network problems since router upgrade
This topic is closed.
  • Lucianp
    • Apr 2018
    • 75
    I have just had my internet service upgraded which included getting a new NVG468MQ router. I am now having problems connecting to my local Media NAS and files NAS.
    I can access both via Windows explorer but not through a web interface. I get a Secure Connection Failed.
    Also, I cannot access the Media Nas via FireTV.
    Research tells me I need an SSL certificate even for local sites because I am using HTTP. Is this true?
    I am unsure what I need to configure on the router to get these to work.
    Any advice will be very much appreciated.
    Thank you
  • Malnutrition
    PCHF Moderator
    • 7045
    Network-Attached Storage (NAS) devices are a convenient solution for storing and accessing data across a network. Whether for personal or business use, connecting a NAS to your router or switch enables seamless access to files, media, and backups from multiple devices. In this guide, we'll explore the steps to properly connect a NAS device to your network for efficient data management and sharing. Understanding NAS Before diving into the setup process, let's briefly understand what a NAS device is and how it functions: Definition: A NAS device is a specialized file server that connects to a network, providing centralized storage accessible to multiple users and devices. Features: NAS devices often include features such as RAID (Redundant Array of Independent Disks) for data redundancy, file sharing protocols (e.g., SMB, NFS), remote access capabilities, and data backup functionality. Use Cases: NAS devices are commonly used for file sharing, media streaming, data backup, and hosting personal cloud services. Choosing the Right NAS Device Before purchasing a NAS device, consider factors such as storage capacity, number of drive bays, performance requirements, and budget. Popular NAS brands include Synology, QNAP, Western Digital, and Buffalo. Steps to Connect a NAS Device to a Router or Switch Follow these steps to connect your NAS device to your network: Choose Location: Select a suitable location for your NAS device, preferably near your router or switch and in a well-ventilated area. Hardware Setup: Insert Hard Drives: If your NAS device requires hard drives, insert them into the drive bays following the manufacturer's instructions. Configure RAID if desired. Connect Power: Plug in the power adapter to your NAS device and connect it to a power outlet. Connect to Router or Switch: Use an Ethernet cable patch cable to connect the LAN port on your NAS device to an available Ethernet port on your router or switch. Network Configuration: Obtain IP Address: Most NAS devices support DHCP and will automatically obtain an IP address from your router. Alternatively, you can assign a static IP address for better control. Access Web Interface: Use a web browser to access the web interface of your NAS device by entering its IP address in the address bar. Initial Setup: Follow Setup Wizard: Many NAS devices include a setup wizard to guide you through the initial configuration process. Follow the prompts to set up user accounts, shared folders, and other settings. Update Firmware: Check for firmware updates and install them to ensure your NAS device has the latest features and security patches. Data Transfer and Management: Create Shared Folders: Organize your data by creating shared folders for different types of files, such as documents, photos, videos, and music. Transfer Data: Copy files from your computer to the NAS device using file explorer or dedicated NAS management software. Set Up Backup: Configure backup jobs to automatically back up critical data from your computers to the NAS device. Accessing NAS from Devices: Mapping Network Drive (Windows): Use the
    https://forum.qnap.com/viewtopic.php?t=168449
    https://www.bitcatcha.com/research/h...ached-storage/
    Make sure and set a static IP when you configure the NAS treat it like a first time setup.
    • xrobwx71
      PCHF Moderator
      • Mar 2023
      • 1067
      If the PC is on the same network as the NAS and the router, you should be able to simply put the IP# of the NAS in the address field of the browser and connect that way.
      To connect remotely (from outside your network), you must use port forwarding from within the router’s Admin settings.
        PCHF Moderator
        • 10702
        @Lucianp - any news?
        • Lucianp
          • Apr 2018
          • 75
          I am using my original FiOS G1100 and everything is good. I’ve had some choice words with Frontier and they are replacing the router again. They have already sent me two Arris and an Eero 6 which are still here. They are coming out at the end of this week for another ONT replacement and help with my lan setup.
            PCHF Moderator
            • 10702
            Awesome, fingers crossed they help you out. (y)
              • 8982
              No follow up closing thread. If you need to re-open thread contact a staff member.
