Resetting?
  • Papa_D
    • 105
    Resetting?
    Hi guys. Friendly somethings wrong and I dont know what Papa D here! So, I am off to research, but thought I would mention it in case someone might say, oh dude, do this…
    Please forgive my inability to term things properly, and THANK YOU for taking time ti read this.
    Sometimes, for no apparent reason, my ventrillo will log out and then back on. Ive noticed this happens on wifes machine also, and at the same time. Which leads me to believe it is a router issue? Possibly a vent server issue, but it seems like my connection is “re setting” itself for whatever reason. This is a new system that I biult myself, which I am starting to think may have been a mistake.Although I am getting quite an education. I also notice things like connected to home network 14, why would I have 14 networks?
    I would appreciate any guidance to help me better understand the sequence of operations and what should be occurring, or even what is occurring and why. As I said, I will try to look up some answers myself, but you guys are pretty sharp…
  • jmarket
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hi,
    Are you talking about Ventrillo the software?
    • Rustys
      • 7862
      Where are you seeing this? If possible please post a screen shot. All you need to do is press the Print Screen button the in a post use the Right mouse button and select paste.
      Thanks,
      Rustys
      • Papa_D
        • 105
        I normally see it when my eset security pops up asking to allow network, but ill try to catch a screen shot of it.
        • Papa_D
          • 105
          Originally posted by jmarket
          Hi,
          Yes and also during webinar I am taking, I lose sound, or it skews, really annoying I was trying to record this class so I can review it and need and had to reboot ectc, etc lost about 5 minutes. Twice it lost sound and came back and once I got the display driver has stopped responding…
          • Malnutrition
            PCHF Moderator
            • 7041
            @Papa D
            Lets get a look at some settings on your machine.
            Checkmark following boxes:
            Flush DNS
            Reset FF proxy Settings
            Reset Ie Proxy Settings
            Report IE Proxy Settings
            Report FF Proxy Settings
            List content of Hosts
            List IP configuration
            List Winsock Entries
            List last 10 Event Viewer log
            List Installed Programs
            List Devices (problems only)
            Click Go and post the result.
            Speccy Scan.
            [li]Please go here and download Speccy.[/li][li]Install and run the program.[/li][li]Upon Completion:[/li][li]Hit File[/li][li]Publish Snap Shot[/li][li]A link will appear, post that link.[/li][/ul]
            • Malnutrition
              PCHF Moderator
              • 7041
              Does your wifes machine also have Eset?
              Have you tried to reset your router to factory settings?
              • Papa_D
                • 105
                Yes
                well…no…
                Ran by Papa Daemon (administrator) on 12-08-2016 at 21:34:56
                Running from “D:\Libraries\Downloads”
                Microsoft Windows 10 Pro (X64)
                Model: To be filled by O.E.M. Manufacturer: Gigabyte Technology Co., Ltd.
                Boot Mode: Normal
                Windows IP Configuration
                Proxy is not enabled.
                No Proxy Server is set.
                “Reset IE Proxy Settings”: IE Proxy Settings were reset.
                “network.proxy.type”, 4
                “Reset FF Proxy Settings”: Firefox Proxy settings were reset.
                Killer e2400 Gigabit Ethernet Controller = Ethernet (Connected)
                Killer Wireless-n/a/ac 1535 Wireless Network Adapter = Wi-Fi (Media disconnected)
                Bluetooth Device (Personal Area Network) = Bluetooth Network Connection (Media disconnected)
                Killer e2400 Gigabit Ethernet Controller = Ethernet 2 (Media disconnected)
                [HEADING=1]----------------------------------[/HEADING]
                [HEADING=1]IPv4 Configuration[/HEADING]
                pushd interface ipv4
                reset
                set global
                set interface interface=“Local Area Connection* 1” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                set interface interface=“Wi-Fi” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                set interface interface=“Local Area Connection* 2” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                set interface interface=“Bluetooth Network Connection” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                set interface interface=“Ethernet” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                set interface interface=“Ethernet 2” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
                popd
                [HEADING=1]End of IPv4 configuration[/HEADING]
                Host Name . . . . . . . . . . . . : DESKTOP-NQTGTPP
                DNS Suffix Search List. . . . . . : hsd1.tn.comcast.net.
                Wireless LAN adapter Wi-Fi:
                Description . . . . . . . . . . . : Killer Wireless-n/a/ac 1535 Wireless Network Adapter
                Physical Address. . . . . . . . . : 9C-B6-D0-00-55-77
                Ethernet adapter Ethernet 2:
                Description . . . . . . . . . . . : Killer e2400 Gigabit Ethernet Controller #2
                Physical Address. . . . . . . . . : 40-8D-5C-51-CD-E6
                Wireless LAN adapter Local Area Connection* 2:
                Physical Address. . . . . . . . . : 9E-B6-D0-00-55-77
                Ethernet adapter Ethernet:
                Connection-specific DNS Suffix . : hsd1.tn.comcast.net.
