Network connection issues
  • lawsonfisher
    • Mar 2021
    • 1
    Specs of my PC are at bottom of thread
    Ever since I built PC I have had wireless connection issues. I move around a lot and am using different modem and routers but can never seem to get a strong wireless signal on my pc. It should be noted that my phone and apple laptop do not have the same issue using a wireless connection so I don’t believe it has anything to do with the distance from modem/router or location of my pc. I have made sure to update all my drivers, restarted my network settings, and have done numerous tests to see what it is wrong but nothing comes up. My motherboard does not have wifi capabilities so I have plugged in a tp-link AC1300 Wireless Dual Band PCI Express Adapter (Archer T6E).
    My Network profile is Private and I am not using a metered connection. Here are some of the properties of my network.
    Security type: WPA2-Personal
    Network Band: 5 Ghz
    Link speed: 866/526
    When clicking on my wifi2 status it shows
    Ipv4 connectivity: Internet
    IPv6 Connectivity: Internet
    Speed: 585.0 Mbps
    When Diagnosing it, no issues show up.
    All three of my Firewall’s are active and on. Chrome is my main search engine and it is allowed through the firewall. When running the β€œInternet Connections” troubleshooter, no problems show up.
    I’ve had to deal with this poor connection for over two years and have spent hours trying to fix it. I ask for any suggestions and comments. Thanks in advance to anyone that tries to help.
    PC Specs
    Device name DESKTOP-SF7TFKL
    Processor AMD Ryzen 5 1600 Six-Core Processor 3.20 GHz
    Installed RAM 8.00 GB
    Device ID F150B707-74C5-4360-ABEB-C44EB1341E9D
    Product ID 00325-80784-76294-AAOEM
    System type 64-bit operating system, x64-based processor
    Pen and touch No pen or touch input is available for this display
    Motherboard B450M Gaming Plus (MS- 7b87)
    hopefully some of our members will chime in soon..
    @Bastet
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      Hi Lawsonfisher
      Welcome to PCHF
      Step 1 is to go through this list one at a time. A lot of variables with wifi. Click On Me
      Updating drivers always check that it is a TP Link driver. Windows 10 has a bad habit of replacing drivers.
      Cheers
      PeterOz
      • Rustys
        • 7862
        You state that you have three firewalls running what other security software is running on the system?
        • Bastet
          • Aug 2016
          • 1514
          I’d forgo two of the firewalls as thsee are fighting with each other & may be the cause of the speed problems.
          Is the adapter connecting to the 5Ghe network or 2.4Ghz?
          Is the adapter’s driver up to date?
          Check under the wireless properties for Duplex settings & change this to Full duplex. If you can’t find it then let me know - it’s been a long time since I had to find this so my memory is a little rusty.
            Thread closed due to lack of any feedback from the OP.
