PC Internet doesn’t work
  • Tokage
    • Dec 2021
    • 1
    I built my pc over a year ago and had no problems whatsoever, but recently when i use my pc the internet connection doesn’t work. It says it’s connected and with internet access but the wifi does not work and I don’t recall recently installing anything new. Weird thing is that the only app the wifi seems to work on is League of Legends, I can get into online matches fine and everything works well. I’ve had this problem for a while now and I would usually just fix the problem with a system restore from a week back but then as of now I have no restore point to go back to and my pc internet continues to not work.
    Are you using the mobo interface for your internet or a card?
    @Rustys
      Abandoned
