Mobil internet sharing problem
  • Panda
    • Mar 2018
    • 3
    I’m trying to use my phone internet connection on my laptop using the internet sharing option and it connects fine but doesn’t connect to the Internet. It comes up saying that the DNS is unavailable. There’s no problem internet sharing from another phone, so it’s not the laptop
    Hopefully some of our members will chime in soon.
    @Samuria jmarket @Malnutrition
    • Rustys
      • 7862
      Some services may not allow you to do that unless you have that service on your plan. May need to check with your provider to make sure that you are able to.
      One other thing to add unless you have an unlimited plan would never suggest that you do this since the data would probaly be used by the time you visited the first page.
      • Malnutrition
        PCHF Moderator
        • 7041
        PDANet
        • Samuria
          • Oct 2016
          • 86
          Open a cmd prompt then type
          ipconfig/all
          post results
          • Malnutrition
            PCHF Moderator
            • 7041
            You can run the command below from command prompt to get the information requested above.
            ipconfig /all >> c:\users%username%\desktop\results.txt
            • Panda
              • Mar 2018
              • 3
              I should be able to do it. I looked on my service provider website and they have page telling you how to do it. As for the data usage that all depends on your network provider
              • Panda
                • Mar 2018
                • 3
                That’s the results for the ipconfig
                • Rustys
                  • 7862
                  Make and model of the phone and Operating System and Version.
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #10
                    Can you post the log as text rather than a picture please. Also, have you tried PDAnet?
                    • plodr
                      • Aug 2016
                      • 1021
                      #11
                      1. brand of working phone and version of android 2. Cellphone provider.
                      Then brand and version of android on your non-working phone.
                      Your cellphone provider.
                        #12
                        Any updates for us?
                          #13
                          Any updates for us? After 48 hrs this thread will be closed.
                          • plodr
                            • Aug 2016
                            • 1021
                            #14
                            Just close it. The OP was on March 6th and I assume chose not to answer any of the questions asked, because he.she didn’t post.