                Physical Address. . . . . . . . . : 40-8D-5C-51-CD-E4
                IPv6 Address. . . . . . . . . . . : 2601:483:8004:82e0::6(Preferred)
                Lease Obtained. . . . . . . . . . : Friday, August 12, 2016 9:27:14 PM
                Lease Expires . . . . . . . . . . : Friday, August 12, 2016 10:27:14 PM
                Link-local IPv6 Address . . . . . : fe80::ac9f:2d78:7260:cc73%12(Preferred)
                IPv4 Address. . . . . . . . . . . : 192.168.0.25(Preferred)
                Lease Obtained. . . . . . . . . . : Friday, August 12, 2016 9:27:04 PM
                Lease Expires . . . . . . . . . . : Saturday, August 13, 2016 9:27:04 PM
                DHCPv6 IAID . . . . . . . . . . . : 473992540
                DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-34-1C-0E-40-8D-5C-51-CD-E4
                DNS Servers . . . . . . . . . . . : 2001:558:feed::1
                2001:558:feed::2
                75.75.75.75
                75.75.76.76
                Ethernet adapter Bluetooth Network Connection:
                Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
                Physical Address. . . . . . . . . : 9C-B6-D0-00-55-78
                Tunnel adapter Teredo Tunneling Pseudo-Interface:
                Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
                IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:10c2:b2f:b81b:ab5(Preferred)
                Link-local IPv6 Address . . . . . : fe80::10c2:b2f:b81b:ab5%18(Preferred)
                DHCPv6 IAID . . . . . . . . . . . : 486539264
                Tunnel adapter isatap.hsd1.tn.comcast.net.:
                Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
                Server: UnKnown
                Address: 2001:558:feed::1
                Pinging google.com [173.194.219.138] with 32 bytes of data:
                Reply from 173.194.219.138: bytes=32 time=17ms TTL=46
                Reply from 173.194.219.138: bytes=32 time=18ms TTL=46
                Ping statistics for 173.194.219.138:
                Minimum = 17ms, Maximum = 18ms, Average = 17ms
                Server: UnKnown
                Pinging yahoo.com [206.190.36.45] with 32 bytes of data:
                Reply from 206.190.36.45: bytes=32 time=91ms TTL=52
                Reply from 206.190.36.45: bytes=32 time=75ms TTL=52
                Ping statistics for 206.190.36.45:
                Minimum = 75ms, Maximum = 91ms, Average = 83ms
                [HEADING=1]Ping statistics for 127.0.0.1:
                Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
                [HEADING=1]Interface List
                10…9c b6 d0 00 55 77 …Killer Wireless-n/a/ac 1535 Wireless Network Adapter
                5…40 8d 5c 51 cd e6 …Killer e2400 Gigabit Ethernet Controller #2
                4…9e b6 d0 00 55 77 …Microsoft Wi-Fi Direct Virtual Adapter
                12…40 8d 5c 51 cd e4 …Killer e2400 Gigabit Ethernet Controller
                7…9c b6 d0 00 55 78 …Bluetooth Device (Personal Area Network)
                1…Software Loopback Interface 1
                18…00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
                14…00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2[/HEADING]
                [HEADING=1]IPv4 Route Table[/HEADING]
                [HEADING=1]Active Routes:
                0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.25 9
                192.168.0.0 255.255.255.0 On-link 192.168.0.25 265
                192.168.0.25 255.255.255.255 On-link 192.168.0.25 265
                192.168.0.255 255.255.255.255 On-link 192.168.0.25 265
                224.0.0.0 240.0.0.0 On-link 192.168.0.25 265
                255.255.255.255 255.255.255.255 On-link 192.168.0.25 265[/HEADING]
                Persistent Routes:
                None
                [HEADING=1]IPv6 Route Table[/HEADING]
                1 306 ::1/128 On-link
                18 306 2001::/32 On-link
                18 306 2001:0:9d38:6ab8:10c2:b2f:b81b:ab5/128
                On-link
                12 265 2601:483:8004:82e0::6/128
                On-link
                12 265 fe80::/64 On-link
                18 306 fe80::/64 On-link
                18 306 fe80::10c2:b2f:b81b:ab5/128
                On-link
                12 265 fe80::ac9f:2d78:7260:cc73/128
                On-link
                1 306 ff00::/8 On-link
                12 265 ff00::/8 On-link
                18 306 ff00::/8 On-link[/HEADING]
                Persistent Routes:
                None
                Catalog5 01 C:\Windows\SysWOW64\napinsp.dll [55808] (Microsoft Corporation)
                Catalog5 02 C:\Windows\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
                Catalog5 04 C:\Windows\SysWOW64\NLAapi.dll [65024] (Microsoft Corporation)
                Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [23552] (Microsoft Corporation)
                Catalog5 07 C:\Windows\SysWOW64\wshbth.dll [51712] (Microsoft Corporation)
                Catalog5 08 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [122128] (Apple Inc.)
                Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 11 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                Catalog9 12 C:\Windows\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
                x64-Catalog5 01 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
                x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [87040] (Microsoft Corporation)
                x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [87040] (Microsoft Corporation)
                x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
                x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
                x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
                x64-Catalog5 08 C:\Program Files\Bonjour\mdnsNSP.dll [133392] (Apple Inc.)
                x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
                Error: (08/12/2016 09:32:53 PM) (Source: ESENT) (User: )
                Description: CCleaner64 (8652) testing: Error -1032 (0xfffffbf8) occurred while opening logfile C:\Users\Papa Daemon\AppData\Local\Microsoft\Windows\WebCache\V0 1.log.
                Description: CCleaner64 (8652) testing: An attempt to open the file “C:\Users\Papa Daemon\AppData\Local\Microsoft\Windows\WebCache\V0 1.log” for read / write access failed with system error 32 (0x00000020): "The process cannot access the file because it is being used by another process. ". The open file operation will fail with error -1032 (0xfffffbf8).
