Unable to connect to network until restart (PC)
  • miniac69
    • Jul 2019
    • 8
    Hello everyone, I have just purchased a new Windows 10 PC but I am having a nightmare connecting to the internet. Basically I noticed that when I turn the machine on it will never connect to the internet and gives me the β€˜Unable to connect to network’ message. However if I restart the machine it connects straight away and works faultlessly. I should also point out that the PC has a wireless network card!
    I contacted the makers of the machine and they have had me try installing drivers, performing a reset of the OS and the fully reinstalling it but none of this has worked. They even sent me a new wireless card to try, but this has not made any difference. I have had the machine over a week now but don’t want to install anything in case it has to be reset or sent back and now they have stopped responding to my emails.
    Can anyone help me? I have a couple of other laptops in the house and they all connect when this one can’t so I am totally stumped.
    Any help would be most appreciated!
  • Malnutrition
    PCHF Moderator
    • 7041
    Speccy Scan.
    [li]Please go here and download Speccy.[/li][li]Install and run the program.[/li][li]Upon Completion:[/li][li]Hit File[/li][li]Publish Snap Shot[/li][li]A link will appear, post that link.[/li][/ul]
    MiniToolBox Scan
    Checkmark following boxes:
    Flush DNS
    Reset FF proxy Settings
    Reset Ie Proxy Settings
    Report IE Proxy Settings
    Report FF Proxy Settings
    List content of Hosts
    List IP configuration
    List Winsock Entries
    List last 10 Event Viewer log
    List Installed Programs
    List Devices (problems only)
    Click Go post the result.
    • miniac69
      • Jul 2019
      • 8
      • miniac69
        • Jul 2019
        • 8
        Ran by Oliver Howard (administrator) on 12-07-2019 at 22:52:38
        Running from β€œC:\Users\Oliver Howard\AppData\Local\Packages\Microsoft.MicrosoftE dge_8wekyb3d8bbwe\TempState\Downloads”
        Model: Vortex XT Manufacturer: PC Specialist LTD
        Boot Mode: Normal
        Windows IP Configuration
        Proxy is not enabled.
        No Proxy Server is set.
        β€œReset IE Proxy Settings”: IE Proxy Settings were reset.
        Realtek 8814AE Wireless LAN 802.11ac PCI-E NIC = WiFi (Connected)
        Intel(R) Ethernet Connection (2) I219-V = Ethernet (Media disconnected)
        [HEADING=1]----------------------------------[/HEADING]
        [HEADING=1]IPv4 Configuration[/HEADING]
        pushd interface ipv4
        reset
        set global
        set interface interface=β€œEthernet (Kernel Debugger)” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=β€œEthernet” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=β€œWiFi” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=β€œLocal Area Connection* 1” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=β€œLocal Area Connection* 2” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        popd
        [HEADING=1]End of IPv4 configuration[/HEADING]
        Host Name . . . . . . . . . . . . : DESKTOP-382C4DR
        DNS Suffix Search List. . . . . . : lan
        Ethernet adapter Ethernet:
        Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
        Physical Address. . . . . . . . . : 04-92-26-C4-C0-71
        Wireless LAN adapter Local Area Connection* 1:
        Physical Address. . . . . . . . . : 02-0C-43-01-9A-6F
        Wireless LAN adapter Local Area Connection* 2:
        Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
        Physical Address. . . . . . . . . : 00-0C-43-01-9A-6F
        Wireless LAN adapter WiFi:
        Connection-specific DNS Suffix . : lan
        Description . . . . . . . . . . . : Realtek 8814AE Wireless LAN 802.11ac PCI-E NIC
        Link-local IPv6 Address . . . . . : fe80::4465:3df9:a4fb:7a78%3(Preferred)
        IPv4 Address. . . . . . . . . . . : 192.168.1.9(Preferred)
        Lease Obtained. . . . . . . . . . : 12 July 2019 22:50:31
        Lease Expires . . . . . . . . . . : 13 July 2019 22:50:30
        Default Gateway . . . . . . . . . : 192.168.1.254
        DHCP Server . . . . . . . . . . . : 192.168.1.254
        DHCPv6 IAID . . . . . . . . . . . : 402656323
        DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-BA-3B-F6-04-92-26-C4-C0-71
        DNS Servers . . . . . . . . . . . : 192.168.1.254
        Server: dsldevice.lan
        Address: 192.168.1.254
        DNS request timed out.
        timeout was 2 seconds.
        Address: 2a00:1450:4009:809::200e
        Pinging google.com [216.58.213.14] with 32 bytes of data:
        Reply from 216.58.213.14: bytes=32 time=105ms TTL=55
        Reply from 216.58.213.14: bytes=32 time=103ms TTL=55
        Ping statistics for 216.58.213.14:
        Minimum = 103ms, Maximum = 105ms, Average = 104ms
        Addresses: 2001:4998:44:41d::4
        2001:4998:44:41d::3
        2001:4998:c:1023::4
        2001:4998:58:1836::11
        2001:4998:58:1836::10
        2001:4998:c:1023::5
        72.30.35.10
        98.137.246.8
        98.138.219.231
        72.30.35.9
        98.137.246.7
        98.138.219.232
        [HEADING=1]Pinging yahoo.com [72.30.35.10] with 32 bytes of data:
        Reply from 72.30.35.10: bytes=32 time=134ms TTL=53
        Reply from 72.30.35.10: bytes=32 time=146ms TTL=53
        Ping statistics for 72.30.35.10:
        Minimum = 134ms, Maximum = 146ms, Average = 140ms
        Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
        [HEADING=1]Interface List
        9…04 92 26 c4 c0 71 …Intel(R) Ethernet Connection (2) I219-V
        4…02 0c 43 01 9a 6f …Microsoft Wi-Fi Direct Virtual Adapter
        8…00 0c 43 01 9a 6f …Microsoft Wi-Fi Direct Virtual Adapter #2
        3…00 0c 43 01 9a 6f …Realtek 8814AE Wireless LAN 802.11ac PCI-E NIC
        1…Software Loopback Interface 1[/HEADING]
        [HEADING=1]IPv4 Route Table[/HEADING]
        [HEADING=1]Active Routes:
        0.0.0.0 0.0.0.0 192.168.1.254 192.168.1.9 55
        192.168.1.0 255.255.255.0 On-link 192.168.1.9 311
        192.168.1.9 255.255.255.255 On-link 192.168.1.9 311
        192.168.1.255 255.255.255.255 On-link 192.168.1.9 311
        224.0.0.0 240.0.0.0 On-link 192.168.1.9 311
        255.255.255.255 255.255.255.255 On-link 192.168.1.9 311[/HEADING]
        [HEADING=1]Persistent Routes:
        None
        IPv6 Route Table[/HEADING]
        1 331 ::1/128 On-link
        3 311 fe80::/64 On-link
        3 311 fe80::4465:3df9:a4fb:7a78/128
        On-link
        1 331 ff00::/8 On-link
        3 311 ff00::/8 On-link[/HEADING]
        None
        Catalog5 01 C:\Windows\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
        Catalog5 02 C:\Windows\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
        Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
        Catalog5 04 C:\Windows\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
        Catalog5 05 C:\Windows\SysWOW64\NLAapi.dll [70144] (Microsoft Corporation)
        Catalog5 06 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog5 07 C:\Windows\SysWOW64\winrnr.dll [23552] (Microsoft Corporation)
        Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 11 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 12 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 13 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 14 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        Catalog9 15 C:\Windows\SysWOW64\mswsock.dll [324408] (Microsoft Corporation)
        x64-Catalog5 01 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
        x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
        x64-Catalog5 04 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
        x64-Catalog5 05 C:\Windows\System32\NLAapi.dll [92160] (Microsoft Corporation)
        x64-Catalog5 06 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog5 07 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
        x64-Catalog9 01 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 02 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 03 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 04 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 05 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 06 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 07 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 08 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 09 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 10 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 11 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 12 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 13 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 14 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        x64-Catalog9 15 C:\Windows\System32\mswsock.dll [408800] (Microsoft Corporation)
        Application errors:[/HEADING]
        Error: (07/12/2019 02:29:07 PM) (Source: Software Protection Platform Service) (User: )
        Description: Acquisition of End User License failed. hr=0xC004C003
        Sku Id=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8
        Description: License acquisition failure details.
