Best mesh Wi-Fi routers 2021: the best wireless mesh routers for large homes
    What’s amazing about the best mesh Wi-Fi routers is they’ll expand your network to cover every corner of your home or office the way your current router never could. Instead of a single unit, these routers are made of multiple units that can be spaced throughout the area of coverage, which allows them to deliver a robust and continuous connection throughout your home or office.
    The best mesh Wi-Fi routers, therefore, can take care of all your network problems, whether it’s because your current router can’t cover your entire area, you’re having issues staying connected, or your network is just overwhelmed by too many devices. While it is possible to upgrade your internet with a better wireless router or a Wi-Fi extender, one of these mesh routers is a simpler and more efficient option.
    No matter if you have a large or overcrowded network, the best mesh Wi-Fi routers are a stellar way of giving you an uninterrupted and robust upgrade. Here are our top picks.
    [li]We found the best Wi-Fi 6 routers on the market right now[/li][li]For the best Wi-Fi extenders, check out our top picks[/li][/ul]
    [HEADING=1]Best mesh Wi-Fi routers at a glance[/HEADING]
    [ol]
    [li]Google Nest Wifi [/li][li]Asus ZenWiFi AX (XT8) [/li][li]Netgear Orbi Pro WiFi 6[/li][li]Linksys Velop WiFi 6 AX4200[/li][li]Netgear Orbi WiFi 6[/li][li]Netgear Nighthawk MK83[/li][li]Netgear Orbi AC1200[/li][li]TP-Link Deco M5[/li][li]Ubiquiti Amplifi HD[/li][li]Linksys Velop[/li][/ol]
    [IMG alt=“The Google Nest Wifi combines Google Home and Wi-Fi in the same product.”]https://cdn.mos.cms.futurecdn.net/y2...3TuPCvGUom.jpg
    The Google Nest Wifi kicks things up a notch. (Image credit: Google)
    [HEADING=2]1. Google Nest Wifi[/HEADING]
    Google Wifi and Home together at long last
    Speed: 802.11a/b/g/n/ac 2.4 GHz/5 GHz simultaneous dual-band | Connectivity: Dual Gigabit Ethernet ports | Features: Advanced security chip, Nest Wifi point with Google Assistant, privacy control
    Excellent design
    Smart speaker(s) included
    Even simpler controls
    No major performance gains
    Not worth replacing existing mesh
    What’s better than the best mesh router? Well, a mesh router with a smart speaker, that’s what. Especially if you’re a smart home fiend, you will appreciate the pure genius of this upgrade in Google’s Wifi line. The Google Nest Wifi kicks things up a notch, taking Google Wifi’s incredible yet simple design and performance then merges it with the convenience of a smart speaker so you’ve got a two-in-one device in an even sleeker and more attractive package. And, if you’re tired of the color white, this one also comes in Mist and Sand colors. As far as the best mesh Wi-Fi routers go, the original Google Wifi is still the one to beat. This one just gives it that extra oomph.
    Read the full review: Google Nest Wifi
    [IMG alt=“The Asus ZenWiFi AX (XT8) is what to get if you want top-of-the-range performance for streaming video, gaming and other online activities.”]https://cdn.mos.cms.futurecdn.net/i3...EN2uBSLhfj.jpg
    (Image credit: Asus)
    [HEADING=2]2. Asus ZenWiFi AX (XT8)[/HEADING]
    Wi-Fi 6 meets mesh routers
    Speed: 802.11ax 4804Mbps down | Connectivity: 2.5 Gigabit Wan, 3 x Gigabit LAN, Gigabit Wan, USB 3.1 | Included mesh nodes: 2 | Features: MU-MIMO, Traffic Analyzer, Adaptive QoS, AiProtection Pro
    Great Wi-Fi performance
    Good security features
    Expensive
    Limited to two routers
    With the Asus ZenWiFi AX (XT8), Asus has managed to introduce Wi-Fi 6 to that other cutting-edge tech in connectivity; mesh routers. While it is among the more expensive options out there and limits you to two mesh routers, the Asus ZenWifi AX offers blazing fast speeds as well as plenty of flexibility in its setup – such as the option to set up one or two networks using the 2.4 and 5GHz bands. With excellent security features to boot, this is a fantastic choice if you’re looking at the best mesh Wi-Fi systems.
    Read the full review: Asus ZenWiFi AX (XT8)
    [IMG alt=“Get the Netgear Orbi Pro WiFi 6 if you want superb WiFi performance over a remarkably large area even with the basic kit.”]https://cdn.mos.cms.futurecdn.net/Yu...ShphkmFLVN.jpg
    (Image credit: Netgear)
    [HEADING=2]3. Netgear Orbi Pro WiFi 6[/HEADING]
    Superb Wi-Fi performance
    Speed: 802.11b/g/n/ax 2.4GHz 2,400Mbps, 802.11a/n/ac/ax 5GHz 2,400Mbps, 802.11a/n/ac/ax 5GHz 1,200Mbps | Connectivity: 1 x Gigabit or 2.5 Gigabit Ethernet WAN or LAN port, 2 x Gigabit Ethernet LAN ports, Link Aggregation Mode4 optional; 2 x Gigabit Ethernet LAN ports | Included mesh nodes: up to 4 | Features: Insight App, 4 SSID wireless networks, up to 4X more devices than with WiFi 5
    Easy to deploy
    6Gbps backhaul
    Expensive
    Hardly inconspicuous
    Sprawling mansions and big companies have demanding network coverage needs that only the best mesh Wi-Fi systems can meet, which is why such routers as the Netgear Orbi Pro WiFi 6 exist. This is a powerful piece of kit, even at its most basic configuration, delivering superb Wi-Fi connection over a remarkably large area. If you want the most powerful mesh Wi-Fi, you’ve found it. However, it also comes at a lofty price that most households shouldn’t spend. Invest, but only if it makes technical sense.
