IPCONFIG gives disconnected media, can only connect wired
  • Macalacka
    • Dec 2017
    • 1
    Just recently I have been having connection issues, at first it would stay connected for 2-5 minutes and then kick me off, and now i cannot even connect to my router wirelessly. I can however connect with a wired connection. Is my router going bad? Or is the network adapter card that I have in my PC bad?
    Hopefully some of our members will chime in soon.
    @Samuria @phillpower2
    • TwitchisMental
      • Nov 2016
      • 176
      Hello Macalacka and welcome to PCHF! We can assist you with the reported issue.
      In order to better assist you, we will need a bit more information. Please follow the instructions below and attach the results in your next post .
      Step 1: Speccy Scan.
      [li]Please go here and download Speccy.[/li][li]Install and run the program.[/li][li]Upon Completion:[/li][li]Hit File[/li][li]Publish Snap Shot[/li][li]A link will appear, post that link.[/li][/ul]
      Step 2 : MiniToolBox Scan
      Checkmark following boxes:
      Flush DNS
      Reset FF proxy Settings
      Reset Ie Proxy Settings
      Report IE Proxy Settings
      Report FF Proxy Settings
      List content of Hosts
      List IP configuration
      List Winsock Entries
      List last 10 Event Viewer log
      List Installed Programs
      List Devices (problems only)
      Click Go post the result.
        Any update MacaLacka?
          Any update MacaLacka? If unreplied to within 48hrs this thread will be closed.
