Internet keeps disconnecting with spikes in ping
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Sometimes when I’m just using my desktop, the wifi will cut out, but it’s only for my specific connection that i use (I think). When this happens some things will still run, such as skype, but i cannot load a new page or anything. This can be solved sometimes by disconnecting from my connection and reconnecting exactly 3 times. but sometimes when i click disconnect it will get stuck, and then i will have to restart. Most of the time in League of Legends, my ping will be at 64 and then spike to around 200 and then hover around there then it will occasionally go back to 64. This can only be fixed by restarting my computer and sometimes it will not help the situation at all.
    I have already updated my drivers and it seems like it has mitigated the situation but hasn’t fixed it completely.
    Also, sometimes when I start up my computer, there will be occasions when there are no internet connections found, and then there’s other times where my own connection that i use cannot be found. This can be solved by restarting once or maybe a couple of times. Can anyone help me find a permanent solution to this problem?
  • Rustys
    • 7862
    Hello iwonlife and welcome to the site.
    Lets see what is going on is the WiFi USB or Card?
    What version and Bit (32/64) is the OS
    DIY or Prebuilt (Make and Model)
    Are the updates current?
    Flush DNS
    Report IE Proxy Settings
    Reset IE Proxy Settings
    Report FF Proxy Settings
    Reset FF Proxy Settings
    List content of Hosts
    List IP Configuration
    List Winsock Entries
    List Installed Programs
    List Devices (Only Problems)
    Please Copy and Paste the information in your next post.
    Thanks…
    • system
      PCHF Owner
      • 7695
      • CachyOS
      I don’t know what the WiFi USS or card is, sorry!
      64 bit OS
      Prebuilt (XPS 8700) 1 1/2 years old
      Yes the updates are current
      Ran by Drake (administrator) on 17-12-2016 at 22:38:27
      Running from β€œC:\Users\Drake\Downloads”
      Model: XPS 8700 Manufacturer: Dell Inc.
      Boot Mode: Normal
      Windows IP Configuration
      Proxy is not enabled.
      No Proxy Server is set.
      β€œReset IE Proxy Settings”: IE Proxy Settings were reset.
      0.0.0.0 pubads.g.doubleclick.net
      0.0.0.0 securepubads.g.doubleclick.net
      0.0.0.0 www.googletagservices.com
      0.0.0.0 gads.pubmatic.com
      0.0.0.0 ads.pubmatic.com
      0.0.0.0 spclient.wg.spotify.com
      Dell Wireless 1704 802.11b/g/n (2.4GHz) = Wi-Fi (Connected)
      Broadcom Virtual Wireless Adapter = Local Area Connection (Hardware not present)
      Realtek PCIe GBE Family Controller = Ethernet (Media disconnected)
      Bluetooth Device (Personal Area Network) = Bluetooth Network Connection (Media disconnected)
      [HEADING=1]----------------------------------[/HEADING]
      [HEADING=1]IPv4 Configuration[/HEADING]
      pushd interface ipv4
      reset
      set global icmpredirects=enabled
      add route prefix=0.0.0.0/0 interface=β€œEthernet 2” nexthop=25.0.0.1 publish=Yes
      add route prefix=0.0.0.0/0 interface=β€œethernet_32768” nexthop=25.0.0.1 publish=Yes
      set interface interface=β€œEthernet 2” forwarding=enabled advertise=enabled metric=9000 nud=enabled ignoredefaultroutes=disabled
      set interface interface=β€œEthernet” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=β€œLocal Area Connection* 1” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=β€œWi-Fi” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=β€œLocal Area Connection* 2” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=β€œBluetooth Network Connection” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=β€œLocal Area Connection* 3” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set interface interface=β€œLocal Area Connection” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
      set subinterface interface= subinterface=ethernet_5 mtu=1477
      set subinterface interface= subinterface=ethernet_32768 mtu=1404
      popd
      [HEADING=1]End of IPv4 configuration[/HEADING]
      Host Name . . . . . . . . . . . . : Drake
      Ethernet adapter Ethernet:
      Physical Address. . . . . . . . . : 98-90-96-BB-AA-1A
      Wireless LAN adapter Local Area Connection* 2:
      Physical Address. . . . . . . . . : 9E-AD-97-DE-7C-F7
      Wireless LAN adapter Wi-Fi:
      Description . . . . . . . . . . . : The DW WLAN Card provides wireless local area networking.
