WiFi disconnecting occasionally
  • Data838
    • Nov 2021
    • 90
    Hi, lately my WiFi has been disconnecting by itself once a day or every 2-3 days. The troubleshooter doesn’t function, so every time I have to go to Network and Internet settings and disable and then enable the WIFI, sometimes I also have to use the option Diagnose for it to work. Other laptops are working just fine, so I think the problem is only on this one.
    Thank you in advance for your suggestions???.
  • Rustys
    • 7862
    Make and model of the serving Modem and or router for the WIFi?
    Have you tried resetting the WiFi setting in the
    Modem
    Router
    Affected system
    No technical information all we can do is guess as to what to do and what has been done.
    Speecy report will provide that information.
    [COLOR=rgb(243, 121, 52)]Do not forget to post the make and model of the PSU if this is a desktop.
    Speccy publishes the profile and displays a second Publish Snapshot. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.[/COLOR]
    • Malnutrition
      PCHF Moderator
      • 7041
      You can also try and set a static ip.
      • Data838
        • Nov 2021
        • 90
        I’m actually using the WiFi from a smartphone (not mine), I have a small router (not sure if it’s really called like that), it’s flat and approx. the size of a hand and it transmits the WiFi from the smartphone wherever it may be. So it has no make or model. Though, as I said earlier, I really think it’s my laptop because other laptops or smartphones don’t have any connection problems.
        I’ll run Speccy and get back to you later.
        • Rustys
          • 7862
          As soon as you get it posted we can get a better idea as to what is going on.
          • Data838
            • Nov 2021
            • 90
            Here it is, sorry for the delay.
            • Rustys
              • 7862
              Could be related to the same reason you posted on the other thread.
              • Data838
                • Nov 2021
                • 90
                I don’t think so, the problem with the mouse started way before the WiFi problem. Actually, since I’m posting on this forum, the connection seems to have gone back more or less to normal again, I had to enable and disable it in Settings just a couple of times.
                • Rustys
                  • 7862
                  Have you tried resetting the WiFi adapter to factory setting and see if that helps at all?
                  Have you tested in a new use account and or safe mode with networking to see if the issue persists?
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #10
                    Can I see a minitoolbox log please.
                    Please download MiniToolBox and save it to your desktop.
                    Run the program by right clicking on it and selecting Run as administrator.
                    When the program opens select the following boxes:
                    Flush DNS
                    Report IE Proxy Settings
                    Reset IE Proxy Settings
                    Report FF Proxy Settings
                    Reset FF Proxy Settings
                    List content of Hosts
                    List IP Configuration
                    List Winsock Entries
                    List Installed Programs
                    List Devices (Only Problems)
                    Please post the log in your next reply
                    • Data838
                      • Nov 2021
                      • 90
                      #11
                      I reset the Wifi network and ran MiniToolBox, see the log below. I’ll test if it it’s working as it should in the next few days.
                      Code:
                      MiniToolBox by Farbar Version: 13-05-2022
                      Ran by acco5 (administrator) on 05-11-2023 at 20:14:27
                      Running from β€œC:\Users\acco5\Desktop”
                      Model: ROG Strix G513IC_G513IC Manufacturer: ASUSTeK COMPUTER INC.
                      Boot Mode: Normal
                      [HR][/HR]
                      Windows IP Configuration
                      Proxy is not enabled.
                      No Proxy Server is set.
                      β€œReset IE Proxy Settings”: IE Proxy Settings were reset.
                      β€œnetwork.proxy.type”, 0
                      β€œReset FF Proxy Settings”: Firefox Proxy settings were reset.
