352 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 01974616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 01892184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 00523088 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 00453456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 00285024 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx11_42.dll
2016-09-05 12:26 - 2009-09-04 17:29 - 00235344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx11_42.dll
2016-09-05 12:26 - 2009-03-16 14:18 - 00521560 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_4.dll
2016-09-05 12:26 - 2009-03-16 14:18 - 00517448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_4.dll
2016-09-05 12:26 - 2009-03-09 15:27 - 05425496 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_41.dll
2016-09-05 12:26 - 2009-03-09 15:27 - 04178264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_41.dll
2016-09-05 12:26 - 2009-03-09 15:27 - 02430312 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_41.dll
2016-09-05 12:26 - 2009-03-09 15:27 - 01846632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_41.dll
2016-09-05 12:26 - 2009-03-09 15:27 - 00520544 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_41.dll
2016-09-05 12:26 - 2009-03-09 15:27 - 00453456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_41.dll
2016-09-05 12:25 - 2009-03-16 14:18 - 00235352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_4.dll
2016-09-05 12:25 - 2009-03-16 14:18 - 00174936 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_4.dll
2016-09-05 12:25 - 2009-03-16 14:18 - 00024920 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_6.dll
2016-09-05 12:25 - 2009-03-16 14:18 - 00022360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_6.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00518480 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_3.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00514384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_3.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00235856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_3.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00175440 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_3.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00074576 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_2.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00070992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_2.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00025936 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_5.dll
2016-09-05 12:25 - 2008-10-27 10:04 - 00023376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_5.dll
2016-09-05 12:25 - 2008-10-15 06:22 - 05631312 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_40.dll
2016-09-05 12:25 - 2008-10-15 06:22 - 04379984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_40.dll
2016-09-05 12:25 - 2008-10-15 06:22 - 02605920 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_40.dll
2016-09-05 12:25 - 2008-10-15 06:22 - 02036576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_40.dll
2016-09-05 12:25 - 2008-10-15 06:22 - 00519000 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_40.dll
2016-09-05 12:25 - 2008-10-15 06:22 - 00452440 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_40.dll
2016-09-05 12:25 - 2008-07-31 10:41 - 00238088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_2.dll
2016-09-05 12:25 - 2008-07-31 10:41 - 00177672 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_2.dll
2016-09-05 12:25 - 2008-07-31 10:41 - 00072200 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_1.dll
2016-09-05 12:25 - 2008-07-31 10:41 - 00068616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_1.dll
2016-09-05 12:25 - 2008-07-31 10:40 - 00513544 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_2.dll
2016-09-05 12:25 - 2008-07-31 10:40 - 00509448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_2.dll
2016-09-05 12:25 - 2008-07-10 11:01 - 00467984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_39.dll
2016-09-05 12:25 - 2008-07-10 11:00 - 04992520 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_39.dll
2016-09-05 12:25 - 2008-07-10 11:00 - 03851784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_39.dll
2016-09-05 12:25 - 2008-07-10 11:00 - 01942552 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_39.dll
2016-09-05 12:25 - 2008-07-10 11:00 - 01493528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_39.dll
2016-09-05 12:25 - 2008-07-10 11:00 - 00540688 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_39.dll
2016-09-05 12:25 - 2008-05-30 14:19 - 00511496 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_1.dll
2016-09-05 12:25 - 2008-05-30 14:19 - 00507400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_1.dll
2016-09-05 12:25 - 2008-05-30 14:18 - 00238088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_1.dll
2016-09-05 12:25 - 2008-05-30 14:18 - 00177672 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_1.dll
2016-09-05 12:25 - 2008-05-30 14:17 - 00068104 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_0.dll
2016-09-05 12:25 - 2008-05-30 14:17 - 00065032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_0.dll
2016-09-05 12:25 - 2008-05-30 14:17 - 00025608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_4.dll
2016-09-05 12:25 - 2008-05-30 14:16 - 00028168 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_4.dll
2016-09-05 12:25 - 2008-05-30 14:11 - 04991496 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_38.dll
2016-09-05 12:25 - 2008-05-30 14:11 - 03850760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_38.dll
2016-09-05 12:25 - 2008-05-30 14:11 - 01941528 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_38.dll
2016-09-05 12:25 - 2008-05-30 14:11 - 01491992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_38.dll
2016-09-05 12:25 - 2008-05-30 14:11 - 00540688 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_38.dll
2016-09-05 12:25 - 2008-05-30 14:11 - 00467984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_38.dll
2016-09-05 12:25 - 2008-03-05 16:04 - 00489480 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_0.dll
2016-09-05 12:25 - 2008-03-05 16:03 - 00479752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_0.dll
2016-09-05 12:25 - 2008-03-05 16:03 - 00238088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_0.dll
2016-09-05 12:25 - 2008-03-05 16:03 - 00177672 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_0.dll
2016-09-05 12:25 - 2008-03-05 16:00 - 00028168 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_3.dll
2016-09-05 12:25 - 2008-03-05 16:00 - 00025608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_3.dll
2016-09-05 12:25 - 2008-03-05 15:56 - 04910088 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_37.dll
2016-09-05 12:25 - 2008-03-05 15:56 - 03786760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_37.dll
2016-09-05 12:25 - 2008-03-05 15:56 - 01860120 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_37.dll
2016-09-05 12:25 - 2008-03-05 15:56 - 01420824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_37.dll
2016-09-05 12:25 - 2008-02-05 23:07 - 00529424 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_37.dll
2016-09-05 12:25 - 2008-02-05 23:07 - 00462864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_37.dll
2016-09-05 12:25 - 2007-10-22 03:40 - 00411656 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_10.dll
2016-09-05 12:25 - 2007-10-22 03:39 - 00267272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_10.dll
2016-09-05 12:25 - 2007-10-22 03:37 - 00021000 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_2.dll
2016-09-05 12:25 - 2007-10-22 03:37 - 00017928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_2.dll
2016-09-05 12:25 - 2007-10-12 15:14 - 05081608 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_36.dll
2016-09-05 12:25 - 2007-10-12 15:14 - 03734536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_36.dll
2016-09-05 12:25 - 2007-10-12 15:14 - 02006552 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_36.dll
2016-09-05 12:25 - 2007-10-12 15:14 - 01374232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_36.dll
2016-09-05 12:25 - 2007-10-02 09:56 - 00508264 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_36.dll
2016-09-05 12:25 - 2007-10-02 09:56 - 00444776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_36.dll
2016-09-05 12:25 - 2007-07-20 00:57 - 00411496 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_9.dll
2016-09-05 12:25 - 2007-07-20 00:57 - 00267112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_9.dll
2016-09-05 12:25 - 2007-07-19 18:14 - 05073256 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_35.dll
2016-09-05 12:25 - 2007-07-19 18:14 - 03727720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_35.dll
2016-09-05 12:25 - 2007-07-19 18:14 - 01985904 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_35.dll
2016-09-05 12:25 - 2007-07-19 18:14 - 01358192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_35.dll
2016-09-05 12:25 - 2007-07-19 18:14 - 00508264 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_35.dll
2016-09-05 12:25 - 2007-07-19 18:14 - 00444776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_35.dll
2016-09-05 12:25 - 2007-06-20 20:49 - 00409960 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_8.dll
2016-09-05 12:25 - 2007-06-20 20:46 - 00266088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_8.dll
2016-09-05 12:25 - 2007-05-16 16:45 - 04496232 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_34.dll
2016-09-05 12:25 - 2007-05-16 16:45 - 03497832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_34.dll
2016-09-05 12:25 - 2007-05-16 16:45 - 01401200 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_34.dll
2016-09-05 12:25 - 2007-05-16 16:45 - 01124720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_34.dll
2016-09-05 12:25 - 2007-05-16 16:45 - 00506728 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_34.dll
2016-09-05 12:25 - 2007-05-16 16:45 - 00443752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_34.dll
2016-09-05 12:25 - 2007-04-04 18:55 - 00403304 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_7.dll
2016-09-05 12:25 - 2007-04-04 18:55 - 00261480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_7.dll
2016-09-05 12:25 - 2007-04-04 18:54 - 00107368 _____ (Microsoft Corporation) C:\WINDOWS\system32\xinput1_3.dll
2016-09-05 12:25 - 2007-04-04 18:53 - 00081768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xinput1_3.dll
2016-09-05 12:25 - 2007-03-15 16:57 - 00506728 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_33.dll
2016-09-05 12:25 - 2007-03-15 16:57 - 00443752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_33.dll
2016-09-05 12:25 - 2007-03-12 16:42 - 04494184 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_33.dll
