Having trouble installing Deepin on a flash drive can someone help?
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    #16
    It is definitely safer to install it to a separate drive, glad you got it sorted.
    BTW: no need to quote previous posts, just clutters up the board.
    Do you consider this issue solved now?
    • Brandon_Byrnes
      • Jan 2017
      • 626
      #17
      Yep I consider it solved thanks for the help.
      • system
        PCHF Owner
        • 7695
        • CachyOS
        #18
        good luck with it.