      Physical Address. . . . . . . . . : 9C-AD-97-DE-7C-F7
      IPv6 Address. . . . . . . . . . . : 2606:6000:ff01:400::1(Preferred)
      Lease Obtained. . . . . . . . . . : Saturday, December 17, 2016 10:32:49 PM
      Lease Expires . . . . . . . . . . : Saturday, December 17, 2016 11:28:40 PM
      IPv6 Address. . . . . . . . . . . : 2606:6000:ff01:400:c5e6:b8fd:bd3c:2187(Preferred)
      Temporary IPv6 Address. . . . . . : 2606:6000:ff01:400:4810:24e3:3a79:3770(Preferred)
      Link-local IPv6 Address . . . . . : fe80::c5e6:b8fd:bd3c:2187%21(Preferred)
      IPv4 Address. . . . . . . . . . . : 192.168.0.9(Preferred)
      Lease Obtained. . . . . . . . . . : Saturday, December 17, 2016 10:32:48 PM
      Lease Expires . . . . . . . . . . : Saturday, December 17, 2016 11:32:54 PM
      Default Gateway . . . . . . . . . : fe80::e288:5dff:fe5a:976%21
      192.168.0.1
      DHCPv6 IAID . . . . . . . . . . . : 60599703
      DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1C-45-D0-E3-98-90-96-BB-AA-1A
      DNS Servers . . . . . . . . . . . : 209.18.47.62
      209.18.47.61
      Ethernet adapter Bluetooth Network Connection:
      Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
      Physical Address. . . . . . . . . : 9C-AD-97-DE-7C-F8
      Tunnel adapter isatap.{F18F0FCE-C228-49D5-9C8E-2EB80A625938}:
      Tunnel adapter Teredo Tunneling Pseudo-Interface:
      Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
      IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:1827:2d2e:9347:3f07(Preferred)
      Link-local IPv6 Address . . . . . : fe80::1827:2d2e:9347:3f07%20(Preferred)
      DHCPv6 IAID . . . . . . . . . . . : 452984832
      Server: dns-cac-lb-02.rr.com
      Address: 209.18.47.62
      Addresses: 2607:f8b0:4007:807::200e
      216.58.216.14
      Pinging google.com [2607:f8b0:4007:809::200e] with 32 bytes of data:
      Reply from 2607:f8b0:4007:809::200e: time=12ms
      Reply from 2607:f8b0:4007:809::200e: time=20ms
      Ping statistics for 2607:f8b0:4007:809::200e:
      Minimum = 12ms, Maximum = 20ms, Average = 16ms
      Addresses: 2001:4998:c:a06::2:4008
      2001:4998:44:204::a7
      2001:4998:58:c02::a9
      98.138.253.109
      98.139.183.24
      206.190.36.45
      Pinging yahoo.com [2001:4998:44:204::a7] with 32 bytes of data:
      Reply from 2001:4998:44:204::a7: time=83ms
      Reply from 2001:4998:44:204::a7: time=91ms
      Ping statistics for 2001:4998:44:204::a7:
      Minimum = 83ms, Maximum = 91ms, Average = 87ms
      [HEADING=1]Ping statistics for 127.0.0.1:
      Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
      [HEADING=1]Interface List
      12…98 90 96 bb aa 1a …Realtek PCIe GBE Family Controller
      13…9e ad 97 de 7c f7 …Microsoft Wi-Fi Direct Virtual Adapter
      21…9c ad 97 de 7c f7 …The DW WLAN Card provides wireless local area networking.