2016-09-05 12:25 - 2007-03-12 16:42 - 03495784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_33.dll
2016-09-05 12:25 - 2007-03-12 16:42 - 01400176 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_33.dll
2016-09-05 12:25 - 2007-03-12 16:42 - 01123696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_33.dll
2016-09-05 12:25 - 2007-03-05 12:42 - 00017688 _____ (Microsoft Corporation) C:\WINDOWS\system32\x3daudio1_1.dll
2016-09-05 12:25 - 2007-03-05 12:42 - 00015128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\x3daudio1_1.dll
2016-09-05 12:25 - 2007-01-24 15:27 - 00393576 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_6.dll
2016-09-05 12:25 - 2007-01-24 15:27 - 00255848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_6.dll
2016-09-05 12:25 - 2006-12-08 12:02 - 00251672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_5.dll
2016-09-05 12:25 - 2006-12-08 12:00 - 00390424 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_5.dll
2016-09-05 12:25 - 2006-11-29 13:06 - 04398360 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_32.dll
2016-09-05 12:25 - 2006-11-29 13:06 - 03426072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_32.dll
2016-09-05 12:25 - 2006-11-29 13:06 - 00469264 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10.dll
2016-09-05 12:25 - 2006-11-29 13:06 - 00440080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10.dll
2016-09-05 12:25 - 2006-09-28 16:05 - 03977496 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_31.dll
2016-09-05 12:25 - 2006-09-28 16:05 - 02414360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_31.dll
2016-09-05 12:25 - 2006-09-28 16:05 - 00237848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_4.dll
2016-09-05 12:25 - 2006-09-28 16:04 - 00364824 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_4.dll
2016-09-05 12:25 - 2006-07-28 09:31 - 00083736 _____ (Microsoft Corporation) C:\WINDOWS\system32\xinput1_2.dll
2016-09-05 12:25 - 2006-07-28 09:30 - 00363288 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_3.dll
2016-09-05 12:25 - 2006-07-28 09:30 - 00236824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_3.dll
2016-09-05 12:25 - 2006-07-28 09:30 - 00062744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xinput1_2.dll
2016-09-05 12:25 - 2006-05-31 07:24 - 00230168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_2.dll
2016-09-05 12:25 - 2006-05-31 07:22 - 00354072 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_2.dll
2016-09-05 12:25 - 2006-03-31 12:41 - 03927248 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_30.dll
2016-09-05 12:25 - 2006-03-31 12:40 - 02388176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_30.dll
2016-09-05 12:25 - 2006-03-31 12:40 - 00352464 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_1.dll
2016-09-05 12:25 - 2006-03-31 12:39 - 00229584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_1.dll
2016-09-05 12:25 - 2006-03-31 12:39 - 00083664 _____ (Microsoft Corporation) C:\WINDOWS\system32\xinput1_1.dll
2016-09-05 12:25 - 2006-03-31 12:39 - 00062672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xinput1_1.dll
2016-09-05 12:25 - 2006-02-03 08:43 - 03830992 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_29.dll
2016-09-05 12:25 - 2006-02-03 08:43 - 02332368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_29.dll
2016-09-05 12:25 - 2006-02-03 08:42 - 00355536 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_0.dll
2016-09-05 12:25 - 2006-02-03 08:42 - 00230096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_0.dll
2016-09-05 12:25 - 2006-02-03 08:41 - 00016592 _____ (Microsoft Corporation) C:\WINDOWS\system32\x3daudio1_0.dll
2016-09-05 12:25 - 2006-02-03 08:41 - 00014032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\x3daudio1_0.dll
2016-09-05 12:25 - 2005-12-05 18:09 - 03815120 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_28.dll
2016-09-05 12:25 - 2005-12-05 18:09 - 02323664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_28.dll
2016-09-05 12:25 - 2005-07-22 19:59 - 03807440 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_27.dll
2016-09-05 12:25 - 2005-07-22 19:59 - 02319568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_27.dll
2016-09-05 12:25 - 2005-05-26 15:34 - 03767504 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_26.dll
2016-09-05 12:25 - 2005-05-26 15:34 - 02297552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_26.dll
2016-09-05 12:25 - 2005-03-18 17:19 - 03823312 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_25.dll
2016-09-05 12:25 - 2005-03-18 17:19 - 02337488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_25.dll
2016-09-05 12:25 - 2005-02-05 19:45 - 03544272 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_24.dll
2016-09-05 12:25 - 2005-02-05 19:45 - 02222800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_24.dll
2016-09-05 12:21 - 2016-09-05 13:07 - 00000000 ____D C:\Users\garar\AppData\Roaming\MSI
2016-09-05 12:21 - 2010-05-26 11:41 - 02526056 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_43.dll
2016-09-05 12:21 - 2010-05-26 11:41 - 02106216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_43.dll
2016-09-05 12:09 - 2016-09-05 18:05 - 00000000 ____D C:\Users\garar\AppData\Roaming\NVIDIA
2016-09-05 12:08 - 2016-09-05 12:08 - 00000000 ____D C:\Users\garar\AppData\Local\Logitech
2016-09-05 12:05 - 2016-09-25 20:16 - 00000000 ____D C:\Program Files (x86)\Overwolf
2016-09-05 12:05 - 2016-09-15 19:53 - 00003806 _____ C:\WINDOWS\System32\Tasks\Overwolf Updater Task
2016-09-05 12:05 - 2016-09-15 19:53 - 00001154 _____ C:\Users\Public\Desktop\Overwolf.lnk
2016-09-05 12:05 - 2016-09-05 12:05 - 00000000 ____D C:\Users\garar\AppData\Roaming\Microsoft\Windows\S tart Menu\Programs\Overwolf
2016-09-05 12:04 - 2016-09-28 21:52 - 00000000 ____D C:\Users\garar\AppData\Local\Overwolf
2016-09-05 12:04 - 2016-09-05 12:05 - 00000000 ____D C:\ProgramData\Overwolf
2016-09-05 12:04 - 2016-09-05 12:04 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Logitech
2016-09-05 12:03 - 2016-09-05 12:04 - 00000000 ____D C:\Program Files\Logitech Gaming Software
2016-09-05 12:02 - 2016-09-05 12:02 - 00000000 ____D C:\Users\garar\AppData\Roaming\Logitech
2016-09-05 12:02 - 2016-09-05 12:02 - 00000000 ____D C:\Users\garar\AppData\Roaming\Logishrd
2016-09-05 02:50 - 2016-09-11 21:28 - 00000000 ____D C:\Users\garar\OneDrive\Documents\The Witcher 3
2016-09-05 00:09 - 2016-09-07 22:37 - 00000000 _____ C:\Users\garar\AppData\Roaming\settings.ini
2016-09-05 00:06 - 2016-09-05 00:06 - 00001177 ____N C:\Users\Public\Desktop\Campaign Cartographer 3+.lnk
2016-09-05 00:06 - 2016-09-05 00:06 - 00000967 ____N C:\Users\Public\Desktop\Read CC3+ Manual.lnk
2016-09-05 00:06 - 2016-09-05 00:06 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ProFantasy
2016-09-05 00:06 - 2016-09-05 00:06 - 00000000 ____D C:\Program Files (x86)\ProFantasy
2016-09-05 00:04 - 2016-09-05 01:06 - 00000000 ____D C:\Users\garar\AppData\Local\IIIQF
2016-09-04 23:46 - 2016-09-04 23:46 - 00000000 ____D C:\Users\garar\AppData\Local\Steam
2016-09-04 23:45 - 2016-09-04 23:45 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Steam
2016-09-03 19:26 - 2016-09-03 19:26 - 00000935 ____N C:\Users\garar\Desktop\Fantasy Grounds.lnk
2016-09-03 19:26 - 2016-09-03 19:26 - 00000000 ____D C:\Users\garar\AppData\Roaming\Microsoft\Windows\S tart Menu\Fantasy Grounds
2016-09-03 01:34 - 2016-09-03 01:34 - 00001769 _____ C:\WINDOWS\Language_trs.ini
2016-09-03 01:10 - 2009-04-02 08:30 - 00010296 _____ C:\WINDOWS\SysWOW64\Drivers\ASUSHWIO.SYS
2016-09-02 23:37 - 2016-09-26 22:55 - 00000000 ____D C:\Users\garar\AppData\Local\CrashDumps
2016-09-02 23:37 - 2016-09-02 23:37 - 00000000 ____D C:\Program Files (x86)\ASUS
2016-09-02 23:37 - 2010-08-24 15:16 - 00013440 _____ C:\WINDOWS\SysWOW64\Drivers\AsIO.sys
2016-09-02 23:37 - 2010-06-29 15:41 - 00028672 _____ (ASUSTek Computer Inc.) C:\WINDOWS\SysWOW64\AsIO.dll
2016-09-02 23:37 - 2008-01-04 14:34 - 00011832 ____N C:\WINDOWS\SysWOW64\Drivers\AsInsHelp64.sys
2016-09-02 23:37 - 2008-01-04 14:34 - 00010216 ____N C:\WINDOWS\SysWOW64\Drivers\AsInsHelp32.sys
2016-09-02 23:35 - 2016-09-02 23:35 - 00000000 ____D C:\Users\garar\AppData\Roaming\WinRAR
2016-09-02 23:35 - 2016-09-02 23:35 - 00000000 ____D C:\Users\garar\AppData\Roaming\Microsoft\Windows\S tart Menu\Programs\WinRAR
2016-09-02 23:35 - 2016-09-02 23:35 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
2016-09-02 23:01 - 2016-09-02 23:01 - 00000000 ____D C:\Users\garar\AppData\LocalLow\Adobe
2016-09-02 23:01 - 2016-09-02 23:01 - 00000000 ____D C:\Users\garar\AppData\Local\CEF
2016-09-02 23:00 - 2016-09-28 20:52 - 00004562 _____ C:\WINDOWS\System32\Tasks\Adobe Acrobat Update Task
2016-09-02 22:59 - 2016-09-05 20:42 - 00000000 ____D C:\ProgramData\Adobe
2016-09-02 22:59 - 2016-09-05 20:33 - 00000000 ____D C:\Program Files (x86)\Adobe
2016-09-02 22:59 - 2016-09-02 23:02 - 00002457 ____N C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
2016-09-02 22:23 - 2016-09-02 22:23 - 00000000 ____D C:\Users\garar\AppData\Roaming\Macromedia
2016-09-02 22:23 - 2016-09-02 22:23 - 00000000 ____D C:\Users\garar\AppData\Local\Macromedia
2016-09-02 22:22 - 2016-09-28 21:52 - 00000000 ____D C:\Users\garar\AppData\Local\Adobe
2016-09-02 22:22 - 2016-09-28 21:30 - 00000830 _____ C:\WINDOWS\Tasks\Adobe Flash Player Updater.job
2016-09-02 22:22 - 2016-09-13 19:30 - 00003816 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
2016-09-02 21:38 - 2016-09-02 21:38 - 00003406 _____ C:\WINDOWS\System32\Tasks\Bitdefender AgentTask_AD394AE64E874073B10A89FEEC305A3C
2016-09-02 21:37 - 2016-09-28 21:50 - 00012141 _____ C:\bdlog.txt
2016-09-02 21:37 - 2016-09-02 21:37 - 00000000 ____D C:\ProgramData\bdch
2016-09-02 21:13 - 2016-09-02 21:13 - 00000385 _____ C:\WINDOWS\system32\user_gensett.xml
2016-09-02 21:08 - 2016-09-02 21:37 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Bitdefender 2016
2016-09-02 21:08 - 2016-09-02 21:08 - 00002274 ____N C:\Users\Public\Desktop\Bitdefender 2016.lnk
2016-09-02 21:08 - 2016-09-02 21:08 - 00000684 ____H C:\bdr-cf01
2016-09-02 21:07 - 2016-09-02 21:23 - 01603264 _____ (BitDefender) C:\WINDOWS\system32\Drivers\avc3.sys
2016-09-02 21:07 - 2016-09-02 21:23 - 00850464 _____ (BitDefender) C:\WINDOWS\system32\Drivers\avckf.sys
2016-09-02 21:07 - 2016-09-02 21:07 - 00000000 ____D C:\ProgramData\BDLogging
2016-09-02 21:07 - 2016-06-16 16:45 - 00299816 _____ (Bitdefender) C:\WINDOWS\system32\Drivers\ignis.sys
2016-09-02 21:07 - 2015-12-04 19:27 - 00087912 _____ (BitDefender) C:\WINDOWS\system32\Drivers\bdvedisk.sys
2016-09-02 21:07 - 2013-09-08 20:04 - 00023568 _____ (Bitdefender) C:\WINDOWS\system32\Drivers\bdelam.sys
2016-09-02 21:07 - 2007-04-11 11:11 - 00511328 _____ (Microsoft Corporation) C:\WINDOWS\capicom.dll
2016-09-02 21:03 - 2016-09-02 21:18 - 00000000 ____D C:\Users\garar\AppData\Roaming\Bitdefender
2016-09-02 21:03 - 2016-09-02 21:08 - 00253404 ____H C:\bdr-ld01
2016-09-02 21:03 - 2016-09-02 21:08 - 00009216 ____H C:\bdr-ld01.mbr
