I need a little help with connecting my PC to a wifi network.
  • ghunt01
    • Dec 2023
    • 3
    So I just built my first PC and I’m having problems right now with the OS installation process. I’m currently installing Windows 11 Pro and I’m at the part where they ask you to connect to a Wi-Fi network. The problem is that it won’t allow me to choose any wifi networks. My mobo runs runs with wifi as it is a MSI B650 Gaming Plus Wifi. The screen only shows an option to connect the PC to an ethernet source. How do I connect this thing to Wifi without ethernet?
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    The board has an ethernet connection.
    Are you not able to use a cable for setup?
    If not, can you take a picture of the place you are stuck.
    • Bastet
      • Aug 2016
      • 1514
      Does the MB have a Wi-Fi card fitted?
      Do other Wi-Fi connections show or none at all?
        @ghunt01 - still need help?