      9…9c ad 97 de 7c f8 …Bluetooth Device (Personal Area Network)
      1…Software Loopback Interface 1
      7…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
      20…00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface[/HEADING]
      [HEADING=1]IPv4 Route Table[/HEADING]
      [HEADING=1]Active Routes:
      0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.9 25
      192.168.0.0 255.255.255.0 On-link 192.168.0.9 281
      192.168.0.9 255.255.255.255 On-link 192.168.0.9 281
      192.168.0.255 255.255.255.255 On-link 192.168.0.9 281
      224.0.0.0 240.0.0.0 On-link 192.168.0.9 281
      255.255.255.255 255.255.255.255 On-link 192.168.0.9 281[/HEADING]
      [HEADING=1]Persistent Routes:
      Network Address Netmask Gateway Address Metric
      0.0.0.0 0.0.0.0 25.0.0.1 Default
      0.0.0.0 0.0.0.0 25.0.0.1 Default[/HEADING]
      [HEADING=1]IPv6 Route Table[/HEADING]
      21 281 ::/0 fe80::e288:5dff:fe5a:976
      1 306 ::1/128 On-link
      20 306 2001::/32 On-link
      20 306 2001:0:9d38:6abd:1827:2d2e:9347:3f07/128
      On-link
      21 281 2606:6000:ff01:400::/56 fe80::e288:5dff:fe5a:976
      21 281 2606:6000:ff01:400::/64 On-link
      21 281 2606:6000:ff01:400::1/128
      On-link
      21 281 2606:6000:ff01:400:4810:24e3:3a79:3770/128
      On-link
      21 281 2606:6000:ff01:400:c5e6:b8fd:bd3c:2187/128
      On-link
      21 281 fe80::/64 On-link
      20 306 fe80::/64 On-link
      20 306 fe80::1827:2d2e:9347:3f07/128
      On-link
      21 281 fe80::c5e6:b8fd:bd3c:2187/128
      On-link
      1 306 ff00::/8 On-link
      20 306 ff00::/8 On-link
      21 281 ff00::/8 On-link[/HEADING]
      0 4294967295 2620:9b::/96 On-link
      0 9000 ::/0 2620:9b::1900:1
      0 9000 ::/0 2620:9b::1900:1[/HEADING]
      Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [55808] (Microsoft Corporation)
      Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
      Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
      Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [65024] (Microsoft Corporation)
      Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [23552] (Microsoft Corporation)
      Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [51712] (Microsoft Corporation)
      Catalog5 08 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [122128] (Apple Inc.)
      Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
      x64-Catalog5 01 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
      x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [87040] (Microsoft Corporation)
      x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [87040] (Microsoft Corporation)
      x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
      x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
      x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
      x64-Catalog5 08 C:\Program Files\Bonjour\mdnsNSP.dll [133392] (Apple Inc.)
      x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
      Error: (12/17/2016 10:38:00 PM) (Source: ESENT) (User: )
      Description: svchost (1424) SRUJet: Database C:\WINDOWS\system32\SRU\SRUDB.dat: Index UserIdTimeStamp of table {D10CA2FE-6FCF-4F6D-848E-B2E99266FA89} is corrupted (0).