                      127.0.0.1 localhost
                      MediaTek Wi-Fi 6 MT7921 Wireless LAN Card = WiFi (Connected)
                      Realtek PCIe GbE Family Controller = Ethernet (Media disconnected)
                      Speedify Virtual Adapter = Local Area Connection (Media disconnected)
                      [HEADING=1]----------------------------------[/HEADING]
                      [HEADING=1]IPv4 Configuration[/HEADING]
                      pushd interface ipv4
                      reset
                      set interface interface=β€œEthernet” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                      set interface interface=β€œWiFi” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                      set interface interface=β€œLocal Area Connection* 1” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                      set interface interface=β€œLocal Area Connection* 12” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                      set subinterface interface=?o??? subinterface=iftype53_32768 mtu=1280
                      popd
                      [HEADING=1]End of IPv4 configuration[/HEADING]
                      Host Name . . . . . . . . . . . . : LAPTOP-6ODOHNQP
                      Ethernet adapter Ethernet:
                      Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
                      Physical Address. . . . . . . . . : 04-42-1A-85-B2-3D
                      Unknown adapter Local Area Connection:
                      Description . . . . . . . . . . . : Speedify Virtual Adapter
                      Physical Address. . . . . . . . . : 00-FF-29-E6-92-AA
                      Wireless LAN adapter Local Area Connection* 1:
                      Physical Address. . . . . . . . . : 4A-E7-DA-53-E0-21
                      Wireless LAN adapter Local Area Connection* 12:
                      Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3
                      Physical Address. . . . . . . . . : 4A-E7-DA-53-E0-31
                      Wireless LAN adapter WiFi:
                      Description . . . . . . . . . . . : MediaTek Wi-Fi 6 MT7921 Wireless LAN Card
                      Physical Address. . . . . . . . . : 48-E7-DA-53-E0-31
                      Link-local IPv6 Address . . . . . : fe80::51ba:aa4e:3551:39d7%20(Preferred)
                      IPv4 Address. . . . . . . . . . . : 192.168.1.105(Preferred)
                      Lease Obtained. . . . . . . . . . : 05 November 2023 20:02:50
                      Lease Expires . . . . . . . . . . : 06 November 2023 20:02:50
                      DHCPv6 IAID . . . . . . . . . . . : 340322266
                      DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-28-A1-C3-CE-04-42-1A-85-B2-3D
                      192.168.1.1
                      DNS request timed out.
                      timeout was 2 seconds.
                      Server: UnKnown
                      Address: 192.168.1.1
                      Addresses: 2a00:1450:4007:81a::200e
                      142.250.75.238
                      Pinging google.com [142.250.75.238] with 32 bytes of data:
                      Request timed out.
                      Reply from 142.250.75.238: bytes=32 time=40ms TTL=112
                      Ping statistics for 142.250.75.238:
                      Packets: Sent = 2, Received = 1, Lost = 1 (50% loss),
                      Minimum = 40ms, Maximum = 40ms, Average = 40ms
                      Server: Bbox.nomad
                      Addresses: 2001:4998:124:1507::f001
                      2001:4998:124:1507::f000
                      2001:4998:24:120d::1:1
                      2001:4998:44:3507::8000
                      2001:4998:44:3507::8001
                      2001:4998:24:120d::1:0
                      98.137.11.164
                      74.6.143.25
                      74.6.231.20
                      74.6.231.21
                      74.6.143.26
                      98.137.11.163
                      Pinging yahoo.com [98.137.11.164] with 32 bytes of data:
                      Reply from 98.137.11.164: bytes=32 time=191ms TTL=46
                      Reply from 98.137.11.164: bytes=32 time=192ms TTL=46
                      Ping statistics for 98.137.11.164:
                      Minimum = 191ms, Maximum = 192ms, Average = 191ms
                      [HEADING=1]Ping statistics for 127.0.0.1:
                      Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
                      [HEADING=1]Interface List
                      19…04 42 1a 85 b2 3d …Realtek PCIe GbE Family Controller
                      5…00 ff 29 e6 92 aa …Speedify Virtual Adapter
                      29…4a e7 da 53 e0 21 …Microsoft Wi-Fi Direct Virtual Adapter
                      35…4a e7 da 53 e0 31 …Microsoft Wi-Fi Direct Virtual Adapter #3
                      20…48 e7 da 53 e0 31 …MediaTek Wi-Fi 6 MT7921 Wireless LAN Card
                      1…Software Loopback Interface 1[/HEADING]
                      [HEADING=1]IPv4 Route Table[/HEADING]
                      [HEADING=1]Active Routes:
                      0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.105 50
                      192.168.1.0 255.255.255.0 On-link 192.168.1.105 306
                      192.168.1.105 255.255.255.255 On-link 192.168.1.105 306
                      192.168.1.255 255.255.255.255 On-link 192.168.1.105 306
                      224.0.0.0 240.0.0.0 On-link 192.168.1.105 306
                      255.255.255.255 255.255.255.255 On-link 192.168.1.105 306[/HEADING]
                      Persistent Routes:
                      None
                      [HEADING=1]IPv6 Route Table[/HEADING]
                      1 331 ::1/128 On-link
                      20 306 fe80::/64 On-link
                      20 306 fe80::51ba:aa4e:3551:39d7/128
                      On-link
                      1 331 ff00::/8 On-link
                      20 306 ff00::/8 On-link[/HEADING]
                      Persistent Routes:
                      None
                      Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
                      Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                      Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                      Catalog5 04 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
                      Catalog5 05 C:\WINDOWS\SysWOW64\NLAapi.dll [71168] (Microsoft Corporation)
                      Catalog5 06 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog5 07 C:\WINDOWS\SysWOW64\winrnr.dll [34304] (Microsoft Corporation)
                      Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
                      x64-Catalog5 01 C:\Windows\System32\napinsp.dll [70144] (Microsoft Corporation)
                      x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
                      x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
                      x64-Catalog5 04 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
                      x64-Catalog5 05 C:\Windows\System32\NLAapi.dll [97280] (Microsoft Corporation)
                      x64-Catalog5 06 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog5 07 C:\Windows\System32\winrnr.dll [49152] (Microsoft Corporation)
                      x64-Catalog9 01 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 02 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 03 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 04 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 05 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 06 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 07 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 08 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 09 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 10 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 11 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 12 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 13 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      x64-Catalog9 14 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
                      Error: (11/05/2023 08:01:59 PM) (Source: CertEnroll) (EventID: 86) (User: NT AUTHORITY)
                      Description: Event-ID 86
                      Error: (11/05/2023 08:01:21 PM) (Source: VSS) (EventID: 8193) (User: )
                      Description: Volume Shadow Copy Service error: Unexpected error calling routine CoCreateInstance. hr = 0x8007045b, A system shutdown is in progress.
                      Error: (11/05/2023 08:01:21 PM) (Source: VSS) (EventID: 13) (User: )
                      Description: Volume Shadow Copy Service information: The COM Server with CLSID {4e14fba2-2e22-11d1-9964-00c04fbbb345} and name CEventSystem cannot be started. [0x8007045b, A system shutdown is in progress.
