Ethernet not connected
  • Penfold7
    • Jul 2021
    • 159
    I recently swapped and relocated my router. I also bought new Cat6 cables for my 3 Ethernet connected devices, a sky q box, Sony android TV, and a powerline adapter.
    Since then I’ve had issues with the TV every couple of days dropping the Ethernet connection, and it being a pain to restore. Sometimes unplugging and plugging in the cable works, reboot TV or reboot router. All other Ethernet devices are fine. I was suspecting the TV had a DHCP lease issue, but I appear to have solved the issue by replacing the Ethernet cable to TV with a cat5e cable and it’s been fine. My question is, why would a cat5 cable be fine but a Cat6 not… The other 2 devices are fine on these cables. I was under the impression cat6 was backward compatible. I would be interested in people’s opinions, unless it was just a faulty cable ???
  • Pyro
    • Jan 2019
    • 1189
    You bought the same cables for all 3 devices? Try switching them around to see if one of the Cat6 is faulty.
    If you were having no issues with the other devices, I would imagine it to be a cable issue.
      @Penfold7 - any news?
      • Pyro
        • Jan 2019
        • 1189
        Sounds good, @veeg can mark this as pending and you can get back to us in a few days.
          did you get shielded or unshielded cat6 cable?
          what is the cable run length from the TV to the modem/router?
          what are the differences between the cat5 and 6 that you know, like cat5e and cat6a, solid vs stranded?
          • Penfold7
            • Jul 2021
            • 159
            Hi Bruce. Whilst I am a little knowledgeable about networking, your questions are a little beyond me???. The cables I got were 3m in length. All 3 I bought were the same type. Cable run from router to TV, Sky box and powerline adapter are all about the same. These are the cables I bought from Amazon.
              i was trying to see if there were any differences between the cable the worked and the one that didn’t.
              has the TV lost connection since changing the ethernet cable?
              • Penfold7
                • Jul 2021
                • 159
                I’ve been checking every day. It’s renewed it’s lease today according to the router. I’ll check If the TV still has a connection later on. Only reason I never suspected the cable was they were all new and the other 2 were working fine, and on a couple of occasions when I swapped ports on the router connection came back up. Lesson for me, always check the simplest things first???
                • Penfold7
                  • Jul 2021
                  • 159
                  The TV is still connected, so barring anything else looks like a cable issue. To be honest the symptoms were a bit odd for a cable issue, I would have assumed the cable would either work or not. I wasn’t expecting bizarre connection issues like this, were a router or TV reboot, or even just changing port on router sometimes would make the connection again ..
                  You live and learn ???
                    #10
                    yeah, computers and tech can be like that.
                    let’s leave this open a couple more days and see if anything happens.
                      #11
                      closing as solved (y)
                      • Penfold7
                        • Jul 2021
                        • 159
                        #12
                        Typically as soon as thread closed the issue reoccurs…
                        Can’t really be another cable issue, but it’s odd this one stayed connected for longer. A cat5 cable stayed connected. I’m at a loss now. Options I feel are.
                        1.. switch to a cat5 cable
                        2.. swap out the router for another one. I’m currently using a BT business hub 6, but I do have my older Plusnet hubq
                        3.. it’s the TV at fault. I have contacted Sony, but they are not very helpful…asking me to do odd things like connect the TV to my mobile via a hotspot.
                        4.. give up and use wireless for the TV and see if that works…
                        Happy if anyone has any other ideas
                        • Penfold7
                          • Jul 2021
                          • 159
                          #13
                          I’ve got ethernet back by swapping ports on the router. I’m feeling more and more this is a router issue
                          • Rustys
                            • 7862
                            #14
                            merged and reopened threads
                            • Rustys
                              • 7862
                              #15
                              @Pyro @Bruce
