problem after partitioning drive
  • omar
    • Feb 2018
    • 11
    #16
    tried suggestions but no success virtual box etc was not user friendly to get W98 so just gave up!
    thanks anyway
    • jmarket
      PCHF Owner
      • 7695
      • CachyOS
      • Intel Arc A770 (16 GB)
      #17
      Hi there omar,
      For Virtual Box, you have to obtain an ISO file of Windows 98, then mount it. If you wish to have a easy tutorial on how to do it, here’s one I found that explains it quite nicely
      [MEDIA=youtube]Eno4l6pKQHc[/MEDIA]
        #18
        Any update for us omar?
        • omar
          • Feb 2018
          • 11
          #19
          many thanks for your continued interest
          I followed the tutorial you kindly sent me but without success getting as far as creating a virtual machine and trying to get the relevant extension pack
          it seems I was unable to mount w98 2nd edition with the cd containing an iso file image which I downloaded from a version bought from someone on ebay
          On inserting this cd rom I got the following screen:
          FATAL No bootable medium found. System halted
          It’s been very frustrating!
            #20
            Two reasons that I can think of why you may get such a message, the ISO is no good and the drive where the ISO is has not been selected, I don[ICODE]t use a VM regular so not the best placed to advise you I[/ICODE]m afraid.
            Got a link to from where you made the purchase.
            • omar
              • Feb 2018
              • 11
              #21
              thanks again for your support
              I don’t want to trouble you any further
              I’ll keep trying as possible and will let you know if I have any success
              Best regards
                #22
                No trouble at all and likewise I`m quite sure that if anyone here has an idea for you they will get back to you.
                You are welcome btw
                  #23
                  @Evan Omo jmarket
                    #24
                    Any updates for us?
                    • omar
                      • Feb 2018
                      • 11
                      #25
                      thanks again for your continued interest
                      after much difficulty I managed to install Win98 only to fail at the last hurdle: connecting to the internet!
                      No matter what I did with trying to change the virtual machine’s β€˜network’ or β€˜shared folders’ etc. I kept getting β€˜this program has performed an illegal operation’ when I clicked on β€˜internet explorer’!
                      I need to get on the internet to download the driver for my scanner.
                      Any ideas??
                      Regards
                        #26
                        Any updates for us?
                        @phillpower2
                          #27
                          Was unable to suggest anything else for omar Veeg and mentioned as such in reply #22, I did ask for a link to from where the Windows 98 ISO was obtained as that may be the crux of the problem.
                          • omar
                            • Feb 2018
                            • 11
                            #28
                            thanks–no further progress–I’m stuck at being unable to connect to the internet
                            My pc is on windows 10 and is connected by cable to broadband internet
                            the iso i got from ebay had a product key so i successfully managed to install Win 98
                            the problem is how to configure network connectionβ€” i used NAT process
                            i am a pc novice!
                              #29
                              Ok thanks for your help @phillpower2 . Omar i am going to tag some other members which are good with internet issues and VM issues and partition issues.
                              @Samuria @gus jmarket @Evan Omo @Lord Chance
                                #30
                                Any updates for us?