                      Error: (11/05/2023 08:01:20 PM) (Source: Application Error) (EventID: 1000) (User: )
                      Description: Faulting application name: gameinputsvc.exe, version: 0.2210.22621.1863, time stamp: 0x90d61c52
                      Faulting module name: gameinputsvc.exe, version: 0.2210.22621.1863, time stamp: 0x90d61c52
                      Exception code: 0xc0000005
                      Fault offset: 0x0000000000004c9d
                      Faulting process ID: 0x3d0c
                      Faulting application start time: 0x01da101a765b0c57
                      Faulting application path: C:\Program Files (x86)\Microsoft GameInput\x64\gameinputsvc.exe
                      Faulting module path: C:\Program Files (x86)\Microsoft GameInput\x64\gameinputsvc.exe
                      Report ID: 6423664d-502e-495b-85b2-6ed44cf9820d
                      Faulting package full name:
                      Error: (11/05/2023 04:31:01 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
                      Description: Event-ID 2
                      Error: (11/04/2023 03:54:17 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
                      Error: (11/04/2023 03:54:17 PM) (Source: Firefox Default Browser Agent) (EventID: 12007) (User: )
                      Description: Event-ID 12007
                      Error: (11/04/2023 03:54:17 PM) (Source: Firefox Default Browser Agent) (EventID: 0) (User: )
                      Description: Event-ID 0
                      Error: (11/03/2023 03:40:08 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
                      Error: (11/02/2023 03:40:08 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
                      Error: (10/29/2023 05:42:01 PM) (Source: DCOM) (EventID: 10010) (User: LAPTOP-6ODOHNQP)
                      Description: Event-ID 10010
                      Error: (10/27/2023 02:38:52 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      Description: Miniport Microsoft Wi-Fi Direct Virtual Adapter #3, {3453b32d-1ecc-413d-9629-4af7469e1a2f}, had event 74
                      Error: (10/22/2023 09:40:58 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      Error: (10/22/2023 03:52:20 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      Error: (10/21/2023 02:09:53 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      Error: (10/19/2023 03:17:58 PM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      Error: (10/16/2023 01:04:37 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      Error: (10/14/2023 02:43:27 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: NT AUTHORITY)
                      Error: (10/12/2023 04:56:16 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      Error: (10/09/2023 12:53:17 PM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
                      [HEADING=1]Windows Defender:[/HEADING]
                      Date: 2023-11-05 09:43:56
                      Description:
                      Microsoft Defender Antivirus scan has been stopped before completion.
                      Scan Type: Antimalware
                      Scan Parameters: Quick Scan
                      Date: 2023-11-04 08:09:01
                      Description:
                      Date: 2023-11-03 04:24:00
                      Description:
                      Date: 2023-11-02 07:08:26
                      Description:
                      Date: 2023-11-01 04:44:11
                      Description:
                      Event[0]:
                      Date: 2023-10-25 12:42:40
                      Description:
                      Microsoft Defender Antivirus has encountered an error trying to update security intelligence.
                      New security intelligence Version:
                      Previous security intelligence Version: 1.399.1226.0
                      Update Source: Microsoft Malware Protection Center
                      Security intelligence Type: AntiVirus
                      Update Type: Full
                      Current Engine Version:
                      Previous Engine Version: 1.1.23090.2007
                      Error code: 0x80072efe
                      Error description: The connection with the server was terminated abnormally
                      Description:
                      Security intelligence Type: AntiSpyware
                      Update Type: Full
                      Description:
                      Update Type: Full
                      Description:
                      Update Type: Full
                      Error code: 0x80072ee2
                      Error description: The operation timed out
                      Description:
                      Update Type: Full
                      [HEADING=1]CodeIntegrity Errors:[/HEADING]
                      Date: 2023-10-30 07:43:23
                      Description:
                      Code Integrity determined that a process (\Device\HarddiskVolume3\ProgramData\Microsoft\Windows Defender\Platform\4.18.23090.2008-0\MsMpEng.exe) attempted to load \Device\HarddiskVolume3\Program Files\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
                      Date: 2023-10-23 07:58:26
                      Description:
                      Code Integrity determined that a process (\Device\HarddiskVolume3\Program Files (x86)\Microsoft\EdgeWebView\Application\118.0.2088.46\msedgewebview2.exe) attempted to load \Device\HarddiskVolume3\Windows\System32\nvspcap64.dll that did not meet the Microsoft signing level requirements.
                      Date: 2023-10-04 15:31:11
                      Description:
                      Code Integrity determined that a process (\Device\HarddiskVolume3\ProgramData\Microsoft\Windows Defender\Platform\4.18.23080.2006-0\MsMpEng.exe) attempted to load \Device\HarddiskVolume3\Program Files\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
                      Date: 2023-08-26 14:26:50
                      Description:
                      Code Integrity determined that a process (\Device\HarddiskVolume3\ProgramData\Microsoft\Windows Defender\Platform\4.18.23070.1004-0\MsMpEng.exe) attempted to load \Device\HarddiskVolume3\Program Files\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
                      Adobe Acrobat (64-bit) (HKLM...{AC76BA86-1033-1033-7760-BC15014EA700}) (Version: 23.006.20360 - Adobe)
                      AI Noise Cancelation Audio Software (HKLM-x32...{ab5f014e-883d-470d-bc2d-127ef91e5611}) (Version: 2.0.3 - ASUSTek Computer Inc.)