      Error: (12/17/2016 10:37:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:36:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:35:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:34:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:33:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:32:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:31:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:30:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 10:29:00 PM) (Source: ESENT) (User: )
      Error: (12/17/2016 08:20:29 PM) (Source: DCOM) (User: DRAKE)
      Description: {4AA0A5C4-1B9B-4F2E-99D7-99C6AEC83474}
      Error: (12/17/2016 08:20:27 PM) (Source: Service Control Manager) (User: )
      Description: The User Data Access_1aca7e2 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
      Description: The User Data Storage_1aca7e2 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
      Description: The Contact Data_1aca7e2 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
      Description: The Sync Host_1aca7e2 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
      Error: (12/17/2016 08:20:27 PM) (Source: DCOM) (User: NT AUTHORITY)
      Description: application-specificLocalActivation{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
      Error: (12/17/2016 06:24:43 PM) (Source: DCOM) (User: NT AUTHORITY)
      Description: application-specificLocalActivation{3185A766-B338-11E4-A71E-12E3F512A338}{7006698D-2974-4091-A424-85DD0B909E23}NT AUTHORITYNETWORK SERVICES-1-5-20LocalHost (Using LRPC)UnavailableUnavailable
      Error: (12/17/2016 01:47:47 AM) (Source: DCOM) (User: DRAKE)
      Description: CortanaUI.AppXn73w0hsq3g4wx1h9fhf7q02vw2wta6qc.mca
      Error: (12/17/2016 01:47:44 AM) (Source: DCOM) (User: DRAKE)
      [HEADING=1]Microsoft Office Sessions:[/HEADING]
      Error: (12/17/2016 10:38:00 PM) (Source: ESENT)(User: )
      Description: svchost1424SRUJet: UserIdTimeStamp{D10CA2FE-6FCF-4F6D-848E-B2E99266FA89}C:\WINDOWS\system32\SRU\SRUDB.dat0
      Error: (12/17/2016 10:37:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:36:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:35:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:34:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:33:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:32:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:31:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:30:00 PM) (Source: ESENT)(User: )
      Error: (12/17/2016 10:29:00 PM) (Source: ESENT)(User: )
      [HEADING=1]CodeIntegrity Errors:[/HEADING]
      Date: 2016-12-17 19:16:29.152
      Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Program Files\Windows Defender\MsMpEng.exe) attempted to load \Device\HarddiskVolume5\Program Files\Bonjour\mdnsNSP.dll that did not meet the Custom 3 / Antimalware signing level requirements.
      Date: 2016-12-17 19:16:29.138
      Date: 2016-12-17 18:24:41.677
      Date: 2016-12-17 18:24:41.661
      Date: 2016-12-17 00:34:47.026
      Date: 2016-12-17 00:34:47.018
      Date: 2016-12-16 21:28:33.205
      Date: 2016-12-16 21:28:33.196
      Date: 2016-12-16 20:16:03.185
      Date: 2016-12-16 20:16:03.152
      Β΅Torrent (HKCU...\uTorrent) (Version: 3.4.9.42973 - BitTorrent Inc.)
      7-Zip 16.04 (x64 edition) (HKLM...{23170F69-40C1-2702-1604-000001000000}) (Version: 16.04.00.0 - Igor Pavlov)
      Adobe Flash Player 23 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 23.0.0.207 - Adobe Systems Incorporated)
      Apple Application Support (32-bit) (HKLM-x32...{FE5C2FAA-118D-4509-B51D-3F71CC9E1B3E}) (Version: 4.3 - Apple Inc.)
      Apple Application Support (64-bit) (HKLM...{2937FD88-C9D6-4B82-B539-37CD0A572F42}) (Version: 4.3 - Apple Inc.)
      Apple Mobile Device Support (HKLM...{2E4AF2A6-50EA-4260-9BA4-5E582D11879A}) (Version: 9.3.0.15 - Apple Inc.)
      Apple Software Update (HKLM-x32...{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
      Battle.net (HKLM-x32...\Battle.net) (Version: - Blizzard Entertainment)
      BlueStacks App Player (HKLM-x32...{52A51D7F-6731-45B6-AE77-0D4B0ECC70B5}) (Version: 2.1.8.5663 - BlueStack Systems, Inc.)
      Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
      CCleaner (HKLM...\CCleaner) (Version: 5.24 - Piriform)
      Cisco EAP-FAST Module (HKLM-x32...{64BF0187-F3D2-498B-99EA-163AF9AE6EC9}) (Version: 2.2.14 - Cisco Systems, Inc.) Hidden
      Cisco LEAP Module (HKLM-x32...{51C7AD07-C3F6-4635-8E8A-231306D810FE}) (Version: 1.0.19 - Cisco Systems, Inc.) Hidden
      Cisco PEAP Module (HKLM-x32...{ED5776D5-59B4-46B7-AF81-5F2D94D7C640}) (Version: 1.1.6 - Cisco Systems, Inc.) Hidden
      Clover 3.0 (HKLM-x32...\Clover) (Version: 3.0 - EJIE Technology)
      Clownfish for Skype (HKLM-x32...\Clownfish) (Version: - )
      Counter-Strike: Global Offensive (HKLM-x32...\Steam App 730) (Version: - Valve)
      Curse (HKLM-x32...{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 6.0.0.0 - Curse)
      CyberLink Media Suite Essentials (HKLM-x32...\InstallShield_{8F14AA37-5193-4A14-BD5B-BDF9B361AEF7}) (Version: 10.0 - CyberLink Corp.)