        hr=0xC004C003
        Error: (07/12/2019 02:27:02 PM) (Source: Software Protection Platform Service) (User: )
        Description: License Activation (slui.exe) failed with the following error code:
        hr=0xC004F025
        Command-line arguments:
        RuleId=3482d82e-ca2c-4e1f-8864-da0267b484b2;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=Use rLogon;SessionId=1
        Error: (07/12/2019 02:26:29 PM) (Source: Software Protection Platform Service) (User: )
        hr=0xC004F025
        RuleId=3482d82e-ca2c-4e1f-8864-da0267b484b2;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=Net workAvailable
        Description: Acquisition of End User License failed. hr=0x80072EFE
        hr=0x80072EFE
        Error: (07/12/2019 02:25:18 PM) (Source: Software Protection Platform Service) (User: )
        hr=0xC004F025
        RuleId=3482d82e-ca2c-4e1f-8864-da0267b484b2;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=Use rLogon;SessionId=2
        Error: (07/12/2019 02:25:17 PM) (Source: Software Protection Platform Service) (User: )
        hr=0x8007139F
        Error: (07/12/2019 02:24:11 PM) (Source: Software Protection Platform Service) (User: )
        hr=0xC004F025
        Error: (07/12/2019 02:20:05 PM) (Source: Software Protection Platform Service) (User: )
        hr=0xC004F025
        Error: (07/12/2019 10:42:39 PM) (Source: DCOM) (User: NT AUTHORITY)
        Description: application-specificLocalLaunchWindows.SecurityCenter.WscDataP rotectionUnavailableNT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
        Description: application-specificLocalLaunchWindows.SecurityCenter.WscBroke rManagerUnavailableNT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
        Description: application-specificLocalLaunchWindows.SecurityCenter.Security AppBrokerUnavailableNT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
        Error: (07/12/2019 10:39:43 PM) (Source: RTWlanE) (User: )
        Description: Realtek 8814AE Wireless LAN 802.11ac PCI-E NIC : Has determined that the network adapter is not functioning properly.
        Error: (07/12/2019 08:22:27 PM) (Source: DCOM) (User: NT AUTHORITY)
        Error: (07/12/2019 08:19:01 PM) (Source: RTWlanE) (User: )
        Error: (07/12/2019 08:12:50 PM) (Source: Service Control Manager) (User: )
        Description: A timeout (30000 milliseconds) was reached while waiting for a transaction response from the CDPSvc service.
        Error: (07/12/2019 08:12:20 PM) (Source: RTWlanE) (User: )
        [HEADING=1]Microsoft Office Sessions:[/HEADING]
        Error: (07/12/2019 02:29:07 PM) (Source: Software Protection Platform Service)(User: )
        Description: hr=0xC004C0032b1f36bb-c1cd-4306-bf5c-a0367c2d97d8
        Description: hr=0xC004C00300010001(0x00000000, 14:28:33:811 - https://activation-v2.sls.microsoft....tension=Retail )
        00020001(0x00000000, 14:28:33:811)
        00030001(0x00000000, 14:28:33:811 - https://activation-v2.sls.microsoft.com )
        00030002(0x00000000, 14:28:33:811 - 0)
        00040001(0x00000000, 14:28:33:811 - https://activation-v2.sls.microsoft.com )
        00040002(0x00000000, 14:28:33:826 - 1, , , )
        00050002(0x80072F94, 14:28:33:826 - 0, 1)
        00040006(0x00000001, 14:28:33:826 - 0, https://activation-v2.sls.microsoft.com , <N/A>, <N/A>)
        00020005(0x00000000, 14:28:33:826 - 0)
        0002000C(0x00000000, 14:29:07:812 - 500)
        00010002(0x8004FC01, 14:29:07:812 - <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap=" http://schemas.xmlsoap.org/soap/envelope/ " xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance " xmlns:xsd=" XML Schema β€œ>soap:Bodysoap:Faultsoap:ServerSoapException0xC00 4C003103 (Activation) - [PA Product key blocked. β€”> Product key blocked]</soap:Fault></soap:Body></soap:Envelope>)
        00010003(0x8004FC01, 14:29:07:812)
        Error: (07/12/2019 02:27:02 PM) (Source: Software Protection Platform Service)(User: )
        Description: hr=0xC004F025RuleId=3482d82e-ca2c-4e1f-8864-da0267b484b2;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=Use rLogon;SessionId=1