2016-09-02 21:03 - 2015-12-15 21:35 - 49760229 ____H C:\bdr-im01.gz
2016-09-02 21:03 - 2013-08-13 13:38 - 03271472 ____H C:\bdr-bz01
2016-09-02 21:02 - 2016-09-02 21:23 - 00000000 ____D C:\ProgramData\Bitdefender
2016-09-02 21:02 - 2016-09-02 21:02 - 00000000 ____D C:\Users\garar\AppData\Roaming\QuickScan
2016-09-02 21:02 - 2016-09-02 21:02 - 00000000 ____D C:\Program Files\Bitdefender
2016-09-02 21:02 - 2016-03-10 07:41 - 00520032 _____ (BitDefender S.R.L.) C:\WINDOWS\system32\Drivers\trufos.sys
2016-09-02 21:02 - 2015-12-16 05:53 - 00182936 _____ (BitDefender LLC) C:\WINDOWS\system32\Drivers\gzflt.sys
2016-09-02 21:01 - 2016-09-02 21:02 - 00000000 ____D C:\Program Files\Common Files\Bitdefender
2016-09-02 20:52 - 2016-09-02 20:52 - 00003794 _____ C:\WINDOWS\System32\Tasks\Bitdefender Agent WatchDog_65D6944A0EF74FDAB96E31112AD39864
2016-09-02 20:50 - 2016-09-28 21:52 - 00000000 ____D C:\Program Files\Bitdefender Agent
2016-09-02 20:50 - 2016-09-02 20:50 - 00000000 ____D C:\ProgramData\Bitdefender Agent
2016-09-02 03:38 - 2016-09-02 03:38 - 00000000 ____D C:\WINDOWS\system32\SleepStudy
2016-09-01 21:33 - 2016-09-01 21:33 - 00003342 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task
2016-09-01 21:32 - 2016-09-01 21:32 - 00000000 ____D C:\Users\garar\AppData\Roaming\Skype
2016-09-01 19:49 - 2016-07-27 15:25 - 00504488 ____N (Microsoft Corporation) C:\WINDOWS\system32\MpSigStub.exe
2016-09-01 19:48 - 2016-09-13 22:10 - 00000000 ____D C:\WINDOWS\system32\MRT
2016-09-01 19:48 - 2016-09-13 22:06 - 144199024 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2016-09-01 00:14 - 2016-09-01 00:14 - 00008192 _____ C:\WINDOWS\system32\config\userdiff
2016-09-01 00:14 - 2016-09-01 00:14 - 00000000 ____D C:\WINDOWS\InfusedApps
2016-09-01 00:14 - 2016-08-31 21:16 - 00000000 ____D C:\Program Files (x86)\Razer
2016-09-01 00:14 - 2016-08-31 20:41 - 00000000 ___DC C:\WINDOWS\Panther
2016-09-01 00:13 - 2016-09-01 00:13 - 00000000 ____D C:\WINDOWS\Setup
2016-09-01 00:11 - 2016-09-01 00:11 - 00000000 ____D C:\WINDOWS\OCR
2016-09-01 00:11 - 2016-09-01 00:11 - 00000000 ____D C:\Program Files\Reference Assemblies
2016-09-01 00:11 - 2016-09-01 00:11 - 00000000 ____D C:\Program Files\MSBuild
2016-09-01 00:11 - 2016-09-01 00:11 - 00000000 ____D C:\Program Files (x86)\Reference Assemblies
2016-09-01 00:11 - 2016-09-01 00:11 - 00000000 ____D C:\Program Files (x86)\MSBuild
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\winrm
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\WCN
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\sysprep
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\slmgr
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\Printing_Admin_Scripts
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\0409
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\system32\winrm
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\system32\WCN
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\system32\slmgr
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\system32\Printing_Admin_Scripts
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\system32\0409
2016-09-01 00:10 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\DigitalLocker
2016-09-01 00:09 - 2016-09-06 21:00 - 00828408 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
2016-09-01 00:09 - 2016-09-06 21:00 - 00176632 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
2016-09-01 00:08 - 2016-09-01 19:51 - 00015703 _____ C:\WINDOWS\system32\OEMDefaultAssociations.xml
2016-09-01 00:08 - 2016-09-01 00:34 - 00028672 _____ C:\WINDOWS\system32\config\BCD-Template
2016-09-01 00:08 - 2016-09-01 00:06 - 00230912 _____ (Microsoft Corporation) C:\WINDOWS\system32\msclmd.dll
2016-09-01 00:08 - 2016-09-01 00:06 - 00215943 _____ C:\WINDOWS\SysWOW64\dssec.dat
2016-09-01 00:08 - 2016-09-01 00:06 - 00215943 _____ C:\WINDOWS\system32\dssec.dat
2016-09-01 00:08 - 2016-09-01 00:06 - 00209408 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msclmd.dll
2016-09-01 00:08 - 2016-09-01 00:06 - 00017463 _____ C:\WINDOWS\system32\Drivers\etc\services
2016-09-01 00:08 - 2016-09-01 00:06 - 00008798 _____ C:\WINDOWS\SysWOW64\icrav03.rat
2016-09-01 00:08 - 2016-09-01 00:06 - 00008798 _____ C:\WINDOWS\system32\icrav03.rat
2016-09-01 00:08 - 2016-09-01 00:06 - 00003683 _____ C:\WINDOWS\system32\Drivers\etc\lmhosts.sam
2016-09-01 00:08 - 2016-09-01 00:06 - 00001988 _____ C:\WINDOWS\SysWOW64\ticrf.rat
2016-09-01 00:08 - 2016-09-01 00:06 - 00001988 _____ C:\WINDOWS\system32\ticrf.rat
2016-09-01 00:08 - 2016-09-01 00:06 - 00001358 _____ C:\WINDOWS\system32\Drivers\etc\protocol
2016-09-01 00:08 - 2016-09-01 00:06 - 00000858 _____ C:\WINDOWS\system32\DefaultQuestions.json
2016-09-01 00:08 - 2016-09-01 00:06 - 00000741 _____ C:\WINDOWS\SysWOW64\NOISE.DAT
2016-09-01 00:08 - 2016-09-01 00:06 - 00000741 _____ C:\WINDOWS\system32\NOISE.DAT
2016-09-01 00:08 - 2016-09-01 00:06 - 00000407 _____ C:\WINDOWS\system32\Drivers\etc\networks
2016-09-01 00:08 - 2016-09-01 00:06 - 00000389 _____ C:\WINDOWS\system32\AutoWorkplace.exe.config
2016-09-01 00:08 - 2016-09-01 00:06 - 00000219 _____ C:\WINDOWS\system.ini
2016-09-01 00:08 - 2016-09-01 00:06 - 00000092 _____ C:\WINDOWS\win.ini
2016-09-01 00:07 - 2016-09-28 21:51 - 00000000 ___RD C:\WINDOWS\DevicesFlow
2016-09-01 00:07 - 2016-09-28 15:24 - 00000000 ___HD C:\Program Files\WindowsApps
2016-09-01 00:07 - 2016-09-28 15:24 - 00000000 ____D C:\WINDOWS\AppReadiness
2016-09-01 00:07 - 2016-09-19 22:35 - 00000000 ____D C:\WINDOWS\rescache
2016-09-01 00:07 - 2016-09-15 21:41 - 00000000 ____D C:\WINDOWS\system32\appraiser
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ___SD C:\WINDOWS\SysWOW64\F12
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ___SD C:\WINDOWS\system32\F12
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ___RD C:\WINDOWS\PrintDialog
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ___RD C:\WINDOWS\ImmersiveControlPanel
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\SysWOW64\Dism
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\SysWOW64\AdvancedInstallers
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\system32\SystemResetPlatform
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\system32\setup
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\system32\oobe
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\system32\migwiz
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\system32\Dism
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\WINDOWS\system32\AdvancedInstallers
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\Program Files\Windows Photo Viewer
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\Program Files\Windows Defender
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\Program Files (x86)\Windows Photo Viewer
2016-09-01 00:07 - 2016-09-15 19:35 - 00000000 ____D C:\Program Files (x86)\Windows Defender
2016-09-01 00:07 - 2016-09-13 19:30 - 00000000 ____D C:\WINDOWS\SysWOW64\Macromed
2016-09-01 00:07 - 2016-09-13 19:30 - 00000000 ____D C:\WINDOWS\system32\Macromed
2016-09-01 00:07 - 2016-09-11 00:05 - 00000000 ____D C:\WINDOWS\LiveKernelReports
2016-09-01 00:07 - 2016-09-05 20:34 - 00000000 ____D C:\Program Files\Common Files\microsoft shared
2016-09-01 00:07 - 2016-09-03 16:37 - 00000000 ____D C:\WINDOWS\appcompat
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 __RSD C:\WINDOWS\Media
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ___SD C:\WINDOWS\system32\DiagSvcs
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ___RD C:\WINDOWS\PurchaseDialog
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\WINDOWS\system32\WinBioPlugIns
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\WINDOWS\Provisioning
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\WINDOWS\PolicyDefinitions
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\WINDOWS\bcastdvr
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\Program Files\Windows Portable Devices
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\Program Files\Windows Multimedia Platform
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\Program Files (x86)\Windows Portable Devices
2016-09-01 00:07 - 2016-09-01 19:51 - 00000000 ____D C:\Program Files (x86)\Windows Multimedia Platform
2016-09-01 00:07 - 2016-09-01 19:49 - 00000000 ____D C:\WINDOWS\system32\SecureBootUpdates
2016-09-01 00:07 - 2016-09-01 00:11 - 00000000 ____D C:\WINDOWS\SystemApps
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ___SD C:\WINDOWS\SysWOW64\DiagSvcs
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ___SD C:\WINDOWS\system32\dsc
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\setup
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\oobe
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\MUI
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\SysWOW64\Com
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\system32\MUI
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\system32\Com
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\IME
2016-09-01 00:07 - 2016-09-01 00:10 - 00000000 ____D C:\Program Files\Common Files\System
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 __RHD C:\Users\Public\Libraries
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ___SD C:\WINDOWS\SysWOW64\Nui
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ___SD C:\WINDOWS\system32\Nui
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ___SD C:\WINDOWS\Downloaded Program Files
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ___RD C:\WINDOWS\Offline Web Pages
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ___RD C:\WINDOWS\DesktopTileResources
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\SysWOW64\WinMetadata
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\SysWOW64\migwiz
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\SysWOW64\MailContactsCalendarSync
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\SysWOW64\icsxml
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\SysWOW64\downlevel
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\SysWOW64\Bthprops
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\system32\WinMetadata
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\system32\MsDtc
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\system32\MailContactsCalendarSync
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\system32\icsxml
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\system32\ias
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\system32\downlevel
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\system32\Bthprops
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\Registration
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\L2Schemas
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\Cursors
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\WINDOWS\addins