                Error: (08/12/2016 09:27:43 PM) (Source: Application Error) (User: )
                Description: Faulting application name: ubssrv_oc_only.exe, version: 1.0.0.0, time stamp: 0x530dce70
                Faulting module name: KERNELBASE.dll, version: 10.0.10586.494, time stamp: 0x5775e78b
                Exception code: 0xe0434352
                Fault offset: 0x000bdae8
                Faulting process id: 0x2668
                Faulting application start time: 0xubssrv_oc_only.exe0
                Faulting application path: ubssrv_oc_only.exe1
                Faulting module path: ubssrv_oc_only.exe2
                Report Id: ubssrv_oc_only.exe3
                Faulting package full name: ubssrv_oc_only.exe4
                Faulting package-relative application ID: ubssrv_oc_only.exe5
                Error: (08/12/2016 09:27:43 PM) (Source: .NET Runtime) (User: )
                Description: Application: ubssrv_oc_only.exe
                Framework Version: v4.0.30319
                Description: The process was terminated due to an unhandled exception.
                Exception Info: System.ComponentModel.Win32Exception
                Exception Info: System.InvalidOperationException
                at System.ServiceProcess.ServiceController.GenerateNa mes()
                at System.ServiceProcess.ServiceController.get_Servic eName()
                at System.ServiceProcess.ServiceController.GenerateSt atus()
                at System.ServiceProcess.ServiceController.get_Status ()
                at Gigabyte.Engine.Utilities.EasyTuneEngineServiceMan agement.get_Status()
                at Gigabyte.Engine.Utilities.EasyTuneEngineServiceAsy nchronizeManagement..ctor()
                at HW_OBJ.Service_New_Tune.InitObjects()
                at HW_OBJ.Service_New_Tune..ctor()
                at HW_OBJ.HWmonitorObj..ctor(System.Windows.Forms.Con trol)
                at ubssrv.Program..cctor()
                Exception Info: System.TypeInitializationException
                at ubssrv.Program.Main(System.String)
                Error: (08/12/2016 09:27:25 PM) (Source: Windows Search Service) (User: )
                Description: The index cannot be initialized.
                Details:
                The specified object cannot be found. Specify the name of an existing object. (HRESULT : 0x80040d06) (0x80040d06)
                Description: The application cannot be initialized.
                Context: Windows Application
                Details:
                Description: The gatherer object cannot be initialized.
                Context: Windows Application, SystemIndex Catalog
                Details:
                Description: The plug-in in <Search.TripoliIndexer> cannot be initialized.
                Details:
                Description: The plug-in manager <Search.TripoliIndexer> cannot be initialized.
                Details:
                (HRESULT : 0x8e5e0210) (0x8e5e0210)
                Description: The Windows Search Service is being stopped because there is a problem with the indexer: The catalog is corrupt.
                Details:
                The content index catalog is corrupt. 0xc0041801 (0xc0041801)
                Error: (08/12/2016 09:27:36 PM) (Source: DCOM) (User: DESKTOP-NQTGTPP)
                Description: 1053WSearchUnavailable{B52D54BB-4818-4EB9-AA80-F9EACD371DF8}
                Error: (08/12/2016 09:27:36 PM) (Source: Service Control Manager) (User: )
                Description: The Windows Search service failed to start due to the following error:
                %%1053 = The service did not respond to the start or control request in a timely fashion.
                Description: A timeout was reached (30000 milliseconds) while waiting for the Windows Search service to connect.
                Error: (08/12/2016 09:27:35 PM) (Source: DCOM) (User: DESKTOP-NQTGTPP)
                Description: 1053WSearchUnavailable{7D096C5F-AC08-4F1F-BEB7-5C22C517CE39}
                Error: (08/12/2016 09:27:35 PM) (Source: Service Control Manager) (User: )
                [HEADING=1]Microsoft Office Sessions:[/HEADING]
                Error: (08/12/2016 09:32:53 PM) (Source: ESENT)(User: )
                Description: CCleaner648652testing: C:\Users\Papa Daemon\AppData\Local\Microsoft\Windows\WebCache\V0 1.log-1032 (0xfffffbf8)
                Description: CCleaner648652testing: C:\Users\Papa Daemon\AppData\Local\Microsoft\Windows\WebCache\V0 1.log-1032 (0xfffffbf8)32 (0x00000020)The process cannot access the file because it is being used by another process.
                Error: (08/12/2016 09:27:43 PM) (Source: Application Error)(User: )
                Description: ubssrv_oc_only.exe1.0.0.0530dce70KERNELBASE.dll10. 0.10586.4945775e78be0434352000bdae8266801d1f50a452 02522C:\Program Files (x86)\Gigabyte\CloudStation_Server\RemoteOC\ubssrv _oc_only.exeC:\Windows\SYSTEM32\KERNELBASE.dllf651 1fa5-5de5-464c-9ff6-0d2afbbfedf5
                Error: (08/12/2016 09:27:43 PM) (Source: .NET Runtime)(User: )
                Error: (08/12/2016 09:27:25 PM) (Source: Windows Search Service)(User: )
                Description:
                Details:
                Description: Context: Windows Application
                Details:
                Description: Context: Windows Application, SystemIndex Catalog
                Details:
                Details:
                Details:
                Description:
                Details:
                [HEADING=1]CodeIntegrity Errors:[/HEADING]
                Date: 2016-08-10 15:33:57.234
                Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume4\Windows\System32\efswrt.dl l because the set of per-page image hashes could not be found on the system.