        Error: (07/12/2019 02:26:29 PM) (Source: Software Protection Platform Service)(User: )
        Description: hr=0xC004F025RuleId=3482d82e-ca2c-4e1f-8864-da0267b484b2;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=Net workAvailable
        Description: hr=0x80072EFE2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8
        Description: hr=0x80072EFE00010001(0x00000000, 14:24:26:491 - https://activation-v2.sls.microsoft....tension=Retail )
        00020001(0x00000000, 14:24:26:491)
        00030001(0x00000000, 14:24:26:491 - https://activation-v2.sls.microsoft.com )
        00030002(0x00000000, 14:24:26:491 - 0)
        00040001(0x00000000, 14:24:26:491 - https://activation-v2.sls.microsoft.com )
        00040002(0x00000000, 14:24:26:491 - 1, , , )
        00050002(0x80072F94, 14:24:31:370 - 0, 1)
        00040006(0x00000001, 14:24:31:370 - 0, https://activation-v2.sls.microsoft.com , <N/A>, <N/A>)
        00020005(0x00000000, 14:24:31:370 - 0)
        00020008(0x80072EFE, 14:26:29:191 - SOAPAction: " http://microsoft.com/SL/ProductActiv...ice/IssueToken "
        Content-Type: text/xml; charset=utf-8
        , <soap:Envelope xmlns:soap=” http://schemas.xmlsoap.org/soap/envelope/ " xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance " xmlns:xsd=" XML Schema " xmlns:soapenc=" http://schemas.xmlsoap.org/soap/encoding/ ">soap:BodyProductActivation http://schemas.xmlsoap.org/ws/2004/0...ty/trust/Issue PublishLicenseviNXW+0lAysy5TvAZ2rj4JYFVcaNq82laZd0 RACKSdrrUtwX6F/ky61iwj9/cPsVz95mqld3CEZvVeAGqDsqhs9v9CjJvEog89mI+maL0u99mc zvUYAkCgoowMLAehU9NwY7/ySv0MbA7JUgsRANtlhKNV/aF6vyNet5im5JwomumxkbR6RMzFQGd+5AXrPgnXMjSeUoRfM9k +6wTBYLK+7LjApi7zwk4nhGgwljU2XNt338kcYjQ4iC417dz3M FZNqIa0M4BHlGaZSXKrq8DyKWXOejfQ6GsBl0fxbZGtLnMcXZY xQaV57B/0HCc9ooK+KZNn+eVHb/OI3vxVkZPcFYcGpkOnMW/o7CNery5s67Bh7y82SXmCja+8xGYthsuoD2KrFA2qKlbWIhwk4 7WsNwUqsCe5iaHVkeBIl7WI+5qZCW6E53i1cTHP1By0ZEwt2Um Gg+KDH2R5BBxxIJ+D6LtFS4hjrZaC73tUmVDuyJlT2w/j1Y4SpLGcUUoBsTo/x2ydNa6OWRIk8PCPFzISgUypJrHyeTp81rdtYOfBVl88EtEFj5/bU3/QcHMCxe1zSU5u9iaSLx8p+bKknqDtqPMXcq5m3NI1VJ63h8SS1 BQJMdMyvMNbtYEZublwNLH7uZ29IF34D3tmA/tasDMS8oMOohLozG6YLFSw59jaEau4aOKW6RP3bHjXGJsAx/RwIzmckqVXrWsNfz5EAPr3awpnotDqJFNxZ2TaPqQ5ptt372dG HUntpNkUod/EBNiELuA8MEHOiARfqsihe7kddjioiQhceFrzdHr2q+yhcc96Z ImCF+PqpXipcVwDy2MEJy4ebkbDba0Pq5A+YIuhayi4fFBvyqc p4UHI5ckRnfbkjcqP9ZfhpV6CYZLKsvjlmE9nRCPwuD1hCzC4y 93sTpfJAQeTSh598vw9+EmvNMcf3ChfRvPbHoCRDEXMlEhkHvX oJbTJRSuNsdtCpQCBrn7psYuN6wOEendRX2ktn0eS4MdHopBW0 +4MbYb9x9KghVsyq44jyEPerLhQE/vAHTkI+sWdDenVL7rHUSEp0tbXLl5njXojhSu1oh52x5XA4n0G OJykgxvDLX6AbmDDAgmOYjSO8axTFKlHmxerN5PYTLPCr+/+kUDdoa7f7s5+7hhQdaMTw/nHI0dFfn5d7pHnUGcWTRfCtggFMvLs3hgySJcDFBTsnp7br3Mn fgLPp0XSpyiVRYq5S1QPu3tOyz/GebAbMW68X5nDngmOyV19MjoMSYp+Fz6Lx7GFIs4/MO378MxXfhQZ0tXUZXFRapFwZTmhUqYgYC7mvLqqgiQfsdslaX ZmPzN+2/enc+ozn19U+d0PQ424+X6LJ+ERpqolh9EKJxfzZUKvOrmfer4R nu8KHwBL+vXUXyovI3pA0KyRZQP8pYgCmIn4VyrloYHcIH4R2b bTQMb/7mCiGnBWnoPLJ/NFF/RSZM7/urRf6RywSmXPSZPuwOga0gR5aNHnHUA6RryueJwK99T1daTPp+ AI3glCnrtOaQTdpX9nPuSyfZpYMXniz90UAASTaUSXFVvIutYF zc7LbwTcmfZCV8HmZ/EkRSnAYhB77pTPG9fJQIQpXUaSw6Et/UOZbI70KLhqZnlylpKtMkfrb7/F+q0NB9LDYDv0NhLVJzv9CdrKqw9ewroVB9/a3cfME/3JHK5TK+Ww28bYF6B2aLj/I/8sYezyI5nCRsvOR0It9ZaWAj4Tv7NJidV1cw2WItcBqvYBbM3L AfeWW0HuXWgikqD4pKMfzxsatdRGPtWPyZVpBmCh6z3oQDzE5g 3+iGmXo9sSCdHp/6wjRb4zhCH/1cCuRLgB2zMDzyxhALCY1oGpFNUkIMnGJaAFWEuZy41F1rmFZ3 CS/LyVLRm/A5lqjix5+NiL+Swug3o9sqMQp2E+ZMB1bXjrxRmyAeYpM09u+w Ux4V0fAKkshB95v3c9FpQLdXIWg5KO86EvPNffgxgk7rGMhy+7 6opWOCMt52k6zfC/CQD6UK5SijAGJt2ESs/XgH1LbMfJaf/G5357FWmieuiUK31OkHluHE8WUY6pqMZg7oohPxOmwbEqdGNPi Dxo0Lx8PbBsw8Zs8w+wceCJCFGWSbM9+hDBB/pWimErhzYfyJ2yQOIy86txj5Axz9jboxp0eXWvf5sQjztJwiX5 iGhsomcPBE2FubfiIZzbs25+TqKniMzU06KAvOLhF4aZZoXgk4 xJ/2SnRoK3wB65ws4uUkEJTsPIvG9Zxf540KYNmctlPz+ESLdaCe2 msphZrfWRrpw/2OyBe2cuP/+ioOlzK+cgyHTwwQCnwE94tto4/tQVB1gchOFu9FEjtQl2CotBRe5ExyNeK3G7V2H0sYr87ruRBEB 6EFhcL+MCPkFiPpCzBlUIEk4vFwTm8DhCsmZnnw+xlcXv41p+G