Best fax machines of 2021: 5 top picks for sending faxes
    • 54586
    Even in 2021, the best fax machines are still important tools for many businesses, and on this page we’ve picked the top devices you can buy right now.
    Many offices still uses faxes to communicate with suppliers and customers, as well as other parts of the business, and if you’re looking to upgrade your fax machine, the good news is that these days there are some brilliant devices that will let you quickly and easily send faxes, including important documents, across the world.
    While faxes are becoming less common in modern offices, that doesn’t mean you should stick with your old fax machine. The best fax machines on this page come with some great additional features.
    In fact, some of the best fax machines are actually all-in-one printers, which not only send faxes, but can print, scan and photocopy documents. Not only can these devices save you money, but also space, which makes them ideal for small offices.
    [IMG alt="FCZk4haLnP86UqEcgsntoV" width="525px" height="500px"]https://cdn.mos.cms.futurecdn.net/FCZk4haLnP86UqEcgsntoV.jpg[/IMG]
    Zapped by Zoom? Here’s 20% off Ringcentral Office
    Integrated video conferencing, screen sharing and messaging for teams big and small. Get more done before, during, and after meetings with fully integrated messaging and a modern business phone system. Join Ringcentral Office and get the first month free, buy a phone and get another for free plus 20% off. This is a limited time offer.
    [HEADING=1]Best fax machines at a glance:[/HEADING]
    [ol]
    [li]Epson WorkForce WF-2750DWF[/li][li]Samsung M2885FW 4-in-1 Multifunction Xpress laser printer[/li][li]Brother MFC-L6800DWT[/li][li]Brother FAX-2940[/li][li]Samsung SF-760P[/li][/ol]
    [IMG alt=“Epson WorkForce WF-2750DWF”]https://cdn.mos.cms.futurecdn.net/UR...ytTMxG4kMG.jpg
    Image credit: Epson
    [HEADING=2]1. Epson WorkForce WF-2750DWF[/HEADING]
    The best all-in-one printer and fax machine
    Print speed: 33 pages per minute | Scan resolution: 1200 x 2400 dpi | Features: Print, copy, scan, fax | Dimensions: 425 x 360 x 230 mm (Width x Depth x Height) | Weight: 6.6 kg
    Economical ink use
    LCD screen
    Loud
    Uninspiring design
    If you want the best fax machine that also doubles up as a printer, photocopier and scanner and you want it for a low price, then the Epson WorkForce WF-2750DWF is the one to go for. Sure, it looks a bit boring, and when in use it can get quite noisy, but the amount of features the Epson WorkForce WF-2750DWF offers, plus the quality of its scanning, printing and faxing, makes it a brilliant choice for home and office use on a budget.
    [IMG alt=“Samsung M2885FW 4-in-1 Multifunction Xpress”]https://cdn.mos.cms.futurecdn.net/3a...530bb5516d.jpg
    Image credit: Samsung
    [HEADING=2]2. Samsung M2885FW 4-in-1 Multifunction Xpress laser printer[/HEADING]
    A great office fax machine and 4-in-1
    Print speed: 28ppm | Print resolution: Effective 4,800 x 600 | Paper capacity: 250 sheets | Dimensions: 401 x 362 x 367mm (Width x Depth x Height) | Weight: 11.3kg
    Superb print quality
    Good connectivity
    Multi-purpose tray only holds one sheet
    Fiddly control panel
    With wired (Ethernet/USB) and wireless (Wi-Fi/NFC) connectivity, duplex printing, decent eco settings and support for a wide range of media, the Samsung M2885FW is an excellent all-rounder, and one of the best fax machines you can buy. As it’s a 4-in-1 device, it can handle printing, scanning and photocopying as well, so if you don’t need those, then this is a bit overkill. However, if you’re looking for a fast laser printer and fax machine for a busy office, it’s a brilliant choice.
    [IMG alt=“Image credit: Brother”]https://cdn.mos.cms.futurecdn.net/g9...jPHyzAbHaj.jpg
    [HEADING=2]3. Brother MFC-L6800DWT[/HEADING]
    A serious fax machine for busy offices
    Print speed: 46ppm | Scan resolution: 1,200 x 1,200 | Paper capacity: 520 sheets | Dimensions: 495 x 427 x 650mm (Width x Depth x Height) | Weight: 22.8kg
    Fast print speeds
    Excellent print quality
    Large
    Expensive
    If you’re looking for the best fax machine for a busy and large office, then the Brother MFC-L6800DWT is definitely worth investing in. As a laser printer, it’s incredibly fast, but maintains a high print quality, and it comes with a large range of connectivity options to work as a fax, including USB and network. As a fax machine, it offers 33.6Kbps speeds, as well as fax forwarding, automatic redialling and group dialling features.
    [IMG alt=“Image credit: Brother”]https://cdn.mos.cms.futurecdn.net/Eh...MPG9oBZi88.jpg
    [HEADING=2]4. Brother FAX-2940[/HEADING]
    The best dedicated fax machine
    Print speed: 20ppm | Fax resolution: 1,200 x 1,200 | Paper capacity: 250 sheets | Dimensions: 360 x 368 x 311mm (Width x Depth x Height) | Weight: 8.8kg
    Dedicated fax machine
    Can be turned into an all-in-one
    Limited non-fax functions
    Dated looks
    If you’re only looking for a fax machine, then you don’t want to spend extra money on an all-in-one printer that will offer you features you’ll not use. If you just want a fax machine, then the Brother FAX-2940 is the best dedicated fax machine money can buy. As primarily a fax machine, it offers plenty of great features including 200 speed dials and up to 500 pages of transmit/receive memory, which means you won’t miss out on any faxes if the Brother FAX-2940 runs out of paper. You can also download a free printer and scanner software update that turns it into a multi-function device.
    [IMG alt=“Image credit: Samsung”]https://cdn.mos.cms.futurecdn.net/fJ...2sDsqZJLbK.jpg
    [HEADING=2]5. Samsung SF-760P[/HEADING]
    A great easy-to-use old school fax machine
    Print speed: 20ppm | Fax resolution: 300dpi | Paper capacity: 250 sheets | Dimensions: 280 x 426 x 260mm (Width x Depth x Height) | Weight: 6.3kg
    Easy to use
    Dated looks
    Not Wi-Fi
    If you’re looking for a dedicated fax machine and don’t mind (or even prefer) a rather old school design, then the Samsung SF-760P could be the best fax machine for you. It’s got a no-nonsense design that sums up what we like about this fax machine so much. It’s dedicated to sending and receiving faxes, and that focus means it excels at its job, offering plenty of features and a decent 33.6kbps fax transmission speed. It can also be used as a printer and scanner, but we’d recommend only using this for faxes.
    [li]We’ve featured the best office equipment: scanners, shredders, copiers, projectors, and even office chairs.[/li][/ul]