      Defraggler (HKLM...\Defraggler) (Version: 2.21 - Piriform)
      Dell Backup and Recovery (HKLM-x32...{0ED7EE95-6A97-47AA-AD73-152C08A15B04}) (Version: 1.7.5.60 - Dell Inc.)
      Dell Data Services (HKLM...{90F9BFC9-A2A9-403F-9A40-1063FAD035BA}) (Version: 1.1.6.0 - Dell Inc.)
      Dell Data Vault (HKLM...{2E55EEFD-2162-4A7D-9158-EDB0305603A6}) (Version: 4.2.2.0 - Dell Inc.) Hidden
      Dell Digital Delivery (HKLM-x32...{D850CB7E-72BC-4510-BA4F-48932BFAB295}) (Version: 2.9.901.0 - Dell Products, LP)
      Dell Foundation Services (HKLM...{76966FD2-4189-41F1-9CF6-9D177B4DEC97}) (Version: 2.0.42.1 - Dell Inc.)
      Dell Product Registration (HKLM-x32...{17FFE63C-6734-4950-B488-134B5A2505F7}) (Version: 2.04.0280 - Aviata Inc.)
      Dell SupportAssistAgent (HKLM-x32...{287348C8-8B47-4C36-AF28-441A3B7D8722}) (Version: 1.0.3.60494 - Dell)
      Dell System Detect (HKCU...\58d94f3ce2c27db0) (Version: 7.11.0.6 - Dell)
      Dell Update (HKLM-x32...{D9E0A33F-19D6-45A7-83BB-535C7B5F699B}) (Version: 1.5.3000.0 - Dell Inc.)
      Discord (HKCU...\Discord) (Version: 0.0.296 - Hammer & Chisel, Inc.)
      DW WLAN Card (HKLM...\DW WLAN Card) (Version: 6.30.223.227 - Dell Inc.)
      DW WLAN Card Utility (HKLM...\DW WLAN Card Utility) (Version: 6.30.59.74 - Dell Inc.)
      Everything 1.3.4.686 (x86) (HKLM-x32...\Everything) (Version: - )
      f.lux (HKCU...\Flux) (Version: - )
      Fraps (HKLM-x32...\Fraps) (Version: - )
      Garry’s Mod (HKLM-x32...\Steam App 4000) (Version: - Facepunch Studios)
      GIMP 2.8.16 (HKLM...\GIMP-2_is1) (Version: 2.8.16 - The GIMP Team)
      Google Chrome (HKLM-x32...\Google Chrome) (Version: 54.0.2840.99 - Google Inc.)
      Google Update Helper (HKLM-x32...{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.31.5 - Google Inc.) Hidden
      Hearthstone (HKLM-x32...\Hearthstone) (Version: - Blizzard Entertainment)
      Hextech Repair Tool (HKLM-x32...{7F9A97E6-E666-11E5-B582-B88687E82322}) (Version: 1.0.16 - Riot Games, Inc.)
      HP Officejet 6600 Basic Device Software (HKLM...{B407F586-D027-45C3-9109-CC2943E839FA}) (Version: 28.0.1315.0 - Hewlett-Packard Co.)
      HP Support Solutions Framework (HKLM-x32...{F6A11738-3EE4-4573-AEA5-6CD5D491C167}) (Version: 12.0.30.219 - Hewlett-Packard Company)
      Intel(R) Chipset Device Software (HKLM-x32...{e48a2f61-851a-4155-82f9-af1b04db8c3b}) (Version: 10.0.13 - Intel(R) Corporation) Hidden
      Intel(R) Management Engine Components (HKLM...{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 10.0.0.1168 - Intel Corporation)
      Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 12.8.0.1016 - Intel Corporation)
      Intel(R) Update Manager (HKLM-x32...{AD6B46F2-FE21-496F-BE90-BE19AABE353C}) (Version: 2.2.12 - Intel Corporation)
      iTunes (HKLM...{A31C5565-90D9-4615-AE13-94D86C3836C7}) (Version: 12.3.3.17 - Apple Inc.)
