The best and most secure way to set-up home network
  • Smoky83
    • Aug 2019
    • 12
    Hey all,
    I am trying to set-up my home network with a combo of wired and Wi-Fi. I have several questions on equipment to get and how to set-up.
    It has been suggested that I incorporate a VPN into the network, is it better to use a service like from Norton (my current AV software) or get a physical device?
    Should I also use a firewall?
    How good are these β€˜Whole Home WIFI’ systems you can buy?
    I do have a Motorola Modem and an ASUS WI-FI router already.
    Any help would be greatly appreciated!
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    The best and most secure way to set up a home network is to hard wire it, anything else is a compromise. No reason to have a VPN on a home lan. Your router should have a firewall and so should your operating system.
    • Smoky83
      • Aug 2019
      • 12
      So for my desktop, media center, PS4 and TVs w/streaming services I should hard wire it to the router with no VPN. I also have 2 laptops, 2 ipads and 5 smartphones, for these I was planning on using the Wi-Fi, should I use a VPN just for the Wi-Fi then?
      • Rustys
        • 7862
        If I may make a few suggestions.
        Hide the SSID this will prevent it from being broadcasted for the world to see.
        Depending on which one that you are planning on using for the WiFi I would also configure it where only these IP address are allowed and or Mac addresses.
        As far as a VPN I would only use one if I am utilizing hot spots remember though you get what you pay for.
        • Smoky83
          • Aug 2019
          • 12
          Hide the SSID on the modem and router, correct? or all the devices?
          Each device has its own IP and MAC address correct? I would just have to locate it and then follow the prompts for my particular WiFi router, correct?
          • Rustys
            • 7862
            What ever is transmitting the WiFi signal
            Yes that is correct
              Any update Smoky83?