                Date: 2016-08-09 18:09:02.774
                Date: 2016-08-05 22:31:33.410
                Date: 2016-08-05 20:40:17.759
                Date: 2016-08-05 16:14:47.441
                Date: 2016-08-05 15:56:16.782
                Date: 2016-08-05 15:44:04.186
                Date: 2016-08-05 14:58:46.420
                Date: 2016-08-05 10:46:01.753
                Date: 2016-08-04 22:32:21.693
                @BIOS B15.0713.1 (HKLM-x32...{C9D46F25-5F9D-4E25-B24F-BC00E9EDF529}) (Version: 3.00.0000 - GIGABYTE) Hidden
                @BIOS B15.0713.1 (HKLM-x32...\InstallShield_{C9D46F25-5F9D-4E25-B24F-BC00E9EDF529}) (Version: 3.00.0000 - GIGABYTE)
                3DMark (HKLM...{C03F143A-6F4C-48E8-926B-0643E6242D83}) (Version: 2.1.2852.0 - Futuremark) Hidden
                3DMark (HKLM-x32...{92d18d18-84fb-4eb2-b52e-c7cc8f48176b}) (Version: 2.1.2852.0 - Futuremark)
                3DOSD (HKLM-x32...{F0D1FAA5-F9F8-4524-9B65-A5BFDDD5A29B}) (Version: 1.00.0010 - GIGABYTE) Hidden
                3DOSD (HKLM-x32...\InstallShield_{F0D1FAA5-F9F8-4524-9B65-A5BFDDD5A29B}) (Version: 1.00.0010 - GIGABYTE)
                ACP Application (HKLM...{DBEBD8D0-AE86-3C68-40A6-807D10F8196E}) (Version: 2.15.30.0019 - Advanced Micro Devices, Inc.) Hidden
                ACP Application (HKLM...{F6191048-C738-9336-04C8-968455D82C31}) (Version: 2016.0718.1650.38 - Advanced Micro Devices, Inc.) Hidden
                Adobe Acrobat DC (HKLM-x32...{AC76BA86-1033-FFFF-7760-0C0F074E4100}) (Version: 15.017.20053 - Adobe Systems Incorporated)
                Adobe Flash Player 22 NPAPI (HKLM-x32...\Adobe Flash Player NPAPI) (Version: 22.0.0.209 - Adobe Systems Incorporated)
                Ambient LED (HKLM-x32...{BEF97B38-D1B8-45B4-A60A-AF5C1556CC72}) (Version: 1.00.1507.0101 - GIGABYTE) Hidden
                Ambient LED (HKLM-x32...\InstallShield_{BEF97B38-D1B8-45B4-A60A-AF5C1556CC72}) (Version: 1.00.1507.0101 - GIGABYTE)
                AMD Install Manager (HKLM...\AMD Catalyst Install Manager) (Version: 9.0.000.4 - Advanced Micro Devices, Inc.)
                APP Center (HKLM-x32...{B164E11B-19B5-432F-ABFA-2D50746C9E50}) (Version: 1.00.1602.2501 - GIGABYTE) Hidden
                APP Center (HKLM-x32...\InstallShield_{B164E11B-19B5-432F-ABFA-2D50746C9E50}) (Version: 1.00.1602.2501 - GIGABYTE)
                Apple Application Support (32-bit) (HKLM-x32...{D4B07658-F443-4445-A261-E643996E139D}) (Version: 4.3.2 - Apple Inc.)
                Apple Application Support (64-bit) (HKLM...{A6B0442B-E159-444B-B49D-6B9AC531EAE3}) (Version: 4.3.2 - Apple Inc.)
                Apple Mobile Device Support (HKLM...{2E4AF2A6-50EA-4260-9BA4-5E582D11879A}) (Version: 9.3.0.15 - Apple Inc.)
                Apple Software Update (HKLM-x32...{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
                Asmedia ASM106x SATA Host Controller Driver (HKLM-x32...{DF6C3726-7E53-4772-9763-E9F147769F51}) (Version: 3.1.6.0000 - Asmedia Technology)
                Asmedia USB Host Controller Driver (HKLM-x32...{E4FB0B39-C991-4EE7-95DD-1A1A7857D33D}) (Version: 1.16.26.1 - Asmedia Technology)
                AutoGreen (HKLM-x32...{CFB76B97-0C1C-4E1A-999A-DE62FA5FEB9A}) (Version: 1.0 - GIGABYTE) Hidden
                AutoGreen (HKLM-x32...\InstallShield_{CFB76B97-0C1C-4E1A-999A-DE62FA5FEB9A}) (Version: 1.0 - GIGABYTE)
                Bandicam (HKLM-x32...\Bandicam) (Version: 3.1.1.1073 - Bandisoft.com)
                Bandisoft MPEG-1 Decoder (HKLM-x32...\BandiMPEG1) (Version: - Bandisoft.com)
                Bonjour (HKLM...{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
                Bonjour Print Services (HKLM...{0DA20600-6130-443B-9D4B-F30520315FA6}) (Version: 2.0.2.0 - Apple Inc.)
