malware & eliminate help .....
  • Malnutrition
    PCHF Moderator
    • 7041
    #31
    No big deal, that program will not run on some computers. Your logs are clean, update all your programs with Patch My PC…
    Glad to have helped!! Please tell a friend … or two about us. https://forum.windowsinstructed.com/...cons/smile.png
    suggest the following in place of adblock.
    Alternate DNS Server. Ad Blocking DNS.
    Ublock Origin.
    Anti Ad Block Killer.
    Also, keep your browsing private with these tools:
    Self Destructing Cookies.
    Self Destructing Cookies Chrome.
    Some items to keep you safe on the internet.
    VooDoo Shield. control of what is running on your machine
    Qualys BrowserCheck To update plugins.
    Web Of Trust To Avoid Shady Websites.
    Unchecky To Avoid Bundled Software.
    Privazer To Clean up your mahcine.
    Now Lets Clean up the tools we used and remove old restore points.
    Download DelFix by “Xplode” to your Desktop.
    Right Click the tool and Run as Admin ( Xp Users Double Click)
    Put a check mark next the items below:
    Remove disinfection tools
    Create registry backup
    Purge System Restore
    Now click on “Run” button.
    allow the program to complete its work.
    all the tools we used will be removed.
    Tool will create and open a log report (DelFix.txt)
    Note: The report can be located at the following location C:\DelFix.txt
    • rusobr2
      • 45
      #32
      hey Mal… thanks for “all” your help … i will be updating some things, and once again go thru your last post to check things over
      thanks… steve
      and yep… i’ll pass it on …
      • Malnutrition
        PCHF Moderator
        • 7041
        #33
        Marked solved.