ZThEfn3ykGgYYtcp2foIjpKhTK0ZW5PsA/ik/S92hlYaigMWTpaSndHjI0lfANYc+wHSgk4j5ABk9U7NR3Nvkrn/RMzqBAc7V3wwvZ7vR5+JRU654OqtnnU/YhBi1qOwpB7wYw19eZO64J2qPVVQkslt4Yi6pU7zW/1PAckavqV3QY4S4cLnoI7vQgaeJO/T01bl4xNmiDiCK0DkCBWtVti56ZjQNPfD39LLI0xM/6yPl7UEnSc064FhLGzWz8J0cTO4o8X3QyI2wT5AMbKuymC4iLN YjXmTm/y+Wz7MaXVui+gWHe4S+DFYmU0f0o8Doil9GbZukv5jbOzUpqV6 9SQ0Skm1EEwWOzJ+QD/USeFoo35YPqUQuBEfC8V+Z1B+eiXmTZSt8efSDxRzSc9H5tXCO igTXu2dR7l+H5gc8i5vcInsIBMnz4B/4Wy4SInKlSFFAeJ/uENtLo6+rnud5ry3j5zEF8DTwaTC0wNQFJPREWpcUSb1FihxFH FvZ1OgeZl4eFalpLG7lQ0EH5rrW/6UKNnxwF3PUWEId/AMe9eKGYQ3EUoX3pCNQy1QGoeOc9uQTkLwhrn6A4bRASoCZlh4 5gJpNDY1Aw3t98Q0hHkNjn57l/0fqPhCYX5v6giiFPOtMS1jCIxBmo2xjVU9LJrwlhPjqExmCQVQ zQ+rn7XhoHNY8fGiYUXYItIUmXAdPOO86ulKfLwCjsekguwXfF AruwWIHRqNj+IXM655UPuO44zI+hoeDPHAugJ0mdh2/MwLC9nHsT79GnspZCFQQpsNuiJnkNq3iDU7UbQ4LgrsHcs2LgO U9M9twD5DnVjqbLYNUmEhBLbH8T2V5v5h+LmbcH7jvl22wXV62 Pe5MgH54j/RWGSJR/DZZJRXj7qRC5AfAYmwQ8PhQVh7Fkuj4MUDFE7sRaDQ3E2ereZr HqOQ1OgEhYgQI48CA/VU+/LvmknS1idc6U26cGNn91EvYhWF5dUHqa3QAZ7ayTtbuq8/pehnjLRXCBoxprt/xcxoJdhrgHxLZAAzuAJM5jlIWQqTnmXVEyAfm2N9aKyxqzDouY 2umUhxrs11BcrJPbF+FkU3WUAo2x4vVl+0GBf+5c5HtWbG6fDa nPPX+/fCp/yt0oxkPLSDaTOKbssfi8kOhuk/x0+A3K7NKzeg+kou8uPyCJOw2q4v/7HtvVpuwHfVKrj7Bz8jzCCJ69yqKWrIgxiVYgbuym7EtAXe5Gm g/NzIXvLmqGSinBXw9DXYwKYrRmp/HwVkRGelZSeogtD0KmNLKN2ZBWeUg5gdlq8ClFDkmI3/sD8Xfcodet42Z8tdKtxpq4S3AelM/qxKiU9wak803Ng9eV0kt0pNh9WpV6CKl5p9VVfsUZ1ub9855OH 5FaFa4alX93DMFijxCHSBAwP23lfn4zbxNIHbjnGnFzbYQdKTF s4mNqzCVk1OllOkrd2Sj3Pa6df0ySL5udn6iu9Jb5adKCHOGte DomNzJYvUy7wBm4fwNfn5eVvfKGxAV1XDQazimrUaPZEaiVf3Y uJzxrF5/4qT+q9w+r1NiKowjTVZm8PGCh26469LAg78qAx9oxIHn/kuwoxv2XHOa8LAPmFRxrpzupVksuK3KypLBgosjNW08RoFlbV+ 7Yquspxg9glIkQgS6n1TxtQ/866x4wYWYfMv0mLLFDZJG+jZfeffcWPFC7JOpCOUJF0nDNQGyq TGvGUMHR9rPjqHBKhYP6DGupDpAUopgzogrwxaWbEMB/6A1GHJQHQh+0mIvOoroqc+DnAp63oH+VeRZucjSHqm86V8UZUh NX9fT9RPg4v2Zsiaf9AbDsvO7Ek+LN4cB+r8VLP0xv55pduDbp GefQ/b87RrVEYz4ivxNelQZXWBk5nOqjpm442rJM2Ra8Ot8vqm3HWYE/FJy7Z/LNOTklD6Oxq+XLqBFnGBHZ2VV0v0WKvkpN7DC0PkPCnrVV7x3G HAhQ110WCBivFQjFL+vQP47rVnn+P5AEZ/Vb4AGDbLSHKhEFXEAAzlgESZ3JmuiKRNC4MDJTE/hgbYw3gZQz6+u7NV6U6BX6F1SCco23Ndd3nr15yi3lj6tokEIt E52OU7ozOa+4enwH691KYlKcKL1EC6BHoU1F5i1lPq8DVPXNZT w9VpFqG67pu+1Dp4cEBeqNSrx3jmgTuOH3n2J+3T3DgLyvZABg xFO55DqJstFGlYNbEJSiToAEboalF5LzNBgLwmGr5MFp8J00Zy Afgfzwypgm6eR5o2KdGkQGnS5gQ1iJNPQUvDJtyIAwDcEbQP+m zHR7pDy853UuzjDGJWae6j3Ciw96ppBuPR10bJdMHPm0Hgq68S T10BHECXTTwy8dSaVYEqXtyqJVYcvyZxeVvSzeLJQarP/1QlclXhneT3tCjWSYnD38y5LFD5lHpJ3iAzPE4kj5dCqP7upOw yUDhLa/q96XG3ZlYyVf52OML1eNQiIZI9PLavlW8p5Q1yJUZtpfAVEVL2 F52+H0yLG6OaG+QZtkbvzPNXjtfgAF2VtdRPcCLjLEHkCbNSSk zPaStD+mZP1Kg+H5bO7uHBPZXchbqbgdnBFzpB7IER4fp/iR5/G4sQcIelR421VEDxSUqYzG0TVB39wQFoLam2pt9L9jZRok5A4X +22RtKHSc0QxdWPViw7it/23tp0c7yQYULn/nI6s86EsXBB8P85MP+GpcEphsFc5xqUaRIcElKzKH1J4JLrKtg F2OESPhnFN7oB0zN/vCJgyd6yAU9Tm6oBgKkoMF6dsrqPzYVVdncpsR8WDxBtYXNbht qrxHCMzkncv96fuPpRrwvPH2Ptmf2WMNlUaGC2p3po8Ebz9x9d X2cVZw7NcBUDuTz2uwjiL2OMy/I/9iEiE0kf9kan68VxRdjZFmhbLmUWf5mj6buWlPYGCGbv75wu6Q 8WsHrEhAJStnVxgWF/XXxAblw8CtKsTLmGoMdrfH2tcYzIF9m/b8sIlS54bmOqIAYUXLSwvHut2cE2q16b0kPnGvCJBIN7rGYXi7 jrL9uK99a++F25dSz7qgsWocGRPJygXUXR6bRjqwgK1HXAYwy+ B+EeYh9yKJl0rc0v7DW02T5/tczK/XVBBeECAqktT1ockky30CiSNcCBcpPazhMrHPrNN+erbP9qUxZ qIiA/cMmIJhg4UmgdFhoAQlcJOBhhWZEVcc5CXklwDXTCFj7h4MWFht 15rJQUPF6dXnhpWL0ykbVzU+dH9Om4mfg528gQYt4KWToFc1lR HJ36fQFAoe1OLX6I1p9lSWzSdQPhRJg9yvD+Uy7/twJELy2v/aRdRcMxg/Aku58f0qGwoh7WP+X9KJW/TfZi5wpZ+kXp1ch18HqGojzDLBqVnzkap9shXDv3ufRm0VU45B kaEj9WmRvbUtJxOnrV5J64dVSLV2i0Lvp2xMmY1ZtmynUVE+fB CvnuNDYtqBRNe5vG39dfCAmoUz5KHUNC1kKS1pZIZeO76tM4Zg ks0IhKZoDGFvh9ovsjoj0DJX0V1EX3ZpQbWY7S65NjsE/XBE0lNDuoZpLYmNibdZNYWQDxUFbWauJp85bQ/wAUm9B+CI9kF319wb+/3tu830bGuw+KteD63GzyxM7KZLp3c0lFxhUkYBV97MDgRyPsGv At8V491zbbFWXszftokLbl4A6SBEPn89FDeFLeqpOJEmyQm5MJ QaTx6GziPukNLzhd6Wm5vyxp4GqW3qH+5eho9ewqZ/em399kH5WUcix/5IqZu3hKjErK1cL+TXxjPrGyCRZrigCBIp6IP2jWI7fGG2AfpT Hn70eWZh9gK9JD0VCHEiH3dEUp6tAS/kO1gDzu5qUlXokCS26M8+w/7kW/sDWnZeG2h++fn+Mkdhmh5E0CSQEYG+xkObgINEfHEFqihZN0Xz pWvpZKEw3fF1H7VhrLVzlo66ZsAEV1VKfj2lDsanofY+dGo+WQ GqBqBKORJ4m/znnMX2XEI3k+1xwAIBaqfcrUV0nPUCH3lZuSGkYIhvhFWQD/dMrV7t7XtKresxc19I9Otk5aL7j5tfnQnhmyLA10ygvOEBMEir lOmO6XMuGVe53e1xgLafV0e5eRc6YcVEw4nsQKEto0O0iHqt67 