2016-09-01 00:07 - 2016-09-01 00:08 - 00000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 __SHD C:\Program Files\Windows Sidebar
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 __SHD C:\Program Files (x86)\Windows Sidebar
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ___SD C:\WINDOWS\SysWOW64\Configuration
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ___SD C:\WINDOWS\system32\Configuration
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\Web
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\Vss
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\tracing
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\TAPI
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\SMI
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\ras
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\NDF
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\MsDtc
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\Ipmi
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\InputMethod
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\inetsrv
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\IME
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\GroupPolicyUsers
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\FxsTmp
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SysWOW64\AppLocker
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SystemResources
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\winevt
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\ras
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\ProximityToast
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\PointOfService
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\NDF
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\Ipmi
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\InputMethod
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\inetsrv
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\IME
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\GroupPolicyUsers
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\config\Journal
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\AppLocker
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SKB
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\security
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\schemas
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\SchCache
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\Resources
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\PLA
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\Performance
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\ModemLogs
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\InputMethod
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\Globalization
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\Branding
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\Program Files\Windows NT
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\Program Files\Common Files\Services
2016-09-01 00:07 - 2016-09-01 00:07 - 00000000 ____D C:\Program Files (x86)\Windows NT
2016-09-01 00:07 - 2016-08-31 23:36 - 00000000 ____D C:\WINDOWS\system32\Sysprep
2016-09-01 00:07 - 2016-08-31 20:50 - 00000000 ____D C:\WINDOWS\Help
2016-09-01 00:07 - 2016-08-31 20:46 - 00000000 ___RD C:\WINDOWS\MiracastView
2016-09-01 00:07 - 2016-08-31 20:44 - 00000000 ____D C:\WINDOWS\system32\WinBioDatabase
2016-09-01 00:07 - 2016-08-31 20:40 - 00000000 ____D C:\WINDOWS\system32\spool
2016-09-01 00:07 - 2016-08-31 20:40 - 00000000 ____D C:\WINDOWS\system32\FxsTmp
2016-09-01 00:07 - 2016-08-31 20:39 - 00000000 ____D C:\ProgramData\USOPrivate
2016-09-01 00:07 - 2016-06-27 19:44 - 00000000 ____D C:\WINDOWS\ELAMBKUP
2016-09-01 00:06 - 2016-09-28 21:58 - 00000000 ____D C:\WINDOWS\INF
2016-09-01 00:00 - 2016-09-15 21:41 - 00000000 ____D C:\WINDOWS\CbsTemp
2016-08-31 23:58 - 2016-09-28 21:51 - 00524288 ___SH C:\WINDOWS\system32\config\BBI
2016-08-31 23:58 - 2016-09-25 20:14 - 00065536 ___SH C:\WINDOWS\system32\config\ELAM
2016-08-31 23:58 - 2016-09-01 00:10 - 00000000 ____D C:\WINDOWS\servicing
2016-08-31 23:58 - 2016-09-01 00:07 - 00000000 ____D C:\WINDOWS\system32\SMI
2016-08-31 23:58 - 2015-10-30 02:33 - 00000164 _____ C:\WINDOWS\system32\config\FP
2016-08-31 23:38 - 2016-09-28 21:51 - 00000006 ____H C:\WINDOWS\Tasks\SA.DAT
2016-08-31 23:38 - 2016-08-31 23:38 - 00000000 _SHDL C:\Users\Default\My Documents
2016-08-31 23:38 - 2016-08-31 23:38 - 00000000 _SHDL C:\Users\Default User
2016-08-31 23:38 - 2016-08-31 23:38 - 00000000 _SHDL C:\Users\All Users
2016-08-31 23:38 - 2016-08-31 23:38 - 00000000 _SHDL C:\Documents and Settings
2016-08-31 23:36 - 2016-08-31 23:36 - 00000000 ____D C:\WINDOWS\SysWOW64\RTCOM
2016-08-31 23:36 - 2016-08-31 23:36 - 00000000 ____D C:\Program Files\Realtek
2016-08-31 23:36 - 2016-08-31 23:36 - 00000000 ____D C:\Program Files\Common Files\logishrd
2016-08-31 23:36 - 2016-08-31 23:36 - 00000000 ____D C:\Program Files\Common Files\Atheros
2016-08-31 23:36 - 2016-08-31 21:15 - 00000000 ____D C:\ProgramData\Razer
2016-08-31 23:35 - 2016-09-15 19:35 - 00216712 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2016-08-31 23:35 - 2016-08-31 23:35 - 00000000 ____D C:\WINDOWS\ServiceProfiles
2016-08-31 22:17 - 2016-08-31 22:17 - 00003132 _____ C:\WINDOWS\System32\Tasks\MSIOSDx86_Host
2016-08-31 22:17 - 2016-08-31 22:17 - 00003132 _____ C:\WINDOWS\System32\Tasks\MSIOSDx64_Host
2016-08-31 22:17 - 2016-08-31 22:17 - 00003058 _____ C:\WINDOWS\System32\Tasks\MSISW_Host
2016-08-31 22:17 - 2016-08-31 22:17 - 00001837 ____N C:\Users\Public\Desktop\Dragon Eye.lnk
2016-08-31 22:17 - 2016-08-31 22:17 - 00000000 ____D C:\Program Files\MSI
2016-08-31 22:17 - 2016-08-31 22:17 - 00000000 ____D C:\Intel
2016-08-31 22:16 - 2016-09-03 19:37 - 00000000 ____D C:\MSI
2016-08-31 22:16 - 2016-08-31 22:17 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MSI
2016-08-31 22:16 - 2016-08-31 22:17 - 00000000 ____D C:\Program Files (x86)\MSI
2016-08-31 22:16 - 2016-08-31 22:16 - 00001198 ____N C:\Users\Public\Desktop\MSI Gaming APP.lnk
2016-08-31 22:16 - 2015-08-18 09:51 - 01692840 _____ (MSI) C:\WINDOWS\SysWOW64\muachost.exe
2016-08-31 22:16 - 2015-07-27 01:37 - 00041760 _____ (FINTEK Corp.) C:\WINDOWS\system32\Drivers\I2cHkBurn.sys
2016-08-31 22:16 - 2015-07-27 01:37 - 00031520 _____ (TODO: <公司名稱>) C:\WINDOWS\system32\FintekIcon1.dll
2016-08-31 22:06 - 2016-08-31 22:14 - 00000000 ____D C:\Users\garar\AppData\Local\NVIDIA Corporation
2016-08-31 22:05 - 2016-08-31 22:14 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
2016-08-31 22:05 - 2016-08-31 22:05 - 00000000 ____D C:\Program Files (x86)\VulkanRT
2016-08-31 22:05 - 2016-07-10 22:34 - 01887800 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvCamera64.dll
2016-08-31 22:05 - 2016-07-10 22:34 - 01595840 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvCamera32.dll
2016-08-31 22:05 - 2016-07-10 18:37 - 00127424 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvStreaming.exe
2016-08-31 22:05 - 2016-06-14 16:01 - 01767944 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspcap64.dll
2016-08-31 22:05 - 2016-06-14 16:01 - 01756424 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspbridge64.dll
2016-08-31 22:05 - 2016-06-14 16:01 - 01377800 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspcap.dll
2016-08-31 22:05 - 2016-06-14 16:01 - 01316184 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspbridge.dll
2016-08-31 22:05 - 2016-06-14 16:01 - 00112216 _____ C:\WINDOWS\system32\NvRtmpStreamer64.dll
2016-08-31 22:05 - 2016-05-03 22:23 - 00129824 _____ C:\WINDOWS\SysWOW64\vulkan-1.dll
2016-08-31 22:05 - 2016-05-03 22:22 - 00130848 _____ C:\WINDOWS\system32\vulkan-1.dll
2016-08-31 22:05 - 2016-05-03 22:22 - 00045344 _____ C:\WINDOWS\system32\vulkaninfo.exe
2016-08-31 22:05 - 2016-05-03 22:22 - 00040224 _____ C:\WINDOWS\SysWOW64\vulkaninfo.exe
2016-08-31 22:05 - 2010-05-26 11:41 - 02401112 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_43.dll
2016-08-31 22:05 - 2010-05-26 11:41 - 01998168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_43.dll
2016-08-31 22:05 - 2010-05-26 11:41 - 00511328 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_43.dll
2016-08-31 22:05 - 2010-05-26 11:41 - 00470880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_43.dll
2016-08-31 22:05 - 2010-05-26 11:41 - 00276832 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx11_43.dll
2016-08-31 22:05 - 2010-05-26 11:41 - 00248672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx11_43.dll
2016-08-31 22:03 - 2016-07-15 14:15 - 00046016 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvhdap64.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 39977920 _____ C:\WINDOWS\system32\nvcompiler.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 35117112 _____ C:\WINDOWS\SysWOW64\nvcompiler.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 31680568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvoglv64.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 25442240 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvoglv32.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 17463992 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvd3dumx.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 10700592 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvopencl.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 10656296 _____ C:\WINDOWS\system32\nvptxJitCompiler.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 10243600 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuda.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 09028360 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvopencl.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 08742360 _____ C:\WINDOWS\SysWOW64\nvptxJitCompiler.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 08622576 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuda.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 03382240 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvapi.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 02868160 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuvid.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 02497984 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuvid.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 01939000 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispco6436881.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 01571776 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispgenco6436881.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00999872 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvFBC64.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00930360 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFR64.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00909248 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvFBC.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00852024 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFR.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00802816 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncMFTH264.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00801792 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncMFThevc.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00694488 _____ C:\WINDOWS\system32\nvfatbinaryLoader.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00644184 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncMFTH264.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00642440 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncMFThevc.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00612064 _____ C:\WINDOWS\system32\nvmcumd.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00583920 _____ C:\WINDOWS\SysWOW64\nvfatbinaryLoader.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00563856 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvumdshimx.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00462904 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvumdshim.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00444472 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFROpenGL.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00413488 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncodeAPI64.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00393152 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFROpenGL.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00383936 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvDecMFTMjpeg.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00348216 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvDecMFTMjpeg.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00345800 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncodeAPI.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00177952 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvinitx.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00155952 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvinit.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00153232 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvoglshim64.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00131584 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvoglshim32.dll
2016-08-31 22:03 - 2016-07-10 22:34 - 00040084 _____ C:\WINDOWS\system32\nvinfo.pb
2016-08-31 22:03 - 2016-04-14 01:38 - 00113216 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvaudcap64v.dll
2016-08-31 22:03 - 2016-04-14 01:38 - 00102976 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvaudcap32v.dll
2016-08-31 22:03 - 2016-04-14 01:38 - 00056384 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvad64v.sys
2016-08-31 22:02 - 2016-08-31 22:02 - 00000000 ____D C:\NVIDIA
2016-08-31 21:42 - 2016-09-26 22:05 - 00001056 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Моzillа Firеfох.lnk
2016-08-31 21:42 - 2016-09-26 22:05 - 00000000 ____D C:\Program Files (x86)\Mozilla Firefox
2016-08-31 21:42 - 2016-08-31 21:50 - 00000000 ____D C:\Users\garar\AppData\Local\Mozilla
2016-08-31 21:42 - 2016-08-31 21:42 - 00001220 _____ C:\Users\Public\Desktop\Mozilla Firefox.lnk
2016-08-31 21:42 - 2016-08-31 21:42 - 00000000 ____D C:\Users\garar\AppData\Roaming\Mozilla
2016-08-31 21:42 - 2016-08-31 21:42 - 00000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
2016-08-31 21:16 - 2016-08-31 21:16 - 00000000 ____D C:\Users\garar\AppData\Local\Razer
2016-08-31 21:16 - 2016-08-31 21:16 - 00000000 ____D C:\Users\garar\AppData\Local\NVIDIA
2016-08-31 21:15 - 2016-08-31 21:15 - 00000000 ____D C:\Users\garar\AppData\Local\Razer_Inc
2016-08-31 21:15 - 2015-12-14 17:24 - 00130880 _____ (Razer, Inc.) C:\WINDOWS\system32\Drivers\rzpnk.sys
2016-08-31 21:14 - 2015-09-22 17:36 - 00037184 _____ (Razer, Inc.) C:\WINDOWS\system32\Drivers\rzpmgrk.sys
2016-08-31 21:13 - 2016-08-31 21:13 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Razer
2016-08-31 20:51 - 2016-09-28 21:51 - 00000000 ____D C:\ProgramData\NVIDIA
2016-08-31 20:50 - 2016-08-31 21:39 - 00000000 ____D C:\Users\garar\AppData\Local\MicrosoftEdge
2016-08-31 20:50 - 2016-07-10 18:58 - 06385720 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcpl.dll
2016-08-31 20:50 - 2016-07-10 18:58 - 02465848 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvc64.dll
2016-08-31 20:50 - 2016-07-10 18:58 - 01762752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvcr.dll
2016-08-31 20:50 - 2016-07-10 18:58 - 01362880 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvvsvc.exe
2016-08-31 20:50 - 2016-07-10 18:58 - 00546240 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshext.dll
2016-08-31 20:50 - 2016-07-10 18:58 - 00393784 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvmctray.dll
2016-08-31 20:50 - 2016-07-10 18:58 - 00083512 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshextr.dll
2016-08-31 20:50 - 2016-07-10 18:58 - 00069568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvshext.dll
2016-08-31 20:50 - 2016-07-07 13:05 - 07211925 _____ C:\WINDOWS\system32\nvcoproc.bin
2016-08-31 20:49 - 2016-09-28 21:58 - 00879220 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2016-08-31 20:49 - 2016-09-01 21:32 - 00000000 ____D C:\ProgramData\NVIDIA Corporation
2016-08-31 20:49 - 2016-08-31 22:05 - 00000000 ____D C:\Program Files\NVIDIA Corporation
2016-08-31 20:49 - 2016-08-31 22:05 - 00000000 ____D C:\Program Files (x86)\NVIDIA Corporation
2016-08-31 20:49 - 2016-08-27 00:30 - 00233016 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.dll
2016-08-31 20:49 - 2016-08-27 00:30 - 00219072 _____ (Khronos Group) C:\WINDOWS\SysWOW64\OpenCL.dll
2016-08-31 20:48 - 2016-09-28 21:52 - 00000000 ___RD C:\Users\garar\OneDrive
2016-08-31 20:48 - 2016-09-01 21:33 - 00002367 ____N C:\Users\garar\AppData\Roaming\Microsoft\Windows\S tart Menu\Programs\OneDrive.lnk
2016-08-31 20:48 - 2016-08-31 20:48 - 00000000 ____D C:\ProgramData\Microsoft OneDrive
2016-08-31 20:47 - 2016-08-31 20:47 - 00000000 ____D C:\Users\garar\AppData\Local\Comms
2016-08-31 20:46 - 2016-09-15 19:52 - 00000000 ____D C:\Users\garar\AppData\Local\Packages
2016-08-31 20:46 - 2016-09-05 20:45 - 00000000 ____D C:\Users\garar\AppData\Roaming\Adobe
2016-08-31 20:46 - 2016-09-01 19:54 - 00000000 __RHD C:\Users\Public\AccountPictures
2016-08-31 20:46 - 2016-08-31 20:46 - 00000000 ____D C:\Users\garar\AppData\Local\TileDataLayer
2016-08-31 20:46 - 2016-08-31 20:46 - 00000000 ____D C:\Users\garar\AppData\Local\Publishers
2016-08-31 20:44 - 2016-09-08 21:30 - 00000000 ____D C:\Users\garar
2016-08-31 20:44 - 2016-08-31 20:44 - 00000020 ___SH C:\Users\garar\ntuser.ini
2016-08-31 20:44 - 2016-08-31 20:44 - 00000000 _SHDL C:\Users\garar\My Documents
2016-08-31 20:40 - 2016-09-07 02:04 - 02718208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PrintConfig.dll
2016-08-31 20:39 - 2016-08-31 20:39 - 00000000 ____D C:\ProgramData\USOShared
2016-08-31 18:40 - 2016-09-01 00:34 - 00000000 ___HD C:$SysReset
2016-08-29 20:17 - 2016-08-29 20:17 - 00067736 _____ (Logitech Inc.) C:\WINDOWS\system32\Drivers\LGJoyXlCore.sys
2016-08-29 20:17 - 2016-08-29 20:17 - 00036496 _____ (Logitech Inc.) C:\WINDOWS\system32\Drivers\LGBusEnum.sys
2016-08-29 20:17 - 2016-08-29 20:17 - 00026008 _____ (Logitech Inc.) C:\WINDOWS\system32\Drivers\LGVirHid.sys
2016-09-13 18:41 - 2015-10-30 03:19 - 00635904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mqsnap.dll
2016-09-13 18:41 - 2015-10-30 03:19 - 00014848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mqcertui.dll
2016-09-13 18:41 - 2015-10-30 03:18 - 00018944 _____ (Microsoft Corporation) C:\WINDOWS\system32\mqcertui.dll
2016-09-01 00:03 - 2015-10-30 03:17 - 00065536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthmodem.sys
2016-09-05 20:43 - 2016-09-19 17:59 - 0000033 _____ () C:\Users\garar\AppData\Roaming\AdobeWLCMCache.dat
2016-09-05 00:09 - 2016-09-07 22:37 - 0000000 _____ () C:\Users\garar\AppData\Roaming\settings.ini
2016-09-19 21:36 - 2016-09-19 21:36 - 0026837 _____ () C:\ProgramData\agent.1474335373.bdinstall.bin
[HEADING=1]Files to move or delete:[/HEADING]
[HEADING=1]Some files in TEMP:[/HEADING]
C:\Users\garar\AppData\Local\Temp\7za.exe
C:\Users\garar\AppData\Local\Temp\DaS_21.exe
C:\Users\garar\AppData\Local\Temp\hijackthis.exe
C:\Users\garar\AppData\Local\Temp\libeay32.dll
C:\Users\garar\AppData\Local\Temp\msvcr120.dll
C:\Users\garar\AppData\Local\Temp\NirCmd.exe
C:\Users\garar\AppData\Local\Temp\nvSCPAPI.dll
C:\Users\garar\AppData\Local\Temp\nvSCPAPI64.dll
C:\Users\garar\AppData\Local\Temp\nvStInst.exe
C:\Users\garar\AppData\Local\Temp\PEVZ.EXE
C:\Users\garar\AppData\Local\Temp\remove.exe
C:\Users\garar\AppData\Local\Temp\sed.exe
C:\Users\garar\AppData\Local\Temp\shortcut.exe
C:\Users\garar\AppData\Local\Temp\sqlite3.dll
C:\Users\garar\AppData\Local\Temp\swreg.exe
C:\Users\garar\AppData\Local\Temp\swxcacls.exe
C:\Users\garar\AppData\Local\Temp\wget.exe
C:\Users\garar\AppData\Local\Temp\zoek-delete.exe
LastRegBack: 2016-09-23 00:03
==================== End of FRST.txt ============================Comment
[HEADING=1]Additional scan result of Farbar Recovery Scan Tool (x64) Version: 28-09-2016
Ran by garar (28-09-2016 22:01:00)
Running from C:\Users\garar\Desktop
Windows 10 Home Version 1511 (X64) (2016-09-01 00:42:27)
Boot Mode: Normal[/HEADING]
Administrator (S-1-5-21-1963327732-3332141323-2774556287-500 - Administrator - Disabled)
DefaultAccount (S-1-5-21-1963327732-3332141323-2774556287-503 - Limited - Disabled)
garar (S-1-5-21-1963327732-3332141323-2774556287-1001 - Administrator - Enabled) => C:\Users\garar
Guest (S-1-5-21-1963327732-3332141323-2774556287-501 - Limited - Disabled)
AV: Bitdefender Antivirus (Enabled - Up to date) {3FB17364-4FCC-0FA7-6BBF-973897395371}
AS: Bitdefender Antispyware (Enabled - Up to date) {84D09280-69F6-0029-510F-AC4AECBE19CC}
FW: Bitdefender Firewall (Enabled) {078AF241-05A3-0EFF-40E0-3E0D69EA140A}
Adobe Acrobat Reader DC (HKLM-x32...{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 15.017.20053 - Adobe Systems Incorporated)
Adobe Creative Cloud (HKLM-x32...\Adobe Creative Cloud) (Version: 3.8.0.310 - Adobe Systems Incorporated)
Adobe Flash Player 23 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 23.0.0.162 - Adobe Systems Incorporated)
Adobe Illustrator CC 2015.3 (HKLM-x32...\ILST_20_1_0) (Version: 20.1.0 - Adobe Systems Incorporated)
Adobe Photoshop CC 2015.5 (HKLM-x32...\PHSP_17_0_1) (Version: 17.0.1 - Adobe Systems Incorporated)
Ansel (Version: 368.81 - NVIDIA Corporation) Hidden
Bitdefender Agent (HKLM...\Bitdefender Agent) (Version: 20.0.29.1517 - Bitdefender)
Bitdefender Internet Security 2016 (HKLM...\Bitdefender) (Version: 20.0.29.1517 - Bitdefender)
CC3+ (HKLM-x32...\CC3+) (Version: 3.74 - ProFantasy Software)
CC3+ (x32 Version: 3.74 - ProFantasy Software) Hidden
Discord (HKU\S-1-5-21-1963327732-3332141323-2774556287-1001...\Discord) (Version: 0.0.296 - Hammer & Chisel, Inc.)