                BUSB (HKLM-x32...{0AADC50C-C4F8-49A7-8699-AFE46875CA67}) (Version: 1.15.0623.1 - GIGABYTE)
                CAM (HKLM-x32...{06A8FB2E-C819-40EC-9F5E-8551191B79EA}) (Version: 3.1.50 - NZXT)
                Catalyst Control Center Next Localization BR (HKLM...{55A4D3AB-C8DF-26B2-89A8-7E16E1E40700}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization BR (HKLM...{AE9699A4-B1B0-10C9-A259-B0A8A56E36D6}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization CHS (HKLM...{2EE8C5F9-A81B-1C26-7D98-AC574ABA09FA}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization CHS (HKLM...{365AEAB2-4CF3-7CBB-0DAC-E9E14B688E65}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization CHT (HKLM...{7ABC6D83-816E-6D48-E65D-B0CEDD294E4E}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization CHT (HKLM...{D925F1AA-CF0B-20C3-ED9E-8A2CBE2DBC69}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization CS (HKLM...{5F86405C-F339-5740-7C7F-1513F413449D}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization CS (HKLM...{C3EE628C-7394-FE2C-0C90-C05284EB528D}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization DA (HKLM...{2F544F46-5F6E-97BB-3550-A0242A3C5754}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization DA (HKLM...{B36E01FA-A830-36CD-67BD-94088E1BB9D9}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization DE (HKLM...{F1B39CC8-0E73-5348-A80E-E76175B7E8A9}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization DE (HKLM...{FC4086D6-E345-5F43-08BB-280FB57DAF49}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization EL (HKLM...{B3A19BE3-8DE7-7AD1-2585-BA82ECC748B8}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization EL (HKLM...{F8EBE530-A4D5-BF51-F623-3787E6B8A878}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization ES (HKLM...{42FBD43F-DE53-6D4D-5134-E3C93B45CBEF}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization ES (HKLM...{B9467156-31C6-FCEE-50F1-843F3280AC19}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization FI (HKLM...{4CECCFDD-32A3-F76E-1B77-5205A7E2AC15}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization FI (HKLM...{AC85CF50-9A55-0103-ADBF-365C37603AA4}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization FR (HKLM...{4F05D35C-7E92-4B0D-3652-B5B23BDE0C4C}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization FR (HKLM...{B349892D-B015-033C-4CA8-3635E6B655D7}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization HU (HKLM...{015BF849-5599-53B7-C285-CD04E93808E5}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization HU (HKLM...{BE8D6AB1-3049-2F0C-67FA-00C0A5D321A3}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization IT (HKLM...{26567561-DFB2-2B63-9BA8-6A490ED37016}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization IT (HKLM...{D9BD316F-BA41-F8B0-0AE5-5BCE61B12CC6}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization JA (HKLM...{0809FEC1-EF86-51E9-8210-DC1B1BDB6745}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization JA (HKLM...{C5B0E34F-37DA-2E68-1F9B-20DD03D57BD4}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization KO (HKLM...{4BB9DB5C-FAFE-7E2C-72E5-D32E36EDBBD4}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization KO (HKLM...{5FD706FF-6AD8-E372-A35A-879409982655}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization NL (HKLM...{6261F969-B6CB-AE39-F87E-5DBA2707A3FA}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization NL (HKLM...{A4E7CA0C-84EB-5E29-2F04-06C4E4790C2F}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization NO (HKLM...{2292A6C2-0681-8BC8-684D-FCB02E1597E1}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization NO (HKLM...{59D2664C-949B-7FA7-9880-ECB993B6616A}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization PL (HKLM...{6E311612-B79E-61BE-8AEC-F05B844D5659}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization PL (HKLM...{970A40CA-46AB-986C-1798-976ED0EA00FA}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization RU (HKLM...{4707CBFC-8ED4-463E-0FF9-DE86F4A743E9}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization RU (HKLM...{5701D87A-68E9-D6CD-8E1E-8FFE27216BEA}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization SV (HKLM...{C14A3A5B-8A86-C239-37D7-158211778C54}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization SV (HKLM...{D6C1036A-8761-1540-60F0-0E7EDDBD4BCB}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization TH (HKLM...{A438B034-65CA-5CDA-0DA2-37CC331FF40A}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization TH (HKLM...{A50C89BC-8D8E-8828-824A-7171F6D583D5}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization TR (HKLM...{0B5633F0-C415-2F08-671E-4C9E2FAACD45}) (Version: 2015.1129.2307.41591 - Advanced Micro Devices, Inc.) Hidden
                Catalyst Control Center Next Localization TR (HKLM...{77FC1E46-D7FC-878D-5401-969AA0E11AAC}) (Version: 2016.0718.1747.30147 - Advanced Micro Devices, Inc.) Hidden
                CCleaner (HKLM...\CCleaner) (Version: 5.20 - Piriform)
                Citrix Online Launcher (HKLM-x32...{09DA5EE2-7E46-4DC4-96F9-BFEE50D40659}) (Version: 1.0.408 - Citrix)
                Cloud Station (Server) (HKLM-x32...{5D132D9D-2A99-48CF-9DCC-775DF6F31384}) (Version: 1.00.1507.1501 - GIGABYTE) Hidden
                Cloud Station (Server) (HKLM-x32...\InstallShield_{5D132D9D-2A99-48CF-9DCC-775DF6F31384}) (Version: 1.00.1507.1501 - GIGABYTE)
                CloudStation (HKLM-x32...{6D8DA122-A40A-421B-9D95-FE4C806BCDBE}) (Version: 1.00.0019 - GIGABYTE) Hidden
                CloudStation (HKLM-x32...\InstallShield_{6D8DA122-A40A-421B-9D95-FE4C806BCDBE}) (Version: 1.00.0019 - GIGABYTE)
                CyberLink Media Suite 10 (HKLM-x32...\InstallShield_{8F14AA37-5193-4A14-BD5B-BDF9B361AEF7}) (Version: 10.0 - CyberLink Corp.)
