Best Way To Tackle WiFi Deadspots?
  • Nick
    • 302
    My house has multiple totally random WiFi deadspots and they can be quite frustrating at times. I have a Netgear Nighthawk X4 router. What are my options to fix these dead zones, and what’s the best option?
    Example:
    http://www.speedtest.net/result/5608889535.png
  • jmarket
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hi,
    The best way is to get a range extender. That’ll eliminate those dead spots.
    • Madmatt2006
      • 175
      Originally posted by jmarket
      Hi,
      Great advice!
      • Nick
        • 302
        Hi,
        How do those work? Do you just plug them in a power outlet that isn’t a dead spot and it extends the Range to the deadspots?
          Until JM comes online… Wireless repeater - Wikipedia
          • jmarket
            PCHF Owner
            • 7695
            • CachyOS
            Hi
            It’s pretty simple but different for each manufacturer. Basically you set it up as a repeater by connecting to the router (repeater) and specify it to be a repeater and specify a password. Then you connect to that repeater.
            • Lord_Chance
              • 113
              I use a Belkin N300 Wi-Fi Range Extender in my small house. The setup was painless and I get good coverage. It works well with my Buffalo Technology router as well. Just plug it in to an electrical outlet and follow the setup instructions and your done.
              • Malnutrition
                PCHF Moderator
                • 7041
                I work on the road and stay in motels for most of the year, let me tell you what works to get Wifi from some of these not so great motel wifi…
                I am only going to list the hardware that actually works, and works well. I have been through a wide range of items being on the road, these actually work and I own each of these.
                I will list them in order of effectiveness…
                N300 WiFi Range Extender - Essentials Edition Found HERE
                Super USB WiFi Antenna 3 – High Power Long Range 802.11 B G N Wireless
                CC X Mile Omni
                [MEDIA=imgur]YS8NUZi[/MEDIA]
                These tools help me to get wifi when others I work with complain of not being able to connect at all…
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  You will want to plug these into areas where your existing wifi is about half strength, this way it actually has something to be able to boost.
                    #10
                    Hello Nick do you have any updates for us?
                    • Nick
                      • 302
                      #11
                      Sorry, vger, I’ve been busy. And I’m going to get a Netgear range extender to kill the deadspots, and I’ll let you know how it goes once I set it up.
                        #12
                        Thanks for the update Nick..
                          #13
                          Nick do you have an update for us?
                          • Nick
                            • 302
                            #14
                            Well it’s been about 6 months since I complained about the bad WiFI in some parts of my house, but we were at the very back of Home Depot 2 days ago and we found a Netgear N300 wireless range extender, and bought it I set it up, it was very quick and easy, and it definitely seems to be effective! Thanks for the help!