      Java 8 Update 111 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F32180111F0}) (Version: 8.0.1110.14 - Oracle Corporation)
      Java 8 Update 45 (HKLM-x32...{26A24AE4-039D-4CA4-87B4-2F83218045F0}) (Version: 8.0.450 - Oracle Corporation)
      League of Legends (HKLM-x32...{79BF4901-1EC4-4726-B3C2-A7859706C6E7}) (Version: 3.0.1 - Riot Games) Hidden
      League of Legends (HKLM-x32...\League of Legends 3.0.1) (Version: 3.0.1 - Riot Games)
      Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
      MapleStory (HKLM-x32...\MapleStory) (Version: - )
      Microsoft Office 365 - en-us (HKLM...\O365HomePremRetail - en-us) (Version: 15.0.4875.1001 - Microsoft Corporation)
      Microsoft Office Word Viewer 2003 (HKLM-x32...{90850409-6000-11D3-8CFE-0150048383C9}) (Version: 11.0.8173.0 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
      Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}) (Version: 8.0.61000 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
      Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23918 (HKLM-x32...{dab68466-3a7d-41a8-a5cf-415e3ff8ef71}) (Version: 14.0.23918.0 - Microsoft Corporation)
      Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.23918 (HKLM-x32...{2e085fd2-a3e4-4b39-8e10-6b8d35f55244}) (Version: 14.0.23918.0 - Microsoft Corporation)
      Microsoft XNA Framework Redistributable 4.0 (HKLM-x32...{2BFC7AA0-544C-4E3A-8796-67F3BE655BE9}) (Version: 4.0.20823.0 - Microsoft Corporation)
      Microsoft XNA Framework Redistributable 4.0 Refresh (HKLM-x32...{D69C8EDE-BBC5-436B-8E0E-C5A6D311CF4F}) (Version: 4.0.30901.0 - Microsoft Corporation)
      Minecraft1.8.4 (HKLM-x32...\Minecraft1.8.4) (Version: - )
      MK LOL (HKCU...\MK LOL) (Version: - )
      My Dell Client Framework (HKLM-x32...{05F1B866-2372-4E82-9AA8-C64FB11CEF8B}) (Version: 1.0.0.3 - Dell) Hidden
      My Dell Client Framework (HKLM-x32...\InstallShield_{05F1B866-2372-4E82-9AA8-C64FB11CEF8B}) (Version: 1.0.0.3 - Dell)
      Nexon Game Manager (HKLM-x32...{EA2DB6E0-72C5-4ef9-A3A0-E6705F4A6A9E}) (Version: - )
      Nexon Launcher (HKLM-x32...\Nexon Nexon Launcher) (Version: 2.0.0 - Nexon)
      Notepad++ (HKLM-x32...\Notepad++) (Version: 6.8.7 - Notepad++ Team)
      NVIDIA PhysX (HKLM-x32...{B455E95A-B804-439F-B533-336B1635AE97}) (Version: 9.14.0702 - NVIDIA Corporation)
      Office 15 Click-to-Run Extensibility Component (HKLM-x32...{90150000-008C-0000-0000-0000000FF1CE}) (Version: 15.0.4875.1001 - Microsoft Corporation) Hidden
      Office 15 Click-to-Run Licensing Component (HKLM...{90150000-008F-0000-1000-0000000FF1CE}) (Version: 15.0.4875.1001 - Microsoft Corporation) Hidden
      Office 15 Click-to-Run Localization Component (HKLM-x32...{90150000-008C-0409-0000-0000000FF1CE}) (Version: 15.0.4875.1001 - Microsoft Corporation) Hidden
      Open Broadcaster Software (HKLM-x32...\Open Broadcaster Software) (Version: - )
      osu! (HKLM-x32...{b3906533-8adb-4b1c-9429-1c4cec44c950}) (Version: latest - ppy Pty Ltd)
      Overwatch (HKLM-x32...\Overwatch) (Version: - Blizzard Entertainment)
      Razer Chroma SDK Core Components (HKLM-x32...\Razer Chroma SDK) (Version: 1.10.6 - Razer Inc.)
