Itโs been a minute since Iโve been on this forum, but Iโm back with a hell of a problem.
This is the equipment I use:
My Setup:
My Problem:
Every Windows PC and iPhone I have connected to the Wi-Fi connection work just fine and are able to look things up on the internet. The only devices in my household that have a problem with the internet are the Chromebook and the Macbook Air. For some reason, they will โconnectโ to the Wi-Fi then drop the Wi-Fi immediately after. The Macbook Air doesnโt display a message as to why, however, the Chromebook comes up with a message stating that โDHCP Lookup has Failed.โ The iPhones and Windows Laptops I have work on the Wi-Fi perfectly fine close to the router and close to the extender, not the case for the Chromebook and Macbook Air when they are close to the extender. Iโm looking to fix this primarily for the Chromebook; my tried fixes will be done primarily from the Chromebook.
My tried fixes:
Things I havenโt tried cause I donโt know how to:
Anything helps and Iโm all ears to try stuff, so feel free to suggest anything. Yโall are the best.
Luke
- Windows PCs
- Chromebook
- Macbook Air
- iPhones
- Netgear Nighthawk XR500 Router
- Netgear Nighthawk X4 Mesh Range Extender
- Netgear 24x8 DOCSIS 3.0 Cable Modem
- Google.com
My Setup:
- Modem and Router upstairs. I have 2 Windows PCs hardwired into the router.
- Range Extender downstairs within signal (signal strength light is green).
- Chromebook and Macbook Air are โconnectedโ to the router and extender via Wi-Fi.
My Problem:
My tried fixes:
- Disabled QoS on the router, rebooted the router, rebooted Chromebook, forgot the network, tried to reconnect. Doesnโt work.
- Factory Reset the Range Extender and reconnected it/paired it to the router. Doesnโt work.
- Power Cycled the Chromebook. Doesnโt work.
- Factory Reset the Router and Range Extender. Reconfigured Wi-Fi name/password and repaired Range Extender. Doesnโt work.
- Manual Configure Range Extender/Router.
- Pretty much anything that deals with configuring the network.
Luke
