Power loop problem
This topic is closed.
  • mackenzie
    • Sep 2022
    • 11
    Power loop problem
    I have a cyberpowerpc laptop from a few years ago. It has a 2060 and a 6 core Intel cpu. It’s currently stuck in a infinite power loop. The screen dosint even get a chance to turn on. The device turns off right away and the results don’t change weather It’s plugged in or not. The charge light indicates the battery has a full charge. I believe the last time I left the laptop I had it do a automatic shutdown after a windows update.
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    Do you have any data you need off the drive
    Was windows 11 working ok on this?
    Do you have access to another computer
    Do you have a spare 8gb or more usb stick
    • mackenzie
      • Sep 2022
      • 11
      Not really, anything important is on an external drive.
      Windows 11 was working fine
      I have access to another computer
      I’m not sure but I can pick one up in the morning if not
      Thank you for responding
      • PeterOz
        • Mar 2021
        • 4181
        You could download the windows 11 creation tool and try a repair.
        However if you do not need any data you could do a fresh install
        The youtube clip below is for win 10. The basics are the same for 11
        Reinstall Win 11 Fresh Install
        Download the win 11 tool run it to recreate the flash drive – Must be minimum 8GB
        https://www.microsoft.com/en-au/soft...load/windows11
        Watch this video
        How To Install Windows 10 From USB - YouTube
        In the video at 2:54 you will notice it restarts the computer.
        When you are doing this and you get to that point Remove the usb stick whilst it is restarting.
        Also if you want to setup a local account instead of logging in with a Microsoft account
        Turn off your wireless network and or remove the network cable.
        This point is 3.32 in the video - Choose I don’t have internet.
        If you want to log in with a Microsoft account then leave the network as is.
        Before doing any install, it is a good idea to go to the support page for your system. Download the drivers you are going to need ie chipset, sound, video, wireless, etc. While win10 has a lot of native drivers, microsoft drivers are designed for ease of use and are NOT designed for any type of performance. Store these drivers on another usb or you can even just make a folder on your install usb when you are finished making the install usb. Copy the drivers into that folder.
        When you are finished with the install, then install your drivers. Install the chipset first then the rest of them. Reboot each time when prompted.
        From here a list on how to install Proper Installation Order for Windows Drivers
        • mackenzie
          • Sep 2022
          • 11
          Thank you so much. I will do all the steps and see if it works
          • mackenzie
            • Sep 2022
            • 11
            It’s a cyperpowerpc laptop. It’s not really an β€œofficial name brand” laptop so alot of the parts are off brand parts. I’d have to look into how to find a driver for some of the things like audio. The chipset and graphics I know how to do
            • PeterOz
              • Mar 2021
              • 4181
              Get what you can
              Or hope windows drivers do enough
              Sometimes you have no choice
              Let’s see what happens
              • mackenzie
                • Sep 2022
                • 11
                I tried downloading windows 11 but it says the file is too big for the usb even though i got a 32 gb usb drive
                • mackenzie
                  • Sep 2022
                  • 11
                  correction, i downloaded the wrong file
                  im still not getting any results. the computer wont turn on for more than a split second
                  i believe there may be something wrong with the battery. there is significant battery expansion, but not a huge amount. and it has been used very often for a few years now
                  • Rustys
                    • 7862
                    #10
                    Can you remove the battery and just tun off the mains?
                    • mackenzie
                      • Sep 2022
                      • 11
                      #11
                      Originally posted by PeterOz
                      Get what you can
                      i tried a fresh windows install but i couldint even do it. it shut off right away. i replaced the os ssd with an new empty one and its doing the same thing. im not sure if its the battery or something messed up on the motherboard
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #12
                        As per post 10 can you remove the battery?
                        Are you comfortable in pulling the laptop apart?
                        If you can give a model number, we might be able to find instructions
                        • mackenzie
                          • Sep 2022
                          • 11
                          #13
                          yes i already have. iv taken the battery out and put it back in. model number: GK5CN-03-13-3S1P-0
                          • mackenzie
                            • Sep 2022
                            • 11
                            #14
                            the battery does have minor physical bloating. the device has been used very often for intensive gaming for the p[ast few years. im not sure if the battery is toast or if a different componet is the problem
                            • PeterOz
                              • Mar 2021
                              • 4181
                              #15
                              Take the battery out and run it without the battery connected