    Read the full review: Netgear Orbi Pro WiFi 6
    [IMG alt=“Competitively priced, the Linksys Velop WiFi 6 AX4200 provides admirable performance and ease of use.”]https://cdn.mos.cms.futurecdn.net/ZZ...ykNSEPmwiS.jpg
    (Image credit: Linksys)
    [HEADING=2]4. Linksys Velop WiFi 6 AX4200[/HEADING]
    Smart design and speedy performance
    Speed: 802.11a/b/g/n/ac/ax 2.4 GHz/5 GHz | Connectivity: 3 x Gigabit LAN, 1 x Gigabit WAN, 1 x USB 3.0 | Features: 4x4 MU-MIMO, Next-Gen OFDMA Technology, Tri-Band Dynamic Backhaul
    Impressive Wi-Fi 6 performance
    4x Ethernet and 1x USB ports
    Defaults to single, merged network
    The Linksys Velop WiFi 6 AX4200 is proof that Wi-Fi 6 mesh systems can be affordable and accessible, giving big households on a budget an excellent option that still delivers admirable performance and ease of use. If you want to improve your home network’s speed and connectivity, this state of the art mesh system is an ideal solution. That’s especially if you’re ready to future-proof your network with Wi-Fi 6 technology. Those who aren’t as computer savvy will also appreciate that easy-to-use Linksys app.
    Read the full review: Linksys Velop WiFi 6 AX4200
    [IMG alt=“The Netgear Orbi WiFi 6 is a fast, reliable mesh Wi-Fi system that’s absolutely state-of-the-art.”]https://cdn.mos.cms.futurecdn.net/ee...nU4ELhVfKN.jpg
    [HEADING=2]5. Netgear Orbi WiFi 6[/HEADING]
    Netgear brings Wi-Fi 6 to its Orbi mesh range
    Speed: WiFi 6 (IEEE 802.11ax) tri-band with 1x 2.4GHz (1200Mbps), 2x 5GHz (2400Mbps) | Connectivity: 2.5Gbps WAN, 4x Gigabit Ethernet; satellite - 4x Gigabit Ethernet | Features: Beamforming implicit and explicit for 2.4GHz/5GHz bands
    Excellent Wi-Fi range and speed
    Simple set-up, and easy-to-use app
    Seriously expensive
    Little support for Wi-Fi 6 right now
    If you’re ready to jump on the Wi-Fi 6 bandwagon, the Orbi WiFi 6 is your best bet when it comes to getting the best mesh Wi-Fi systems. It’s not by any means a casual purchase, with its steep price tag, but if you’re looking to upgrade to a faster and more reliable router to cover a massive space – like your countryside mansion, perhaps, or your crowded smart home – then this one’s absolutely worth the money. Plus, it’s easy and straightforward to setup, making it great for people who don’t have too much experience with Wi-Fi networks.
    Read the full review: Netgear Orbi WiFi 6
    [IMG alt=“Netgear Nighthawk MK83”]https://cdn.mos.cms.futurecdn.net/bY...aMnvTB3nT.jpeg
    [HEADING=2]6. Netgear Nighthawk MK83[/HEADING]
    Fast, reliable Wi-Fi 6 mesh system
    Speed: Wi-Fi 6 (IEEE 802.11ax), tri-band 2.4GHz + 5GHz + 5GHz | Connectivity: 4 Gigabit Ethernet ports (1WAN + 3LAN) on router, 2 Gigabit Ethernet ports satellite | Features: Bitdefender VPN
    Strong performance on 2.4GHz and 5.0GHz bands
    Covers areas up to 6,750 sq.ft
    Nighthawk app is pretty basic
    Although there are opportunities for improvement here – that Nighthawk app is disappointingly sparse and demands additional subscriptions for extra vital features – the Nighthawk MK83 still delivers excellent connectivity for two- to three-bedroom homes. It’s capable of covering 6,750 sq.ft with its three-piece kit and offers Wi-Fi 6 for more efficiently transmitting data to lots of devices all at the same time. This is just what you need for a multi-room, multi-device smart household, especially if you have some cash to spare.