                      AI Noise Cancelation Audio Software SDK (HKLM...{9B441197-6389-46FC-BE60-56C8B6E5ADE9}) (Version: 1.0.6 - ASUSTeK COMPUTER INC.)
                      Amys Greenmart 2 - Crimson Island (HKLM-x32...\Amys Greenmart 2 - Crimson IslandFinal) (Version: Final - Game Owl)
                      ARMOURY CRATE Service (HKLM...{01378DC3-088F-4F55-AAFA-DC6A9CCA292A}) (Version: 5.4.8 - ASUS)
                      ASUS Aac_GmAcc HAL (HKLM...{998249B1-6913-447E-AA37-F445B8CA33D0}) (Version: 1.0.0.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Aac_GmAcc HAL (HKLM-x32...{fd4cf3d0-9937-417e-89b4-56658158819a}) (Version: 1.0.0.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Aac_NBDT HAL (HKLM...{01D3B7AA-D078-4506-B460-60877FCDDBD6}) (Version: 2.5.24.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Aac_NBDT HAL (HKLM-x32...{ba95a7ce-ede3-4308-a5d6-6c08a15bff04}) (Version: 2.5.24.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS AURA Display Component (HKLM...{AFD1CF98-FE97-434C-A095-9F27C5BEA53C}) (Version: 1.2.12.0 - ASUSTek COMPUTER INC. ) Hidden
                      ASUS AURA Display Component (HKLM-x32...{fe2996bf-7174-4ad7-af8c-3e8e510c8263}) (Version: 1.2.12.0 - ASUSTek COMPUTER INC. ) Hidden
                      ASUS AURA Headset Component (HKLM...{A3C4120D-8096-4307-91A2-FFE37EBD5A3D}) (Version: 1.3.26.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS AURA Headset Component (HKLM-x32...{b351ae91-a5dd-4741-8830-883dddd22eb7}) (Version: 1.3.26.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Aura SDK (HKLM...{CF8E6E00-9C03-4440-81C0-21FACB921A6B}) (Version: 3.04.39 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Framework Service (HKLM-x32...{339A6383-7862-46DA-8A9D-E84180EF9424}) (Version: 3.1.0.2 - ASUSTeK Computer Inc.)
                      ASUS Framework Service (HKLM-x32...{80f60ecc-98e1-474b-aee2-0c470f02dbbc}) (Version: 2.0.2.6 - ASUSTek COMPUTER INC.)
                      ASUS Framework Service (HKLM-x32...{EA6A87BE-8AD3-40D2-944C-9DF5FBFF4332}) (Version: 2.0.2.6 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Keyboard HAL (HKLM...{0FA0CDEE-5DC8-421E-A97D-C74FA6E66FC3}) (Version: 1.1.48.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Keyboard HAL (HKLM-x32...{79497ebd-229a-42ac-9410-87264af2e929}) (Version: 1.1.48.0 - ASUSTek COMPUTER INC.) Hidden
                      ASUS MB Peripheral Products (HKLM...{BFED9861-7D96-4528-89F1-B090ABBF11A7}) (Version: 1.0.35 - ASUSTeK Computer Inc.) Hidden
                      ASUS MB Peripheral Products (HKLM-x32...{193a2068-8738-4276-ab1b-9133f9403487}) (Version: 1.0.35 - ASUSTeK Computer Inc.) Hidden
                      ASUS Mouse HAL (HKLM...{B8F984F2-7887-4DD2-8D96-F9A4BC5A4AC5}) (Version: 1.1.0.45 - ASUSTek COMPUTER INC.) Hidden
                      ASUS Mouse HAL (HKLM-x32...{559342ce-3e0f-4daf-bd9f-dfb67f065c28}) (Version: 1.1.0.45 - ASUSTek COMPUTER INC.) Hidden
                      ASUS MultiAntenna Service (HKLM...{EBB02F2E-0856-4B8A-9E70-980102C90BBA}) (Version: 3.2.2 - ASUSTeK COMPUTER INC.)
