I used to play league of legends at 44ms for days, but last night it went up to 120ms and its not going down no matter what i try, i tried youtube tutorials but its still the same, idk what to do anymore its so annoying
My ping in game became high out of nowhere, I need help please
Ping fluctuates, depending on how busy the servers are (events can make it worse depending on how the game functions), but weβll see what we can do about it.
Letβs get some more information:
Download and run the free version of speccy.
Once you have ran speccy, follow the instructions to upload a snapshot found here.
[ol]
[li]In Speccy, click File, and then click Publish Snapshot.[/li][li]In the Publish Snapshot dialog box, click Yes to enable Speccy to proceed.[/li][li]Speccy publishes the profile and displays a second Publish Snapshot dialog box. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.[/li][/ol]
If it is a desktop unit, please list your power supply unit.
Run a speedtest and get the results back to us, I like Ookla. -
Thank you for helping me, I just want my 44ms back smhComment
Those speeds are no good for online gaming, thatβs probably a contributing factor.
Do you have any other issues in the game?
This is my laundry list, itβs a good starting point for troubleshooting and should get you an idea whatβs going on:- Try running the following programs, also try to keep at least 25-30% of your disks as free space.
Run Disk Cleanup (check all the boxes) this will delete things such as your recycling bin, so make sure you donβt have any files you want to keep.
Run Defragment and Optimize Drives, run this on your drives.- Disable any overclocking or changes to power/performance settings
Undo any overclocking you may have done (if any)
Settings > System > Power and sleep > Additional power settings
Make sure your power plan is set to balanced, high performance/ultimate performance is only beneficial on gaming laptops where it needs that extra boost.- Check for Operating System Corruption
Right click on the Windows logo in the bottom left and select Windows Powershell (Admin)
Run these three commands separately:
[COLOR=rgb(184, 49, 47)]sfc /scannow
Dism /Online /Cleanup-Image /CheckHealth
Dism /Online /Cleanup-Image /RestoreHealth
These will take a while to run, do not close out of Powershell while they are running, if one fails then move onto the next and then loop back around.
Note: It doesnβt hurt to make a system backup before you make all these changes, save any important files of folders. While these changes shouldnβt cause any issues, better to be safe than sorry.- Unplug unnecessary devices.
If you have a gamepad, extra monitor, external hard drive/flash drive, or anything that is not essential to using the computer plugged in, unplug it.
Once you have completed all of these tasks, restart it (using the restart option in the power menu) and re-test.[/COLOR]Comment