Dungeon Designer 3 for CC3+ (HKLM-x32...\Dungeon Designer 3 for CC3+) (Version: 3.0 - ProFantasy Software)
Dungeon Designer 3 for CC3+ (x32 Version: 3.0 - ProFantasy Software) Hidden
FastCAD (HKLM-x32...\FastCAD) (Version: - )
Logitech Gaming Software 8.87 (HKLM...\Logitech Gaming Software) (Version: 8.87.116 - Logitech Inc.)
Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32...{7299052b-02a4-4627-81f2-1818da5d550d}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23918 (HKLM-x32...{dab68466-3a7d-41a8-a5cf-415e3ff8ef71}) (Version: 14.0.23918.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.23918 (HKLM-x32...{2e085fd2-a3e4-4b39-8e10-6b8d35f55244}) (Version: 14.0.23918.0 - Microsoft Corporation)
Mozilla Firefox 48.0.2 (x86 en-US) (HKLM-x32...\Mozilla Firefox 48.0.2 (x86 en-US)) (Version: 48.0.2 - Mozilla)
Mozilla Maintenance Service (HKLM-x32...\MozillaMaintenanceService) (Version: 48.0.2 - Mozilla)
MSI DragonEye (HKLM...{7116875E-F251-4C33-AB3F-37DE05B15595}_is1) (Version: 0.0.2.3 - MSI)
MSI Gaming APP (HKLM-x32...{E0229316-E73B-484B-B9E0-45098AB38D8C}}_is1) (Version: 6.0.0.21 - MSI)
NVIDIA 3D Vision Controller Driver 364.44 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 364.44 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 368.81 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 368.81 - NVIDIA Corporation)
NVIDIA GeForce Experience 2.11.4.0 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 2.11.4.0 - NVIDIA Corporation)
NVIDIA Graphics Driver 368.81 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 368.81 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.34.15 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.15 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
Overwolf (HKLM-x32...\Overwolf) (Version: 0.98.16.0 - Overwolf Ltd.)
Overwolf.Setup.VC100CRTx64.Dist (HKLM...{EC9D5554-6852-4A55-81BB-AC02C7A8CFED}) (Version: 1.0.0 - Overwolf)
Razer Synapse (HKLM-x32...{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.15.810 - Razer Inc.)
Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.6235 - Realtek Semiconductor Corp.)
SHIELD Streaming (Version: 7.1.0280 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (Version: 2.11.4.0 - NVIDIA Corporation) Hidden
SketchUp 2016 (HKLM...{E2B66CF6-ABA0-4E5F-B426-7478B18301AE}) (Version: 16.1.1449 - Trimble Navigation Limited)
Steam (HKLM-x32...\Steam) (Version: 2.10.91.91 - Valve Corporation)
Symbol Set 4 for CC3+ (HKLM-x32...\Symbol Set 4 for CC3+) (Version: 1.0 - ProFantasy Software)
Symbol Set 4 for CC3+ (x32 Version: 1.0 - ProFantasy Software) Hidden
TeamSpeak 3 Client (HKLM...\TeamSpeak 3 Client) (Version: 3.0.19 - TeamSpeak Systems GmbH)
The Witcher 3: Wild Hunt (HKLM...\Steam App 292030) (Version: - CD PROJEKT RED)
TorrentsTime Media Player (HKLM...\TorrentsTime Media Player_is1) (Version: 1.1.9.5 - Torrents Time)
Vulkan Run Time Libraries 1.0.11.1 (HKLM...\VulkanRT1.0.11.1) (Version: 1.0.11.1 - LunarG, Inc.)
WinRAR 5.40 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
Zemana AntiMalware (HKLM-x32...{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.50.72 - Zemana Ltd.)
CustomCLSID: HKU\S-1-5-21-1963327732-3332141323-2774556287-1001_Classes\CLSID{0E270DAA-1BE6-48F2-AC49-50903CC8184B}\InprocServer32 → %%systemroot%%\system32\shell32.dll => No File
CustomCLSID: HKU\S-1-5-21-1963327732-3332141323-2774556287-1001_Classes\CLSID{71DCE5D6-4B57-496B-AC21-CD5B54EB93FD}\localserver32 → C:\Users\garar\AppData\Local\Microsoft\OneDrive\17 .3.6517.0809\FileCoAuth.exe (Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-1963327732-3332141323-2774556287-1001_Classes\CLSID{e8c77137-e224-5791-b6e9-ff0305797a13}\InprocServer32 → C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\npAdobeAAMDetect64.dll (Adobe Systems)
Task: {08CA42E2-97F3-4796-B785-49B82165C8B8} - System32\Tasks\Bitdefender Agent WatchDog_65D6944A0EF74FDAB96E31112AD39864 => C:\Program Files\Bitdefender Agent\WatchDog.exe [2016-09-13] (Bitdefender)
Task: {5F2401FF-5A8F-4F43-87DF-83ADD03F4A91} - System32\Tasks\MSIOSDx86_Host => C:\Program Files (x86)\MSI\Gaming APP\OSD\x86\MsiGamingOSD_x86.exe [2016-07-28] (Micro-Star INT’L CO., LTD.)
Task: {6A6E8D7D-AB7A-4CDB-8630-BE73D75BCA9C} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2016-09-16] (Adobe Systems Incorporated)
Task: {6BE31F69-634B-4608-84DB-8C56A8CBBBB7} - System32\Tasks\MSISW_Host => C:\WINDOWS\SysWOW64\muachost.exe [2015-08-18] (MSI)
Task: {6DCB024B-B6F8-41BF-8325-57F442E978E4} - System32\Tasks\OneDrive Standalone Update Task => C:\Users\garar\AppData\Local\Microsoft\OneDrive\17 .3.6517.0809\OneDriveStandaloneUpdater.exe [2016-09-01] (Microsoft Corporation)
Task: {9044030B-5A38-4E69-9D0D-D0AF91144446} - System32\Tasks\Bitdefender AgentTask_AD394AE64E874073B10A89FEEC305A3C => C:\Program Files\Bitdefender\Bitdefender 2016\bdagent.exe [2016-06-24] (Bitdefender)
Task: {C0047965-CA8B-4E9A-BA04-0D6C657B69B5} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpda teService.exe [2016-09-13] (Adobe Systems Incorporated)
Task: {C9646A87-8EA7-4300-B7FE-38BFE368DFC1} - System32\Tasks\AdobeAAMUpdater-1.0-MicrosoftAccount-gararion@gmail.com => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.e xe [2016-07-01] (Adobe Systems Incorporated)
Task: {E0223F54-96A9-4DB9-B512-7E0C8F9D8155} - System32\Tasks\Overwolf Updater Task => C:\Program Files (x86)\Overwolf\OverwolfUpdater.exe [2016-09-15] (Overwolf LTD)
Task: {E21AC619-0D98-425D-8029-9E1FBB45EC0E} - System32\Tasks\MSIOSDx64_Host => C:\Program Files (x86)\MSI\Gaming APP\OSD\x64\MsiGamingOSD_x64.exe [2016-07-28] (Micro-Star INT’L CO., LTD.)