                CyberLink PowerProducer 5.5 (HKLM-x32...\InstallShield_{B7A0CE06-068E-11D6-97FD-0050BACBF861}) (Version: 5.5.3.4118 - CyberLink Corp.)
                Driver Support (HKLM-x32...\DriverSupport) (Version: 10.1.3.34 - PC Drivers HeadQuarters LP)
                ESET Smart Security (HKLM...{C20E6525-879A-47C3-BBC4-6B8096D3F53D}) (Version: 9.0.386.0 - ESET, spol. s r.o.)
                Futuremark SystemInfo (HKLM-x32...{C7FF0DD8-90C1-4612-B41F-0CA013062953}) (Version: 4.47.597.0 - Futuremark)
                Geeks3D FurMark 1.17.0.0 (HKLM-x32...{2397CAD4-2263-4CD0-96BE-E43A980B9C9A}_is1) (Version: - Geeks3D)
                GoToMeeting 7.21.0.5387 (HKCU...\GoToMeeting) (Version: 7.21.0.5387 - CitrixOnline)
                HP Designjet ePrint & Share (HKLM-x32...{4D1B7E4E-47B1-40E3-9E15-C50E42D81610}) (Version: 1.0.7 - Hewlett-Packard)
                HP Designjet T120 and T520 ePrinter Series (HKLM-x32...\HPAmpereXL) (Version: - Hewlett-Packard Co.)
                HP Designjet Utility (HKLM-x32...{D03C0D1E-9FD6-40EB-B27B-BBBEEE0F94D0}) (Version: 1.1.8.1556 - Hewlett-Packard)
                HP Officejet 6600 Basic Device Software (HKLM...{B407F586-D027-45C3-9109-CC2943E839FA}) (Version: 28.0.1315.0 - Hewlett-Packard Co.)
                HP Officejet 7610 series Basic Device Software (HKLM...{3507BAF4-20F8-4AAC-8B4B-C61D67607728}) (Version: 29.1.971.39251 - Hewlett-Packard Co.)
                HP T120 and T520 series ICC Profiles (HKLM...{4F9E7F57-1D06-4B50-9691-813F87C655B8}) (Version: 2.0.0 - Hewlett Packard, Co.)
                HP Update (HKLM-x32...{912D30CF-F39E-4B31-AD9A-123C6B794EE2}) (Version: 5.005.002.002 - Hewlett-Packard)
                HP Web Registration (HKLM-x32...{D2FF897E-4A99-446E-8BB4-DD99CD496838}) (Version: 1.2.0.0 - Hewlett Packard, Co.)
                I.R.I.S. OCR (HKLM-x32...{CA6BCA2F-EDEB-408F-850B-31404BE16A61}) (Version: 12.3.4.0 - HP)
                ICQ (version 10.0.12094) (HKCU...\icq.desktop) (Version: 10.0.12094 - ICQ)
                Intel Extreme Tuning Utility (HKLM-x32...{3e93c46f-8b15-4bb9-939f-646ab7287be9}) (Version: 6.0.2.1 - Intel Corporation)
                Intel Extreme Tuning Utility (HKLM-x32...{51B6F1D8-D460-4883-BB85-66C3BD88771B}) (Version: 6.0.2.1 - Intel Corporation) Hidden
                Intel(R) Chipset Device Software (HKLM-x32...{c7f54569-0018-439c-809a-48046a4d4ebc}) (Version: 10.1.1.9 - Intel(R) Corporation) Hidden
                Intel(R) Management Engine Components (HKLM...{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.0.0.1158 - Intel Corporation)
                Intel(R) Processor Graphics (HKLM-x32...{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4331 - Intel Corporation)
                Intel(R) Rapid Storage Technology (HKLM...{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 14.5.0.1081 - Intel Corporation)
                Intel® PROSet/Wireless Software (HKLM-x32...{d9e230c1-06bb-4b78-a9f1-c1ddce14e6fc}) (Version: 18.11.0 - Intel Corporation)
                Intel® Watchdog Timer Driver (Intel® WDT) (HKLM-x32...{3FD0C489-0F02-481a-A3E1-9754CD396761}) (Version: - Intel Corporation)
                Intel® Watchdog Timer Driver (Intel® WDT) (HKLM-x32...\3FD0C489-0F02-481a-A3E1-9754CD396761) (Version: - Intel Corporation)
                iTunes (HKLM...{955524E7-79EB-4CA9-BA4D-FD2DF587651B}) (Version: 12.4.3.1 - Apple Inc.)
