Blue Audio Port for Headset Sound
  • wabla1
    • Sep 2021
    • 2
    Hello there [IMG alt=β€œβ€]https://www.bleepingcomputer.com/for...ault/smile.png
    My green audio ports are broken. I want to plug my headset (green audio cable) into the blue audio port on the back of my pc. However, when i plug it in my pc recognizes my headset as β€œLine In”.
    Is there a way to change that to β€œline out” or something?
    With the realtek audio manager this would be super easy because it would just ask me wheter my cable is supposed to be a speaker or a mikrofon.
    However, i have the newest version of the AMD High Definition Audio Device driver and i could not find a program to help me with my problem.
    Would appreciate the help… thanks for your time.[/IMG]
    • 10697
    does the case have a front headphone jack?
    what happened to the back audio port for it to be broken?
    if the audio driver doesn’t allow the Line In to be swapped to a Line Out, your options are to either change to a USB headset or get an add-on PCI-ex audio card.
    • wabla1
      • Sep 2021
      • 2
      Thank you for your answer. I was able to resolve this issue by installing the right audio driver.
        • 10697
        phew - when you said the blue port was broken, I thought you meant physically.
        glad you got it sorted.
