WiFi access point
  • nigel_cook
    • Nov 2016
    • 29
    WiFi access point
    Hi. To try and extend my WiFi back to front of a long bungalow I’ve setup a WiFi access point from a previous router
    It all works perfectly. Question though
    Connected WiFi to main network 200 Mbps
    Connected to new access point from a router. 30 Mbps
    Is that normal to get such a vast drop off. Or am I missing something?
    Thanks
    Nigel
    @phillpower2 @Rustys
      What are make/model of both routers?
      • system
        PCHF Owner
        • 7695
        • CachyOS
        • Intel Arc A770 (16 GB)
        Any update @nigel cook?
        • nigel_cook
          • Nov 2016
          • 29
          Apologies I missed replying.
          The main router is a Virgin hub – On both Hard wiired and wifi - i can get 200 mbps
          The secondary router is quite old, and suspect that this is the cause It is a Belkin N150, F6D4630-4 It is not dual band - which I suspect might be the main issue when connected through mobile phone to secondary router, and then running a speed test,.
            Sorry for the no replies. Any updates?
              Any updates? After 48 hrs this thread will close.
