Connection times out, ping spikes then goes back to normal.
  • AHHMYSHOULDER
    • Oct 2018
    • 1
    I have tried running "ping -t in CMD and the results are basicaly:
    Ping:8ms
    Ping:7ms
    Timed out
    Ping:388ms
    Ping:105ms
    Ping:7
    And it just goes like this all day.
    I tried unplugging every device, but this PC (every device has this problem, the problem is not my PC) and made sure there are no background processes downloading and this just keeps happening and my ISP said that everything was alright on their part, so I dont really know what to do next…
    I tried 3 different routers, different cables and stuff like that, but that does not seem to do it.
    @Samuria jmarket
    • Rustys
      • 7862
      Ping:8ms
      Ping:7ms
      Timed out
      Ping:388ms
      Ping:105ms
      Ping:7
      You state that you restarted the devices what about the Modem?
      Are any devices connecting via WiFi?
      Have you reset then network connections on the computers?
      Is the firewall on the modem or the router turned on?
      Remove the Router and connect directly to the modem and see if that has any difference.
        Any updates for us?