                Killer Bandwidth Control Filter Driver (HKLM...{AA08CAC2-27E6-4C18-BA97-D57D9FEDCECB}) (Version: 1.1.53.1329 - Rivet Networks) Hidden
                Killer E240x Drivers (HKLM...{8818D7D3-B700-46A5-B841-D56CC0978CE5}) (Version: 1.1.53.1329 - Rivet Networks) Hidden
                Killer Network Manager (HKLM...{4DD4A2C5-99CC-4B02-B7FB-EF4CBD1A5DF3}) (Version: 1.1.53.1329 - Rivet Networks) Hidden
                Killer Performance Suite (HKLM-x32...{186515F8-E855-452F-9733-5D8B4DD54814}) (Version: 1.1.53.1329 - Rivet Networks)
                Killer Wireless-AC 1535 Drivers (HKLM...{327A1CAD-987F-41CD-95FB-B01E5368CDE5}) (Version: 1.1.53.1329 - Rivet Networks) Hidden
                LG ODD Auto Firmware Update (HKLM-x32...{6179550A-3E7C-499E-BCC9-9E8113E0A285}) (Version: 10.01.0712.01 - )
                LightScribe System Software (HKLM-x32...{10427BCB-0742-43BE-81E2-3920972946F5}) (Version: 1.18.23.1 - LightScribe)
                Logitech Gaming Software 8.84 (HKLM...\Logitech Gaming Software) (Version: 8.84.15 - Logitech Inc.)
                Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
                Microsoft ASP.NET 2.0 AJAX Extensions 1.0 (HKLM-x32...{082BDF7B-4810-4599-BF0D-E3AC44EC8524}) (Version: 1.0.61025 - Microsoft Corporation)
                Microsoft Office 365 - en-us (HKLM...\O365HomePremRetail - en-us) (Version: 16.0.7070.2033 - Microsoft Corporation)
                Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32...{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
                Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.50727 (HKLM-x32...{15134cb0-b767-4960-a911-f2d16ae54797}) (Version: 11.0.50727.1 - Microsoft Corporation)
                Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32...{d491dd9d-2eda-4d75-b504-1a201436e7fd}) (Version: 11.0.61030.0 - Microsoft Corporation)
                Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.50727 (HKLM-x32...{22154f09-719a-4619-bb71-5b3356999fbf}) (Version: 11.0.50727.1 - Microsoft Corporation)
                Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 (HKLM-x32...{3994d355-238a-4612-af93-26d13deddef1}) (Version: 11.0.61030.0 - Microsoft Corporation)
                Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23918 (HKLM-x32...{dab68466-3a7d-41a8-a5cf-415e3ff8ef71}) (Version: 14.0.23918.0 - Microsoft Corporation)
                Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.23918 (HKLM-x32...{2e085fd2-a3e4-4b39-8e10-6b8d35f55244}) (Version: 14.0.23918.0 - Microsoft Corporation)
                Mozilla Firefox 48.0 (x86 en-US) (HKLM-x32...\Mozilla Firefox 48.0 (x86 en-US)) (Version: 48.0 - Mozilla)
                Mozilla Maintenance Service (HKLM-x32...\MozillaMaintenanceService) (Version: 48.0 - Mozilla)
                Office 16 Click-to-Run Extensibility Component (HKLM-x32...{90160000-008C-0000-0000-0000000FF1CE}) (Version: 16.0.7030.1021 - Microsoft Corporation) Hidden
                Office 16 Click-to-Run Licensing Component (HKLM...{90160000-008F-0000-1000-0000000FF1CE}) (Version: 16.0.7030.1021 - Microsoft Corporation) Hidden
                Office 16 Click-to-Run Localization Component (HKLM-x32...{90160000-008C-0409-0000-0000000FF1CE}) (Version: 16.0.7030.1021 - Microsoft Corporation) Hidden
                PlaysTV (HKLM-x32...\PlaysTV) (Version: 1.13.1-r115223-release - Plays.tv, LLC)
                Qualcomm Atheros 61x4 Bluetooth Suite (64) (HKLM...{628988B4-3FA5-4EA6-BAA3-DA640F6718BD}) (Version: 3.0.0.543 - Qualcomm Atheros)
                QuickBooks (HKLM-x32...{2B0E1E07-2F3D-4E7D-AD0A-1C74A8881B9B}) (Version: 26.0.4007.2607 - Intuit Inc.) Hidden
                QuickBooks Pro 2016 (HKLM-x32...{4338BDE2-0035-41BC-87BE-EE0AD5D48042}) (Version: 26.0.4007.2607 - Intuit Inc.)
                QuickBooks Runtime Redistributable (HKLM...{F2A4F809-2DE6-4D27-888B-4D2BB8DAF20E}) (Version: 1.00.0000 - Intuit Inc.)
                Raptr (HKLM-x32...\Raptr) (Version: 5.2.5-r115042-release - Raptr, Inc)
                Razer Chroma SDK Core Components (HKLM-x32...\Razer Chroma SDK) (Version: 1.7.8 - Razer Inc.)
                Razer Synapse (HKLM-x32...{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.15.707 - Razer Inc.)
