Network Shares
  • Penfold7
    • Jul 2021
    • 159
    Network Shares
    I have 4 pcs on my internal network. They are all in the same named workgroup.
    2 laptops run Windows 10 Home, 1 Desktop runs Windows 10 Pro, and the newest laptop runs Windows 11.
    1 laptop on Win 10 home is on Version 21H2, the other on 2004. The Win 10 Pro is on 20H2. Windows 11 is up to date.
    My issues are viewing of network shares. All Windows 10 systems see each other and can access each others Public folders with no issues. (At times the icons randomly appear and disappear, but shares can still be accessed by using \PCNAME\ )
    The win 10 systems can see the Win 11 system, but no public folder is seen when we try and access the system. There are no error messages.
    All systems networks are set to private. File and Printer sharing is turned on as is network discovery, under the Private profile.
    Password protected sharing is off under all networks.
    I have no idea why we cannot see the public folder on the win 11 system. The win 11 system can see and access all the windows 10 public folders.
    Any ideas?
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    try turning on password protection on win 11
    Just to test.
    also check smb in windows 11 https://www.thewindowsclub.com/check...ersion-windows
    • PeterOz
      • Mar 2021
      • 4181
      and this in group policy
      [ol]
      [li]Scroll the list to find the policy β€œNetwork Security: LAN Manager authentication level”.[/li][li]Right click on this policy and choose β€œProperties”.[/li][li]Choose β€œSend NTLMv2 response only/refuse LM & NTLM” (My original setting was: β€œSend LM & NTLM - use NTLMv2 session security if negotiated” )[/li][li]Click OK and confirm the setting change.[/li][li]Close the β€œGroup Policy” window.[/li][/ol]
      • Penfold7
        • Jul 2021
        • 159
        Thanks. Will try these tomorrow. I rightly or wrongly assumed that as I could see the win 11 system, that smb client would be enabled, but I will check this also. I think it’s win11 home, is group policy access able??
        • PeterOz
          • Mar 2021
          • 4181
          Home should be illegal I am not sure my guess no
          • Penfold7
            • Jul 2021
            • 159
            Thanks. Will check anyways
            • Penfold7
              • Jul 2021
              • 159
              I agree why not just have 1version…if you don’t need the features then don’t use them or at least let there be a way to enable these features… Seems more like a marketing and money thing to me
                @Penfold7 - do you still need help?
                • Penfold7
                  • Jul 2021
                  • 159
                  Hi… Really sorry for not getting back, other more pressing matters have taken up my time.. I will get to looking at the suggestions made today or tomorrow… I didn’t mention and not sure if it makes any odds… I had to set up win11 with a Microsoft account, but then reverted to a local account, it wouldn’t let me setup with a local account. All win 10 systems are on local accounts…
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #10
                    On the one that does not work and on one that does
                    Open the cmd prompt and either type or copy and paste
                    what is in Blue. What is in Red is what you do e.g Enter (Press the Enter key)
                    [COLOR=rgb(84, 172, 210)]ipconfig /all >β€œ%userprofile%\desktop\ipconfig.txt” [COLOR=rgb(226, 80, 65)]Enter
                    This should put a text file on your desktop. Please attach the files in your reply.[/COLOR][/COLOR]
                      #11
                      To avoid us having to ask for an update every couple of days we will close this thread until the OP has the time available to work towards resolving the issue, Penfold7, PM a member of staff when you are ready and the thread can be reopened.
                        #12
                        Thread reopened at request of Penfold7.
                        • Penfold7
                          • Jul 2021
                          • 159
                          #13
                          I had a look today, as I now have time. Whilst checking a few basic things such as the sharing status of the folders, I went back to the advanced sharing options, and under all networks, public file sharing had switched itself off, even though when I checked the public folder it was actually shared to all users. I enabled this again, and all seems fine, and all PCs on the network can see each others public folders.
                          I have no idea how it came to be switched off, as I am almost 100% certain I enabled it previously. Note to self… Check the basics first!!!
                          I did find it odd, that all PCs could see the win 11 system, just no folders, and the 11 system could see every other PCs public folders
                            #14
                            good outcome!
