ip not valid, error 0x80070483
  • technologicalpixel
    • Dec 2021
    • 12
    basically all my pc connected with ethernet to the modem, sometime work and sometime don’t, when they don’t i get the error β€œip configuration not valid” 0x80070483
    This is happening from when i changed my modem/internet connection , probably is configured bad but i have no idea of how to check it
    This problem pops up only on pc connected with ethernet, all wifi device are connected and have no problem
    also if i change the spot of the ethernet cable multiple times then it work again, or if i do right click on the internet icon in the bottom right of windows and then β€œtroubleshooting”
    Does anyone know why is happening and how i can fix it? thanks!
    ps: i unistalled kmspico sorry about that, please help me
  • Malnutrition
    PCHF Moderator
    • 7041
    How to Get windows 10 key, If you are need windows 10 product key buy direct games windows 10 pro product key. Direct games offer cheap windows 10 pro key.
    Here is a key for under 12 dollars. You can use paypal. It’s Unfortunate that uninstalling Kmspico still leaves the machine activated. So basically you have used Kmspico to activate the machine, and then just uninstalled it. Provide me proof that you have purchased they key via private message, then we can continue. You can block out your name and any credit card info, I do not care about that, I only need to see that it is purchased.
    The websites checks out as legit.
    Check directgames.store with our free review tool and find out if directgames.store is legit and reliable. Need advice? βœ“ Report scams βœ“ Check Scamadviser!
    Or show me that windows is not activated and we can continue. To check activation status in Windows 10, select the Start button, and then select Settings > Update & Security and then select Activation . Your activation status will be listed next to Activation.
    Screen shot that and post it here.
    • jmarket
      PCHF Owner
      • 7695
      • CachyOS
      • Intel Arc A770 (16 GB)
      We can not assist unless you provide proof that the activation is real and you have a valid license. When you signed up you agreed to our terms and conditions. Failure to do will result in this thread being closed
        • Dec 2021
        • 12
        [ATTACH type=β€œfull”]9598[/ATTACH]
        • Malnutrition
          PCHF Moderator
          • 7041
          I have to go by what jmarket has said. Showing that the machine is not activated is not what he wants. In order to get help here you must purchase a windows 10 key And provide proof to either of us via private message.
          • Rustys
            • 7862
            This is the second time that you have been told this on this forum.
              • Dec 2021
              • 12
              isn’t also illegal to buy keys not from the official microsoft site?
              • Malnutrition
                PCHF Moderator
                • 7041
                No. Many vendors are licensed to sell windows keys.
                  • Dec 2021
                  • 12
                  how can i verify that?
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #10
                    The link I sent you, is legit. They are certified Microsoft partners.
                      • Dec 2021
                      • 12
                      #11
                      alright i have bought it
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #12
                        Ok, activate your windows computer with the key. And I’ll send instructions when I get home from work.
                        Send me the picture of the key and your activation Stats with that key via private message.
                        You should not post that key here in the open forum.
                        • Malnutrition
                          PCHF Moderator
                          • 7041
                          #13
                          It’s just the way it has to be, this forum could get shut down if we supported illegal software. ???
                          • Malnutrition
                            PCHF Moderator
                            • 7041
                            #14
                            Still await the private message detailing your activation.
                            • Malnutrition
                              PCHF Moderator
                              • 7041
                              #15
                              @technologicalpixel any luck with the activation?
