Wifi Connecting Problem
  • JokerDaffa24
    • Mar 2024
    • 1
    my PC has a problem where i use wifi dongle 802.11n to make internet connection but now the wifi still work but i cant connect to any wifi who avaliable its says β€œcant connect to network” even tho i put the correct password, i already try from update wifi driver, rollback driver, uninstall and install driver, use CMD to fix the IP, network reset, troubleshoot and many more from all tutorial on youtube nothing work, and then i try to use CMD Command
    [li]ipconfig /release[/li][li]ipconfig /flushdns[/li][li]ipconfig /renew[/li][li]netsh winsock reset[/li][/ul]
    when use CMD an running the prompt it said β€œipconfig release not working media disconnected”
    Can anyone help me it will be a big help?
    We know nothing about your PC, let’s get your complete specs.
    Get Speccy; Speccy - Download Builds
    In Speccy, click File > Publish Snapshot (hit Yes if prompted to proceed with publish) > Copy to Clipboard > Close.
    Now you can paste that link into your next post.
    Speccy doesn’t show the Power Supply Unit so, if a Desktop PC, list the make/model of the PSU.
    Is Speccy safe?
    Have you tried connecting the PC to the network using an ethernet cable?
      @JokerDaffa24 - still need help?
        Closing - no activity.