Task: C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpda teService.exe
==================== Shortcuts =============================
Shortcut: C:\Users\garar\AppData\Roaming\Microsoft\Windows\S tart Menu\Programs\Accessories\Intеrnеt Ехplоrеr.lnk → C:\Program Files\Internet Explorer\iexplore.exe (Microsoft Corporation)
Shortcut: C:\Users\garar\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Моzillа Firеfох.lnk → C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation)
Shortcut: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Моzillа Firеfох.lnk → C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation)
2015-10-30 03:17 - 2015-10-30 03:17 - 00028672 _____ () C:\WINDOWS\SYSTEM32\efsext.dll
2015-10-30 03:18 - 2015-10-30 03:18 - 00185856 _____ () C:\WINDOWS\SYSTEM32\ism32k.dll
2016-09-02 21:07 - 2013-09-03 14:29 - 00101328 _____ () C:\Program Files\Bitdefender\Bitdefender 2016\bdmetrics.dll
2016-09-02 21:07 - 2016-05-09 11:29 - 01006336 _____ () C:\Program Files\Bitdefender\Bitdefender 2016\otengines_001_001\ashttpbr.mdl
2016-09-02 21:07 - 2016-05-09 11:29 - 00541952 _____ () C:\Program Files\Bitdefender\Bitdefender 2016\otengines_001_001\ashttpdsp.mdl
2016-09-02 21:07 - 2016-05-09 11:29 - 03035488 _____ () C:\Program Files\Bitdefender\Bitdefender 2016\otengines_001_001\ashttpph.mdl
2016-09-02 21:07 - 2016-05-09 11:29 - 01541440 _____ () C:\Program Files\Bitdefender\Bitdefender 2016\otengines_001_001\ashttprbl.mdl
2016-08-31 20:50 - 2016-07-10 18:58 - 00133056 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
2016-09-02 23:37 - 2011-10-29 09:59 - 00918448 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.18\atkexComSvc.exe
2015-11-04 19:11 - 2015-11-04 19:12 - 00188072 _____ () C:\Program Files (x86)\Razer\Razer Services\GSS\GameScannerService.exe
2016-09-13 18:54 - 2016-09-07 01:39 - 02656952 _____ () C:\WINDOWS\system32\CoreUIComponents.dll
2016-08-31 22:16 - 2016-06-14 16:35 - 00187392 _____ () C:\Program Files (x86)\MSI\Gaming APP\OSD\x64\D3D11FontDraw.dll
2016-09-13 18:54 - 2016-09-07 01:39 - 02656952 _____ () C:\WINDOWS\System32\CoreUIComponents.dll
2016-05-22 19:33 - 2016-05-22 19:33 - 00491184 _____ () C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSyncExtension\CoreSync_x64.dll
2016-09-01 21:32 - 2016-09-01 21:32 - 01864384 _____ () C:\Users\garar\AppData\Local\Microsoft\OneDrive\17 .3.6517.0809\amd64\ClientTelemetry.dll
2016-09-26 21:57 - 2016-09-26 21:57 - 00123760 _____ () C:\Program Files (x86)\Zemana AntiMalware\ZAMShellExt64.dll
2016-08-31 21:37 - 2016-08-31 21:37 - 00144384 _____ () C:\Program Files\WindowsApps\Microsoft.Messaging_2.15.20002.0 _x86__8wekyb3d8bbwe\SkypeHost.exe
2016-02-13 08:54 - 2016-02-13 08:54 - 00093696 _____ () C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2t xyewy\Windows.UI.Shell.SharedUtilities.dll
2016-07-13 14:47 - 2016-06-30 23:48 - 00472064 _____ () C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2t xyewy\QuickActions.dll
2016-09-13 18:52 - 2016-09-07 00:15 - 07992832 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\CortanaApi.dll
2016-09-13 18:52 - 2016-09-07 00:10 - 00591360 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.Core.dll
2016-09-13 18:52 - 2016-09-07 00:10 - 02483200 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\Cortana.BackgroundTask.dll
2016-09-13 18:52 - 2016-09-07 00:13 - 04089856 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw 5n1h2txyewy\RemindersUI.dll
2015-03-06 20:07 - 2015-03-06 20:07 - 00908568 _____ () C:\Program Files\Logitech Gaming Software\libGLESv2.dll
2016-08-29 20:17 - 2016-08-29 20:17 - 01096824 _____ () C:\Program Files\Logitech Gaming Software\platforms\qwindows.dll
2015-03-06 20:07 - 2015-03-06 20:07 - 00060184 _____ () C:\Program Files\Logitech Gaming Software\libEGL.dll
2016-08-29 20:17 - 2016-08-29 20:17 - 00241784 _____ () C:\Program Files\Logitech Gaming Software\imageformats\qjpeg.dll
2016-05-22 19:32 - 2016-05-22 19:32 - 31680176 _____ () C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\CoreSync.exe
2016-09-02 23:37 - 2016-09-28 21:51 - 00023552 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.18\PEbiosinterface32.dll
2016-09-02 23:37 - 2010-06-29 10:58 - 00104448 _____ () C:\Program Files (x86)\ASUS\AXSP\1.00.18\ATKEX.dll
2016-09-10 11:15 - 2016-02-25 18:35 - 03843584 _____ () C:\Program Files (x86)\TorrentsTime Media Player\bin\torrent.dll
2016-08-31 22:16 - 2016-06-14 16:35 - 00163328 _____ () C:\Program Files (x86)\MSI\Gaming APP\OSD\x86\D3D11FontDraw.dll
2016-08-31 21:37 - 2016-08-31 21:37 - 00141312 _____ () C:\Program Files\WindowsApps\Microsoft.Messaging_2.15.20002.0 _x86__8wekyb3d8bbwe\SkypeBackgroundTasks.dll
2016-08-31 21:37 - 2016-08-31 21:37 - 22284800 _____ () C:\Program Files\WindowsApps\Microsoft.Messaging_2.15.20002.0 _x86__8wekyb3d8bbwe\SkyWrap.dll
2016-08-31 22:05 - 2016-06-14 16:03 - 00018880 _____ () C:\Program Files (x86)\NVIDIA Corporation\Update Core\detoured.dll
2016-08-22 13:49 - 2016-08-22 13:49 - 40523480 _____ () C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\libcef.dll
2016-09-01 21:32 - 2016-09-01 21:32 - 01383616 _____ () C:\Users\garar\AppData\Local\Microsoft\OneDrive\17 .3.6517.0809\ClientTelemetry.dll
2016-09-01 21:32 - 2016-09-01 21:32 - 00118976 _____ () C:\Users\garar\AppData\Local\Microsoft\OneDrive\17 .3.6517.0809\FileSyncViews.dll
2016-09-26 20:05 - 2016-09-07 23:14 - 00784672 _____ () D:\Program Files (x86)\Steam\SDL2.dll
2016-09-26 20:05 - 2016-08-31 21:02 - 04969248 _____ () D:\Program Files (x86)\Steam\v8.dll
2016-09-26 20:05 - 2016-09-20 15:28 - 02321696 _____ () D:\Program Files (x86)\Steam\video.dll
2016-09-26 20:05 - 2016-08-31 21:02 - 01563936 _____ () D:\Program Files (x86)\Steam\icui18n.dll
2016-09-26 20:05 - 2016-08-31 21:02 - 01195296 _____ () D:\Program Files (x86)\Steam\icuuc.dll
2016-09-04 23:45 - 2016-01-27 03:49 - 02549760 _____ () D:\Program Files (x86)\Steam\libavcodec-56.dll
2016-09-04 23:45 - 2016-01-27 03:49 - 00491008 _____ () D:\Program Files (x86)\Steam\libavformat-56.dll
2016-09-04 23:45 - 2016-01-27 03:49 - 00332800 _____ () D:\Program Files (x86)\Steam\libavresample-2.dll
2016-09-04 23:45 - 2016-01-27 03:49 - 00442880 _____ () D:\Program Files (x86)\Steam\libavutil-54.dll
2016-09-04 23:45 - 2016-01-27 03:49 - 00485888 _____ () D:\Program Files (x86)\Steam\libswscale-3.dll
2016-09-26 20:05 - 2016-09-20 15:28 - 00835360 _____ () D:\Program Files (x86)\Steam\bin\chromehtml.DLL
2016-09-04 23:45 - 2016-07-04 18:17 - 00266560 _____ () D:\Program Files (x86)\Steam\openvr_api.dll
2016-09-15 10:48 - 2016-09-15 10:48 - 45069312 _____ () C:\Program Files (x86)\Overwolf\0.98.16.0\libcef.DLL
2016-09-06 19:33 - 2016-08-24 17:49 - 01950392 _____ () C:\Users\garar\AppData\Local\Discord\app-0.0.296\ffmpeg.dll
2016-09-26 20:05 - 2016-09-26 20:05 - 01050296 _____ () \?\C:\Users\garar\AppData\Roaming\discord\0.0.296\ modules\discord_voice\discord_voice.node
2016-09-26 20:05 - 2016-09-26 20:05 - 03793080 _____ () \?\C:\Users\garar\AppData\Roaming\discord\0.0.296\ modules\discord_voice\libdiscord.dll
2016-09-26 20:05 - 2016-09-26 20:05 - 00894136 _____ () \?\C:\Users\garar\AppData\Roaming\discord\0.0.296\ modules\discord_utils\discord_utils.node
2016-09-26 20:05 - 2016-09-26 20:05 - 01119416 _____ () \?\C:\Users\garar\AppData\Roaming\discord\0.0.296\ modules\discord_toaster\discord_toaster.node
2016-08-24 08:45 - 2016-08-24 08:45 - 40523456 _____ () C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\CEF\libcef.dll
2016-09-04 23:45 - 2016-08-04 16:56 - 49825056 _____ () D:\Program Files (x86)\Steam\bin\libcef.dll
2016-09-06 19:33 - 2016-08-24 17:49 - 02230456 _____ () C:\Users\garar\AppData\Local\Discord\app-0.0.296\libglesv2.dll
2016-09-06 19:33 - 2016-08-24 17:49 - 00088760 _____ () C:\Users\garar\AppData\Local\Discord\app-0.0.296\libegl.dll
2016-09-28 21:52 - 2016-09-28 21:52 - 00170496 _____ () \?\C:\Users\garar\AppData\Local\Temp\2BAE.tmp.node
2016-09-26 20:05 - 2016-09-26 20:05 - 02022072 _____ () \?\C:\Users\garar\AppData\Roaming\discord\0.0.296\ modules\discord_contact_import\discord_contact_imp ort.node
2016-06-08 00:10 - 2016-06-08 00:10 - 00118272 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\js\node_modules\fs-ext\build\Release\fs-ext.node
2016-06-08 00:10 - 2016-06-08 00:10 - 00205824 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\js\node_modules\node-vulcanjs\build\Release\VulcanJS.node
2016-06-08 00:10 - 2016-06-08 00:10 - 00117248 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\js\node_modules\ref\build\Release \binding.node
2016-06-08 00:10 - 2016-06-08 00:10 - 00125440 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\js\node_modules\ffi\build\Release \ffi_bindings.node
2016-08-24 08:24 - 2016-08-24 08:24 - 00098496 _____ () C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\js\node_modules\node-ProxyResolver\build\Release\ProxyResolverWin.dll
2016-06-08 00:10 - 2016-06-08 00:10 - 00166400 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\js\node_modules\idle-gc\build\Release\idle-gc.node
2016-09-15 10:48 - 2016-09-15 10:48 - 01643008 _____ () C:\Program Files (x86)\Overwolf\0.98.16.0\libglesv2.dll
2016-09-15 10:48 - 2016-09-15 10:48 - 00074752 _____ () C:\Program Files (x86)\Overwolf\0.98.16.0\libegl.dll
2016-08-08 22:29 - 2016-08-08 22:29 - 00118272 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\fs-ext\build\Release\fs-ext.node
2016-08-08 22:30 - 2016-08-08 22:30 - 00117760 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\ref\build\Release\ binding.node
2016-08-08 22:31 - 2016-08-08 22:31 - 00124928 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\ffi\build\Release\ ffi_bindings.node
2016-08-08 22:31 - 2016-08-08 22:31 - 00223232 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\node-vulcanjs\build\Release\VulcanJS.node
2016-08-24 08:17 - 2016-08-24 08:17 - 00098496 _____ () C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\node-ProxyResolver\build\Release\ProxyResolverWin.dll
2016-08-08 22:30 - 2016-08-08 22:30 - 00121856 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\bufferutil\build\R elease\bufferutil.node
2016-08-08 22:29 - 2016-08-08 22:29 - 00166400 _____ () \?\C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\js\node_modules\idle-gc\build\Release\idle-gc.node
AlternateDataStreams: C:\ProgramData\Reprise:wupeogjxldtlfudivq[ICODE]qsp[/ICODE]27hfm [0]
AlternateDataStreams: C:\Users\garar\Desktop\Adware Removal Tool by TSA.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Desktop\adwcleaner_6.020.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Desktop\JRT.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Desktop\ZHPCleaner.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Desktop\zoek.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Downloads\aswmbr.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Downloads\mbam-setup-2.2.1.1043.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Downloads\TeamSpeak3-Client-win64-3.0.19.4.exe:BDU [0]
AlternateDataStreams: C:\Users\garar\Downloads\Zemana.AntiMalware.Setup. exe:BDU [0]
2016-09-01 00:08 - 2016-09-28 21:52 - 00000754 ____A C:\WINDOWS\system32\Drivers\etc\hosts
127.0.0.1 localhost
HKU\S-1-5-21-1963327732-3332141323-2774556287-1001\Control Panel\Desktop\Wallpaper → C:\Users\garar\AppData\Local\Microsoft\Windows\The mes\RoamedThemeFiles\DesktopBackground\desktop background.bmp
DNS Servers: 216.104.96.22 - 216.104.98.222
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Pol icies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
Windows Firewall is enabled.
