Help with sound
    • 8978
    #16
    @Bruce @phillpower2
    Any updates? After 48 hrs this thread will be closed.
      PCHF Moderator
      • 10697
      #17
      OK, let’s go back a step.
      try plugging in any 3.5mm headphones to see if it’s those krakens or the pc itself.
      • Niraal
        • Feb 2019
        • 22
        #18
        Originally posted by vger
        @Bruce @phillpower2
        Nope because not one helps me lel
        • Niraal
          • Feb 2019
          • 22
          #19
          Doesn’t work I think the problem is with the pc or with the HDMI cable (Reminding that my monitor got speakers)
            PCHF Moderator
            • 10697
            #20
            and did you change the output device to say Speakers?
            • Niraal
              • Feb 2019
              • 22
              #21
              Wdym
              • Rustys
                • 7862
                #22
                Originally posted by Niraal
                Wdym
                Please follow the rules for proper posting.
                4. When posting, please use proper grammar. Refrain from β€œtext speak”. While primarily English speaking, we are a multi-national forum. Therefore our international members must use translation software which does not understand abbreviations.
                • Niraal
                  • Feb 2019
                  • 22
                  #23
                  Sorry
                    • 8978
                    #24
                    Any updates?
                    • Niraal
                      • Feb 2019
                      • 22
                      #25
                      Any updates?
                      Nope
                      • Rustys
                        • 7862
                        #26
                        @Bruce
                        Has this ever worked?
                        How long ago?
                        What was changed prior to it no longer working (if it did)?
                        Did you ever change you output for the sound and or check to make sure that it is on the correct one?
                        What is the make and model of the computer?
                        Have you tried a different cable?
                        Is HDMI the only way you can connect to the monitor?
                        I don’t use a audio software
                        Could be the issue you need may need to install the actual audio software for the sound card in the system?
                        • Niraal
                          • Feb 2019
                          • 22
                          #27
                          @Bruce
                          How long ago?
                          My monitor and graphic card can use DisplayPort I think I will just buy DisplayPort Cable and it will fix the problem
                            PCHF Moderator
                            • 10697
                            #28
                            unlikely, but hey, let’s see what happens.
                            • Baroona
                              • Apr 2019
                              • 27
                              #29
                              The first one doesn’t work and the second one i haven’t tried because I can’t find the drivers and I don’t think that reinstalling the drivers will work
                              The driver is located on Control panel > hardware and sound > sound
                              i am not trying to butt in, but i believe you should do as advised from the support team so they can help you accordingly
                                • 15206
                                #30
                                Any update Niraal?