8ErKNN28Py6kz53L0aVdsPkOVupH6fVQujboI3xW9kLbdkd5Gz F6Qhc1ff78x5t8PhRiAWc8jEkUyCWdD4JLwwAdjK2BeEJ6uOmB Xq51qb7OTUmT/D3bLPWTSYhf1OZ4lpb9McIg4+HeHanFoeMLaO+Htk0cqtlBAg6 yvbAMl+MTnkzFKGPNPqb21oOVklrMbsuKgXnFirPTAT1bm5Qr/QBLGVvvNk0/Ta0sIeihLcBEhj09PvYdimZ6hzVLQQvO2mB0CcM21dAs8xDMcc xHwO5gS+iD8LBKpP1TfnVyGxLGmp1nFtrsvv5ANz5cMZnRnT2C 0XonU6+eFKliLRwDjVxz0VcAE7c7cN43a8uDSdvrTJ0rqtgMSd 2O0g7p49Hc6BpA0B2B68Oqk1XXQfmfJwvfBnhQ1bDCyQyYEIM3 pwc0wzfZ37mVn5+w6PdSEIIeG6hbVdkyIZeS9KxStf5h5HO+U6 bywXwL63IDogZ4kbgst3uPaeUfNlcOmvioZ25dN7/VOKo+d0nxAflFfz5x8WPlZvWz/c+XA6HG3ZoKdtkWkFnqcowyU4H10Fa27y2urTqUaLXedRGxK42 ySKBPoOgxh1PwQB6pJSwfdTm3yzXvPQiP2Nb0zZOlL6MBPlIBf CeOyXTFXBuzTH68m28kk4lpS7GN59vF46ccHo7CmO3mPXHysek WU7dJCz29KkiRm27Qcgi7A9K9Aq4YOMIF+AEjk83sxCRLbKBxd +BC2WwDDFBbO+eXIdz7NNrE43z2v06u+XLRaLr79Y9HlBCa8d2 kEVNh4sU9/NGTq0eNZbeTeN51iLWChz6apd+wRG8LsNToetselUsG5maGDAu I0pLN2rFTDsopvXrcQLa5D5uEryZzfhC/FGZDgQHw1ZSnjQD4hCFO+dQXtsEDkQ051gnUCaytth57iKaybB l9Qbm0tzR67VRdwdPkhl9oY+woo/bFOIKqz8DirirJ6xydrzpcVjuL0u6/7VJDGohBYe4nSOH0GXfV+fqMmX/T8XkaX7G9rRxjL6dkQrr7KltYeB+IvYROuqoy+XAPRnZ1AGrGQ 2osmZMge5gKkYaK+DY1jG7aAWr4TPkK2meaKtEKtQoRCONCLQv su2qoWuMIp/CdohKy3v3W5+2Wu3aDenOnnUR3AxBgQS2Z15gmTtVtteSS430U AIlMkX2j4sDyMmpEec+uJR3+uk6wzUC2/V8Do7zxjsNM2SwDXPffBqmJBMmGqPQ/1jdFvyB+RH9yakVWO8983f58/Q7s5tAVUj05w79BYSCcdSKcL28r8modVCR/B/fxehbAJM5o76iQoy/QwwoU4Umh5uzh56/Jc3Xxo5CHMoApefKBJWc/w+a2KYMPa2uRbhw+ql4/dFxnVsjxkoVGhbUMA58bgHRhp6Fllq7vfi35E8/rfN5/6DFWXHz6DcLNlzE015ire7j2mm5FdckpZmcpndsKYMQI0Dq/gMqNiLtnkJVJTEYJV2nKeYJa6SidV7whCdqmVy+bR0+hreyoiu zyDB9eXciuNvjJqCg6L0Dvc1+oygwA85FbV9M90I632LQsoedQ m1BWVA/2vBfijoIkxdKEYXi9BNussHau0pej4ZkWIu5LUABj8kSDQTDYP Qud4QKDzB6A4vSiX9IYVIXHbhqR6lRXgoS/dqYyYsqLLA/Kv+YYpKZKOOkHOO7cp6e4UdKWLTmYnyUI9HXz0srVj6/gw1ONyC0MWS/4Je/aNS76AQ6b5PcW1uL3Xw0uN7A35zGY/Xn91NBMUDFaNqVXOMoExh5fq1FY7CsHJwrJUxnYlfDJ+n4GDFP R8n8WNFoDSyRaHfaBdwzD+LQETgD+vxfU3cSi5j64Ui4nED+Lb Vz6Uyy+X5SIX8tdBxtCf4Qnvb5Nr2ocnz67hFDzj35dHPDer+M tVT3JKRcVZV3oRyrS3jYelZizpX3yeNSvPuB9K1ZPVrBPcy/RqR+npk+mc28N14tq4DkV96en0fb6ypqIN1L5lT+WTziU/JfeSWimQqSKRZ4TMSBPxhl9csMvqTZDa71nSTTFymPETHFQS8V HJtchda0tlcLVseE+A+1PxSvHLV+6XzVP+iktNxni4OR77382k t4QjG9oUP9dG4fEXWMBsDiP1pIsTqRscw+EbGi3TGfZ2iUWtPY ioU0Lxt02qpz8snS/IpNfqnYRmxdkckg0uwiFs1tfKtAN8UYNNu2iX2JVwR0fgxbypX cCXUIMl5EWZnLDtJy7RxbPgnjrJHiLz2Sj1QzozEuU1rw8pXbZ QSoC3Zj9TKtt78pzsvOeiXRRRnqUmZRAEcIFe30rf1bljPdT/r0Cux7XS/nYQswIENWoFmONoAMhr7g1v98atbEIBQQQ72A1Quc0xTA0Bi1H dh18avt3QX9h5n5O3IDsG+1tDqfuSlfPFvoQk2dPRhE9bI8/hVzh06imEqKpF3087Kd2HbtyT7cOquYd4YZT7WXhMvkaNW8tFf ho63rNAV3kZ/8DnmAAEaQJdObyKtI+0sfFT7FeyFrz+DdT4IAmFiD9GpoDdVcV 4zdcB0HSw0uEBk5ZWPf6+hME82kknPOVETbiz7MxAmsmWp1H7y j9pvys9ILl+q+RnJONMeMxiqYngvhhGyRLC08FF/KxEomXJBlukk0LkBpabHfnNkknBoNzAliapJJK4WnPBptlu14k SkiBeeVaV8jHoQAFayUQ5vey4HvVKZvU73rwpNiwBrl7X5DQaJ +CKgoimYe0kf1f2yPd1x6YEn8Ce25UwDtKZ5o+pSc84iz71O/u+8yNqekPZDhbmrcw+NSgIQwl7AL+dfGSc5HFia5Q/p7cuNQ5sK2YEE+ZfVMF6dh5TOTBiI5DoTYtWpAEBfoZWfiWHUO eKY9PyCDMQ2awwT7J6KqpWTg0PoFHKlthE836vY1kyKOnl/XfwHJEPddB9EGwb5/Y75TYwzSjF6St/VLGVUiATxVpHVHt4Ih4/Q/9V5b6Pt3PVJo6eRgAGV/ALxTWmixE2O0A1XBN5daMrq9bG8x6WfboB81jAnJm83fanQGdg IE8OTuyn+BTToH1d5RzCxp5sdohFS7kWhqTqqjZpwUF79LcWRu toJMmkm9JpqkkXSxECOln8YuaRms+x1auubXLzLcXbEFQ1m/kgztz4SEktR1HymCCF+kNsu/d0Y81lHHeu3CDrXABSu9UB2I/Qrbc4Ceszk14v0Qt5yyfMskoxtTuu2oXpcY8TojJJ6zAhTSM3G taLoV8yvowa+6FkNOVG5ZJ3xRk1DFmKsGTRCQQqo5f4csSZeys 4Pc+MEd0qEt4jm/XXqsbhjnY2slJe20kAPL6jSbD2EkVUDgLyrkAMu3cs7tjjolD/C2sEB/HQqwpUrfkrDzzqEp7hiHcbq71FHKe+jrvVPU7liDLCuotAqT16 1ZmKebH1lVo/g0DWvLXj5vI2WLBACaCvoqqVyDftIiRD2bgntOiWUBpzr8qubl PVDJEuCo3z5w7OCMN9wsIZuZk1ElRr2WYb6l3W1Wa9DZqc5cMV PqwT7cZvk9h+42Z3XkJy8Z1D6eeaA4pwABy1IpiIHsWFc15kS6 v8XKCvTYlHhNXBiYsUlp1QJWEQd5fgS+cIr891fbRm39hOkkGi Nn7tyLfbtrnWZgjRKgk1kYd/unAjjj62sF1CIvUjb9wDHXugXrA+RS6fUxFl2ZA7aNG+wH3Fpq LTZuM1lxBSY2vMnCtb0YetkFn1SSu2IdoDdoO0vvjI6GCOuc3E yQpf0zN2Vzzn/dhmpDY/yp3Q8ElvkZaLRefQDEmmTHrSDeRNs9UAfJTAeYsG9Hmu13bcbq xJPR5b0weEFHSV9b6AFJf1uhay43Bu6QtlyYTU+EC5yRH3lmZu dqcx9R3Dq0S2I6wYSalRXq2nMgedPJo75fa6KBdB2yqj16Pi08 zMssNRG2cg/nB244N8zz3w+YnYcOf1SnS7xs6oQHRUm0VOSnXZ4jscCk3F8ZM