@Evan Omo would you mind putting a second look at this thanks.
Just to confirm do you have a modem and a router or a just a modem?
When you put in the new WiFi device you did remove the old one and software?
Should not make a difference yet windows is windows.
Hare you tried removing the network references in Device Manager?
To remove them use the information under [COLOR=rgb(65, 168, 95)]Step One B In Speeding Up Your Internet Connection. Uninstalling Your Network Drivers. with in this resource.
While in Device Manager go under View and select Show Hidden Devices.
We suggest that you change the Windows Power Plan to Balanced, High Performance is a form of overclocking that is known to cause stability and overheating issues and the setting should only be used for gaming type notebooks that have a discrete GPU that needs the extra power.
If the system was close enough would suggest try connecting via cable directly to the modem to see if the same thing happens.[/COLOR]
