Recently I will load up a game and it will tell me I canβt connect to online. The two games I mainly play are Halo Infinite and COD warzone. Both games wonβt let me play online. Last week both games worked perfectly fine then all of a sudden neither game will work. At random times theyβll work. Halo tells me its my local network connection. Does anyone know what it could be? I hard reset my pc and the problem still happens.
Everytime I load up a game it won't connect to online services?
Check your security setting and make sure that some update and or patch has not changed a setting that now blocks them.
See what happens when you disable the security software.
Does this happen on other users on that system?
Reset the modem and router if there is one.
Wired or Wireless
Reset the computer network configuration