      Razer Synapse (HKLM-x32...{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.15.1104 - Razer Inc.)
      Realtek Card Reader (HKLM-x32...{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.2.9200.30164 - Realtek Semiconductor Corp.)
      Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7544 - Realtek Semiconductor Corp.)
      ROBLOX Player for Drake (HKCU...{373B1718-8CC5-4567-8EE2-9033AD08A680}) (Version: - ROBLOX Corporation)
      ShareX (HKLM...\82E6AC09-0FEF-4390-AD9F-0DD3F5561EFC_is1) (Version: 11.4.1 - ShareX Team)
      Skype Audio Player (remove only) (HKLM-x32...\SkypePlayer) (Version: - )
      Skype Web Plugin (HKLM-x32...{34E6C3B4-9354-41C2-9484-25B17F48E7E9}) (Version: 7.13.0.71 - Skype Technologies S.A.)
      Skypeβ„’ 7.30 (HKLM-x32...{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.30.105 - Skype Technologies S.A.)
      SpaceEngine version 0.9.7.2 (HKLM-x32...{E65FD500-9218-44EC-9586-D39FAB4DFDAF}_is1) (Version: 0.9.7.2 - SpaceEngine)
      Spotify (HKCU...\Spotify) (Version: 1.0.44.100.ga60c0ce1 - Spotify AB)
      Star Wars(R) Knights of the Old Republic(R) II: The Sith Lordsβ„’ (HKLM-x32...{629F65FB-7F3C-4D66-A1C0-20722744B7B6}) (Version: 1.00.0000 - Obsidian)
      Stardew Valley (HKLM...\Steam App 413150) (Version: - ConcernedApe)
      Stardew Valley (HKLM-x32...\1453375253_is1) (Version: 2.2.0.4 - GOG.com)
      Steam (HKLM-x32...\Steam) (Version: 2.10.91.91 - Valve Corporation)
      Swords and Sandals 2 2.0 (HKLM-x32...\Swords and Sandals 2) (Version: 2.0 - 3RDsense)
      TeamSpeak 3 Client (HKCU...\TeamSpeak 3 Client) (Version: 3.0.18 - TeamSpeak Systems GmbH)
      TeamViewer 11 (HKLM-x32...\TeamViewer) (Version: 11.0.66695 - TeamViewer)
      Terraria (HKLM-x32...\Steam App 105600) (Version: - Re-Logic)
      Unity Web Player (HKCU...\UnityWebPlayer) (Version: 5.0.3f2 - Unity Technologies ApS)
      VLC media player (HKLM...\VLC media player) (Version: 2.2.2 - VideoLAN)
      VVVVVV (HKLM-x32...\Steam App 70300) (Version: - Terry Cavanagh)
      WIDCOMM Bluetooth Software (HKLM...{C6D9ED03-6FCF-4410-9CB7-45CA285F9E11}) (Version: 12.0.0.9800 - Broadcom Corporation)
      Name: Broadcom Virtual Wireless Adapter
      Description: Broadcom Virtual Wireless Adapter
      Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
      Manufacturer: Broadcom
      Service: BcmVWL
      Device ID: ROOT\NET\0000
      Problem: : The software for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48)
      Resolution: Download the latest drivers from the manufacturer, uninstall the current driver, and then install the latest drivers.
      Percentage of memory in use: 43%
      Total physical RAM: 8143.21 MB
      Available physical RAM: 4622.91 MB
      Total Virtual: 16335.21 MB
      Available Virtual: 12099.03 MB
      1 Drive c: (OS) (Fixed) (Total:921.67 GB) (Free:559.12 GB) NTFS
      2 Drive d: (KOTOR2_1) (CDROM) (Total:0.63 GB) (Free:0 GB) CDFS
      User accounts for \DRAKE
      Administrator DefaultAccount Drake
      Dzung Guest
      **** End of log ****
      • Rustys
        • 7862
        The following command will give us a list of WiFi signal that you wireless sees.