    Read the full review: Netgear Nighthawk MK83
    [IMG alt=“The tri-band Netgear Orbi Whole Home Mesh WiFi System offers solid performance at a reasonable price.”]https://cdn.mos.cms.futurecdn.net/AR...ZAUgJnqu9B.jpg
    The tri-band Orbi Whole Home AC1200 offers solid performance at a reasonable price. (Image credit: Netgear)
    [HEADING=2]7. Netgear Orbi Whole Home Mesh WiFi System[/HEADING]
    Fast, affordable, tri-band mesh Wi-Fi
    Speed: IEEE 802.11ac dual-band with 1x 2.4GHz (400Mbps), 1x 5GHz (866Mbps) | Connectivity: 2 x Gigabit Ethernet | Features: Beamforming implicit and explicit for 2.4GHz/5GHz bands
    Affordable dual-band mesh Wi-Fi system
    Good performance
    Free parental controls are limited
    Only one Ethernet port for wired connections
    The tri-band Orbi Whole Home AC1200 offers solid performance at a reasonable price, and will be a good choice for most small and medium-size homes that need to improve their Wi-Fi coverage. It’s simple to set-up and use for newcomers, although Netgear’s decision to use Disney’s subscription-based Circle service for parental controls is discouraging, considering that rival routers and mesh systems have often provided better parental controls for free. The lack of Ethernet ports for wired connections as well as more advanced features in the Orbi app might turn off experienced users as well.
    [IMG alt=“The TP-Link Deco M5 is an affordable way to spread Wi-Fi throughout your home.”]https://cdn.mos.cms.futurecdn.net/qJ...iBYvqxZVGM.jpg
    [HEADING=2]8. TP-Link Deco M5[/HEADING]
    The affordable Wi-Fi Mesh option
    Speed: 802.11ac 5GHz down: 76.69 Mbps | Connectivity: 2 x Gigabit ports per Deco M5 unit, 1 x USB Type-C port, Bluetooth 4.2 | Included mesh nodes: 1-3 | Features: Quad-core CPU, MU-MIMO ready, Router-based antivirus, Alexa compatibility
    Incredible value
    Easy to configure
    Slower than compeition
    If you’re looking for a way to spread Wi-Fi throughout your home without having to spend a lot of dough, then look into the TP-Link Deco M5. It’s not as speedy as some of the other best mesh Wi-Fi routers on this list, but if you’re not too concerned about getting the maximum theoretical throughput, which you probably won’t be able to take full advantage of anyway, this shouldn’t be too much of an issue. Setup, similar to the other devices here, is a breeze, even if you’re not tech-savvy. The TP-Link Deco M5 is among the best wireless mesh routers for those who don’t want to get too technical.
    Read the full review: TP-Link Deco M5
    [IMG alt=“The Ubiquiti Amplifi HD is one of the simplest routers we’ve ever set up.”]https://cdn.mos.cms.futurecdn.net/mr...cnpy5F3yFA.jpg
    [HEADING=2]9. Ubiquiti Amplifi HD[/HEADING]
    Style backed by power
    Speed: 802.11AC 5GHz down: 74.1Mbps | Connectivity: 1 x Gigabit WAN, 4 x Gigabit LAN | Mesh nodes: 1 x router, 2 x nodes | Features: Modular network coverage, modern design, LCD touchscreen
    Modern aesthetic
    Extremely powerful
    Expensive
    If you love Apple’s design philosophy, enjoy having attractive gadgets set up around your home and have more than enough extra money sitting around, then the Ubiquiti Amplifi HD is the perfect mesh router for you. You’ll find a lot to love with this device, especially if you live in a large house and can take advantage of the full power that this mesh Wi-Fi setup provides, as it’s capable of a very large amount of throughput. You might find that the value diminishes quite a bit when you live in a smaller space however, since there are more affordable alternatives on hand for small to medium homes. The Ubiquiti Amplifi HD may be pricey, but you’re paying for a piece of tech that both exudes style and a ton of substance. That’s more than enough to justify the price tag, making this a great addition to the best wireless mesh routers list.
    Read the full review: Ubiquiti Amplifi HD
    [IMG alt=“The Linksys Velop is easy to configure and delivers great wireless speeds over a wide area.”]https://cdn.mos.cms.futurecdn.net/Ps...iY9rrW4CS4.jpg
    [HEADING=2]10. Linksys Velop[/HEADING]
    Paying for simplicity
    Speed: 802.11ac 5GHz down: 117.46Mbps | Connectivity: 2 x Gigabit Ethernet ports per unit (1 WAN and 1 LAN port each) | Included mesh nodes: 1-3 | Features: Guided setup, Modular, Easy parental controls, Auto-fix
    Simple r
    Simple setup
    Expensive
    While it’s expensive and not quite as powerful as the other Wi-Fi mesh routers on this list, there’s something to be said about the simplicity that the Linksys Velop offers. It might come with a heftier price than the competition, but the Velop will appeal to people who need to create a Wi-Fi network and want to avoid setting it up. More tech-savvy users will most likely look elsewhere – why spend money when you can do the work yourself for free? However, for most users, the Linksys Velop is among the best wireless mesh routers because of the convenience it offers from the start. It’s also completely modular, so you only have to pick up as many nodes as you actually need – one node will cover up to 2,000 square feet.
    [li]These are the best routers of 2021[/li][li]Discover the best antivirus[/li][/ul]