                      ASUS Smart Display Control (HKLM-x32...{8714A8D1-0F08-4681-9DF6-A8C4607A58B4}) (Version: 1.2.0 - ASUSTek COMPUTER INC.)
                      ASUS Update Helper (HKLM-x32...{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.107.107 - ASUSTeK Computer Inc.) Hidden
                      AURA lighting effect add-on (HKLM-x32...{1E2EA04B-FCA7-457E-B6F4-F33E1858E859}) (Version: 0.0.28 - ASUS)
                      AURA lighting effect add-on x64 (HKLM...{C5A4A164-4428-4931-B728-96EEF0FA3C44}) (Version: 0.0.28 - ASUS)
                      AURA Service (HKLM-x32...{0fcadbd2-1a6a-4a4a-a56d-fc7163d9b3fa}) (Version: 3.07.25 - ASUSTeK Computer Inc.)
                      AURA Service (HKLM-x32...{56EEEF7D-0AE3-401A-898B-581719D005AE}) (Version: 3.07.25 - ASUSTeK Computer Inc.) Hidden
                      FreeWriter (HKLM-x32...{6BB5F8AA-0329-400C-B4B9-82DBE033746F}) (Version: 1.0.7 - Lifestyle Toolbox)
                      GameSDK Service (HKLM-x32...{021d69c3-d686-4a94-8fb5-fd1ee782fb14}) (Version: 1.0.5.0 - ASUSTek COMPUTER INC.)
                      GameSDK Service (HKLM-x32...{7160DA8D-3F25-4F6E-ABC8-F693551D82FA}) (Version: 1.0.5.0 - ASUSTek COMPUTER INC.) Hidden
                      Golden Rails 3 - Road to Klondike Collector’s Edition (HKLM-x32...\Golden Rails 3 - Road to Klondike Collector’s EditionFinal) (Version: Final - Game-Owl)
                      Golden Rails 4- World’s Fair CE (HKLM-x32...\Golden Rails 4- World’s Fair CEFinal) (Version: Final - Game Owl)
                      LibreOffice 7.1.3.2 (HKLM...{76B2DBF3-5773-4463-9EEB-D4A099EB6265}) (Version: 7.1.3.2 - The Document Foundation)
                      Malwarebytes version 4.6.3.282 (HKLM...{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 4.6.3.282 - Malwarebytes)
                      Microsoft 365 - en-us (HKLM...\O365HomePremRetail - en-us) (Version: 16.0.16924.20124 - Microsoft Corporation)
                      Microsoft Update Health Tools (HKLM...{89581302-705F-42C5-99B0-E368A845DAD5}) (Version: 3.70.0.0 - Microsoft Corporation)
                      Mozilla Firefox (x64 en-US) (HKLM...\Mozilla Firefox 119.0 (x64 en-US)) (Version: 119.0 - Mozilla)
                      Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 110.0 - Mozilla)
                      MusicBee 3.5.8447 (HKLM-x32...\MusicBee) (Version: 3.5.8447 - Steven Mayall)
                      NVIDIA FrameView SDK 1.1.4923.29548709 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_FrameViewSdk) (Version: 1.1.4923.29548709 - NVIDIA Corporation)
                      NVIDIA GeForce Experience 3.21.0.36 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.21.0.36 - NVIDIA Corporation)
                      NVIDIA Graphics Driver 462.06 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 462.06 - NVIDIA Corporation)
                      NVIDIA HD Audio Driver 1.3.38.40 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.40 - NVIDIA Corporation)
                      NVIDIA PhysX System Software 9.20.0221 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.20.0221 - NVIDIA Corporation)
                      Office 16 Click-to-Run Extensibility Component (HKLM...{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.16924.20124 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Licensing Component (HKLM...{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.16924.20078 - Microsoft Corporation) Hidden
                      Office 16 Click-to-Run Localization Component (HKLM...{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.13127.20616 - Microsoft Corporation) Hidden
                      Rainlendar2 (remove only) (HKLM-x32...\Rainlendar2) (Version: - )
                      RefreshRateService (HKLM-x32...{7E5E84CB-B190-4658-A4DC-166779C329D1}) (Version: 2.1.0 - ASUSTeK COMPUTER INC.)