                Right-Suite Universal (HKLM-x32...\Right-Suite Universal) (Version: - )
                Samsung Magician (HKLM-x32...{29AE3F9F-7158-4ca7-B1ED-28A73ECDB215}_is1) (Version: 4.9.7 - Samsung Electronics)
                Samsung NVM Express Driver (HKLM...{D767F147-306C-4E91-BC7F-624EB509EC39}_is1) (Version: 1.1 - Samsung Electronics)
                Sid Meier’s Civilization IV: Colonization (HKLM...\Steam App 16810) (Version: - Firaxis Games)
                Steam (HKLM-x32...\Steam) (Version: 2.10.91.91 - Valve Corporation)
                TechPowerUp GPU-Z (HKLM-x32...\TechPowerUp GPU-Z) (Version: - TechPowerUp)
                The Elder Scrolls V: Skyrim (HKLM...\Steam App 72850) (Version: - Bethesda Game Studios)
                Thunderbolt™ Software (HKLM-x32...{E265C71F-14DA-462C-A06A-CBA776B695F1}) (Version: 15.2.32.250 - Intel Corporation)
                Total War: WARHAMMER (HKLM...\Steam App 364360) (Version: - Creative Assembly)
                Ultima Online Classic Client (HKLM-x32...\Ultima Online Classic) (Version: - Electronic Arts)
                Ultima Online Enhanced Client (HKLM-x32...\Ultima Online Enhanced) (Version: - Electronic Arts)
                UOAssist (HKLM-x32...\UOAssist) (Version: - )
                UOCartographer 0.9 (HKLM-x32...\UOCartographer 0.9) (Version: - UOCartographer.com)
                Ventrilo Client for Windows x64 (HKLM...{EEB3F6BB-318D-4CE5-989F-8191FCBFB578}) (Version: 3.0.8.0 - Flagship Industries, Inc.)
                Vulkan Run Time Libraries 1.0.17.0 (HKLM...\VulkanRT1.0.17.0) (Version: 1.0.17.0 - LunarG, Inc.) Hidden
                Vulkan Run Time Libraries 1.0.17.0 (HKLM...\VulkanRT1.0.17.0-2) (Version: 1.0.17.0 - LunarG, Inc.)
                WD Discovery (HKLM-x32...{A80AE043-EF68-4B64-9C6F-088405FED315}) (Version: 102.0.1.10 - Western Digital Technologies, Inc.)
                WD My Cloud (HKLM...{8F19C800-80A5-4636-B560-39A58112D45B}) (Version: 1.0.4.37 - Western Digital Technologies, Inc.)
                WD Quick View (HKLM-x32...{F4F2EF32-EAFE-4F87-B7DC-E19C9F8E76FC}) (Version: 2.4.16.16 - Western Digital Technologies, Inc.)
                WD SmartWare (HKLM...{515B34CA-1229-4EDA-AE7C-53CBA68B8A7A}) (Version: 2.4.16.16 - Western Digital Technologies, Inc.)
                WD SmartWare Installer (HKLM-x32...{4555885d-a64c-4234-9aac-72a8a6b5590b}) (Version: 2.4.16.16 - Western Digital Technologies, Inc.)
                WinZip 20.5 (HKLM...{CD95F661-A5C4-44F5-A6AA-ECDD91C24105}) (Version: 20.5.12118 - WinZip Computing, S.L. )
                Wondershare DVD Slideshow Builder Deluxe(Build 6.5.1.1) (HKLM-x32...\Wondershare DVD Slideshow Builder Deluxe_is1) (Version: 6.5.1.1 - Wondershare Software Co.,Ltd.)
                Wondershare Filmora(Build 7.5.0) (HKLM...\Wondershare Filmora_is1) (Version: - Wondershare Software)
                Wondershare Helper Compact 2.5.0 (HKLM-x32...{5363CE84-5F09-48A1-8B6C-6BB590FFEDF2}_is1) (Version: 2.5.0 - Wondershare)
                Wondershare Video Converter Ultimate(Build 8.7.2.1) (HKLM-x32...\Wondershare Video Converter Ultimate_is1) (Version: 8.7.2.1 - Wondershare Software)
                Name: High Definition Audio Bus
                Description: High Definition Audio Bus
                Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
                Manufacturer: AMD
                Service: HDAudBus
                Device ID: PCI\VEN_1002&DEV_AAC8&SUBSYS_AAC81458&REV_00\6&C32 FAAB&0&01400008
                Problem: : This device is disabled. (Code 22)
                Resolution: In Device Manager, click “Action”, and then click “Enable Device”. This starts the Enable Device wizard. Follow the instructions.
                Percentage of memory in use: 11%
                Total physical RAM: 32713.74 MB
                Available physical RAM: 28872.94 MB
                Total Virtual: 37577.74 MB
                Available Virtual: 32273.37 MB
                1 Drive c: () (Fixed) (Total:476.39 GB) (Free:372.83 GB) NTFS
                2 Drive d: (New Volume) (Fixed) (Total:5589.03 GB) (Free:5553.7 GB) NTFS
                3 Drive e: (My Book) (Fixed) (Total:2794.49 GB) (Free:1850.37 GB) NTFS
                User accounts for \DESKTOP-NQTGTPP
                Papa Daemon
                **** End of log ****
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  For now, I think the best option would be to reset your router to factory settings. Then if the issue happens again, let me know; we will investigate further if needed.
                  • Papa_D
                    • 105
                    #10
                    ok Thank you. I will do that.
                    • Papa_D
                      • 105
                      #11
                      Reseting to factory seems to have cleared up that issue. Thank you!
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #12
                        You are very welcome, glad to have helped.
