Pc is having problems need help can’t find
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #16
    Ok then you have a different issue
    That part we did only affects the hdd - nothing else
    Nothing to do with bios or booting from usb
    either the bios is not set to boot from usb or usb is not made correctly.
    Lets start from scratch
    Get a new download - make sure you choose to use on another computer
    Reinstall Win 10 Fresh Install
    Download the win 10 tool run it to recreate the flash drive – Must be minimum 8GB
    Download Windows 10
    Watch this video
    How To Install Windows 10 From USB - YouTube
    In the video at 2:54 you will notice it restarts the computer.
    When you are doing this and you get to that point Remove the usb stick whilst it is restarting.
    Also if you want to setup a local account instead of logging in with a Microsoft account
    Turn off your wireless network and or remove the network cable.
    This point is 3.32 in the video - Choose I don’t have internet.
    If you want to log in with a Microsoft account then leave the network as is.
    Before doing any install, it is a good idea to go to the support page for your system. Download the drivers you are going to need ie chipset, sound, video, wireless, etc. While win10 has a lot of native drivers, microsoft drivers are designed for ease of use and are NOT designed for any type of performance. Store these drivers on another usb or you can even just make a folder on your install usb when you are finished making the install usb. Copy the drivers into that folder.
    When you are finished with the install, then install your drivers. Install the chipset first then the rest of them. Reboot each time when prompted.
    From here a list on how to install Proper Installation Order for Windows Drivers
    • PeterOz
      • Mar 2021
      • 4181
      #17
      Also check your boot menu in bios
      Fast boot has to be off
      • Rustys
        • 7862
        #18
        What was the Disk number that you used in post # 12?
          #19
          @Icantdrive69 - any updates?
          • Rustys
            • 7862
            #20
            Abandoned closed thread
