Laptop won't connect anymore to a specific network over wi-fi
  • Lustro
    • Nov 2021
    • 37
    Hi,
    Itโ€™s the second time that a laptop, an Asus X541U, out of the blue doesnโ€™t connect to my wi-fi anymore. It used to connect to it and I could use it no problem for several months, then one day it automatically disconnected and wonโ€™t let me connect anymore: whenever I try to connect, Windows 10, after โ€œverifying the networkโ€™s requirementsโ€, displays an error stating โ€œConnecting to this network is not possibleโ€ (Iโ€™m translating so it may not be fully accurate), but it doesnโ€™t specify why.
    The first time this happened, we reinstalled Windows from scratch and the Wi-Fi worked just fine for around seven months, until now. Both times, weโ€™ve tried connecting it to an hotspot and that works, thatโ€™s why I think itโ€™s specific to this network (although I have no other means of testing besides hotspot). Connecting it via ethernet to the router works.
    Iโ€™ve tried making it forget the password and reinsert it, Iโ€™ve tried changing DNS, switching it to airplane mode for a while, resetting the network configuration (via Windows 10 itself) and tried the Windows 10 tool to solve network problems, Iโ€™ve also just now updated it to Windows 21H2, but nothing works.
    Could you give me any advice? If you need any specific info Iโ€™d be more than happy to comply; reinstalling windows from scratch might work once again, but doing so everytime this problem arises doesnโ€™t sound ideal.
    Thanks in advance and sorry for the English, itโ€™s not my native language
    • Lustro
      • Nov 2021
      • 37
      Thanks for the answer, this is the result http://speccy.piriform.com/results/5...7PcvhBdhbALvam
      Iโ€™ve noticed some of the info is in Italian (my language), if thatโ€™s a problem I can try changing the osโ€™ language and see if that makes everything appear in English
        Sorry, did reply earlier but it must have been deleted by the issues that we are presently having
        [COLOR=rgb(226, 80, 65)]ASUS Wireless Radio Control Have you reinstalled the drivers for this direct from ASUS.
        [COLOR=rgb(226, 80, 65)]Driver Booster SkipUAC (Tina) Avoid such garbage like the plague.
        Once Windows has been installed, you install the necessary drivers for the MB and other hardware and then leave well alone, drivers should not be allowed to auto update and you should never update any driver/s unless the new drivers are intended to resolve a specific issue that you are having, installing new drivers unnecessarily can actually cause you the very issues that any new drivers are intended to resolve and uninstalling the new drivers may not resolve the problem/s that installing the new drivers has caused.
        Depending on priority it can take many months before the driver provider releases any fix and depending on the age of the hardware or software concerned they sometimes do not even bother or may have already announced an end of support.[/COLOR][/COLOR]
        • Lustro
          • Nov 2021
          • 37
          Thank you for your answer, and no worries, no need to be sorry for the deleted message issue.
          I have tried downloading all of its drivers from the asus site (Iโ€™ve downloaded them here), including the wireless radio control one, and I rebooted just as they asked after installation - but no luck: it still wonโ€™t let me connect to my wi-fi.
          In the meantime Iโ€™ve also tried connecting to one of those public wi-fi that require you to register in order to use them, and it does connect to them leading to the registration page, but for some reason it still wonโ€™t let me connect to mine, at all - not even in the โ€œConnected but no internet availableโ€ status, it just displays a generic โ€œConnecting to this network is not possibleโ€.
          Next time I will install Windows, I will do as you suggested - I will install those drivers before connecting the computer to internet and disable windows 10 from auto-updating them. Still, Iโ€™d like to re-install Windows only as a last resort, do you think thereโ€™s anything else I could try?
            what is the make/model of the internet modem/wireless router?
            have you rebooted the modem/router?
            does the laptop connect to the web OK if using an ethernet cable from the laptop to the modem?
            • Lustro
              • Nov 2021
              • 37
              Thanks for the answer!
              1. Itโ€™s a modem bundled with the ISPโ€™s offer and installed by their technicians, on it thereโ€™s written โ€œZyxel Home&Life HUBโ€ but maybe this is a more commercial name than anything; by searching on the web I think itโ€™s a Zyxel VMG8825-B50B
              2. Do you mean powering it off and then on or something more sophisticated? If itโ€™s the first, I think Iโ€™ve tried it but it didnโ€™t work; I will surely try it again tomorrow morning, just to be sure, and post an update on the matter
              3. Yes it does! Thatโ€™s how itโ€™s been used in these days as itโ€™s needed for some work
                as to rebooting the modem, yep, just unplug it, wait a few seconds, and plug it back in.
                wait for all the green lights to stay steady, and youโ€™ll be back on the web.
                then see if the wireless connection works.
                • Lustro
                  • Nov 2021
                  • 37
                  I tried that andโ€ฆit actually worked. I feel so dumb, grateful and sorry for bothering you when it was this simple, and I really thought I had tried that before, Iโ€™m sorry about that.
                  I still wonder why that happened though, and if everytime it happens Iโ€™ll have to reboot my router (which is not a big deal, of course) or if there is a solution that is permanent.
                  Iโ€™m ignorant on the matter, but I live in a flat in which there are many home wi-fis active, my phone can detect about eight - could that be the source of the problem? I mean: maybe thereโ€™s interference or something like that, and it could be solved by moving the bandwith on another channel in the routerโ€™s settings? I donโ€™t know if what I said has any sense sorry, but maybe it can be an useful information.
                    #10
                    it could be as simple as all the other wireless networks in the area are set to the default settings and all using channel 4, or 1, or whatever.
                    so yeah, you could try changing yours to something up in the high end for both the 2.4G and 5G bands.
                    or it could be that the modem/router needs to be rebooted every month or two.
                    they arenโ€™t perfect, some are better than others, typically the one provided by your Service Provider is adequate but there are better.
                    with all the traffic flowing through these units, logging MAC address, wifi connections, up/down time etc, Iโ€™ve always felt there is this internal โ€˜bucketโ€™ that gets full and a reboot flushes everything out.
                    but hey, thatโ€™s just me!
                    • Lustro
                      • Nov 2021
                      • 37
                      #11
                      I see, thanks! I was weirded out because this was only happening with this one specific laptop, but not with any other wireless device; if there will be a โ€œnext timeโ€ in which this problem reoccurs, Iโ€™ll try changing channels to see if that works, but as long as a simple reboot of the router does it Iโ€™m pretty happy.
                      Thank you all once again and sorry if the answer was something so simple; the problem is solved, so the thread can be closed (do I have to click a button to close it or is it something only moderators can do?)
                        #12
                        always a pleasure to help - especially with a successful outcome.
