Best wireless keyboards: fast and reliable wireless keyboards for productivity and gaming
    • 54687
    Round out your wireless rig with the best wireless keyboards. If you still find yourself spending hours detangling cables every few months or so, it’s time to chuck them for good. Or at least just minimize their number by investing in wireless peripherals.
    Just like the best wireless mice, the best wireless keyboards have evolved quite spectacularly. Gone are the days when you have to contend with faulty or unreliable connectivity, keypress latency, and a short wireless range. Thanks to vast improvements in Bluetooth connectivity and USB wireless adapters, these wireless peripherals are just as responsive and accurate as the best wired keyboards.
    Only, they bring in new advantages to the table like impressive range and long battery life. Some of the gaming ones are even brilliant enough to offer customizable RGB lighting without it being much of a drain on battery life.
    Live untethered (to your desk) and cable-free whether you’re all about gaming or attached to your job. The best wireless keyboards below are, in many ways, loads better than their wired counterparts.
    [IMG alt=“Cherry Stream Desktop”]https://cdn.mos.cms.futurecdn.net/tj...vdqpRfctEN.jpg
    (Image credit: Cherry)
    [HEADING=2]1. Cherry Stream Desktop[/HEADING]
    Best all-rounder wireless keyboard
    Connectivity: USB wireless | Switches: Cherry SX scissor | Backlighting: No
    Affordable
    Painfree setup
    Not the best looking
    Choosing the best peripherals isn’t just about finding the best looking one. The Cherry Stream Desktop is proof of this, and while it might look like it time-traveled from the Aughts or the late 90s, this wireless keyboard is the most compelling choice out there overall.
    Extremely affordable, comfortable to use, and easy to set up, this keyboard from Cherry is a pleasure to type on because of its incredibly responsive performance and satisfying tactile feedback. It’s a bit sparse on special features, but it also makes up for that with the wireless mouse it comes bundled with. Both utilize one USB wireless receiver, which means you’re not only saving money, you’re also hitting two birds with one single port.
    Read the full review: Cherry Stream Desktop
    [IMG alt=“Razer BlackWidow V3 Pro”]https://cdn.mos.cms.futurecdn.net/Qo...sbp6tEfXPR.jpg
    (Image credit: Razer)
    [HEADING=2]2. Razer BlackWidow V3 Pro[/HEADING]
    Best premium wireless keyboard
    Connectivity: USB wireless, 3 x Bluetooth | Switches: Razer Green or Yellow Switch | Backlighting: Yes
    Built like a tank
    Best for gaming
    Not the cheapest
    By premium, we don’t just mean its price. Where do we even begin? The Razer BlackWidow V3 Pro comes with all the premium trimmings, from its build and impressive switches down to its multiple connectivity options, low latency connection, and deliciously plush wrist rest.
    In other words, there’s much to love here to justify that admittedly higher price tag. Breaking its wireless feature and performance down, however, there are three modes of connection here: Razer HyperSpeed wireless, Bluetooth, and USB-C cable (if you’re in the mood to be old school). That’s not all; it also lets you pair up to three devices via Bluetooth, which means it can connect to up to five devices at the same time - a major boon to multitaskers. What’s even more impressive is that both Bluetooth and USB wireless connectivities are equally reliable in range and responsiveness. You can have your computer in one room and be typing in another, and you won’t notice the difference between these and a wired connection.
    [IMG alt=“Logitech K380”]https://cdn.mos.cms.futurecdn.net/TQ...WS4fei7SZN.jpg
    (Image credit: Logitech)
    [HEADING=2]3. Logitech K380 Multi-Device Bluetooth Keyboard[/HEADING]
    Best budget wireless keyboard
    Connectivity: 3 x Bluetooth | Switches: Unspecified | Backlighting: No
    Under $50
    Travel-friendly
    Not rechargeable
    We’ve been using the Logitech K380 as our go-to work keyboard for months now, and we can honestly say that it’s one of the best keyboards out there for writers, digital nomads, and folks who spend most of their time pounding away. But, even if you’re not always typing on your computer, the fact that it’s very cheaply priced for what it offers also makes it a fantastic choice for you.