FirewallRules: [vm-monitoring-nb-session] => (Allow) LPort=139
FirewallRules: [{A5F85C36-01FA-43D8-A9EF-BE2193B219BC}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{FF79128C-B506-4C42-A0D2-D31B6FE4A9EA}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{398BE0D3-72D8-47B4-B3D8-1F25FA82AA0A}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
FirewallRules: [{253FEF33-FBBB-4A18-AB67-AABA12F0C8F3}] => (Allow) C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
FirewallRules: [{EE3069FC-A6F3-4669-9CC7-52B305760348}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
FirewallRules: [{227386A7-85C8-478F-A21E-14259B14FA3F}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamNetworkService.exe
FirewallRules: [{C8BE6155-8521-4375-9462-95F4A2D571D1}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
FirewallRules: [{3D418713-81C5-4636-9BD9-1485DDF1353A}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
FirewallRules: [{DEB2F376-67C8-4BDD-B6D9-848A3907D21E}] => (Allow) C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamer.exe
FirewallRules: [{AEF3D32B-83B4-4A5F-AC78-C49618A77052}] => (Allow) LPort=26789
FirewallRules: [{78B8D7FD-6E27-4343-9F02-E1D9DAB88487}] => (Allow) D:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{1FFFE87C-3499-4D03-88A7-43A03B029FA9}] => (Allow) D:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{97D7D01F-0A3E-49F8-A9B5-8D1A36AAE96F}] => (Allow) D:\Program Files (x86)\Steam\bin\steamwebhelper.exe
FirewallRules: [{DB3E6808-1938-4546-A483-1EBEB0D144C8}] => (Allow) D:\Program Files (x86)\Steam\bin\steamwebhelper.exe
FirewallRules: [{4381A743-4EA3-420D-9B5F-B6259724C542}] => (Allow) D:\Program Files (x86)\Steam\steamapps\common\The Witcher 3\bin\x64\witcher3.exe
FirewallRules: [{2BFBA710-B0AF-4B0B-A413-E1B22495DAA5}] => (Allow) D:\Program Files (x86)\Steam\steamapps\common\The Witcher 3\bin\x64\witcher3.exe
FirewallRules: [{A9E38D39-4CF9-4D04-AE4D-2BE704B28001}] => (Allow) C:\Users\garar\AppData\Local\Temp\MPCOnline\MPCDow nload.exe
FirewallRules: [{539E7F19-8BB5-4547-B127-66A31783A806}] => (Allow) C:\Users\garar\AppData\Local\Temp\MPCOnline\MPCDow nload.exe
FirewallRules: [{94357AF6-5E26-4A25-BBDB-8C43DA2DE336}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe
FirewallRules: [{DC8BBA11-5262-4276-8D0C-BC3F8A27D1DF}] => (Allow) C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe
FirewallRules: [{1D8FAF57-3C5D-4A12-A44A-8F021476C25A}] => (Allow) C:\Program Files (x86)\TorrentsTime Media Player\bin\chromecast\node.exe
FirewallRules: [{A23D41D0-FC5E-4A89-A1D0-B9C2F1902A3B}] => (Allow) C:\Program Files (x86)\TorrentsTime Media Player\bin\chromecast\node.exe
FirewallRules: [TCP Query User{559D2F46-64CE-4DBE-AFFD-2BACAC782DD9}C:\program files\logitech gaming software\lcore.exe] => (Allow) C:\program files\logitech gaming software\lcore.exe
FirewallRules: [UDP Query User{90921C7A-7C2A-46A4-89D0-5E30DBC95C93}C:\program files\logitech gaming software\lcore.exe] => (Allow) C:\program files\logitech gaming software\lcore.exe
26-09-2016 16:24:42 zoek.exe restore point
26-09-2016 22:47:17 JRT Pre-Junkware Removal
Error: (09/28/2016 09:52:34 PM) (Source: Perflib) (EventID: 1008) (User: )
Description: The Open Procedure for service “WmiApRpl” in DLL “C:\WINDOWS\system32\wbem\wmiaprpl.dll” failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Error: (09/28/2016 09:52:34 PM) (Source: Perflib) (EventID: 1023) (User: )
Description: Windows cannot load the extensible counter DLL rdyboost. The first four bytes (DWORD) of the Data section contains the Windows error code.
Error: (09/28/2016 09:52:34 PM) (Source: PerfNet) (EventID: 2004) (User: )
Description: Unable to open the Server service performance object. The first four bytes (DWORD) of the Data section contains the status code.
Description: The Open Procedure for service “MSDTC” in DLL “C:\WINDOWS\system32\msdtcuiu.DLL” failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Error: (09/28/2016 09:52:33 PM) (Source: Perflib) (EventID: 1008) (User: )
Description: The Open Procedure for service “Lsa” in DLL “C:\Windows\System32\Secur32.dll” failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Description: The Open Procedure for service “ESENT” in DLL “C:\WINDOWS\system32\esentprf.dll” failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Description: The Open Procedure for service “BITS” in DLL “C:\Windows\System32\bitsperf.dll” failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Error: (09/28/2016 09:41:45 PM) (Source: SideBySide) (EventID: 78) (User: )
Description: Activation context generation failed for “C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\Creative Cloud Uninstaller.exe”.Error in manifest or policy file “” on line .
A component version required by the application conflicts with another component version already active.
Conflicting components are:.
Component 1: C:\WINDOWS\WinSxS\manifests\x86_microsoft.windows. common-controls_6595b64144ccf1df_6.0.10586.589_none_ea8ae aa1b9b5d5d4.manifest.
Component 2: C:\WINDOWS\WinSxS\manifests\amd64_microsoft.window s.common-controls_6595b64144ccf1df_6.0.10586.589_none_a2ddb 3caa539acce.manifest.
Error: (09/27/2016 12:23:13 AM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: NvStreamUserAgent.exe, version: 7.1.2084.9592, time stamp: 0x57605c64
Faulting module name: ntdll.dll, version: 10.0.10586.306, time stamp: 0x571af2eb
Exception code: 0xc0000005
Fault offset: 0x000000000002e909
Faulting process id: 0x1394
Faulting application start time: 0x01d21876daab7c7b
Faulting application path: C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamUserAgent.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: 242581a8-eb20-4c68-91f8-ce32ec980db4
Faulting package full name:
Error: (09/27/2016 12:22:56 AM) (Source: Application Error) (EventID: 1000) (User: )
Faulting process id: 0x12ec
Faulting application start time: 0x01d21876d20efb52
Report Id: 4d9619d1-6ae8-4aac-9c9d-a64acdd516cc
Error: (09/28/2016 09:50:30 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
Description: The User Data Access_3897f service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Description: The User Data Storage_3897f service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Description: The Contact Data_3897f service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Description: The Sync Host_3897f service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Error: (09/26/2016 11:08:02 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
Description: The User Data Access_3a791 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Description: The User Data Storage_3a791 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Description: The Contact Data_3a791 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Description: The Sync Host_3a791 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Error: (09/26/2016 10:47:25 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The ZAM Controller Service service terminated unexpectedly. It has done this 1 time(s).
Error: (09/26/2016 10:41:44 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
Description: The User Data Access_3999e service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Date: 2016-09-26 15:56:11.342
Description: Code Integrity determined that a process (\Device\HarddiskVolume3\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume3\Program Files (x86)\Overwolf\0.98.16.0\x64\OWExplorer.dll that did not meet the Store signing level requirements.
Date: 2016-09-20 17:56:32.106
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume3\Windows\System32\efswrt.dl l because the set of per-page image hashes could not be found on the system.
Date: 2016-09-15 22:04:15.285
Date: 2016-09-15 19:39:44.275
Date: 2016-09-14 01:06:27.813
Description: Code Integrity determined that a process (\Device\HarddiskVolume3\Windows\SystemApps\Micros oft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.ex e) attempted to load \Device\HarddiskVolume3\Program Files (x86)\Overwolf\0.97.209.0\x64\OWExplorer.dll that did not meet the Store signing level requirements.
Date: 2016-09-06 19:35:15.356
Date: 2016-09-05 20:09:29.398
Date: 2016-09-05 20:08:28.386
Date: 2016-09-02 20:27:17.980
Processor: Intel(R) Core™ i7-2600K CPU @ 3.40GHz
Percentage of memory in use: 25%
Total physical RAM: 16364.13 MB
Available physical RAM: 12222.02 MB
Total Virtual: 17388.13 MB
Available Virtual: 13057.23 MB
Drive c: () (Fixed) (Total:111.69 GB) (Free:72.56 GB) NTFS
Drive d: (Storage) (Fixed) (Total:931.51 GB) (Free:890.23 GB) NTFS
Disk: 0 (MBR Code: Windows 7 or 8) (Size: 931.5 GB) (Disk ID: CEEBCC53)
Partition 1: (Not Active) - (Size=931.5 GB) - (Type=07 NTFS)
Disk: 1 (MBR Code: Windows 7 or 8) (Size: 111.8 GB) (Disk ID: 03ED3558)
Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=111.7 GB) - (Type=07 NTFS)
==================== End of Addition.txt ============================Comment
There are the logs that yous wanted. I am no longer getting messages from Bitdefender. Only issues I am having now I think are:- When posted the logs from FRST, firefox seems to freeze. thinking it is mainly just the size of those logs but thought I’d brign it up.
- Also, my computer wont stay in sleep mode. At first I thought it was this message from bitdefender every 6 minutes waking up the computer from sleep, but it was still doing it before I ran the last two scans. Haven’t tested it since the last two scans, that will be done while I try to go to sleep.