MdLCgElABwnRZoLTKXgnW5ysamm9EGldRIqUwaC6ReUXtUTz/6/kgrl0mJtnsSZ09EjXepTujC65VNLirhbdNvb4h/Sgwi5Nb2pyj9C93EBv5wufJGedjHgjPmuFEZEYaAuaOoEiJ5Xg QB5Fakz3pePrwt8wSxcYuWlj0b7Vd0nwuSw6ddl7F0mCQbl4vX ugEUhZKEwRU9FEkTXV6AlR3CtfhG9XxVAEWwsYJVJWiGEHnNuM hkSOjG35CjuG276b5B+N1j4qdfCUJ7vV+P5CYhoWQKQlFlkuHU/AUPqdvOvsmlGMytkKB3br0FXl7s06i3gVvyFVhcuLx5kUmMz2y gcPLW6pIdH5EK8r/h0TGYKCqQkeKTdCg5LRNvg1lMaLKHRv2LQJyRevriDkAYWk/mcHxaMJDQxHcII9bKzdR3rHyhfPIUsmAFt1Rn6b7qzl8XrE/0JYkd+XRQSedjV2fmkQT92pwYgM7Ir30eyga4OYaG90jd2lWyp xNJKCujByn03JCJanWvW+fDXumjcb/NYCyU12VIeFrdVaf/lghhro2dfQBW4eYDpU1V3CSescsJ8MVJ0pTIeOiKJYjoS4fpoG GkhrNA+zxkcKFIaZqcilezsfjsSEpegCJkMGxQiLOkw9P6+7eh +mUcGHvlcsPLcvV6ALdvGT81Tq+f0DI2+AKtx/+u2TMJYGqc7CfOCJz4o5e+2O3lnzJXn6j1IfViMScvc2HMr2gc saJFuAUOJxrHB5VftYYLFSJVrEfTXR/2qN60EhLeh9EiujInDJTfI0ItWMhCu216uLZxrQ6CHSsYOswFe 0pKrs9YYcoZYpWyTCoslCYzSw7eIptkt9/Q01D8polshkzcysoERwqHV36+R5sftN0XV/plN/iiE+MFYWcqzsXGEbs4skGvhzRMjlGT2vt3y6yXcxqI8qft7xuT 2aMYhfILdhta5aLO8b28CpAMF6iUn2aAst1hJai6XwKNMCvCXp DGzAGzW9uekjspVnc8/vGxhL6xGfNAwLenrlUXSGxcx0lQtSxbaosDFeKl9nhMsDphpn5 oqiXvAZDgPjlMXaJ55tTK3xoJfCvLfDxoFmjKoi1ill3OIGl8P RYS/G6OAPAUlsMq0R5V/wVS8OI1AZmloKhlZwkBGUGGQEbpYRjeIfL1LPcozKHfJpOeywd sdO7dGqH7kD+fc0lpRPjmHY673M4cpUtb9DmHBJEv5K1SCCNr3 0OBmrKP6cxRM92gzTg1ZQ8gqU1xXWsmsxtVb696IlMoI7+odsI BzILh0flBQHAOlCqswNEG8rVj2NCglRhZZcdj6UZwYm7TPD9Of TCi36BUCgIHNLc4pSlQKLnTgRm2UH+kSoFC7eATKAXhttADdBt OtYYtM2I4D3LzFnml9NwG89jbNS6tqulJqxr+FW6xX2sx9ljeT D3OBraiUBnmN+npgP9GDUplWWXCofYAkO4V9azLGsAunVcivK4 GnOdNyaqJbgBHznvnBbMgpJiCEDXtBxlKxGTtkAJ9/uyzmpc8AvRRH6PKfq+rFTRWGJa06fMycqVk9YlFMMeK9rrJgJq 0Fdx1wGwC8/FFcuQNRpzIvYx6+DddRGBbe4iWy2hi3bu+XS/ilqfHdBAM80ekvSSgF40Fjvc8OrmAnaTzQxBYAK3+IFm9ldLkf KlatpnJJN5fwaKZgM4Uru5zCcUHOqVux3NX2Qq7r+60QA/MhFxiB6SDZhfMwA6QI+QJK+/3popVtfoo+PZ91mTlevEgHQ/vJHCyEvEhwEc/hDWq8woQ1zRrM1y/TWXF1sK0+pdTERl//pSFkS6EunFiMSa0JrRVOuhCPqok4z/yKhi975qSOhIt5AqCAjC0639UKhDSy6/faFDGzkbMi9SKy3pbvElwqEp/vjdu1BRG8hlKEi9y+7lZjHkPfkLDrllHjNhMZ4HPfXavxR2TAu MDXXW01IhR662nCSsVG2ZFHoiLmHUutURrdJTKAtOTOYXjwNSx 7LLMi4FLbAxjXFhpR3O4/fts9FIe9ttPk6ZqUKcg6NU4d2LqKbBL2j79j74HhRYJC7gQf8Z 45wnyr8bEtqR0X5rrTNNYNxgy7smc5wp29/Hj+P0rbottxHfJlVsvesM9I1hROXJOooToMTwAA6pzfQwn41gV BJoL3UAFUc43Mm0abJOa98L0sZ7LiT7rdEQ51R5SrDNfsWw4D6 CJz/3dFENSW9VV8njtLEa6EF7FK4jMSgvXP9r4FJv40ctP6ToAaGcT SN0Lz85OTvLR5YTu7/4VaZiEfohuC71EGXl0g4rXHBuLBC2jr/IAFceQWT5tHMoThUEe774H/0b4vm+VvmWgOvj8G8pxWVbfZ0yu3FUYdX7LDTe9l9JUe22IRGP SSSDfvDXO4fmxZtQZ0MzVu7ZZMeky1INnra2evUohmZObqb0gB TO0NvV7ryiHAdNRXHLd8dfl0aDokYhGhcu9dIJOJSwn/8Q1YTvXP3aZ+sbMSDzUHuzEmvTgO3VlFYn0RayG2gD41KIBXy7 kLYqT54Yg5LK/z8Pa96zrhB8bh0vIlpXx1GPiGa0sxvFq98+130B8nmzegOHJwE 9NMv7vsdPimoIgVtPF61Gb8ubIx86lXGYe0KWCKI/r5jAH5rt42klQRdpQv5flxeO6olJtRHGFWbFRCXkzZwyt9rl5Q jOTgy0HMVN4ZtOEKJijjMGICBV7xm3Z/PtBXdMDdb29dzoajXWRPdBEX6KZicNqWDpZK/Sius28YffpM2YK3R80b7HTA7AZP5MmlTqtZXldzyoRHxPMlNC2 8kubM5s7ItzaqX65SJx7LzEE8e+hw4llYW0MDoddy32wECCREB zW8kXaWKuBLjWuSpJGwq5S1J+z0t3+Al9pAuU841vmDgE6NTVm KmOAejli1HB6SYeSnB7Wnb9PzrstIKiAFqSN1i3VALV0OfG5Wg PskQ+madi3LhP8xgzbLPD9mCqjc2B+pz6CyO1mJ+KCS+dUzv5U 0ZD95Rq2RmUY+lE02C6GCCP2gyc9wENLP1eWiPBhPCGvM3X5mn 6wCPQPra/AWNNqRDslkxwRmFizt2xK8lWzIQm8e6/05WScdxTFuFWvMhcOIwEA9rpL7qe2rGcrnJ75mWzy2U8P7qWvd a+O5QgTNAzZae0IM1bxSGAOckwfUcx+yaAUy8OXYMmA1a++C3B iEl309aa9//vA8dwT1xfISXMSy1+ldMml6vgOe55WMF0m+LFK42Xb0nJjxZ2F JK7YpxCvvK71/jJyhGrPY53oEMlwp0Tfi7rTHvKJ63LfuzCS4cAXleeUBjLIRpU YcoaBc5ZCUnkuNjTlo6zuUa1ZYSXXgNdFCti3FQhRmt5UTkmCQ 3zBhkj8AdGMmp2sP95tYijhjg4Sfspp0BxEQR4au9+kyqbA6s9 f5r0MqkTeFLvfhmfi5sSJeHsA51QZ6APuNms111u23iwYMOch1 vwXrEDoLPqkjjGk5ZSU09yEom0kd4rIbrnSqC1kNUqNDrfGOxo opZ+TXpAoUjmIOt1SykzLLkG8wgJK7HdlUhJgJCwPEmfkbnXV5 voEGrG1T7xGhdTOGdSGnGHf1MK8ygUFH5PITHtyHHndqCwsPXS v1K07VpGL0mBiL1lMqzL5nTMYBXpqJjkeu5AECdnuJ3fnZ0KZq 9/eBdJ3KQmI0oJbPYWAAsX8QJrCy5LS234VkHczXjY5tQNJkjgED oca/tvMOGD7WjKRjnMCZxptEOR2958PTClkziGnRv3hB1Yy4h/k+ltBDfidbA35mBPs+GKz6vaJiHwnugz9TRIO5MhBw9jPrPtMU dpMgaQYKMZuBJaPLisK5+qsgsNBL1WFUEDyVUO9Qv1sdNItHbZ 1PsSjZKrsvHvHSAVSvk+zKnAg==SessionKeycbLLh3Bk9sJuZ qak1WLoka7lvDPo6We2p9p040ucMuGM4JfgdPdMD4bYPXq6uNV