    Adding to its value, it also comes with features like multi-device connectivity (specifically, up to three) and multi-platform compatibility. You can even toggle from one device to another with just a press of a button for the ultimate productivity if you’re multitasking. That’s without mentioning its super sleek and portable form factor, which makes it not just travel-ready, but also travel-friendly. We only wish Logitech made it rechargeable, but with a 24-month battery life, this missing piece is hardly a deal-breaker.
    [IMG alt=“Logitech G915”]https://cdn.mos.cms.futurecdn.net/hr...S5EwFzrcPN.jpg
    [HEADING=2]4. Logitech G915 TKL Lightspeed[/HEADING]
    Best TKL wireless keyboard
    Connectivity: USB wireless, Bluetooth | Switches: GL Clicky, GL Tactile, GL Linear | Backlighting: Yes
    Low profile
    Satisfying presses despite shorter travel distance
    Pricey
    Logitech G’s G915 TKL Lightspeed keyboard is one of the best looking keyboards we’ve ever used, touting a sleek and incredibly slim deck and even thinner floating keys. That’s without mentioning its cool volume wheel and unique round keys for connectivity and media controls.
    It doesn’t just go by looks alone, however. Its performance and feature set are just as impressive, rocking an actuation distance of 1.5 mm, long wireless range, and low latency. Rounding those off are its onboard memory that lets you save two lighting and three macro profiles, a battery life rating of 40 hours when its RGB is at 100% brightness, and its Game Mode button that disables the Windows key. And, while it’s compact, it doesn’t completely abandon its special and arrow keys. In other words, what you’ve got here is a wireless keyboard that’s just as great for productivity as it is for gaming, whether you’re on-the-go or at your desk.
    [IMG alt=“Razer BlackWidow V3 Mini”]https://cdn.mos.cms.futurecdn.net/8L...QgSGMhh9rN.jpg
    [HEADING=2]5. Razer BlackWidow V3 Mini Hyperspeed[/HEADING]
    Best wireless mini keyboard
    Breathtakingly responsive
    Feature-rich
    Pricier than competing mini keyboards
    There are quite a few impressive mini keyboards that recently hit the shelves, but only a handful deliver wireless connectivity and fewer still do so impressively. If we were to list the best mini keyboards with wireless connectivity, then the Razer BlackWidow V3 Mini Hyperspeed would be sitting at the very top.
    Despite its size, this new release from Razer more than punches above its weight, touting an incredibly robust build, vibrant RGB lighting, and satisfying tactile feedback. Go with Razer’s yellow switches, and you’ll also get a quieter typing experience without sacrificing your comfort. But, what’s truly impressive about this wireless keyboard is its connectivity. Offering both USB wireless and Bluetooth connections, it not only boasts an impressively long wireless range, but also zero discernable latency (much like its full-sized brother, the BlackWidow V3 Pro). That’s even when you’re in one room with the keyboard and the computer it’s connected to is in another. That’s already impressive in its own right, but given the competition, that’s really saying something.
    Read the full review: Razer BlackWidow V3 Mini Hyperspeed
    [IMG alt=“Apple Magic Keyboard”]https://cdn.mos.cms.futurecdn.net/hr...jATwVzh5xL.jpg
    (Image credit: Apple)
    [HEADING=2]6. Apple Magic Keyboard[/HEADING]
    Best wireless keyboard for Mac
    Connectivity: Bluetooth | Switches: Apple’s Scissor Switch | Backlighting: Yes
    Amazing tactile feedback
    Thin and portable
    Not for Windows
    Who are we kidding? The best wireless keyboard for Apple’s Macs and MacBooks is the actual wireless keyboard Apple specifically designed for them. Now touting the company’s scissor switches, the Magic Keyboard is aptly named, as the experience of typing on it may be bordering a magical experience.
    It’s true there’s not really a lot of features here. Very much an Apple product, this one focuses more on form and function, and not as much on features. There’s still much to love, however. It pairs incredibly easily with an Apple computer, and it’s among the thinnest and most compact keyboards we’ve ever had the pleasure of using. And, if you plan on investing in the new iMac 24-inch, you can even get it in the same shade (of which there are six on top of the usual silver). Unfortunately, you can only get these colors if you purchase the matching AIO, but here’s to hoping Apple will make them available for individual purchase.
    [li]These are the best keyboards[/li][/ul]
