Trouble Streaming
  • Shmuel
    • Mar 2020
    • 4
    Trouble Streaming
    I can’t connect my Microsoft Wireless Display Adapter to Windows 10. I can see the adapter on the TV (MSDisplayAdapter_54). Added the device on Windows Settings successfully and can temporarily connect it. I even get to the firmware update stage, BUT I always lose the connection after precisely one minute.
    I have: installed the special Win app, followed every boilerplate Microsoft troubleshooting / help support page and the processes they recommend.
    After uninstalling/reinstalling the computer’s wifi network adapter, I think I’ve identified the problem, I think. It could be the fairly cheap and cheerful adapter, the TP-Link TL-WN7200ND. When I run it on the original drivers (2009 I believe), the computer will connect with the TV display adapter (for a minute). But when I run the TP-Link on the latest drivers (2012), Windows says the TV is not discoverable.
    This makes me think I need a newer/better network adapter for the computer to sync with the display adapter on the TV. Tried researching known compatibility issues, but all I get are the aforementioned boilerplate responses (which I’ve already spent hours trying to apply). Google clearly isn’t helping, so I thought I would turn to higher powers.
    Like I said, I think it’s a compatability issue between the dongle and my comp wifi adapter, but that might just be because I’ve reached the limits of my know-how.
    Help, please!
    You have answered your own question.. I read some reviews on the TP-Link and the fact it is from 2009 -ish.. You may need to find a newer wireless device..
    • Shmuel
      • Mar 2020
      • 4
      Originally posted by vger
      Thanks for your feedback, vger. Do you have any recommendations for a good, new wifi adapter?
        Check these links.. You may find some available in your area…
        https://gameslearningsociety.org/best-wireless-adapter/
        Keep a solid connection with one of the best USB Wi-Fi adapters.
        USB WiFi adapter allows you to connect your gadgets to the web whenever you want. We’ve compiled a list of the best USB WiFi Adapters to help you make the right choice
        A USB Wi-Fi adapter can improve an old device’s terrible internet connectivity. MSI’s AX1800 WiFi USB Adapter is the best one you can buy.
        • Shmuel
          • Mar 2020
          • 4
            Do you still require assistance or should we mark your thread as solved Shmuel?
            • Shmuel
              • Mar 2020
              • 4
              I’m good. Thanks again. (y)
                Great and thanks for letting us know (y)