C4t1U7N3bwb3WtqmV5bkGg3iDCfMpNB/JTJ1pTjRrVAk2DywVSeO5O9PO0Dh9diL0hFUjiGMG84xXs91m2/TDyqbA5hPyahgQ9UlY0uBh65RsXl4EznIctLKjWSlUye2/40rKhrT9vlY5H9d+CDUwIEHuT6fVvsP/XCyi/QF4YN2O6z+kb1FaJYsJkWYnD/au30bLhxdmYqouoKBQif6qYJkbnL7injNsYP79v9rpKrQHmx8Z tayzA8BkEOp/oxrjwQ4XkP/AlxuK8CFaP1CpGA==BindingTypeuv7v+AS5vIfDVbykUezv4M y38pevQSxDM6GEL2xF/2o=BindingJjjqS4mrdBwz2oHLCjSlvqeAQd3AKcy2Va9CVOhJ 4tf/w6LIdHRHWhotlXaMyrEn5G1LdpZH8+5DMnsL8IoEpCzKMe51R4 NXBhjL9W4Ej7M=ProductKey7H6vFYO3vTDflHKQdBqC2opcAW 6mrUiCxFa86e5TmhU=ProductKeyTypeuv7v+AS5vIfDVbykUe zv4HHuFRg6I0lMXDTz+O53j2I=ProductKeyActConfigIdd7r 9XxykPCJsxIUOmd0d8HBQoxVScKAlIMrMsuDQpKHvdjseiauJZ ftqKvj86y19RIDHxOBKRb4Oo4PQO/ia52pno1aoqVBMqP26PT6aZZU=SppSvcVersionMyr1yc7sFQ6 kTV9B4iQenw==otherInfoPublic.licenseCategoryTY4lsQ 60U4Uia1yxOH2EmRP0Jy3ze5FCzZG8EES3Mjo=otherInfoPri vate.licenseCategoryTY4lsQ60U4Uia1yxOH2EmVHX6Q5jBk otHxI0Vasayik=otherInfoPublic.sysprepActionl3adRBx F51Y/T8XW0iHzyA==otherInfoPrivate.sysprepActionl3adRBxF 51Y/T8XW0iHzyA==ClientInformationFiZhI6iJyiHxqPT0lYEvf Oirxetp2VhgyAt3UvzS4rL7IDjVupVQZtfET8fQElxP8wbI6kS Dx7CosZ1SlMvgXg==ReferralInformationAQ218gLejPdbv6 WTZf6mDKGJv53yjR91L0xEffjG//AuYtIToKxPIVEEA9s0pbCcOYMjWWjpyhpnx0VK2lw7Jg==Clie ntSystemTimeiVTx5Ke8Ldr8WbhzwbPtCAYtiwXa6FJIKhROe6 noVtY=ClientSystemTimeUtciVTx5Ke8Ldr8WbhzwbPtCAYti wXa6FJIKhROe6noVtY=otherInfoPublic.secureStoreId2f E+vcsK69ihpjqNMvDproKKnJwhOxTA0NyuDBMm8eEt4wCg9Gu5 9XdUc9xv+DQcotherInfoPrivate.secureStoreId2fE+vcsK 69ihpjqNMvDproKKnJwhOxTA0NyuDBMm8eEt4wCg9Gu59XdUc9 xv+DQc</soap:Body></soap:Envelope>)
        00010002(0x80072EFE, 14:26:29:191 - )
        00010003(0x80072EFE, 14:26:29:191)
        Error: (07/12/2019 02:25:18 PM) (Source: Software Protection Platform Service)(User: )
        Description: hr=0xC004F025RuleId=3482d82e-ca2c-4e1f-8864-da0267b484b2;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=Use rLogon;SessionId=2
        Error: (07/12/2019 02:25:17 PM) (Source: Software Protection Platform Service)(User: )
        Description: hr=0x8007139FRuleId=3482d82e-ca2c-4e1f-8864-da0267b484b2;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=Net workAvailable
        Error: (07/12/2019 02:24:11 PM) (Source: Software Protection Platform Service)(User: )
        Error: (07/12/2019 02:20:05 PM) (Source: Software Protection Platform Service)(User: )
        [HEADING=1]CodeIntegrity Errors:[/HEADING]
        Date: 2019-07-12 13:41:33.295
        Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume6\Windows\Microsoft.NET\Fram ework64\v4.0.30319\mscorsvw.exe because the set of per-page image hashes could not be found on the system.
        Date: 2019-07-12 13:41:33.294
        Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume6\Windows\Microsoft.NET\Fram ework\v4.0.30319\mscorsvw.exe because the set of per-page image hashes could not be found on the system.
        Microsoft OneDrive (HKCU...\OneDriveSetup.exe) (Version: 19.103.0527.0003 - Microsoft Corporation)
        Realtek PCI-E Wireless LAN Driver (HKLM-x32...\InstallShield_{70714FB7-4084-4202-A599-2D5935DECB67}) (Version: Drv_3.00.0018 - REALTEK Semiconductor Corp.)
        Speccy (HKLM...\Speccy) (Version: 1.32 - Piriform)
        Percentage of memory in use: 13%
        Total physical RAM: 16322.87 MB
        Available physical RAM: 14044.79 MB
        Total Virtual: 19266.87 MB
        Available Virtual: 15145.96 MB
        1 Drive c: (Windows) (Fixed) (Total:237.61 GB) (Free:207.6 GB) NTFS
        2 Drive d: (New Volume) (Fixed) (Total:931.5 GB) (Free:931.33 GB) NTFS
        User accounts for \DESKTOP-382C4DR
        Oliver Howard WDAGUtilityAccount
        **** End of log ****
        • Malnutrition
          PCHF Moderator
          • 7041
          Set your DNS to Google DNS.
          Use DNS jumper.
          If this has no help, then we will set you up a static IP address.
          • miniac69
            • Jul 2019
            • 8
            I downloaded DNS jumper and selected Google public DNS and then clicked β€˜Apply DNS’. I hope that was correct. However it still does the same as before, I need to restart before it connects.