                      ROG CustomHotkey (HKLM-x32...{374883e6-b31d-4a3c-9c4a-2685a840aed4}) (Version: 1.1.1 - ASUSTek Computer Inc.)
                      ROG Live Service (HKLM...{2D87BFB6-C184-4A59-9BBE-3E20CE797631}) (Version: 2.0.4.0 - ASUSTek COMPUTER INC.)
                      Roman Adventures - Britons 2 (HKLM-x32...\Roman Adventures - Britons 2Final) (Version: Final - Game-Owl)
                      Shotcut (HKLM...\Shotcut) (Version: 21.10.31 - Meltytech, LLC)
                      Speccy (HKLM...\Speccy) (Version: 1.32 - Piriform)
                      Speedify (HKLM...\Speedify) (Version: 12.8.0.10689 - Connectify)
                      TreeSize Free V4.6.3 (64 bit) (HKLM...\TreeSize Free_is1) (Version: 4.6.3 - JAM Software)
                      Undercover - Blood Bonds (HKLM-x32...\Undercover - Blood BondsFinal) (Version: Final - Game Owl)
                      Waterfox (x64 en-US) (HKLM...\Waterfox 102.5.0 (x64 en-US)) (Version: 102.5.0 - WaterfoxLimited)
                      Welcome to Primrose Lake 2 Premium Edition (HKLM-x32...\Welcome to Primrose Lake 2 Premium EditionFinal) (Version: Final - Game Owl)
                      Welcome to Primrose Lake 3 (HKLM-x32...\Welcome to Primrose Lake 3Final) (Version: Final - Game Owl)
                      Windows PC Health Check (HKLM...{6798C408-2636-448C-8AC6-F4E341102D27}) (Version: 3.6.2204.08001 - Microsoft Corporation)
                      WinRAR 6.02 (64-bit) (HKLM...\WinRAR archiver) (Version: 6.02.0 - win.rar GmbH)
                      WizTree v4.12 (HKLM...\WizTree_is1) (Version: 4.12 - Antibody Software)
                      [HEADING=1]Packages:[/HEADING]
                      Adobe Acrobat Reader β†’ C:\Program Files\Adobe\Acrobat DC [2023-10-29] (0)
                      AMD Radeon Software β†’ C:\Program Files\WindowsApps\advancedmicrodevicesinc-2.amdradeonsoftware_10.21.30024.0_x64__0a9344xs7nr4m [2022-09-12] (Advanced Micro Devices Inc.) [Startup Task]
                      ARMOURY CRATE β†’ C:\Program Files\WindowsApps\B9ECED6F.ArmouryCrate_5.4.8.0_x64__qmba6cd70vzyy [2023-09-14] (ASUSTeK COMPUTER INC.)
                      AURA Creator β†’ C:\Program Files\WindowsApps\B9ECED6F.AURACreator_3.5.6.0_x64__qmba6cd70vzyy [2023-02-01] (ASUSTeK COMPUTER INC.)