        Type or copy and paste the following commands in an Administrator Command Prompt
        netsh wlan show networks mode=bssid >> %userprofile%\desktop\PCHF.txt
        This will create a file called PCHF.txt on the desktop.
        COPY the contents from this file and PASTE the information in your next post.
        • system
          PCHF Owner
          • 7695
          • CachyOS
          Interface name : Wi-Fi
          There are 1 networks currently visible.
          SSID 1 : House 2.4
          Network type : Infrastructure
          Authentication : WPA2-Personal
          Encryption : CCMP
          BSSID 1 : e0:88:5d:5a:09:78
          Signal : 86%
          Radio type : 802.11n
          Channel : 11
          Basic rates (Mbps) : 1 2 5.5 11
          Other rates (Mbps) : 6 9 12 18 24 36 48 54
          • Rustys
            • 7862
            Open an Administrator command prompt
            Click on Start and in the text box type CMD
            Right Click on CMD and select Run as Administrator
            Type the following commands, pressing Enter after each command:
            netsh winsock reset catalog
            netsh branchcache reset
            netsh int ipv4 reset
            netsh int ipv6 reset
            Reboot the system and try the connection to see if that improves it at all.
            Does this happen with any other WiFi device and does this happen if the system is wired to the modem?
            • system
              PCHF Owner
              • 7695
              • CachyOS
              It is better, but there are still some high ping spikes every couple of seconds.
              This does not happen to any other wifi device and i cannot wire my desktop to the modem.
              • Rustys
                • 7862
                Let run the System File Checker.
                To run System File Checker (Windows XP, Vista, 7, 8, and 10): (with out the quotes)
                1.Click the Start button.
                2.Type β€œcommand” in the search box… DO NOT hit ENTER yet!
                3.While holding CTRL-Shift on your keyboard, hit ENTER.
                4.You will be prompted with a permission dialog box.
                5.Click Yes.
                6.A black box will open with a blinking cursor.
                7.Type β€œsfc /scannow” and hit ENTER.
                8.System File Checker will begin scanning for system file problems (be patient - the system scan may take a while).
                9.Follow the on-screen commands.
                • system
                  PCHF Owner
                  • 7695
                  • CachyOS
                  It says β€œWindows Resource Protection did not find any integrity violations” and there is still a couple of lag spikes.
                  • Rustys
                    • 7862
                    #10
                    When you get the lag spikes is Β΅Torrent running?
                    Try disabling and see if that helps.
                    • system
                      PCHF Owner
                      • 7695
                      • CachyOS
                      #11
                      Β΅Torrent is almost never running
                      • Rustys
                        • 7862
                        #12
                        Check the Date and Time on you system make sure that is set properly. While time settings typically don’t affect internet connectivity, however if it is significantly off, certificates can show as expired or not yet valid, causing browser warnings.
                        If one is a computer please run the following command and paste the results from the text file. The text file will be called ipconfig.txt and should be on your desktop.
                        Open an Command Prompt and type or Copy and Paste
                        Then Press Enter
                        ipconfig /all >%userprofile%\desktop\ipconfig.txt
                        What Anti Malware, Anti Virus, and any other security software are you running currently on the system?
                        nbtstat -R
                        nbtstat -RR
                        ipconfig /flushdns
                        • Samuria
                          • Oct 2016
                          • 86
                          #13
                          You lease for your ip is set to one hour logon to the router. Set it to 7 days, it will stop renewing so often. Set dns to 208.67.220.220 & 208.67.222.222
                          what is this that’s blocked, this may cause conflict
                          Service: BcmVWL
                          • Rustys
                            • 7862
                            #14
                            @iwonlife do you still need help?
                            • system
                              PCHF Owner
                              • 7695
                              • CachyOS
                              #15
                              Yes I still need help sorry I forgot about this.
                              My internet was fine for a couple of days, but now it’s sluggish again and I have high ping again.