            I don’t know a whole lot about computers but couldn’t help notice this in the minitoolbox results:
            Is that anything to be concerned about?
            Thank you for your help by the way!
            • Malnutrition
              PCHF Moderator
              • 7041
              We will try a static ip.
              Hit the start button type ncpa.cpl
              [MEDIA=imgur]7nbTmOb[/MEDIA]
              Right Click your connection, then select properties,
              [MEDIA=imgur]Y6YGJqS[/MEDIA]
              Select Internet Protocol Version 4, then Properties.
              [MEDIA=imgur]Poy4YDl[/MEDIA]
              Set your Default GateWay To: Default Gateway . . . . . . . . . : 192.168.1.254
              Set your IP Address To : IPv4 Address. . . . . . . . . . . : 192.168.1.9
              Set your Subnet Mask To: Subnet Mask . . . . . . . . . . . : 255.255.255.0
              Set your Primary DNS To: … : 8.8.8.8
              Set your Alternate DNS To: … : 8.8.4.4
              [MEDIA=imgur]eImnGEm[/MEDIA]
              • miniac69
                • Jul 2019
                • 8
                Thanks for your help once again but it has made no difference. I am beginning to wonder if I have just been really unlucky with two network cards or perhaps for some reason they are not right for my pc? That might not make sense but in desperation am wondering if I should just go and buy a cheap one and try it?
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  That would be the next most logical step. If you are sure the network card is seated correctly.
                  The minitoolbox log does specify that it isn’t working correctly, although that could be due to a driver but you say you have tried that.
                  Only thing left is to try a cheap adapter or try the computer on a different network, that is easier said than done tho.
                  • miniac69
                    • Jul 2019
                    • 8
                    #10
                    OK so I bought the cheapest card that I could get my hands on and it is now working fine! Is it possible that they could have fitted one to my PC that was not compatible? I have been sent one replacement for it already so it would seem unlikely that I could have had two bad ones in a row.
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #11
                      You would think that they would know what cards are compatible, I’m guessing that you just have some bad luck and got two faulty cards, I’d just request a refund for the card.
                      • miniac69
                        • Jul 2019
                        • 8
                        #12
                        Well I shall see what happens but thank you for your help Malnutrition!
                        • Malnutrition
                          PCHF Moderator
                          • 7041
                          #13
                          Alright, let us know what happens.
                            #14
                            Any updates?
                            • miniac69
                              • Jul 2019
                              • 8
                              #15
                              Originally posted by vger
                              Any updates?
                              As I said in my last post the cheap wireless card has worked. I thought the makers of my PC would get funny over the warranty if I told them I had put a different card in it so I emailed to ask if I could. They will only keep the 3 year warranty if they are the only people to touch the machine, which I suppose is fair as they are offering to repair it (although they were happy for me to fit the card they swapped). I just didnt want to lose the machine for weeks, after already spending a couple of weeks not using it over this problem. So I have just told them I will live with it until I can spare the machine, but in reality I am just going to use it as it is.
                              Thanks for your help!