                      Disney+ β†’ C:\Program Files\WindowsApps\Disney.37853FC22B2CE_1.45.5.0_x64__6rarf9sa4v8jt [2023-02-02] (Disney)
                      Dolby Access β†’ C:\Program Files\WindowsApps\DolbyLaboratories.DolbyAccess_3.16.345.0_x64__rz1tebttyb220 [2023-01-23] (Dolby Laboratories)
                      Microsoft Whiteboard β†’ C:\Program Files\WindowsApps\Microsoft.Whiteboard_53.10114.505.0_x64__8wekyb3d8bbwe [2023-01-20] (Microsoft Corporation)
                      MyASUS β†’ C:\Program Files\WindowsApps\B9ECED6F.ASUSPCAssistant_3.1.13.0_x64__qmba6cd70vzyy [2022-12-23] (ASUSTeK COMPUTER INC.)
                      NVIDIA Control Panel β†’ C:\Program Files\WindowsApps\NVIDIACorp.NVIDIAControlPanel_8.1.963.0_x64__56jybvy8sckqj [2022-10-29] (NVIDIA Corp.)
                      Realtek Audio Control β†’ C:\Program Files\WindowsApps\RealtekSemiconductorCorp.RealtekAudioControl_1.37.275.0_x64__dt26b99r8h8gj [2022-11-14] (Realtek Semiconductor Corp)
                      Solitaire & Casual Games β†’ C:\Program Files\WindowsApps\Microsoft.MicrosoftSolitaireCollection_4.15.12020.0_x64__8wekyb3d8bbwe [2023-02-02] (Microsoft Studios) [MS Ad]
                      Spotify Music β†’ C:\Program Files\WindowsApps\SpotifyAB.SpotifyMusic_1.203.1115.0_x86__zpdnekdrzrea0 [2023-01-20] (Spotify AB) [Startup Task]
                      Percentage of memory in use: 56%
                      Total physical RAM: 15792.36 MB
                      Available physical RAM: 6868.79 MB
                      Total Virtual: 31584.73 MB
                      Available Virtual: 19364.09 MB
                      1 Drive c: (OS) (Fixed) (Total:453.5 GB) (Free:19.98 GB) NTFS
                      User accounts for \LAPTOP-6ODOHNQP
                      acco5 Administrator DefaultAccount
                      Guest WDAGUtilityAccount
                      **** End of log ****
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #12
                        From the logs you are getting DNS time outs.
                        [COLOR=rgb(184, 49, 47)]DNS request timed out.
                        [COLOR=rgb(184, 49, 47)]timeout was 2 seconds.
                        So Do these steps. Disable IPV6
                        Find the best dns server for your machine.
                        Disable [COLOR=rgb(184, 49, 47)]Miniport Microsoft Wi-Fi Direct Virtual Adapter #3, in your device manager.
                        Then reboot your computer and post a new log for me to check and make sure everything is changed.[/COLOR][/COLOR][/COLOR]
                        • Data838
                          • Nov 2021
                          • 90
                          #13
                          I got to the part Find the best dns server for your machine and wanted to make sure if I have to also proceed with How to change your DNS server with command prompt page because these instructions are a bit hard for me to understand. If so, is it possible to avoid Google DNS as alternate DNS server? I don’t know exactly in what volume it would affect my system, but usually I try to avoid everything related to Google. So hould I just paste the numbers after C:\WINDOWS\system32> because there is no word code there? Also, there’s a list of DNS servers below, so should I choose one from there and based on what criteria? Thank you in advance.
                          • Malnutrition
                            PCHF Moderator
                            • 7041
                            #14
                            If you run DNS benchmark there will be a list of dns servers that are best for your machine., if you can get that far and provide a screen shot of the fastest dns servers for your machine we can go from there.
                            • Malnutrition
                              PCHF Moderator
                              • 7041
                              #15
                              A simpler way to change the dns server would be this tool, after you have used the dns bench tool to find the fastest/
                              DNS Jumper is a free and portable software that lets you change DNS with a few clicks and is the world's first IPv6 support software.
